[Geoprisma-dev] Legend Panel - Scrollbar
louis.rocheleau
louis.rocheleau at boreal-is.com
Fri Nov 27 02:31:37 EST 2009
Hi Jean-Samuel,
actually I do not develop GP, I am a user of it. I copied the legend panel
from Sample1, as Yves recommended to me. I then realized that when I load
many layers, the scrollbar does not come. Did you test to see if the
scrollbar is coming when you put many layers ?
Also, you mention that "it may be because [I] put the Panel inside another
Panel...", is there another way to display a legend ?
Regards
Louis
Boréalis
Julien-Samuel Lacroix wrote:
> Hi,
> I would have think that the scrollbar would be automatically there. It
> may be because you put the Panel inside another Panel...
> Does that help?
> http://www.extjs.com/forum/showthread.php?t=42912
> http://www.yui-ext.com/forum/showthread.php?t=56199
> Julien
> louis.rocheleau wrote:
>> Hello again,
>> I have configured a Legend Panel for the layers on a GP map. It goes all
>> fine using the Sample1 example. My only concern is when you reach a
>> certain
>> number of elements in the Legend Panel, you can't see all the
>> information,
>> as there is no scroll bar. Is there any development on having such a tool
>> I am not sure but would the layer tree act the same if too many layers
>> were
>> defined ?
>> Thanks
>> Louis
> Mapgears
> http://www.mapgears.com/
> Geoprisma-dev mailing list
> Geoprisma-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geoprisma-dev
View this message in context: http://n3.nabble.com/Legend-Panel-Scrollbar-tp41268p41797.html
Sent from the GeoPrisma-dev mailing list archive at Nabble.com.
More information about the Geoprisma-dev
