[Geoprisma-dev] Where do we build the widget doc ?
Alexandre Dube adube at mapgears.com
Mon Nov 23 15:02:41 EST 2009
Yves Moisan wrote:
> If that works, you're good to go
> your-machine: .../geoprisma/trunk/docs$ sphinx-build -b html
> source/ ../dist/build/
> Yves
I think I found why it doesn't work :
When I type "sphinx-build 2>&1" in a shell, it finds the Sphinx version,
but I use FGS (which has its own environment)... When setting the FGS
environment and typing the command again, I get the error...
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev mailing list
