[Geoprisma-dev] Attribute filtering
Etienne Dube
etienne.dube at boreal-is.com
Fri Oct 29 15:11:43 EDT 2010
Hi guys,
We have a new requirement in one of our projects, that involves
attribute filtering on a vector layer. What's needed is a widget that
allows the user to filter the features to be displayed by specifying an
attribute, an operator and a comparison value. One or more of these
criteria could be combined using logical operators (AND/OR) to create
more complex queries; eventually multiple filtering expressions could be
combined by forming a tree of conditions, similar to what the OGC Filter
Encoding standard describes. Such a feature has already been discussed
previously (see ticket http://trac.osgeo.org/geoprisma/ticket/38).
I spent some time defining the problem and exploring what tools could be
used to solve it. A few thoughts:
- We could offer two different modes for this widget:
1. A preconfigured mode, in which the choices of attributes (and
possibly operators) to filter on, along with the logical operators used
to combine these criteria, would be defined in the widget's
configuration. Different preconfigured query templates could be defined
in this way, for every layer the widget applies to. The user would only
have to fill in the values to filter on.
2. An "expression builder" mode. In this case, the choice of
attributes, operators and any logical combination (AND/OR) or criteria
would be left to the user, and a GUI panel would be provided to build
these expressions. This mode mostly targets GIS specialists and other
power users who have an understanding of boolean logic, in order to
fulfill various free-form querying needs.
- Initially we could provide support for vector layers only. OpenLayers
already provides the OpenLayers.Filter classes to build the filtering
expressions, and is able to do filtering on the client side. However,
since it's not a particularly efficient way of doing things, a way to
pass the filter expression to the service would be desirable. As Yves
mentioned in ticket #38, FeatureServer offers basic attribute filters as
criteria passed in key/value pairs in a GET request, but this support is
quite limited: it seems that only 1 criteria per attribute is accepted,
there's no way to combine multiple criteria using AND/OR operators (AND
is the default when specifying a filter for more than 1 attribute) and
only the PostGIS data source is supported for attribute filters. Short
of extending FS and its protocol, a solution could be to add a WFS proxy
and pass a Filter Encoding expression in the request (as you may know,
OL already has the logic to generate an ogc:Filter element from
OpenLayers.Filter objects).
- Support for filtering WMS layers (issued from vector sources) would be
a good idea too. I believe it's possible by passing an ogc:Filter as
part of a SLD in the GetMap request.
- OpenGeo developed a QueryPanel widget (it's in their GXP repository)
that offers similar functionality; see
http://workshops.opengeo.org/geoext/more_ogc/app.html. I've not been
able to make it work yet, and from what I see it can only apply filters
on WFS and WMS layers. Nevertheless, this could be a good starting point.
- For the moment we can settle with text boxes for entering filter
values, but it would be interesting to offer other control types (date
picker, selection list). Another cool feature to have would be the
ability to populate such selection lists with domain values (e.g. coming
from a catalog table in the DB). However I'm not aware if any feature
service (be it FeatureServer, WFS or MapFish Server) can do that kind of
stuff, and I think it wouldn't be extremely elegant to have to establish
an off-the-band connection to the data source for retrieving those
domain value lists.
I think that the widget could be developed as a GeoExt ux first, since
it's usefulness goes beyond the scope of GeoPrisma. I'm writing here to
have some initial feedback, and I'm open to continue the discussion on
the GeoExt dev mailing list if you feel it would be more relevant there.
Ideas, suggestions and corrections are welcome.
Etienne
Etienne Dubé
Consultant / Développeur
Boréal Informations Stratégiques
101, Du Moulin, bureau 202-A
Magog (Québec)
J1X 4A1
Tel. : 514.313.5951 #1131
Courriel: etienne.dube at boreal-is.com
More information about the Geoprisma-dev
