[Geoprisma-dev] Proposed change in workspaces
Alexandre Dube
adube at mapgears.com
Thu Nov 26 09:13:46 EST 2009
Yves,
How about :
<workspace>
<name>MyWorkspace_3</name>
<layout>MyLayout_1</layout>
<maps>
<map>
<name>MyMapWidget_1</name>
<options></options>
<resources>
<resource>
<name>R_MY_RESOURCE</name>
<widgets>
<widget>MyMapFishLayerTreeWidget</widget>
<widget>MyGeoExtToolbarWidget</widget>
A workspace always has one layout, but could have many maps. Each map
is refered to the "map" widget, it options could be redefined in
<options>. To it is attached all the resources we want with all their
widgets, including the MapFishLayerTree (that is a widget also anyway so
it doesn't need to be treated differently).
The <map> node is our 'core' node in this structure. That's already the
case in all printWidgetExecution xsl:templates, where we use <pMapName>
everywhere to get the map object linked to the widget.
What do you think ?
Alexandre
Yves Moisan wrote:
> Hi All,
> I found out today that for one installation we have I need to specify a
> different map object within the same configuration file. The topic was
> raised a few times on the list before, but now I need to get something
> working, so here's what we set out to do. I'm checking base with the
> list now even though there are some bits that don't quite work yet, but
> everything should be ok tomorrow.
> In a nutshell, here's what the proposed changes bring about :
> - multiple map objects; referenced by name in the workspace;
> - multiple mapfishlayertrees; referenced by name in the workspace;
> - multiple layout objects; referenced by name in the workspace;
> What this means in the config is the following :
> <workspace>
> <name>workspace3</name>
> <layout>workspacelayout</layout>
> <map>DefaultMap2</map>
> <mapfishlayertree>LegendDemo2</mapfishlayertree>
> <resources>
> <resource>
> <name>ResourceVMap0</name>
> <widgets>
> <!--widget>LegendDemo2</widget-->
> So the mapfishlayertree that used to be included as a widget of one of
> the resources now gets included as a workspace object. A layout and a
> map also become "root" workspace objects allowing to use maps with
> different projections, extent, etc and new layouts in the same
> configuration file. For us, and I suspect for many GeoPrisma users,
> this would make GP much more agile, although potentially a bit complex
> as far as configuration is concerned.
> Two issues we found :
> 1) the map object has to be force renamed "DefaultMap";
> 2) a mapfishlayertree and a map object must correspond, but I think
> that's a fair assumption
> I'm working on the XMLWorkspaceConfig sample at
> http://geoprisma.org/samples/workspace/select_workspace.php. I would
> soon update it with a third workspace allowing for a different map,
> layertree and template (layout) if people thought this is a good idea.
> Comments welcome.
> Yves
> Geoprisma-dev mailing list
> Geoprisma-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geoprisma-dev
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev
