[geos-commits] r2231 - in trunk/source/operation: buffer linemerge
svn_geos at osgeo.org
Mon Jan 5 18:42:08 EST 2009
Author: swongu
Date: 2009-01-05 18:42:08 -0500 (Mon, 05 Jan 2009)
New Revision: 2231
trunk/source/operation/buffer/BufferBuilder.cpp
trunk/source/operation/buffer/OffsetCurveVertexList.h
trunk/source/operation/linemerge/LineMerger.cpp
Fixed memory leak in BufferBuilder (#218); added read-only coordinates function in OffsetCurveVertexList; explicity pass ownership in LineMerger.
Modified: trunk/source/operation/buffer/BufferBuilder.cpp
--- trunk/source/operation/buffer/BufferBuilder.cpp 2008-11-26 19:47:22 UTC (rev 2230)
+++ trunk/source/operation/buffer/BufferBuilder.cpp 2009-01-05 23:42:08 UTC (rev 2231)
@@ -190,6 +190,8 @@
// just in case ...
if ( resultPolyList->empty() )
+ for (size_t i=0, n=subgraphList.size(); i<n; i++)
+ delete subgraphList[i];
return createEmptyResultGeometry();
Modified: trunk/source/operation/buffer/OffsetCurveVertexList.h
--- trunk/source/operation/buffer/OffsetCurveVertexList.h 2008-11-26 19:47:22 UTC (rev 2230)
+++ trunk/source/operation/buffer/OffsetCurveVertexList.h 2009-01-05 23:42:08 UTC (rev 2231)
@@ -148,6 +148,14 @@
return ptList;
+ // Added getCoordinatesRO(), which returns the coordinates without
+ // passing ownership to the caller.
+ const geom::CoordinateSequence* getCoordinatesRO()
+ closeRing();
+ return ptList;
} // namespace geos.operation.buffer
Modified: trunk/source/operation/linemerge/LineMerger.cpp
--- trunk/source/operation/linemerge/LineMerger.cpp 2008-11-26 19:47:22 UTC (rev 2230)
+++ trunk/source/operation/linemerge/LineMerger.cpp 2009-01-05 23:42:08 UTC (rev 2231)
@@ -207,7 +207,11 @@
LineMerger::getMergedLineStrings()
merge();
- return mergedLineStrings;
+ // Explicitly give ownership to the caller.
+ vector<LineString*>* ret = mergedLineStrings;
+ mergedLineStrings = NULL;
+ return ret;
} // namespace geos.operation.linemerge
More information about the geos-commits
