[Geoprisma-users] More Sample Problems - using r702
Alexandre Dube
adube at mapgears.com
Fri Nov 13 15:34:28 EST 2009
I can confirm that problem as well locally.
Stephen, could you confirm that you don't have this kind of behavior
with trunk ?
Alexandre
Stephen Woodbridge wrote:
> Hi guys,
> I'm have gone through all the samples and the follow fail to load:
> http://imaptools.com:8080/gp/samples/borealis-authentication/
> http://imaptools.com:8080/gp/samples/helloworld/
> http://imaptools.com:8080/gp/samples/mapfishlayertree/
> failed to load external entity
> "/var/www/geoprisma-r702/src/client/templates/inc/Globals.xslt"
> and a lot more errors.
> http://imaptools.com:8080/gp/samples/merge_split/
> http://imaptools.com:8080/gp/samples/navtools/
> http://imaptools.com:8080/gp/samples/queryonclick/myownmarker/
> http://imaptools.com:8080/gp/samples/queryonclick/simple/
> http://imaptools.com:8080/gp/samples/quickzoom/
> http://imaptools.com:8080/gp/samples/sample0/
> loads with only "Droit insuffisant" message
> http://imaptools.com:8080/gp/samples/sample1/default/
> loads with Google apikey error, but does not show a google layer
> option.
> http://imaptools.com:8080/gp/samples/sample1/auth_xml/
> loads with Google apikey error, and then displays "Droit
> http://imaptools.com:8080/gp/samples/sandbox1/default/index.php
> http://imaptools.com:8080/gp/samples/shortcut/activateresources/
> http://imaptools.com:8080/gp/samples/shortcut/inpanel/
> http://imaptools.com:8080/gp/samples/shortcut/intoolbar/
> So it looks like there are probably three separate errors effecting
> the bulk of these:
> 1) is the Autoload.php path problem
> 2) is an xslt path problem
> 3) issues is the google apikey issue which seems to be cached
> somewhere or defined also in some other place that config/*.xml
> So it looks like these run:
> http://imaptools.com:8080/gp/samples/acl2/
> http://imaptools.com:8080/gp/samples/bdga/
> http://imaptools.com:8080/gp/samples/complex_workspace/
> http://imaptools.com:8080/gp/samples/google/ (with apikey issue)
> http://imaptools.com:8080/gp/samples/onegeology/default/ (with
> apikey issue)
> http://imaptools.com:8080/gp/samples/release/
> http://imaptools.com:8080/gp/samples/sampleLink/ ( but links might
> have issues)
> http://imaptools.com:8080/gp/samples/sampleObservable/
> http://imaptools.com:8080/gp/samples/workspace/
> Nothing critical from my point of view, but thought I could help with
> the little extrat testing.
> -Steve
> Geoprisma-users mailing list
> Geoprisma-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geoprisma-users
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-users
