[geos-commits] r2761 - in trunk/tests/unit: algorithm capi geom io
	linearref noding
    svn_geos at osgeo.org
    Thu Dec  3 13:56:26 EST 2009
Author: mloskot
Date: 2009-12-03 13:56:25 -0500 (Thu, 03 Dec 2009)
New Revision: 2761
   trunk/tests/unit/algorithm/RobustLineIntersectionTest.cpp
   trunk/tests/unit/capi/GEOSBufferTest.cpp
   trunk/tests/unit/capi/GEOSGeomFromWKBTest.cpp
   trunk/tests/unit/capi/GEOSPreparedGeometryTest.cpp
   trunk/tests/unit/geom/CoordinateTest.cpp
   trunk/tests/unit/geom/GeometryFactoryTest.cpp
   trunk/tests/unit/geom/IntersectionMatrixTest.cpp
   trunk/tests/unit/geom/LinearRingTest.cpp
   trunk/tests/unit/geom/MultiPointTest.cpp
   trunk/tests/unit/geom/PolygonTest.cpp
   trunk/tests/unit/geom/TriangleTest.cpp
   trunk/tests/unit/io/ByteOrderValuesTest.cpp
   trunk/tests/unit/linearref/LengthIndexedLineTest.cpp
   trunk/tests/unit/noding/BasicSegmentStringTest.cpp
   trunk/tests/unit/noding/NodedSegmentStringTest.cpp
Part 1 of larger changeset - tests/unit:
* Declare noncopyable types as such explicitly (Ticket #304).
* Cleanup.
* Unified EOL to LF.
Modified: trunk/tests/unit/algorithm/RobustLineIntersectionTest.cpp
--- trunk/tests/unit/algorithm/RobustLineIntersectionTest.cpp	2009-12-03 14:48:08 UTC (rev 2760)
+++ trunk/tests/unit/algorithm/RobustLineIntersectionTest.cpp	2009-12-03 18:56:25 UTC (rev 2761)
@@ -123,8 +123,8 @@
 		LineString* l1ptr = dynamic_cast<LineString*>(g1.get());
 		LineString* l2ptr = dynamic_cast<LineString*>(g2.get());
-		ensure(l1ptr);
-		ensure(l2ptr);
+		ensure(0 != l1ptr);
+		ensure(0 != l2ptr);
 		LineString& l1 = *l1ptr;
 		LineString& l2 = *l2ptr;
@@ -160,8 +160,8 @@
-		ensure(l1ptr);
-		ensure(l2ptr);
Modified: trunk/tests/unit/capi/GEOSBufferTest.cpp
--- trunk/tests/unit/capi/GEOSBufferTest.cpp	2009-12-03 14:48:08 UTC (rev 2760)
+++ trunk/tests/unit/capi/GEOSBufferTest.cpp	2009-12-03 18:56:25 UTC (rev 2761)
@@ -146,7 +146,7 @@
         ensure_equals(GEOSGetNumCoordinates(geom2_), 7);
-        ensure(GEOSArea(geom2_, &area_));
+        ensure(0 != GEOSArea(geom2_, &area_));
         ensure_distance(area_, 161.803, 0.001);
@@ -168,7 +168,7 @@
         ensure_equals(GEOSGetNumCoordinates(geom2_), 11);
         ensure_distance(area_, 182.514, 0.001);
@@ -190,7 +190,7 @@
         ensure_distance(area_, 211.803, 0.001);
@@ -213,7 +213,7 @@
         ensure_equals(GEOSGetNumCoordinates(geom2_), 5);
         ensure_distance(area_, 111.803, 0.001);
@@ -235,7 +235,7 @@
         ensure_distance(area_, 50.0, 0.001);
         ensure_equals(std::string(wkt_), std::string(
@@ -261,7 +261,7 @@
         ensure_distance(area_, 150.0, 0.001);
@@ -288,7 +288,7 @@
         ensure_equals(GEOSGetNumCoordinates(geom2_), 29);
         ensure_distance(area_, 244.615, 0.001);
@@ -312,7 +312,7 @@
         ensure_equals(GEOSGetNumCoordinates(geom2_), 9);
         ensure_distance(area_, 250.0, 0.001);
@@ -339,7 +339,7 @@
         ensure_equals(GEOSGetNumCoordinates(geom2_), 10);
         ensure_distance(area_, 237.5, 0.001);
@@ -367,7 +367,7 @@
@@ -393,7 +393,7 @@
         ensure_distance(area_, 127.452, 0.001);
@@ -416,7 +416,7 @@
         ensure_equals(GEOSGetNumCoordinates(geom2_), 6);
         ensure_distance(area_, 139.043, 0.001);
@@ -439,7 +439,7 @@
         ensure_equals(GEOSGetNumCoordinates(geom2_), 4);
         ensure_distance(area_, 141.598, 0.001);
Modified: trunk/tests/unit/capi/GEOSGeomFromWKBTest.cpp
--- trunk/tests/unit/capi/GEOSGeomFromWKBTest.cpp	2009-12-03 14:48:08 UTC (rev 2760)
+++ trunk/tests/unit/capi/GEOSGeomFromWKBTest.cpp	2009-12-03 18:56:25 UTC (rev 2761)
@@ -65,6 +65,7 @@
             ensure("GEOSGeomFromWKB_buf failed to create geometry", 0 != geom1_ );
             // TODO: Update test to compare with WKT-based geometry
+            (void)wkt;
             //       ATM, some XYZ and XYZM geometries fail
             //geom2_ = GEOSWKTReader_read(reader_, wkt.c_str());
             //ensure ( 0 != geom2_ );
Modified: trunk/tests/unit/capi/GEOSPreparedGeometryTest.cpp
--- trunk/tests/unit/capi/GEOSPreparedGeometryTest.cpp	2009-12-03 14:48:08 UTC (rev 2760)
+++ trunk/tests/unit/capi/GEOSPreparedGeometryTest.cpp	2009-12-03 18:56:25 UTC (rev 2761)
@@ -82,7 +82,7 @@
         // docs say so
         //geom1_ = 0;
-        ensure(prepGeom1_);
+        ensure(0 != prepGeom1_);
@@ -102,7 +102,7 @@
     // docs say so
     //geom1_ = 0;
     int ret = GEOSPreparedContainsProperly(prepGeom1_, geom2_);
     ensure_equals(ret, 1);
@@ -125,7 +125,7 @@
     // docs say so
     //geom1_ = 0;
     ensure_equals(ret, 0);
Modified: trunk/tests/unit/geom/CoordinateTest.cpp
--- trunk/tests/unit/geom/CoordinateTest.cpp	2009-12-03 14:48:08 UTC (rev 2760)
+++ trunk/tests/unit/geom/CoordinateTest.cpp	2009-12-03 18:56:25 UTC (rev 2761)
@@ -22,6 +22,10 @@
         test_coordinate_data()
             : x(1.234), y(2.345), z(3.456)
+    private:
+        // Declare type as noncopyable
+        test_coordinate_data(test_coordinate_data const& other);
+        test_coordinate_data& operator=(test_coordinate_data const& rhs);
     typedef test_group<test_coordinate_data> group;
@@ -50,7 +54,7 @@
         geos::geom::Coordinate coord;
         ensure_equals( coord.x, 0.0 );
         ensure_equals( coord.y, 0.0 );
-        ensure( ISNAN( coord.z ) );
+        ensure(0 != ISNAN( coord.z ) );
     // Test of copy constructor and assignment operator
@@ -172,16 +176,16 @@
         // Make it null and check
         not_null_coord.setNull();
-        ensure( ISNAN( not_null_coord.x ) );
-        ensure( ISNAN( not_null_coord.y ) );
-        ensure( ISNAN( not_null_coord.z ) );
+        ensure( 0 != ISNAN( not_null_coord.x ) );
+        ensure( 0 != ISNAN( not_null_coord.y ) );
+        ensure( 0 != ISNAN( not_null_coord.z ) );
         // Build in static null instance
         geos::geom::Coordinate null_coord;
         null_coord = geos::geom::Coordinate::getNull();
-        ensure( ISNAN( null_coord.x ) );
-        ensure( ISNAN( null_coord.y ) );
-        ensure( ISNAN( null_coord.z ) );
+        ensure( 0 != ISNAN( null_coord.x ) );
+        ensure( 0 != ISNAN( null_coord.y ) );
+        ensure( 0 != ISNAN( null_coord.z ) );
 } // namespace tut
Modified: trunk/tests/unit/geom/GeometryFactoryTest.cpp
--- trunk/tests/unit/geom/GeometryFactoryTest.cpp	2009-12-03 14:48:08 UTC (rev 2760)
+++ trunk/tests/unit/geom/GeometryFactoryTest.cpp	2009-12-03 18:56:25 UTC (rev 2761)
@@ -46,22 +46,26 @@
 	// Common data used by tests
-	struct test_geometryfactory_data
-		// Test data
-		const int x_;
-		const int y_;
-		const int z_;
+    struct test_geometryfactory_data
+        // Test data
+        const int x_;
+        const int y_;
+        const int z_;
-		const int srid_;
-		geos::geom::PrecisionModel pm_;
-		geos::geom::GeometryFactory factory_;
-		geos::io::WKTReader reader_;
+        const int srid_;
+        geos::geom::PrecisionModel pm_;
+        geos::geom::GeometryFactory factory_;
+        geos::io::WKTReader reader_;
-		test_geometryfactory_data()
-			: x_(5), y_(10), z_(15), srid_(666), pm_(1.0), factory_(&pm_, srid_), reader_(&factory_)
+        test_geometryfactory_data()
+            : x_(5), y_(10), z_(15), srid_(666), pm_(1.0), factory_(&pm_, srid_), reader_(&factory_)
+    private:
+        test_geometryfactory_data(const test_geometryfactory_data& other);
+        test_geometryfactory_data& operator=(const test_geometryfactory_data& rhs);
 	typedef test_group<test_geometryfactory_data> group;
 	typedef group::object object;
Modified: trunk/tests/unit/geom/IntersectionMatrixTest.cpp
--- trunk/tests/unit/geom/IntersectionMatrixTest.cpp	2009-12-03 14:48:08 UTC (rev 2760)
+++ trunk/tests/unit/geom/IntersectionMatrixTest.cpp	2009-12-03 18:56:25 UTC (rev 2761)
@@ -19,17 +19,21 @@
     // Common data used by test cases
     struct test_intersectionmatrix_data
-		typedef geos::geom::IntersectionMatrix* MatrixPtr;
-		typedef geos::geom::IntersectionMatrix const* MatrixCPtr;
+        typedef geos::geom::IntersectionMatrix* MatrixPtr;
+        typedef geos::geom::IntersectionMatrix const* MatrixCPtr;
-		const std::string pattern_false_;
-		geos::geom::IntersectionMatrix im_;
+        const std::string pattern_false_;
+        geos::geom::IntersectionMatrix im_;
-		test_intersectionmatrix_data()
-			: pattern_false_("FFFFFFFFF"),im_(pattern_false_)
+        test_intersectionmatrix_data()
+            : pattern_false_("FFFFFFFFF"),im_(pattern_false_)
+    private:
+        test_intersectionmatrix_data(const test_intersectionmatrix_data& other);
+        test_intersectionmatrix_data& operator=(const test_intersectionmatrix_data& rhs);
     typedef test_group<test_intersectionmatrix_data> group;
Modified: trunk/tests/unit/geom/LinearRingTest.cpp
--- trunk/tests/unit/geom/LinearRingTest.cpp	2009-12-03 14:48:08 UTC (rev 2760)
+++ trunk/tests/unit/geom/LinearRingTest.cpp	2009-12-03 18:56:25 UTC (rev 2761)
@@ -62,7 +62,12 @@
 		~test_linearring_data()
 			factory_.destroyGeometry(ring_);
+    private:
+        test_linearring_data(const test_linearring_data& other);
+        test_linearring_data& operator=(const test_linearring_data& rhs);
 	typedef test_group<test_linearring_data> group;
Modified: trunk/tests/unit/geom/MultiPointTest.cpp
--- trunk/tests/unit/geom/MultiPointTest.cpp	2009-12-03 14:48:08 UTC (rev 2760)
+++ trunk/tests/unit/geom/MultiPointTest.cpp	2009-12-03 18:56:25 UTC (rev 2761)
@@ -50,6 +50,11 @@
 			factory_.destroyGeometry(mp_);
+    private:
+        test_multipoint_data(const test_multipoint_data& other);
+        test_multipoint_data& operator=(const test_multipoint_data& rhs);
 	typedef test_group<test_multipoint_data> group;
Modified: trunk/tests/unit/geom/PolygonTest.cpp
--- trunk/tests/unit/geom/PolygonTest.cpp	2009-12-03 14:48:08 UTC (rev 2760)
+++ trunk/tests/unit/geom/PolygonTest.cpp	2009-12-03 18:56:25 UTC (rev 2761)
@@ -53,11 +53,16 @@
 			poly_ = static_cast<PolygonPtr>(geo);
-		~test_polygon_data()
-			// FREE MEMORY
-			factory_.destroyGeometry(poly_);
+        ~test_polygon_data()
+            // FREE MEMORY
+            factory_.destroyGeometry(poly_);
+    private:
+        test_polygon_data(const test_polygon_data& other);
+        test_polygon_data& operator=(const test_polygon_data& rhs);
     typedef test_group<test_polygon_data> group;
Modified: trunk/tests/unit/geom/TriangleTest.cpp
--- trunk/tests/unit/geom/TriangleTest.cpp	2009-12-03 14:48:08 UTC (rev 2760)
+++ trunk/tests/unit/geom/TriangleTest.cpp	2009-12-03 18:56:25 UTC (rev 2761)
@@ -113,6 +113,6 @@
 		ensure( fabs(center.x - 6.0) < 1e-15 );
 		ensure( center.y > 4.2 );
 		ensure( center.y < 4.3 );
-		ensure( ISNAN( center.z ) );
+		ensure( 0 != ISNAN( center.z ) );
 } // namespace tut
Modified: trunk/tests/unit/io/ByteOrderValuesTest.cpp
--- trunk/tests/unit/io/ByteOrderValuesTest.cpp	2009-12-03 14:48:08 UTC (rev 2760)
+++ trunk/tests/unit/io/ByteOrderValuesTest.cpp	2009-12-03 18:56:25 UTC (rev 2761)
@@ -128,8 +128,7 @@
 		ensure("putLong big endian[6]", buf[6] == 0);
 		ensure("putLong big endian[7]", buf[7] == 2);
-		out = ByteOrderValues::getLong(buf,
-				ByteOrderValues::ENDIAN_BIG);
+		out = static_cast<long>(ByteOrderValues::getLong(buf, ByteOrderValues::ENDIAN_BIG));
 		ensure_equals("getLong big endian", out, in);
 		ByteOrderValues::putLong(in, buf,
@@ -143,8 +142,7 @@
 		ensure("putLong little endian[6]", buf[6] == 0);
 		ensure("putLong little endian[7]", buf[7] == 0);
-				ByteOrderValues::ENDIAN_LITTLE);
+		out = static_cast<long>(ByteOrderValues::getLong(buf, ByteOrderValues::ENDIAN_LITTLE));
 		ensure_equals("getLong little endian", out, in);
Modified: trunk/tests/unit/linearref/LengthIndexedLineTest.cpp
--- trunk/tests/unit/linearref/LengthIndexedLineTest.cpp	2009-12-03 14:48:08 UTC (rev 2760)
+++ trunk/tests/unit/linearref/LengthIndexedLineTest.cpp	2009-12-03 18:56:25 UTC (rev 2761)
@@ -411,7 +411,7 @@
     LengthIndexedLine indexedLine(linearGeom.get());
     double projIndex = indexedLine.project(Coordinate(5, 5));
     Coordinate projPt = indexedLine.extractPoint(projIndex);
-    ensure(ISNAN(projPt.z));
+    ensure(0 != ISNAN(projPt.z));
Modified: trunk/tests/unit/noding/BasicSegmentStringTest.cpp
--- trunk/tests/unit/noding/BasicSegmentStringTest.cpp	2009-12-03 14:48:08 UTC (rev 2760)
+++ trunk/tests/unit/noding/BasicSegmentStringTest.cpp	2009-12-03 18:56:25 UTC (rev 2761)
@@ -66,7 +66,7 @@
     	CoordinateSequenceAutoPtr cs(csFactory->create(0, 2));
-	ensure(cs.get());
+	ensure(0 != cs.get());
 	geos::geom::Coordinate c0(0, 0);
 	geos::geom::Coordinate c1(0, 0);
@@ -77,7 +77,7 @@
 	ensure_equals(cs->size(), 2u);
 	SegmentStringAutoPtr ss(makeSegmentString(cs.get()));
-	ensure(ss.get());
+	ensure(0 != ss.get());
 	ensure_equals(ss->size(), 2u);
@@ -109,7 +109,7 @@
-	ensure(cs.get());
 	geos::geom::Coordinate c1(1, 0);
@@ -120,7 +120,7 @@
-	ensure(ss.get());
@@ -145,7 +145,7 @@
-	ensure(cs.get());
@@ -159,7 +159,7 @@
 	ensure_equals(cs->size(), 4u);
-	ensure(ss.get());
 	ensure_equals(ss->size(), 4u);
@@ -203,7 +203,7 @@
 		catch (...) {
 			testPassed = false;
-		ensure(testPassed);
+		ensure( 0 != testPassed);
Modified: trunk/tests/unit/noding/NodedSegmentStringTest.cpp
--- trunk/tests/unit/noding/NodedSegmentStringTest.cpp	2009-12-03 14:48:08 UTC (rev 2760)
+++ trunk/tests/unit/noding/NodedSegmentStringTest.cpp	2009-12-03 18:56:25 UTC (rev 2761)
@@ -66,7 +66,7 @@
-        ensure(cs.get());
@@ -77,7 +77,7 @@
-        ensure(ss.get());
@@ -113,7 +113,7 @@
-    ensure(cs.get());
@@ -124,7 +124,7 @@
-    ensure(ss.get());
@@ -150,7 +150,7 @@
-    ensure(cs.get());
@@ -164,7 +164,7 @@
-    ensure(ss.get());
@@ -209,7 +209,7 @@
         catch (...) {
             testPassed = false;
     // test adding intersections
More information about the geos-commits
