[geos-commits] r2823 - trunk
svn_geos at osgeo.org
Fri Dec 11 08:17:02 EST 2009
Author: strk
Date: 2009-12-11 08:17:01 -0500 (Fri, 11 Dec 2009)
New Revision: 2823
trunk/ChangeLog
Updated
Modified: trunk/ChangeLog
--- trunk/ChangeLog 2009-12-11 13:10:32 UTC (rev 2822)
+++ trunk/ChangeLog 2009-12-11 13:17:01 UTC (rev 2823)
@@ -1,44 +1,70 @@
-2009-12-08 21:40 mloskot
+2009-12-11 13:10 Sandro Santilli <strk at keybit.net>
- * tests/geostest, tests/thread: Updated svn:ignore patterns
+ * [r2822] source/geom/prep/BasicPreparedGeometry.cpp: Fix memory
+ leak in BasicPreparedGeometry::isAnyTargetComponentInTest (issue
+ #308) and drop Coordinate copies from it.
-2009-12-08 21:39 mloskot
+2009-12-09 11:10 Mateusz Loskot <mateusz at loskot.net>
- * build/msvc10/Makefile.am: build/msvc10: fixed list of EXTRA_DIST
- files
+ * [r2821] build/msvc10/geos_lib/geos_lib.vcxproj: Fixed generation
+ of platform.h as pre-build step of GEOS lib project for Visual
+ C++
-2009-12-08 17:51 strk
+2009-12-09 11:05 Mateusz Loskot <mateusz at loskot.net>
- * tests/geostest/.deps/geostest.Po: This shouldn't be in the
- repository !
+ * [r2820] build/msvc80/geos_lib/geos_lib.vcproj,
+ build/msvc90/geos_lib/geos_lib.vcproj: * Fixed generation of
+ platform.h as pre-build step of GEOS lib project for Visual C++
+ 2005 and 2008
+ * Added missing headers.
-2009-12-08 17:50 strk
+2009-12-08 22:47 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/algorithm/NonRobustLineIntersector.cpp,
+ * [r2817] ChangeLog, INSTALL, configure.in: Prepare for RC4
+ release.
+2009-12-08 21:40 Mateusz Loskot <mateusz at loskot.net>
+ * [r2816] tests/geostest, tests/thread: Updated svn:ignore patterns
+2009-12-08 21:39 Mateusz Loskot <mateusz at loskot.net>
+ * [r2815] build/msvc10/Makefile.am: build/msvc10: fixed list of
+ EXTRA_DIST files
+2009-12-08 17:51 Sandro Santilli <strk at keybit.net>
+ * [r2814] tests/geostest/.deps/geostest.Po: This shouldn't be in
+ the repository !
+2009-12-08 17:50 Sandro Santilli <strk at keybit.net>
+ * [r2813] source/algorithm/NonRobustLineIntersector.cpp,
source/algorithm/RobustLineIntersector.cpp: Remove
deprecated/unused files
-2009-12-08 17:42 strk
+2009-12-08 17:42 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom/prep/PreparedLineStringIntersects.h:
+ * [r2812]
+ source/headers/geos/geom/prep/PreparedLineStringIntersects.h:
Drop useless (and leaking) heap allocation exposed by the new
prepared linestring intersection test
- * source/geom/prep/PreparedLineString.cpp,
+ * [r2811] source/geom/prep/PreparedLineString.cpp,
source/headers/geos/geom/prep/PreparedLineString.h: Add missing
destructor of PreparedLineString (closes ticket #305)
-2009-12-08 17:39 strk
+2009-12-08 17:39 Sandro Santilli <strk at keybit.net>
- * tests/unit/capi/GEOSPreparedGeometryTest.cpp: Add test with
- Prepared linestrings, for the sake of testing the leak reported
- in ticket #305
+ * [r2810] tests/unit/capi/GEOSPreparedGeometryTest.cpp: Add test
+ with Prepared linestrings, for the sake of testing the leak
+ reported in ticket #305
-2009-12-06 01:05 mloskot
+2009-12-06 01:05 Mateusz Loskot <mateusz at loskot.net>
- * source/algorithm/Angle.cpp,
+ * [r2809] source/algorithm/Angle.cpp,
source/algorithm/BoundaryNodeRule.cpp,
source/algorithm/distance/DiscreteHausdorffDistance.cpp,
source/algorithm/distance/DistanceToPoint.cpp,
@@ -118,24 +144,26 @@
tests/xmltester/tinyxml/tinyxmlparser.cpp: Updated source code
files with svn:keywords property.
-2009-12-06 01:01 mloskot
+2009-12-06 01:01 Mateusz Loskot <mateusz at loskot.net>
- * build/msvc90/geos_xmltester, source: Updated svn:ignore patterns
+ * [r2808] build/msvc90/geos_xmltester, source: Updated svn:ignore
+ patterns
-2009-12-06 00:56 mloskot
+2009-12-06 00:56 Mateusz Loskot <mateusz at loskot.net>
- * build/msvc10, build/msvc10/geos_c_dll, build/msvc10/geos_lib,
- build/msvc10/geos_unit, build/msvc10/geos_xmltester,
- build/msvc80/geos_xmltester: Updated svn:ignore patterns
+ * [r2807] build/msvc10, build/msvc10/geos_c_dll,
+ build/msvc10/geos_lib, build/msvc10/geos_unit,
+ build/msvc10/geos_xmltester, build/msvc80/geos_xmltester: Updated
+ svn:ignore patterns
-2009-12-06 00:51 mloskot
+2009-12-06 00:51 Mateusz Loskot <mateusz at loskot.net>
- * configure.in: Updated configure.in after moved non-unit tests
- programs out of tests/unit (Tickets #240).
+ * [r2806] configure.in: Updated configure.in after moved non-unit
+ tests programs out of tests/unit (Tickets #240).
-2009-12-06 00:47 mloskot
+2009-12-06 00:47 Mateusz Loskot <mateusz at loskot.net>
- * tests/Makefile.am, tests/geostest, tests/geostest/.deps,
+ * [r2805] tests/Makefile.am, tests/geostest, tests/geostest/.deps,
tests/geostest/.deps/geostest.Po, tests/geostest/Makefile.am,
tests/geostest/brokengrammar, tests/geostest/geostest.c,
tests/geostest/test.expected, tests/geostest/test.wkt,
@@ -149,49 +177,52 @@
of tests/unit: geostest -> tests/geostest, threadtest ->
tests/thread, badthreadtest -> tests/thread (Ticket #240).
-2009-12-05 21:59 mloskot
+2009-12-05 21:59 Mateusz Loskot <mateusz at loskot.net>
- * configure.in: Added build/msvc80/geos_xmltester to configure.in
+ * [r2804] configure.in: Added build/msvc80/geos_xmltester to
+ configure.in
-2009-12-05 21:28 mloskot
+2009-12-05 21:28 Mateusz Loskot <mateusz at loskot.net>
- * build/msvc80/Makefile.am, build/msvc80/geos.sln,
+ * [r2803] build/msvc80/Makefile.am, build/msvc80/geos.sln,
build/msvc80/geos_xmltester,
build/msvc80/geos_xmltester/Makefile.am,
build/msvc80/geos_xmltester/geos_xmltester.vcproj: Added
geos_xmltester.vcproj project to build/msvc80
-2009-12-05 21:20 mloskot
+2009-12-05 21:20 Mateusz Loskot <mateusz at loskot.net>
- * build/msvc80/geos_c_dll/geos_c_dll.vcproj: Added GEOS_DLL_EXPORT
- to preprocessor definitions in
+ * [r2802] build/msvc80/geos_c_dll/geos_c_dll.vcproj: Added
+ GEOS_DLL_EXPORT to preprocessor definitions in
-2009-12-05 20:30 mloskot
+2009-12-05 20:30 Mateusz Loskot <mateusz at loskot.net>
- * source/linearref/ExtractLineByLocation.cpp: small cleanup
+ * [r2801] source/linearref/ExtractLineByLocation.cpp: small cleanup
-2009-12-05 20:23 mloskot
+2009-12-05 20:23 Mateusz Loskot <mateusz at loskot.net>
- * build/msvc80/geos.sln, build/msvc80/geos_c_dll/geos_c_dll.vcproj,
+ * [r2800] build/msvc80/geos.sln,
+ build/msvc80/geos_c_dll/geos_c_dll.vcproj,
build/msvc80/geos_unit/geos_unit.vcproj: Updated solution for
Visual C++ 8.0 (Visual Studio 2005) (Ticket #303)
-2009-12-05 20:21 mloskot
+2009-12-05 20:21 Mateusz Loskot <mateusz at loskot.net>
- * build/README: Updated information in README about build/msvcXY
- solutions
+ * [r2799] build/README: Updated information in README about
+ build/msvcXY solutions
-2009-12-04 17:38 mloskot
+2009-12-04 17:38 Mateusz Loskot <mateusz at loskot.net>
- * configure.in: Updated configure.in with msvc10
+ * [r2798] configure.in: Updated configure.in with msvc10
-2009-12-04 17:05 mloskot
+2009-12-04 17:05 Mateusz Loskot <mateusz at loskot.net>
- * build/Makefile.am, build/msvc10, build/msvc10/Makefile.am,
- build/msvc10/README, build/msvc10/geos.sln,
- build/msvc10/geos_c_dll, build/msvc10/geos_c_dll/Makefile.am,
+ * [r2797] build/Makefile.am, build/msvc10,
+ build/msvc10/Makefile.am, build/msvc10/README,
+ build/msvc10/geos.sln, build/msvc10/geos_c_dll,
+ build/msvc10/geos_c_dll/Makefile.am,
build/msvc10/geos_c_dll/geos_c_dll.vcxproj,
build/msvc10/geos_c_dll/geos_c_dll.vcxproj.filters,
build/msvc10/geos_lib, build/msvc10/geos_lib/Makefile.am,
@@ -207,66 +238,69 @@
solution and projects for Visual Studio 2010 (note msvc90 denotes
9.0 however msvc10 is 10 not 1.0)
-2009-12-04 15:58 mloskot
+2009-12-04 15:58 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/geos_unit.cpp: Missing svn keywords
+ * [r2796] tests/unit/geos_unit.cpp: Missing svn keywords
-2009-12-04 15:30 mloskot
+2009-12-04 15:30 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/tut/tut_exception.hpp: Small fixes to TUT.
+ * [r2795] tests/unit/tut/tut_exception.hpp: Small fixes to TUT.
-2009-12-04 15:20 mloskot
+2009-12-04 15:20 Mateusz Loskot <mateusz at loskot.net>
- * source/io/WKBReader.cpp: Replaced long with std::streampos
+ * [r2794] source/io/WKBReader.cpp: Replaced long with
+ std::streampos
-2009-12-04 15:07 mloskot
+2009-12-04 15:07 Mateusz Loskot <mateusz at loskot.net>
- * source/geom/CoordinateSequence.cpp: std::back_inserter requires
- <iterator> in geom/CoordinateSequence.cpp
+ * [r2793] source/geom/CoordinateSequence.cpp: std::back_inserter
+ requires <iterator> in geom/CoordinateSequence.cpp
-2009-12-04 13:57 mloskot
+2009-12-04 13:57 Mateusz Loskot <mateusz at loskot.net>
- * build/msvc90/geos_lib/geos_lib.vcproj: Updated Visual C++ 9.0
- project
+ * [r2792] build/msvc90/geos_lib/geos_lib.vcproj: Updated Visual C++
+ 9.0 project
-2009-12-03 22:51 mloskot
+2009-12-03 22:51 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/export.h: Yet another try to fix EOL in
- geos/export.h
+ * [r2791] source/headers/geos/export.h: Yet another try to fix EOL
+ in geos/export.h
-2009-12-03 20:29 mloskot
+2009-12-03 20:29 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/export.h: Removed mysterious extra tokens
- (blanks) from geos/export.h
+ * [r2790] source/headers/geos/export.h: Removed mysterious extra
+ tokens (blanks) from geos/export.h
-2009-12-03 20:16 mloskot
+2009-12-03 20:16 Mateusz Loskot <mateusz at loskot.net>
+ * [r2789] source/headers/geos/export.h: Removed mysterious extra
-2009-12-03 20:01 mloskot
+2009-12-03 20:01 Mateusz Loskot <mateusz at loskot.net>
- * build/msvc90/geos_unit/geos_unit.vcproj: Updated Visual C++
- project geos_unit.vcproj
+ * [r2788] build/msvc90/geos_unit/geos_unit.vcproj: Updated Visual
+ C++ project geos_unit.vcproj
-2009-12-03 19:59 mloskot
+2009-12-03 19:59 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/platform.h.vc, source/headers/geos/timeval.h:
- Part 26 of larger changeset - source/headers:
+ * [r2787] source/headers/geos/platform.h.vc,
+ source/headers/geos/timeval.h: Part 26 of larger changeset -
+ source/headers:
* Refine FINITE macro - pseudo-POSIX layer in Visual C++ does not
offer long double version of finite()
* Tidy up.
-2009-12-03 19:57 mloskot
+2009-12-03 19:57 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/util/UniqueCoordinateArrayFilter.h: Part 25
- of larger changeset - source/headers/geos/util:
+ * [r2786] source/headers/geos/util/UniqueCoordinateArrayFilter.h:
+ Part 25 of larger changeset - source/headers/geos/util:
* Declare noncopyable types as such explicitly (Ticket #304).
* Tidy up.
-2009-12-03 19:55 mloskot
+2009-12-03 19:55 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/simplify/DouglasPeuckerLineSimplifier.h,
+ * [r2785]
+ source/headers/geos/simplify/DouglasPeuckerLineSimplifier.h,
source/headers/geos/simplify/DouglasPeuckerSimplifier.h,
source/headers/geos/simplify/LineSegmentIndex.h,
source/headers/geos/simplify/TaggedLineSegment.h,
@@ -278,32 +312,35 @@
* Tidy up.
-2009-12-03 19:52 mloskot
+2009-12-03 19:52 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/planargraph/Subgraph.h: Part 23 of larger
- changeset - source/headers/geos/planargraph
+ * [r2784] source/headers/geos/planargraph/Subgraph.h: Part 23 of
+ larger changeset - source/headers/geos/planargraph
* Tidy up.
-2009-12-03 19:51 mloskot
+2009-12-03 19:51 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/planargraph/algorithm/ConnectedSubgraphFinder.h:
+ * [r2783]
+ source/headers/geos/planargraph/algorithm/ConnectedSubgraphFinder.h:
Part 22 of larger changeset -
source/headers/geos/planargraph/algorithm:
* Tidy up.
-2009-12-03 19:50 mloskot
+2009-12-03 19:50 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/operation/valid/ConnectedInteriorTester.h:
+ * [r2782]
+ source/headers/geos/operation/valid/ConnectedInteriorTester.h:
Part 21 of larger changeset -
source/headers/geos/operation/valid:
* Tidy up.
-2009-12-03 19:48 mloskot
+2009-12-03 19:48 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/operation/predicate/RectangleContains.h,
+ * [r2781]
+ source/headers/geos/operation/predicate/RectangleContains.h,
source/headers/geos/operation/predicate/RectangleIntersects.h:
Part 20 of larger changeset -
source/headers/geos/operation/overlay:
@@ -311,9 +348,9 @@
* Unified EOL and style.
* Tidy up.
-2009-12-03 19:46 mloskot
+2009-12-03 19:46 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/operation/overlay/ElevationMatrix.h,
+ * [r2780] source/headers/geos/operation/overlay/ElevationMatrix.h,
source/headers/geos/operation/overlay/snap/GeometrySnapper.h,
source/headers/geos/operation/overlay/snap/LineStringSnapper.h,
source/headers/geos/operation/overlay/snap/SnapIfNeededOverlayOp.h,
@@ -327,9 +364,9 @@
* Tidy up.
-2009-12-03 19:45 mloskot
+2009-12-03 19:45 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/operation/buffer/BufferBuilder.h,
+ * [r2779] source/headers/geos/operation/buffer/BufferBuilder.h,
source/headers/geos/operation/buffer/OffsetCurveBuilder.h,
source/headers/geos/operation/buffer/OffsetCurveSetBuilder.h:
Part 18of larger changeset -
@@ -338,9 +375,9 @@
* Tidy up.
-2009-12-03 19:44 mloskot
+2009-12-03 19:44 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/noding/FastNodingValidator.h,
+ * [r2778] source/headers/geos/noding/FastNodingValidator.h,
source/headers/geos/noding/IntersectionAdder.h,
source/headers/geos/noding/IntersectionFinderAdder.h,
source/headers/geos/noding/MCIndexNoder.h,
@@ -360,9 +397,9 @@
* Tidy up.
-2009-12-03 19:41 mloskot
+2009-12-03 19:41 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/noding/snapround/HotPixel.h,
+ * [r2777] source/headers/geos/noding/snapround/HotPixel.h,
source/headers/geos/noding/snapround/MCIndexPointSnapper.h,
source/headers/geos/noding/snapround/MCIndexSnapRounder.h,
source/headers/geos/noding/snapround/SimpleSnapRounder.h: Part 16
@@ -372,41 +409,42 @@
* Tidy up.
-2009-12-03 19:39 mloskot
+2009-12-03 19:39 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/linearref/LinearIterator.h: Part 15 of larger
- changeset - source/headers/geos/linearref:
+ * [r2776] source/headers/geos/linearref/LinearIterator.h: Part 15
+ of larger changeset - source/headers/geos/linearref:
* Tidy up.
-2009-12-03 19:38 mloskot
+2009-12-03 19:38 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/io/StringTokenizer.h,
+ * [r2775] source/headers/geos/io/StringTokenizer.h,
source/headers/geos/io/WKBReader.h: Part 14 of larger changeset -
source/headers/geos/io:
* Tidy up.
-2009-12-03 19:36 mloskot
+2009-12-03 19:36 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/index/chain/MonotoneChain.h: Part 13 of
- larger changeset - source/headers/geos/index/chain:
+ * [r2774] source/headers/geos/index/chain/MonotoneChain.h: Part 13
+ of larger changeset - source/headers/geos/index/chain:
* Added Visual C++ pragmas.
* Tidy up.
- * source/headers/geos/geomgraph/GeometryGraph.h,
+ * [r2773] source/headers/geos/geomgraph/GeometryGraph.h,
source/headers/geos/geomgraph/NodeMap.h: Part 12 of larger
changeset - source/headers/geos/geomgraph:
* Tidy up.
-2009-12-03 19:30 mloskot
+2009-12-03 19:30 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/geom/util/ComponentCoordinateExtracter.h,
+ * [r2772]
+ source/headers/geos/geom/util/ComponentCoordinateExtracter.h,
source/headers/geos/geom/util/GeometryCombiner.h,
source/headers/geos/geom/util/GeometryTransformer.h,
source/headers/geos/geom/util/LinearComponentExtracter.h,
@@ -417,18 +455,19 @@
* Tidy up.
-2009-12-03 19:29 mloskot
+2009-12-03 19:29 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/geom/prep/PreparedLineStringIntersects.h,
+ * [r2771]
+ source/headers/geos/geom/prep/PreparedLineStringIntersects.h,
source/headers/geos/geom/prep/PreparedPolygonPredicate.h: Part
10of larger changeset - source/headers/geos/geom/prep:
* Tidy up.
-2009-12-03 19:27 mloskot
+2009-12-03 19:27 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/algorithm/RayCrossingCounter.h,
+ * [r2770] source/headers/geos/algorithm/RayCrossingCounter.h,
source/headers/geos/algorithm/distance/DiscreteHausdorffDistance.h,
source/headers/geos/algorithm/locate/IndexedPointInAreaLocator.h:
Part 9 of larger changeset - source/headers/geos/algorithm:
@@ -436,53 +475,53 @@
* Tidy up.
-2009-12-03 19:24 mloskot
+2009-12-03 19:24 Mateusz Loskot <mateusz at loskot.net>
- * source/geomgraph/PlanarGraph.cpp: Part 7 of larger changeset -
- source/geomgraph:
+ * [r2769] source/geomgraph/PlanarGraph.cpp: Part 7 of larger
+ changeset - source/geomgraph:
* Fixed incorrect int to string conversion.
-2009-12-03 19:23 mloskot
+2009-12-03 19:23 Mateusz Loskot <mateusz at loskot.net>
- * source/index/intervalrtree/SortedPackedIntervalRTree.cpp: Part 7
- of larger changeset - source/index/intervalrtree:
+ * [r2768] source/index/intervalrtree/SortedPackedIntervalRTree.cpp:
+ Part 7 of larger changeset - source/index/intervalrtree:
* Tidy up.
-2009-12-03 19:22 mloskot
+2009-12-03 19:22 Mateusz Loskot <mateusz at loskot.net>
- * source/noding/ScaledNoder.cpp: Refined changeset r2766 - fix for
- nested classes required by GCC.
+ * [r2767] source/noding/ScaledNoder.cpp: Refined changeset r2766 -
+ fix for nested classes required by GCC.
-2009-12-03 19:14 mloskot
+2009-12-03 19:14 Mateusz Loskot <mateusz at loskot.net>
- * source/noding/OrientedCoordinateArray.cpp,
+ * [r2766] source/noding/OrientedCoordinateArray.cpp,
source/noding/ScaledNoder.cpp: Part 6 of larger changeset -
source/noding:
* Tidy up.
-2009-12-03 19:11 mloskot
+2009-12-03 19:11 Mateusz Loskot <mateusz at loskot.net>
- * source/noding/snapround/MCIndexPointSnapper.cpp: Part 5 of larger
- changeset - source/noding/snapround:
+ * [r2765] source/noding/snapround/MCIndexPointSnapper.cpp: Part 5
+ of larger changeset - source/noding/snapround:
* Tidy up.
-2009-12-03 19:03 mloskot
+2009-12-03 19:03 Mateusz Loskot <mateusz at loskot.net>
- * source/algorithm/RobustDeterminant.cpp: Part 4 of larger
+ * [r2764] source/algorithm/RobustDeterminant.cpp: Part 4 of larger
changeset - source/algorithm:
* Tidy up.
-2009-12-03 19:02 mloskot
+2009-12-03 19:02 Mateusz Loskot <mateusz at loskot.net>
- * source/operation/buffer/BufferInputLineSimplifier.h,
+ * [r2763] source/operation/buffer/BufferInputLineSimplifier.h,
source/operation/buffer/OffsetCurveBuilder.cpp,
source/operation/linemerge/LineSequencer.cpp,
source/operation/overlay/OverlayOp.cpp,
@@ -493,17 +532,17 @@
* Tidy up.
-2009-12-03 19:01 mloskot
+2009-12-03 19:01 Mateusz Loskot <mateusz at loskot.net>
- * source/simplify/TopologyPreservingSimplifier.cpp: Part 2 of
- larger changeset - source/simplify:
+ * [r2762] source/simplify/TopologyPreservingSimplifier.cpp: Part 2
+ of larger changeset - source/simplify:
* Cleanup.
* Unified EOL to LF.
-2009-12-03 18:56 mloskot
+2009-12-03 18:56 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/algorithm/RobustLineIntersectionTest.cpp,
+ * [r2761] tests/unit/algorithm/RobustLineIntersectionTest.cpp,
tests/unit/capi/GEOSBufferTest.cpp,
tests/unit/capi/GEOSGeomFromWKBTest.cpp,
tests/unit/capi/GEOSPreparedGeometryTest.cpp,
@@ -523,22 +562,23 @@
* Cleanup.
-2009-12-03 14:48 mloskot
+2009-12-03 14:48 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/operation/valid/IsValidTest.cpp,
+ * [r2760] tests/unit/operation/valid/IsValidTest.cpp,
tests/unit/operation/valid/ValidClosedRingTest.cpp,
tests/xmltester/XMLTester.cpp: * Added Visual C++ pragmas.
* Fixed implicit pointer tests for 0 (save typing is a myth, be
explicit is bless).
-2009-12-03 13:25 mloskot
+2009-12-03 13:25 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/geos_unit.cpp, tests/unit/tut/tut_restartable.hpp,
- tests/xmltester/XMLTester.h: Updated C++ TUT framework.
+ * [r2759] tests/unit/geos_unit.cpp,
+ tests/unit/tut/tut_restartable.hpp, tests/xmltester/XMLTester.h:
+ Updated C++ TUT framework.
-2009-12-01 16:16 mloskot
+2009-12-01 16:16 Mateusz Loskot <mateusz at loskot.net>
- * source/geom/util/CoordinateOperation.cpp,
+ * [r2758] source/geom/util/CoordinateOperation.cpp,
source/io/WKBReader.cpp,
source/operation/distance/DistanceOp.cpp,
source/operation/overlay/snap/SnapIfNeededOverlayOp.cpp,
@@ -546,10 +586,10 @@
encoded with lower-case hex digits, useful if combined with SQL
encode(geometry, 'hex')
-2009-12-01 15:39 mloskot
+2009-12-01 15:39 Mateusz Loskot <mateusz at loskot.net>
- * build/msvc90/geos_lib/geos_lib.vcproj, capi/geos_ts_c.cpp,
- source/geom/GeometryComponentFilter.cpp,
+ * [r2757] build/msvc90/geos_lib/geos_lib.vcproj,
+ capi/geos_ts_c.cpp, source/geom/GeometryComponentFilter.cpp,
source/geom/PrecisionModel.cpp,
source/geom/util/GeometryTransformer.cpp,
source/headers/geos/geom/BinaryOp.h,
@@ -576,25 +616,25 @@
* Replaced utility macros with disappearing ignorance template
trick.
-2009-12-01 13:05 mloskot
+2009-12-01 13:05 Mateusz Loskot <mateusz at loskot.net>
- * build/msvc90/geos_c_dll/geos_c_dll.vcproj,
+ * [r2756] build/msvc90/geos_c_dll/geos_c_dll.vcproj,
build/msvc90/geos_unit/geos_unit.vcproj,
build/msvc90/geos_xmltester/geos_xmltester.vcproj: Tweaked
projects for Visual Studio 2008
-2009-11-30 17:29 mloskot
+2009-11-30 17:29 Mateusz Loskot <mateusz at loskot.net>
- * capi/geos_ts_c.cpp, source/geomgraph/EdgeEnd.cpp,
+ * [r2755] capi/geos_ts_c.cpp, source/geomgraph/EdgeEnd.cpp,
source/headers/geos/geom/CoordinateSequenceFilter.h,
source/precision/EnhancedPrecisionOp.cpp: * GEOSFree_r should
check context handle even if its not used - nullptr may indicate
logic error.
-2009-11-30 13:55 mloskot
+2009-11-30 13:55 Mateusz Loskot <mateusz at loskot.net>
+ * [r2754] build/msvc90/geos_c_dll/geos_c_dll.vcproj,
build/msvc90/geos_xmltester/geos_xmltester.vcproj,
@@ -607,29 +647,29 @@
* Removed unreachable code.
* Removed /Wp64 option from Visual Studio 2008 projects.
-2009-11-30 12:25 mloskot
+2009-11-30 12:25 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog: Missing log.
+ * [r2753] ChangeLog: Missing log.
-2009-11-30 10:48 mloskot
+2009-11-30 10:48 Mateusz Loskot <mateusz at loskot.net>
- * build/msvc90/geos_unit/geos_unit.vcproj,
+ * [r2752] build/msvc90/geos_unit/geos_unit.vcproj,
tests/unit/linearref/LengthIndexedLineTest.cpp: * Added missing
tests to Visual Studio 2008 project
* Replaced call to isnan() missing in Visual C++ with ISNAN macro
-2009-11-29 10:09 strk
+2009-11-29 10:09 Sandro Santilli <strk at keybit.net>
- * ChangeLog: updated
+ * [r2749] ChangeLog: updated
-2009-11-26 21:42 strk
+2009-11-26 21:42 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/platform.h.in: Add ISNAN support in
+ * [r2748] source/headers/geos/platform.h.in: Add ISNAN support in
platform.h.in
-2009-11-26 21:34 strk
+2009-11-26 21:34 Sandro Santilli <strk at keybit.net>
- * source/geom/util/LinearComponentExtracter.cpp,
+ * [r2747] source/geom/util/LinearComponentExtracter.cpp,
source/geom/util/Makefile.am,
source/geom/util/PointExtracter.cpp,
source/geom/util/PolygonExtracter.cpp,
@@ -639,206 +679,216 @@
source/util/UnsupportedOperationException.cpp: Remove
unreferenced files from the repository
-2009-11-26 21:28 strk
+2009-11-26 21:28 Sandro Santilli <strk at keybit.net>
- * build/msvc90/geos_lib/geos_lib.vcproj: Remove reference to files
- not needing to go in the dll
+ * [r2746] build/msvc90/geos_lib/geos_lib.vcproj: Remove reference
+ to files not needing to go in the dll
-2009-11-26 21:21 strk
+2009-11-26 21:21 Sandro Santilli <strk at keybit.net>
- * source/geom/CoordinateSequenceFactory.cpp,
+ * [r2745] source/geom/CoordinateSequenceFactory.cpp,
source/geom/Makefile.am,
source/headers/geos/geom/CoordinateSequenceFactory.h: Put
destructor of the CoordinateSequenceFactory in an implementation
file, hopefully reducing linker confusion about RTTI (see ticket
#299)
-2009-11-26 19:49 pramsey
+2009-11-26 19:49 Paul Ramsey <pramsey at cleverelephant.ca>
- * configure.in: Add magic flags for OS/X Snow Leopard only. (#299)
+ * [r2744] configure.in: Add magic flags for OS/X Snow Leopard only.
+ (#299)
-2009-11-26 19:46 pramsey
+2009-11-26 19:46 Paul Ramsey <pramsey at cleverelephant.ca>
- * configure.in: Add vc90 xmltester target to Makefile build
+ * [r2743] configure.in: Add vc90 xmltester target to Makefile build
-2009-11-26 18:29 warmerdam
+2009-11-26 18:29 Frank Warmerdam <warmerdam at pobox.com>
- * capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp: clarify
- ownership of returned buffer from wkbwriter
+ * [r2742] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp:
+ clarify ownership of returned buffer from wkbwriter
-2009-11-26 16:32 pramsey
+2009-11-26 16:32 Paul Ramsey <pramsey at cleverelephant.ca>
- * Makefile.am, build/msvc90/Makefile.am,
+ * [r2741] Makefile.am, build/msvc90/Makefile.am,
build/msvc90/geos_xmltester/Makefile.am: Fix missing components
in tarball (#300)
-2009-11-24 18:05 strk
+2009-11-24 18:05 Sandro Santilli <strk at keybit.net>
+ * [r2736] ChangeLog: updated
-2009-11-23 18:17 strk
+2009-11-23 18:17 Sandro Santilli <strk at keybit.net>
- * tests/unit/geom/CoordinateArraySequenceFactoryTest.cpp:
+ * [r2735] tests/unit/geom/CoordinateArraySequenceFactoryTest.cpp:
Coordiante->Coordinate
-2009-11-23 18:06 strk
+2009-11-23 18:06 Sandro Santilli <strk at keybit.net>
- * source/geom/Geometry.cpp: Avoid reallocations in Union
+ * [r2734] source/geom/Geometry.cpp: Avoid reallocations in Union
short-circuit
-2009-11-20 19:58 strk
+2009-11-20 19:58 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/planargraph/NodeMap.h,
+ * [r2733] source/headers/geos/planargraph/NodeMap.h,
source/headers/geos/planargraph/PlanarGraph.h,
source/operation/linemerge/LineMerger.cpp,
source/operation/polygonize/PolygonizeGraph.cpp,
source/planargraph/NodeMap.cpp: Don't force heap allocation of
vectors for getting nodes of a NodeMap
-2009-11-19 21:30 strk
+2009-11-19 21:30 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/noding/MCIndexSegmentSetMutualIntersector.h,
+ * [r2732]
+ source/headers/geos/noding/MCIndexSegmentSetMutualIntersector.h,
source/noding/MCIndexSegmentSetMutualIntersector.cpp: Don't
heap-allocate std::vector in MCIndexSegmentSetMutualIntersector
-2009-11-19 21:06 strk
+2009-11-19 21:06 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/overlay/MaximalEdgeRing.h,
+ * [r2731] source/headers/geos/operation/overlay/MaximalEdgeRing.h,
source/headers/geos/operation/valid/ConnectedInteriorTester.h,
source/operation/overlay/MaximalEdgeRing.cpp,
source/operation/valid/ConnectedInteriorTester.cpp: Don't force
heap allocation when building edge rings for isValidOp
-2009-11-19 20:29 strk
+2009-11-19 20:29 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/polygonize/PolygonizeGraph.h,
+ * [r2730]
+ source/headers/geos/operation/polygonize/PolygonizeGraph.h,
source/operation/polygonize/Polygonizer.cpp: Don't force heap
allocation of std::vector in PolygonizeGraph when deleting
dangles (moved allocation higher, in Polygonizer, so needs a
second pass)
-2009-11-19 20:20 strk
+2009-11-19 20:20 Sandro Santilli <strk at keybit.net>
+ * [r2729]
source/operation/polygonize/PolygonizeGraph.cpp: don't
heap-allocate vectors in findLabeledEdgeRings
-2009-11-19 19:57 strk
+2009-11-19 19:57 Sandro Santilli <strk at keybit.net>
+ * [r2728]
source/headers/geos/operation/polygonize/Polygonizer.h,
source/operation/polygonize/Polygonizer.cpp: Move heap-allocation
of vector used for 'cut-lines' containment out of PolygonizeGraph
(but into Polygonizer)
-2009-11-19 19:31 strk
+2009-11-19 19:31 Sandro Santilli <strk at keybit.net>
+ * [r2727]
source/operation/polygonize/PolygonizeGraph.cpp: Don't force
heap-allocation of vectors for finding/labeling edge rings
-2009-11-19 19:19 strk
+2009-11-19 19:19 Sandro Santilli <strk at keybit.net>
+ * [r2726]
source/operation/polygonize/Polygonizer.cpp: Change
PolygonizeGraph::getEdgeRings signature so not to force heap
allocation of std::vector, update Polygonizer accordingly
-2009-11-19 19:06 strk
+2009-11-19 19:06 Sandro Santilli <strk at keybit.net>
+ * [r2725]
source/operation/polygonize/PolygonizeGraph.cpp: Do not
heap-allocate vector of Node when finding intersections
-2009-11-19 18:52 strk
+2009-11-19 18:52 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/index/strtree/AbstractNode.h,
+ * [r2724] source/headers/geos/index/strtree/AbstractNode.h,
source/index/strtree/AbstractNode.cpp: Don not allocate the
container of STRtree node childs on the heap
-2009-11-19 16:40 pramsey
+2009-11-19 16:40 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/geomgraph/index/SegmentIntersector.cpp,
+ * [r2723] source/geomgraph/index/SegmentIntersector.cpp,
tests/xmltester/XMLTester.cpp: Apply patch for --disable-cassert
compilation (#291)
-2009-11-18 18:57 pramsey
+2009-11-18 18:57 Paul Ramsey <pramsey at cleverelephant.ca>
- * HOWTO_RELEASE: Reverse the upgrade process a bit, bump up
+ * [r2720] HOWTO_RELEASE: Reverse the upgrade process a bit, bump up
revision numbers *after* release so that the repo version is
always one higher than the release version. (#287)
-2009-11-18 01:28 mloskot
+2009-11-18 01:28 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, capi/geos_c.cpp, capi/geos_ts_c.cpp: Silent warning
- thrown by Visual C++ about mixed class and struct keyword (#269)
+ * [r2717] ChangeLog, capi/geos_c.cpp, capi/geos_ts_c.cpp: Silent
+ warning thrown by Visual C++ about mixed class and struct keyword
+ (#269)
-2009-11-17 20:29 strk
+2009-11-17 20:29 Sandro Santilli <strk at keybit.net>
- * tests/unit/Makefile.am: Include capi::GEOSGeomFromWKB test in
- geos_unit build (should also distribute as side-effect)
+ * [r2716] tests/unit/Makefile.am: Include capi::GEOSGeomFromWKB
+ test in geos_unit build (should also distribute as side-effect)
-2009-11-11 23:05 strk
+2009-11-11 23:05 Sandro Santilli <strk at keybit.net>
- * HOWTO_RELEASE, Makefile.am: Change ChangeLog generation rule so
- it doesn't mess with make dist. Reflect in HOW_TO_RELEASE
+ * [r2713] HOWTO_RELEASE, Makefile.am: Change ChangeLog generation
+ rule so it doesn't mess with make dist. Reflect in HOW_TO_RELEASE
-2009-11-10 23:54 strk
+2009-11-10 23:54 Sandro Santilli <strk at keybit.net>
- * HOWTO_RELEASE, Makefile.am: Make ChangeLog target non-phony to
- keep 'distcheck' happy. Reorganize HOW_TO_RELEASE steps.
+ * [r2712] HOWTO_RELEASE, Makefile.am: Make ChangeLog target
+ non-phony to keep 'distcheck' happy. Reorganize HOW_TO_RELEASE
+ steps.
-2009-11-10 22:58 strk
+2009-11-10 22:58 Sandro Santilli <strk at keybit.net>
- * ChangeLog, HOWTO_RELEASE, NEWS: Package stuff for release
+ * [r2711] ChangeLog, HOWTO_RELEASE, NEWS: Package stuff for release
-2009-10-29 21:06 mloskot
+2009-10-29 21:06 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/operation/buffer/BufferOpTest.cpp: Testing linker
- problem with DEFAULT_QUADRANT_SEGMENT constant
+ * [r2710] tests/unit/operation/buffer/BufferOpTest.cpp: Testing
+ linker problem with DEFAULT_QUADRANT_SEGMENT constant
-2009-10-29 20:58 mloskot
+2009-10-29 20:58 Mateusz Loskot <mateusz at loskot.net>
+ * [r2709] tests/unit/operation/buffer/BufferOpTest.cpp: Testing
-2009-10-29 20:55 mloskot
+2009-10-29 20:55 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/operation/buffer/BufferOpTest.cpp: Fixed CRLF to LF in
- BufferOpTest.cpp
+ * [r2708] tests/unit/operation/buffer/BufferOpTest.cpp: Fixed CRLF
+ to LF in BufferOpTest.cpp
-2009-10-29 20:47 mloskot
+2009-10-29 20:47 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, tests/unit/operation/buffer/BufferOpTest.cpp: Missing
- include of BufferParameters.h header in BufferOpTest.cpp unit
- suite
+ * [r2707] ChangeLog, tests/unit/operation/buffer/BufferOpTest.cpp:
+ Missing include of BufferParameters.h header in BufferOpTest.cpp
+ unit suite
-2009-10-29 16:20 mloskot
+2009-10-29 16:20 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, tests/unit/operation/buffer/BufferOpTest.cpp: Added
- more test cases for buffer calculation based on A (input)
+ * [r2706] ChangeLog, tests/unit/operation/buffer/BufferOpTest.cpp:
+ Added more test cases for buffer calculation based on A (input)
geometries from XMLTester's buffer.xml and
TestBufferExternal2.xml tests.
-2009-10-29 15:11 mloskot
+2009-10-29 15:11 Mateusz Loskot <mateusz at loskot.net>
- test case for buffer of multipolygon from XMLTester's buffer.xml,
- case #25 but with custom quadrant segments
+ * [r2705] ChangeLog, tests/unit/operation/buffer/BufferOpTest.cpp:
+ Added test case for buffer of multipolygon from XMLTester's
+ buffer.xml, case #25 but with custom quadrant segments
-2009-10-29 14:24 mloskot
+2009-10-29 14:24 Mateusz Loskot <mateusz at loskot.net>
- test case for buffer of POINT(0 0) with distance 1.0 and 32
+ * [r2704] ChangeLog, tests/unit/operation/buffer/BufferOpTest.cpp:
+ Added test case for buffer of POINT(0 0) with distance 1.0 and 32
quadrant segments.
-2009-10-29 12:33 mloskot
+2009-10-29 12:33 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, build/msvc90/geos_unit/geos_unit.vcproj,
+ * [r2703] ChangeLog, build/msvc90/geos_unit/geos_unit.vcproj,
tests/unit/Makefile.am, tests/unit/operation/buffer,
tests/unit/operation/buffer/BufferOpTest.cpp: *
tests/unit/operation/buffer: added unit test case for BufferOp,
@@ -846,170 +896,175 @@
* build/msvc90/geos_unit/geos_unit.vcproj: updated Visual C++
project.
-2009-10-28 12:09 mloskot
+2009-10-28 12:09 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, build/msvc90/geos.sln, tests/xmltester/XMLTester.cpp:
- tests/xmltester/XMLTester.cpp: declare checkBufferSuccess
- function to take geometries by refernece to const
+ * [r2702] ChangeLog, build/msvc90/geos.sln,
+ tests/xmltester/XMLTester.cpp: tests/xmltester/XMLTester.cpp:
+ declare checkBufferSuccess function to take geometries by
+ refernece to const
-2009-10-25 18:48 mloskot
+2009-10-25 18:48 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, source/headers/geos/geom/Geometry.h: Fixed typo in
- getCentroid function comment in Geometry.h.
+ * [r2701] ChangeLog, source/headers/geos/geom/Geometry.h: Fixed
+ typo in getCentroid function comment in Geometry.h.
-2009-10-23 13:04 strk
+2009-10-23 13:04 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/linearref/LinearLocation.h,
+ * [r2700] source/headers/geos/linearref/LinearLocation.h,
source/linearref/LinearLocation.cpp: Have
LinearLocation::getSegment return by auto_ptr to encode ownership
transfer. Fixes leak reported in #296.
-2009-10-23 12:58 strk
+2009-10-23 12:58 Sandro Santilli <strk at keybit.net>
+ * [r2699] source/headers/geos/linearref/LinearLocation.h,
source/linearref/LinearLocation.cpp: Fix port info, add standard
protection notes
-2009-10-23 10:21 strk
+2009-10-23 10:21 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/linearref/LinearGeometryBuilder.h,
+ * [r2698] source/headers/geos/linearref/LinearGeometryBuilder.h,
source/linearref/LinearGeometryBuilder.cpp: Add destructor to
LinearGeometryBuilder fixing memory leaks there.
-2009-10-23 10:13 strk
+2009-10-23 10:13 Sandro Santilli <strk at keybit.net>
- * source/linearref/LinearGeometryBuilder.cpp: Fix memory access
- error (#283)
+ * [r2697] source/linearref/LinearGeometryBuilder.cpp: Fix memory
+ access error (#283)
-2009-10-23 10:03 strk
+2009-10-23 10:03 Sandro Santilli <strk at keybit.net>
+ * [r2696] source/headers/geos/linearref/LinearGeometryBuilder.h,
source/linearref/LinearGeometryBuilder.cpp: Fix port info for
-2009-10-23 09:53 strk
+2009-10-23 09:53 Sandro Santilli <strk at keybit.net>
+ * [r2695] source/headers/geos/linearref/LinearGeometryBuilder.h,
source/linearref/LinearGeometryBuilder.cpp: Cleanup
LinearGeometrybuilder defs and impl to match common code style,
add note about suspicious things (not written but noted that the
class seems to lack a destructor..)
-2009-10-23 09:43 strk
+2009-10-23 09:43 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/linearref/LocationIndexOfLine.h,
+ * [r2694] source/headers/geos/linearref/LocationIndexOfLine.h,
source/linearref/LengthIndexedLine.cpp,
source/linearref/LocationIndexOfLine.cpp,
tests/unit/linearref/LengthIndexedLineTest.cpp: Document
ownership of return from LocationIndexOfLine::indicesOf, fix
mismatch delete/delete[] in core and unit test
-2009-10-23 09:34 strk
+2009-10-23 09:34 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/algorithm/BoundaryNodeRule.h: Add virtual
- dtor to virtual class
+ * [r2693] source/headers/geos/algorithm/BoundaryNodeRule.h: Add
+ virtual dtor to virtual class
-2009-10-23 09:33 strk
+2009-10-23 09:33 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/tinyxml/tinyxmlparser.cpp: add some parens to
- hush gcc warning
+ * [r2692] tests/xmltester/tinyxml/tinyxmlparser.cpp: add some
+ parens to hush gcc warning
-2009-10-23 09:00 strk
+2009-10-23 09:00 Sandro Santilli <strk at keybit.net>
- * tests/unit/Makefile.am: Fix static building of C-api demo/tests
+ * [r2691] tests/unit/Makefile.am: Fix static building of C-api
+ demo/tests
-2009-10-23 08:34 strk
+2009-10-23 08:34 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/Makefile.am: Run the last
+ * [r2690] tests/xmltester/Makefile.am: Run the last
available-but-no-automatically-run test: test.xml
-2009-10-22 18:18 strk
+2009-10-22 18:18 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/tests/buffer.xml,
+ * [r2689] tests/xmltester/tests/buffer.xml,
tests/xmltester/tests/buffer_snapround.xml: Merge
buffer_snapround.xml into buffer.xml
-2009-10-22 17:13 strk
+2009-10-22 17:13 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/Makefile.am: A quick check reveals that the tests
- in buffer.xml are not really duplicated elsewhere so we run that
- test too now as part of make check
+ * [r2688] tests/xmltester/Makefile.am: A quick check reveals that
+ the tests in buffer.xml are not really duplicated elsewhere so we
+ run that test too now as part of make check
-2009-10-22 17:07 strk
+2009-10-22 17:07 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/tests/buffer.xml: Give buffer.xml cases a
+ * [r2687] tests/xmltester/tests/buffer.xml: Give buffer.xml cases a
somewhat more helpful description, fix 4 expected results after
eye-checking. This is still not automatically run case it might
contain duplicated tests from elsewhere (to be checked).
-2009-10-22 16:30 strk
+2009-10-22 16:30 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/XMLTester.cpp: Don't segfault on EOF inside <op>
- tag
+ * [r2686] tests/xmltester/XMLTester.cpp: Don't segfault on EOF
+ inside <op> tag
-2009-10-20 16:59 strk
+2009-10-20 16:59 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/index/strtree/AbstractSTRtree.h,
+ * [r2685] source/headers/geos/index/strtree/AbstractSTRtree.h,
source/index/strtree/STRtree.cpp: Commit MingW bug workaround
provided by sanak in ticket #293
-2009-10-19 13:38 mloskot
+2009-10-19 13:38 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, build/msvc90/geos_xmltester/geos_xmltester.vcproj,
+ * [r2684] ChangeLog,
+ build/msvc90/geos_xmltester/geos_xmltester.vcproj,
tests/xmltester/tests/buffer_snapround.xml: not well-formed XML,
fixed missing attribute.
-2009-10-17 14:47 strk
+2009-10-17 14:47 Sandro Santilli <strk at keybit.net>
+ * [r2683] ChangeLog: updated
-2009-10-17 14:43 strk
+2009-10-17 14:43 Sandro Santilli <strk at keybit.net>
- * NEWS: updated
+ * [r2682] NEWS: updated
-2009-10-17 14:35 strk
+2009-10-17 14:35 Sandro Santilli <strk at keybit.net>
- * source/algorithm/distance/DistanceToPoint.cpp: Half the calls to
- the virtual CoordinateSequence::getAt when computing line
- distances
+ * [r2681] source/algorithm/distance/DistanceToPoint.cpp: Half the
+ calls to the virtual CoordinateSequence::getAt when computing
+ line distances
-2009-10-17 13:40 strk
+2009-10-17 13:40 Sandro Santilli <strk at keybit.net>
- * source/geom/CoordinateArraySequence.cpp: Drop pointless asserts.
- We'd abort anyway if vector is null. For the out-of-range case
- the GNU c++ lib helps debugging with an environment variable
+ * [r2680] source/geom/CoordinateArraySequence.cpp: Drop pointless
+ asserts. We'd abort anyway if vector is null. For the
+ out-of-range case the GNU c++ lib helps debugging with an
+ environment variable
-2009-10-17 13:04 strk
+2009-10-17 13:04 Sandro Santilli <strk at keybit.net>
- * source/noding/OrientedCoordinateArray.cpp: Add note of
+ * [r2679] source/noding/OrientedCoordinateArray.cpp: Add note of
private/static nature of implemented methods
-2009-10-17 12:28 strk
+2009-10-17 12:28 Sandro Santilli <strk at keybit.net>
- * source/geom/CoordinateArraySequence.cpp, source/geom/Polygon.cpp,
+ * [r2678] source/geom/CoordinateArraySequence.cpp,
+ source/geom/Polygon.cpp,
source/headers/geos/geom/CoordinateArraySequence.h,
source/headers/geos/geom/CoordinateSequence.h: Expose a usable
toVector method for CoordinateSequence (ie: no memory management
issues). Use it from Polygon::getCoordinates.
-2009-10-17 12:02 strk
+2009-10-17 12:02 Sandro Santilli <strk at keybit.net>
- * source/geom/Polygon.cpp: Don't allocate too much space for
- polygon points vector. Fixes bug #294.
+ * [r2677] source/geom/Polygon.cpp: Don't allocate too much space
+ for polygon points vector. Fixes bug #294.
-2009-10-16 15:27 mloskot
+2009-10-16 15:27 Mateusz Loskot <mateusz at loskot.net>
- * tests/xmltester/tests/fme.xml: xmltester/tests: missing double
- quotes around XML attribute value in fme.xml.
+ * [r2676] tests/xmltester/tests/fme.xml: xmltester/tests: missing
+ double quotes around XML attribute value in fme.xml.
-2009-10-14 20:42 strk
+2009-10-14 20:42 Sandro Santilli <strk at keybit.net>
- * ChangeLog: regenerate ChangeLog
+ * [r2675] ChangeLog: regenerate ChangeLog
-2009-10-14 15:32 mloskot
+2009-10-14 15:32 Mateusz Loskot <mateusz at loskot.net>
+ * [r2674] build/msvc90/geos_unit/geos_unit.vcproj,
tests/xmltester/XMLTester.cpp, tests/xmltester/makefile.vc: *
Optional use of GEOS_DEBUG_MSVC_USE_VLD in XMLTester.cpp
@@ -1017,129 +1072,134 @@
Windows to be able to run all tests in batch:
** nmake /f makefile.vc XMLTESTER=C:\path\to\xmltester.exe
-2009-10-14 12:05 mloskot
+2009-10-14 12:05 Mateusz Loskot <mateusz at loskot.net>
- * build/msvc90/geos.sln, build/msvc90/geos_xmltester,
+ * [r2673] build/msvc90/geos.sln, build/msvc90/geos_xmltester,
build/msvc90/geos_xmltester/geos_xmltester.vcproj: Added
msvc90/geos_xmltester to solution for Visual Studio 2008.
-2009-10-14 12:03 mloskot
+2009-10-14 12:03 Mateusz Loskot <mateusz at loskot.net>
- * tests/xmltester/XMLTester.cpp: Enable use of Stalkwalker only if
- building with Visual C++ and GEOS_TEST_USE_STACKWALKER is
+ * [r2672] tests/xmltester/XMLTester.cpp: Enable use of Stalkwalker
+ only if building with Visual C++ and GEOS_TEST_USE_STACKWALKER is
defined.
-2009-10-13 16:25 mloskot
+2009-10-13 16:25 Mateusz Loskot <mateusz at loskot.net>
- * build/msvc90/geos_lib/geos_lib.vcproj: build/msvc90: added
- missing sources of linearref package. Builds with Visual C++ 9.0
- (using both project and makefiles).
+ * [r2671] build/msvc90/geos_lib/geos_lib.vcproj: build/msvc90:
+ added missing sources of linearref package. Builds with Visual
+ C++ 9.0 (using both project and makefiles).
-2009-10-13 14:20 warmerdam
+2009-10-13 14:20 Frank Warmerdam <warmerdam at pobox.com>
- * ChangeLog, capi/geos_c.h.in, nmake.opt, source/Makefile.vc: fix
- nmake dll export, and link test programs (#288)
+ * [r2670] ChangeLog, capi/geos_c.h.in, nmake.opt,
+ source/Makefile.vc: fix nmake dll export, and link test programs
+ (#288)
-2009-10-08 12:51 warmerdam
+2009-10-08 12:51 Frank Warmerdam <warmerdam at pobox.com>
- * source/Makefile.vc, source/dirlist.mk: add new directories and
- source (#288)
+ * [r2669] source/Makefile.vc, source/dirlist.mk: add new
+ directories and source (#288)
-2009-10-08 08:56 strk
+2009-10-08 08:56 Sandro Santilli <strk at keybit.net>
- * ChangeLog: regenerate ChangeLog now that we have all names in
+ * [r2668] ChangeLog: regenerate ChangeLog now that we have all
+ names in
-2009-10-08 08:47 strk
+2009-10-08 08:47 Sandro Santilli <strk at keybit.net>
- * authors.svn: Add other missing names/addresses
+ * [r2667] authors.svn: Add other missing names/addresses
-2009-10-08 08:40 strk
+2009-10-08 08:40 Sandro Santilli <strk at keybit.net>
- * ChangeLog, ChangeLog.svn, Makefile.am: Automatically generate the
- ChangeLog file, forget ChangeLog.svn.
+ * [r2666] ChangeLog, ChangeLog.svn, Makefile.am: Automatically
+ generate the ChangeLog file, forget ChangeLog.svn.
-2009-10-08 08:38 strk
+2009-10-08 08:38 Sandro Santilli <strk at keybit.net>
- * source/operation/overlay/snap/SnapIfNeededOverlayOp.cpp: Don't
- signal topology exception when it triggers snapping
+ * [r2665] source/operation/overlay/snap/SnapIfNeededOverlayOp.cpp:
+ Don't signal topology exception when it triggers snapping
-2009-10-08 08:37 strk
+2009-10-08 08:37 Sandro Santilli <strk at keybit.net>
- * authors.svn: Add yury, fernando and sean
+ * [r2664] authors.svn: Add yury, fernando and sean
-2009-10-08 08:17 strk
+2009-10-08 08:17 Sandro Santilli <strk at keybit.net>
- * tests/unit/Makefile.am: Distribute all of TUT
+ * [r2663] tests/unit/Makefile.am: Distribute all of TUT
-2009-10-08 07:56 strk
+2009-10-08 07:56 Sandro Santilli <strk at keybit.net>
- * capi/geos_c.h.in, source/headers/geos/version.h.vc: Properly set
- version for win target
+ * [r2662] capi/geos_c.h.in, source/headers/geos/version.h.vc:
+ Properly set version for win target
-2009-10-07 07:53 strk
+2009-10-07 07:53 Sandro Santilli <strk at keybit.net>
- * capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp,
+ * [r2661] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp,
tests/unit/capi/GEOSBufferTest.cpp: Expose single-sided buffering
in C-API (see ticket #258)
-2009-10-05 21:36 strk
+2009-10-05 21:36 Sandro Santilli <strk at keybit.net>
- * source/algorithm/distance/DistanceToPoint.cpp,
+ * [r2659] source/algorithm/distance/DistanceToPoint.cpp,
source/headers/geos/algorithm/distance/DistanceToPoint.h: Drop
use of static data in DistanceToPoint class (for thread-safety)
-2009-10-05 19:29 strk
+2009-10-05 19:29 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferBuilder.cpp: release memory
+ * [r2658] source/operation/buffer/BufferBuilder.cpp: release memory
earlier, and closer to allocation
-2009-10-05 19:04 strk
+2009-10-05 19:04 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferBuilder.cpp: Finish plugging leaks.
- Make check runs with no leaks.
+ * [r2657] source/operation/buffer/BufferBuilder.cpp: Finish
+ plugging leaks. Make check runs with no leaks.
-2009-10-05 18:42 strk
+2009-10-05 18:42 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/buffer/OffsetCurveBuilder.h:
+ * [r2656]
+ source/headers/geos/operation/buffer/OffsetCurveBuilder.h:
another memory management doc
-2009-10-05 18:40 strk
+2009-10-05 18:40 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/buffer/OffsetCurveBuilder.h,
+ * [r2655]
+ source/headers/geos/operation/buffer/OffsetCurveBuilder.h,
source/headers/geos/operation/buffer/OffsetCurveSetBuilder.h,
source/operation/buffer/OffsetCurveSetBuilder.cpp: Document more
memory management issues
-2009-10-05 17:20 strk
+2009-10-05 17:20 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferBuilder.cpp,
+ * [r2654] source/operation/buffer/BufferBuilder.cpp,
source/operation/buffer/OffsetCurveBuilder.cpp: More memory leak
fixes in single-sided buffering implementation
-2009-10-05 16:58 strk
+2009-10-05 16:58 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferBuilder.cpp: Plug some memory leaks
- in single sided buffering implementation
+ * [r2653] source/operation/buffer/BufferBuilder.cpp: Plug some
+ memory leaks in single sided buffering implementation
-2009-10-05 16:44 strk
+2009-10-05 16:44 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/linemerge/LineMerger.h: Document
- ownership of return from LineMerger::getMergedLineStrings
+ * [r2652] source/headers/geos/operation/linemerge/LineMerger.h:
+ Document ownership of return from
+ LineMerger::getMergedLineStrings
-2009-10-05 16:40 strk
+2009-10-05 16:40 Sandro Santilli <strk at keybit.net>
- * .vimrc: Alright, there's no standard style yet so this file is
- made empty, but good to have for reference
+ * [r2651] .vimrc: Alright, there's no standard style yet so this
+ file is made empty, but good to have for reference
-2009-10-01 10:30 strk
+2009-10-01 10:30 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferBuilder.cpp: Throw an exception
- rather than returning NULL if input to single-sided buffer code
- is invalid
+ * [r2650] source/operation/buffer/BufferBuilder.cpp: Throw an
+ exception rather than returning NULL if input to single-sided
+ buffer code is invalid
-2009-10-01 09:10 strk
+2009-10-01 09:10 Sandro Santilli <strk at keybit.net>
+ * [r2649] source/operation/buffer/BufferBuilder.cpp,
tests/xmltester/Makefile.am, tests/xmltester/tests/safe,
tests/xmltester/tests/safe/16595.xml,
tests/xmltester/tests/safe/16596.xml,
@@ -1148,81 +1208,87 @@
rather than forcing a MULTI; import 2 tests from the SAFE
testsuite
-2009-10-01 09:01 strk
+2009-10-01 09:01 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/safe_to_xml.sh: Better parse style parameter
+ * [r2648] tests/xmltester/safe_to_xml.sh: Better parse style
+ parameter
-2009-10-01 08:46 strk
+2009-10-01 08:46 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/safe_to_xml.sh: Add utility script to import
- tests from SAFE software
+ * [r2647] tests/xmltester/safe_to_xml.sh: Add utility script to
+ import tests from SAFE software
-2009-10-01 08:42 strk
+2009-10-01 08:42 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/XMLTester.cpp: Don't segfault on xml tests
- missing precision model specification
+ * [r2646] tests/xmltester/XMLTester.cpp: Don't segfault on xml
+ tests missing precision model specification
-2009-10-01 07:24 strk
+2009-10-01 07:24 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/tests/singlesidedbuffer.xml: Re-enable the now
- succeeding test for sharp edges line single sided buffering
+ * [r2645] tests/xmltester/tests/singlesidedbuffer.xml: Re-enable
+ the now succeeding test for sharp edges line single sided
+ buffering
-2009-10-01 07:23 strk
+2009-10-01 07:23 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferBuilder.cpp: Use FLAT/BUTT endcaps
- when doing single sided buffering
+ * [r2644] source/operation/buffer/BufferBuilder.cpp: Use FLAT/BUTT
+ endcaps when doing single sided buffering
-2009-10-01 07:06 strk
+2009-10-01 07:06 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/OffsetCurveBuilder.cpp: Fix trimming of
- left/right curves (ie: don't include the endcap)
+ * [r2643] source/operation/buffer/OffsetCurveBuilder.cpp: Fix
+ trimming of left/right curves (ie: don't include the endcap)
-2009-10-01 06:33 strk
+2009-10-01 06:33 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferBuilder.cpp: Use snapped
+ * [r2642] source/operation/buffer/BufferBuilder.cpp: Use snapped
intersection between full buffer boundary and single-sided offset
curves
-2009-09-30 22:18 strk
+2009-09-30 22:18 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/SingleSidedBufferResultMatcher.cpp: Check
+ * [r2641] tests/xmltester/SingleSidedBufferResultMatcher.cpp: Check
hausdorff distance in both directions, or an expected output line
longer than the obtained one would be found as correct
-2009-09-30 20:27 strk
+2009-09-30 20:27 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferBuilder.cpp: Some debugging for
- single sided buffers
+ * [r2640] source/operation/buffer/BufferBuilder.cpp: Some debugging
+ for single sided buffers
-2009-09-30 19:18 strk
+2009-09-30 19:18 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/tests/singlesidedbuffer.xml: Another simple test
- for single-sided buffer (horizontal line, both directions)
+ * [r2639] tests/xmltester/tests/singlesidedbuffer.xml: Another
+ simple test for single-sided buffer (horizontal line, both
+ directions)
-2009-09-30 19:07 strk
+2009-09-30 19:07 Sandro Santilli <strk at keybit.net>
- for a vertical line, opposite direction from previous
+ * [r2638] tests/xmltester/tests/singlesidedbuffer.xml: Another
+ simple test for a vertical line, opposite direction from previous
-2009-09-30 19:05 strk
+2009-09-30 19:05 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/tests/singlesidedbuffer.xml: Add test for single
- sided buffer on simple, vertical, line (this one succeeds both
- left and right)
+ * [r2637] tests/xmltester/tests/singlesidedbuffer.xml: Add test for
+ single sided buffer on simple, vertical, line (this one succeeds
+ both left and right)
-2009-09-30 18:57 strk
+2009-09-30 18:57 Sandro Santilli <strk at keybit.net>
- * .vimrc: VIM setting for GEOS source code style (3-spaces tabs)
+ * [r2636] .vimrc: VIM setting for GEOS source code style (3-spaces
+ tabs)
-2009-09-30 14:14 strk
+2009-09-30 14:14 Sandro Santilli <strk at keybit.net>
- * autogen.sh: Don't use non-standard escape sequences with 'echo'
+ * [r2635] autogen.sh: Don't use non-standard escape sequences with
+ 'echo'
-2009-09-28 10:35 strk
+2009-09-28 10:35 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/Makefile.am, tests/xmltester/XMLTester.cpp,
- tests/xmltester/XMLTester.h, tests/xmltester/markup,
- tests/xmltester/tinyxml, tests/xmltester/tinyxml/tinystr.cpp,
+ * [r2634] tests/xmltester/Makefile.am,
+ tests/xmltester/XMLTester.cpp, tests/xmltester/XMLTester.h,
+ tests/xmltester/markup, tests/xmltester/tinyxml,
+ tests/xmltester/tinyxml/tinystr.cpp,
tests/xmltester/tinyxml/tinystr.h,
tests/xmltester/tinyxml/tinyxml.cpp,
tests/xmltester/tinyxml/tinyxml.h,
@@ -1230,29 +1296,30 @@
tests/xmltester/tinyxml/tinyxmlparser.cpp: Replace
no-commercial-use licenced MarkupSTL with tinyXML
-2009-09-28 10:34 strk
+2009-09-28 10:34 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/tests/singlesidedbuffer.xml: Temporarly disable
- failing single sided buffer test
+ * [r2633] tests/xmltester/tests/singlesidedbuffer.xml: Temporarly
+ disable failing single sided buffer test
-2009-09-28 10:10 strk
+2009-09-28 10:10 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/SingleSidedBufferResultMatcher.cpp: Oops, it
- seems I just don't want a test to fail ;)
+ * [r2632] tests/xmltester/SingleSidedBufferResultMatcher.cpp: Oops,
+ it seems I just don't want a test to fail ;)
-2009-09-28 10:09 strk
+2009-09-28 10:09 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/SingleSidedBufferResultMatcher.cpp: Don't give a
- false success if one of the expected/obtained geometry is empty
+ * [r2631] tests/xmltester/SingleSidedBufferResultMatcher.cpp: Don't
+ give a false success if one of the expected/obtained geometry is
+ empty
-2009-09-28 09:03 strk
+2009-09-28 09:03 Sandro Santilli <strk at keybit.net>
- * source/geom/PrecisionModel.cpp: Add offsets to PrecisionModel
- text output
+ * [r2630] source/geom/PrecisionModel.cpp: Add offsets to
+ PrecisionModel text output
-2009-09-28 07:02 strk
+2009-09-28 07:02 Sandro Santilli <strk at keybit.net>
+ * [r2629] tests/xmltester/Makefile.am,
tests/xmltester/SingleSidedBufferResultMatcher.cpp,
tests/xmltester/SingleSidedBufferResultMatcher.h,
@@ -1261,9 +1328,9 @@
Enable the single sided buffer test provided by swong in ticket
#215 with minor tweak (expect multilinestring).
-2009-09-27 20:43 strk
+2009-09-27 20:43 Sandro Santilli <strk at keybit.net>
+ * [r2628] source/headers/geos/operation/buffer/BufferBuilder.h,
@@ -1271,33 +1338,33 @@
tests/xmltester/XMLTester.cpp: Re-introduce the singlesided
buffer patch. Tests still need to be worked on.
-2009-09-21 19:47 pramsey
+2009-09-21 19:47 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/geom/Polygon.cpp: Polygon with empty ring causes a crash
- in WKBReader (from Tamas Szekeres) (#290)
+ * [r2626] source/geom/Polygon.cpp: Polygon with empty ring causes a
+ crash in WKBReader (from Tamas Szekeres) (#290)
-2009-09-11 18:47 pramsey
+2009-09-11 18:47 Paul Ramsey <pramsey at cleverelephant.ca>
- * capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp: Patch for
- #285, C api for project and interpolate, from David Turner
- (novalis)
+ * [r2624] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp:
+ Patch for #285, C api for project and interpolate, from David
+ Turner (novalis)
-2009-08-21 09:54 mloskot
+2009-08-21 09:54 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/linearref, source/linearref: Updated
+ * [r2623] source/headers/geos/linearref, source/linearref: Updated
svn:ignore property
-2009-08-21 09:50 mloskot
+2009-08-21 09:50 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/export.h,
+ * [r2622] source/headers/geos/export.h,
tests/unit/geom/CoordinateArraySequenceTest.cpp,
tests/unit/geos_unit.cpp: Cleaned compilation warnings in unit
tests.
-2009-08-21 09:43 mloskot
+2009-08-21 09:43 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/tut/tut.hpp, tests/unit/tut/tut_assert.hpp,
+ * [r2621] tests/unit/tut/tut.hpp, tests/unit/tut/tut_assert.hpp,
tests/unit/tut/tut_console_reporter.hpp,
tests/unit/tut/tut_exception.hpp, tests/unit/tut/tut_posix.hpp,
tests/unit/tut/tut_reporter.hpp,
@@ -1306,9 +1373,9 @@
Updated C++ TUT Framework to latest revision (147) of its SVN
trunk
-2009-08-15 13:26 strk
+2009-08-15 13:26 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/linearref/ExtractLineByLocation.h,
+ * [r2620] source/headers/geos/linearref/ExtractLineByLocation.h,
source/headers/geos/linearref/LengthIndexOfPoint.h,
source/headers/geos/linearref/LengthIndexedLine.h,
source/headers/geos/linearref/LengthLocationMap.h,
@@ -1326,9 +1393,9 @@
source/linearref/LocationIndexOfPoint.cpp: Const correctness of
LenghtIndexedLine port, by novalis (issue #284)
-2009-08-12 19:01 pramsey
+2009-08-12 19:01 Paul Ramsey <pramsey at cleverelephant.ca>
- * configure.in, source/Makefile.am,
+ * [r2619] configure.in, source/Makefile.am,
source/headers/geos/Makefile.am,
source/headers/geos/geom/CoordinateList.h,
@@ -1356,142 +1423,148 @@
tests/unit/linearref/LengthIndexedLineTest.cpp: Port of JTS
linear referencing (from David Turner) (#283)
-2009-08-02 23:39 mloskot
+2009-08-02 23:39 Mateusz Loskot <mateusz at loskot.net>
- * source/operation/overlay/PolygonBuilder.cpp: Removed incomplete
- GEOS_DEBUG message causing compilation error because Edge type is
- incomplete.
+ * [r2618] source/operation/overlay/PolygonBuilder.cpp: Removed
+ incomplete GEOS_DEBUG message causing compilation error because
+ Edge type is incomplete.
-2009-08-02 23:15 mloskot
+2009-08-02 23:15 Mateusz Loskot <mateusz at loskot.net>
- * source/geom/GeometryFactory.cpp: Fixed broken escape sequence in
- debug msg.
+ * [r2617] source/geom/GeometryFactory.cpp: Fixed broken escape
+ sequence in debug msg.
-2009-07-17 22:23 pramsey
+2009-07-17 22:23 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/headers/geos/io/WKBReader.h, source/io/WKBReader.cpp:
- Remove static string in WKB reader (#232)
+ * [r2616] source/headers/geos/io/WKBReader.h,
+ source/io/WKBReader.cpp: Remove static string in WKB reader
+ (#232)
-2009-07-15 18:56 pramsey
+2009-07-15 18:56 Paul Ramsey <pramsey at cleverelephant.ca>
- * swig/geos.i.in, swig/ruby/ruby.i: Add PreparedGeometry and
- STRtree support to SWIG (#279) Schuyler Erle
+ * [r2613] swig/geos.i.in, swig/ruby/ruby.i: Add PreparedGeometry
+ and STRtree support to SWIG (#279) Schuyler Erle
-2009-07-15 18:55 pramsey
+2009-07-15 18:55 Paul Ramsey <pramsey at cleverelephant.ca>
- * capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp: Add
- STRtree support to the C API (#278) Schuyler Erle
+ * [r2612] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp:
+ Add STRtree support to the C API (#278) Schuyler Erle
-2009-07-15 18:53 pramsey
+2009-07-15 18:53 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r2611] source/headers/geos/index/strtree/AbstractSTRtree.h,
source/index/strtree/AbstractSTRtree.cpp: Add
geos::index::strtree::AbstractSTRtree::iterate (#277) Schuyler
Erle
-2009-07-06 17:35 strk
+2009-07-06 17:35 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/Makefile.am, tests/xmltester/tests/bug275.xml:
- Add automated XML test for issue #275. Succeeds here.
+ * [r2610] tests/xmltester/Makefile.am,
+ tests/xmltester/tests/bug275.xml: Add automated XML test for
+ issue #275. Succeeds here.
-2009-07-05 15:58 strk
+2009-07-05 15:58 Sandro Santilli <strk at keybit.net>
+ * [r2609] build/msvc90/geos_c_dll/geos_c_dll.vcproj,
build/msvc90/geos_unit/geos_unit.vcproj: Apply
fix-msvc90-only2.patch by Sanak from issue #273
-2009-07-04 16:19 strk
+2009-07-04 16:19 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/export.h, source/headers/geos/platform.h.in:
- Apply fix-mingw.patch by Sanak (issue #273)
+ * [r2608] source/headers/geos/export.h,
+ source/headers/geos/platform.h.in: Apply fix-mingw.patch by Sanak
+ (issue #273)
-2009-06-29 16:40 pramsey
+2009-06-29 16:40 Paul Ramsey <pramsey at cleverelephant.ca>
- * Makefile.am: Include nmake.opt in 'dist' target (#274)
+ * [r2607] Makefile.am: Include nmake.opt in 'dist' target (#274)
-2009-06-26 21:59 strk
+2009-06-26 21:59 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/buffer/BufferOp.h: Fix typo
+ * [r2605] source/headers/geos/operation/buffer/BufferOp.h: Fix typo
reported in ticket #272
-2009-06-24 21:43 pramsey
+2009-06-24 21:43 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r2604] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp,
tests/unit/capi/geostest.c, tests/unit/capi/test.expected: Expose
Hausdorf distance to CAPI (#264) from Vincent Picavet
-2009-06-24 21:30 pramsey
+2009-06-24 21:30 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/headers/geos/platform.h.in: Fix stoopid syntax error.
+ * [r2603] source/headers/geos/platform.h.in: Fix stoopid syntax
+ error.
-2009-06-24 21:21 pramsey
+2009-06-24 21:21 Paul Ramsey <pramsey at cleverelephant.ca>
- * configure.in: Remove old logging noise.
+ * [r2602] configure.in: Remove old logging noise.
-2009-06-24 21:19 pramsey
+2009-06-24 21:19 Paul Ramsey <pramsey at cleverelephant.ca>
- * configure.in, source/headers/geos/platform.h.in: Fix for #270,
- bad definition of isnan() in OS/X <cmath>. This needs to be
+ * [r2601] configure.in, source/headers/geos/platform.h.in: Fix for
+ #270, bad definition of isnan() in OS/X <cmath>. This needs to be
tested on other operating systems to make sure it doesn't break
them instead.
-2009-06-23 22:20 pramsey
+2009-06-23 22:20 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/Makefile.vc, source/dirlist.mk: Fix clean target for VC
- build (#267)
+ * [r2599] source/Makefile.vc, source/dirlist.mk: Fix clean target
+ for VC build (#267)
-2009-06-23 18:22 hobu
+2009-06-23 18:22 Howard Butler <hobu.inc at gmail.com>
- * source/Makefile.vc: fix up syntax of the makefile related to the
- patch for #257
+ * [r2598] source/Makefile.vc: fix up syntax of the makefile related
+ to the patch for #257
-2009-06-22 19:14 strk
+2009-06-22 19:14 Sandro Santilli <strk at keybit.net>
- * tests/unit/capi/GEOSBufferTest.cpp: Add tests for limited mitre
- join (now working)
+ * [r2597] tests/unit/capi/GEOSBufferTest.cpp: Add tests for limited
+ mitre join (now working)
-2009-06-22 19:02 strk
+2009-06-22 19:02 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/buffer/BufferParameters.h: Fix bug
- in BufferParameters::setMitreLimit
+ * [r2596] source/headers/geos/operation/buffer/BufferParameters.h:
+ Fix bug in BufferParameters::setMitreLimit
-2009-06-20 21:29 strk
+2009-06-20 21:29 Sandro Santilli <strk at keybit.net>
- * configure.in: Bump versions (core 3.2.0, capi 1.6.0, port 1.10.0)
+ * [r2595] configure.in: Bump versions (core 3.2.0, capi 1.6.0, port
+ 1.10.0)
-2009-06-20 08:53 strk
+2009-06-20 08:53 Sandro Santilli <strk at keybit.net>
- * tests/unit/Makefile.am, tests/unit/capi/GEOSBufferTest.cpp: Add
- tests for GEOSBufferWithStyle
+ * [r2594] tests/unit/Makefile.am,
+ tests/unit/capi/GEOSBufferTest.cpp: Add tests for
+ GEOSBufferWithStyle
-2009-06-19 22:32 strk
+2009-06-19 22:32 Sandro Santilli <strk at keybit.net>
- * capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp: Extend the
- C-API interface to expose a GEOSBufferWithStyle (and
+ * [r2593] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp:
+ Extend the C-API interface to expose a GEOSBufferWithStyle (and
corresponding thread-safe version) and related enums.
-2009-06-16 15:49 strk
+2009-06-16 15:49 Sandro Santilli <strk at keybit.net>
- * source/algorithm/RobustDeterminant.cpp,
+ * [r2592] source/algorithm/RobustDeterminant.cpp,
source/headers/geos/algorithm/RobustDeterminant.h: Sync
RobustDeterminant to JTS-1.10 (r1.15 was just commented-out code)
-2009-06-16 15:46 strk
+2009-06-16 15:46 Sandro Santilli <strk at keybit.net>
+ * [r2591] source/algorithm/RobustDeterminant.cpp,
RobustDeterminant to revision 1.14
-2009-06-16 15:43 strk
+2009-06-16 15:43 Sandro Santilli <strk at keybit.net>
+ * [r2590] source/algorithm/RobustDeterminant.cpp,
source/headers/geos/algorithm/RobustDeterminant.h: Port info for
RobustDeterminant
-2009-06-16 15:33 strk
+2009-06-16 15:33 Sandro Santilli <strk at keybit.net>
+ * [r2589] source/headers/geos/operation/buffer/BufferBuilder.h,
@@ -1499,18 +1572,19 @@
tests/xmltester/XMLTester.cpp: Revert single-sided patch. Martin
Davis is workin on it from the JTS side
-2009-06-16 00:00 pramsey
+2009-06-16 00:00 Paul Ramsey <pramsey at cleverelephant.ca>
- * HOWTO_RELEASE: add reminders on bump versions in various places
+ * [r2581] HOWTO_RELEASE: add reminders on bump versions in various
+ places
-2009-06-15 14:57 pramsey
+2009-06-15 14:57 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/headers/geos/Makefile.am: operation.h in Makefile.am
- twice. (#261)
+ * [r2580] source/headers/geos/Makefile.am: operation.h in
+ Makefile.am twice. (#261)
-2009-06-15 14:03 strk
+2009-06-15 14:03 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/io/ByteOrderDataInStream.h,
+ * [r2579] source/headers/geos/io/ByteOrderDataInStream.h,
source/headers/geos/io/ByteOrderDataInStream.inl,
source/headers/geos/io/ByteOrderValues.h,
source/headers/geos/io/CLocalizer.h,
@@ -1530,31 +1604,33 @@
source/io/WKTReader.cpp, source/io/WKTWriter.cpp,
source/io/Writer.cpp: Port info in the geos::io namespace
-2009-06-15 13:19 strk
+2009-06-15 13:19 Sandro Santilli <strk at keybit.net>
- * source/io/WKTWriter.cpp: Put CLocalizer in the correct function.
- Fixes #260 for the writing part.
+ * [r2578] source/io/WKTWriter.cpp: Put CLocalizer in the correct
+ function. Fixes #260 for the writing part.
-2009-06-15 10:13 strk
+2009-06-15 10:13 Sandro Santilli <strk at keybit.net>
- * capi/geos_ts_c.cpp: Stop explicitly using the CLocalizer now that
- it is done within WKTReader and WKTWriter (see bug #260). Some
- deep testing about this would be good. Make check worked for me
- with comma-using locale.
+ * [r2577] capi/geos_ts_c.cpp: Stop explicitly using the CLocalizer
+ now that it is done within WKTReader and WKTWriter (see bug
+ #260). Some deep testing about this would be good. Make check
+ worked for me with comma-using locale.
-2009-06-15 10:06 strk
+2009-06-15 10:06 Sandro Santilli <strk at keybit.net>
- * source/io/WKTReader.cpp, source/io/WKTWriter.cpp: Use C locale
- while reading/writing WKT. Fixes bug #260.
+ * [r2576] source/io/WKTReader.cpp, source/io/WKTWriter.cpp: Use C
+ locale while reading/writing WKT. Fixes bug #260.
-2009-06-15 06:57 strk
+2009-06-15 06:57 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/Makefile.am, tests/xmltester/tests/bug176.xml:
- Add XML version of the testcase provided for bug #176
+ * [r2575] tests/xmltester/Makefile.am,
+ tests/xmltester/tests/bug176.xml: Add XML version of the testcase
+ provided for bug #176
-2009-06-08 22:10 strk
+2009-06-08 22:10 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/valid/ConnectedInteriorTester.h,
+ * [r2572]
+ source/headers/geos/operation/valid/ConnectedInteriorTester.h,
source/headers/geos/operation/valid/IsValidOp.h,
source/headers/geos/operation/valid/QuadtreeNestedRingTester.h,
source/headers/geos/operation/valid/RepeatedPointTester.h,
@@ -1572,37 +1648,41 @@
source/operation/valid/TopologyValidationError.cpp: JTS-1.10 port
sync. The whole 'operation' namespace is complete on this.
-2009-06-08 21:53 strk
+2009-06-08 21:53 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/union/CascadedPolygonUnion.h,
+ * [r2571]
+ source/headers/geos/operation/union/CascadedPolygonUnion.h,
source/operation/union/CascadedPolygonUnion.cpp: Port info for
operation::union
-2009-06-08 17:15 strk
+2009-06-08 17:15 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/predicate/RectangleIntersects.h,
+ * [r2570]
+ source/headers/geos/operation/predicate/RectangleIntersects.h,
source/headers/geos/operation/predicate/SegmentIntersectionTester.h,
source/operation/predicate/RectangleIntersects.cpp,
source/operation/predicate/SegmentIntersectionTester.cpp: Sync to
JTS-1.10 (port info in SegmentIntersectionTester was wrong, btw)
-2009-06-08 17:12 strk
+2009-06-08 17:12 Sandro Santilli <strk at keybit.net>
+ * [r2569]
source/operation/predicate/RectangleContains.cpp: Sync
RectangleContains to JTS-1.10
-2009-06-08 17:02 strk
+2009-06-08 17:02 Sandro Santilli <strk at keybit.net>
+ * [r2568]
source/operation/predicate/SegmentIntersectionTester.cpp: Port
info for operation::predicate (we're at JTS-1.7 here)
-2009-06-08 16:58 strk
+2009-06-08 16:58 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/polygonize/EdgeRing.h,
+ * [r2567] source/headers/geos/operation/polygonize/EdgeRing.h,
source/headers/geos/operation/polygonize/PolygonizeDirectedEdge.h,
source/headers/geos/operation/polygonize/PolygonizeEdge.h,
@@ -1614,9 +1694,10 @@
source/operation/polygonize/Polygonizer.cpp: Port info for
polygonize operation
-2009-06-08 16:46 strk
+2009-06-08 16:46 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/overlay/validate/FuzzyPointLocator.h,
+ * [r2566]
+ source/headers/geos/operation/overlay/validate/FuzzyPointLocator.h,
source/headers/geos/operation/overlay/validate/OffsetPointGenerator.h,
source/headers/geos/operation/overlay/validate/OverlayResultValidator.h,
source/operation/overlay/validate/FuzzyPointLocator.cpp,
@@ -1624,15 +1705,15 @@
source/operation/overlay/validate/OverlayResultValidator.cpp:
Port info and sync for operation::overlay::validate
-2009-06-08 16:26 strk
+2009-06-08 16:26 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/overlay/LineBuilder.h,
+ * [r2565] source/headers/geos/operation/overlay/LineBuilder.h,
source/operation/overlay/LineBuilder.cpp: sync LineBuilder to
JTS-1.10, completing overlay port
-2009-06-08 16:09 strk
+2009-06-08 16:09 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/overlay/EdgeSetNoder.h,
+ * [r2564] source/headers/geos/operation/overlay/EdgeSetNoder.h,
source/headers/geos/operation/overlay/ElevationMatrixCell.h,
@@ -1649,17 +1730,17 @@
source/operation/overlay/PointBuilder.cpp: Complete port info in
overlay package
-2009-06-08 15:43 strk
+2009-06-08 15:43 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/linemerge/LineMerger.h,
+ * [r2563] source/headers/geos/operation/linemerge/LineMerger.h,
source/headers/geos/planargraph/GraphComponent.h,
source/operation/linemerge/LineMerger.cpp: Add missing setMarked
static methods in GraphComponent and make use of them in
LineMerger making it able to be called incrementally (JTS-1.10)
-2009-06-08 15:28 strk
+2009-06-08 15:28 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/linemerge/EdgeString.h,
+ * [r2562] source/headers/geos/operation/linemerge/EdgeString.h,
source/headers/geos/operation/linemerge/LineMergeDirectedEdge.h,
source/headers/geos/operation/linemerge/LineMergeEdge.h,
source/headers/geos/operation/linemerge/LineMergeGraph.h,
@@ -1674,21 +1755,22 @@
operation::linemerge (a single class is still at JTS-1.7, needs
changes in GeometryGraphComponent.h to go up)
-2009-06-08 10:37 strk
+2009-06-08 10:37 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/distance/GeometryLocation.h,
+ * [r2561]
+ source/headers/geos/operation/distance/GeometryLocation.h,
source/operation/distance/GeometryLocation.cpp: GeometryLocation
sync to JTS-1.10 (docs)
-2009-06-08 10:29 strk
+2009-06-08 10:29 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/distance/DistanceOp.h,
+ * [r2560] source/headers/geos/operation/distance/DistanceOp.h,
source/operation/distance/DistanceOp.cpp: DistanceOp sync to
JTS-1.10 (renames, docs...)
-2009-06-08 10:07 strk
+2009-06-08 10:07 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/buffer/BufferBuilder.h,
+ * [r2559] source/headers/geos/operation/buffer/BufferBuilder.h,
source/headers/geos/operation/buffer/BufferOp.h,
source/headers/geos/operation/buffer/BufferParameters.h,
source/headers/geos/operation/buffer/BufferSubgraph.h,
@@ -1709,14 +1791,14 @@
source/operation/buffer/SubgraphDepthLocater.cpp: Update port
info for buffer package (it's really JTS-1.10)
-2009-06-08 09:40 strk
+2009-06-08 09:40 Sandro Santilli <strk at keybit.net>
- * configure.in: Warn at configure time if 64bit integer type isn't
- found. See bug #202.
+ * [r2558] configure.in: Warn at configure time if 64bit integer
+ type isn't found. See bug #202.
-2009-06-08 09:30 strk
+2009-06-08 09:30 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/Makefile.am,
+ * [r2557] source/headers/geos/Makefile.am,
source/headers/geos/algorithm/Makefile.am,
source/headers/geos/algorithm/distance/Makefile.am,
source/headers/geos/algorithm/locate/Makefile.am,
@@ -1791,9 +1873,9 @@
documented as being unstable after all so let's give users the
power to hurt themselves :)
-2009-06-06 22:22 strk
+2009-06-06 22:22 Sandro Santilli <strk at keybit.net>
+ * [r2556] build/msvc90/geos_c_dll/geos_c_dll.vcproj,
build/msvc90/geos_unit/geos_unit.vcproj, capi/geos_c.cpp,
@@ -2037,15 +2119,16 @@
C++ exports by Ragi Y. Burhum. See
http://lists.osgeo.org/pipermail/geos-devel/2009-June/004190.html
-2009-06-06 22:17 strk
+2009-06-06 22:17 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/SimpleWKTTester.cpp: fix headers inclusion
- warnings
+ * [r2555] tests/xmltester/SimpleWKTTester.cpp: fix headers
+ inclusion warnings
-2009-06-06 21:14 strk
+2009-06-06 21:14 Sandro Santilli <strk at keybit.net>
- configure.in, source/algorithm/InteriorPointLine.cpp,
+ * [r2554] build/msvc90/geos_lib/geos_lib.vcproj,
+ capi/geos_ts_c.cpp, configure.in,
+ source/algorithm/InteriorPointLine.cpp,
source/algorithm/InteriorPointPoint.cpp,
source/algorithm/MinimumDiameter.cpp, source/geom/Geometry.cpp,
source/geom/GeometryFactory.cpp, source/geom/LineSegment.cpp,
@@ -2065,9 +2148,10 @@
autoconf checks for finite() and isfinite() and makes use of them
for unix systems (platform.h)
-2009-06-06 00:55 strk
+2009-06-06 00:55 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/distance/ConnectedElementLocationFilter.h,
+ * [r2553]
+ source/headers/geos/operation/distance/ConnectedElementLocationFilter.h,
source/headers/geos/operation/distance/ConnectedElementPointFilter.h,
@@ -2076,38 +2160,39 @@
source/operation/distance/GeometryLocation.cpp: Complete port
info and headers exposion for operation::distance package
-2009-06-05 18:18 strk
+2009-06-05 18:18 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/overlay/OverlayOp.h,
+ * [r2552] source/headers/geos/operation/overlay/OverlayOp.h,
source/operation/overlay/OverlayOp.cpp: JTS-1.10 OverlayOp
-2009-06-05 18:12 strk
+2009-06-05 18:12 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geomgraph/EdgeNodingValidator.h: Add missing
- static function
+ * [r2551] source/headers/geos/geomgraph/EdgeNodingValidator.h: Add
+ missing static function
-2009-06-05 18:02 strk
+2009-06-05 18:02 Sandro Santilli <strk at keybit.net>
+ * [r2550] source/headers/geos/operation/overlay/MaximalEdgeRing.h,
source/operation/overlay/MaximalEdgeRing.cpp: JTS-1.10 sync
-2009-06-05 17:50 strk
+2009-06-05 17:50 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/GeometryGraphOperation.h,
+ * [r2549] source/headers/geos/operation/GeometryGraphOperation.h,
source/headers/geos/operation/relate/RelateOp.h,
source/operation/GeometryGraphOperation.cpp,
source/operation/relate/RelateOp.cpp: Boundary Node Rule support
in relateOp. JTS-1.10.
-2009-06-05 13:44 strk
+2009-06-05 13:44 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/EdgeList.cpp, source/geomgraph/Node.cpp,
+ * [r2548] source/geomgraph/EdgeList.cpp, source/geomgraph/Node.cpp,
source/headers/geos/geomgraph/Node.h: geomgraph package fully
sync'ed to JTS-1.10 now
-2009-06-05 13:41 strk
+2009-06-05 13:41 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/EdgeEnd.cpp, source/geomgraph/EdgeEndStar.cpp,
+ * [r2547] source/geomgraph/EdgeEnd.cpp,
+ source/geomgraph/EdgeEndStar.cpp,
source/headers/geos/geomgraph/EdgeEnd.h,
source/headers/geos/geomgraph/EdgeEndStar.h,
source/headers/geos/operation/relate/EdgeEndBundle.h,
@@ -2116,16 +2201,17 @@
source/operation/valid/ConsistentAreaTester.cpp: added
BoundaryNodeRule capability to EdgeEnds
-2009-06-05 12:42 strk
+2009-06-05 12:42 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/GeometryGraph.cpp,
+ * [r2546] source/geomgraph/GeometryGraph.cpp,
source/headers/geos/geomgraph/GeometryGraph.h,
source/headers/geos/geomgraph/GeometryGraph.inl: Add support for
custom BoundaryNodeRule bringing GeometryGraph to JTS-1.10
-2009-06-05 12:07 strk
+2009-06-05 12:07 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/DirectedEdgeStar.cpp, source/geomgraph/Edge.cpp,
+ * [r2545] source/geomgraph/DirectedEdgeStar.cpp,
+ source/geomgraph/Edge.cpp,
source/geomgraph/EdgeIntersectionList.cpp,
source/geomgraph/EdgeNodingValidator.cpp,
source/geomgraph/EdgeRing.cpp, source/geomgraph/Label.cpp,
@@ -2145,9 +2231,10 @@
source/headers/geos/geomgraph/TopologyLocation.h: Complete port
info in geomgraph package
-2009-06-05 11:03 strk
+2009-06-05 11:03 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/Depth.cpp, source/geomgraph/GeometryGraph.cpp,
+ * [r2544] source/geomgraph/Depth.cpp,
+ source/geomgraph/GeometryGraph.cpp,
source/geomgraph/GraphComponent.cpp,
source/geomgraph/NodeMap.cpp, source/geomgraph/PlanarGraph.cpp,
source/headers/geos/geomgraph/Depth.h,
@@ -2163,9 +2250,9 @@
geomgraph package (unfinished); fix compiler warning in
GeometryGraph and make code more readable;
-2009-06-05 10:23 strk
+2009-06-05 10:23 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/relate/EdgeEndBuilder.h,
+ * [r2543] source/headers/geos/operation/relate/EdgeEndBuilder.h,
source/headers/geos/operation/relate/EdgeEndBundleStar.h,
source/headers/geos/operation/relate/RelateComputer.h,
@@ -2184,17 +2271,17 @@
header exposion info. Relate op results partially in JTS-1.7
still.
-2009-06-05 09:36 strk
+2009-06-05 09:36 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom.h: typo in doxygen index page
+ * [r2542] source/headers/geos/geom.h: typo in doxygen index page
-2009-06-05 09:35 strk
+2009-06-05 09:35 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom.h: Fix doxygen link
+ * [r2541] source/headers/geos/geom.h: Fix doxygen link
-2009-06-05 09:28 strk
+2009-06-05 09:28 Sandro Santilli <strk at keybit.net>
- * source/algorithm/locate/IndexedPointInAreaLocator.cpp,
+ * [r2540] source/algorithm/locate/IndexedPointInAreaLocator.cpp,
source/headers/geos/algorithm/locate/IndexedPointInAreaLocator.h,
source/headers/geos/index/intervalrtree/IntervalRTreeLeafNode.h,
source/headers/geos/index/intervalrtree/SortedPackedIntervalRTree.h:
@@ -2202,14 +2289,14 @@
ownership, fix callers tracking allocations to avoid leaks. Fixes
bug #227.
-2009-06-05 09:15 strk
+2009-06-05 09:15 Sandro Santilli <strk at keybit.net>
- * ChangeLog.svn, Makefile.am: Allow generating ChangeLog from
- external build tree
+ * [r2539] ChangeLog.svn, Makefile.am: Allow generating ChangeLog
+ from external build tree
-2009-06-04 15:01 mloskot
+2009-06-04 15:01 Mateusz Loskot <mateusz at loskot.net>
+ * [r2538] build/msvc90/geos_c_dll/geos_c_dll.vcproj,
build/msvc90/geos_unit/geos_unit.vcproj, source/Makefile.vc,
source/geom/LinearRing.cpp,
@@ -2222,119 +2309,120 @@
1>---> group: geos::operation::valid::IsValidOp, test: test<1>
1> problem: assertion failed
-2009-06-04 14:59 mloskot
+2009-06-04 14:59 Mateusz Loskot <mateusz at loskot.net>
- * source/operation/buffer/BufferBuilder.cpp: Fixed bug of
+ * [r2537] source/operation/buffer/BufferBuilder.cpp: Fixed bug of
inaccessible constructor of incomplete type NodedSegmentString -
header missing.
-2009-06-04 13:59 strk
+2009-06-04 13:59 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/XMLTester.cpp: Add support for testing single
- sided buffers
+ * [r2536] tests/xmltester/XMLTester.cpp: Add support for testing
+ single sided buffers
-2009-06-01 03:34 hobu
+2009-06-01 03:34 Howard Butler <hobu.inc at gmail.com>
- * capi/geos_c.cpp: #256 finishGEOS called multiple times will
- segfault
+ * [r2534] capi/geos_c.cpp: #256 finishGEOS called multiple times
+ will segfault
-2009-05-28 14:38 mloskot
+2009-05-28 14:38 Mateusz Loskot <mateusz at loskot.net>
- * configure.in, tests/bigtest: Fixed aclocal warnings for mixing
- cache-id's in configure.in.
+ * [r2533] configure.in, tests/bigtest: Fixed aclocal warnings for
+ mixing cache-id's in configure.in.
-2009-05-27 16:57 pramsey
+2009-05-27 16:57 Paul Ramsey <pramsey at cleverelephant.ca>
- * NEWS: remove error
+ * [r2516] NEWS: remove error
- * NEWS: Add single-sided item
+ * [r2515] NEWS: Add single-sided item
-2009-05-21 10:08 strk
+2009-05-21 10:08 Sandro Santilli <strk at keybit.net>
- * ChangeLog.svn, Makefile.am, authors.svn: Add Mat's and Paul's
- entries, make ChangeLog.svn rule phony
+ * [r2514] ChangeLog.svn, Makefile.am, authors.svn: Add Mat's and
+ Paul's entries, make ChangeLog.svn rule phony
-2009-05-21 09:56 strk
+2009-05-21 09:56 Sandro Santilli <strk at keybit.net>
- * ChangeLog.svn, Makefile.am, authors.svn: Add a rule to generate a
- ChangeLog using svn2cl. The authors.svn file will be used to map
- usernames and full names: please expand your own nick. The
- generated ChangeLog is added to repository to show you how it
- looks. If everybody agree we could rename this to ChangeLog and
- stop requiring manual edits (+1 from me:)
+ * [r2513] ChangeLog.svn, Makefile.am, authors.svn: Add a rule to
+ generate a ChangeLog using svn2cl. The authors.svn file will be
+ used to map usernames and full names: please expand your own
+ nick. The generated ChangeLog is added to repository to show you
+ how it looks. If everybody agree we could rename this to
+ ChangeLog and stop requiring manual edits (+1 from me:)
-2009-05-13 11:29 warmerdam
+2009-05-13 11:29 Frank Warmerdam <warmerdam at pobox.com>
- * capi/geos_c.h.in: refer to GEOSFree() instead of free()
+ * [r2508] capi/geos_c.h.in: refer to GEOSFree() instead of free()
-2009-05-13 11:26 warmerdam
+2009-05-13 11:26 Frank Warmerdam <warmerdam at pobox.com>
- * capi/geos_c.cpp, capi/geos_ts_c.cpp: forward GEOSFree to
+ * [r2507] capi/geos_c.cpp, capi/geos_ts_c.cpp: forward GEOSFree to
GEOSFree_r, use std:: prefix on free() (#249)
-2009-05-13 04:14 warmerdam
+2009-05-13 04:14 Frank Warmerdam <warmerdam at pobox.com>
- * ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp:
- Added GEOSFree() and GEOSFree_r() (#249)
+ * [r2506] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in,
+ capi/geos_ts_c.cpp: Added GEOSFree() and GEOSFree_r() (#249)
-2009-05-12 17:47 strk
+2009-05-12 17:47 Sandro Santilli <strk at keybit.net>
- * NEWS: Add note about single-sided buffer
+ * [r2505] NEWS: Add note about single-sided buffer
-2009-05-12 16:49 strk
+2009-05-12 16:49 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/Makefile.am, tests/xmltester/tests/bug244.xml:
- Never fail bug #244 again (regression testcase added)
+ * [r2504] tests/xmltester/Makefile.am,
+ tests/xmltester/tests/bug244.xml: Never fail bug #244 again
+ (regression testcase added)
-2009-05-12 16:48 strk
+2009-05-12 16:48 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/SubgraphDepthLocater.cpp: Have
+ * [r2503] source/operation/buffer/SubgraphDepthLocater.cpp: Have
DepthSegment hold a real LineSegment, not a reference.
SubgraphDepthLocater was passing the same LineSegment reference
to multiple DepthSegments, messing everything up. This fixes bug
#244.
-2009-05-12 15:38 strk
+2009-05-12 15:38 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/DirectedEdge.cpp,
+ * [r2502] source/geomgraph/DirectedEdge.cpp,
source/headers/geos/geomgraph/DirectedEdge.h,
source/headers/geos/geomgraph/DirectedEdge.inl: Port info
-2009-05-08 16:30 strk
+2009-05-08 16:30 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/overlay/PolygonBuilder.h,
+ * [r2501] source/headers/geos/operation/overlay/PolygonBuilder.h,
source/operation/overlay/PolygonBuilder.cpp: Update port info
-2009-05-08 12:47 strk
+2009-05-08 12:47 Sandro Santilli <strk at keybit.net>
- * capi/geos_c.h.in: When included in a C++ environment, include
- <cstddef> and use std::size_t. Patch by Mateusz Loskot, ticket
- #252.
+ * [r2500] capi/geos_c.h.in: When included in a C++ environment,
+ include <cstddef> and use std::size_t. Patch by Mateusz Loskot,
+ ticket #252.
-2009-05-08 12:46 strk
+2009-05-08 12:46 Sandro Santilli <strk at keybit.net>
- * source/operation/distance/DistanceOp.cpp: Oops, forgot to update
- the static closedPoints signature..
+ * [r2499] source/operation/distance/DistanceOp.cpp: Oops, forgot to
+ update the static closedPoints signature..
-2009-05-08 12:29 strk
+2009-05-08 12:29 Sandro Santilli <strk at keybit.net>
- * NEWS: Note the withinDistance addition to DistanceOp
+ * [r2498] NEWS: Note the withinDistance addition to DistanceOp
-2009-05-08 12:27 strk
+2009-05-08 12:27 Sandro Santilli <strk at keybit.net>
- * tests/unit/operation/distance/DistanceOpTest.cpp: Add the
+ * [r2497] tests/unit/operation/distance/DistanceOpTest.cpp: Add the
complete set of tests for closedPoints
-2009-05-08 12:11 strk
+2009-05-08 12:11 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/distance/DistanceOp.h: Document
- semantic of a null return from closestPoints
+ * [r2496] source/headers/geos/operation/distance/DistanceOp.h:
+ Document semantic of a null return from closestPoints
-2009-05-08 12:09 strk
+2009-05-08 12:09 Sandro Santilli <strk at keybit.net>
+ * [r2495] source/headers/geos/operation/distance/DistanceOp.h,
source/operation/distance/DistanceOp.cpp: Don't wipe out closest
locations after computing them (doh). Fixes bug #236. Takes the
chance to make the GeometryLocation retrival function private as
@@ -2342,92 +2430,93 @@
cleanups), and to rename a function to follow current JTS naming
(more renames to come for proper sync)
-2009-05-08 10:10 strk
+2009-05-08 10:10 Sandro Santilli <strk at keybit.net>
+ * [r2494] source/headers/geos/operation/distance/DistanceOp.h,
source/operation/distance/DistanceOp.cpp: Add isWithinDistance()
to DistanceOp, reaching rev 1.17 of JTS
-2009-05-08 09:39 strk
+2009-05-08 09:39 Sandro Santilli <strk at keybit.net>
+ * [r2493] source/headers/geos/operation/distance/DistanceOp.h,
source/operation/distance/DistanceOp.cpp: Port info for
DistanceOp
-2009-05-08 08:44 strk
+2009-05-08 08:44 Sandro Santilli <strk at keybit.net>
- * capi/geos_c.h.in: Always include stddef.h. Closes bug #213
+ * [r2492] capi/geos_c.h.in: Always include stddef.h. Closes bug
+ #213
-2009-05-07 16:15 strk
+2009-05-07 16:15 Sandro Santilli <strk at keybit.net>
- "thread-safe" version of GEOSGeom_setSRID. Closes bug #242.
+ * [r2491] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp:
+ Add "thread-safe" version of GEOSGeom_setSRID. Closes bug #242.
-2009-05-07 16:00 strk
+2009-05-07 16:00 Sandro Santilli <strk at keybit.net>
- * tests/bigtest/bug234.cpp: minor debug output improvement
+ * [r2490] tests/bigtest/bug234.cpp: minor debug output improvement
-2009-05-07 15:57 strk
+2009-05-07 15:57 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/GeometryGraph.cpp, tests/bigtest/Makefile.am,
- tests/bigtest/README, tests/bigtest/bug234.cpp: Skip empty
- components when building GeometryGraph. Fixes bug #234. Add
- non-automated test for it, and README file in the directory
- containing it...
+ * [r2489] source/geomgraph/GeometryGraph.cpp,
+ tests/bigtest/Makefile.am, tests/bigtest/README,
+ tests/bigtest/bug234.cpp: Skip empty components when building
+ GeometryGraph. Fixes bug #234. Add non-automated test for it, and
+ README file in the directory containing it...
-2009-05-07 15:36 strk
+2009-05-07 15:36 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/Makefile.am, tests/xmltester/tests/bug188.xml:
- Add XML testcase for bug 188
+ * [r2488] tests/xmltester/Makefile.am,
+ tests/xmltester/tests/bug188.xml: Add XML testcase for bug 188
- * tests/xmltester/XMLTester.cpp: remove code duplication on buffer
- result validation
+ * [r2487] tests/xmltester/XMLTester.cpp: remove code duplication on
+ buffer result validation
-2009-05-07 08:52 strk
+2009-05-07 08:52 Sandro Santilli <strk at keybit.net>
- * source/geom/CoordinateSequenceFactory.cpp,
+ * [r2486] source/geom/CoordinateSequenceFactory.cpp,
source/headers/geos/geom/CoordinateSequenceFactory.h: Port info,
doxygen cleanups
-2009-05-07 08:45 strk
+2009-05-07 08:45 Sandro Santilli <strk at keybit.net>
- * tests/unit/capi/GEOSCoordSeqTest.cpp: Add test for creating a
- CoordinateSequence with at least 2 dimension
+ * [r2485] tests/unit/capi/GEOSCoordSeqTest.cpp: Add test for
+ creating a CoordinateSequence with at least 2 dimension
-2009-05-06 20:47 strk
+2009-05-06 20:47 Sandro Santilli <strk at keybit.net>
- * capi/geos_c.h.in, capi/geos_ts_c.cpp: Fix bug #135, give an hint
- about GEOSGeom_getDimensions being related to
+ * [r2484] capi/geos_c.h.in, capi/geos_ts_c.cpp: Fix bug #135, give
+ an hint about GEOSGeom_getDimensions being related to
GEOSCoordSeq_getDimensions, fix signed vs. unsigned compiler
warning.
-2009-05-06 20:22 strk
+2009-05-06 20:22 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/markup/MarkupSTL.cpp: Fix compilation warnings
- thrown by GCC 4.3.x. Patch by Mateus, closes bug #92.
+ * [r2483] tests/xmltester/markup/MarkupSTL.cpp: Fix compilation
+ warnings thrown by GCC 4.3.x. Patch by Mateus, closes bug #92.
-2009-05-06 20:12 mloskot
+2009-05-06 20:12 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/operation/overlay/snap: Updated svn:ignore
- property.
+ * [r2482] source/headers/geos/operation/overlay/snap: Updated
+ svn:ignore property.
-2009-05-06 17:54 strk
+2009-05-06 17:54 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/noding/SegmentNodeList.h,
+ * [r2481] source/headers/geos/noding/SegmentNodeList.h,
source/noding/SegmentNodeList.cpp:
findCollapsesFromExistingVertices: don't choke on sets of < 2
points. Fixes bug #219.
-2009-05-06 17:52 strk
+2009-05-06 17:52 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferBuilder.cpp: minor indentation
- thing
+ * [r2480] source/operation/buffer/BufferBuilder.cpp: minor
+ indentation thing
-2009-05-06 17:42 strk
+2009-05-06 17:42 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom/Makefile.am,
+ * [r2479] source/headers/geos/geom/Makefile.am,
source/headers/geos/index/chain/MonotoneChain.h,
source/headers/geos/index/chain/MonotoneChainOverlapAction.h,
source/headers/geos/noding/MCIndexNoder.h,
@@ -2439,15 +2528,16 @@
MonotoneChainOverlapAction, reduce heap allocations. Cascade
changes.
-2009-05-06 17:14 strk
+2009-05-06 17:14 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/index/chain/MonotoneChainOverlapAction.h,
+ * [r2478]
+ source/headers/geos/index/chain/MonotoneChainOverlapAction.h,
source/index/chain/MonotoneChainOverlapAction.cpp: Port info (to
be worked on for heap allocations reduction)
-2009-05-06 17:10 strk
+2009-05-06 17:10 Sandro Santilli <strk at keybit.net>
- * source/algorithm/MCPointInRing.cpp,
+ * [r2477] source/algorithm/MCPointInRing.cpp,
source/headers/geos/algorithm/MCPointInRing.h,
source/headers/geos/index/chain/MonotoneChainSelectAction.h,
source/index/chain/MonotoneChain.cpp,
@@ -2456,9 +2546,9 @@
MonotoneChainSelectAction port review, heap allocation reduced,
const-corrected.
-2009-05-06 16:44 strk
+2009-05-06 16:44 Sandro Santilli <strk at keybit.net>
+ * [r2476] source/algorithm/MCPointInRing.cpp,
source/headers/geos/index/SpatialIndex.h,
source/headers/geos/index/bintree/Bintree.h,
source/headers/geos/index/bintree/Root.h,
@@ -2474,52 +2564,53 @@
changes. Possibly discovered a leak in MCPointInRing algorithm,
needs some unit testing.
-2009-05-06 16:36 strk
+2009-05-06 16:36 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/index/bintree/Interval.h,
+ * [r2475] source/headers/geos/index/bintree/Interval.h,
source/index/bintree/Interval.cpp: Const-correctness for bintree
Interval
-2009-05-06 15:47 strk
+2009-05-06 15:47 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/index/chain/MonotoneChain.h,
+ * [r2474] source/headers/geos/index/chain/MonotoneChain.h,
source/index/chain/MonotoneChain.cpp: Port MonotoneChain up to
JTS-1.10, plus minor dox improvement (memory-oriented)
-2009-05-06 15:31 strk
+2009-05-06 15:31 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/index/chain/MonotoneChainBuilder.h,
+ * [r2473] source/headers/geos/index/chain/MonotoneChainBuilder.h,
source/index/chain/MonotoneChainBuilder.cpp: Port
MonotoneChainBuilder up to JTS-1.10. Tweak some signatures to use
stricter signedness.
-2009-05-06 14:55 strk
+2009-05-06 14:55 Sandro Santilli <strk at keybit.net>
+ * [r2472] source/headers/geos/index/chain/MonotoneChainBuilder.h,
source/index/chain/MonotoneChainBuilder.cpp: Port to 1.9, fixing
an out of boundary access in findEdgeEnd
-2009-05-06 14:42 strk
+2009-05-06 14:42 Sandro Santilli <strk at keybit.net>
+ * [r2471] source/headers/geos/index/chain/MonotoneChainBuilder.h,
source/index/chain/MonotoneChainBuilder.cpp: Add port info. We're
4 revision old (catching up next)
-2009-05-05 14:28 strk
+2009-05-05 14:28 Sandro Santilli <strk at keybit.net>
- * source/geom/Envelope.cpp, source/headers/geos/geom/Envelope.h,
+ * [r2470] source/geom/Envelope.cpp,
+ source/headers/geos/geom/Envelope.h,
source/headers/geos/geom/Envelope.inl: Sync Envelope to JTS-1.10
-2009-05-05 10:30 strk
+2009-05-05 10:30 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/XMLTester.cpp: Add compile-time support to skip
- use of BinaryOp thus engaging SnapIfNeededOverlayOp used by
- Geometry methods. Shows that BinaryOp (GEOS-specific original
+ * [r2469] tests/xmltester/XMLTester.cpp: Add compile-time support
+ to skip use of BinaryOp thus engaging SnapIfNeededOverlayOp used
+ by Geometry methods. Shows that BinaryOp (GEOS-specific original
work) gives better numerical stability.
-2009-05-05 10:14 strk
+2009-05-05 10:14 Sandro Santilli <strk at keybit.net>
- * configure.in, source/headers/geos/geom/BinaryOp.h,
+ * [r2468] configure.in, source/headers/geos/geom/BinaryOp.h,
source/headers/geos/operation/overlay/Makefile.am,
source/headers/geos/operation/overlay/snap/GeometrySnapper.h,
source/headers/geos/operation/overlay/snap/LineStringSnapper.h,
@@ -2541,24 +2632,26 @@
GeometrySnapper/LineStringSnapper classes in an unexpected
directory. Move them where they belong, sync with JTS-1.10.
-2009-05-05 00:04 strk
+2009-05-05 00:04 Sandro Santilli <strk at keybit.net>
- * source/geom/util/GeometryTransformer.cpp: Fix memory leak on
- exception
+ * [r2467] source/geom/util/GeometryTransformer.cpp: Fix memory leak
+ on exception
-2009-05-04 23:43 strk
+2009-05-04 23:43 Sandro Santilli <strk at keybit.net>
- * source/operation/IsSimpleOp.cpp: Fix memory bug
+ * [r2466] source/operation/IsSimpleOp.cpp: Fix memory bug
-2009-05-04 23:23 strk
+2009-05-04 23:23 Sandro Santilli <strk at keybit.net>
- * source/geom/Geometry.cpp, source/headers/geos/geom/Geometry.h,
+ * [r2465] source/geom/Geometry.cpp,
+ source/headers/geos/geom/Geometry.h,
source/headers/geos/geom/Geometry.inl: Geometry up to 1.112 with
a minor bugfix and performance improvement in Geometry::covers
-2009-05-04 23:04 strk
+2009-05-04 23:04 Sandro Santilli <strk at keybit.net>
+ * [r2464] source/geom/Geometry.cpp,
source/headers/geos/geom/Geometry.inl: Bring Geometry port up a
revision by having it use SnapIfNeededOp for overlay operations.
Note that currently this doesn't affect the C-API nor the
@@ -2566,18 +2659,19 @@
JTS-ported) doing about the same thing as the SnapIfNeededOp
class.
-2009-05-04 22:03 strk
+2009-05-04 22:03 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/overlay/Makefile.am,
+ * [r2463] source/headers/geos/operation/overlay/Makefile.am,
source/headers/geos/operation/overlay/snap/SnapIfNeededOverlayOp.h,
source/headers/geos/operation/overlay/snap/SnapOverlayOp.h,
source/operation/overlay/Makefile.am,
source/operation/overlay/snap/SnapIfNeededOverlayOp.cpp: Port
-2009-05-04 21:28 strk
+2009-05-04 21:28 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/overlay/FuzzyPointLocator.h,
+ * [r2462]
+ source/headers/geos/operation/overlay/FuzzyPointLocator.h,
source/headers/geos/operation/overlay/OffsetPointGenerator.h,
source/headers/geos/operation/overlay/OverlayResultValidator.h,
@@ -2604,9 +2698,9 @@
tests/unit/operation/overlay/validate/OverlayResultValidatorTest.cpp:
Move overlay.validate package files where they belong
-2009-05-04 21:02 strk
+2009-05-04 21:02 Sandro Santilli <strk at keybit.net>
+ * [r2461] source/headers/geos/operation/overlay/Makefile.am,
@@ -2615,25 +2709,26 @@
overlay.snap.SnapOverlayOp, update GeometrySnapper to be more
useful
-2009-05-04 19:54 strk
+2009-05-04 19:54 Sandro Santilli <strk at keybit.net>
+ * [r2460] source/headers/geos/operation/overlay/Makefile.am,
source/operation/overlay/snap/GeometrySnapper.cpp: Port
overlay.snap.GeometrySnapper
-2009-05-04 19:51 strk
+2009-05-04 19:51 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/overlay/snap/LineStringSnapper.h,
+ * [r2459]
+ source/headers/geos/operation/overlay/snap/LineStringSnapper.h,
source/operation/overlay/snap/LineStringSnapper.cpp: Extend to
accept a vector of const Coordinate pointers for snap pointers,
fix typo making it clone snap points rather than source points on
snapping...
-2009-05-02 11:01 strk
+2009-05-02 11:01 Sandro Santilli <strk at keybit.net>
+ * [r2458] source/headers/geos/operation/overlay/Makefile.am,
source/headers/geos/operation/overlay/snap,
@@ -2641,9 +2736,9 @@
source/operation/overlay/snap/LineStringSnapper.cpp: Port
overlay.snap.LineStringSnapper from JTS-1.10
-2009-05-02 10:59 strk
+2009-05-02 10:59 Sandro Santilli <strk at keybit.net>
+ * [r2457] source/geom/CoordinateArraySequence.cpp,
source/headers/geos/geom/CoordinateSequence.h,
tests/unit/geom/CoordinateArraySequenceTest.cpp: Add an
@@ -2651,36 +2746,36 @@
CoordinateList of JTS, historically bound to CoordinateSequence
in GEOS. Add test for that interface.
-2009-05-02 09:44 strk
+2009-05-02 09:44 Sandro Santilli <strk at keybit.net>
+ * [r2456] tests/xmltester/Makefile.am,
tests/xmltester/tests/general/MISSING,
tests/xmltester/tests/general/TestRectanglePredicate.xml: Copy
last portable JTS general test, add a file with info about what's
missing
-2009-05-02 09:42 strk
+2009-05-02 09:42 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/tests/testLeaksBig.xml: Drop test also found in
- TestFunctionPLPrec.xml
+ * [r2455] tests/xmltester/tests/testLeaksBig.xml: Drop test also
+ found in TestFunctionPLPrec.xml
-2009-05-02 09:40 strk
+2009-05-02 09:40 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/XMLTester.cpp: Add support for testing within,
- covers and coveredby. Properly use 'arg1' and 'arg2' for these
- tests.
+ * [r2454] tests/xmltester/XMLTester.cpp: Add support for testing
+ within, covers and coveredby. Properly use 'arg1' and 'arg2' for
+ these tests.
-2009-05-02 09:25 strk
+2009-05-02 09:25 Sandro Santilli <strk at keybit.net>
+ * [r2453] tests/xmltester/Makefile.am,
tests/xmltester/tests/general/TestWithinDistance.xml,
tests/xmltester/tests/testLeaksBig.xml: Copy
TestWithinDistance.xml test, drop duplicates from
testLeaksBig.xml
-2009-05-02 09:20 strk
+2009-05-02 09:20 Sandro Santilli <strk at keybit.net>
+ * [r2452] tests/xmltester/Makefile.am,
tests/xmltester/tests/general/TestFunctionAA.xml,
tests/xmltester/tests/general/TestFunctionAAPrec.xml,
tests/xmltester/tests/general/TestFunctionLA.xml,
@@ -2693,21 +2788,22 @@
tests/xmltester/tests/general/TestFunctionPP.xml: More tests from
JTS (TestFunction*)
-2009-05-02 09:17 strk
+2009-05-02 09:17 Sandro Santilli <strk at keybit.net>
+ * [r2451] tests/xmltester/Makefile.am,
tests/xmltester/tests/general/TestBoundary.xml: Boundary test
-2009-05-02 09:16 strk
+2009-05-02 09:16 Sandro Santilli <strk at keybit.net>
+ * [r2450] tests/xmltester/Makefile.am,
tests/xmltester/tests/general/TestConvexHull-big.xml,
tests/xmltester/tests/general/TestConvexHull.xml: ConvexHull
tests
-2009-05-02 09:11 strk
+2009-05-02 09:11 Sandro Santilli <strk at keybit.net>
+ * [r2449] tests/xmltester/Makefile.am,
tests/xmltester/tests/general/TestRelateAA.xml,
tests/xmltester/tests/general/TestRelateAC.xml,
tests/xmltester/tests/general/TestRelateLA.xml,
@@ -2718,9 +2814,9 @@
tests/xmltester/tests/general/TestRelatePP.xml: Add support for
testing 'contains' in XMLTester, add all Relate tests from JTS
-2009-05-02 09:01 strk
+2009-05-02 09:01 Sandro Santilli <strk at keybit.net>
+ * [r2448] tests/xmltester/Makefile.am,
tests/xmltester/tests/TestBuffer.xml,
tests/xmltester/tests/TestBufferMitredJoin.xml,
tests/xmltester/tests/TestCentroid.xml,
@@ -2740,18 +2836,18 @@
tests/xmltester/tests/general/TestValid2.xml: More organization
of xml tests: 'general' subdir following JTS
-2009-05-02 08:44 strk
+2009-05-02 08:44 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/Makefile.am, tests/xmltester/tests/stmlf,
+ * [r2447] tests/xmltester/Makefile.am, tests/xmltester/tests/stmlf,
tests/xmltester/tests/stmlf-cases-20061020.xml,
tests/xmltester/tests/stmlf-cases-20070119.xml,
tests/xmltester/tests/stmlf/stmlf-cases-20061020.xml,
tests/xmltester/tests/stmlf/stmlf-cases-20070119.xml: Put stml
testcases under their own dir (like in JTS)
-2009-05-02 08:37 strk
+2009-05-02 08:37 Sandro Santilli <strk at keybit.net>
+ * [r2446] tests/xmltester/Makefile.am,
tests/xmltester/tests/TestRobustOverlayFixed.xml,
tests/xmltester/tests/robust,
tests/xmltester/tests/robust/TestRobustOverlayFixed.xml,
@@ -2761,132 +2857,134 @@
TestRobustRelate.xml from JTS, organize robust-related tests as
in JTS repository.
-2009-04-30 12:42 strk
+2009-04-30 12:42 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/noding/snapround/SimpleSnapRounder.h: drop
- duplicated (and old) port info
+ * [r2444] source/headers/geos/noding/snapround/SimpleSnapRounder.h:
+ drop duplicated (and old) port info
-2009-04-30 12:33 strk
+2009-04-30 12:33 Sandro Santilli <strk at keybit.net>
- * NEWS, source/geom/Geometry.cpp,
+ * [r2443] NEWS, source/geom/Geometry.cpp,
source/headers/geos/geom/Geometry.inl: Update port info
-2009-04-30 12:17 strk
+2009-04-30 12:17 Sandro Santilli <strk at keybit.net>
- * source/geom/Point.cpp, source/headers/geos/geom/Point.h: Point
- full up to JTS-1.0 (rev 1.37) : adds reverse()
+ * [r2442] source/geom/Point.cpp, source/headers/geos/geom/Point.h:
+ Point full up to JTS-1.0 (rev 1.37) : adds reverse()
-2009-04-30 12:07 strk
+2009-04-30 12:07 Sandro Santilli <strk at keybit.net>
- * source/geom/LineString.cpp,
+ * [r2441] source/geom/LineString.cpp,
source/headers/geos/geom/LineString.h: LineString to rev 1.46 :
don't override isSimple, always return MultiPoint as bondary
-2009-04-30 11:47 strk
+2009-04-30 11:47 Sandro Santilli <strk at keybit.net>
- * source/geom/Polygon.cpp, source/headers/geos/geom/Polygon.h:
- Polygon to rev 1.50 (getBoundary always return MultiLineString)
+ * [r2440] source/geom/Polygon.cpp,
+ source/headers/geos/geom/Polygon.h: Polygon to rev 1.50
+ (getBoundary always return MultiLineString)
-2009-04-30 11:42 strk
+2009-04-30 11:42 Sandro Santilli <strk at keybit.net>
- * source/geom/MultiPoint.cpp,
+ * [r2439] source/geom/MultiPoint.cpp,
source/headers/geos/geom/MultiPoint.h: MultiPoint up to rev 1.30
(drop isSimple override)
-2009-04-30 11:36 strk
+2009-04-30 11:36 Sandro Santilli <strk at keybit.net>
- * source/geom/MultiLineString.cpp,
+ * [r2438] source/geom/MultiLineString.cpp,
source/headers/geos/geom/MultiLineString.h,
source/headers/geos/geom/MultiLineString.inl: MultiLineString
port info and sync to 1.40 (don't override isSimple)
-2009-04-30 11:29 strk
+2009-04-30 11:29 Sandro Santilli <strk at keybit.net>
- * source/geom/MultiPolygon.cpp,
+ * [r2437] source/geom/MultiPolygon.cpp,
source/headers/geos/geom/MultiPolygon.h,
source/headers/geos/geom/MultiPolygon.inl: MultiPolygon up to rev
1.34 (getBoundary always returns a MultiLineString now)
-2009-04-30 11:19 strk
+2009-04-30 11:19 Sandro Santilli <strk at keybit.net>
- * source/geom/GeometryCollection.cpp,
+ * [r2436] source/geom/GeometryCollection.cpp,
source/headers/geos/geom/GeometryCollection.h: Oops, *now* we're
at 1.14 (drop isSimple, rely on the one in base class)
-2009-04-30 11:15 strk
+2009-04-30 11:15 Sandro Santilli <strk at keybit.net>
+ * [r2435] source/geom/GeometryCollection.cpp,
source/headers/geos/geom/GeometryCollection.h,
source/headers/geos/geom/GeometryCollection.inl: Port info. It's
at 1.41 now, JTS is at 1.42
-2009-04-30 11:03 strk
+2009-04-30 11:03 Sandro Santilli <strk at keybit.net>
+ * [r2434] source/geom/Geometry.cpp,
source/headers/geos/geom/Geometry.inl: Geometry class up to JTS
rev 1.104 (need reach 1.127...)
-2009-04-30 10:59 strk
+2009-04-30 10:59 Sandro Santilli <strk at keybit.net>
- * NEWS: Add some info about things changed (might have missed
- something)
+ * [r2433] NEWS: Add some info about things changed (might have
+ missed something)
-2009-04-30 10:51 strk
+2009-04-30 10:51 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/IsSimpleOp.h,
+ * [r2432] source/headers/geos/operation/IsSimpleOp.h,
source/operation/IsSimpleOp.cpp: Sync to rev 1.22 (JTS-1.10)
-2009-04-30 10:47 strk
+2009-04-30 10:47 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation.h: EndpointInfo.h header is gone
- (it's always been private in JTS)
+ * [r2431] source/headers/geos/operation.h: EndpointInfo.h header is
+ gone (it's always been private in JTS)
-2009-04-30 10:46 strk
+2009-04-30 10:46 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/EndpointInfo.h,
+ * [r2430] source/headers/geos/operation/EndpointInfo.h,
source/headers/geos/operation/Makefile.am,
source/operation/IsSimpleOp.cpp: Port revision 1.9 of IsSimplOp :
allow inspecting non-simple location coordinate.
-2009-04-30 10:43 strk
+2009-04-30 10:43 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/EdgeIntersection.cpp,
+ * [r2429] source/geomgraph/EdgeIntersection.cpp,
source/headers/geos/geomgraph/EdgeIntersection.h: Sync to
revision 1.5 (JTS-1.10) : add accessors
-2009-04-30 09:54 strk
+2009-04-30 09:54 Sandro Santilli <strk at keybit.net>
+ * [r2428] source/headers/geos/operation/IsSimpleOp.h,
source/operation/IsSimpleOp.cpp: port to rev 1.8 (use of
BoundaryNodeRule)
-2009-04-30 09:49 strk
+2009-04-30 09:49 Sandro Santilli <strk at keybit.net>
+ * [r2427] tests/xmltester/Makefile.am,
tests/xmltester/tests/TestSimple.xml,
tests/xmltester/tests/testLeaksBig.xml: Import TestSimple.xml
from JTS, drop duplicated tests from testLeaksBig.xml
-2009-04-30 09:26 strk
+2009-04-30 09:26 Sandro Santilli <strk at keybit.net>
- * source/algorithm/BoundaryNodeRule.cpp,
+ * [r2426] source/algorithm/BoundaryNodeRule.cpp,
source/algorithm/Makefile.am,
source/headers/geos/algorithm/BoundaryNodeRule.h,
source/headers/geos/algorithm/Makefile.am: Port
algorithm::BoundaryNodeRule from JTS-1.10 (needed for IsSimpleOp
sync)
-2009-04-30 08:33 strk
+2009-04-30 08:33 Sandro Santilli <strk at keybit.net>
+ * [r2425] source/headers/geos/operation/IsSimpleOp.h,
source/operation/IsSimpleOp.cpp: Port info, and sync from 1.14 to
1.17 (more to do, need more classes)
-2009-04-29 23:52 mloskot
+2009-04-29 23:52 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/capi/GEOSContainsTest.cpp,
+ * [r2424] tests/unit/capi/GEOSContainsTest.cpp,
tests/unit/capi/GEOSCoordSeqTest.cpp,
tests/unit/capi/GEOSGeomFromWKBTest.cpp,
tests/unit/capi/GEOSGeomToWKTTest.cpp,
@@ -2896,30 +2994,31 @@
tests/unit/capi/GEOSWithinTest.cpp: test/unit/capi: re-tab all
.cpp files to use spaces.
-2009-04-29 23:46 mloskot
+2009-04-29 23:46 Mateusz Loskot <mateusz at loskot.net>
+ * [r2423] tests/unit/capi/GEOSContainsTest.cpp,
tests/unit/capi/GEOSWithinTest.cpp: Removed unused <memory>
header from C API tests.
-2009-04-29 23:44 mloskot
+2009-04-29 23:44 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/Makefile.am, tests/unit/capi/GEOSContainsTest.cpp,
+ * [r2422] tests/unit/Makefile.am,
+ tests/unit/capi/GEOSContainsTest.cpp,
tests/unit/capi/GEOSWithinTest.cpp: Added new unit tests for C
API: GEOSWithinTest and GEOSContainsTest. This is check and
response for problems reporting in Ticket #250. Running the new
tests does not reproduce the problem, so it likely has been fixed
or the bug is somewhere else (i.e. Django layers).
-2009-04-29 09:44 strk
+2009-04-29 09:44 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/util/GeometricShapeFactory.h,
+ * [r2421] source/headers/geos/util/GeometricShapeFactory.h,
source/util/GeometricShapeFactory.cpp: Sync GeometricShapeFactory
to JTS-1.10 (createArcPolygon added)
-2009-04-29 08:56 strk
+2009-04-29 08:56 Sandro Santilli <strk at keybit.net>
- * source/geom/prep/AbstractPreparedPolygonContains.cpp,
+ * [r2420] source/geom/prep/AbstractPreparedPolygonContains.cpp,
source/geom/prep/PreparedPolygonContainsProperly.cpp,
source/geom/prep/PreparedPolygonCovers.cpp,
source/geom/prep/PreparedPolygonIntersects.cpp,
@@ -2931,16 +3030,16 @@
source/headers/geos/geom/prep/PreparedPolygonPredicate.h: Bring
all geom::prep package in sync with JTS-1.10
-2009-04-29 08:22 strk
+2009-04-29 08:22 Sandro Santilli <strk at keybit.net>
- * source/geom/prep/BasicPreparedGeometry.cpp,
+ * [r2419] source/geom/prep/BasicPreparedGeometry.cpp,
source/headers/geos/geom/prep/BasicPreparedGeometry.h: Sync
BasicPreparedGeometry to JTS-1.10 (short-circuit in
containsProperly)
-2009-04-29 08:15 strk
+2009-04-29 08:15 Sandro Santilli <strk at keybit.net>
+ * [r2418] source/geom/prep/AbstractPreparedPolygonContains.cpp,
source/geom/prep/PreparedGeometry.cpp,
source/geom/prep/PreparedGeometryFactory.cpp,
@@ -2969,61 +3068,61 @@
port information for geom::prep package. Next stop: sync to
JTS-1.10.
-2009-04-27 19:47 strk
+2009-04-27 19:47 Sandro Santilli <strk at keybit.net>
- * tests/unit/capi/GEOSGeomToWKTTest.cpp: Plug last one. All heap
- blocks were freed -- no leaks are possible.
+ * [r2417] tests/unit/capi/GEOSGeomToWKTTest.cpp: Plug last one. All
+ heap blocks were freed -- no leaks are possible.
-2009-04-27 19:42 strk
+2009-04-27 19:42 Sandro Santilli <strk at keybit.net>
- * tests/unit/algorithm/RobustLineIntersectorTest.cpp: Fix leak in
- testcase
+ * [r2416] tests/unit/algorithm/RobustLineIntersectorTest.cpp: Fix
+ leak in testcase
-2009-04-27 19:38 strk
+2009-04-27 19:38 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/index/quadtree/Node.h,
+ * [r2415] source/headers/geos/index/quadtree/Node.h,
source/headers/geos/index/quadtree/Root.h,
source/index/quadtree/Node.cpp, source/index/quadtree/Root.cpp:
Refactor signatures to make ownership transfers more explicit.
Fixed another leak in Node::insertNode.
-2009-04-27 19:22 strk
+2009-04-27 19:22 Sandro Santilli <strk at keybit.net>
- * source/index/quadtree/NodeBase.cpp: Fix memory leak in
+ * [r2414] source/index/quadtree/NodeBase.cpp: Fix memory leak in
NodeBase::remove, exposed by unit testing
-2009-04-27 15:52 strk
+2009-04-27 15:52 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/index/quadtree/Root.h,
+ * [r2413] source/headers/geos/index/quadtree/Root.h,
source/index/quadtree/Root.cpp: Port info for quadtree::root
-2009-04-27 15:47 strk
+2009-04-27 15:47 Sandro Santilli <strk at keybit.net>
+ * [r2412] source/headers/geos/index/quadtree/Node.h,
source/index/quadtree/Node.cpp: Port info for quadtree::Node
-2009-04-27 15:39 strk
+2009-04-27 15:39 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/index/quadtree/IntervalSize.h,
+ * [r2411] source/headers/geos/index/quadtree/IntervalSize.h,
source/index/quadtree/IntervalSize.cpp: Port info and check,
doxygen.
-2009-04-27 15:30 strk
+2009-04-27 15:30 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/index/quadtree/Quadtree.h,
+ * [r2410] source/headers/geos/index/quadtree/Quadtree.h,
source/index/quadtree/Quadtree.cpp: Sync to JTS-1.10, reduce heap
allocations and pointers usage. Includes a bugfix in
collectStats.
-2009-04-27 15:00 strk
+2009-04-27 15:00 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/index/quadtree/DoubleBits.h,
+ * [r2409] source/headers/geos/index/quadtree/DoubleBits.h,
source/index/quadtree/DoubleBits.cpp: DoubleBits didn't change in
JTS, update port info accordingly
-2009-04-27 14:58 strk
+2009-04-27 14:58 Sandro Santilli <strk at keybit.net>
+ * [r2408] source/headers/geos/index/quadtree/Node.h,
source/headers/geos/index/quadtree/NodeBase.h,
source/index/quadtree/NodeBase.cpp,
@@ -3031,9 +3130,9 @@
port sync, add port info, drop unneeded pointers and virtuals,
document objects ownership.
-2009-04-25 00:23 strk
+2009-04-25 00:23 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/index/SpatialIndex.h,
+ * [r2407] source/headers/geos/index/SpatialIndex.h,
source/headers/geos/index/quadtree/Key.h,
source/index/quadtree/Key.cpp, source/index/quadtree/Node.cpp,
@@ -3041,205 +3140,207 @@
allocations and port info for quadtree::Key class, a few more
cleanups in user classes, to be continued.
-2009-04-24 23:44 strk
+2009-04-24 23:44 Sandro Santilli <strk at keybit.net>
- * source/index/quadtree/Quadtree.cpp: Fix memory leak in
+ * [r2406] source/index/quadtree/Quadtree.cpp: Fix memory leak in
Quadtree::remove
-2009-04-23 15:26 strk
+2009-04-23 15:26 Sandro Santilli <strk at keybit.net>
+ * [r2405] source/headers/geos/operation/buffer/BufferBuilder.h,
source/headers/geos/operation/buffer/OffsetCurveBuilder.h,
source/operation/buffer/BufferBuilder.cpp,
source/operation/buffer/OffsetCurveBuilder.cpp,
source/operation/buffer/OffsetCurveVertexList.h: Apply
Single-sided buffer patch, issue #215. UNTESTED.
-2009-04-21 16:11 strk
+2009-04-21 16:11 Sandro Santilli <strk at keybit.net>
+ * [r2404] tests/unit/Makefile.am,
tests/unit/operation/valid/ValidSelfTouchingRingFormingHoleTest.cpp:
Port ValidSelfTouchingRingFormingHoleTest
-2009-04-21 15:30 strk
+2009-04-21 15:30 Sandro Santilli <strk at keybit.net>
+ * [r2403] tests/unit/Makefile.am,
tests/unit/operation/valid/ValidClosedRingTest.cpp: Port
ValidClosedRingTest
-2009-04-21 15:13 strk
+2009-04-21 15:13 Sandro Santilli <strk at keybit.net>
+ * [r2402] source/geom/LineString.cpp,
source/headers/geos/geom/LineString.h: ::reverse returns a
Geometry now (to be available up in base class)
-2009-04-21 15:12 strk
+2009-04-21 15:12 Sandro Santilli <strk at keybit.net>
- * source/geom/LinearRing.cpp,
+ * [r2401] source/geom/LinearRing.cpp,
source/headers/geos/geom/LinearRing.h,
tests/unit/geom/LinearRingTest.cpp: Sync LinearRing to JTS-1.10
(fixing a bug in isClosed)
-2009-04-21 14:03 strk
+2009-04-21 14:03 Sandro Santilli <strk at keybit.net>
- * tests/unit/Makefile.am, tests/unit/operation/valid,
+ * [r2400] tests/unit/Makefile.am, tests/unit/operation/valid,
tests/unit/operation/valid/IsValidTest.cpp: Port IsValidOp unit
test
-2009-04-21 11:14 strk
+2009-04-21 11:14 Sandro Santilli <strk at keybit.net>
- * configure.in: Configure for CXX, not C. Should fix unknown tag
- and link issues on telascience.
+ * [r2399] configure.in: Configure for CXX, not C. Should fix
+ unknown tag and link issues on telascience.
-2009-04-21 09:06 strk
+2009-04-21 09:06 Sandro Santilli <strk at keybit.net>
- * configure.in: Add an AC_LIBTOOL_LANG_C_CONFIG call right before
- the AC_LIBTOOL_COMPILER_OPTION calls. Seems to fix compiler
- selection on telascience (whereas AC_LANG and AC_LANG_PUSH didn't
- work)
+ * [r2398] configure.in: Add an AC_LIBTOOL_LANG_C_CONFIG call right
+ before the AC_LIBTOOL_COMPILER_OPTION calls. Seems to fix
+ compiler selection on telascience (whereas AC_LANG and
+ AC_LANG_PUSH didn't work)
-2009-04-20 20:32 strk
+2009-04-20 20:32 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/BufferResultMatcher.cpp,
+ * [r2397] tests/xmltester/BufferResultMatcher.cpp,
tests/xmltester/BufferResultMatcher.h: Use JTS heuristic for
distance-0 buffer checking
-2009-04-20 11:04 mloskot
+2009-04-20 11:04 Mateusz Loskot <mateusz at loskot.net>
- * tests/perf, tests/perf/operation, tests/perf/operation/buffer:
- Updated svn:ignore patterns.
+ * [r2396] tests/perf, tests/perf/operation,
+ tests/perf/operation/buffer: Updated svn:ignore patterns.
-2009-04-20 10:37 strk
+2009-04-20 10:37 Sandro Santilli <strk at keybit.net>
- * configure.in, tests/Makefile.am, tests/perf,
+ * [r2395] configure.in, tests/Makefile.am, tests/perf,
tests/perf/Makefile.am, tests/perf/operation,
tests/perf/operation/Makefile.am, tests/perf/operation/buffer,
tests/perf/operation/buffer/IteratedBufferStressTest.cpp,
tests/perf/operation/buffer/Makefile.am: Port
IteratedBufferStessTest
-2009-04-20 09:37 strk
+2009-04-20 09:37 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/Quadrant.cpp,
+ * [r2394] source/geomgraph/Quadrant.cpp,
source/headers/geos/geomgraph/Quadrant.h: Add named constants,
sync to JTS-1.10
-2009-04-20 09:24 mloskot
+2009-04-20 09:24 Mateusz Loskot <mateusz at loskot.net>
- * source/algorithm/distance,
+ * [r2393] source/algorithm/distance,
source/headers/geos/algorithm/distance: Updated svn:ignore
patterns.
-2009-04-18 07:55 strk
+2009-04-18 07:55 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/XMLTester.cpp: Use BufferResultMatcher for buffer
- operations. No failures.
+ * [r2392] tests/xmltester/XMLTester.cpp: Use BufferResultMatcher
+ for buffer operations. No failures.
-2009-04-18 07:49 strk
+2009-04-18 07:49 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/tests/TestBigNastyBuffer.xml: Imported cleaned-up
- version of fme.xml -- this one fails (the one we have is actually
- expecting a wrong result)
+ * [r2391] tests/xmltester/tests/TestBigNastyBuffer.xml: Imported
+ cleaned-up version of fme.xml -- this one fails (the one we have
+ is actually expecting a wrong result)
-2009-04-18 07:46 strk
+2009-04-18 07:46 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/BufferResultMatcher.cpp: Don't densify
+ * [r2390] tests/xmltester/BufferResultMatcher.cpp: Don't densify
coordinates if buffer distance is 0
-2009-04-17 16:50 strk
+2009-04-17 16:50 Sandro Santilli <strk at keybit.net>
- * tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp:
+ * [r2389]
+ tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp:
comment out debugging lines
-2009-04-17 16:49 strk
+2009-04-17 16:49 Sandro Santilli <strk at keybit.net>
- * tests/unit/Makefile.am, tests/unit/algorithm/distance,
+ * [r2388] tests/unit/Makefile.am, tests/unit/algorithm/distance,
Port DiscreteHausdorffDistance unit test
-2009-04-17 16:47 strk
+2009-04-17 16:47 Sandro Santilli <strk at keybit.net>
- * source/algorithm/distance/DiscreteHausdorffDistance.cpp,
+ * [r2387] source/algorithm/distance/DiscreteHausdorffDistance.cpp,
source/headers/geos/algorithm/distance/DiscreteHausdorffDistance.h:
Offline some more
-2009-04-17 16:46 strk
+2009-04-17 16:46 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/algorithm/distance/PointPairDistance.h: Fix
+ * [r2386]
+ source/headers/geos/algorithm/distance/PointPairDistance.h: Fix
typo
-2009-04-17 16:26 strk
+2009-04-17 16:26 Sandro Santilli <strk at keybit.net>
+ * [r2385] source/algorithm/distance/DiscreteHausdorffDistance.cpp,
Add missing implementation bits
-2009-04-17 15:47 strk
+2009-04-17 15:47 Sandro Santilli <strk at keybit.net>
+ * [r2384] tests/xmltester/BufferResultMatcher.cpp,
tests/xmltester/BufferResultMatcher.h,
tests/xmltester/XMLTester.cpp: Port BufferResultMatcher. Gives 31
new failures !!
-2009-04-17 15:37 strk
+2009-04-17 15:37 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom/BinaryOp.h, tests/xmltester/Makefile.am,
- tests/xmltester/XMLTester.cpp: proper inline check_valid
- source/headers/geos/geom/BinaryOp.h
+ * [r2383] source/headers/geos/geom/BinaryOp.h,
+ tests/xmltester/Makefile.am, tests/xmltester/XMLTester.cpp:
+ proper inline check_valid source/headers/geos/geom/BinaryOp.h
-2009-04-17 15:34 strk
+2009-04-17 15:34 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom/BinaryOp.h: Header guard
+ * [r2382] source/headers/geos/geom/BinaryOp.h: Header guard
-2009-04-17 13:59 strk
+2009-04-17 13:59 Sandro Santilli <strk at keybit.net>
- * source/algorithm/LineIntersector.cpp,
+ * [r2381] source/algorithm/LineIntersector.cpp,
source/headers/geos/algorithm/LineIntersector.h,
tests/unit/algorithm/RobustLineIntersectorTest.cpp: renamed
intersection constants
-2009-04-17 09:56 strk
+2009-04-17 09:56 Sandro Santilli <strk at keybit.net>
- * configure.in: Add debugging output of variables used by
+ * [r2380] configure.in: Add debugging output of variables used by
AC_LIBTOOL_COMPILER_OPTION. Surprisingly, the buildbots try to
use a fortran compiler there
-2009-04-17 07:50 strk
+2009-04-17 07:50 Sandro Santilli <strk at keybit.net>
- * configure.in: Differentiate variable used in
+ * [r2379] configure.in: Differentiate variable used in
AC_LIBTOOL_COMPILE_OPTION for proper use of configuration cache
-2009-04-16 18:05 strk
+2009-04-16 18:05 Sandro Santilli <strk at keybit.net>
- * configure.in: Use -ffloat-store flag when available. See
+ * [r2378] configure.in: Use -ffloat-store flag when available. See
http://lists.osgeo.org/pipermail/geos-devel/2009-April/004089.html
-2009-04-16 12:56 strk
+2009-04-16 12:56 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/algorithm/LineIntersector.h: Make enum values
- explicit, as JTS tests rely on those..
+ * [r2377] source/headers/geos/algorithm/LineIntersector.h: Make
+ enum values explicit, as JTS tests rely on those..
-2009-04-16 12:54 strk
+2009-04-16 12:54 Sandro Santilli <strk at keybit.net>
+ * [r2376] tests/unit/Makefile.am,
tests/unit/algorithm/RobustLineIntersectorTest.cpp: Port
RobustLineIntersectorTest from JTS
-2009-04-16 12:08 strk
+2009-04-16 12:08 Sandro Santilli <strk at keybit.net>
- * tests/unit/algorithm/RobustLineIntersectionTest.cpp: better
- isolation of test-specific functions
+ * [r2375] tests/unit/algorithm/RobustLineIntersectionTest.cpp:
+ better isolation of test-specific functions
-2009-04-16 10:48 strk
+2009-04-16 10:48 Sandro Santilli <strk at keybit.net>
+ * [r2374] tests/unit/Makefile.am,
tests/unit/algorithm/RobustLineIntersectionTest.cpp: Port
RobustLineIntersectionTest (mostly failing, but reported by
Martin Davis to be expected)
-2009-04-15 15:58 strk
+2009-04-15 15:58 Sandro Santilli <strk at keybit.net>
+ * [r2373] source/algorithm/distance/DiscreteHausdorffDistance.cpp,
source/algorithm/distance/DistanceToPoint.cpp,
source/algorithm/distance/EuclideanDistanceToPoint.cpp,
source/algorithm/distance/Makefile.am,
@@ -3249,46 +3350,47 @@
source/headers/geos/algorithm/distance/Makefile.am: New class
rename, following JTS
-2009-04-15 12:56 strk
+2009-04-15 12:56 Sandro Santilli <strk at keybit.net>
- * source/algorithm/HCoordinate.cpp: typo in disabled section
+ * [r2372] source/algorithm/HCoordinate.cpp: typo in disabled
+ section
-2009-04-15 11:17 strk
+2009-04-15 11:17 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/index/quadtree/Key.h,
+ * [r2371] source/headers/geos/index/quadtree/Key.h,
source/index/quadtree/Key.cpp: Few more docs about memory
management in quadtree indexing; fix a potential leak in
quadtree::Key
-2009-04-15 10:43 strk
+2009-04-15 10:43 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/index/quadtree/NodeBase.h: Document ownership
- of quadtree::NodeBase subnodes
+ * [r2370] source/headers/geos/index/quadtree/NodeBase.h: Document
+ ownership of quadtree::NodeBase subnodes
-2009-04-15 10:18 strk
+2009-04-15 10:18 Sandro Santilli <strk at keybit.net>
- * tests/unit/util/UniqueCoordinateArrayFilterTest.cpp: Fix memory
- leak in unit test
+ * [r2369] tests/unit/util/UniqueCoordinateArrayFilterTest.cpp: Fix
+ memory leak in unit test
-2009-04-15 10:02 strk
+2009-04-15 10:02 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom/CoordinateSequence.h,
+ * [r2368] source/headers/geos/geom/CoordinateSequence.h,
source/headers/geos/geom/util/CoordinateOperation.h,
source/precision/SimpleGeometryPrecisionReducer.cpp: Fix leak in
SimpleGeometryPrecisionReducer, improve memory management docs
where topic.
-2009-04-15 09:29 strk
+2009-04-15 09:29 Sandro Santilli <strk at keybit.net>
+ * [r2367] source/headers/geos/operation/distance/DistanceOp.h,
tests/unit/operation/distance/DistanceOpTest.cpp: Document
ownership of DistanceOp::closestPoints return, fix leak in unit
test.
-2009-04-15 09:25 strk
+2009-04-15 09:25 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/EdgeRing.cpp,
+ * [r2366] source/geomgraph/EdgeRing.cpp,
source/headers/geos/geomgraph/EdgeRing.h,
@@ -3298,32 +3400,33 @@
stmlf-cases-20061020.xml testcase. This commit also adds some
doc-only throw specs related to the bug.
-2009-04-15 07:52 strk
+2009-04-15 07:52 Sandro Santilli <strk at keybit.net>
- * source/operation/valid/IndexedNestedRingTester.cpp: Fix memory
- leaks in IsValid operation
+ * [r2365] source/operation/valid/IndexedNestedRingTester.cpp: Fix
+ memory leaks in IsValid operation
-2009-04-15 00:27 strk
+2009-04-15 00:27 Sandro Santilli <strk at keybit.net>
- * source/algorithm/HCoordinate.cpp: Explain why unrolled
+ * [r2364] source/algorithm/HCoordinate.cpp: Explain why unrolled
computation is turned off, and keep it off
-2009-04-15 00:14 strk
+2009-04-15 00:14 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferInputLineSimplifier.cpp: Fix typo
- in computing angleOrientation
+ * [r2363] source/operation/buffer/BufferInputLineSimplifier.cpp:
+ Fix typo in computing angleOrientation
-2009-04-14 19:11 strk
+2009-04-14 19:11 Sandro Santilli <strk at keybit.net>
- * source/algorithm/HCoordinate.cpp, tests/xmltester/Makefile.am,
+ * [r2362] source/algorithm/HCoordinate.cpp,
tests/xmltester/tests/TestBufferMitredJoin.xml: Temporarly revert
the unrolled computation in HCoordinate::intersection. Added
mitred join buffer test from JTS (failed with the unrolled comp,
to be further inspected).
-2009-04-14 16:43 strk
+2009-04-14 16:43 Sandro Santilli <strk at keybit.net>
- * configure.in, source/algorithm/Makefile.am,
+ * [r2361] configure.in, source/algorithm/Makefile.am,
@@ -3337,9 +3440,10 @@
source/headers/geos/geom/CoordinateSequenceFilter.h: Port the
algorithm::distance package from JTS 1.9
-2009-04-14 15:25 strk
+2009-04-14 15:25 Sandro Santilli <strk at keybit.net>
- * source/geom/Geometry.cpp, source/geom/GeometryCollection.cpp,
+ * [r2360] source/geom/Geometry.cpp,
+ source/geom/GeometryCollection.cpp,
source/geom/GeometryComponentFilter.cpp,
source/geom/LineString.cpp, source/geom/Point.cpp,
@@ -3353,36 +3457,37 @@
support, fix default GeometryComponentFilter moving the logic to
the correct place (a Geometry private class).
-2009-04-14 13:35 strk
+2009-04-14 13:35 Sandro Santilli <strk at keybit.net>
+ * [r2359] source/algorithm/LineIntersector.cpp,
source/headers/geos/algorithm/LineIntersector.h: Sync
(Robust)LineIntersector to JTS-1.9
-2009-04-14 13:23 strk
+2009-04-14 13:23 Sandro Santilli <strk at keybit.net>
- * source/algorithm/CGAlgorithms.cpp,
+ * [r2358] source/algorithm/CGAlgorithms.cpp,
source/headers/geos/algorithm/CGAlgorithms.h: Sync CGAlgorithms
with JTS-1.9
-2009-04-14 12:55 strk
+2009-04-14 12:55 Sandro Santilli <strk at keybit.net>
- * source/algorithm/RayCrossingCounter.cpp,
+ * [r2357] source/algorithm/RayCrossingCounter.cpp,
source/headers/geos/algorithm/RayCrossingCounter.h: Fix memory
leak in RayCrossingCounter; update signatures to avoid pointers
when unneeded; add a locatePointInRing taking a vector of
coordinate pointers, for use by CGAlgorithms
-2009-04-14 12:42 strk
+2009-04-14 12:42 Sandro Santilli <strk at keybit.net>
+ * [r2356] source/algorithm/RayCrossingCounter.cpp,
source/headers/geos/algorithm/RayCrossingCounter.h: Update port
info, checked against JTS-1.9
-2009-04-14 11:03 strk
+2009-04-14 11:03 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/Makefile.am, tests/xmltester/TestBuffer.xml,
+ * [r2355] tests/xmltester/Makefile.am,
+ tests/xmltester/TestBuffer.xml,
tests/xmltester/TestBufferExternal.xml,
tests/xmltester/TestBufferExternal2.xml,
tests/xmltester/TestCentroid.xml,
@@ -3426,19 +3531,20 @@
tests/xmltester/tests/testLeaksBig.xml: Move XML tests under
their own directory
-2009-04-14 10:50 strk
+2009-04-14 10:50 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferBuilder.cpp: Fix memory leak in
- BufferBuilder (due to just-ported short-circuit)
+ * [r2354] source/operation/buffer/BufferBuilder.cpp: Fix memory
+ leak in BufferBuilder (due to just-ported short-circuit)
-2009-04-14 10:27 strk
+2009-04-14 10:27 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/XMLTester.cpp: Add support for bufferMitredJoin
- tests
+ * [r2353] tests/xmltester/XMLTester.cpp: Add support for
+ bufferMitredJoin tests
-2009-04-14 09:53 strk
+2009-04-14 09:53 Sandro Santilli <strk at keybit.net>
+ * [r2352] tests/xmltester/Makefile.am,
tests/xmltester/XMLTester.cpp, tests/xmltester/badguy3.xml,
@@ -3448,53 +3554,56 @@
arg3 for quadrant segments); copy buffer-related tests from jts:
they succeed w/out editing.
-2009-04-14 09:22 strk
+2009-04-14 09:22 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/buffer/SubgraphDepthLocater.h,
+ * [r2351]
+ source/headers/geos/operation/buffer/SubgraphDepthLocater.h,
info of SubgraphDepthLocater
-2009-04-14 09:19 strk
+2009-04-14 09:19 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/buffer/RightmostEdgeFinder.h,
+ * [r2350]
+ source/headers/geos/operation/buffer/RightmostEdgeFinder.h,
source/operation/buffer/RightmostEdgeFinder.cpp: Update port info
for RightmostEdgeFinder (checked)
-2009-04-14 09:14 strk
+2009-04-14 09:14 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/buffer/BufferSubgraph.h,
+ * [r2349] source/headers/geos/operation/buffer/BufferSubgraph.h,
source/operation/buffer/BufferSubgraph.cpp: Sync BufferSubgraph
to JTS-1.9
-2009-04-14 08:52 strk
+2009-04-14 08:52 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/buffer/OffsetCurveBuilder.h,
+ * [r2348]
+ source/headers/geos/operation/buffer/OffsetCurveBuilder.h,
source/operation/buffer/OffsetCurveBuilder.cpp: Port
OffsetCurveBuilder from JTS-1.9. Twenty time faster completion of
fme.xml testcase !
-2009-04-10 20:22 strk
+2009-04-10 20:22 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferInputLineSimplifier.cpp,
+ * [r2347] source/operation/buffer/BufferInputLineSimplifier.cpp,
source/operation/buffer/BufferInputLineSimplifier.h,
source/operation/buffer/Makefile.am: Port
BufferInputLineSimplifier from JTS 1.9
-2009-04-10 15:15 mloskot
+2009-04-10 15:15 Mateusz Loskot <mateusz at loskot.net>
- * configure.in: Do not generate Makefile for tests/unit/tut. Fixed
- bug reported as #247.
+ * [r2346] configure.in: Do not generate Makefile for
+ tests/unit/tut. Fixed bug reported as #247.
-2009-04-10 12:08 strk
+2009-04-10 12:08 Sandro Santilli <strk at keybit.net>
- * source/geom/LineSegment.cpp,
+ * [r2345] source/geom/LineSegment.cpp,
source/headers/geos/geom/LineSegment.h,
source/headers/geos/geom/LineSegment.inl: Sync LineSegment with
JTS-1.9
-2009-04-09 21:46 mloskot
+2009-04-09 21:46 Mateusz Loskot <mateusz at loskot.net>
+ * [r2344] tests/unit/Makefile.am,
tests/unit/algorithm/CGAlgorithms/computeOrientationTest.cpp,
tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp,
tests/unit/algorithm/CGAlgorithms/isPointInRingTest.cpp,
@@ -3556,25 +3665,25 @@
tests/unit/utility.h: Updated tests/unit package with latest
relase of C++ TUT Framework from 2008-11-30.
-2009-04-09 19:39 mloskot
+2009-04-09 19:39 Mateusz Loskot <mateusz at loskot.net>
- * configure.in, tests/Makefile.am, tests/tut,
+ * [r2343] configure.in, tests/Makefile.am, tests/tut,
tests/unit/Makefile.am, tests/unit/tut,
tests/unit/tut/Makefile.am, tests/unit/tut/tut.h,
tests/unit/tut/tut_reporter.h, tests/unit/tut/tut_restartable.h:
Moved tests/tut to tests/unit/tut. Preparing for update to latest
version of C++ TUT Framework.
-2009-04-09 16:22 strk
+2009-04-09 16:22 Sandro Santilli <strk at keybit.net>
- * source/algorithm/Angle.cpp, source/algorithm/Makefile.am,
+ * [r2342] source/algorithm/Angle.cpp, source/algorithm/Makefile.am,
source/headers/geos/algorithm/Angle.h,
source/headers/geos/algorithm/Makefile.am: Port algorithm.Angle
from JTS-1.9
-2009-04-09 11:45 strk
+2009-04-09 11:45 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/buffer/BufferBuilder.h,
+ * [r2341] source/headers/geos/operation/buffer/BufferBuilder.h,
source/headers/geos/operation/buffer/BufferOp.h,
@@ -3584,93 +3693,95 @@
OffsetCurveBuilder to use of BufferParameter (needs more work for
JTS-sync).
-2009-04-09 10:21 strk
+2009-04-09 10:21 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/buffer/BufferParameters.h: typo
+ * [r2340] source/headers/geos/operation/buffer/BufferParameters.h:
+ typo
-2009-04-09 09:45 strk
+2009-04-09 09:45 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/buffer/BufferParameters.h,
+ * [r2339] source/headers/geos/operation/buffer/BufferParameters.h,
source/headers/geos/operation/buffer/Makefile.am,
source/operation/buffer/BufferParameters.cpp,
source/operation/buffer/Makefile.am: Port BufferParameters from
JTS-1.9
-2009-04-09 08:54 strk
+2009-04-09 08:54 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/OffsetCurveBuilder.cpp,
+ * [r2338] source/operation/buffer/OffsetCurveBuilder.cpp,
source/operation/buffer/OffsetCurveVertexList.h: Sync port of
OffsetCurveVertexList to JTS-1.9, improve memory management
documentation (would need some refactoring/love)
-2009-04-08 16:52 strk
+2009-04-08 16:52 Sandro Santilli <strk at keybit.net>
+ * [r2337] source/geomgraph/EdgeList.cpp,
source/headers/geos/geomgraph/EdgeList.h,
source/headers/geos/noding/OrientedCoordinateArray.h: Improve
duplicate edge detection performance (JTS-1.9 sync) - fme.xml
runs 3 times as fast now.
-2009-04-08 16:17 strk
+2009-04-08 16:17 Sandro Santilli <strk at keybit.net>
- * source/noding/OrientedCoordinateArray.cpp: const correctness
+ * [r2332] source/noding/OrientedCoordinateArray.cpp: const
+ correctness
-2009-04-08 15:38 strk
+2009-04-08 15:38 Sandro Santilli <strk at keybit.net>
- * capi/geos_c.h.in: Fix documentation for GEOSPrepare,
+ * [r2329] capi/geos_c.h.in: Fix documentation for GEOSPrepare,
GEOSPrepare_r
-2009-04-08 14:54 strk
+2009-04-08 14:54 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/noding/Makefile.am,
+ * [r2328] source/headers/geos/noding/Makefile.am,
source/headers/geos/noding/OrientedCoordinateArray.h,
source/noding/Makefile.am,
OrientedCoordinateArray ported from JTS
-2009-04-08 14:41 strk
+2009-04-08 14:41 Sandro Santilli <strk at keybit.net>
- * source/geom/CoordinateSequence.cpp,
+ * [r2327] source/geom/CoordinateSequence.cpp,
source/headers/geos/geom/CoordinateSequence.h: Add
increasingDirection static method, from JTS's CoordinateArray
(GEOS puts all of them in CoordinateSequence for historical
reasons)
-2009-04-08 13:16 strk
+2009-04-08 13:16 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/noding/snapround/SimpleSnapRounder.h,
+ * [r2326] source/headers/geos/noding/snapround/SimpleSnapRounder.h,
source/noding/snapround/SimpleSnapRounder.cpp: Complete porting
of SimpleSnapRounder (refactoring for adding snapped nodes)
-2009-04-08 13:02 strk
+2009-04-08 13:02 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/noding/SegmentStringUtil.h: Improve
+ * [r2325] source/headers/geos/noding/SegmentStringUtil.h: Improve
documentation about memory usage for SegmentStringUtil class
-2009-04-08 12:58 strk
+2009-04-08 12:58 Sandro Santilli <strk at keybit.net>
+ * [r2324] tests/unit/Makefile.am,
tests/unit/capi/GEOSPreparedGeometryTest.cpp: Stub initial unit
tests for C-API's GEOSPreparedGeometry operations. Helped fixing
issue 147 of postgis
-2009-04-08 12:55 strk
+2009-04-08 12:55 Sandro Santilli <strk at keybit.net>
- * source/geom/prep/PreparedPolygonContainsProperly.cpp: Don't
- access deleted memory. Fixes issue 147.
+ * [r2323] source/geom/prep/PreparedPolygonContainsProperly.cpp:
+ Don't access deleted memory. Fixes issue 147.
-2009-04-08 10:53 strk
+2009-04-08 10:53 Sandro Santilli <strk at keybit.net>
- * source/noding/snapround/HotPixel.cpp: Fix typo
+ * [r2322] source/noding/snapround/HotPixel.cpp: Fix typo
-2009-04-08 10:06 strk
+2009-04-08 10:06 Sandro Santilli <strk at keybit.net>
- * tests/unit/noding/SegmentNodeTest.cpp: Add a couple more tests to
- SegmentNode unit test
+ * [r2321] tests/unit/noding/SegmentNodeTest.cpp: Add a couple more
+ tests to SegmentNode unit test
-2009-04-08 09:42 strk
+2009-04-08 09:42 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/noding/NodableSegmentString.h,
+ * [r2320] source/headers/geos/noding/NodableSegmentString.h,
source/headers/geos/noding/NodedSegmentString.h,
source/headers/geos/noding/SegmentNode.h,
@@ -3679,9 +3790,9 @@
tests/unit/noding/SegmentPointComparatorTest.cpp: Port
SegmentNode to JTS-1.9
-2009-04-07 19:00 strk
+2009-04-07 19:00 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/EdgeNodingValidator.cpp,
+ * [r2319] source/geomgraph/EdgeNodingValidator.cpp,
source/headers/geos/geomgraph/EdgeNodingValidator.h,
source/headers/geos/noding/BasicSegmentString.h,
source/headers/geos/noding/IntersectionAdder.h,
@@ -3719,224 +3830,228 @@
tests/unit/noding/SegmentStringTest.cpp: Refactor SegmentString
to be an abstract class, to be in sync with JTS-1.9.
-2009-04-07 12:36 strk
+2009-04-07 12:36 Sandro Santilli <strk at keybit.net>
- * source/operation/valid/IndexedNestedRingTester.cpp,
+ * [r2318] source/operation/valid/IndexedNestedRingTester.cpp,
source/operation/valid/IndexedNestedRingTester.h: update
copyright notice
-2009-04-07 11:11 strk
+2009-04-07 11:11 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/noding/snapround/HotPixel.h,
+ * [r2317] source/headers/geos/noding/snapround/HotPixel.h,
source/headers/geos/noding/snapround/HotPixel.inl,
source/noding/snapround/HotPixel.cpp: Sync HotPixel to JTS-1.9
(rev 1.3); fix a few bugs and use standard algorithms for min/max
-2009-04-07 10:48 strk
+2009-04-07 10:48 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/noding/NodedSegmentString.h: Fix signed vs.
- unsigned compiler warning
+ * [r2316] source/headers/geos/noding/NodedSegmentString.h: Fix
+ signed vs. unsigned compiler warning
-2009-04-07 10:18 strk
+2009-04-07 10:18 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/valid/IsValidOp.h: Port info,
- indenting
+ * [r2315] source/headers/geos/operation/valid/IsValidOp.h: Port
+ info, indenting
-2009-04-07 09:56 strk
+2009-04-07 09:56 Sandro Santilli <strk at keybit.net>
+ * [r2314] source/operation/valid/IndexedNestedRingTester.cpp,
source/operation/valid/IndexedNestedRingTester.h,
source/operation/valid/IsValidOp.cpp,
source/operation/valid/Makefile.am: Port IndexedNestedRingTester
and have IsValidOp use it, syncing the operation to JTS-1.9
-2009-04-07 09:55 strk
+2009-04-07 09:55 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/noding/SegmentStringUtil.h: Update port info,
- minor tweaks to doxygen comments
+ * [r2313] source/headers/geos/noding/SegmentStringUtil.h: Update
+ port info, minor tweaks to doxygen comments
-2009-04-07 08:14 strk
+2009-04-07 08:14 Sandro Santilli <strk at keybit.net>
+ * [r2312] source/algorithm/HCoordinate.cpp,
source/headers/geos/algorithm/HCoordinate.h: Sync HCoordinate
class to JTS-1.9 (rev 1.18)
-2009-04-03 15:27 mloskot
+2009-04-03 15:27 Mateusz Loskot <mateusz at loskot.net>
- * nmake.opt: Added _NMAKE_VER 9.00.21022.08 to nmake.opt. Fixed bug
- with using BUILD_DEBUG instead of BUILD_BATCH in nmake.opt.
+ * [r2311] nmake.opt: Added _NMAKE_VER 9.00.21022.08 to nmake.opt.
+ Fixed bug with using BUILD_DEBUG instead of BUILD_BATCH in
+ nmake.opt.
-2009-03-27 02:39 mloskot
+2009-03-27 02:39 Mateusz Loskot <mateusz at loskot.net>
- * build/msvc80/geos.sln, build/msvc80/geos_lib/geos_lib.vcproj:
- Updated build/msvc80.
+ * [r2310] build/msvc80/geos.sln,
+ build/msvc80/geos_lib/geos_lib.vcproj: Updated build/msvc80.
-2009-03-27 02:38 mloskot
+2009-03-27 02:38 Mateusz Loskot <mateusz at loskot.net>
- * nmake.opt, source/Makefile.vc: Forgotten nmake.opt in last
- commit.
+ * [r2309] nmake.opt, source/Makefile.vc: Forgotten nmake.opt in
+ last commit.
-2009-03-26 21:52 mloskot
+2009-03-26 21:52 Mateusz Loskot <mateusz at loskot.net>
- * build/msvc90/geos.sln, build/msvc90/geos_lib/geos_lib.vcproj,
- makefile.vc, source/Makefile.vc, source/dirlist.mk: Refactored
- NMAKE makefiles. Added nmake.opt file - GDAL style. Added some
+ * [r2308] build/msvc90/geos.sln,
+ build/msvc90/geos_lib/geos_lib.vcproj, makefile.vc,
+ source/Makefile.vc, source/dirlist.mk: Refactored NMAKE
+ makefiles. Added nmake.opt file - GDAL style. Added some
auto-magic to determine version of Visual C++ compiler and set
version specific compilation flags. No need to specify Visual C++
version in cmd line, but just run: nmake -f makefile.vc in root
dir of the tree.
-2009-03-26 21:07 mloskot
+2009-03-26 21:07 Mateusz Loskot <mateusz at loskot.net>
- * source/operation/union/CascadedPolygonUnion.cpp:
+ * [r2307] source/operation/union/CascadedPolygonUnion.cpp:
CascadedPolygonUnion.cpp: added missing std headers.
-2009-03-26 01:53 mloskot
+2009-03-26 01:53 Mateusz Loskot <mateusz at loskot.net>
- * TODO: Dummy commit - testing buildbot resurection.
+ * [r2306] TODO: Dummy commit - testing buildbot resurection.
-2009-03-24 16:49 mloskot
+2009-03-24 16:49 Mateusz Loskot <mateusz at loskot.net>
- * capi/geos_ts_c.cpp: Fixed bug introduced in recent refactoring
- work (r2281). This is the reason of PostGIS regression test
- failing (Issue 143)
+ * [r2304] capi/geos_ts_c.cpp: Fixed bug introduced in recent
+ refactoring work (r2281). This is the reason of PostGIS
+ regression test failing (Issue 143)
-2009-03-24 15:58 pramsey
+2009-03-24 15:58 Paul Ramsey <pramsey at cleverelephant.ca>
- * autogen.sh: Allow version test to work in glibtoolize
+ * [r2303] autogen.sh: Allow version test to work in glibtoolize
-2009-03-24 00:48 mloskot
+2009-03-24 00:48 Mateusz Loskot <mateusz at loskot.net>
- * capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp:
+ * [r2302] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp:
capi/geos_ts_c.cpp: refactoring, assert() to test against nullptr
where it is forbidden.
-2009-03-24 00:30 mloskot
+2009-03-24 00:30 Mateusz Loskot <mateusz at loskot.net>
- * capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp: REVERTED
- r2299: Fixed GEOSSetSRID_r missing, GEOSSetSRID duplicated
- (Ticket #242). A little of refactoring.
+ * [r2301] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp:
+ REVERTED r2299: Fixed GEOSSetSRID_r missing, GEOSSetSRID
+ duplicated (Ticket #242). A little of refactoring.
-2009-03-24 00:19 mloskot
+2009-03-24 00:19 Mateusz Loskot <mateusz at loskot.net>
- * capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp: Fixed
- GEOSSetSRID_r missing, GEOSSetSRID duplicated (Ticket #242). A
- little of refactoring.
+ * [r2300] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp:
+ Fixed GEOSSetSRID_r missing, GEOSSetSRID duplicated (Ticket
+ #242). A little of refactoring.
-2009-03-23 23:50 mloskot
+2009-03-23 23:50 Mateusz Loskot <mateusz at loskot.net>
- * capi/geos_ts_c.cpp: capi/geos_ts_c.cpp: refactoring, use single
- return expression per function, added assert() to test against
- nullptr where it is forbidden.
+ * [r2299] capi/geos_ts_c.cpp: capi/geos_ts_c.cpp: refactoring, use
+ single return expression per function, added assert() to test
+ against nullptr where it is forbidden.
-2009-03-23 23:29 mloskot
+2009-03-23 23:29 Mateusz Loskot <mateusz at loskot.net>
- nullptr where it is forbidden, addd some comments.
+ * [r2298] capi/geos_ts_c.cpp: capi/geos_ts_c.cpp: refactoring, use
+ against nullptr where it is forbidden, addd some comments.
-2009-03-23 22:19 mloskot
+2009-03-23 22:19 Mateusz Loskot <mateusz at loskot.net>
+ * [r2297] capi/geos_ts_c.cpp: capi/geos_ts_c.cpp: refactoring, use
-2009-03-23 21:07 mloskot
+2009-03-23 21:07 Mateusz Loskot <mateusz at loskot.net>
- * capi/geos_ts_c.cpp: capi/geos_ts_c.cpp: refactoring, replace
- manual strdup with gstrdup, use single return expression per
- function, added some comments.
+ * [r2296] capi/geos_ts_c.cpp: capi/geos_ts_c.cpp: refactoring,
+ replace manual strdup with gstrdup, use single return expression
+ per function, added some comments.
-2009-03-23 20:31 mloskot
+2009-03-23 20:31 Mateusz Loskot <mateusz at loskot.net>
- * autogen.sh: dummy commit
+ * [r2295] autogen.sh: dummy commit
-2009-03-23 20:03 mloskot
+2009-03-23 20:03 Mateusz Loskot <mateusz at loskot.net>
- * autogen.sh: autogen.sh: Fixed typo in tab character.
+ * [r2294] autogen.sh: autogen.sh: Fixed typo in tab character.
-2009-03-23 17:08 mloskot
+2009-03-23 17:08 Mateusz Loskot <mateusz at loskot.net>
- * autogen.sh: autogen.sh: be more verbose about versions, check for
- autoconf, check if ./configure is really generated.
+ * [r2293] autogen.sh: autogen.sh: be more verbose about versions,
+ check for autoconf, check if ./configure is really generated.
-2009-03-23 16:28 mloskot
+2009-03-23 16:28 Mateusz Loskot <mateusz at loskot.net>
- * configure.in: configure.in: mloskot made a stupid mistake,
- mloskot has fixed it.
+ * [r2292] configure.in: configure.in: mloskot made a stupid
+ mistake, mloskot has fixed it.
-2009-03-23 14:38 mloskot
+2009-03-23 14:38 Mateusz Loskot <mateusz at loskot.net>
- * configure.in: configure.in: wrap macro arguments with proper M4
- quote characters.
+ * [r2291] configure.in: configure.in: wrap macro arguments with
+ proper M4 quote characters.
-2009-03-23 14:08 mloskot
+2009-03-23 14:08 Mateusz Loskot <mateusz at loskot.net>
- * autogen.sh: autogen.sh: Call libtool *before* aclocal and
+ * [r2290] autogen.sh: autogen.sh: Call libtool *before* aclocal and
automake (see Automake manual,8.3.9.1).
-2009-03-23 14:01 mloskot
+2009-03-23 14:01 Mateusz Loskot <mateusz at loskot.net>
- * autogen.sh: autogen.sh: verbose check if autotools versions.
+ * [r2289] autogen.sh: autogen.sh: verbose check if autotools
+ versions.
-2009-03-22 20:29 pramsey
+2009-03-22 20:29 Paul Ramsey <pramsey at cleverelephant.ca>
- * autogen.sh: Show what versions of things we're running
+ * [r2288] autogen.sh: Show what versions of things we're running
-2009-03-21 02:17 mloskot
+2009-03-21 02:17 Mateusz Loskot <mateusz at loskot.net>
- * capi/geos_ts_c.cpp: capi/geos_ts_c.cpp: refactoring - removed
- redundant return expressions, replaced bloated use of malloc +
- memcpy with single call to gstrdup, use of C++ cast operators,
- removed unnecessary allocation of std::string objects.
+ * [r2287] capi/geos_ts_c.cpp: capi/geos_ts_c.cpp: refactoring -
+ removed redundant return expressions, replaced bloated use of
+ malloc + memcpy with single call to gstrdup, use of C++ cast
+ operators, removed unnecessary allocation of std::string objects.
-2009-03-21 01:37 mloskot
+2009-03-21 01:37 Mateusz Loskot <mateusz at loskot.net>
- * capi/geos_ts_c.cpp: capi/geos_ts_c.cpp: added gstrdup and
+ * [r2286] capi/geos_ts_c.cpp: capi/geos_ts_c.cpp: added gstrdup and
gstrdup_s helper functions to get rid of bloated code in future.
Started eliminating redundant return expressions.
-2009-03-21 01:10 mloskot
+2009-03-21 01:10 Mateusz Loskot <mateusz at loskot.net>
- * macros: macros: Updated svn:ignore property.
+ * [r2285] macros: macros: Updated svn:ignore property.
-2009-03-21 01:08 mloskot
+2009-03-21 01:08 Mateusz Loskot <mateusz at loskot.net>
- * capi/geos_ts_c.cpp: capi/geos_ts_c.cpp: Use of spaces instead of
- tabs applied.
+ * [r2284] capi/geos_ts_c.cpp: capi/geos_ts_c.cpp: Use of spaces
+ instead of tabs applied.
-2009-03-21 01:05 mloskot
+2009-03-21 01:05 Mateusz Loskot <mateusz at loskot.net>
- * source/operation/polygonize/EdgeRing.cpp:
+ * [r2283] source/operation/polygonize/EdgeRing.cpp:
source/operation/polygonize/edgering.cpp: cleaned compiler
warnings about mixed integral types.
-2009-03-21 01:01 mloskot
+2009-03-21 01:01 Mateusz Loskot <mateusz at loskot.net>
- * capi/geos_ts_c.cpp: Fixed deprecated conversion from string
- constant to char* in GEOSisValidReason_r. Small refactoring.
+ * [r2282] capi/geos_ts_c.cpp: Fixed deprecated conversion from
+ string constant to char* in GEOSisValidReason_r. Small
+ refactoring.
-2009-03-21 00:47 mloskot
+2009-03-21 00:47 Mateusz Loskot <mateusz at loskot.net>
- * capi/geos_ts_c.cpp: capi/geos_ts_c.cpp: refactoring, use c++ cast
- operators.
+ * [r2281] capi/geos_ts_c.cpp: capi/geos_ts_c.cpp: refactoring, use
+ c++ cast operators.
-2009-03-20 23:37 mloskot
+2009-03-20 23:37 Mateusz Loskot <mateusz at loskot.net>
- * source/operation/union: Updated svn:ignore property.
+ * [r2280] source/operation/union: Updated svn:ignore property.
-2009-03-20 23:35 mloskot
+2009-03-20 23:35 Mateusz Loskot <mateusz at loskot.net>
- * build/msvc80/geos_unit/geos_unit.vcproj: Updated build/msvc80
- project.
+ * [r2279] build/msvc80/geos_unit/geos_unit.vcproj: Updated
+ build/msvc80 project.
-2009-03-19 16:45 pramsey
+2009-03-19 16:45 Paul Ramsey <pramsey at cleverelephant.ca>
- * autogen.sh: Fix spellingn mistake.
+ * [r2278] autogen.sh: Fix spellingn mistake.
-2009-03-19 16:19 mloskot
+2009-03-19 16:19 Mateusz Loskot <mateusz at loskot.net>
- * build/msvc90/geos_unit/geos_unit.vcproj,
+ * [r2277] build/msvc90/geos_unit/geos_unit.vcproj,
tests/unit/capi/GEOSGeomFromWKBTest.cpp, tests/unit/utility.h: *
tests/unit/capi: added GEOSGeomFromWKBTest with test cases (see
comment) reported as a bug (See
@@ -3946,9 +4061,9 @@
* test/unit/utility.h: Added helper class wkb_hex_decoder.
* Updated build/msvc90 projects.
-2009-03-11 12:51 mloskot
+2009-03-11 12:51 Mateusz Loskot <mateusz at loskot.net>
- * source/operation/distance/DistanceOp.cpp,
+ * [r2276] source/operation/distance/DistanceOp.cpp,
tests/unit/operation/distance/DistanceOpTest.cpp: BUG in
DistanceOp:
* Test case and explanation of existing bug in
@@ -3962,54 +4077,55 @@
* A dirty fix: if loc0 or loc1 are nullptr, return nullptr
CoordinatesSequence from closestPoints().
-2009-03-11 12:18 mloskot
+2009-03-11 12:18 Mateusz Loskot <mateusz at loskot.net>
- * source/geom/CoordinateArraySequence.cpp: Number of assertions in
- CoordinateArraySequence class.
+ * [r2275] source/geom/CoordinateArraySequence.cpp: Number of
+ assertions in CoordinateArraySequence class.
-2009-03-10 17:29 pramsey
+2009-03-10 17:29 Paul Ramsey <pramsey at cleverelephant.ca>
- * build/msvc90/geos_c_dll, build/msvc90/geos_lib,
+ * [r2274] build/msvc90/geos_c_dll, build/msvc90/geos_lib,
build/msvc90/geos_python, build/msvc90/geos_ruby,
build/msvc90/geos_unit: svn:ignore
-2009-03-10 17:28 pramsey
+2009-03-10 17:28 Paul Ramsey <pramsey at cleverelephant.ca>
- * build/msvc90, build/msvc90/geos_c_dll, build/msvc90/geos_lib,
- build/msvc90/geos_python, build/msvc90/geos_ruby,
- build/msvc90/geos_unit: svn:ignore
+ * [r2273] build/msvc90, build/msvc90/geos_c_dll,
+ build/msvc90/geos_lib, build/msvc90/geos_python,
+ build/msvc90/geos_ruby, build/msvc90/geos_unit: svn:ignore
-2009-03-10 17:18 pramsey
+2009-03-10 17:18 Paul Ramsey <pramsey at cleverelephant.ca>
- * NEWS: Update NEWS for 3.1.0
+ * [r2272] NEWS: Update NEWS for 3.1.0
-2009-03-10 16:23 pramsey
+2009-03-10 16:23 Paul Ramsey <pramsey at cleverelephant.ca>
- * ChangeLog: Update ChangeLog for 3.1.0 release
+ * [r2271] ChangeLog: Update ChangeLog for 3.1.0 release
-2009-02-07 23:29 pramsey
+2009-02-07 23:29 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/headers/geos/precision/Makefile.am: Include
+ * [r2269] source/headers/geos/precision/Makefile.am: Include
GeometrySnapper.h in distribution package.
-2009-02-02 22:58 sgillies
+2009-02-02 22:58 Sean Gillies <sgillies at frii.com>
- * swig/python/README.txt: Note lack of Python support since 3.0
+ * [r2268] swig/python/README.txt: Note lack of Python support since
+ 3.0
-2009-02-02 22:53 sgillies
+2009-02-02 22:53 Sean Gillies <sgillies at frii.com>
- * README: Notes on state of scripting language bindings
+ * [r2267] README: Notes on state of scripting language bindings
-2009-01-30 20:01 pramsey
+2009-01-30 20:01 Paul Ramsey <pramsey at cleverelephant.ca>
- * configure.in: Add new msvc targets to build
+ * [r2266] configure.in: Add new msvc targets to build
-2009-01-29 19:22 mloskot
+2009-01-29 19:22 Mateusz Loskot <mateusz at loskot.net>
- * build/Makefile.am, build/msvc90, build/msvc90/Makefile.am,
- build/msvc90/README, build/msvc90/geos.sln,
- build/msvc90/geos.vsprops, build/msvc90/geos_c_dll,
- build/msvc90/geos_c_dll/Makefile.am,
+ * [r2265] build/Makefile.am, build/msvc90,
+ build/msvc90/Makefile.am, build/msvc90/README,
+ build/msvc90/geos.sln, build/msvc90/geos.vsprops,
+ build/msvc90/geos_c_dll, build/msvc90/geos_c_dll/Makefile.am,
build/msvc90/geos_c_dll/geos_c_dll.vcproj, build/msvc90/geos_lib,
build/msvc90/geos_lib/Makefile.am,
build/msvc90/geos_lib/geos_lib.vcproj, build/msvc90/geos_python,
@@ -4022,13 +4138,13 @@
solution and project files for Microsoft Visual C++ 2009 (9.0).
Successfully built and tested GEOS with Visual C++ 9.0.
-2009-01-29 19:02 pramsey
+2009-01-29 19:02 Paul Ramsey <pramsey at cleverelephant.ca>
- * README: update autogen.bat ref
+ * [r2264] README: update autogen.bat ref
-2009-01-29 18:56 mloskot
+2009-01-29 18:56 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/algorithm/RayCrossingCounter.h,
+ * [r2263] source/headers/geos/algorithm/RayCrossingCounter.h,
source/headers/geos/algorithm/locate/IndexedPointInAreaLocator.h,
source/headers/geos/algorithm/locate/PointOnGeometryLocator.h,
source/headers/geos/geom/util/ComponentCoordinateExtracter.h,
@@ -4043,53 +4159,55 @@
source/headers/geos/noding/SegmentStringUtil.h: Fixed broken
svn:keyword Id
-2009-01-29 18:51 mloskot
+2009-01-29 18:51 Mateusz Loskot <mateusz at loskot.net>
- * autogen.bat, bootstrap.bat: Renamed bootstrap.bat to autogen.bat
- for easier guass of the script purpose. Wiki updated.
+ * [r2262] autogen.bat, bootstrap.bat: Renamed bootstrap.bat to
+ autogen.bat for easier guass of the script purpose. Wiki updated.
-2009-01-28 01:06 pramsey
+2009-01-28 01:06 Paul Ramsey <pramsey at cleverelephant.ca>
- * README: Add to win32 instructions
+ * [r2261] README: Add to win32 instructions
-2009-01-27 18:10 pramsey
+2009-01-27 18:10 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/headers/geos/geom/util/Makefile.am: Add GeometryCombiner.h
- to include dist
+ * [r2260] source/headers/geos/geom/util/Makefile.am: Add
+ GeometryCombiner.h to include dist
-2009-01-27 00:18 pramsey
+2009-01-27 00:18 Paul Ramsey <pramsey at cleverelephant.ca>
- * build/msvc80/geos_c_dll/geos_c_dll.vcproj: Revert some junk from
- an old commit, per issue #220
+ * [r2259] build/msvc80/geos_c_dll/geos_c_dll.vcproj: Revert some
+ junk from an old commit, per issue #220
-2009-01-26 20:44 warmerdam
+2009-01-26 20:44 Frank Warmerdam <warmerdam at pobox.com>
- * source/Makefile.vc: added two new files related to cascaded
- polygon union (#226)
+ * [r2258] source/Makefile.vc: added two new files related to
+ cascaded polygon union (#226)
-2009-01-24 05:03 pramsey
+2009-01-24 05:03 Paul Ramsey <pramsey at cleverelephant.ca>
- * HOWTO_RELEASE: Update
+ * [r2257] HOWTO_RELEASE: Update
-2009-01-24 05:02 pramsey
+2009-01-24 05:02 Paul Ramsey <pramsey at cleverelephant.ca>
- * ChangeLog: Update changelog
+ * [r2256] ChangeLog: Update changelog
-2009-01-24 01:33 mloskot
+2009-01-24 01:33 Mateusz Loskot <mateusz at loskot.net>
- * capi/geos_ts_c.cpp: Fixed mixed signed/unsigned integral types in
- geos_ts_c.cpp, so no compilers should flood with warnings now.
+ * [r2255] capi/geos_ts_c.cpp: Fixed mixed signed/unsigned integral
+ types in geos_ts_c.cpp, so no compilers should flood with
+ warnings now.
-2009-01-24 01:30 mloskot
+2009-01-24 01:30 Mateusz Loskot <mateusz at loskot.net>
- * build/msvc80/geos_c_dll/geos_c_dll.vcproj,
+ * [r2254] build/msvc80/geos_c_dll/geos_c_dll.vcproj,
build/msvc80/geos_lib/geos_lib.vcproj,
build/msvc80/geos_unit/geos_unit.vcproj: Updated projects for
Visual Studio 2005 adding new .h/.cpp files.
-2009-01-23 23:58 mloskot
+2009-01-23 23:58 Mateusz Loskot <mateusz at loskot.net>
- * capi/geos_ts_c.cpp, source/geom/util/GeometryCombiner.cpp,
+ * [r2253] capi/geos_ts_c.cpp,
+ source/geom/util/GeometryCombiner.cpp,
source/headers/geos/geom/util/GeometryCombiner.h,
source/headers/geos/io/CLocalizer.h,
source/headers/geos/operation/union/CascadedPolygonUnion.h,
@@ -4100,51 +4218,52 @@
tests/unit/operation/union/CascadedPolygonUnionTest.cpp: Updated
svn:keywords property on C/C++ files.
-2009-01-21 22:18 pramsey
+2009-01-21 22:18 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/geom/Geometry.cpp: Remove geometryCollection protection
- from Union/Relate/Intersection/Difference.
+ * [r2252] source/geom/Geometry.cpp: Remove geometryCollection
+ protection from Union/Relate/Intersection/Difference.
-2009-01-20 01:01 pramsey
+2009-01-20 01:01 Paul Ramsey <pramsey at cleverelephant.ca>
- * capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp,
+ * [r2251] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_ts_c.cpp,
source/operation/union/CascadedPolygonUnion.cpp: Add
GEOSUnionCascaded(*GEOSGeometry) to CAPI in preparation for
PostGIS hook-up.
-2009-01-19 23:55 pramsey
+2009-01-19 23:55 Paul Ramsey <pramsey at cleverelephant.ca>
- * capi/geos_c.cpp, capi/geos_ts_c.cpp: Formatting changes to
- function decls.
+ * [r2250] capi/geos_c.cpp, capi/geos_ts_c.cpp: Formatting changes
+ to function decls.
-2009-01-19 20:41 hobu
+2009-01-19 20:41 Howard Butler <hobu.inc at gmail.com>
- * source/Makefile.vc: fixes to allow building in msvc 2003
+ * [r2249] source/Makefile.vc: fixes to allow building in msvc 2003
-2009-01-19 20:00 pramsey
+2009-01-19 20:00 Paul Ramsey <pramsey at cleverelephant.ca>
- * configure.in: Make warning flags conditional behind a compiler
- test... fix to bug #192 ?
+ * [r2248] configure.in: Make warning flags conditional behind a
+ compiler test... fix to bug #192 ?
-2009-01-19 16:44 pramsey
+2009-01-19 16:44 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/headers/geos/operation/union/CascadedPolygonUnion.h,
+ * [r2247]
+ source/headers/geos/operation/union/CascadedPolygonUnion.h,
source/operation/union/CascadedPolygonUnion.cpp: Added patch from
hkaiser to allow cascadedunion to be run directly on a
multipolygon.
-2009-01-19 00:12 pramsey
+2009-01-19 00:12 Paul Ramsey <pramsey at cleverelephant.ca>
- * autogen.sh: Fix error left behind from testing.
+ * [r2246] autogen.sh: Fix error left behind from testing.
-2009-01-18 23:28 pramsey
+2009-01-18 23:28 Paul Ramsey <pramsey at cleverelephant.ca>
- * autogen.sh: Add some more info on missing tools.
+ * [r2245] autogen.sh: Add some more info on missing tools.
-2009-01-18 23:07 pramsey
+2009-01-18 23:07 Paul Ramsey <pramsey at cleverelephant.ca>
- * HOWTO_RELEASE, Makefile.am, build, build/Makefile.am,
+ * [r2244] HOWTO_RELEASE, Makefile.am, build, build/Makefile.am,
build/msvc80, build/msvc80/Makefile.am, build/msvc80/geos_c_dll,
build/msvc80/geos_c_dll/Makefile.am, build/msvc80/geos_lib,
build/msvc80/geos_lib/Makefile.am, build/msvc80/geos_python,
@@ -4156,18 +4275,18 @@
updating
version in .vc headers.
-2009-01-18 22:35 pramsey
+2009-01-18 22:35 Paul Ramsey <pramsey at cleverelephant.ca>
- * configure.in: Add a couple extra program checks.
+ * [r2243] configure.in: Add a couple extra program checks.
-2009-01-18 21:30 pramsey
+2009-01-18 21:30 Paul Ramsey <pramsey at cleverelephant.ca>
- * autogen.sh: Add version test for aclocal and automake to allow
- OpenSolaris to work.
+ * [r2241] autogen.sh: Add version test for aclocal and automake to
+ allow OpenSolaris to work.
-2009-01-18 20:34 pramsey
+2009-01-18 20:34 Paul Ramsey <pramsey at cleverelephant.ca>
- * configure.in, source/geom/Envelope.cpp,
+ * [r2240] configure.in, source/geom/Envelope.cpp,
source/geom/util/Makefile.am,
source/headers/geos/geom/Envelope.h,
@@ -4186,43 +4305,44 @@
tests/unit/operation/union/CascadedPolygonUnionTest.cpp: Apply
cascaded union patch, for issue #225
-2009-01-15 01:00 pramsey
+2009-01-15 01:00 Paul Ramsey <pramsey at cleverelephant.ca>
- * tests/xmltester/Makefile.am: Remove XMLTester from list of
- installed programs.
+ * [r2239] tests/xmltester/Makefile.am: Remove XMLTester from list
+ of installed programs.
-2009-01-14 20:25 pramsey
+2009-01-14 20:25 Paul Ramsey <pramsey at cleverelephant.ca>
- * capi/geos_ts_c.cpp: Remove strdup use from code for compilation
- in mingw
+ * [r2238] capi/geos_ts_c.cpp: Remove strdup use from code for
+ compilation in mingw
-2009-01-13 20:59 pramsey
+2009-01-13 20:59 Paul Ramsey <pramsey at cleverelephant.ca>
- * configure.in: Add [macros] include to configure.in directly.
- Seems to make more recent aclocals happy
+ * [r2237] configure.in: Add [macros] include to configure.in
+ directly. Seems to make more recent aclocals happy
-2009-01-13 20:43 pramsey
+2009-01-13 20:43 Paul Ramsey <pramsey at cleverelephant.ca>
- * configure.in: Change AC_SUBST to one-per-line instead of
+ * [r2236] configure.in: Change AC_SUBST to one-per-line instead of
one-line-for-all. Seems to make more recent autoconf's happier.
-2009-01-13 19:23 pramsey
+2009-01-13 19:23 Paul Ramsey <pramsey at cleverelephant.ca>
- * capi/geos_ts_c.cpp: Change return values for
+ * [r2235] capi/geos_ts_c.cpp: Change return values for
GEOSWKBWriter_getIncludeSRID_r to match function signature.
-2009-01-13 17:04 pramsey
+2009-01-13 17:04 Paul Ramsey <pramsey at cleverelephant.ca>
- * tests/unit/capi/badthreadtest.c, tests/unit/capi/brokengrammar,
- tests/unit/capi/threadtest.c: More files missing from commit.
+ * [r2234] tests/unit/capi/badthreadtest.c,
+ tests/unit/capi/brokengrammar, tests/unit/capi/threadtest.c: More
+ files missing from commit.
-2009-01-13 15:47 pramsey
+2009-01-13 15:47 Paul Ramsey <pramsey at cleverelephant.ca>
- * capi/geos_ts_c.cpp: Add missing file to SVN.
+ * [r2233] capi/geos_ts_c.cpp: Add missing file to SVN.
-2009-01-13 01:21 pramsey
+2009-01-13 01:21 Paul Ramsey <pramsey at cleverelephant.ca>
- * capi/Makefile.am, capi/geos_c.cpp, capi/geos_c.h.in,
+ * [r2232] capi/Makefile.am, capi/geos_c.cpp, capi/geos_c.h.in,
capi/geostest.c, capi/test.expected, capi/test.wkt,
capi/testrunner.sh, tests/unit/Makefile.am,
tests/unit/capi/geostest.c, tests/unit/capi/test.expected,
@@ -4230,97 +4350,99 @@
patch for issue #210 (thread safe c-api) submitted by Chuck
Thibert.
-2009-01-05 23:42 swongu
+2009-01-05 23:42 Stephen Wong <swongu at gmail.com>
- * source/operation/buffer/BufferBuilder.cpp,
+ * [r2231] source/operation/buffer/BufferBuilder.cpp,
source/operation/buffer/OffsetCurveVertexList.h,
source/operation/linemerge/LineMerger.cpp: Fixed memory leak in
BufferBuilder (#218); added read-only coordinates function in
OffsetCurveVertexList; explicity pass ownership in LineMerger.
-2008-11-26 19:41 pramsey
+2008-11-26 19:41 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/headers/geos/noding/Octant.h,
+ * [r2229] source/headers/geos/noding/Octant.h,
tests/unit/noding/SegmentStringTest.cpp: Octant.h error (#185)
from Denise Macleod.
-2008-11-26 19:27 pramsey
+2008-11-26 19:27 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/io/WKBWriter.cpp: Allow proper writing out of z ordinates.
- From Justin Bronn (#216)
+ * [r2228] source/io/WKBWriter.cpp: Allow proper writing out of z
+ ordinates. From Justin Bronn (#216)
-2008-11-26 19:25 pramsey
+2008-11-26 19:25 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/io/WKBReader.cpp: Allow readpoint to look at input
+ * [r2227] source/io/WKBReader.cpp: Allow readpoint to look at input
dimension and fill higher ordinates. (#217)
-2008-11-26 19:06 pramsey
+2008-11-26 19:06 Paul Ramsey <pramsey at cleverelephant.ca>
- * capi/geos_c.cpp, capi/geos_c.h.in: Expose GEOSIsValidReason to
- CAPI
+ * [r2226] capi/geos_c.cpp, capi/geos_c.h.in: Expose
+ GEOSIsValidReason to CAPI
-2008-11-18 03:09 pramsey
+2008-11-18 03:09 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/inlines.cpp: Cygwin build fix from MCA
+ * [r2221] source/inlines.cpp: Cygwin build fix from MCA
-2008-11-11 17:32 pramsey
+2008-11-11 17:32 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/geomgraph/EdgeList.cpp,
+ * [r2220] source/geomgraph/EdgeList.cpp,
source/operation/overlay/OverlayOp.cpp: Memory leak on invalid
polygons in intersection(). (#170) from Denise MacLeod.
-2008-11-05 20:52 pramsey
+2008-11-05 20:52 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/geom/prep/PreparedLineStringIntersects.cpp: Another minor
- memory leak removed.
+ * [r2218] source/geom/prep/PreparedLineStringIntersects.cpp:
+ Another minor memory leak removed.
-2008-10-28 15:47 pramsey
+2008-10-28 15:47 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/inlines.cpp: Cygwin/Mingw patch from Mark Cave-Ayland
+ * [r2217] source/inlines.cpp: Cygwin/Mingw patch from Mark
+ Cave-Ayland
-2008-10-23 17:33 warmerdam
+2008-10-23 17:33 Frank Warmerdam <warmerdam at pobox.com>
- * source/operation/valid/IsValidOp.cpp: set isChecked flag after
- checking to fix memory leak (#169)
+ * [r2210] source/operation/valid/IsValidOp.cpp: set isChecked flag
+ after checking to fix memory leak (#169)
-2008-10-16 00:40 pramsey
+2008-10-16 00:40 Paul Ramsey <pramsey at cleverelephant.ca>
- * HOWTO_RELEASE: change info to point to osgeo.org
+ * [r2203] HOWTO_RELEASE: change info to point to osgeo.org
-2008-10-14 15:01 pramsey
+2008-10-14 15:01 Paul Ramsey <pramsey at cleverelephant.ca>
- * capi/geos_c.cpp, capi/geos_c.h.in: Consistent const declarations
- in c-api ($#209)
+ * [r2200] capi/geos_c.cpp, capi/geos_c.h.in: Consistent const
+ declarations in c-api ($#209)
-2008-10-13 22:40 pramsey
+2008-10-13 22:40 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/headers/geos/io/Makefile.am: Add CLocalizer.h to build so
- it gets packaged in make dist
+ * [r2199] source/headers/geos/io/Makefile.am: Add CLocalizer.h to
+ build so it gets packaged in make dist
-2008-10-10 17:46 pramsey
+2008-10-10 17:46 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/geom/prep/PreparedPolygonContainsProperly.cpp: One last
- memory leak fix.
+ * [r2198] source/geom/prep/PreparedPolygonContainsProperly.cpp: One
+ last memory leak fix.
-2008-10-09 16:39 pramsey
+2008-10-09 16:39 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/geom/prep/PreparedPolygonIntersects.cpp: Memory leak fix
- for for prepared intersects. (#207)
+ * [r2197] source/geom/prep/PreparedPolygonIntersects.cpp: Memory
+ leak fix for for prepared intersects. (#207)
-2008-10-04 18:14 pramsey
+2008-10-04 18:14 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/headers/geos/noding/MCIndexSegmentSetMutualIntersector.h,
+ * [r2196]
+ source/headers/geos/noding/MCIndexSegmentSetMutualIntersector.h,
source/noding/MCIndexSegmentSetMutualIntersector.cpp: Memory leak
fix for prepared geometry, from Hartmut Kaiser. (#207)
-2008-09-29 19:24 pramsey
+2008-09-29 19:24 Paul Ramsey <pramsey at cleverelephant.ca>
- * capi/geos_c.cpp: Put function sig on one line
+ * [r2195] capi/geos_c.cpp: Put function sig on one line
-2008-09-23 23:01 mloskot
+2008-09-23 23:01 Mateusz Loskot <mateusz at loskot.net>
+ * [r2194] source/geom/prep/AbstractPreparedPolygonContains.cpp,
source/geom/prep/PreparedPolygon.cpp,
source/geom/prep/PreparedPolygonContains.cpp,
source/geom/prep/PreparedPolygonPredicate.cpp,
@@ -4338,170 +4460,174 @@
readability. TODO: We need to run a beast like AStyle on all GEOS
code because many places are very hard to read.
-2008-09-23 22:55 mloskot
+2008-09-23 22:55 Mateusz Loskot <mateusz at loskot.net>
- * source/noding/MCIndexSegmentSetMutualIntersector.cpp:
+ * [r2193] source/noding/MCIndexSegmentSetMutualIntersector.cpp:
MCIndexSegmentSetMutualIntersector::addToIndex: Completed BWJ's
comment on memory leaks with important observations about objects
relation & lifetime. The note is a diagnosis of roots of the
problem. Improved source code readability.
-2008-09-22 21:48 mloskot
+2008-09-22 21:48 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/io/WKBWriter.h: Use conditional operators
- instead of cast bool to int.
+ * [r2192] source/headers/geos/io/WKBWriter.h: Use conditional
+ operators instead of cast bool to int.
-2008-09-22 20:16 mloskot
+2008-09-22 20:16 Mateusz Loskot <mateusz at loskot.net>
- * source/simplify/TopologyPreservingSimplifier.cpp: Removed
+ * [r2191] source/simplify/TopologyPreservingSimplifier.cpp: Removed
unnecessary std::endl from debug messages in
TopologyPreservingSimplifier.cpp.
-2008-09-21 21:32 mloskot
+2008-09-21 21:32 Mateusz Loskot <mateusz at loskot.net>
- * source/Makefile.vc: Patched NMAKE makefiles: replaced lib.exe
- with link.exe /lib command to enabled compilation using Microsoft
- Visual C++ Toolkit 2003
+ * [r2190] source/Makefile.vc: Patched NMAKE makefiles: replaced
+ lib.exe with link.exe /lib command to enabled compilation using
+ Microsoft Visual C++ Toolkit 2003
-2008-09-16 21:09 mloskot
+2008-09-16 21:09 Mateusz Loskot <mateusz at loskot.net>
- * source/operation/predicate/SegmentIntersectionTester.cpp,
+ * [r2189] source/operation/predicate/SegmentIntersectionTester.cpp,
source/util/math.cpp: Patch fixing build problems on Solaris
(Ticket #205).
-2008-09-16 21:01 mloskot
+2008-09-16 21:01 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp: Fixed EOL
- to LF.
+ * [r2188] tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp:
+ Fixed EOL to LF.
-2008-09-16 20:58 mloskot
+2008-09-16 20:58 Mateusz Loskot <mateusz at loskot.net>
- * source/geom/prep/PreparedGeometryFactory.cpp,
+ * [r2187] source/geom/prep/PreparedGeometryFactory.cpp,
tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp: Fixed crash
of Prepared Geometry construction with nullptr to Geometry object
(Ticket #197).
-2008-09-16 20:55 mloskot
+2008-09-16 20:55 Mateusz Loskot <mateusz at loskot.net>
- * build/msvc80/geos_unit/geos_unit.vcproj: Added
+ * [r2186] build/msvc80/geos_unit/geos_unit.vcproj: Added
PreparedGeometryFactoryTest to geos_unit.vcproj.
-2008-09-16 20:15 mloskot
+2008-09-16 20:15 Mateusz Loskot <mateusz at loskot.net>
- * build/msvc80/geos_lib/geos_lib.vcproj: Added CLocalizer to
- geos_lib.vcproj project for Visual C++ 2005/2008.
+ * [r2185] build/msvc80/geos_lib/geos_lib.vcproj: Added CLocalizer
+ to geos_lib.vcproj project for Visual C++ 2005/2008.
-2008-09-16 20:13 mloskot
+2008-09-16 20:13 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/algorithm/CGAlgorithms/isPointInRingTest.cpp: Include
- missing <cassert> in isPointInRingTest.cpp
+ * [r2184] tests/unit/algorithm/CGAlgorithms/isPointInRingTest.cpp:
+ Include missing <cassert> in isPointInRingTest.cpp
-2008-09-16 20:05 mloskot
+2008-09-16 20:05 Mateusz Loskot <mateusz at loskot.net>
- * source/Makefile.vc, source/io/CLocalizer.cpp: Fixed undeclared
- std::locale in CLocalizer when building using Visual C++ (Ticket
- #201)
+ * [r2183] source/Makefile.vc, source/io/CLocalizer.cpp: Fixed
+ undeclared std::locale in CLocalizer when building using Visual
+ C++ (Ticket #201)
-2008-08-31 20:28 mloskot
+2008-08-31 20:28 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/geos_unit.cpp: Replaced incorrect <cmath> with
+ * [r2182] tests/unit/geos_unit.cpp: Replaced incorrect <cmath> with
<cstdlib> in geos_unit.cpp.
-2008-08-31 20:23 mloskot
+2008-08-31 20:23 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/geos_unit.cpp: Added missing include <cmath> in
- geos_unit.cpp.
+ * [r2181] tests/unit/geos_unit.cpp: Added missing include <cmath>
+ in geos_unit.cpp.
-2008-08-31 19:54 mloskot
+2008-08-31 19:54 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/io/CLocalizer.h, source/io/CLocalizer.cpp:
- Removed use of strdup function to fix compilation with GCC 4.3.1
- (Ticket #204).
+ * [r2180] source/headers/geos/io/CLocalizer.h,
+ source/io/CLocalizer.cpp: Removed use of strdup function to fix
+ compilation with GCC 4.3.1 (Ticket #204).
-2008-08-29 18:17 mloskot
+2008-08-29 18:17 Mateusz Loskot <mateusz at loskot.net>
- * capi/geos_c.cpp: Removed redundant return expressions from
- geos_c.cpp. Testing changes notifications for buildbot.
+ * [r2179] capi/geos_c.cpp: Removed redundant return expressions
+ from geos_c.cpp. Testing changes notifications for buildbot.
-2008-08-29 00:30 mloskot
+2008-08-29 00:30 Mateusz Loskot <mateusz at loskot.net>
- * capi/geos_c.cpp: Fixed execution paths and removed redundant
- return expr in some C API calls.
+ * [r2176] capi/geos_c.cpp: Fixed execution paths and removed
+ redundant return expr in some C API calls.
-2008-08-29 00:29 mloskot
+2008-08-29 00:29 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/io/WKBWriter.h, source/io/WKBWriter.cpp:
- Added missing virtual destructor to WKBWriter class.
+ * [r2175] source/headers/geos/io/WKBWriter.h,
+ source/io/WKBWriter.cpp: Added missing virtual destructor to
+ WKBWriter class.
-2008-08-28 22:20 sgillies
+2008-08-28 22:20 Sean Gillies <sgillies at frii.com>
- * capi/geos_c.cpp, source/headers/geos/io.h,
+ * [r2174] capi/geos_c.cpp, source/headers/geos/io.h,
source/headers/geos/io/CLocalizer.h, source/io/CLocalizer.cpp,
source/io/Makefile.am: Added CLocalizer class that switches to C
locale and restores to the outer context's locale when deleted
(#201)
-2008-08-28 21:35 mloskot
+2008-08-28 21:35 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/Makefile.am, tests/unit/capi/GEOSGeomToWKTTest.cpp:
- tests/unit: added GEOSGeomToWKTTest.
+ * [r2173] tests/unit/Makefile.am,
+ tests/unit/capi/GEOSGeomToWKTTest.cpp: tests/unit: added
+ GEOSGeomToWKTTest.
-2008-08-28 19:16 sgillies
+2008-08-28 19:16 Sean Gillies <sgillies at frii.com>
- * capi/geos_c.cpp: Switch to C locale while reading and writing WKT
- and restore to the original context's locale afterward (#201)
+ * [r2172] capi/geos_c.cpp: Switch to C locale while reading and
+ writing WKT and restore to the original context's locale
+ afterward (#201)
-2008-08-22 17:25 warmerdam
+2008-08-22 17:25 Frank Warmerdam <warmerdam at pobox.com>
- * source/operation/buffer/BufferOp.cpp: include cmath for
+ * [r2171] source/operation/buffer/BufferOp.cpp: include cmath for
std::pow() and std:log() on MSVC7.1 (#199)
-2008-08-22 16:10 mloskot
+2008-08-22 16:10 Mateusz Loskot <mateusz at loskot.net>
- * build/bjam/README: Added build/bjam/README with status note.
+ * [r2170] build/bjam/README: Added build/bjam/README with status
+ note.
-2008-08-19 17:02 mloskot
+2008-08-19 17:02 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/geom/LineStringTest.cpp: LineStringTest: fixed memory
- leak.
+ * [r2169] tests/unit/geom/LineStringTest.cpp: LineStringTest: fixed
+ memory leak.
-2008-08-19 17:00 mloskot
+2008-08-19 17:00 Mateusz Loskot <mateusz at loskot.net>
- * source/geom/util/CoordinateOperation.cpp,
+ * [r2168] source/geom/util/CoordinateOperation.cpp,
source/geom/util/GeometryEditor.cpp: geos/geom/util: Prefer
strict static_cast than C-style cast. Commented ownership
transfer of coordinates object.
-2008-08-19 00:18 mloskot
+2008-08-19 00:18 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/algorithm/ConvexHullTest.cpp:
+ * [r2167] tests/unit/algorithm/ConvexHullTest.cpp:
tests/unit/algorithm/ConvexHullTest.cpp: Fixed memory leaks.
-2008-08-19 00:05 mloskot
+2008-08-19 00:05 Mateusz Loskot <mateusz at loskot.net>
+ * [r2166] tests/unit/algorithm/CGAlgorithms/isPointInRingTest.cpp:
tests/unit/algorithm/CGAlgorithms: Fixed memory leaks.
-2008-08-18 23:45 mloskot
+2008-08-18 23:45 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp:
+ * [r2165] tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp:
tests/unit/algorithm/CGAlgorithms: Fixed number of memory leaks.
-2008-08-18 23:30 mloskot
+2008-08-18 23:30 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/capi/GEOSCoordSeqTest.cpp,
+ * [r2164] tests/unit/capi/GEOSCoordSeqTest.cpp,
tests/unit/capi/GEOSSimplifyTest.cpp: tests/unit/capi: Fixed
-2008-08-18 16:32 mloskot
+2008-08-18 16:32 Mateusz Loskot <mateusz at loskot.net>
- * tests/bigtest/GeometryTestFactory.cpp,
+ * [r2163] tests/bigtest/GeometryTestFactory.cpp,
tests/bigtest/TestSweepLineSpeed.cpp: tests/bigtest: Pointed out
number of memory leaks but not fixing them, waiting for comments.
-2008-08-18 16:30 mloskot
+2008-08-18 16:30 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/algorithm/ConvexHullTest.cpp,
+ * [r2162] tests/unit/algorithm/ConvexHullTest.cpp,
tests/unit/geom/GeometryFactoryTest.cpp,
tests/unit/geom/LineStringTest.cpp,
tests/unit/geom/MultiLineStringTest.cpp,
@@ -4513,9 +4639,9 @@
PreparedGeometryFactoryTest, refactored casting utils and
geometry comparators, small cleanup.
-2008-08-18 16:29 mloskot
+2008-08-18 16:29 Mateusz Loskot <mateusz at loskot.net>
+ * [r2161] source/algorithm/RayCrossingCounter.cpp,
source/algorithm/locate/IndexedPointInAreaLocator.cpp,
source/algorithm/locate/PointOnGeometryLocator.cpp,
source/geom/util/ComponentCoordinateExtracter.cpp,
@@ -4529,13 +4655,15 @@
source/noding/SegmentIntersectionDetector.cpp,
source/noding/SegmentStringUtil.cpp: Fixed svn:keywords.
-2008-08-18 16:27 mloskot
+2008-08-18 16:27 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/util.h: Fixed UNREFERENCED_PARAMETER macro.
+ * [r2160] source/headers/geos/util.h: Fixed UNREFERENCED_PARAMETER
+ macro.
- * source/headers/geos/geom/prep/AbstractPreparedPolygonContains.h,
+ * [r2159]
+ source/headers/geos/geom/prep/AbstractPreparedPolygonContains.h,
source/headers/geos/geom/prep/BasicPreparedGeometry.h,
source/headers/geos/geom/prep/PreparedGeometry.h,
source/headers/geos/geom/prep/PreparedLineString.h,
@@ -4549,9 +4677,9 @@
source/headers/geos/geom/prep/PreparedPolygonPredicate.h: Fixed
svn:keywords.
-2008-08-18 16:24 mloskot
+2008-08-18 16:24 Mateusz Loskot <mateusz at loskot.net>
- * source/geom/prep/AbstractPreparedPolygonContains.cpp,
+ * [r2158] source/geom/prep/AbstractPreparedPolygonContains.cpp,
source/geom/prep/BasicPreparedGeometry.cpp,
source/geom/prep/PreparedGeometry.cpp,
@@ -4567,56 +4695,58 @@
Refactored kamikaze casts to more readable form. Fixed
svn:keywords.
-2008-08-12 00:25 mloskot
+2008-08-12 00:25 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/geomPrep.h: Fixed Id keywords.
+ * [r2157] source/headers/geos/geomPrep.h: Fixed Id keywords.
-2008-08-12 00:23 mloskot
+2008-08-12 00:23 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/algorithm/CGAlgorithms/computeOrientationTest.cpp,
+ * [r2156]
+ tests/unit/algorithm/CGAlgorithms/computeOrientationTest.cpp,
tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp,
tests/unit/operation/IsSimpleOpTest.cpp: Fixed EOL to LF in
trunk/tests.
-2008-08-12 00:09 mloskot
+2008-08-12 00:09 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/geom/prep/PreparedGeometryFactory.h: Updated
- svn:keywords property.
+ * [r2155] source/headers/geos/geom/prep/PreparedGeometryFactory.h:
+ Updated svn:keywords property.
-2008-08-12 00:03 mloskot
+2008-08-12 00:03 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp: Updated
+ * [r2154] tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp:
-2008-08-11 23:54 mloskot
+2008-08-11 23:54 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp: Refactored
- tabs vs spaces in PreparedGeometryFactoryTest.
+ * [r2153] tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp:
+ Refactored tabs vs spaces in PreparedGeometryFactoryTest.
-2008-08-11 23:52 mloskot
+2008-08-11 23:52 Mateusz Loskot <mateusz at loskot.net>
+ * [r2152] source/headers/geos/geom/prep/PreparedGeometryFactory.h:
PreparedGeometry must be a complete type where it is destroyed by
the factory (Ticket #198).
-2008-08-11 23:42 mloskot
+2008-08-11 23:42 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/geom/prep/PreparedGeometryFactory.h,
+ * [r2151] source/headers/geos/geom/prep/PreparedGeometryFactory.h,
tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp: Completed
PreparedGeometryFactory class with missing named destructor for
PreparedGeometry (Ticket #198)
-2008-08-11 23:35 mloskot
+2008-08-11 23:35 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/geom/prep/.PreparedGeometryFactoryTest.cpp.swp:
+ * [r2150]
+ tests/unit/geom/prep/.PreparedGeometryFactoryTest.cpp.swp:
Removed .PreparedGeometryFactoryTest.cpp.swp that must sneaked
accidentally.
-2008-08-11 22:48 mloskot
+2008-08-11 22:48 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/Makefile.am, tests/unit/geom/prep,
+ * [r2149] tests/unit/Makefile.am, tests/unit/geom/prep,
tests/unit/geom/prep/.PreparedGeometryFactoryTest.cpp.swp,
tests/unit/geom/prep/PreparedGeometryFactoryTest.cpp: Added
PreparedGeometryFactoryTest with first test cases included.
@@ -4624,38 +4754,39 @@
destroy PreparedGeometry objects returned by the factory,
discussing on the geos-devel list now.
-2008-08-07 16:59 pramsey
+2008-08-07 16:59 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/algorithm/RobustDeterminant.cpp: Added original author to
- main copyright block.
+ * [r2148] source/algorithm/RobustDeterminant.cpp: Added original
+ author to main copyright block.
-2008-08-07 16:57 pramsey
+2008-08-07 16:57 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/headers/geos/timeval.h: Change to standard header, with
- (c) credit to author.
+ * [r2147] source/headers/geos/timeval.h: Change to standard header,
+ with (c) credit to author.
-2008-08-01 23:23 mloskot
+2008-08-01 23:23 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog: Updated ChangeLog with latest submissions. Hmm, should
- we stil maintain the ChangeLog file?
+ * [r2146] ChangeLog: Updated ChangeLog with latest submissions.
+ Hmm, should we stil maintain the ChangeLog file?
-2008-07-31 17:08 mloskot
+2008-07-31 17:08 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/capi/GEOSPolygonizer_getCutEdgesTest.cpp: Fixed tabs,
- hopefully. Updated svn:keywords property.
+ * [r2145] tests/unit/capi/GEOSPolygonizer_getCutEdgesTest.cpp:
+ Fixed tabs, hopefully. Updated svn:keywords property.
-2008-07-31 17:01 mloskot
+2008-07-31 17:01 Mateusz Loskot <mateusz at loskot.net>
- * capi/geos_c.cpp, capi/geos_c.h.in, tests/unit/Makefile.am,
+ * [r2144] capi/geos_c.cpp, capi/geos_c.h.in,
+ tests/unit/Makefile.am,
tests/unit/capi/GEOSPolygonizer_getCutEdgesTest.cpp: Patch
completing C API interface with wrapper on
Polygonizer::getCutEdges (Ticket #195). Unit test included in
tests/unit/capi/GEOSPolygonizer_getCutEdgeTest.cpp. Thanks to
Jurgen E. Fischer for this patch.
-2008-07-26 23:06 mloskot
+2008-07-26 23:06 Mateusz Loskot <mateusz at loskot.net>
- * doc/example.cpp, source/geomgraph/GeometryGraph.cpp,
+ * [r2143] doc/example.cpp, source/geomgraph/GeometryGraph.cpp,
source/headers/geos/noding/FastNodingValidator.h,
source/index/quadtree/DoubleBits.cpp,
@@ -4663,33 +4794,34 @@
tests/bigtest/TestSweepLineSpeed.cpp: Number of fixes enabling
GEOS compilation with GCC 4.3 (Ticket #167).
-2008-07-26 21:00 mloskot
+2008-07-26 21:00 Mateusz Loskot <mateusz at loskot.net>
- * capi/geos_c.h.in: Guarded version macros with #ifndef conditions
- to avoid redefinition errors (Ticket #167).
+ * [r2142] capi/geos_c.h.in: Guarded version macros with #ifndef
+ conditions to avoid redefinition errors (Ticket #167).
-2008-07-26 20:47 mloskot
+2008-07-26 20:47 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/version.h.in,
+ * [r2141] source/headers/geos/version.h.in,
source/headers/geos/version.h.vc: Guarded version macros with
#ifndef conditions to avoid redefinition errors (Ticket #167).
-2008-07-26 20:24 mloskot
+2008-07-26 20:24 Mateusz Loskot <mateusz at loskot.net>
- * macros/ac_python_devel.m4: Fixed problems with finding libpython
- on Mac Darwin (Ticket #191).
+ * [r2140] macros/ac_python_devel.m4: Fixed problems with finding
+ libpython on Mac Darwin (Ticket #191).
-2008-07-26 19:57 mloskot
+2008-07-26 19:57 Mateusz Loskot <mateusz at loskot.net>
- * autogen.sh: Updated svn:keywords property.
+ * [r2139] autogen.sh: Updated svn:keywords property.
-2008-07-26 19:56 mloskot
+2008-07-26 19:56 Mateusz Loskot <mateusz at loskot.net>
- * autogen.sh: Fixed autogen.sh for OpenSolaris (Ticket #192).
+ * [r2138] autogen.sh: Fixed autogen.sh for OpenSolaris (Ticket
+ #192).
-2008-07-25 21:00 mloskot
+2008-07-25 21:00 Mateusz Loskot <mateusz at loskot.net>
- * build/README, build/msvc80/README, macros/geos.m4,
+ * [r2137] build/README, build/msvc80/README, macros/geos.m4,
source/headers/geos/algorithm/CentralEndpointIntersector.h,
source/headers/geos/geomPrep.h,
source/headers/geos/indexIntervalRTree.h,
@@ -4700,24 +4832,26 @@
swig/python/tests/TESTING.txt: Updated svn:keywords property
-2008-07-25 20:56 mloskot
+2008-07-25 20:56 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/operation/IsSimpleOpTest.cpp,
+ * [r2136] tests/unit/operation/IsSimpleOpTest.cpp,
tests/unit/precision/SimpleGeometryPrecisionReducerTest.cpp:
-2008-07-19 19:11 warmerdam
+2008-07-19 19:11 Frank Warmerdam <warmerdam at pobox.com>
- * source/Makefile.vc: added manifest handling for DLLs (#193)
+ * [r2135] source/Makefile.vc: added manifest handling for DLLs
+ (#193)
-2008-07-19 19:07 warmerdam
+2008-07-19 19:07 Frank Warmerdam <warmerdam at pobox.com>
- * source/Makefile.vc: added rules to create platform.h, version.h
- and geos_c.h from templates on win32
+ * [r2134] source/Makefile.vc: added rules to create platform.h,
+ version.h and geos_c.h from templates on win32
-2008-07-15 22:04 mloskot
+2008-07-15 22:04 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, capi/geos_c.cpp, source/algorithm/ConvexHull.cpp,
+ * [r2131] ChangeLog, capi/geos_c.cpp,
+ source/algorithm/ConvexHull.cpp,
source/algorithm/RobustDeterminant.cpp,
source/geomgraph/EdgeEnd.cpp, source/geomgraph/GeometryGraph.cpp,
@@ -4738,24 +4872,25 @@
Studio compiler on Solaris x86 and Sparc (Ticket #189). Thanks to
Magne Mahre for the patch.
-2008-07-15 13:35 mloskot
+2008-07-15 13:35 Mateusz Loskot <mateusz at loskot.net>
- * source/Makefile.vc: For building with Visual C++, added new flag
- DEBUG=1 (see GEOS building instructions on GEOS Wiki). Added
- missing flags for Visual C++ compiler, in release and debug
+ * [r2130] source/Makefile.vc: For building with Visual C++, added
+ new flag DEBUG=1 (see GEOS building instructions on GEOS Wiki).
+ Added missing flags for Visual C++ compiler, in release and debug
configuration.
-2008-05-20 21:34 mloskot
+2008-05-20 21:34 Mateusz Loskot <mateusz at loskot.net>
- * source/dirlist.mk: Added missing subdirs to source/dirlist.mk
+ * [r2129] source/dirlist.mk: Added missing subdirs to
+ source/dirlist.mk
-2008-05-20 21:31 mloskot
+2008-05-20 21:31 Mateusz Loskot <mateusz at loskot.net>
- * source/geom/prep: Updated svn:ignore patterns.
+ * [r2128] source/geom/prep: Updated svn:ignore patterns.
-2008-05-20 21:25 mloskot
+2008-05-20 21:25 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, bootstrap.bat, build/msvc80/geos.sln,
+ * [r2127] ChangeLog, bootstrap.bat, build/msvc80/geos.sln,
source/geom/GeometryComponentFilter.cpp,
source/geom/PrecisionModel.cpp,
@@ -4797,33 +4932,34 @@
* build\msvc80\geos_lib\geos_lib.vcproj: Remove non-existing
source files.
-2008-05-20 20:45 mloskot
+2008-05-20 20:45 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, source/Makefile.vc: source/makefile.vc: Removed
- non-existing file entry: PreparedPolygonLineIntersects.obj.
+ * [r2126] ChangeLog, source/Makefile.vc: source/makefile.vc:
+ Removed non-existing file entry:
+ PreparedPolygonLineIntersects.obj.
-2008-05-20 20:33 mloskot
+2008-05-20 20:33 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, bootstrap.bat, source/Makefile.vc: * bootstrap.bat:
- Added script generating headers for use with Visual C++ compiler.
- DO NOT include this script in GEOS source distribution. *
- source/makefile.vc: Do not make copies of 3 dynamic headers but
- let users to use bootstrap.bat instead.
+ * [r2125] ChangeLog, bootstrap.bat, source/Makefile.vc: *
+ bootstrap.bat: Added script generating headers for use with
+ Visual C++ compiler. DO NOT include this script in GEOS source
+ distribution. * source/makefile.vc: Do not make copies of 3
+ dynamic headers but let users to use bootstrap.bat instead.
-2008-02-07 22:59 warmerdam
+2008-02-07 22:59 Frank Warmerdam <warmerdam at pobox.com>
- * Makefile.am: make sure makefile.vc gets distributed
+ * [r2123] Makefile.am: make sure makefile.vc gets distributed
-2008-02-06 22:17 warmerdam
+2008-02-06 22:17 Frank Warmerdam <warmerdam at pobox.com>
- * source/Makefile.am, source/Makefile.vc,
+ * [r2122] source/Makefile.am, source/Makefile.vc,
source/headers/geos/noding/Makefile.am: try to fix up the files
include in distribution, and remove unused files from Makefile.vc
(#175)
-2008-01-30 22:34 benjubb
+2008-01-30 22:34 Ben Jubb <benjubb at refractions.net>
+ * [r2120] source/headers/geos/algorithm/RayCrossingCounter.h,
source/headers/geos/algorithm/locate/SimplePointInAreaLocator.h,
@@ -4854,37 +4990,38 @@
source/headers/geos/noding/SegmentStringUtil.h: Added
documentation, for benefit of doxygen.
-2008-01-30 22:30 benjubb
+2008-01-30 22:30 Ben Jubb <benjubb at refractions.net>
- * source/geom/prep/PreparedPolygonIntersects.cpp: deleted
+ * [r2119] source/geom/prep/PreparedPolygonIntersects.cpp: deleted
out-commented line.
-2008-01-30 22:29 benjubb
+2008-01-30 22:29 Ben Jubb <benjubb at refractions.net>
- * source/geom/prep/PreparedPolygon.cpp: removed ref to
+ * [r2118] source/geom/prep/PreparedPolygon.cpp: removed ref to
PreparedPolygonLineIntersection
-2008-01-30 22:18 benjubb
+2008-01-30 22:18 Ben Jubb <benjubb at refractions.net>
- * source/geom/prep/Makefile.am,
+ * [r2117] source/geom/prep/Makefile.am,
source/headers/geos/geom/prep/Makefile.am: Removed refs to
PreparedPolygonLineIntersection.
-2008-01-30 22:17 benjubb
+2008-01-30 22:17 Ben Jubb <benjubb at refractions.net>
- * source/geom/prep/PreparedPolygonLineIntersection.cpp,
+ * [r2116] source/geom/prep/PreparedPolygonLineIntersection.cpp,
source/headers/geos/geom/prep/PreparedPolygonLineIntersection.h:
Deleted. not used, not needed.
-2008-01-30 19:09 benjubb
+2008-01-30 19:09 Ben Jubb <benjubb at refractions.net>
- * source/headers/geos/geomPrep.h: Added for benefit of doxygen.
+ * [r2115] source/headers/geos/geomPrep.h: Added for benefit of
+ doxygen.
-2008-01-29 17:55 benjubb
+2008-01-29 17:55 Ben Jubb <benjubb at refractions.net>
+ * [r2114] source/geom/prep/AbstractPreparedPolygonContains.cpp,
source/geom/prep/PreparedLineString.cpp,
@@ -4895,286 +5032,292 @@
to improve the memory management. These changes plug a few leaks,
but not all.
-2008-01-29 17:49 benjubb
+2008-01-29 17:49 Ben Jubb <benjubb at refractions.net>
- * source/operation/predicate/RectangleContains.cpp: Fix a bug in
- the shortcut test for containment in a rectangle. This test
- wasn't correctly testing for case of a point on the boundary.
+ * [r2113] source/operation/predicate/RectangleContains.cpp: Fix a
+ bug in the shortcut test for containment in a rectangle. This
+ test wasn't correctly testing for case of a point on the
+ boundary.
Was also a bug in JTS (now fixed).
-2008-01-29 17:37 benjubb
+2008-01-29 17:37 Ben Jubb <benjubb at refractions.net>
- * source/geom/Geometry.cpp: Patch to fix bug in ticket #171
+ * [r2112] source/geom/Geometry.cpp: Patch to fix bug in ticket #171
-2008-01-22 19:34 benjubb
+2008-01-22 19:34 Ben Jubb <benjubb at refractions.net>
- * capi/geos_c.h.in, source/headers/geos/version.h.vc: Updated for
- VC to give correct version (3.1.0-CAPI-1.5.0).
+ * [r2111] capi/geos_c.h.in, source/headers/geos/version.h.vc:
+ Updated for VC to give correct version (3.1.0-CAPI-1.5.0).
-2008-01-18 00:37 benjubb
+2008-01-18 00:37 Ben Jubb <benjubb at refractions.net>
- * configure.in: Added to CAPI interface, cleared
+ * [r2110] configure.in: Added to CAPI interface, cleared
CAPI_INTERFACE_REV, bumped AGE & CURRENT
-2008-01-18 00:35 benjubb
+2008-01-18 00:35 Ben Jubb <benjubb at refractions.net>
- * source/index/chain/MonotoneChainBuilder.cpp: Fixed a bug in the
- handling of line strings with repeated points.
+ * [r2109] source/index/chain/MonotoneChainBuilder.cpp: Fixed a bug
+ in the handling of line strings with repeated points.
-This line, and those below, will be ignored--
M MonotoneChainBuilder.cpp
-2008-01-17 19:15 benjubb
+2008-01-17 19:15 Ben Jubb <benjubb at refractions.net>
- * capi/geos_c.cpp: Fixed a misspelling,
+ * [r2108] capi/geos_c.cpp: Fixed a misspelling,
GEOSPreparedContainsProperty => GEOSPreparedContainsProperly
-2008-01-16 18:36 warmerdam
+2008-01-16 18:36 Frank Warmerdam <warmerdam at pobox.com>
- * source/Makefile.vc: updated to include post 3.0 classes
+ * [r2107] source/Makefile.vc: updated to include post 3.0 classes
-2008-01-09 23:49 benjubb
+2008-01-09 23:49 Ben Jubb <benjubb at refractions.net>
- * capi/geos_c.cpp, capi/geos_c.h.in: Added support for prepared
- geometry
+ * [r2106] capi/geos_c.cpp, capi/geos_c.h.in: Added support for
+ prepared geometry
-2008-01-09 23:48 benjubb
+2008-01-09 23:48 Ben Jubb <benjubb at refractions.net>
- * source/headers/geos/geom/prep/PreparedGeometryFactory.h: removed
- extraneous 'using namespace'
+ * [r2105] source/headers/geos/geom/prep/PreparedGeometryFactory.h:
+ removed extraneous 'using namespace'
-2008-01-03 21:11 benjubb
+2008-01-03 21:11 Ben Jubb <benjubb at refractions.net>
- * source/noding/MCIndexSegmentSetMutualIntersector.cpp: commented
- out some delete's in
+ * [r2104] source/noding/MCIndexSegmentSetMutualIntersector.cpp:
+ commented out some delete's in
MCIndexSegmentSetMutualIntersector::addToIndex, to fix a bug in
prepared contains() predicate.
-2008-01-02 23:23 sgillies
+2008-01-02 23:23 Sean Gillies <sgillies at frii.com>
- * swig/Makefile.am: Conditionally add swig/python,ruby to SUBDIRS
+ * [r2102] swig/Makefile.am: Conditionally add swig/python,ruby to
+ SUBDIRS
-2007-12-22 00:04 mloskot
+2007-12-22 00:04 Mateusz Loskot <mateusz at loskot.net>
- * build/bjam/geos/Jamfile, build/bjam/geos_c, build/bjam/geos_unit:
- Updated configuration of experimental builder based on
- Boost.Build. GEOS compiles with bjam successfully as static
- library.
+ * [r2101] build/bjam/geos/Jamfile, build/bjam/geos_c,
+ build/bjam/geos_unit: Updated configuration of experimental
+ builder based on Boost.Build. GEOS compiles with bjam
+ successfully as static library.
-2007-12-21 23:50 mloskot
+2007-12-21 23:50 Mateusz Loskot <mateusz at loskot.net>
- * source/Makefile.vc, source/algorithm/locate,
+ * [r2100] source/Makefile.vc, source/algorithm/locate,
source/index/intervalrtree: Updated Visual C++ makefiles with new
submissions from Ben. Now, new GEOS features compiles with NMAKE
too.
-2007-12-21 23:31 mloskot
+2007-12-21 23:31 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/algorithm/Makefile.am: Removed
+ * [r2099] source/headers/geos/algorithm/Makefile.am: Removed
SimplePointInAreaLocator.h from algorithm/Makefile.am (header
migrated to algorithm/locate).
-2007-12-21 23:26 mloskot
+2007-12-21 23:26 Mateusz Loskot <mateusz at loskot.net>
- * source/algorithm/Makefile.am: Added comment about deprecated
- translation units in source/algorithm.
+ * [r2098] source/algorithm/Makefile.am: Added comment about
+ deprecated translation units in source/algorithm.
-2007-12-21 23:26 pramsey
+2007-12-21 23:26 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/geom/util/Makefile.am: remove trailing backslash
+ * [r2097] source/geom/util/Makefile.am: remove trailing backslash
-2007-12-21 23:21 mloskot
+2007-12-21 23:21 Mateusz Loskot <mateusz at loskot.net>
- * ., source/headers/geos/algorithm,
+ * [r2096] ., source/headers/geos/algorithm,
source/headers/geos/algorithm/locate, tests/unit: Updated
-2007-12-21 23:18 mloskot
+2007-12-21 23:18 Mateusz Loskot <mateusz at loskot.net>
- * source/geom/prep/PreparedPolygonContainsProperly.cpp: Fixed extra
- qualifications in /geom/prep/PreparedPolygonContainsProperly.
+ * [r2095] source/geom/prep/PreparedPolygonContainsProperly.cpp:
+ Fixed extra qualifications in
+ /geom/prep/PreparedPolygonContainsProperly.
-2007-12-21 23:12 mloskot
+2007-12-21 23:12 Mateusz Loskot <mateusz at loskot.net>
+ * [r2094] source/geom/prep/AbstractPreparedPolygonContains.cpp,
source/headers/geos/geom/prep/PreparedGeometryFactory.h: Fixed
extra qualifications in PreparedGeometryFactory class.
-2007-12-21 22:57 mloskot
+2007-12-21 22:57 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/geom/util/ComponentCoordinateExtracter.h:
+ * [r2093]
+ source/headers/geos/geom/util/ComponentCoordinateExtracter.h:
Fixed GeometryTypeId misused in
geos/geom/util/ComponentCoordinateExtracter.h.
-2007-12-21 22:49 pramsey
+2007-12-21 22:49 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/geom/util/Makefile.am: remove .cpp files that weren't
- there before
+ * [r2092] source/geom/util/Makefile.am: remove .cpp files that
+ weren't there before
-2007-12-21 22:49 mloskot
+2007-12-21 22:49 Mateusz Loskot <mateusz at loskot.net>
- * source/geom/CoordinateArraySequence.cpp,
+ * [r2091] source/geom/CoordinateArraySequence.cpp,
source/geom/CoordinateSequence.cpp, source/geom/LineString.cpp:
Reverted changes appled in r2089 to three files from source/geom.
-2007-12-21 22:47 pramsey
+2007-12-21 22:47 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/algorithm/Makefile.am: type subdir typo
+ * [r2090] source/algorithm/Makefile.am: type subdir typo
-2007-12-21 22:43 mloskot
+2007-12-21 22:43 Mateusz Loskot <mateusz at loskot.net>
+ * [r2089] source/geom/CoordinateArraySequence.cpp,
source/geom/CoordinateSequence.cpp, source/geom/LineString.cpp,
source/geom/prep, source/headers/geos/geom/prep,
source/headers/geos/index/intervalrtree,
source/index/intervalrtree: Updated svn:ignore property.
-2007-12-21 22:41 mloskot
+2007-12-21 22:41 Mateusz Loskot <mateusz at loskot.net>
- * source/examples/CustomPointCoordinateSequence.cpp: Added missing
- <iostream> header to CustomPointCoordinateSequence.cpp.
+ * [r2088] source/examples/CustomPointCoordinateSequence.cpp: Added
+ missing <iostream> header to CustomPointCoordinateSequence.cpp.
-2007-12-21 22:40 mloskot
+2007-12-21 22:40 Mateusz Loskot <mateusz at loskot.net>
- * source/algorithm/Makefile.am,
+ * [r2087] source/algorithm/Makefile.am,
source/algorithm/SimplePointInAreaLocator.cpp,
source/algorithm/locate: Removed unused
SimplePointInAreaLocator.cpp. This unit migrated to
algorithm/locate module.
-2007-12-21 22:21 pramsey
+2007-12-21 22:21 Paul Ramsey <pramsey at cleverelephant.ca>
- * configure.in: Updated configure.in with new locations.
+ * [r2086] configure.in: Updated configure.in with new locations.
-2007-12-21 22:14 mloskot
+2007-12-21 22:14 Mateusz Loskot <mateusz at loskot.net>
+ * [r2085] configure.in: Updated configure.in with new locations.
-2007-12-21 22:12 mloskot
+2007-12-21 22:12 Mateusz Loskot <mateusz at loskot.net>
+ * [r2084] configure.in: Updated configure.in with new locations.
-2007-12-21 22:09 mloskot
+2007-12-21 22:09 Mateusz Loskot <mateusz at loskot.net>
+ * [r2083] configure.in: Updated configure.in with new locations.
-2007-12-21 22:07 mloskot
+2007-12-21 22:07 Mateusz Loskot <mateusz at loskot.net>
+ * [r2082] configure.in: Updated configure.in with new locations.
-2007-12-21 22:02 pramsey
+2007-12-21 22:02 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/headers/geos/algorithm/Makefile.am,
+ * [r2081] source/headers/geos/algorithm/Makefile.am,
source/headers/geos/algorithm/locate/Makefile.am,
source/headers/geos/noding/Makefile.am: Add
headers/geos/algorithm/locate to automake
-2007-12-21 22:01 pramsey
+2007-12-21 22:01 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/noding/Makefile.am: Add files to automake
+ * [r2080] source/noding/Makefile.am: Add files to automake
-2007-12-21 21:57 pramsey
+2007-12-21 21:57 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/headers/geos/index/Makefile.am,
+ * [r2079] source/headers/geos/index/Makefile.am,
source/headers/geos/index/intervalrtree/Makefile.am: Added
headers/index/intervalrtree to automake
-2007-12-21 21:55 pramsey
+2007-12-21 21:55 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/headers/geos/geom/Makefile.am,
+ * [r2078] source/headers/geos/geom/Makefile.am,
source/headers/geos/geom/prep/Makefile.am,
source/headers/geos/geom/util/Makefile.am: Added
headers/geom/prep headers/geom/util to automake
-2007-12-21 21:47 pramsey
+2007-12-21 21:47 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/index/Makefile.am, source/index/intervalrtree/Makefile.am:
- Added index/intervalrtree to automake
+ * [r2077] source/index/Makefile.am,
+ source/index/intervalrtree/Makefile.am: Added index/intervalrtree
+ to automake
-2007-12-21 21:43 pramsey
+2007-12-21 21:43 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/geom/util/Makefile.am: added
+ * [r2076] source/geom/util/Makefile.am: added
-2007-12-21 21:40 pramsey
+2007-12-21 21:40 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/geom/Makefile.am, source/geom/prep/Makefile.am: Add
- geom/prep to automake
+ * [r2075] source/geom/Makefile.am, source/geom/prep/Makefile.am:
+ Add geom/prep to automake
-2007-12-21 21:36 pramsey
+2007-12-21 21:36 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r2074] source/algorithm/Makefile.am,
source/algorithm/locate/Makefile.am: Add algorithm/location to
automake
-2007-12-21 21:31 pramsey
+2007-12-21 21:31 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/algorithm/Makefile.am: Added new files
+ * [r2073] source/algorithm/Makefile.am: Added new files
-2007-12-21 20:50 benjubb
+2007-12-21 20:50 Ben Jubb <benjubb at refractions.net>
- * source/algorithm/RayCrossingCounter.cpp:
+ * [r2072] source/algorithm/RayCrossingCounter.cpp:
-2007-12-21 20:48 benjubb
+2007-12-21 20:48 Ben Jubb <benjubb at refractions.net>
+ * [r2071] build/msvc80/geos_lib/geos_lib.vcproj:
-2007-12-21 20:47 benjubb
+2007-12-21 20:47 Ben Jubb <benjubb at refractions.net>
- * source/headers/geos/index/intervalrtree,
+ * [r2070] source/headers/geos/index/intervalrtree,
source/headers/geos/index/intervalrtree/IntervalRTreeBranchNode.h,
source/headers/geos/index/intervalrtree/IntervalRTreeLeafNode.h,
source/headers/geos/index/intervalrtree/IntervalRTreeNode.h,
source/headers/geos/index/intervalrtree/SortedPackedIntervalRTree.h:
Added from JTS 1.9 to support prepared geometry
- * source/algorithm/locate,
+ * [r2069] source/algorithm/locate,
source/algorithm/locate/SimplePointInAreaLocator.cpp: Added from
-2007-12-21 20:44 benjubb
+2007-12-21 20:44 Ben Jubb <benjubb at refractions.net>
- * source/geom/util/ComponentCoordinateExtracter.cpp: Added from JTS
- 1.9 to support prepared geometry
+ * [r2068] source/geom/util/ComponentCoordinateExtracter.cpp: Added
+ from JTS 1.9 to support prepared geometry
+ * [r2067]
-2007-12-21 20:42 benjubb
+2007-12-21 20:42 Ben Jubb <benjubb at refractions.net>
- * source/operation/predicate/RectangleIntersects.cpp: modified
- because SimplePointInAreaLocator.h moved
+ * [r2066] source/operation/predicate/RectangleIntersects.cpp:
+ modified because SimplePointInAreaLocator.h moved
-2007-12-21 20:41 benjubb
+2007-12-21 20:41 Ben Jubb <benjubb at refractions.net>
- * source/noding/FastSegmentSetIntersectionFinder.cpp,
+ * [r2065] source/noding/FastSegmentSetIntersectionFinder.cpp,
source/noding/MCIndexSegmentSetMutualIntersector.cpp,
source/noding/NodedSegmentString.cpp,
source/noding/SegmentStringUtil.cpp: Added from JTS 1.9 to
- * source/index/intervalrtree,
+ * [r2064] source/index/intervalrtree,
source/index/intervalrtree/IntervalRTreeBranchNode.cpp,
source/index/intervalrtree/IntervalRTreeLeafNode.cpp,
source/index/intervalrtree/IntervalRTreeNode.cpp,
source/index/intervalrtree/SortedPackedIntervalRTree.cpp: Added
-2007-12-21 20:40 benjubb
+2007-12-21 20:40 Ben Jubb <benjubb at refractions.net>
- * source/geom/prep,
+ * [r2063] source/geom/prep,
@@ -5191,24 +5334,24 @@
source/geom/prep/PreparedPolygonPredicate.cpp: Added from JTS 1.9
-2007-12-21 20:39 benjubb
+2007-12-21 20:39 Ben Jubb <benjubb at refractions.net>
- * source/geomgraph/EdgeEndStar.cpp: modified because
+ * [r2062] source/geomgraph/EdgeEndStar.cpp: modified because
-2007-12-21 20:38 benjubb
+2007-12-21 20:38 Ben Jubb <benjubb at refractions.net>
- * source/headers/geos/algorithm/SimplePointInAreaLocator.h: Moved
- into geos::algorithm::locate
+ * [r2061] source/headers/geos/algorithm/SimplePointInAreaLocator.h:
+ Moved into geos::algorithm::locate
-2007-12-21 20:37 benjubb
+2007-12-21 20:37 Ben Jubb <benjubb at refractions.net>
- * source/headers/geos/algorithm/RayCrossingCounter.h: Added from
- JTS 1.9 to support prepared geometry
+ * [r2060] source/headers/geos/algorithm/RayCrossingCounter.h: Added
-2007-12-21 20:35 benjubb
+2007-12-21 20:35 Ben Jubb <benjubb at refractions.net>
- * source/headers/geos/geom/prep,
+ * [r2059] source/headers/geos/geom/prep,
@@ -5225,9 +5368,10 @@
source/headers/geos/geom/prep/PreparedPolygonPredicate.h: Added
-2007-12-21 20:34 benjubb
+2007-12-21 20:34 Ben Jubb <benjubb at refractions.net>
- * source/headers/geos/noding/FastSegmentSetIntersectionFinder.h,
+ * [r2058]
+ source/headers/geos/noding/FastSegmentSetIntersectionFinder.h,
source/headers/geos/noding/NodableSegmentString.h,
source/headers/geos/noding/NodedSegmentString.h,
@@ -5236,79 +5380,81 @@
source/headers/geos/noding/SegmentStringUtil.h: Added from JTS
-2007-12-21 20:33 benjubb
+2007-12-21 20:33 Ben Jubb <benjubb at refractions.net>
- * source/headers/geos/noding/SegmentString.h: changed destructor to
- be virtual
+ * [r2057] source/headers/geos/noding/SegmentString.h: changed
+ destructor to be virtual
-2007-12-21 20:31 benjubb
+2007-12-21 20:31 Ben Jubb <benjubb at refractions.net>
- * source/headers/geos/geom/Envelope.h: Added a covers() predicate,
- from JTS 1.9, to support prepared geometry
+ * [r2056] source/headers/geos/geom/Envelope.h: Added a covers()
+ predicate, from JTS 1.9, to support prepared geometry
-2007-12-21 20:30 benjubb
+2007-12-21 20:30 Ben Jubb <benjubb at refractions.net>
- * source/headers/geos/geom/Geometry.h: changed IsRectangle to be
- public
+ * [r2055] source/headers/geos/geom/Geometry.h: changed IsRectangle
+ to be public
-2007-12-21 20:03 benjubb
+2007-12-21 20:03 Ben Jubb <benjubb at refractions.net>
- * source/headers/geos/geom/Envelope.inl: Added a covers()
+ * [r2054] source/headers/geos/geom/Envelope.inl: Added a covers()
-2007-12-21 20:00 benjubb
+2007-12-21 20:00 Ben Jubb <benjubb at refractions.net>
- * source/headers/geos/algorithm/locate/SimplePointInAreaLocator.h:
+ * [r2053]
+ source/headers/geos/algorithm/locate/SimplePointInAreaLocator.h:
Moved from geos::algorithm as in JTS 1.9
-2007-12-21 19:55 benjubb
+2007-12-21 19:55 Ben Jubb <benjubb at refractions.net>
- * source/headers/geos/algorithm/locate,
+ * [r2052] source/headers/geos/algorithm/locate,
source/headers/geos/algorithm/locate/PointOnGeometryLocator.h:
New namaspace geos::algorithm::locate, as in JTS 1.9..
-2007-12-21 19:52 benjubb
+2007-12-21 19:52 Ben Jubb <benjubb at refractions.net>
- * source/headers/geos/algorithm/SimplePointInAreaLocator.h: Added a
- public constructor, and a method to bring in line with JTS 1.9.
- Changed namespace to geos::algorithm::locate
+ * [r2051] source/headers/geos/algorithm/SimplePointInAreaLocator.h:
+ Added a public constructor, and a method to bring in line with
+ JTS 1.9. Changed namespace to geos::algorithm::locate
-2007-12-21 18:44 pramsey
+2007-12-21 18:44 Paul Ramsey <pramsey at cleverelephant.ca>
- * configure.in: version numbering for next release (3.1.0)
+ * [r2050] configure.in: version numbering for next release (3.1.0)
-2007-12-21 18:41 pramsey
+2007-12-21 18:41 Paul Ramsey <pramsey at cleverelephant.ca>
- * ChangeLog, configure.in: 3.0.0 release
+ * [r2046] ChangeLog, configure.in: 3.0.0 release
-2007-12-19 20:18 mloskot
+2007-12-19 20:18 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, source/headers/geos/geom.h, source/headers/geos/io.h:
- Improved warning message about using DEPRECATED headers
+ * [r2045] ChangeLog, source/headers/geos/geom.h,
+ source/headers/geos/io.h: Improved warning message about using
+ DEPRECATED headers
-2007-12-17 23:09 mloskot
+2007-12-17 23:09 Mateusz Loskot <mateusz at loskot.net>
- * tests/xmltester/XMLTester.cpp: Fixed std::tolower usage in
- XMLTester.cpp (Ticket #163).
+ * [r2044] tests/xmltester/XMLTester.cpp: Fixed std::tolower usage
+ in XMLTester.cpp (Ticket #163).
-2007-12-17 23:05 mloskot
+2007-12-17 23:05 Mateusz Loskot <mateusz at loskot.net>
- * source/algorithm/HCoordinate.cpp: Replaced finite function with
- std::numeric_limits (Ticket #162).
+ * [r2043] source/algorithm/HCoordinate.cpp: Replaced finite
+ function with std::numeric_limits (Ticket #162).
-2007-12-17 21:52 mloskot
+2007-12-17 21:52 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, source/Makefile.vc: source\Makefile.vc: Fixed MSVC_VER
- condition for Microsoft Visual C++ 2008 (9.0).
+ * [r2042] ChangeLog, source/Makefile.vc: source\Makefile.vc: Fixed
+ MSVC_VER condition for Microsoft Visual C++ 2008 (9.0).
-2007-12-13 16:11 mloskot
+2007-12-13 16:11 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog: Added Id keyword at the top of ChangeLog file.
+ * [r2041] ChangeLog: Added Id keyword at the top of ChangeLog file.
-2007-12-13 16:09 mloskot
+2007-12-13 16:09 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, build/msvc80/geos_unit/geos_unit.vcproj,
+ * [r2040] ChangeLog, build/msvc80/geos_unit/geos_unit.vcproj,
source/geom/Geometry.cpp, source/geom/GeometryCollection.cpp,
tests/unit/geom/GeometryFactoryTest.cpp: *
build\msvc80\geos_unit\geos_unit.vcproj: fixed post-build event
@@ -5320,243 +5466,247 @@
instead of
int where unsigned integral type required.
-2007-12-09 00:02 mloskot
+2007-12-09 00:02 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, tests/unit/Makefile.am,
+ * [r2038] ChangeLog, tests/unit/Makefile.am,
Added test suite for class
geos::precision::SimpleGeometryPrecisionReducer.
-2007-12-08 22:59 mloskot
+2007-12-08 22:59 Mateusz Loskot <mateusz at loskot.net>
- * .: Updated svn:keyword property.
+ * [r2037] .: Updated svn:keyword property.
-2007-11-26 16:26 mloskot
+2007-11-26 16:26 Mateusz Loskot <mateusz at loskot.net>
- * build/msvc80/geos.vsprops: Added geos.vsprops - property sheet
- for Visual C++ projects.
+ * [r2036] build/msvc80/geos.vsprops: Added geos.vsprops - property
+ sheet for Visual C++ projects.
-2007-11-26 15:19 mloskot
+2007-11-26 15:19 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, build/msvc80/geos_python/geos_python.vcproj,
+ * [r2035] ChangeLog, build/msvc80/geos_python/geos_python.vcproj,
build/msvc80/geos_ruby/geos_ruby.vcproj,
swig/python/geos_wrap.cxx: Added common Property Sheet for Visual
C++ projects where Python and Ruby macros/locations are defined.
Fixed include of Python.h, see Ticket #164 for details.
-2007-11-26 06:21 mloskot
+2007-11-26 06:21 Mateusz Loskot <mateusz at loskot.net>
- * source/algorithm: Updated svn:ignore patterns.
+ * [r2034] source/algorithm: Updated svn:ignore patterns.
-2007-11-26 06:16 mloskot
+2007-11-26 06:16 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, source/Makefile.vc, source/headers/geos/version.h.vc:
- Enabled target copying version.h.vc and geos_c.h.vc to headers
- used by Visual C++. Added test if version.h.vc is used with
- Visual C++.
+ * [r2033] ChangeLog, source/Makefile.vc,
+ source/headers/geos/version.h.vc: Enabled target copying
+ version.h.vc and geos_c.h.vc to headers used by Visual C++. Added
+ test if version.h.vc is used with Visual C++.
-2007-11-23 02:33 mloskot
+2007-11-23 02:33 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, source/headers/geos/io/WKBWriter.h: A bit of
+ * [r2032] ChangeLog, source/headers/geos/io/WKBWriter.h: A bit of
purification with explicit casting int to bool type.
-2007-11-02 22:41 pramsey
+2007-11-02 22:41 Paul Ramsey <pramsey at cleverelephant.ca>
- * web/index.html: urls updated to point to osgeo locations
+ * [r2031] web/index.html: urls updated to point to osgeo locations
-2007-11-02 22:17 pramsey
+2007-11-02 22:17 Paul Ramsey <pramsey at cleverelephant.ca>
- * web, web/index.html, web/style.css: add the web site content to
- svn for collaborative management
+ * [r2030] web, web/index.html, web/style.css: add the web site
+ content to svn for collaborative management
-2007-09-21 17:42 csavage
+2007-09-21 17:42 Charlie Savage <cfis at savagexi.com>
- * configure.in: Update the CAPI and GEOS version numbers based on
- Reader/Writer additions to the CAPI and EWKB support for the C++
- api.
+ * [r2029] configure.in: Update the CAPI and GEOS version numbers
+ based on Reader/Writer additions to the CAPI and EWKB support for
+ the C++ api.
-2007-09-21 17:40 csavage
+2007-09-21 17:40 Charlie Savage <cfis at savagexi.com>
- * swig/geos.i.in, swig/ruby/geos_wrap.cxx, swig/ruby/ruby.i,
- swig/ruby/test/test_buffer.rb, swig/ruby/test/test_helper.rb,
- swig/ruby/test/test_io.rb, swig/ruby/test/test_operations.rb,
- swig/ruby/test/test_srid.rb, swig/ruby/test/test_version.rb:
- Updated the SWIG bindings and tests to use the new Reader/Writer
- classes exposed in the CAPI.
+ * [r2028] swig/geos.i.in, swig/ruby/geos_wrap.cxx,
+ swig/ruby/ruby.i, swig/ruby/test/test_buffer.rb,
+ swig/ruby/test/test_helper.rb, swig/ruby/test/test_io.rb,
+ swig/ruby/test/test_operations.rb, swig/ruby/test/test_srid.rb,
+ swig/ruby/test/test_version.rb: Updated the SWIG bindings and
+ tests to use the new Reader/Writer classes exposed in the CAPI.
- * capi/geos_c.cpp, capi/geos_c.h.in: Update the CAPI to expose
- WKTReader/WBTWriter and WKBReader/WBKWriter in the CAPI. This is
- an improvement over the existing API since it avoids the use of
- the static variable used to control byte order and # of
+ * [r2027] capi/geos_c.cpp, capi/geos_c.h.in: Update the CAPI to
+ expose WKTReader/WBTWriter and WKBReader/WBKWriter in the CAPI.
+ This is an improvement over the existing API since it avoids the
+ use of the static variable used to control byte order and # of
dimenions, and gives clients more control over the
creation/destruction of readers and writers. Finally, exposed the
ability to output the EWKB format (set SRID to true in the
WKBWriter).
-2007-09-21 17:35 csavage
+2007-09-21 17:35 Charlie Savage <cfis at savagexi.com>
- * source/index/strtree/STRtree.cpp: Switched back to using <
- because the fuzzy comparison now in use trips assertion errors in
- VC++. See comments in code for more information. Note this change
- may cause problems. Strk left a note in the code saying that the
- '<' comparison sometimes gives unstable results. But that seems
- better than an assertion failure.
+ * [r2026] source/index/strtree/STRtree.cpp: Switched back to using
+ < because the fuzzy comparison now in use trips assertion errors
+ in VC++. See comments in code for more information. Note this
+ change may cause problems. Strk left a note in the code saying
+ that the '<' comparison sometimes gives unstable results. But
+ that seems better than an assertion failure.
-2007-09-21 17:32 csavage
+2007-09-21 17:32 Charlie Savage <cfis at savagexi.com>
- Updated the WKBWriter so it can output EWKB format similar to
- PostGIS. Also added a few getter/setter methods that allow
- clients to specify the reader's number of dimensions, byte order
- and whether srid values should be output. These getters/setters
- make it easier to wrap the reader in the CAPI.
+ * [r2025] source/headers/geos/io/WKBWriter.h,
+ source/io/WKBWriter.cpp: Updated the WKBWriter so it can output
+ EWKB format similar to PostGIS. Also added a few getter/setter
+ methods that allow clients to specify the reader's number of
+ dimensions, byte order and whether srid values should be output.
+ These getters/setters make it easier to wrap the reader in the
+ CAPI.
-2007-09-14 15:34 csavage
+2007-09-14 15:34 Charlie Savage <cfis at savagexi.com>
- * build/msvc80/geos_c_dll/geos_c_dll.vcproj,
+ * [r2024] build/msvc80/geos_c_dll/geos_c_dll.vcproj,
build/msvc80/geos_ruby, build/msvc80/geos_ruby/geos_ruby.vcproj:
- * build/msvc80/geos_python: Told SVN to ignore MSCV++ Python swig
- build directories.
+ * [r2023] build/msvc80/geos_python: Told SVN to ignore MSCV++
+ Python swig build directories.
-2007-09-14 15:25 csavage
+2007-09-14 15:25 Charlie Savage <cfis at savagexi.com>
- * source/io/WKBReader.cpp: Set unknown SRID values to 0 instead of
- -1 to be more consistent with the rest of GEOS (srid values are
- initialized to 0 by default).
+ * [r2022] source/io/WKBReader.cpp: Set unknown SRID values to 0
+ instead of -1 to be more consistent with the rest of GEOS (srid
+ values are initialized to 0 by default).
-2007-09-11 02:02 csavage
+2007-09-11 02:02 Charlie Savage <cfis at savagexi.com>
- * source/headers/geos/profiler.h: Don't include config.h for MSVC++
- builds.
+ * [r2021] source/headers/geos/profiler.h: Don't include config.h
+ for MSVC++ builds.
-2007-09-07 17:32 csavage
+2007-09-07 17:32 Charlie Savage <cfis at savagexi.com>
- * configure.in: The test for SWIG was incorrect. Fixed by patch
- from Mark Cave-Ayland.
+ * [r2020] configure.in: The test for SWIG was incorrect. Fixed by
+ patch from Mark Cave-Ayland.
-2007-09-06 23:24 csavage
+2007-09-06 23:24 Charlie Savage <cfis at savagexi.com>
- * source/headers/geos/profiler.h: Applied patch from Mark
+ * [r2019] source/headers/geos/profiler.h: Applied patch from Mark
Cave-Ayland's to make older versions of MingW that don't have
struct timezone defined compile again. Also fixed issues with
more recent versions of MingW that don't correctly compile with
the -ansi compiler switch.
-2007-09-06 23:22 csavage
+2007-09-06 23:22 Charlie Savage <cfis at savagexi.com>
- * configure.in, macros/ruby.m4: Applied patches from Mark
+ * [r2018] configure.in, macros/ruby.m4: Applied patches from Mark
Cave-Ayland's that reorganize/improve the SWIG support in the
generated configure file.\
-2007-08-31 20:44 csavage
+2007-08-31 20:44 Charlie Savage <cfis at savagexi.com>
- * capi/geos_c.cpp, capi/geos_c.h.in: For MSVC++ builds the CAPI
- version was set in geos_c.cpp instead of geos_c.h and it was set
- incorrectly. This patch fixes the MSVC++ version number and
+ * [r2017] capi/geos_c.cpp, capi/geos_c.h.in: For MSVC++ builds the
+ CAPI version was set in geos_c.cpp instead of geos_c.h and it was
+ set incorrectly. This patch fixes the MSVC++ version number and
centralizes the various versoin #defines in the geos_c.h.
-2007-08-31 20:18 csavage
+2007-08-31 20:18 Charlie Savage <cfis at savagexi.com>
- * swig/python/Makefile.am, swig/ruby/Makefile.am: Update swig
- makefiles to make the wrappers dependent on the SWIG interface
- files even if SWIG is disabled. Doing this means that Make will
- correctly recognize that a user has modified an I file, but that
- the .cxx wrapper cannot be regenerated since SWIG is not
+ * [r2016] swig/python/Makefile.am, swig/ruby/Makefile.am: Update
+ swig makefiles to make the wrappers dependent on the SWIG
+ interface files even if SWIG is disabled. Doing this means that
+ Make will correctly recognize that a user has modified an I file,
+ but that the .cxx wrapper cannot be regenerated since SWIG is not
available.
-2007-08-30 20:06 csavage
+2007-08-30 20:06 Charlie Savage <cfis at savagexi.com>
- * source/headers/geos/profiler.h, source/headers/geos/timeval.h:
- MingW now includes the gettimeofday function - so reworked
- includes to only use custom version when building with VC++.
+ * [r2015] source/headers/geos/profiler.h,
+ source/headers/geos/timeval.h: MingW now includes the
+ gettimeofday function - so reworked includes to only use custom
+ version when building with VC++.
-2007-08-30 17:00 csavage
+2007-08-30 17:00 Charlie Savage <cfis at savagexi.com>
- * macros/ruby.m4, swig/ruby/Makefile.am: Added RUBY_BIN_DIR to
- autoconf macros - simplified auto make input file for ruby
+ * [r2014] macros/ruby.m4, swig/ruby/Makefile.am: Added RUBY_BIN_DIR
+ to autoconf macros - simplified auto make input file for ruby
bindings.
-2007-08-30 06:19 csavage
+2007-08-30 06:19 Charlie Savage <cfis at savagexi.com>
- * macros/ac_pkg_swig.m4: The last attempt to fix this file failed -
- instead keep the code that queries the swig libraries but use sed
- to merge multiple lines together. If this is not done, then the
- swig output causes ./configure to blow up on msys.
+ * [r2013] macros/ac_pkg_swig.m4: The last attempt to fix this file
+ failed - instead keep the code that queries the swig libraries
+ but use sed to merge multiple lines together. If this is not
+ done, then the swig output causes ./configure to blow up on msys.
-2007-08-30 05:31 csavage
+2007-08-30 05:31 Charlie Savage <cfis at savagexi.com>
- * macros/ac_pkg_swig.m4: Fixes sed issue with swig on msys. For
- more info see:
+ * [r2012] macros/ac_pkg_swig.m4: Fixes sed issue with swig on msys.
+ For more info see:
http://lists.refractions.net/pipermail/geos-devel/2007-August/002956.html
-2007-08-30 03:18 csavage
+2007-08-30 03:18 Charlie Savage <cfis at savagexi.com>
- * swig/geos.i.in: Changed from dos to unix line feeds.
+ * [r2011] swig/geos.i.in: Changed from dos to unix line feeds.
-2007-08-29 01:41 csavage
+2007-08-29 01:41 Charlie Savage <cfis at savagexi.com>
- * build/msvc80/geos.sln, build/msvc80/geos_python,
+ * [r2010] build/msvc80/geos.sln, build/msvc80/geos_python,
build/msvc80/geos_ruby/geos_ruby.vcproj: New VC++ project for the
python SWIG bindings.
-2007-08-29 01:29 csavage
+2007-08-29 01:29 Charlie Savage <cfis at savagexi.com>
- * build/msvc80/geos_ruby/geos_ruby.vcproj, swig/geos.i.in,
+ * [r2009] build/msvc80/geos_ruby/geos_ruby.vcproj, swig/geos.i.in,
swig/python/python.i, swig/ruby/geos_wrap.cxx, swig/ruby/ruby.i:
Ruby SWIG bindings - mapped eql? to == so that you can do point
== point2 in ruby. Removed a hard-coded path from VC++ project.
Updated out-of-date copyright notices for no particularly good
reason.
-2007-08-28 21:29 csavage
+2007-08-28 21:29 Charlie Savage <cfis at savagexi.com>
- * build/msvc80: Added release as an ignored directory for VC++,
- similar to the debug directory.
+ * [r2008] build/msvc80: Added release as an ignored directory for
+ VC++, similar to the debug directory.
-2007-08-28 21:28 csavage
+2007-08-28 21:28 Charlie Savage <cfis at savagexi.com>
- * build/msvc80/geos_ruby: Added new ruby VC++ project to solution
- file.
+ * [r2007] build/msvc80/geos_ruby: Added new ruby VC++ project to
+ solution file.
-2007-08-28 21:27 csavage
+2007-08-28 21:27 Charlie Savage <cfis at savagexi.com>
- * capi/geos_c.h.in: Fixed c api include for VC++ - it should be
- #include <geos/version.h> instead of #include <version.h>.
+ * [r2006] capi/geos_c.h.in: Fixed c api include for VC++ - it
+ should be #include <geos/version.h> instead of #include
+ <version.h>.
- * build/msvc80/geos.sln: Added new ruby VC++ project to solution
- file.
+ * [r2005] build/msvc80/geos.sln: Added new ruby VC++ project to
+ solution file.
-2007-08-28 21:26 csavage
+2007-08-28 21:26 Charlie Savage <cfis at savagexi.com>
- * build/msvc80/geos_c_dll/geos_c_dll.vcproj: Follow lead of
+ * [r2004] build/msvc80/geos_c_dll/geos_c_dll.vcproj: Follow lead of
geos_lib project - copy geos/geos_c.h.in to geos/geos_c.h when
building with VC++.
-2007-08-28 21:25 csavage
+2007-08-28 21:25 Charlie Savage <cfis at savagexi.com>
- * build/msvc80/geos_ruby, build/msvc80/geos_ruby/geos_ruby.vcproj:
- Added new vc++ project for building ruby bindings. Its not
- perfect since it hard-codes the path to Ruby, but its enough to
- get one started.
+ * [r2003] build/msvc80/geos_ruby,
+ build/msvc80/geos_ruby/geos_ruby.vcproj: Added new vc++ project
+ for building ruby bindings. Its not perfect since it hard-codes
+ the path to Ruby, but its enough to get one started.
-2007-08-28 21:22 csavage
+2007-08-28 21:22 Charlie Savage <cfis at savagexi.com>
- * swig/python/geos.py, swig/python/geos_wrap.cxx,
+ * [r2002] swig/python/geos.py, swig/python/geos_wrap.cxx,
swig/ruby/geos_wrap.cxx: Updated SWIG wrappers based on changed
interface file. Also generated with SWIG 1.3.31
-2007-08-28 20:42 csavage
+2007-08-28 20:42 Charlie Savage <cfis at savagexi.com>
- * swig/ruby/test/geos_tests.rb, swig/ruby/test/test_buffer.rb,
+ * [r2001] swig/ruby/test/geos_tests.rb,
+ swig/ruby/test/test_buffer.rb,
swig/ruby/test/test_combinations.rb,
swig/ruby/test/test_coordinate_sequence.rb,
swig/ruby/test/test_envelope.rb, swig/ruby/test/test_geometry.rb,
@@ -5565,62 +5715,63 @@
swig/ruby/test/test_version.rb: SWIG bindings - updated Ruby
tests based on name changes.
-2007-08-28 20:41 csavage
+2007-08-28 20:41 Charlie Savage <cfis at savagexi.com>
- * swig/ruby/ruby.i: Updated Ruby swig bindings to more closely
- match Ruby style names. So eql? instead of equals, dimensions
- instead of get_dimensions, etc.
+ * [r2000] swig/ruby/ruby.i: Updated Ruby swig bindings to more
+ closely match Ruby style names. So eql? instead of equals,
+ dimensions instead of get_dimensions, etc.
-2007-08-28 20:40 csavage
+2007-08-28 20:40 Charlie Savage <cfis at savagexi.com>
- * swig/geos.i.in: Exposed Geometry::Clone method in SWIG bindings.
- Added check for NULL string in geomFromWKT wrapper.
+ * [r1999] swig/geos.i.in: Exposed Geometry::Clone method in SWIG
+ bindings. Added check for NULL string in geomFromWKT wrapper.
-2007-08-23 20:35 pramsey
+2007-08-23 20:35 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/operation/buffer/BufferBuilder.cpp,
+ * [r1998] source/operation/buffer/BufferBuilder.cpp,
source/operation/buffer/OffsetCurveSetBuilder.cpp,
source/operation/buffer/OffsetCurveVertexList.h: Memory leak
patches from Robert Coup
-2007-08-22 23:45 mloskot
+2007-08-22 23:45 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/io/ByteOrderDataInStream.inl,
+ * [r1997] source/headers/geos/io/ByteOrderDataInStream.inl,
source/operation/overlay/ElevationMatrix.cpp,
source/operation/polygonize/Polygonizer.cpp: Cleaned compilation
warnings from VC++.
-2007-06-11 07:43 mloskot
+2007-06-11 07:43 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, source/operation/IsSimpleOp.cpp: Replaced
+ * [r1996] ChangeLog, source/operation/IsSimpleOp.cpp: Replaced
post-increment operators with pre-increment operators where
standard iterators are incremented in loops. NOTE: Prefer
pre-incr. over post-inc. when working with standard iterators.
-2007-06-11 07:39 mloskot
+2007-06-11 07:39 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/Makefile.am, tests/unit/operation/IsSimpleOpTest.cpp:
- Added unit test for geos::operation::IsSimpleOp class.
+ * [r1995] tests/unit/Makefile.am,
+ tests/unit/operation/IsSimpleOpTest.cpp: Added unit test for
+ geos::operation::IsSimpleOp class.
-2007-06-10 13:03 mloskot
+2007-06-10 13:03 Mateusz Loskot <mateusz at loskot.net>
- * ., ChangeLog, tests/unit/Makefile.am: Updated
+ * [r1994] ., ChangeLog, tests/unit/Makefile.am: Updated
tests/unit/Makefile.am with new files.
-2007-06-10 11:53 mloskot
+2007-06-10 11:53 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, build/msvc80/geos.sln,
+ * [r1993] ChangeLog, build/msvc80/geos.sln,
tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp,
tests/unit/algorithm/ConvexHullTest.cpp: Added unit test for
geos::algorithm::CGAlgorithms::computeOrientation() function.
-2007-06-10 11:29 mloskot
+2007-06-10 11:29 Mateusz Loskot <mateusz at loskot.net>
- * ., capi, source, source/geom, source/geom/util, source/geomgraph,
- source/geomgraph/index, source/index/bintree, source/index/chain,
- source/index/quadtree, source/index/strtree,
+ * [r1992] ., capi, source, source/geom, source/geom/util,
+ source/geomgraph, source/geomgraph/index, source/index/bintree,
+ source/index/chain, source/index/quadtree, source/index/strtree,
source/index/sweepline, source/io, source/noding,
source/noding/snapround, source/operation,
source/operation/buffer, source/operation/distance,
@@ -5632,38 +5783,38 @@
svn:ignore property for the whole tree adding VC++ and Windows
specific patterns.
-2007-06-10 11:18 mloskot
+2007-06-10 11:18 Mateusz Loskot <mateusz at loskot.net>
+ * [r1991] ChangeLog, build/msvc80/geos_unit/geos_unit.vcproj,
tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp: Added unit test
for CGAlgorithms::isCCW() function.
-2007-06-10 11:08 mloskot
+2007-06-10 11:08 Mateusz Loskot <mateusz at loskot.net>
+ * [r1990] tests/unit/algorithm/ConvexHullTest.cpp,
tests/unit/geom/LineStringTest.cpp: Added unit test for
geos::algorithm::ConvexHull.
-2007-06-10 11:03 mloskot
+2007-06-10 11:03 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/utility.h: Added custom operators for static and
- dynamic casts of pointers wrapped with std::auto_ptr<T> type.
+ * [r1989] tests/unit/utility.h: Added custom operators for static
+ and dynamic casts of pointers wrapped with std::auto_ptr<T> type.
-2007-06-08 17:13 mloskot
+2007-06-08 17:13 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp: Identified
- test case failing because of geos::index::strtree::yComparator()
- instability.
+ * [r1988] tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp:
+ Identified test case failing because of
+ geos::index::strtree::yComparator() instability.
-2007-06-08 17:10 mloskot
+2007-06-08 17:10 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, source/index/strtree/STRtree.cpp: Analysis of
+ * [r1987] ChangeLog, source/index/strtree/STRtree.cpp: Analysis of
instability of the yComparator, there are some new important
questions to answer.
-2007-06-08 15:27 mloskot
+2007-06-08 15:27 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, build/msvc80/geos_lib/geos_lib.vcproj,
+ * [r1986] ChangeLog, build/msvc80/geos_lib/geos_lib.vcproj,
source/algorithm/CGAlgorithms.cpp,
source/algorithm/CentroidArea.cpp,
source/algorithm/CentroidLine.cpp,
@@ -5691,28 +5842,28 @@
signed/unsigned types mixtures, got rid from annoying compiler
warnings.
-2007-06-08 14:50 mloskot
+2007-06-08 14:50 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog: Applied Konstantin Baumann's suggestion about
+ * [r1985] ChangeLog: Applied Konstantin Baumann's suggestion about
including version.h in C API header for Visual C++.
- * capi/geos_c.h.in: Applied Konstantin Baumann's suggestion about
- including version.h in C API header for Visual C++.
+ * [r1984] capi/geos_c.h.in: Applied Konstantin Baumann's suggestion
+ about including version.h in C API header for Visual C++.
-2007-06-01 13:53 mloskot
+2007-06-01 13:53 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, build/bjam, build/bjam/Jamroot, build/bjam/geos,
- build/bjam/geos/Jamfile, build/bjam/geos_c,
+ * [r1983] ChangeLog, build/bjam, build/bjam/Jamroot,
+ build/bjam/geos, build/bjam/geos/Jamfile, build/bjam/geos_c,
build/bjam/geos_c/Jamfile, build/bjam/geos_unit,
build/bjam/geos_unit/Jamfile: Added Boost.Build configuration for
GEOS (experimental). The idea is to enable users to build GEOS
with bjam tool from Boost.Build package.
-2007-06-01 13:43 mloskot
+2007-06-01 13:43 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/platform.h.vc,
+ * [r1982] source/headers/geos/platform.h.vc,
source/headers/geos/version.h.vc,
tests/unit/operation/distance/DistanceOpTest.cpp,
tests/unit/operation/overlay/FuzzyPointLocatorTest.cpp,
@@ -5720,51 +5871,53 @@
tests/unit/operation/overlay/OverlayResultValidatorTest.cpp: Set
missing svn:keywords property.
-2007-06-01 13:06 mloskot
+2007-06-01 13:06 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, build/msvc80/geos_lib/geos_lib.vcproj: Applied patch
- with pre-build events generating platform.h and version.h
+ * [r1981] ChangeLog, build/msvc80/geos_lib/geos_lib.vcproj: Applied
+ patch with pre-build events generating platform.h and version.h
headers. Thanks to Konstantin Baumann for this patch.
-2007-05-06 02:42 mloskot
+2007-05-06 02:42 Mateusz Loskot <mateusz at loskot.net>
- * build/msvc80, build/msvc80/geos_c_dll, build/msvc80/geos_lib,
- build/msvc80/geos_unit: Updated svn:ignore property for
- build\msvc80.
+ * [r1980] build/msvc80, build/msvc80/geos_c_dll,
+ build/msvc80/geos_lib, build/msvc80/geos_unit: Updated svn:ignore
+ property for build\msvc80.
-2007-05-06 02:40 mloskot
+2007-05-06 02:40 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, source/headers/geos/version.h.vc: Added
+ * [r1979] ChangeLog, source/headers/geos/version.h.vc: Added
source/headers/geos/version.h.vc file for Visual C++ compiler.
-2007-04-22 04:44 mloskot
+2007-04-22 04:44 Mateusz Loskot <mateusz at loskot.net>
- * ., ChangeLog, capi, source/geom/CoordinateArraySequence.cpp,
- swig, tests/unit/capi/GEOSCoordSeqTest.cpp: Added assertion
- validating ordinateIndex in setOrdinate() function. Extended
+ * [r1978] ., ChangeLog, capi,
+ source/geom/CoordinateArraySequence.cpp, swig,
+ tests/unit/capi/GEOSCoordSeqTest.cpp: Added assertion validating
+ ordinateIndex in setOrdinate() function. Extended
GEOSCoordSeqTest with swapped and non-swapped calls of
coordiantes assignment functions.
-2007-04-15 18:02 mloskot
+2007-04-15 18:02 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, autogen.sh: Added detection of glibtoolize under Mac
- OS X.
+ * [r1977] ChangeLog, autogen.sh: Added detection of glibtoolize
+ under Mac OS X.
-2007-03-05 09:58 strk
+2007-03-05 09:58 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/xmltester/Makefile.am,
+ * [r1976] ChangeLog, tests/xmltester/Makefile.am,
tests/xmltester/hole_from_shell.xml,
tests/xmltester/hole_red.xml: Add new testcases by Carl Anderson
-2007-02-26 10:46 strk
+2007-02-26 10:46 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/inlines.cpp: Patch by Tom Elwertowski:
+ * [r1975] ChangeLog, source/inlines.cpp: Patch by Tom Elwertowski:
* source/inlines.cpp: fix for MingW32 builds.
-2007-02-21 10:14 strk
+2007-02-21 10:14 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/operation/buffer/SubgraphDepthLocater.cpp:
- Patch by Carl Anderson:
+ * [r1974] ChangeLog,
+ source/operation/buffer/SubgraphDepthLocater.cpp: Patch by Carl
+ Anderson:
* source/operation/buffer/SubgraphDepthLocater.cpp
(findStabbedSegments):
@@ -5773,24 +5926,25 @@
Fixes badguy3.xml
-2007-02-21 10:12 strk
+2007-02-21 10:12 Sandro Santilli <strk at keybit.net>
+ * [r1973] ChangeLog, tests/xmltester/Makefile.am,
tests/xmltester/badguy3.xml: * tests/xmltester/: Makefile.am,
badguy3.xml:
Added simplified version of nasty buffer bug test.
-2007-02-08 23:33 strk
+2007-02-08 23:33 Sandro Santilli <strk at keybit.net>
- * ChangeLog, configure.in: Patch by Mark Cave-Ayland:
+ * [r1972] ChangeLog, configure.in: Patch by Mark Cave-Ayland:
* configure.in: Allow configure to continue with use_python
set to false if a python binary is not found, as per
http://sources.redhat.com/automake/automake.html#Python.
-2007-02-07 00:34 strk
+2007-02-07 00:34 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/index/strtree/AbstractNode.h,
+ * [r1971] ChangeLog,
+ source/headers/geos/index/strtree/AbstractNode.h,
source/headers/geos/index/strtree/AbstractSTRtree.h,
source/headers/geos/index/strtree/Boundable.h,
source/headers/geos/index/strtree/ItemBoundable.h,
@@ -5808,16 +5962,18 @@
operator for sorting child boundables in STRtree, this
fixes the heisenbug when building with inlines disabled.
-2007-02-06 02:05 strk
+2007-02-06 02:05 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp:
+ * [r1970] ChangeLog,
+ tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp: *
Expect result of POLYGON simplification to always be
a polygon, even if collapsed to the empty geom.
-2007-02-06 01:57 strk
+2007-02-06 01:57 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/operation/buffer/BufferBuilder.h,
+ * [r1969] ChangeLog,
+ source/headers/geos/operation/buffer/BufferBuilder.h,
source/headers/geos/operation/buffer/BufferOp.h,
source/operation/buffer/BufferOp.cpp: *
@@ -5826,27 +5982,28 @@
Fixed buffer operation to always return polygonal
geometry
-2007-02-03 02:18 pramsey
+2007-02-03 02:18 Paul Ramsey <pramsey at cleverelephant.ca>
- * ChangeLog, configure.in: 3.0.0rc4 tagging
+ * [r1967] ChangeLog, configure.in: 3.0.0rc4 tagging
-2007-02-01 11:11 strk
+2007-02-01 11:11 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/operation/buffer/BufferOp.h,
+ * [r1966] ChangeLog,
+ source/headers/geos/operation/buffer/BufferOp.h,
operation::buffer::BufferOp: set MAX_PRECISION_DIGITS
so to match JTS.
-2007-01-26 01:19 strk
+2007-01-26 01:19 Sandro Santilli <strk at keybit.net>
+ * [r1965] ChangeLog, tests/xmltester/Makefile.am,
tests/xmltester/stmlf-cases-20070119.xml: * tests/xmltester/:
Makefile.am, stmlf-cases-20070119.xml:
New overlay test.
-2007-01-26 00:57 strk
+2007-01-26 00:57 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/operation/buffer/BufferBuilder.cpp,
+ * [r1964] ChangeLog, source/operation/buffer/BufferBuilder.cpp,
tests/xmltester/XMLTester.cpp: * tests/xmltester/XMLTester.cpp:
improved buffer
result validator.
@@ -5854,34 +6011,34 @@
remove repeated points from noded SegmentStrings, skip collapsed
edges.
-2007-01-17 11:59 strk
+2007-01-17 11:59 Sandro Santilli <strk at keybit.net>
+ * [r1963] ChangeLog, tests/xmltester/Makefile.am,
tests/xmltester/heisenbugs.xml: New testcase for bug fixed by
previous commit.
-2007-01-17 01:05 strk
+2007-01-17 01:05 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/index/strtree/STRtree.cpp: *
+ * [r1962] ChangeLog, source/index/strtree/STRtree.cpp: *
source/index/strtree/STRtree.cpp (yComparator):
Use static_cast<> and make code more readable.
A side effect seems to be fixing a segfault :!
-2007-01-17 00:45 strk
+2007-01-17 00:45 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/index/strtree/STRtree.h: *
+ * [r1961] ChangeLog, source/headers/geos/index/strtree/STRtree.h: *
source/headers/geos/index/strtree/STRtree.h (centreY):
const-corrected.
-2007-01-16 14:12 strk
+2007-01-16 14:12 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/xmltester/XMLTester.cpp,
+ * [r1960] ChangeLog, tests/xmltester/XMLTester.cpp,
tests/xmltester/XMLTester.h: * tests/xmltester/XMLTester.cpp:
don't include catch-all headers.
-2007-01-09 17:34 strk
+2007-01-09 17:34 Sandro Santilli <strk at keybit.net>
- * ChangeLog,
+ * [r1959] ChangeLog,
source/headers/geos/operation/buffer/OffsetCurveBuilder.h,
source/operation/buffer/Makefile.am,
source/operation/buffer/OffsetCurveBuilder.cpp,
@@ -5902,9 +6059,9 @@
to be smaller then 1/1000 of expected geometry
area.
-2007-01-09 15:08 strk
+2007-01-09 15:08 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/geom/CoordinateArraySequence.cpp,
+ * [r1958] ChangeLog, source/geom/CoordinateArraySequence.cpp,
source/headers/geos/geom/CoordinateArraySequence.h,
source/headers/geos/geom/CoordinateSequence.h: *
@@ -5915,83 +6072,85 @@
(single virtual call vs. multiple); added front() and
back() methods.
-2007-01-09 10:27 strk
+2007-01-09 10:27 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/xmltester/XMLTester.cpp: *
+ * [r1957] ChangeLog, tests/xmltester/XMLTester.cpp: *
tests/xmltester/XMLTester.cpp: add areatest to buffer test
handler.
-2007-01-05 01:01 strk
+2007-01-05 01:01 Sandro Santilli <strk at keybit.net>
- * ChangeLog, configure.in: * configure.in: prepared for version to
- 3.0.0rc4,
+ * [r1956] ChangeLog, configure.in: * configure.in: prepared for
+ version to 3.0.0rc4,
fixed swig python errors as suggested by hint
(AM_PATH_PYTHON).
-2007-01-04 22:43 strk
+2007-01-04 22:43 Sandro Santilli <strk at keybit.net>
- * ChangeLog, configure.in, swig/geos.i, swig/geos.i.in: *
+ * [r1955] ChangeLog, configure.in, swig/geos.i, swig/geos.i.in: *
configure.in, swig/geos.i.in, swig/geos.i:
geos.i generated at configure time from geos.i.in
(so we don't have to manually update versions there).
-2007-01-04 22:38 strk
+2007-01-04 22:38 Sandro Santilli <strk at keybit.net>
- * ChangeLog, swig/geos.i: Patch by dev-zero at gentoo dot org:
+ * [r1954] ChangeLog, swig/geos.i: Patch by dev-zero at gentoo dot
+ org:
* swig/geos.i: use unsigned int when CAPI signatures
expect unsigned int (not size_t).
-2007-01-03 20:11 strk
+2007-01-03 20:11 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/xmltester/Makefile.am, tests/xmltester/fme.xml:
- * tests/xmltester/: fme.xml, Makefile.am: added buffer testcase.
+ * [r1953] ChangeLog, tests/xmltester/Makefile.am,
+ tests/xmltester/fme.xml: * tests/xmltester/: fme.xml,
+ Makefile.am: added buffer testcase.
-2007-01-03 20:06 strk
+2007-01-03 20:06 Sandro Santilli <strk at keybit.net>
+ * [r1952] ChangeLog, tests/xmltester/XMLTester.cpp: *
tests/xmltester/XMLTester.cpp: use a tolerance of 10E-6
for buffer validation (~10cm at worst when using latlong
projections); create sql tables with oid to work around a
bug in qgis 0.7.4.
-2007-01-03 19:18 strk
+2007-01-03 19:18 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/algorithm/HCoordinate.cpp, source/inlines.cpp:
- Applied patch by Mark Cave-Ayland
+ * [r1951] ChangeLog, source/algorithm/HCoordinate.cpp,
+ source/inlines.cpp: Applied patch by Mark Cave-Ayland
<mark.cave-ayland at ilande.co.uk>:
* source/inlines.cpp, source/algorithm/HCoordinate.cpp:
Fixes for MingW builds. See geos-devel/2007-January/002766.html.
-2007-01-03 14:56 strk
+2007-01-03 14:56 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/operation/buffer/BufferOp.cpp: *
+ * [r1950] ChangeLog, source/operation/buffer/BufferOp.cpp: *
source/operation/buffer/BufferOp.cpp (bufferReducedPrecision):
Fixed computation of reduced PrecisionModel scale.
-2006-12-18 20:04 strk
+2006-12-18 20:04 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/xmltester/robustness.xml: *
+ * [r1949] ChangeLog, tests/xmltester/robustness.xml: *
tests/xmltester/robustness.xml: added
testcase reported to fail with 2.2.3 on
postgis-users/2006-November/014013.html.
-2006-12-18 18:44 strk
+2006-12-18 18:44 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/geom/BinaryOp.h,
+ * [r1948] ChangeLog, source/headers/geos/geom/BinaryOp.h,
source/headers/geos/precision/GeometrySnapper.h,
source/precision/GeometrySnapper.cpp: Geometry snapping synced
with JTS.
-2006-12-18 14:27 strk
+2006-12-18 14:27 Sandro Santilli <strk at keybit.net>
- * ChangeLog, HOWTO_RELEASE: * HOWTO_RELEASE: add ChangeLog's
- release mark step.
+ * [r1947] ChangeLog, HOWTO_RELEASE: * HOWTO_RELEASE: add
+ ChangeLog's release mark step.
-2006-12-18 14:19 strk
+2006-12-18 14:19 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/precision/GeometrySnapper.cpp,
+ * [r1946] ChangeLog, source/precision/GeometrySnapper.cpp,
tests/xmltester/TestRobustOverlayFixed.xml: *
source/precision/GeometrySnapper.cpp (computeSnapTolerance):
@@ -5999,23 +6158,23 @@
* tests/xmltester/: Makefile.am, TestRobustOverlayFixed.xml:
new test for fixed precision snapping.
-2006-12-15 10:50 strk
+2006-12-15 10:50 Sandro Santilli <strk at keybit.net>
- * ChangeLog: release 3.0.0rc3 marked
+ * [r1945] ChangeLog: release 3.0.0rc3 marked
-2006-12-14 19:12 pramsey
+2006-12-14 19:12 Paul Ramsey <pramsey at cleverelephant.ca>
- * configure.in: bumped version numbers for 3.0.0rc3
+ * [r1943] configure.in: bumped version numbers for 3.0.0rc3
-2006-12-13 11:05 mloskot
+2006-12-13 11:05 Mateusz Loskot <mateusz at loskot.net>
+ * [r1942] ChangeLog, build/msvc80/geos_lib/geos_lib.vcproj,
source/Makefile.vc: Updated makefile and project files for Visual
C++.
-2006-12-13 10:55 strk
+2006-12-13 10:55 Sandro Santilli <strk at keybit.net>
- * ChangeLog,
+ * [r1941] ChangeLog,
source/headers/geos/operation/overlay/FuzzyPointLocator.h,
source/headers/geos/operation/overlay/OffsetPointGenerator.h,
source/headers/geos/operation/overlay/OverlayResultValidator.h,
@@ -6024,18 +6183,20 @@
source/operation/overlay/OverlayResultValidator.cpp: Updated port
information.
-2006-12-13 10:51 strk
+2006-12-13 10:51 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/precision/GeometrySnapper.h,
+ * [r1940] ChangeLog,
+ source/headers/geos/precision/GeometrySnapper.h,
source/headers/geos/precision/LineStringSnapper.h,
source/precision/LineStringSnapper.cpp: *
precision::GeometrySnapper, precision::LineStringSnapper:
Updated port information.
-2006-12-11 17:42 strk
+2006-12-11 17:42 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/geomgraph/EdgeNodingValidator.h,
+ * [r1939] ChangeLog,
+ source/headers/geos/geomgraph/EdgeNodingValidator.h,
source/headers/geos/noding/FastNodingValidator.h,
source/headers/geos/noding/Makefile.am,
source/headers/geos/noding/SegmentIntersector.h,
@@ -6058,9 +6219,9 @@
* source/headers/geos/geomgraph/EdgeNodingValidator.h:
use a FastNodingValidator rather then a simple NodingValidator.
-2006-12-07 10:45 strk
+2006-12-07 10:45 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/algorithm/LineIntersector.cpp,
+ * [r1938] ChangeLog, source/algorithm/LineIntersector.cpp,
source/headers/geos/algorithm/CentralEndpointIntersector.h,
source/headers/geos/algorithm/LineIntersector.h,
source/headers/geos/algorithm/Makefile.am: *
@@ -6069,37 +6230,37 @@
* algorithm::LineIntersector: robustness improvements
from JTS-1.8.
-2006-12-05 11:22 mloskot
+2006-12-05 11:22 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/capi/GEOSCoordSeqTest.cpp,
+ * [r1937] tests/unit/capi/GEOSCoordSeqTest.cpp,
tests/unit/capi/GEOSSimplifyTest.cpp: Fixed indentantion in
tests/unit/capi.
-2006-12-05 11:10 mloskot
+2006-12-05 11:10 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog: Fixed typos in changelog.
+ * [r1936] ChangeLog: Fixed typos in changelog.
-2006-12-05 11:05 mloskot
+2006-12-05 11:05 Mateusz Loskot <mateusz at loskot.net>
+ * [r1935] tests/unit/capi/GEOSCoordSeqTest.cpp,
tests/unit/capi/GEOSSimplifyTest.cpp: Set svn:keyword property on
CAPI tests.
-2006-12-05 11:02 mloskot
+2006-12-05 11:02 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, tests/unit/capi/GEOSCoordSeqTest.cpp,
+ * [r1934] ChangeLog, tests/unit/capi/GEOSCoordSeqTest.cpp,
tests/unit/capi/GEOSSimplifyTest.cpp,
tests/unit/util/UniqueCoordinateArrayFilterTest.cpp: Purifying
CAPI unit tests.
-2006-12-05 10:59 mloskot
+2006-12-05 10:59 Mateusz Loskot <mateusz at loskot.net>
- * build/msvc80/geos_unit/geos_unit.vcproj: Added CAPI tests to VC++
- project.
+ * [r1933] build/msvc80/geos_unit/geos_unit.vcproj: Added CAPI tests
+ to VC++ project.
-2006-12-05 10:42 strk
+2006-12-05 10:42 Sandro Santilli <strk at keybit.net>
+ * [r1932] ChangeLog, source/headers/geos/geom/BinaryOp.h,
source/operation/overlay/OverlayOp.cpp: *
source/operation/overlay/OverlayOp.cpp: Use EdgeNodingValidator
instead of OverlayResultValidator (faster and more effective).
@@ -6108,30 +6269,32 @@
* source/headers/geos/geom/BinaryOp.h: be quiet if not in DEBUG
mode.
-2006-12-05 09:59 strk
+2006-12-05 09:59 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/noding/NodingValidator.h,
+ * [r1931] ChangeLog, source/headers/geos/noding/NodingValidator.h,
source/noding/NodingValidator.cpp: * noding::NodingValidator.h:
throw TopologyException
rather then a generic GEOSException.
-2006-12-04 12:41 strk
+2006-12-04 12:41 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/geomgraph/EdgeNodingValidator.h: *
+ * [r1930] ChangeLog,
+ source/headers/geos/geomgraph/EdgeNodingValidator.h: *
fix members initialization order.
-2006-12-04 11:38 strk
+2006-12-04 11:38 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/geomgraph/EdgeNodingValidator.cpp,
+ * [r1929] ChangeLog, source/geomgraph/EdgeNodingValidator.cpp,
geomgraph::EdgeNodingValidator: minor cleanup
to use references args instead of pointers for
method that doesn't handle NULLs anyway.
-2006-12-04 10:31 strk
+2006-12-04 10:31 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/simplify/DouglasPeuckerLineSimplifier.cpp,
+ * [r1928] ChangeLog,
+ source/simplify/DouglasPeuckerLineSimplifier.cpp,
tests/unit/Makefile.am, tests/unit/capi/GEOSCoordSeq.cpp,
tests/unit/capi/GEOSSimplifyTest.cpp: * tests/unit/capi/:
@@ -6141,79 +6304,82 @@
* source/simplify/DouglasPeuckerLineSimplifier.cpp (simplify):
don't try to simplify empty coordinate lists. Fixes bug #134.
-2006-12-04 10:14 strk
+2006-12-04 10:14 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/unit/capi/GEOSCoordSeq.cpp: Other tests using
- setOrdinate instead of set{X,Y,Z}
+ * [r1927] ChangeLog, tests/unit/capi/GEOSCoordSeq.cpp: Other tests
+ using setOrdinate instead of set{X,Y,Z}
-2006-12-04 10:12 strk
+2006-12-04 10:12 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/geom/CoordinateArraySequence.cpp: *
+ * [r1926] ChangeLog, source/geom/CoordinateArraySequence.cpp: *
source/geom/CoordinateArraySequence.cpp (setOrdinate): fix bug
#133.
-2006-12-04 10:00 strk
+2006-12-04 10:00 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/unit/capi/GEOSCoordSeq.cpp: *
+ * [r1925] ChangeLog, tests/unit/capi/GEOSCoordSeq.cpp: *
tests/unit/capi/GEOSCoordSeq.cpp: add test for bug #133
(failing).
-2006-12-04 09:57 strk
+2006-12-04 09:57 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/unit/geom/CoordinateArraySequenceTest.cpp: *
+ * [r1924] ChangeLog,
+ tests/unit/geom/CoordinateArraySequenceTest.cpp: *
tests/unit/geom/CoordinateArraySequenceTest.cpp: added tests for
setOrdinate()
-2006-11-30 14:49 strk
+2006-11-30 14:49 Sandro Santilli <strk at keybit.net>
- * ChangeLog, capi/geos_c.cpp, tests/unit/Makefile.am,
+ * [r1923] ChangeLog, capi/geos_c.cpp, tests/unit/Makefile.am,
tests/unit/capi, tests/unit/capi/GEOSCoordSeq.cpp: * tests/unit/:
Makefile.am, capi/GEOSCoordSeq.cpp:
new experimental test for C-API GEOSCoordSeq.
* capi/geos_c.cpp (GEOSCoordSeq_create): removed
suspicious static cast.
-2006-11-28 19:13 mloskot
+2006-11-28 19:13 Mateusz Loskot <mateusz at loskot.net>
- * build, build/README, build/msvc80, build/msvc80/README,
+ * [r1922] build, build/README, build/msvc80, build/msvc80/README,
build/msvc80/geos.sln, build/msvc80/geos_c_dll,
build/msvc80/geos_c_dll/geos_c_dll.vcproj, build/msvc80/geos_lib,
build/msvc80/geos_lib/geos_lib.vcproj, build/msvc80/geos_unit,
build/msvc80/geos_unit/geos_unit.vcproj: Added Visual C++ 2005
project files.
-2006-11-23 20:17 strk
+2006-11-23 20:17 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/geom/Point.cpp: * source/geom/Point.cpp
+ * [r1921] ChangeLog, source/geom/Point.cpp: * source/geom/Point.cpp
(equalsExact): don't segfault on empty points. Fixes bug #132.
-2006-11-23 12:25 strk
+2006-11-23 12:25 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/stmlf-cases-20061020.xml: Added short descripion
- of testcases provenience
+ * [r1920] tests/xmltester/stmlf-cases-20061020.xml: Added short
+ descripion of testcases provenience
-2006-11-22 20:29 strk
+2006-11-22 20:29 Sandro Santilli <strk at keybit.net>
+ * [r1919] ChangeLog, tests/xmltester/Makefile.am,
tests/xmltester/stmlf-cases-20061020.xml: * tests/xmltester/:
stmlf-cases-20061020.xml, Makefile.am: add more robustness
testcases.
-2006-11-22 12:26 strk
+2006-11-22 12:26 Sandro Santilli <strk at keybit.net>
- * ChangeLog, autogen.sh: Patch by dron at ak4719.spb.edu:
+ * [r1918] ChangeLog, autogen.sh: Patch by dron at ak4719.spb.edu:
* autogen.sh: call 'autoheader' after 'aclocal'.
Fixes bug #131
-2006-11-18 15:30 mloskot
+2006-11-18 15:30 Mateusz Loskot <mateusz at loskot.net>
- * source/Makefile.vc: Fixed path to geos_c.h in source/makefile.vc.
+ * [r1917] source/Makefile.vc: Fixed path to geos_c.h in
+ source/makefile.vc.
-2006-11-15 18:26 strk
+2006-11-15 18:26 Sandro Santilli <strk at keybit.net>
- * ChangeLog, capi/Makefile.am, capi/geos_c.h.vc.in, configure.in,
- source/Makefile.vc, source/headers/geos/Makefile.am,
+ * [r1916] ChangeLog, capi/Makefile.am, capi/geos_c.h.vc.in,
+ configure.in, source/Makefile.vc,
+ source/headers/geos/Makefile.am,
source/headers/geos/version.h.vc: * configure.in: don't generate
geos_c.h.vc
* source/Makefile.vc: don't generate geos_c.h and version.h
@@ -6222,61 +6388,61 @@
* source/headers/geos/Makefile.am: distribute version.h
* capi/Makefile.am: distribute geos_c.h
-2006-11-15 14:42 strk
+2006-11-15 14:42 Sandro Santilli <strk at keybit.net>
- * ChangeLog, capi/geos_c.h.in: * capi/geos_c.h.in: hopefully fixed
- GEOS_DLL use.
+ * [r1915] ChangeLog, capi/geos_c.h.in: * capi/geos_c.h.in:
+ hopefully fixed GEOS_DLL use.
-2006-11-15 11:28 strk
+2006-11-15 11:28 Sandro Santilli <strk at keybit.net>
- * ChangeLog, capi/geos_c.cpp: * capi/geos_c.cpp
+ * [r1914] ChangeLog, capi/geos_c.cpp: * capi/geos_c.cpp
(GEOSGeom_getDimensions): Fix a segfault on empty geometry input
(fix bug #126).
-2006-11-11 05:32 pramsey
+2006-11-11 05:32 Paul Ramsey <pramsey at cleverelephant.ca>
- * capi/geos_c.h.vc.in: Retreived original .vc file and put in MACRO
- substitutions. Somehow GNU version replaced .vc version during
- file shuffles to get macros in.
+ * [r1913] capi/geos_c.h.vc.in: Retreived original .vc file and put
+ in MACRO substitutions. Somehow GNU version replaced .vc version
+ during file shuffles to get macros in.
-2006-11-10 18:24 strk
+2006-11-10 18:24 Sandro Santilli <strk at keybit.net>
- * ChangeLog: fixed timewarp
+ * [r1912] ChangeLog: fixed timewarp
-2006-11-10 17:56 pramsey
+2006-11-10 17:56 Paul Ramsey <pramsey at cleverelephant.ca>
- * ChangeLog: noted .vc change
+ * [r1911] ChangeLog: noted .vc change
-2006-11-10 17:55 pramsey
+2006-11-10 17:55 Paul Ramsey <pramsey at cleverelephant.ca>
- * capi/Makefile.am: Made sure geos_c.h.vc is part of 'make dist'
- since VC users won't have .configure
+ * [r1910] capi/Makefile.am: Made sure geos_c.h.vc is part of 'make
+ dist' since VC users won't have .configure
-2006-11-10 17:38 pramsey
+2006-11-10 17:38 Paul Ramsey <pramsey at cleverelephant.ca>
- * capi/Makefile.am, capi/geos_c.h.vc, capi/geos_c.h.vc.in: Added
- substitution strings to .in files for .vc generation.
+ * [r1909] capi/Makefile.am, capi/geos_c.h.vc, capi/geos_c.h.vc.in:
+ Added substitution strings to .in files for .vc generation.
-2006-11-10 17:35 pramsey
+2006-11-10 17:35 Paul Ramsey <pramsey at cleverelephant.ca>
- * configure.in: Changes for capi .vc generation
+ * [r1908] configure.in: Changes for capi .vc generation
-2006-11-10 14:50 hobu
+2006-11-10 14:50 Howard Butler <hobu.inc at gmail.com>
- * capi/geos_c.h.vc: update
+ * [r1907] capi/geos_c.h.vc: update
-2006-11-09 09:10 strk
+2006-11-09 09:10 Sandro Santilli <strk at keybit.net>
+ * [r1906] ChangeLog, tests/xmltester/XMLTester.cpp: *
test/xmltester/XMLTester.cpp: improved 'testarea' test.
-2006-11-08 11:54 strk
+2006-11-08 11:54 Sandro Santilli <strk at keybit.net>
- * ChangeLog: added 'release-separator' tag
+ * [r1905] ChangeLog: added 'release-separator' tag
-2006-11-08 11:51 strk
+2006-11-08 11:51 Sandro Santilli <strk at keybit.net>
+ * [r1904] ChangeLog, tests/xmltester/Makefile.am,
tests/xmltester/robustness.xml: * tests/xmltester/robustness.xml:
made test safe to
run by using the new 'areatest' operation; added
@@ -6284,79 +6450,81 @@
* tests/xmltester/Makefile.am: robustness.xml is now safe
to run, so run it on make check.
-2006-11-08 10:40 strk
+2006-11-08 10:40 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/geom/BinaryOp.h: *
+ * [r1903] ChangeLog, source/headers/geos/geom/BinaryOp.h: *
source/headers/geos/geom/BinaryOp.h: enable
COMMONBITS-removal heuristic so it is attempted
before geometry snapping.
-2006-11-05 20:34 strk
+2006-11-05 20:34 Sandro Santilli <strk at keybit.net>
- * ChangeLog, capi/Makefile.am: * capi/Makefile.am: distribute files
- needed for testing, proper cleanup (make distcheck works now)
+ * [r1900] ChangeLog, capi/Makefile.am: * capi/Makefile.am:
+ distribute files needed for testing, proper cleanup (make
+ distcheck works now)
-2006-11-05 00:24 csavage
+2006-11-05 00:24 Charlie Savage <cfis at savagexi.com>
- * swig/ruby/geos_wrap.cxx: Updated ruby swig wrapper for changes in
- header files.
+ * [r1899] swig/ruby/geos_wrap.cxx: Updated ruby swig wrapper for
+ changes in header files.
- * swig/python/geos_wrap.cxx: Updated python swig wrapper for
- changes in header files.
+ * [r1898] swig/python/geos_wrap.cxx: Updated python swig wrapper
+ for changes in header files.
-2006-11-05 00:23 csavage
+2006-11-05 00:23 Charlie Savage <cfis at savagexi.com>
- * swig/geos.i: Fixes for changes in header files.
+ * [r1897] swig/geos.i: Fixes for changes in header files.
-2006-11-03 12:35 strk
+2006-11-03 12:35 Sandro Santilli <strk at keybit.net>
- * capi/testrunner.sh: redirect 'diff' output to stderr
+ * [r1896] capi/testrunner.sh: redirect 'diff' output to stderr
-2006-11-03 10:54 strk
+2006-11-03 10:54 Sandro Santilli <strk at keybit.net>
- * ChangeLog, capi/testrunner.sh: hopefully fixed proper quoting
+ * [r1895] ChangeLog, capi/testrunner.sh: hopefully fixed proper
+ quoting
-2006-11-03 10:30 strk
+2006-11-03 10:30 Sandro Santilli <strk at keybit.net>
- * ChangeLog, capi/testrunner.sh: Report non-zero return from
- ./geostest run
+ * [r1894] ChangeLog, capi/testrunner.sh: Report non-zero return
+ from ./geostest run
-2006-11-02 10:08 strk
+2006-11-02 10:08 Sandro Santilli <strk at keybit.net>
+ * [r1893] ChangeLog, source/headers/geos/geom/BinaryOp.h: *
source/headers/geos/geom/BinaryOp.h: disable debugging output by
default.
-2006-11-02 10:02 strk
+2006-11-02 10:02 Sandro Santilli <strk at keybit.net>
- * ChangeLog, capi/geostest.c: * capi/geostest.c: updated to use the
- new GEOSGeometry typedef, so to build w/out warnings and fully
- respecting current const specification.
+ * [r1892] ChangeLog, capi/geostest.c: * capi/geostest.c: updated to
+ use the new GEOSGeometry typedef, so to build w/out warnings and
+ fully respecting current const specification.
-2006-11-02 09:48 strk
+2006-11-02 09:48 Sandro Santilli <strk at keybit.net>
- * ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in: * capi/geos_c.cpp,
- capi/geos_c.h.in: const-corrected and documented GEOSPolygonize
- function.
+ * [r1891] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in: *
+ capi/geos_c.cpp, capi/geos_c.h.in: const-corrected and documented
+ GEOSPolygonize function.
-2006-11-02 09:38 strk
+2006-11-02 09:38 Sandro Santilli <strk at keybit.net>
- * ChangeLog, capi/test.expected, capi/testrunner.sh: *
+ * [r1890] ChangeLog, capi/test.expected, capi/testrunner.sh: *
capi/test.expected: updated expected version
* capi/testrunner.sh: be happy with geostest running w/out
segfaulting, still run diff for reference.
-2006-11-02 09:33 strk
+2006-11-02 09:33 Sandro Santilli <strk at keybit.net>
- * ChangeLog, configure.in: * configure.in: updated versions to
- 3.0.0rc2 / CAPI-1.3.0
+ * [r1889] ChangeLog, configure.in: * configure.in: updated versions
+ to 3.0.0rc2 / CAPI-1.3.0
-2006-11-02 08:32 strk
+2006-11-02 08:32 Sandro Santilli <strk at keybit.net>
- * ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in: Patch by Markus
- Schaber <schabi at logix-tt.com>:
+ * [r1888] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in: Patch by
+ Markus Schaber <schabi at logix-tt.com>:
* capi/geos_c.h.in: add GEOSGeometry and GEOSCoordSequence
typedef, to unhide the pointer type and allow fine-grained
@@ -6365,27 +6533,28 @@
* capi/geos_c.cpp: define GEOSGeometry and GEOSCoordSequence
for cross-checking of types in header.
-2006-10-30 15:14 strk
+2006-10-30 15:14 Sandro Santilli <strk at keybit.net>
+ * [r1887] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in: Patch by
* capi/geos_c.cpp: more focused 'using' directives.
* capi/geos_c.h.in: let the enum visible by geos_c.cpp
now that there are no more name clashes.
-2006-10-30 13:20 strk
+2006-10-30 13:20 Sandro Santilli <strk at keybit.net>
- * capi/geos_c.cpp: removed useless GEOSGeomTypes define
+ * [r1886] capi/geos_c.cpp: removed useless GEOSGeomTypes define
-2006-10-30 13:00 strk
+2006-10-30 13:00 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/operation/overlay/OverlayOp.cpp: reduce default
- verbosity
+ * [r1885] ChangeLog, source/operation/overlay/OverlayOp.cpp: reduce
+ default verbosity
-2006-10-30 12:49 strk
+2006-10-30 12:49 Sandro Santilli <strk at keybit.net>
- * ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in: * capi/geos_c.cpp:
+ * [r1884] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in: *
+ capi/geos_c.cpp:
Remove a typedef which is also included via Header;
Use dynamic_cast instead of C cast in 2 cases to allow the RTTI
type check;
@@ -6398,16 +6567,17 @@
Added a comment explaining ou #ifndef magic;
Unified the two #ifndef into a single one.
-2006-10-30 10:29 strk
+2006-10-30 10:29 Sandro Santilli <strk at keybit.net>
- * ChangeLog, capi/Makefile.am, capi/test.expected,
+ * [r1883] ChangeLog, capi/Makefile.am, capi/test.expected,
capi/testrunner.sh: * capi/: test.expected, testrunner.sh,
Makefile.am: Added a run of ./geostest as part of 'make check'
-2006-10-30 10:15 strk
+2006-10-30 10:15 Sandro Santilli <strk at keybit.net>
- * ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in: Patch submitted by
- Markus Schaber <schabi at logix-tt.com> ( reviewed and fixed )
+ * [r1882] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in: Patch
+ submitted by Markus Schaber <schabi at logix-tt.com> ( reviewed and
+ fixed )
* capi/: geos_c.cpp, geos_c.h.in:
Changed the C-API implementation to actually include the header
@@ -6415,15 +6585,15 @@
declarations and implementation for consistency, fixed geos_c.cpp
accordingly (const-correctness, mainly).
-2006-10-30 09:49 strk
+2006-10-30 09:49 Sandro Santilli <strk at keybit.net>
- * ChangeLog, capi/geostest.c: * capi/geostest.c: added some checks
- of return from CAPI functions returning GEOSGeom (not all, just a
- few)
+ * [r1881] ChangeLog, capi/geostest.c: * capi/geostest.c: added some
+ checks of return from CAPI functions returning GEOSGeom (not all,
+ just a few)
-2006-10-27 11:54 strk
+2006-10-27 11:54 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/algorithm/InteriorPointLine.cpp,
+ * [r1880] ChangeLog, source/algorithm/InteriorPointLine.cpp,
source/headers/geos/algorithm/InteriorPointLine.h,
source/headers/geos/geom/Geometry.h,
@@ -6438,220 +6608,224 @@
then filter_rw, as it doesn't change the Geometry, propagated
change to internal interfaces (add methods)
-2006-10-26 09:22 strk
+2006-10-26 09:22 Sandro Santilli <strk at keybit.net>
- * ChangeLog, capi/geos_c.h.in: * capi/geos_c.h.in: reverted all
- changes of 'int' types
+ * [r1879] ChangeLog, capi/geos_c.h.in: * capi/geos_c.h.in: reverted
+ all changes of 'int' types
to 'size_t' types (the lib never changed, and still expects
ints)
-2006-10-24 16:54 strk
+2006-10-24 16:54 Sandro Santilli <strk at keybit.net>
+ * [r1878] ChangeLog, source/headers/geos/geom/BinaryOp.h: *
source/headers/geos/geom/BinaryOp.h: try original geoms first by
default.
-2006-10-24 16:53 strk
+2006-10-24 16:53 Sandro Santilli <strk at keybit.net>
- * ChangeLog,
+ * [r1877] ChangeLog,
source/operation/overlay/OverlayResultValidator.cpp: *
operation::overlay::OverlayResultValidator.cpp (isValid): run the
test even if inputs and output are not areal.
-2006-10-24 16:49 strk
+2006-10-24 16:49 Sandro Santilli <strk at keybit.net>
- * ChangeLog,
+ * [r1876] ChangeLog,
source/operation/overlay/FuzzyPointLocator.cpp: *
operation::overlay::FuzzyPointLocator: eliminate non-polygonal
components from consideration when testing the location of
points.
-2006-10-24 10:16 strk
+2006-10-24 10:16 Sandro Santilli <strk at keybit.net>
+ * [r1875] ChangeLog,
source/precision/GeometrySnapper.cpp: *
precision::GeometrySnapper: snapPrecisionFactor augmented from
10e-12 to 10e-10.
-2006-10-24 09:49 strk
+2006-10-24 09:49 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/precision/LineStringSnapper.h,
+ * [r1874] ChangeLog,
+ source/headers/geos/precision/LineStringSnapper.h,
precision::LineStringSnapper (findSegmentToSnap):
return the *closest* segment, don't snap if the closest
segment *intersects* the snap points, consider a distance
of exactly snapTolerance as non-tolerated (got in sync with JTS)
-2006-10-23 10:23 strk
+2006-10-23 10:23 Sandro Santilli <strk at keybit.net>
+ * [r1873] ChangeLog, source/headers/geos/geom/BinaryOp.h: *
source/headers/geos/geom/BinaryOp.h (SnapOp): document and add
optional CBR step (snap after applying common bits removal - this
is the default); (check_valid): add validity checker function.
-2006-10-20 11:18 strk
+2006-10-20 11:18 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/noding/SegmentString.h,
+ * [r1872] ChangeLog, source/headers/geos/noding/SegmentString.h,
source/noding/ScaledNoder.cpp, source/noding/SegmentString.cpp: *
noding::SegmentString: added notifyCoordinatesChange method.
* noding::ScaledNoder: notify possible coordinates change to
SegmentString after removing repeated points.
-2006-10-19 18:26 strk
+2006-10-19 18:26 Sandro Santilli <strk at keybit.net>
- * ChangeLog, configure.in: * configure.in: use 'expr' for
+ * [r1871] ChangeLog, configure.in: * configure.in: use 'expr' for
arithmetics (more portable)
-2006-10-18 19:21 mloskot
+2006-10-18 19:21 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, makefile.vc, source/Makefile.vc: Refactored Visual C++
- makefiles.
+ * [r1870] ChangeLog, makefile.vc, source/Makefile.vc: Refactored
+ Visual C++ makefiles.
-2006-10-18 17:53 mloskot
+2006-10-18 17:53 Mateusz Loskot <mateusz at loskot.net>
- * source/Makefile.vc, source/dirlist.mk: Updated source\makefile.vc
- and source\dirlist.mk files.
+ * [r1869] source/Makefile.vc, source/dirlist.mk: Updated
+ source\makefile.vc and source\dirlist.mk files.
- * makefile.vc: Added top-level makefile.vc.
+ * [r1868] makefile.vc: Added top-level makefile.vc.
-2006-10-18 14:28 strk
+2006-10-18 14:28 Sandro Santilli <strk at keybit.net>
- * .: fixed svn:ignore property
+ * [r1867] .: fixed svn:ignore property
-2006-10-18 12:08 strk
+2006-10-18 12:08 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/operation/overlay/OverlayOp.cpp: disable
- non-JTS overlay result validators (to more closely track JTS at
- this stage)
+ * [r1866] ChangeLog, source/operation/overlay/OverlayOp.cpp:
+ disable non-JTS overlay result validators (to more closely track
+ JTS at this stage)
-2006-10-17 14:26 strk
+2006-10-17 14:26 Sandro Santilli <strk at keybit.net>
+ * [r1865] ChangeLog, source/headers/geos/geom/BinaryOp.h: *
source/headers/geos/geom/BinaryOp.h (SnapOp): fixed horrible
bug applying overlay of first geom to itself :(
-2006-10-17 10:15 strk
+2006-10-17 10:15 Sandro Santilli <strk at keybit.net>
- * capi/geos_c.h.in: really fixed 'extra tokens at end of #endif
- directive' warning
+ * [r1864] capi/geos_c.h.in: really fixed 'extra tokens at end of
+ #endif directive' warning
-2006-10-17 10:10 strk
+2006-10-17 10:10 Sandro Santilli <strk at keybit.net>
- * capi/geos_c.h.in: fixed 'extra tokens at end of #endif directive'
- warning
+ * [r1863] capi/geos_c.h.in: fixed 'extra tokens at end of #endif
+ directive' warning
-2006-10-17 08:44 strk
+2006-10-17 08:44 Sandro Santilli <strk at keybit.net>
- * ChangeLog, capi/Makefile.am: * capi/Makefile.am: don't directly
- link geostest against
+ * [r1862] ChangeLog, capi/Makefile.am: * capi/Makefile.am: don't
+ directly link geostest against
both libgeos.so and libstdc++ (should be derived by
libgeos_c.so).
-2006-10-12 15:33 strk
+2006-10-12 15:33 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/bigtest/GeometryTestFactory.cpp,
+ * [r1861] ChangeLog, tests/bigtest/GeometryTestFactory.cpp,
tests/bigtest/TestSweepLineSpeed.cpp, tests/bigtest/bigtest.h: *
tests/bigtest/GeometryTestFactory.cpp, tests/bigtest/bigtest.h,
tests/bigtest/TestSweepLineSpeed.cpp: fixed header inclusion, to
reduce compiler noise.
-2006-10-09 16:39 strk
+2006-10-09 16:39 Sandro Santilli <strk at keybit.net>
+ * [r1860] ChangeLog, source/headers/geos/geom/BinaryOp.h: *
source/headers/geos/geom/BinaryOp.h: always snap geoms to
each-other before applying an overlay (temp hack).
-2006-10-09 16:35 strk
+2006-10-09 16:35 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/operation/overlay/OverlayOp.cpp: *
+ * [r1859] ChangeLog, source/operation/overlay/OverlayOp.cpp: *
source/operation/overlay/OverlayOp.cpp: enable all overlay result
validators, make it disablable at compile time.
-2006-10-05 10:58 mloskot
+2006-10-05 10:58 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, capi/geos_c.h.in, capi/geos_c.h.vc: Added inclusion
- guards to geos_c.h files.
+ * [r1858] ChangeLog, capi/geos_c.h.in, capi/geos_c.h.vc: Added
+ inclusion guards to geos_c.h files.
-2006-10-05 09:46 strk
+2006-10-05 09:46 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/xmltester/XMLTester.cpp: increment areatest
- verbosity (needs -v -v)
+ * [r1857] ChangeLog, tests/xmltester/XMLTester.cpp: increment
+ areatest verbosity (needs -v -v)
-2006-10-02 18:53 hobu
+2006-10-02 18:53 Howard Butler <hobu.inc at gmail.com>
- * ChangeLog, capi/geos_c.cpp: GEOSEnvelope wasn't in the PROTOTYPES
- section in geos_c.cpp
+ * [r1856] ChangeLog, capi/geos_c.cpp: GEOSEnvelope wasn't in the
+ PROTOTYPES section in geos_c.cpp
-2006-09-27 07:48 strk
+2006-09-27 07:48 Sandro Santilli <strk at keybit.net>
- * HOWTO_RELEASE: updated tag item
+ * [r1855] HOWTO_RELEASE: updated tag item
-2006-09-27 07:43 strk
+2006-09-27 07:43 Sandro Santilli <strk at keybit.net>
- * HOWTO_RELEASE: added info about svn tags
+ * [r1854] HOWTO_RELEASE: added info about svn tags
-2006-09-19 06:54 strk
+2006-09-19 06:54 Sandro Santilli <strk at keybit.net>
- * source/operation/overlay/OffsetPointGenerator.cpp: Added
+ * [r1853] source/operation/overlay/OffsetPointGenerator.cpp: Added
<algorithm> include
-2006-09-08 23:13 pramsey
+2006-09-08 23:13 Paul Ramsey <pramsey at cleverelephant.ca>
- * AUTHORS: Added information about funders of the 3.0.0 series:
- Safe Software, Autodesk,
+ * [r1851] AUTHORS: Added information about funders of the 3.0.0
+ series: Safe Software, Autodesk,
Bavarian State Ministry of Agriculture and Forestry and the State
Survey of Bavaria.
-2006-09-08 09:38 strk
+2006-09-08 09:38 Sandro Santilli <strk at keybit.net>
- * TODO: updated
+ * [r1850] TODO: updated
-2006-09-08 09:31 strk
+2006-09-08 09:31 Sandro Santilli <strk at keybit.net>
- * source/operation/overlay/OverlayResultValidator.cpp: more
+ * [r1849] source/operation/overlay/OverlayResultValidator.cpp: more
debugging output
-2006-09-08 09:21 strk
+2006-09-08 09:21 Sandro Santilli <strk at keybit.net>
- * tests/unit/operation/overlay/FuzzyPointLocatorTest.cpp,
+ * [r1848] tests/unit/operation/overlay/FuzzyPointLocatorTest.cpp,
tests/unit/operation/overlay/OverlayResultValidatorTest.cpp: More
testcases
-2006-09-07 18:07 strk
+2006-09-07 18:07 Sandro Santilli <strk at keybit.net>
+ * [r1847] tests/unit/Makefile.am,
tests/unit/operation/overlay/OverlayResultValidatorTest.cpp: New
unit test for OverlayResultValidator class
+ * [r1846] source/operation/overlay/OverlayResultValidator.cpp: more
debugging output
-2006-09-07 17:52 strk
+2006-09-07 17:52 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/overlay/OverlayResultValidator.h,
+ * [r1845]
+ source/headers/geos/operation/overlay/OverlayResultValidator.h,
source/operation/overlay/OverlayResultValidator.cpp: Added
addVertices private method (unused, as in JTS, but possibly
useful in the future)
-2006-09-07 17:41 strk
+2006-09-07 17:41 Sandro Santilli <strk at keybit.net>
- * source/operation/overlay/OverlayResultValidator.cpp: Added
- debugging code
+ * [r1844] source/operation/overlay/OverlayResultValidator.cpp:
+ Added debugging code
-2006-09-07 17:35 strk
+2006-09-07 17:35 Sandro Santilli <strk at keybit.net>
- * tests/unit/operation/overlay/OffsetPointGeneratorTest.cpp: more
+ * [r1843]
+ tests/unit/operation/overlay/OffsetPointGeneratorTest.cpp: more
testcases (added test for max distance of offset points)
-2006-09-07 15:28 strk
+2006-09-07 15:28 Sandro Santilli <strk at keybit.net>
- * tests/unit/algorithm/PointLocatorTest.cpp,
+ * [r1842] tests/unit/algorithm/PointLocatorTest.cpp,
tests/unit/geom/CoordinateArraySequenceFactoryTest.cpp,
tests/unit/geom/CoordinateArraySequenceTest.cpp,
tests/unit/geom/CoordinateListTest.cpp,
@@ -6674,118 +6848,120 @@
tests/unit/precision/LineStringSnapperTest.cpp: removed
svn:executable prop from all .cpp files
-2006-09-07 15:22 strk
+2006-09-07 15:22 Sandro Santilli <strk at keybit.net>
+ * [r1841] tests/unit/operation/overlay/FuzzyPointLocatorTest.cpp,
removed svn:executable property
-2006-09-07 15:21 strk
+2006-09-07 15:21 Sandro Santilli <strk at keybit.net>
- * tests/unit/operation/overlay/FuzzyPointLocatorTest.cpp: testing
- execute bit state
+ * [r1840] tests/unit/operation/overlay/FuzzyPointLocatorTest.cpp:
+ testing execute bit state
-2006-09-07 12:17 mloskot
+2006-09-07 12:17 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/operation/distance/DistanceOpTest.cpp: Set svn:keyword
- for $ expansion.
+ * [r1839] tests/unit/operation/distance/DistanceOpTest.cpp: Set
+ svn:keyword for $ expansion.
-2006-09-07 11:34 strk
+2006-09-07 11:34 Sandro Santilli <strk at keybit.net>
- * source/operation/overlay/OverlayOp.cpp: Cleaned up
+ * [r1838] source/operation/overlay/OverlayOp.cpp: Cleaned up
OverlayResultValidator call (still disabled due to bugs)
-2006-09-07 11:27 strk
+2006-09-07 11:27 Sandro Santilli <strk at keybit.net>
- * source/operation/overlay/OverlayResultValidator.cpp: blindly
- return positive result if any input or output is not an area
+ * [r1837] source/operation/overlay/OverlayResultValidator.cpp:
+ blindly return positive result if any input or output is not an
+ area
-2006-09-07 11:08 strk
+2006-09-07 11:08 Sandro Santilli <strk at keybit.net>
- * tests/unit/operation/overlay/FuzzyPointLocatorTest.cpp: new test
- for FuzzyPointLocator
+ * [r1836] tests/unit/operation/overlay/FuzzyPointLocatorTest.cpp:
+ new test for FuzzyPointLocator
-2006-09-07 10:30 strk
+2006-09-07 10:30 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom/Location.h: Explicit values to
+ * [r1835] source/headers/geos/geom/Location.h: Explicit values to
LocationValue enum items. Removed CVS Log
-2006-09-07 09:33 strk
+2006-09-07 09:33 Sandro Santilli <strk at keybit.net>
- * doc/example.cpp: Removed catch-all headers inclusion and use of
- obsoleted Unload class
+ * [r1834] doc/example.cpp: Removed catch-all headers inclusion and
+ use of obsoleted Unload class
-2006-09-07 09:24 strk
+2006-09-07 09:24 Sandro Santilli <strk at keybit.net>
- * README: updated
+ * [r1833] README: updated
-2006-09-07 09:23 strk
+2006-09-07 09:23 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/overlay/OverlayResultValidator.h:
+ * [r1832]
+ source/headers/geos/operation/overlay/OverlayResultValidator.h:
comment cleanup
-2006-09-07 09:01 strk
+2006-09-07 09:01 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/distance/DistanceOp.h: Comments
- about ownership (and lifetime) of returned objects
+ * [r1831] source/headers/geos/operation/distance/DistanceOp.h:
+ Comments about ownership (and lifetime) of returned objects
-2006-09-07 08:59 strk
+2006-09-07 08:59 Sandro Santilli <strk at keybit.net>
- * tests/unit/Makefile.am, tests/unit/operation/distance,
+ * [r1830] tests/unit/Makefile.am, tests/unit/operation/distance,
tests/unit/operation/distance/DistanceOpTest.cpp: New DistanceOp
unit test
-2006-09-07 08:57 strk
+2006-09-07 08:57 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/operation/distance/DistanceOp.cpp:
+ * [r1829] ChangeLog, source/operation/distance/DistanceOp.cpp:
(computeMinDistancePoints): fixed invalid reference.
-2006-09-07 08:23 strk
+2006-09-07 08:23 Sandro Santilli <strk at keybit.net>
- * ChangeLog, autogen.sh: don't giveup on automake failures
+ * [r1828] ChangeLog, autogen.sh: don't giveup on automake failures
(testing)
-2006-09-06 18:44 strk
+2006-09-06 18:44 Sandro Santilli <strk at keybit.net>
- * source/operation/overlay/OverlayOp.cpp: Ops, overlay result
- validation erroenously committed
+ * [r1827] source/operation/overlay/OverlayOp.cpp: Ops, overlay
+ result validation erroenously committed
-2006-09-06 18:41 strk
+2006-09-06 18:41 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/unit/Makefile.am,
+ * [r1826] ChangeLog, tests/unit/Makefile.am,
tests/unit/operation/overlay/OffsetPointGeneratorTest.cpp: new
test for OffsetPointGenerator class
-2006-09-06 18:37 strk
+2006-09-06 18:37 Sandro Santilli <strk at keybit.net>
- * source/operation/overlay/OffsetPointGenerator.cpp: Fixed
+ * [r1825] source/operation/overlay/OffsetPointGenerator.cpp: Fixed
uninitialized memory bug
-2006-09-06 17:59 strk
+2006-09-06 17:59 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/operation/overlay/OverlayOp.cpp,
+ * [r1824] ChangeLog, source/operation/overlay/OverlayOp.cpp,
tests/unit/Makefile.am, tests/unit/operation,
tests/unit/operation/overlay,
for FuzzyPointLocator class
-2006-09-06 17:48 strk
+2006-09-06 17:48 Sandro Santilli <strk at keybit.net>
- * tests/unit/precision/GeometrySnapperTest.cpp: updated after
- GeometrySnapper interface change.
+ * [r1823] tests/unit/precision/GeometrySnapperTest.cpp: updated
+ after GeometrySnapper interface change.
-2006-09-06 17:26 mloskot
+2006-09-06 17:26 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog,
+ * [r1822] ChangeLog,
source/operation/overlay/OffsetPointGenerator.cpp,
source/operation/overlay/OverlayResultValidator.cpp: Set $
expansion for new files in 'overlay' module.
-2006-09-06 17:22 strk
+2006-09-06 17:22 Sandro Santilli <strk at keybit.net>
- * ChangeLog,
+ * [r1821] ChangeLog,
source/headers/geos/operation/overlay/Makefile.am,
@@ -6796,11 +6972,11 @@
source/operation/overlay/OverlayResultValidator.cpp: Rest of
Overlay validation classes.
-2006-09-06 16:54 mloskot
+2006-09-06 16:54 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_c.h.vc,
- capi/geostest.c, configure.in, debian/watch, doc/Doxyfile.in,
- doc/example.cpp, source/Makefile.vc,
+ * [r1820] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in,
+ capi/geos_c.h.vc, capi/geostest.c, configure.in, debian/watch,
+ doc/Doxyfile.in, doc/example.cpp, source/Makefile.vc,
@@ -7319,137 +7495,142 @@
tests/xmltester/markup/MarkupSTL.h, tools/geos-config.in: Set
svn:keyword property for Id keyword expansion.
-2006-09-06 15:50 strk
+2006-09-06 15:50 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/overlay/FuzzyPointLocator.h,
+ * [r1819]
+ source/headers/geos/operation/overlay/FuzzyPointLocator.h,
source/operation/overlay/FuzzyPointLocator.cpp: Fixed comments
and includes
-2006-09-06 15:33 strk
+2006-09-06 15:33 Sandro Santilli <strk at keybit.net>
- * ChangeLog,
+ * [r1818] ChangeLog,
source/operation/overlay/FuzzyPointLocator.cpp: new helper class
for Overlay op validation.
-2006-09-06 15:21 strk
+2006-09-06 15:21 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom/Geometry.h: (getBoundary) memory
+ * [r1817] source/headers/geos/geom/Geometry.h: (getBoundary) memory
allocations documented
-2006-09-05 16:18 strk
+2006-09-05 16:18 Sandro Santilli <strk at keybit.net>
- * ChangeLog: updated (last commit log was bogus, refer to ChangeLog
- entry)
+ * [r1816] ChangeLog: updated (last commit log was bogus, refer to
+ ChangeLog entry)
-2006-09-05 16:07 strk
+2006-09-05 16:07 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom/BinaryOp.h,
+ * [r1815] source/headers/geos/geom/BinaryOp.h,
(OverlayOp::checkObviouslyWrongResult): exceptions messages
rewording
-2006-08-31 23:13 strk
+2006-08-31 23:13 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/index/quadtree/Root.cpp: (insertContained):
- fixed bug reported in geos-devel/2006-August/002541.html
+ * [r1814] ChangeLog, source/index/quadtree/Root.cpp:
+ (insertContained): fixed bug reported in
+ geos-devel/2006-August/002541.html
-2006-08-31 23:07 strk
+2006-08-31 23:07 Sandro Santilli <strk at keybit.net>
- * ChangeLog, configure.in: Reverted last two commits. Darwin host
- on buildbot seems to have its own problems...
+ * [r1813] ChangeLog, configure.in: Reverted last two commits.
+ Darwin host on buildbot seems to have its own problems...
-2006-08-31 22:28 strk
+2006-08-31 22:28 Sandro Santilli <strk at keybit.net>
- * configure.in: Ops, it was AM_CONFIG_HEADER the old version -
- still testing
+ * [r1812] configure.in: Ops, it was AM_CONFIG_HEADER the old
+ version - still testing
-2006-08-31 22:21 strk
+2006-08-31 22:21 Sandro Santilli <strk at keybit.net>
- * ChangeLog, configure.in: AC_CONFIG_HEADERS => AM_CONFIG_HEADER
- (to support older automake versions)
+ * [r1811] ChangeLog, configure.in: AC_CONFIG_HEADERS =>
+ AM_CONFIG_HEADER (to support older automake versions)
-2006-08-04 20:30 hobu
+2006-08-04 20:30 Howard Butler <hobu.inc at gmail.com>
- * capi/geos_c.h.vc: version should be 3.0.0 instead of 3.3.0
+ * [r1810] capi/geos_c.h.vc: version should be 3.0.0 instead of
+ 3.3.0
-2006-08-04 20:29 hobu
+2006-08-04 20:29 Howard Butler <hobu.inc at gmail.com>
- * source/headers/geos/version.h.vc: bump patch to rc1
+ * [r1809] source/headers/geos/version.h.vc: bump patch to rc1
-2006-08-04 20:23 hobu
+2006-08-04 20:23 Howard Butler <hobu.inc at gmail.com>
- * source/Makefile.vc: give makefile.vc some love
+ * [r1808] source/Makefile.vc: give makefile.vc some love
-2006-08-04 16:40 csavage
+2006-08-04 16:40 Charlie Savage <cfis at savagexi.com>
- * swig/geos.i, swig/python/geos.py, swig/python/geos_wrap.cxx,
- swig/ruby/geos_wrap.cxx: Updated SWIG bindings to expose the
- equalsExact and normalize methods.
+ * [r1807] swig/geos.i, swig/python/geos.py,
+ swig/python/geos_wrap.cxx, swig/ruby/geos_wrap.cxx: Updated SWIG
+ bindings to expose the equalsExact and normalize methods.
-2006-08-03 23:43 csavage
+2006-08-03 23:43 Charlie Savage <cfis at savagexi.com>
- * source/headers/geos/platform.h.in, source/headers/geos/timeval.h:
- Two changes needed to include the correct definitions for
- compiling geos using MingW/msys on Windows.
+ * [r1806] source/headers/geos/platform.h.in,
+ source/headers/geos/timeval.h: Two changes needed to include the
+ correct definitions for compiling geos using MingW/msys on
+ Windows.
-2006-08-03 22:46 strk
+2006-08-03 22:46 Sandro Santilli <strk at keybit.net>
- * ChangeLog: try to keep text within 80 cols
+ * [r1805] ChangeLog: try to keep text within 80 cols
-2006-08-03 22:24 csavage
+2006-08-03 22:24 Charlie Savage <cfis at savagexi.com>
- * configure.in: Changed configure.in to use *nix line feeds.
+ * [r1804] configure.in: Changed configure.in to use *nix line
+ feeds.
-2006-08-03 22:17 csavage
+2006-08-03 22:17 Charlie Savage <cfis at savagexi.com>
- * capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_c.h.vc: Mistakenly
- used Geometry* in C api headers instead of GEOSGeom.
+ * [r1803] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_c.h.vc:
+ Mistakenly used Geometry* in C api headers instead of GEOSGeom.
-2006-08-03 22:13 csavage
+2006-08-03 22:13 Charlie Savage <cfis at savagexi.com>
- * configure.in: Removed native line endings for configure.in since
- CR/LF does not work on Windows under msys.
+ * [r1802] configure.in: Removed native line endings for
+ configure.in since CR/LF does not work on Windows under msys.
-2006-08-03 22:02 csavage
+2006-08-03 22:02 Charlie Savage <cfis at savagexi.com>
- * ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_c.h.vc:
- Added equalsExact and normalize to the c api as discussed on the
- mailing list
+ * [r1801] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in,
+ capi/geos_c.h.vc: Added equalsExact and normalize to the c api as
+ discussed on the mailing list
(http://geos.refractions.net/pipermail/geos-devel/2006-July/002452.html).
-2006-08-03 21:34 csavage
+2006-08-03 21:34 Charlie Savage <cfis at savagexi.com>
- * ChangeLog, swig/python/Makefile.am, swig/ruby/Makefile.am:
- Updated build scripts so that ruby/geos_wrap.cxx,
- python/geos_wrap.cxx and python/geos.py are removed by make
- maintainer-clean but not make clean.
+ * [r1800] ChangeLog, swig/python/Makefile.am,
+ swig/ruby/Makefile.am: Updated build scripts so that
+ ruby/geos_wrap.cxx, python/geos_wrap.cxx and python/geos.py are
+ removed by make maintainer-clean but not make clean.
-2006-08-03 16:28 mloskot
+2006-08-03 16:28 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, tests/unit/geos_unit.cpp: Fixed Bug #90
+ * [r1799] ChangeLog, tests/unit/geos_unit.cpp: Fixed Bug #90
-2006-08-03 16:18 csavage
+2006-08-03 16:18 Charlie Savage <cfis at savagexi.com>
- * swig/python/geos.py, swig/python/geos_wrap.cxx,
+ * [r1798] swig/python/geos.py, swig/python/geos_wrap.cxx,
swig/ruby/geos_wrap.cxx: Added SWIG generated wrapper files for
Ruby and Python
-2006-07-27 06:18 mloskot
+2006-07-27 06:18 Mateusz Loskot <mateusz at loskot.net>
- * .: Added svn:ignore property to ignore 'geos-3.0.0rc1' dir
- (testing commit access to SVN).
+ * [r1797] .: Added svn:ignore property to ignore 'geos-3.0.0rc1'
+ dir (testing commit access to SVN).
-2006-07-26 19:06 strk
+2006-07-26 19:06 Sandro Santilli <strk at keybit.net>
- * .cvsignore, capi/.cvsignore, doc/.cvsignore, macros/.cvsignore,
- source/.cvsignore, source/algorithm/.cvsignore,
- source/examples/.cvsignore, source/geom/.cvsignore,
- source/geom/util/.cvsignore, source/geomgraph/.cvsignore,
- source/geomgraph/index/.cvsignore, source/headers/.cvsignore,
- source/headers/geos/.cvsignore,
+ * [r1795] .cvsignore, capi/.cvsignore, doc/.cvsignore,
+ macros/.cvsignore, source/.cvsignore,
+ source/algorithm/.cvsignore, source/examples/.cvsignore,
+ source/geom/.cvsignore, source/geom/util/.cvsignore,
+ source/geomgraph/.cvsignore, source/geomgraph/index/.cvsignore,
+ source/headers/.cvsignore, source/headers/geos/.cvsignore,
source/headers/geos/algorithm/.cvsignore,
source/headers/geos/geom/.cvsignore,
source/headers/geos/geom/util/.cvsignore,
@@ -7499,42 +7680,45 @@
tests/unit/.cvsignore, tests/xmltester/.cvsignore,
tools/.cvsignore: Removed .cvsignore files from repository
-2006-07-26 17:51 strk
+2006-07-26 17:51 Sandro Santilli <strk at keybit.net>
- * ChangeLog, capi/Makefile.am, tests/xmltester/XMLTester.cpp: *
- capi/Makefile.am: forced link of geostest against stdc++ lib
+ * [r1794] ChangeLog, capi/Makefile.am,
+ tests/xmltester/XMLTester.cpp: * capi/Makefile.am: forced link of
+ geostest against stdc++ lib
* tests/xmltester/XMLTester.cpp: added <cmath> include (for fabs
use)
-2006-07-26 15:28 strk
+2006-07-26 15:28 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/geom/BinaryOp.h: Added geometry
- snapping heuristic
+ * [r1776] ChangeLog, source/headers/geos/geom/BinaryOp.h: Added
+ geometry snapping heuristic
-2006-07-25 20:45 strk
+2006-07-25 20:45 Sandro Santilli <strk at keybit.net>
- * ChangeLog, autogen.sh: Made autogen.sh errors more visible
+ * [r1775] ChangeLog, autogen.sh: Made autogen.sh errors more
+ visible
-2006-07-21 19:37 csavage
+2006-07-21 19:37 Charlie Savage <cfis at savagexi.com>
- * NEWS: Added note about inclusion of version.in.vc. See
+ * [r1773] NEWS: Added note about inclusion of version.in.vc. See
http://geos.refractions.net/pipermail/geos-devel/2006-July/002463.html
for more info.
-2006-07-21 17:59 strk
+2006-07-21 17:59 Sandro Santilli <strk at keybit.net>
+ * [r1772] ChangeLog, tests/unit/Makefile.am,
tests/unit/precision/GeometrySnapperTest.cpp: Added test for
GeometrySnapper
- * source/precision/LineStringSnapper.cpp: Fixed preprocessor
- directive use
+ * [r1771] source/precision/LineStringSnapper.cpp: Fixed
+ preprocessor directive use
-2006-07-21 17:09 strk
+2006-07-21 17:09 Sandro Santilli <strk at keybit.net>
+ * [r1770] ChangeLog,
source/headers/geos/precision/Makefile.am,
@@ -7545,393 +7729,406 @@
precision::LineStringSnapper class + test
and precision::GeometrySnapper (w/out test)
-2006-07-21 17:05 strk
+2006-07-21 17:05 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/geom/CoordinateList.h: added
- operator<< for CoordinateList class
+ * [r1769] ChangeLog, source/headers/geos/geom/CoordinateList.h:
+ added operator<< for CoordinateList class
-2006-07-21 17:00 strk
+2006-07-21 17:00 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/unit/geom/LineSegmentTest.cpp: Added another
- distance() test
+ * [r1768] ChangeLog, tests/unit/geom/LineSegmentTest.cpp: Added
+ another distance() test
-2006-07-21 16:45 mloskot
+2006-07-21 16:45 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, source/headers/geos/geom.h, source/headers/geos/io.h:
- Wrapped FIXME message with #warning directive to shout about
- potential headers removal in future.
+ * [r1767] ChangeLog, source/headers/geos/geom.h,
+ source/headers/geos/io.h: Wrapped FIXME message with #warning
+ directive to shout about potential headers removal in future.
-2006-07-21 14:53 strk
+2006-07-21 14:53 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/geom/CoordinateList.h,
+ * [r1766] ChangeLog, source/headers/geos/geom/CoordinateList.h,
source/headers/geos/geom/Makefile.am, tests/unit/Makefile.am,
tests/unit/geom/CoordinateListTest.cpp: CoordinateList class
re-introduced, for list-based ops
(not strictly mapped to JTS version, not yet at least)
-2006-07-21 14:49 strk
+2006-07-21 14:49 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom/LineSegment.h: Fixed typo in comment
+ * [r1765] source/headers/geos/geom/LineSegment.h: Fixed typo in
+ comment
-2006-07-21 08:33 strk
+2006-07-21 08:33 Sandro Santilli <strk at keybit.net>
- * swig/ruby/test/Makefile.am: Removed blank space after backslash
- (automake complained)
+ * [r1764] swig/ruby/test/Makefile.am: Removed blank space after
+ backslash (automake complained)
-2006-07-19 02:43 csavage
+2006-07-19 02:43 Charlie Savage <cfis at savagexi.com>
- * source/headers/geos/Makefile.am: Added veresion.h.vc as
+ * [r1763] source/headers/geos/Makefile.am: Added veresion.h.vc as
EXTRA_DIST to ensure it is packaged when doing make dist.
-2006-07-15 19:36 csavage
+2006-07-15 19:36 Charlie Savage <cfis at savagexi.com>
- * configure.in: Removed python test/cases directory (tests are now
- just in tests directory).
+ * [r1762] configure.in: Removed python test/cases directory (tests
+ are now just in tests directory).
-2006-07-13 08:02 csavage
+2006-07-13 08:02 Charlie Savage <cfis at savagexi.com>
- * ChangeLog: Updated ChangeLog to note additional SWIG tests and
- integration with the GEOS build system.
+ * [r1761] ChangeLog: Updated ChangeLog to note additional SWIG
+ tests and integration with the GEOS build system.
-2006-07-13 07:49 csavage
+2006-07-13 07:49 Charlie Savage <cfis at savagexi.com>
- * capi/geos_c.h.vc: Updated version number to 3.0.0rc1-CAPI-1.1.1
- to match the autoconf generated files.
+ * [r1760] capi/geos_c.h.vc: Updated version number to
+ 3.0.0rc1-CAPI-1.1.1 to match the autoconf generated files.
-2006-07-13 07:38 csavage
+2006-07-13 07:38 Charlie Savage <cfis at savagexi.com>
- * swig/ruby/test/Makefile.am: Fixed spelling mistake in test task.
+ * [r1759] swig/ruby/test/Makefile.am: Fixed spelling mistake in
+ test task.
-2006-07-13 07:36 csavage
+2006-07-13 07:36 Charlie Savage <cfis at savagexi.com>
- * swig/Makefile.am: Removed dependency on README.txt since it has
- been removed.
+ * [r1758] swig/Makefile.am: Removed dependency on README.txt since
+ it has been removed.
-2006-07-13 07:35 csavage
+2006-07-13 07:35 Charlie Savage <cfis at savagexi.com>
- * swig/ruby/test/test_buffer.rb: New tests for the buffer
+ * [r1757] swig/ruby/test/test_buffer.rb: New tests for the buffer
operation.
-2006-07-13 07:29 csavage
+2006-07-13 07:29 Charlie Savage <cfis at savagexi.com>
- * configure.in: Added SWIG Python and Ruby bindings back into the
- main GEOS build system.
+ * [r1756] configure.in: Added SWIG Python and Ruby bindings back
+ into the main GEOS build system.
-2006-07-13 07:27 csavage
+2006-07-13 07:27 Charlie Savage <cfis at savagexi.com>
- * swig/python/tests/Makefile.am, swig/ruby/test/Makefile.am:
- Updated extra_dist for test directories.
+ * [r1755] swig/python/tests/Makefile.am,
+ swig/ruby/test/Makefile.am: Updated extra_dist for test
+ directories.
-2006-07-13 07:20 csavage
+2006-07-13 07:20 Charlie Savage <cfis at savagexi.com>
- * swig/python/tests/Makefile.am: Remove the dependency on the cases
- subdirectory which is no longer needed.
+ * [r1754] swig/python/tests/Makefile.am: Remove the dependency on
+ the cases subdirectory which is no longer needed.
-2006-07-13 07:19 csavage
+2006-07-13 07:19 Charlie Savage <cfis at savagexi.com>
- * swig/python/tests/runtests.py: Updated test suite to use the
- correct tests.
+ * [r1753] swig/python/tests/runtests.py: Updated test suite to use
+ the correct tests.
-2006-07-13 07:16 csavage
+2006-07-13 07:16 Charlie Savage <cfis at savagexi.com>
- * swig/python/tests/cases: Removed old tests cases which are no
- longer valid (worked using the C++ api).
+ * [r1752] swig/python/tests/cases: Removed old tests cases which
+ are no longer valid (worked using the C++ api).
-2006-07-13 07:14 csavage
+2006-07-13 07:14 Charlie Savage <cfis at savagexi.com>
- * swig/python/tests/test_geometry.py: New Python test case to
- ensure creating coordinate sequences and geometries works
+ * [r1751] swig/python/tests/test_geometry.py: New Python test case
+ to ensure creating coordinate sequences and geometries works
correctly.
- * swig/README.txt, swig/python/Makefile.am, swig/python/README.txt,
- swig/ruby/Makefile.am, swig/ruby/README.txt: Removed README.txt
- files which are no longer applicable now that the SWIG bindings
- have been intergrated into the GEOS build system.
+ * [r1750] swig/README.txt, swig/python/Makefile.am,
+ swig/python/README.txt, swig/ruby/Makefile.am,
+ swig/ruby/README.txt: Removed README.txt files which are no
+ longer applicable now that the SWIG bindings have been
+ intergrated into the GEOS build system.
-2006-07-13 07:13 csavage
+2006-07-13 07:13 Charlie Savage <cfis at savagexi.com>
- * swig/ruby/test/test_geometry.rb: Renamed test class.
+ * [r1749] swig/ruby/test/test_geometry.rb: Renamed test class.
-2006-07-13 07:09 csavage
+2006-07-13 07:09 Charlie Savage <cfis at savagexi.com>
- * swig/python/Makefile.am: Removed old, unused code.
+ * [r1748] swig/python/Makefile.am: Removed old, unused code.
- * swig/python/python.i: Added tyepmap to support creating polygons
- with holes.
+ * [r1747] swig/python/python.i: Added tyepmap to support creating
+ polygons with holes.
-2006-07-13 07:08 csavage
+2006-07-13 07:08 Charlie Savage <cfis at savagexi.com>
- * swig/geos.i: Added default value for quadsegs parmeter in buffer
- operation.
+ * [r1746] swig/geos.i: Added default value for quadsegs parmeter in
+ buffer operation.
-2006-07-13 04:47 csavage
+2006-07-13 04:47 Charlie Savage <cfis at savagexi.com>
- * swig/python/tests/example.py: Manually moved from parent
+ * [r1745] swig/python/tests/example.py: Manually moved from parent
directory.
-2006-07-13 04:46 csavage
+2006-07-13 04:46 Charlie Savage <cfis at savagexi.com>
- * swig/python/Makefile.am: Updated EXTRA_DIST to include python.i
- and geos.pth
+ * [r1744] swig/python/Makefile.am: Updated EXTRA_DIST to include
+ python.i and geos.pth
- * swig/python/example.py: Moved file to tests subdirectory.
+ * [r1743] swig/python/example.py: Moved file to tests subdirectory.
-2006-07-13 04:45 csavage
+2006-07-13 04:45 Charlie Savage <cfis at savagexi.com>
- * swig/python/setup.py: Installation is now done by autoconf macros
- instead of setup.py
+ * [r1742] swig/python/setup.py: Installation is now done by
+ autoconf macros instead of setup.py
-2006-07-13 04:39 csavage
+2006-07-13 04:39 Charlie Savage <cfis at savagexi.com>
- * swig/geos.i, swig/python/python.i, swig/ruby/ruby.i: Cleaned up
- ruby.i, added licenxe to python.i, commented back in python.i
- into geos.i.
+ * [r1741] swig/geos.i, swig/python/python.i, swig/ruby/ruby.i:
+ Cleaned up ruby.i, added licenxe to python.i, commented back in
+ python.i into geos.i.
-2006-07-13 04:09 csavage
+2006-07-13 04:09 Charlie Savage <cfis at savagexi.com>
- * swig/ruby/test/test_helper.rb: Added code to read xml test cases.
+ * [r1740] swig/ruby/test/test_helper.rb: Added code to read xml
+ test cases.
-2006-07-13 04:08 csavage
+2006-07-13 04:08 Charlie Savage <cfis at savagexi.com>
- * swig/geos.i: Added exception handling for results that return
- geometries. Added normalize and equalsExact, but for the moment
- they are commented out.
+ * [r1739] swig/geos.i: Added exception handling for results that
+ return geometries. Added normalize and equalsExact, but for the
+ moment they are commented out.
-2006-07-13 03:59 csavage
+2006-07-13 03:59 Charlie Savage <cfis at savagexi.com>
- * tests/xmltester/XMLTester.cpp: Changes to compile on VC++ - fully
- qualified polygon name. Should also work on MingW, will test
- next.
+ * [r1738] tests/xmltester/XMLTester.cpp: Changes to compile on VC++
+ - fully qualified polygon name. Should also work on MingW, will
+ test next.
-2006-07-12 23:17 csavage
+2006-07-12 23:17 Charlie Savage <cfis at savagexi.com>
- * swig/ruby/test/geos_tests.rb: Disabled test_combinations.rb for
- the moment since it fails.
+ * [r1737] swig/ruby/test/geos_tests.rb: Disabled
+ test_combinations.rb for the moment since it fails.
-2006-07-12 23:16 csavage
+2006-07-12 23:16 Charlie Savage <cfis at savagexi.com>
- * swig/geos.i: Fixed serious bug in geom_to_hex and geom_to_wkb
- type maps. Was using temporary variable instead of passed in
- variable.
+ * [r1736] swig/geos.i: Fixed serious bug in geom_to_hex and
+ geom_to_wkb type maps. Was using temporary variable instead of
+ passed in variable.
-2006-07-12 22:55 csavage
+2006-07-12 22:55 Charlie Savage <cfis at savagexi.com>
- * capi/geos_c.h.vc: Switched GeosBytesOrder to int in api
+ * [r1735] capi/geos_c.h.vc: Switched GeosBytesOrder to int in api
signatures.
-2006-07-12 22:11 csavage
+2006-07-12 22:11 Charlie Savage <cfis at savagexi.com>
- * swig/geos.i: A number of changes to fix warning generated by gcc
- and to make sure the bindings compile for Python.
+ * [r1734] swig/geos.i: A number of changes to fix warning generated
+ by gcc and to make sure the bindings compile for Python.
- * swig/python/Makefile.am: Updated Python SWIG makefile to build
- with the c api.
+ * [r1733] swig/python/Makefile.am: Updated Python SWIG makefile to
+ build with the c api.
-2006-07-12 22:10 csavage
+2006-07-12 22:10 Charlie Savage <cfis at savagexi.com>
- * swig/ruby/ruby.i: Minor change to fix gcc warning.
+ * [r1732] swig/ruby/ruby.i: Minor change to fix gcc warning.
- * swig/ruby/Makefile.am: Updated Ruby SWIG makefile to build with
- the c api.
+ * [r1731] swig/ruby/Makefile.am: Updated Ruby SWIG makefile to
-2006-07-12 21:03 csavage
+2006-07-12 21:03 Charlie Savage <cfis at savagexi.com>
- * capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_c.h.vc: Fixed an
- error in the way GEOSByteOrder was declared. It is now an enum in
- geos_c.h
+ * [r1730] capi/geos_c.cpp, capi/geos_c.h.in, capi/geos_c.h.vc:
+ Fixed an error in the way GEOSByteOrder was declared. It is now
+ an enum in geos_c.h
-2006-07-12 19:10 csavage
+2006-07-12 19:10 Charlie Savage <cfis at savagexi.com>
- * swig/geos.i: Added %rename directive so that GeomUnion is exposed
- as union is SWIG languages.
+ * [r1729] swig/geos.i: Added %rename directive so that GeomUnion is
+ exposed as union is SWIG languages.
-2006-07-12 19:08 csavage
+2006-07-12 19:08 Charlie Savage <cfis at savagexi.com>
- * swig/ruby/test/geos_tests.rb,
+ * [r1728] swig/ruby/test/geos_tests.rb,
swig/ruby/test/test_combinations.rb,
swig/ruby/test/test_operations.rb: Updated tests for combinatins
(union, intersection, etc.) and operaptions (buffer, centroid,
etc.).
-2006-07-12 19:07 csavage
+2006-07-12 19:07 Charlie Savage <cfis at savagexi.com>
- * swig/ruby/test/test_simple.rb: These tests are no longer needed.
+ * [r1727] swig/ruby/test/test_simple.rb: These tests are no longer
+ needed.
-2006-07-12 17:51 csavage
+2006-07-12 17:51 Charlie Savage <cfis at savagexi.com>
- * swig/ruby/test/geos_tests.rb, swig/ruby/test/test_helper.rb,
- swig/ruby/test/test_relations.rb: Ported old tests for relations,
- such as intersects, touches, etc., to new swig bindings.
+ * [r1726] swig/ruby/test/geos_tests.rb,
+ swig/ruby/test/test_helper.rb, swig/ruby/test/test_relations.rb:
+ Ported old tests for relations, such as intersects, touches,
+ etc., to new swig bindings.
-2006-07-12 08:30 csavage
+2006-07-12 08:30 Charlie Savage <cfis at savagexi.com>
- * swig/ruby/ruby.i: Added type map needed to create polygons with
- holes. Unfortunately, this is Ruby specific. It needs to be
- ported to Python next.
+ * [r1725] swig/ruby/ruby.i: Added type map needed to create
+ polygons with holes. Unfortunately, this is Ruby specific. It
+ needs to be ported to Python next.
-2006-07-12 08:29 csavage
+2006-07-12 08:29 Charlie Savage <cfis at savagexi.com>
- * swig/geos.i: Removed wrapper classes and replace them with SWIG
- "fake" classes. This makes the interface cleaner, and makes
- memory management much easier. Also added area, dimension,
+ * [r1724] swig/geos.i: Removed wrapper classes and replace them
+ with SWIG "fake" classes. This makes the interface cleaner, and
+ makes memory management much easier. Also added area, dimension,
length, getExteriorRing, getInteriorRingN methods.
-2006-07-12 08:27 csavage
+2006-07-12 08:27 Charlie Savage <cfis at savagexi.com>
- * swig/ruby/test/test_srid.rb: Added test to read from wkb geometry
- - currently fails, needs more investigation.
+ * [r1723] swig/ruby/test/test_srid.rb: Added test to read from wkb
+ geometry - currently fails, needs more investigation.
- * swig/ruby/test/test_io.rb: Added tests for invalid geometries.
+ * [r1722] swig/ruby/test/test_io.rb: Added tests for invalid
+ geometries.
- * swig/ruby/test/geos_tests.rb: Updated ruby test suite.
+ * [r1721] swig/ruby/test/geos_tests.rb: Updated ruby test suite.
-2006-07-12 08:24 csavage
+2006-07-12 08:24 Charlie Savage <cfis at savagexi.com>
- * swig/ruby/test/test_geometry.rb: New tests for area, length,
- distance.
+ * [r1720] swig/ruby/test/test_geometry.rb: New tests for area,
+ length, distance.
-2006-07-12 05:21 csavage
+2006-07-12 05:21 Charlie Savage <cfis at savagexi.com>
- * swig/ruby/test/test_coordinate_sequence.rb,
+ * [r1719] swig/ruby/test/test_coordinate_sequence.rb,
swig/ruby/test/test_version.rb: Converted line feeds to Unix
style.
- * swig/ruby/test/test_geometry.rb: New tests for creating
+ * [r1718] swig/ruby/test/test_geometry.rb: New tests for creating
geometries and calling various functions such as numGeometries,
isValid, etc.
-2006-07-12 05:20 csavage
+2006-07-12 05:20 Charlie Savage <cfis at savagexi.com>
- * swig/ruby/test/test_srid.rb: Tests for srid handling.
+ * [r1717] swig/ruby/test/test_srid.rb: Tests for srid handling.
- * swig/ruby/test/test_io.rb: Merged tests from test_wkb_reader.rb
+ * [r1716] swig/ruby/test/test_io.rb: Merged tests from
+ test_wkb_reader.rb
-2006-07-12 05:18 csavage
+2006-07-12 05:18 Charlie Savage <cfis at savagexi.com>
- * swig/ruby/test/test_wkb_reader.rb: Merging into test_io.rb
+ * [r1715] swig/ruby/test/test_wkb_reader.rb: Merging into
+ test_io.rb
-2006-07-12 04:46 csavage
+2006-07-12 04:46 Charlie Savage <cfis at savagexi.com>
- * swig/ruby/test/test_version.rb: Tests to verify returned version
- numbers from C api.
+ * [r1714] swig/ruby/test/test_version.rb: Tests to verify returned
+ version numbers from C api.
-2006-07-11 18:48 csavage
+2006-07-11 18:48 Charlie Savage <cfis at savagexi.com>
- * swig/geos.i: Fixes for coordinate sequences. Fixed bug in range
- checking, chaned clone to be a method instead of copy
+ * [r1713] swig/geos.i: Fixes for coordinate sequences. Fixed bug in
+ range checking, chaned clone to be a method instead of copy
constructor, marked clone as creating a new object.
-2006-07-11 18:44 csavage
+2006-07-11 18:44 Charlie Savage <cfis at savagexi.com>
- * swig/ruby/test/test_coordinate_sequence.rb: Tests for SWIG
- coordinate sequence class.
+ * [r1712] swig/ruby/test/test_coordinate_sequence.rb: Tests for
+ SWIG coordinate sequence class.
-2006-07-11 09:07 csavage
+2006-07-11 09:07 Charlie Savage <cfis at savagexi.com>
- * capi/geos_c.h.in, capi/geos_c.h.vc: Added reference to new enum
- called GEOSByteOrders. The enum has two values, GEOS_WKB_NDR and
- GEOS_WKB_XDR which signify big endian and little endian byte
- orders.
+ * [r1711] capi/geos_c.h.in, capi/geos_c.h.vc: Added reference to
+ new enum called GEOSByteOrders. The enum has two values,
+ GEOS_WKB_NDR and GEOS_WKB_XDR which signify big endian and little
+ endian byte orders.
-2006-07-11 09:05 csavage
+2006-07-11 09:05 Charlie Savage <cfis at savagexi.com>
- * capi/geos_c.h.in, capi/geos_c.h.vc: Added 5 methods to the C API
- as documented in the changelong. The new methods are read/write
- WKB Hex values, read/write WKB byte order and read wkb output
- dimensions.
+ * [r1710] capi/geos_c.h.in, capi/geos_c.h.vc: Added 5 methods to
+ the C API as documented in the changelong. The new methods are
+ read/write WKB Hex values, read/write WKB byte order and read wkb
+ output dimensions.
-2006-07-11 08:55 csavage
+2006-07-11 08:55 Charlie Savage <cfis at savagexi.com>
- * swig/ruby/test/test_wkb_reader.rb: Test cases for reading and
- writing geometries to WKT, WKB and hex encoded WKB formats via
- the SWIG bindings.
+ * [r1709] swig/ruby/test/test_wkb_reader.rb: Test cases for reading
+ and writing geometries to WKT, WKB and hex encoded WKB formats
+ via the SWIG bindings.
-2006-07-11 08:54 csavage
+2006-07-11 08:54 Charlie Savage <cfis at savagexi.com>
- * capi/geos_c.h.vc: Updated visual studio header file to match
- geos_c.h.in
+ * [r1708] capi/geos_c.h.vc: Updated visual studio header file to
+ match geos_c.h.in
-2006-07-11 08:53 csavage
+2006-07-11 08:53 Charlie Savage <cfis at savagexi.com>
- * capi/geos_c.cpp: Added 5 methods to the C API as documented in
- the changelong. The new methods are read/write WKB Hex values,
- read/write WKB byte order and read wkb output dimensions.
+ * [r1707] capi/geos_c.cpp: Added 5 methods to the C API as
+ documented in the changelong. The new methods are read/write WKB
+ Hex values, read/write WKB byte order and read wkb output
+ dimensions.
-2006-07-11 08:52 csavage
+2006-07-11 08:52 Charlie Savage <cfis at savagexi.com>
- * ChangeLog: Noted additions to the C API and porting of SWIG to
- use the C api.
+ * [r1706] ChangeLog: Noted additions to the C API and porting of
+ SWIG to use the C api.
-2006-07-11 08:44 csavage
+2006-07-11 08:44 Charlie Savage <cfis at savagexi.com>
- * swig/geos.i, swig/ruby/ruby.i: Ported SWIG bindings to use c-api.
+ * [r1705] swig/geos.i, swig/ruby/ruby.i: Ported SWIG bindings to
+ use c-api.
-2006-07-10 22:29 strk
+2006-07-10 22:29 Sandro Santilli <strk at keybit.net>
- * tests/tut, tests/tut/.cvsignore: Added .cvsignore file
+ * [r1704] tests/tut, tests/tut/.cvsignore: Added .cvsignore file
-2006-07-10 21:51 strk
+2006-07-10 21:51 Sandro Santilli <strk at keybit.net>
- * ChangeLog, capi/geos_c.cpp: don't use dynamic strings as format
- arg the formatted message callbacks.
+ * [r1703] ChangeLog, capi/geos_c.cpp: don't use dynamic strings as
+ format arg the formatted message callbacks.
-2006-07-10 10:16 strk
+2006-07-10 10:16 Sandro Santilli <strk at keybit.net>
- * ChangeLog,
+ * [r1702] ChangeLog,
source/headers/geos/simplify/DouglasPeuckerLineSimplifier.h:
changed vector<bool> to vector<short int> (see bug#101)
-2006-07-09 03:37 mloskot
+2006-07-09 03:37 Mateusz Loskot <mateusz at loskot.net>
- * tests/xmltester, tests/xmltester/.cvsignore: Added 'testrunner'
- pattern to tests/xmltester/.cvsignore.
+ * [r1701] tests/xmltester, tests/xmltester/.cvsignore: Added
+ 'testrunner' pattern to tests/xmltester/.cvsignore.
-2006-07-09 03:21 mloskot
+2006-07-09 03:21 Mateusz Loskot <mateusz at loskot.net>
- * ., .cvsignore: Added 'testrunner' to .cvsignore patterns.
+ * [r1700] ., .cvsignore: Added 'testrunner' to .cvsignore patterns.
- * ChangeLog: Updated ChangeLog with details about new unit tests.
+ * [r1699] ChangeLog: Updated ChangeLog with details about new unit
+ tests.
-2006-07-09 03:16 mloskot
+2006-07-09 03:16 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/Makefile.am: Added new tests to
+ * [r1698] tests/unit/Makefile.am: Added new tests to
tests/unit/Makefile.am.
-2006-07-09 03:15 mloskot
+2006-07-09 03:15 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/noding/SegmentNodeTest.cpp,
+ * [r1697] tests/unit/noding/SegmentNodeTest.cpp,
tests/unit/noding/SegmentPointComparatorTest.cpp,
tests/unit/noding/SegmentStringTest.cpp: Added new tests cases to
tests/unit/noding. Removed zero-to-pointer casts.
-2006-07-09 00:24 strk
+2006-07-09 00:24 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/Makefile.am: Added testrunner to CLEANFILES. make
- distcheck now succeeds.
+ * [r1696] tests/xmltester/Makefile.am: Added testrunner to
+ CLEANFILES. make distcheck now succeeds.
-2006-07-08 00:33 strk
+2006-07-08 00:33 Sandro Santilli <strk at keybit.net>
- * ChangeLog, configure.in, source/geom/Geometry.cpp,
+ * [r1693] ChangeLog, configure.in, source/geom/Geometry.cpp,
source/geom/GeometryFactory.cpp, source/geomgraph/EdgeRing.cpp,
source/headers/geos/geom/GeometryFactory.h,
@@ -7950,280 +8147,287 @@
* source/headers/geos/platform.h.in: include <inttypes.h>
rather then <stdint.h>
-2006-07-07 20:02 mloskot
+2006-07-07 20:02 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog: Updated ChangeLog with version comparison fix in
- GEOS_UNIT.
+ * [r1691] ChangeLog: Updated ChangeLog with version comparison fix
+ in GEOS_UNIT.
-2006-07-07 20:00 mloskot
+2006-07-07 20:00 Mateusz Loskot <mateusz at loskot.net>
- * macros/geos.m4: Fixed versions comparison in the GEOS_UNIT macro.
+ * [r1690] macros/geos.m4: Fixed versions comparison in the
+ GEOS_UNIT macro.
-2006-07-07 19:33 strk
+2006-07-07 19:33 Sandro Santilli <strk at keybit.net>
- * ChangeLog, acsite.m4, configure.in: * acsite.m4: include
+ * [r1689] ChangeLog, acsite.m4, configure.in: * acsite.m4: include
<inttypes.h> rather then <stdint.h>
(the latter is not available on Solaris 9)
* configure.in: make sure CFLAGS is set before compiling
using the 64bit integer detection macro.
-2006-07-06 16:39 mloskot
+2006-07-06 16:39 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, macros/geos.m4: Fixed version query regexp with
- escaped dots. Removed -lpq from GEOS_LIBS flags.
+ * [r1688] ChangeLog, macros/geos.m4: Fixed version query regexp
+ with escaped dots. Removed -lpq from GEOS_LIBS flags.
-2006-07-05 23:27 mloskot
+2006-07-05 23:27 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, macros/geos.m4: Removed redundant -L and -I from
- GEOS_LIBS and GEOS_CFLAGS.
+ * [r1687] ChangeLog, macros/geos.m4: Removed redundant -L and -I
+ from GEOS_LIBS and GEOS_CFLAGS.
-2006-07-05 23:10 mloskot
+2006-07-05 23:10 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, macros/geos.m4: Fixed GEOS_INIT to support full paths
- to geos-config passed to --with-geos. Fixed version decoding.
+ * [r1686] ChangeLog, macros/geos.m4: Fixed GEOS_INIT to support
+ full paths to geos-config passed to --with-geos. Fixed version
+ decoding.
-2006-07-05 22:54 strk
+2006-07-05 22:54 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/unit/Makefile.am: distribute utility.h
+ * [r1685] ChangeLog, tests/unit/Makefile.am: distribute utility.h
-2006-07-05 22:19 strk
+2006-07-05 22:19 Sandro Santilli <strk at keybit.net>
- * ChangeLog, configure.in, tests/Makefile.am,
+ * [r1684] ChangeLog, configure.in, tests/Makefile.am,
tests/tut/Makefile.am: distribute the TUT framework.
-2006-07-05 21:47 strk
+2006-07-05 21:47 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/xmltester/Makefile.am: Distribute XML tests and
- tester.
+ * [r1683] ChangeLog, tests/xmltester/Makefile.am: Distribute XML
+ tests and tester.
-2006-07-05 21:18 strk
+2006-07-05 21:18 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/operation/valid/Makefile.am: Fixed missing
- SweeplineNestedRingTester.cpp file.
+ * [r1682] ChangeLog, source/operation/valid/Makefile.am: Fixed
+ missing SweeplineNestedRingTester.cpp file.
-2006-07-05 20:52 strk
+2006-07-05 20:52 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/operation/linemerge/Makefile.am:
- Fixed missing backslash, dropping headers from distribution.
+ * [r1681] ChangeLog,
+ source/headers/geos/operation/linemerge/Makefile.am: Fixed
+ missing backslash, dropping headers from distribution.
-2006-07-05 20:20 strk
+2006-07-05 20:20 Sandro Santilli <strk at keybit.net>
- * TODO: updated
+ * [r1680] TODO: updated
-2006-07-05 20:19 strk
+2006-07-05 20:19 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/operation/overlay/OverlayOp.h,
+ * [r1679] ChangeLog,
+ source/headers/geos/operation/overlay/OverlayOp.h,
source/operation/overlay/OverlayOp.cpp: added checks for
obviously wrong result of difference and intersection ops
-2006-06-27 15:59 strk
+2006-06-27 15:59 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/algorithm/HCoordinate.cpp: *
+ * [r1677] ChangeLog, source/algorithm/HCoordinate.cpp: *
source/algorithm/HCoordinate.cpp: added support for MingW -ansi
builds.
-2006-06-27 15:26 strk
+2006-06-27 15:26 Sandro Santilli <strk at keybit.net>
- fixed forward declaration of GEOSCoordSeq_getOrdinate.
+ * [r1676] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in: *
+ capi/geos_c.cpp: fixed forward declaration of
+ GEOSCoordSeq_getOrdinate.
* capi/geos_c.h.in: renamed GEOSGeomTypeId enum to GEOSGeomTypes,
to make VC++ 2005 happy.
-2006-06-19 23:33 strk
+2006-06-19 23:33 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/geom/CoordinateFilter.h,
+ * [r1675] ChangeLog, source/headers/geos/geom/CoordinateFilter.h,
source/headers/geos/noding/ScaledNoder.h,
source/headers/geos/util/CoordinateArrayFilter.h,
source/headers/geos/util/UniqueCoordinateArrayFilter.h,
source/noding/ScaledNoder.cpp: Don't *require* CoordinateFilters
to define both read-only and read-write methods.
-2006-06-19 22:52 strk
+2006-06-19 22:52 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/geom/Polygon.cpp: optimized loops
+ * [r1674] ChangeLog, source/geom/Polygon.cpp: optimized loops
-2006-06-19 21:20 strk
+2006-06-19 21:20 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/geom/util/GeometryTransformer.cpp,
+ * [r1673] ChangeLog, source/geom/util/GeometryTransformer.cpp,
source/headers/geos/geom/util/GeometryTransformer.h: updated port
info
-2006-06-19 21:17 strk
+2006-06-19 21:17 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/geom/GeometryFactory.cpp,
+ * [r1672] ChangeLog, source/geom/GeometryFactory.cpp,
source/headers/geos/geom/GeometryFactory.inl: port info and
doxygen dox.
-2006-06-19 20:48 strk
+2006-06-19 20:48 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/xmltester/XMLTester.cpp: parseCase(): make sure
- to exit the <case> tag before returning
+ * [r1671] ChangeLog, tests/xmltester/XMLTester.cpp: parseCase():
+ make sure to exit the <case> tag before returning
-2006-06-14 19:27 strk
+2006-06-14 19:27 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/geom/Coordinate.cpp,
+ * [r1670] ChangeLog, source/geom/Coordinate.cpp,
source/headers/geos/geom/Coordinate.h,
source/headers/geos/geom/Coordinate.inl: Let the compiler
synthetize copy ctor and assignment op for Coordinate class to
obtain better numerical stability.
-2006-06-14 19:19 strk
+2006-06-14 19:19 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/xmltester/XMLTester.cpp: Added support for
- "AreaTest" operations.
+ * [r1669] ChangeLog, tests/xmltester/XMLTester.cpp: Added support
+ for "AreaTest" operations.
-2006-06-14 19:17 strk
+2006-06-14 19:17 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/operation/overlay/PolygonBuilder.cpp: Fixed bug
- in findShell() needlessly erasing vector elements
+ * [r1668] ChangeLog, source/operation/overlay/PolygonBuilder.cpp:
+ Fixed bug in findShell() needlessly erasing vector elements
-2006-06-14 15:38 strk
+2006-06-14 15:38 Sandro Santilli <strk at keybit.net>
- * source/operation/overlay/OverlayOp.cpp: Fixed just-introduced bug
+ * [r1667] source/operation/overlay/OverlayOp.cpp: Fixed
+ just-introduced bug
-2006-06-14 15:03 strk
+2006-06-14 15:03 Sandro Santilli <strk at keybit.net>
+ * [r1666] ChangeLog, source/operation/overlay/OverlayOp.cpp: *
source/operation/overlay/OverlayOp.cpp: use NodeMap::container
and related typedefs, removed (int) casts, optimized loops.
-2006-06-14 14:32 strk
+2006-06-14 14:32 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/geomgraph/EdgeEnd.cpp,
+ * [r1665] ChangeLog, source/geomgraph/EdgeEnd.cpp,
source/headers/geos/geomgraph/DirectedEdge.h,
source/headers/geos/geomgraph/DirectedEdge.inl,
source/headers/geos/geomgraph/EdgeEnd.h: EdgeEnd::getEdge() made
non-virtual and inlined.
-2006-06-14 13:59 strk
+2006-06-14 13:59 Sandro Santilli <strk at keybit.net>
- in PolygonBuilder::placePolygonHoles, performance improved as a
- side effect.
+ * [r1664] ChangeLog, source/operation/overlay/PolygonBuilder.cpp:
+ Fixed bug in PolygonBuilder::placePolygonHoles, performance
+ improved as a side effect.
-2006-06-13 23:26 strk
+2006-06-13 23:26 Sandro Santilli <strk at keybit.net>
- * ChangeLog,
+ * [r1663] ChangeLog,
source/headers/geos/operation/overlay/PolygonBuilder.h,
source/operation/overlay/PolygonBuilder.cpp: cleanups
-2006-06-13 22:50 strk
+2006-06-13 22:50 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/io/WKTReader.inl: *
+ * [r1662] ChangeLog, source/headers/geos/io/WKTReader.inl: *
source/headers/geos/io/WKTReader.inl: added missing include for
GEOS_DEBUG set case, use stderr for debugging output.
-2006-06-13 22:19 strk
+2006-06-13 22:19 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/operation/overlay/LineBuilder.cpp: fixed unused
- parameter warning
+ * [r1661] ChangeLog, source/operation/overlay/LineBuilder.cpp:
+ fixed unused parameter warning
-2006-06-13 22:00 strk
+2006-06-13 22:00 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/geomgraph/GeometryGraph.h: Changed
- GeometryGraph::lineEdgeMap set comparison function to be
+ * [r1660] ChangeLog, source/headers/geos/geomgraph/GeometryGraph.h:
+ Changed GeometryGraph::lineEdgeMap set comparison function to be
pointer-based. Should be safe and much faster. Available tests
all succeed.
-2006-06-13 21:42 strk
+2006-06-13 21:42 Sandro Santilli <strk at keybit.net>
- * source/operation/overlay/OverlayOp.cpp: trimmed cvs log, cleanups
+ * [r1659] source/operation/overlay/OverlayOp.cpp: trimmed cvs log,
+ cleanups
-2006-06-13 21:40 strk
+2006-06-13 21:40 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/GeometryGraph.cpp: Cleanups and some more
- debugging lines
+ * [r1658] source/geomgraph/GeometryGraph.cpp: Cleanups and some
+ more debugging lines
-2006-06-13 21:38 strk
+2006-06-13 21:38 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/geom/Geometry.cpp: Added self comparison check
- in Geometry::compareTo().
+ * [r1657] ChangeLog, source/geom/Geometry.cpp: Added self
+ comparison check in Geometry::compareTo().
-2006-06-13 19:16 strk
+2006-06-13 19:16 Sandro Santilli <strk at keybit.net>
- * ChangeLog: fixed mis-assigned commit
+ * [r1656] ChangeLog: fixed mis-assigned commit
-2006-06-12 17:18 strk
+2006-06-12 17:18 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/simplify/LineSegmentIndex.cpp:
+ * [r1655] ChangeLog, source/simplify/LineSegmentIndex.cpp:
LineSegmentIndex: explicitly initialized parent class in
constructors.
-2006-06-12 17:15 strk
+2006-06-12 17:15 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/index/quadtree/Root.h,
+ * [r1654] ChangeLog, source/headers/geos/index/quadtree/Root.h,
source/headers/geos/operation/distance/ConnectedElementPointFilter.h,
source/headers/geos/operation/polygonize/Polygonizer.h: Removed
unused parameters warning
-2006-06-12 17:14 strk
+2006-06-12 17:14 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/geom/GeometryFilter.h: added
- assert(0) version of filter_ro() and filter_rw() to allow
+ * [r1653] ChangeLog, source/headers/geos/geom/GeometryFilter.h:
+ added assert(0) version of filter_ro() and filter_rw() to allow
implementations to only defined the required one.
-2006-06-12 16:59 strk
+2006-06-12 16:59 Sandro Santilli <strk at keybit.net>
- * tests/bigtest/TestSweepLineSpeed.cpp,
+ * [r1652] tests/bigtest/TestSweepLineSpeed.cpp,
tests/xmltester/SimpleWKTTester.cpp: Removed unused parameter
warnings
-2006-06-12 16:57 strk
+2006-06-12 16:57 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/planargraph/Node.h: Added note about
+ * [r1651] source/headers/geos/planargraph/Node.h: Added note about
ownership of return from getEdgesBetween()
-2006-06-12 16:55 strk
+2006-06-12 16:55 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/io/WKTWriter.h,
+ * [r1650] ChangeLog, source/headers/geos/io/WKTWriter.h,
source/io/WKTWriter.cpp: fixed compiler warnings, fixed some
methods to omit unused parameters.
-2006-06-12 16:51 strk
+2006-06-12 16:51 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/geom/CoordinateSequence.cpp,
+ * [r1649] ChangeLog, source/geom/CoordinateSequence.cpp,
source/headers/geos/geom/CoordinateSequence.h,
tests/unit/geom/CoordinateArraySequenceTest.cpp: Added equality
and inequality operators and tests
-2006-06-12 16:36 strk
+2006-06-12 16:36 Sandro Santilli <strk at keybit.net>
+ * [r1648] ChangeLog, source/geom/CoordinateSequence.cpp,
source/headers/geos/geom/CoordinateSequence.h: indentation, notes
about things to be fixed.
-2006-06-12 15:47 strk
+2006-06-12 15:47 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/planargraph/Node.cpp: implemented missing
- getEdgesBetween() method (untested).
+ * [r1647] ChangeLog, source/planargraph/Node.cpp: implemented
+ missing getEdgesBetween() method (untested).
-2006-06-12 15:46 strk
+2006-06-12 15:46 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/planargraph/DirectedEdge.h,
+ * [r1646] source/headers/geos/planargraph/DirectedEdge.h,
source/planargraph/DirectedEdge.cpp: provided a memory friendly
version of toEdges() method.
-2006-06-12 15:07 strk
+2006-06-12 15:07 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/geom/CoordinateArraySequence.cpp: explicitly
- invoked CoordinateSequence (copy) ctor - suggested by GCC
- warning.
+ * [r1645] ChangeLog, source/geom/CoordinateArraySequence.cpp:
+ explicitly invoked CoordinateSequence (copy) ctor - suggested by
+ GCC warning.
-2006-06-12 15:06 strk
+2006-06-12 15:06 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom/CoordinateSequence.h: Added default ctor
- and copy ctor (protected)
+ * [r1644] source/headers/geos/geom/CoordinateSequence.h: Added
+ default ctor and copy ctor (protected)
-2006-06-12 13:57 strk
+2006-06-12 13:57 Sandro Santilli <strk at keybit.net>
- * ChangeLog, acsite.m4, configure.in,
+ * [r1643] ChangeLog, acsite.m4, configure.in,
source/headers/geos/platform.h.in: Check for int64_t type for
int64 typedef.
-2006-06-12 11:29 strk
+2006-06-12 11:29 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/algorithm/SimplePointInAreaLocator.cpp,
+ * [r1642] ChangeLog, source/algorithm/SimplePointInAreaLocator.cpp,
source/geomgraph/EdgeNodingValidator.cpp,
source/geomgraph/GeometryGraph.cpp,
@@ -8265,9 +8469,9 @@
source/simplify/TaggedLineString.cpp, source/util/Profiler.cpp:
unsigned int => size_t
-2006-06-12 10:49 strk
+2006-06-12 10:49 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/algorithm/ConvexHull.cpp,
+ * [r1641] ChangeLog, source/algorithm/ConvexHull.cpp,
source/algorithm/PointLocator.cpp, source/geom/Envelope.cpp,
source/geom/LineString.cpp,
source/headers/geos/geom/LineString.h,
@@ -8284,14 +8488,14 @@
source/operation/linemerge/LineSequencer.cpp,
source/planargraph/PlanarGraph.cpp: unsigned int => size_t
-2006-06-12 10:39 strk
+2006-06-12 10:39 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/xmltester/XMLTester.cpp: don't print test file
- precision model if verbosity level < 2.
+ * [r1640] ChangeLog, tests/xmltester/XMLTester.cpp: don't print
+ test file precision model if verbosity level < 2.
-2006-06-12 10:10 strk
+2006-06-12 10:10 Sandro Santilli <strk at keybit.net>
- * ChangeLog, NEWS, capi/geos_c.h.in,
+ * [r1639] ChangeLog, NEWS, capi/geos_c.h.in,
source/algorithm/CGAlgorithms.cpp,
source/geom/CoordinateArraySequence.cpp,
source/geom/CoordinateSequence.cpp, source/geom/Geometry.cpp,
@@ -8311,30 +8515,31 @@
getGeometryN() to take size_t rather then int, changed unsigned
int parameters to size_t.
-2006-06-09 08:28 strk
+2006-06-09 08:28 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/SimpleWKTTester.cpp: Removed compiler warning
+ * [r1638] tests/xmltester/SimpleWKTTester.cpp: Removed compiler
+ warning
-2006-06-09 08:17 strk
+2006-06-09 08:17 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/unit/noding/SegmentStringTest.cpp: removed
- signed/unsigned comparison warnings.
+ * [r1637] ChangeLog, tests/unit/noding/SegmentStringTest.cpp:
+ removed signed/unsigned comparison warnings.
-2006-06-09 08:09 strk
+2006-06-09 08:09 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/unit/geom/LinearRingTest.cpp,
+ * [r1636] ChangeLog, tests/unit/geom/LinearRingTest.cpp,
tests/unit/geom/MultiPointTest.cpp,
tests/unit/geom/PolygonTest.cpp: removed signed/unsigned
-2006-06-09 08:02 strk
+2006-06-09 08:02 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/unit/geom/LineStringTest.cpp: Fixed
+ * [r1635] ChangeLog, tests/unit/geom/LineStringTest.cpp: Fixed
signed/unsigned comparison tests
-2006-06-09 07:42 strk
+2006-06-09 07:42 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/geomgraph/GeometryGraph.cpp,
+ * [r1634] ChangeLog, source/geomgraph/GeometryGraph.cpp,
source/operation/buffer/OffsetCurveSetBuilder.cpp,
source/operation/valid/RepeatedPointTester.cpp: *
@@ -8345,60 +8550,62 @@
after Polygon ring accessor methods changed to work with size_t.
Small optimizations in loops.
-2006-06-09 06:41 strk
+2006-06-09 06:41 Sandro Santilli <strk at keybit.net>
- * ChangeLog: Added missing log for mloskot change
+ * [r1633] ChangeLog: Added missing log for mloskot change
-2006-06-08 18:50 mloskot
+2006-06-08 18:50 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/geom/DimensionTest.cpp: Fixed no-effect warning in
- test<1> from DimensionTest.cpp.
+ * [r1632] tests/unit/geom/DimensionTest.cpp: Fixed no-effect
+ warning in test<1> from DimensionTest.cpp.
-2006-06-08 18:18 strk
+2006-06-08 18:18 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/unit/geom/GeometryFactoryTest.cpp: *
+ * [r1631] ChangeLog, tests/unit/geom/GeometryFactoryTest.cpp: *
tests/unit/geom/GeometryFactoryTest.cpp: fixed compiler warnings
about signed/unsigned comparisons.
-2006-06-08 17:58 strk
+2006-06-08 17:58 Sandro Santilli <strk at keybit.net>
- * ChangeLog, NEWS, source/algorithm/CentroidArea.cpp,
+ * [r1630] ChangeLog, NEWS, source/algorithm/CentroidArea.cpp,
source/geom/Polygon.cpp, source/geom/util/GeometryEditor.cpp,
source/headers/geos/geom/Polygon.h, source/io/WKTWriter.cpp:
Polygon::getNumInteriorRing() return size_t,
Polygon::interiorRingN() takes size_t.
-2006-06-08 17:46 strk
+2006-06-08 17:46 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/unit/geom/CoordinateArraySequenceTest.cpp: *
+ * [r1629] ChangeLog,
+ tests/unit/geom/CoordinateArraySequenceTest.cpp: *
tests/unit/geom/CoordinateArraySequenceTest.cpp: fix
signed/unsigned comparison warning.
-2006-06-08 15:55 strk
+2006-06-08 15:55 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/xmltester/markup/MarkupSTL.cpp: *
+ * [r1628] ChangeLog, tests/xmltester/markup/MarkupSTL.cpp: *
tests/xmltester/markup/MarkupSTL.cpp: removed use of
allocator<char>, which brings in some incompatibilities with
libstdc++ 6.0.7 (gcc 4.0.2).
-2006-06-08 13:19 strk
+2006-06-08 13:19 Sandro Santilli <strk at keybit.net>
- * configure.in: Commented out ruby and python detection
+ * [r1627] configure.in: Commented out ruby and python detection
-2006-06-08 12:58 strk
+2006-06-08 12:58 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/Makefile.am, tests/xmltester/testrunner.sh: Fixed
- xml testrunner rule
+ * [r1626] tests/xmltester/Makefile.am,
+ tests/xmltester/testrunner.sh: Fixed xml testrunner rule
-2006-06-08 12:16 strk
+2006-06-08 12:16 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/xmltester/Makefile.am,
+ * [r1625] ChangeLog, tests/xmltester/Makefile.am,
tests/xmltester/testrunner.sh: added XML tests run to the 'make
check' rule.
-2006-06-08 11:20 strk
+2006-06-08 11:20 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/geom/CoordinateSequenceFactory.h,
+ * [r1624] ChangeLog,
+ source/headers/geos/geom/CoordinateSequenceFactory.h,
source/headers/geos/geom/GeometryComponentFilter.h,
source/headers/geos/geom/GeometryFilter.h,
source/headers/geos/geom/util/CoordinateOperation.h,
@@ -8410,66 +8617,68 @@
source/headers/geos/index/sweepline/SweepLineOverlapAction.h:
Added missing virtual destructor to abstract classes.
-2006-06-07 20:04 strk
+2006-06-07 20:04 Sandro Santilli <strk at keybit.net>
- * ChangeLog, configure.in: * configure.in: enforce -Wall -ansi
- -pedantic -Wno-long-long to C and CXX flags.
+ * [r1623] ChangeLog, configure.in: * configure.in: enforce -Wall
+ -ansi -pedantic -Wno-long-long to C and CXX flags.
-2006-06-07 19:45 strk
+2006-06-07 19:45 Sandro Santilli <strk at keybit.net>
- * swig/ruby/test/Makefile.am: Renamed (reserved) TESTS variable to
- RUBY_TESTS
+ * [r1622] swig/ruby/test/Makefile.am: Renamed (reserved) TESTS
+ variable to RUBY_TESTS
-2006-06-07 19:26 strk
+2006-06-07 19:26 Sandro Santilli <strk at keybit.net>
- * Makefile.am: Fixed SUBDIRS order, and added a NOTE about
+ * [r1621] Makefile.am: Fixed SUBDIRS order, and added a NOTE about
maintaining it.
-2006-06-07 17:03 strk
+2006-06-07 17:03 Sandro Santilli <strk at keybit.net>
- * ChangeLog, Makefile.am, configure.in, swig/python/Makefile.am,
- swig/ruby/Makefile.am, swig/ruby/test/Makefile.am: * Makefile.am,
- configure.in, swig/python/Makefile.am, swig/ruby/Makefile.am,
+ * [r1620] ChangeLog, Makefile.am, configure.in,
+ swig/python/Makefile.am, swig/ruby/Makefile.am,
+ swig/ruby/test/Makefile.am: * Makefile.am, configure.in,
swig/ruby/test/Makefile.am: swig removed from automatic build
process.
* configure.in: removed check for boost availability.
-2006-06-07 16:07 strk
+2006-06-07 16:07 Sandro Santilli <strk at keybit.net>
- * configure.in: Set release version to 3.0.0rc1
+ * [r1619] configure.in: Set release version to 3.0.0rc1
-2006-06-07 14:10 mloskot
+2006-06-07 14:10 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog, tests/unit/Makefile.am: Update ChangeLog with info
- about new test case isPointInRingTest.cpp.
+ * [r1618] ChangeLog, tests/unit/Makefile.am: Update ChangeLog with
+ info about new test case isPointInRingTest.cpp.
-2006-06-07 14:06 mloskot
+2006-06-07 14:06 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/algorithm/CGAlgorithms/isPointInRing.cpp,
+ * [r1617] tests/unit/algorithm/CGAlgorithms/isPointInRing.cpp,
tests/unit/algorithm/CGAlgorithms/isPointInRingTest.cpp: Renamed
file isPointInRing.cpp to isPointInRingTest.cpp to follow GEOS
Unit Test convention.
-2006-06-07 13:52 mloskot
+2006-06-07 13:52 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/Makefile.am, tests/unit/algorithm/CGAlgorithms,
+ * [r1616] tests/unit/Makefile.am,
+ tests/unit/algorithm/CGAlgorithms,
tests/unit/algorithm/CGAlgorithms/isPointInRing.cpp: Added new
test: CGAlgorithms/isPointInRing.cpp.
-2006-06-07 13:10 strk
+2006-06-07 13:10 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/geom.h: Removed Triangle.h include
- from geom.h
+ * [r1615] ChangeLog, source/headers/geos/geom.h: Removed Triangle.h
+ include from geom.h
-2006-06-07 13:08 strk
+2006-06-07 13:08 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/geom/Makefile.am: *
+ * [r1614] ChangeLog, source/headers/geos/geom/Makefile.am: *
source/headers/geos/geom/Makefile.am: removed Triangle.h from
installed header set.
-2006-06-05 19:42 strk
+2006-06-05 19:42 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/Makefile.am,
+ * [r1613] ChangeLog, source/headers/geos/Makefile.am,
source/headers/geos/algorithm/Makefile.am,
source/headers/geos/geom/util/Makefile.am,
@@ -8508,10 +8717,10 @@
source/headers/geos/util.h, source/headers/geos/util/Makefile.am:
Fixed noinst_geos_HEADERS => noinst_HEADERS.
-2006-06-05 15:36 strk
+2006-06-05 15:36 Sandro Santilli <strk at keybit.net>
- * ChangeLog, NEWS, capi/geos_c.cpp, source/geom/Geometry.cpp,
- source/headers/geos/noding.h,
+ * [r1612] ChangeLog, NEWS, capi/geos_c.cpp,
+ source/geom/Geometry.cpp, source/headers/geos/noding.h,
source/headers/geos/noding/Makefile.am,
source/headers/geos/operation/overlay/LineBuilder.h,
@@ -8523,19 +8732,19 @@
name and renamed values to have a lowercase prefix. Drop all of
noding headers from installed header set.
-2006-06-03 22:31 hobu
+2006-06-03 22:31 Howard Butler <hobu.inc at gmail.com>
- * source/Makefile.vc: update to track latest removals
+ * [r1611] source/Makefile.vc: update to track latest removals
-2006-06-03 22:29 hobu
+2006-06-03 22:29 Howard Butler <hobu.inc at gmail.com>
- * source/simplify/DouglasPeuckerLineSimplifier.cpp: Use a fully
- qualified namespace for LineSegment because we're inside of
+ * [r1610] source/simplify/DouglasPeuckerLineSimplifier.cpp: Use a
+ fully qualified namespace for LineSegment because we're inside of
geos::simplify at the time
-2006-06-01 11:49 strk
+2006-06-01 11:49 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/geomgraph.h,
+ * [r1609] ChangeLog, source/headers/geos/geomgraph.h,
source/headers/geos/geomgraph/Makefile.am,
source/headers/geos/geomgraph/Node.h,
source/headers/geos/geomgraph/PlanarGraph.h,
@@ -8551,9 +8760,9 @@
source/io/WKTWriter.cpp, source/io/Writer.cpp: Reduced installed
headers form geomgraph namespace
-2006-06-01 10:28 strk
+2006-06-01 10:28 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/index/bintree/Makefile.am,
+ * [r1608] ChangeLog, source/headers/geos/index/bintree/Makefile.am,
source/headers/geos/index/chain/Makefile.am,
source/headers/geos/index/quadtree/Makefile.am,
source/headers/geos/index/strtree/Makefile.am,
@@ -8567,38 +8776,38 @@
source/operation/valid/Makefile.am: Reduced number of installed
headers for the geos::index namespace
-2006-05-25 18:44 strk
+2006-05-25 18:44 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/unit/geom/TriangleTest.cpp: *
+ * [r1607] ChangeLog, tests/unit/geom/TriangleTest.cpp: *
tests/unit/geom/TriangleTest.cpp: take floating-point rounding
error into account.
-2006-05-25 16:11 mloskot
+2006-05-25 16:11 Mateusz Loskot <mateusz at loskot.net>
- * tests/tut/tut.h: Changed precision constant with epsilon() from
- std::numeric_limits.
+ * [r1606] tests/tut/tut.h: Changed precision constant with
+ epsilon() from std::numeric_limits.
-2006-05-25 15:54 mloskot
+2006-05-25 15:54 Mateusz Loskot <mateusz at loskot.net>
- * tests/tut/tut.h: Added specialization of ensure_equals for double
- type.
+ * [r1605] tests/tut/tut.h: Added specialization of ensure_equals
+ for double type.
-2006-05-24 16:29 strk
+2006-05-24 16:29 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/index/quadtree/DoubleBits.cpp: *
+ * [r1604] ChangeLog, source/index/quadtree/DoubleBits.cpp: *
source/index/quadtree/DoubleBits.cpp: handled negative or zero
values in getExponent().
-2006-05-24 16:01 strk
+2006-05-24 16:01 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/unit/utility.h: * tests/unit/utility.h: fixed
- missing return from isSameStructure's specialization on
+ * [r1603] ChangeLog, tests/unit/utility.h: * tests/unit/utility.h:
+ fixed missing return from isSameStructure's specialization on
GeometryCollection, also fixed a signed/unsigned mismatch warning
there.
-2006-05-24 15:42 strk
+2006-05-24 15:42 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/util/CoordinateArrayFiter.cpp,
+ * [r1602] ChangeLog, source/util/CoordinateArrayFiter.cpp,
source/util/GEOSException.cpp, source/util/Makefile.am,
source/util/UniqueCoordinateArrayFilter.cpp: *
source/util/Makefile.am, source/util/CoordinateArrayFiter.cpp,
@@ -8606,16 +8815,17 @@
source/util/UniqueCoordinateArrayFilter.cpp: removed empty
implementation files.
-2006-05-24 15:32 strk
+2006-05-24 15:32 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/simplify/TaggedLinesSimplifier.h:
- * source/headers/geos/simplify/TaggedLinesSimplifier.h: added
+ * [r1601] ChangeLog,
+ source/headers/geos/simplify/TaggedLinesSimplifier.h: *
+ source/headers/geos/simplify/TaggedLinesSimplifier.h: added
LineSegmentIndex.h include so that every use of the templated
simplify() function get all the required definitions.
-2006-05-24 15:17 strk
+2006-05-24 15:17 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/algorithm/Makefile.am,
+ * [r1600] ChangeLog, source/headers/geos/algorithm/Makefile.am,
source/headers/geos/opLinemerge.h,
@@ -8629,17 +8839,18 @@
source/headers/geos/planargraph/Makefile.am: Reduced number of
installed headers in geos/operation/ subdir
-2006-05-24 13:44 strk
+2006-05-24 13:44 Sandro Santilli <strk at keybit.net>
- * NEWS: Added a note about unit tests being introduced
+ * [r1599] NEWS: Added a note about unit tests being introduced
-2006-05-24 11:44 mloskot
+2006-05-24 11:44 Mateusz Loskot <mateusz at loskot.net>
- * ChangeLog: Added missing entries to ChangeLog.
+ * [r1598] ChangeLog: Added missing entries to ChangeLog.
-2006-05-24 11:41 strk
+2006-05-24 11:41 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/simplify/TaggedLinesSimplifier.h,
+ * [r1597] ChangeLog,
+ source/headers/geos/simplify/TaggedLinesSimplifier.h,
source/simplify/TaggedLinesSimplifier.cpp,
source/simplify/TopologyPreservingSimplifier.cpp: *
@@ -8650,145 +8861,149 @@
class to more closely match JTS and use templated
functions.
-2006-05-24 08:32 strk
+2006-05-24 08:32 Sandro Santilli <strk at keybit.net>
- * ChangeLog, capi/geos_c.h.in: * capi/geos_c.h.in: #include
+ * [r1596] ChangeLog, capi/geos_c.h.in: * capi/geos_c.h.in: #include
<stddef.h> to get size_t definition (only #ifndef __cplusplus)
-2006-05-24 05:53 mloskot
+2006-05-24 05:53 Mateusz Loskot <mateusz at loskot.net>
+ * [r1595] tests/unit/Makefile.am,
tests/unit/simplify/TopologyPreservingSimplifierTest.cpp,
tests/unit/utility.h: Added new test:
TopologyPreservingSimplifierTest.cpp. Added new utility.cpp
helper for Unit Tests (implementes utils from JTS Unit Tests).
-2006-05-23 15:06 strk
+2006-05-23 15:06 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/geom/Coordinate.h: *
+ * [r1594] ChangeLog, source/headers/geos/geom/Coordinate.h: *
source/headers/geos/geom/Coordinate.h: added missing <string>
include.
-2006-05-23 14:44 strk
+2006-05-23 14:44 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/config.h: *
+ * [r1593] ChangeLog, source/headers/geos/config.h: *
source/headers/geos/config.h: removed file which is not supposed
to be in the repository.
-2006-05-23 14:29 strk
+2006-05-23 14:29 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/index/quadtree/DoubleBits.h,
+ * [r1592] ChangeLog,
+ source/headers/geos/index/quadtree/DoubleBits.h,
source/index/quadtree/DoubleBits.cpp: const correctness and
documentation.
-2006-05-23 13:21 strk
+2006-05-23 13:21 Sandro Santilli <strk at keybit.net>
- * tests/unit/io/ByteOrderValuesTest.cpp: Added test for put/get
- Long values
+ * [r1591] tests/unit/io/ByteOrderValuesTest.cpp: Added test for
+ put/get Long values
-2006-05-23 13:16 strk
+2006-05-23 13:16 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/io/WKBWriter.cpp: Fixed a bug in
+ * [r1590] ChangeLog, source/io/WKBWriter.cpp: Fixed a bug in
WKBWriter::writeByteOrder() failing to consider machine's byte
order
-2006-05-23 12:57 strk
+2006-05-23 12:57 Sandro Santilli <strk at keybit.net>
- * tests/unit/geom/CoordinateTest.cpp: Fixed small typo in label
+ * [r1589] tests/unit/geom/CoordinateTest.cpp: Fixed small typo in
+ label
-2006-05-23 12:33 strk
+2006-05-23 12:33 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/io/ByteOrderValues.cpp: *
+ * [r1588] ChangeLog, source/io/ByteOrderValues.cpp: *
source/io/ByteOrderValues.cpp: fixed bug in putLong() also
affecting putDouble()
-2006-05-23 12:23 strk
+2006-05-23 12:23 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/unit/Makefile.am,
+ * [r1587] ChangeLog, tests/unit/Makefile.am,
tests/unit/io/ByteOrderValuesTest.cpp: * tests/unit/Makefile.am,
tests/unit/io/ByteOrderValuesTest.cpp: unit test for
ByteOrderValues class.
-2006-05-23 11:07 strk
+2006-05-23 11:07 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/io/WKBWriter.cpp: * source/io/WKBWriter.cpp:
- fixed bug in ::writeInt missing to honour the requested byte
- order.
+ * [r1586] ChangeLog, source/io/WKBWriter.cpp: *
+ source/io/WKBWriter.cpp: fixed bug in ::writeInt missing to
+ honour the requested byte order.
-2006-05-23 10:56 strk
+2006-05-23 10:56 Sandro Santilli <strk at keybit.net>
- * tests/unit/io/WKBReaderTest.cpp: Fixed top comment
+ * [r1585] tests/unit/io/WKBReaderTest.cpp: Fixed top comment
-2006-05-23 10:48 strk
+2006-05-23 10:48 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/unit/io/WKBReaderTest.cpp: *
+ * [r1584] ChangeLog, tests/unit/io/WKBReaderTest.cpp: *
tests/unit/io/WKBReaderTest.cpp: cleaned up and added both XDR
and NDR tests.
-2006-05-23 09:24 strk
+2006-05-23 09:24 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/io/WKBConstants.h,
+ * [r1583] ChangeLog, source/headers/geos/io/WKBConstants.h,
source/io/ByteOrderValues.cpp: * source/io/ByteOrderValues.cpp:
changed ENDIAN_BIG and ENDIAN_LITTLE values to match
WKBConstants::XDR and WKBConstants::NDR respectively.
* source/headers/geos/io/WKBConstants.h: added comments about
meaning of XDR/NDR.
-2006-05-22 15:08 strk
+2006-05-22 15:08 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/util/GEOSException.h: Print colon after
- exception name (as it has always been)
+ * [r1582] source/headers/geos/util/GEOSException.h: Print colon
+ after exception name (as it has always been)
-2006-05-19 17:44 strk
+2006-05-19 17:44 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/simplify/TopologyPreservingSimplifier.cpp: *
+ * [r1581] ChangeLog,
+ source/simplify/TopologyPreservingSimplifier.cpp: *
removed friend specification in
TopologyPreservingSimplifier helper class
(no more needed)
-2006-05-19 17:39 strk
+2006-05-19 17:39 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/unit/geom/Geometry/coversTest.cpp: *
+ * [r1580] ChangeLog, tests/unit/geom/Geometry/coversTest.cpp: *
keep tests in 'tut' namespace.
-2006-05-19 16:38 strk
+2006-05-19 16:38 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/xmltester/XMLTester.cpp: *
+ * [r1579] ChangeLog, tests/xmltester/XMLTester.cpp: *
tests/xmltester/XMLTester.cpp: report
error on load of requested tests.
-2006-05-18 10:19 strk
+2006-05-18 10:19 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/geom.h: *
+ * [r1578] ChangeLog, source/headers/geos/geom.h: *
source/headers/geos/geom.h: fixed doxygen header for mainpage.
-2006-05-18 10:16 strk
+2006-05-18 10:16 Sandro Santilli <strk at keybit.net>
- * NEWS: Added note about the new BinaryOp class and its uses.
+ * [r1577] NEWS: Added note about the new BinaryOp class and its
+ uses.
-2006-05-18 10:13 strk
+2006-05-18 10:13 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/geom/BinaryOp.h: *
+ * [r1576] ChangeLog, source/headers/geos/geom/BinaryOp.h: *
source/headers/geos/geom/BinaryOp.h: added compile-time defines
to avoid precision-reduction and simplify based policies (default
to enabled).
-2006-05-18 09:32 strk
+2006-05-18 09:32 Sandro Santilli <strk at keybit.net>
- * NEWS: added note about new Geometry predicates
+ * [r1575] NEWS: added note about new Geometry predicates
-2006-05-18 09:00 strk
+2006-05-18 09:00 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/unit/geom/Geometry/coversTest.cpp: Added tests
- for coveredBy(), fixed ChangeLog entry
+ * [r1574] ChangeLog, tests/unit/geom/Geometry/coversTest.cpp: Added
+ tests for coveredBy(), fixed ChangeLog entry
-2006-05-18 08:56 strk
+2006-05-18 08:56 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/geom/Geometry.cpp,
+ * [r1573] ChangeLog, source/geom/Geometry.cpp,
source/headers/geos/geom/Geometry.h, tests/unit/Makefile.am,
@@ -8798,81 +9013,82 @@
added test for covers() predicates.
-2006-05-17 17:41 strk
+2006-05-17 17:41 Sandro Santilli <strk at keybit.net>
- * source/geom/IntersectionMatrix.cpp,
+ * [r1572] source/geom/IntersectionMatrix.cpp,
source/headers/geos/geom/IntersectionMatrix.h,
tests/unit/geom/IntersectionMatrixTest.cpp: Added output operator
+ test
-2006-05-17 17:24 strk
+2006-05-17 17:24 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/geom/IntersectionMatrix.cpp,
+ * [r1571] ChangeLog, source/geom/IntersectionMatrix.cpp,
source/headers/geos/geom/IntersectionMatrix.h: Added port info,
fixed isCoveredBy() comment.
-2006-05-17 17:20 strk
+2006-05-17 17:20 Sandro Santilli <strk at keybit.net>
+ * [r1570] ChangeLog, source/geom/IntersectionMatrix.cpp,
tests/unit/geom/IntersectionMatrixTest.cpp: added isCovers() and
isCoveredBy() public methods to IntersectionMatrix and associated
tests.
-2006-05-17 08:40 strk
+2006-05-17 08:40 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom/BinaryOp.h: typo fixed to make
+ * [r1569] source/headers/geos/geom/BinaryOp.h: typo fixed to make
description more clear
-2006-05-13 10:42 mloskot
+2006-05-13 10:42 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/algorithm/PointLocatorTest.cpp: Fixed line-ends in
- PointLocatorTest.cpp file.
+ * [r1563] tests/unit/algorithm/PointLocatorTest.cpp: Fixed
+ line-ends in PointLocatorTest.cpp file.
-2006-05-13 08:26 mloskot
+2006-05-13 08:26 Mateusz Loskot <mateusz at loskot.net>
- * ., .cvsignore, tests/unit, tests/unit/.cvsignore,
+ * [r1562] ., .cvsignore, tests/unit, tests/unit/.cvsignore,
tests/unit/geom/Geometry/isRectangleTest.cpp: Fixed line-ends in
isRectangleTest.cpp. Added new patterns to .cvsignore.
-2006-05-05 15:40 strk
+2006-05-05 15:40 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/noding/snapround/MCIndexSnapRounder.cpp,
+ * [r1561] ChangeLog,
+ source/noding/snapround/MCIndexSnapRounder.cpp,
source/noding/snapround/SimpleSnapRounder.cpp: Had nodind
validation error throw an exception for SimpleSnapRounder
and MCIndexSnapRounder
-2006-05-05 14:34 strk
+2006-05-05 14:34 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/unit/Makefile.am, tests/unit/noding,
+ * [r1560] ChangeLog, tests/unit/Makefile.am, tests/unit/noding,
tests/unit/noding/SegmentStringTest.cpp: New SegmentString unit
test
-2006-05-05 14:25 strk
+2006-05-05 14:25 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/noding/SegmentString.h,
+ * [r1559] source/headers/geos/noding/SegmentString.h,
source/headers/geos/noding/SegmentString.inl,
source/noding/SegmentString.cpp: moved getSegmentOctant out of
.inl into .cpp, renamed private eiList to nodeList as in JTS,
added more assertion checking and fixed doxygen comments
-2006-05-05 10:19 strk
+2006-05-05 10:19 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/noding/SegmentString.h,
+ * [r1558] ChangeLog, source/headers/geos/noding/SegmentString.h,
source/noding/SegmentNodeList.cpp: droppped
SegmentString::getContext(), new name is getData() to reflect
change in JTS
-2006-05-05 09:37 strk
+2006-05-05 09:37 Sandro Santilli <strk at keybit.net>
+ * [r1557] ChangeLog, source/headers/geos/geom.h: *
source/headers/geos/geom.h: fixed namespace qualification in
doxygen page about C++ interface.
-2006-05-04 15:49 strk
+2006-05-04 15:49 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/geom/GeometryCollection.cpp,
+ * [r1556] ChangeLog, source/geom/GeometryCollection.cpp,
source/geom/LineString.cpp, source/geom/MultiLineString.cpp,
source/geom/MultiPoint.cpp, source/geom/MultiPolygon.cpp,
source/geom/Point.cpp, source/geom/Polygon.cpp,
@@ -8889,9 +9105,9 @@
Geometry::getDimension() methods to return
Dimension::DimensionType (closes bug#93)
-2006-05-04 14:05 strk
+2006-05-04 14:05 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/geom/PrecisionModel.cpp,
+ * [r1555] ChangeLog, source/geom/PrecisionModel.cpp,
source/headers/geos/noding/snapround/HotPixel.inl,
source/headers/geos/util/math.h, source/noding/ScaledNoder.cpp: *
source/headers/geos/util/math.h: provided an util::round() method
@@ -8899,248 +9115,254 @@
function for the whole GEOS codebase. Currently pointing at
util::java_math_round() being the last being used.
-2006-05-04 13:38 strk
+2006-05-04 13:38 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geomgraph/DirectedEdge.h: doxygen comments
- cleanup
+ * [r1554] source/headers/geos/geomgraph/DirectedEdge.h: doxygen
+ comments cleanup
-2006-05-04 12:54 strk
+2006-05-04 12:54 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/geomgraph/NodeMap.h: Added
+ * [r1553] ChangeLog, source/headers/geos/geomgraph/NodeMap.h: Added
invariant tester for NodeMap class, fixed comment about ownership
of NodeFactory
-2006-05-04 12:33 strk
+2006-05-04 12:33 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferSubgraph.cpp: Added some comments
- about RightmostEdgeFinder only considering forward DirectedEdge
+ * [r1552] source/operation/buffer/BufferSubgraph.cpp: Added some
+ comments about RightmostEdgeFinder only considering forward
+ DirectedEdge
-2006-05-04 12:19 strk
+2006-05-04 12:19 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/buffer/RightmostEdgeFinder.h: Added
+ * [r1551]
+ source/headers/geos/operation/buffer/RightmostEdgeFinder.h: Added
note about findEdge() only scanning for forward DirectedEdges
-2006-05-04 12:17 strk
+2006-05-04 12:17 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/PlanarGraph.cpp: Added comment about management
- of newly created DirectedEdges
+ * [r1550] source/geomgraph/PlanarGraph.cpp: Added comment about
+ management of newly created DirectedEdges
-2006-05-04 10:15 strk
+2006-05-04 10:15 Sandro Santilli <strk at keybit.net>
- * ChangeLog,
+ * [r1549] ChangeLog,
source/headers/geos/operation/buffer/OffsetCurveSetBuilder.h:
Doxygen comments
-2006-05-04 09:16 strk
+2006-05-04 09:16 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferBuilder.cpp: Added JTS debugging,
- for comparison with JTS
+ * [r1548] source/operation/buffer/BufferBuilder.cpp: Added JTS
+ debugging, for comparison with JTS
-2006-05-04 08:42 strk
+2006-05-04 08:42 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/geom/CoordinateSequence.h: Added
- note about the CoordinateSequence::toVector() method.
+ * [r1547] ChangeLog, source/headers/geos/geom/CoordinateSequence.h:
+ Added note about the CoordinateSequence::toVector() method.
-2006-05-04 08:35 strk
+2006-05-04 08:35 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/noding/SegmentNodeList.cpp:
+ * [r1546] ChangeLog, source/noding/SegmentNodeList.cpp:
noding/SegmentNodeList.cpp: cleanups, changed output operator to
be more similar to JTS
-2006-05-04 08:30 strk
+2006-05-04 08:30 Sandro Santilli <strk at keybit.net>
- * source/noding/ScaledNoder.cpp: removed use of
+ * [r1545] source/noding/ScaledNoder.cpp: removed use of
SegmentString::setCoordinates() [dropped]
-2006-05-04 08:29 strk
+2006-05-04 08:29 Sandro Santilli <strk at keybit.net>
+ * [r1544] ChangeLog, source/headers/geos/noding/SegmentString.h,
source/headers/geos/noding/SegmentString.inl: *
SegmentString::setCoordinates().
* source/headers/geos/noding/SegmentStrign.{h,inl}: removed new
setCoordinates() interface.
-2006-05-04 07:43 strk
+2006-05-04 07:43 Sandro Santilli <strk at keybit.net>
+ * [r1543] ChangeLog, source/headers/geos/noding/SegmentString.h,
source/noding/SegmentString.cpp: output operator for
SegmentString class
-2006-05-04 07:41 strk
+2006-05-04 07:41 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/noding/SegmentNodeList.h:
+ * [r1542] ChangeLog, source/headers/geos/noding/SegmentNodeList.h:
const-correct size() method for SegmentNodeList
-2006-05-04 06:36 strk
+2006-05-04 06:36 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/noding/ScaledNoder.h: Extended definition to
- take new CoordinateSequence tracking into account
+ * [r1541] source/headers/geos/noding/ScaledNoder.h: Extended
+ definition to take new CoordinateSequence tracking into account
-2006-05-03 20:05 strk
+2006-05-03 20:05 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/noding/ScaledNoder.cpp: Added SQL debugging
- output
+ * [r1540] ChangeLog, source/noding/ScaledNoder.cpp: Added SQL
+ debugging output
-2006-05-03 19:47 strk
+2006-05-03 19:47 Sandro Santilli <strk at keybit.net>
+ * [r1539] ChangeLog, source/geom/CoordinateSequence.cpp,
source/headers/geos/geom/CoordinateSequence.h: added operator<<
for CoordinateSequence
-2006-05-03 18:04 strk
+2006-05-03 18:04 Sandro Santilli <strk at keybit.net>
+ * [r1538] ChangeLog, source/headers/geos/noding/SegmentString.h,
source/headers/geos/noding/SegmentString.inl: added
SegmentString::setCoordinates() interface
-2006-05-03 17:54 strk
+2006-05-03 17:54 Sandro Santilli <strk at keybit.net>
- * source/noding/snapround/SimpleSnapRounder.cpp: Uncommented
- correctness checker
+ * [r1537] source/noding/snapround/SimpleSnapRounder.cpp:
+ Uncommented correctness checker
-2006-05-03 17:51 strk
+2006-05-03 17:51 Sandro Santilli <strk at keybit.net>
- * source/noding/snapround/HotPixel.cpp: system headers included
- after package headers
+ * [r1536] source/noding/snapround/HotPixel.cpp: system headers
+ included after package headers
-2006-05-03 17:50 strk
+2006-05-03 17:50 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/noding/snapround/HotPixel.h:
- Doxygen comments
+ * [r1535] ChangeLog,
+ source/headers/geos/noding/snapround/HotPixel.h: Doxygen comments
-2006-05-03 17:48 strk
+2006-05-03 17:48 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/nodingSnapround.h: Forgot a slash
+ * [r1534] source/headers/geos/nodingSnapround.h: Forgot a slash
- * ChangeLog, source/headers/geos/nodingSnapround.h: Doxygen brief
+ * [r1533] ChangeLog, source/headers/geos/nodingSnapround.h: Doxygen
+ brief
-2006-05-03 16:22 hobu
+2006-05-03 16:22 Howard Butler <hobu.inc at gmail.com>
- * source/Makefile.vc: tweak clean target
+ * [r1532] source/Makefile.vc: tweak clean target
-2006-05-03 16:21 hobu
+2006-05-03 16:21 Howard Butler <hobu.inc at gmail.com>
- * source/Makefile.vc: Build the C API and shared lib separate from
- the normal lib
+ * [r1531] source/Makefile.vc: Build the C API and shared lib
+ separate from the normal lib
Add missing files
-2006-05-03 16:19 strk
+2006-05-03 16:19 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/noding/SegmentString.h: fit in 80 columns
+ * [r1530] source/headers/geos/noding/SegmentString.h: fit in 80
+ columns
-2006-05-03 16:09 hobu
+2006-05-03 16:09 Howard Butler <hobu.inc at gmail.com>
- * capi/geos_c.h.vc: Maintain a geos_c.h.vc until we come up with a
- better solution
+ * [r1529] capi/geos_c.h.vc: Maintain a geos_c.h.vc until we come up
+ with a better solution
-2006-05-03 15:50 hobu
+2006-05-03 15:50 Howard Butler <hobu.inc at gmail.com>
- * ChangeLog: *** empty log message ***
+ * [r1528] ChangeLog: *** empty log message ***
-2006-05-03 15:49 strk
+2006-05-03 15:49 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/noding/snapround/SimpleSnapRounder.cpp: fixed
- bug in SimpleSnapRounder::computeSnaps, trying to access
+ * [r1527] ChangeLog, source/noding/snapround/SimpleSnapRounder.cpp:
+ fixed bug in SimpleSnapRounder::computeSnaps, trying to access
out-of-bound vector element.
-2006-05-03 15:49 hobu
+2006-05-03 15:49 Howard Butler <hobu.inc at gmail.com>
- * source/Makefile.vc: add additional files and change names where
- necessary
+ * [r1526] source/Makefile.vc: add additional files and change names
+ where necessary
-2006-05-03 15:40 strk
+2006-05-03 15:40 Sandro Santilli <strk at keybit.net>
- * source/noding/ScaledNoder.cpp: test SegmentString invariant
- before and after scaling
+ * [r1525] source/noding/ScaledNoder.cpp: test SegmentString
+ invariant before and after scaling
-2006-05-03 15:37 strk
+2006-05-03 15:37 Sandro Santilli <strk at keybit.net>
- * ChangeLog: Tabs for indent
+ * [r1524] ChangeLog: Tabs for indent
-2006-05-03 15:32 hobu
+2006-05-03 15:32 Howard Butler <hobu.inc at gmail.com>
+ * [r1523] ChangeLog: *** empty log message ***
-2006-05-03 15:30 hobu
+2006-05-03 15:30 Howard Butler <hobu.inc at gmail.com>
- * source/headers/geos/version.h.vc: Maintain a version.h.vc until
- we come up with a better solution
+ * [r1522] source/headers/geos/version.h.vc: Maintain a version.h.vc
+ until we come up with a better solution
-2006-05-03 15:28 strk
+2006-05-03 15:28 Sandro Santilli <strk at keybit.net>
- * ChangeLog, configure.in: updated JTS_PORT to 1.7.1
+ * [r1521] ChangeLog, configure.in: updated JTS_PORT to 1.7.1
-2006-05-03 15:26 strk
+2006-05-03 15:26 Sandro Santilli <strk at keybit.net>
+ * [r1520] ChangeLog, source/headers/geos/noding/SegmentString.h,
source/headers/geos/noding/SegmentString.inl: testInvariant made
public and always inlined
-2006-05-03 15:19 strk
+2006-05-03 15:19 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/noding/snapround/HotPixel.inl:
- Changed sym_round() to java_math_round()
+ * [r1519] ChangeLog,
+ source/headers/geos/noding/snapround/HotPixel.inl: Changed
+ sym_round() to java_math_round()
-2006-05-03 15:12 strk
+2006-05-03 15:12 Sandro Santilli <strk at keybit.net>
- * source/noding/ScaledNoder.cpp: Oops, uninitialized value fix
+ * [r1518] source/noding/ScaledNoder.cpp: Oops, uninitialized value
+ fix
-2006-05-03 15:06 strk
+2006-05-03 15:06 Sandro Santilli <strk at keybit.net>
+ * [r1517] ChangeLog: Updated
- * source/headers/geos/noding/IntersectionFinderAdder.h: Better
- doxygen comment
+ * [r1516] source/headers/geos/noding/IntersectionFinderAdder.h:
+ Better doxygen comment
-2006-05-03 15:05 strk
+2006-05-03 15:05 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/RightmostEdgeFinder.cpp: Assertions
- checking
+ * [r1515] source/operation/buffer/RightmostEdgeFinder.cpp:
+ Assertions checking
-2006-05-03 15:04 strk
+2006-05-03 15:04 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/noding/ScaledNoder.h: removed reduntant port
- info
+ * [r1514] source/headers/geos/noding/ScaledNoder.h: removed
+ reduntant port info
-2006-05-03 15:02 strk
+2006-05-03 15:02 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/noding/snapround/SimpleSnapRounder.h,
+ * [r1513] source/headers/geos/noding/snapround/SimpleSnapRounder.h,
source/noding/snapround/SimpleSnapRounder.cpp: moved some
implementations from header to .cpp file (taken out of inline)
-2006-05-03 15:00 strk
+2006-05-03 15:00 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/noding/ScaledNoder.h,
+ * [r1512] source/headers/geos/noding/ScaledNoder.h,
source/noding/ScaledNoder.cpp: Fixed scale() function to remove
repeated points *after* rounding. Added brief doxygen class
description.
-2006-05-03 10:26 strk
+2006-05-03 10:26 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/operation/buffer/BufferOp.cpp: Fixed misuse of
- precision model in noder (bufferFixedPrecision)
+ * [r1511] ChangeLog, source/operation/buffer/BufferOp.cpp: Fixed
+ misuse of precision model in noder (bufferFixedPrecision)
-2006-05-03 09:46 strk
+2006-05-03 09:46 Sandro Santilli <strk at keybit.net>
- * ChangeLog: buffer headers reduction item
+ * [r1510] ChangeLog: buffer headers reduction item
-2006-05-03 09:45 strk
+2006-05-03 09:45 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/opBuffer.h,
+ * [r1509] source/headers/geos/opBuffer.h,
source/headers/geos/operation/buffer/Makefile.am: Do not install
following buffer headers: BufferBuilder.h,
OffsetCurveSetBuilder.h, BufferSubgraph.h,
SubgraphDepthLocater.h,
-2006-05-03 09:14 strk
+2006-05-03 09:14 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/noding/ScaledNoder.h,
+ * [r1508] ChangeLog, source/headers/geos/noding/ScaledNoder.h,
source/noding/ScaledNoder.cpp,
source/operation/buffer/OffsetCurveSetBuilder.cpp: *
source/operation/buffer/OffsetCurveSetBuilder.cpp: used auto_ptr
@@ -9149,59 +9371,59 @@
source/headers/geos/noding/ScaledNoder.h: ported JTS bugfix in
scale method.
-2006-05-03 08:58 strk
+2006-05-03 08:58 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/geom/CoordinateArraySequence.cpp,
+ * [r1507] ChangeLog, source/geom/CoordinateArraySequence.cpp,
source/headers/geos/geom/CoordinateArraySequence.h,
tests/unit/geom/CoordinateArraySequenceTest.cpp: added new
non-static CoordinateSequence::removeRepeatedPoints() mutator.
-2006-05-02 16:22 strk
+2006-05-02 16:22 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/noding/ScaledNoder.cpp: *
+ * [r1506] ChangeLog, source/noding/ScaledNoder.cpp: *
source/noding/ScaledNoder.cpp: use java_math_round instead of
sym_round.
-2006-05-02 14:51 strk
+2006-05-02 14:51 Sandro Santilli <strk at keybit.net>
- * source/algorithm/CGAlgorithms.cpp,
+ * [r1505] source/algorithm/CGAlgorithms.cpp,
source/headers/geos/algorithm/CGAlgorithms.h: Added port info and
fixed doxygen comments for CGAlgorithms class
-2006-05-02 14:32 strk
+2006-05-02 14:32 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/opPolygonize.h,
+ * [r1503] ChangeLog, source/headers/geos/opPolygonize.h,
source/headers/geos/operation/polygonize/EdgeRing.h,
source/headers/geos/operation/polygonize/Makefile.am,
source/operation/polygonize/EdgeRing.cpp: Added port info for
polygonize/EdgeRing class, polygonize/EdgeRing.h header
not installed.
-2006-05-02 14:22 strk
+2006-05-02 14:22 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/operation/polygonize/EdgeRing.cpp,
+ * [r1502] ChangeLog, source/operation/polygonize/EdgeRing.cpp,
source/operation/polygonize/Makefile.am,
source/operation/polygonize/polygonizeEdgeRing.cpp: *
source/operation/polygonize/: polygonizeEdgeRing.cpp renamed to
EdgeRing.cpp, to follow JTS naming.
-2006-05-02 14:01 strk
+2006-05-02 14:01 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/io/WKBReader.cpp: * source/io/WKBReader.cpp:
- fixed reads of XDR WKB.
+ * [r1500] ChangeLog, source/io/WKBReader.cpp: *
+ source/io/WKBReader.cpp: fixed reads of XDR WKB.
-2006-04-28 12:09 strk
+2006-04-28 12:09 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/Makefile.am: Added 'verbose-test' rule
+ * [r1497] tests/xmltester/Makefile.am: Added 'verbose-test' rule
-2006-04-28 12:08 strk
+2006-04-28 12:08 Sandro Santilli <strk at keybit.net>
- * NEWS: Added note about Geometry constructors
+ * [r1496] NEWS: Added note about Geometry constructors
-2006-04-28 11:56 strk
+2006-04-28 11:56 Sandro Santilli <strk at keybit.net>
+ * [r1495] ChangeLog, source/geom/GeometryFactory.cpp,
source/headers/geos/geom/GeometryFactory.h: *
@@ -9210,17 +9432,17 @@
* source/geom/Polygon.cpp: fixed getBoundary method to always
return a geometry composed by LineStrings (not LinearRings)
-2006-04-28 11:12 strk
+2006-04-28 11:12 Sandro Santilli <strk at keybit.net>
- * ChangeLog,
+ * [r1494] ChangeLog,
source/headers/geos/operation/predicate/RectangleIntersects.h,
source/operation/predicate/RectangleIntersects.cpp: removed
warnings related to change in getNumPoints() return type.
-2006-04-28 10:55 strk
+2006-04-28 10:55 Sandro Santilli <strk at keybit.net>
+ * [r1493] ChangeLog, source/geom/GeometryCollection.cpp,
@@ -9237,224 +9459,226 @@
getNumPoints() changed to return
size_t.
-2006-04-28 10:51 strk
+2006-04-28 10:51 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/unit/geom/LineStringTest.cpp,
+ * [r1492] ChangeLog, tests/unit/geom/LineStringTest.cpp,
tests/unit/geom/PointTest.cpp, tests/unit/geom/PolygonTest.cpp:
Unit tests: only construct Geoms using GeometryFactory.
-2006-04-27 15:15 strk
+2006-04-27 15:15 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/geomgraph/Node.h: Z check removed
- from invariant tester to avoid aborts due to differences in FP
- computations.
+ * [r1491] ChangeLog, source/headers/geos/geomgraph/Node.h: Z check
+ removed from invariant tester to avoid aborts due to differences
+ in FP computations.
-2006-04-27 15:07 strk
+2006-04-27 15:07 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/PlanarGraph.cpp: use output operators in
+ * [r1490] source/geomgraph/PlanarGraph.cpp: use output operators in
debugging lines
-2006-04-27 15:06 strk
+2006-04-27 15:06 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/geomgraph/NodeMap.cpp: (addNode): always use
- the Node Coordinate as a key in the map to reduce likeliness of a
- premature deletion.
+ * [r1489] ChangeLog, source/geomgraph/NodeMap.cpp: (addNode):
+ always use the Node Coordinate as a key in the map to reduce
+ likeliness of a premature deletion.
-2006-04-27 15:03 strk
+2006-04-27 15:03 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/Node.cpp: standard algorithm used in addZ() for
- vector seek
+ * [r1488] source/geomgraph/Node.cpp: standard algorithm used in
+ addZ() for vector seek
-2006-04-26 16:35 strk
+2006-04-26 16:35 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/io/StringTokenizer.cpp,
+ * [r1485] ChangeLog, source/io/StringTokenizer.cpp,
source/io/WKTReader.cpp, tests/xmltester/testLeaksBig.xml: Had
WKTReader accept correct form for MultiPoint
-2006-04-26 10:39 strk
+2006-04-26 10:39 Sandro Santilli <strk at keybit.net>
- * ChangeLog: Added mloskot item (bug#100)
+ * [r1482] ChangeLog: Added mloskot item (bug#100)
-2006-04-26 10:26 strk
+2006-04-26 10:26 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tools/geos-config.in: tools/geos-config.in: fixed
- library path to use layout detected by autoconf
+ * [r1481] ChangeLog, tools/geos-config.in: tools/geos-config.in:
+ fixed library path to use layout detected by autoconf
-2006-04-24 15:47 strk
+2006-04-24 15:47 Sandro Santilli <strk at keybit.net>
- * source/simplify/TopologyPreservingSimplifier.cpp: Public
+ * [r1480] source/simplify/TopologyPreservingSimplifier.cpp: Public
constructors change made permanent
-2006-04-23 11:58 mloskot
+2006-04-23 11:58 Mateusz Loskot <mateusz at loskot.net>
- * ., .cvsignore,
+ * [r1479] ., .cvsignore,
tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp: Small
refactoring of DouglasPeuckerSimplifierTest (prefer to use ctor
instead of operator= to create objects). Added new patterns to
.cvsignore.
-2006-04-23 11:29 mloskot
+2006-04-23 11:29 Mateusz Loskot <mateusz at loskot.net>
- * ., .cvsignore: Added new patterns to .cvsignore file.
+ * [r1478] ., .cvsignore: Added new patterns to .cvsignore file.
-2006-04-22 17:16 mloskot
+2006-04-22 17:16 Mateusz Loskot <mateusz at loskot.net>
- * source/simplify/TopologyPreservingSimplifier.cpp: Temporar fix of
- Bug #100. This report requires deeper analysis!.
+ * [r1477] source/simplify/TopologyPreservingSimplifier.cpp:
+ Temporar fix of Bug #100. This report requires deeper analysis!.
-2006-04-21 17:04 strk
+2006-04-21 17:04 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/geom/PrecisionModel.cpp: Fixed constructor by
- type to always initialize scale factor
+ * [r1476] ChangeLog, source/geom/PrecisionModel.cpp: Fixed
+ constructor by type to always initialize scale factor
-2006-04-20 16:21 strk
+2006-04-20 16:21 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/geom/BinaryOp.h: Added missing
- debugging output
+ * [r1475] ChangeLog, source/headers/geos/geom/BinaryOp.h: Added
+ missing debugging output
-2006-04-20 14:27 strk
+2006-04-20 14:27 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/algorithm/HCoordinate.cpp,
+ * [r1474] ChangeLog, source/algorithm/HCoordinate.cpp,
source/headers/geos/algorithm/HCoordinate.h: HCoordinate class
changed to use long double types internally, in order to improve
computation precision
-2006-04-20 14:16 strk
+2006-04-20 14:16 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/algorithm/LineIntersector.h: Added some more
- doxygen comments
+ * [r1473] source/headers/geos/algorithm/LineIntersector.h: Added
+ some more doxygen comments
-2006-04-20 11:11 strk
+2006-04-20 11:11 Sandro Santilli <strk at keybit.net>
+ * [r1472] ChangeLog, source/algorithm/HCoordinate.cpp:
source/algorithm/HCoordinate.cpp: added compile time define to
force storage of intermediate computation values to variables (in
order to make the -ffloat-store gcc switch effective). Disabled
by default.
-2006-04-19 09:21 strk
+2006-04-19 09:21 Sandro Santilli <strk at keybit.net>
- * TODO: Added snapround and simplify tests items
+ * [r1471] TODO: Added snapround and simplify tests items
-2006-04-19 09:20 strk
+2006-04-19 09:20 Sandro Santilli <strk at keybit.net>
- * NEWS: updated
+ * [r1470] NEWS: updated
-2006-04-14 15:34 strk
+2006-04-14 15:34 Sandro Santilli <strk at keybit.net>
- * ChangeLog, capi/geos_c.cpp: Had CAPI use new BinaryOp class in an
- aim to reduce robustness problems
+ * [r1469] ChangeLog, capi/geos_c.cpp: Had CAPI use new BinaryOp
+ class in an aim to reduce robustness problems
-2006-04-14 15:25 strk
+2006-04-14 15:25 Sandro Santilli <strk at keybit.net>
- * TODO: updated, somehow
+ * [r1468] TODO: updated, somehow
-2006-04-14 15:19 strk
+2006-04-14 15:19 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/operation/overlay/OverlayOp.cpp: removed
- precision reduction code (use BinaryOp for that)
+ * [r1467] ChangeLog, source/operation/overlay/OverlayOp.cpp:
+ removed precision reduction code (use BinaryOp for that)
-2006-04-14 15:06 strk
+2006-04-14 15:06 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom/Makefile.am: Added BinaryOp.h header
+ * [r1466] source/headers/geos/geom/Makefile.am: Added BinaryOp.h
+ header
-2006-04-14 15:04 strk
+2006-04-14 15:04 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/overlay/OverlayOp.h: fixed missing
- namespace qualification in overlay::overlayOp
+ * [r1465] source/headers/geos/operation/overlay/OverlayOp.h: fixed
+ missing namespace qualification in overlay::overlayOp
-2006-04-14 14:57 strk
+2006-04-14 14:57 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/xmltester/XMLTester.cpp: XMLTester binary ops
- invoked using the new BinaryOp template function.
+ * [r1464] ChangeLog, tests/xmltester/XMLTester.cpp: XMLTester
+ binary ops invoked using the new BinaryOp template function.
-2006-04-14 14:38 strk
+2006-04-14 14:38 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/geom/BinaryOp.h: new
+ * [r1463] ChangeLog, source/headers/geos/geom/BinaryOp.h: new
geos::Geom::BinaryOp template function implementing various
heuristics aimed at making binary geometry ops work around
robustness issues.
-2006-04-14 14:35 strk
+2006-04-14 14:35 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/operation/overlay/OverlayOp.h:
- Added overlayOp() adapter for use in templates expecting binary
- ops
+ * [r1462] ChangeLog,
+ source/headers/geos/operation/overlay/OverlayOp.h: Added
+ overlayOp() adapter for use in templates expecting binary ops
-2006-04-14 09:02 strk
+2006-04-14 09:02 Sandro Santilli <strk at keybit.net>
+ * [r1461] ChangeLog, source/algorithm/HCoordinate.cpp,
source/headers/geos/algorithm/HCoordinate.h: Hadded output
operator and debugging prints for HCoordinate.
-2006-04-13 23:57 strk
+2006-04-13 23:57 Sandro Santilli <strk at keybit.net>
- * source/operation/overlay/OverlayOp.cpp: Disables reduced
+ * [r1460] source/operation/overlay/OverlayOp.cpp: Disables reduced
precision overlayOp (is broken)
-2006-04-13 23:42 strk
+2006-04-13 23:42 Sandro Santilli <strk at keybit.net>
- * source/operation/overlay/OverlayOp.cpp: Plugged CommonBitsOp
- attempts in overlay op, before brute force precision
+ * [r1459] source/operation/overlay/OverlayOp.cpp: Plugged
+ CommonBitsOp attempts in overlay op, before brute force precision
reduction (this is likely going to change)
-2006-04-13 23:28 strk
+2006-04-13 23:28 Sandro Santilli <strk at keybit.net>
- * source/precision/CommonBitsOp.cpp: "always build before commit"
- (forgot a closing paren)
+ * [r1458] source/precision/CommonBitsOp.cpp: "always build before
+ commit" (forgot a closing paren)
-2006-04-13 23:23 strk
+2006-04-13 23:23 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/precision/CommonBitsOp.h,
+ * [r1457] ChangeLog, source/headers/geos/precision/CommonBitsOp.h,
source/precision/CommonBitsOp.cpp: fixed bug in binary ops
failing to consistently reduce operands.
-2006-04-13 21:53 strk
+2006-04-13 21:53 Sandro Santilli <strk at keybit.net>
- * capi/geostest.c: fixed bug introduced by previous commit
+ * [r1456] capi/geostest.c: fixed bug introduced by previous commit
-2006-04-13 21:52 strk
+2006-04-13 21:52 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/simplify/TaggedLineString.h,
+ * [r1455] source/headers/geos/simplify/TaggedLineString.h,
source/headers/geos/simplify/TaggedLineStringSimplifier.h,
source/simplify/TaggedLineStringSimplifier.cpp,
source/simplify/TopologyPreservingSimplifier.cpp: Many debugging
lines and assertions added. Fixed bug in TaggedLineString class.
-2006-04-13 17:09 strk
+2006-04-13 17:09 Sandro Santilli <strk at keybit.net>
- * ChangeLog, capi/geos_c.cpp: Use default GeometryFactory instance
- (finishGEOS() is a no-op now)
+ * [r1454] ChangeLog, capi/geos_c.cpp: Use default GeometryFactory
+ instance (finishGEOS() is a no-op now)
-2006-04-13 16:48 strk
+2006-04-13 16:48 Sandro Santilli <strk at keybit.net>
- * ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in, capi/geostest.c:
- Added GEOSSimplify and GEOSTopologyPreserveSimplify interfaces.
- Removed compiler warnings in geostest
+ * [r1453] ChangeLog, capi/geos_c.cpp, capi/geos_c.h.in,
+ capi/geostest.c: Added GEOSSimplify and
+ GEOSTopologyPreserveSimplify interfaces. Removed compiler
+ warnings in geostest
-2006-04-13 16:44 strk
+2006-04-13 16:44 Sandro Santilli <strk at keybit.net>
- * source/simplify/DouglasPeuckerSimplifier.cpp: Fixed a bug in
- DPTransformer handling of MultiPolygons
+ * [r1452] source/simplify/DouglasPeuckerSimplifier.cpp: Fixed a bug
+ in DPTransformer handling of MultiPolygons
-2006-04-13 16:04 strk
+2006-04-13 16:04 Sandro Santilli <strk at keybit.net>
+ * [r1451] source/headers/geos/simplify/TaggedLineString.h,
source/headers/geos/simplify/TopologyPreservingSimplifier.h,
source/simplify/Makefile.am,
source/simplify/TopologyPreservingSimplifier.cpp: Made
TopologyPreservingSimplifier implementation successfully build
-2006-04-13 14:51 strk
+2006-04-13 14:51 Sandro Santilli <strk at keybit.net>
- * ChangeLog, tests/unit/io/WKBReaderTest.cpp: Forced NDR output (to
- not rely on architecture). Removed CRs endings.
+ * [r1450] ChangeLog, tests/unit/io/WKBReaderTest.cpp: Forced NDR
+ output (to not rely on architecture). Removed CRs endings.
-2006-04-13 14:25 strk
+2006-04-13 14:25 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/geom/GeometryComponentFilter.cpp,
+ * [r1449] ChangeLog, source/geom/GeometryComponentFilter.cpp,
source/headers/geos/geom/util/GeometryTransformer.h,
@@ -9464,9 +9688,9 @@
TopologyPreservingSimplifier initial port
-2006-04-13 10:39 strk
+2006-04-13 10:39 Sandro Santilli <strk at keybit.net>
- * ChangeLog,
+ * [r1448] ChangeLog,
source/headers/geos/simplify/DouglasPeuckerLineSimplifier.h,
source/headers/geos/simplify/DouglasPeuckerSimplifier.h,
source/headers/geos/simplify/Makefile.am,
@@ -9478,29 +9702,29 @@
source/simplify/TopologyPreservingSimplifier.cpp: Initial
implementation of TaggedLinesSimplifier class
-2006-04-13 09:28 mloskot
+2006-04-13 09:28 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/simplify/LineSegmentIndex.h,
+ * [r1447] source/headers/geos/simplify/LineSegmentIndex.h,
source/simplify/LineSegmentIndex.cpp: Removed definition of copy
ctor and assignment operator for LineSegmentString class.
-2006-04-13 09:21 mloskot
+2006-04-13 09:21 Mateusz Loskot <mateusz at loskot.net>
+ * [r1446] source/headers/geos/simplify/TaggedLineString.h,
source/simplify/TaggedLineString.cpp: Removed definition of copy
ctor and assignment operator for TaggedLineString class.
According to following rule: Declaring, but not defining, private
copy operations has
the effect of "turning off" copying for the class.
-2006-04-12 17:24 strk
+2006-04-12 17:24 Sandro Santilli <strk at keybit.net>
- * ChangeLog: Added note about reduction of installed headers in
- simplify namespace
+ * [r1445] ChangeLog: Added note about reduction of installed
+ headers in simplify namespace
-2006-04-12 17:19 strk
+2006-04-12 17:19 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/geom/LineSegment.h,
+ * [r1444] ChangeLog, source/headers/geos/geom/LineSegment.h,
source/headers/geos/simplify/TaggedLineSegment.h,
@@ -9511,18 +9735,19 @@
TaggedLineStringSimplifier class, made LineSegment class
polymorphic to fix derivation of TaggedLineSegment
-2006-04-12 15:20 strk
+2006-04-12 15:20 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/simplify/LineSegmentIndex.h,
+ * [r1443] ChangeLog,
+ source/headers/geos/simplify/LineSegmentIndex.h,
source/simplify/LineSegmentIndex.cpp,
source/simplify/TaggedLineString.cpp: LineSegmentIndex class
-2006-04-12 14:22 strk
+2006-04-12 14:22 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/simplify/Makefile.am,
+ * [r1442] ChangeLog, source/headers/geos/simplify/Makefile.am,
@@ -9530,36 +9755,37 @@
source/simplify/TaggedLineString.cpp: Initial implementation of
TaggedLineSegment and TaggedLineString classes
-2006-04-12 12:20 strk
+2006-04-12 12:20 Sandro Santilli <strk at keybit.net>
- * source/operation/overlay/OverlayOp.cpp: Added support for use of
- CommonBitsOp in reduced precision attempts
+ * [r1441] source/operation/overlay/OverlayOp.cpp: Added support for
+ use of CommonBitsOp in reduced precision attempts
(compile-time option)
-2006-04-12 11:57 strk
+2006-04-12 11:57 Sandro Santilli <strk at keybit.net>
- * source/algorithm/LineIntersector.cpp: Fixed debugging line
+ * [r1440] source/algorithm/LineIntersector.cpp: Fixed debugging
+ line
-2006-04-12 11:39 strk
+2006-04-12 11:39 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom/GeometryFactory.h: Removed Geometry.h
- and CoordinateSequence.h includes.
+ * [r1439] source/headers/geos/geom/GeometryFactory.h: Removed
+ Geometry.h and CoordinateSequence.h includes.
The former created a circular dependency.
-2006-04-12 11:17 strk
+2006-04-12 11:17 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/io/WKBReader.cpp: Fixed exceptions constructors
- (were using operator+ with strings and const char*)
+ * [r1438] ChangeLog, source/io/WKBReader.cpp: Fixed exceptions
+ constructors (were using operator+ with strings and const char*)
-2006-04-12 10:57 strk
+2006-04-12 10:57 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/io/WKBReader.h,
+ * [r1437] ChangeLog, source/headers/geos/io/WKBReader.h,
source/io/WKBReader.cpp: Added WKBReader default ctor using
-2006-04-11 16:04 strk
+2006-04-11 16:04 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/geom/util/GeometryTransformer.cpp,
+ * [r1436] ChangeLog, source/geom/util/GeometryTransformer.cpp,
source/simplify/DouglasPeuckerSimplifier.cpp,
@@ -9568,59 +9794,59 @@
geos::simplify::DouglasPeukerSimplifier class + unit test
-2006-04-11 12:56 strk
+2006-04-11 12:56 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom/util/GeometryTransformer.h: used typedef
- for auto_ptr<CoordinateSequence>
+ * [r1435] source/headers/geos/geom/util/GeometryTransformer.h: used
+ typedef for auto_ptr<CoordinateSequence>
-2006-04-11 12:21 strk
+2006-04-11 12:21 Sandro Santilli <strk at keybit.net>
+ * [r1434] ChangeLog, source/geom/util/GeometryTransformer.cpp,
source/geom/util/Makefile.am,
source/headers/geos/geom/util/Makefile.am: GeometryTransformer
class ported
-2006-04-11 11:55 strk
+2006-04-11 11:55 Sandro Santilli <strk at keybit.net>
+ * [r1433] source/headers/geos/geom/CoordinateSequence.h: Added
CoordinateSequence::AutoPtr typedef
-2006-04-11 11:16 strk
+2006-04-11 11:16 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/geom/GeometryFactory.cpp,
+ * [r1432] ChangeLog, source/geom/GeometryFactory.cpp,
source/geom/LineString.cpp, source/geom/LinearRing.cpp,
source/headers/geos/geom/GeometryFactory.h,
source/headers/geos/geom/LinearRing.h: Added LineString and
LinearRing constructors by auto_ptr
-2006-04-11 09:53 strk
+2006-04-11 09:53 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom/GeometryList.h: Added missing duplicated
- include sentinel
+ * [r1431] source/headers/geos/geom/GeometryList.h: Added missing
+ duplicated include sentinel
-2006-04-11 09:41 strk
+2006-04-11 09:41 Sandro Santilli <strk at keybit.net>
- * source/geom/GeometryList.cpp, source/geom/Makefile.am,
+ * [r1430] source/geom/GeometryList.cpp, source/geom/Makefile.am,
source/headers/geos/geom/GeometryList.h,
source/headers/geos/geom/Makefile.am: Initial implementation of a
GeometryList class, to be used to manage
lists of Geometry pointers.
-2006-04-11 09:31 strk
+2006-04-11 09:31 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom/Geometry.h: Added Geometry::AutoPtr
- typedef
+ * [r1429] source/headers/geos/geom/Geometry.h: Added
+ Geometry::AutoPtr typedef
-2006-04-11 09:29 strk
+2006-04-11 09:29 Sandro Santilli <strk at keybit.net>
- * source/geom/Geometry.cpp: Fixed initialization list (removed
- compiler warning)
+ * [r1428] source/geom/Geometry.cpp: Fixed initialization list
+ (removed compiler warning)
-2006-04-10 18:15 strk
+2006-04-10 18:15 Sandro Santilli <strk at keybit.net>
+ * [r1427] ChangeLog, source/geom/Geometry.cpp,
source/geom/GeometryCollection.cpp, source/geom/LineString.cpp,
source/headers/geos/geom/Envelope.h,
@@ -9633,9 +9859,9 @@
Changed computeEnvelopeInternal() signater to return
auto_ptr<Envelope>
-2006-04-10 17:35 strk
+2006-04-10 17:35 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/geom/LineString.cpp,
+ * [r1426] ChangeLog, source/geom/LineString.cpp,
source/geom/LinearRing.cpp, source/geom/Point.cpp,
source/headers/geos/geom/LinearRing.h,
@@ -9645,50 +9871,51 @@
Point::coordinates to be wrapped
in an auto_ptr<>. This should close bugs #86 and #89
-2006-04-10 15:11 strk
+2006-04-10 15:11 Sandro Santilli <strk at keybit.net>
- * ChangeLog: First manual edit (will likely update later tonight...
- with changes grouped
+ * [r1425] ChangeLog: First manual edit (will likely update later
+ tonight... with changes grouped
by date)
-2006-04-10 15:05 strk
+2006-04-10 15:05 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/TestInteriorPoint.xml: Re-synced with JTS version
- (so this actually *was* a bug :)
+ * [r1424] tests/xmltester/TestInteriorPoint.xml: Re-synced with JTS
+ version (so this actually *was* a bug :)
- * source/geom/Geometry.cpp: Fixed a bug introduced by previous
- commit in getCentroid()
+ * [r1423] source/geom/Geometry.cpp: Fixed a bug introduced by
+ previous commit in getCentroid()
-2006-04-10 14:18 strk
+2006-04-10 14:18 Sandro Santilli <strk at keybit.net>
- * source/geom/Geometry.cpp: Fixed getCentroid(Coordinate&) to round
- using PrecisionModel
+ * [r1422] source/geom/Geometry.cpp: Fixed getCentroid(Coordinate&)
+ to round using PrecisionModel
all unit tests succeed.
-2006-04-10 13:40 strk
+2006-04-10 13:40 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/io/WKTReader.h,
+ * [r1421] source/headers/geos/io/WKTReader.h,
source/headers/geos/io/WKTReader.inl: Added default ctor for
WKTReader (using GeometryFactory's default instance)
-2006-04-10 13:13 strk
+2006-04-10 13:13 Sandro Santilli <strk at keybit.net>
- * tools/geos-config.in: Removed INLINE flags from geos-config
- --libs
+ * [r1420] tools/geos-config.in: Removed INLINE flags from
+ geos-config --libs
-2006-04-10 13:09 strk
+2006-04-10 13:09 Sandro Santilli <strk at keybit.net>
- * source/geom/Geometry.cpp, source/geom/GeometryFactory.cpp,
+ * [r1419] source/geom/Geometry.cpp,
+ source/geom/GeometryFactory.cpp,
source/headers/geos/geom/GeometryFactory.h, source/io/Unload.cpp:
Added GeometryFactory::defaultInstance()
Made Geometry::INTERNAL_GEOMETRY_FACTORY an alias for it
removed last deletion from Unload::Release class
-2006-04-10 12:05 strk
+2006-04-10 12:05 Sandro Santilli <strk at keybit.net>
- * source/Makefile.am, source/geom/LineSegment.cpp,
+ * [r1418] source/Makefile.am, source/geom/LineSegment.cpp,
source/headers/geos/geom/LineSegment.inl,
source/headers/geos/io/WKTReader.inl,
@@ -9702,14 +9929,14 @@
functions in .inl files are still available out-of-line.
A side effect is this should fix MingW build.
-2006-04-10 11:34 strk
+2006-04-10 11:34 Sandro Santilli <strk at keybit.net>
- * tests/unit/algorithm/PointLocatorTest.cpp: Uncommented required
- Geometry.h include (for use in auto_ptr)
+ * [r1417] tests/unit/algorithm/PointLocatorTest.cpp: Uncommented
+ required Geometry.h include (for use in auto_ptr)
-2006-04-10 09:21 mloskot
+2006-04-10 09:21 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/util/UniqueCoordinateArrayFilter.h,
+ * [r1416] source/headers/geos/util/UniqueCoordinateArrayFilter.h,
tests/unit/geom/CoordinateArraySequenceFactoryTest.cpp,
tests/unit/geom/CoordinateArraySequenceTest.cpp,
@@ -9721,109 +9948,112 @@
test for UniqueCoordinateArrayFilter class. Small fixes related
to signed/unsigned comparison.
-2006-04-09 11:07 mloskot
+2006-04-09 11:07 Mateusz Loskot <mateusz at loskot.net>
- * doc/example.cpp: Small fixes in doc/example.cpp.
+ * [r1413] doc/example.cpp: Small fixes in doc/example.cpp.
-2006-04-09 04:56 mloskot
+2006-04-09 04:56 Mateusz Loskot <mateusz at loskot.net>
- * tests/xmltester/markup/MarkupSTL.cpp: Removed redundant
+ * [r1412] tests/xmltester/markup/MarkupSTL.cpp: Removed redundant
semicolons from xmltester sources.
-2006-04-09 04:26 mloskot
+2006-04-09 04:26 Mateusz Loskot <mateusz at loskot.net>
- * tests/xmltester/markup/MarkupSTL.cpp: Removed redundant semicolon
- reported by g++ -pedantic.
+ * [r1411] tests/xmltester/markup/MarkupSTL.cpp: Removed redundant
+ semicolon reported by g++ -pedantic.
-2006-04-09 04:09 mloskot
+2006-04-09 04:09 Mateusz Loskot <mateusz at loskot.net>
- * source/operation/valid/SweeplineNestedRingTester.cpp: Removed
- redundant semicolon reported by g++ -pedantic.
+ * [r1410] source/operation/valid/SweeplineNestedRingTester.cpp:
+ Removed redundant semicolon reported by g++ -pedantic.
-2006-04-09 01:48 mloskot
+2006-04-09 01:48 Mateusz Loskot <mateusz at loskot.net>
+ * [r1409] tests/unit/Makefile.am,
tests/unit/geom/IntersectionMatrixTest.cpp: Added Unit Test for
IntersectionMatrix class.
-2006-04-09 01:46 mloskot
+2006-04-09 01:46 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/geom/IntersectionMatrix.h: [SORRY] Added
- comments for doxygen based on JTS docs. Added row/col dimension
- consts. Added asserts in functions to check if given row/col is
- in range.
+ * [r1408] source/headers/geos/geom/IntersectionMatrix.h: [SORRY]
+ Added comments for doxygen based on JTS docs. Added row/col
+ dimension consts. Added asserts in functions to check if given
+ row/col is in range.
-2006-04-09 01:41 mloskot
+2006-04-09 01:41 Mateusz Loskot <mateusz at loskot.net>
- * source/geom/IntersectionMatrix.cpp: Added comments for doxygen
- based on JTS docs. Added row/col dimension consts. Added asserts
- in functions to check if given row/col is in range.
+ * [r1407] source/geom/IntersectionMatrix.cpp: Added comments for
+ doxygen based on JTS docs. Added row/col dimension consts. Added
+ asserts in functions to check if given row/col is in range.
-2006-04-08 15:57 mloskot
+2006-04-08 15:57 Mateusz Loskot <mateusz at loskot.net>
- * tests/tut/tut.h, tests/tut/tut_reporter.h,
+ * [r1406] tests/tut/tut.h, tests/tut/tut_reporter.h,
tests/tut/tut_restartable.h: Added copyright notice to TUT files.
Small cleaning.
-2006-04-08 13:05 strk
+2006-04-08 13:05 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/EdgeEnd.cpp: Added assertion
+ * [r1405] source/geomgraph/EdgeEnd.cpp: Added assertion
-2006-04-08 13:00 strk
+2006-04-08 13:00 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/NodeMap.cpp: assertion checking, mergeLabel()
- call fix (bug#91)
+ * [r1404] source/geomgraph/NodeMap.cpp: assertion checking,
+ mergeLabel() call fix (bug#91)
-2006-04-07 16:52 strk
+2006-04-07 16:52 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/PlanarGraph.cpp,
+ * [r1403] source/geomgraph/PlanarGraph.cpp,
source/headers/geos/geomgraph/PlanarGraph.h: Port info, doxygen
comments, assertion checking
-2006-04-07 16:01 strk
+2006-04-07 16:01 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/Node.cpp, source/headers/geos/geomgraph/Node.h:
- Port info, doxygen comments, testInvariant(), many assertionss,
- handling of
+ * [r1402] source/geomgraph/Node.cpp,
+ source/headers/geos/geomgraph/Node.h: Port info, doxygen
+ comments, testInvariant(), many assertionss, handling of
the NULL EdgeEndStar member
-2006-04-07 13:26 strk
+2006-04-07 13:26 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/XMLTester.cpp, tests/xmltester/XMLTester.h: Use
- of auto_ptr<> to prevent confusing leaks in tester
+ * [r1401] tests/xmltester/XMLTester.cpp,
+ tests/xmltester/XMLTester.h: Use of auto_ptr<> to prevent
+ confusing leaks in tester
-2006-04-07 13:14 mloskot
+2006-04-07 13:14 Mateusz Loskot <mateusz at loskot.net>
- * tests/tut/tut_reporter.h: Fixed annoying warnings from TUT.
+ * [r1400] tests/tut/tut_reporter.h: Fixed annoying warnings from
+ TUT.
-2006-04-07 13:01 mloskot
+2006-04-07 13:01 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/geos_unit.cpp: Fixed line-ends to LF.
+ * [r1399] tests/unit/geos_unit.cpp: Fixed line-ends to LF.
-2006-04-07 12:55 mloskot
+2006-04-07 12:55 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/geom/PolygonTest.cpp: Uncommented test nr 38 in
- PolygonTest.cpp.
+ * [r1398] tests/unit/geom/PolygonTest.cpp: Uncommented test nr 38
+ in PolygonTest.cpp.
-2006-04-07 12:37 mloskot
+2006-04-07 12:37 Mateusz Loskot <mateusz at loskot.net>
- * source/geom/PrecisionModel.cpp, source/headers/geos/util/math.h,
- source/util/math.cpp, tests/tut/tut_reporter.h,
+ * [r1397] source/geom/PrecisionModel.cpp,
+ source/headers/geos/util/math.h, source/util/math.cpp,
+ tests/tut/tut_reporter.h,
tests/unit/geom/MultiLineStringTest.cpp,
tests/unit/geom/MultiPolygonTest.cpp,
tests/unit/geom/PointTest.cpp, tests/unit/geom/PolygonTest.cpp,
tests/unit/geos_unit.cpp: Added java_math_round() function for
Asymmetric Arithmetic Rounding. Small fixes in Unit Tests.
-2006-04-07 10:42 mloskot
+2006-04-07 10:42 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/geom/GeometryFactoryTest.cpp,
+ * [r1396] tests/unit/geom/GeometryFactoryTest.cpp,
tests/unit/geom/PointTest.cpp: Added test nr 29 to PointTest (JTS
conformance). Removed inform() calls from GeometryFactoryTest.
-2006-04-07 09:54 strk
+2006-04-07 09:54 Sandro Santilli <strk at keybit.net>
- * source/algorithm/CentroidArea.cpp,
+ * [r1395] source/algorithm/CentroidArea.cpp,
source/algorithm/CentroidPoint.cpp,
source/algorithm/InteriorPointArea.cpp,
source/algorithm/PointLocator.cpp, source/geom/Geometry.cpp,
@@ -9837,42 +10067,43 @@
Geometry::getNumGeometries() changed to return 'unsigned int'
rather then 'int'
-2006-04-07 09:12 strk
+2006-04-07 09:12 Sandro Santilli <strk at keybit.net>
- * source/algorithm/LineIntersector.cpp: kept isInSegmentEnvelopes()
- check even when not debugging
+ * [r1394] source/algorithm/LineIntersector.cpp: kept
+ isInSegmentEnvelopes() check even when not debugging
-2006-04-07 08:31 strk
+2006-04-07 08:31 Sandro Santilli <strk at keybit.net>
- * source/precision/EnhancedPrecisionOp.cpp: Debugging lines
+ * [r1393] source/precision/EnhancedPrecisionOp.cpp: Debugging lines
-2006-04-07 08:30 strk
+2006-04-07 08:30 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/precision/CommonBitsRemover.h: made
+ * [r1392] source/headers/geos/precision/CommonBitsRemover.h: made
addCommonBits/removeCommonBits interface consistent, doxygen
comments
-2006-04-07 08:28 strk
+2006-04-07 08:28 Sandro Santilli <strk at keybit.net>
- * source/precision/CommonBitsRemover.cpp: debugging lines,
+ * [r1391] source/precision/CommonBitsRemover.cpp: debugging lines,
assertions
-2006-04-07 08:27 strk
+2006-04-07 08:27 Sandro Santilli <strk at keybit.net>
- * source/precision/CommonBitsOp.cpp: debugging blocks
+ * [r1390] source/precision/CommonBitsOp.cpp: debugging blocks
-2006-04-07 07:21 mloskot
+2006-04-07 07:21 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/Makefile.am, tests/unit/geom/CoordinateTest.cpp: Add
- new-line at the EOF some files.
+ * [r1389] tests/unit/Makefile.am,
+ tests/unit/geom/CoordinateTest.cpp: Add new-line at the EOF some
+ files.
-2006-04-07 05:55 mloskot
+2006-04-07 05:55 Mateusz Loskot <mateusz at loskot.net>
- * ., .cvsignore: Added new objects to .cvsignore.
+ * [r1388] ., .cvsignore: Added new objects to .cvsignore.
-2006-04-07 05:44 mloskot
+2006-04-07 05:44 Mateusz Loskot <mateusz at loskot.net>
- * source/headers/geos/geom/Dimension.h,
+ * [r1387] source/headers/geos/geom/Dimension.h,
tests/unit/geom/CoordinateTest.cpp,
@@ -9891,15 +10122,15 @@
in Dimension class (bug). Added missing new-line at the end of
source files. Removed CR from line ends.
-2006-04-07 00:05 mloskot
+2006-04-07 00:05 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/geom/Geometry,
+ * [r1386] tests/unit/geom/Geometry,
tests/unit/geom/Geometry/isRectangleTest.cpp: Adding missing
isRectangleTest.cpp
-2006-04-06 23:50 mloskot
+2006-04-06 23:50 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/Makefile.am, tests/unit/geom,
+ * [r1385] tests/unit/Makefile.am, tests/unit/geom,
@@ -9917,59 +10148,60 @@
tests/unit/geom/TriangleTest.cpp, tests/unit/io,
tests/unit/io/WKBReaderTest.cpp: Adding new Unit Tests.
-2006-04-06 23:35 strk
+2006-04-06 23:35 Sandro Santilli <strk at keybit.net>
- * AUTHORS: Added Mateusz Loskot
+ * [r1384] AUTHORS: Added Mateusz Loskot
-2006-04-06 23:31 mloskot
+2006-04-06 23:31 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/algorithm, tests/unit/algorithm/PointLocatorTest.cpp:
- [UT Files Renaming] Add PointLocatorTest.cpp
+ * [r1383] tests/unit/algorithm,
+ tests/unit/algorithm/PointLocatorTest.cpp: [UT Files Renaming]
+ Add PointLocatorTest.cpp
-2006-04-06 23:28 mloskot
+2006-04-06 23:28 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/io: [UT Files Renaming] Remove 'io' tests.
+ * [r1382] tests/unit/io: [UT Files Renaming] Remove 'io' tests.
-2006-04-06 23:26 mloskot
+2006-04-06 23:26 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/geom: [UT Files Renaming] Remove 'geom' tests.
+ * [r1381] tests/unit/geom: [UT Files Renaming] Remove 'geom' tests.
-2006-04-06 23:25 mloskot
+2006-04-06 23:25 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/algorithm: [UT Files Renaming] Remove file
+ * [r1380] tests/unit/algorithm: [UT Files Renaming] Remove file
PointLocator.cpp
-2006-04-06 23:20 mloskot
+2006-04-06 23:20 Mateusz Loskot <mateusz at loskot.net>
- * tests/unit/geos_unit.cpp: New version of Unit Test runner. Now,
- it's more GNU style compatible
+ * [r1379] tests/unit/geos_unit.cpp: New version of Unit Test
+ runner. Now, it's more GNU style compatible
-2006-04-06 22:30 mloskot
+2006-04-06 22:30 Mateusz Loskot <mateusz at loskot.net>
- * tests/tut/tut.h, tests/tut/tut_reporter.h: Add inform() target in
- tut.h and new callbacks in tut_reporter.h
+ * [r1378] tests/tut/tut.h, tests/tut/tut_reporter.h: Add inform()
+ target in tut.h and new callbacks in tut_reporter.h
-2006-04-06 21:31 strk
+2006-04-06 21:31 Sandro Santilli <strk at keybit.net>
- * source/algorithm/LineIntersector.cpp,
+ * [r1377] source/algorithm/LineIntersector.cpp,
source/headers/geos/algorithm/LineIntersector.h: Const
correctness for debugging function
-2006-04-06 21:30 strk
+2006-04-06 21:30 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/util/math.h: Added missing rint_vc() forward
- declaration
+ * [r1376] source/headers/geos/util/math.h: Added missing rint_vc()
+ forward declaration
-2006-04-06 17:33 strk
+2006-04-06 17:33 Sandro Santilli <strk at keybit.net>
- * tests/unit/Makefile.am, tests/unit/index,
+ * [r1375] tests/unit/Makefile.am, tests/unit/index,
tests/unit/index/quadtree,
tests/unit/index/quadtree/DoubleBitsTest.cpp: Added unit test for
DoubleBits
-2006-04-06 14:36 strk
+2006-04-06 14:36 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/precision/CommonBitsOp.h,
+ * [r1374] source/headers/geos/precision/CommonBitsOp.h,
source/headers/geos/precision/CommonBitsRemover.h,
source/headers/geos/precision/EnhancedPrecisionOp.h,
source/precision/CommonBitsOp.cpp,
@@ -9977,156 +10209,159 @@
source/precision/EnhancedPrecisionOp.cpp: Cleanup in
geos::precision namespace (leaks plugged, auto_ptr use, ...)
-2006-04-06 12:58 strk
+2006-04-06 12:58 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/DirectedEdge.cpp: Added printing of EdgeRing if
- available
+ * [r1373] source/geomgraph/DirectedEdge.cpp: Added printing of
+ EdgeRing if available
-2006-04-06 12:48 strk
+2006-04-06 12:48 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/valid/ConnectedInteriorTester.h:
+ * [r1372]
+ source/headers/geos/operation/valid/ConnectedInteriorTester.h:
Added private vector to keep track of allocated MaximalEdgeRings
objects
-2006-04-06 12:47 strk
+2006-04-06 12:47 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/EdgeEnd.cpp: Fixed output function
+ * [r1371] source/geomgraph/EdgeEnd.cpp: Fixed output function
-2006-04-06 12:45 strk
+2006-04-06 12:45 Sandro Santilli <strk at keybit.net>
- * source/operation/valid/ConnectedInteriorTester.cpp: Delayed
- deletion of newly allocated MaximalEdgeRings.
+ * [r1370] source/operation/valid/ConnectedInteriorTester.cpp:
+ Delayed deletion of newly allocated MaximalEdgeRings.
Existing 'valid' operation tests don't should instability with
this patch.
-2006-04-06 12:36 strk
+2006-04-06 12:36 Sandro Santilli <strk at keybit.net>
- * source/geom/PrecisionModel.cpp: removed spurious lines from
- previous commi
+ * [r1369] source/geom/PrecisionModel.cpp: removed spurious lines
+ from previous commi
-2006-04-06 12:34 strk
+2006-04-06 12:34 Sandro Santilli <strk at keybit.net>
+ * [r1368] source/geom/PrecisionModel.cpp,
source/headers/geos/geom/PrecisionModel.h,
source/headers/geos/geom/PrecisionModel.inl: Port info, more
debugging lines, doxygen comments
-2006-04-06 12:33 strk
+2006-04-06 12:33 Sandro Santilli <strk at keybit.net>
- * source/geom/GeometryFactory.cpp: More debugging lines
+ * [r1367] source/geom/GeometryFactory.cpp: More debugging lines
-2006-04-06 12:29 strk
+2006-04-06 12:29 Sandro Santilli <strk at keybit.net>
- * source/io/WKBReader.cpp: Fixed bogus static PrecisionModel
- variable in ::readCoordinate().
+ * [r1366] source/io/WKBReader.cpp: Fixed bogus static
+ PrecisionModel variable in ::readCoordinate().
-2006-04-06 09:41 strk
+2006-04-06 09:41 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/EdgeRing.cpp,
+ * [r1365] source/geomgraph/EdgeRing.cpp,
source/headers/geos/geomgraph/EdgeRing.h: Added operator<<, added
pts!=NULL assertion in testInvariant() function
-2006-04-06 09:39 strk
+2006-04-06 09:39 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/EdgeEnd.cpp,
+ * [r1364] source/geomgraph/EdgeEnd.cpp,
source/headers/geos/geomgraph/EdgeEnd.h: Added operator<<
-2006-04-06 09:01 strk
+2006-04-06 09:01 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/Label.cpp,
+ * [r1363] source/geomgraph/Label.cpp,
source/geomgraph/TopologyLocation.cpp,
source/headers/geos/geomgraph/Label.h,
source/headers/geos/geomgraph/TopologyLocation.h: Doxygen
comments, port info, operator<<, assertion checking
-2006-04-06 07:52 strk
+2006-04-06 07:52 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/DirectedEdge.cpp: Fixed bug in ::print()
+ * [r1362] source/geomgraph/DirectedEdge.cpp: Fixed bug in ::print()
function
-2006-04-05 18:28 strk
+2006-04-05 18:28 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geomgraph/Edge.h,
+ * [r1361] source/headers/geos/geomgraph/Edge.h,
source/headers/geos/geomgraph/EdgeRing.h: Moved testInvariant()
methods from private to public, added
some comments about them.
-2006-04-05 15:59 strk
+2006-04-05 15:59 Sandro Santilli <strk at keybit.net>
- * source/operation/overlay/OverlayOp.cpp: Removed dead code
+ * [r1360] source/operation/overlay/OverlayOp.cpp: Removed dead code
-2006-04-05 14:33 strk
+2006-04-05 14:33 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/markup/MarkupSTL.cpp,
+ * [r1359] tests/xmltester/markup/MarkupSTL.cpp,
tests/xmltester/markup/MarkupSTL.h: Removed annoying warnings
from external source
-2006-04-05 14:04 strk
+2006-04-05 14:04 Sandro Santilli <strk at keybit.net>
- * source/geom/Envelope.cpp, source/headers/geos/geom/Envelope.h,
+ * [r1358] source/geom/Envelope.cpp,
+ source/headers/geos/geom/Envelope.h,
source/headers/geos/geom/Envelope.inl: Fixed copy ctor to support
"Null" Envelope copies.
Drop init(Envelope&) method.
Port info and various cleanups.
-2006-04-05 10:25 strk
+2006-04-05 10:25 Sandro Santilli <strk at keybit.net>
- * source/geom/LineString.cpp,
+ * [r1357] source/geom/LineString.cpp,
source/headers/geos/geom/LineString.h: Fixed LineString
constructor to ensure deletion of CoordinateSequence
argument on exception throw
-2006-04-05 09:34 strk
+2006-04-05 09:34 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/util/GEOSException.h: GEOSException derived
- from std::exception again, hopefully the correct way now
+ * [r1356] source/headers/geos/util/GEOSException.h: GEOSException
+ derived from std::exception again, hopefully the correct way now
-2006-04-05 09:20 strk
+2006-04-05 09:20 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/buffer/RightmostEdgeFinder.h,
+ * [r1355]
+ source/headers/geos/operation/buffer/RightmostEdgeFinder.h,
source/operation/buffer/RightmostEdgeFinder.cpp: Added port
informations and many assertion checking.
Fixed bug in getRightmostSide() method ( a "testing-only" corner
case )
-2006-04-04 16:07 strk
+2006-04-04 16:07 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/DirectedEdgeStar.cpp: More assertion checking,
- less overhead when built with NDEBUG defined
+ * [r1353] source/geomgraph/DirectedEdgeStar.cpp: More assertion
+ checking, less overhead when built with NDEBUG defined
-2006-04-04 13:35 strk
+2006-04-04 13:35 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/EdgeEndStar.cpp,
+ * [r1352] source/geomgraph/EdgeEndStar.cpp,
source/headers/geos/geomgraph/EdgeEndStar.h: Port info, assertion
checking, indentation
-2006-04-04 12:39 strk
+2006-04-04 12:39 Sandro Santilli <strk at keybit.net>
- * source/algorithm/LineIntersector.cpp: Changed
+ * [r1351] source/algorithm/LineIntersector.cpp: Changed
NotRepresentableCoordinate exception handler to throw
a TopologyException. This allows further handling.
-2006-04-04 11:37 strk
+2006-04-04 11:37 Sandro Santilli <strk at keybit.net>
- * source/algorithm/HCoordinate.cpp,
+ * [r1350] source/algorithm/HCoordinate.cpp,
source/headers/geos/algorithm/HCoordinate.h: Port information +
initialization lists in ctors
-2006-04-04 11:28 strk
+2006-04-04 11:28 Sandro Santilli <strk at keybit.net>
- * source/algorithm/HCoordinate.cpp: NotRepresentable condition
- detected using finite() from <cmath>
+ * [r1349] source/algorithm/HCoordinate.cpp: NotRepresentable
+ condition detected using finite() from <cmath>
rather then using FINITE() macro. Made ::intersection() body
more readable.
-2006-04-04 09:53 strk
+2006-04-04 09:53 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom/CoordinateSequence.h: Fixed
+ * [r1348] source/headers/geos/geom/CoordinateSequence.h: Fixed
applyCoordinateFilter() templated function body
-2006-04-04 08:16 strk
+2006-04-04 08:16 Sandro Santilli <strk at keybit.net>
- * NEWS, doc/example.cpp,
+ * [r1345] NEWS, doc/example.cpp,
source/algorithm/NotRepresentableException.cpp,
source/examples/CPCLException.cpp,
source/examples/CustomCoordinateSequenceExample.cpp,
@@ -10141,61 +10376,63 @@
Removed the GEOSException::toString redundant method (use
::what() instead)
-2006-04-04 01:54 hobu
+2006-04-04 01:54 Howard Butler <hobu.inc at gmail.com>
- * source/Makefile.vc: Add in changes/missing from previous
+ * [r1344] source/Makefile.vc: Add in changes/missing from previous
rearranging.
-2006-04-04 01:29 hobu
+2006-04-04 01:29 Howard Butler <hobu.inc at gmail.com>
- * capi/geos_c.cpp: GEOS_JTS_PORT is in version.h not platform.h
+ * [r1343] capi/geos_c.cpp: GEOS_JTS_PORT is in version.h not
+ platform.h
-2006-04-04 01:28 hobu
+2006-04-04 01:28 Howard Butler <hobu.inc at gmail.com>
- * source/Makefile.vc: remove objects that no longer exist
+ * [r1342] source/Makefile.vc: remove objects that no longer exist
default to MSVC_VER=1310
-2006-04-03 17:05 strk
+2006-04-03 17:05 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/DirectedEdge.cpp, source/geomgraph/EdgeEnd.cpp,
- source/geomgraph/Label.cpp,
+ * [r1341] source/geomgraph/DirectedEdge.cpp,
+ source/geomgraph/EdgeEnd.cpp, source/geomgraph/Label.cpp,
source/headers/geos/geomgraph/EdgeEnd.h: Assertion checking, port
info, cleanups
-2006-04-03 15:54 strk
+2006-04-03 15:54 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/GeometryGraphOperation.h,
+ * [r1340] source/headers/geos/operation/GeometryGraphOperation.h,
source/operation/GeometryGraphOperation.cpp: - getArgGeometry()
parameter type changed from 'int' to 'unsigned int'
- Added port informations
- minor assertions checking
- minor cleanups
-2006-04-03 14:07 strk
+2006-04-03 14:07 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom/PrecisionModel.h: Commented out
+ * [r1339] source/headers/geos/geom/PrecisionModel.h: Commented out
obsoleted toInternal() method
-2006-04-03 13:58 strk
+2006-04-03 13:58 Sandro Santilli <strk at keybit.net>
- * macros/ac_pkg_swig.m4, macros/ac_python_devel.m4, swig/geos.i,
- swig/python/Makefile.am, swig/python/python.i, swig/ruby/ruby.i,
- swig/ruby/test/geos_tests.rb, swig/ruby/test/test_helper.rb:
- Applied patch by Charlie Savage:
+ * [r1337] macros/ac_pkg_swig.m4, macros/ac_python_devel.m4,
+ swig/geos.i, swig/python/Makefile.am, swig/python/python.i,
+ swig/ruby/ruby.i, swig/ruby/test/geos_tests.rb,
+ swig/ruby/test/test_helper.rb: Applied patch by Charlie Savage:
- Fixes up the SWIG bindings to use the new GEOS namespaces
- Fixes a bug in the Python m4 macro
- Adds the -modern flag for SWIG when compiling a Python
extension
-2006-04-03 13:56 strk
+2006-04-03 13:56 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/precision/SimpleGeometryPrecisionReducer.h,
+ * [r1336]
+ source/headers/geos/precision/SimpleGeometryPrecisionReducer.h,
source/precision/SimpleGeometryPrecisionReducer.cpp: Made
externally-owned PrecisionModel const
-2006-04-03 10:56 strk
+2006-04-03 10:56 Sandro Santilli <strk at keybit.net>
- * source/geom/CoordinateSequenceFactory.cpp,
+ * [r1334] source/geom/CoordinateSequenceFactory.cpp,
source/geom/util/LinearComponentExtracter.cpp,
@@ -10207,15 +10444,15 @@
source/util/UnsupportedOperationException.cpp: Removed
implementation files build spec for fully-inlined classes
-2006-04-03 10:44 strk
+2006-04-03 10:44 Sandro Santilli <strk at keybit.net>
- * source/index/strtree/STRtree.cpp,
+ * [r1333] source/index/strtree/STRtree.cpp,
source/noding/snapround/MCIndexSnapRounder.cpp: Added missing
headers
-2006-04-03 10:16 strk
+2006-04-03 10:16 Sandro Santilli <strk at keybit.net>
- * configure.in, source/Makefile.am,
+ * [r1332] configure.in, source/Makefile.am,
source/headers/geos/Makefile.am, source/headers/geos/simplify,
source/headers/geos/simplify/.cvsignore,
@@ -10225,74 +10462,75 @@
source/simplify/Makefile.am: DouglasPeuckerLineSimplifier class
port
-2006-04-03 08:43 strk
+2006-04-03 08:43 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/index/strtree/STRtree.h,
+ * [r1331] source/headers/geos/index/strtree/STRtree.h,
source/index/strtree/STRtree.cpp: Added port info, minor cleanups
-2006-04-03 08:29 strk
+2006-04-03 08:29 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/index/quadtree/Quadtree.h,
+ * [r1330] source/headers/geos/index/quadtree/Quadtree.h,
source/index/quadtree/Quadtree.cpp: Added port info, cleaned up
log message, minor assertion checking.
-2006-03-31 17:51 strk
+2006-03-31 17:51 Sandro Santilli <strk at keybit.net>
- * source/geom/GeometryFactory.cpp,
+ * [r1329] source/geom/GeometryFactory.cpp,
source/headers/geos/geom/GeometryFactory.h: A few assertion
checking, comments cleanup, use of initialization lists
in constructors, handled NULL parameters.
-2006-03-31 16:55 strk
+2006-03-31 16:55 Sandro Santilli <strk at keybit.net>
- * NEWS, source/geom/LineString.cpp,
+ * [r1328] NEWS, source/geom/LineString.cpp,
source/headers/geos/geom/LineString.h: Added many assertions
checking in LineString implementation.
Changed ::getCoordinate() to return NULL on empty geom.
Changed ::get{Start,End}Point() to return NULL on empty geom.
-2006-03-31 16:53 strk
+2006-03-31 16:53 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom/Geometry.h: Added comment about possible
- NULL return from getCoordinate()
+ * [r1327] source/headers/geos/geom/Geometry.h: Added comment about
+ possible NULL return from getCoordinate()
-2006-03-31 11:03 strk
+2006-03-31 11:03 Sandro Santilli <strk at keybit.net>
- * source/geom/Geometry.cpp: Fixed NULL-GeometryFactory constructor
- to use INTERNAL_GEOMETRY_FACTORY
+ * [r1325] source/geom/Geometry.cpp: Fixed NULL-GeometryFactory
+ constructor to use INTERNAL_GEOMETRY_FACTORY
(should fix bug #81)
-2006-03-30 09:26 strk
+2006-03-30 09:26 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/io/WKTReader.h: minor cleanup
+ * [r1324] source/headers/geos/io/WKTReader.h: minor cleanup
-2006-03-29 15:48 strk
+2006-03-29 15:48 Sandro Santilli <strk at keybit.net>
- * capi/geos_c.cpp: Added missing 'const' in catch std::exception
- statements
+ * [r1323] capi/geos_c.cpp: Added missing 'const' in catch
+ std::exception statements
-2006-03-29 15:23 strk
+2006-03-29 15:23 Sandro Santilli <strk at keybit.net>
+ * [r1322] source/geomgraph/DirectedEdge.cpp,
source/geomgraph/GeometryGraph.cpp,
source/headers/geos/geomgraph/GeometryGraph.h,
source/headers/geos/geomgraph/GeometryGraph.inl,
source/headers/geos/geomgraph/Makefile.am: Moved GeometryGraph
inlines from .h to .inl file
-2006-03-29 14:34 strk
+2006-03-29 14:34 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/TestValid.xml: Sync'ed testfile with JTS head
+ * [r1321] tests/xmltester/TestValid.xml: Sync'ed testfile with JTS
+ head
-2006-03-29 14:31 strk
+2006-03-29 14:31 Sandro Santilli <strk at keybit.net>
- * tests/unit/Makefile.am, tests/unit/algorithm,
+ * [r1320] tests/unit/Makefile.am, tests/unit/algorithm,
tests/unit/algorithm/PointLocator.cpp,
tests/unit/io/WKBReader.cpp: Added PointLocator unit test
-2006-03-29 13:53 strk
+2006-03-29 13:53 Sandro Santilli <strk at keybit.net>
+ * [r1319] source/geomgraph/EdgeRing.cpp,
source/headers/geos/geomgraph/EdgeRing.h,
source/headers/geos/operation/valid/IsValidOp.h,
source/operation/valid/ConnectedInteriorTester.cpp,
@@ -10300,101 +10538,105 @@
Invariant testing function and lots of exceptional assertions.
Removed useless heap allocations, and pointers usages.
-2006-03-29 11:52 strk
+2006-03-29 11:52 Sandro Santilli <strk at keybit.net>
- * source/algorithm/MCPointInRing.cpp,
+ * [r1318] source/algorithm/MCPointInRing.cpp,
source/headers/geos/algorithm/MCPointInRing.h: const correctness,
useless heap allocations removal
-2006-03-29 11:48 strk
+2006-03-29 11:48 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/valid/QuadtreeNestedRingTester.h,
+ * [r1317]
+ source/headers/geos/operation/valid/QuadtreeNestedRingTester.h,
source/operation/valid/QuadtreeNestedRingTester.cpp: Removed
useless heap allocations in construction, enforced const
correctness
-2006-03-28 16:49 strk
+2006-03-28 16:49 Sandro Santilli <strk at keybit.net>
- * source/io/WKBReader.cpp: Reintroduced rewind of input parameter
- in printHEX() [dropped by prev commit]
+ * [r1316] source/io/WKBReader.cpp: Reintroduced rewind of input
+ parameter in printHEX() [dropped by prev commit]
-2006-03-28 16:33 strk
+2006-03-28 16:33 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom/GeometryFactory.h: Added note about args
- responsibility in GeometryFactory constructor
+ * [r1315] source/headers/geos/geom/GeometryFactory.h: Added note
+ about args responsibility in GeometryFactory constructor
-2006-03-28 16:11 strk
+2006-03-28 16:11 Sandro Santilli <strk at keybit.net>
- * tests/unit/io/WKBReader.cpp: swapped assert_equals() args to get
- obtained/expected the right way.
+ * [r1314] tests/unit/io/WKBReader.cpp: swapped assert_equals() args
+ to get obtained/expected the right way.
-2006-03-28 15:27 strk
+2006-03-28 15:27 Sandro Santilli <strk at keybit.net>
- * source/io/WKBReader.cpp: Simplified printHEX() implementation
+ * [r1313] source/io/WKBReader.cpp: Simplified printHEX()
+ implementation
-2006-03-28 15:19 strk
+2006-03-28 15:19 Sandro Santilli <strk at keybit.net>
- * doc/example.cpp: Added macros for sections skip (useful in
- debugging)
+ * [r1312] doc/example.cpp: Added macros for sections skip (useful
+ in debugging)
-2006-03-28 14:45 strk
+2006-03-28 14:45 Sandro Santilli <strk at keybit.net>
- * tests/unit/Makefile.am, tests/unit/io,
+ * [r1311] tests/unit/Makefile.am, tests/unit/io,
tests/unit/io/WKBReader.cpp: Added simple test for WKB reader.
-2006-03-28 14:02 strk
+2006-03-28 14:02 Sandro Santilli <strk at keybit.net>
- * source/io/WKBReader.cpp: added missing header for non-inlined
- builds
+ * [r1310] source/io/WKBReader.cpp: added missing header for
+ non-inlined builds
-2006-03-28 14:01 strk
+2006-03-28 14:01 Sandro Santilli <strk at keybit.net>
- * source/io/ByteOrderDataInStream.cpp: forgot to add in previous
- commit
+ * [r1309] source/io/ByteOrderDataInStream.cpp: forgot to add in
+ previous commit
-2006-03-28 11:26 strk
+2006-03-28 11:26 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/io/ByteOrderDataInStream.h,
+ * [r1308] source/headers/geos/io/ByteOrderDataInStream.h,
source/headers/geos/io/ByteOrderDataInStream.inl,
source/headers/geos/io/Makefile.am,
source/headers/geos/io/WKBWriter.h, source/io/Makefile.am:
ByteOrderDataInStream inlines moved to .inl file, updated
implementation files includes.
-2006-03-28 11:25 strk
+2006-03-28 11:25 Sandro Santilli <strk at keybit.net>
- * source/io/WKBWriter.cpp: Assertion checking
+ * [r1307] source/io/WKBWriter.cpp: Assertion checking
-2006-03-28 09:14 strk
+2006-03-28 09:14 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom/LineSegment.h,
+ * [r1306] source/headers/geos/geom/LineSegment.h,
source/headers/geos/geom/LineSegment.inl: Headers inclusion fix.
-2006-03-28 08:57 strk
+2006-03-28 08:57 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom/PrecisionModel.h,
+ * [r1305] source/headers/geos/geom/PrecisionModel.h,
source/headers/geos/geom/PrecisionModel.inl: Comments cleanup,
system headers included after project headers
-2006-03-28 08:40 strk
+2006-03-28 08:40 Sandro Santilli <strk at keybit.net>
- * configure.in: C-API lib version bumped to 1.1.1 (release 2.2.2
- will ship 1.1.0)
+ * [r1304] configure.in: C-API lib version bumped to 1.1.1 (release
+ 2.2.2 will ship 1.1.0)
-2006-03-27 17:59 strk
+2006-03-27 17:59 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/OffsetCurveBuilder.cpp: Fixed small leak.
+ * [r1302] source/operation/buffer/OffsetCurveBuilder.cpp: Fixed
+ small leak.
-2006-03-27 17:04 strk
+2006-03-27 17:04 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/buffer/OffsetCurveBuilder.h,
+ * [r1301]
+ source/headers/geos/operation/buffer/OffsetCurveBuilder.h,
source/operation/buffer/OffsetCurveBuilder.cpp,
source/operation/buffer/OffsetCurveSetBuilder.cpp: Cleanups and
explicit initializations
-2006-03-27 16:02 strk
+2006-03-27 16:02 Sandro Santilli <strk at keybit.net>
+ * [r1300] source/geomgraph/EdgeRing.cpp,
source/headers/geos/operation/overlay/Makefile.am,
source/headers/geos/operation/overlay/MaximalEdgeRing.h,
@@ -10406,99 +10648,103 @@
file for MinimalEdgeRing, added many debugging blocks,
fixed memory leak in ConnectedInteriorTester (bug #59)
-2006-03-27 15:57 strk
+2006-03-27 15:57 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom/Coordinate.h,
+ * [r1299] source/headers/geos/geom/Coordinate.h,
source/headers/geos/geom/Coordinate.inl: Commented need for
platform.h include
-2006-03-27 15:56 strk
+2006-03-27 15:56 Sandro Santilli <strk at keybit.net>
- * source/geom/Coordinate.cpp: Added missing platform.h include (for
- ISNAN macro)
+ * [r1298] source/geom/Coordinate.cpp: Added missing platform.h
+ include (for ISNAN macro)
-2006-03-27 14:20 strk
+2006-03-27 14:20 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/valid/ConnectedInteriorTester.h,
+ * [r1297]
+ source/headers/geos/operation/valid/ConnectedInteriorTester.h,
source/operation/valid/ConnectedInteriorTester.cpp: Added
paranoid assertion checking and a note in header about
responsibility of return from buildMaximalEdgeRings()
-2006-03-27 10:37 strk
+2006-03-27 10:37 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/valid/ConsistentAreaTester.h,
+ * [r1296]
+ source/headers/geos/operation/valid/ConsistentAreaTester.h,
source/operation/valid/ConsistentAreaTester.cpp: Reduced heap
allocations and probability of error by making LineIntersector
and RelateNodeGraph part of ConsistentAreaTester class .
-2006-03-27 10:36 strk
+2006-03-27 10:36 Sandro Santilli <strk at keybit.net>
- * source/operation/valid/TopologyValidationError.cpp: added missing
- space in exception message
+ * [r1295] source/operation/valid/TopologyValidationError.cpp: added
+ missing space in exception message
-2006-03-27 10:34 strk
+2006-03-27 10:34 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom/Coordinate.inl: moved external includes
- after internal ones
+ * [r1294] source/headers/geos/geom/Coordinate.inl: moved external
+ includes after internal ones
-2006-03-27 09:50 strk
+2006-03-27 09:50 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/Makefile.am, tests/xmltester/TestValid2-big.xml:
- Added final isValid test from JTS (floating version)
+ * [r1293] tests/xmltester/Makefile.am,
+ tests/xmltester/TestValid2-big.xml: Added final isValid test from
+ JTS (floating version)
-2006-03-27 09:48 strk
+2006-03-27 09:48 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/Makefile.am, tests/xmltester/TestValid2.xml,
- tests/xmltester/testLeaksBig.xml: Extracted TestValid2.xml from
- testLeaksBig.xml (target file is taken from JTS source tree)
+ * [r1292] tests/xmltester/Makefile.am,
+ tests/xmltester/TestValid2.xml, tests/xmltester/testLeaksBig.xml:
+ Extracted TestValid2.xml from testLeaksBig.xml (target file is
+ taken from JTS source tree)
-2006-03-27 09:45 strk
+2006-03-27 09:45 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/Makefile.am, tests/xmltester/TestValid.xml,
- tests/xmltester/testLeaksBig.xml: Added TestValid.xml test, taken
- from JTS source tree, already present in testLeaksBig (from which
- tests were removed)
+ * [r1291] tests/xmltester/Makefile.am,
+ tests/xmltester/TestValid.xml, tests/xmltester/testLeaksBig.xml:
+ Added TestValid.xml test, taken from JTS source tree, already
+ present in testLeaksBig (from which tests were removed)
-2006-03-27 09:28 strk
+2006-03-27 09:28 Sandro Santilli <strk at keybit.net>
- * NEWS: added namespaces use and headers split
+ * [r1290] NEWS: added namespaces use and headers split
-2006-03-27 09:05 strk
+2006-03-27 09:05 Sandro Santilli <strk at keybit.net>
- * capi/geos_c.h.in: Added note about responsibility of return from
- GEOSGeomType()
+ * [r1289] capi/geos_c.h.in: Added note about responsibility of
+ return from GEOSGeomType()
-2006-03-27 09:00 strk
+2006-03-27 09:00 Sandro Santilli <strk at keybit.net>
- * source/geom/CoordinateArraySequence.cpp: Bug #79 - Small fix in
- CoordinateArraySequence::toString()
+ * [r1288] source/geom/CoordinateArraySequence.cpp: Bug #79 - Small
+ fix in CoordinateArraySequence::toString()
-2006-03-24 11:42 strk
+2006-03-24 11:42 Sandro Santilli <strk at keybit.net>
- * configure.in: reverted default of assertion checking
+ * [r1287] configure.in: reverted default of assertion checking
-2006-03-24 11:11 strk
+2006-03-24 11:11 Sandro Santilli <strk at keybit.net>
- * TODO, configure.in, tools/geos-config.in: Inlining enabled by
- default, assertion checking disabled by default.
+ * [r1286] TODO, configure.in, tools/geos-config.in: Inlining
+ enabled by default, assertion checking disabled by default.
Added --enable-cassert and --disable-inline configure switches.
Had geos-config --cflags output appropriate inline flag if
required (-DGEOS_INLINE)
-2006-03-24 11:04 strk
+2006-03-24 11:04 Sandro Santilli <strk at keybit.net>
- * source/operation/linemerge/LineSequencer.cpp: Changed assert()
- with Assert::isTrue in addReverseSubpath
+ * [r1285] source/operation/linemerge/LineSequencer.cpp: Changed
+ assert() with Assert::isTrue in addReverseSubpath
-2006-03-24 10:44 strk
+2006-03-24 10:44 Sandro Santilli <strk at keybit.net>
- * source/operation/linemerge/LineSequencer.cpp: Fixed to build with
- -DNDEBUG
+ * [r1284] source/operation/linemerge/LineSequencer.cpp: Fixed to
+ build with -DNDEBUG
-2006-03-24 09:52 strk
+2006-03-24 09:52 Sandro Santilli <strk at keybit.net>
- * TODO, capi/geos_c.cpp.bak, source/algorithm/ConvexHull.cpp,
- source/geom/Coordinate.cpp,
+ * [r1283] TODO, capi/geos_c.cpp.bak,
+ source/algorithm/ConvexHull.cpp, source/geom/Coordinate.cpp,
source/geom/CoordinateArraySequenceFactory.cpp,
source/geom/Envelope.cpp, source/geom/Geometry.cpp,
@@ -10583,23 +10829,25 @@
source/operation/distance/DistanceOp.cpp: USE_INLINE =>
GEOS_INLINE
-2006-03-24 09:26 strk
+2006-03-24 09:26 Sandro Santilli <strk at keybit.net>
- * capi/geos_c.cpp: Bug #77 - Missing platform.h
+ * [r1282] capi/geos_c.cpp: Bug #77 - Missing platform.h
-2006-03-24 09:25 strk
+2006-03-24 09:25 Sandro Santilli <strk at keybit.net>
- * source/noding/snapround/MCIndexPointSnapper.cpp,
+ * [r1281] source/noding/snapround/MCIndexPointSnapper.cpp,
source/operation/buffer/BufferBuilder.cpp: Bugs #77 and #76:
missing <algorithm>
-2006-03-24 09:23 strk
+2006-03-24 09:23 Sandro Santilli <strk at keybit.net>
- * tests/unit/geos_unit.cpp: Bug #78 - Small fixes and cleaning
+ * [r1280] tests/unit/geos_unit.cpp: Bug #78 - Small fixes and
+ cleaning
-2006-03-23 15:10 strk
+2006-03-23 15:10 Sandro Santilli <strk at keybit.net>
- * source/geom/Coordinate.cpp, source/geomgraph/DirectedEdge.cpp,
+ * [r1278] source/geom/Coordinate.cpp,
+ source/geomgraph/DirectedEdge.cpp,
source/geomgraph/DirectedEdgeStar.cpp,
source/geomgraph/EdgeEndStar.cpp, source/geomgraph/EdgeRing.cpp,
source/headers/geos/geom/Geometry.h,
@@ -10609,9 +10857,9 @@
source/operation/overlay/OverlayOp.cpp: Dropped by-pointer
TopologyException constructor, various small cleanups
-2006-03-23 13:31 strk
+2006-03-23 13:31 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/Edge.cpp,
+ * [r1277] source/geomgraph/Edge.cpp,
source/geomgraph/EdgeIntersectionList.cpp,
source/geomgraph/index/SegmentIntersector.cpp,
source/index/chain/MonotoneChainBuilder.cpp,
@@ -10620,10 +10868,10 @@
source/index/quadtree/Quadtree.cpp: Fixed to allow build with
GEOS_DEBUG
-2006-03-23 12:12 strk
+2006-03-23 12:12 Sandro Santilli <strk at keybit.net>
- * source/geom/Geometry.cpp, source/geom/MultiLineString.cpp,
- source/geom/MultiPolygon.cpp,
+ * [r1276] source/geom/Geometry.cpp,
+ source/geom/MultiLineString.cpp, source/geom/MultiPolygon.cpp,
source/headers/geos/geom/Geometry.inl,
source/headers/geos/geom/GeometryCollection.h,
@@ -10635,26 +10883,26 @@
source/operation/distance/DistanceOp.cpp: Fixes to allow build
with -DUSE_INLINE
-2006-03-23 10:55 strk
+2006-03-23 10:55 Sandro Santilli <strk at keybit.net>
- * Makefile.am, configure.in: Temporarly excluded 'swig' extension
- from distribution, to allow for
+ * [r1275] Makefile.am, configure.in: Temporarly excluded 'swig'
+ extension from distribution, to allow for
successufull 'dist' rule and distributed testing.
-2006-03-23 10:41 strk
+2006-03-23 10:41 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/Makefile.am,
+ * [r1274] source/headers/geos/Makefile.am,
source/headers/geos/operation/relate/Makefile.am: Fixed automake
files
-2006-03-23 10:09 strk
+2006-03-23 10:09 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/predicate/Makefile.am: Fixed
- missing backslash
+ * [r1273] source/headers/geos/operation/predicate/Makefile.am:
+ Fixed missing backslash
-2006-03-23 09:17 strk
+2006-03-23 09:17 Sandro Santilli <strk at keybit.net>
- * configure.in, source/headers/geos/Makefile.am,
+ * [r1272] configure.in, source/headers/geos/Makefile.am,
source/headers/geos/precision, source/headers/geos/precision.h,
source/headers/geos/precision/.cvsignore,
source/headers/geos/precision/CommonBits.h,
@@ -10672,9 +10920,9 @@
source/precision/SimpleGeometryPrecisionReducer.cpp: precision.h
header split, minor optimizations
-2006-03-22 18:12 strk
+2006-03-22 18:12 Sandro Santilli <strk at keybit.net>
- * configure.in, source/algorithm/MCPointInRing.cpp,
+ * [r1271] configure.in, source/algorithm/MCPointInRing.cpp,
source/headers/geos/algorithm/MCPointInRing.h,
source/headers/geos/index/Makefile.am,
@@ -10701,13 +10949,13 @@
source/operation/buffer/BufferBuilder.cpp,
source/operation/valid/IsValidOp.cpp: indexChain.h header split.
-2006-03-22 16:59 strk
+2006-03-22 16:59 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geosAlgorithm.h: cleaned up
+ * [r1270] source/headers/geos/geosAlgorithm.h: cleaned up
-2006-03-22 16:58 strk
+2006-03-22 16:58 Sandro Santilli <strk at keybit.net>
- * source/geom/CoordinateArraySequence.cpp,
+ * [r1269] source/geom/CoordinateArraySequence.cpp,
source/geom/CoordinateList.cpp,
source/geom/CoordinateSequence.cpp, source/geom/Dimension.cpp,
source/geom/GeometryCollectionIterator.cpp,
@@ -10733,9 +10981,9 @@
CoordinateSequence
implementation, optimized out some memory allocations.
-2006-03-22 16:01 strk
+2006-03-22 16:01 Sandro Santilli <strk at keybit.net>
+ * [r1268] configure.in, source/algorithm/MCPointInRing.cpp,
source/headers/geos/index/bintree,
source/headers/geos/index/bintree/.cvsignore,
@@ -10756,9 +11004,10 @@
tests/xmltester/XMLTester.cpp: indexBintree.h header split,
classes renamed to match JTS
-2006-03-22 14:28 strk
+2006-03-22 14:28 Sandro Santilli <strk at keybit.net>
- * source/index/quadtree/Key.cpp, source/index/quadtree/Makefile.am,
+ * [r1267] source/index/quadtree/Key.cpp,
+ source/index/quadtree/Makefile.am,
source/index/quadtree/Node.cpp,
source/index/quadtree/NodeBase.cpp,
source/index/quadtree/QuadTreeKey.cpp,
@@ -10768,9 +11017,9 @@
source/index/quadtree/Root.cpp: Filenames renamed to match class
names (matching JTS)
-2006-03-22 12:22 strk
+2006-03-22 12:22 Sandro Santilli <strk at keybit.net>
- * configure.in, source/geomgraph/EdgeList.cpp,
+ * [r1266] configure.in, source/geomgraph/EdgeList.cpp,
source/headers/geos/index/quadtree,
source/headers/geos/index/quadtree/.cvsignore,
@@ -10794,9 +11043,9 @@
indexQuadtree.h split
-2006-03-22 11:19 strk
+2006-03-22 11:19 Sandro Santilli <strk at keybit.net>
- * capi/geos_c.cpp, configure.in,
+ * [r1265] capi/geos_c.cpp, configure.in,
source/headers/geos/opPolygonize.h,
source/headers/geos/operation/Makefile.am,
source/headers/geos/operation/polygonize,
@@ -10815,16 +11064,17 @@
source/operation/polygonize/polygonizeEdgeRing.cpp:
opPolygonize.h headers split.
-2006-03-22 11:18 strk
+2006-03-22 11:18 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferSubgraph.cpp,
+ * [r1264] source/operation/buffer/BufferSubgraph.cpp,
source/operation/buffer/OffsetCurveSetBuilder.cpp: Changed back
'unable to find edge to compute depths' from assertion to
TopologyException
-2006-03-22 10:13 strk
+2006-03-22 10:13 Sandro Santilli <strk at keybit.net>
- * capi/geos_c.cpp, configure.in, source/headers/geos/opLinemerge.h,
+ * [r1263] capi/geos_c.cpp, configure.in,
+ source/headers/geos/opLinemerge.h,
source/headers/geos/operation/linemerge,
source/headers/geos/operation/linemerge/.cvsignore,
source/headers/geos/operation/linemerge/EdgeString.h,
@@ -10841,9 +11091,9 @@
source/operation/linemerge/LineMerger.cpp,
source/operation/linemerge/LineSequencer.cpp: opLinemerge.h split
-2006-03-21 21:42 strk
+2006-03-21 21:42 Sandro Santilli <strk at keybit.net>
+ * [r1262] configure.in, source/headers/geos/Makefile.am,
source/headers/geos/planargraph,
source/headers/geos/planargraph.h,
source/headers/geos/planargraph/.cvsignore,
@@ -10886,9 +11136,9 @@
source/planargraph/planarSubgraph.cpp: planargraph.h header
split, planargraph:: classes renamed to match JTS symbols
-2006-03-21 17:55 strk
+2006-03-21 17:55 Sandro Santilli <strk at keybit.net>
- * configure.in, source/geom/Geometry.cpp,
+ * [r1261] configure.in, source/geom/Geometry.cpp,
source/headers/geos/opDistance.h,
source/headers/geos/opOverlay.h, source/headers/geos/opRelate.h,
source/headers/geos/opValid.h, source/headers/geos/operation.h,
@@ -10906,9 +11156,9 @@
source/operation/distance/GeometryLocation.cpp: opDistance.h
header split
-2006-03-21 17:11 strk
+2006-03-21 17:11 Sandro Santilli <strk at keybit.net>
+ * [r1260] configure.in, source/geom/Geometry.cpp,
source/headers/geos/opPredicate.h,
source/headers/geos/operation/predicate,
@@ -10922,9 +11172,9 @@
source/operation/predicate/SegmentIntersectionTester.cpp:
opPredicate.h header split
-2006-03-21 13:11 strk
+2006-03-21 13:11 Sandro Santilli <strk at keybit.net>
+ * [r1259] configure.in, source/geom/Geometry.cpp,
source/headers/geos/operation/relate,
@@ -10949,17 +11199,17 @@
source/operation/valid/ConsistentAreaTester.cpp: opRelate.h
header split
-2006-03-21 11:20 strk
+2006-03-21 11:20 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/TestInteriorPoint.xml: Changed expected result to
- the obtained one :)
+ * [r1258] tests/xmltester/TestInteriorPoint.xml: Changed expected
+ result to the obtained one :)
We're not cheating, it's a 2-vertex linestring for
which an InteriorPoint is requested, both vertexes
are correct answer (equidistant from centroid).
-2006-03-21 11:12 strk
+2006-03-21 11:12 Sandro Santilli <strk at keybit.net>
- * source/algorithm/CGAlgorithms.cpp,
+ * [r1257] source/algorithm/CGAlgorithms.cpp,
source/algorithm/CentroidLine.cpp,
@@ -10982,9 +11232,9 @@
source/headers/geos/algorithm/SIRtreePointInRing.h: Cleanups:
headers inclusion and Log section
-2006-03-21 10:47 strk
+2006-03-21 10:47 Sandro Santilli <strk at keybit.net>
- * configure.in, source/headers/geos/index/Makefile.am,
+ * [r1256] configure.in, source/headers/geos/index/Makefile.am,
source/headers/geos/index/strtree,
source/headers/geos/index/strtree/.cvsignore,
source/headers/geos/index/strtree/AbstractNode.h,
@@ -11003,14 +11253,14 @@
source/index/strtree/SIRtree.cpp,
source/index/strtree/STRtree.cpp: indexStrtree.h split
-2006-03-21 10:46 strk
+2006-03-21 10:46 Sandro Santilli <strk at keybit.net>
- * source/algorithm/RobustDeterminant.cpp: streamlined header
- inclusion, put original copyright on top
+ * [r1255] source/algorithm/RobustDeterminant.cpp: streamlined
+ header inclusion, put original copyright on top
-2006-03-21 10:01 strk
+2006-03-21 10:01 Sandro Santilli <strk at keybit.net>
+ * [r1254] configure.in, source/headers/geos/index/Makefile.am,
source/headers/geos/index/sweepline,
source/headers/geos/index/sweepline/.cvsignore,
source/headers/geos/index/sweepline/Makefile.am,
@@ -11027,11 +11277,11 @@
indexSweepline.h header split
-2006-03-20 18:18 strk
+2006-03-20 18:18 Sandro Santilli <strk at keybit.net>
- * capi/geos_c.cpp, configure.in, source/headers/geos/Makefile.am,
- source/headers/geos/io, source/headers/geos/io.h,
- source/headers/geos/io/.cvsignore,
+ * [r1253] capi/geos_c.cpp, configure.in,
+ source/headers/geos/Makefile.am, source/headers/geos/io,
+ source/headers/geos/io.h, source/headers/geos/io/.cvsignore,
source/headers/geos/io/ByteOrderValues.h,
@@ -11050,29 +11300,29 @@
source/io/Writer.cpp, source/operation/buffer/BufferSubgraph.cpp:
io.h header split
-2006-03-20 17:40 strk
+2006-03-20 17:40 Sandro Santilli <strk at keybit.net>
- * source/index/quadtree/DoubleBits.cpp: <cmath> included when
- appropriate
+ * [r1252] source/index/quadtree/DoubleBits.cpp: <cmath> included
+ when appropriate
-2006-03-20 17:27 strk
+2006-03-20 17:27 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom/CoordinateSequence.h,
+ * [r1251] source/headers/geos/geom/CoordinateSequence.h,
source/headers/geos/geom/GeometryFactory.h: Bug #72 - Missing
<vector> header
-2006-03-20 17:17 strk
+2006-03-20 17:17 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geomgraph/index/Makefile.am,
+ * [r1250] source/headers/geos/geomgraph/index/Makefile.am,
source/headers/geos/noding/snapround/Makefile.am,
source/headers/geos/operation/buffer/Makefile.am,
source/headers/geos/operation/valid/Makefile.am: Fixed geosdir
-2006-03-20 16:57 strk
+2006-03-20 16:57 Sandro Santilli <strk at keybit.net>
+ * [r1249] configure.in, source/geom/Geometry.cpp,
source/headers/geos/Makefile.am, source/headers/geos/index,
source/headers/geos/index/.cvsignore,
source/headers/geos/index/ItemVisitor.h,
@@ -11116,70 +11366,73 @@
spatialindex.h and opValid.h headers split
-2006-03-20 16:08 strk
+2006-03-20 16:08 Sandro Santilli <strk at keybit.net>
- * macros/ac_python_devel.m4: redirected find stderr to /dev/null
+ * [r1248] macros/ac_python_devel.m4: redirected find stderr to
+ /dev/null
-2006-03-20 13:20 strk
+2006-03-20 13:20 Sandro Santilli <strk at keybit.net>
- * source/operation/overlay/PolygonBuilder.cpp: Changed assertion to
- TopologyException for the "orphaned" hole case
+ * [r1247] source/operation/overlay/PolygonBuilder.cpp: Changed
+ assertion to TopologyException for the "orphaned" hole case
in order to allow for reduced precision ops to catch the case.
-2006-03-20 12:33 strk
+2006-03-20 12:33 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/overlay/PolygonBuilder.h,
+ * [r1246] source/headers/geos/operation/overlay/PolygonBuilder.h,
source/operation/overlay/PolygonBuilder.cpp: Simplified some
privat methods to use refs instead of pointers, added
debugging section for failiures of holes/shells associations
-2006-03-20 12:32 strk
+2006-03-20 12:32 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geomgraph/EdgeRing.h: Added note about
- responsibility of return from ::toPolygon
+ * [r1245] source/headers/geos/geomgraph/EdgeRing.h: Added note
+ about responsibility of return from ::toPolygon
-2006-03-20 12:03 strk
+2006-03-20 12:03 Sandro Santilli <strk at keybit.net>
- * source/geom/Geometry.cpp, source/headers/geos/geom/Geometry.h:
- Added operator<< for Geometry, writing HEXWKB
+ * [r1244] source/geom/Geometry.cpp,
+ source/headers/geos/geom/Geometry.h: Added operator<< for
+ Geometry, writing HEXWKB
-2006-03-20 11:42 strk
+2006-03-20 11:42 Sandro Santilli <strk at keybit.net>
- * source/noding/Octant.cpp,
+ * [r1243] source/noding/Octant.cpp,
source/operation/buffer/OffsetCurveSetBuilder.cpp: Added missing
<cmath> include
-2006-03-20 10:42 strk
+2006-03-20 10:42 Sandro Santilli <strk at keybit.net>
- * source/operation/predicate/RectangleContains.cpp,
+ * [r1242] source/operation/predicate/RectangleContains.cpp,
source/operation/predicate/RectangleIntersects.cpp: Bug #61 -
Disambiguated geom::Polygon use
-2006-03-20 10:14 strk
+2006-03-20 10:14 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/timeval.h: Bug #69 - Check for macro
+ * [r1241] source/headers/geos/timeval.h: Bug #69 - Check for macro
WIN32_LEAN_AND_MEAN
-2006-03-20 10:13 strk
+2006-03-20 10:13 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/SubgraphDepthLocater.cpp: Bug #71 -
- Missing <algorithm>
+ * [r1240] source/operation/buffer/SubgraphDepthLocater.cpp: Bug #71
+ - Missing <algorithm>
-2006-03-20 10:12 strk
+2006-03-20 10:12 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom/Coordinate.h: Bug #70 - Small fix in fwd
- decl. of CoordinateLessThen
+ * [r1239] source/headers/geos/geom/Coordinate.h: Bug #70 - Small
+ fix in fwd decl. of CoordinateLessThen
-2006-03-20 10:11 strk
+2006-03-20 10:11 Sandro Santilli <strk at keybit.net>
- * source/geom/GeometryFactory.cpp: Bug #67 - Debugging helpers in
- GeometryFactory class
+ * [r1238] source/geom/GeometryFactory.cpp: Bug #67 - Debugging
+ helpers in GeometryFactory class
-2006-03-17 16:48 strk
+2006-03-17 16:48 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/opRelate.h, source/headers/geos/opValid.h,
- source/io/Unload.cpp, source/operation/relate/EdgeEndBundle.cpp,
+ * [r1237] source/headers/geos/opRelate.h,
+ source/headers/geos/opValid.h, source/io/Unload.cpp,
+ source/operation/relate/EdgeEndBundle.cpp,
source/operation/relate/RelateComputer.cpp,
source/operation/relate/RelateOp.cpp,
@@ -11193,14 +11446,14 @@
opRelate.h
and opValid.h, updated .cpp files to allow build.
-2006-03-17 14:56 strk
+2006-03-17 14:56 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/XMLTester.cpp: Fixed filename normalizer for sql
- output
+ * [r1236] tests/xmltester/XMLTester.cpp: Fixed filename normalizer
+ for sql output
-2006-03-17 13:24 strk
+2006-03-17 13:24 Sandro Santilli <strk at keybit.net>
+ * [r1235] configure.in, source/geom/Geometry.cpp,
source/headers/geos/operation/overlay,
@@ -11235,81 +11488,82 @@
implementation files. ElevationMatrixFilter code moved from own
file to ElevationMatrix.cpp (ideally a class-private).
-2006-03-16 13:30 strk
+2006-03-16 13:30 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/linemerge.xml: Added missing testfile
+ * [r1234] tests/xmltester/linemerge.xml: Added missing testfile
-2006-03-16 13:29 strk
+2006-03-16 13:29 Sandro Santilli <strk at keybit.net>
- * tests/unit/Makefile.am, tests/unit/geom/LineSegment.cpp: new unit
- test for LineSegment (adding tests would be helpful)
+ * [r1233] tests/unit/Makefile.am, tests/unit/geom/LineSegment.cpp:
+ new unit test for LineSegment (adding tests would be helpful)
-2006-03-16 13:28 strk
+2006-03-16 13:28 Sandro Santilli <strk at keybit.net>
- * source/geom/LineSegment.cpp,
+ * [r1232] source/geom/LineSegment.cpp,
source/headers/geos/geom/LineSegment.inl: obsoleted
getCoordinate(), replaced by operator[]
-2006-03-16 13:27 strk
+2006-03-16 13:27 Sandro Santilli <strk at keybit.net>
- * README: Added notes about testing
+ * [r1231] README: Added notes about testing
-2006-03-16 10:47 strk
+2006-03-16 10:47 Sandro Santilli <strk at keybit.net>
+ * [r1230] tests/tut/tut.h, tests/tut/tut_reporter.h,
tests/tut/tut_restartable.h, tests/unit/geom/Envelope.cpp,
tests/unit/geom/Geometry/isRectangle.cpp,
tests/unit/geos_unit.cpp: Bug #65 - Command line changes and EOL
fixes Unit Test
-2006-03-16 10:42 strk
+2006-03-16 10:42 Sandro Santilli <strk at keybit.net>
- * source/geom/Geometry.cpp: Bug #64 - Not all control paths return
- a value in geos::geom::Geometry::getClassSortIndex
+ * [r1229] source/geom/Geometry.cpp: Bug #64 - Not all control paths
+ return a value in geos::geom::Geometry::getClassSortIndex
-2006-03-16 10:38 strk
+2006-03-16 10:38 Sandro Santilli <strk at keybit.net>
- * source/algorithm/LineIntersector.cpp: Bug #63 - Remove
+ * [r1228] source/algorithm/LineIntersector.cpp: Bug #63 - Remove
unreferenced local variable warning
-2006-03-16 09:37 strk
+2006-03-16 09:37 Sandro Santilli <strk at keybit.net>
- * tests/tut, tests/tut/tut.h, tests/tut/tut_reporter.h,
+ * [r1227] tests/tut, tests/tut/tut.h, tests/tut/tut_reporter.h,
tests/tut/tut_restartable.h, tests/unit/Makefile.am,
tests/unit/envelope_class_test.cpp, tests/unit/geom,
tests/unit/geom/Envelope.cpp, tests/unit/geom/Geometry,
tests/unit/geos_unit.cpp: Initial unit tests
-2006-03-15 18:59 strk
+2006-03-15 18:59 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/IsSimpleOp.h: Bug #62: 'struct'
- CoordinateLessThen in forward declaration
+ * [r1226] source/headers/geos/operation/IsSimpleOp.h: Bug #62:
+ 'struct' CoordinateLessThen in forward declaration
-2006-03-15 18:57 strk
+2006-03-15 18:57 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/SubgraphDepthLocater.cpp: small cleanup
+ * [r1225] source/operation/buffer/SubgraphDepthLocater.cpp: small
+ cleanup
- * source/operation/buffer/BufferBuilder.cpp: cleanups in DEBUG
- lines
+ * [r1224] source/operation/buffer/BufferBuilder.cpp: cleanups in
+ DEBUG lines
-2006-03-15 18:56 strk
+2006-03-15 18:56 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferOp.cpp: Temporary hack to avoid
- snapround:: Noders (still using ScaledNoder wrapper)
+ * [r1223] source/operation/buffer/BufferOp.cpp: Temporary hack to
+ avoid snapround:: Noders (still using ScaledNoder wrapper)
to allow for buffer_snapround.xml test to succeed
-2006-03-15 18:55 strk
+2006-03-15 18:55 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/buffer_snapround.xml: Added xml testfile showing
- bug in snapround:: noders
+ * [r1222] tests/xmltester/buffer_snapround.xml: Added xml testfile
+ showing bug in snapround:: noders
-2006-03-15 18:44 strk
+2006-03-15 18:44 Sandro Santilli <strk at keybit.net>
- * doc/example.cpp, source/geom/Envelope.cpp,
+ * [r1221] doc/example.cpp, source/geom/Envelope.cpp,
source/geom/LineSegment.cpp, source/geom/PrecisionModel.cpp,
source/headers/geos/geom/Coordinate.inl,
source/index/bintree/Key.cpp,
@@ -11319,21 +11573,22 @@
source/util/GeometricShapeFactory.cpp: Bug #60 - Missing <cmath>
header in some files
-2006-03-15 17:33 strk
+2006-03-15 17:33 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferSubgraph.cpp: Changed operator<< to
- use operator<< for Nodes
+ * [r1220] source/operation/buffer/BufferSubgraph.cpp: Changed
+ operator<< to use operator<< for Nodes
-2006-03-15 17:17 strk
+2006-03-15 17:17 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geomgraph/DirectedEdgeStar.h,
+ * [r1219] source/headers/geos/geomgraph/DirectedEdgeStar.h,
source/headers/geos/geomgraph/index/SweepLineEvent.h: Added
missing forward declarations
-2006-03-15 17:16 strk
+2006-03-15 17:16 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/Depth.cpp, source/geomgraph/DirectedEdge.cpp,
+ * [r1218] source/geomgraph/Depth.cpp,
source/geomgraph/DirectedEdgeStar.cpp, source/geomgraph/Edge.cpp,
source/geomgraph/EdgeEnd.cpp, source/geomgraph/EdgeEndStar.cpp,
source/geomgraph/EdgeIntersection.cpp,
@@ -11356,87 +11611,89 @@
source/geomgraph/index/SweepLineSegment.cpp: streamlined headers
inclusion
-2006-03-15 16:27 strk
+2006-03-15 16:27 Sandro Santilli <strk at keybit.net>
- operator<< for Node class
+ * [r1217] source/geomgraph/Node.cpp,
+ source/headers/geos/geomgraph/Node.h: operator<< for Node class
-2006-03-15 15:50 strk
+2006-03-15 15:50 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/buffer/SubgraphDepthLocater.h,
+ * [r1216]
+ source/headers/geos/operation/buffer/SubgraphDepthLocater.h,
source/operation/buffer/SubgraphDepthLocater.cpp: const
correctness, cleanups
-2006-03-15 15:27 strk
+2006-03-15 15:27 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geomgraph/DirectedEdge.h,
+ * [r1215] source/headers/geos/geomgraph/DirectedEdge.h,
source/headers/geos/geomgraph/EdgeEnd.h: cleanups
-2006-03-15 15:26 strk
+2006-03-15 15:26 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/DirectedEdge.cpp, source/geomgraph/EdgeRing.cpp:
- Cleanups
+ * [r1214] source/geomgraph/DirectedEdge.cpp,
+ source/geomgraph/EdgeRing.cpp: Cleanups
-2006-03-15 13:03 strk
+2006-03-15 13:03 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferBuilder.cpp: removed leftover
- debugging line
+ * [r1213] source/operation/buffer/BufferBuilder.cpp: removed
+ leftover debugging line
-2006-03-15 12:54 strk
+2006-03-15 12:54 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/opBuffer.h: Removed DepthSegment.h include
+ * [r1212] source/headers/geos/opBuffer.h: Removed DepthSegment.h
+ include
- * source/headers/geos/operation/buffer/DepthSegment.h,
+ * [r1211] source/headers/geos/operation/buffer/DepthSegment.h,
source/headers/geos/operation/buffer/Makefile.am: Removed public
DepthSegment definition (moved inside SubgraphDepthLocater
implementation)
-2006-03-15 12:52 strk
+2006-03-15 12:52 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/DepthSegment.cpp,
+ * [r1210] source/operation/buffer/DepthSegment.cpp,
source/operation/buffer/Makefile.am,
source/operation/buffer/SubgraphDepthLocater.cpp: DepthSegment
class moved inside SubgraphDepthLocator implementaion
as it was private to this file in JTS. Also, changed to reduce
copies of LineSegment copies.
-2006-03-15 11:45 strk
+2006-03-15 11:45 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/buffer/BufferSubgraph.h: doxygen
- comments
+ * [r1209] source/headers/geos/operation/buffer/BufferSubgraph.h:
+ doxygen comments
-2006-03-15 11:44 strk
+2006-03-15 11:44 Sandro Santilli <strk at keybit.net>
- * source/operation/overlay/PolygonBuilder.cpp: debug blocks,
- dumping SQL when GEOS_DEBUG > 1
+ * [r1208] source/operation/overlay/PolygonBuilder.cpp: debug
+ blocks, dumping SQL when GEOS_DEBUG > 1
-2006-03-15 11:42 strk
+2006-03-15 11:42 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferBuilder.cpp: more debugging lines,
- with two levels of debugging handled
+ * [r1207] source/operation/buffer/BufferBuilder.cpp: more debugging
+ lines, with two levels of debugging handled
-2006-03-15 11:39 strk
+2006-03-15 11:39 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferSubgraph.cpp: comments cleanup,
- changed computeDepths to use a list<> rather then a vector
- (performance related)
+ * [r1206] source/operation/buffer/BufferSubgraph.cpp: comments
+ cleanup, changed computeDepths to use a list<> rather then a
+ vector (performance related)
-2006-03-15 10:40 strk
+2006-03-15 10:40 Sandro Santilli <strk at keybit.net>
- * doc/Doxyfile.in: Fixed to allow doxygen runs from external
- builddir
+ * [r1205] doc/Doxyfile.in: Fixed to allow doxygen runs from
+ external builddir
-2006-03-15 09:51 strk
+2006-03-15 09:51 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/noding/SegmentString.inl,
+ * [r1204] source/headers/geos/noding/SegmentString.inl,
source/headers/geos/noding/SimpleNoder.h: streamlined header
usage
- * source/noding/IntersectionAdder.cpp,
+ * [r1203] source/noding/IntersectionAdder.cpp,
source/noding/IntersectionFinderAdder.cpp,
source/noding/IteratedNoder.cpp, source/noding/MCIndexNoder.cpp,
source/noding/NodingValidator.cpp, source/noding/Octant.cpp,
@@ -11447,75 +11704,77 @@
source/noding/snapround/SimpleSnapRounder.cpp: streamlined
headers usage
-2006-03-15 09:13 strk
+2006-03-15 09:13 Sandro Santilli <strk at keybit.net>
- * source/geom/Polygon.cpp: updated port info
+ * [r1202] source/geom/Polygon.cpp: updated port info
-2006-03-15 09:12 strk
+2006-03-15 09:12 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom/Polygon.h: isSimple doc
+ * [r1201] source/headers/geos/geom/Polygon.h: isSimple doc
-2006-03-14 17:46 strk
+2006-03-14 17:46 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/util/Assert.h: Removed unrequired include
+ * [r1200] source/headers/geos/util/Assert.h: Removed unrequired
+ include
-2006-03-14 17:10 strk
+2006-03-14 17:10 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferSubgraph.cpp: cleanups
+ * [r1199] source/operation/buffer/BufferSubgraph.cpp: cleanups
-2006-03-14 17:08 strk
+2006-03-14 17:08 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/opOverlay.h,
+ * [r1198] source/headers/geos/opOverlay.h,
source/operation/overlay/MaximalEdgeRing.cpp: comments cleanup,
integrity checks
-2006-03-14 16:55 strk
+2006-03-14 16:55 Sandro Santilli <strk at keybit.net>
- * source/operation/overlay/PolygonBuilder.cpp: oops, GEOS_DEBUG
- default to 0
+ * [r1197] source/operation/overlay/PolygonBuilder.cpp: oops,
+ GEOS_DEBUG default to 0
+ * [r1196] source/headers/geos/opOverlay.h,
source/operation/overlay/PolygonBuilder.cpp: comments cleanup
-2006-03-14 16:53 strk
+2006-03-14 16:53 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/Edge.cpp: removed endline from printing funx
+ * [r1195] source/geomgraph/Edge.cpp: removed endline from printing
+ funx
-2006-03-14 16:08 strk
+2006-03-14 16:08 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/buffer/BufferBuilder.h,
+ * [r1194] source/headers/geos/operation/buffer/BufferBuilder.h,
source/operation/buffer/BufferBuilder.cpp: changed buildSubgraphs
signature to use refs rather then pointers, made it
const-correct. Reduced heap allocations in createSubgraphs()
-2006-03-14 15:46 strk
+2006-03-14 15:46 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/PlanarGraph.cpp,
+ * [r1193] source/geomgraph/PlanarGraph.cpp,
source/headers/geos/geomgraph/PlanarGraph.h: Added
PlanarGraph::getNodes(vector&) func, to reduce useless heap
allocations
-2006-03-14 15:32 strk
+2006-03-14 15:32 Sandro Santilli <strk at keybit.net>
+ * [r1192] source/geom/Coordinate.cpp,
source/geomgraph/DirectedEdge.cpp, source/geomgraph/Edge.cpp,
source/geomgraph/Node.cpp: Cleaned up toString funx (more WKT
friendly)
-2006-03-14 14:16 strk
+2006-03-14 14:16 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/buffer/BufferSubgraph.h,
+ * [r1191] source/headers/geos/operation/buffer/BufferSubgraph.h,
source/operation/overlay/PolygonBuilder.cpp: operator<< for
BufferSubgraph, more debugging calls
-2006-03-14 12:55 strk
+2006-03-14 12:55 Sandro Santilli <strk at keybit.net>
+ * [r1190] configure.in, source/geom/Geometry.cpp,
source/geomgraph/Label.cpp, source/geomgraph/Node.cpp,
source/geomgraph/NodeMap.cpp,
source/headers/geos/geomgraph/Makefile.am,
@@ -11558,26 +11817,26 @@
source/operation/buffer/BufferOp.cpp: Headers split:
geomgraphindex.h, nodingSnapround.h
-2006-03-14 11:03 strk
+2006-03-14 11:03 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/Edge.cpp, source/geomgraph/EdgeList.cpp,
+ * [r1189] source/geomgraph/Edge.cpp, source/geomgraph/EdgeList.cpp,
source/headers/geos/geomgraph/EdgeList.h: Added operator<< for
Edge and EdgeList
-2006-03-14 00:37 strk
+2006-03-14 00:37 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/operation/buffer/Makefile.am: Fixed include
- filenames
+ * [r1188] source/headers/geos/operation/buffer/Makefile.am: Fixed
+ include filenames
-2006-03-14 00:36 strk
+2006-03-14 00:36 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferOp.cpp: Reduced 'buffer' headers
- inclusion
+ * [r1187] source/operation/buffer/BufferOp.cpp: Reduced 'buffer'
+ headers inclusion
-2006-03-14 00:19 strk
+2006-03-14 00:19 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/opBuffer.h,
+ * [r1186] source/headers/geos/opBuffer.h,
source/headers/geos/operation/buffer,
source/headers/geos/operation/buffer/.cvsignore,
@@ -11599,135 +11858,139 @@
split, streamlined headers in some (not all) files in
operation/buffer/
-2006-03-13 22:33 strk
+2006-03-13 22:33 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom/LineSegment.h: Added missing forward
- declarations
+ * [r1185] source/headers/geos/geom/LineSegment.h: Added missing
+ forward declarations
-2006-03-13 21:54 strk
+2006-03-13 21:54 Sandro Santilli <strk at keybit.net>
- * source/geom/Coordinate.cpp, source/geom/CoordinateSequence.cpp,
+ * [r1184] source/geom/Coordinate.cpp,
+ source/geom/CoordinateSequence.cpp,
source/geom/GeometryComponentFilter.cpp,
source/geom/IntersectionMatrix.cpp, source/geom/LineSegment.cpp,
source/geom/Triangle.cpp: Streamlined headers inclusion.
-2006-03-13 21:19 strk
+2006-03-13 21:19 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/noding/ScaledNoder.h,
+ * [r1183] source/headers/geos/noding/ScaledNoder.h,
source/noding/ScaledNoder.cpp: Fixed bug in ScaledNoder scaling
mechanism (hugly code, due to CoordinateSequence visitor pattern
design). Tests are still failing so this possibly needs some
other fix. Streamlined includes by implementation file.
-2006-03-13 21:14 strk
+2006-03-13 21:14 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/noding/SegmentString.h: Added missing forward
- declarations
+ * [r1182] source/headers/geos/noding/SegmentString.h: Added missing
-2006-03-13 21:13 strk
+2006-03-13 21:13 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom/CoordinateFilter.h: Added comment about
- possible refactoring
+ * [r1181] source/headers/geos/geom/CoordinateFilter.h: Added
+ comment about possible refactoring
-2006-03-11 16:58 strk
+2006-03-11 16:58 Sandro Santilli <strk at keybit.net>
+ * [r1180] source/headers/geos/opBuffer.h,
source/operation/buffer/OffsetCurveBuilder.cpp: Fixed bug in
OffsetCurveBuilder::getCoordinates.
-2006-03-10 15:50 strk
+2006-03-10 15:50 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/EdgeRing.cpp: Changed 'found null Directed Edge'
- from an Assertion to a TopologyException, to give
+ * [r1179] source/geomgraph/EdgeRing.cpp: Changed 'found null
+ Directed Edge' from an Assertion to a TopologyException, to give
'precision-reducing' overlay operation a chance to handle it (it
seems to work)
-2006-03-10 13:07 strk
+2006-03-10 13:07 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/EdgeRing.cpp: fine-tuned includes, reverted
- Assert=>assert due to user-input based failure
+ * [r1178] source/geomgraph/EdgeRing.cpp: fine-tuned includes,
+ reverted Assert=>assert due to user-input based failure
-2006-03-10 12:50 strk
+2006-03-10 12:50 Sandro Santilli <strk at keybit.net>
- * configure.in, tests/unit/Makefile.am,
+ * [r1177] configure.in, tests/unit/Makefile.am,
tests/unit/envelope_class_test.cpp: boost detection code fix,
first UTF source for testing purposes
-2006-03-10 12:43 strk
+2006-03-10 12:43 Sandro Santilli <strk at keybit.net>
- * TODO: updated
+ * [r1176] TODO: updated
-2006-03-10 12:09 strk
+2006-03-10 12:09 Sandro Santilli <strk at keybit.net>
- * configure.in: Update configure script to work with new boost.m4
- file
+ * [r1175] configure.in: Update configure script to work with new
+ boost.m4 file
-2006-03-10 11:49 strk
+2006-03-10 11:49 Sandro Santilli <strk at keybit.net>
- * macros/boost.m4: Updated boost detection macro
+ * [r1174] macros/boost.m4: Updated boost detection macro
-2006-03-10 11:41 strk
+2006-03-10 11:41 Sandro Santilli <strk at keybit.net>
- * source/index/quadtree/QuadTreeNodeBase.cpp: Added missing
+ * [r1173] source/index/quadtree/QuadTreeNodeBase.cpp: Added missing
<algorithm> include (bug#56)
-2006-03-10 11:10 strk
+2006-03-10 11:10 Sandro Santilli <strk at keybit.net>
- * configure.in, macros/boost.m4, tests/Makefile.am, tests/unit,
- tests/unit/.cvsignore, tests/unit/Makefile.am: Initial boost
- detection code
+ * [r1172] configure.in, macros/boost.m4, tests/Makefile.am,
+ tests/unit, tests/unit/.cvsignore, tests/unit/Makefile.am:
+ Initial boost detection code
-2006-03-10 11:09 strk
+2006-03-10 11:09 Sandro Santilli <strk at keybit.net>
- * source/operation/valid/ConnectedInteriorTester.cpp: Comments
- cleanup
+ * [r1171] source/operation/valid/ConnectedInteriorTester.cpp:
+ Comments cleanup
-2006-03-10 10:48 strk
+2006-03-10 10:48 Sandro Santilli <strk at keybit.net>
- * source/Makefile.vc: Bug #58 - Patch to makefile.vc after big
- refactoring commit
+ * [r1170] source/Makefile.vc: Bug #58 - Patch to makefile.vc after
+ big refactoring commit
-2006-03-10 10:44 strk
+2006-03-10 10:44 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferBuilder.cpp,
+ * [r1169] source/operation/buffer/BufferBuilder.cpp,
source/operation/overlay/ElevationMatrixFilter.cpp,
source/precision/EnhancedPrecisionOp.cpp: Unreferenced exception
objects cleanup (#52)
-2006-03-10 10:37 strk
+2006-03-10 10:37 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/index/SimpleSweepLineIntersector.cpp: Added
- missing <algorithm> include (#55)
+ * [r1168] source/geomgraph/index/SimpleSweepLineIntersector.cpp:
+ Added missing <algorithm> include (#55)
-2006-03-10 10:34 strk
+2006-03-10 10:34 Sandro Santilli <strk at keybit.net>
- * source/geom/Polygon.cpp: Added missing <algorithm> include (#54)
+ * [r1167] source/geom/Polygon.cpp: Added missing <algorithm>
+ include (#54)
-2006-03-09 18:22 strk
+2006-03-09 18:22 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/Makefile.am, tests/xmltester/TestIsValid.xml:
- Added isvalid test for latest validop patch
+ * [r1166] tests/xmltester/Makefile.am,
+ tests/xmltester/TestIsValid.xml: Added isvalid test for latest
+ validop patch
-2006-03-09 18:18 strk
+2006-03-09 18:18 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/opOverlay.h, source/headers/geos/opValid.h,
+ * [r1165] source/headers/geos/opOverlay.h,
source/operation/overlay/MaximalEdgeRing.cpp,
memory-friendly MaximalEdgeRing::buildMinimalRings()
implementation.
Applied patch to IsValid operation from JTS-1.7.1
-2006-03-09 17:40 strk
+2006-03-09 17:40 Sandro Santilli <strk at keybit.net>
+ * [r1164] source/headers/geos/opBuffer.h,
source/operation/buffer/OffsetCurveBuilder.cpp: Fixed bug#33
(hopefully)
-2006-03-09 16:46 strk
+2006-03-09 16:46 Sandro Santilli <strk at keybit.net>
- * configure.in, source/algorithm/CGAlgorithms.cpp,
+ * [r1163] configure.in, source/algorithm/CGAlgorithms.cpp,
source/algorithm/CentroidArea.cpp,
source/algorithm/CentroidPoint.cpp,
@@ -11941,92 +12204,94 @@
tests/xmltester/XMLTester.cpp, tests/xmltester/buffer.xml:
geos::geom namespace definition, first pass at headers split
-2006-03-09 16:18 strk
+2006-03-09 16:18 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/Makefile.am: Fixed to allow tests from external
- build tree (thanks Norman:)
+ * [r1162] tests/xmltester/Makefile.am: Fixed to allow tests from
+ external build tree (thanks Norman:)
-2006-03-09 16:01 strk
+2006-03-09 16:01 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/Position.cpp,
+ * [r1161] source/geomgraph/Position.cpp,
source/operation/overlay/ElevationMatrixFilter.cpp: Fixed
debugging lines
-2006-03-09 15:50 strk
+2006-03-09 15:50 Sandro Santilli <strk at keybit.net>
- * source/operation/overlay/OverlayOp.cpp: Fixed debugging lines,
- added missing header
+ * [r1160] source/operation/overlay/OverlayOp.cpp: Fixed debugging
+ lines, added missing header
-2006-03-09 15:47 strk
+2006-03-09 15:47 Sandro Santilli <strk at keybit.net>
- * source/operation/linemerge/LineMergeGraph.cpp: Fixed debugging
- lines
+ * [r1159] source/operation/linemerge/LineMergeGraph.cpp: Fixed
+ debugging lines
-2006-03-09 15:39 strk
+2006-03-09 15:39 Sandro Santilli <strk at keybit.net>
- * source/index/quadtree/QuadTreeKey.cpp,
+ * [r1158] source/index/quadtree/QuadTreeKey.cpp,
source/index/quadtree/QuadTreeRoot.cpp,
source/noding/SegmentNodeList.cpp: Fixed debugging lines
-2006-03-09 14:48 strk
+2006-03-09 14:48 Sandro Santilli <strk at keybit.net>
- * capi/Makefile.am: Added missing INCLUDES line
+ * [r1157] capi/Makefile.am: Added missing INCLUDES line
-2006-03-07 14:21 strk
+2006-03-07 14:21 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/XMLTester.cpp: Leak plugged, tweeked output to be
- nice with --sql-output
+ * [r1156] tests/xmltester/XMLTester.cpp: Leak plugged, tweeked
+ output to be nice with --sql-output
-2006-03-07 14:20 strk
+2006-03-07 14:20 Sandro Santilli <strk at keybit.net>
+ * [r1155] source/headers/geos/opBuffer.h,
source/operation/buffer/OffsetCurveBuilder.cpp: Big deal of heap
allocations reduction
-2006-03-07 14:18 strk
+2006-03-07 14:18 Sandro Santilli <strk at keybit.net>
- * source/util/Profiler.cpp: Profiler singleton implemented with a
- function-static Profiler instance
+ * [r1154] source/util/Profiler.cpp: Profiler singleton implemented
+ with a function-static Profiler instance
-2006-03-07 12:42 strk
+2006-03-07 12:42 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/buffer.xml: addedvalidity test for a case with
- invalid input
+ * [r1153] tests/xmltester/buffer.xml: addedvalidity test for a case
+ with invalid input
-2006-03-07 12:41 strk
+2006-03-07 12:41 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/XMLTester.cpp, tests/xmltester/XMLTester.h: Added
- --wkb-output and made --sql-output compatible with -v
+ * [r1152] tests/xmltester/XMLTester.cpp,
+ tests/xmltester/XMLTester.h: Added --wkb-output and made
+ --sql-output compatible with -v
-2006-03-07 11:22 strk
+2006-03-07 11:22 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/XMLTester.cpp: table name for sqlOutput
+ * [r1151] tests/xmltester/XMLTester.cpp: table name for sqlOutput
normalized
-2006-03-07 11:06 strk
+2006-03-07 11:06 Sandro Santilli <strk at keybit.net>
- --sql-output switch for debugging
+ * [r1150] tests/xmltester/XMLTester.cpp,
+ tests/xmltester/XMLTester.h: Added --sql-output switch for
+ debugging
-2006-03-07 10:46 strk
+2006-03-07 10:46 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/XMLTester.cpp: verbose validity errors
+ * [r1149] tests/xmltester/XMLTester.cpp: verbose validity errors
-2006-03-06 21:27 strk
+2006-03-06 21:27 Sandro Santilli <strk at keybit.net>
- * doc/example.cpp, source/headers/geos/geom.h,
+ * [r1148] doc/example.cpp, source/headers/geos/geom.h,
source/headers/geos/opRelate.h, tests/xmltester/XMLTester.cpp:
Cascading fixed after Unload definition moved to geos::io
namespace
-2006-03-06 19:43 strk
+2006-03-06 19:43 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/unload.h: Fixed Unload class definition
- namespace (geos::io)
+ * [r1147] source/headers/geos/unload.h: Fixed Unload class
+ definition namespace (geos::io)
-2006-03-06 19:40 strk
+2006-03-06 19:40 Sandro Santilli <strk at keybit.net>
- * capi/geos_c.cpp, doc/example.cpp,
+ * [r1146] capi/geos_c.cpp, doc/example.cpp,
source/algorithm/LineIntersector.cpp,
source/algorithm/PointLocator.cpp,
@@ -12101,86 +12366,88 @@
tests/xmltester/XMLTester.cpp: geos::util namespace. New
GeometryCollection::iterator interface, many cleanups.
-2006-03-06 15:23 strk
+2006-03-06 15:23 Sandro Santilli <strk at keybit.net>
- * capi/geos_c.cpp, doc/example.cpp, source/geom/Geometry.cpp,
- source/headers/geos/io.h, source/io/ByteOrderValues.cpp,
- source/io/ParseException.cpp, source/io/StringTokenizer.cpp,
- source/io/Unload.cpp, source/io/WKBReader.cpp,
- source/io/WKBWriter.cpp, source/io/WKTReader.cpp,
- source/io/WKTWriter.cpp, source/io/Writer.cpp,
- tests/xmltester/SimpleWKTTester.cpp,
+ * [r1145] capi/geos_c.cpp, doc/example.cpp,
+ source/geom/Geometry.cpp, source/headers/geos/io.h,
+ source/io/ByteOrderValues.cpp, source/io/ParseException.cpp,
+ source/io/StringTokenizer.cpp, source/io/Unload.cpp,
+ source/io/WKBReader.cpp, source/io/WKBWriter.cpp,
+ source/io/WKTReader.cpp, source/io/WKTWriter.cpp,
+ source/io/Writer.cpp, tests/xmltester/SimpleWKTTester.cpp,
tests/xmltester/XMLTester.cpp, tests/xmltester/XMLTester.h,
tests/xmltester/buffer.xml: geos::io namespace
-2006-03-06 14:30 strk
+2006-03-06 14:30 Sandro Santilli <strk at keybit.net>
- * capi/geos_c.cpp: Validity error include Coordinate
+ * [r1143] capi/geos_c.cpp: Validity error include Coordinate
-2006-03-06 13:27 strk
+2006-03-06 13:27 Sandro Santilli <strk at keybit.net>
- * source/geom/Polygon.cpp: Cleaned up equalsExact
+ * [r1142] source/geom/Polygon.cpp: Cleaned up equalsExact
-2006-03-06 13:26 strk
+2006-03-06 13:26 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/XMLTester.cpp: Fixed equalsExact check, and also
- reduced tolerance
+ * [r1141] tests/xmltester/XMLTester.cpp: Fixed equalsExact check,
+ and also reduced tolerance
-2006-03-06 12:47 strk
+2006-03-06 12:47 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/opValid.h,
+ * [r1140] source/headers/geos/opValid.h,
source/operation/valid/IsValidOp.cpp: TopologyValidationError
error names (enum) renamed to avoid conflicts.
-2006-03-06 12:16 strk
+2006-03-06 12:16 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/robustness.xml: Added second case for Union
+ * [r1139] tests/xmltester/robustness.xml: Added second case for
+ Union
-2006-03-06 12:11 strk
+2006-03-06 12:11 Sandro Santilli <strk at keybit.net>
- * source/operation/overlay/OverlayOp.cpp: precision.h =>
+ * [r1138] source/operation/overlay/OverlayOp.cpp: precision.h =>
geos/precision.h (#48)
-2006-03-06 11:39 strk
+2006-03-06 11:39 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/robustness.xml: Added test extracted from data
- provided by Guillaume Sueur
+ * [r1137] tests/xmltester/robustness.xml: Added test extracted from
+ data provided by Guillaume Sueur
-2006-03-06 11:34 strk
+2006-03-06 11:34 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom.h: Dropped
+ * [r1136] source/headers/geos/geom.h: Dropped
unused/unmaintained/platform-problematic serial version info for
classes (#47)
-2006-03-06 11:17 strk
+2006-03-06 11:17 Sandro Santilli <strk at keybit.net>
- * capi/geos_c.cpp: added a compile-time option to get
+ * [r1135] capi/geos_c.cpp: added a compile-time option to get
VERBOSE_EXCEPTION (print args on exceptions)
- * source/operation/overlay/OverlayOp.cpp: precision reducing
- overlayOp made compile-time optional
+ * [r1134] source/operation/overlay/OverlayOp.cpp: precision
+ reducing overlayOp made compile-time optional
-2006-03-06 11:05 strk
+2006-03-06 11:05 Sandro Santilli <strk at keybit.net>
- input and output validity test facilities
+ * [r1133] tests/xmltester/XMLTester.cpp,
+ tests/xmltester/XMLTester.h: Added input and output validity test
+ facilities
-2006-03-03 14:01 strk
+2006-03-03 14:01 Sandro Santilli <strk at keybit.net>
- * source/operation/overlay/OverlayOp.cpp: Experimental
+ * [r1132] source/operation/overlay/OverlayOp.cpp: Experimental
precision-reducing overlayOp
-2006-03-03 13:50 strk
+2006-03-03 13:50 Sandro Santilli <strk at keybit.net>
- * source/algorithm/InteriorPointLine.cpp,
+ * [r1131] source/algorithm/InteriorPointLine.cpp,
source/headers/geos/geom.h, source/headers/geos/geosAlgorithm.h:
Cleaned up InteriorPointLine class
-2006-03-03 10:46 strk
+2006-03-03 10:46 Sandro Santilli <strk at keybit.net>
+ * [r1130] capi/geos_c.cpp, doc/example.cpp,
source/algorithm/HCoordinate.cpp,
source/algorithm/InteriorPointArea.cpp,
@@ -12300,50 +12567,51 @@
Removed 'using namespace' from headers, added missing headers in
.cpp files, removed useless includes in headers (bug#46)
-2006-03-02 18:17 strk
+2006-03-02 18:17 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/Makefile.am, tests/xmltester/robustness.xml:
- Added robustness testcases
+ * [r1129] tests/xmltester/Makefile.am,
+ tests/xmltester/robustness.xml: Added robustness testcases
-2006-03-02 16:22 strk
+2006-03-02 16:22 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/XMLTester.cpp: Updated copyright notice
+ * [r1128] tests/xmltester/XMLTester.cpp: Updated copyright notice
-2006-03-02 16:21 strk
+2006-03-02 16:21 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/PlanarGraph.cpp, source/headers/geos/geomUtil.h,
- source/headers/geos/precision.h, source/precision/CommonBits.cpp,
+ * [r1127] source/geomgraph/PlanarGraph.cpp,
+ source/headers/geos/geomUtil.h, source/headers/geos/precision.h,
+ source/precision/CommonBits.cpp,
source/precision/CommonBitsOp.cpp,
source/precision/CommonBitsRemover.cpp,
source/precision/EnhancedPrecisionOp.cpp,
geos::precision namespace added
-2006-03-02 14:53 strk
+2006-03-02 14:53 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/index/SweepLineEvent.cpp,
+ * [r1126] source/geomgraph/index/SweepLineEvent.cpp,
source/headers/geos/geomgraphindex.h,
source/headers/geos/indexSweepline.h,
source/index/sweepline/indexSweepLineEvent.cpp:
SweepLineEvent::DELETE=>DELETE_EVENT, INSERT=>INSERT_EVENT (#45)
-2006-03-02 14:34 strk
+2006-03-02 14:34 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geomgraph.h, source/headers/geos/operation.h,
+ * [r1125] source/headers/geos/geomgraph.h,
+ source/headers/geos/operation.h, source/io/Unload.cpp,
source/operation/GeometryGraphOperation.cpp,
source/operation/overlay/OverlayOp.cpp,
GeometryGraphOperation::li made a non-static member, and not more
a pointer
-2006-03-02 14:21 strk
+2006-03-02 14:21 Sandro Santilli <strk at keybit.net>
- * capi/geos_c.cpp: DEBUG => GEOS_DEBUG [#44]
+ * [r1124] capi/geos_c.cpp: DEBUG => GEOS_DEBUG [#44]
-2006-03-02 12:12 strk
+2006-03-02 12:12 Sandro Santilli <strk at keybit.net>
- * source/algorithm/LineIntersector.cpp,
+ * [r1123] source/algorithm/LineIntersector.cpp,
@@ -12380,60 +12648,62 @@
to GEOS_DEBUG, all wrapped in #ifndef block to allow global
override (bug#43)
-2006-03-02 11:03 strk
+2006-03-02 11:03 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/XMLTester.cpp: Added assertion in relate test
- handler
+ * [r1122] tests/xmltester/XMLTester.cpp: Added assertion in relate
+ test handler
-2006-03-02 11:00 strk
+2006-03-02 11:00 Sandro Santilli <strk at keybit.net>
- * source/geom/IntersectionMatrix.cpp, source/headers/geos/geom.h:
- Changed IntersectionMatrix funx taking strings to take const
- string& instead
+ * [r1121] source/geom/IntersectionMatrix.cpp,
+ source/headers/geos/geom.h: Changed IntersectionMatrix funx
+ taking strings to take const string& instead
-2006-03-02 10:25 strk
+2006-03-02 10:25 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/XMLTester.cpp, tests/xmltester/buffer.xml: Added
- support for FLOATING_SINGLE precisionmodel in XML tests
+ * [r1120] tests/xmltester/XMLTester.cpp,
+ tests/xmltester/buffer.xml: Added support for FLOATING_SINGLE
+ precisionmodel in XML tests
-2006-03-02 10:03 strk
+2006-03-02 10:03 Sandro Santilli <strk at keybit.net>
- * capi/Makefile.am, capi/geos_c.cpp: Removed use of strdup, changed
- GEOSjtsport() to return const char* instead of char* (is not
- advertised in headerfile, so no compatibility problems)
+ * [r1119] capi/Makefile.am, capi/geos_c.cpp: Removed use of strdup,
+ changed GEOSjtsport() to return const char* instead of char* (is
+ not advertised in headerfile, so no compatibility problems)
-2006-03-02 09:51 strk
+2006-03-02 09:51 Sandro Santilli <strk at keybit.net>
- * source/operation/overlay/OverlayOp.cpp: Fixes in DEBUG lines
- (bug#42)
+ * [r1118] source/operation/overlay/OverlayOp.cpp: Fixes in DEBUG
+ lines (bug#42)
-2006-03-02 09:49 strk
+2006-03-02 09:49 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/LineSegment.inl: Changed LineSegment output
- to use 'LINESEGMENT' label rather then 'LINESTRING'
+ * [r1117] source/headers/geos/LineSegment.inl: Changed LineSegment
+ output to use 'LINESEGMENT' label rather then 'LINESTRING'
- * source/headers/geos/timeval.h: WINCE implmentation of
+ * [r1116] source/headers/geos/timeval.h: WINCE implmentation of
gettimeofday (bug#40)
-2006-03-02 09:46 strk
+2006-03-02 09:46 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/SubgraphDepthLocater.cpp: cleaned up
- debugging lines
+ * [r1115] source/operation/buffer/SubgraphDepthLocater.cpp: cleaned
+ up debugging lines
-2006-03-01 18:44 strk
+2006-03-01 18:44 Sandro Santilli <strk at keybit.net>
- * NEWS: added note about getInteriorPoint() possibly returning NULL
+ * [r1114] NEWS: added note about getInteriorPoint() possibly
+ returning NULL
-2006-03-01 18:43 strk
+2006-03-01 18:43 Sandro Santilli <strk at keybit.net>
- * capi/geos_c.cpp: Handled new NULL return from
+ * [r1113] capi/geos_c.cpp: Handled new NULL return from
Geometry::getInteriorPoint()
-2006-03-01 18:37 strk
+2006-03-01 18:37 Sandro Santilli <strk at keybit.net>
+ * [r1112] source/algorithm/InteriorPointLine.cpp,
source/algorithm/InteriorPointPoint.cpp,
source/geom/Geometry.cpp, source/geom/GeometryFactory.cpp,
@@ -12442,28 +12712,29 @@
Fixed bugs in InteriorPoint* and getCentroid() inserted by
previous commits.
-2006-03-01 18:19 strk
+2006-03-01 18:19 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/Makefile.am, tests/xmltester/TestCentroid.xml,
+ * [r1111] tests/xmltester/Makefile.am,
+ tests/xmltester/TestCentroid.xml,
tests/xmltester/testLeaksBig.xml: getCentroid() test moved from
testLeaksBig.xml to TestCentroid.xml (synced with JTS-1.7)
-2006-03-01 18:15 strk
+2006-03-01 18:15 Sandro Santilli <strk at keybit.net>
+ * [r1110] tests/xmltester/Makefile.am,
tests/xmltester/TestInteriorPoint.xml,
tests/xmltester/testLeaksBig.xml: Extracted getInteriorPoint()
tests out of testLeaksBig.xml and into TestInteriorPoint.xml
(synced with JTS-1.7).
-2006-03-01 18:14 strk
+2006-03-01 18:14 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/XMLTester.cpp: Handled NULL return from
+ * [r1109] tests/xmltester/XMLTester.cpp: Handled NULL return from
-2006-03-01 17:16 strk
+2006-03-01 17:16 Sandro Santilli <strk at keybit.net>
- * source/algorithm/CentroidArea.cpp,
+ * [r1108] source/algorithm/CentroidArea.cpp,
@@ -12480,82 +12751,86 @@
Reduced heap allocations in Centroid{Area,Line,Point} and
InteriorPoint{Area,Line,Point}.
-2006-03-01 16:42 strk
+2006-03-01 16:42 Sandro Santilli <strk at keybit.net>
- * source/Makefile.vc: Fixed include name (Bug#41)
+ * [r1107] source/Makefile.vc: Fixed include name (Bug#41)
-2006-03-01 16:01 strk
+2006-03-01 16:01 Sandro Santilli <strk at keybit.net>
- * source/noding/SegmentNodeList.cpp: Fixed const correctness of
- operator<<(ostream&, SegmentNodeList&) [bug#37]
+ * [r1106] source/noding/SegmentNodeList.cpp: Fixed const
+ correctness of operator<<(ostream&, SegmentNodeList&) [bug#37]
-2006-03-01 13:49 strk
+2006-03-01 13:49 Sandro Santilli <strk at keybit.net>
- * source/index/quadtree/Quadtree.cpp: Fixed debug lines (bug#36)
+ * [r1105] source/index/quadtree/Quadtree.cpp: Fixed debug lines
+ (bug#36)
-2006-03-01 13:48 strk
+2006-03-01 13:48 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/Stackwalker.cpp: Fixed missing type specifier
- (bug#35)
+ * [r1104] tests/xmltester/Stackwalker.cpp: Fixed missing type
+ specifier (bug#35)
-2006-03-01 13:06 strk
+2006-03-01 13:06 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/Makefile.am, tests/xmltester/XMLTester.cpp,
- tests/xmltester/buffer.xml: Used FLOATING precision model in
- buffer.xml test, added expected results,
+ * [r1103] tests/xmltester/Makefile.am,
+ tests/xmltester/XMLTester.cpp, tests/xmltester/buffer.xml: Used
+ FLOATING precision model in buffer.xml test, added expected
+ results,
changed XMLTester.cpp to use a tolerance when comparing expected
and obtained
results from buffer operations.
-2006-03-01 12:12 strk
+2006-03-01 12:12 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/XMLTester.cpp: Fixed a bug in verbose output
- preventing geometry arg 'A' from being properly printed
+ * [r1102] tests/xmltester/XMLTester.cpp: Fixed a bug in verbose
+ output preventing geometry arg 'A' from being properly printed
-2006-03-01 11:47 strk
+2006-03-01 11:47 Sandro Santilli <strk at keybit.net>
- * source/Makefile.vc: Applied patch by Mateusz Loskot (Bug #39)
+ * [r1101] source/Makefile.vc: Applied patch by Mateusz Loskot (Bug
+ #39)
-2006-03-01 10:48 strk
+2006-03-01 10:48 Sandro Santilli <strk at keybit.net>
+ * [r1100] source/headers/geos/opValid.h,
source/operation/valid/TopologyValidationError.cpp: Changed
static TopologyValidationError::errMsg[] from 'string' to 'const
char*'
to reduce dynamic memory allocations.
-2006-03-01 10:39 strk
+2006-03-01 10:39 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/unload.h, source/io/Unload.cpp: ctor and dtor
- made private and inlined
+ * [r1099] source/headers/geos/unload.h, source/io/Unload.cpp: ctor
+ and dtor made private and inlined
-2006-03-01 09:56 strk
+2006-03-01 09:56 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/XMLTester.cpp: Case insensitive operation names
- and geometry arguments names (a/b)
+ * [r1098] tests/xmltester/XMLTester.cpp: Case insensitive operation
+ names and geometry arguments names (a/b)
-2006-03-01 09:43 strk
+2006-03-01 09:43 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/XMLTester.cpp: Unrecognized tests always printed
- (was only printed when verbose before)
+ * [r1097] tests/xmltester/XMLTester.cpp: Unrecognized tests always
+ printed (was only printed when verbose before)
-2006-03-01 08:52 strk
+2006-03-01 08:52 Sandro Santilli <strk at keybit.net>
- * source/dirlist.mk: File to be included by Makefile.vc
+ * [r1096] source/dirlist.mk: File to be included by Makefile.vc
-2006-02-28 19:22 strk
+2006-02-28 19:22 Sandro Santilli <strk at keybit.net>
+ * [r1095] source/headers/geos/opBuffer.h,
source/operation/buffer/OffsetCurveBuilder.cpp: Fixed in-place
definition of static members in OffsetCurveBuilder (bug#33)
-2006-02-28 19:18 strk
+2006-02-28 19:18 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/XMLTester.cpp: Added cctype include (bug #34)
+ * [r1094] tests/xmltester/XMLTester.cpp: Added cctype include (bug
+ #34)
-2006-02-28 17:44 strk
+2006-02-28 17:44 Sandro Santilli <strk at keybit.net>
- * source/geom/Coordinate.cpp, source/headers/geos/geom.h,
+ * [r1093] source/geom/Coordinate.cpp, source/headers/geos/geom.h,
source/headers/geos/noding.h, source/noding/SegmentNode.cpp,
source/noding/SegmentNodeList.cpp,
source/noding/SegmentString.cpp,
@@ -12566,13 +12841,14 @@
temporary
as Martin Davis review would really be needed there.
-2006-02-28 15:34 strk
+2006-02-28 15:34 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/XMLTester.cpp: Fix for VC++ builds (Bug #32)
+ * [r1092] tests/xmltester/XMLTester.cpp: Fix for VC++ builds (Bug
+ #32)
-2006-02-28 14:34 strk
+2006-02-28 14:34 Sandro Santilli <strk at keybit.net>
+ * [r1091] source/geom/Coordinate.cpp,
@@ -12590,43 +12866,45 @@
tests/xmltester/buffer.xml: Added many assertions and debugging
output hunting for a bug in BufferOp
-2006-02-28 14:05 strk
+2006-02-28 14:05 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/Edge.cpp: Fixed a bug in a debugging line
+ * [r1090] source/geomgraph/Edge.cpp: Fixed a bug in a debugging
+ line
-2006-02-28 13:08 strk
+2006-02-28 13:08 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/noding.h: Added missing definition of
+ * [r1089] source/headers/geos/noding.h: Added missing definition of
IteratedNoder::MAX_ITER, moving it to private access level
-2006-02-28 11:15 strk
+2006-02-28 11:15 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/markup/MarkupSTL.cpp: Fixed strchr use (Bug #30)
+ * [r1088] tests/xmltester/markup/MarkupSTL.cpp: Fixed strchr use
+ (Bug #30)
-2006-02-28 11:11 strk
+2006-02-28 11:11 Sandro Santilli <strk at keybit.net>
- * capi/geos_c.cpp: Fixed typo in GEOSLenght function
+ * [r1087] capi/geos_c.cpp: Fixed typo in GEOSLenght function
-2006-02-28 05:03 sgillies
+2006-02-28 05:03 Sean Gillies <sgillies at frii.com>
- * NEWS, capi/geos_c.cpp, capi/geos_c.h.in: added GEOSLength(),
- GEOSEnvelope() to the C API
+ * [r1085] NEWS, capi/geos_c.cpp, capi/geos_c.h.in: added
+ GEOSLength(), GEOSEnvelope() to the C API
-2006-02-27 14:41 strk
+2006-02-27 14:41 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/XMLTester.cpp: More verbose handling of
+ * [r1076] tests/xmltester/XMLTester.cpp: More verbose handling of
exceptions
-2006-02-27 11:53 strk
+2006-02-27 11:53 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/DirectedEdgeStar.cpp,
+ * [r1075] source/geomgraph/DirectedEdgeStar.cpp,
source/headers/geos/geomgraph.h: DirectedEdgeStar made more safe
trough assert(), use of standard iterator and
dynamic casts substituting static ones.
-2006-02-27 09:05 strk
+2006-02-27 09:05 Sandro Santilli <strk at keybit.net>
+ * [r1074] source/algorithm/LineIntersector.cpp,
source/headers/geos/geom.h, source/headers/geos/geomgraph.h,
@@ -12636,9 +12914,9 @@
source/operation/overlay/OverlayOp.cpp: Doxygen comments, a few
inlines and general cleanups
-2006-02-24 16:20 strk
+2006-02-24 16:20 Sandro Santilli <strk at keybit.net>
- * source/geom/PrecisionModel.cpp,
+ * [r1073] source/geom/PrecisionModel.cpp,
source/headers/geos/nodingSnapround.h,
source/headers/geos/util.h, source/util/Makefile.am,
source/util/math.cpp, tests/xmltester/testLeaksBig.xml: Added
@@ -12648,9 +12926,9 @@
Moved rint_vc to math.cpp (geos::util namespace), to be renamed
to something more meaningful
-2006-02-24 15:39 strk
+2006-02-24 15:39 Sandro Santilli <strk at keybit.net>
+ * [r1072] source/geom/Coordinate.cpp, source/headers/geos/geom.h,
source/operation/linemerge/LineMergeGraph.cpp,
@@ -12661,13 +12939,13 @@
- Fixed bug in planarGraphComponent::setMarked
- Added linemerge.xml test (single test, should grow a bit)
-2006-02-24 12:19 strk
+2006-02-24 12:19 Sandro Santilli <strk at keybit.net>
- * doc/Doxyfile.in: Fixed typo in config file
+ * [r1071] doc/Doxyfile.in: Fixed typo in config file
-2006-02-23 23:17 strk
+2006-02-23 23:17 Sandro Santilli <strk at keybit.net>
- * source/geom/Coordinate.cpp, source/geom/Envelope.cpp,
+ * [r1070] source/geom/Coordinate.cpp, source/geom/Envelope.cpp,
source/geom/GeometryFactory.cpp, source/geom/LineSegment.cpp,
source/geom/PrecisionModel.cpp, source/headers/geos/geom.h,
@@ -12686,14 +12964,14 @@
file
- Misc cleanups
-2006-02-23 20:32 strk
+2006-02-23 20:32 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/XMLTester.cpp: Added support for LineMerge tests.
- Exception printed on stderr.
+ * [r1069] tests/xmltester/XMLTester.cpp: Added support for
+ LineMerge tests. Exception printed on stderr.
-2006-02-23 20:05 strk
+2006-02-23 20:05 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/noding.h,
+ * [r1068] source/headers/geos/noding.h,
source/headers/geos/opBuffer.h, source/noding/MCIndexNoder.cpp,
source/noding/SimpleNoder.cpp,
@@ -12702,13 +12980,14 @@
constructor making memory checker go crazy, more
doxygen-friendly comments, miscellaneous cleanups
-2006-02-23 20:03 strk
+2006-02-23 20:03 Sandro Santilli <strk at keybit.net>
- * doc/Doxyfile.in: updated to also show undocumented methods
+ * [r1067] doc/Doxyfile.in: updated to also show undocumented
+ methods
-2006-02-23 11:54 strk
+2006-02-23 11:54 Sandro Santilli <strk at keybit.net>
- * source/geom/MultiLineString.cpp,
+ * [r1066] source/geom/MultiLineString.cpp,
source/geom/TopologyException.cpp, source/geom/Triangle.cpp,
source/geomgraph/GeometryGraph.cpp, source/geomgraph/NodeMap.cpp,
@@ -12753,9 +13032,9 @@
- Added an XML test for snaprounding buffer (shows leaks, working
on it)
-2006-02-21 16:53 strk
+2006-02-21 16:53 Sandro Santilli <strk at keybit.net>
- * source/algorithm/MCPointInRing.cpp,
+ * [r1065] source/algorithm/MCPointInRing.cpp,
source/headers/geos/indexChain.h, source/headers/geos/noding.h,
@@ -12768,9 +13047,9 @@
MCIndexPointSnapper, MCIndexSnapRounder
-2006-02-20 21:04 strk
+2006-02-20 21:04 Sandro Santilli <strk at keybit.net>
+ * [r1064] source/headers/geos/geomgraph.h,
source/headers/geos/indexQuadtree.h,
source/headers/geos/indexStrtree.h, source/headers/geos/noding.h,
source/headers/geos/spatialIndex.h,
@@ -12780,9 +13059,10 @@
source/index/strtree/STRtree.cpp: - namespace geos::index
- SpatialIndex interface synced
-2006-02-20 10:14 strk
+2006-02-20 10:14 Sandro Santilli <strk at keybit.net>
- * ChangeLog, doc/Doxyfile.in, source/algorithm/MCPointInRing.cpp,
+ * [r1063] ChangeLog, doc/Doxyfile.in,
+ source/algorithm/MCPointInRing.cpp,
source/algorithm/SIRtreePointInRing.cpp,
source/geom/Geometry.cpp, source/geomgraph/EdgeList.cpp,
@@ -12828,9 +13108,9 @@
namespaces geos::index::*
- Doxygen documentation cleanup
-2006-02-19 19:46 strk
+2006-02-19 19:46 Sandro Santilli <strk at keybit.net>
- * NEWS, capi/geos_c.cpp, configure.in, doc/example.cpp,
+ * [r1062] NEWS, capi/geos_c.cpp, configure.in, doc/example.cpp,
@@ -12979,9 +13259,9 @@
for most GEOS internal code (uncomplete, but working). Dir-level
libs for index/ subdirs.
-2006-02-18 21:08 strk
+2006-02-18 21:08 Sandro Santilli <strk at keybit.net>
- * NEWS, source/geom/Geometry.cpp,
+ * [r1061] NEWS, source/geom/Geometry.cpp,
source/geomgraph/EdgeNodingValidator.cpp,
@@ -13008,45 +13288,46 @@
- Simplified internal interaces of OffsetCurveBuilder and
-2006-02-16 08:41 strk
+2006-02-16 08:41 Sandro Santilli <strk at keybit.net>
- * source/noding/NodingValidator.cpp: Fixed include: "util.h" =>
- "geos/util.h"
+ * [r1060] source/noding/NodingValidator.cpp: Fixed include:
+ "util.h" => "geos/util.h"
- * source/headers/geos/nodingSnapround.h: added <cmath> include for
- round()
+ * [r1059] source/headers/geos/nodingSnapround.h: added <cmath>
+ include for round()
-2006-02-16 08:19 strk
+2006-02-16 08:19 Sandro Santilli <strk at keybit.net>
- * source/noding/IntersectionAdder.cpp: Missed from last commit
+ * [r1058] source/noding/IntersectionAdder.cpp: Missed from last
+ commit
-2006-02-15 22:48 sgillies
+2006-02-15 22:48 Sean Gillies <sgillies at frii.com>
- * capi/geos_c.h.in: added GEOSGeomType
+ * [r1057] capi/geos_c.h.in: added GEOSGeomType
-2006-02-15 17:19 strk
+2006-02-15 17:19 Sandro Santilli <strk at keybit.net>
- * NEWS, source/geomgraph/EdgeNodingValidator.cpp,
+ * [r1056] NEWS, source/geomgraph/EdgeNodingValidator.cpp,
source/headers/geos/noding.h, source/noding/NodingValidator.cpp,
source/noding/snapround/SimpleSnapRounder.cpp: NodingValidator
synced with JTS-1.7, added CoordinateSequence::operator[]
and size() to easy port maintainance.
-2006-02-15 14:59 strk
+2006-02-15 14:59 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/noding.h, source/noding/SegmentNode.cpp,
- source/noding/SegmentNodeList.cpp,
+ * [r1055] source/headers/geos/noding.h,
+ source/noding/SegmentNode.cpp, source/noding/SegmentNodeList.cpp,
source/noding/SegmentString.cpp: JTS-1.7 sync for:
-2006-02-14 13:28 strk
+2006-02-14 13:28 Sandro Santilli <strk at keybit.net>
- * NEWS, configure.in, source/algorithm/LineIntersector.cpp,
+ * [r1054] NEWS, configure.in, source/algorithm/LineIntersector.cpp,
source/headers/geos/geosAlgorithm.h,
@@ -13077,9 +13358,9 @@
Buffer op optimized by using new snaprounding code.
Leaks fixed in XMLTester.
-2006-02-09 15:52 strk
+2006-02-09 15:52 Sandro Santilli <strk at keybit.net>
- * capi/geos_c.cpp, capi/geos_c.cpp.bak, configure.in,
+ * [r1053] capi/geos_c.cpp, capi/geos_c.cpp.bak, configure.in,
doc/example.cpp, source/algorithm/CGAlgorithms.cpp,
@@ -13128,41 +13409,41 @@
tests/xmltester/XMLTester.cpp: GEOSException derived from
std::exception; always thrown and cought by const ref.
-2006-02-09 15:41 sgillies
+2006-02-09 15:41 Sean Gillies <sgillies at frii.com>
- * configure.in: incrementing C API patch level
+ * [r1052] configure.in: incrementing C API patch level
-2006-02-09 14:49 sgillies
+2006-02-09 14:49 Sean Gillies <sgillies at frii.com>
- * capi/geos_c.cpp, capi/geos_c.h.in, capi/geostest.c: added
+ * [r1051] capi/geos_c.cpp, capi/geos_c.h.in, capi/geostest.c: added
GEOSArea() to the C API
-2006-02-09 13:44 strk
+2006-02-09 13:44 Sandro Santilli <strk at keybit.net>
- * source/geom/Geometry.cpp, source/headers/geos/geom.h,
+ * [r1050] source/geom/Geometry.cpp, source/headers/geos/geom.h,
source/io/WKBReader.cpp: Added support for SRID in input WKB,
undeprecated Geometry::setSRID
and Geometry::getSRID
2006-02-09 01:47 frank
- * source/io/WKBReader.cpp: Botched last fix. Hopefully this is
- better.
+ * [r1049] source/io/WKBReader.cpp: Botched last fix. Hopefully this
+ is better.
-2006-02-09 01:13 strk
+2006-02-09 01:13 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/operation/linemerge/LineSequencer.cpp: Added
- missing <limits> include
+ * [r1048] ChangeLog, source/operation/linemerge/LineSequencer.cpp:
+ Added missing <limits> include
2006-02-09 00:06 frank
- * ChangeLog, source/io/WKBReader.cpp: Fixed support for consuming
- WKB for 'POLYGON EMPTY' with numRings==0.
+ * [r1047] ChangeLog, source/io/WKBReader.cpp: Fixed support for
+ consuming WKB for 'POLYGON EMPTY' with numRings==0.
http://bugzilla.remotesensing.org/show_bug.cgi?id=1064
-2006-02-08 17:18 strk
+2006-02-08 17:18 Sandro Santilli <strk at keybit.net>
- * NEWS, source/geom/Envelope.cpp, source/geom/Geometry.cpp,
+ * [r1046] NEWS, source/geom/Envelope.cpp, source/geom/Geometry.cpp,
source/geom/LineString.cpp, source/geom/MultiLineString.cpp,
source/geom/MultiPoint.cpp, source/headers/geos/geom.h,
source/headers/geos/io.h, source/headers/geos/opBuffer.h,
@@ -13181,13 +13462,14 @@
- Obsoleted toInternalGeometry/fromInternalGeometry
- More const-correctness in Buffer "package"
-2006-02-08 13:07 strk
+2006-02-08 13:07 Sandro Santilli <strk at keybit.net>
- * NEWS: Added note about new LineSequencer class
+ * [r1045] NEWS: Added note about new LineSequencer class
-2006-02-08 12:59 strk
+2006-02-08 12:59 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom.h, source/headers/geos/opLinemerge.h,
+ * [r1044] source/headers/geos/geom.h,
+ source/headers/geos/opLinemerge.h,
source/headers/geos/planargraph.h,
source/operation/linemerge/LineSequencer.cpp,
source/operation/linemerge/Makefile.am,
@@ -13208,22 +13490,22 @@
- Added const versions of some planarDirectedEdgeStar methods.
- Added containers typedefs for planarDirectedEdgeStar
-2006-02-07 13:26 strk
+2006-02-07 13:26 Sandro Santilli <strk at keybit.net>
- * source/Makefile.am: Added missing geomgraph SUBDIR
+ * [r1043] source/Makefile.am: Added missing geomgraph SUBDIR
-2006-02-07 12:02 strk
+2006-02-07 12:02 Sandro Santilli <strk at keybit.net>
- * tests/xmltester/Makefile.am: Removed TestConvexHull.xml file
- (already included in testLeaksBig.xml
+ * [r1042] tests/xmltester/Makefile.am: Removed TestConvexHull.xml
+ file (already included in testLeaksBig.xml
-2006-02-06 11:27 strk
+2006-02-06 11:27 Sandro Santilli <strk at keybit.net>
- * tests, tests/.cvsignore: new entry
+ * [r1041] tests, tests/.cvsignore: new entry
-2006-02-05 17:14 strk
+2006-02-05 17:14 Sandro Santilli <strk at keybit.net>
- * NEWS, source/headers/geos/planargraph.h,
+ * [r1040] NEWS, source/headers/geos/planargraph.h,
source/planargraph/Makefile.am, source/planargraph/algorithm,
source/planargraph/algorithm/ConnectedSubgraphFinder.cpp,
source/planargraph/planarDirectedEdgeStar.cpp,
@@ -13234,9 +13516,9 @@
- More iterators returning methods, inlining and cleanups
in planargraph.
-2006-02-04 00:54 strk
+2006-02-04 00:54 Sandro Santilli <strk at keybit.net>
- * ChangeLog, NEWS, source/headers/geos/geom.h,
+ * [r1039] ChangeLog, NEWS, source/headers/geos/geom.h,
source/planargraph/planarSubgraph.cpp, swig/ruby/Makefile.am,
@@ -13247,23 +13529,23 @@
- Renamed TESTS variable to XMLTESTS to not confuse 'make check'
rule
-2006-02-03 09:26 strk
+2006-02-03 09:26 Sandro Santilli <strk at keybit.net>
- * source/geom/util/ShortCircuitedGeometryVisitor.cpp: Added missing
- file
+ * [r1038] source/geom/util/ShortCircuitedGeometryVisitor.cpp: Added
+ missing file
-2006-02-02 02:20 strk
+2006-02-02 02:20 Sandro Santilli <strk at keybit.net>
- * source/geom/Polygon.cpp: Fixed bug in isRectangle() failing to
- detect rectangles.
+ * [r1037] source/geom/Polygon.cpp: Fixed bug in isRectangle()
+ failing to detect rectangles.
-2006-02-01 22:22 strk
+2006-02-01 22:22 Sandro Santilli <strk at keybit.net>
- * NEWS: updated
+ * [r1036] NEWS: updated
-2006-02-01 22:21 strk
+2006-02-01 22:21 Sandro Santilli <strk at keybit.net>
- * source/geom/Geometry.cpp, source/geom/Polygon.cpp,
+ * [r1035] source/geom/Geometry.cpp, source/geom/Polygon.cpp,
source/geom/util/Makefile.am, source/headers/geos/geom.h,
source/headers/geos/opPredicate.h,
@@ -13273,36 +13555,36 @@
rectangle-based optimizations of intersects() and contains() ops
- Inlined all planarGraphComponent class
-2006-01-31 21:42 strk
+2006-01-31 21:42 Sandro Santilli <strk at keybit.net>
- * source/Makefile.vc: Added DepthSegment object
+ * [r1034] source/Makefile.vc: Added DepthSegment object
-2006-01-31 21:36 strk
+2006-01-31 21:36 Sandro Santilli <strk at keybit.net>
- * swig/geos.i: Fixes error in calling read_hex from scripting
- languages.
+ * [r1033] swig/geos.i: Fixes error in calling read_hex from
+ scripting languages.
-2006-01-31 21:35 strk
+2006-01-31 21:35 Sandro Santilli <strk at keybit.net>
- * capi/Makefile.in: Erroneusly ended in CVS
+ * [r1032] capi/Makefile.in: Erroneusly ended in CVS
-2006-01-31 21:17 strk
+2006-01-31 21:17 Sandro Santilli <strk at keybit.net>
- * source/operation/predicate/RectangleContains.cpp: Added missing
- file from last commits
+ * [r1031] source/operation/predicate/RectangleContains.cpp: Added
+ missing file from last commits
-2006-01-31 19:11 strk
+2006-01-31 19:11 Sandro Santilli <strk at keybit.net>
- * source/bigtest: Another left-over from cleanups
+ * [r1030] source/bigtest: Another left-over from cleanups
-2006-01-31 19:10 strk
+2006-01-31 19:10 Sandro Santilli <strk at keybit.net>
- * source/capi, source/test: Removed leftover files in obsoleted
- dirs
+ * [r1029] source/capi, source/test: Removed leftover files in
+ obsoleted dirs
-2006-01-31 19:07 strk
+2006-01-31 19:07 Sandro Santilli <strk at keybit.net>
- * Makefile.am, NEWS, README, capi, capi/.cvsignore,
+ * [r1028] Makefile.am, NEWS, README, capi, capi/.cvsignore,
capi/Makefile.am, capi/Makefile.in, capi/geos_c.cpp,
capi/geos_c.cpp.bak, capi/geos_c.h.in, capi/geostest.c,
capi/test.wkt, configure.in, doc/Doxyfile.in, doc/Makefile.am,
@@ -13467,29 +13749,29 @@
2006-01-30 21:59 frank
- * source/algorithm/LineIntersector.cpp: yikes! comment out debug
- define again
+ * [r1027] source/algorithm/LineIntersector.cpp: yikes! comment out
+ debug define again
2006-01-30 21:58 frank
- * ChangeLog, source/algorithm/LineIntersector.cpp: fixed up some
- debug messages
+ * [r1026] ChangeLog, source/algorithm/LineIntersector.cpp: fixed up
+ some debug messages
-2006-01-30 16:55 strk
+2006-01-30 16:55 Sandro Santilli <strk at keybit.net>
- * macros/ac_python_devel.m4, swig/python/Makefile.am,
+ * [r1025] macros/ac_python_devel.m4, swig/python/Makefile.am,
swig/python/example.py, swig/python/geos.pth,
swig/python/python.i, swig/ruby/test/geos_tests.rb: More patches
from Charlie Savage
-2006-01-27 08:58 strk
+2006-01-27 08:58 Sandro Santilli <strk at keybit.net>
- * configure.in: Python and Ruby build disable by default (until
- we've properly tested it)
+ * [r1024] configure.in: Python and Ruby build disable by default
+ (until we've properly tested it)
-2006-01-27 08:25 strk
+2006-01-27 08:25 Sandro Santilli <strk at keybit.net>
+ * [r1023] macros/ac_python_devel.m4, swig/python/Makefile.am,
swig/ruby/ruby.i: * Ruby - removes dependency on renames.i file
which is no longer deleted
and was removed from CVS last week
@@ -13500,160 +13782,162 @@
extension can
be built
-2006-01-22 22:48 strk
+2006-01-22 22:48 Sandro Santilli <strk at keybit.net>
- * TODO: Added Safe's performance improvement idea for
+ * [r1022] TODO: Added Safe's performance improvement idea for
CoordinateSequence
-2006-01-21 16:11 strk
+2006-01-21 16:11 Sandro Santilli <strk at keybit.net>
- * NEWS: updated
+ * [r1021] NEWS: updated
-2006-01-21 16:08 strk
+2006-01-21 16:08 Sandro Santilli <strk at keybit.net>
- * source/io/ByteOrderValues.cpp: Fixed integer conversion bug
- (ported from JTS-1.7).
+ * [r1020] source/io/ByteOrderValues.cpp: Fixed integer conversion
+ bug (ported from JTS-1.7).
Added last port information.
-2006-01-21 16:04 strk
+2006-01-21 16:04 Sandro Santilli <strk at keybit.net>
- * source/test/hexwkb.xml: Added endian specification to case
- descriptions.
+ * [r1019] source/test/hexwkb.xml: Added endian specification to
+ case descriptions.
All tests are Little Endian, should add the same
tests with Big Endian format.
-2006-01-20 19:28 strk
+2006-01-20 19:28 Sandro Santilli <strk at keybit.net>
- * source/operation/overlay/PolygonBuilder.cpp: Updated port
+ * [r1018] source/operation/overlay/PolygonBuilder.cpp: Updated port
information
-2006-01-20 19:21 strk
+2006-01-20 19:21 Sandro Santilli <strk at keybit.net>
- * source/operation/overlay/PolygonBuilder.cpp: Fixed bug #13
+ * [r1017] source/operation/overlay/PolygonBuilder.cpp: Fixed bug
+ #13
-2006-01-20 19:11 strk
+2006-01-20 19:11 Sandro Santilli <strk at keybit.net>
- * source/operation/valid/IsValidOp.cpp,
+ * [r1016] source/operation/valid/IsValidOp.cpp,
source/operation/valid/TopologyValidationError.cpp: Updated last
port info
-2006-01-20 17:20 strk
+2006-01-20 17:20 Sandro Santilli <strk at keybit.net>
- * configure.in, macros/ruby.m4, swig/python/Makefile.am,
+ * [r1015] configure.in, macros/ruby.m4, swig/python/Makefile.am,
swig/ruby/Makefile.am, swig/ruby/example.rb, swig/ruby/renames.i,
swig/ruby/test/Makefile.am, swig/ruby/test/example.rb,
swig/ruby/test/test_envelope.rb: More SWIG/python/ruby patches
-2006-01-20 00:59 strk
+2006-01-20 00:59 Sandro Santilli <strk at keybit.net>
- * source/io/WKBReader.cpp: Better debugging
+ * [r1014] source/io/WKBReader.cpp: Better debugging
- * source/test/hexwkb.xml: PrecisionModel made FLOATING
+ * [r1013] source/test/hexwkb.xml: PrecisionModel made FLOATING
-2006-01-18 17:49 strk
+2006-01-18 17:49 Sandro Santilli <strk at keybit.net>
- * source/test/XMLTester.cpp, source/test/XMLTester.h: Reworked
- XMLTester to be quiet by default. Use -v switch to make it
- verbose.
+ * [r1012] source/test/XMLTester.cpp, source/test/XMLTester.h:
+ Reworked XMLTester to be quiet by default. Use -v switch to make
+ it verbose.
-2006-01-18 17:47 strk
+2006-01-18 17:47 Sandro Santilli <strk at keybit.net>
- * source/test/hexwkb.xml: Added GEOMETRYCOLLECTION test
+ * [r1011] source/test/hexwkb.xml: Added GEOMETRYCOLLECTION test
- * source/test/Makefile.am: Added another local test to the test
- rule
+ * [r1010] source/test/Makefile.am: Added another local test to the
+ test rule
-2006-01-18 17:46 strk
+2006-01-18 17:46 Sandro Santilli <strk at keybit.net>
- * source/io/WKTWriter.cpp: Fixed leak in ::writeFormatted(Geometry
+ * [r1009] source/io/WKTWriter.cpp: Fixed leak in
+ ::writeFormatted(Geometry *)
-2006-01-18 17:45 strk
+2006-01-18 17:45 Sandro Santilli <strk at keybit.net>
- * source/io/WKBReader.cpp: more debugging lines
+ * [r1008] source/io/WKBReader.cpp: more debugging lines
-2006-01-18 13:23 strk
+2006-01-18 13:23 Sandro Santilli <strk at keybit.net>
- * source/io/WKBReader.cpp: Set binary flag for stringstream used in
- ::readHEX()
+ * [r1007] source/io/WKBReader.cpp: Set binary flag for stringstream
+ used in ::readHEX()
-2006-01-18 12:54 strk
+2006-01-18 12:54 Sandro Santilli <strk at keybit.net>
- * source/test/Makefile.am, source/test/XMLTester.cpp,
+ * [r1006] source/test/Makefile.am, source/test/XMLTester.cpp,
source/test/XMLTester.h, source/test/hexwkb.xml: Added HEXWKB
support in XMLTester. Added a simple test in HEXWKB form
and a 'test' rule running the locally-available tests and showing
result summay.
-2006-01-18 10:02 strk
+2006-01-18 10:02 Sandro Santilli <strk at keybit.net>
- * macros/ac_python_devel.m4: Added missing macro file
+ * [r1005] macros/ac_python_devel.m4: Added missing macro file
-2006-01-17 12:03 strk
+2006-01-17 12:03 Sandro Santilli <strk at keybit.net>
- * configure.in, macros/ac_pkg_swig.m4: Modified AC_PROG_SWIG macro
- to set SWIG to the empty string
+ * [r1004] configure.in, macros/ac_pkg_swig.m4: Modified
+ AC_PROG_SWIG macro to set SWIG to the empty string
on error (rather then making it echo an error and return false).
SWIG version 1.3.28 or up required in order to build SWIG-based
extensions.
-2006-01-16 18:34 strk
+2006-01-16 18:34 Sandro Santilli <strk at keybit.net>
- * autogen.sh, configure.in, macros/ac_pkg_swig.m4,
+ * [r1003] autogen.sh, configure.in, macros/ac_pkg_swig.m4,
macros/python.m4, swig/python, swig/python/.cvsignore,
swig/python/Makefile.am, swig/python/python.i,
swig/ruby/Makefile.am: Added initial conditional build of python
and ruby wrappers
-2006-01-15 23:01 strk
+2006-01-15 23:01 Sandro Santilli <strk at keybit.net>
- * NEWS, configure.in, swig/Makefile.am, swig/geos.i, swig/ruby,
- swig/ruby/.cvsignore, swig/ruby/Makefile, swig/ruby/Makefile.am,
- swig/ruby/renames.i, swig/ruby/ruby.i, swig/ruby/test,
- swig/ruby/test/.cvsignore, swig/ruby/test/Makefile.am: Added bare
- build/install/dist scripts support for ruby interface
+ * [r1001] NEWS, configure.in, swig/Makefile.am, swig/geos.i,
+ swig/ruby, swig/ruby/.cvsignore, swig/ruby/Makefile,
+ swig/ruby/Makefile.am, swig/ruby/renames.i, swig/ruby/ruby.i,
+ swig/ruby/test, swig/ruby/test/.cvsignore,
+ swig/ruby/test/Makefile.am: Added bare build/install/dist scripts
+ support for ruby interface
-2006-01-15 21:23 strk
+2006-01-15 21:23 Sandro Santilli <strk at keybit.net>
- * swig/ruby/test, swig/ruby/test/geos_tests.rb,
+ * [r1000] swig/ruby/test, swig/ruby/test/geos_tests.rb,
swig/ruby/test/test_combinations.rb,
swig/ruby/test/test_helper.rb, swig/ruby/test/test_io.rb,
swig/ruby/test/test_operations.rb,
swig/ruby/test/test_relations.rb, swig/ruby/test/test_simple.rb:
Initial import of ruby unit tests
-2006-01-15 21:22 strk
+2006-01-15 21:22 Sandro Santilli <strk at keybit.net>
- * source/geom/Envelope.cpp, source/headers/geos/geom.h: Added
- Envelope constructor by string (accepting what's returned by
- ::toString)
+ * [r999] source/geom/Envelope.cpp, source/headers/geos/geom.h:
+ Added Envelope constructor by string (accepting what's returned
+ by ::toString)
-2006-01-15 21:19 strk
+2006-01-15 21:19 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/io.h, source/io/WKBReader.cpp,
+ * [r998] source/headers/geos/io.h, source/io/WKBReader.cpp,
source/io/WKBWriter.cpp: Added WKBWriter::writeHEX() and
WKBReader::readHEX()
-2006-01-12 11:44 strk
+2006-01-12 11:44 Sandro Santilli <strk at keybit.net>
- * NEWS: synced after 2.2.1 release
+ * [r997] NEWS: synced after 2.2.1 release
- * source/capi/geos_c.cpp: Removed double call to ::isValid
+ * [r996] source/capi/geos_c.cpp: Removed double call to ::isValid
-2006-01-08 15:39 strk
+2006-01-08 15:39 Sandro Santilli <strk at keybit.net>
- * source/capi/geos_c.cpp: Changed finite() function call with
- FINITE() macro.
+ * [r994] source/capi/geos_c.cpp: Changed finite() function call
+ with FINITE() macro.
-2006-01-08 15:24 strk
+2006-01-08 15:24 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/EdgeIntersectionList.cpp,
+ * [r993] source/geomgraph/EdgeIntersectionList.cpp,
source/headers/geos/geomgraph.h, source/operation/IsSimpleOp.cpp,
@@ -13668,87 +13952,89 @@
defined M_PI when undef as suggested by Charlie Savage.
Removed <stdio.h> include from GeometricShapeFactory.cpp.
-2005-12-22 12:46 strk
+2005-12-22 12:46 Sandro Santilli <strk at keybit.net>
- * swig/README.txt, swig/geos.i, swig/ruby, swig/ruby/Makefile,
- swig/ruby/README.txt, swig/ruby/example.rb, swig/ruby/renames.i,
- swig/ruby/ruby.i: Imported Charlie Savage new ruby wrapper and
- swig changes
+ * [r992] swig/README.txt, swig/geos.i, swig/ruby,
+ swig/ruby/Makefile, swig/ruby/README.txt, swig/ruby/example.rb,
+ swig/ruby/renames.i, swig/ruby/ruby.i: Imported Charlie Savage
+ new ruby wrapper and swig changes
-2005-12-14 11:22 strk
+2005-12-14 11:22 Sandro Santilli <strk at keybit.net>
- * HOWTO_RELEASE: Added a note about the need to *always* increment
- CAPI version
+ * [r991] HOWTO_RELEASE: Added a note about the need to *always*
+ increment CAPI version
-2005-12-14 02:32 strk
+2005-12-14 02:32 Sandro Santilli <strk at keybit.net>
- * HOWTO_RELEASE, source/algorithm/ConvexHull.cpp: New entry
+ * [r990] HOWTO_RELEASE, source/algorithm/ConvexHull.cpp: New entry
-2005-12-13 23:59 strk
+2005-12-13 23:59 Sandro Santilli <strk at keybit.net>
- * source/capi/geos_c.h.in: Removed INTERFACE_* defines (obsoleted).
+ * [r989] source/capi/geos_c.h.in: Removed INTERFACE_* defines
+ (obsoleted).
Made GEOSCoordSeq_clone() arg const (won't change ABI, it's C
world, lucky ;)
-2005-12-13 23:03 strk
+2005-12-13 23:03 Sandro Santilli <strk at keybit.net>
- * source/capi/geos_c.cpp: Removed conditional blocks based on GEOS
- version (we're always
+ * [r988] source/capi/geos_c.cpp: Removed conditional blocks based
+ on GEOS version (we're always
in sync). This fixed an annoying problem introduced since
INTERFACE_LAST
and INTERFACE_CURREN were taken off geos/version.h
-2005-12-12 09:32 strk
+2005-12-12 09:32 Sandro Santilli <strk at keybit.net>
- * configure.in, source/geom/Makefile.am,
+ * [r987] configure.in, source/geom/Makefile.am,
source/headers/geos/version.h.in: Switched to -release mode for
C++ library versioning.
Every release will be binary-incompatible with previous.
Removed GEOS_FIRST_INTERFACE and GEOS_LAST_INTERFACE defines
from geos/version.h.
-2005-12-11 10:41 strk
+2005-12-11 10:41 Sandro Santilli <strk at keybit.net>
- * source/operation/overlay/ElevationMatrix.cpp,
+ * [r984] source/operation/overlay/ElevationMatrix.cpp,
premature initialization of average Z value in
-2005-12-11 10:38 strk
+2005-12-11 10:38 Sandro Santilli <strk at keybit.net>
- * configure.in: Fixed mungled versions (1.0.0/3.0.1 => 1.0.1/3.0.0)
+ * [r983] configure.in: Fixed mungled versions (1.0.0/3.0.1 =>
+ 1.0.1/3.0.0)
-2005-12-10 16:07 strk
+2005-12-10 16:07 Sandro Santilli <strk at keybit.net>
- * source/capi/geos_c.cpp: Unkown -> Unknown typo fix
+ * [r981] source/capi/geos_c.cpp: Unkown -> Unknown typo fix
-2005-12-09 13:24 strk
+2005-12-09 13:24 Sandro Santilli <strk at keybit.net>
- * configure.in: Capi lib version set to 1.0.1 (due to leak fix in
- GEOSHasZ)
+ * [r980] configure.in: Capi lib version set to 1.0.1 (due to leak
+ fix in GEOSHasZ)
-2005-12-09 11:36 strk
+2005-12-09 11:36 Sandro Santilli <strk at keybit.net>
- * NEWS, source/capi/geos_c.cpp,
+ * [r977] NEWS, source/capi/geos_c.cpp,
source/operation/polygonize/PolygonizeGraph.cpp: Small leak
plugged in CAPI::GEOSHasZ() and in
invalid input to PolygonizeGraph (again)
-2005-12-09 10:32 strk
+2005-12-09 10:32 Sandro Santilli <strk at keybit.net>
- * source/operation/polygonize/Polygonizer.cpp: Cleaned up debugging
- line left over from previous commit
+ * [r974] source/operation/polygonize/Polygonizer.cpp: Cleaned up
+ debugging line left over from previous commit
-2005-12-09 10:03 strk
+2005-12-09 10:03 Sandro Santilli <strk at keybit.net>
- * NEWS, source/operation/polygonize/PolygonizeGraph.cpp,
+ * [r972] NEWS, source/operation/polygonize/PolygonizeGraph.cpp,
source/operation/polygonize/Polygonizer.cpp: Fixed a bug making
PolygonizeGraph choking on invalid LineStrings.
Minor optimizations in Polygonizer loops.
-2005-12-08 14:14 strk
+2005-12-08 14:14 Sandro Santilli <strk at keybit.net>
- * NEWS, source/geom/DefaultCoordinateSequence.cpp,
+ * [r971] NEWS, source/geom/DefaultCoordinateSequence.cpp,
source/geom/GeometryCollection.cpp, source/geom/LineString.cpp,
source/geom/Point.cpp, source/geom/Polygon.cpp,
source/headers/geos/geom.h, source/headers/geos/opOverlay.h,
@@ -13764,40 +14050,41 @@
Changed CoordinateFilter::filter_rw to be a const method: updated
all apply_rw() methods to take a const CoordinateFilter.
-2005-12-08 01:39 strk
+2005-12-08 01:39 Sandro Santilli <strk at keybit.net>
- * NEWS, source/headers/geos/noding.h, source/noding/Noder.cpp,
- source/noding/SegmentString.cpp: SegmentString::eiList made a
- real object rather then a pointer.
+ * [r970] NEWS, source/headers/geos/noding.h,
+ source/noding/Noder.cpp, source/noding/SegmentString.cpp:
+ SegmentString::eiList made a real object rather then a pointer.
Adde getter for const and non-const references of it (dropping
get by pointer)
-2005-12-08 01:11 strk
+2005-12-08 01:11 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/EdgeIntersectionList.cpp: minor optimizations in
- loops
+ * [r969] source/geomgraph/EdgeIntersectionList.cpp: minor
+ optimizations in loops
-2005-12-08 00:24 strk
+2005-12-08 00:24 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/EdgeIntersectionList.cpp: Reduced coordinate
- assignments in ::createSplitEdge
+ * [r968] source/geomgraph/EdgeIntersectionList.cpp: Reduced
+ coordinate assignments in ::createSplitEdge
-2005-12-08 00:03 strk
+2005-12-08 00:03 Sandro Santilli <strk at keybit.net>
- * NEWS, source/headers/geos/opOverlay.h,
+ * [r967] NEWS, source/headers/geos/opOverlay.h,
source/operation/overlay/LineBuilder.cpp:
LineBuilder::lineEdgesList made a real vector, rather then
pointer (private member).
Small optimizations in LineBuilder loops, cleanups in LineBuilder
class dox.
-2005-12-07 23:36 strk
+2005-12-07 23:36 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/EdgeIntersection.cpp: standard indentation
+ * [r966] source/geomgraph/EdgeIntersection.cpp: standard
+ indentation
-2005-12-07 22:52 strk
+2005-12-07 22:52 Sandro Santilli <strk at keybit.net>
+ * [r965] NEWS, source/geom/DefaultCoordinateSequence.cpp,
source/geom/LineString.cpp, source/headers/geos/geom.h: Added
CoordinateSequence::apply_rw(CoordinateFilter *) and
CoordinateSequence::apply_ro(CoordinateFilter *) const
@@ -13806,32 +14093,32 @@
Undefined PROFILE_COORDINATE_COPIES (erroneously left defined by
previous commit)
-2005-12-07 21:55 strk
+2005-12-07 21:55 Sandro Santilli <strk at keybit.net>
- * source/geom/CoordinateSequence.cpp: Optimized memory allocations
- in ::removeRepeatedPoints
+ * [r964] source/geom/CoordinateSequence.cpp: Optimized memory
+ allocations in ::removeRepeatedPoints
-2005-12-07 20:52 strk
+2005-12-07 20:52 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/GeometryGraph.cpp: minor container methods call
- reduction
+ * [r963] source/geomgraph/GeometryGraph.cpp: minor container
+ methods call reduction
-2005-12-07 20:51 strk
+2005-12-07 20:51 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/EdgeEndStar.cpp: removed dead code
+ * [r962] source/geomgraph/EdgeEndStar.cpp: removed dead code
- * source/geomgraph/DirectedEdgeStar.cpp: minor cleanups
+ * [r961] source/geomgraph/DirectedEdgeStar.cpp: minor cleanups
-2005-12-07 20:49 strk
+2005-12-07 20:49 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/Edge.cpp: Oops, removed Coordinate copies
+ * [r960] source/geomgraph/Edge.cpp: Oops, removed Coordinate copies
introduced by recent code cleanups
-2005-12-07 19:18 strk
+2005-12-07 19:18 Sandro Santilli <strk at keybit.net>
- * NEWS, source/geomgraph/EdgeList.cpp,
+ * [r959] NEWS, source/geomgraph/EdgeList.cpp,
source/geomgraph/PlanarGraph.cpp, source/headers/geos/geom.h,
@@ -13842,83 +14129,83 @@
Optimized polygon vector allocations in
OverlayOp::computeOverlay.
-2005-12-06 10:24 strk
+2005-12-06 10:24 Sandro Santilli <strk at keybit.net>
- * Makefile.am, NEWS, configure.in, source/capi/Makefile.am,
+ * [r958] Makefile.am, NEWS, configure.in, source/capi/Makefile.am,
source/geom/Makefile.am: Added acsite.m4 to distribution.
Added macros and flags required to build on mingw arch.
-2005-11-30 16:07 strk
+2005-11-30 16:07 Sandro Santilli <strk at keybit.net>
- * source/capi, source/capi/.cvsignore: Added geos_c.h
+ * [r955] source/capi, source/capi/.cvsignore: Added geos_c.h
-2005-11-30 16:03 strk
+2005-11-30 16:03 Sandro Santilli <strk at keybit.net>
- * tools/geos-config.in: Added --ldflags
+ * [r951] tools/geos-config.in: Added --ldflags
-2005-11-30 16:01 strk
+2005-11-30 16:01 Sandro Santilli <strk at keybit.net>
- * README: Updated with C-API usage
+ * [r949] README: Updated with C-API usage
-2005-11-30 11:27 strk
+2005-11-30 11:27 Sandro Santilli <strk at keybit.net>
- * doc/example.cpp: catch std::exception by ref
+ * [r945] doc/example.cpp: catch std::exception by ref
-2005-11-30 11:25 strk
+2005-11-30 11:25 Sandro Santilli <strk at keybit.net>
- * doc/example.cpp: includes cleanup
+ * [r944] doc/example.cpp: includes cleanup
-2005-11-29 23:01 strk
+2005-11-29 23:01 Sandro Santilli <strk at keybit.net>
- * NEWS: updated moving some items to 2.2.0
+ * [r942] NEWS: updated moving some items to 2.2.0
-2005-11-29 15:45 strk
+2005-11-29 15:45 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/TopologyLocation.cpp,
+ * [r936] source/geomgraph/TopologyLocation.cpp,
source/headers/geos/geomgraph.h: Fixed signedness of
TopologyLocation methods, cleanups.
-2005-11-29 15:16 strk
+2005-11-29 15:16 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/algorithm/MinimumDiameter.cpp,
+ * [r935] ChangeLog, source/algorithm/MinimumDiameter.cpp,
source/headers/geos/geosAlgorithm.h: Fixed sign-related warnings
and signatures.
-2005-11-29 14:49 strk
+2005-11-29 14:49 Sandro Santilli <strk at keybit.net>
- * NEWS: More info
+ * [r934] NEWS: More info
-2005-11-29 14:44 strk
+2005-11-29 14:44 Sandro Santilli <strk at keybit.net>
- * NEWS: Updated
+ * [r933] NEWS: Updated
-2005-11-29 14:39 strk
+2005-11-29 14:39 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/Edge.cpp, source/headers/geos/geomgraph.h:
- Removed number of points cache in Edge, replaced with local
- caches.
+ * [r932] source/geomgraph/Edge.cpp,
+ source/headers/geos/geomgraph.h: Removed number of points cache
+ in Edge, replaced with local caches.
- * source/geom/CoordinateSequence.cpp,
+ * [r931] source/geom/CoordinateSequence.cpp,
source/geom/DefaultCoordinateSequence.cpp: More signed/unsigned
fixes
-2005-11-29 13:39 strk
+2005-11-29 13:39 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom.h, source/headers/geos/io.h: Moved byte
- typedef from geom.h to io.h.
+ * [r930] source/headers/geos/geom.h, source/headers/geos/io.h:
+ Moved byte typedef from geom.h to io.h.
Removed useless commas at inlined funx end.
Changed CoordinateSequenceFactory::create(siz,dims) to use
unsigned for dims.
-2005-11-29 11:18 strk
+2005-11-29 11:18 Sandro Santilli <strk at keybit.net>
- * NEWS: organized changes info
+ * [r929] NEWS: organized changes info
-2005-11-29 00:48 strk
+2005-11-29 00:48 Sandro Santilli <strk at keybit.net>
+ * [r928] source/geomgraph/DirectedEdgeStar.cpp,
source/geomgraph/EdgeEndStar.cpp, source/geomgraph/Node.cpp,
source/operation/buffer/BufferSubgraph.cpp,
@@ -13929,24 +14216,24 @@
abstraction
with scoped typedefs.
-2005-11-28 18:37 strk
+2005-11-28 18:37 Sandro Santilli <strk at keybit.net>
- * source/geom/LineString.cpp: Minor warning removal
+ * [r927] source/geom/LineString.cpp: Minor warning removal
-2005-11-25 12:22 strk
+2005-11-25 12:22 Sandro Santilli <strk at keybit.net>
- * NEWS, source/test/XMLTester.cpp, source/test/XMLTester.h: Made
- XMLTester able to run multiple test files and keep overall
+ * [r926] NEWS, source/test/XMLTester.cpp, source/test/XMLTester.h:
+ Made XMLTester able to run multiple test files and keep overall
counters.
-2005-11-25 11:40 strk
+2005-11-25 11:40 Sandro Santilli <strk at keybit.net>
- * source/precision/SimpleGeometryPrecisionReducer.cpp: Another
- getSize in for loop, another int-unsigned int warning
+ * [r925] source/precision/SimpleGeometryPrecisionReducer.cpp:
+ Another getSize in for loop, another int-unsigned int warning
-2005-11-25 11:31 strk
+2005-11-25 11:31 Sandro Santilli <strk at keybit.net>
- * source/algorithm/InteriorPointArea.cpp,
+ * [r924] source/algorithm/InteriorPointArea.cpp,
source/noding/NodingValidator.cpp, source/noding/SimpleNoder.cpp,
source/noding/snapround/SimpleSegmentStringsSnapper.cpp,
source/operation/buffer/RightmostEdgeFinder.cpp,
@@ -13958,34 +14245,36 @@
source/operation/valid/RepeatedPointTester.cpp: Removed all
CoordinateSequence::getSize() calls embedded in for loops.
-2005-11-25 11:30 strk
+2005-11-25 11:30 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/Edge.cpp: Fix in ::equals() - this finally
- passes testLeaksBig.xml tests
+ * [r923] source/geomgraph/Edge.cpp: Fix in ::equals() - this
+ finally passes testLeaksBig.xml tests
-2005-11-25 09:57 strk
+2005-11-25 09:57 Sandro Santilli <strk at keybit.net>
- * source/geom/GeometryCollection.cpp: Fixed bug in getCoordinates()
- [ introduced by previous commit ]
+ * [r922] source/geom/GeometryCollection.cpp: Fixed bug in
+ getCoordinates() [ introduced by previous commit ]
-2005-11-24 23:43 strk
+2005-11-24 23:43 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/Edge.cpp, source/headers/geos/geomgraph.h: Yes
- another fix, sorry. Missing const-correctness.
+ * [r921] source/geomgraph/Edge.cpp,
+ source/headers/geos/geomgraph.h: Yes another fix, sorry. Missing
+ const-correctness.
-2005-11-24 23:24 strk
+2005-11-24 23:24 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/Edge.cpp, source/headers/geos/geomgraph.h: Fixed
- equals() function [ optimized in previous commit, but unchecked ]
+ * [r920] source/geomgraph/Edge.cpp,
+ source/headers/geos/geomgraph.h: Fixed equals() function [
+ optimized in previous commit, but unchecked ]
- * NEWS: Added note about CoordinateSequence signed->unsigned change
- in API
+ * [r919] NEWS: Added note about CoordinateSequence signed->unsigned
+ change in API
-2005-11-24 23:09 strk
+2005-11-24 23:09 Sandro Santilli <strk at keybit.net>
- * source/algorithm/CGAlgorithms.cpp,
+ * [r918] source/algorithm/CGAlgorithms.cpp,
source/algorithm/ConvexHull.cpp,
@@ -14006,16 +14295,16 @@
to avoid calling getSize() in loops.
Update of all callers is not complete yet.
-2005-11-24 23:07 strk
+2005-11-24 23:07 Sandro Santilli <strk at keybit.net>
- * source/algorithm/CentroidLine.cpp,
+ * [r917] source/algorithm/CentroidLine.cpp,
source/headers/geos/geosAlgorithm.h: CentroidLine made concrete
class (only destructor was virtual) - avoided heap allocation for
owned Coordinate centSum
-2005-11-21 16:03 strk
+2005-11-21 16:03 Sandro Santilli <strk at keybit.net>
+ * [r916] source/algorithm/CentroidArea.cpp,
source/algorithm/LineIntersector.cpp, source/geom/Coordinate.cpp,
@@ -14081,10 +14370,10 @@
storage. LineIntersector changed to reflect
the above change.
-2005-11-18 00:55 strk
+2005-11-18 00:55 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/EdgeRing.cpp, source/headers/geos/geomgraph.h,
- source/headers/geos/opOverlay.h,
+ * [r915] source/geomgraph/EdgeRing.cpp,
+ source/headers/geos/geomgraph.h, source/headers/geos/opOverlay.h,
source/operation/overlay/MaximalEdgeRing.cpp,
source/operation/overlay/MinimalEdgeRing.cpp,
source/operation/overlay/PolygonBuilder.cpp: Fixed a bug in
@@ -14098,9 +14387,9 @@
Removed heap allocations for EdgeRing containers.
Initialization lists and cleanups.
-2005-11-16 22:21 strk
+2005-11-16 22:21 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/EdgeEnd.cpp,
+ * [r913] source/geomgraph/EdgeEnd.cpp,
source/geomgraph/EdgeIntersection.cpp,
@@ -14108,9 +14397,10 @@
source/operation/valid/IsValidOp.cpp: enforced const-correctness
and use of initializer lists.
-2005-11-16 15:49 strk
+2005-11-16 15:49 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/Edge.cpp, source/geomgraph/GeometryGraph.cpp,
+ * [r912] source/geomgraph/Edge.cpp,
+ source/geomgraph/GeometryGraph.cpp,
source/geomgraph/GraphComponent.cpp,
source/headers/geos/geomgraph.h, source/headers/geos/opValid.h,
@@ -14123,16 +14413,17 @@
source/operation/valid/IsValidOp.cpp: Reduced gratuitous heap
allocations.
-2005-11-15 18:30 strk
+2005-11-15 18:30 Sandro Santilli <strk at keybit.net>
- * source/algorithm/LineIntersector.cpp, source/geomgraph/Label.cpp,
+ * [r911] source/algorithm/LineIntersector.cpp,
+ source/geomgraph/Label.cpp,
source/headers/geos/geosAlgorithm.h: Removed dead code
-2005-11-15 12:14 strk
+2005-11-15 12:14 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/opOverlay.h,
+ * [r909] source/headers/geos/opOverlay.h,
source/headers/geos/opPolygonize.h,
source/operation/linemerge/LineMergeDirectedEdge.cpp,
@@ -14149,9 +14440,9 @@
allocations, made use of references when appropriate,
small optimizations here and there.
-2005-11-15 10:04 strk
+2005-11-15 10:04 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/index/MonotoneChain.cpp,
+ * [r908] source/geomgraph/index/MonotoneChain.cpp,
source/geomgraph/index/MonotoneChainEdge.cpp,
source/geomgraph/index/MonotoneChainIndexer.cpp,
source/geomgraph/index/SegmentIntersector.cpp,
@@ -14163,14 +14454,15 @@
Enforced const-correctness, changed some interfaces
to use references rather then pointers when appropriate.
-2005-11-15 10:02 strk
+2005-11-15 10:02 Sandro Santilli <strk at keybit.net>
- * source/geom/LineString.cpp: optimized envelope computation
+ * [r907] source/geom/LineString.cpp: optimized envelope computation
reducing virtual calls
-2005-11-14 18:14 strk
+2005-11-14 18:14 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/Depth.cpp, source/geomgraph/DirectedEdge.cpp,
+ * [r906] source/geomgraph/Depth.cpp,
+ source/geomgraph/DirectedEdge.cpp,
source/geomgraph/DirectedEdgeStar.cpp, source/geomgraph/Edge.cpp,
source/geomgraph/GraphComponent.cpp, source/geomgraph/Label.cpp,
@@ -14184,106 +14476,111 @@
Enforced const-correctness on GraphComponent.
Cleanups.
-2005-11-10 16:26 strk
+2005-11-10 16:26 Sandro Santilli <strk at keybit.net>
- * source/io/WKBReader.cpp: Fixed printHEX (was printing one char
- past the WKB)
+ * [r904] source/io/WKBReader.cpp: Fixed printHEX (was printing one
+ char past the WKB)
-2005-11-10 15:20 strk
+2005-11-10 15:20 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geomUtil.h, source/headers/geos/geomgraph.h,
+ * [r903] source/headers/geos/geomUtil.h,
source/headers/geos/precision.h: Made virtual overloads explicit.
-2005-11-10 10:47 strk
+2005-11-10 10:47 Sandro Santilli <strk at keybit.net>
- * source/geom/MultiPoint.cpp, source/headers/geos/geom.h: Renamed
- MultiPoint::getCoordinate(int) to MultiPoint::getCoordinateN(int)
+ * [r902] source/geom/MultiPoint.cpp, source/headers/geos/geom.h:
+ Renamed MultiPoint::getCoordinate(int) to
+ MultiPoint::getCoordinateN(int)
to avoid hiding of Geometry::getCoordinate().
-2005-11-10 10:24 strk
+2005-11-10 10:24 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/util.h, source/util/CoordinateArrayFiter.cpp:
- Fixed virtual overload of CoordinateArrayFilter::filter*
+ * [r901] source/headers/geos/util.h,
+ source/util/CoordinateArrayFiter.cpp: Fixed virtual overload of
+ CoordinateArrayFilter::filter*
-2005-11-10 09:33 strk
+2005-11-10 09:33 Sandro Santilli <strk at keybit.net>
- * source/geom/LineString.cpp, source/headers/geos/geom.h: Removed
- virtual overloading LineString::compareTo(LineString *)
+ * [r900] source/geom/LineString.cpp, source/headers/geos/geom.h:
+ Removed virtual overloading LineString::compareTo(LineString *)
-2005-11-09 15:14 strk
+2005-11-09 15:14 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/DepthSegment.cpp: Forgot to add this
+ * [r899] source/operation/buffer/DepthSegment.cpp: Forgot to add
+ this
-2005-11-09 13:44 strk
+2005-11-09 13:44 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/Node.cpp, source/geomgraph/NodeMap.cpp,
+ * [r898] source/geomgraph/Node.cpp, source/geomgraph/NodeMap.cpp,
source/headers/geos/geomgraph.h: Cleanups in Node and NodeMap.
Optimization of EdgeIntersectionLessThen.
-2005-11-09 08:57 strk
+2005-11-09 08:57 Sandro Santilli <strk at keybit.net>
- IntersectionMatrix made a concrete and final type.
+ * [r897] source/geom/IntersectionMatrix.cpp,
+ source/headers/geos/geom.h: IntersectionMatrix made a concrete
+ and final type.
Cleanups in class definition.
-2005-11-08 20:12 strk
+2005-11-08 20:12 Sandro Santilli <strk at keybit.net>
- * NEWS, source/geom/Makefile.am, source/headers/geos/geom.h,
+ * [r896] NEWS, source/geom/Makefile.am, source/headers/geos/geom.h,
source/operation/buffer/SubgraphDepthLocater.cpp: Memory overhead
reductions in buffer operations.
-2005-11-08 12:32 strk
+2005-11-08 12:32 Sandro Santilli <strk at keybit.net>
- * source/geom/DefaultCoordinateSequence.cpp: Cleanups, ::setPoint
- small improvement
+ * [r895] source/geom/DefaultCoordinateSequence.cpp: Cleanups,
+ ::setPoint small improvement
-2005-11-08 11:33 strk
+2005-11-08 11:33 Sandro Santilli <strk at keybit.net>
- * source/operation/overlay/OverlayOp.cpp: comments cleanup
+ * [r894] source/operation/overlay/OverlayOp.cpp: comments cleanup
-2005-11-08 10:26 strk
+2005-11-08 10:26 Sandro Santilli <strk at keybit.net>
- * configure.in: Library versioning took back to 3.0.0
+ * [r893] configure.in: Library versioning took back to 3.0.0
-2005-11-08 10:03 strk
+2005-11-08 10:03 Sandro Santilli <strk at keybit.net>
- * configure.in, doc/Doxyfile.in, source/geom/Envelope.cpp,
+ * [r892] configure.in, doc/Doxyfile.in, source/geom/Envelope.cpp,
source/geom/Geometry.cpp, source/headers/geos/geom.h: Set library
version to 2.2.0.
Cleaned up Doxygen warnings.
Inlined more Envelope methods.
Dropped deprecated Envelope::overlaps methods.
-2005-11-07 18:07 strk
+2005-11-07 18:07 Sandro Santilli <strk at keybit.net>
- * configure.in: Removed VisualStudio knowledge from configure
- script
+ * [r890] configure.in: Removed VisualStudio knowledge from
+ configure script
-2005-11-07 18:05 strk
+2005-11-07 18:05 Sandro Santilli <strk at keybit.net>
+ * [r889] source/geomgraph/EdgeIntersectionList.cpp,
source/headers/geos/noding.h, source/noding/SegmentNodeList.cpp:
Reduced set<> lookups
2005-11-07 13:17 frank
- * VisualStudio: no longer used
+ * [r888] VisualStudio: no longer used
- * Makefile.am: removed VisualStudio, no longer distributed
+ * [r887] Makefile.am: removed VisualStudio, no longer distributed
2005-11-07 13:16 frank
- * VisualStudio/.cvsignore: obsolete
+ * [r886] VisualStudio/.cvsignore: obsolete
-2005-11-07 12:31 strk
+2005-11-07 12:31 Sandro Santilli <strk at keybit.net>
- * NEWS, source/geomgraph/Edge.cpp,
+ * [r885] NEWS, source/geomgraph/Edge.cpp,
@@ -14300,26 +14597,26 @@
to avoid dynamic allocation of initial header.
Inlined short SweepLineEvent methods.
-2005-11-07 11:32 strk
+2005-11-07 11:32 Sandro Santilli <strk at keybit.net>
- * source/capi/geos_c.h.in: Added const qualifiers to function to
- reflect paradigm of immutable
+ * [r884] source/capi/geos_c.h.in: Added const qualifiers to
+ function to reflect paradigm of immutable
Geometry objects.
-2005-11-04 15:42 strk
+2005-11-04 15:42 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/index/SweepLineEvent.cpp: Fixed bug in
+ * [r883] source/geomgraph/index/SweepLineEvent.cpp: Fixed bug in
SweepLineEventLessThen functor
(didn't conform to strict weak ordering).
Note: this was introduced by previous commit.
-2005-11-04 11:06 strk
+2005-11-04 11:06 Sandro Santilli <strk at keybit.net>
- * NEWS: updated
+ * [r882] NEWS: updated
-2005-11-04 11:04 strk
+2005-11-04 11:04 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/opValid.h,
+ * [r881] source/headers/geos/opValid.h,
source/operation/valid/QuadtreeNestedRingTester.cpp,
source/operation/valid/SimpleNestedRingTester.cpp,
@@ -14330,180 +14627,181 @@
rather then actual objects, to speedup NULL tests.
Added JTS port revision when applicable.
-2005-11-04 08:28 strk
+2005-11-04 08:28 Sandro Santilli <strk at keybit.net>
- * NEWS, source/operation/overlay/OverlayOp.cpp: Ported speedup of
- OverlayOp::insertUniqueEdge() from JTS-1.7 (rev 1.23)
+ * [r880] NEWS, source/operation/overlay/OverlayOp.cpp: Ported
+ speedup of OverlayOp::insertUniqueEdge() from JTS-1.7 (rev 1.23)
Updated NEWS file.
-2005-11-03 21:28 strk
+2005-11-03 21:28 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/index/SimpleMCSweepLineIntersector.cpp,
+ * [r878] source/geomgraph/index/SimpleMCSweepLineIntersector.cpp,
source/geomgraph/index/SimpleSweepLineIntersector.cpp: Fixed
constructors broke by previous commit
-2005-11-03 19:51 strk
+2005-11-03 19:51 Sandro Santilli <strk at keybit.net>
+ * [r877] source/geomgraph/index/SimpleMCSweepLineIntersector.cpp,
source/geomgraph/index/SimpleSweepLineIntersector.cpp,
source/headers/geos/geomgraphindex.h: Indentation changes, small
vector memory allocation optimization.
-2005-11-03 09:15 strk
+2005-11-03 09:15 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom.h: Removed declaration of
+ * [r876] source/headers/geos/geom.h: Removed declaration of
PointCoordinateSequence and PointCoordinateSequenceFactory
-2005-11-01 09:40 strk
+2005-11-01 09:40 Sandro Santilli <strk at keybit.net>
- * source/operation/valid/IsValidOp.cpp: Replaced finite() with
- FINITE() calls.
+ * [r875] source/operation/valid/IsValidOp.cpp: Replaced finite()
+ with FINITE() calls.
-2005-10-27 14:05 strk
+2005-10-27 14:05 Sandro Santilli <strk at keybit.net>
+ * [r873] source/geomgraph/index/SimpleMCSweepLineIntersector.cpp,
source/geomgraph/index/SweepLineEvent.cpp,
source/headers/geos/geomgraphindex.h: Added a
SweepLineEventLessThen functor to be used by sort algorithm.
-2005-10-24 13:28 strk
+2005-10-24 13:28 Sandro Santilli <strk at keybit.net>
- * source/capi/geos_c.cpp, source/capi/geos_c.h.in,
+ * [r872] source/capi/geos_c.cpp, source/capi/geos_c.h.in,
source/capi/geostest.c: Changed constructors to take ownership of
GEOSGeom and GEOSCoordSeq objects.
Changed inspectors to retain ownership of GEOSGeom and
Added GEOSGeom_clone() method.
-2005-10-21 15:13 strk
+2005-10-21 15:13 Sandro Santilli <strk at keybit.net>
- * source/capi/geos_c.cpp, source/capi/geos_c.h.in: Added
+ * [r871] source/capi/geos_c.cpp, source/capi/geos_c.h.in: Added
GEOSGeom_clone() function
-2005-10-21 12:14 strk
+2005-10-21 12:14 Sandro Santilli <strk at keybit.net>
- * source/capi/geos_c.h.in: Added missing GEOS_DLL specifiers
+ * [r870] source/capi/geos_c.h.in: Added missing GEOS_DLL specifiers
-2005-10-21 12:07 strk
+2005-10-21 12:07 Sandro Santilli <strk at keybit.net>
+ * [r869] source/capi/geos_c.cpp, source/capi/geos_c.h.in,
source/capi/geostest.c: Added fine-grained geometry constructors
and GEOSCoordSeq abstract data type.
Renamed GEOSmakeCollection to GEOSGeom_createCollection
-2005-10-21 09:02 strk
+2005-10-21 09:02 Sandro Santilli <strk at keybit.net>
- * configure.in: typo fixed
+ * [r868] configure.in: typo fixed
2005-10-21 02:46 frank
- * AUTHORS: added myself to authors - isn't that cheeky!
+ * [r867] AUTHORS: added myself to authors - isn't that cheeky!
2005-10-21 02:45 frank
- * README: added note on source\makefile.vc
+ * [r866] README: added note on source\makefile.vc
2005-10-21 02:44 frank
- * source/Makefile.vc: added a wee readme
+ * [r865] source/Makefile.vc: added a wee readme
2005-10-21 02:41 frank
- * source/Makefile.vc: added DLL building, and geostest.exe
+ * [r864] source/Makefile.vc: added DLL building, and geostest.exe
- * source/capi/geos_c.h.in: need to DLL export C API
+ * [r863] source/capi/geos_c.h.in: need to DLL export C API
2005-10-21 02:37 frank
- * source/capi/geos_c.cpp: DLL Export functions
+ * [r862] source/capi/geos_c.cpp: DLL Export functions
- * source/capi/geostest.c: avoid non-portable vasprintf, make big
- buffer static
+ * [r861] source/capi/geostest.c: avoid non-portable vasprintf, make
+ big buffer static
2005-10-21 01:57 frank
- * source/Makefile.vc: updated for 3.0.0 and added C API
+ * [r860] source/Makefile.vc: updated for 3.0.0 and added C API
2005-10-20 20:37 frank
- * source/headers/geos/platform.h.vc: added getMachineByteOrder(),
- convert to unix text mode
+ * [r859] source/headers/geos/platform.h.vc: added
+ getMachineByteOrder(), convert to unix text mode
-2005-10-19 13:07 strk
+2005-10-19 13:07 Sandro Santilli <strk at keybit.net>
- * source/io/WKBReader.cpp: Added support for SRID flag in WKB (full
- EWKB is accepted now)
+ * [r858] source/io/WKBReader.cpp: Added support for SRID flag in
+ WKB (full EWKB is accepted now)
-2005-10-19 12:59 strk
+2005-10-19 12:59 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/io.h: Added input stream checks in
+ * [r857] source/headers/geos/io.h: Added input stream checks in
ByteOrderDataInStream, throwing ParseException on unexpected EOF
-2005-10-17 15:55 strk
+2005-10-17 15:55 Sandro Santilli <strk at keybit.net>
+ * [r856] source/capi/geos_c.cpp, source/capi/geos_c.h.in: Added
GetGeometryN, GetInteriorRingN, GetExteriorRing
-2005-10-17 14:37 strk
+2005-10-17 14:37 Sandro Santilli <strk at keybit.net>
- * source/capi/geos_c.h.in: Added comments on exception returns for
- Geometry info functions
+ * [r855] source/capi/geos_c.h.in: Added comments on exception
+ returns for Geometry info functions
-2005-10-17 14:33 strk
+2005-10-17 14:33 Sandro Santilli <strk at keybit.net>
- * source/capi/geos_c.cpp: Added missing exception handlers from
- previous commit.
+ * [r854] source/capi/geos_c.cpp: Added missing exception handlers
+ from previous commit.
Fixed GEOSGeomTypeId signatures.
-2005-10-17 12:56 strk
+2005-10-17 12:56 Sandro Santilli <strk at keybit.net>
- * source/geom/Makefile.am: Removed GEOS_VERSION define
+ * [r853] source/geom/Makefile.am: Removed GEOS_VERSION define
(Geometry.cpp, the only file using this will use the one in
version.h)
-2005-10-17 12:55 strk
+2005-10-17 12:55 Sandro Santilli <strk at keybit.net>
- * source/capi/geos_c.h.in: Fixed GEOSGeom typedef to be accepted by
- C++ compilers, added extern "C" namespace for inclusion by C++
- code (really needed?)
+ * [r852] source/capi/geos_c.h.in: Fixed GEOSGeom typedef to be
+ accepted by C++ compilers, added extern "C" namespace for
+ inclusion by C++ code (really needed?)
-2005-10-17 09:38 strk
+2005-10-17 09:38 Sandro Santilli <strk at keybit.net>
+ * [r851] source/capi/geos_c.cpp, source/capi/geos_c.h.in,
source/capi/geostest.c: Added GEOSDistance() function.
Trapped all exceptions and reported using ERROR_MESSAGE rather
then NOTICE_MESSAGE.
Changed WKB functions to use 'unsigned char' rather then 'char'
Added missing GEOS_setWKBOutputDims() function in header file.
-2005-09-28 16:33 strk
+2005-09-28 16:33 Sandro Santilli <strk at keybit.net>
- * source/capi/geos_c.cpp: Added GEOS_setWKBOutputDims(int) function
- to specify coordinate
+ * [r850] source/capi/geos_c.cpp: Added GEOS_setWKBOutputDims(int)
+ function to specify coordinate
dimension in WKB output.
-2005-09-28 10:15 strk
+2005-09-28 10:15 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/io.h, source/io/WKBWriter.cpp: WKBWriter ctor
- out-lined (will require changes in the near future, for higher
- dimensions support), added support for 3d WKB output
+ * [r849] source/headers/geos/io.h, source/io/WKBWriter.cpp:
+ WKBWriter ctor out-lined (will require changes in the near
+ future, for higher dimensions support), added support for 3d WKB
+ output
-2005-09-28 09:36 strk
+2005-09-28 09:36 Sandro Santilli <strk at keybit.net>
- * source/io/WKBReader.cpp: Cleanups in the printHEX function
+ * [r848] source/io/WKBReader.cpp: Cleanups in the printHEX function
-2005-09-27 16:29 strk
+2005-09-27 16:29 Sandro Santilli <strk at keybit.net>
- * source/io/WKBReader.cpp: Ported JTS-1.7 use of PrecisionModel in
- WKBReader
+ * [r847] source/io/WKBReader.cpp: Ported JTS-1.7 use of
+ PrecisionModel in WKBReader
-2005-09-27 16:20 strk
+2005-09-27 16:20 Sandro Santilli <strk at keybit.net>
- * doc/example.cpp, source/capi/geos_c.cpp,
+ * [r846] doc/example.cpp, source/capi/geos_c.cpp,
source/headers/geos/io.h, source/io/WKBReader.cpp: Reverted
previous change, fixed the bug by turning WKBReader.factory
into a reference rather then a real object. ABI still breaks, but
@@ -14512,126 +14810,128 @@
breaking
ABI is not a big deal at this stage).
-2005-09-27 16:00 strk
+2005-09-27 16:00 Sandro Santilli <strk at keybit.net>
+ * [r845] doc/example.cpp, source/capi/geos_c.cpp,
source/headers/geos/io.h, source/io/WKBReader.cpp: Fixed bug in
WKBReader destroying the GeometryFactory used in Geometry
construction. Changed it's definition to *require* a
GeometryFactory
pointer parameter.
-2005-09-27 08:51 strk
+2005-09-27 08:51 Sandro Santilli <strk at keybit.net>
- * source/test/Makefile.am: Added XMLTester.h in XMLTester_SOURCES
- list
+ * [r844] source/test/Makefile.am: Added XMLTester.h in
+ XMLTester_SOURCES list
-2005-09-26 14:40 strk
+2005-09-26 14:40 Sandro Santilli <strk at keybit.net>
- * source/io/WKBReader.cpp: Fixed handling of higher dimensional WKB
- streams
+ * [r843] source/io/WKBReader.cpp: Fixed handling of higher
+ dimensional WKB streams
-2005-09-26 13:46 strk
+2005-09-26 13:46 Sandro Santilli <strk at keybit.net>
- * source/capi/Makefile.am: Modified GEOS_CAPI_VERSION to include
- underlying GEOS version
+ * [r842] source/capi/Makefile.am: Modified GEOS_CAPI_VERSION to
+ include underlying GEOS version
-2005-09-26 13:42 strk
+2005-09-26 13:42 Sandro Santilli <strk at keybit.net>
- * configure.in, source/capi/Makefile.am, source/capi/geos_c.cpp,
- source/capi/geos_c.h, source/capi/geos_c.h.in: Moved C-api
- versioning to top-level configure.in
+ * [r841] configure.in, source/capi/Makefile.am,
+ source/capi/geos_c.cpp, source/capi/geos_c.h,
+ source/capi/geos_c.h.in: Moved C-api versioning to top-level
+ configure.in
Added version info in geos_c.h
-2005-09-26 12:25 strk
+2005-09-26 12:25 Sandro Santilli <strk at keybit.net>
- * source/capi/geos_c.cpp, source/capi/geos_c.h,
+ * [r840] source/capi/geos_c.cpp, source/capi/geos_c.h,
source/capi/geostest.c: Changed LineMerge interface to accept a
single Geometry and return the simpler Geometry obtainable with
the set of merger LineStrings. Fixed leaks in geostest, fixed a
leak in GEOSRelate().
-2005-09-26 12:23 strk
+2005-09-26 12:23 Sandro Santilli <strk at keybit.net>
- * source/geom/PrecisionModel.cpp: Initializzation lists in
+ * [r839] source/geom/PrecisionModel.cpp: Initializzation lists in
PrecisionModel ctors
-2005-09-26 11:04 strk
+2005-09-26 11:04 Sandro Santilli <strk at keybit.net>
- * NEWS: Added changes in LineMerger
+ * [r838] NEWS: Added changes in LineMerger
-2005-09-26 11:01 strk
+2005-09-26 11:01 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/opLinemerge.h,
+ * [r837] source/headers/geos/opLinemerge.h,
source/operation/linemerge/EdgeString.cpp,
source/operation/linemerge/LineMergeEdge.cpp,
source/operation/linemerge/LineMerger.cpp: Const correctness
changes in LineMerger package, and a few speedups.
-2005-09-26 08:18 strk
+2005-09-26 08:18 Sandro Santilli <strk at keybit.net>
- * source/capi, source/capi/.cvsignore: Added .lo, .la and geostest
+ * [r836] source/capi, source/capi/.cvsignore: Added .lo, .la and
+ geostest
-2005-09-26 08:17 strk
+2005-09-26 08:17 Sandro Santilli <strk at keybit.net>
- * doc/example.cpp: Removed memory leak from WKB tester
+ * [r835] doc/example.cpp: Removed memory leak from WKB tester
-2005-09-23 17:20 strk
+2005-09-23 17:20 Sandro Santilli <strk at keybit.net>
+ * [r834] source/headers/geos/opLinemerge.h,
source/operation/linemerge/LineMerger.cpp: Made LineMerger graph
be a real object (rather then a pointer to it)
-2005-09-23 16:07 strk
+2005-09-23 16:07 Sandro Santilli <strk at keybit.net>
- * source/capi/geos_c.cpp: Fixed export of GEOSPolygonize() and
- GEOSMakeCollection()
+ * [r833] source/capi/geos_c.cpp: Fixed export of GEOSPolygonize()
+ and GEOSMakeCollection()
-2005-09-23 09:49 strk
+2005-09-23 09:49 Sandro Santilli <strk at keybit.net>
- * source/capi/geos_c.cpp, source/capi/geos_c.h: Added
+ * [r832] source/capi/geos_c.cpp, source/capi/geos_c.h: Added
GEOSMakeCollection.
Changed GEOSGetCentroid to return an EmptyGeometry when no
Centroid can be
computed (Empty input, for example).
-2005-09-19 08:16 strk
+2005-09-19 08:16 Sandro Santilli <strk at keybit.net>
- * NEWS: Added C api
+ * [r831] NEWS: Added C api
-2005-09-14 15:11 strk
+2005-09-14 15:11 Sandro Santilli <strk at keybit.net>
- * source/capi/geos_c.h: Removed functions returning not-new
+ * [r830] source/capi/geos_c.h: Removed functions returning not-new
GEOSGeom objects to avoid ambiguity
whereas when to destroy returns. Added not about memory
management.
-2005-09-14 14:55 strk
+2005-09-14 14:55 Sandro Santilli <strk at keybit.net>
+ * [r829] source/capi/geos_c.cpp, source/capi/geos_c.h,
source/capi/geostest.c: Added copyright notices and usage notes
-2005-09-14 14:28 strk
+2005-09-14 14:28 Sandro Santilli <strk at keybit.net>
- * source/io/WKBWriter.cpp: Fixed bug writing WKB for all Multi*
- geoms as Collections.
+ * [r828] source/io/WKBWriter.cpp: Fixed bug writing WKB for all
+ Multi* geoms as Collections.
-2005-09-14 13:58 strk
+2005-09-14 13:58 Sandro Santilli <strk at keybit.net>
- * configure.in, source/Makefile.am, source/capi,
+ * [r827] configure.in, source/Makefile.am, source/capi,
source/capi/.cvsignore, source/capi/Makefile.am,
source/capi/geostest.c, source/capi/test.wkt: Initial abstract C
api.
-2005-09-14 13:56 strk
+2005-09-14 13:56 Sandro Santilli <strk at keybit.net>
- * source/io/WKBReader.cpp: Typo fixed
+ * [r826] source/io/WKBReader.cpp: Typo fixed
-2005-09-03 21:26 strk
+2005-09-03 21:26 Sandro Santilli <strk at keybit.net>
- * doc/example.cpp, source/geom/Makefile.am,
+ * [r825] doc/example.cpp, source/geom/Makefile.am,
source/headers/geos/ByteOrderDataInStreamT.h,
source/headers/geos/Makefile.am,
source/headers/geos/WKBReaderT.h,
@@ -14639,124 +14939,128 @@
source/io/WKBReader.cpp, source/io/WKBWriter.cpp: Reworked WKB
I/O to avoid use of templates and make better use of STL
-2005-08-22 13:34 strk
+2005-08-22 13:34 Sandro Santilli <strk at keybit.net>
- * NEWS: Added 2.1.4 section
+ * [r822] NEWS: Added 2.1.4 section
-2005-08-22 13:31 strk
+2005-08-22 13:31 Sandro Santilli <strk at keybit.net>
+ * [r821] source/geom/Geometry.cpp,
source/operation/buffer/BufferBuilder.cpp,
source/planargraph/planarDirectedEdgeStar.cpp: Fixed comparator
functions used with STL sort() algorithm to
implement StrictWeakOrdering semantic.
-2005-07-12 14:33 strk
+2005-07-12 14:33 Sandro Santilli <strk at keybit.net>
- * NEWS: updated
+ * [r819] NEWS: updated
-2005-07-11 16:21 strk
+2005-07-11 16:21 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/ByteOrderDataInStreamT.h,
+ * [r818] source/headers/geos/ByteOrderDataInStreamT.h,
source/headers/geos/WKBWriterT.h: Removed '_' prefix from header
guards
-2005-07-11 12:17 strk
+2005-07-11 12:17 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/io.h, source/headers/geos/opOverlay.h,
+ * [r817] source/headers/geos/io.h, source/headers/geos/opOverlay.h,
source/headers/geos/platform.h.in: Cleaned up syntax
- * doc/example.cpp: Commented out useless include
+ * [r816] doc/example.cpp: Commented out useless include
-2005-07-11 10:50 strk
+2005-07-11 10:50 Sandro Santilli <strk at keybit.net>
- * source/geom/Geometry.cpp: Added parens suggested by compiler
+ * [r815] source/geom/Geometry.cpp: Added parens suggested by
+ compiler
-2005-07-11 10:27 strk
+2005-07-11 10:27 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/Edge.cpp, source/headers/geos/WKBReaderT.h:
- Cleaned up signed/unsigned mismatches
+ * [r814] source/geomgraph/Edge.cpp,
+ source/headers/geos/WKBReaderT.h: Cleaned up signed/unsigned
+ mismatches
- * source/geomgraph/DirectedEdge.cpp,
+ * [r813] source/geomgraph/DirectedEdge.cpp,
source/operation/buffer/BufferOp.cpp,
source/operation/buffer/SubgraphDepthLocater.cpp: Fixed
initializzazion lists
-2005-07-11 10:26 strk
+2005-07-11 10:26 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom.h: Made CoordinateSequence::getDimension
- return unsigned int instead of int
+ * [r812] source/headers/geos/geom.h: Made
+ CoordinateSequence::getDimension return unsigned int instead of
+ int
-2005-07-11 10:23 strk
+2005-07-11 10:23 Sandro Santilli <strk at keybit.net>
- * source/geom/Geometry.cpp: removed useless assignment
+ * [r811] source/geom/Geometry.cpp: removed useless assignment
-2005-06-30 18:31 strk
+2005-06-30 18:31 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/opBuffer.h,
+ * [r807] source/headers/geos/opBuffer.h,
source/operation/buffer/SubgraphDepthLocater.cpp: Ported
SubgraphDepthLocator optimizations from JTS code
-2005-06-28 21:13 strk
+2005-06-28 21:13 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/SubgraphDepthLocater.cpp: Fixed a bug
- introduced by LineSegment skip - made LineSegment skip a
+ * [r803] source/operation/buffer/SubgraphDepthLocater.cpp: Fixed a
+ bug introduced by LineSegment skip - made LineSegment skip a
compile-time optione
-2005-06-28 16:52 strk
+2005-06-28 16:52 Sandro Santilli <strk at keybit.net>
- * source/test/XMLTester.cpp: Added number of points count as a
- debugging aid
+ * [r802] source/test/XMLTester.cpp: Added number of points count as
+ a debugging aid
-2005-06-28 11:22 strk
+2005-06-28 11:22 Sandro Santilli <strk at keybit.net>
- * NEWS: Added DepthSegmentLT bugfix
+ * [r801] NEWS: Added DepthSegmentLT bugfix
-2005-06-28 01:07 strk
+2005-06-28 01:07 Sandro Santilli <strk at keybit.net>
+ * [r796] source/headers/geos/opOverlay.h,
source/operation/overlay/PointBuilder.cpp: improved extraction of
result points in overlay op
-2005-06-28 00:04 strk
+2005-06-28 00:04 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/Node.cpp: improved ::isIncidentEdgeInResult()
- method
+ * [r794] source/geomgraph/Node.cpp: improved
+ ::isIncidentEdgeInResult() method
-2005-06-27 21:58 strk
+2005-06-27 21:58 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/SubgraphDepthLocater.cpp: Bugfix in
- DepthSegmentLT as suggested by Graeme Hiebert
+ * [r793] source/operation/buffer/SubgraphDepthLocater.cpp: Bugfix
+ in DepthSegmentLT as suggested by Graeme Hiebert
-2005-06-27 21:24 strk
+2005-06-27 21:24 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/SubgraphDepthLocater.cpp: Fixed bug
- just-introduced with optimization.
+ * [r790] source/operation/buffer/SubgraphDepthLocater.cpp: Fixed
+ bug just-introduced with optimization.
-2005-06-27 21:21 strk
+2005-06-27 21:21 Sandro Santilli <strk at keybit.net>
- * NEWS, source/operation/buffer/SubgraphDepthLocater.cpp: Reduced
- Coordinate copies due to LineSegment overuse
+ * [r789] NEWS, source/operation/buffer/SubgraphDepthLocater.cpp:
+ Reduced Coordinate copies due to LineSegment overuse
-2005-06-25 10:20 strk
+2005-06-25 10:20 Sandro Santilli <strk at keybit.net>
- * NEWS, source/geomgraph/Node.cpp, source/headers/geos/geomgraph.h,
+ * [r787] NEWS, source/geomgraph/Node.cpp,
source/operation/overlay/PointBuilder.cpp: OverlayOp speedup (JTS
port)
-2005-06-24 11:12 strk
+2005-06-24 11:12 Sandro Santilli <strk at keybit.net>
- * NEWS: Added LineIntersector concrete type note
+ * [r786] NEWS: Added LineIntersector concrete type note
-2005-06-24 11:09 strk
+2005-06-24 11:09 Sandro Santilli <strk at keybit.net>
+ * [r785] source/algorithm/CGAlgorithms.cpp,
source/algorithm/PointLocator.cpp, source/geom/LineSegment.cpp,
source/geom/Makefile.am, source/geomgraph/PlanarGraph.cpp,
@@ -14776,130 +15080,132 @@
to avoid computing intersection point (Z) when it's not
necessary.
-2005-06-23 14:22 strk
+2005-06-23 14:22 Sandro Santilli <strk at keybit.net>
- * NEWS, source/geom/GeometryCollection.cpp,
+ * [r784] NEWS, source/geom/GeometryCollection.cpp,
source/geom/LineString.cpp, source/geom/LinearRing.cpp,
source/headers/geos/geom.h: Inlined and added missing ::clone()
for Geometry subclasses
-2005-06-23 11:23 strk
+2005-06-23 11:23 Sandro Santilli <strk at keybit.net>
- * NEWS, source/algorithm/CGAlgorithms.cpp: performance improvement
- for CGAlgorithms::isOnLine()
+ * [r782] NEWS, source/algorithm/CGAlgorithms.cpp: performance
+ improvement for CGAlgorithms::isOnLine()
-2005-06-22 00:46 strk
+2005-06-22 00:46 Sandro Santilli <strk at keybit.net>
- * NEWS, source/geom/Geometry.cpp: Shortcircuit tests for Union
+ * [r779] NEWS, source/geom/Geometry.cpp: Shortcircuit tests for
+ Union
- * source/geom/GeometryFactory.cpp: Fixed bugus handling of
+ * [r777] source/geom/GeometryFactory.cpp: Fixed bugus handling of
collections in ::buildGeometry
-2005-06-21 12:22 strk
+2005-06-21 12:22 Sandro Santilli <strk at keybit.net>
+ * [r773] NEWS, source/test/XMLTester.cpp, source/test/XMLTester.h:
XMLTester code cleanups
-2005-06-20 10:23 strk
+2005-06-20 10:23 Sandro Santilli <strk at keybit.net>
- * NEWS, source/test/Makefile.am: XMLTester installed by default
+ * [r772] NEWS, source/test/Makefile.am: XMLTester installed by
+ default
-2005-06-17 15:17 strk
+2005-06-17 15:17 Sandro Santilli <strk at keybit.net>
- * ., .cvsignore, ltmain.sh: Removed ltmain.sh from repository, will
- be created by autogen.sh
+ * [r770] ., .cvsignore, ltmain.sh: Removed ltmain.sh from
+ repository, will be created by autogen.sh
-2005-06-17 15:08 strk
+2005-06-17 15:08 Sandro Santilli <strk at keybit.net>
- * NEWS, source/operation/polygonize/Polygonizer.cpp,
+ * [r766] NEWS, source/operation/polygonize/Polygonizer.cpp,
source/operation/polygonize/polygonizeEdgeRing.cpp: Polygonizer
segfault fix
-2005-06-17 14:58 strk
+2005-06-17 14:58 Sandro Santilli <strk at keybit.net>
- * source/geom/GeometryFactory.cpp: Fixed segfault in LinearRing and
- LineString constructors
+ * [r764] source/geom/GeometryFactory.cpp: Fixed segfault in
+ LinearRing and LineString constructors
-2005-06-14 11:57 strk
+2005-06-14 11:57 Sandro Santilli <strk at keybit.net>
- * NEWS, source/test/XMLTester.cpp: Added workaround for mingw
- Polygon name clash
+ * [r761] NEWS, source/test/XMLTester.cpp: Added workaround for
+ mingw Polygon name clash
-2005-06-10 14:04 strk
+2005-06-10 14:04 Sandro Santilli <strk at keybit.net>
- * autogen.sh: Added libtoolize call
+ * [r760] autogen.sh: Added libtoolize call
-2005-06-10 13:24 strk
+2005-06-10 13:24 Sandro Santilli <strk at keybit.net>
- * source/test/XMLTester.cpp: Added use declaration to make MingW
- build work
+ * [r758] source/test/XMLTester.cpp: Added use declaration to make
+ MingW build work
-2005-06-08 09:38 strk
+2005-06-08 09:38 Sandro Santilli <strk at keybit.net>
- * INSTALL: Added GCC version requirement note
+ * [r754] INSTALL: Added GCC version requirement note
-2005-06-05 10:41 strk
+2005-06-05 10:41 Sandro Santilli <strk at keybit.net>
- * CHANGES, NEWS: Changes file renamed back to NEWS, automake
+ * [r752] CHANGES, NEWS: Changes file renamed back to NEWS, automake
insists on finding it.
2005-05-30 16:20 autorun
- * NEWS: Blank news file to molfify new versions of autoconf
+ * [r750] NEWS: Blank news file to molfify new versions of autoconf
-2005-05-24 08:42 strk
+2005-05-24 08:42 Sandro Santilli <strk at keybit.net>
- * NEWS: Info moved into CHANGES file
+ * [r749] NEWS: Info moved into CHANGES file
- * CHANGES: Filled in section from 2.0.0 to 2.1.1
+ * [r748] CHANGES: Filled in section from 2.0.0 to 2.1.1
-2005-05-24 07:48 strk
+2005-05-24 07:48 Sandro Santilli <strk at keybit.net>
- * CHANGES: Initial import
+ * [r744] CHANGES: Initial import
-2005-05-23 16:42 strk
+2005-05-23 16:42 Sandro Santilli <strk at keybit.net>
- * source/geom/Point.cpp: Added Refractions copyright
+ * [r728] source/geom/Point.cpp: Added Refractions copyright
-2005-05-23 15:13 strk
+2005-05-23 15:13 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferSubgraph.cpp,
+ * [r717] source/operation/buffer/BufferSubgraph.cpp,
source/operation/buffer/SubgraphDepthLocater.cpp: Added debugging
output
-2005-05-23 15:04 strk
+2005-05-23 15:04 Sandro Santilli <strk at keybit.net>
- * source/geom/LineSegment.cpp: Fixed bug in ::reverse()
+ * [r716] source/geom/LineSegment.cpp: Fixed bug in ::reverse()
-2005-05-22 17:45 strk
+2005-05-22 17:45 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferSubgraph.cpp: Fixed initialization
- list order
+ * [r715] source/operation/buffer/BufferSubgraph.cpp: Fixed
+ initialization list order
-2005-05-22 17:42 strk
+2005-05-22 17:42 Sandro Santilli <strk at keybit.net>
- * ChangeLog, source/headers/geos/Makefile.am: Added missing
+ * [r714] ChangeLog, source/headers/geos/Makefile.am: Added missing
WKBWriterT.h
-2005-05-20 16:15 strk
+2005-05-20 16:15 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/Position.cpp,
+ * [r713] source/geomgraph/Position.cpp,
source/operation/buffer/SubgraphDepthLocater.cpp: Code cleanups
-2005-05-20 16:14 strk
+2005-05-20 16:14 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/OffsetCurveSetBuilder.cpp: Fixed a bug in
- addPolygonRing setting wrong depths on Edges
+ * [r712] source/operation/buffer/OffsetCurveSetBuilder.cpp: Fixed a
+ bug in addPolygonRing setting wrong depths on Edges
-2005-05-19 10:29 strk
+2005-05-19 10:29 Sandro Santilli <strk at keybit.net>
- * source/algorithm/CentroidArea.cpp,
+ * [r711] source/algorithm/CentroidArea.cpp,
source/geomgraph/DirectedEdge.cpp, source/geomgraph/EdgeEnd.cpp,
source/headers/geos/geosAlgorithm.h,
@@ -14923,43 +15229,43 @@
Inlined some smaller functions encountered during bug hunting.
Updated Copyright notices in the touched files.
-2005-05-19 10:26 strk
+2005-05-19 10:26 Sandro Santilli <strk at keybit.net>
- * source/test/testLeaksBig.xml: Added bogus multipolygon buffering
- test
+ * [r710] source/test/testLeaksBig.xml: Added bogus multipolygon
+ buffering test
-2005-05-13 18:06 strk
+2005-05-13 18:06 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom.h: Added default tolerance parameter for
- equalsExact
+ * [r709] source/headers/geos/geom.h: Added default tolerance
+ parameter for equalsExact
-2005-05-13 17:15 strk
+2005-05-13 17:15 Sandro Santilli <strk at keybit.net>
- * source/geom/Point.cpp: cleanups and indentations
+ * [r708] source/geom/Point.cpp: cleanups and indentations
-2005-05-13 17:14 strk
+2005-05-13 17:14 Sandro Santilli <strk at keybit.net>
- * source/geom/Geometry.cpp: Added comment about 2D-only comparison
- of ::equal(Coordinate, Coordinate, double)
+ * [r707] source/geom/Geometry.cpp: Added comment about 2D-only
+ comparison of ::equal(Coordinate, Coordinate, double)
-2005-05-09 21:17 strk
+2005-05-09 21:17 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/WKBWriterT.h: Second argument to ::write made
- mandatory.
+ * [r706] source/headers/geos/WKBWriterT.h: Second argument to
+ ::write made mandatory.
-2005-05-09 10:35 strk
+2005-05-09 10:35 Sandro Santilli <strk at keybit.net>
- * source/algorithm/RobustLineIntersector.cpp,
+ * [r705] source/algorithm/RobustLineIntersector.cpp,
source/headers/geos/geosAlgorithm.h: Ported JTS robustness
patches made by Martin on suggestions by Kevin.
-2005-05-03 15:30 strk
+2005-05-03 15:30 Sandro Santilli <strk at keybit.net>
- * TODO: Added WKB TODOs
+ * [r704] TODO: Added WKB TODOs
-2005-04-29 17:40 strk
+2005-04-29 17:40 Sandro Santilli <strk at keybit.net>
- * source/geom/Geometry.cpp, source/headers/geos.h,
+ * [r703] source/geom/Geometry.cpp, source/headers/geos.h,
source/headers/geos/WKBWriterT.h, source/headers/geos/geom.h,
@@ -14967,19 +15273,20 @@
source/operation/overlay/OverlayOp.cpp: Updated Doxygen
documentation and some Copyright headers.
-2005-04-29 16:36 strk
+2005-04-29 16:36 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/io.h: Fixed biostringstream stream output.
+ * [r702] source/headers/geos/io.h: Fixed biostringstream stream
+ output.
- * doc/example.cpp: Made WKBReader use global_factory, for having
- WKB reads produce
+ * [r701] doc/example.cpp: Made WKBReader use global_factory, for
+ having WKB reads produce
same context of input geoms.
-2005-04-29 15:34 strk
+2005-04-29 15:34 Sandro Santilli <strk at keybit.net>
- * doc/example.cpp, source/headers/geos/WKBReaderT.h,
+ * [r700] doc/example.cpp, source/headers/geos/WKBReaderT.h,
source/headers/geos/WKBWriterT.h, source/headers/geos/io.h,
source/io/ByteOrderValues.cpp: Typedef'ed biostringstream,
preferred parameter for
@@ -14989,9 +15296,9 @@
biostringstream.
Added WKBtest in doc/example.cpp
-2005-04-29 11:52 strk
+2005-04-29 11:52 Sandro Santilli <strk at keybit.net>
+ * [r699] source/geom/CoordinateSequence.cpp,
source/geom/DefaultCoordinateSequenceFactory.cpp,
source/geom/Makefile.am, source/geom/PointCoordinateSequence.cpp,
@@ -15006,34 +15313,34 @@
a template class.
-2005-04-29 11:50 strk
+2005-04-29 11:50 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/platform.h.in: Added machine byte order
- extractor
+ * [r698] source/headers/geos/platform.h.in: Added machine byte
+ order extractor
-2005-04-21 15:13 strk
+2005-04-21 15:13 Sandro Santilli <strk at keybit.net>
- * configure.in: library version bumped to 3.0.0
+ * [r697] configure.in: library version bumped to 3.0.0
-2005-04-21 13:43 strk
+2005-04-21 13:43 Sandro Santilli <strk at keybit.net>
- * ChangeLog, NEWS: Updated chage logs
+ * [r696] ChangeLog, NEWS: Updated chage logs
-2005-04-21 11:16 strk
+2005-04-21 11:16 Sandro Santilli <strk at keybit.net>
- * source/operation/overlay/OverlayOp.cpp: Removed useless
+ * [r695] source/operation/overlay/OverlayOp.cpp: Removed useless
Coordinate copies in mergeZ() - patch by Safe Software
-2005-04-20 17:56 strk
+2005-04-20 17:56 Sandro Santilli <strk at keybit.net>
- * source/algorithm/NonRobustCGAlgorithms.cpp,
+ * [r694] source/algorithm/NonRobustCGAlgorithms.cpp,
source/algorithm/RobustCGAlgorithms.cpp, source/geom/Makefile.am:
Removed NonRobustCGAlgorithms and RobustCGAlgorithms, already
unused (CGAlgorithms replaces both with robust implementation).
-2005-04-20 17:22 strk
+2005-04-20 17:22 Sandro Santilli <strk at keybit.net>
- * source/geom/Makefile.am,
+ * [r693] source/geom/Makefile.am,
source/headers/geos/WKBReaderT.h, source/headers/geos/geom.h,
@@ -15045,29 +15352,29 @@
CoordinateSequence
taking higher dimensions into account.
-2005-04-20 17:18 strk
+2005-04-20 17:18 Sandro Santilli <strk at keybit.net>
- * source/headers/geos.h: Added standard copyright header
+ * [r692] source/headers/geos.h: Added standard copyright header
-2005-04-19 11:49 strk
+2005-04-19 11:49 Sandro Santilli <strk at keybit.net>
- * source/geom/Point.cpp: Fixed segfault in ::isEmpty
+ * [r691] source/geom/Point.cpp: Fixed segfault in ::isEmpty
-2005-04-14 11:49 strk
+2005-04-14 11:49 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/io.h, source/io/StringTokenizer.cpp,
+ * [r690] source/headers/geos/io.h, source/io/StringTokenizer.cpp,
source/io/WKTReader.cpp: Applied slightly modified patch by Cheng
Shan to speedup WKT parsing.
-2005-04-07 18:43 strk
+2005-04-07 18:43 Sandro Santilli <strk at keybit.net>
- * source/operation/valid/IsValidOp.cpp: Fixed bug throwing an
- exception when a result could be returned instead
+ * [r689] source/operation/valid/IsValidOp.cpp: Fixed bug throwing
+ an exception when a result could be returned instead
(ported JTS patch)
-2005-04-06 11:09 strk
+2005-04-06 11:09 Sandro Santilli <strk at keybit.net>
- * ChangeLog, ltmain.sh, source/algorithm/CGAlgorithms.cpp,
+ * [r688] ChangeLog, ltmain.sh, source/algorithm/CGAlgorithms.cpp,
source/algorithm/NonRobustLineIntersector.cpp,
source/algorithm/RobustDeterminant.cpp,
@@ -15079,88 +15386,90 @@
source/planargraph/planarDirectedEdge.cpp: Applied patch from Jon
Schlueter (math.h => cmath; ieeefp.h in "C" block)
-2005-04-02 17:07 sgillies
+2005-04-02 17:07 Sean Gillies <sgillies at frii.com>
- * swig/python/setup.py: now supporting the win32 platform, thanks
- to Howard Butler
+ * [r687] swig/python/setup.py: now supporting the win32 platform,
+ thanks to Howard Butler
-2005-03-26 08:19 strk
+2005-03-26 08:19 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/opPolygonize.h: Commented out
+ * [r686] source/headers/geos/opPolygonize.h: Commented out
Polygonizer::LineStringAdder friendship
-2005-03-10 17:27 strk
+2005-03-10 17:27 Sandro Santilli <strk at keybit.net>
- * source/io/WKBReader.cpp: ported from current JTS
+ * [r685] source/io/WKBReader.cpp: ported from current JTS
-2005-03-04 07:48 strk
+2005-03-04 07:48 Sandro Santilli <strk at keybit.net>
- * source/algorithm/CGAlgorithms.cpp: Removed useless copy from
- ::isOnLine() - suggested by Dale Lutz
+ * [r684] source/algorithm/CGAlgorithms.cpp: Removed useless copy
+ from ::isOnLine() - suggested by Dale Lutz
-2005-03-02 08:14 strk
+2005-03-02 08:14 Sandro Santilli <strk at keybit.net>
- * source/headers/Makefile.am: Removed commented line, cousing
- strange behaviours with autotools.
+ * [r683] source/headers/Makefile.am: Removed commented line,
+ cousing strange behaviours with autotools.
-2005-02-22 18:21 strk
+2005-02-22 18:21 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/noding.h, source/index/strtree/STRtree.cpp,
- source/noding/SegmentNode.cpp, source/noding/SegmentNodeList.cpp,
+ * [r682] source/headers/geos/noding.h,
+ source/index/strtree/STRtree.cpp, source/noding/SegmentNode.cpp,
+ source/noding/SegmentNodeList.cpp,
source/noding/SegmentString.cpp: Changed SegmentNode to contain a
*real* Coordinate (not a pointer) to reduce
construction costs.
-2005-02-22 17:10 strk
+2005-02-22 17:10 Sandro Santilli <strk at keybit.net>
- * source/geom/CoordinateSequence.cpp, source/geom/LineString.cpp,
- source/noding/MCQuadtreeNoder.cpp,
+ * [r681] source/geom/CoordinateSequence.cpp,
+ source/geom/LineString.cpp, source/noding/MCQuadtreeNoder.cpp,
source/operation/buffer/RightmostEdgeFinder.cpp: Reduced
CoordinateSequence::getSize() calls.
-2005-02-22 16:24 strk
+2005-02-22 16:24 Sandro Santilli <strk at keybit.net>
- cached number of points in Edge
+ * [r680] source/geomgraph/Edge.cpp,
+ source/headers/geos/geomgraph.h: cached number of points in Edge
-2005-02-22 16:23 strk
+2005-02-22 16:23 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/noding.h, source/noding/SegmentString.cpp:
- Cached number of points in CoordinateSequence.
+ * [r679] source/headers/geos/noding.h,
+ source/noding/SegmentString.cpp: Cached number of points in
+ CoordinateSequence.
-2005-02-22 15:49 strk
+2005-02-22 15:49 Sandro Santilli <strk at keybit.net>
- * source/noding/SegmentString.cpp: Reduced calls to
+ * [r678] source/noding/SegmentString.cpp: Reduced calls to
DefaultCoordinateSequence->getSize().
-2005-02-22 15:16 strk
+2005-02-22 15:16 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/indexStrtree.h,
+ * [r677] source/headers/geos/indexStrtree.h,
source/index/strtree/STRtree.cpp: STRtree::avg() and
STRtree::centreY() inlined.
-2005-02-22 10:55 strk
+2005-02-22 10:55 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/Edge.cpp: Optimized Edge::equals(Edge *e)
+ * [r676] source/geomgraph/Edge.cpp: Optimized Edge::equals(Edge *e)
-2005-02-18 08:20 strk
+2005-02-18 08:20 Sandro Santilli <strk at keybit.net>
- * source/test/XMLTester.cpp: Added support for point-per-quadrant
- argument in buffer tests (using arg2).
+ * [r675] source/test/XMLTester.cpp: Added support for
+ point-per-quadrant argument in buffer tests (using arg2).
-2005-02-17 09:56 strk
+2005-02-17 09:56 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/OffsetCurveBuilder.cpp: Commented out
- unused variable.
+ * [r674] source/operation/buffer/OffsetCurveBuilder.cpp: Commented
+ out unused variable.
- * source/headers/geos/geom.h: Applied patch from Jon Schlueter
- using <cmath> instead of <math.h>
+ * [r673] source/headers/geos/geom.h: Applied patch from Jon
+ Schlueter using <cmath> instead of <math.h>
-2005-02-15 17:15 strk
+2005-02-15 17:15 Sandro Santilli <strk at keybit.net>
+ * [r672] source/algorithm/RobustLineIntersector.cpp,
source/geom/Envelope.cpp, source/geom/LineSegment.cpp,
source/headers/geos/geom.h, source/headers/geos/indexChain.h,
@@ -15174,16 +15483,16 @@
reserved() memory for some vectors when
the usage was known a priori.
-2005-02-11 08:58 strk
+2005-02-11 08:58 Sandro Santilli <strk at keybit.net>
- * source/geom/Makefile.am, source/headers/Makefile.am,
+ * [r671] source/geom/Makefile.am, source/headers/Makefile.am,
source/headers/geos/Makefile.am: Applied patch from Curtis
Barrett handling --includedir and --libdir
params for configure.
-2005-02-05 05:44 strk
+2005-02-05 05:44 Sandro Santilli <strk at keybit.net>
+ * [r670] source/algorithm/CGAlgorithms.cpp,
@@ -15208,71 +15517,72 @@
to use Coordinate pointers as keys, reduces
lots of other Coordinate copies.
-2005-02-04 23:55 strk
+2005-02-04 23:55 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom.h: Envelope destructor made non-virtual
- to give compiler more static
+ * [r669] source/headers/geos/geom.h: Envelope destructor made
+ non-virtual to give compiler more static
binding options.
-2005-02-04 18:49 strk
+2005-02-04 18:49 Sandro Santilli <strk at keybit.net>
+ * [r668] source/headers/geos/opBuffer.h,
source/operation/buffer/BufferSubgraph.cpp: Changed
::computeDepths to use a set instead of a vector for checking
visited Edges.
-2005-02-04 14:49 strk
+2005-02-04 14:49 Sandro Santilli <strk at keybit.net>
- * source/test/Makefile.am: Added rule to build staticXMLTester (for
- profiling with gprof)
+ * [r667] source/test/Makefile.am: Added rule to build
+ staticXMLTester (for profiling with gprof)
-2005-02-03 09:17 strk
+2005-02-03 09:17 Sandro Santilli <strk at keybit.net>
- * source/geom/CoordinateSequence.cpp: more profiling label
+ * [r666] source/geom/CoordinateSequence.cpp: more profiling label
-2005-02-01 16:09 strk
+2005-02-01 16:09 Sandro Santilli <strk at keybit.net>
- * source/noding/MCQuadtreeNoder.cpp, source/noding/Noder.cpp: more
- profiling labels
+ * [r665] source/noding/MCQuadtreeNoder.cpp,
+ source/noding/Noder.cpp: more profiling labels
-2005-02-01 16:06 strk
+2005-02-01 16:06 Sandro Santilli <strk at keybit.net>
- * source/geom/Envelope.cpp,
+ * [r664] source/geom/Envelope.cpp,
source/index/chain/indexMonotoneChain.cpp: Small optimizations.
-2005-02-01 14:18 strk
+2005-02-01 14:18 Sandro Santilli <strk at keybit.net>
- * source/noding/SegmentNodeList.cpp,
+ * [r663] source/noding/SegmentNodeList.cpp,
source/noding/SegmentString.cpp: More profiler labels
- * source/headers/geos/profiler.h, source/util/Profiler.cpp: Made
- profiler start/stop inline
+ * [r662] source/headers/geos/profiler.h, source/util/Profiler.cpp:
+ Made profiler start/stop inline
-2005-02-01 13:44 strk
+2005-02-01 13:44 Sandro Santilli <strk at keybit.net>
- * source/geom/LineSegment.cpp, source/geomgraph/EdgeList.cpp,
+ * [r661] source/geom/LineSegment.cpp,
+ source/geomgraph/EdgeList.cpp,
source/index/chain/MonotoneChainOverlapAction.cpp,
source/noding/IteratedNoder.cpp,
source/util/Profiler.cpp: More profiling labels.
-2005-01-31 15:41 strk
+2005-01-31 15:41 Sandro Santilli <strk at keybit.net>
- * source/index/strtree/AbstractSTRtree.cpp,
+ * [r660] source/index/strtree/AbstractSTRtree.cpp,
source/noding/MCQuadtreeNoder.cpp: Small optimizations.
-2005-01-28 10:01 strk
+2005-01-28 10:01 Sandro Santilli <strk at keybit.net>
- * source/io/ParseException.cpp: substituted sprintf calls with use
- of ostringstream
+ * [r659] source/io/ParseException.cpp: substituted sprintf calls
+ with use of ostringstream
-2005-01-28 09:47 strk
+2005-01-28 09:47 Sandro Santilli <strk at keybit.net>
- * source/examples/CustomPointCoordinateSequence.cpp,
+ * [r658] source/examples/CustomPointCoordinateSequence.cpp,
source/geom/Dimension.cpp, source/geom/Envelope.cpp,
source/geom/IntersectionMatrix.cpp, source/geom/LineSegment.cpp,
source/geom/Location.cpp,
@@ -15287,98 +15597,102 @@
source/planargraph/planarDirectedEdge.cpp: Replaced sprintf uses
with ostringstream.
-2005-01-28 08:47 strk
+2005-01-28 08:47 Sandro Santilli <strk at keybit.net>
- * source/geom/Coordinate.cpp: Removed sprintf usage, replaced with
- sstream
+ * [r657] source/geom/Coordinate.cpp: Removed sprintf usage,
+ replaced with sstream
-2005-01-28 07:58 strk
+2005-01-28 07:58 Sandro Santilli <strk at keybit.net>
- * source/geom/DefaultCoordinateSequence.cpp: removed sprintf usage,
- ad ::toString call Coordinate::toString
+ * [r656] source/geom/DefaultCoordinateSequence.cpp: removed sprintf
+ usage, ad ::toString call Coordinate::toString
-2005-01-18 17:22 strk
+2005-01-18 17:22 Sandro Santilli <strk at keybit.net>
- * source/algorithm/LineIntersector.cpp: reverted previous change,
- sign was actually stored in zgap
+ * [r655] source/algorithm/LineIntersector.cpp: reverted previous
+ change, sign was actually stored in zgap
-2005-01-18 17:09 strk
+2005-01-18 17:09 Sandro Santilli <strk at keybit.net>
- * source/algorithm/RobustLineIntersector.cpp: Fixed interpolateZ
- call using final intersection point instead of HCoordinate.
+ * [r654] source/algorithm/RobustLineIntersector.cpp: Fixed
+ interpolateZ call using final intersection point instead of
+ HCoordinate.
-2005-01-14 08:04 strk
+2005-01-14 08:04 Sandro Santilli <strk at keybit.net>
- * source/algorithm/LineIntersector.cpp: Fixed Z interpolation to
- use the correct sign
+ * [r653] source/algorithm/LineIntersector.cpp: Fixed Z
+ interpolation to use the correct sign
-2005-01-03 16:06 strk
+2005-01-03 16:06 Sandro Santilli <strk at keybit.net>
- * source/test/XMLTester.cpp: Changed polygonize op to return a
- GeometryCollection
+ * [r652] source/test/XMLTester.cpp: Changed polygonize op to return
+ a GeometryCollection
-2005-01-03 15:56 strk
+2005-01-03 15:56 Sandro Santilli <strk at keybit.net>
- * source/test/XMLTester.cpp: Fixed memory leaks just introduced for
- Polygonizer test case.
+ * [r651] source/test/XMLTester.cpp: Fixed memory leaks just
+ introduced for Polygonizer test case.
-2005-01-03 15:49 strk
+2005-01-03 15:49 Sandro Santilli <strk at keybit.net>
- * source/test/XMLTester.cpp: Added Polygonize test handling
+ * [r650] source/test/XMLTester.cpp: Added Polygonize test handling
-2004-12-30 13:32 strk
+2004-12-30 13:32 Sandro Santilli <strk at keybit.net>
- * source/test/XMLTester.cpp: Handled NULL result from getCentroid()
+ * [r649] source/test/XMLTester.cpp: Handled NULL result from
+ getCentroid()
-2004-12-30 13:31 strk
+2004-12-30 13:31 Sandro Santilli <strk at keybit.net>
- * source/geom/Geometry.cpp: Fixed a segfault on
+ * [r648] source/geom/Geometry.cpp: Fixed a segfault on
EMPTYGEOM->getCeontroid()
-2004-12-30 10:14 strk
+2004-12-30 10:14 Sandro Santilli <strk at keybit.net>
- * source/geom/Polygon.cpp: never return LinearRing or
+ * [r647] source/geom/Polygon.cpp: never return LinearRing or
MultiLinearRing from getBoundary
- * source/geom/GeometryFactory.cpp: input checking and class
+ * [r646] source/geom/GeometryFactory.cpp: input checking and class
promoting in createMultiLineString()
-2004-12-22 09:42 strk
+2004-12-22 09:42 Sandro Santilli <strk at keybit.net>
- * source/geom/util/GeometryEditor.cpp: Fixed a premature Geometry
- destruction, Avoided CoordinateSequence copies
+ * [r645] source/geom/util/GeometryEditor.cpp: Fixed a premature
+ Geometry destruction, Avoided CoordinateSequence copies
when possible.
-2004-12-16 18:29 pramsey
+2004-12-16 18:29 Paul Ramsey <pramsey at cleverelephant.ca>
- * configure.in: Bumped minor version number for 2.1.1 release.
+ * [r644] configure.in: Bumped minor version number for 2.1.1
+ release.
-2004-12-16 16:27 strk
+2004-12-16 16:27 Sandro Santilli <strk at keybit.net>
- * source/geom/LinearRing.cpp, source/headers/geos/geom.h: Fixed
- LinearRing::clone() to return LinearRing instead of LineString
+ * [r643] source/geom/LinearRing.cpp, source/headers/geos/geom.h:
+ Fixed LinearRing::clone() to return LinearRing instead of
+ LineString
-2004-12-16 16:08 strk
+2004-12-16 16:08 Sandro Santilli <strk at keybit.net>
- * swig/geos.i, swig/python/example.py: New patches from Niki
+ * [r642] swig/geos.i, swig/python/example.py: New patches from Niki
Spahiev <niki.spahiev at gmail.com>
(still unstable)
-2004-12-16 09:05 strk
+2004-12-16 09:05 Sandro Santilli <strk at keybit.net>
- * swig/python/example.py: Added python example by Niki Spahiev
- <niki.spahiev at gmail.com>
+ * [r641] swig/python/example.py: Added python example by Niki
+ Spahiev <niki.spahiev at gmail.com>
-2004-12-16 08:56 strk
+2004-12-16 08:56 Sandro Santilli <strk at keybit.net>
- * swig/geos.i: Applyed patches by Niki Spahiev
+ * [r640] swig/geos.i: Applyed patches by Niki Spahiev
-2004-12-14 10:35 strk
+2004-12-14 10:35 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/opPolygonize.h,
+ * [r638] source/headers/geos/opPolygonize.h,
source/headers/geos/planargraph.h,
source/operation/polygonize/PolygonizeGraph.cpp,
source/planargraph/planarDirectedEdge.cpp,
@@ -15386,47 +15700,49 @@
PolygonizeGraph keeps track of generated CoordinateSequence
for delayed destruction.
-2004-12-13 13:54 strk
+2004-12-13 13:54 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/opPolygonize.h: Added a not about gcc 2.95.4
- required friendship
+ * [r637] source/headers/geos/opPolygonize.h: Added a not about gcc
+ 2.95.4 required friendship
-2004-12-13 13:53 strk
+2004-12-13 13:53 Sandro Santilli <strk at keybit.net>
- * source/geom/TopologyException.cpp: Fixed uninitialized
+ * [r636] source/geom/TopologyException.cpp: Fixed uninitialized
Coordinate.
-2004-12-12 17:22 strk
+2004-12-12 17:22 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/Makefile.am: version.h and platform.h
+ * [r635] source/headers/geos/Makefile.am: version.h and platform.h
installed again (missed when removed from dist)
-2004-12-08 14:33 strk
+2004-12-08 14:33 Sandro Santilli <strk at keybit.net>
- * source/geom/MultiPolygon.cpp: Checked inner polys getBoundary
- return for the single LineString case.
+ * [r634] source/geom/MultiPolygon.cpp: Checked inner polys
+ getBoundary return for the single LineString case.
-2004-12-08 14:32 strk
+2004-12-08 14:32 Sandro Santilli <strk at keybit.net>
- * source/geom/GeometryCollection.cpp: cleanups
+ * [r633] source/geom/GeometryCollection.cpp: cleanups
-2004-12-08 14:31 strk
+2004-12-08 14:31 Sandro Santilli <strk at keybit.net>
- * source/test/testLeaksBig.xml: adjusted getBoundary expected
- returns to match OGC specs
+ * [r632] source/test/testLeaksBig.xml: adjusted getBoundary
+ expected returns to match OGC specs
- * source/operation/overlay/OverlayOp.cpp: elevationMatrix deleted
- by destructor
+ * [r631] source/operation/overlay/OverlayOp.cpp: elevationMatrix
+ deleted by destructor
-2004-12-08 14:30 strk
+2004-12-08 14:30 Sandro Santilli <strk at keybit.net>
- * source/io/Unload.cpp: Added default profiler instance cleanup
+ * [r630] source/io/Unload.cpp: Added default profiler instance
+ cleanup
-2004-12-08 13:54 strk
+2004-12-08 13:54 Sandro Santilli <strk at keybit.net>
- * doc/example.cpp, source/algorithm/RobustLineIntersector.cpp,
+ * [r629] doc/example.cpp,
+ source/algorithm/RobustLineIntersector.cpp,
source/bigtest/GeometryTestFactory.cpp, source/geom/Polygon.cpp,
source/geom/util/GeometryEditor.cpp,
@@ -15464,48 +15780,49 @@
source/util/GeometricShapeFactory.cpp: gcc warnings checked and
fixed, general cleanups.
-2004-12-06 10:54 strk
+2004-12-06 10:54 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/Makefile.am: Added timeval.h in distribution.
+ * [r628] source/headers/geos/Makefile.am: Added timeval.h in
+ distribution.
-2004-12-05 10:54 strk
+2004-12-05 10:54 Sandro Santilli <strk at keybit.net>
- * VisualStudio, VisualStudio/.cvsignore: initial revision
+ * [r627] VisualStudio, VisualStudio/.cvsignore: initial revision
-2004-12-05 10:50 strk
+2004-12-05 10:50 Sandro Santilli <strk at keybit.net>
- * VisualStudio/Makefile.am: forgot to add
+ * [r626] VisualStudio/Makefile.am: forgot to add
-2004-12-05 10:48 strk
+2004-12-05 10:48 Sandro Santilli <strk at keybit.net>
- * debian/control, debian/libgeos-doc.doc-base, debian/rules:
+ * [r625] debian/control, debian/libgeos-doc.doc-base, debian/rules:
Modifications by Alex Bodnaru
-2004-12-05 10:44 strk
+2004-12-05 10:44 Sandro Santilli <strk at keybit.net>
- * configure.in, doc/Makefile.am, source/bigtest/Makefile.am,
+ * [r624] configure.in, doc/Makefile.am, source/bigtest/Makefile.am,
source/examples/Makefile.am, source/test/Makefile.am: Applied
Norman Vine patches for cleaner win32 build.
-2004-12-04 15:56 strk
+2004-12-04 15:56 Sandro Santilli <strk at keybit.net>
- * source/Makefile.am, source/headers/geos/Makefile.am: Added
+ * [r623] source/Makefile.am, source/headers/geos/Makefile.am: Added
source/Makefile.vc and source/headers/geos/platform.h.in in
distribution
-2004-12-04 15:31 strk
+2004-12-04 15:31 Sandro Santilli <strk at keybit.net>
- * Makefile.am, configure.in, source/headers/geos/Makefile.am: Added
- VisualStudio dir in distribution, removed platform.h and
- version.h from it.
+ * [r622] Makefile.am, configure.in,
+ source/headers/geos/Makefile.am: Added VisualStudio dir in
+ distribution, removed platform.h and version.h from it.
2004-12-04 01:20 frank
- * source/Makefile.vc: removed dll delete
+ * [r621] source/Makefile.vc: removed dll delete
-2004-12-03 22:52 strk
+2004-12-03 22:52 Sandro Santilli <strk at keybit.net>
+ * [r620] source/geom/CoordinateSequence.cpp,
source/geom/DefaultCoordinateSequence.cpp,
@@ -15515,44 +15832,45 @@
2004-12-03 16:26 frank
- * source/headers/geos/platform.h.vc: added headers
+ * [r619] source/headers/geos/platform.h.vc: added headers
2004-12-03 16:25 frank
- * source/Makefile.vc: New
+ * [r618] source/Makefile.vc: New
2004-12-03 16:22 frank
- * source/headers/geos/geom.h: update to use I64 on MSVC for 64 bit
- integer constants, also toVector chg.
+ * [r617] source/headers/geos/geom.h: update to use I64 on MSVC for
+ 64 bit integer constants, also toVector chg.
2004-12-03 16:21 frank
- * source/headers/geos/profiler.h: dont try for sys/time.h with MSVC
+ * [r616] source/headers/geos/profiler.h: dont try for sys/time.h
+ with MSVC
2004-12-03 16:19 frank
- * source/headers/geos/platform.h.vc: New
+ * [r615] source/headers/geos/platform.h.vc: New
-2004-11-30 16:44 strk
+2004-11-30 16:44 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/profiler.h, source/headers/geos/timeval.h:
- Added gettimeofday implementation for win32, curtesy of Wu
- Yongwei.
+ * [r614] source/headers/geos/profiler.h,
+ source/headers/geos/timeval.h: Added gettimeofday implementation
+ for win32, curtesy of Wu Yongwei.
-2004-11-30 13:05 strk
+2004-11-30 13:05 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/platform.h.in: Removed inclusion of stdio.h,
- which should now be useless.
+ * [r613] source/headers/geos/platform.h.in: Removed inclusion of
+ stdio.h, which should now be useless.
-2004-11-30 13:04 strk
+2004-11-30 13:04 Sandro Santilli <strk at keybit.net>
- * configure.in, source/headers/geos/platform.h.in: Added optional
- inclusion of ieeefp.h on platform providing it.
+ * [r612] configure.in, source/headers/geos/platform.h.in: Added
+ optional inclusion of ieeefp.h on platform providing it.
-2004-11-29 16:05 strk
+2004-11-29 16:05 Sandro Santilli <strk at keybit.net>
- * source/algorithm/HCoordinate.cpp,
+ * [r611] source/algorithm/HCoordinate.cpp,
source/geom/Coordinate.cpp, source/geomgraph/Node.cpp,
@@ -15568,23 +15886,23 @@
Added ISNAN macro and changed ISNAN/FINITE macros to avoid
dispendious isnan() and finite() calls.
-2004-11-27 11:36 strk
+2004-11-27 11:36 Sandro Santilli <strk at keybit.net>
- * debian/Makefile, debian/README.Debian, debian/changelog,
+ * [r610] debian/Makefile, debian/README.Debian, debian/changelog,
debian/control, debian/libgeos-dev.install,
debian/libgeos-dev.manpages, debian/rules, debian/shlibs.local:
Updated scripts by Alex Bodnaru, added Makefile
-2004-11-26 09:53 strk
+2004-11-26 09:53 Sandro Santilli <strk at keybit.net>
+ * [r609] source/algorithm/LineIntersector.cpp,
source/geomgraph/Node.cpp, source/headers/geos/platform.h.in:
Added more FINITE calls, and added inf and -inf to FINITE checks
-2004-11-26 09:22 strk
+2004-11-26 09:22 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/platform.h.in,
+ * [r608] source/headers/geos/platform.h.in,
source/operation/overlay/ElevationMatrix.cpp,
source/operation/overlay/ElevationMatrixCell.cpp,
source/operation/overlay/ElevationMatrixFilter.cpp,
@@ -15592,28 +15910,29 @@
its use.
Made input geoms average Z computation optional in OverlayOp.
-2004-11-24 18:10 strk
+2004-11-24 18:10 Sandro Santilli <strk at keybit.net>
- * source/operation/overlay/OverlayOp.cpp: Stricter handling of
- USE_ELEVATION_MATRIX define
+ * [r607] source/operation/overlay/OverlayOp.cpp: Stricter handling
+ of USE_ELEVATION_MATRIX define
- * source/algorithm/LineIntersector.cpp: Cleanup of interpolateZ
+ * [r606] source/algorithm/LineIntersector.cpp: Cleanup of
+ interpolateZ
-2004-11-24 12:29 strk
+2004-11-24 12:29 Sandro Santilli <strk at keybit.net>
- * source/operation/overlay/ElevationMatrix.cpp: Handled boundary
- cases in ::getCell
+ * [r605] source/operation/overlay/ElevationMatrix.cpp: Handled
+ boundary cases in ::getCell
-2004-11-24 11:32 strk
+2004-11-24 11:32 Sandro Santilli <strk at keybit.net>
- * source/operation/overlay/LineBuilder.cpp: Re-enabled Z
+ * [r604] source/operation/overlay/LineBuilder.cpp: Re-enabled Z
propagation in output lines.
-2004-11-23 19:53 strk
+2004-11-23 19:53 Sandro Santilli <strk at keybit.net>
- * source/algorithm/LineIntersector.cpp,
+ * [r603] source/algorithm/LineIntersector.cpp,
source/geomgraph/Edge.cpp, source/geomgraph/EdgeEndStar.cpp,
@@ -15624,9 +15943,9 @@
source/operation/overlay/OverlayOp.cpp: Had LineIntersector
compute Z by interpolation.
-2004-11-23 16:22 strk
+2004-11-23 16:22 Sandro Santilli <strk at keybit.net>
- * source/geom/DefaultCoordinateSequence.cpp,
+ * [r602] source/geom/DefaultCoordinateSequence.cpp,
source/geom/LineString.cpp, source/geom/Makefile.am,
source/geom/Point.cpp, source/headers/geos/geom.h,
@@ -15637,91 +15956,96 @@
class and components to do post-processing draping of overlayed
geometries.
-2004-11-22 15:51 strk
+2004-11-22 15:51 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/opOverlay.h,
+ * [r601] source/headers/geos/opOverlay.h,
source/operation/overlay/OverlayOp.cpp: Added interpolation of
containing geometry's average Z for point_in_poly case.
-2004-11-22 13:02 strk
+2004-11-22 13:02 Sandro Santilli <strk at keybit.net>
- * source/algorithm/RobustLineIntersector.cpp: Fixed a bug in
+ * [r600] source/algorithm/RobustLineIntersector.cpp: Fixed a bug in
Collinear intersection Z computation
- * source/geomgraph/EdgeIntersectionList.cpp: Forced use if computed
- intersection point in ::createSplitEdge (for Z computation)
+ * [r599] source/geomgraph/EdgeIntersectionList.cpp: Forced use if
+ computed intersection point in ::createSplitEdge (for Z
+ computation)
-2004-11-22 12:59 strk
+2004-11-22 12:59 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/Edge.cpp: Added debugging lines
+ * [r598] source/geomgraph/Edge.cpp: Added debugging lines
-2004-11-22 11:34 strk
+2004-11-22 11:34 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/EdgeEndStar.cpp, source/geomgraph/EdgeList.cpp,
+ * [r597] source/geomgraph/EdgeEndStar.cpp,
source/geomgraph/GeometryGraph.cpp,
source/operation/overlay/OverlayOp.cpp: More debugging lines and
comments/indentation cleanups
- * source/algorithm/RobustLineIntersector.cpp: Added Z computation
- for CollinearIntersections
+ * [r596] source/algorithm/RobustLineIntersector.cpp: Added Z
+ computation for CollinearIntersections
-2004-11-20 18:54 strk
+2004-11-20 18:54 Sandro Santilli <strk at keybit.net>
- * debian/README.Debian, debian/control, debian/libgeos-dev.install,
- debian/rules: Scripts updates from Alex Bodnaru
+ * [r595] debian/README.Debian, debian/control,
+ debian/libgeos-dev.install, debian/rules: Scripts updates from
+ Alex Bodnaru
-2004-11-20 18:17 strk
+2004-11-20 18:17 Sandro Santilli <strk at keybit.net>
+ * [r594] source/headers/geos/opOverlay.h,
source/operation/overlay/LineBuilder.cpp: Added Z propagation for
overlay lines output.
-2004-11-20 17:16 strk
+2004-11-20 17:16 Sandro Santilli <strk at keybit.net>
+ * [r593] source/headers/geos/opOverlay.h,
source/operation/overlay/OverlayOp.cpp: Handled Z merging for
point on polygon boundary case.
-2004-11-20 16:25 strk
+2004-11-20 16:25 Sandro Santilli <strk at keybit.net>
- * source/operation/overlay/OverlayOp.cpp: Added Z computation for
- point on line case.
+ * [r592] source/operation/overlay/OverlayOp.cpp: Added Z
+ computation for point on line case.
-2004-11-20 15:46 strk
+2004-11-20 15:46 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geomgraph.h: Added composing Z management
- functions and elements for class Node
+ * [r591] source/headers/geos/geomgraph.h: Added composing Z
+ management functions and elements for class Node
-2004-11-20 15:45 strk
+2004-11-20 15:45 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/NodeMap.cpp: Fixed Z merging in addNode(Node *)
+ * [r590] source/geomgraph/NodeMap.cpp: Fixed Z merging in
+ addNode(Node *)
-2004-11-20 15:41 strk
+2004-11-20 15:41 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/NodeMap.cpp: Added Z merging in ::addNode
+ * [r589] source/geomgraph/NodeMap.cpp: Added Z merging in ::addNode
- * source/geomgraph/Node.cpp: Added management of vector of
+ * [r588] source/geomgraph/Node.cpp: Added management of vector of
composing Z values.
-2004-11-20 15:40 strk
+2004-11-20 15:40 Sandro Santilli <strk at keybit.net>
- in point-segment intersection.
+ * [r587] source/algorithm/RobustLineIntersector.cpp: Added Z
+ computation in point-segment intersection.
-2004-11-20 15:39 strk
+2004-11-20 15:39 Sandro Santilli <strk at keybit.net>
- * source/algorithm/CGAlgorithms.cpp: Reduced HEAP allocations.
+ * [r586] source/algorithm/CGAlgorithms.cpp: Reduced HEAP
+ allocations.
-2004-11-19 16:35 strk
+2004-11-19 16:35 Sandro Santilli <strk at keybit.net>
- * debian, debian/changelog, debian/compat, debian/control,
+ * [r585] debian, debian/changelog, debian/compat, debian/control,
debian/copyright, debian/geos-config.1, debian/libgeos-dev.dirs,
debian/libgeos-dev.docs, debian/libgeos-dev.install,
debian/libgeos-doc.doc-base, debian/libgeos-doc.docs,
@@ -15729,42 +16053,42 @@
debian/makedoc, debian/rules, debian/shlibs.local, debian/watch:
Added debian package builder scripts.
-2004-11-19 16:15 strk
+2004-11-19 16:15 Sandro Santilli <strk at keybit.net>
- * source/index/quadtree/QuadTreeNode.cpp: Completely removed
+ * [r584] source/index/quadtree/QuadTreeNode.cpp: Completely removed
sprintf usage, substituted by stringstream.
-2004-11-19 16:09 strk
+2004-11-19 16:09 Sandro Santilli <strk at keybit.net>
- * source/index/quadtree/QuadTreeNode.cpp: Added <stdio.h> include
- for sprintf recognition.
+ * [r583] source/index/quadtree/QuadTreeNode.cpp: Added <stdio.h>
+ include for sprintf recognition.
-2004-11-19 10:10 strk
+2004-11-19 10:10 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/Node.cpp: COMPUTE_Z re-enabled by default
+ * [r582] source/geomgraph/Node.cpp: COMPUTE_Z re-enabled by default
-2004-11-19 09:33 strk
+2004-11-19 09:33 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/GeometryGraph.cpp: removed useless
+ * [r581] source/geomgraph/GeometryGraph.cpp: removed useless
CoordinateSequence copy in ::addLineString
-2004-11-17 15:09 strk
+2004-11-17 15:09 Sandro Santilli <strk at keybit.net>
+ * [r580] source/algorithm/RobustLineIntersector.cpp,
source/operation/overlay/OverlayOp.cpp,
source/operation/overlay/PointBuilder.cpp: Changed COMPUTE_Z
defaults to be more conservative
-2004-11-17 08:41 strk
+2004-11-17 08:41 Sandro Santilli <strk at keybit.net>
+ * [r579] source/algorithm/RobustLineIntersector.cpp,
source/geomgraph/index/SegmentIntersector.cpp: Fixed a bug in Z
computation and removed debugging output by default.
-2004-11-17 08:13 strk
+2004-11-17 08:13 Sandro Santilli <strk at keybit.net>
- * source/algorithm/PointLocator.cpp,
+ * [r578] source/algorithm/PointLocator.cpp,
source/geom/Geometry.cpp, source/geomgraph/EdgeEndStar.cpp,
source/geomgraph/EdgeIntersectionList.cpp,
@@ -15779,68 +16103,69 @@
source/operation/overlay/PointBuilder.cpp: Indentation changes.
Some Z_COMPUTATION activated by default.
-2004-11-12 18:12 strk
+2004-11-12 18:12 Sandro Santilli <strk at keybit.net>
- * source/geom/Polygon.cpp: Changed ::getBoundary() to return
+ * [r576] source/geom/Polygon.cpp: Changed ::getBoundary() to return
LineString if polygon has no holes.
(has required to pass OGC conformance test T20)
-2004-11-09 20:22 strk
+2004-11-09 20:22 Sandro Santilli <strk at keybit.net>
- * tools/geos-config.in: Removed -g -O2 from geos-config --cflags
- output
+ * [r575] tools/geos-config.in: Removed -g -O2 from geos-config
+ --cflags output
-2004-11-08 18:33 strk
+2004-11-08 18:33 Sandro Santilli <strk at keybit.net>
- * source/index/strtree/STRtree.cpp: Just another small improvement.
+ * [r574] source/index/strtree/STRtree.cpp: Just another small
+ improvement.
-2004-11-08 15:58 strk
+2004-11-08 15:58 Sandro Santilli <strk at keybit.net>
+ * [r573] source/headers/geos/indexStrtree.h,
source/operation/buffer/BufferOp.cpp: More performance tuning.
-2004-11-08 13:12 strk
+2004-11-08 13:12 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/Makefile.am: Added profiler.h
+ * [r572] source/headers/geos/Makefile.am: Added profiler.h
-2004-11-08 12:15 strk
+2004-11-08 12:15 Sandro Santilli <strk at keybit.net>
- * source/util/Profiler.cpp: Added number of gathered timings in
- output.
+ * [r571] source/util/Profiler.cpp: Added number of gathered timings
+ in output.
-2004-11-08 11:19 strk
+2004-11-08 11:19 Sandro Santilli <strk at keybit.net>
- * source/util/Profiler.cpp: Profiler::get() always return a Profile
- (new if not existant).
+ * [r570] source/util/Profiler.cpp: Profiler::get() always return a
+ Profile (new if not existant).
-2004-11-08 10:58 strk
+2004-11-08 10:58 Sandro Santilli <strk at keybit.net>
- * source/geom/Envelope.cpp: Optimized the ::intersect function to
- avoid nested function calls.
+ * [r569] source/geom/Envelope.cpp: Optimized the ::intersect
+ function to avoid nested function calls.
-2004-11-08 10:57 strk
+2004-11-08 10:57 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom.h: Moved Log lines at the bottom, and
- cut oldest
+ * [r568] source/headers/geos/geom.h: Moved Log lines at the bottom,
+ and cut oldest
-2004-11-06 08:16 strk
+2004-11-06 08:16 Sandro Santilli <strk at keybit.net>
- * source/algorithm/CGAlgorithms.cpp,
+ * [r567] source/algorithm/CGAlgorithms.cpp,
source/operation/valid/IsValidOp.cpp: Fixed CGAlgorithms::isCCW
from JTS port.
Code cleanup in IsValidOp.
-2004-11-05 12:18 strk
+2004-11-05 12:18 Sandro Santilli <strk at keybit.net>
- * TODO: updated
+ * [r566] TODO: updated
-2004-11-05 11:41 strk
+2004-11-05 11:41 Sandro Santilli <strk at keybit.net>
+ * [r565] source/algorithm/CGAlgorithms.cpp,
source/headers/geos/opValid.h,
source/operation/valid/IsValidOp.cpp,
@@ -15850,9 +16175,9 @@
as a sign of invalidity (just for Polygon geometries).
Removed leaks generated by this specific exception.
-2004-11-04 19:08 strk
+2004-11-04 19:08 Sandro Santilli <strk at keybit.net>
- * source/algorithm/MinimumDiameter.cpp,
+ * [r564] source/algorithm/MinimumDiameter.cpp,
@@ -15871,57 +16196,57 @@
source/test/XMLTester.cpp: Cleanups, initializers list,
profiling.
-2004-11-04 08:49 strk
+2004-11-04 08:49 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/indexQuadtree.h,
+ * [r563] source/headers/geos/indexQuadtree.h,
source/index/quadtree/DoubleBits.cpp: Unlinked new documentation.
-2004-11-03 08:22 strk
+2004-11-03 08:22 Sandro Santilli <strk at keybit.net>
- * source/index/quadtree/DoubleBits.cpp: Slightly modified log/log2
- based algo to better handle numbers in the
+ * [r562] source/index/quadtree/DoubleBits.cpp: Slightly modified
+ log/log2 based algo to better handle numbers in the
range 0-1.
-2004-11-02 16:38 strk
+2004-11-02 16:38 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/indexQuadtree.h: Fixed ieee-754 detection
- switch
+ * [r561] source/headers/geos/indexQuadtree.h: Fixed ieee-754
+ detection switch
-2004-11-02 16:31 strk
+2004-11-02 16:31 Sandro Santilli <strk at keybit.net>
- * TODO: updated
+ * [r560] TODO: updated
-2004-11-02 16:05 strk
+2004-11-02 16:05 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/indexQuadtree.h: Autodetect availability of
- IEEE-754 FP
+ * [r559] source/headers/geos/indexQuadtree.h: Autodetect
+ availability of IEEE-754 FP
-2004-11-02 15:49 strk
+2004-11-02 15:49 Sandro Santilli <strk at keybit.net>
+ * [r558] source/headers/geos/indexQuadtree.h,
source/index/quadtree/DoubleBits.cpp: Moved ASSUME_IEEE_DOUBLE
define from DoubleBits.cpp to indexQuadtree.h.
Fixed a bug in powerOf2(). Made the !IEEE version less prone to
round-offs (still has approximation errors).
-2004-11-02 14:13 strk
+2004-11-02 14:13 Sandro Santilli <strk at keybit.net>
- * source/index/quadtree/DoubleBits.cpp: Fixed bug in IEEE-based
- exponent and PowerOf2 computation, but disabled
+ * [r557] source/index/quadtree/DoubleBits.cpp: Fixed bug in
+ IEEE-based exponent and PowerOf2 computation, but disabled
at compile time.
-2004-11-02 14:11 strk
+2004-11-02 14:11 Sandro Santilli <strk at keybit.net>
- * source/noding/MCQuadtreeNoder.cpp: Added more profiling.
+ * [r556] source/noding/MCQuadtreeNoder.cpp: Added more profiling.
-2004-11-02 09:38 strk
+2004-11-02 09:38 Sandro Santilli <strk at keybit.net>
- * source/test/XMLTester.cpp: Added timer for buffer test.
+ * [r555] source/test/XMLTester.cpp: Added timer for buffer test.
-2004-11-01 16:43 strk
+2004-11-01 16:43 Sandro Santilli <strk at keybit.net>
- * source/geom/Coordinate.cpp, source/geom/Envelope.cpp,
+ * [r554] source/geom/Coordinate.cpp, source/geom/Envelope.cpp,
source/geom/Makefile.am, source/geomgraph/Edge.cpp,
@@ -15950,44 +16275,44 @@
Temporarly patched a bug in DoubleBits (must check drawbacks).
Various cleanups and speedups.
-2004-10-27 13:57 strk
+2004-10-27 13:57 Sandro Santilli <strk at keybit.net>
- * source/operation/polygonize/Polygonizer.cpp,
+ * [r553] source/operation/polygonize/Polygonizer.cpp,
source/operation/polygonize/polygonizeEdgeRing.cpp: Added some
debugging lines (disabled by default)
-2004-10-27 11:05 strk
+2004-10-27 11:05 Sandro Santilli <strk at keybit.net>
- * TODO: updated
+ * [r552] TODO: updated
-2004-10-26 17:46 strk
+2004-10-26 17:46 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/indexBintree.h,
+ * [r551] source/headers/geos/indexBintree.h,
source/headers/geos/spatialIndex.h: Removed slash-stars in
comments to remove annoying compiler warnings.
-2004-10-26 17:14 strk
+2004-10-26 17:14 Sandro Santilli <strk at keybit.net>
- * NEWS, configure.in: current:revision:age set to 3.0.1 (will be
- release 2.1.0).
+ * [r550] NEWS, configure.in: current:revision:age set to 3.0.1
+ (will be release 2.1.0).
added news.
-2004-10-26 16:22 strk
+2004-10-26 16:22 Sandro Santilli <strk at keybit.net>
- * TODO: updated
+ * [r549] TODO: updated
-2004-10-26 16:09 strk
+2004-10-26 16:09 Sandro Santilli <strk at keybit.net>
- * source/operation/polygonize/PolygonizeGraph.cpp,
+ * [r548] source/operation/polygonize/PolygonizeGraph.cpp,
source/operation/polygonize/polygonizeEdgeRing.cpp: Some more
intentation and envelope equality check fix.
-2004-10-21 22:29 strk
+2004-10-21 22:29 Sandro Santilli <strk at keybit.net>
+ * [r547] source/algorithm/LineIntersector.cpp,
source/geom/Coordinate.cpp, source/geomgraph/EdgeEnd.cpp,
@@ -16002,18 +16327,19 @@
and some more COMPUTE_Z rules
-2004-10-21 17:13 strk
+2004-10-21 17:13 Sandro Santilli <strk at keybit.net>
- * source/io/WKTReader.cpp: Fixed bug introduced by previous patch.
+ * [r546] source/io/WKTReader.cpp: Fixed bug introduced by previous
+ patch.
-2004-10-21 07:03 strk
+2004-10-21 07:03 Sandro Santilli <strk at keybit.net>
- * source/io/WKTReader.cpp: Removed leak in ::readPolygonText
+ * [r545] source/io/WKTReader.cpp: Removed leak in ::readPolygonText
reported by Carlos A. Rueda
-2004-10-20 17:32 strk
+2004-10-20 17:32 Sandro Santilli <strk at keybit.net>
+ * [r544] source/algorithm/HCoordinate.cpp,
@@ -16030,13 +16356,13 @@
source/operation/overlay/PointBuilder.cpp: Initial approach to
2.5d intersection()
-2004-10-19 21:04 strk
+2004-10-19 21:04 Sandro Santilli <strk at keybit.net>
- * TODO: updated
+ * [r543] TODO: updated
-2004-10-19 19:51 strk
+2004-10-19 19:51 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/GeometryGraph.cpp,
+ * [r542] source/geomgraph/GeometryGraph.cpp,
source/operation/polygonize/PolygonizeDirectedEdge.cpp,
@@ -16051,9 +16377,9 @@
in Polygonizer.
Output still bogus.
-2004-10-18 12:43 strk
+2004-10-18 12:43 Sandro Santilli <strk at keybit.net>
- * Makefile.am, configure.in, swig, swig/.cvsignore,
+ * [r541] Makefile.am, configure.in, swig, swig/.cvsignore,
swig/Makefile.am, swig/python, swig/python/.cvsignore,
swig/python/Makefile.am, swig/python/tests,
swig/python/tests/.cvsignore, swig/python/tests/Makefile.am,
@@ -16061,9 +16387,9 @@
swig/python/tests/cases/Makefile.am: swig interface added to
distribution.
-2004-10-13 10:03 strk
+2004-10-13 10:03 Sandro Santilli <strk at keybit.net>
- * doc/example.cpp, source/geom/CoordinateSequence.cpp,
+ * [r540] doc/example.cpp, source/geom/CoordinateSequence.cpp,
source/headers/geos/geom.h, source/headers/geos/opLinemerge.h,
@@ -16088,128 +16414,130 @@
planargraph (used by them).
Some comments and indentation changes.
-2004-09-23 21:36 strk
+2004-09-23 21:36 Sandro Santilli <strk at keybit.net>
- * source/geom/CoordinateSequence.cpp: Fixed a bug in ::reverse
- (thanks to Elliott Edwards)
+ * [r539] source/geom/CoordinateSequence.cpp: Fixed a bug in
+ ::reverse (thanks to Elliott Edwards)
-2004-09-23 21:28 pramsey
+2004-09-23 21:28 Paul Ramsey <pramsey at cleverelephant.ca>
- * configure.in: Back minor version back to 2.0.1
+ * [r538] configure.in: Back minor version back to 2.0.1
-2004-09-23 04:30 pramsey
+2004-09-23 04:30 Paul Ramsey <pramsey at cleverelephant.ca>
- * configure.in: Bumped minor version to 2.0.2 after 2.0.1 release.
+ * [r537] configure.in: Bumped minor version to 2.0.2 after 2.0.1
+ release.
-2004-09-21 09:47 strk
+2004-09-21 09:47 Sandro Santilli <strk at keybit.net>
- * source/precision/SimpleGeometryPrecisionReducer.cpp: fixed a
- mis-initialization bug in ::reduce
+ * [r536] source/precision/SimpleGeometryPrecisionReducer.cpp: fixed
+ a mis-initialization bug in ::reduce
- * source/index/quadtree/DoubleBits.cpp: Removed useless auto_ptr
- usage in ::exponent
+ * [r535] source/index/quadtree/DoubleBits.cpp: Removed useless
+ auto_ptr usage in ::exponent
-2004-09-16 09:50 strk
+2004-09-16 09:50 Sandro Santilli <strk at keybit.net>
- * TODO: updated
+ * [r534] TODO: updated
-2004-09-16 09:48 strk
+2004-09-16 09:48 Sandro Santilli <strk at keybit.net>
- * source/geom/Geometry.cpp: Finer short-circuit tests for equals,
- within, contains.
+ * [r533] source/geom/Geometry.cpp: Finer short-circuit tests for
+ equals, within, contains.
- * source/geom/Envelope.cpp, source/headers/geos/geom.h: Added
- Envelope::equals
+ * [r532] source/geom/Envelope.cpp, source/headers/geos/geom.h:
+ Added Envelope::equals
-2004-09-16 07:32 strk
+2004-09-16 07:32 Sandro Santilli <strk at keybit.net>
- * TODO: updated
+ * [r531] TODO: updated
- * source/geom/Geometry.cpp: Added short-circuit tests. Can be
- disabled at compile-time
+ * [r530] source/geom/Geometry.cpp: Added short-circuit tests. Can
+ be disabled at compile-time
-2004-09-13 12:50 strk
+2004-09-13 12:50 Sandro Santilli <strk at keybit.net>
- * source/operation/valid/IsValidOp.cpp: comments cleanup
+ * [r529] source/operation/valid/IsValidOp.cpp: comments cleanup
-2004-09-13 12:40 strk
+2004-09-13 12:40 Sandro Santilli <strk at keybit.net>
- * TODO: updated
+ * [r528] TODO: updated
- * configure.in: Updated version number
+ * [r527] configure.in: Updated version number
-2004-09-13 12:39 strk
+2004-09-13 12:39 Sandro Santilli <strk at keybit.net>
- * source/test/XMLTester.cpp: Added missing newline at end of output
+ * [r526] source/test/XMLTester.cpp: Added missing newline at end of
+ output
- * source/geom/MultiPoint.cpp, source/geom/Point.cpp,
+ * [r525] source/geom/MultiPoint.cpp, source/geom/Point.cpp,
source/headers/geos/geom.h, source/headers/geos/opValid.h,
source/operation/valid/IsValidOp.cpp: Made Point and MultiPoint
subject to Validity tests.
-2004-09-13 10:14 strk
+2004-09-13 10:14 Sandro Santilli <strk at keybit.net>
- * source/operation/valid/TopologyValidationError.cpp: Added
+ * [r524] source/operation/valid/TopologyValidationError.cpp: Added
INVALID_COORDINATE code num and error message.
-2004-09-13 10:12 strk
+2004-09-13 10:12 Sandro Santilli <strk at keybit.net>
- * TODO, source/headers/geos/geosAlgorithm.h,
+ * [r523] TODO, source/headers/geos/geosAlgorithm.h,
source/operation/valid/IsValidOp.cpp: Added invalid coordinates
checks in IsValidOp.
Cleanups.
-2004-09-13 09:18 strk
+2004-09-13 09:18 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/opValid.h,
+ * [r522] source/headers/geos/opValid.h,
IsValidOp::isValid(Coordinate &)
-2004-09-13 09:07 strk
+2004-09-13 09:07 Sandro Santilli <strk at keybit.net>
- * source/geom/LineString.cpp: Ported fix in
+ * [r521] source/geom/LineString.cpp: Ported fix in
LineString::isCoordinate
-2004-09-12 03:51 pramsey
+2004-09-12 03:51 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/geom/LineString.cpp, source/geom/MultiLineString.cpp,
- source/geom/MultiPoint.cpp: Casting changes to allow OS/X
- compilation.
+ * [r520] source/geom/LineString.cpp,
+ source/geom/MultiLineString.cpp, source/geom/MultiPoint.cpp:
+ Casting changes to allow OS/X compilation.
-2004-09-07 08:29 strk
+2004-09-07 08:29 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom.h: Fixed doxygen malformed comment for
- Coordinate class
+ * [r519] source/headers/geos/geom.h: Fixed doxygen malformed
+ comment for Coordinate class
-2004-08-20 03:20 pramsey
+2004-08-20 03:20 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/bigtest/Makefile.am: Added reference to bigtest.h so 'make
- dist' includes it properly.
+ * [r517] source/bigtest/Makefile.am: Added reference to bigtest.h
+ so 'make dist' includes it properly.
-2004-08-20 01:55 pramsey
+2004-08-20 01:55 Paul Ramsey <pramsey at cleverelephant.ca>
- * configure.in: Removed examples from build directories for release
- (they don't build now).
+ * [r516] configure.in: Removed examples from build directories for
+ release (they don't build now).
-2004-08-04 08:26 strk
+2004-08-04 08:26 Sandro Santilli <strk at keybit.net>
- * source/operation/relate/RelateComputer.cpp: comments lift, stack
- allocation reduced
+ * [r515] source/operation/relate/RelateComputer.cpp: comments lift,
+ stack allocation reduced
-2004-07-27 16:35 strk
+2004-07-27 16:35 Sandro Santilli <strk at keybit.net>
- * source/algorithm/InteriorPointArea.cpp,
+ * [r514] source/algorithm/InteriorPointArea.cpp,
source/algorithm/SIRtreePointInRing.cpp,
source/geom/Geometry.cpp, source/geom/GeometryCollection.cpp,
source/geom/GeometryFactory.cpp, source/geom/Polygon.cpp,
@@ -16240,33 +16568,33 @@
a
geometry remains the same.
-2004-07-26 19:28 sgillies
+2004-07-26 19:28 Sean Gillies <sgillies at frii.com>
- * AUTHORS: added to AUTHORS
+ * [r513] AUTHORS: added to AUTHORS
-2004-07-26 18:53 sgillies
+2004-07-26 18:53 Sean Gillies <sgillies at frii.com>
- * swig/geos.i, swig/python/tests/cases/pointtest.py,
+ * [r512] swig/geos.i, swig/python/tests/cases/pointtest.py,
swig/python/tests/cases/wkttest.py: added simple exception
handling on all method calls
-2004-07-26 16:35 strk
+2004-07-26 16:35 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom.h: Removed dangling
+ * [r511] source/headers/geos/geom.h: Removed dangling
MultiPoint::isClosed() method definition.
-2004-07-26 15:40 sgillies
+2004-07-26 15:40 Sean Gillies <sgillies at frii.com>
- * swig/geos.i, swig/python/setup.py,
+ * [r510] swig/geos.i, swig/python/setup.py,
swig/python/tests/cases/wkttest.py,
swig/python/tests/runtests.py: wrapped up WKT reader and writer
and added two test cases to check that it works. found a bug
where the WKT reader crashes the program in the case of poorly
formatted WKT string.
-2004-07-25 23:45 sgillies
+2004-07-25 23:45 Sean Gillies <sgillies at frii.com>
- * swig, swig/README.txt, swig/geos.i, swig/python,
+ * [r509] swig, swig/README.txt, swig/geos.i, swig/python,
swig/python/README.txt, swig/python/setup.py, swig/python/tests,
swig/python/tests/TESTING.txt, swig/python/tests/cases,
swig/python/tests/cases/__init__.py,
@@ -16278,33 +16606,36 @@
today's CVS GEOS, and the test passes -- means that a module can
be built, installed, and imported.
-2004-07-22 16:58 strk
+2004-07-22 16:58 Sandro Santilli <strk at keybit.net>
- * TODO, doc/example.cpp, source/geom/Geometry.cpp,
+ * [r508] TODO, doc/example.cpp, source/geom/Geometry.cpp,
source/headers/geos/geom.h: runtime version extractor functions
split. geos::version() is now
geos::geosversion() and geos::jtsport()
-2004-07-22 08:45 strk
+2004-07-22 08:45 Sandro Santilli <strk at keybit.net>
- * TODO, source/geom/GeometryCollection.cpp,
+ * [r507] TODO, source/geom/GeometryCollection.cpp,
source/geom/MultiPoint.cpp, source/headers/geos/geom.h:
Documentation updates, memory leaks fixed.
-2004-07-22 07:19 strk
+2004-07-22 07:19 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom.h: Changed getCoordinatesRO description.
+ * [r506] source/headers/geos/geom.h: Changed getCoordinatesRO
+ description.
-2004-07-22 07:04 strk
+2004-07-22 07:04 Sandro Santilli <strk at keybit.net>
- * source/geom/Coordinate.cpp, source/geom/GeometryCollection.cpp,
- source/geom/Polygon.cpp, source/headers/geos/geom.h: Documented
- missing geometry functions.
+ * [r505] source/geom/Coordinate.cpp,
+ source/geom/GeometryCollection.cpp, source/geom/Polygon.cpp,
+ source/headers/geos/geom.h: Documented missing geometry
+ functions.
-2004-07-21 09:55 strk
+2004-07-21 09:55 Sandro Santilli <strk at keybit.net>
- * source/geom/Coordinate.cpp, source/geom/CoordinateList.cpp,
+ * [r504] source/geom/Coordinate.cpp,
+ source/geom/CoordinateList.cpp,
source/geom/CoordinateSequence.cpp, source/geom/Envelope.cpp,
source/geom/Geometry.cpp, source/geom/LineSegment.cpp,
source/geom/PrecisionModel.cpp, source/geomgraph/Edge.cpp,
@@ -16312,31 +16643,31 @@
CoordinateSequence::atLeastNCoordinatesOrNothing definition fix.
Documentation fixes.
-2004-07-21 09:11 strk
+2004-07-21 09:11 Sandro Santilli <strk at keybit.net>
- * NEWS, README, TODO: Updated
+ * [r503] NEWS, README, TODO: Updated
-2004-07-20 08:35 strk
+2004-07-20 08:35 Sandro Santilli <strk at keybit.net>
- * doc/README: Updated doxygen rule
+ * [r502] doc/README: Updated doxygen rule
-2004-07-20 08:34 strk
+2004-07-20 08:34 Sandro Santilli <strk at keybit.net>
- * doc/Doxyfile.in, source/geom/CoordinateList.cpp,
+ * [r501] doc/Doxyfile.in, source/geom/CoordinateList.cpp,
source/geom/Geometry.cpp, source/headers/geos/geom.h,
source/headers/geos/opDistance.h: Fixed a bug in opDistance.h.
Removed doxygen tags from obsoleted CoordinateList.cpp.
Got doxygen to run with no warnings.
-2004-07-19 19:37 pramsey
+2004-07-19 19:37 Paul Ramsey <pramsey at cleverelephant.ca>
- * doc/Makefile.am: Changed doxygen target to be more "make dist"
- friendly. (and allow autogeneration of CVS snapshot to work
+ * [r500] doc/Makefile.am: Changed doxygen target to be more "make
+ dist" friendly. (and allow autogeneration of CVS snapshot to work
again.)
-2004-07-19 13:19 strk
+2004-07-19 13:19 Sandro Santilli <strk at keybit.net>
- * doc/Doxyfile.in, source/geom/Envelope.cpp,
+ * [r499] doc/Doxyfile.in, source/geom/Envelope.cpp,
source/geom/Geometry.cpp, source/geom/GeometryFactory.cpp,
source/geom/LineString.cpp, source/headers/geos/geom.h,
source/headers/geos/geomUtil.h, source/headers/geos/geomgraph.h,
@@ -16360,181 +16691,186 @@
source/headers/geos/spatialIndex.h, source/io/WKTWriter.cpp:
Documentation fixes
-2004-07-19 10:38 strk
+2004-07-19 10:38 Sandro Santilli <strk at keybit.net>
- * doc, doc/.cvsignore: Added Doxyfile
+ * [r498] doc, doc/.cvsignore: Added Doxyfile
- * TODO: updated
+ * [r497] TODO: updated
-2004-07-19 10:37 strk
+2004-07-19 10:37 Sandro Santilli <strk at keybit.net>
- * doc/Makefile.am: Doxygen doc added to default build rules
+ * [r496] doc/Makefile.am: Doxygen doc added to default build rules
- * source/geom/DefaultCoordinateSequenceFactory.cpp:
+ * [r495] source/geom/DefaultCoordinateSequenceFactory.cpp:
defaultCoordinateSequenceFactory made module-static (use
DefaultCoordinateSequenceFactory::instance() instead)
-2004-07-19 10:35 strk
+2004-07-19 10:35 Sandro Santilli <strk at keybit.net>
- * source/bigtest/GeometryTestFactory.cpp,
+ * [r494] source/bigtest/GeometryTestFactory.cpp,
source/bigtest/TestSweepLineSpeed.cpp, source/bigtest/bigtest.h,
source/headers/geos/bigtest.h: bigtest.h moved to local dir
-2004-07-19 10:34 strk
+2004-07-19 10:34 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom.h: removed doxygen documentation of
- removed feature
+ * [r493] source/headers/geos/geom.h: removed doxygen documentation
+ of removed feature
-2004-07-19 10:33 strk
+2004-07-19 10:33 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/io.h: Class documentation changed to report
- geos.h as WKT writer/parser header file
+ * [r492] source/headers/geos/io.h: Class documentation changed to
+ report geos.h as WKT writer/parser header file
-2004-07-19 10:30 strk
+2004-07-19 10:30 Sandro Santilli <strk at keybit.net>
- * source/headers/acconfig.h, source/headers/geos/Makefile.am,
- source/headers/geos/acconfig.h: acconfig.h moved one directory up
+ * [r491] source/headers/acconfig.h,
+ source/headers/geos/Makefile.am, source/headers/geos/acconfig.h:
+ acconfig.h moved one directory up
-2004-07-19 10:28 strk
+2004-07-19 10:28 Sandro Santilli <strk at keybit.net>
- * doc/Doxyfile.in: Excluded example and test dirs from input set
+ * [r490] doc/Doxyfile.in: Excluded example and test dirs from input
+ set
-2004-07-17 10:48 strk
+2004-07-17 10:48 Sandro Santilli <strk at keybit.net>
- * TODO: updated
+ * [r489] TODO: updated
- * doc, doc/.cvsignore: added Doxyfile (generated)
+ * [r488] doc, doc/.cvsignore: added Doxyfile (generated)
- * source/geom/Geometry.cpp: fixed typo in documentation
+ * [r487] source/geom/Geometry.cpp: fixed typo in documentation
-2004-07-17 10:47 strk
+2004-07-17 10:47 Sandro Santilli <strk at keybit.net>
- * configure.in, doc/Doxyfile, doc/Doxyfile.in: Doxygen
+ * [r486] configure.in, doc/Doxyfile, doc/Doxyfile.in: Doxygen
configuration created at ./configure time, for versioning.
-2004-07-17 09:19 strk
+2004-07-17 09:19 Sandro Santilli <strk at keybit.net>
- * doc/example.cpp: added GEOS version report
+ * [r485] doc/example.cpp: added GEOS version report
-2004-07-17 09:18 strk
+2004-07-17 09:18 Sandro Santilli <strk at keybit.net>
- * source/geom/Geometry.cpp, source/headers/geos/geom.h: Added
- geos::version()
+ * [r484] source/geom/Geometry.cpp, source/headers/geos/geom.h:
+ Added geos::version()
-2004-07-17 09:07 strk
+2004-07-17 09:07 Sandro Santilli <strk at keybit.net>
- * tools/geos-config.in: Added --jtsport
+ * [r483] tools/geos-config.in: Added --jtsport
-2004-07-17 09:06 strk
+2004-07-17 09:06 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/version.h.in: Added GEOS_FIRST_INTERFACE,
- GEOS_LAST_INTERFACE and GEOS_JTS_PORT
+ * [r482] source/headers/geos/version.h.in: Added
+ GEOS_FIRST_INTERFACE, GEOS_LAST_INTERFACE and GEOS_JTS_PORT
-2004-07-17 09:05 strk
+2004-07-17 09:05 Sandro Santilli <strk at keybit.net>
- * configure.in: Added JTS_PORT variable.
+ * [r481] configure.in: Added JTS_PORT variable.
Simplified versioning settings: comments added,
major/minor/patchlevel
extracted by CURRENT,AGE,REVISION.
-2004-07-16 17:02 strk
+2004-07-16 17:02 Sandro Santilli <strk at keybit.net>
- * TODO: updated
+ * [r480] TODO: updated
-2004-07-16 16:20 strk
+2004-07-16 16:20 Sandro Santilli <strk at keybit.net>
- * configure.in, source/geom/Makefile.am: Libtool versioning scheme
- adopted.
+ * [r479] configure.in, source/geom/Makefile.am: Libtool versioning
+ scheme adopted.
-2004-07-16 16:09 strk
+2004-07-16 16:09 Sandro Santilli <strk at keybit.net>
- * doc/Makefile.am: removed useless Includedir
+ * [r478] doc/Makefile.am: removed useless Includedir
-2004-07-16 15:57 strk
+2004-07-16 15:57 Sandro Santilli <strk at keybit.net>
- * source/headers/geos.h: made includes use <>
+ * [r477] source/headers/geos.h: made includes use <>
-2004-07-16 13:27 strk
+2004-07-16 13:27 Sandro Santilli <strk at keybit.net>
- * TODO: updated
+ * [r476] TODO: updated
-2004-07-16 10:28 strk
+2004-07-16 10:28 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/util.h,
+ * [r475] source/headers/geos/util.h,
source/util/GeometricShapeFactory.cpp: Dimesions object allocated
on the heap
-2004-07-16 10:00 strk
+2004-07-16 10:00 Sandro Santilli <strk at keybit.net>
- * doc/example.cpp: Bug fixed in GeometricShapeFactory examples.
+ * [r474] doc/example.cpp: Bug fixed in GeometricShapeFactory
+ examples.
Added example of GeometricShapeFactory::createArc.
-2004-07-16 09:58 strk
+2004-07-16 09:58 Sandro Santilli <strk at keybit.net>
- * TODO: updated
+ * [r473] TODO: updated
- * doc/example.tosql: Added LINEARRING to LINESTRING conversion
+ * [r472] doc/example.tosql: Added LINEARRING to LINESTRING
+ conversion
-2004-07-16 09:57 strk
+2004-07-16 09:57 Sandro Santilli <strk at keybit.net>
- * source/geom/Makefile.am: Modified library version to 1.4.0
+ * [r471] source/geom/Makefile.am: Modified library version to 1.4.0
-2004-07-15 13:41 strk
+2004-07-15 13:41 Sandro Santilli <strk at keybit.net>
- * doc/example.cpp: Added createRectangle example.
+ * [r470] doc/example.cpp: Added createRectangle example.
-2004-07-15 13:40 strk
+2004-07-15 13:40 Sandro Santilli <strk at keybit.net>
- * source/util/GeometricShapeFactory.cpp: Memory leaks fixed,
+ * [r469] source/util/GeometricShapeFactory.cpp: Memory leaks fixed,
CoordinateSequence use made JTS - compatible.
-2004-07-14 21:21 strk
+2004-07-14 21:21 Sandro Santilli <strk at keybit.net>
- * TODO: updated
+ * [r468] TODO: updated
-2004-07-14 21:20 strk
+2004-07-14 21:20 Sandro Santilli <strk at keybit.net>
- * source/geom/Geometry.cpp: Added GeometricShapeFactory note on
- doxygen mainpage
+ * [r467] source/geom/Geometry.cpp: Added GeometricShapeFactory note
+ on doxygen mainpage
- * source/headers/geos.h: added geos/io.h and geos/unload.h
+ * [r466] source/headers/geos.h: added geos/io.h and geos/unload.h
-2004-07-14 21:19 strk
+2004-07-14 21:19 Sandro Santilli <strk at keybit.net>
+ * [r465] source/headers/geos/util.h,
source/util/GeometricShapeFactory.cpp: GeometricShapeFactory
first pass of bug fixes
-2004-07-14 21:17 strk
+2004-07-14 21:17 Sandro Santilli <strk at keybit.net>
- * source/geom/Makefile.am: added missing GeometricShapeFactory.cpp
+ * [r464] source/geom/Makefile.am: added missing
+ GeometricShapeFactory.cpp
- * source/geom/Coordinate.cpp, source/headers/geos/geom.h: added
- inequality operator for Coordinate
+ * [r463] source/geom/Coordinate.cpp, source/headers/geos/geom.h:
+ added inequality operator for Coordinate
-2004-07-14 21:15 strk
+2004-07-14 21:15 Sandro Santilli <strk at keybit.net>
- * doc/example.cpp, doc/example.tosql: Added GeometricShapeFactory
- example: createCircle.
+ * [r462] doc/example.cpp, doc/example.tosql: Added
+ GeometricShapeFactory example: createCircle.
Added simple filter to send example output to a postgis table.
-2004-07-13 08:33 strk
+2004-07-13 08:33 Sandro Santilli <strk at keybit.net>
- * source/geom/GeometryFactory.cpp, source/geom/Polygon.cpp,
+ * [r461] source/geom/GeometryFactory.cpp, source/geom/Polygon.cpp,
source/headers/geos/geom.h, source/headers/geos/geomgraph.h,
@@ -16554,22 +16890,23 @@
virtual destructor to virtual classes.
Fixed implicit unsigned int -> int casts
-2004-07-12 19:16 strk
+2004-07-12 19:16 Sandro Santilli <strk at keybit.net>
- * source/headers/geos/geom.h: Commented out CoordinateList class
- definition.
+ * [r460] source/headers/geos/geom.h: Commented out CoordinateList
+ class definition.
-2004-07-12 15:42 strk
+2004-07-12 15:42 Sandro Santilli <strk at keybit.net>
- * source/geom/PrecisionModel.cpp: Fixed maximumPreciseValue scope
+ * [r459] source/geom/PrecisionModel.cpp: Fixed maximumPreciseValue
+ scope
-2004-07-09 08:01 strk
+2004-07-09 08:01 Sandro Santilli <strk at keybit.net>
- * TODO: updated
+ * [r458] TODO: updated
-2004-07-08 19:41 strk
+2004-07-08 19:41 Sandro Santilli <strk at keybit.net>
- * source/examples/CoordinateListsExample.cpp,
+ * [r457] source/examples/CoordinateListsExample.cpp,
source/examples/CoordinateSequencesExample.cpp,
source/examples/CustomCoordinateListExample.cpp,
source/examples/CustomCoordinateListExample.h,
@@ -16579,9 +16916,9 @@
source/examples/CustomPointCoordinateSequence.cpp: renamed to
reflect JTS API.
-2004-07-08 19:38 strk
+2004-07-08 19:38 Sandro Santilli <strk at keybit.net>
+ * [r456] source/geom/CoordinateSequence.cpp,
source/geom/CoordinateSequenceFactory.cpp,
source/geom/DefaultCoordinateSequenceFactory.cpp,
@@ -16589,24 +16926,24 @@
source/geom/PointCoordinateSequenceFactory.cpp: renamed from
*List* equivalents
-2004-07-08 19:37 strk
+2004-07-08 19:37 Sandro Santilli <strk at keybit.net>
- * source/geom/PointCoordinateList.cpp: Renamed to
+ * [r455] source/geom/PointCoordinateList.cpp: Renamed to
- * source/geom/CoordinateListFactory.cpp: Renamed to
+ * [r454] source/geom/CoordinateListFactory.cpp: Renamed to
-2004-07-08 19:36 strk
+2004-07-08 19:36 Sandro Santilli <strk at keybit.net>
- * source/geom/BasicCoordinateList.cpp: Renamed to
+ * [r453] source/geom/BasicCoordinateList.cpp: Renamed to
-2004-07-08 19:34 strk
+2004-07-08 19:34 Sandro Santilli <strk at keybit.net>
- * TODO, doc/example.cpp, source/Makefile.am,
+ * [r452] TODO, doc/example.cpp, source/Makefile.am,
source/algorithm/CentroidArea.cpp,
source/algorithm/CentroidLine.cpp,
@@ -16683,43 +17020,43 @@
default implementations.
Added DefaultCoordinateSequenceFactory::instance() function.
-2004-07-07 18:54 strk
+2004-07-07 18:54 Sandro Santilli <strk at keybit.net>
- * TODO: updated
+ * [r451] TODO: updated
-2004-07-07 10:29 strk
+2004-07-07 10:29 Sandro Santilli <strk at keybit.net>
- * source/algorithm/NotRepresentableException.cpp,
+ * [r450] source/algorithm/NotRepresentableException.cpp,
source/headers/geos/geosAlgorithm.h, source/headers/geos/io.h,
source/headers/geos/util.h: Adjusted exceptions documentation.
-2004-07-07 09:38 strk
+2004-07-07 09:38 Sandro Santilli <strk at keybit.net>
- * NEWS, source/geom/Geometry.cpp, source/headers/geos/geom.h,
- source/headers/geos/geosAlgorithm.h, source/headers/geos/io.h,
- source/io/WKTReader.cpp, source/io/WKTWriter.cpp,
- source/test/XMLTester.cpp: Dropped WKTWriter::stringOfChars
- (implemented by std::string).
+ * [r449] NEWS, source/geom/Geometry.cpp,
+ source/headers/geos/geom.h, source/headers/geos/geosAlgorithm.h,
+ source/headers/geos/io.h, source/io/WKTReader.cpp,
+ source/io/WKTWriter.cpp, source/test/XMLTester.cpp: Dropped
+ WKTWriter::stringOfChars (implemented by std::string).
Dropped WKTWriter default constructor (internally created
GeometryFactory).
Updated XMLTester to respect the changes.
Main documentation page made nicer.
-2004-07-07 07:52 strk
+2004-07-07 07:52 Sandro Santilli <strk at keybit.net>
- * TODO, source/operation/buffer/BufferSubgraph.cpp: Removed note
- about required speedup in BufferSubgraph.
+ * [r448] TODO, source/operation/buffer/BufferSubgraph.cpp: Removed
+ note about required speedup in BufferSubgraph.
I've made tests with 'sets' and there is actually a big slow
down..
-2004-07-06 17:58 strk
+2004-07-06 17:58 Sandro Santilli <strk at keybit.net>
- * source/geom/Geometry.cpp, source/geom/GeometryCollection.cpp,
- source/geom/LineString.cpp, source/geom/LinearRing.cpp,
- source/geom/MultiLineString.cpp, source/geom/MultiPoint.cpp,
- source/geom/MultiPolygon.cpp, source/geom/Point.cpp,
- source/geom/Polygon.cpp, source/headers/geos/geom.h,
- source/headers/geos/precision.h,
+ * [r447] source/geom/Geometry.cpp,
+ source/geom/GeometryCollection.cpp, source/geom/LineString.cpp,
+ source/geom/LinearRing.cpp, source/geom/MultiLineString.cpp,
+ source/geom/MultiPoint.cpp, source/geom/MultiPolygon.cpp,
+ source/geom/Point.cpp, source/geom/Polygon.cpp,
+ source/headers/geos/geom.h, source/headers/geos/precision.h,
source/operation/buffer/OffsetCurveSetBuilder.cpp,
source/precision/SimpleGeometryPrecisionReducer.cpp: Removed
deprecated Geometry constructors based on PrecisionModel and
@@ -16728,31 +17065,31 @@
of changing Geometry's factory. Reverted Geometry::factory member
to be a reference to external factory.
-2004-07-05 19:40 strk
+2004-07-05 19:40 Sandro Santilli <strk at keybit.net>
- * source/geom/Geometry.cpp, source/geom/GeometryFactory.cpp,
+ * [r446] source/geom/Geometry.cpp, source/geom/GeometryFactory.cpp,
GeometryFactory::destroyGeometry(Geometry *)
-2004-07-05 15:20 strk
+2004-07-05 15:20 Sandro Santilli <strk at keybit.net>
- * TODO, source/geom/Geometry.cpp, source/headers/geos/geom.h:
- Documentation again.
+ * [r445] TODO, source/geom/Geometry.cpp,
+ source/headers/geos/geom.h: Documentation again.
-2004-07-05 14:23 strk
+2004-07-05 14:23 Sandro Santilli <strk at keybit.net>
- * NEWS, source/geom/CoordinateList.cpp,
+ * [r444] NEWS, source/geom/CoordinateList.cpp,
source/geom/GeometryFactory.cpp, source/geom/LineString.cpp,
source/geom/PrecisionModel.cpp, source/headers/geos/geom.h,
source/headers/geos/util.h: More documentation cleanups.
-2004-07-05 11:50 strk
+2004-07-05 11:50 Sandro Santilli <strk at keybit.net>
- * doc/README: initial import
+ * [r443] doc/README: initial import
-2004-07-05 10:50 strk
+2004-07-05 10:50 Sandro Santilli <strk at keybit.net>
- * NEWS, doc/Doxyfile, source/geom/BasicCoordinateList.cpp,
+ * [r442] NEWS, doc/Doxyfile, source/geom/BasicCoordinateList.cpp,
@@ -16770,32 +17107,33 @@
copy semantic (by-ref instead of by-pointer).
Cleaned up documentation.
-2004-07-03 12:54 strk
+2004-07-03 12:54 Sandro Santilli <strk at keybit.net>
- * source/headers/geos, source/headers/geos/.cvsignore: more entries
+ * [r441] source/headers/geos, source/headers/geos/.cvsignore: more
+ entries
-2004-07-03 12:51 strk
+2004-07-03 12:51 Sandro Santilli <strk at keybit.net>
+ * [r440] source/algorithm/NotRepresentableException.cpp,
source/geom/LineString.cpp, source/geom/PrecisionModel.cpp,
source/headers/geos.h, source/headers/geos/geom.h: Documentation
cleanups for DoxyGen.
-2004-07-02 17:22 strk
+2004-07-02 17:22 Sandro Santilli <strk at keybit.net>
- * doc/Doxyfile, doc/Makefile.am, doc/geosDoxygen.conf: Doxygen
- configuration file renamed.
+ * [r439] doc/Doxyfile, doc/Makefile.am, doc/geosDoxygen.conf:
+ Doxygen configuration file renamed.
-2004-07-02 14:27 strk
+2004-07-02 14:27 Sandro Santilli <strk at keybit.net>
- * source/geom/GeometryFactory.cpp, source/geom/Point.cpp,
+ * [r438] source/geom/GeometryFactory.cpp, source/geom/Point.cpp,
source/headers/geos/geom.h: Added deep-copy / take-ownerhship for
Point type.
-2004-07-02 13:28 strk
+2004-07-02 13:28 Sandro Santilli <strk at keybit.net>
- * ChangeLog, README, configure.in, doc/Makefile.am,
+ * [r437] ChangeLog, README, configure.in, doc/Makefile.am,
doc/example.cpp, source/algorithm/CGAlgorithms.cpp,
@@ -16974,13 +17312,14 @@
lines to reflect headers layout change.
Added client application build tips in README.
-2004-07-02 13:21 strk
+2004-07-02 13:21 Sandro Santilli <strk at keybit.net>
- * source/headers/geos_version.h.in: renamed to geos/version.h.in
+ * [r436] source/headers/geos_version.h.in: renamed to
+ geos/version.h.in
-2004-07-02 13:20 strk
+2004-07-02 13:20 Sandro Santilli <strk at keybit.net>
- * source/headers, source/headers/.cvsignore,
+ * [r435] source/headers, source/headers/.cvsignore,
source/headers/Makefile.am, source/headers/acconfig.h,
source/headers/bigtest.h, source/headers/geom.h,
source/headers/geomUtil.h, source/headers/geomgraph.h,
@@ -17023,29 +17362,29 @@
source/headers/spatialIndex.h, source/headers/unload.h,
source/headers/util.h: Header files moved under geos/ dir.
-2004-07-01 17:34 strk
+2004-07-01 17:34 Sandro Santilli <strk at keybit.net>
- * source/geom/Geometry.cpp: GeometryFactory argument in Geometry
- constructor reverted
+ * [r434] source/geom/Geometry.cpp: GeometryFactory argument in
+ Geometry constructor reverted
to its copy-and-destroy semantic.
-2004-07-01 17:07 strk
+2004-07-01 17:07 Sandro Santilli <strk at keybit.net>
- * doc, doc/.cvsignore, doc/Makefile.am: Added doxygen_docs
+ * [r433] doc, doc/.cvsignore, doc/Makefile.am: Added doxygen_docs
generation rule
-2004-07-01 16:49 strk
+2004-07-01 16:49 Sandro Santilli <strk at keybit.net>
- * doc/geosDoxygen.conf: re-generated with doxygen 1.2.15
+ * [r432] doc/geosDoxygen.conf: re-generated with doxygen 1.2.15
2004-07-01 15:47 cvs
- * doc/geosDoxygen.conf: Added doxygen file for better doco
+ * [r431] doc/geosDoxygen.conf: Added doxygen file for better doco
generation.
-2004-07-01 14:12 strk
+2004-07-01 14:12 Sandro Santilli <strk at keybit.net>
- * ChangeLog, NEWS, TODO, doc/example.cpp,
+ * [r430] ChangeLog, NEWS, TODO, doc/example.cpp,
source/algorithm/ConvexHull.cpp,
source/algorithm/InteriorPointArea.cpp, source/geom/Geometry.cpp,
@@ -17072,9 +17411,10 @@
Same functionality is available through GeometryFactory,
including buildGeometry().
-2004-06-30 20:59 strk
+2004-06-30 20:59 Sandro Santilli <strk at keybit.net>
+ * [r429] source/geom/Geometry.cpp,
source/geomgraph/EdgeRing.cpp, source/headers/geom.h,
source/headers/geomgraph.h, source/headers/geosAlgorithm.h,
source/headers/opBuffer.h, source/headers/opOverlay.h,
@@ -17086,49 +17426,51 @@
GeoemtryFactory copy from geometry constructors.
Enforced const-correctness on GeometryFactory arguments.
-2004-06-28 21:58 strk
+2004-06-28 21:58 Sandro Santilli <strk at keybit.net>
- * source/geom/Polygon.cpp: Constructors speedup.
+ * [r428] source/geom/Polygon.cpp: Constructors speedup.
-2004-06-28 21:11 strk
+2004-06-28 21:11 Sandro Santilli <strk at keybit.net>
- * source/geom/GeometryCollection.cpp, source/geom/LineString.cpp,
- source/geom/LinearRing.cpp, source/geom/MultiLineString.cpp,
- source/geom/MultiPoint.cpp, source/geom/MultiPolygon.cpp,
- source/geom/Point.cpp, source/geom/Polygon.cpp,
- source/headers/geom.h: Moved getGeometryTypeId() definitions from
- geom.h to each geometry module.
+ * [r427] source/geom/GeometryCollection.cpp,
+ source/geom/LineString.cpp, source/geom/LinearRing.cpp,
+ source/geom/MultiLineString.cpp, source/geom/MultiPoint.cpp,
+ source/geom/MultiPolygon.cpp, source/geom/Point.cpp,
+ source/geom/Polygon.cpp, source/headers/geom.h: Moved
+ getGeometryTypeId() definitions from geom.h to each geometry
+ module.
Added holes argument check in Polygon.cpp.
-2004-06-25 14:26 strk
+2004-06-25 14:26 Sandro Santilli <strk at keybit.net>
- * tools/geos-config.in: fixed --includes
+ * [r426] tools/geos-config.in: fixed --includes
-2004-06-22 16:57 strk
+2004-06-22 16:57 Sandro Santilli <strk at keybit.net>
- * NEWS: Written down some news
+ * [r425] NEWS: Written down some news
-2004-06-22 16:56 strk
+2004-06-22 16:56 Sandro Santilli <strk at keybit.net>
- * source/headers/Makefile.am, source/headers/geos.h: Added geos.h
- file.
+ * [r424] source/headers/Makefile.am, source/headers/geos.h: Added
+ geos.h file.
-2004-06-21 22:14 strk
+2004-06-21 22:14 Sandro Santilli <strk at keybit.net>
- * source/headers, source/headers/.cvsignore: added geos_version.h
+ * [r423] source/headers, source/headers/.cvsignore: added
+ geos_version.h
-2004-06-21 22:13 strk
+2004-06-21 22:13 Sandro Santilli <strk at keybit.net>
- * TODO: updated
+ * [r422] TODO: updated
- * configure.in, source/headers/Makefile.am,
+ * [r421] configure.in, source/headers/Makefile.am,
source/headers/geos_version.h.in: Added VERSION defines
-2004-06-16 13:13 strk
+2004-06-16 13:13 Sandro Santilli <strk at keybit.net>
- * TODO, source/geom/BasicCoordinateList.cpp,
+ * [r420] TODO, source/geom/BasicCoordinateList.cpp,
source/geom/GeometryFactory.cpp, source/geom/MultiPolygon.cpp,
source/geomgraph/Edge.cpp, source/headers/noding.h,
source/noding/MCQuadtreeNoder.cpp,
@@ -17140,258 +17482,262 @@
constructors.
Other associated fixes.
-2004-06-15 21:35 strk
+2004-06-15 21:35 Sandro Santilli <strk at keybit.net>
- * source/geom/GeometryFactory.cpp: fixed buildGeometry to always
- return a newly allocated geometry
+ * [r419] source/geom/GeometryFactory.cpp: fixed buildGeometry to
+ always return a newly allocated geometry
-2004-06-15 20:42 strk
+2004-06-15 20:42 Sandro Santilli <strk at keybit.net>
- * doc/example.cpp, source/geom/LineString.cpp,
+ * [r418] doc/example.cpp, source/geom/LineString.cpp,
source/geom/MultiPolygon.cpp, source/geom/Polygon.cpp: updated to
respect deep-copy GeometryCollection interface
-2004-06-15 20:30 strk
+2004-06-15 20:30 Sandro Santilli <strk at keybit.net>
- * source/io/WKTReader.cpp: fixed a typo
+ * [r417] source/io/WKTReader.cpp: fixed a typo
-2004-06-15 20:20 strk
+2004-06-15 20:20 Sandro Santilli <strk at keybit.net>
- * source/geom/util/GeometryEditor.cpp, source/io/WKTReader.cpp,
+ * [r416] source/geom/util/GeometryEditor.cpp,
+ source/io/WKTReader.cpp,
source/operation/buffer/BufferBuilder.cpp,
source/operation/overlay/OverlayOp.cpp: updated to respect
-2004-06-15 20:07 strk
+2004-06-15 20:07 Sandro Santilli <strk at keybit.net>
+ * [r415] source/geom/GeometryCollection.cpp,
source/geom/GeometryFactory.cpp, source/headers/geom.h:
GeometryCollections constructors make a deep copy of Geometry
vector argument.
-2004-06-15 20:01 strk
+2004-06-15 20:01 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferBuilder.cpp: Empty geometry
+ * [r414] source/operation/buffer/BufferBuilder.cpp: Empty geometry
creation call made using NULL instead of newly created empty
vector (will be faster)
-2004-06-15 19:24 strk
+2004-06-15 19:24 Sandro Santilli <strk at keybit.net>
- * tools/geos-config.in: Fixed a bug preventing geos-config from
- giving correct version info
+ * [r413] tools/geos-config.in: Fixed a bug preventing geos-config
+ from giving correct version info
-2004-06-15 07:40 strk
+2004-06-15 07:40 Sandro Santilli <strk at keybit.net>
- * source/noding/SegmentNode.cpp,
+ * [r412] source/noding/SegmentNode.cpp,
source/planargraph/planarDirectedEdge.cpp: Added missing
<stdio.h> include
- * TODO: Updated
+ * [r411] TODO: Updated
-2004-05-28 18:16 ybychkov
+2004-05-28 18:16 Yury Bychkov <me at yury.ca>
- * source/geom/PrecisionModel.cpp: Changed rounding method to make
- compilable with VC++
+ * [r410] source/geom/PrecisionModel.cpp: Changed rounding method to
+ make compilable with VC++
-2004-05-27 12:09 strk
+2004-05-27 12:09 Sandro Santilli <strk at keybit.net>
- * source/test/testLeaksBig.xml: added one buffer test
+ * [r409] source/test/testLeaksBig.xml: added one buffer test
-2004-05-27 10:27 strk
+2004-05-27 10:27 Sandro Santilli <strk at keybit.net>
- * source/noding/SegmentNodeList.cpp,
+ * [r408] source/noding/SegmentNodeList.cpp,
source/noding/SegmentString.cpp: Memory leaks fixed.
-2004-05-27 10:26 strk
+2004-05-27 10:26 Sandro Santilli <strk at keybit.net>
- * source/noding/nodingSegmentIntersector.cpp: set (useless?)
+ * [r407] source/noding/nodingSegmentIntersector.cpp: set (useless?)
recordIsolated member in constructor
-2004-05-27 09:53 strk
+2004-05-27 09:53 Sandro Santilli <strk at keybit.net>
- * source/headers/indexChain.h:
+ * [r406] source/headers/indexChain.h:
MonotoneChainOverlapAction::overlap(*) funx made virtual
as they are supposed to be.
-2004-05-27 08:40 strk
+2004-05-27 08:40 Sandro Santilli <strk at keybit.net>
- * source/test/XMLTester.cpp: Fixed a memleak in buffer test.
+ * [r405] source/test/XMLTester.cpp: Fixed a memleak in buffer test.
-2004-05-27 08:37 strk
+2004-05-27 08:37 Sandro Santilli <strk at keybit.net>
- * source/headers/opBuffer.h,
+ * [r404] source/headers/opBuffer.h,
source/operation/buffer/OffsetCurveBuilder.cpp: Fixed a bug
preventing OffsetCurveBuilder point list from being reset.
-2004-05-26 19:48 strk
+2004-05-26 19:48 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/OffsetCurveBuilder.cpp,
+ * [r403] source/operation/buffer/OffsetCurveBuilder.cpp,
source/operation/buffer/OffsetCurveSetBuilder.cpp: Changed abs()
to fabs() when working with doubles.
Used dynamic_cast<> instead of typeid() when JTS uses instanceof.
-2004-05-26 13:12 strk
+2004-05-26 13:12 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferBuilder.cpp: Removed try/catch
- block from ::buildSubgraphs
+ * [r402] source/operation/buffer/BufferBuilder.cpp: Removed
+ try/catch block from ::buildSubgraphs
-2004-05-26 09:50 strk
+2004-05-26 09:50 Sandro Santilli <strk at keybit.net>
- * source/headers/geomgraph.h: Added comments about
+ * [r401] source/headers/geomgraph.h: Added comments about
OverlayNodeFactory() ownership in NodeMap and PlanarGraph
constuctors
-2004-05-26 09:49 strk
+2004-05-26 09:49 Sandro Santilli <strk at keybit.net>
+ * [r400] source/headers/opBuffer.h,
source/operation/buffer/BufferBuilder.cpp: PlanarGraph made local
to ::buffer instead of Class private.
-2004-05-21 14:17 strk
+2004-05-21 14:17 Sandro Santilli <strk at keybit.net>
- * TODO: updated
+ * [r399] TODO: updated
-2004-05-21 13:58 strk
+2004-05-21 13:58 Sandro Santilli <strk at keybit.net>
- * source/geom/Geometry.cpp: ::intersection missed to invalidate
- geometryCollection inputs
+ * [r398] source/geom/Geometry.cpp: ::intersection missed to
+ invalidate geometryCollection inputs
-2004-05-21 13:55 strk
+2004-05-21 13:55 Sandro Santilli <strk at keybit.net>
- * TODO: updated
+ * [r397] TODO: updated
-2004-05-21 13:39 strk
+2004-05-21 13:39 Sandro Santilli <strk at keybit.net>
- * source/geom/PrecisionModel.cpp: ::makePrecise make use of
+ * [r396] source/geom/PrecisionModel.cpp: ::makePrecise make use of
nearbyint() now, to be compatible with JTS
-2004-05-21 13:37 strk
+2004-05-21 13:37 Sandro Santilli <strk at keybit.net>
- * source/test/testLeaksBig.xml: first import
+ * [r395] source/test/testLeaksBig.xml: first import
-2004-05-20 09:14 strk
+2004-05-20 09:14 Sandro Santilli <strk at keybit.net>
- * TODO: updated
+ * [r394] TODO: updated
-2004-05-19 19:39 ybychkov
+2004-05-19 19:39 Yury Bychkov <me at yury.ca>
+ * [r393] source/geom/PrecisionModel.cpp: Changed rounding method to
-2004-05-19 13:40 strk
+2004-05-19 13:40 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/OffsetCurveBuilder.cpp: Fixed bug in
- ::addCircle
+ * [r392] source/operation/buffer/OffsetCurveBuilder.cpp: Fixed bug
+ in ::addCircle
-2004-05-19 13:18 strk
+2004-05-19 13:18 Sandro Santilli <strk at keybit.net>
- * source/geom/BasicCoordinateList.cpp,
+ * [r391] source/geom/BasicCoordinateList.cpp,
source/geom/PointCoordinateList.cpp, source/headers/geom.h: made
CoordinateList::toString() a const member function
-2004-05-19 13:01 strk
+2004-05-19 13:01 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferOp.cpp: avoided assignment operator
- calls for BufferBuilder
+ * [r390] source/operation/buffer/BufferOp.cpp: avoided assignment
+ operator calls for BufferBuilder
-2004-05-19 12:50 strk
+2004-05-19 12:50 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferSubgraph.cpp: Removed all try/catch
- blocks transforming stack allocated-vectors to
+ * [r389] source/operation/buffer/BufferSubgraph.cpp: Removed all
+ try/catch blocks transforming stack allocated-vectors to
auto-heap-allocations
-2004-05-19 09:57 ybychkov
+2004-05-19 09:57 Yury Bychkov <me at yury.ca>
- * source/operation/buffer/OffsetCurveSetBuilder.cpp: Bugfix in
- OffsetCurveSetBuilder::addPolygon (JTS 1.4.1)
+ * [r388] source/operation/buffer/OffsetCurveSetBuilder.cpp: Bugfix
+ in OffsetCurveSetBuilder::addPolygon (JTS 1.4.1)
-2004-05-18 13:49 strk
+2004-05-18 13:49 Sandro Santilli <strk at keybit.net>
- * source/test/XMLTester.cpp: Output made more neat (geometry B is
- not printed if not existent).
+ * [r387] source/test/XMLTester.cpp: Output made more neat (geometry
+ B is not printed if not existent).
Added support for buffer tests.
-2004-05-18 13:15 strk
+2004-05-18 13:15 Sandro Santilli <strk at keybit.net>
- * source/geom/CoordinateList.cpp: made ::scroll handle already
- scrolled vect and more readable
+ * [r386] source/geom/CoordinateList.cpp: made ::scroll handle
+ already scrolled vect and more readable
-2004-05-18 00:02 ybychkov
+2004-05-18 00:02 Yury Bychkov <me at yury.ca>
- * source/headers/opValid.h, source/operation/valid/IsValidOp.cpp:
+ * [r385] source/headers/opValid.h,
+ source/operation/valid/IsValidOp.cpp:
IsValidOp::checkShellNotNested() bugfix from JTS 1.4.1 (not
released yet) has been added.
-2004-05-17 21:14 ybychkov
+2004-05-17 21:14 Yury Bychkov <me at yury.ca>
- * source/geom/GeometryCollection.cpp, source/headers/geom.h:
+ * [r384] source/geom/GeometryCollection.cpp, source/headers/geom.h:
JavaDoc updated
-2004-05-17 21:09 ybychkov
+2004-05-17 21:09 Yury Bychkov <me at yury.ca>
+ * [r383] source/geom/BasicCoordinateList.cpp,
source/geom/PointCoordinateList.cpp: toString() performance
enhancement
-2004-05-17 21:03 ybychkov
+2004-05-17 21:03 Yury Bychkov <me at yury.ca>
- * source/geom/CoordinateList.cpp, source/headers/geom.h: JavaDoc
- updated
+ * [r382] source/geom/CoordinateList.cpp, source/headers/geom.h:
+ JavaDoc updated
-2004-05-17 12:54 strk
+2004-05-17 12:54 Sandro Santilli <strk at keybit.net>
- * source/io/markup/MarkupSTL.cpp: Added tab in list of blank chars
+ * [r381] source/io/markup/MarkupSTL.cpp: Added tab in list of blank
+ chars
-2004-05-17 12:53 strk
+2004-05-17 12:53 Sandro Santilli <strk at keybit.net>
- * source/test/XMLTester.cpp: Expected result string trimmed for
- blanks
+ * [r380] source/test/XMLTester.cpp: Expected result string trimmed
+ for blanks
-2004-05-17 12:37 strk
+2004-05-17 12:37 Sandro Santilli <strk at keybit.net>
- * source/io/StringTokenizer.cpp: Added carriage returns and tabs in
- set of blanks chars
+ * [r379] source/io/StringTokenizer.cpp: Added carriage returns and
+ tabs in set of blanks chars
-2004-05-17 12:36 strk
+2004-05-17 12:36 Sandro Santilli <strk at keybit.net>
- * source/io/ParseException.cpp: ParseException message made more
- readable
+ * [r378] source/io/ParseException.cpp: ParseException message made
+ more readable
-2004-05-17 10:45 strk
+2004-05-17 10:45 Sandro Santilli <strk at keybit.net>
- * source/geom/PrecisionModel.cpp: Fixed bogus FIXED coordinate
- rounding
+ * [r377] source/geom/PrecisionModel.cpp: Fixed bogus FIXED
+ coordinate rounding
-2004-05-17 08:34 strk
+2004-05-17 08:34 Sandro Santilli <strk at keybit.net>
- * source/operation/overlay/OverlayOp.cpp: reduced stack
+ * [r376] source/operation/overlay/OverlayOp.cpp: reduced stack
allocations, try/catch blocks in ::overlayOp
-2004-05-17 07:42 strk
+2004-05-17 07:42 Sandro Santilli <strk at keybit.net>
- * source/algorithm/CentroidArea.cpp: CentroidArea::add(const
+ * [r375] source/algorithm/CentroidArea.cpp: CentroidArea::add(const
Geometry *geom) uses dynamic_cast
-2004-05-17 07:23 strk
+2004-05-17 07:23 Sandro Santilli <strk at keybit.net>
- * source/geom/Geometry.cpp: ::getCeontroid(): reduced dynamic
- allocations, added missing check for isEmpty
+ * [r374] source/geom/Geometry.cpp: ::getCeontroid(): reduced
+ dynamic allocations, added missing check for isEmpty
-2004-05-14 14:47 strk
+2004-05-14 14:47 Sandro Santilli <strk at keybit.net>
- * source/operation/distance/ConnectedElementLocationFilter.cpp:
+ * [r373]
+ source/operation/distance/ConnectedElementLocationFilter.cpp:
Added LinearRing support
-2004-05-14 14:45 strk
+2004-05-14 14:45 Sandro Santilli <strk at keybit.net>
- * source/headers/geomUtil.h: Fixed bogus inheritance of
+ * [r372] source/headers/geomUtil.h: Fixed bogus inheritance of
LinearComponentExtracter
-2004-05-14 13:42 strk
+2004-05-14 13:42 Sandro Santilli <strk at keybit.net>
- * source/geom/LineSegment.cpp,
+ * [r371] source/geom/LineSegment.cpp,
source/geom/util/LinearComponentExtracter.cpp,
source/geom/util/PointExtracter.cpp,
source/geom/util/PolygonExtracter.cpp, source/headers/geomUtil.h,
@@ -17400,65 +17746,68 @@
source/operation/distance/DistanceOp.cpp: DistanceOp bug removed,
cascading errors fixed.
-2004-05-14 12:14 strk
+2004-05-14 12:14 Sandro Santilli <strk at keybit.net>
- * source/geom/Geometry.cpp, source/headers/geom.h: const
+ * [r370] source/geom/Geometry.cpp, source/headers/geom.h: const
correctness
-2004-05-14 12:10 strk
+2004-05-14 12:10 Sandro Santilli <strk at keybit.net>
- * source/io/WKTReader.cpp: avoided leaks on malformed LinearRing
+ * [r369] source/io/WKTReader.cpp: avoided leaks on malformed
+ LinearRing
-2004-05-14 09:20 strk
+2004-05-14 09:20 Sandro Santilli <strk at keybit.net>
- * source/geom/util/LinearComponentExtracter.cpp,
+ * [r368] source/geom/util/LinearComponentExtracter.cpp,
source/geom/util/PolygonExtracter.cpp: Mem leaks fixed
-2004-05-14 07:19 strk
+2004-05-14 07:19 Sandro Santilli <strk at keybit.net>
- * source/test/XMLTester.cpp: Changed the algorythm for finding
- precisionModel type (current way did
+ * [r367] source/test/XMLTester.cpp: Changed the algorythm for
+ finding precisionModel type (current way did
not work): now if you specify a scale precisionModel will be
FIXED,
otherwise it will be FLOATING.
-2004-05-07 14:15 strk
+2004-05-07 14:15 Sandro Santilli <strk at keybit.net>
- * source/io/StringTokenizer.cpp: fixed peekNextToken to avoid
- incrementing string pointer
+ * [r366] source/io/StringTokenizer.cpp: fixed peekNextToken to
+ avoid incrementing string pointer
-2004-05-07 14:13 strk
+2004-05-07 14:13 Sandro Santilli <strk at keybit.net>
- * source/index/bintree/Bintree.cpp: Fixed segfault in ::insert
+ * [r365] source/index/bintree/Bintree.cpp: Fixed segfault in
+ ::insert
-2004-05-07 14:12 strk
+2004-05-07 14:12 Sandro Santilli <strk at keybit.net>
- * source/algorithm/InteriorPointArea.cpp: Fixed segfault in
+ * [r364] source/algorithm/InteriorPointArea.cpp: Fixed segfault in
destructor
-2004-05-07 13:23 strk
+2004-05-07 13:23 Sandro Santilli <strk at keybit.net>
- * source/io/WKTReader.cpp, source/test/XMLTester.cpp: Memory leaks
- fixed.
+ * [r363] source/io/WKTReader.cpp, source/test/XMLTester.cpp: Memory
+ leaks fixed.
-2004-05-07 13:04 strk
+2004-05-07 13:04 Sandro Santilli <strk at keybit.net>
- * source/geom/MultiLineString.cpp: leak removed in
+ * [r362] source/geom/MultiLineString.cpp: leak removed in
MultiLineString::getBoundary()
-2004-05-07 09:05 strk
+2004-05-07 09:05 Sandro Santilli <strk at keybit.net>
+ * [r361] source/geom/Geometry.cpp,
source/geom/MultiPolygon.cpp, source/headers/geom.h: Some const
correctness added. Fixed bug in GeometryFactory::createMultiPoint
to handle NULL CoordinateList.
-2004-05-07 07:57 strk
+2004-05-07 07:57 Sandro Santilli <strk at keybit.net>
- * source/geom/Makefile.am, source/headers/noding.h,
+ * [r360] source/geom/Makefile.am, source/headers/noding.h,
source/headers/opBuffer.h, source/noding/SegmentString.cpp,
source/operation/buffer/OffsetCurveSetBuilder.cpp: Added missing
EdgeNodingValidator to build scripts.
@@ -17466,17 +17815,18 @@
(takes const void *), implemented local tracking of "contexts"
in caller objects for proper destruction.
-2004-05-06 16:30 strk
+2004-05-06 16:30 Sandro Santilli <strk at keybit.net>
- * source/headers/indexBintree.h, source/headers/indexQuadtree.h,
- source/index/bintree/Bintree.cpp,
+ * [r359] source/headers/indexBintree.h,
+ source/headers/indexQuadtree.h, source/index/bintree/Bintree.cpp,
source/index/quadtree/Quadtree.cpp: Kept track of newly allocated
objects by ensureExtent for Bintree and Quadtree,
deleted at destruction time. doc/example.cpp runs with no leaks.
-2004-05-06 15:54 strk
+2004-05-06 15:54 Sandro Santilli <strk at keybit.net>
- * source/headers/noding.h, source/noding/SegmentNodeList.cpp,
+ * [r358] source/headers/noding.h,
+ source/noding/SegmentNodeList.cpp,
SegmentNodeList keeps track of created splitEdges for later
@@ -17484,9 +17834,9 @@
SegmentString constructor copies given Label.
Buffer operation does no more leaks for doc/example.cpp
-2004-05-06 15:00 strk
+2004-05-06 15:00 Sandro Santilli <strk at keybit.net>
- * source/headers/indexStrtree.h,
+ * [r357] source/headers/indexStrtree.h,
source/index/strtree/AbstractSTRtree.cpp,
source/index/strtree/ItemBoundable.cpp,
source/index/strtree/SIRtree.cpp,
@@ -17496,18 +17846,19 @@
used to keep track of created node to cleanly delete them at
destruction time.
-2004-05-06 13:58 strk
+2004-05-06 13:58 Sandro Santilli <strk at keybit.net>
- * source/index/strtree/STRtree.cpp: leak removed from
+ * [r356] source/index/strtree/STRtree.cpp: leak removed from
createParentBoundablesFromVerticalSlices
-2004-05-06 08:59 strk
+2004-05-06 08:59 Sandro Santilli <strk at keybit.net>
- * source/index/strtree/AbstractSTRtree.cpp: memory leak fixed
+ * [r355] source/index/strtree/AbstractSTRtree.cpp: memory leak
+ fixed
-2004-05-05 17:42 strk
+2004-05-05 17:42 Sandro Santilli <strk at keybit.net>
+ * [r354] source/headers/indexStrtree.h,
source/index/strtree/STRtree.cpp: AbstractNode destructor made
@@ -17518,75 +17869,75 @@
appropriate
Class in the subClasses).
-2004-05-05 16:57 strk
+2004-05-05 16:57 Sandro Santilli <strk at keybit.net>
+ * [r353] source/headers/opBuffer.h,
source/operation/buffer/BufferBuilder.cpp: Rewritten static cga
allocation to avoid copy constructor calls.
-2004-05-05 16:51 strk
+2004-05-05 16:51 Sandro Santilli <strk at keybit.net>
- * source/geom/Geometry.cpp: avoided copy constructor in
+ * [r352] source/geom/Geometry.cpp: avoided copy constructor in
Geometry::geometryChangedFilter initializzazion
-2004-05-05 16:39 strk
+2004-05-05 16:39 Sandro Santilli <strk at keybit.net>
- * source/noding/MCQuadtreeNoder.cpp: reduced explicit local objects
- allocation
+ * [r351] source/noding/MCQuadtreeNoder.cpp: reduced explicit local
+ objects allocation
-2004-05-05 16:36 strk
+2004-05-05 16:36 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferBuilder.cpp: Avoid use of copy
- c'tors on local objects initializzation
+ * [r350] source/operation/buffer/BufferBuilder.cpp: Avoid use of
+ copy c'tors on local objects initializzation
-2004-05-05 15:51 strk
+2004-05-05 15:51 Sandro Santilli <strk at keybit.net>
- * source/noding/MCQuadtreeNoder.cpp: Fixed big leak in
+ * [r349] source/noding/MCQuadtreeNoder.cpp: Fixed big leak in
intersectChains()
-2004-05-05 13:08 strk
+2004-05-05 13:08 Sandro Santilli <strk at keybit.net>
+ * [r348] source/algorithm/MinimumDiameter.cpp,
source/operation/buffer/OffsetCurveSetBuilder.cpp: Leaks fixed,
explicit allocations/deallocations reduced.
-2004-05-05 12:29 strk
+2004-05-05 12:29 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/SubgraphDepthLocater.cpp: memleak fixed
- in ::getDepth
+ * [r347] source/operation/buffer/SubgraphDepthLocater.cpp: memleak
+ fixed in ::getDepth
-2004-05-05 12:20 strk
+2004-05-05 12:20 Sandro Santilli <strk at keybit.net>
- * source/geom/util/GeometryEditor.cpp: Memory leak plugged in
- editGeometryCollection
+ * [r346] source/geom/util/GeometryEditor.cpp: Memory leak plugged
+ in editGeometryCollection
-2004-05-05 10:54 strk
+2004-05-05 10:54 Sandro Santilli <strk at keybit.net>
- * source/geom/Geometry.cpp, source/headers/geom.h,
+ * [r345] source/geom/Geometry.cpp, source/headers/geom.h,
source/headers/opBuffer.h, source/io/Unload.cpp,
source/operation/buffer/BufferBuilder.cpp: Removed some private
static heap explicit allocation, less cleanup done by
the unloader.
-2004-05-05 10:44 strk
+2004-05-05 10:44 Sandro Santilli <strk at keybit.net>
- * TODO: updated
+ * [r344] TODO: updated
-2004-05-05 10:22 strk
+2004-05-05 10:22 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferOp.cpp: Removed dynamic
+ * [r343] source/operation/buffer/BufferOp.cpp: Removed dynamic
allocations.
-2004-05-05 10:03 strk
+2004-05-05 10:03 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferOp.cpp: Reduced dynamic allocations
- in bufferOriginalPrecision and bufferFixedPrecision.
+ * [r342] source/operation/buffer/BufferOp.cpp: Reduced dynamic
+ allocations in bufferOriginalPrecision and bufferFixedPrecision.
-2004-05-03 22:56 strk
+2004-05-03 22:56 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/EdgeList.cpp, source/headers/noding.h,
+ * [r341] source/geomgraph/EdgeList.cpp, source/headers/noding.h,
source/noding/IteratedNoder.cpp,
source/noding/MCQuadtreeNoder.cpp, source/noding/Noder.cpp,
@@ -17596,16 +17947,16 @@
source/operation/buffer/SubgraphDepthLocater.cpp: leaks fixed,
exception specification omitted.
-2004-05-03 20:49 strk
+2004-05-03 20:49 Sandro Santilli <strk at keybit.net>
+ * [r340] source/geom/util/LinearComponentExtracter.cpp,
source/noding/SegmentNodeList.cpp: Some more leaks fixed
-2004-05-03 17:15 strk
+2004-05-03 17:15 Sandro Santilli <strk at keybit.net>
- * source/geom/util/GeometryEditor.cpp, source/headers/precision.h,
- source/index/strtree/STRtree.cpp,
+ * [r339] source/geom/util/GeometryEditor.cpp,
+ source/headers/precision.h, source/index/strtree/STRtree.cpp,
source/operation/buffer/BufferOp.cpp,
source/operation/buffer/BufferSubgraph.cpp,
@@ -17613,9 +17964,9 @@
source/precision/SimpleGeometryPrecisionReducer.cpp: leaks on
exception fixed.
-2004-05-03 16:29 strk
+2004-05-03 16:29 Sandro Santilli <strk at keybit.net>
+ * [r338] source/headers/indexStrtree.h,
source/index/strtree/STRtree.cpp: Added sortBoundables(const
@@ -17624,22 +17975,22 @@
in STRtree.cpp
and SIRtree.cpp.
-2004-05-03 13:17 strk
+2004-05-03 13:17 Sandro Santilli <strk at keybit.net>
+ * [r337] source/headers/indexStrtree.h,
source/index/strtree/AbstractSTRtree.cpp: Fixed comparator
function to express StrictWeakOrdering.
-2004-05-03 12:09 strk
+2004-05-03 12:09 Sandro Santilli <strk at keybit.net>
- * source/noding/Noder.cpp, source/noding/SegmentNode.cpp,
+ * [r336] source/noding/Noder.cpp, source/noding/SegmentNode.cpp,
source/noding/nodingSegmentIntersector.cpp,
source/planargraph/planarNodeMap.cpp: newline added at end of
file
-2004-05-03 10:43 strk
+2004-05-03 10:43 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/DirectedEdgeStar.cpp,
+ * [r335] source/geomgraph/DirectedEdgeStar.cpp,
source/geomgraph/EdgeEndStar.cpp,
source/geomgraph/PlanarGraph.cpp, source/headers/geomgraph.h,
@@ -17650,17 +18001,17 @@
source/planargraph/planarDirectedEdge.cpp: Exception
specification considered harmful - left as comment.
-2004-04-30 09:15 strk
+2004-04-30 09:15 Sandro Santilli <strk at keybit.net>
- * source/geom/Geometry.cpp, source/headers/noding.h,
+ * [r334] source/geom/Geometry.cpp, source/headers/noding.h,
source/headers/opBuffer.h, source/noding/IteratedNoder.cpp,
source/operation/buffer/BufferBuilder.cpp: Enlarged exception
specifications to allow for AssertionFailedException.
Added missing initializers.
-2004-04-28 14:58 strk
+2004-04-28 14:58 Sandro Santilli <strk at keybit.net>
- * source/index/strtree/AbstractSTRtree.cpp: Made
+ * [r333] source/index/strtree/AbstractSTRtree.cpp: Made
AbstractSTRtree::query use dynamic_cast<> to simulate java's
instanceof. Previous typeid(*) use missed to catch an
STRAbstractNode
@@ -17669,59 +18020,61 @@
SIGABORT
are no more raised.
-2004-04-26 22:00 pramsey
+2004-04-26 22:00 Paul Ramsey <pramsey at cleverelephant.ca>
- * configure.in: Bump version number to 1.4 to indicate new changes.
+ * [r332] configure.in: Bump version number to 1.4 to indicate new
+ changes.
-2004-04-26 12:37 strk
+2004-04-26 12:37 Sandro Santilli <strk at keybit.net>
- * source/index/strtree/AbstractSTRtree.cpp,
+ * [r331] source/index/strtree/AbstractSTRtree.cpp,
source/index/strtree/STRtree.cpp: Some leaks fixed.
-2004-04-23 00:02 strk
+2004-04-23 00:02 Sandro Santilli <strk at keybit.net>
- * source/headers/noding.h, source/headers/opBuffer.h,
+ * [r330] source/headers/noding.h, source/headers/opBuffer.h,
source/operation/buffer/BufferOp.cpp: const-correctness changes
-2004-04-21 14:14 strk
+2004-04-21 14:14 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/DirectedEdgeStar.cpp: Fixed bug in computeDepths
+ * [r329] source/geomgraph/DirectedEdgeStar.cpp: Fixed bug in
+ computeDepths
-2004-04-20 13:24 strk
+2004-04-20 13:24 Sandro Santilli <strk at keybit.net>
- * source/algorithm/ConvexHull.cpp,
+ * [r328] source/algorithm/ConvexHull.cpp,
source/algorithm/MinimumDiameter.cpp, source/geom/LineString.cpp,
source/geom/LinearRing.cpp, source/geom/Polygon.cpp,
source/operation/overlay/OverlayOp.cpp: More leaks removed.
-2004-04-20 12:47 strk
+2004-04-20 12:47 Sandro Santilli <strk at keybit.net>
- * source/algorithm/MinimumDiameter.cpp,
+ * [r327] source/algorithm/MinimumDiameter.cpp,
source/headers/geosAlgorithm.h: MinimumDiameter leaks plugged.
-2004-04-20 10:58 strk
+2004-04-20 10:58 Sandro Santilli <strk at keybit.net>
+ * [r326] source/headers/opBuffer.h,
source/operation/buffer/OffsetCurveSetBuilder.cpp: More memory
leaks removed.
-2004-04-20 10:14 strk
+2004-04-20 10:14 Sandro Santilli <strk at keybit.net>
- * source/algorithm/MinimumDiameter.cpp, source/geom/Geometry.cpp,
- source/geom/util/GeometryEditor.cpp,
+ * [r325] source/algorithm/MinimumDiameter.cpp,
+ source/geom/Geometry.cpp, source/geom/util/GeometryEditor.cpp,
source/precision/SimpleGeometryPrecisionReducer.cpp: Memory leaks
removed.
-2004-04-20 08:52 strk
+2004-04-20 08:52 Sandro Santilli <strk at keybit.net>
+ * [r324] source/geom/GeometryCollection.cpp,
@@ -17733,19 +18086,20 @@
Memory leaks removed from SimpleGeometryPrecisionReducer
and GeometryFactory.
-2004-04-19 16:14 strk
+2004-04-19 16:14 Sandro Santilli <strk at keybit.net>
- * source/headers/noding.h, source/noding/IteratedNoder.cpp,
+ * [r323] source/headers/noding.h, source/noding/IteratedNoder.cpp,
source/operation/buffer/OffsetCurveSetBuilder.cpp: Some memory
leaks plugged in noding algorithms.
-2004-04-19 15:14 strk
+2004-04-19 15:14 Sandro Santilli <strk at keybit.net>
- * source/geomgraph/PlanarGraph.cpp, source/headers/indexQuadtree.h,
- source/headers/opBuffer.h, source/headers/spatialIndex.h,
+ * [r322] source/geomgraph/PlanarGraph.cpp,
+ source/headers/indexQuadtree.h, source/headers/opBuffer.h,
+ source/headers/spatialIndex.h,
source/index/quadtree/Quadtree.cpp,
@@ -17754,141 +18108,144 @@
virtual destructor in SpatialIndex class.
Memory leaks fixes. Const and throw specifications added.
-2004-04-19 12:51 strk
+2004-04-19 12:51 Sandro Santilli <strk at keybit.net>
+ * [r321] source/headers/noding.h, source/headers/opBuffer.h,
source/operation/buffer/BufferOp.cpp: Memory leaks fixes. Throw
-2004-04-16 14:12 strk
+2004-04-16 14:12 Sandro Santilli <strk at keybit.net>
- * source/geom/Point.cpp: Memory leak fix in copy constructor
+ * [r320] source/geom/Point.cpp: Memory leak fix in copy constructor
-2004-04-16 14:09 strk
+2004-04-16 14:09 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferOp.cpp: Leaks fixes
+ * [r319] source/operation/buffer/BufferOp.cpp: Leaks fixes
-2004-04-16 13:03 strk
+2004-04-16 13:03 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/OffsetCurveBuilder.cpp: More leaks fixed
+ * [r318] source/operation/buffer/OffsetCurveBuilder.cpp: More leaks
+ fixed
-2004-04-16 12:48 strk
+2004-04-16 12:48 Sandro Santilli <strk at keybit.net>
- * source/noding/IteratedNoder.cpp,
+ * [r317] source/noding/IteratedNoder.cpp,
source/operation/buffer/OffsetCurveBuilder.cpp: Leak fixes.
-2004-04-16 11:04 strk
+2004-04-16 11:04 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferOp.cpp: Memory leaks plugged on
- exception thrown
+ * [r316] source/operation/buffer/BufferOp.cpp: Memory leaks plugged
+ on exception thrown
-2004-04-16 10:00 strk
+2004-04-16 10:00 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferOp.cpp: Memory leak fixed.
+ * [r315] source/operation/buffer/BufferOp.cpp: Memory leak fixed.
-2004-04-16 09:01 strk
+2004-04-16 09:01 Sandro Santilli <strk at keybit.net>
- * source/algorithm/CGAlgorithms.cpp: Removed memory leak in
+ * [r314] source/algorithm/CGAlgorithms.cpp: Removed memory leak in
CGAlgorithms::isOnline
-2004-04-16 08:52 strk
+2004-04-16 08:52 Sandro Santilli <strk at keybit.net>
- * source/headers/planargraph.h, source/io/Unload.cpp:
+ * [r313] source/headers/planargraph.h, source/io/Unload.cpp:
Unload::Release final delete (static heap allocations should be
gone now)
-2004-04-16 08:35 strk
+2004-04-16 08:35 Sandro Santilli <strk at keybit.net>
+ * [r312] source/geom/GeometryFactory.cpp, source/geom/Point.cpp,
source/headers/geom.h: Memory leaks fixed and const correctness
applied for Point class.
-2004-04-16 07:42 strk
+2004-04-16 07:42 Sandro Santilli <strk at keybit.net>
- * source/geom/PrecisionModel.cpp, source/headers/geom.h,
+ * [r311] source/geom/PrecisionModel.cpp, source/headers/geom.h,
source/io/Unload.cpp: PrecisionModel::Type made an enum instead
of a Type.
-2004-04-15 15:11 strk
+2004-04-15 15:11 Sandro Santilli <strk at keybit.net>
- * source/io/Unload.cpp: Commented out deletion that seems to cause
- segfaults
+ * [r310] source/io/Unload.cpp: Commented out deletion that seems to
+ cause segfaults
-2004-04-15 14:00 strk
+2004-04-15 14:00 Sandro Santilli <strk at keybit.net>
- * source/headers/geom.h, source/headers/opBuffer.h,
+ * [r309] source/headers/geom.h, source/headers/opBuffer.h,
source/io/Unload.cpp: Added new cleanup to Unload::Release
-2004-04-14 13:56 strk
+2004-04-14 13:56 Sandro Santilli <strk at keybit.net>
- * source/geom/Geometry.cpp, source/headers/geom.h: All geometries
- returned by {from,to}InternalGeometry calls are
+ * [r308] source/geom/Geometry.cpp, source/headers/geom.h: All
+ geometries returned by {from,to}InternalGeometry calls are
now deleted after use (unless NOT new).
Some 'commented' throw specifications in geom.h
-2004-04-14 13:14 strk
+2004-04-14 13:14 Sandro Santilli <strk at keybit.net>
- * source/operation/overlay/OverlayOp.cpp: Removed deletion of
- externally pointed GeometryFactory from OverlayOp destructor
+ * [r307] source/operation/overlay/OverlayOp.cpp: Removed deletion
+ of externally pointed GeometryFactory from OverlayOp destructor
-2004-04-14 12:28 strk
+2004-04-14 12:28 Sandro Santilli <strk at keybit.net>
+ * [r306] source/geom/GeometryCollection.cpp,
source/index/strtree/AbstractSTRtree.cpp: shouldNeverReachHere
exceptions made more verbose
-2004-04-14 11:05 strk
+2004-04-14 11:05 Sandro Santilli <strk at keybit.net>
- * source/geom/util/GeometryEditor.cpp: Added support for LinearRing
- in GeometryEditor
+ * [r305] source/geom/util/GeometryEditor.cpp: Added support for
+ LinearRing in GeometryEditor
-2004-04-14 10:56 strk
+2004-04-14 10:56 Sandro Santilli <strk at keybit.net>
- * source/operation/distance/DistanceOp.cpp: Uncommented
+ * [r304] source/operation/distance/DistanceOp.cpp: Uncommented
initializzazion and destruction of
DistanceOp::minDistanceLocation
-2004-04-14 09:38 strk
+2004-04-14 09:38 Sandro Santilli <strk at keybit.net>
- * source/geom/PrecisionModel.cpp: PrecisionModel(double newScale)
- missed to set the scale
+ * [r303] source/geom/PrecisionModel.cpp: PrecisionModel(double
+ newScale) missed to set the scale
-2004-04-14 09:30 strk
+2004-04-14 09:30 Sandro Santilli <strk at keybit.net>
- * source/headers/noding.h, source/noding/IteratedNoder.cpp: Private
- iterated noding funx now use int* instead of vector to know
+ * [r302] source/headers/noding.h, source/noding/IteratedNoder.cpp:
+ Private iterated noding funx now use int* instead of vector to
+ know
when it's time to stop.
-2004-04-14 09:11 strk
+2004-04-14 09:11 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferOp.cpp: endCapStyle was never set
- in BufferOp contructor
+ * [r301] source/operation/buffer/BufferOp.cpp: endCapStyle was
+ never set in BufferOp contructor
-2004-04-14 08:38 strk
+2004-04-14 08:38 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferBuilder.cpp: BufferBuilder
+ * [r300] source/operation/buffer/BufferBuilder.cpp: BufferBuilder
constructor missed to initialize workingPrecisionModel
- * source/operation/buffer/BufferOp.cpp: BufferOp constructor missed
- to set argGeom
+ * [r299] source/operation/buffer/BufferOp.cpp: BufferOp constructor
+ missed to set argGeom
-2004-04-14 07:29 strk
+2004-04-14 07:29 Sandro Santilli <strk at keybit.net>
+ * [r298] source/geom/Geometry.cpp, source/geom/GeometryFactory.cpp,
source/headers/geom.h: Fixed GeometryFactory constructors to copy
given PrecisionModel. Added GeometryFactory copy constructor.
Fixed Geometry constructors to copy GeometryFactory.
-2004-04-14 06:04 ybychkov
+2004-04-14 06:04 Yury Bychkov <me at yury.ca>
- * source/geomgraph/index, source/geomgraph/index/MonotoneChain.cpp,
+ * [r297] source/geomgraph/index,
+ source/geomgraph/index/MonotoneChain.cpp,
source/geomgraph/index/MonotoneChainEdge.cpp,
source/geomgraph/index/MonotoneChainIndexer.cpp,
source/geomgraph/index/SegmentIntersector.cpp,
@@ -17899,57 +18256,58 @@
source/geomgraph/index/SweepLineSegment.cpp: "geomgraph/index"
committ problem fixed.
-2004-04-13 14:45 strk
+2004-04-13 14:45 Sandro Santilli <strk at keybit.net>
- * source/geom/Point.cpp: Removed faulty assert in constructor
+ * [r296] source/geom/Point.cpp: Removed faulty assert in
+ constructor
-2004-04-13 14:33 strk
+2004-04-13 14:33 Sandro Santilli <strk at keybit.net>
- * source/geom/Makefile.am: Added more source files
+ * [r295] source/geom/Makefile.am: Added more source files
-2004-04-13 14:28 strk
+2004-04-13 14:28 Sandro Santilli <strk at keybit.net>
- * doc/example.cpp: Removed spurious line
+ * [r294] doc/example.cpp: Removed spurious line
-2004-04-13 13:31 strk
+2004-04-13 13:31 Sandro Santilli <strk at keybit.net>
- * source/headers/precision.h: prototype mismatch fixed
+ * [r293] source/headers/precision.h: prototype mismatch fixed
-2004-04-13 12:29 strk
+2004-04-13 12:29 Sandro Santilli <strk at keybit.net>
- * source/headers/opDistance.h,
+ * [r292] source/headers/opDistance.h,
source/operation/distance/GeometryLocation.cpp: GeometryLocation
const-correctness.
-2004-04-13 11:04 strk
+2004-04-13 11:04 Sandro Santilli <strk at keybit.net>
- * source/headers/Makefile.am: Added lost opDistance.h
+ * [r291] source/headers/Makefile.am: Added lost opDistance.h
-2004-04-13 11:03 strk
+2004-04-13 11:03 Sandro Santilli <strk at keybit.net>
- * source/headers/Makefile.am: Added new header files
+ * [r290] source/headers/Makefile.am: Added new header files
-2004-04-13 10:58 strk
+2004-04-13 10:58 Sandro Santilli <strk at keybit.net>
- * source/geom/Makefile.am: Added new source files
+ * [r289] source/geom/Makefile.am: Added new source files
-2004-04-13 10:05 strk
+2004-04-13 10:05 Sandro Santilli <strk at keybit.net>
+ * [r288] source/headers/opDistance.h,
source/operation/distance/DistanceOp.cpp,
constructor made const-correct.
Fixed erroneus down-casting in
DistanceOp::computeMinDistancePoints.
-2004-04-13 08:15 strk
+2004-04-13 08:15 Sandro Santilli <strk at keybit.net>
- * source/headers/geom.h: Changed all 'long long' with int64.
+ * [r287] source/headers/geom.h: Changed all 'long long' with int64.
Changed all 'long long' constants to end with two Ls.
-2004-04-10 22:41 ybychkov
+2004-04-10 22:41 Yury Bychkov <me at yury.ca>
- * VisualStudio/GEOS.vcproj, source/geom/LineString.cpp,
+ * [r286] VisualStudio/GEOS.vcproj, source/geom/LineString.cpp,
source/geom/Point.cpp, source/headers/geom.h,
source/headers/precision.h, source/headers/util.h,
source/operation/buffer/BufferOp.cpp, source/precision,
@@ -17961,11 +18319,11 @@
source/util/UniqueCoordinateArrayFilter.cpp: "precision" upgraded
to JTS 1.4
-2004-04-10 08:40 ybychkov
+2004-04-10 08:40 Yury Bychkov <me at yury.ca>
- * VisualStudio/GEOS.vcproj, source/geomgraph/PlanarGraph.cpp,
- source/headers/geomgraph.h, source/headers/opBuffer.h,
- source/headers/opOverlay.h,
+ * [r285] VisualStudio/GEOS.vcproj,
+ source/geomgraph/PlanarGraph.cpp, source/headers/geomgraph.h,
+ source/headers/opBuffer.h, source/headers/opOverlay.h,
source/operation/buffer/BufferEdgeBuilder.cpp,
source/operation/buffer/BufferLineBuilder.cpp,
@@ -17980,9 +18338,9 @@
source/operation/overlay/PolygonBuilder.cpp: "operation/buffer"
upgraded to JTS 1.4
-2004-04-08 04:53 ybychkov
+2004-04-08 04:53 Yury Bychkov <me at yury.ca>
- * VisualStudio/GEOS.vcproj, source/headers/opPolygonize.h,
+ * [r284] VisualStudio/GEOS.vcproj, source/headers/opPolygonize.h,
source/operation/polygonize,
source/operation/polygonize/PolygonizeDirectedEdge.cpp,
source/operation/polygonize/PolygonizeEdge.cpp,
@@ -17991,9 +18349,9 @@
source/operation/polygonize/polygonizeEdgeRing.cpp:
"operation/polygonize" ported from JTS 1.4
-2004-04-07 06:55 ybychkov
+2004-04-07 06:55 Yury Bychkov <me at yury.ca>
- * VisualStudio/GEOS.vcproj, source/geom/CoordinateList.cpp,
+ * [r283] VisualStudio/GEOS.vcproj, source/geom/CoordinateList.cpp,
source/headers/geom.h, source/headers/opLinemerge.h,
source/headers/planargraph.h, source/operation/linemerge,
source/operation/linemerge/EdgeString.cpp,
@@ -18006,11 +18364,12 @@
source/planargraph/planarPlanarGraph.cpp: "operation/linemerge"
ported from JTS 1.4
-2004-04-05 06:35 ybychkov
+2004-04-05 06:35 Yury Bychkov <me at yury.ca>
- * VisualStudio/GEOS.vcproj, source/algorithm/CGAlgorithms.cpp,
- source/geom/LineSegment.cpp, source/headers/indexStrtree.h,
- source/headers/opDistance.h, source/index/strtree/STRtree.cpp,
+ * [r282] VisualStudio/GEOS.vcproj,
+ source/algorithm/CGAlgorithms.cpp, source/geom/LineSegment.cpp,
+ source/headers/indexStrtree.h, source/headers/opDistance.h,
+ source/index/strtree/STRtree.cpp,
source/operation/distance/ConnectedElementLocationFilter.cpp,
source/operation/distance/ConnectedElementPointFilter.cpp,
@@ -18020,9 +18379,9 @@
source/operation/distance/PolygonExtracterFilter.cpp:
"operation/distance" upgraded to JTS 1.4
-2004-04-04 06:29 ybychkov
+2004-04-04 06:29 Yury Bychkov <me at yury.ca>
- * VisualStudio/GEOS.vcproj, source/geom/GeometryFactory.cpp,
+ * [r281] VisualStudio/GEOS.vcproj, source/geom/GeometryFactory.cpp,
source/geom/util, source/geom/util/GeometryEditor.cpp,
@@ -18038,26 +18397,27 @@
source/planargraph/planarNodeMap.cpp: "planargraph" and
"geom/utill" upgraded to JTS 1.4
-2004-04-01 10:44 ybychkov
+2004-04-01 10:44 Yury Bychkov <me at yury.ca>
+ * [r280] source/geom/Geometry.cpp,
source/geom/MultiPoint.cpp, source/geom/Polygon.cpp,
source/headers/geom.h, source/io/Unload.cpp: All "geom" classes
from JTS 1.3 upgraded to JTS 1.4
-2004-03-31 07:50 ybychkov
+2004-03-31 07:50 Yury Bychkov <me at yury.ca>
- * source/geom/LineString.cpp, source/geom/MultiPoint.cpp,
+ * [r279] source/geom/LineString.cpp, source/geom/MultiPoint.cpp,
source/geom/Polygon.cpp, source/geom/PrecisionModel.cpp,
source/geomgraph/EdgeNodingValidator.cpp, source/headers/geom.h:
"geom" partially upgraded to JTS 1.4
-2004-03-29 06:59 ybychkov
+2004-03-29 06:59 Yury Bychkov <me at yury.ca>
- * VisualStudio/GEOS.vcproj, source/geom/LineSegment.cpp,
+ * [r278] VisualStudio/GEOS.vcproj, source/geom/LineSegment.cpp,
source/headers/geom.h, source/headers/nodingSnapround.h,
source/headers/opOverlay.h, source/headers/opRelate.h,
source/headers/opValid.h, source/headers/operation.h,
@@ -18079,10 +18439,10 @@
"operation/overlay" upgraded to JTS 1.4;
"geom" partially upgraded.
-2004-03-26 07:48 ybychkov
+2004-03-26 07:48 Yury Bychkov <me at yury.ca>
- * VisualStudio/GEOS.vcproj, source/headers/noding.h, source/noding,
- source/noding/IteratedNoder.cpp,
+ * [r277] VisualStudio/GEOS.vcproj, source/headers/noding.h,
+ source/noding, source/noding/IteratedNoder.cpp,
source/noding/NodingValidator.cpp, source/noding/SegmentNode.cpp,
@@ -18090,9 +18450,9 @@
source/noding/nodingSegmentIntersector.cpp: "noding" package
ported (JTS 1.4)
-2004-03-25 02:23 ybychkov
+2004-03-25 02:23 Yury Bychkov <me at yury.ca>
- * source/algorithm/RobustLineIntersector.cpp, source/graph,
+ * [r276] source/algorithm/RobustLineIntersector.cpp, source/graph,
source/headers/indexBintree.h, source/headers/indexChain.h,
source/headers/indexQuadtree.h, source/headers/indexStrtree.h,
@@ -18107,11 +18467,11 @@
source/index/strtree/STRtree.cpp: All "index/*" packages upgraded
to JTS 1.4
-2004-03-19 09:49 ybychkov
+2004-03-19 09:49 Yury Bychkov <me at yury.ca>
- * VisualStudio/GEOS.vcproj, source/algorithm/PointLocator.cpp,
- source/geomgraph, source/geomgraph/Depth.cpp,
- source/geomgraph/DirectedEdge.cpp,
+ * [r275] VisualStudio/GEOS.vcproj,
+ source/algorithm/PointLocator.cpp, source/geomgraph,
+ source/geomgraph/Depth.cpp, source/geomgraph/DirectedEdge.cpp,
source/geomgraph/DirectedEdgeStar.cpp, source/geomgraph/Edge.cpp,
source/geomgraph/EdgeEnd.cpp, source/geomgraph/EdgeEndStar.cpp,
source/geomgraph/EdgeIntersection.cpp,
@@ -18144,9 +18504,9 @@
source/test/XMLTester.cpp: "geomgraph" and "geomgraph/indexl"
upgraded to JTS 1.4
-2004-03-18 10:42 ybychkov
+2004-03-18 10:42 Yury Bychkov <me at yury.ca>
- * VisualStudio/GEOS.vcproj, source/geom/Coordinate.cpp,
+ * [r274] VisualStudio/GEOS.vcproj, source/geom/Coordinate.cpp,
source/geom/CoordinateList.cpp, source/geom/Envelope.cpp,
source/geom/Triangle.cpp, source/headers/geom.h,
source/headers/io.h, source/headers/util.h,
@@ -18155,9 +18515,9 @@
"IO" and "Util" upgraded to JTS 1.4
"Geometry" partially upgraded.
-2004-03-17 02:00 ybychkov
+2004-03-17 02:00 Yury Bychkov <me at yury.ca>
- * VisualStudio/GEOS.sln, VisualStudio/GEOS.vcproj,
+ * [r273] VisualStudio/GEOS.sln, VisualStudio/GEOS.vcproj,
@@ -18174,143 +18534,147 @@
source/headers/geom.h, source/headers/geosAlgorithm.h,
source/test/Stackwalker.h: "Algorithm" upgraded to JTS 1.4
-2004-03-01 22:04 strk
+2004-03-01 22:04 Sandro Santilli <strk at keybit.net>
+ * [r272] source/geom/Geometry.cpp, source/headers/geom.h,
source/headers/opBuffer.h, source/headers/opRelate.h,
source/operation/relate/RelateOp.cpp: applied const correctness
changes by Manuel Prieto Villegas
<ManuelPrietoVillegas at telefonica.net>
-2004-02-27 17:43 strk
+2004-02-27 17:43 Sandro Santilli <strk at keybit.net>
- * source/geom/Polygon.cpp: memory leak fix in Polygon::getArea() -
- reported by 'Manuel Prieto Villegas' <mprieto at dap.es>
+ * [r271] source/geom/Polygon.cpp: memory leak fix in
+ Polygon::getArea() - reported by 'Manuel Prieto Villegas'
+ <mprieto at dap.es>
-2004-02-27 17:42 strk
+2004-02-27 17:42 Sandro Santilli <strk at keybit.net>
- * source/algorithm/CGAlgorithms.cpp,
+ * [r270] source/algorithm/CGAlgorithms.cpp,
source/headers/geosAlgorithm.h: made CGAlgorithms::signedArea()
and CGAlgorithms::length() arguments const-correct
-2004-02-20 05:44 pramsey
+2004-02-20 05:44 Paul Ramsey <pramsey at cleverelephant.ca>
- * ltmain.sh: Changed to new version of ltmain, that matches the
- version of libtool
+ * [r269] ltmain.sh: Changed to new version of ltmain, that matches
+ the version of libtool
on build box
-2004-01-20 05:51 pramsey
+2004-01-20 05:51 Paul Ramsey <pramsey at cleverelephant.ca>
- * configure.in: Change platform.h back to AM_CONFIG_HEADER.
+ * [r268] configure.in: Change platform.h back to AM_CONFIG_HEADER.
-2004-01-20 05:10 pramsey
+2004-01-20 05:10 Paul Ramsey <pramsey at cleverelephant.ca>
- * configure.in: Change AM_CONFIG_HEADER to AC_CONFIG_HEADERS to
- allow autoheader to work
+ * [r267] configure.in: Change AM_CONFIG_HEADER to AC_CONFIG_HEADERS
+ to allow autoheader to work
its magic.
-2003-12-11 17:01 strk
+2003-12-11 17:01 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferOp.cpp: made buffer(0) back to its
- *correct* semantic (empy collection)
+ * [r266] source/operation/buffer/BufferOp.cpp: made buffer(0) back
+ to its *correct* semantic (empy collection)
-2003-12-11 16:01 strk
+2003-12-11 16:01 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferOp.cpp: made buffer operation
- return a cloned input geom when called with 0 as distance
+ * [r265] source/operation/buffer/BufferOp.cpp: made buffer
+ operation return a cloned input geom when called with 0 as
+ distance
-2003-12-11 15:53 strk
+2003-12-11 15:53 Sandro Santilli <strk at keybit.net>
- * source/geom/GeometryCollection.cpp: Fixed bogus copy constructor
- (making clone bogus)
+ * [r264] source/geom/GeometryCollection.cpp: Fixed bogus copy
+ constructor (making clone bogus)
-2003-11-13 11:57 strk
+2003-11-13 11:57 Sandro Santilli <strk at keybit.net>
- * doc/example.cpp: bug fixed in relate call
+ * [r263] doc/example.cpp: bug fixed in relate call
-2003-11-12 22:03 strk
+2003-11-12 22:03 Sandro Santilli <strk at keybit.net>
- * doc/example.cpp: added relational operators
+ * [r262] doc/example.cpp: added relational operators
-2003-11-12 18:02 strk
+2003-11-12 18:02 Sandro Santilli <strk at keybit.net>
- * source/graph/PlanarGraph.cpp, source/headers/graph.h,
+ * [r261] source/graph/PlanarGraph.cpp, source/headers/graph.h,
source/operation/overlay/OverlayOp.cpp,
source/operation/overlay/PolygonBuilder.cpp: Added throw
specification. Fixed leaks on exceptions.
-2003-11-12 17:15 strk
+2003-11-12 17:15 Sandro Santilli <strk at keybit.net>
- * source/geom/PrecisionModel.cpp: made sure PrecisionModel scale is
- never 0
+ * [r260] source/geom/PrecisionModel.cpp: made sure PrecisionModel
+ scale is never 0
-2003-11-12 17:10 strk
+2003-11-12 17:10 Sandro Santilli <strk at keybit.net>
- * source/test/XMLTester.cpp: added missing initialization
+ * [r259] source/test/XMLTester.cpp: added missing initialization
-2003-11-12 16:14 strk
+2003-11-12 16:14 Sandro Santilli <strk at keybit.net>
- * source/headers/opOverlay.h,
+ * [r258] source/headers/opOverlay.h,
source/operation/overlay/OverlayOp.cpp: Added some more throw
specifications and cleanup on exception (leaks removed).
-2003-11-12 15:43 strk
+2003-11-12 15:43 Sandro Santilli <strk at keybit.net>
- * source/graph/DirectedEdgeStar.cpp, source/graph/EdgeEndStar.cpp,
- source/graph/GeometryGraph.cpp, source/headers/graph.h: Added
- some more throw specifications
+ * [r257] source/graph/DirectedEdgeStar.cpp,
+ source/graph/EdgeEndStar.cpp, source/graph/GeometryGraph.cpp,
+ source/headers/graph.h: Added some more throw specifications
-2003-11-12 15:02 strk
+2003-11-12 15:02 Sandro Santilli <strk at keybit.net>
- * source/test/XMLTester.cpp: more cleanup on exception
+ * [r256] source/test/XMLTester.cpp: more cleanup on exception
-2003-11-12 11:08 strk
+2003-11-12 11:08 Sandro Santilli <strk at keybit.net>
- * doc/example.cpp: removed old changelog, moved comments in the
- nice standard frame
+ * [r255] doc/example.cpp: removed old changelog, moved comments in
+ the nice standard frame
-2003-11-12 11:05 strk
+2003-11-12 11:05 Sandro Santilli <strk at keybit.net>
- * autogen.sh: added autoheader call
+ * [r254] autogen.sh: added autoheader call
-2003-11-07 17:51 strk
+2003-11-07 17:51 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferOp.cpp: Memory leak fix in
+ * [r253] source/operation/buffer/BufferOp.cpp: Memory leak fix in
insertEdge()
-2003-11-07 17:49 pramsey
+2003-11-07 17:49 Paul Ramsey <pramsey at cleverelephant.ca>
- * ChangeLog: Added current ChangeLog
+ * [r252] ChangeLog: Added current ChangeLog
-2003-11-07 17:45 strk
+2003-11-07 17:45 Sandro Santilli <strk at keybit.net>
- * source/headers/config.h.in: will be generated with ./autogen.sh
+ * [r251] source/headers/config.h.in: will be generated with
+ ./autogen.sh
-2003-11-07 14:21 strk
+2003-11-07 14:21 Sandro Santilli <strk at keybit.net>
- * Makefile.am, configure.in, doc, doc/.cvsignore, doc/Makefile,
- doc/Makefile.am: Made doc/ directory part of distribution.
- Uniformed doc build script to
+ * [r250] Makefile.am, configure.in, doc, doc/.cvsignore,
+ doc/Makefile, doc/Makefile.am: Made doc/ directory part of
+ distribution. Uniformed doc build script to
autotools.
-2003-11-07 14:19 strk
+2003-11-07 14:19 Sandro Santilli <strk at keybit.net>
- * source/headers, source/headers/.cvsignore: added config.h.in
- (missed before)
+ * [r249] source/headers, source/headers/.cvsignore: added
+ config.h.in (missed before)
-2003-11-07 14:18 strk
+2003-11-07 14:18 Sandro Santilli <strk at keybit.net>
+ * [r248] source/headers, source/headers/.cvsignore: added
+ config.h.in
-2003-11-07 01:58 pramsey
+2003-11-07 01:58 Paul Ramsey <pramsey at cleverelephant.ca>
- * AUTHORS: Added people!
+ * [r247] AUTHORS: Added people!
-2003-11-07 01:23 pramsey
+2003-11-07 01:23 Paul Ramsey <pramsey at cleverelephant.ca>
- * doc/example.cpp, source/algorithm/CGAlgorithms.cpp,
+ * [r245] doc/example.cpp, source/algorithm/CGAlgorithms.cpp,
source/algorithm/CentroidPoint.cpp,
@@ -18459,217 +18823,218 @@
headers licence notices and copyrights to all cpp and h
files.
-2003-11-06 19:04 strk
+2003-11-06 19:04 Sandro Santilli <strk at keybit.net>
- * source/graph/EdgeIntersectionList.cpp: removed useless Coordinate
- copy in ::createSplitEdge()
+ * [r244] source/graph/EdgeIntersectionList.cpp: removed useless
+ Coordinate copy in ::createSplitEdge()
-2003-11-06 18:50 strk
+2003-11-06 18:50 Sandro Santilli <strk at keybit.net>
- * doc, doc/.cvsignore: first import
+ * [r243] doc, doc/.cvsignore: first import
-2003-11-06 18:48 strk
+2003-11-06 18:48 Sandro Santilli <strk at keybit.net>
- * TODO: updated
+ * [r242] TODO: updated
- * source/operation/overlay/PolygonBuilder.cpp: added throw
+ * [r241] source/operation/overlay/PolygonBuilder.cpp: added throw
information comment in PolygonBuilder
-2003-11-06 18:47 strk
+2003-11-06 18:47 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferOp.cpp: Added throw specification
- for BufferOp's ::buildSubgraphs() and ::computeBuffer(). Cleanup
- on exception in computeBuffer().
+ * [r240] source/operation/buffer/BufferOp.cpp: Added throw
+ specification for BufferOp's ::buildSubgraphs() and
+ ::computeBuffer(). Cleanup on exception in computeBuffer().
-2003-11-06 18:46 strk
+2003-11-06 18:46 Sandro Santilli <strk at keybit.net>
- * source/headers/opBuffer.h: Added throw specification for
+ * [r239] source/headers/opBuffer.h: Added throw specification for
-2003-11-06 18:45 strk
+2003-11-06 18:45 Sandro Santilli <strk at keybit.net>
- * source/graph/DirectedEdgeStar.cpp, source/headers/graph.h: Added
- throw specification for DirectEdgeStar::linkResultDirectedEdges()
+ * [r238] source/graph/DirectedEdgeStar.cpp, source/headers/graph.h:
+ Added throw specification for
+ DirectEdgeStar::linkResultDirectedEdges()
-2003-11-06 18:00 strk
+2003-11-06 18:00 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferOp.cpp: Cleanup on exception in
- ::bufferOp()
+ * [r237] source/operation/buffer/BufferOp.cpp: Cleanup on exception
+ in ::bufferOp()
-2003-11-06 17:59 strk
+2003-11-06 17:59 Sandro Santilli <strk at keybit.net>
- * source/graph/EdgeRing.cpp: Memory leaks fixed in
+ * [r236] source/graph/EdgeRing.cpp: Memory leaks fixed in
::containsPoint()
-2003-11-06 17:48 strk
+2003-11-06 17:48 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferLineBuilder.cpp: Fixed memory leaks
- in ::closePt() and ::addLineEndCap()
+ * [r235] source/operation/buffer/BufferLineBuilder.cpp: Fixed
+ memory leaks in ::closePt() and ::addLineEndCap()
-2003-11-06 17:47 strk
+2003-11-06 17:47 Sandro Santilli <strk at keybit.net>
- * source/operation/buffer/BufferEdgeBuilder.cpp: Added support for
- LinearRing, removed memory leaks in ::addLineString
+ * [r234] source/operation/buffer/BufferEdgeBuilder.cpp: Added
+ support for LinearRing, removed memory leaks in ::addLineString
-2003-11-06 17:41 strk
+2003-11-06 17:41 Sandro Santilli <strk at keybit.net>
- * doc/example.cpp: Added Buffer,Intersection,Difference and
+ * [r233] doc/example.cpp: Added Buffer,Intersection,Difference and
Symdifference. Exception cleanup
-2003-11-06 17:33 pramsey
+2003-11-06 17:33 Paul Ramsey <pramsey at cleverelephant.ca>
- * INSTALL: Small addition of into about LD_LIBRARY_PATH
+ * [r232] INSTALL: Small addition of into about LD_LIBRARY_PATH
-2003-11-05 21:52 strk
+2003-11-05 21:52 Sandro Santilli <strk at keybit.net>
- * doc/Makefile, doc/example.cpp: Modified example.cpp to make use
- of vectors instead of Geometry * / int
+ * [r231] doc/Makefile, doc/example.cpp: Modified example.cpp to
+ make use of vectors instead of Geometry * / int
couples. Added LineString creation example. Added Makefile to
compile it.
-2003-11-03 16:09 strk
+2003-11-03 16:09 Sandro Santilli <strk at keybit.net>
- * doc/example.cpp: Removed comments about segfaults, made the
- simple collection creation call
+ * [r230] doc/example.cpp: Removed comments about segfaults, made
+ the simple collection creation call
cleaner by use of the clone() method.
-2003-10-31 16:36 strk
+2003-10-31 16:36 Sandro Santilli <strk at keybit.net>
- source/headers/geom.h: Re-introduced clone() method. Copy
- constructor could not really replace it.
+ * [r229] source/geom/GeometryCollection.cpp,
+ source/geom/LineString.cpp, source/geom/Point.cpp,
+ source/geom/Polygon.cpp, source/headers/geom.h: Re-introduced
+ clone() method. Copy constructor could not really replace it.
-2003-10-29 10:38 strk
+2003-10-29 10:38 Sandro Santilli <strk at keybit.net>
- * doc/example.cpp: Added centroid computation example
+ * [r228] doc/example.cpp: Added centroid computation example
- * source/algorithm/CentroidLine.cpp: Added support for LinearRing
- types (treated as LineString)
+ * [r227] source/algorithm/CentroidLine.cpp: Added support for
+ LinearRing types (treated as LineString)
-2003-10-24 21:27 strk
+2003-10-24 21:27 Sandro Santilli <strk at keybit.net>
- * source/headers/geom.h: Added GeometryTypeId enum and
+ * [r226] source/headers/geom.h: Added GeometryTypeId enum and
getGeometryTypeId abstract Geometry method.
-2003-10-23 09:17 strk
+2003-10-23 09:17 Sandro Santilli <strk at keybit.net>
- * source/headers, source/headers/.cvsignore: Added stamp-h2 and
- platform.h
+ * [r225] source/headers, source/headers/.cvsignore: Added stamp-h2
+ and platform.h
-2003-10-23 09:12 strk
+2003-10-23 09:12 Sandro Santilli <strk at keybit.net>
- * source/headers/util.h: Made CoordinateArrayFilter destructor
- virtual.
+ * [r224] source/headers/util.h: Made CoordinateArrayFilter
+ destructor virtual.
-2003-10-22 23:58 strk
+2003-10-22 23:58 Sandro Santilli <strk at keybit.net>
- * configure.in, source/headers/platform.h,
+ * [r223] configure.in, source/headers/platform.h,
source/headers/platform.h.in: Made platform.h be created by
configure. In this way we will not have
problems of installed headers trying to include phantom config.h.
-2003-10-22 00:44 strk
+2003-10-22 00:44 Sandro Santilli <strk at keybit.net>
- * source/headers/indexQuadtree.h, source/headers/platform.h,
+ * [r222] source/headers/indexQuadtree.h, source/headers/platform.h,
source/index/quadtree/DoubleBits.cpp: Quadtree bitfield
operations made using type int64. Type int64 typedef'ed based
on autoconf detected int type (long or long long). If long is not
64bits int64
will be really 32 bits and INT64_IS_REALLY32 will be defined.
-2003-10-21 23:51 strk
+2003-10-21 23:51 Sandro Santilli <strk at keybit.net>
- * acsite.m4, configure.in, source/headers/acconfig.h,
+ * [r221] acsite.m4, configure.in, source/headers/acconfig.h,
source/headers/config.h.in: Added macros to find 64bit integer.
-2003-10-21 16:16 strk
+2003-10-21 16:16 Sandro Santilli <strk at keybit.net>
- * doc/example.cpp: Uncommented point creation lines. Updated
+ * [r220] doc/example.cpp: Uncommented point creation lines. Updated
comments about segfaults.
-2003-10-21 05:35 pramsey
+2003-10-21 05:35 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/test/Makefile.am: Added test.xml so it gets picked up by
- 'make dist'
+ * [r219] source/test/Makefile.am: Added test.xml so it gets picked
+ up by 'make dist'
-2003-10-21 05:09 pramsey
+2003-10-21 05:09 Paul Ramsey <pramsey at cleverelephant.ca>
- * INSTALL: Added simple installation directions.
+ * [r218] INSTALL: Added simple installation directions.
-2003-10-21 04:55 pramsey
+2003-10-21 04:55 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/examples/Makefile.am, source/geom/Makefile.am,
+ * [r217] source/examples/Makefile.am, source/geom/Makefile.am,
source/test/Makefile.am: Fix up references to header files to
'make dist' works.
-2003-10-20 17:50 strk
+2003-10-20 17:50 Sandro Santilli <strk at keybit.net>
- * doc/example.cpp: added Union example
+ * [r216] doc/example.cpp: added Union example
-2003-10-20 15:41 strk
+2003-10-20 15:41 Sandro Santilli <strk at keybit.net>
+ * [r215] source/geom/Geometry.cpp, source/headers/geom.h:
Geometry::checkNotGeometryCollection made static and
non-distructive.
-2003-10-20 14:02 strk
+2003-10-20 14:02 Sandro Santilli <strk at keybit.net>
- * source/graph/EdgeRing.cpp,
+ * [r214] source/graph/EdgeRing.cpp,
source/operation/valid/ConnectedInteriorTester.cpp: more explicit
exception thrown on null Directed Edge detection
-2003-10-20 13:56 strk
+2003-10-20 13:56 Sandro Santilli <strk at keybit.net>
- * source/util/AssertionFailedException.cpp: fixed typo
+ * [r213] source/util/AssertionFailedException.cpp: fixed typo
-2003-10-20 13:53 strk
+2003-10-20 13:53 Sandro Santilli <strk at keybit.net>
- * source/graph/GeometryGraph.cpp: LinearRing handled as a
+ * [r212] source/graph/GeometryGraph.cpp: LinearRing handled as a
LineString in GeometryGraph::add(const Geometry *) - more
explicit exception thrown for unknown geometries
-2003-10-17 05:51 ybychkov
+2003-10-17 05:51 Yury Bychkov <me at yury.ca>
- * VisualStudio/GEOS.vcproj, source/geom/Polygon.cpp,
+ * [r211] VisualStudio/GEOS.vcproj, source/geom/Polygon.cpp,
source/index/quadtree/DoubleBits.cpp, source/test/XMLTester.cpp:
Fixed a small memory leak.
-2003-10-16 17:41 strk
+2003-10-16 17:41 Sandro Santilli <strk at keybit.net>
- * source/util/GEOSException.cpp,
+ * [r210] source/util/GEOSException.cpp,
source/util/UnsupportedOperationException.cpp: Fixed a bug in
GEOSException that prevented print of the type of exception
thrown.
-2003-10-16 17:33 strk
+2003-10-16 17:33 Sandro Santilli <strk at keybit.net>
- * source/operation/valid/RepeatedPointTester.cpp: dropped useless
- string() cast
+ * [r209] source/operation/valid/RepeatedPointTester.cpp: dropped
+ useless string() cast
-2003-10-16 17:05 strk
+2003-10-16 17:05 Sandro Santilli <strk at keybit.net>
- * source/geom/TopologyException.cpp, source/headers/geom.h,
+ * [r208] source/geom/TopologyException.cpp, source/headers/geom.h,
source/headers/util.h, source/util/IllegalArgumentException.cpp:
Made TopologyException inherit from GEOSException. Adjusted
IllegalArgumentException subclassing.
-2003-10-16 13:01 strk
+2003-10-16 13:01 Sandro Santilli <strk at keybit.net>
- * source/test/XMLTester.cpp: Added call to Unload::Release()
+ * [r207] source/test/XMLTester.cpp: Added call to Unload::Release()
-2003-10-16 12:09 strk
+2003-10-16 12:09 Sandro Santilli <strk at keybit.net>
- * source/test/XMLTester.cpp: bug fixed in exception handling
+ * [r206] source/test/XMLTester.cpp: bug fixed in exception handling
-2003-10-16 08:50 strk
+2003-10-16 08:50 Sandro Santilli <strk at keybit.net>
- * source/algorithm/CentroidArea.cpp,
+ * [r205] source/algorithm/CentroidArea.cpp,
source/algorithm/CentroidLine.cpp,
source/algorithm/InteriorPointArea.cpp,
source/algorithm/InteriorPointLine.cpp,
@@ -18686,13 +19051,13 @@
fixes. Improved performance by mean of more calls to new
getCoordinatesRO() when applicable.
-2003-10-16 08:48 strk
+2003-10-16 08:48 Sandro Santilli <strk at keybit.net>
- * source/test/XMLTester.cpp: Exceptions handled
+ * [r204] source/test/XMLTester.cpp: Exceptions handled
-2003-10-15 16:39 strk
+2003-10-15 16:39 Sandro Santilli <strk at keybit.net>
- * source/geom/GeometryFactory.cpp, source/graph/Edge.cpp,
+ * [r203] source/geom/GeometryFactory.cpp, source/graph/Edge.cpp,
source/graph/EdgeList.cpp, source/graph/EdgeRing.cpp,
source/graph/GeometryGraph.cpp, source/graph/PlanarGraph.cpp,
source/graph/index/MonotoneChainEdge.cpp,
@@ -18707,15 +19072,15 @@
source/operation/overlay/LineBuilder.cpp: Made
Edge::getCoordinates() return a 'const' value. Adapted code set.
-2003-10-15 15:47 strk
+2003-10-15 15:47 Sandro Santilli <strk at keybit.net>
- * source/algorithm/MCPointInRing.cpp,
+ * [r202] source/algorithm/MCPointInRing.cpp,
source/algorithm/PointLocator.cpp: Adapted to new
getCoordinatesRO() interface
-2003-10-15 15:30 strk
+2003-10-15 15:30 Sandro Santilli <strk at keybit.net>
- * source/graph/index/MonotoneChain.cpp,
+ * [r201] source/graph/index/MonotoneChain.cpp,
source/graph/index/SweepLineEvent.cpp,
source/graph/index/SweepLineSegment.cpp,
source/headers/graphindex.h: Declared a SweepLineEventOBJ from
@@ -18724,103 +19089,103 @@
* pointers.
No more compiler warnings...
-2003-10-15 11:24 strk
+2003-10-15 11:24 Sandro Santilli <strk at keybit.net>
- * source/graph/GeometryGraph.cpp,
+ * [r200] source/graph/GeometryGraph.cpp,
source/operation/valid/ConnectedInteriorTester.cpp,
source/operation/valid/IsValidOp.cpp: Use getCoordinatesRO()
introduced.
-2003-10-15 11:23 strk
+2003-10-15 11:23 Sandro Santilli <strk at keybit.net>
+ * [r199] source/geom/BasicCoordinateList.cpp,
Formalized const nature of toVector() method and of first
argument to static removeRepeatedPoints().
-2003-10-15 10:17 strk
+2003-10-15 10:17 Sandro Santilli <strk at keybit.net>
+ * [r198] source/geom/BasicCoordinateList.cpp,
source/geom/PointCoordinateList.cpp, source/headers/geom.h: Made
setPoints() get a const vector<Coordinate>.
-2003-10-15 09:54 strk
+2003-10-15 09:54 Sandro Santilli <strk at keybit.net>
- * source/geom/LineString.cpp, source/headers/geom.h: Added
+ * [r197] source/geom/LineString.cpp, source/headers/geom.h: Added
getCoordinatesRO() public method.
-2003-10-15 08:52 strk
+2003-10-15 08:52 Sandro Santilli <strk at keybit.net>
- * source/io/WKTReader.cpp: Memory leaks fixed.
+ * [r196] source/io/WKTReader.cpp: Memory leaks fixed.
-2003-10-15 08:51 strk
+2003-10-15 08:51 Sandro Santilli <strk at keybit.net>
- * TODO: Initial import
+ * [r195] TODO: Initial import
-2003-10-15 08:08 strk
+2003-10-15 08:08 Sandro Santilli <strk at keybit.net>
- * source/geom/Polygon.cpp: Memory leaks fixed. Partially due to
- getCoordinates() and GeometryCollection()
+ * [r194] source/geom/Polygon.cpp: Memory leaks fixed. Partially due
+ to getCoordinates() and GeometryCollection()
changes, partially old dated.
-2003-10-14 15:58 strk
+2003-10-14 15:58 Sandro Santilli <strk at keybit.net>
- * source/geom/GeometryFactory.cpp: Useless vector<Geometry *>
- leaking allocations removed
+ * [r193] source/geom/GeometryFactory.cpp: Useless vector<Geometry
+ *> leaking allocations removed
-2003-10-13 21:26 strk
+2003-10-13 21:26 Sandro Santilli <strk at keybit.net>
- * ., .cvsignore, macros, macros/.cvsignore, source/bigtest,
+ * [r192] ., .cvsignore, macros, macros/.cvsignore, source/bigtest,
source/bigtest/.cvsignore, source/examples,
source/examples/.cvsignore, source/geom, source/geom/.cvsignore,
source/headers, source/headers/.cvsignore, source/test,
source/test/.cvsignore: Added build time created files to
cvsignore lists
-2003-10-13 17:54 strk
+2003-10-13 17:54 Sandro Santilli <strk at keybit.net>
- IsValidOp constructor used same name for the arg and a private
- element. Fixed.
+ * [r191] source/headers/opValid.h,
+ source/operation/valid/IsValidOp.cpp: IsValidOp constructor used
+ same name for the arg and a private element. Fixed.
-2003-10-13 17:47 strk
+2003-10-13 17:47 Sandro Santilli <strk at keybit.net>
- * source/operation/overlay/MaximalEdgeRing.cpp,
+ * [r190] source/operation/overlay/MaximalEdgeRing.cpp,
source/operation/overlay/PolygonBuilder.cpp: delete statement
removed
-2003-10-13 15:39 strk
+2003-10-13 15:39 Sandro Santilli <strk at keybit.net>
+ * [r189] source/algorithm/CentroidArea.cpp,
source/algorithm/InteriorPointPoint.cpp,
source/headers/geosAlgorithm.h: Fixed some leak or fault flips
(forced copy of a single coordinate)
-2003-10-13 15:02 strk
+2003-10-13 15:02 Sandro Santilli <strk at keybit.net>
- * source/test/XMLTester.cpp: accept input file as first argument on
- cmdline
+ * [r188] source/test/XMLTester.cpp: accept input file as first
+ argument on cmdline
-2003-10-13 12:51 strk
+2003-10-13 12:51 Sandro Santilli <strk at keybit.net>
- * source/geom/Geometry.cpp, source/headers/geom.h: removed
+ * [r187] source/geom/Geometry.cpp, source/headers/geom.h: removed
sortedClasses strings array from all geometries.
-2003-10-13 09:24 strk
+2003-10-13 09:24 Sandro Santilli <strk at keybit.net>
+ * [r186] source/headers/indexQuadtree.h,
source/index/quadtree/DoubleBits.cpp: long -> long long
enlargement of types to allow for left/rigth shift of 53 bits
-2003-10-11 03:23 strk
+2003-10-11 03:23 Sandro Santilli <strk at keybit.net>
- * source/geom/LineString.cpp, source/geom/LinearRing.cpp: fixed
- spurious typos
+ * [r185] source/geom/LineString.cpp, source/geom/LinearRing.cpp:
+ fixed spurious typos
-2003-10-11 01:56 strk
+2003-10-11 01:56 Sandro Santilli <strk at keybit.net>
+ * [r184] source/algorithm/CGAlgorithms.cpp,
@@ -18891,76 +19256,76 @@
source/util/UniqueCoordinateArrayFilter.cpp: Code base padded
with 'const' keywords ;)
-2003-10-09 15:35 strk
+2003-10-09 15:35 Sandro Santilli <strk at keybit.net>
- * source/geom/GeometryFactory.cpp, source/headers/geom.h: added
- 'const' keyword to GeometryFactory constructor, Log on top of
- geom.h
+ * [r183] source/geom/GeometryFactory.cpp, source/headers/geom.h:
+ added 'const' keyword to GeometryFactory constructor, Log on top
+ of geom.h
-2003-10-09 11:20 strk
+2003-10-09 11:20 Sandro Santilli <strk at keybit.net>
- * doc/example.cpp: moved Log to a better place
+ * [r182] doc/example.cpp: moved Log to a better place
-2003-10-09 11:19 strk
+2003-10-09 11:19 Sandro Santilli <strk at keybit.net>
- * doc/example.cpp: added convexHull and PrecisionModel
+ * [r181] doc/example.cpp: added convexHull and PrecisionModel
-2003-10-09 10:14 strk
+2003-10-09 10:14 Sandro Santilli <strk at keybit.net>
- * source/geom/GeometryFactory.cpp: just a style change in top Log
- comment.
+ * [r180] source/geom/GeometryFactory.cpp: just a style change in
+ top Log comment.
-2003-10-09 10:10 strk
+2003-10-09 10:10 Sandro Santilli <strk at keybit.net>
- * source/geom/PrecisionModel.cpp: Throw an exception if scale is 0.
- Added Log entry.
+ * [r179] source/geom/PrecisionModel.cpp: Throw an exception if
+ scale is 0. Added Log entry.
-2003-10-09 09:42 strk
+2003-10-09 09:42 Sandro Santilli <strk at keybit.net>
- * source/geom/GeometryFactory.cpp: Tried to "formalize" constant
- nature of the first argument given to constructor by
+ * [r178] source/geom/GeometryFactory.cpp: Tried to "formalize"
+ constant nature of the first argument given to constructor by
PrecisionModel and SRID specification. Added CVS Log on top.
-2003-10-09 08:58 strk
+2003-10-09 08:58 Sandro Santilli <strk at keybit.net>
- * doc/example.cpp, source/algorithm/ConvexHull.cpp: Added
+ * [r177] doc/example.cpp, source/algorithm/ConvexHull.cpp: Added
convexHull() call to example, fixed leaks in ConvexHull
-2003-10-09 00:11 strk
+2003-10-09 00:11 Sandro Santilli <strk at keybit.net>
- * doc, doc/example.cpp: First reference-by-example file.
+ * [r176] doc, doc/example.cpp: First reference-by-example file.
-2003-10-08 16:51 strk
+2003-10-08 16:51 Sandro Santilli <strk at keybit.net>
- * source/geom/Makefile.am, source/headers/Makefile.am,
+ * [r175] source/geom/Makefile.am, source/headers/Makefile.am,
source/headers/geom.h, source/headers/graph.h,
source/headers/indexQuadtree.h, source/headers/opRelate.h,
source/headers/unload.h, source/io/Unload.cpp: Added xie's Unload
class with some fixes.
-2003-10-08 13:18 strk
+2003-10-08 13:18 Sandro Santilli <strk at keybit.net>
- * source/headers/io.h, source/io/WKTWriter.cpp: added missing
- LinearRing writing capabilities.
+ * [r174] source/headers/io.h, source/io/WKTWriter.cpp: added
+ missing LinearRing writing capabilities.
-2003-10-08 10:36 strk
+2003-10-08 10:36 Sandro Santilli <strk at keybit.net>
- * source/geom/GeometryCollection.cpp: Constructor by
+ * [r173] source/geom/GeometryCollection.cpp: Constructor by
vector<Geometry *> * now makes a copy of the vector so that call
ers can safely delete it when done.
-2003-10-07 21:47 strk
+2003-10-07 21:47 Sandro Santilli <strk at keybit.net>
- * source/algorithm/SimplePointInAreaLocator.cpp,
+ * [r172] source/algorithm/SimplePointInAreaLocator.cpp,
source/geom/Polygon.cpp, source/graph/EdgeRing.cpp,
source/operation/overlay/PolygonBuilder.cpp: had all
getCoordinates() callers free returned value.
-2003-10-07 18:58 strk
+2003-10-07 18:58 Sandro Santilli <strk at keybit.net>
- * source/algorithm/PointLocator.cpp,
+ * [r171] source/algorithm/PointLocator.cpp,
source/geom/GeometryCollection.cpp, source/geom/LineString.cpp,
source/graph/GeometryGraph.cpp, source/headers/config.h.in:
@@ -18969,47 +19334,49 @@
getCoordinates().
will be easier to remove by anyone else.
-2003-10-03 01:20 ybychkov
+2003-10-03 01:20 Yury Bychkov <me at yury.ca>
- * source/geom/MultiPolygon.cpp, source/test/XMLTester.cpp: Memory
- leak in Overlay fixed.
+ * [r170] source/geom/MultiPolygon.cpp, source/test/XMLTester.cpp:
+ Memory leak in Overlay fixed.
-2003-09-29 16:25 strk
+2003-09-29 16:25 Sandro Santilli <strk at keybit.net>
- * macros, macros/.cvsignore, source/bigtest,
+ * [r169] macros, macros/.cvsignore, source/bigtest,
source/examples/.cvsignore, source/headers,
source/headers/.cvsignore: Some more cvsignore files. Some
entries should probably not be
in the local copy
-2003-09-29 15:07 strk
+2003-09-29 15:07 Sandro Santilli <strk at keybit.net>
- * ., .cvsignore: Added config.sub, config.guess and autom4te.cache
+ * [r168] ., .cvsignore: Added config.sub, config.guess and
+ autom4te.cache
-2003-09-29 13:15 strk
+2003-09-29 13:15 Sandro Santilli <strk at keybit.net>
- * tools, tools/.cvsignore: Don't wonder about Makefile.in,
+ * [r167] tools, tools/.cvsignore: Don't wonder about Makefile.in,
Makefile, gdal-config
-2003-09-26 17:31 strk
+2003-09-26 17:31 Sandro Santilli <strk at keybit.net>
- * source/algorithm/ConvexHull.cpp: getConvexHull() made check value
- returned by reduce() before deleting
+ * [r166] source/algorithm/ConvexHull.cpp: getConvexHull() made
+ check value returned by reduce() before deleting
it (might be the untouched input).
-2003-09-26 09:17 ybychkov
+2003-09-26 09:17 Yury Bychkov <me at yury.ca>
- * source/index/bintree/NodeBase.cpp,
+ * [r165] source/index/bintree/NodeBase.cpp,
source/index/quadtree/QuadTreeNodeBase.cpp,
source/index/quadtree/QuadTreeRoot.cpp,
source/test/XMLTester.cpp: isValid segfault fixed. Overlay still
leaks a bit.
-2003-09-24 02:16 ybychkov
+2003-09-24 02:16 Yury Bychkov <me at yury.ca>
- * source/geom/MultiPolygon.cpp, source/graph/EdgeEndStar.cpp,
- source/index/bintree/NodeBase.cpp, source/index/bintree/Root.cpp,
+ * [r164] source/geom/MultiPolygon.cpp,
+ source/graph/EdgeEndStar.cpp, source/index/bintree/NodeBase.cpp,
+ source/index/bintree/Root.cpp,
@@ -19017,9 +19384,9 @@
source/test/XMLTester.cpp: All reported bugs fiexd. Small leak in
Overlay remains.
-2003-09-06 08:24 ybychkov
+2003-09-06 08:24 Yury Bychkov <me at yury.ca>
- * source/geom/Geometry.cpp, source/headers/opDistance.h,
+ * [r163] source/geom/Geometry.cpp, source/headers/opDistance.h,
source/operation/distance/LineExtracterFilter.cpp,
@@ -19027,9 +19394,9 @@
source/operation/distance/PolygonExtracterFilter.cpp,
source/test/XMLTester.cpp: isWithinDistance fixed and tested.
-2003-09-06 00:01 ybychkov
+2003-09-06 00:01 Yury Bychkov <me at yury.ca>
- * source/algorithm/InteriorPointArea.cpp,
+ * [r162] source/algorithm/InteriorPointArea.cpp,
source/geom/Geometry.cpp, source/graph/DirectedEdge.cpp,
@@ -19039,57 +19406,59 @@
source/test/XMLTester.cpp: getInteriorPoint bugs fixed.
-2003-09-01 06:32 ybychkov
+2003-09-01 06:32 Yury Bychkov <me at yury.ca>
- * source/algorithm/ConvexHull.cpp, source/geom/Geometry.cpp,
+ * [r161] source/algorithm/ConvexHull.cpp, source/geom/Geometry.cpp,
source/geom/Polygon.cpp, source/test/XMLTester.cpp: Some
ConvexHull bugs fixed.
-2003-08-30 07:55 ybychkov
+2003-08-30 07:55 Yury Bychkov <me at yury.ca>
- * source/algorithm/CentroidArea.cpp, source/geom/Geometry.cpp,
- source/geom/GeometryCollection.cpp, source/geom/Polygon.cpp,
- source/graph/GeometryGraph.cpp, source/operation/IsSimpleOp.cpp,
- source/test/XMLTester.cpp: Some bugfixes. XMLTester expanded to
- accomodate getBoundary, getCentroid, isSimple.
+ * [r160] source/algorithm/CentroidArea.cpp,
+ source/geom/Geometry.cpp, source/geom/GeometryCollection.cpp,
+ source/geom/Polygon.cpp, source/graph/GeometryGraph.cpp,
+ source/operation/IsSimpleOp.cpp, source/test/XMLTester.cpp: Some
+ bugfixes. XMLTester expanded to accomodate getBoundary,
+ getCentroid, isSimple.
-2003-08-18 23:40 pramsey
+2003-08-18 23:40 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/algorithm/ConvexHull.java: Removed java source file from
- archive.
+ * [r159] source/algorithm/ConvexHull.java: Removed java source file
+ from archive.
-2003-08-18 22:34 pramsey
+2003-08-18 22:34 Paul Ramsey <pramsey at cleverelephant.ca>
- * configure.in: Change it back :/
+ * [r158] configure.in: Change it back :/
-2003-08-18 22:33 pramsey
+2003-08-18 22:33 Paul Ramsey <pramsey at cleverelephant.ca>
- * configure.in: Change version number.
+ * [r157] configure.in: Change version number.
-2003-08-18 20:42 pramsey
+2003-08-18 20:42 Paul Ramsey <pramsey at cleverelephant.ca>
- * ltmain.sh: Return ltmain to distro (oops)
+ * [r156] ltmain.sh: Return ltmain to distro (oops)
-2003-08-18 20:36 pramsey
+2003-08-18 20:36 Paul Ramsey <pramsey at cleverelephant.ca>
- * mkinstalldirs: Remove more autoconf files
+ * [r155] mkinstalldirs: Remove more autoconf files
-2003-08-18 20:34 pramsey
+2003-08-18 20:34 Paul Ramsey <pramsey at cleverelephant.ca>
- * acinclude.m4, config.guess, config.sub, install-sh, ltmain.sh:
- Removed more autoconf files...
+ * [r154] acinclude.m4, config.guess, config.sub, install-sh,
+ ltmain.sh: Removed more autoconf files...
-2003-08-18 20:27 pramsey
+2003-08-18 20:27 Paul Ramsey <pramsey at cleverelephant.ca>
- * missing: Removed 'missing' script.
+ * [r153] missing: Removed 'missing' script.
-2003-08-18 16:38 pramsey
+2003-08-18 16:38 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/headers/Makefile.am: Fixed up to treat headers as headers.
+ * [r152] source/headers/Makefile.am: Fixed up to treat headers as
+ headers.
-2003-08-17 18:40 pramsey
+2003-08-17 18:40 Paul Ramsey <pramsey at cleverelephant.ca>
- * Makefile.am, source/Makefile.am,
+ * [r151] Makefile.am, source/Makefile.am,
@@ -19223,26 +19592,27 @@
global removal of "no newline" + small changes
to make Norman's patch work in the linux build environment.
-2003-08-17 18:01 pramsey
+2003-08-17 18:01 Paul Ramsey <pramsey at cleverelephant.ca>
- * libtool: Removed more configuration files per Norman's request.
+ * [r150] libtool: Removed more configuration files per Norman's
+ request.
-2003-08-17 17:56 pramsey
+2003-08-17 17:56 Paul Ramsey <pramsey at cleverelephant.ca>
- * aclocal.m4, configure: Removed more configure files per Norman's
- request.
+ * [r149] aclocal.m4, configure: Removed more configure files per
+ Norman's request.
-2003-08-17 17:55 pramsey
+2003-08-17 17:55 Paul Ramsey <pramsey at cleverelephant.ca>
- * Makefile.in, macros/Makefile.in, source/Makefile.in,
+ * [r148] Makefile.in, macros/Makefile.in, source/Makefile.in,
source/bigtest/Makefile.in, source/geom/Coordinate.cpp,
source/geom/Makefile.in, source/headers/Makefile.in,
source/test/Makefile.in, tools/Makefile.in: Removed Makefile.in
files, per Norman's request.
-2003-08-16 06:33 ybychkov
+2003-08-16 06:33 Yury Bychkov <me at yury.ca>
- * VisualStudio/GEOS.vcproj, source/algorithm/ConvexHull.cpp,
+ * [r147] VisualStudio/GEOS.vcproj, source/algorithm/ConvexHull.cpp,
source/algorithm/HCoordinate.cpp,
source/algorithm/LineIntersector.cpp,
@@ -19318,13 +19688,13 @@
source/test/XMLTester.cpp, source/util/CoordinateArrayFiter.cpp,
source/util/UniqueCoordinateArrayFilter.cpp: Memory leak fixes.
-2003-06-21 22:17 pramsey
+2003-06-21 22:17 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/geom/Makefile.am: GNU compile fixes from nvine.
+ * [r146] source/geom/Makefile.am: GNU compile fixes from nvine.
-2003-06-19 20:54 ybychkov
+2003-06-19 20:54 Yury Bychkov <me at yury.ca>
+ * [r145] source/algorithm/CGAlgorithms.cpp,
@@ -19465,9 +19835,9 @@
source/util/UnsupportedOperationException.cpp: 'geos' namespace
added.
-2003-06-18 20:08 ybychkov
+2003-06-18 20:08 Yury Bychkov <me at yury.ca>
- * source/headers/opBuffer.h, source/operation/buffer,
+ * [r144] source/headers/opBuffer.h, source/operation/buffer,
@@ -19476,90 +19846,95 @@
source/operation/buffer/RightmostEdgeFinder.cpp: Buffer is almost
fully debugged.
-2003-05-29 00:05 pramsey
+2003-05-29 00:05 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/bigtest/Makefile.am, source/geom/Makefile.am: Final GNU
- build adjustments.
+ * [r143] source/bigtest/Makefile.am, source/geom/Makefile.am: Final
+ GNU build adjustments.
-2003-05-28 23:55 pramsey
+2003-05-28 23:55 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/examples/Makefile.am: Added new exception class.
+ * [r142] source/examples/Makefile.am: Added new exception class.
-2003-05-28 23:39 pramsey
+2003-05-28 23:39 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/headers/Makefile.am: Change reference to spatialIndex.h
+ * [r141] source/headers/Makefile.am: Change reference to
+ spatialIndex.h
-2003-05-28 23:22 pramsey
+2003-05-28 23:22 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/geom/Makefile.am: Removed obsolete build entries for
- removed classes.
+ * [r140] source/geom/Makefile.am: Removed obsolete build entries
+ for removed classes.
-2003-05-28 22:22 ybychkov
+2003-05-28 22:22 Yury Bychkov <me at yury.ca>
- * source/headers/indexStrtree.h, source/index/strtree/Interval.cpp:
- Some bugfixes.
+ * [r139] source/headers/indexStrtree.h,
+ source/index/strtree/Interval.cpp: Some bugfixes.
-2003-05-28 22:11 ybychkov
+2003-05-28 22:11 Yury Bychkov <me at yury.ca>
- * source/index/bintree/Interval.cpp, source/index/bintree/Node.cpp,
- source/test/XMLTester.cpp: no message
+ * [r138] source/index/bintree/Interval.cpp,
+ source/index/bintree/Node.cpp, source/test/XMLTester.cpp: no
+ message
-2003-05-28 05:02 pramsey
+2003-05-28 05:02 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/index/strtree/Interval.cpp,
+ * [r137] source/index/strtree/Interval.cpp,
source/index/strtree/SIRtree.cpp: Changed __max/__min to max/min
-2003-05-28 05:01 pramsey
+2003-05-28 05:01 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/index/quadtree/IntervalSize.cpp: Change __max to max
+ * [r136] source/index/quadtree/IntervalSize.cpp: Change __max to
+ max
-2003-05-27 23:56 pramsey
+2003-05-27 23:56 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/geom/Makefile.am: Changed from mistaken cpp file names.
+ * [r135] source/geom/Makefile.am: Changed from mistaken cpp file
+ names.
-2003-05-27 23:54 pramsey
+2003-05-27 23:54 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/algorithm/CentroidArea.cpp: Added include for <typeinfo>
+ * [r134] source/algorithm/CentroidArea.cpp: Added include for
+ <typeinfo>
-2003-05-27 23:45 pramsey
+2003-05-27 23:45 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/headers/indexStrtree.h: GNU build support
+ * [r133] source/headers/indexStrtree.h: GNU build support
-2003-05-27 23:42 pramsey
+2003-05-27 23:42 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/headers/indexQuadtree.h: Fix reference to spatialIndex
- header
+ * [r132] source/headers/indexQuadtree.h: Fix reference to
+ spatialIndex header
-2003-05-27 23:41 pramsey
+2003-05-27 23:41 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/headers/Makefile.in, source/headers/SpatialIndex.h,
+ * [r131] source/headers/Makefile.in, source/headers/SpatialIndex.h,
source/headers/geom.h, source/headers/indexStrtree.h,
source/headers/spatialIndex.h: Build updates.
-2003-05-27 23:33 pramsey
+2003-05-27 23:33 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/geom/Makefile.am: Add new files into build support
+ * [r130] source/geom/Makefile.am: Add new files into build support
-2003-05-27 23:17 pramsey
+2003-05-27 23:17 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/headers/Makefile.am: Add all new headers into the build
- process.
+ * [r129] source/headers/Makefile.am: Add all new headers into the
+ build process.
-2003-05-27 23:11 pramsey
+2003-05-27 23:11 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/geom/Makefile.am, source/headers/Makefile.am: Some updates
- to synch build with devel.
+ * [r128] source/geom/Makefile.am, source/headers/Makefile.am: Some
+ updates to synch build with devel.
-2003-05-21 23:28 ybychkov
+2003-05-21 23:28 Yury Bychkov <me at yury.ca>
+ * [r127] source/algorithm/MCPointInRing.cpp,
source/geom/PrecisionModel.cpp, source/graph/GeometryGraph.cpp,
source/index/bintree/Key.cpp,
source/operation/relate/RelateOp.cpp: Several bugs fixed.
-2003-05-19 06:18 ybychkov
+2003-05-19 06:18 Yury Bychkov <me at yury.ca>
- * source/algorithm/HCoordinate.cpp,
+ * [r126] source/algorithm/HCoordinate.cpp,
source/algorithm/NotRepresentableException.cpp,
source/examples/CPCLException.cpp,
@@ -19590,9 +19965,9 @@
source/util/UnsupportedOperationException.cpp: All exceptions are
now classes.
-2003-05-17 07:47 ybychkov
+2003-05-17 07:47 Yury Bychkov <me at yury.ca>
+ * [r125] source/algorithm/CentroidArea.cpp,
@@ -19601,10 +19976,10 @@
source/algorithm/SIRtreePointInRing.cpp,
source/index/quadtree/QuadTreeNodeBase.cpp: Last fix for CVS.
-2003-05-17 06:08 ybychkov
+2003-05-17 06:08 Yury Bychkov <me at yury.ca>
- * source/algorithm/MCPointInRing.cpp, source/geom/Geometry.cpp,
+ * [r124] source/algorithm/MCPointInRing.cpp,
source/geom/GeometryFactory.cpp, source/graph/GeometryGraph.cpp,
source/headers/graph.h, source/headers/graphindex.h,
@@ -19613,15 +19988,15 @@
source/operation/valid/IsValidOp.cpp: Fixing CVS error.
-2003-05-17 00:27 ybychkov
+2003-05-17 00:27 Yury Bychkov <me at yury.ca>
- * source/geom/GeometryCollection.cpp,
+ * [r123] source/geom/GeometryCollection.cpp,
source/headers/geosAlgorithm.h: Fixing a commit problem.
-2003-05-17 00:07 ybychkov
+2003-05-17 00:07 Yury Bychkov <me at yury.ca>
+ * [r122] source/algorithm/MCPointInRing.cpp,
source/headers/graph.h, source/headers/opDistance.h,
@@ -19634,9 +20009,9 @@
source/operation/distance/PolygonExtracterFilter.cpp: SIRtree is
done. Distance is done.
-2003-05-07 09:06 ybychkov
+2003-05-07 09:06 Yury Bychkov <me at yury.ca>
+ * [r121] source/algorithm/CentroidArea.cpp,
source/algorithm/ConvexHull.java,
@@ -19675,9 +20050,9 @@
source/operation/valid/QuadtreeNestedRingTester.cpp: Closer to
1.3
-2003-05-04 22:34 ybychkov
+2003-05-04 22:34 Yury Bychkov <me at yury.ca>
- * source/algorithm/NonRobustCGAlgorithms.cpp,
+ * [r120] source/algorithm/NonRobustCGAlgorithms.cpp,
source/algorithm/NonRobustLineIntersector.cpp,
source/algorithm/RobustCGAlgorithms.cpp,
@@ -19696,9 +20071,9 @@
source/operation/relate/RelateOp.cpp,
source/operation/valid/IsValidOp.cpp: Closer to JTS 1.3
-2003-04-28 06:01 ybychkov
+2003-04-28 06:01 Yury Bychkov <me at yury.ca>
+ * [r119] source/algorithm/CGAlgorithms.cpp,
source/algorithm/IntTreePointInRing.cpp,
@@ -19791,91 +20166,93 @@
source/util/Assert.cpp, source/util/AssertionFailedException.cpp:
Partially upgraded to JTS 1.3
-2003-04-21 22:16 ybychkov
+2003-04-21 22:16 Yury Bychkov <me at yury.ca>
- * VisualStudio, VisualStudio/GEOS.sln, VisualStudio/GEOS.vcproj:
- VisualStudio project added.
+ * [r118] VisualStudio, VisualStudio/GEOS.sln,
+ VisualStudio/GEOS.vcproj: VisualStudio project added.
-2003-04-17 00:37 ybychkov
+2003-04-17 00:37 Yury Bychkov <me at yury.ca>
- * source/geom/BasicCoordinateList.cpp, source/geom/Geometry.cpp,
- source/geom/GeometryFactory.cpp,
+ * [r117] source/geom/BasicCoordinateList.cpp,
+ source/geom/Geometry.cpp, source/geom/GeometryFactory.cpp,
source/graph/GeometryGraph.cpp, source/io/WKTReader.cpp: Changed
PrecisionModel to Value type. Removed bounds checking from *At
methods in CoordinateLists.
-2003-04-12 04:31 ybychkov
+2003-04-12 04:31 Yury Bychkov <me at yury.ca>
+ * [r116] source/graph/EdgeRing.cpp,
source/operation/overlay/OverlayOp.cpp: Overlay passes all tests
(both precise and normal)
-2003-04-11 23:16 ybychkov
+2003-04-11 23:16 Yury Bychkov <me at yury.ca>
- * source/geom/Geometry.cpp, source/geom/GeometryCollection.cpp,
+ * [r115] source/geom/Geometry.cpp,
+ source/geom/GeometryCollection.cpp,
source/geom/GeometryFactory.cpp, source/geom/LineString.cpp,
source/geom/Point.cpp, source/geom/Polygon.cpp,
source/headers/geom.h, source/io/WKTReader.cpp,
source/test/XMLTester.cpp: Overlay almost works. Fails 2 tests.
-2003-04-10 04:34 ybychkov
+2003-04-10 04:34 Yury Bychkov <me at yury.ca>
- * source/geom/Geometry.cpp, source/geom/GeometryFactory.cpp,
+ * [r114] source/geom/Geometry.cpp, source/geom/GeometryFactory.cpp,
source/graph/Depth.cpp, source/graph/DirectedEdgeStar.cpp,
source/graph/EdgeIntersectionList.cpp,
source/test/XMLTester.cpp: Overlay passes all normal tests. Still
fails on Precision tests.
-2003-04-09 21:52 pramsey
+2003-04-09 21:52 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/headers/geom.h: Changed destructors to virtual to quiet
- GNU warnings
+ * [r113] source/headers/geom.h: Changed destructors to virtual to
+ quiet GNU warnings
-2003-04-04 23:49 pramsey
+2003-04-04 23:49 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/headers/Makefile.am: Install all headers at install time.
+ * [r112] source/headers/Makefile.am: Install all headers at install
+ time.
-2003-04-04 22:04 pramsey
+2003-04-04 22:04 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/examples/CustomCoordinateListExample.cpp,
+ * [r111] source/examples/CustomCoordinateListExample.cpp,
source/examples/CustomCoordinateListExample.h,
source/examples/CustomPointCoordinateList.cpp: Newlines added to
quiet gcc.
-2003-04-04 03:44 pramsey
+2003-04-04 03:44 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/geom/Makefile.am: Build support
+ * [r110] source/geom/Makefile.am: Build support
-2003-04-04 03:43 pramsey
+2003-04-04 03:43 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/examples/Makefile.am: Build support.
+ * [r109] source/examples/Makefile.am: Build support.
-2003-04-04 03:28 pramsey
+2003-04-04 03:28 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/geom/Makefile.am: Build support updates.
+ * [r108] source/geom/Makefile.am: Build support updates.
-2003-04-04 03:11 pramsey
+2003-04-04 03:11 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/examples/Makefile.am: Build support for new example
+ * [r107] source/examples/Makefile.am: Build support for new example
programs.
2003-04-04 00:18 dblasby
- * INSTALL: added comment about running ./autogen.sh
+ * [r106] INSTALL: added comment about running ./autogen.sh
-2003-04-02 21:55 ybychkov
+2003-04-02 21:55 Yury Bychkov <me at yury.ca>
+ * [r105] source/examples/CustomCoordinateListExample.cpp,
source/examples/CustomPointCoordinateList.cpp: Added example on
how to wrap internal storage format with CoordinateLists.
-2003-04-02 08:02 ybychkov
+2003-04-02 08:02 Yury Bychkov <me at yury.ca>
+ * [r104] source/algorithm/MCPointInRing.cpp,
source/geom/BasicCoordinateList.cpp, source/geom/LineString.cpp,
source/graph/DirectedEdge.cpp, source/graph/EdgeEnd.cpp,
@@ -19890,14 +20267,15 @@
source/operation/valid/IsValidOp.cpp: isValid is debugged (passes
all 805 tests).
-2003-03-24 19:23 pramsey
+2003-03-24 19:23 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/headers/indexQuadtree.h, source/headers/indexSweepline.h:
- Added newlines to end to quiet gcc
+ * [r103] source/headers/indexQuadtree.h,
+ source/headers/indexSweepline.h: Added newlines to end to quiet
+ gcc
-2003-03-24 19:21 pramsey
+2003-03-24 19:21 Paul Ramsey <pramsey at cleverelephant.ca>
- * Makefile.in, aclocal.m4, configure, configure.in, libtool,
+ * [r102] Makefile.in, aclocal.m4, configure, configure.in, libtool,
macros/Makefile.in, source/Makefile.am, source/Makefile.in,
source/algorithm/Makefile.am, source/algorithm/Makefile.in,
source/bigtest/Makefile.in, source/geom/Makefile.in,
@@ -19916,13 +20294,13 @@
extraneous build support from all
non-geom library directories.
-2003-03-24 03:45 pramsey
+2003-03-24 03:45 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/geom/Makefile.am: More GNU build support
+ * [r101] source/geom/Makefile.am: More GNU build support
-2003-03-24 03:07 pramsey
+2003-03-24 03:07 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r100] Makefile.in, aclocal.m4, configure, configure.in, libtool,
source/algorithm/Makefile.in, source/bigtest/Makefile.in,
source/geom/Makefile.am, source/geom/Makefile.in,
@@ -19935,9 +20313,9 @@
source/test/XMLTester.cpp, source/util/Makefile.in,
tools/Makefile.in: GNU build support on latest changes.
-2003-03-19 00:34 ybychkov
+2003-03-19 00:34 Yury Bychkov <me at yury.ca>
- * source/algorithm/IntTreePointInRing.cpp,
+ * [r99] source/algorithm/IntTreePointInRing.cpp,
source/geom/Geometry.cpp, source/headers/geosAlgorithm.h,
source/operation/overlay/LineBuilder.cpp,
@@ -19945,9 +20323,9 @@
source/operation/overlay/OverlayOp.java: All Overlay classes are
ported. Overlay and isValid have not been tested yet.
-2003-03-18 01:42 ybychkov
+2003-03-18 01:42 Yury Bychkov <me at yury.ca>
- * source/geom/Geometry.cpp, source/graph/PlanarGraph.cpp,
+ * [r98] source/geom/Geometry.cpp, source/graph/PlanarGraph.cpp,
source/headers/opOverlay.h, source/headers/opValid.h,
source/index/intervaltree/IntervalNode.cpp,
source/index/quadtree/Quad.cpp,
@@ -19962,9 +20340,9 @@
source/operation/valid/RepeatedPointTester.cpp,
source/test/XMLTester.cpp: 90% of Overlay classes ported.
-2003-03-17 18:04 ybychkov
+2003-03-17 18:04 Yury Bychkov <me at yury.ca>
+ * [r97] source/algorithm/MCPointInRing.cpp,
source/headers/geosAlgorithm.h, source/headers/indexChain.h,
source/headers/indexIntervaltree.h, source/index/chain,
source/index/chain/MonotoneChainBuilder.cpp,
@@ -19976,9 +20354,9 @@
source/index/intervaltree/IntervalTree.cpp: All 'index' packages
and part of 'overlay' are done.
-2003-03-17 02:49 ybychkov
+2003-03-17 02:49 Yury Bychkov <me at yury.ca>
+ * [r96] source/algorithm/MCPointInRing.cpp,
source/headers/geosAlgorithm.h, source/headers/opOverlay.h,
source/headers/opValid.h, source/operation/overlay,
@@ -19986,24 +20364,25 @@
source/operation/valid/IsValidOp.cpp: IsValid and supporting
packages are ported (but NOT tested).
-2003-03-12 23:45 pramsey
+2003-03-12 23:45 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/geom/Makefile.am, source/operation/Makefile.am,
+ * [r95] source/geom/Makefile.am, source/operation/Makefile.am,
source/operation/valid/Makefile.am: Build support for valid.
-2003-03-10 10:18 ybychkov
+2003-03-10 10:18 Yury Bychkov <me at yury.ca>
- * source/headers/indexQuadtree.h, source/headers/opOverlay.h,
+ * [r94] source/headers/indexQuadtree.h, source/headers/opOverlay.h,
source/operation/valid/QuadtreeNestedRingTester.cpp: IsValid()
and supporting index classes are ported, but don't work yet
(external dependencies)
-2003-03-10 01:17 ybychkov
+2003-03-10 01:17 Yury Bychkov <me at yury.ca>
- * source/headers/indexQuadtree.h, source/headers/indexSweepline.h,
- source/headers/opValid.h, source/index, source/index/quadtree,
+ * [r93] source/headers/indexQuadtree.h,
+ source/headers/indexSweepline.h, source/headers/opValid.h,
+ source/index, source/index/quadtree,
source/index/quadtree/Quadtree.cpp, source/index/sweepline,
source/index/sweepline/SweepLineIndex.cpp,
@@ -20019,41 +20398,43 @@
source/test/XMLTester.cpp: IsValid and supporting index classes
are almost done.
-2003-03-05 17:04 pramsey
+2003-03-05 17:04 Paul Ramsey <pramsey at cleverelephant.ca>
- * configure.in, source/Makefile.am, source/examples/Makefile.am:
- Build support for new coordinateline examples.
+ * [r92] configure.in, source/Makefile.am,
+ source/examples/Makefile.am: Build support for new coordinateline
+ examples.
-2003-03-05 08:02 ybychkov
+2003-03-05 08:02 Yury Bychkov <me at yury.ca>
- * source/examples, source/examples/CoordinateListsExample.cpp,
+ * [r91] source/examples,
+ source/examples/CoordinateListsExample.cpp,
CoordinateList interface example.
-2003-03-03 03:56 pramsey
+2003-03-03 03:56 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/geom/Makefile.am: Remove PointInRing
+ * [r90] source/geom/Makefile.am: Remove PointInRing
-2003-03-03 03:35 pramsey
+2003-03-03 03:35 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/algorithm/PointInRing.cpp: Removed unused file.
+ * [r89] source/algorithm/PointInRing.cpp: Removed unused file.
-2003-03-03 02:41 ybychkov
+2003-03-03 02:41 Yury Bychkov <me at yury.ca>
- * source/algorithm/LineIntersector.cpp,
+ * [r88] source/algorithm/LineIntersector.cpp,
source/bigtest/GeometryTestFactory.cpp,
source/graph/EdgeIntersectionList.cpp, source/io/WKTReader.cpp:
Some Coordinate& related bugs fixed.
-2003-03-03 02:26 ybychkov
+2003-03-03 02:26 Yury Bychkov <me at yury.ca>
- * source/geom/GeometryFactory.cpp: GeometryFactory bug fix.
+ * [r87] source/geom/GeometryFactory.cpp: GeometryFactory bug fix.
-2003-03-03 00:46 ybychkov
+2003-03-03 00:46 Yury Bychkov <me at yury.ca>
+ * [r86] source/algorithm/CGAlgorithms.cpp,
@@ -20083,9 +20464,9 @@
source/util/Assert.cpp: Second pass of code cleanup. Coordinate
references and inlining.
-2003-03-02 03:47 ybychkov
+2003-03-02 03:47 Yury Bychkov <me at yury.ca>
- * source/graph/Depth.cpp, source/graph/DirectedEdge.cpp,
+ * [r85] source/graph/Depth.cpp, source/graph/DirectedEdge.cpp,
source/graph/DirectedEdgeStar.cpp, source/graph/Edge.cpp,
source/graph/EdgeEnd.cpp, source/graph/EdgeEndStar.cpp,
source/graph/EdgeIntersectionList.cpp, source/graph/EdgeRing.cpp,
@@ -20103,18 +20484,19 @@
source/operation/relate/RelateNodeGraph.cpp: First pass of code
cleanup completed over all packages.
-2003-03-01 06:10 pramsey
+2003-03-01 06:10 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/headers/geosAlgorithm.h: Uncommented default constructor
- for PointInRing
+ * [r84] source/headers/geosAlgorithm.h: Uncommented default
+ constructor for PointInRing
-2003-03-01 06:08 pramsey
+2003-03-01 06:08 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/test/SimpleWKTTester.cpp: Fixed call to geometry factory.
+ * [r83] source/test/SimpleWKTTester.cpp: Fixed call to geometry
+ factory.
-2003-02-26 23:16 ybychkov
+2003-02-26 23:16 Yury Bychkov <me at yury.ca>
+ * [r82] source/algorithm/LineIntersector.cpp,
@@ -20127,22 +20509,22 @@
source/io/Writer.cpp, source/test/XMLTester.cpp: All packages
except 'graph' has been refactored.
-2003-02-20 03:32 pramsey
+2003-02-20 03:32 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/test/SimpleWKTTester.cpp: Fixed small bug in call to
+ * [r81] source/test/SimpleWKTTester.cpp: Fixed small bug in call to
GeometryFactory (instantiate PrecisionModel
with new)
-2003-02-20 03:30 pramsey
+2003-02-20 03:30 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/geom/CoordinateListFactory.cpp,
+ * [r80] source/geom/CoordinateListFactory.cpp,
source/geom/GeometryFactory.cpp: GFactory: Move i outside of for
loop. Needed to compile GNU
CListFactory: Add newline to end of file.
-2003-02-20 00:10 ybychkov
+2003-02-20 00:10 Yury Bychkov <me at yury.ca>
- * source/geom/GeometryFactory.cpp, source/headers/opRelate.h,
+ * [r79] source/geom/GeometryFactory.cpp, source/headers/opRelate.h,
source/operation/relate/EdgeEndBundle.cpp,
source/operation/relate/RelateComputer.cpp,
@@ -20150,9 +20532,9 @@
source/operation/relate/RelateOp.cpp: Geom and Operation
(including Relate) packages are updated.
-2003-02-17 09:38 ybychkov
+2003-02-17 09:38 Yury Bychkov <me at yury.ca>
- * source/geom/Envelope.cpp, source/geom/Geometry.cpp,
+ * [r78] source/geom/Envelope.cpp, source/geom/Geometry.cpp,
source/geom/IntersectionMatrix.cpp, source/geom/LineString.cpp,
@@ -20164,19 +20546,19 @@
source/operation/relate/RelateOp.cpp, source/test/XMLTester.cpp:
GEOM package fully updated & bugs fixed.
-2003-02-17 00:40 ybychkov
+2003-02-17 00:40 Yury Bychkov <me at yury.ca>
- * source/geom/Geometry.cpp, source/geom/MultiLineString.cpp,
+ * [r77] source/geom/Geometry.cpp, source/geom/MultiLineString.cpp,
source/geom/MultiPoint.cpp, source/geom/MultiPolygon.cpp,
source/graph/EdgeRing.cpp, source/graph/GeometryGraph.cpp,
source/headers/geom.h, source/headers/io.h,
source/io/WKTReader.cpp: GEOM package fully updated.
-2003-02-16 22:52 ybychkov
+2003-02-16 22:52 Yury Bychkov <me at yury.ca>
- * source/bigtest/GeometryTestFactory.cpp, source/geom/Geometry.cpp,
+ * [r76] source/bigtest/GeometryTestFactory.cpp,
source/geom/GeometryCollectionIterator.cpp,
@@ -20186,33 +20568,33 @@
source/graph/EdgeRing.cpp, source/headers/geom.h,
source/io/WKTReader.cpp: GEOM package partially updated.
-2003-02-12 21:09 pramsey
+2003-02-12 21:09 Paul Ramsey <pramsey at cleverelephant.ca>
- * INSTALL, missing: Added two files required by autoconf build
- process.
+ * [r75] INSTALL, missing: Added two files required by autoconf
+ build process.
-2003-02-12 20:51 pramsey
+2003-02-12 20:51 Paul Ramsey <pramsey at cleverelephant.ca>
- * configure, libtool, source/geom/Makefile.in,
+ * [r74] configure, libtool, source/geom/Makefile.in,
source/headers/Makefile.in, source/test/Makefile.in: Commit build
support files.
-2003-02-12 19:11 pramsey
+2003-02-12 19:11 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/headers/Makefile.am: Change header installation path to
- $(prefix)/include/geos.
+ * [r73] source/headers/Makefile.am: Change header installation path
+ to $(prefix)/include/geos.
-2003-02-12 06:50 pramsey
+2003-02-12 06:50 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r72] source/algorithm/LineIntersector.cpp,
source/algorithm/SimplePointInRing.cpp,
source/operation/GeometryGraphOperation.cpp,
source/operation/relate/EdgeEndBundle.cpp: Added newlines to
quiet g++ warnings.
-2003-02-12 06:48 pramsey
+2003-02-12 06:48 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r71] source/graph/Depth.cpp, source/graph/DirectedEdge.cpp,
source/graph/DirectedEdgeStar.cpp, source/graph/EdgeEnd.cpp,
source/graph/EdgeIntersectionList.cpp, source/graph/EdgeList.cpp,
source/graph/Label.cpp, source/graph/NodeFactory.cpp,
@@ -20221,80 +20603,81 @@
source/graph/index/SweepLineEvent.cpp: Added newlines to ends of
files to quiet g++ warnings.
-2003-02-12 06:27 pramsey
+2003-02-12 06:27 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/test/XMLTester.cpp: Fix headers.
+ * [r70] source/test/XMLTester.cpp: Fix headers.
-2003-02-12 06:26 pramsey
+2003-02-12 06:26 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/test/SimpleWKTTester.cpp: Changed headers.
+ * [r69] source/test/SimpleWKTTester.cpp: Changed headers.
-2003-02-12 06:24 pramsey
+2003-02-12 06:24 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/bigtest/TestSweepLineSpeed.cpp: Added return value.
+ * [r68] source/bigtest/TestSweepLineSpeed.cpp: Added return value.
- * source/bigtest/TestSweepLineSpeed.cpp, source/test/CTS.cpp,
+ * [r67] source/bigtest/TestSweepLineSpeed.cpp, source/test/CTS.cpp,
source/test/XMLTester.cpp: Changed headers.
-2003-02-12 06:19 pramsey
+2003-02-12 06:19 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/test/XMLTester.cpp: Make path to test file relative.
+ * [r66] source/test/XMLTester.cpp: Make path to test file relative.
-2003-02-12 06:18 pramsey
+2003-02-12 06:18 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/bigtest/GeometryTestFactory.cpp: Change include reference
- syntax.
+ * [r65] source/bigtest/GeometryTestFactory.cpp: Change include
+ reference syntax.
-2003-02-12 06:07 pramsey
+2003-02-12 06:07 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/graph/EdgeEndStar.cpp: Remove NULL test.
+ * [r64] source/graph/EdgeEndStar.cpp: Remove NULL test.
- * source/io/WKTWriter.cpp: Pass double to log().
+ * [r63] source/io/WKTWriter.cpp: Pass double to log().
- * source/bigtest/TestSweepLineSpeed.cpp: Fixed main() return type.
+ * [r62] source/bigtest/TestSweepLineSpeed.cpp: Fixed main() return
+ type.
-2003-02-12 06:04 pramsey
+2003-02-12 06:04 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/test/Makefile.am: Remove old library references.
+ * [r61] source/test/Makefile.am: Remove old library references.
-2003-02-12 05:58 pramsey
+2003-02-12 05:58 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/bigtest/TestSweepLineSpeed.cpp: Added stdio reference and
- newline at end.
+ * [r60] source/bigtest/TestSweepLineSpeed.cpp: Added stdio
+ reference and newline at end.
-2003-02-12 00:58 pramsey
+2003-02-12 00:58 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/test/test.xml: Added all JTS test cases to the file.
+ * [r59] source/test/test.xml: Added all JTS test cases to the file.
-2003-02-11 23:54 pramsey
+2003-02-11 23:54 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/geom/Makefile.am: Added support for new cpp files.
+ * [r58] source/geom/Makefile.am: Added support for new cpp files.
-2003-02-11 23:33 ybychkov
+2003-02-11 23:33 Yury Bychkov <me at yury.ca>
- * source/geom/CoordinateList.cpp, source/geom/Geometry.cpp,
+ * [r57] source/geom/CoordinateList.cpp, source/geom/Geometry.cpp,
source/geom/PointCoordinateList.cpp, source/geom/Polygon.cpp,
source/headers/geom.h: Some bugs fixed.
-2003-02-11 20:24 ybychkov
+2003-02-11 20:24 Yury Bychkov <me at yury.ca>
- * source/geom/PointCoordinateList.cpp,
+ * [r56] source/geom/PointCoordinateList.cpp,
source/graph/EdgeEndStar.cpp, source/headers/graph.h: Small
changes in PointCoordinateList and EdgeEndStar.
2003-02-11 19:01 mbdavis
- * source/geom/Geometry.cpp: fixed duplicate for loop index
+ * [r55] source/geom/Geometry.cpp: fixed duplicate for loop index
-2003-02-05 08:14 ybychkov
+2003-02-05 08:14 Yury Bychkov <me at yury.ca>
+ * [r54] source/bigtest/GeometryTestFactory.cpp,
source/geom/CoordinateListFactory.cpp, source/geom/Geometry.cpp,
@@ -20310,9 +20693,9 @@
Second pass of CoordinateList interface migration.
-2003-01-27 08:04 ybychkov
+2003-01-27 08:04 Yury Bychkov <me at yury.ca>
+ * [r53] source/algorithm/NonRobustCGAlgorithms.cpp,
@@ -20334,19 +20717,19 @@
source/io/WKTReader.cpp: First pass of CoordinateList interface
replacement.
-2003-01-27 07:56 ybychkov
+2003-01-27 07:56 Yury Bychkov <me at yury.ca>
- * source/algorithm/CGAlgorithms.cpp: First pass of CoordinateList
- interface replacement.
+ * [r52] source/algorithm/CGAlgorithms.cpp: First pass of
+ CoordinateList interface replacement.
-2003-01-27 07:26 ybychkov
+2003-01-27 07:26 Yury Bychkov <me at yury.ca>
+ * [r51] source/algorithm/CGAlgorithms.cpp: First pass of
-2002-12-02 09:48 ybychkov
+2002-12-02 09:48 Yury Bychkov <me at yury.ca>
- * source/algorithm/CGAlgorithms.cpp,
+ * [r50] source/algorithm/CGAlgorithms.cpp,
@@ -20364,25 +20747,25 @@
source/headers/geosAlgorithm.h, source/headers/graph.h: More
performance updates.
-2002-11-24 10:48 ybychkov
+2002-11-24 10:48 Yury Bychkov <me at yury.ca>
- * source/algorithm/RobustLineIntersector.cpp,
+ * [r49] source/algorithm/RobustLineIntersector.cpp,
source/graph/index/MonotoneChainIndexer.cpp,
source/headers/geom.h, source/headers/graphindex.h: Some
performance improvements.
-2002-11-14 23:43 pramsey
+2002-11-14 23:43 Paul Ramsey <pramsey at cleverelephant.ca>
- * configure.in, source/Makefile.am, source/Makefile.in,
+ * [r48] configure.in, source/Makefile.am, source/Makefile.in,
source/bigtest/Makefile.am, source/bigtest/Makefile.in,
source/geom/Makefile.am, source/geom/Makefile.in: Build support
for the bigtest programs.
-2002-11-08 19:49 ybychkov
+2002-11-08 19:49 Yury Bychkov <me at yury.ca>
+ * [r47] source/bigtest/TestSweepLineSpeed.cpp,
source/geom/Coordinate.cpp, source/graph/Edge.cpp,
@@ -20392,37 +20775,38 @@
source/headers/graph.h, source/headers/graphindex.h: Preformance
is drastically improved
-2002-11-05 23:13 ybychkov
+2002-11-05 23:13 Yury Bychkov <me at yury.ca>
- * source/bigtest, source/bigtest/GeometryTestFactory.cpp,
+ * [r46] source/bigtest, source/bigtest/GeometryTestFactory.cpp,
source/graph/index/SimpleMCSweepLineIntersector.cpp,
source/headers/bigtest.h,
source/operation/relate/RelateComputer.cpp: Code for generating
large tests added.
-2002-10-31 07:37 ybychkov
+2002-10-31 07:37 Yury Bychkov <me at yury.ca>
- * source/graph/index/SimpleMCSweepLineIntersector.cpp,
+ * [r45] source/graph/index/SimpleMCSweepLineIntersector.cpp,
source/io/StringTokenizer.cpp, source/test/XMLTester.cpp: XML
tester is less fragile now.
-2002-10-30 21:59 pramsey
+2002-10-30 21:59 Paul Ramsey <pramsey at cleverelephant.ca>
- * config.guess, config.sub: Added configure support files for
+ * [r44] config.guess, config.sub: Added configure support files for
building w/o automake/autoconf
-2002-10-30 21:58 pramsey
+2002-10-30 21:58 Paul Ramsey <pramsey at cleverelephant.ca>
- * configure.in: Small changes to make autoconf happy.
+ * [r43] configure.in: Small changes to make autoconf happy.
-2002-10-30 20:04 pramsey
+2002-10-30 20:04 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/test/test.xml: Edited test file to not crash XMLTester
+ * [r42] source/test/test.xml: Edited test file to not crash
+ XMLTester
-2002-10-30 19:54 pramsey
+2002-10-30 19:54 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r41] Makefile.in, aclocal.m4, configure, configure.in, libtool,
source/algorithm/Makefile.in, source/geom/Makefile.am,
source/geom/Makefile.in, source/graph/Makefile.in,
@@ -20437,7 +20821,7 @@
2002-10-23 02:21 nvine
- * configure.in, source/Makefile.am, source/geom/Geometry.cpp,
+ * [r40] configure.in, source/Makefile.am, source/geom/Geometry.cpp,
source/geom/GeometryCollection.cpp, source/geom/Makefile.am,
source/geom/Polygon.cpp, source/graph/Depth.cpp,
@@ -20453,9 +20837,9 @@
source/test/SimpleWKTTester.cpp, source/test/XMLTester.cpp: GNU
portability changes
-2002-10-17 07:12 ybychkov
+2002-10-17 07:12 Yury Bychkov <me at yury.ca>
+ * [r39] source/algorithm/SimplePointInAreaLocator.cpp,
@@ -20463,9 +20847,9 @@
source/headers/graphindex.h, source/test/XMLTester.cpp: All test
cases now work. Some are still too slow.
-2002-10-06 09:56 ybychkov
+2002-10-06 09:56 Yury Bychkov <me at yury.ca>
+ * [r38] source/algorithm/PointLocator.cpp,
source/graph/DirectedEdgeStar.cpp, source/graph/EdgeEndStar.cpp,
source/graph/GeometryGraph.cpp, source/graph/Label.cpp,
@@ -20481,9 +20865,9 @@
source/operation/relate/RelateNodeGraph.cpp,
source/test/XMLTester.cpp: Relate() is almost debugged.
-2002-09-12 14:08 fvilla
+2002-09-12 14:08 Fernando Villa <fvilla at zoo.uvm.edu>
- * Makefile.in, configure, configure.in, libtool,
+ * [r37] Makefile.in, configure, configure.in, libtool,
source/headers/Makefile.am, source/headers/Makefile.in,
source/operation/Makefile.am, source/operation/Makefile.in,
@@ -20491,9 +20875,9 @@
source/operation/relate/Makefile.in: Add makefile support for new
files and dir
-2002-09-12 01:27 ybychkov
+2002-09-12 01:27 Yury Bychkov <me at yury.ca>
- * source/geom/Geometry.cpp, source/geom/LineString.cpp,
+ * [r36] source/geom/Geometry.cpp, source/geom/LineString.cpp,
source/geom/MultiLineString.cpp, source/geom/MultiPoint.cpp,
source/geom/Polygon.cpp, source/graph/DirectedEdgeStar.cpp,
source/graph/Edge.cpp, source/graph/EdgeEnd.cpp,
@@ -20518,16 +20902,16 @@
Relate is finished,but doesn't work yet.
-2002-09-10 13:46 fvilla
+2002-09-10 13:46 Fernando Villa <fvilla at zoo.uvm.edu>
- * configure, configure.in, libtool, source/Makefile.am,
+ * [r35] configure, configure.in, libtool, source/Makefile.am,
source/Makefile.in, source/geom/Makefile.am,
source/geom/Makefile.in, source/operation/Makefile.am,
source/operation/Makefile.in: Added operation/Makefiles
-2002-09-06 20:18 ybychkov
+2002-09-06 20:18 Yury Bychkov <me at yury.ca>
+ * [r34] source/algorithm/CGAlgorithms.cpp,
@@ -20553,9 +20937,9 @@
brought to version 1.2 of JTS. Compilable part of Operation
added.
-2002-09-05 18:32 fvilla
+2002-09-05 18:32 Fernando Villa <fvilla at zoo.uvm.edu>
- * ChangeLog, Makefile.in, configure, configure.in, libtool,
+ * [r33] ChangeLog, Makefile.in, configure, configure.in, libtool,
source/graph/index/Makefile.in, source/headers/Makefile.am,
@@ -20569,15 +20953,15 @@
version is
#define'd for code being compiled as GEOS_VERSION.
-2002-09-03 16:04 pramsey
+2002-09-03 16:04 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/test/Makefile.am: Changed reference to 'libgeom' to
+ * [r32] source/test/Makefile.am: Changed reference to 'libgeom' to
'libgeos'
-2002-09-03 13:53 fvilla
+2002-09-03 13:53 Fernando Villa <fvilla at zoo.uvm.edu>
- * Makefile.am, Makefile.in, acinclude.m4, aclocal.m4, configure,
- configure.in, install-sh, libtool, ltmain.sh, macros,
+ * [r31] Makefile.am, Makefile.in, acinclude.m4, aclocal.m4,
+ configure, configure.in, install-sh, libtool, ltmain.sh, macros,
macros/Makefile.am, macros/Makefile.in, macros/geos.m4,
mkinstalldirs, source/Makefile.am, source/Makefile.in,
@@ -20619,9 +21003,9 @@
solution is not
easy to work with in automake.
-2002-09-01 18:08 pramsey
+2002-09-01 18:08 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/algorithm/NotRepresentableException.cpp,
+ * [r30] source/algorithm/NotRepresentableException.cpp,
source/algorithm/PointInRing.cpp,
@@ -20629,14 +21013,15 @@
source/io/Writer.cpp, source/io/markup/MarkupSTL.cpp: Minor
portability changes.
-2002-09-01 17:53 pramsey
+2002-09-01 17:53 Paul Ramsey <pramsey at cleverelephant.ca>
- * configure.in, source/Makefile.am, source/algorithm/Makefile.am:
- Changes to support algorithm directory in build structure.
+ * [r29] configure.in, source/Makefile.am,
+ source/algorithm/Makefile.am: Changes to support algorithm
+ directory in build structure.
-2002-09-01 17:51 pramsey
+2002-09-01 17:51 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/geom/Coordinate.cpp, source/geom/CoordinateList.cpp,
+ * [r28] source/geom/Coordinate.cpp, source/geom/CoordinateList.cpp,
source/geom/Dimension.cpp, source/geom/Envelope.cpp,
@@ -20647,39 +21032,39 @@
stdio.h where needed, small syntax adjustments, newlines at
end of files.
-2002-08-30 18:33 pramsey
+2002-08-30 18:33 Paul Ramsey <pramsey at cleverelephant.ca>
- * COPYING: Added LGPL licence text.
+ * [r27] COPYING: Added LGPL licence text.
-2002-08-30 18:30 pramsey
+2002-08-30 18:30 Paul Ramsey <pramsey at cleverelephant.ca>
- * AUTHORS, Authors: Changed name of authors file as requested by
- autoconf.
+ * [r26] AUTHORS, Authors: Changed name of authors file as requested
+ by autoconf.
-2002-08-30 18:28 pramsey
+2002-08-30 18:28 Paul Ramsey <pramsey at cleverelephant.ca>
- * autogen.sh: Removed --force-missing which did not work for my
- version of autoconf
+ * [r25] autogen.sh: Removed --force-missing which did not work for
+ my version of autoconf
-2002-08-30 18:16 pramsey
+2002-08-30 18:16 Paul Ramsey <pramsey at cleverelephant.ca>
- * ., .cvsignore, source, source/.cvsignore, source/geom,
+ * [r24] ., .cvsignore, source, source/.cvsignore, source/geom,
source/geom/.cvsignore, source/graph, source/graph/.cvsignore,
source/graph/index, source/graph/index/.cvsignore, source/io,
source/io/.cvsignore, source/io/markup,
source/io/markup/.cvsignore, source/test, source/test/.cvsignore,
source/util, source/util/.cvsignore: Added cvs ignore files.
-2002-08-30 18:15 pramsey
+2002-08-30 18:15 Paul Ramsey <pramsey at cleverelephant.ca>
- * source/test/CTS.cpp, source/test/SimpleWKTTester.cpp,
+ * [r23] source/test/CTS.cpp, source/test/SimpleWKTTester.cpp,
source/test/WKTIn, source/test/WKTOut, source/test/XMLTester.cpp,
source/test/test.xml: Added the testing files back into their new
subdirectory.
- * Authors, ChangeLog, Makefile.am, NEWS, README, autogen.sh,
+ * [r22] Authors, ChangeLog, Makefile.am, NEWS, README, autogen.sh,
configure.in, source/CTS.cpp, source/Makefile.am,
source/SimpleWKTTester.cpp, source/WKTIn, source/WKTOut,
source/XMLTester.cpp, source/geom/Makefile.am,
@@ -20690,9 +21075,9 @@
submitted by Norman Vine. Moved test
files to a new subdirectory.
-2002-08-30 15:52 ybychkov
+2002-08-30 15:52 Yury Bychkov <me at yury.ca>
- * source/algorithm, source/algorithm/HCoordinate.cpp,
+ * [r21] source/algorithm, source/algorithm/HCoordinate.cpp,
@@ -20713,9 +21098,9 @@
source/headers/util.h, source/io/WKTWriter.cpp: 'algorithm' is
almost complete
-2002-08-22 09:23 ybychkov
+2002-08-22 09:23 Yury Bychkov <me at yury.ca>
- * source/graph/index, source/graph/index/MonotoneChain.cpp,
+ * [r20] source/graph/index, source/graph/index/MonotoneChain.cpp,
source/graph/index/SegmentIntersector.cpp,
@@ -20727,22 +21112,22 @@
source/headers/operation.h, source/headers/platform.h,
source/headers/util.h: 'graph/index' finished. Some .h changes.
-2002-08-21 05:49 ybychkov
+2002-08-21 05:49 Yury Bychkov <me at yury.ca>
- * source/graph/GeometryGraph.cpp, source/headers/graph.h,
+ * [r19] source/graph/GeometryGraph.cpp, source/headers/graph.h,
source/headers/graphindex.h: Some changes in 'graph'
-2002-08-20 21:08 ybychkov
+2002-08-20 21:08 Yury Bychkov <me at yury.ca>
- * source/XMLTester.cpp, source/graph/Node.cpp,
+ * [r18] source/XMLTester.cpp, source/graph/Node.cpp,
source/graph/NodeMap.cpp, source/graph/PlanarGraph.cpp,
source/headers/geom.h, source/headers/geosAlgorithm.h,
source/headers/graph.h, source/headers/io.h: Changed consts to
enums
-2002-08-14 07:00 ybychkov
+2002-08-14 07:00 Yury Bychkov <me at yury.ca>
- * Assert.cpp, AssertionFailedException.cpp, CTS.cpp,
+ * [r17] Assert.cpp, AssertionFailedException.cpp, CTS.cpp,
Coordinate.cpp, CoordinateList.cpp, Depth.cpp, Dimension.cpp,
Envelope.cpp, Geometry.cpp, GeometryCollection.cpp,
GeometryCollectionIterator.cpp, GeometryFactory.cpp,
@@ -20789,81 +21174,84 @@
source/util/AssertionFailedException.cpp, test.xml, util.h: New
structure of source.
-2002-07-11 07:57 ybychkov
+2002-07-11 07:57 Yury Bychkov <me at yury.ca>
- * Assert.cpp, AssertionFailedException.cpp, Depth.cpp,
+ * [r16] Assert.cpp, AssertionFailedException.cpp, Depth.cpp,
Geometry.cpp, GeometryCollection.cpp, GeometryFactory.cpp,
Label.cpp, Position.cpp, TopologyLocation.cpp, WKTReader.cpp,
WKTWriter.cpp, XMLTester.cpp, graph.h, operation.h, test.xml,
util.h: Assert and some graph classes
-2002-07-03 05:24 ybychkov
+2002-07-03 05:24 Yury Bychkov <me at yury.ca>
- * MarkupSTL.cpp, MarkupSTL.h, XMLTester.cpp: started XML tester
+ * [r15] MarkupSTL.cpp, MarkupSTL.h, XMLTester.cpp: started XML
+ tester
-2002-07-02 06:41 ybychkov
+2002-07-02 06:41 Yury Bychkov <me at yury.ca>
- * CTS.cpp, GeometryCollection.cpp, GeometryCollectionIterator.cpp,
- GeometryFactory.cpp, MultiPolygon.cpp, Polygon.cpp,
- SimpleWKTTester.cpp, WKTIn, WKTOut, WKTReader.cpp, WKTWriter.cpp,
- geom.h, io.h: 'io' and SimpleTester done
+ * [r14] CTS.cpp, GeometryCollection.cpp,
+ GeometryCollectionIterator.cpp, GeometryFactory.cpp,
+ MultiPolygon.cpp, Polygon.cpp, SimpleWKTTester.cpp, WKTIn,
+ WKTOut, WKTReader.cpp, WKTWriter.cpp, geom.h, io.h: 'io' and
+ SimpleTester done
-2002-06-27 02:50 ybychkov
+2002-06-27 02:50 Yury Bychkov <me at yury.ca>
- * CTS.cpp, StringTokenizer.cpp, WKTWriter.cpp, Writer.cpp, io.h:
- 'io' is almost done
+ * [r13] CTS.cpp, StringTokenizer.cpp, WKTWriter.cpp, Writer.cpp,
+ io.h: 'io' is almost done
-2002-06-26 09:10 ybychkov
+2002-06-26 09:10 Yury Bychkov <me at yury.ca>
- * CTS.cpp, GeometryCollection.cpp, ParseException.cpp, Polygon.cpp,
- StringTokenizer.cpp, WKTReader.cpp, io.h: Some 'io' classes done.
+ * [r12] CTS.cpp, GeometryCollection.cpp, ParseException.cpp,
+ Polygon.cpp, StringTokenizer.cpp, WKTReader.cpp, io.h: Some 'io'
+ classes done.
-2002-06-21 07:13 ybychkov
+2002-06-21 07:13 Yury Bychkov <me at yury.ca>
- * CTS.cpp, CoordinateList.cpp, Geometry.cpp,
+ * [r11] CTS.cpp, CoordinateList.cpp, Geometry.cpp,
GeometryCollection.cpp, LineString.cpp, Point.cpp, Polygon.cpp,
geom.h: 'geos': first pass done. Some external dependencies and
polishing left.
-2002-06-20 08:58 ybychkov
+2002-06-20 08:58 Yury Bychkov <me at yury.ca>
- * CTS.cpp, Geometry.cpp, GeometryCollection.cpp,
+ * [r10] CTS.cpp, Geometry.cpp, GeometryCollection.cpp,
GeometryCollectionIterator.cpp, GeometryFactory.cpp, geom.h: Only
Geometry.java left
-2002-06-19 06:29 ybychkov
+2002-06-19 06:29 Yury Bychkov <me at yury.ca>
+ * [r9] CTS.cpp, CoordinateList.cpp, Geometry.cpp,
GeometryCollection.cpp, LineString.cpp, LinearRing.cpp,
MultiLineString.cpp, MultiPoint.cpp, MultiPolygon.cpp, Point.cpp,
Polygon.cpp, geom.h: 'geom' mostly done.
-2002-06-14 07:46 ybychkov
+2002-06-14 07:46 Yury Bychkov <me at yury.ca>
- * CTS.cpp, GeometryCollection.cpp, GeometryFactory.cpp,
+ * [r8] CTS.cpp, GeometryCollection.cpp, GeometryFactory.cpp,
Polygon.cpp, geom.h: 'geom' almost done
-2002-06-12 01:47 ybychkov
+2002-06-12 01:47 Yury Bychkov <me at yury.ca>
- * CoordinateList.cpp, LineString.cpp, geom.h: LineString is 99%
- finished
+ * [r7] CoordinateList.cpp, LineString.cpp, geom.h: LineString is
+ 99% finished
-2002-06-11 23:43 ybychkov
+2002-06-11 23:43 Yury Bychkov <me at yury.ca>
- * CTS.cpp, Coordinate.cpp, CoordinateList.cpp, Dimension.cpp,
+ * [r6] CTS.cpp, Coordinate.cpp, CoordinateList.cpp, Dimension.cpp,
IntersectionMatrix.cpp, LineSegment.cpp, LineString.cpp,
LinearRing.cpp, Location.cpp, Point.cpp, PrecisionModel.cpp,
geom.h, operation.h, platform.h: 'geom' package 70% done
-2002-06-07 17:47 pramsey
+2002-06-07 17:47 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r2] CTS.cpp, Coordinate.cpp, CoordinateList.cpp, Dimension.cpp,
Envelope.cpp, LineSegment.cpp, Location.cpp, geom.h, platform.h:
Initial revision
2002-06-07 17:47 cvs
- * .: New repository initialized by cvs2svn.
+ * [r1] .: New repository initialized by cvs2svn.
More information about the geos-commits
