[Geoprisma-users] Problems trying to get edit attributes in a
panel instead of inwindow
Alexandre Dube
adube at mapgears.com
Mon Dec 21 08:47:17 EST 2009
Steve,
One quick problem I found :
in ./src/client/widgets/featurepanel/form/Form.xslt, at line 266,
replace :
objGP<xsl:value-of select="$pWidgetName" />
for
objGPWidget<xsl:value-of select="$pWidgetName" />
Either if this is enough for this to work or not, please fill a ticket.
A patch would be welcomed too.
About the 'drawWidget' method : yes, you can use a method like the
QuickZoom widget.
Regards,
Alexandre
Stephen Woodbridge wrote:
> This is not critical and I know you said it was not tested.
> I step up a test case to try this out and I get an error in ext-all.js
> and the stack trace does not help me understand the issue.
> http://imaptools.com:8080/project/myproj2/index2.php
> http://imaptools.com:8080/project/myproj2/config2.xml
> I set <inwindow>false</inwindow>
> http://imaptools.com:8080/project/myproj2/xslt/default2.xslt
> And added the following to the xslt template:
> <xsl:for-each select="/geoprisma/widgets/widget[./type =
> 'featurepanel_form']">
> <xsl:if test="./options/inwindow = 'false'">
> oWestPanel.items.push(
> <xsl:call-template name="featurepanel_form:drawWidget">
> <xsl:with-param name="pWidgetName" select="./name" />
> </xsl:call-template>);
> </xsl:if>
> </xsl:for-each>
> And what I end up with is a lot of lines like:
> oWestPanel.items.push(objGPFeaturePanelForm_ONEMILEETJ);
> oWestPanel.items.push(objGPFeaturePanelForm_LAKES);
> where these are all undefined:
> So I'm probably missing something the outputs those definitions.
> I also suspect the I probably want something more like the
> QuickZoomForm where all of these objects get pushed onto an items[]
> array and then that is pushed on the panel so there is only one tab
> with all the featurepanel_form in it and the widget then makes the
> appropriate one visible when it is used and populated with values.
> If this is a bug let me know and I'll write it up with any additional
> explanation you want me to add.
> Thanks,
> -Steve
> Geoprisma-users mailing list
> Geoprisma-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geoprisma-users
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-users
