[Geoprisma-users] New Widgets Ideas
Yves Moisan
yves.moisan at boreal-is.com
Fri Dec 4 08:36:19 EST 2009
> Like the dev needs more work ;)
Hi Stephen,
You've noticed we can't quite give you the support you need and that is
because we're swamped ;-).
> But a couple of widgets I would to have are:
I hope to be able to answer some of your points soon, but regarding
widget suggestion maybe you could fill in some points in Trac ?
> 1) initialView widget that x,y,zoom and positions the map to that
> location and zoom on initial load. You should also be able to pass the
> x,y,zoom on the url.
There is such a widget. Look in the API docs (Natural docs) further
down in the general documentation page. It does just what you want. The
complex_workspace widget uses an initialview using "dumpingid" as an
attribute to zoom in on. Except it relies on featureserver.
> 2) A permalink widget that might extend the initalView widget with a
> list of layers on/off. I would be nice if it could be placed in the
> geoexttoolbar or a separate div somewhere.
> I'm starting to get a handle on this stuff, but there are a lot of
> pieces and it is not obvious how it all fits together.
Hopefully, the next iterations will produce simpler code while allowing
more complex things done.
Cheers,
Yves
More information about the Geoprisma-users
