[Geoprisma-users] QueryOnClick Configuration
Alexandre Dube
adube at mapgears.com
Thu Nov 26 08:52:01 EST 2009
I took a note about that.
Thanks,
Alexdnre
louis.rocheleau wrote:
> Philippe,
> this is it. Thanks !
> I think it may be a good idea to put some mapfile information into the
> widget documentation (in the case of a user with a mapfile)
> - "gml_include_items" "all" into the WEB section (under METADATA)
> - "gml_include_items" "all" into the LAYER section (under METADATA)
> - DUMP true into the LAYER section
> Cheers
> Louis
> Your problem seems to be on the mapfile side of things. For a layer to
> output GML on a query on click, you need to have the "DUMP true" line
> inside the LAYER object.
> Hope this helps.
> Philippe
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-users
