[Geoprisma-dev] Tutorial - How to create a GeoPrisma project
Yves Moisan
yves.moisan at boreal-is.com
Mon Nov 30 16:29:52 EST 2009
Stephen,
Please forgive a quick top-post, but I wanted to thank you for hanging
on there as a dedicated docs/code commenter and also to let you know
we're still brewing some ideas to ease the creation of maps by an order
of magnitude or so we hope! However, expect another change in the docs,
for the better (and hopefully I'll then do my share of docs; me ducks).
Yves
> Yves Moisan wrote:
> > L
> >> Given enough time and money, then sure, we should add a set of more
> >> hands-on exercise to complement this more abstract tutorial. The
> >> MapServer tutorial is a good example of what we could aim for:
> >> http://biometry.gis.umn.edu/tutorial/sections.html
> >> However, until the resources are available to produce this level of docs
> >> I consider that what you've got is a great start.
> >> Thanks for you work on this Alexandre.
> > Agreed ! Thanx for doing that work.
> Since I raised the question, I would like to give my thanks to Alexandre
> also. The Tutorial has improved significantly since I first looked at it.
> Since I'm new to GeoPrisma and this is my first time through the
> tutorial and the fact that I know a lot about the related technologies,
> I thought it might prove useful with regards to ways to improve the
> "newbie" experience with GeoPrisma. I'll continue to report issues and
> successes with the hope that they might prove useful to the team and/or
> users in the future that might be searching the archives.
> So, Alexandre, in case it was not obvious in my flood of issues to the
> list, you are doing a great job and I appreciate the tutorial and your
> support on and off the list.
> -Steve W
More information about the Geoprisma-dev
