[geos-commits] r2824 - in trunk/source: headers/geos/util io
svn_geos at osgeo.org
Mon Dec 14 10:23:13 EST 2009
Author: mloskot
Date: 2009-12-14 10:23:12 -0500 (Mon, 14 Dec 2009)
New Revision: 2824
trunk/source/headers/geos/util/TopologyException.h
trunk/source/io/WKTWriter.cpp
* Fixed bug in WKTWriter that was dropping geometry tag in string representation of geometry
* Improved message carried by TopologyException
Modified: trunk/source/headers/geos/util/TopologyException.h
--- trunk/source/headers/geos/util/TopologyException.h 2009-12-11 13:17:01 UTC (rev 2823)
+++ trunk/source/headers/geos/util/TopologyException.h 2009-12-14 15:23:12 UTC (rev 2824)
@@ -47,7 +47,7 @@
TopologyException(const std::string& msg, const geom::Coordinate& newPt)
- GEOSException("TopologyException", msg+" "+newPt.toString()),
+ GEOSException("TopologyException", msg + " at " + newPt.toString()),
pt(newPt)
Modified: trunk/source/io/WKTWriter.cpp
--- trunk/source/io/WKTWriter.cpp 2009-12-11 13:17:01 UTC (rev 2823)
+++ trunk/source/io/WKTWriter.cpp 2009-12-14 15:23:12 UTC (rev 2824)
@@ -58,7 +58,8 @@
string
WKTWriter::toLineString(const CoordinateSequence& seq)
- stringstream buf("LINESTRING ", ios_base::in|ios_base::out);
+ stringstream buf(ios_base::in|ios_base::out);
+ buf << "LINESTRING ";
unsigned int npts = seq.getSize();
if ( npts == 0 )
@@ -85,8 +86,8 @@
string
WKTWriter::toLineString(const Coordinate& p0, const Coordinate& p1)
- stringstream ret("LINESTRING (", ios_base::in|ios_base::out);
- ret << p0.x << " " << p0.y;
+ stringstream ret(ios_base::in|ios_base::out);
+ ret << "LINESTRING (" << p0.x << " " << p0.y;
#if PRINT_Z
ret << " " << p0.z;
#endif
@@ -94,6 +95,7 @@
#if PRINT_Z
ret << " " << p1.z;
#endif
+ ret << ")";
return ret.str();
@@ -102,7 +104,8 @@
string
WKTWriter::toPoint(const Coordinate& p0)
- stringstream ret("POINT (", ios_base::in|ios_base::out);
+ ret << "POINT (";
#if PRINT_Z
ret << p0.x << " " << p0.y << " " << p0.z << " )";
#else
More information about the geos-commits
