Yves Moisan wrote: > If that works, you're good to go > > your-machine: .../geoprisma/trunk/docs$ sphinx-build -b html > source/ ../dist/build/ > > Yves > That works (runs), but I still got no "widget" nor "samples" doc... -- Alexandre Dubé Mapgears www.mapgears.com
