[geos-commits] r2060 - trunk/source/headers/geos/algorithm
svn_geos at osgeo.org
Fri Dec 21 15:37:33 EST 2007
Author: benjubb
Date: 2007-12-21 15:37:32 -0500 (Fri, 21 Dec 2007)
New Revision: 2060
Added:
trunk/source/headers/geos/algorithm/RayCrossingCounter.h
Added from JTS 1.9 to support prepared geometry
Added: trunk/source/headers/geos/algorithm/RayCrossingCounter.h
--- trunk/source/headers/geos/algorithm/RayCrossingCounter.h (rev 0)
+++ trunk/source/headers/geos/algorithm/RayCrossingCounter.h 2007-12-21 20:37:32 UTC (rev 2060)
@@ -0,0 +1,142 @@
+ * $Id
+ * GEOS - Geometry Engine Open Source
+ * http://geos.refractions.net
+ * Copyright (C) 2006 Refractions Research Inc.
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+#ifndef GEOS_ALGORITHM_RAYCROSSINGCOUNTER_H
+#define GEOS_ALGORITHM_RAYCROSSINGCOUNTER_H
+// forward declarations
+namespace geos {
+ namespace geom {
+ class Coordinate;
+ class CoordinateSequence;
+namespace geos {
+namespace algorithm {
+ * Counts the number of segments crossed by a horizontal ray extending to the right
+ * from a given point, in an incremental fashion.
+ * This can be used to determine whether a point lies in a {@link Polygonal} geometry.
+ * The class determines the situation where the point lies exactly on a segment.
+ * When being used for Point-In-Polygon determination, this case allows short-circuiting
+ * the evaluation.
+ * <p>
+ * This class handles polygonal geometries with any number of shells and holes.
+ * The orientation of the shell and hole rings is unimportant.
+ * In order to compute a correct location for a given polygonal geometry,
+ * it is essential that <b>all</b> segments are counted which
+ * <ul>
+ * <li>touch the ray
+ * <li>lie in in any ring which may contain the point
+ * </ul>
+ * The only exception is when the point-on-segment situation is detected, in which
+ * case no further processing is required.
+ * The implication of the above rule is that segments
+ * which can be a priori determined to <i>not</i> touch the ray
+ * (i.e. by a test of their bounding box or Y-extent)
+ * do not need to be counted. This allows for optimization by indexing.
+ * @author Martin Davis
+class RayCrossingCounter
+private:
+ const geom::Coordinate * point;
+ int crossingCount;
+ // true if the test point lies on an input segment
+ bool isPointOnSegment;
+protected:
+public:
+ * Determines the {@link Location} of a point in a ring.
+ * This method is an exemplar of how to use this class.
+ * @param p the point to test
+ * @param ring an array of Coordinates forming a ring
+ * @return the location of the point in the ring
+ static int locatePointInRing( const geom::Coordinate * p, const geom::CoordinateSequence * ring);
+ RayCrossingCounter( const geom::Coordinate * point)
+ : point( point),
+ crossingCount( 0),
+ isPointOnSegment( false)
+ * Counts a segment
+ * @param p1 an endpoint of the segment
+ * @param p2 another endpoint of the segment
+ void countSegment( const geom::Coordinate * p1, const geom::Coordinate * p2);
+ * Reports whether the point lies exactly on one of the supplied segments.
+ * This method may be called at any time as segments are processed.
+ * If the result of this method is <tt>true</tt>,
+ * no further segments need be supplied, since the result
+ * will never change again.
+ * @return true if the point lies exactly on a segment
+ bool isOnSegment()
+ return isPointOnSegment;
+ * Gets the {@link Location} of the point relative to
+ * the ring, polygon
+ * or multipolygon from which the processed segments were provided.
+ * <p>
+ * This method only determines the correct location
+ * if <b>all</b> relevant segments must have been processed.
+ * @return the Location of the point
+ int getLocation();
+ * Tests whether the point lies in or on
+ * <p>
+ * @return true if the point lies in or on the supplied polygon
+ bool isPointInPolygon();
+} // geos::algorithm
+} // geos
+#endif // GEOS_ALGORITHM_RAYCROSSINGCOUNTER_H
+ * $Log$
Property changes on: trunk/source/headers/geos/algorithm/RayCrossingCounter.h
___________________________________________________________________
+ text/plain
+ Id
+ native
More information about the geos-commits
