[Geoprisma-users] Progress of sorts :)
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Dec 3 02:00:04 EST 2009
I am making progress of sorts.
http://imaptools.com:8080/project/myproj/
This is based on nearly 2500 line config.xml which is not complete yet.
Since the bulk of the file is generated from a perl script, it is pretty
easy to make changes to and regenerate.
When you move a sample out of the release directory structure and move
it into the tutorial directory structure lots of things break break
because of path issues.
Questions:
1) how do I debug the map requests going through the proxy.php
2) I'm down to one JS error, but not sure why I get this:
handler is not a constructor
this.handler = new handler(this, this.callbacks,
this.handlerOptions);\r\nDrawFeature.js (line 95)
http://imaptools.com:8080/project/lib/openlayers-r9843/lib/OpenLayers/Control/DrawFeature.js
Line 95
3) I also tried to add the GYMO errors, but that caused a bunch of other
errors so they are gone until I get this much working.
Any help would be appreciated,
-Steve W
More information about the Geoprisma-users
