[Geoprisma-users] Does Geoprisma proxy works with generic WMS
client/server ?
Alexandre Dube
adube at mapgears.com
Tue Jun 21 13:17:39 EDT 2011
You could also change the onlineresource of your layer in order to
point to your proxy url (with the osmresource and osmservice parameters
set).
Regards,
Alexandre
On 11-06-21 12:39 PM, Julien-Samuel Lacroix wrote:
> Hi,
> The proxy currently does not play with the Capabilities. It should
> indeed modify the online resource and probably filter out the layer
> you don't have access to.
> You can look in the following file. That's where the call to the WMS
> server is done.
> geoprisma/src/server/core/org/geoprisma/proxy/wms/WMSProxy.php
> Patch welcome.
> Julien
> On 11-06-21 12:19 PM, Niccolo Rigacci wrote:
>> Hi to all,
>> I'm moving my first steps with Geoprisma; my goal is to use the
>> Geoprisma proxy to add ACL into a standard interaction between
>> WMS client/server (e.g. QGIS/QGIS-Mapserver).
>> I managed to setup the proxy so it responds to a GetCapabilities
>> query:
>> http://../proxy.php?osmservice=S_MYDEMO&osmresource[]=R_MYDEMO&username=admin&password=demo&SERVICE=WMS&REQUEST=GetCapabilities
>>> From the proxy I was expecting a different response upon the
>> original WMS GetCapabilities: at least the OnlineResource should
>> be changed, pointing to the proxy.php itself.
>> The GetCapabilities is passed unaltered instead.
>> Am I trying to force Geoprisma proxy beyond its intended use?
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Geoprisma-users
