[geos-commits] r2061 - trunk/source/headers/geos/algorithm
svn_geos at osgeo.org
Fri Dec 21 15:38:26 EST 2007
Author: benjubb
Date: 2007-12-21 15:38:26 -0500 (Fri, 21 Dec 2007)
New Revision: 2061
Removed:
trunk/source/headers/geos/algorithm/SimplePointInAreaLocator.h
Moved into geos::algorithm::locate
Deleted: trunk/source/headers/geos/algorithm/SimplePointInAreaLocator.h
--- trunk/source/headers/geos/algorithm/SimplePointInAreaLocator.h 2007-12-21 20:37:32 UTC (rev 2060)
+++ trunk/source/headers/geos/algorithm/SimplePointInAreaLocator.h 2007-12-21 20:38:26 UTC (rev 2061)
@@ -1,77 +0,0 @@
- * $Id$
- * GEOS - Geometry Engine Open Source
- * http://geos.refractions.net
- * Copyright (C) 2005-2006 Refractions Research Inc.
- * Copyright (C) 2001-2002 Vivid Solutions Inc.
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
-#ifndef GEOS_ALGORITHM_LOCATE_SIMPLEPOINTINAREALOCATOR_H
-#define GEOS_ALGORITHM_LOCATE_SIMPLEPOINTINAREALOCATOR_H
-#include <geos/algorithm/locate/PointOnGeometryLocator.h> // inherited
-// Forward declarations
-namespace geos {
- namespace geom {
- class Geometry;
- class Coordinate;
- class Polygon;
-namespace geos {
-namespace algorithm { // geos::algorithm
-namespace locate { // geos::algorithm::locate
-class SimplePointInAreaLocator : public PointOnGeometryLocator
-public:
- static int locate(const geom::Coordinate& p,
- const geom::Geometry *geom);
- static bool containsPointInPolygon(const geom::Coordinate& p,
- const geom::Polygon *poly);
- SimplePointInAreaLocator( const geom::Geometry * g)
- : g( g)
- int locate( const geom::Coordinate * p)
- return locate( *p, g);
-private:
- static bool containsPoint(const geom::Coordinate& p,
- const geom::Geometry * g;
-} // geos::algorithm::locate
-} // geos
-#endif // GEOS_ALGORITHM_LOCATE_SIMPLEPOINTINAREALOCATOR_H
- * $Log$
- * Revision 1.1 2006/03/09 16:46:48 strk
- * geos::geom namespace definition, first pass at headers split
More information about the geos-commits
