[geos-commits] r2760 - in trunk/tests: unit/operation/valid
xmltester
svn_geos at osgeo.org
Thu Dec 3 09:48:09 EST 2009
Author: mloskot
Date: 2009-12-03 09:48:08 -0500 (Thu, 03 Dec 2009)
New Revision: 2760
trunk/tests/unit/operation/valid/IsValidTest.cpp
trunk/tests/unit/operation/valid/ValidClosedRingTest.cpp
trunk/tests/xmltester/XMLTester.cpp
* Added Visual C++ pragmas.
* Fixed implicit pointer tests for 0 (save typing is a myth, be explicit is bless).
Modified: trunk/tests/unit/operation/valid/IsValidTest.cpp
--- trunk/tests/unit/operation/valid/IsValidTest.cpp 2009-12-03 13:25:57 UTC (rev 2759)
+++ trunk/tests/unit/operation/valid/IsValidTest.cpp 2009-12-03 14:48:08 UTC (rev 2760)
@@ -71,7 +71,7 @@
ensure_equals( err->getErrorType(),
TopologyValidationError::eInvalidCoordinate );
- ensure(ISNAN(errCoord.y));
+ ensure(0 != ISNAN(errCoord.y));
ensure_equals(valid, false);
Modified: trunk/tests/unit/operation/valid/ValidClosedRingTest.cpp
--- trunk/tests/unit/operation/valid/ValidClosedRingTest.cpp 2009-12-03 13:25:57 UTC (rev 2759)
+++ trunk/tests/unit/operation/valid/ValidClosedRingTest.cpp 2009-12-03 14:48:08 UTC (rev 2760)
@@ -95,7 +95,7 @@
GeomPtr geom = fromWKT("LINEARRING (0 0, 0 10, 10 10, 10 0, 0 0)");
LinearRing* ring_chk = dynamic_cast<LinearRing*>(geom.get());
- ensure(ring_chk);
+ ensure(0 != ring_chk);
LinearRing& ring = *ring_chk;
//cout << ring.toString() << endl;
updateNonClosedRing(ring);
@@ -119,11 +119,11 @@
GeomPtr geom = fromWKT("POLYGON ((0 0, 0 10, 10 10, 10 0, 0 0), (1 1, 2 1, 2 2, 1 2, 1 1) ))");
Polygon* poly = dynamic_cast<Polygon*>(geom.get());
- ensure(poly);
+ ensure(0 != poly);
const LineString* ring = poly->getExteriorRing();
const LinearRing* lr = dynamic_cast<const LinearRing*>(ring);
- ensure(lr);
+ ensure(0 != lr);
LinearRing* nclr = const_cast<LinearRing*>(lr);
@@ -138,11 +138,11 @@
- ensure(poly);
const LineString* ring = poly->getInteriorRingN(0);
- ensure(lr);
+ ensure(0 != lr);
Modified: trunk/tests/xmltester/XMLTester.cpp
--- trunk/tests/xmltester/XMLTester.cpp 2009-12-03 13:25:57 UTC (rev 2759)
+++ trunk/tests/xmltester/XMLTester.cpp 2009-12-03 14:48:08 UTC (rev 2760)
@@ -22,6 +22,7 @@
//#include <stdlib.h>
# include <crtdbg.h>
# endif
+#pragma warning(disable : 4127)
#endif
#include <geos/geom/Point.h>
@@ -604,7 +605,7 @@
geomAin = trimBlanks(geomAin);
gA = parseGeometry(geomAin, "Geometry A");
- if ( (el = node->FirstChild("b")) )
+ if ( 0 != (el = node->FirstChild("b")) )
geomBin = el->FirstChild()->Value();
geomBin = trimBlanks(geomBin);
@@ -1140,7 +1141,7 @@
else if (opName=="iswithindistance")
- float dist=std::atof(opArg3.c_str());
+ double dist=std::atof(opArg3.c_str());
if (gA->isWithinDistance(gB, dist)) {
actual_result="true";
} else {
@@ -1370,7 +1371,7 @@
if ((!success && verbose) || verbose > 1)
- printTest(success, expected_result, actual_result);
+ printTest(!!success, expected_result, actual_result);
if (test_predicates && gB && gA) {
More information about the geos-commits
