[Geoprisma-dev] InitialView issue
Alexandre Dube
adube at mapgears.com
Wed May 5 08:24:19 EDT 2010
Yves,
All geometry objects have the 'getBounds' property so you could use it
regardless of the geometry type, then use 'getCenterLonLat' of the
returned Bounds object to get the center to create your point feature from.
Alexandre
Yves Moisan wrote:
> Does anyone have an example of conditional code I could use to check
> geometry type ? More importantly, I'd like to get all possible code
> options as a function of geometry type, that is get x and y for a
> point and whatever function returns a point as a function of
> geometry. There's gotta be some generic geometry checking code
> somewhere.
> TIA,
> Yves
> Geoprisma-dev mailing list
> Geoprisma-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geoprisma-dev
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev
