[Geoprisma-dev] InitialView issue
Alexandre Dube
adube at mapgears.com
Fri May 7 11:39:11 EDT 2010
Yves,
Were you able to fix the issue ?
Alexandre
Alexandre Dube wrote:
> Yves,
> All geometry objects have the 'getBounds' property so you could use
> it regardless of the geometry type, then use 'getCenterLonLat' of the
> returned Bounds object to get the center to create your point feature
> from.
> Alexandre
> Yves Moisan wrote:
>> Does anyone have an example of conditional code I could use to check
>> geometry type ? More importantly, I'd like to get all possible code
>> options as a function of geometry type, that is get x and y for a
>> point and whatever function returns a point as a function of
>> geometry. There's gotta be some generic geometry checking code
>> somewhere.
>> TIA,
>> Yves
>> Geoprisma-dev mailing list
>> Geoprisma-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geoprisma-dev
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev
