[Geoprisma-users] Auto hiding of vector layers if no
	edit	permissions?
    Alexandre Dube
    adube at mapgears.com
    Mon Dec 21 08:26:42 EST 2009
Steve,
  You're right.  WFS/Vector resources should be displayed as layers only
if a widget use them (like the edition widgets, as you mentioned).
That's currently in discussion, but it is a fact regardless and should
be added at some point.
  Please, fill a ticket for this and report it back here.
Regards,
Alexandre
Stephen Woodbridge wrote:
> Hi all,
> I am wondering what is the best approach to hiding WFS vector layers
> in the mapfish layertree and the application in general when the user
> only has read permissions.
> Permissions are tied to resources and a resource defines both WMS and
> WFS capabilities for a resource. If the user has "read" access then
> both are configured in the layertree which clutters the GUI if you
> have 10 layers defined that show up twice. It seems that there should
> be a way to say WFS is shown always or WFS is shown only if required
> by edit widget. This would be like adding a dependency to an object.
> This would allow WFS only resources to continue to be displayed if
> need because they did not have a WMS alternative, but would allow you
> to eliminate those that did have a WMS alternative.
> Thoughts?
> -Steve
> Geoprisma-users mailing list
> Geoprisma-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geoprisma-users
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-users
