[Geoprisma-dev] InitialView issue
Yves Moisan
yves.moisan at boreal-is.com
Tue May 4 16:44:41 EDT 2010
Hi All,
It's been a while since there was life on this channel ! I've come
across an issue today with InitialView for the case of 'no FeatureServer
layer'. In that case, a temporary vector layer with a feature (a red
cross only modifiable in the xslt for now) is created. Without noticing
(and also because I didn't care to make real tests ...) I found out
today that a cross only works for point geometries :
Indeed,
new
OpenLayers.Geometry.Point(GeoPrisma.Widget.InitialView.oFeatures[0].geometry.x,GeoPrisma.Widget.InitialView.oFeatures[0].geometry.y)
will generate x = y = NaN for anything but points, obviously.
Hardcoding for a polygon with :
new
OpenLayers.Geometry.Point(GeoPrisma.Widget.InitialView.oFeatures[0].geometry.getCentroid().x,GeoPrisma.Widget.InitialView.oFeatures[0].geometry.getCentroid().y)
works for the case of polygons (only?).
Does anyone have an example of conditional code I could use to check
geometry type ? More importantly, I'd like to get all possible code
options as a function of geometry type, that is get x and y for a point
and whatever function returns a point as a function of geometry.
There's gotta be some generic geometry checking code somewhere.
TIA,
Yves
More information about the Geoprisma-dev
