[Geoprisma-dev] Legend Panel - Scrollbar
Julien-Samuel Lacroix
jlacroix at mapgears.com
Thu Nov 26 16:35:18 EST 2009
I would have think that the scrollbar would be automatically there. It
may be because you put the Panel inside another Panel...
Does that help?
http://www.extjs.com/forum/showthread.php?t=42912
http://www.yui-ext.com/forum/showthread.php?t=56199
Julien
louis.rocheleau wrote:
> Hello again,
> I have configured a Legend Panel for the layers on a GP map. It goes all
> fine using the Sample1 example. My only concern is when you reach a certain
> number of elements in the Legend Panel, you can't see all the information,
> as there is no scroll bar. Is there any development on having such a tool ?
> I am not sure but would the layer tree act the same if too many layers were
> defined ?
> Thanks
> Louis
Mapgears
http://www.mapgears.com/
More information about the Geoprisma-dev
