[geos-commits] r2058 - trunk/source/headers/geos/noding
svn_geos at osgeo.org
Fri Dec 21 15:34:33 EST 2007
Author: benjubb
Date: 2007-12-21 15:34:32 -0500 (Fri, 21 Dec 2007)
New Revision: 2058
Added:
trunk/source/headers/geos/noding/FastSegmentSetIntersectionFinder.h
trunk/source/headers/geos/noding/MCIndexSegmentSetMutualIntersector.h
trunk/source/headers/geos/noding/NodableSegmentString.h
trunk/source/headers/geos/noding/NodedSegmentString.h
trunk/source/headers/geos/noding/SegmentIntersectionDetector.h
trunk/source/headers/geos/noding/SegmentSetMutualIntersector.h
trunk/source/headers/geos/noding/SegmentStringUtil.h
Added from JTS 1.9 to support prepared geometry
Added: trunk/source/headers/geos/noding/FastSegmentSetIntersectionFinder.h
--- trunk/source/headers/geos/noding/FastSegmentSetIntersectionFinder.h (rev 0)
+++ trunk/source/headers/geos/noding/FastSegmentSetIntersectionFinder.h 2007-12-21 20:34:32 UTC (rev 2058)
@@ -0,0 +1,72 @@
+ * $Id
+ * GEOS - Geometry Engine Open Source
+ * http://geos.refractions.net
+ * Copyright (C) 2006 Refractions Research Inc.
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+#ifndef GEOS_NODING_FASTSEGMENTSETINTERSECTIONFINDER_H
+#define GEOS_NODING_FASTSEGMENTSETINTERSECTIONFINDER_H
+#include <geos/noding/SegmentString.h>
+#include <geos/noding/MCIndexSegmentSetMutualIntersector.h>
+//forward declarations
+namespace geos {
+ namespace noding {
+ class SegmentIntersectionDetector;
+ class SegmentSetMutualIntersector;
+ //class MCIndexSegmentSetMutualIntersector : public SegmentSetMutualIntersector;
+namespace geos {
+namespace noding { // geos::noding
+class FastSegmentSetIntersectionFinder
+private:
+ MCIndexSegmentSetMutualIntersector * segSetMutInt;
+ geos::algorithm::LineIntersector * lineIntersector;
+protected:
+public:
+ FastSegmentSetIntersectionFinder( SegmentString::ConstVect * baseSegStrings);
+ ~FastSegmentSetIntersectionFinder();
+ * Gets the segment set intersector used by this class.
+ * This allows other uses of the same underlying indexed structure.
+ * @return the segment set intersector used
+ SegmentSetMutualIntersector * getSegmentSetIntersector()
+ return segSetMutInt;
+ bool intersects( SegmentString::ConstVect * segStrings);
+ bool intersects( SegmentString::ConstVect * segStrings, SegmentIntersectionDetector * intDetector);
+} // geos::noding
+} // geos
+#endif // GEOS_NODING_FASTSEGMENTSETINTERSECTIONFINDER_H
+ * $Log$
Property changes on: trunk/source/headers/geos/noding/FastSegmentSetIntersectionFinder.h
___________________________________________________________________
+ text/plain
+ Id
+ native
Added: trunk/source/headers/geos/noding/MCIndexSegmentSetMutualIntersector.h
--- trunk/source/headers/geos/noding/MCIndexSegmentSetMutualIntersector.h (rev 0)
+++ trunk/source/headers/geos/noding/MCIndexSegmentSetMutualIntersector.h 2007-12-21 20:34:32 UTC (rev 2058)
@@ -0,0 +1,113 @@
+ * $Id
+#ifndef GEOS_NODING_MCINDEXSEGMENTSETMUTUALINTERSECTOR_H
+#define GEOS_NODING_MCINDEXSEGMENTSETMUTUALINTERSECTOR_H
+#include <geos/noding/SegmentSetMutualIntersector.h> // inherited
+//#include <geos/noding/SegmentString.h>
+//#include <geos/noding/SegmentIntersector.h>
+//#include <geos/index/SpatialIndex.h>
+//#include <geos/index/strtree/STRtree.h> // for constructor
+//#include <geos/index/chain/MonotoneChain.h>
+#include <geos/index/chain/MonotoneChainOverlapAction.h> // inherited
+namespace geos {
+ namespace index {
+ class SpatialIndex;
+ namespace chain {
+ class MonotoneChain;
+ namespace strtree {
+ //class STRtree;
+ class SegmentString;
+ class SegmentIntersector;
+//using namespace geos::index::strtree;
+namespace geos {
+class MCIndexSegmentSetMutualIntersector : public SegmentSetMutualIntersector
+private:
+ std::vector<index::chain::MonotoneChain *> * monoChains;
+ * The {@link SpatialIndex} used should be something that supports
+ * envelope (range) queries efficiently (such as a {@link Quadtree}
+ * or {@link STRtree}.
+ index::SpatialIndex * index;
+ int indexCounter;
+ int processCounter;
+ // statistics
+ int nOverlaps;
+ void addToIndex( SegmentString * segStr);
+ void intersectChains();
+ void addToMonoChains( SegmentString * segStr);
+protected:
+public:
+ MCIndexSegmentSetMutualIntersector();
+ ~MCIndexSegmentSetMutualIntersector();
+ std::vector<index::chain::MonotoneChain *> * getMonotoneChains()
+ return monoChains;
+ index::SpatialIndex * getIndex()
+ return index;
+ void setBaseSegments( SegmentString::ConstVect * segStrings);
+ void process( SegmentString::ConstVect * segStrings);
+ class SegmentOverlapAction : public index::chain::MonotoneChainOverlapAction
+ private:
+ SegmentIntersector & si;
+ public:
+ SegmentOverlapAction( SegmentIntersector & si) : si(si)
+ void overlap( index::chain::MonotoneChain * mc1, int start1, index::chain::MonotoneChain * mc2, int start2);
+} // namespace geos::noding
+#endif // GEOS_NODING_MCINDEXSEGMENTSETMUTUALINTERSECTOR_H
+ * $Log$
Property changes on: trunk/source/headers/geos/noding/MCIndexSegmentSetMutualIntersector.h
+ text/plain
+ Id
+ native
Added: trunk/source/headers/geos/noding/NodableSegmentString.h
--- trunk/source/headers/geos/noding/NodableSegmentString.h (rev 0)
+++ trunk/source/headers/geos/noding/NodableSegmentString.h 2007-12-21 20:34:32 UTC (rev 2058)
@@ -0,0 +1,62 @@
+ * $Id
+#ifndef GEOS_NODING_NODABLESEGMENTSTRING_H
+#define GEOS_NODING_NODABLESEGMENTSTRING_H
+namespace geos {
+ namespace geom {
+ class Coordinate;
+namespace geos {
+ * An interface for classes which support adding nodes to
+ * a segment string.
+ * @author Martin Davis
+class NodableSegmentString : public SegmentString
+private:
+protected:
+public:
+ NodableSegmentString( geom::CoordinateSequence *newPts, const void* newContext)
+ : SegmentString( newPts, newContext )
+ * Adds an intersection node for a given point and segment to this segment string.
+ * @param intPt the location of the intersection
+ * @param segmentIndex the index of the segment containing the intersection
+ //virtual void addIntersection( const geom::Coordinate * intPt, int segmentIndex) =0;
+#endif // GEOS_NODING_NODABLESEGMENTSTRING_H
+ * $Log$
Property changes on: trunk/source/headers/geos/noding/NodableSegmentString.h
+ text/plain
+ Id
+ native
Added: trunk/source/headers/geos/noding/NodedSegmentString.h
--- trunk/source/headers/geos/noding/NodedSegmentString.h (rev 0)
+++ trunk/source/headers/geos/noding/NodedSegmentString.h 2007-12-21 20:34:32 UTC (rev 2058)
@@ -0,0 +1,101 @@
+ * $Id
+#ifndef GEOS_NODING_NODEDSEGMENTSTRING_H
+#define GEOS_NODING_NODEDSEGMENTSTRING_H
+#include <geos/algorithm/LineIntersector.h>
+#include <geos/noding/NodableSegmentString.h>
+#include <geos/noding/SegmentNode.h>
+#include <geos/noding/SegmentNodeList.h>
+//#include <geos/noding/Octant.h>
+#include <geos/geom/Coordinate.h>
+//using namespace
+namespace geos {
+class NodedSegmentString : public NodableSegmentString
+private:
+protected:
+public:
+ static void getNodedSubstrings( SegmentString::ConstVect * segStrings, SegmentString::NonConstVect * resultEdgelist)
+ for (size_t i=0, n=segStrings->size(); i<n; i++)
+ NodedSegmentString * nss = (NodedSegmentString *)((*segStrings)[i]);
+ nss->getNodeList().addSplitEdges( resultEdgelist);
+ * Creates a new segment string from a list of vertices.
+ * @param pts the vertices of the segment string
+ * @param data the user-defined data of this segment string (may be null)
+ NodedSegmentString( geom::CoordinateSequence *newPts, const void* newContext)
+ : NodableSegmentString( newPts, newContext )
+ ~NodedSegmentString()
+ * If an intersection already exists for this exact location, the existing
+ * node will be returned.
+ * @return the intersection node for the point
+ SegmentNode * addIntersectionNode( geom::Coordinate * intPt, int segmentIndex)
+ int normalizedSegmentIndex = segmentIndex;
+ // normalize the intersection point location
+ int nextSegIndex = normalizedSegmentIndex + 1;
+ if (nextSegIndex < size())
+ const geom::Coordinate &nextPt = getCoordinate( nextSegIndex);
+ // Normalize segment index if intPt falls on vertex
+ // The check for point equality is 2D only - Z values are ignored
+ if ( intPt->equals2D( nextPt ))
+ normalizedSegmentIndex = nextSegIndex;
+ // Add the intersection point to edge intersection list.
+ SegmentNode * ei = getNodeList().add( *intPt, normalizedSegmentIndex);
+ return ei;
+#endif // GEOS_NODING_NODEDSEGMENTSTRING_H
+ * $Log$
Property changes on: trunk/source/headers/geos/noding/NodedSegmentString.h
+ text/plain
+ Id
+ native
Added: trunk/source/headers/geos/noding/SegmentIntersectionDetector.h
--- trunk/source/headers/geos/noding/SegmentIntersectionDetector.h (rev 0)
+++ trunk/source/headers/geos/noding/SegmentIntersectionDetector.h 2007-12-21 20:34:32 UTC (rev 2058)
@@ -0,0 +1,156 @@
+ * $Id
+#ifndef GEOS_GEOM_PREP_SEGMENTINTERSECTIONDETECTOR_H
+#define GEOS_GEOM_PREP_SEGMENTINTERSECTIONDETECTOR_H
+#include <geos/noding/SegmentIntersector.h>
+#include <geos/geom/CoordinateSequence.h>
+using namespace geos::algorithm;
+namespace geos {
+class SegmentIntersectionDetector : public SegmentIntersector
+private:
+ LineIntersector * li;
+ bool findProper;
+ bool findAllTypes;
+ bool _hasIntersection;
+ bool _hasProperIntersection;
+ bool _hasNonProperIntersection;
+ const geom::Coordinate * intPt;
+ geom::CoordinateSequence * intSegments;
+protected:
+public:
+ SegmentIntersectionDetector( LineIntersector * li)
+ li( li),
+ findProper(false),
+ findAllTypes(false),
+ _hasIntersection(false),
+ _hasProperIntersection(false),
+ _hasNonProperIntersection(false),
+ intPt( NULL),
+ intSegments( NULL)
+ void setFindProper( bool findProper)
+ this->findProper = findProper;
+ void setFindAllIntersectionTypes( bool findAllTypes)
+ this->findAllTypes = findAllTypes;
+ * Tests whether an intersection was found.
+ * @return true if an intersection was found
+ bool hasIntersection() const
+ return _hasIntersection;
+ * Tests whether a proper intersection was found.
+ * @return true if a proper intersection was found
+ bool hasProperIntersection() const
+ return _hasProperIntersection;
+ * Tests whether a non-proper intersection was found.
+ * @return true if a non-proper intersection was found
+ bool hasNonProperIntersection() const
+ return _hasNonProperIntersection;
+ * Gets the computed location of the intersection.
+ * Due to round-off, the location may not be exact.
+ * @return the coordinate for the intersection location
+ const geom::Coordinate * const getIntersection() const
+ return intPt;
+ * Gets the endpoints of the intersecting segments.
+ * @return an array of the segment endpoints (p00, p01, p10, p11)
+ const geom::CoordinateSequence * getIntersectionSegments() const
+ return intSegments;
+ bool isDone() const
+ // If finding all types, we can stop
+ // when both possible types have been found.
+ if (findAllTypes)
+ return _hasProperIntersection && _hasNonProperIntersection;
+ // If searching for a proper intersection, only stop if one is found
+ if (findProper)
+ * This method is called by clients
+ * of the {@link SegmentIntersector} class to process
+ * intersections for two segments of the {@link SegmentStrings} being intersected.
+ * Note that some clients (such as {@link MonotoneChain}s) may optimize away
+ * this call for segment pairs which they have determined do not intersect
+ * (e.g. by an disjoint envelope test).
+ void processIntersections( noding::SegmentString * e0, int segIndex0,
+ noding::SegmentString * e1, int segIndex1 );
+#endif // GEOS_GEOM_PREP_SEGMENTINTERSECTIONDETECTOR_H
+ * $Log$
Property changes on: trunk/source/headers/geos/noding/SegmentIntersectionDetector.h
+ text/plain
+ Id
+ native
Added: trunk/source/headers/geos/noding/SegmentSetMutualIntersector.h
--- trunk/source/headers/geos/noding/SegmentSetMutualIntersector.h (rev 0)
+++ trunk/source/headers/geos/noding/SegmentSetMutualIntersector.h 2007-12-21 20:34:32 UTC (rev 2058)
@@ -0,0 +1,74 @@
+ * $Id
+#ifndef GEOS_NODING_SEGMENTSETMUTUALINTERSECTOR_H
+#define GEOS_NODING_SEGMENTSETMUTUALINTERSECTOR_H
+namespace geos {
+class SegmentSetMutualIntersector
+private:
+protected:
+ SegmentIntersector * segInt;
+public:
+ SegmentSetMutualIntersector()
+ : segInt( NULL)
+ virtual ~SegmentSetMutualIntersector()
+ * Sets the {@link SegmentIntersector} to use with this intersector.
+ * The SegmentIntersector will either rocord or add intersection nodes
+ * for the input segment strings.
+ * @param segInt the segment intersector to use
+ void setSegmentIntersector( SegmentIntersector * si)
+ segInt = si;
+ * @param segStrings0 a collection of {@link SegmentString}s to node
+ virtual void setBaseSegments( SegmentString::ConstVect * segStrings) =0;
+ * Computes the intersections for two collections of {@link SegmentString}s.
+ * @param segStrings1 a collection of {@link SegmentString}s to node
+ virtual void process( SegmentString::ConstVect * segStrings) =0;
+} // geos::noding
+} // geos
+#endif // GEOS_NODING_SEGMENTSETMUTUALINTERSECTOR_H
+ * $Log$
Property changes on: trunk/source/headers/geos/noding/SegmentSetMutualIntersector.h
+ text/plain
+ Id
+ native
Added: trunk/source/headers/geos/noding/SegmentStringUtil.h
--- trunk/source/headers/geos/noding/SegmentStringUtil.h (rev 0)
+++ trunk/source/headers/geos/noding/SegmentStringUtil.h 2007-12-21 20:34:32 UTC (rev 2058)
@@ -0,0 +1,65 @@
+ * $Id
+#ifndef GEOS_NODING_SEGMENTSTRINGUTIL_H
+#define GEOS_NODING_SEGMENTSTRINGUTIL_H
+#include <geos/noding/NodedSegmentString.h>
+#include <geos/geom/LineString.h>
+#include <geos/geom/util/LinearComponentExtracter.h>
+namespace geos {
+class SegmentStringUtil
+private:
+protected:
+public:
+ * Extracts all linear components from a given {@link Geometry}
+ * to {@link SegmentString}s.
+ * The SegmentString data item is set to be the source Geometry.
+ * @param geom the geometry to extract from
+ * @return a List of SegmentStrings
+ static void extractSegmentStrings( const geom::Geometry * g, SegmentString::ConstVect & segStr)
+ geom::LineString::ConstVect lines;
+ geom::util::LinearComponentExtracter::getLines( *g, lines);
+ for (size_t i=0, n=lines.size(); i<n; i++)
+ geom::LineString * line = (geom::LineString *)(lines[i]);
+ geom::CoordinateSequence * pts = line->getCoordinates();
+ segStr.push_back( new NodedSegmentString( pts, g));
+} // geos::noding
+} // geos
+#endif // GEOS_NODING_SEGMENTSTRINGUTIL_H
+ * $Log$
Property changes on: trunk/source/headers/geos/noding/SegmentStringUtil.h
+ text/plain
+ Id
+ native
More information about the geos-commits
