[Geoprisma-dev] SVN problem with Ext JS lib
Alexandre Dube
adube at mapgears.com
Fri Oct 15 08:20:41 EDT 2010
On 10-10-14 05:44 PM, Yves Moisan wrote:
> The Ext source at
> http://trac.geoext.org/browser/ext/3.2.1/docs/source shows only
> Menu.html. I was thinking there would be an svn:externals in
> trunk/lib pointing to Ext 3.2.1 but it's not the case. Was the Ext
> code checked out on a *NIX box then commited back into GP's SVN ?
> Maybe we could try removing Ext-3.2.1 and using an externals instead ?
We could do that. It wouldn't need to be an external though. We could
download the ext 3.2.1 from geoext repository then remove all .svn
folders from it and replace the one in ./lib by this new one.
But moving it to svn could do the trick too.
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev
