[Geoprisma-users] Google key getting cached by smarty???
Yves Moisan yves.moisan at boreal-is.com
Fri Nov 13 13:24:13 EST 2009
Le vendredi 13 novembre 2009 à 12:00 -0500, Stephen Woodbridge a écrit :
> Hi,
> Still working with geoprisma-r699, will checkout trunk in a bit.
> I changed config/config-google.xml and config/config-one-geology.xml to
> have my google apikey, but when I load the following page it complains
> about the apikey and viewing the source does not have the correct apikey.
> http://imaptools.com:8080/gp/samples/google/default/
Yep.  The key is hardcoded in the template (xslt) file pointed to in the
<layout><file> tag.  So Smarty has nothing to do with that.  I need to
correct that.  Will report when done.
I guess we needed a little more testing before putting GP in the
wild ;-).
Thanx for reporting issues.
Yves
> Is smarty caching this somewhere that I need to cleanup. Or is this
> maybe related the the other path issue?
> -Steve
> Geoprisma-users mailing list
> Geoprisma-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geoprisma-users
More information about the Geoprisma-users mailing list
