[Geoprisma-dev] InitialView issue
Yves Moisan yves.moisan at boreal-is.com
Tue May 11 14:25:51 EDT 2010
Le 2010-05-05 08:24, Alexandre Dube a écrit :
> Yves,
>  All geometry objects have the 'getBounds' property so you could use
> it regardless of the geometry type, then use 'getCenterLonLat' of the
> returned Bounds object to get the center to create your point feature
> from.
Hi Alexandre,
Thanx for the pointer.  I tested on the GP InitialView example
(http://localhost:8081/gp/samples/initialview/index.php?workspace=wms2&id=302)
and what I thought would apply only to polygons ends up applying to
points as well.  As it turns out, geometry.point has a getCentroid
function.  geometry.polygon does not, but it inherits from linearRing
and that has a getCentroid.  I haven't tested with a geometry.linestring
but I went up the dependeny stack and geometry.collection implements a
getCentroid, so my guess is that it works for lines too.  I'll commit
what I have now.  I'll add a linestring example later.
Thanx (and sorry for the late answer!),
Yves
More information about the Geoprisma-dev mailing list
