[Geoprisma-dev] Project management / Pointers for potential contributors (doc)
Daniel Morissette dmorissette at mapgears.com
Mon Nov 23 14:07:09 EST 2009
Yves Moisan wrote:
> Right.  So that means either to have a ticket created first then that
> ticket url is used in the commit message or, if the change is not worth
> opening up a ticket, make sure the commit comments are verbose enough.
BTW, no need for the full URL in the SVN log message. With Trac/SVN
integration, you can just put "#123" in the SVN log message and that
will automatically link to the ticket number when you look at the change
log in Trac.
You can also use the notation "r1234" to refer to a SVN revision number
in a Trac ticket comment (or in Trac wiki) and that will automatically
link to the changeset (svn diff) when you click the link.
Here is an example of this notation in action, a ticket referring to a
changeset (look for r9388 in the last comment):
http://trac.osgeo.org/mapserver/ticket/3129#comment:2
And the corresponding changeset refers back to the ticket in its change
comment (look for #3129):
http://trac.osgeo.org/mapserver/changeset/9388
Daniel
Daniel Morissette
http://www.mapgears.com/
More information about the Geoprisma-dev mailing list
