[Geoprisma-dev] Project management / Pointers for potential
contributors (doc)
Yves Moisan
yves.moisan at boreal-is.com
Mon Nov 23 14:27:12 EST 2009
I didn't lnow the integration between SVN and Trac went that far.
Thanx.
Yves
> Yves Moisan wrote:
> > Right. So that means either to have a ticket created first then that
> > ticket url is used in the commit message or, if the change is not worth
> > opening up a ticket, make sure the commit comments are verbose enough.
> BTW, no need for the full URL in the SVN log message. With Trac/SVN
> integration, you can just put "#123" in the SVN log message and that
> will automatically link to the ticket number when you look at the change
> log in Trac.
> You can also use the notation "r1234" to refer to a SVN revision number
> in a Trac ticket comment (or in Trac wiki) and that will automatically
> link to the changeset (svn diff) when you click the link.
> Here is an example of this notation in action, a ticket referring to a
> changeset (look for r9388 in the last comment):
> http://trac.osgeo.org/mapserver/ticket/3129#comment:2
> And the corresponding changeset refers back to the ticket in its change
> comment (look for #3129):
> http://trac.osgeo.org/mapserver/changeset/9388
> Daniel
More information about the Geoprisma-dev
