[Geoprisma-users] Problems trying to get edit attributes in a panel
	instead of inwindow
    Stephen Woodbridge
    woodbri at swoodbridge.com
    Sun Dec 20 18:39:57 EST 2009
This is not critical and I know you said it was not tested.
I step up a test case to try this out and I get an error in ext-all.js
and the stack trace does not help me understand the issue.
http://imaptools.com:8080/project/myproj2/index2.php
http://imaptools.com:8080/project/myproj2/config2.xml
I set <inwindow>false</inwindow>
http://imaptools.com:8080/project/myproj2/xslt/default2.xslt
And added the following to the xslt template:
        <xsl:for-each select="/geoprisma/widgets/widget[./type =
'featurepanel_form']">
          <xsl:if test="./options/inwindow = 'false'">
          oWestPanel.items.push(
            <xsl:call-template name="featurepanel_form:drawWidget">
              <xsl:with-param name="pWidgetName" select="./name" />
            </xsl:call-template>);
          </xsl:if>
        </xsl:for-each>
And what I end up with is a lot of lines like:
  oWestPanel.items.push(objGPFeaturePanelForm_ONEMILEETJ);
  oWestPanel.items.push(objGPFeaturePanelForm_LAKES);
where these are all undefined:
So I'm probably missing something the outputs those definitions.
I also suspect the I probably want something more like the QuickZoomForm
where all of these objects get pushed onto an items[] array and then
that is pushed on the panel so there is only one tab with all the
featurepanel_form in it and the widget then makes the appropriate one
visible when it is used and populated with values.
If this is a bug let me know and I'll write it up with any additional
explanation you want me to add.
Thanks,
   -Steve
More information about the Geoprisma-users
