[geos-commits] r2176 - trunk/capi
svn_geos at osgeo.org
Thu Aug 28 20:30:47 EDT 2008
Author: mloskot
Date: 2008-08-28 20:30:47 -0400 (Thu, 28 Aug 2008)
New Revision: 2176
trunk/capi/geos_c.cpp
Fixed execution paths and removed redundant return expr in some C API calls.
Modified: trunk/capi/geos_c.cpp
--- trunk/capi/geos_c.cpp 2008-08-29 00:29:58 UTC (rev 2175)
+++ trunk/capi/geos_c.cpp 2008-08-29 00:30:47 UTC (rev 2176)
@@ -2035,7 +2035,7 @@
try
std::string s = writer->write(geom);
- char *result;
+ char *result = NULL;
result = (char*) std::malloc( s.length() + 1);
std::strcpy(result, s.c_str() );
return result;
@@ -2043,14 +2043,13 @@
catch (const std::exception &e)
ERROR_MESSAGE("%s", e.what());
- return NULL;
catch (...)
ERROR_MESSAGE("Unknown exception thrown");
- return NULL;
+ return NULL;
/* WKB Reader */
@@ -2065,14 +2064,13 @@
- return NULL;
catch (...)
- return NULL;
+ return NULL;
void
@@ -2110,14 +2108,13 @@
- return NULL;
catch (...)
- return NULL;
+ return NULL;
Geometry*
@@ -2136,14 +2133,13 @@
- return NULL;
catch (...)
- return NULL;
+ return NULL;
/* WKB Writer */
@@ -2158,14 +2154,13 @@
- return NULL;
catch (...)
- return NULL;
+ return NULL;
void
@@ -2198,7 +2193,7 @@
std::string wkbstring = s.str();
size_t len = wkbstring.length();
- unsigned char *result;
+ unsigned char *result = NULL;
result = (unsigned char*) std::malloc(len);
std::memcpy(result, wkbstring.c_str(), len);
*size = len;
@@ -2207,14 +2202,12 @@
- return NULL;
catch (...)
- return NULL;
+ return NULL;
/* The owner owns the result */
@@ -2226,9 +2219,9 @@
std::ostringstream s(std::ios_base::binary);
writer->writeHEX(*geom, s);
- size_t len = wkbstring.length();
+ const size_t len = wkbstring.length();
*size = len;
@@ -2237,14 +2230,13 @@
- return NULL;
catch (...)
- return NULL;
+ return NULL;
int
@@ -2258,8 +2250,8 @@
catch (...)
- return NULL;
+ return 0;
void
@@ -2287,8 +2279,8 @@
catch (...)
- return NULL;
+ return 0;
void
@@ -2342,11 +2334,11 @@
const geos::geom::prep::PreparedGeometry*
GEOSPrepare(const Geometry *g)
- try
+ const geos::geom::prep::PreparedGeometry* prep = NULL;
+ try
- const geos::geom::prep::PreparedGeometry* prep;
- prep = geos::geom::prep::PreparedGeometryFactory::prepare( g);
- return prep;
+ prep = geos::geom::prep::PreparedGeometryFactory::prepare(g);
@@ -2356,6 +2348,8 @@
+ return prep;
void
More information about the geos-commits
