[Geoprisma-dev] MapExtent calculation issues ?
Alexandre Dube
adube at mapgears.com
Tue Oct 19 15:47:50 EDT 2010
I only saw that kind of problem while trying to print a WMS layer
poiting to a tilecache server (i.e. with tilecache service without the
'staticCache' option set). Are you able to reproduce the problem with
one of the samples ? Have you tried with the 'staticCache' option
(don't forget to point to the cache url if you want to try this) ?
Regards,
Alexandre
On 10-10-19 03:19 PM, Yves Moisan wrote:
> Hi All,
> We have a very intriguing issue pointing to geoprisma-r914 (from
> r805). All TileCached layers stop working with "a tile corner too far
> ..." error and when repointing back to the old (r805) libraries
> everything is fine. I don't have much detail on the issue but my
> suspicion is that something changed, probably in OL, so that now
> extents aren't quite calculated the same way. Version differences are :
> r805 r914
> ol-r10165 ol-r10848
> mf-r3433 mf-r3639
> geoext-r2073 geoext-r2465
> We also changed from Ext 3.1.2 to 3.2.1
> I was wondering whether any of you knew of any specific change in OL
> or elsewhere that may have someting to bear with what we are seing.
> TIA,
> Yves
> Geoprisma-dev mailing list
> Geoprisma-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geoprisma-dev
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-dev
