[Geoprisma-dev] The image cannot be displayed
Yves Moisan yves.moisan at boreal-is.com
Thu Feb 4 11:46:01 EST 2010
> Bonjour yves,
Hi Daniel,
> I have seen this error a few times before, but the last time was quite a
> while ago. If I remember correctly the "... cannot be displayed, because
> it contains errors" message is produced by Firefox itself because it
> receives a corrupt image from MapServer (or whatever the remote server is).
Right.  IE just shows an empty thumbnail.
> The image may be corrupt for a few reasons, either it is truncated
> (server crashed before returning the full image), or it contains some
> unexpected bytes in the binary data, most likely some error or debug
> message (caused by a poorly handled error situation in the server).
I have seen the situation once in a while in GeoPrisma.  Our current
focus is on the curl call done by the proxy.  There's probably something
in the call to MapServer that doesn't make MapServer happy.
> I
> think a "View Source" on the error page will reveal the contents of the
> data stream which should contain hints about the source of the problem.
> If you can't find it yourself, please send me a URL that produces this
> error and I'll have a look.
If I find a public facing url that does it, I'll send it to the list.  I
encountered the error with MetaCarta's VMAP0, which is known to work
quite well in all the GeoPrisma examples.
Thanx for helping
Yves
> Daniel
More information about the Geoprisma-dev mailing list
