Yves, Nope : "Sphinx was not installed, make sure sphinx-build is in your system path." Any more clue ? Thanks, Alexandre Yves Moisan wrote: > Go to the "Documentation" tab and you should see "Build" just below the > "General" tab. Does that work ? > > Yves > -- Alexandre Dubé Mapgears www.mapgears.com
