[Geoprisma-users] MeasureTool
Alexandre Dube adube at mapgears.com
Mon Dec 21 08:40:28 EST 2009
Steve,
  They're working on this demo :
http://dev4g.mapgears.com/geoprisma/demo/  Pick any user.
  I didn't check your config, but the MeasureTool widgets must be
manually added to the toolbar and they must by added to a resource too
(even thought it has nothing to do with the chosen resource).
Does the following config work for you ? (it's the one used in the demo)
<!-- WIDGETS -->
        <geoexttoolbar>
          <name>GeoExtToolbar</name>
          <options>
            <widgets>
              <widget>MeasureToolLength</widget>
              <widget>MeasureToolArea</widget>
            </widgets>
          </options>
        </geoexttoolbar>
        <measuretool>
            <name>MeasureToolLength</name>
            <options>
              <measuretype>Length</measuretype>
            </options>
        </measuretool>
        <measuretool>
            <name>MeasureToolArea</name>
            <options>
              <measuretype>Area</measuretype>
            </options>
        </measuretool>
<!-- RESOURCES -->
        <resource>
            <name>R_GMAP_BASE</name>
            <datastores>
                <datastore>DS_WMS_DEV4G_GMAP_BASE</datastore>
                <datastore>DS_TC_DEV4G_GMAP_BASE</datastore>
            </datastores>
            <widgets>
                <widget>GeoExtToolbar</widget>
            </widgets>
        </resource>
Regards,
Alexandre
Stephen Woodbridge wrote:
> Does MeasureTool work?
> Can someone add it to an existing or new sample?
> I tried to install it and on the good side I get no errors, on the
> other side I get no measure tools.
> Is graphicName option the path to an image for the toolbar? Or does
> the widget expect to find it as the basename for an image in the
> directory:
> .../widgets/geoexttoolbar/img/
> that are in the /mapfish/client/mfbase/mapfish/img/ svn or some nicer
> ones the match the create, update, delete icons in GeoPrisma.
> -Steve
> Geoprisma-users mailing list
> Geoprisma-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geoprisma-users
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-users mailing list
