[Geoprisma-users] More Sample Problems - using r702
Stephen Woodbridge woodbri at swoodbridge.com
Fri Nov 13 13:55:46 EST 2009
Hi guys,
I'm have gone through all the samples and the follow fail to load:
http://imaptools.com:8080/gp/samples/borealis-authentication/
http://imaptools.com:8080/gp/samples/helloworld/
http://imaptools.com:8080/gp/samples/mapfishlayertree/
   failed to load external entity
"/var/www/geoprisma-r702/src/client/templates/inc/Globals.xslt"
   and a lot more errors.
http://imaptools.com:8080/gp/samples/merge_split/
http://imaptools.com:8080/gp/samples/navtools/
http://imaptools.com:8080/gp/samples/queryonclick/myownmarker/
http://imaptools.com:8080/gp/samples/queryonclick/simple/
http://imaptools.com:8080/gp/samples/quickzoom/
http://imaptools.com:8080/gp/samples/sample0/
   loads with only "Droit insuffisant" message
http://imaptools.com:8080/gp/samples/sample1/default/
   loads with Google apikey error, but does not show a google layer option.
http://imaptools.com:8080/gp/samples/sample1/auth_xml/
   loads with Google apikey error, and then displays "Droit insuffisant"
message
http://imaptools.com:8080/gp/samples/sandbox1/default/index.php
http://imaptools.com:8080/gp/samples/shortcut/activateresources/
http://imaptools.com:8080/gp/samples/shortcut/inpanel/
http://imaptools.com:8080/gp/samples/shortcut/intoolbar/
So it looks like there are probably three separate errors effecting the
bulk of these:
1) is the Autoload.php path problem
2) is an xslt path problem
3) issues is the google apikey issue which seems to be cached somewhere
or defined also in some other place that config/*.xml
So it looks like these run:
http://imaptools.com:8080/gp/samples/acl2/
http://imaptools.com:8080/gp/samples/bdga/
http://imaptools.com:8080/gp/samples/complex_workspace/
http://imaptools.com:8080/gp/samples/google/  (with apikey issue)
http://imaptools.com:8080/gp/samples/onegeology/default/   (with apikey
issue)
http://imaptools.com:8080/gp/samples/release/
http://imaptools.com:8080/gp/samples/sampleLink/  ( but links might have
issues)
http://imaptools.com:8080/gp/samples/sampleObservable/
http://imaptools.com:8080/gp/samples/workspace/
Nothing critical from my point of view, but thought I could help with
the little extrat testing.
-Steve
More information about the Geoprisma-users mailing list
