[geos-commits] r2059 - in trunk/source/headers/geos/geom: . prep
svn_geos at osgeo.org
Fri Dec 21 15:35:10 EST 2007
Author: benjubb
Date: 2007-12-21 15:35:10 -0500 (Fri, 21 Dec 2007)
New Revision: 2059
Added:
trunk/source/headers/geos/geom/prep/
trunk/source/headers/geos/geom/prep/AbstractPreparedPolygonContains.h
trunk/source/headers/geos/geom/prep/BasicPreparedGeometry.h
trunk/source/headers/geos/geom/prep/PreparedGeometry.h
trunk/source/headers/geos/geom/prep/PreparedGeometryFactory.h
trunk/source/headers/geos/geom/prep/PreparedLineString.h
trunk/source/headers/geos/geom/prep/PreparedLineStringIntersects.h
trunk/source/headers/geos/geom/prep/PreparedPoint.h
trunk/source/headers/geos/geom/prep/PreparedPolygon.h
trunk/source/headers/geos/geom/prep/PreparedPolygonContains.h
trunk/source/headers/geos/geom/prep/PreparedPolygonContainsProperly.h
trunk/source/headers/geos/geom/prep/PreparedPolygonCovers.h
trunk/source/headers/geos/geom/prep/PreparedPolygonIntersects.h
trunk/source/headers/geos/geom/prep/PreparedPolygonLineIntersection.h
trunk/source/headers/geos/geom/prep/PreparedPolygonPredicate.h
Added from JTS 1.9 to support prepared geometry
Added: trunk/source/headers/geos/geom/prep/AbstractPreparedPolygonContains.h
--- trunk/source/headers/geos/geom/prep/AbstractPreparedPolygonContains.h (rev 0)
+++ trunk/source/headers/geos/geom/prep/AbstractPreparedPolygonContains.h 2007-12-21 20:35:10 UTC (rev 2059)
@@ -0,0 +1,115 @@
+ * $Id
+ * GEOS - Geometry Engine Open Source
+ * http://geos.refractions.net
+ * Copyright (C) 2006 Refractions Research Inc.
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+#ifndef GEOS_GEOM_PREP_ABSTRACTPREPAREDPOLYGONCONTAINS_H
+#define GEOS_GEOM_PREP_ABSTRACTPREPAREDPOLYGONCONTAINS_H
+#include <geos/geom/prep/PreparedPolygonPredicate.h> // inherited
+// forward declarations
+namespace geos {
+ namespace geom {
+ class Geometry;
+ namespace prep {
+ class PreparedPolygon;
+namespace geos {
+namespace geom { // geos::geom
+namespace prep { // geos::geom::prep
+class AbstractPreparedPolygonContains : public PreparedPolygonPredicate
+private:
+ // information about geometric situation
+ bool hasSegmentIntersection;
+ bool hasProperIntersection;
+ bool hasNonProperIntersection;
+ bool isProperIntersectionImpliesNotContainedSituation( const geom::Geometry * testGeom);
+ * Tests whether a geometry consists of a single polygon with no holes.
+ * @return true if the geometry is a single polygon with no holes
+ bool isSingleShell( const geom::Geometry & geom);
+ void findAndClassifyIntersections( const geom::Geometry * geom);
+protected:
+ * This flag controls a difference between contains and covers.
+ * For contains the value is true.
+ * For covers the value is false.
+ bool requireSomePointInInterior;
+ * Evaluate the <tt>contains</tt> or <tt>covers</tt> relationship
+ * for the given geometry.
+ * @param geom the test geometry
+ * @return true if the test geometry is contained
+ bool eval( const geom::Geometry * geom);
+ * Computes the full topological predicate.
+ * Used when short-circuit tests are not conclusive.
+ * @return true if this prepared polygon has the relationship with the test geometry
+ virtual bool fullTopologicalPredicate( const geom::Geometry * geom) =0;
+public:
+ AbstractPreparedPolygonContains( const PreparedPolygon * const prepPoly)
+ : PreparedPolygonPredicate( prepPoly),
+ hasSegmentIntersection( false),
+ hasProperIntersection( false),
+ hasNonProperIntersection( false),
+ requireSomePointInInterior(true)
+ AbstractPreparedPolygonContains( const PreparedPolygon * const prepPoly, bool requireSomePointInInterior)
+ requireSomePointInInterior(requireSomePointInInterior)
+ virtual ~AbstractPreparedPolygonContains()
+} // geos::geom::prep
+} // geos::geom
+} // geos
+#endif // GEOS_GEOM_PREP_ABSTRACTPREPAREDPOLYGONCONTAINS_H
+ * $Log$
Property changes on: trunk/source/headers/geos/geom/prep/AbstractPreparedPolygonContains.h
___________________________________________________________________
+ text/plain
+ Id
+ native
Added: trunk/source/headers/geos/geom/prep/BasicPreparedGeometry.h
--- trunk/source/headers/geos/geom/prep/BasicPreparedGeometry.h (rev 0)
+++ trunk/source/headers/geos/geom/prep/BasicPreparedGeometry.h 2007-12-21 20:35:10 UTC (rev 2059)
@@ -0,0 +1,171 @@
+ * $Id
+#ifndef GEOS_GEOM_PREP_BASICPREPAREDGEOMETRY_H
+#define GEOS_GEOM_PREP_BASICPREPAREDGEOMETRY_H
+#include <geos/geom/prep/PreparedGeometry.h> // for inheritance
+//#include <geos/algorithm/PointLocator.h>
+//#include <geos/geom/util/ComponentCoordinateExtracter.h>
+#include <geos/geom/Coordinate.h>
+//#include <geos/geom/Location.h>
+#include <vector>
+#include <string>
+namespace geos {
+ namespace geom {
+ class Geometry;
+ class Coordinate;
+namespace geos {
+ * A base class for {@link PreparedGeometry} subclasses.
+ * Contains default implementations for methods, which simply delegate
+ * to the equivalent {@link Geometry} methods.
+ * This class may be used as a "no-op" class for Geometry types
+ * which do not have a corresponding {@link PreparedGeometry} implementation.
+ * @author Martin Davis
+class BasicPreparedGeometry: public PreparedGeometry
+private:
+ const geom::Geometry * baseGeom;
+ Coordinate::ConstVect representativePts;
+protected:
+ void setGeometry( const geom::Geometry * geom );
+ * Determines whether a Geometry g interacts with
+ * this geometry by testing the geometry envelopes.
+ * @param g a Geometry
+ * @return true if the envelopes intersect
+ bool envelopesIntersect(const geom::Geometry* g) const;
+ * Determines whether the envelope of
+ * this geometry covers the Geometry g.
+ * @return true if g is contained in this envelope
+ bool envelopeCovers(const geom::Geometry* g) const;
+public:
+ BasicPreparedGeometry( const Geometry * geom);
+ ~BasicPreparedGeometry( );
+ const geom::Geometry & getGeometry() const
+ return *baseGeom;
+ * Gets the list of representative points for this geometry.
+ * One vertex is included for every component of the geometry
+ * (i.e. including one for every ring of polygonal geometries)
+ * @return a List of Coordinate
+ const Coordinate::ConstVect * getRepresentativePoints() const
+ return &representativePts;
+ * Tests whether any representative of the target geometry
+ * intersects the test geometry.
+ * This is useful in A/A, A/L, A/P, L/P, and P/P cases.
+ * @param repPts the representative points of the target geometry
+ * @return true if any component intersects the areal test geometry
+ bool isAnyTargetComponentInTest(const geom::Geometry * testGeom) const;
+ * Default implementation.
+ bool contains(const geom::Geometry * g) const;
+ bool containsProperly(const geom::Geometry * g) const;
+ bool coveredBy(const geom::Geometry * g) const;
+ bool covers(const geom::Geometry * g) const;
+ bool crosses(const geom::Geometry * g) const;
+ bool disjoint(const geom::Geometry * g) const;
+ bool intersects(const geom::Geometry * g) const;
+ bool overlaps(const geom::Geometry * g) const;
+ bool touches(const geom::Geometry * g) const;
+ bool within(const geom::Geometry * g) const;
+ std::string toString();
+} // namespace geos::geom::prep
+#endif // GEOS_GEOM_PREP_BASICPREPAREDGEOMETRY_H
+ * $Log$
Property changes on: trunk/source/headers/geos/geom/prep/BasicPreparedGeometry.h
+ text/plain
+ Id
+ native
Added: trunk/source/headers/geos/geom/prep/PreparedGeometry.h
--- trunk/source/headers/geos/geom/prep/PreparedGeometry.h (rev 0)
+++ trunk/source/headers/geos/geom/prep/PreparedGeometry.h 2007-12-21 20:35:10 UTC (rev 2059)
@@ -0,0 +1,180 @@
+ * $Id
+#ifndef GEOS_GEOM_PREP_PREPAREDGEOMETRY_H
+#define GEOS_GEOM_PREP_PREPAREDGEOMETRY_H
+// Forward declarations
+namespace geos {
+ namespace geom {
+ class Geometry;
+namespace geos {
+ * \class PreparedGeometry
+ * \brief
+ * An interface for classes which prepare {@link Geometry}s
+ * in order to optimize the performance
+ * of repeated calls to specific geometric operations.
+ * <p>
+ * A given implementation may provide optimized implementations
+ * for only some of the specified methods,
+ * and delegate the remaining methods to the original {@link Geometry} operations.
+ * An implementation may also only optimize certain situations,
+ * and delegate others.
+ * See the implementing classes for documentation about which methods and situations
+ * they optimize.
+ * Last port: index/SpatialIndex.java (JTS-1.9) *
+class PreparedGeometry {
+public:
+ virtual ~PreparedGeometry() {};
+ * Gets the original {@link Geometry} which has been prepared.
+ * @return the base geometry
+ virtual const geom::Geometry & getGeometry() const =0;
+ * Tests whether the base {@link Geometry} contains a given geometry.
+ * @param geom the Geometry to test
+ * @return true if this Geometry contains the given Geometry
+ * @see Geometry#contains(Geometry)
+ virtual bool contains(const geom::Geometry *geom) const =0;
+ * <p>
+ * The <code>containsProperly</code> predicate has the following equivalent definitions:
+ * <ul>
+ * <li>Every point of the other geometry is a point of this geometry's interior.
+ * <li>The DE-9IM Intersection Matrix for the two geometries matches
+ * <code>[T**FF*FF*]</code>
+ * </ul>
+ * The advantage to using this predicate is that it can be computed
+ * efficiently, with no need to compute topology at individual points.
+ * @return true if this Geometry containsProperly the given Geometry
+ virtual bool containsProperly(const geom::Geometry *geom) const =0;
+ * Tests whether the base {@link Geometry} is covered by a given geometry.
+ * @return true if this Geometry is covered by the given Geometry
+ * @see Geometry#coveredBy(Geometry)
+ virtual bool coveredBy(const geom::Geometry *geom) const =0;
+ * Tests whether the base {@link Geometry} covers a given geometry.
+ * @return true if this Geometry covers the given Geometry
+ * @see Geometry#covers(Geometry)
+ virtual bool covers(const geom::Geometry *geom) const =0;
+ * Tests whether the base {@link Geometry} crosses a given geometry.
+ * @return true if this Geometry crosses the given Geometry
+ * @see Geometry#crosses(Geometry)
+ virtual bool crosses(const geom::Geometry *geom) const =0;
+ * Tests whether the base {@link Geometry} is disjoint from a given geometry.
+ * @return true if this Geometry is disjoint from the given Geometry
+ * @see Geometry#disjoint(Geometry)
+ virtual bool disjoint(const geom::Geometry *geom) const =0;
+ * Tests whether the base {@link Geometry} intersects a given geometry.
+ * @return true if this Geometry intersects the given Geometry
+ * @see Geometry#intersects(Geometry)
+ virtual bool intersects(const geom::Geometry *geom) const =0;
+ * Tests whether the base {@link Geometry} overlaps a given geometry.
+ * @return true if this Geometry overlaps the given Geometry
+ * @see Geometry#overlaps(Geometry)
+ virtual bool overlaps(const geom::Geometry *geom) const =0;
+ * Tests whether the base {@link Geometry} touches a given geometry.
+ * @return true if this Geometry touches the given Geometry
+ * @see Geometry#touches(Geometry)
+ virtual bool touches(const geom::Geometry *geom) const =0;
+ * Tests whether the base {@link Geometry} is within a given geometry.
+ * @return true if this Geometry is within the given Geometry
+ * @see Geometry#within(Geometry)
+ virtual bool within(const geom::Geometry *geom) const =0;
+#endif // ndef GEOS_GEOM_PREP_PREPAREDGEOMETRY_H
+ * $Log$
Property changes on: trunk/source/headers/geos/geom/prep/PreparedGeometry.h
+ text/plain
+ Id
+ native
Added: trunk/source/headers/geos/geom/prep/PreparedGeometryFactory.h
--- trunk/source/headers/geos/geom/prep/PreparedGeometryFactory.h (rev 0)
+++ trunk/source/headers/geos/geom/prep/PreparedGeometryFactory.h 2007-12-21 20:35:10 UTC (rev 2059)
@@ -0,0 +1,86 @@
+ * $Id
+#ifndef GEOS_GEOM_PREP_PREPAREDGEOMETRYFACTORY_H
+#define GEOS_GEOM_PREP_PREPAREDGEOMETRYFACTORY_H
+namespace geos {
+ namespace geom {
+ class Geometry;
+ namespace prep {
+ class PreparedGeometry;
+using namespace geos::geom;
+namespace geos {
+ * A factory for creating {@link PreparedGeometry}s.
+ * It chooses an appropriate implementation of PreparedGeometry
+ * based on the geoemtric type of the input geometry.
+ * <p>
+ * In the future, the factory may accept hints that indicate
+ * special optimizations which can be performed.
+class PreparedGeometryFactory
+private:
+protected:
+public:
+ * Creates a new {@link PreparedGeometry} appropriate for the argument {@link Geometry}.
+ * @param geom the geometry to prepare
+ * @return the prepared geometry
+ static const PreparedGeometry * prepare( const geom::Geometry * geom)
+ PreparedGeometryFactory pf;
+ return pf.create(geom);
+ PreparedGeometryFactory()
+ const PreparedGeometry * PreparedGeometryFactory::create( const geom::Geometry * geom) const;
+#endif // GEOS_GEOM_PREP_PREPAREDGEOMETRYFACTORY_H
+ * $Log$
Property changes on: trunk/source/headers/geos/geom/prep/PreparedGeometryFactory.h
+ text/plain
+ Id
+ native
Added: trunk/source/headers/geos/geom/prep/PreparedLineString.h
--- trunk/source/headers/geos/geom/prep/PreparedLineString.h (rev 0)
+++ trunk/source/headers/geos/geom/prep/PreparedLineString.h 2007-12-21 20:35:10 UTC (rev 2059)
@@ -0,0 +1,65 @@
+ * $Id
+#ifndef GEOS_GEOM_PREP_PREPAREDLINESTRING_H
+#define GEOS_GEOM_PREP_PREPAREDLINESTRING_H
+#include <geos/geom/prep/BasicPreparedGeometry.h> // for inheritance
+namespace geos {
+ namespace noding {
+ class FastSegmentSetIntersectionFinder;
+namespace geos {
+ * A prepared version for {@link Lineal} geometries.
+ * @author mbdavis
+class PreparedLineString : public BasicPreparedGeometry
+private:
+ noding::FastSegmentSetIntersectionFinder * segIntFinder;
+protected:
+public:
+ PreparedLineString(const Geometry * geom)
+ BasicPreparedGeometry( geom),
+ segIntFinder( NULL)
+ noding::FastSegmentSetIntersectionFinder * getIntersectionFinder();
+#endif // GEOS_GEOM_PREP_PREPAREDLINESTRING_H
+ * $Log$
Property changes on: trunk/source/headers/geos/geom/prep/PreparedLineString.h
+ text/plain
+ Id
+ native
Added: trunk/source/headers/geos/geom/prep/PreparedLineStringIntersects.h
--- trunk/source/headers/geos/geom/prep/PreparedLineStringIntersects.h (rev 0)
+++ trunk/source/headers/geos/geom/prep/PreparedLineStringIntersects.h 2007-12-21 20:35:10 UTC (rev 2059)
@@ -0,0 +1,116 @@
+ * $Id
+#ifndef GEOS_GEOM_PREP_PREPAREDLINESTRINGINTERSECTS_H
+#define GEOS_GEOM_PREP_PREPAREDLINESTRINGINTERSECTS_H
+#include <geos/geom/prep/PreparedLineString.h>
+#include <geos/algorithm/PointLocator.h>
+#include <geos/geom/util/ComponentCoordinateExtracter.h>
+#include <geos/noding/SegmentStringUtil.h>
+using namespace geos::algorithm;
+using namespace geos::geom::util;
+namespace geos {
+ * Computes the <tt>intersects</tt> spatial relationship predicate
+ * for a target {@link PreparedLineString} relative to other {@link Geometry} classes.
+ * Uses short-circuit tests and indexing to improve performance.
+class PreparedLineStringIntersects
+private:
+protected:
+ PreparedLineString & prepLine;
+ //PreparedLineString * prepLine;
+ * Tests whether any representative point of the test Geometry intersects
+ * the target geometry.
+ * Only handles test geometries which are Puntal (dimension 0)
+ * @param geom a Puntal geometry to test
+ * @return true if any point of the argument intersects the prepared geometry
+ bool isAnyTestPointInTarget(const geom::Geometry * testGeom) const;
+ // * This could be optimized by using the segment index on the lineal target.
+ // * However, it seems like the L/P case would be pretty rare in practice.
+ // PointLocator * locator = new PointLocator();
+ // geom::Coordinate::ConstVect coords;
+ // ComponentCoordinateExtracter::getCoordinates( *testGeom, coords);
+ // for (size_t i=0, n=coords.size(); i<n; i++)
+ // geom::Coordinate c = *(coords[i]);
+ // if ( locator->intersects( c, &(prepLine->getGeometry()) ))
+ // return true;
+ // return false;
+public:
+ * Computes the intersects predicate between a {@link PreparedLineString}
+ * and a {@link Geometry}.
+ * @param prep the prepared linestring
+ * @param geom a test geometry
+ * @return true if the linestring intersects the geometry
+ static bool intersects( PreparedLineString & prep, const geom::Geometry * geom )
+ PreparedLineStringIntersects * op = new PreparedLineStringIntersects( prep);
+ return op->intersects( geom);
+ PreparedLineStringIntersects(PreparedLineString & prep)
+ : prepLine( prep)
+ * Tests whether this geometry intersects a given geometry.
+ * @return true if the test geometry intersects
+#endif // GEOS_GEOM_PREP_PREPAREDLINESTRINGINTERSECTS_H
+ * $Log$
Property changes on: trunk/source/headers/geos/geom/prep/PreparedLineStringIntersects.h
+ text/plain
+ Id
+ native
Added: trunk/source/headers/geos/geom/prep/PreparedPoint.h
--- trunk/source/headers/geos/geom/prep/PreparedPoint.h (rev 0)
+++ trunk/source/headers/geos/geom/prep/PreparedPoint.h 2007-12-21 20:35:10 UTC (rev 2059)
@@ -0,0 +1,59 @@
+ * $Id
+#ifndef GEOS_GEOM_PREP_PREPAREDPOINT_H
+#define GEOS_GEOM_PREP_PREPAREDPOINT_H
+namespace geos {
+ * A prepared version for {@link Puntal} geometries.
+class PreparedPoint: public BasicPreparedGeometry
+private:
+protected:
+public:
+ PreparedPoint(const Geometry * geom)
+ : BasicPreparedGeometry( geom)
+ * Tests whether this point intersects a {@link Geometry}.
+ * <p>
+ * The optimization here is that computing topology for the test geometry
+ * is avoided. This can be significant for large geometries.
+ bool intersects(geom::Geometry* g);
+#endif // GEOS_GEOM_PREP_PREPAREDPOINT_H
+ * $Log$
Property changes on: trunk/source/headers/geos/geom/prep/PreparedPoint.h
+ text/plain
+ Id
+ native
Added: trunk/source/headers/geos/geom/prep/PreparedPolygon.h
--- trunk/source/headers/geos/geom/prep/PreparedPolygon.h (rev 0)
+++ trunk/source/headers/geos/geom/prep/PreparedPolygon.h 2007-12-21 20:35:10 UTC (rev 2059)
@@ -0,0 +1,75 @@
+ * $Id
+#ifndef GEOS_GEOM_PREP_PREPAREDPOLYGON_H
+#define GEOS_GEOM_PREP_PREPAREDPOLYGON_H
+#include <geos/noding/SegmentString.h>
+namespace geos {
+ namespace algorithm {
+ namespace locate {
+ class PointOnGeometryLocator;
+namespace geos {
+ * A prepared version for {@link Polygonal} geometries.
+ * @author mbdavis
+class PreparedPolygon : public BasicPreparedGeometry
+private:
+ bool isRectangle;
+ mutable noding::FastSegmentSetIntersectionFinder * segIntFinder;
+ mutable algorithm::locate::PointOnGeometryLocator * ptOnGeomLoc;
+ mutable noding::SegmentString::ConstVect segStrings;
+protected:
+public:
+ PreparedPolygon( const geom::Geometry * geom);
+ ~PreparedPolygon( );
+ noding::FastSegmentSetIntersectionFinder * getIntersectionFinder() const;
+ algorithm::locate::PointOnGeometryLocator * getPointLocator() const;
+ bool contains( const geom::Geometry* g) const;
+ bool containsProperly( const geom::Geometry* g) const;
+ bool covers( const geom::Geometry* g) const;
+ bool intersects( const geom::Geometry* g) const;
+#endif // GEOS_GEOM_PREP_PREPAREDPOLYGON_H
+ * $Log$
Property changes on: trunk/source/headers/geos/geom/prep/PreparedPolygon.h
+ text/plain
+ Id
+ native
Added: trunk/source/headers/geos/geom/prep/PreparedPolygonContains.h
--- trunk/source/headers/geos/geom/prep/PreparedPolygonContains.h (rev 0)
+++ trunk/source/headers/geos/geom/prep/PreparedPolygonContains.h 2007-12-21 20:35:10 UTC (rev 2059)
@@ -0,0 +1,95 @@
+ * $Id
+#ifndef GEOS_GEOM_PREP_PREPAREDPOLYGONCONTAINS_H
+#define GEOS_GEOM_PREP_PREPAREDPOLYGONCONTAINS_H
+#include <geos/geom/prep/AbstractPreparedPolygonContains.h> // inherited
+namespace geos {
+ namespace geom {
+ class Geometry;
+ namespace prep {
+namespace geos {
+class PreparedPolygonContains : public AbstractPreparedPolygonContains
+private:
+protected:
+ * Computes the full topological <tt>contains</tt> predicate.
+ * @return true if this prepared polygon contains the test geometry
+ bool fullTopologicalPredicate( const geom::Geometry * geom);
+public:
+ * Computes the </tt>contains</tt> predicate between a {@link PreparedPolygon}
+ * @param prep the prepared polygon
+ * @return true if the polygon contains the geometry
+ static bool contains( const PreparedPolygon * const prep, const geom::Geometry * geom)
+ PreparedPolygonContains polyInt( prep);
+ return polyInt.contains( geom);
+ * Creates an instance of this operation.
+ * @param prepPoly the PreparedPolygon to evaluate
+ PreparedPolygonContains( const PreparedPolygon * const prepPoly)
+ : AbstractPreparedPolygonContains( prepPoly)
+ * Tests whether this PreparedPolygon <tt>contains</tt> a given geometry.
+ bool contains( const geom::Geometry * geom)
+ return eval( geom);
+} // geos::geom
+} // geos
+#endif // GEOS_GEOM_PREP_PREPAREDPOLYGONCONTAINS_H
+ * $Log$
Property changes on: trunk/source/headers/geos/geom/prep/PreparedPolygonContains.h
+ text/plain
+ Id
+ native
Added: trunk/source/headers/geos/geom/prep/PreparedPolygonContainsProperly.h
--- trunk/source/headers/geos/geom/prep/PreparedPolygonContainsProperly.h (rev 0)
+++ trunk/source/headers/geos/geom/prep/PreparedPolygonContainsProperly.h 2007-12-21 20:35:10 UTC (rev 2059)
@@ -0,0 +1,85 @@
+ * $Id
+#ifndef GEOS_GEOM_PREP_PREPAREDPOLYGONCONTAINSPROPERLY_H
+#define GEOS_GEOM_PREP_PREPAREDPOLYGONCONTAINSPROPERLY_H
+namespace geos {
+ namespace geom {
+ class Geometry;
+ namespace prep {
+namespace geos {
+class PreparedPolygonContainsProperly : public PreparedPolygonPredicate
+private:
+protected:
+public:
+ * Computes the </tt>containsProperly</tt> predicate between a {@link PreparedPolygon}
+ * @return true if the polygon properly contains the geometry
+ static
+ bool
+ containsProperly( const PreparedPolygon * const prep, const geom::Geometry * geom)
+ PreparedPolygonContainsProperly polyInt( prep);
+ return polyInt.containsProperly( geom);
+ PreparedPolygonContainsProperly( const PreparedPolygon * const prep)
+ : PreparedPolygonPredicate( prep)
+ * Tests whether this PreparedPolygon containsProperly a given geometry.
+ * @return true if the test geometry is contained properly
+ bool
+ containsProperly( const geom::Geometry * geom);
+} // geos::geom
+} // geos
+#endif // GEOS_GEOM_PREP_PREPAREDPOLYGONCONTAINSPROPERLY_H
+ * $Log$
Property changes on: trunk/source/headers/geos/geom/prep/PreparedPolygonContainsProperly.h
+ text/plain
+ Id
+ native
Added: trunk/source/headers/geos/geom/prep/PreparedPolygonCovers.h
--- trunk/source/headers/geos/geom/prep/PreparedPolygonCovers.h (rev 0)
+++ trunk/source/headers/geos/geom/prep/PreparedPolygonCovers.h 2007-12-21 20:35:10 UTC (rev 2059)
@@ -0,0 +1,95 @@
+ * $Id
+#ifndef GEOS_GEOM_PREP_PREPAREDPOLYGONCOVERS_H
+#define GEOS_GEOM_PREP_PREPAREDPOLYGONCOVERS_H
+namespace geos {
+ namespace geom {
+ class Geometry;
+ namespace prep {
+namespace geos {
+class PreparedPolygonCovers : public AbstractPreparedPolygonContains
+private:
+protected:
+ * Computes the full topological <tt>covers</tt> predicate.
+public:
+ * Computes the </tt>covers</tt> predicate between a {@link PreparedPolygon}
+ * @return true if the polygon covers the geometry
+ static bool covers(const PreparedPolygon * const prep, const geom::Geometry * geom)
+ PreparedPolygonCovers polyInt(prep);
+ return polyInt.covers(geom);
+ PreparedPolygonCovers(const PreparedPolygon * const prep)
+ : AbstractPreparedPolygonContains( prep, false)
+ * Tests whether this PreparedPolygon <tt>covers</tt> a given geometry.
+ bool covers( const Geometry * geom)
+} // geos::geom
+} // geos
+#endif // GEOS_GEOM_PREP_PREPAREDPOLYGONCOVERS_H
+ * $Log$
Property changes on: trunk/source/headers/geos/geom/prep/PreparedPolygonCovers.h
+ text/plain
+ Id
+ native
Added: trunk/source/headers/geos/geom/prep/PreparedPolygonIntersects.h
--- trunk/source/headers/geos/geom/prep/PreparedPolygonIntersects.h (rev 0)
+++ trunk/source/headers/geos/geom/prep/PreparedPolygonIntersects.h 2007-12-21 20:35:10 UTC (rev 2059)
@@ -0,0 +1,82 @@
+ * $Id
+#ifndef GEOS_GEOM_PREP_PREPAREDPOLYGONINTERSECTS_H
+#define GEOS_GEOM_PREP_PREPAREDPOLYGONINTERSECTS_H
+namespace geos {
+ namespace geom {
+ class Geometry;
+ namespace prep {
+namespace geos {
+class PreparedPolygonIntersects : public PreparedPolygonPredicate
+private:
+protected:
+public:
+ * Computes the intersects predicate between a {@link PreparedPolygon}
+ * @return true if the polygon intersects the geometry
+ static bool intersects( const PreparedPolygon * const prep, const geom::Geometry * geom)
+ PreparedPolygonIntersects polyInt(prep);
+ return polyInt.intersects( geom);
+ PreparedPolygonIntersects( const PreparedPolygon * const prep)
+ * Tests whether this PreparedPolygon intersects a given geometry.
+ bool intersects( const geom::Geometry * geom);
+} // geos::geom
+} // geos
+#endif // GEOS_GEOM_PREP_PREPAREDPOLYGONINTERSECTS_H
+ * $Log$
Property changes on: trunk/source/headers/geos/geom/prep/PreparedPolygonIntersects.h
+ text/plain
+ Id
+ native
Added: trunk/source/headers/geos/geom/prep/PreparedPolygonLineIntersection.h
--- trunk/source/headers/geos/geom/prep/PreparedPolygonLineIntersection.h (rev 0)
+++ trunk/source/headers/geos/geom/prep/PreparedPolygonLineIntersection.h 2007-12-21 20:35:10 UTC (rev 2059)
@@ -0,0 +1,40 @@
+ * $Id
+#ifndef GEOS_GEOM_PREP_PREPAREDPOLYGONLINEINTERSECTION_H
+#define GEOS_GEOM_PREP_PREPAREDPOLYGONLINEINTERSECTION_H
+namespace geos {
+class PreparedPolygonLineIntersection
+private:
+protected:
+public:
+} // geos::geom
+} // geos
+#endif // GEOS_GEOM_PREP_PREPAREDPOLYGONLINEINTERSECTION_H
+ * $Log$
Property changes on: trunk/source/headers/geos/geom/prep/PreparedPolygonLineIntersection.h
+ text/plain
+ Id
+ native
Added: trunk/source/headers/geos/geom/prep/PreparedPolygonPredicate.h
--- trunk/source/headers/geos/geom/prep/PreparedPolygonPredicate.h (rev 0)
+++ trunk/source/headers/geos/geom/prep/PreparedPolygonPredicate.h 2007-12-21 20:35:10 UTC (rev 2059)
@@ -0,0 +1,125 @@
+ * $Id
+#ifndef GEOS_GEOM_PREP_PREPAREDPOLYGONPREDICATE_H
+#define GEOS_GEOM_PREP_PREPAREDPOLYGONPREDICATE_H
+namespace geos {
+ namespace geom {
+ class Geometry;
+ namespace prep {
+namespace geos {
+class PreparedPolygonPredicate
+private:
+protected:
+ const PreparedPolygon * const prepPoly;
+ * Tests whether all components of the test Geometry
+ * are contained in the target geometry.
+ * Handles both linear and point components.
+ * @param geom a geometry to test
+ * @return true if all componenta of the argument are contained in the target geometry
+ bool isAllTestComponentsInTargetArea( const geom::Geometry * testGeom);
+ * are contained in the interior of the target geometry.
+ * @return true if all componenta of the argument are contained in the target geometry interior
+ bool isAllTestComponentsInTargetInterior( const geom::Geometry * testGeom);
+ * Tests whether any component of the test Geometry intersects
+ * the area of the target geometry.
+ * Handles test geometries with both linear and point components.
+ * @return true if any component of the argument intersects the prepared geometry
+ bool isAnyTestComponentInTargetArea( const geom::Geometry * testGeom);
+ * the interior of the target geometry.
+ * @return true if any component of the argument intersects the prepared area geometry interior
+ bool isAnyTestComponentInTargetInterior( const geom::Geometry * testGeom);
+ * Tests whether any component of the target geometry
+ * intersects the area of the test geometry
+ bool isAnyTargetComponentInTestArea( const geom::Geometry * testGeom, const geom::Coordinate::ConstVect * targetRepPts);
+public:
+ PreparedPolygonPredicate( const PreparedPolygon * const prepPoly)
+ : prepPoly( prepPoly)
+ ~PreparedPolygonPredicate()
+#endif // GEOS_GEOM_PREP_PREPAREDPOLYGONPREDICATE_H
+ * $Log$
Property changes on: trunk/source/headers/geos/geom/prep/PreparedPolygonPredicate.h
+ text/plain
+ Id
+ native
More information about the geos-commits
