[Geoprisma-dev] Highlight on shortcut
Yves Moisan
yves.moisan at boreal-is.com
Mon Feb 22 14:55:46 EST 2010
Hi Folks,
r798 closes a first pass on feature highlighting. With that commit, the
ShortCut widget behaves like the InitialView : if an existing vector
(featureserver) layer exists, it uses that for highlighting, else it
creates a temporary one. The way it's implemented is a bit different
than in InitialView so maybe we'll be due for some code refactoring
soon. Also, I'm pretty sure we could do better than create/destroy the
temps layer on evert zoomTo event triggered by the ShortCut.
Like for the InitialView, highlighting is optional (in the ShortCut
options in the configuration file). I changed the 3 config.xml files
for the ShortCut examples to include highlighting. Also : the
unhighlight (or temp vector layer destruction) is triggered on click now
rather than on moveend both for ShortCut and InitialView. This allows
users to zoom in/out and still see the feature highlighted. I thought
pan would work too, but it seems the mouse drag ends up as a click so
panning unhighlights features.
Cheers,
Yves
More information about the Geoprisma-dev
