[Geoprisma-users] MeasureTool
Yves Moisan yves.moisan at boreal-is.com
Mon Dec 21 09:31:01 EST 2009
>   I didn't check your config, but the MeasureTool widgets must be
> manually added to the toolbar and they must by added to a resource too
> (even thought it has nothing to do with the chosen resource).
One issue I had too was that you need to explicitly mention
<units>m</units> in your map options.  I suspect you've already done
that, but just in case.
HTH,
Yves
More information about the Geoprisma-users mailing list
