[geos-commits] r2177 - in branches/3.0: capi source/headers/geos source/io
svn_geos at osgeo.org svn_geos at osgeo.org
Fri Aug 29 10:57:50 EDT 2008
Author: sgillies
Date: 2008-08-29 10:57:50 -0400 (Fri, 29 Aug 2008)
New Revision: 2177
   branches/3.0/capi/geos_c.cpp
   branches/3.0/source/headers/geos/io.h
   branches/3.0/source/io/Makefile.am
   branches/3.0/source/io/WKTWriter.cpp
Added CLocalizer class that switches to C locale and restores to the outer context's locale when deleted (#201)
Modified: branches/3.0/capi/geos_c.cpp
--- branches/3.0/capi/geos_c.cpp	2008-08-29 00:30:47 UTC (rev 2176)
+++ branches/3.0/capi/geos_c.cpp	2008-08-29 14:57:50 UTC (rev 2177)
@@ -32,6 +32,7 @@
 #include <geos/io/WKBReader.h>
 #include <geos/io/WKTWriter.h>
 #include <geos/io/WKBWriter.h>
+#include <geos/io/CLocalizer.h>
 #include <geos/simplify/DouglasPeuckerSimplifier.h>
 #include <geos/simplify/TopologyPreservingSimplifier.h>
 #include <geos/operation/valid/IsValidOp.h>
@@ -83,6 +84,7 @@
 using geos::io::WKTWriter;
 using geos::io::WKBReader;
 using geos::io::WKBWriter;
+using geos::io::CLocalizer;
 using geos::operation::overlay::OverlayOp;
 using geos::operation::overlay::overlayOp;
@@ -501,7 +503,7 @@
 Geometry *
 GEOSGeomFromWKT(const char *wkt)
-	using geos::io::WKTReader;
+    CLocalizer clocale;
 	try
 		WKTReader r(geomFactory);
@@ -525,6 +527,7 @@
 char *
 GEOSGeomToWKT(const Geometry *g1)
 	try
 		std::string s = g1->toString();
@@ -1914,6 +1917,7 @@
 Geometry*
 GEOSWKTReader_read(WKTReader *reader, const char *wkt)
 	try
 		const std::string wktstring = std::string(wkt);
@@ -1977,6 +1981,7 @@
 char*
 GEOSWKTWriter_write(WKTWriter *writer, const Geometry *geom)
 	try
 		std::string s = writer->write(geom);
Modified: branches/3.0/source/headers/geos/io.h
--- branches/3.0/source/headers/geos/io.h	2008-08-29 00:30:47 UTC (rev 2176)
+++ branches/3.0/source/headers/geos/io.h	2008-08-29 14:57:50 UTC (rev 2177)
@@ -55,6 +55,7 @@
 #include <geos/io/WKTReader.h>
 //#include <geos/io/Writer.h>
 #ifdef __GNUC__
Modified: branches/3.0/source/io/Makefile.am
--- branches/3.0/source/io/Makefile.am	2008-08-29 00:30:47 UTC (rev 2176)
+++ branches/3.0/source/io/Makefile.am	2008-08-29 14:57:50 UTC (rev 2177)
@@ -14,7 +14,8 @@
 	WKBReader.cpp \
 	WKBWriter.cpp \
 	Writer.cpp \
-	Unload.cpp
+	Unload.cpp \
+	CLocalizer.cpp
 libio_la_LIBADD =
Modified: branches/3.0/source/io/WKTWriter.cpp
--- branches/3.0/source/io/WKTWriter.cpp	2008-08-29 00:30:47 UTC (rev 2176)
+++ branches/3.0/source/io/WKTWriter.cpp	2008-08-29 14:57:50 UTC (rev 2177)
@@ -54,6 +54,7 @@
 WKTWriter::toLineString(const CoordinateSequence& seq)
 	stringstream buf("LINESTRING ", ios_base::in|ios_base::out);
+    buf.imbue(std::locale("C"));
 	unsigned int npts = seq.getSize();
 	if ( npts == 0 )
@@ -81,6 +82,7 @@
 WKTWriter::toLineString(const Coordinate& p0, const Coordinate& p1)
 	stringstream ret("LINESTRING (", ios_base::in|ios_base::out);
+    ret.imbue(std::locale("C"));
 	ret << p0.x << " " << p0.y;
 #if PRINT_Z
 	ret << " " << p0.z;
@@ -98,6 +100,7 @@
 WKTWriter::toPoint(const Coordinate& p0)
 	stringstream ret("POINT (", ios_base::in|ios_base::out);
 #if PRINT_Z
 	ret << p0.x << " " << p0.y  << " " << p0.z << " )";
 #else
More information about the geos-commits mailing list
