[Geoprisma-users] datastore vs resource
Steve.Toutant at inspq.qc.ca
Mon Dec 3 06:33:15 PST 2012
The confusion was that we only have wms service. So 1 datastore = 1
resource. We have more than 200 layers...
The concept of a resource seems to be unnecessary to us...for the moment.
thanks everyone for your help
Steve
Alexandre Dubé <adube at mapgears.com>@lists.osgeo.org
Envoyé par : geoprisma-users-bounces at lists.osgeo.org
2012-12-03 09:12
A
geoprisma-users at lists.osgeo.org
cc
Objet
Re: [Geoprisma-users] datastore vs resource
Steve,
If I may add: a DataStore is the equivalent of a mapfile layer, or a
layer in any service config. To retake Alexandre's example :
[DATA] is a 'hospital' table from PostGIS
[DATA] -> [MapServer WMS Service] -> served as a 'hospital' layer inside
a mapfile, which becomes the [Hospital WMS DataSource] in GeoPrisma
[DATA] -> [TinyOWS WFS Service] -> served as well as a 'hospital' layer
inside the config.xml, which becomes the [Hospital WFS DataSource] in
GeoPrisma
Those 2 DataSource point to the same data in the back-end. They are now
grouped as a single entity called 'Resource' in GeoPrisma. The
authorization to read/write this data is then linked to the Resource, not
the DataStore nor the Services. That way, a single 'Read access to the
Resource to a user' would allow all requests to the WMS service as well as
GetFeature requests to the WFS one.
HTH,
Regards,
Alexandre
On 12-11-30 02:48 PM, Lessard Alexandre wrote:
This part is a little difficulte I'll try my vest to explain.
A ressource is a group of datastores that represent all the part of the
data.
A data store is a part of the data linked to a service.
Exemple :
Say you want to show Hospitals on a map:
You'll have a ressource for the hospitals with those datastore for exemple
- DS_hospital_WFS that link to your WFS server with the layer of the
hospitals;
- DS_hospital_WMS that link to your WMS server;
- DS_hospital_HTTPRequest if you want to manage your data via http
forms;
- DS_hospital_Cache that will be linked to your MapCache server;
So a ressource is to define the content and the datastores are the way to
connect with it.
Check the samples with the source code, there is a lot of the configs that
are used there.
Belug
Le 2012-11-30 14:37, Steve.Toutant at inspq.qc.ca a écrit :
We are 3 here reading the doc and trying to understand the difference
between a datastore and a resource.
If someone could explain by an example it would be very appreciated
many thanks
steve
Steve Toutant, M. Sc.
Analyste en géomatique
Secteur environnement
Direction de la santé environnementale et de la toxicologie
Institut national de santé publique du Québec
Tél.: 418 646-6777 poste 30015
Téléc.: 418 644-4593
steve.toutant at inspq.qc.ca
http://www.inspq.qc.ca
http://www.monclimatmasante.qc.ca
Pour me rejoindre par courrier
Service de l'infrastructure et du réseau
Direction des technologies de l'information
Ministère de la Sécurité Publique
2525 boul. Laurier, 2è étage
Tour Laurentides
Québec, G1V 2L2
Geoprisma-users mailing list
Geoprisma-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/geoprisma-users
Alexandre Dubé
Mapgears
www.mapgears.com
URL: <http://lists.osgeo.org/pipermail/geoprisma-users/attachments/20121203/e35ebd6d/attachment.html>
More information about the Geoprisma-users
