[Geoprisma-users] Does Geoprisma proxy works with generic WMS
client/server ?
Niccolo Rigacci
niccolo at rigacci.org
Thu Jun 23 05:39:42 EDT 2011
On Tue, Jun 21, 2011 at 01:17:39PM -0400, Alexandre Dube wrote:
> You could also change the onlineresource of your layer in order to
> point to your proxy url (with the osmresource and osmservice
> parameters set).
First of all: thank you for getting the time to answer.
Unfortunately now I'm confused.
It seems that the Geoprisma WMS proxy does not alter the
GetCapabilities returned by the WMS service in any way.
The GetCapabilities returned by the proxy contains all the
layers, regardless the user having rights on them.
Also the OnlineResource xlink:href in the GetCapabilities (this
is from the on-line samples/borealisacl/) is:
<OnlineResource xlink:href="http://dev4g.mapgears.com?"/>
whereas I expect to see the proxy href:
http://geoprisma.org/samples/borealisacl/xml/proxy.php?....
This will breaks some WMS clients (e.g. QGIS), which will asks
the GetMap directly to the WMS service instead to the proxy.
I was not able to fix it fiddling with the config or with the
query parameters. I searched also the Geoprisma code, but it
seems to me that that functionalities are not implemented.
If I am right with this insight, is Geoprisma proxy intended to
support this features? Is there some code stub where I can to
start looking at?
Thank you again.
Niccolo Rigacci
Firenze - Italy
Tel. ufficio: 055-0118525
More information about the Geoprisma-users
