[geos-commits] r2232 - in trunk: capi tests/unit tests/unit/capi
svn_geos at osgeo.org
Mon Jan 12 20:21:06 EST 2009
Author: pramsey
Date: 2009-01-12 20:21:05 -0500 (Mon, 12 Jan 2009)
New Revision: 2232
Added:
trunk/tests/unit/capi/geostest.c
trunk/tests/unit/capi/test.expected
trunk/tests/unit/capi/test.wkt
trunk/tests/unit/capi/testrunner.sh
Removed:
trunk/capi/geostest.c
trunk/capi/test.expected
trunk/capi/test.wkt
trunk/capi/testrunner.sh
trunk/capi/Makefile.am
trunk/capi/geos_c.cpp
trunk/capi/geos_c.h.in
trunk/tests/unit/Makefile.am
Apply patch for issue #210 (thread safe c-api) submitted by Chuck Thibert.
Modified: trunk/capi/Makefile.am
--- trunk/capi/Makefile.am 2009-01-05 23:42:08 UTC (rev 2231)
+++ trunk/capi/Makefile.am 2009-01-13 01:21:05 UTC (rev 2232)
@@ -3,27 +3,17 @@
GEOS_CAPI_VERSION="@VERSION at -CAPI-@CAPI_VERSION@"
GEOS_JTS_PORT="@JTS_PORT@"
-TESTS = testrunner
-check_PROGRAMS = geostest
-geostest_SOURCES = geostest.c
-# stdc++ dependency should be deduced by libgeos_c.la
-##geostest_LDFLAGS = -lstdc++
-geostest_LDADD = libgeos_c.la
-geostest_INCLUDES = -I.
INCLUDES = -I$(top_srcdir)/source/headers
capidir = $(includedir)
nodist_capi_HEADERS = \
- geos_c.h
+ geos_c.h
lib_LTLIBRARIES = libgeos_c.la
DIR_SOURCES = \
- geos_c.cpp
+ geos_c.cpp geos_ts_c.cpp
libgeos_c_la_SOURCES = $(DIR_SOURCES)
libgeos_c_la_CPPFLAGS = -DGEOS_CAPI_VERSION='$(GEOS_CAPI_VERSION)' -DGEOS_JTS_PORT='$(GEOS_JTS_PORT)'
@@ -35,9 +25,4 @@
dist-local:
cp -p $(DIST_SOURCES) Makefile.am Makefile.in $(distdir)
-CLEANFILES = testrunner test.out
-EXTRA_DIST = testrunner.sh test.expected test.wkt geos_c.h
-testrunner: testrunner.sh
- sh $(srcdir)/testrunner.sh $@ $(srcdir)
+EXTRA_DIST = geos_c.h
Modified: trunk/capi/geos_c.cpp
--- trunk/capi/geos_c.cpp 2009-01-05 23:42:08 UTC (rev 2231)
+++ trunk/capi/geos_c.cpp 2009-01-13 01:21:05 UTC (rev 2232)
@@ -15,45 +15,14 @@
-#include <geos/geom/Geometry.h>
-#include <geos/geom/prep/PreparedGeometry.h>
#include <geos/geom/prep/PreparedGeometryFactory.h>
-#include <geos/geom/GeometryCollection.h>
-#include <geos/geom/Polygon.h>
-#include <geos/geom/Point.h>
-#include <geos/geom/MultiPoint.h>
-#include <geos/geom/MultiLineString.h>
-#include <geos/geom/MultiPolygon.h>
-#include <geos/geom/LinearRing.h>
-#include <geos/geom/LineString.h>
-#include <geos/geom/PrecisionModel.h>
-#include <geos/geom/GeometryFactory.h>
-#include <geos/geom/CoordinateSequenceFactory.h>
-#include <geos/geom/IntersectionMatrix.h>
#include <geos/io/WKTReader.h>
#include <geos/io/WKBReader.h>
#include <geos/io/WKTWriter.h>
#include <geos/io/WKBWriter.h>
#include <geos/io/CLocalizer.h>
-#include <geos/simplify/DouglasPeuckerSimplifier.h>
-#include <geos/simplify/TopologyPreservingSimplifier.h>
-#include <geos/operation/valid/IsValidOp.h>
-#include <geos/operation/polygonize/Polygonizer.h>
-#include <geos/operation/linemerge/LineMerger.h>
#include <geos/operation/overlay/OverlayOp.h>
-#include <geos/geom/BinaryOp.h>
-#include <geos/version.h>
-// This should go away
-#include <cstdio>
-#include <cstdlib>
-#include <cstring>
-#include <fstream>
-#include <iostream>
-#include <sstream>
-#include <string>
-#include <memory>
// Some extra magic to make type declarations in geos_c.h work - for cross-checking of types in header.
#define GEOSGeometry geos::geom::Geometry
#define GEOSPreparedGeometry geos::geom::prep::PreparedGeometry
@@ -94,36 +63,23 @@
typedef std::auto_ptr<Geometry> GeomAutoPtr;
-//## PROTOTYPES #############################################
-extern "C" const char GEOS_DLL *GEOSjtsport();
-extern "C" char GEOS_DLL *GEOSasText(Geometry *g1);
//## GLOBALS ################################################
// NOTE: SRID will have to be changed after geometry creation
-static const GeometryFactory *geomFactory =
- GeometryFactory::getDefaultInstance();
+GEOSContextHandle_t handle = NULL;
-static GEOSMessageHandler NOTICE_MESSAGE;
-static GEOSMessageHandler ERROR_MESSAGE;
-static int WKBOutputDims = 2;
-static int WKBByteOrder = getMachineByteOrder();
extern "C" {
void
initGEOS (GEOSMessageHandler nf, GEOSMessageHandler ef)
- NOTICE_MESSAGE = nf;
- ERROR_MESSAGE = ef;
+ handle = initGEOS_r( nf, ef );
void
finishGEOS ()
- // Nothing to do
- //delete geomFactory;
+ finishGEOS_r( handle );
@@ -134,110 +90,31 @@
char
GEOSDisjoint(const Geometry *g1, const Geometry *g2)
- try {
- bool result;
- result = g1->disjoint(g2);
- return result;
- catch (const std::exception &e)
- ERROR_MESSAGE("%s", e.what());
- return 2;
- catch (...)
- ERROR_MESSAGE("Unknown exception thrown");
- return 2;
+ return GEOSDisjoint_r( handle, g1, g2 );
char
GEOSTouches(const Geometry *g1, const Geometry *g2)
- try {
- bool result;
- result = g1->touches(g2);
- return result;
- return 2;
- catch (...)
- return 2;
+ return GEOSTouches_r( handle, g1, g2 );
char
GEOSIntersects(const Geometry *g1, const Geometry *g2)
- try {
- bool result;
- result = g1->intersects(g2);
- return result;
- return 2;
- catch (...)
- return 2;
+ return GEOSIntersects_r( handle, g1, g2 );
char
GEOSCrosses(const Geometry *g1, const Geometry *g2)
- try {
- bool result;
- result = g1->crosses(g2);
- return result;
- return 2;
- catch (...)
- return 2;
+ return GEOSCrosses_r( handle, g1, g2 );
char
GEOSWithin(const Geometry *g1, const Geometry *g2)
- try {
- bool result;
- result = g1->within(g2);
- return result;
- return 2;
- catch (...)
- return 2;
+ return GEOSWithin_r( handle, g1, g2 );
// call g1->contains(g2)
@@ -247,45 +124,13 @@
char
GEOSContains(const Geometry *g1, const Geometry *g2)
- try {
- bool result;
- result = g1->contains(g2);
- return result;
- return 2;
- catch (...)
- return 2;
+ return GEOSContains_r( handle, g1, g2 );
char
GEOSOverlaps(const Geometry *g1, const Geometry *g2)
- try {
- bool result;
- result = g1->overlaps(g2);
- return result;
- return 2;
- catch (...)
- return 2;
+ return GEOSOverlaps_r( handle, g1, g2 );
@@ -296,54 +141,13 @@
char
GEOSRelatePattern(const Geometry *g1, const Geometry *g2, const char *pat)
- try {
- bool result;
- std::string s = pat;
- result = g1->relate(g2,s);
- return result;
- return 2;
- catch (...)
- return 2;
+ return GEOSRelatePattern_r( handle, g1, g2, pat );
char *
GEOSRelate(const Geometry *g1, const Geometry *g2)
- using geos::geom::IntersectionMatrix;
- try {
- IntersectionMatrix *im = g1->relate(g2);
- if (im == NULL)
- return NULL;
- std::string s(im->toString());
- char *result = NULL;
- result = (char*) std::malloc( s.length() + 1);
- std::strcpy(result, s.c_str() );
- delete im;
- return result;
- catch (...)
- return NULL;
+ return GEOSRelate_r( handle, g1, g2 );
@@ -356,77 +160,13 @@
char
GEOSisValid(const Geometry *g1)
- using geos::operation::valid::IsValidOp;
- using geos::operation::valid::TopologyValidationError;
- IsValidOp ivo(g1);
- bool result;
- try {
- result = ivo.isValid();
- if ( result == 0 )
- TopologyValidationError *err = ivo.getValidationError();
- if ( err ) {
- std::string errmsg = err->toString();
- NOTICE_MESSAGE("%s", errmsg.c_str());
- return result;
- return 2;
- catch (...)
- return 2;
+ return GEOSisValid_r( handle, g1 );
char *
GEOSisValidReason(const Geometry *g1)
- try {
- bool isvalid = ivo.isValid();
- if ( ! isvalid )
- int msglen = 0;
- int loclen = 0;
- std::string errmsg = err->getMessage();
- std::string errloc = err->getCoordinate().toString();
- msglen = errmsg.length();
- loclen = errloc.length();
- result = (char*)std::malloc(msglen + loclen + 3);
- sprintf(result, "%s [%s]", errmsg.c_str(), errloc.c_str());
- else {
- result = strdup( "Valid Geometry" );
- return result;
- return NULL;
- catch (...)
- return NULL;
+ return GEOSisValidReason_r( handle, g1 );
@@ -436,218 +176,56 @@
char
GEOSEquals(const Geometry *g1, const Geometry *g2)
- try {
- bool result;
- result = g1->equals(g2);
- return result;
- return 2;
- catch (...)
- return 2;
+ return GEOSEquals_r( handle, g1, g2 );
char
GEOSEqualsExact(const Geometry *g1, const Geometry *g2, double tolerance)
- try {
- bool result;
- result = g1->equalsExact(g2, tolerance);
- return result;
- return 2;
- catch (...)
- return 2;
+ return GEOSEqualsExact_r( handle, g1, g2, tolerance );
int
GEOSDistance(const Geometry *g1, const Geometry *g2, double *dist)
- try {
- *dist = g1->distance(g2);
- return 1;
- return 0;
- catch (...)
- return 0;
+ return GEOSDistance_r( handle, g1, g2, dist );
int
GEOSArea(const Geometry *g, double *area)
- try {
- *area = g->getArea();
- return 1;
- return 0;
- catch (...)
- return 0;
+ return GEOSArea_r( handle, g, area );
int
GEOSLength(const Geometry *g, double *length)
- try {
- *length = g->getLength();
- return 1;
- return 0;
- catch (...)
- return 0;
+ return GEOSLength_r( handle, g, length );
Geometry *
GEOSGeomFromWKT(const char *wkt)
- CLocalizer clocale;
- try
- WKTReader r(geomFactory);
- const std::string wktstring = std::string(wkt);
- Geometry *g = r.read(wktstring);
- return g;
- return NULL;
- catch (...)
- return NULL;
+ return GEOSGeomFromWKT_r( handle, wkt );
char *
GEOSGeomToWKT(const Geometry *g1)
- try
- std::string s = g1->toString();
- char *result;
- return result;
- return NULL;
- catch (...)
- return NULL;
+ return GEOSGeomToWKT_r( handle, g1 );
// Remember to free the result!
unsigned char *
GEOSGeomToWKB_buf(const Geometry *g, size_t *size)
- using geos::io::WKBWriter;
- try
- int byteOrder = (int) WKBByteOrder;
- WKBWriter w(WKBOutputDims, byteOrder);
- std::ostringstream s(std::ios_base::binary);
- w.write(*g, s);
- std::string wkbstring = s.str();
- size_t len = wkbstring.length();
- unsigned char *result;
- result = (unsigned char*) std::malloc(len);
- std::memcpy(result, wkbstring.c_str(), len);
- *size = len;
- return result;
- return NULL;
- catch (...)
- return NULL;
+ return GEOSGeomToWKB_buf_r( handle, g, size );
Geometry *
GEOSGeomFromWKB_buf(const unsigned char *wkb, size_t size)
- using geos::io::WKBReader;
- try
- std::string wkbstring = std::string((const char*)wkb, size); // make it binary !
- WKBReader r(*geomFactory);
- std::istringstream s(std::ios_base::binary);
- s.str(wkbstring);
- s.seekg(0, std::ios::beg); // rewind reader pointer
- Geometry *g = r.read(s);
- return g;
- return NULL;
- catch (...)
- return NULL;
+ return GEOSGeomFromWKB_buf_r( handle, wkb, size );
/* Read/write wkb hex values. Returned geometries are
@@ -655,126 +233,31 @@
unsigned char *
GEOSGeomToHEX_buf(const Geometry *g, size_t *size)
- try
- w.writeHEX(*g, s);
- std::string hexstring = s.str();
- size_t len = hexstring.length();
- char *result;
- result = (char*) std::malloc(len);
- std::memcpy(result, hexstring.c_str(), len);
- *size = len;
- return (unsigned char*) result;
- return NULL;
- catch (...)
- return NULL;
+ return GEOSGeomToHEX_buf_r( handle, g, size );
Geometry *
GEOSGeomFromHEX_buf(const unsigned char *hex, size_t size)
- try
- std::string hexstring = std::string((const char*)hex, size);
- s.str(hexstring);
- Geometry *g = r.readHEX(s);
- return g;
- return NULL;
- catch (...)
- return NULL;
+ return GEOSGeomFromHEX_buf_r( handle, hex, size );
char
GEOSisEmpty(const Geometry *g1)
- try
- return g1->isEmpty();
- return 2;
- catch (...)
- return 2;
+ return GEOSisEmpty_r( handle, g1 );
char
GEOSisSimple(const Geometry *g1)
- try
- return g1->isSimple();
- return 2;
- catch (...)
- return 2;
+ return GEOSisSimple_r( handle, g1 );
char
GEOSisRing(const Geometry *g)
- try
- const LineString *ls = dynamic_cast<const LineString *>(g);
- if ( ls ) {
- return (ls->isRing());
- } else {
- return 0;
- return 2;
- catch (...)
- return 2;
+ return GEOSisRing_r( handle, g );
@@ -783,47 +266,14 @@
char *
GEOSGeomType(const Geometry *g1)
- try
- std::string s = g1->getGeometryType();
- char *result;
- return result;
- return NULL;
- catch (...)
- return NULL;
+ return GEOSGeomType_r( handle, g1 );
// Return postgis geometry type index
int
GEOSGeomTypeId(const Geometry *g1)
- try
- return g1->getGeometryTypeId();
- return -1;
- catch (...)
- return -1;
+ return GEOSGeomTypeId_r( handle, g1 );
@@ -836,207 +286,56 @@
Geometry *
GEOSEnvelope(const Geometry *g1)
- try
- Geometry *g3 = g1->getEnvelope();
- return g3;
- return NULL;
- catch (...)
- return NULL;
+ return GEOSEnvelope_r( handle, g1 );
Geometry *
GEOSIntersection(const Geometry *g1, const Geometry *g2)
- try
- GeomAutoPtr g3 = BinaryOp(g1, g2, overlayOp(OverlayOp::opINTERSECTION));
- return g3.release();
- //Geometry *g3 = g1->intersection(g2);
- //return g3;
- return NULL;
- catch (...)
- return NULL;
+ return GEOSIntersection_r( handle, g1, g2 );
Geometry *
GEOSBuffer(const Geometry *g1, double width, int quadrantsegments)
- try
- Geometry *g3 = g1->buffer(width, quadrantsegments);
- return g3;
- return NULL;
- catch (...)
- return NULL;
+ return GEOSBuffer_r( handle, g1, width, quadrantsegments );
Geometry *
GEOSConvexHull(const Geometry *g1)
- try
- Geometry *g3 = g1->convexHull();
- return g3;
- return NULL;
- catch (...)
- return NULL;
+ return GEOSConvexHull_r( handle, g1 );
Geometry *
GEOSDifference(const Geometry *g1, const Geometry *g2)
- try
- GeomAutoPtr g3 = BinaryOp(g1, g2, overlayOp(OverlayOp::opDIFFERENCE));
- //Geometry *g3 = g1->difference(g2);
- //return g3;
- return NULL;
- catch (...)
- return NULL;
+ return GEOSDifference_r( handle, g1, g2 );
Geometry *
GEOSBoundary(const Geometry *g1)
- try
- Geometry *g3 = g1->getBoundary();
- return g3;
- return NULL;
- catch (...)
- return NULL;
+ return GEOSBoundary_r( handle, g1 );
Geometry *
GEOSSymDifference(const Geometry *g1, const Geometry *g2)
- try
- GeomAutoPtr g3 = BinaryOp(g1, g2, overlayOp(OverlayOp::opSYMDIFFERENCE));
- //Geometry *g3 = g1->symDifference(g2);
- //return g3;
- return NULL;
- catch (...)
- return NULL;
+ return GEOSSymDifference_r( handle, g1, g2 );
Geometry *
GEOSUnion(const Geometry *g1, const Geometry *g2)
- try
- GeomAutoPtr g3 = BinaryOp(g1, g2, overlayOp(OverlayOp::opUNION));
- //Geometry *g3 = g1->Union(g2);
- //return g3;
-#if VERBOSE_EXCEPTIONS
- std::ostringstream s;
- s << "Exception on GEOSUnion with following inputs:" << std::endl;
- s << "A: "<<g1->toString() << std::endl;
- s << "B: "<<g2->toString() << std::endl;
- NOTICE_MESSAGE("%s", s.str().c_str());
-#endif // VERBOSE_EXCEPTIONS
- return NULL;
- catch (...)
- return NULL;
+ return GEOSUnion_r( handle, g1, g2 );
Geometry *
GEOSPointOnSurface(const Geometry *g1)
- try
- Geometry *ret = g1->getInteriorPoint();
- if ( ! ret ) return geomFactory->createGeometryCollection();
- return ret;
- return NULL;
- catch (...)
- return NULL;
+ return GEOSPointOnSurface_r( handle, g1 );
@@ -1051,63 +350,14 @@
void
GEOSGeom_destroy(Geometry *a)
- try{
- delete a;
- catch (...)
+ return GEOSGeom_destroy_r( handle, a );
-void
-GEOSSetSRID(Geometry *g, int SRID)
- g->setSRID(SRID);
-void
-GEOSdeleteChar(char *a)
- try{
- free(a);
- catch (...)
int
GEOSGetNumCoordinates(const Geometry *g1)
- try{
- return g1->getNumPoints();
- return -1;
- catch (...)
- return -1;
+ return GEOSGetNumCoordinates_r( handle, g1 );
@@ -1117,46 +367,13 @@
int
GEOSNormalize(Geometry *g1)
- try{
- g1->normalize();
- return -1;
- catch (...)
- return -1;
- return 0;
+ return GEOSNormalize_r( handle, g1 );
int
GEOSGetNumInteriorRings(const Geometry *g1)
- try{
- const Polygon *p = dynamic_cast<const Polygon *>(g1);
- if ( ! p )
- ERROR_MESSAGE("Argument is not a Polygon");
- return -1;
- return p->getNumInteriorRing();
- return -1;
- catch (...)
- return -1;
+ return GEOSGetNumInteriorRings_r( handle, g1 );
@@ -1164,20 +381,7 @@
int
GEOSGetNumGeometries(const Geometry *g1)
- try{
- return g1->getNumGeometries();
- return -1;
- catch (...)
- return -1;
+ return GEOSGetNumGeometries_r( handle, g1 );
@@ -1188,27 +392,7 @@
const Geometry *
GEOSGetGeometryN(const Geometry *g1, int n)
- using geos::geom::GeometryCollection;
- try{
- const GeometryCollection *gc = dynamic_cast<const GeometryCollection *>(g1);
- if ( ! gc )
- ERROR_MESSAGE("Argument is not a GeometryCollection");
- return NULL;
- return gc->getGeometryN(n);
- return NULL;
- catch (...)
- return NULL;
+ return GEOSGetGeometryN_r( handle, g1, n );
@@ -1219,26 +403,7 @@
const Geometry *
GEOSGetExteriorRing(const Geometry *g1)
- try{
- if ( ! p )
- ERROR_MESSAGE("Invalid argument (must be a Polygon)");
- return NULL;
- return p->getExteriorRing();
- return NULL;
- catch (...)
- return NULL;
+ return GEOSGetExteriorRing_r( handle, g1 );
@@ -1248,352 +413,87 @@
const Geometry *
GEOSGetInteriorRingN(const Geometry *g1, int n)
- try{
- if ( ! p )
- return NULL;
- return p->getInteriorRingN(n);
- return NULL;
- catch (...)
- return NULL;
+ return GEOSGetInteriorRingN_r( handle, g1, n );
Geometry *
GEOSGetCentroid(const Geometry *g)
- try{
- Geometry *ret = g->getCentroid();
- return ret;
- return NULL;
- catch (...)
- return NULL;
+ return GEOSGetCentroid_r( handle, g );
Geometry *
GEOSGeom_createCollection(int type, Geometry **geoms, unsigned int ngeoms)
-#ifdef GEOS_DEBUG
- char buf[256];
- sprintf(buf, "PostGIS2GEOS_collection: requested type %d, ngeoms: %d",
- type, ngeoms);
- NOTICE_MESSAGE("%s", buf);// TODO: Can NOTICE_MESSAGE format that directly?
-#endif
- try
- Geometry *g;
- std::vector<Geometry *> *vgeoms = new std::vector<Geometry *>(geoms, geoms+ngeoms);
- switch (type)
- case GEOS_GEOMETRYCOLLECTION:
- g = geomFactory->createGeometryCollection(vgeoms);
- break;
- case GEOS_MULTIPOINT:
- g = geomFactory->createMultiPoint(vgeoms);
- break;
- case GEOS_MULTILINESTRING:
- g = geomFactory->createMultiLineString(vgeoms);
- break;
- case GEOS_MULTIPOLYGON:
- g = geomFactory->createMultiPolygon(vgeoms);
- break;
- default:
- ERROR_MESSAGE("Unsupported type request for PostGIS2GEOS_collection");
- g = NULL;
- if (g==NULL) return NULL;
- return g;
- return NULL;
- catch (...)
- return NULL;
+ return GEOSGeom_createCollection_r( handle, type, geoms, ngeoms );
Geometry *
GEOSPolygonize(const Geometry * const * g, unsigned int ngeoms)
- using geos::operation::polygonize::Polygonizer;
- unsigned int i;
- Geometry *out = NULL;
- try{
- // Polygonize
- Polygonizer plgnzr;
- for (i=0; i<ngeoms; i++) plgnzr.add(g[i]);
-#if GEOS_DEBUG
- NOTICE_MESSAGE("geometry vector added to polygonizer");
-#endif
- std::vector<Polygon *>*polys = plgnzr.getPolygons();
-#if GEOS_DEBUG
- NOTICE_MESSAGE("output polygons got");
-#endif
- // We need a vector of Geometry pointers, not
- // Polygon pointers.
- // STL vector doesn't allow transparent upcast of this
- // nature, so we explicitly convert.
- // (it's just a waste of processor and memory, btw)
- std::vector<Geometry*> *polyvec =
- new std::vector<Geometry *>(polys->size());
- for (i=0; i<polys->size(); i++) (*polyvec)[i] = (*polys)[i];
- delete polys;
- out = geomFactory->createGeometryCollection(polyvec);
- // the above method takes ownership of the passed
- // vector, so we must *not* delete it
- return NULL;
- catch (...)
- return NULL;
- return out;
+ return GEOSPolygonize_r( handle, g, ngeoms );
Geometry *
GEOSPolygonizer_getCutEdges(const Geometry * const * g, unsigned int ngeoms)
- unsigned int i;
- try{
- // Polygonize
-#if GEOS_DEBUG
-#endif
- std::vector<const LineString *>*lines = plgnzr.getCutEdges();
-#if GEOS_DEBUG
-#endif
- std::vector<Geometry*> *linevec =
- new std::vector<Geometry *>(lines->size());
- for (i=0; i<lines->size(); i++) (*linevec)[i] = (*lines)[i]->clone();
- out = geomFactory->createGeometryCollection(linevec);
- return NULL;
- catch (...)
- return NULL;
- return out;
+ return GEOSPolygonizer_getCutEdges_r( handle, g, ngeoms );
Geometry *
GEOSLineMerge(const Geometry *g)
- using geos::operation::linemerge::LineMerger;
- unsigned int i;
- try{
- // LineMerge
- LineMerger lmrgr;
- lmrgr.add(g);
- std::vector<LineString *>*lines = lmrgr.getMergedLineStrings();
-#if GEOS_DEBUG
- NOTICE_MESSAGE("output lines got");
-#endif
- std::vector<Geometry *>*geoms = new std::vector<Geometry *>(lines->size());
- for (i=0; i<lines->size(); i++) (*geoms)[i] = (*lines)[i];
- delete lines;
- out = geomFactory->buildGeometry(geoms);
- //out = geomFactory->createGeometryCollection(geoms);
- return NULL;
- catch (...)
- return NULL;
- return out;
+ return GEOSLineMerge_r( handle, g );
int
GEOSGetSRID(const Geometry *g1)
- try{
- return g1->getSRID();
- return 0;
- catch (...)
- return 0;
+ return GEOSGetSRID_r( handle, g1 );
-const char *
-GEOSversion()
- //static string version = GEOS_CAPI_VERSION;
- return GEOS_CAPI_VERSION;
-const char *
-GEOSjtsport()
- //string version = jtsport();
- //char *res = strdup(version.c_str());
- //return res;
- return GEOS_JTS_PORT;
char
GEOSHasZ(const Geometry *g)
- if ( g->isEmpty() ) return false;
- double az = g->getCoordinate()->z;
- //ERROR_MESSAGE("ZCoord: %g", az);
- return FINITE(az);
+ return GEOSHasZ_r( handle, g );
int
GEOS_getWKBOutputDims()
- return WKBOutputDims;
+ return GEOS_getWKBOutputDims_r( handle );
int
GEOS_setWKBOutputDims(int newdims)
- if ( newdims < 2 || newdims > 3 )
- ERROR_MESSAGE("WKB output dimensions out of range 2..3");
- int olddims = WKBOutputDims;
- WKBOutputDims = newdims;
- return olddims;
+ return GEOS_setWKBOutputDims_r( handle, newdims );
int
GEOS_getWKBByteOrder()
- return WKBByteOrder;
+ return GEOS_getWKBByteOrder_r( handle );
int
GEOS_setWKBByteOrder(int byteOrder)
- int oldByteOrder = WKBByteOrder;
- WKBByteOrder = byteOrder;
- return oldByteOrder;
+ return GEOS_setWKBByteOrder_r( handle, byteOrder );
CoordinateSequence *
GEOSCoordSeq_create(unsigned int size, unsigned int dims)
- try {
- return geomFactory->getCoordinateSequenceFactory()->create(size, dims);
- return NULL;
- catch (...)
- return NULL;
+ return GEOSCoordSeq_create_r( handle, size, dims );
int
GEOSCoordSeq_setOrdinate(CoordinateSequence *s, unsigned int idx,
unsigned int dim, double val)
- try {
- s->setOrdinate(static_cast<int>(idx),
- static_cast<int>(dim), val);
- return 1;
- return 0;
- catch (...)
- return 0;
+ return GEOSCoordSeq_setOrdinate_r( handle, s, idx, dim, val );
int
@@ -1617,41 +517,14 @@
GEOSCoordSeq_clone(const CoordinateSequence *s)
- try { return s->clone(); }
- return NULL;
- catch (...)
- return NULL;
+ return GEOSCoordSeq_clone_r( handle, s );
int
GEOSCoordSeq_getOrdinate(const CoordinateSequence *s, unsigned int idx,
unsigned int dim, double *val)
- try {
- double d = s->getOrdinate(static_cast<int>(idx),
- static_cast<int>(dim));
- *val = d;
- return 1;
- return 0;
- catch (...)
- return 0;
+ return GEOSCoordSeq_getOrdinate_r( handle, s, idx, dim, val );
int
@@ -1675,287 +548,73 @@
int
GEOSCoordSeq_getSize(const CoordinateSequence *s, unsigned int *size)
- try {
- int sz = s->getSize();
- *size = static_cast<unsigned int>(sz);
- return 1;
- return 0;
- catch (...)
- return 0;
+ return GEOSCoordSeq_getSize_r( handle, s, size );
int
GEOSCoordSeq_getDimensions(const CoordinateSequence *s, unsigned int *dims)
- try {
- unsigned int dm = s->getDimension();
- *dims = dm;
- return 1;
- return 0;
- catch (...)
- return 0;
+ return GEOSCoordSeq_getDimensions_r( handle, s, dims );
void
GEOSCoordSeq_destroy(CoordinateSequence *s)
- try{
- delete s;
- catch (...)
+ return GEOSCoordSeq_destroy_r( handle, s );
GEOSGeom_getCoordSeq(const Geometry *g)
- using geos::geom::Point;
- try
- if ( ls )
- return ls->getCoordinatesRO();
- const Point *p = dynamic_cast<const Point *>(g);
- if ( p )
- return p->getCoordinatesRO();
- ERROR_MESSAGE("Geometry must be a Point or LineString");
- return NULL;
- return NULL;
- catch (...)
- return NULL;
+ return GEOSGeom_getCoordSeq_r( handle, g );
Geometry *
GEOSGeom_createPoint(CoordinateSequence *cs)
- try { return geomFactory->createPoint(cs); }
- return NULL;
- catch (...)
- return NULL;
+ return GEOSGeom_createPoint_r( handle, cs );
Geometry *
GEOSGeom_createLinearRing(CoordinateSequence *cs)
- try { return geomFactory->createLinearRing(cs); }
- return NULL;
- catch (...)
- return NULL;
+ return GEOSGeom_createLinearRing_r( handle, cs );
Geometry *
GEOSGeom_createLineString(CoordinateSequence *cs)
- try { return geomFactory->createLineString(cs); }
- return NULL;
- catch (...)
- return NULL;
+ return GEOSGeom_createLineString_r( handle, cs );
Geometry *
GEOSGeom_createPolygon(Geometry *shell, Geometry **holes, unsigned int nholes)
- using geos::geom::LinearRing;
- try
- std::vector<Geometry *> *vholes = new std::vector<Geometry *>(holes, holes+nholes);
- LinearRing *nshell = dynamic_cast<LinearRing *>(shell);
- if ( ! nshell )
- ERROR_MESSAGE("Shell is not a LinearRing");
- return NULL;
- return geomFactory->createPolygon(nshell, vholes);
- return NULL;
- catch (...)
- return NULL;
+ return GEOSGeom_createPolygon_r( handle, shell, holes, nholes );
Geometry *
GEOSGeom_clone(const Geometry *g)
- try { return g->clone(); }
- return NULL;
- catch (...)
- return NULL;
+ return GEOSGeom_clone_r( handle, g );
int
GEOSGeom_getDimensions(const Geometry *g)
- try {
- if ( ls )
- return ls->getCoordinatesRO()->getDimension();
- if ( p )
- return p->getCoordinatesRO()->getDimension();
- const Polygon *poly = dynamic_cast<const Polygon *>(g);
- if ( poly )
- return GEOSGeom_getDimensions(poly->getExteriorRing());
- const GeometryCollection *coll =
- dynamic_cast<const GeometryCollection *>(g);
- if ( coll )
- if ( coll->isEmpty() ) return 0;
- return GEOSGeom_getDimensions(coll->getGeometryN(0));
- ERROR_MESSAGE("Unknown geometry type");
- return 0;
- return 0;
- catch (...)
- return 0;
+ return GEOSGeom_getDimensions_r( handle, g );
Geometry *
GEOSSimplify(const Geometry *g1, double tolerance)
- using namespace geos::simplify;
- try
- Geometry::AutoPtr g(DouglasPeuckerSimplifier::simplify(
- g1, tolerance));
- return g.release();
- return NULL;
- catch (...)
- return NULL;
+ return GEOSSimplify_r( handle, g1, tolerance );
Geometry *
GEOSTopologyPreserveSimplify(const Geometry *g1, double tolerance)
- try
- Geometry::AutoPtr g(TopologyPreservingSimplifier::simplify(
- g1, tolerance));
- return NULL;
- catch (...)
- return NULL;
+ return GEOSTopologyPreserveSimplify_r( handle, g1, tolerance );
@@ -1963,258 +622,79 @@
WKTReader *
GEOSWKTReader_create()
- using geos::io::WKTReader;
- try
- return new WKTReader(geomFactory);
- return NULL;
- catch (...)
- return NULL;
+ return GEOSWKTReader_create_r( handle );
void
GEOSWKTReader_destroy(WKTReader *reader)
- try
- delete reader;
- catch (...)
+ GEOSWKTReader_destroy_r( handle, reader );
Geometry*
GEOSWKTReader_read(WKTReader *reader, const char *wkt)
- try
- Geometry *g = reader->read(wktstring);
- return g;
- return NULL;
- catch (...)
- return NULL;
+ return GEOSWKTReader_read_r( handle, reader, wkt );
/* WKT Writer */
WKTWriter *
GEOSWKTWriter_create()
- using geos::io::WKTWriter;
- try
- return new WKTWriter();
- return NULL;
- catch (...)
- return NULL;
+ return GEOSWKTWriter_create_r( handle );
void
GEOSWKTWriter_destroy(WKTWriter *Writer)
- try
- delete Writer;
- catch (...)
+ GEOSWKTWriter_destroy_r( handle, Writer );
char*
GEOSWKTWriter_write(WKTWriter *writer, const Geometry *geom)
- try
- std::string s = writer->write(geom);
- return result;
- catch (...)
- return NULL;
+ return GEOSWKTWriter_write_r( handle, writer, geom );
/* WKB Reader */
WKBReader *
GEOSWKBReader_create()
- try
- return new WKBReader(*geomFactory);
- catch (...)
- return NULL;
+ return GEOSWKBReader_create_r( handle );
void
GEOSWKBReader_destroy(WKBReader *reader)
- try
- delete reader;
- catch (...)
+ GEOSWKBReader_destroy_r( handle, reader );
Geometry*
GEOSWKBReader_read(WKBReader *reader, const unsigned char *wkb, size_t size)
- try
- s.str(wkbstring);
- Geometry *g = reader->read(s);
- return g;
- catch (...)
- return NULL;
+ return GEOSWKBReader_read_r( handle, reader, wkb, size );
Geometry*
GEOSWKBReader_readHEX(WKBReader *reader, const unsigned char *hex, size_t size)
- try
- s.str(hexstring);
- Geometry *g = reader->readHEX(s);
- return g;
- catch (...)
- return NULL;
+ return GEOSWKBReader_readHEX_r( handle, reader, hex, size );
/* WKB Writer */
WKBWriter *
GEOSWKBWriter_create()
- try
- return new WKBWriter();
- catch (...)
- return NULL;
+ return GEOSWKBWriter_create_r( handle );
void
GEOSWKBWriter_destroy(WKBWriter *Writer)
- try
- delete Writer;
- catch (...)
+ GEOSWKBWriter_destroy_r( handle, Writer );
@@ -2222,144 +702,50 @@
unsigned char*
GEOSWKBWriter_write(WKBWriter *writer, const Geometry *geom, size_t *size)
- try
- writer->write(*geom, s);
- unsigned char *result = NULL;
- *size = len;
- return result;
- catch (...)
- return NULL;
+ return GEOSWKBWriter_write_r( handle, writer, geom, size );
/* The owner owns the result */
unsigned char*
GEOSWKBWriter_writeHEX(WKBWriter *writer, const Geometry *geom, size_t *size)
- try
- writer->writeHEX(*geom, s);
- const size_t len = wkbstring.length();
- *size = len;
- return result;
- catch (...)
- return NULL;
+ return GEOSWKBWriter_writeHEX_r( handle, writer, geom, size );
int
GEOSWKBWriter_getOutputDimension(const GEOSWKBWriter* writer)
- try
- return writer->getOutputDimension();
- catch (...)
- return 0;
+ return GEOSWKBWriter_getOutputDimension_r( handle, writer );
void
GEOSWKBWriter_setOutputDimension(GEOSWKBWriter* writer, int newDimension)
- try
- return writer->setOutputDimension(newDimension);
- catch (...)
+ GEOSWKBWriter_setOutputDimension_r( handle, writer, newDimension );
int
GEOSWKBWriter_getByteOrder(const GEOSWKBWriter* writer)
- try
- return writer->getByteOrder();
- catch (...)
- return 0;
+ return GEOSWKBWriter_getByteOrder_r( handle, writer );
void
GEOSWKBWriter_setByteOrder(GEOSWKBWriter* writer, int newByteOrder)
- try
- return writer->setByteOrder(newByteOrder);
- catch (...)
+ GEOSWKBWriter_setByteOrder_r( handle, writer, newByteOrder );
char
GEOSWKBWriter_getIncludeSRID(const GEOSWKBWriter* writer)
- try
- return writer->getIncludeSRID();
- catch (...)
- return NULL;
+ return GEOSWKBWriter_getIncludeSRID_r( handle, writer );
void
GEOSWKBWriter_setIncludeSRID(GEOSWKBWriter* writer, const char newIncludeSRID)
- try
- writer->setIncludeSRID(newIncludeSRID);
- catch (...)
+ GEOSWKBWriter_setIncludeSRID_r( handle, writer, newIncludeSRID );
@@ -2370,123 +756,41 @@
const geos::geom::prep::PreparedGeometry*
GEOSPrepare(const Geometry *g)
- const geos::geom::prep::PreparedGeometry* prep = NULL;
- try
- prep = geos::geom::prep::PreparedGeometryFactory::prepare(g);
- catch (...)
- return prep;
+ return GEOSPrepare_r( handle, g );
void
GEOSPreparedGeom_destroy(const geos::geom::prep::PreparedGeometry *a)
- try
- delete a;
- catch (...)
+ GEOSPreparedGeom_destroy_r( handle, a );
char
-GEOSPreparedContains(const geos::geom::prep::PreparedGeometry *pg1, const Geometry *g2)
+GEOSPreparedContains(const geos::geom::prep::PreparedGeometry *pg1,
+ const Geometry *g2)
- try
- bool result;
- result = pg1->contains(g2);
- return result;
- return 2;
- catch (...)
- return 2;
+ return GEOSPreparedContains_r( handle, pg1, g2 );
char
-GEOSPreparedContainsProperly(const geos::geom::prep::PreparedGeometry *pg1, const Geometry *g2)
+GEOSPreparedContainsProperly(const geos::geom::prep::PreparedGeometry *pg1,
- try
- bool result;
- result = pg1->containsProperly(g2);
- return result;
- return 2;
- catch (...)
- return 2;
+ return GEOSPreparedContainsProperly_r( handle, pg1, g2 );
char
-GEOSPreparedCovers(const geos::geom::prep::PreparedGeometry *pg1, const Geometry *g2)
+GEOSPreparedCovers(const geos::geom::prep::PreparedGeometry *pg1,
- try
- bool result;
- result = pg1->covers(g2);
- return result;
- return 2;
- catch (...)
- return 2;
+ return GEOSPreparedCovers_r( handle, pg1, g2 );
char
-GEOSPreparedIntersects(const geos::geom::prep::PreparedGeometry *pg1, const Geometry *g2)
+GEOSPreparedIntersects(const geos::geom::prep::PreparedGeometry *pg1,
- try
- bool result;
- result = pg1->intersects(g2);
- return result;
- return 2;
- catch (...)
- return 2;
+ return GEOSPreparedIntersects_r( handle, pg1, g2 );
} //extern "C"
Modified: trunk/capi/geos_c.h.in
--- trunk/capi/geos_c.h.in 2009-01-05 23:42:08 UTC (rev 2231)
+++ trunk/capi/geos_c.h.in 2009-01-13 01:21:05 UTC (rev 2232)
@@ -45,9 +45,9 @@
- * Following 'ifdef' hack fixes problem with generating geos_c.h on Windows,
- * when building with Visual C++ compiler.
+ * * Following 'ifdef' hack fixes problem with generating geos_c.h on Windows,
+ * * when building with Visual C++ compiler.
#if defined(_MSC_VER)
#define GEOS_CAPI_VERSION_MAJOR 1
@@ -75,16 +75,16 @@
#define GEOS_CAPI_VERSION_MINOR @CAPI_VERSION_MINOR@
#define GEOS_CAPI_VERSION_PATCH @CAPI_VERSION_PATCH@
#define GEOS_CAPI_VERSION "@VERSION at -CAPI-@CAPI_VERSION@"
-#endif
+#endif
#define GEOS_CAPI_FIRST_INTERFACE GEOS_CAPI_VERSION_MAJOR
#define GEOS_CAPI_LAST_INTERFACE (GEOS_CAPI_VERSION_MAJOR+GEOS_CAPI_VERSION_MINOR)
* (Abstract) type definitions
typedef void (*GEOSMessageHandler)(const char *fmt, ...);
@@ -112,22 +112,23 @@
enum GEOSGeomTypes {
- GEOS_POINT,
- GEOS_LINESTRING,
- GEOS_LINEARRING,
- GEOS_POLYGON,
- GEOS_MULTIPOINT,
- GEOS_MULTILINESTRING,
- GEOS_MULTIPOLYGON,
- GEOS_GEOMETRYCOLLECTION
+ GEOS_POINT,
+ GEOS_LINESTRING,
+ GEOS_LINEARRING,
+ GEOS_POLYGON,
+ GEOS_MULTIPOINT,
+ GEOS_MULTILINESTRING,
+ GEOS_MULTIPOLYGON,
+ GEOS_GEOMETRYCOLLECTION
/* Byte oders exposed via the c api */
enum GEOSByteOrders {
- GEOS_WKB_XDR = 0, /* Big Endian */
- GEOS_WKB_NDR = 1 /* Little Endian */
+ GEOS_WKB_XDR = 0, /* Big Endian */
+ GEOS_WKB_NDR = 1 /* Little Endian */
+typedef struct GEOSContextHandle_HS *GEOSContextHandle_t;
@@ -144,6 +145,12 @@
extern void GEOS_DLL initGEOS(GEOSMessageHandler notice_function,
GEOSMessageHandler error_function);
extern void GEOS_DLL finishGEOS(void);
+extern GEOSContextHandle_t GEOS_DLL initGEOS_r(
+ GEOSMessageHandler notice_function,
+ GEOSMessageHandler error_function);
+extern void GEOS_DLL finishGEOS_r(GEOSContextHandle_t handle);
extern const char GEOS_DLL *GEOSversion();
@@ -157,6 +164,11 @@
extern GEOSGeometry GEOS_DLL *GEOSGeomFromWKT(const char *wkt);
extern char GEOS_DLL *GEOSGeomToWKT(const GEOSGeometry* g);
+extern GEOSGeometry GEOS_DLL *GEOSGeomFromWKT_r(GEOSContextHandle_t handle,
+ const char *wkt);
+extern char GEOS_DLL *GEOSGeomToWKT_r(GEOSContextHandle_t handle,
+ const GEOSGeometry* g);
* Specify whether output WKB should be 2d or 3d.
* Return previously set number of dimensions.
@@ -164,6 +176,10 @@
extern int GEOS_DLL GEOS_getWKBOutputDims();
extern int GEOS_DLL GEOS_setWKBOutputDims(int newDims);
+extern int GEOS_DLL GEOS_getWKBOutputDims_r(GEOSContextHandle_t handle);
+extern int GEOS_DLL GEOS_setWKBOutputDims_r(GEOSContextHandle_t handle,
+ int newDims);
* Specify whether the WKB byte order is big or little endian.
* The return value is the previous byte order.
@@ -177,6 +193,24 @@
extern GEOSGeometry GEOS_DLL *GEOSGeomFromHEX_buf(const unsigned char *hex, size_t size);
extern unsigned char GEOS_DLL *GEOSGeomToHEX_buf(const GEOSGeometry* g, size_t *size);
+extern int GEOS_DLL GEOS_getWKBByteOrder_r(GEOSContextHandle_t handle);
+extern int GEOS_DLL GEOS_setWKBByteOrder_r(GEOSContextHandle_t handle,
+ int byteOrder);
+extern GEOSGeometry GEOS_DLL *GEOSGeomFromWKB_buf_r(GEOSContextHandle_t handle,
+ const unsigned char *wkb,
+ size_t size);
+extern unsigned char GEOS_DLL *GEOSGeomToWKB_buf_r(GEOSContextHandle_t handle,
+ const GEOSGeometry* g,
+ size_t *size);
+extern GEOSGeometry GEOS_DLL *GEOSGeomFromHEX_buf_r(GEOSContextHandle_t handle,
+ const unsigned char *hex,
+ size_t size);
+extern unsigned char GEOS_DLL *GEOSGeomToHEX_buf_r(GEOSContextHandle_t handle,
+ size_t *size);
* Coordinate Sequence functions
@@ -190,17 +224,29 @@
extern GEOSCoordSequence GEOS_DLL *GEOSCoordSeq_create(unsigned int size, unsigned int dims);
+extern GEOSCoordSequence GEOS_DLL *GEOSCoordSeq_create_r(
+ GEOSContextHandle_t handle,
+ unsigned int size,
+ unsigned int dims);
* Clone a Coordinate Sequence.
* Return NULL on exception.
extern GEOSCoordSequence GEOS_DLL *GEOSCoordSeq_clone(const GEOSCoordSequence* s);
+extern GEOSCoordSequence GEOS_DLL *GEOSCoordSeq_clone_r(
+ const GEOSCoordSequence* s);
* Destroy a Coordinate Sequence.
extern void GEOS_DLL GEOSCoordSeq_destroy(GEOSCoordSequence* s);
+extern void GEOS_DLL GEOSCoordSeq_destroy_r(GEOSContextHandle_t handle,
+ GEOSCoordSequence* s);
* Set ordinate values in a Coordinate Sequence.
* Return 0 on exception.
@@ -214,6 +260,20 @@
extern int GEOS_DLL GEOSCoordSeq_setOrdinate(GEOSCoordSequence* s,
unsigned int idx, unsigned int dim, double val);
+extern int GEOS_DLL GEOSCoordSeq_setX_r(GEOSContextHandle_t handle,
+ GEOSCoordSequence* s, unsigned int idx,
+ double val);
+extern int GEOS_DLL GEOSCoordSeq_setY_r(GEOSContextHandle_t handle,
+ double val);
+extern int GEOS_DLL GEOSCoordSeq_setZ_r(GEOSContextHandle_t handle,
+ double val);
+extern int GEOS_DLL GEOSCoordSeq_setOrdinate_r(GEOSContextHandle_t handle,
+ unsigned int idx,
+ unsigned int dim, double val);
* Get ordinate values from a Coordinate Sequence.
@@ -227,6 +287,19 @@
extern int GEOS_DLL GEOSCoordSeq_getOrdinate(const GEOSCoordSequence* s,
unsigned int idx, unsigned int dim, double *val);
+extern int GEOS_DLL GEOSCoordSeq_getX_r(GEOSContextHandle_t handle,
+ const GEOSCoordSequence* s,
+ unsigned int idx, double *val);
+extern int GEOS_DLL GEOSCoordSeq_getY_r(GEOSContextHandle_t handle,
+extern int GEOS_DLL GEOSCoordSeq_getZ_r(GEOSContextHandle_t handle,
+extern int GEOS_DLL GEOSCoordSeq_getOrdinate_r(GEOSContextHandle_t handle,
+ unsigned int idx,
+ unsigned int dim, double *val);
* Get size and dimensions info from a Coordinate Sequence.
@@ -236,6 +309,12 @@
extern int GEOS_DLL GEOSCoordSeq_getDimensions(const GEOSCoordSequence* s,
unsigned int *dims);
+extern int GEOS_DLL GEOSCoordSeq_getSize_r(GEOSContextHandle_t handle,
+ unsigned int *size);
+extern int GEOS_DLL GEOSCoordSeq_getDimensions_r(GEOSContextHandle_t handle,
+ unsigned int *dims);
@@ -249,6 +328,16 @@
extern GEOSGeometry GEOS_DLL *GEOSGeom_createLinearRing(GEOSCoordSequence* s);
extern GEOSGeometry GEOS_DLL *GEOSGeom_createLineString(GEOSCoordSequence* s);
+extern GEOSGeometry GEOS_DLL *GEOSGeom_createPoint_r(
+extern GEOSGeometry GEOS_DLL *GEOSGeom_createLinearRing_r(
+extern GEOSGeometry GEOS_DLL *GEOSGeom_createLineString_r(
* Second argument is an array of GEOSGeometry* objects.
* The caller remains owner of the array, but pointed-to
@@ -259,8 +348,21 @@
extern GEOSGeometry GEOS_DLL *GEOSGeom_createCollection(int type,
GEOSGeometry* *geoms, unsigned int ngeoms);
+extern GEOSGeometry GEOS_DLL *GEOSGeom_createPolygon_r(
+ GEOSGeometry* shell,
+ GEOSGeometry** holes,
+ unsigned int nholes);
+extern GEOSGeometry GEOS_DLL *GEOSGeom_createCollection_r(
+ GEOSContextHandle_t handle, int type,
+ GEOSGeometry* *geoms,
+ unsigned int ngeoms);
extern GEOSGeometry GEOS_DLL *GEOSGeom_clone(const GEOSGeometry* g);
+extern GEOSGeometry GEOS_DLL *GEOSGeom_clone_r(GEOSContextHandle_t handle,
* Memory management
@@ -269,6 +371,8 @@
extern void GEOS_DLL GEOSGeom_destroy(GEOSGeometry* g);
+extern void GEOS_DLL GEOSGeom_destroy_r(GEOSContextHandle_t handle,
+ GEOSGeometry* g);
@@ -290,6 +394,35 @@
extern GEOSGeometry GEOS_DLL *GEOSGetCentroid(const GEOSGeometry* g);
extern char GEOS_DLL *GEOSRelate(const GEOSGeometry* g1, const GEOSGeometry* g2);
+extern GEOSGeometry GEOS_DLL *GEOSEnvelope_r(GEOSContextHandle_t handle,
+ const GEOSGeometry* g1);
+extern GEOSGeometry GEOS_DLL *GEOSIntersection_r(GEOSContextHandle_t handle,
+ const GEOSGeometry* g1,
+ const GEOSGeometry* g2);
+extern GEOSGeometry GEOS_DLL *GEOSBuffer_r(GEOSContextHandle_t handle,
+ double width, int quadsegs);
+extern GEOSGeometry GEOS_DLL *GEOSConvexHull_r(GEOSContextHandle_t handle,
+extern GEOSGeometry GEOS_DLL *GEOSDifference_r(GEOSContextHandle_t handle,
+extern GEOSGeometry GEOS_DLL *GEOSSymDifference_r(GEOSContextHandle_t handle,
+extern GEOSGeometry GEOS_DLL *GEOSBoundary_r(GEOSContextHandle_t handle,
+extern GEOSGeometry GEOS_DLL *GEOSUnion_r(GEOSContextHandle_t handle,
+extern GEOSGeometry GEOS_DLL *GEOSPointOnSurface_r(GEOSContextHandle_t handle,
+extern GEOSGeometry GEOS_DLL *GEOSGetCentroid_r(GEOSContextHandle_t handle,
+extern char GEOS_DLL *GEOSRelate_r(GEOSContextHandle_t handle,
* all arguments remain ownership of the caller
* (both Geometries and pointers)
@@ -302,6 +435,23 @@
extern GEOSGeometry GEOS_DLL *GEOSTopologyPreserveSimplify(const GEOSGeometry* g1,
double tolerance);
+extern GEOSGeometry GEOS_DLL *GEOSPolygonize_r(GEOSContextHandle_t handle,
+ const GEOSGeometry *const geoms[],
+extern GEOSGeometry GEOS_DLL *GEOSPolygonizer_getCutEdges_r(
+ const GEOSGeometry * const geoms[],
+extern GEOSGeometry GEOS_DLL *GEOSLineMerge_r(GEOSContextHandle_t handle,
+extern GEOSGeometry GEOS_DLL *GEOSSimplify_r(GEOSContextHandle_t handle,
+ double tolerance);
+extern GEOSGeometry GEOS_DLL *GEOSTopologyPreserveSimplify_r(
+ const GEOSGeometry* g1, double tolerance);
* Binary predicates - return 2 on exception, 1 on true, 0 on false
@@ -320,6 +470,38 @@
extern char GEOS_DLL GEOSEquals(const GEOSGeometry* g1, const GEOSGeometry* g2);
extern char GEOS_DLL GEOSEqualsExact(const GEOSGeometry* g1, const GEOSGeometry* g2, double tolerance);
+extern char GEOS_DLL GEOSRelatePattern_r(GEOSContextHandle_t handle,
+ const GEOSGeometry* g2,
+ const char *pat);
+extern char GEOS_DLL GEOSDisjoint_r(GEOSContextHandle_t handle,
+extern char GEOS_DLL GEOSTouches_r(GEOSContextHandle_t handle,
+extern char GEOS_DLL GEOSIntersects_r(GEOSContextHandle_t handle,
+extern char GEOS_DLL GEOSCrosses_r(GEOSContextHandle_t handle,
+extern char GEOS_DLL GEOSWithin_r(GEOSContextHandle_t handle,
+extern char GEOS_DLL GEOSContains_r(GEOSContextHandle_t handle,
+extern char GEOS_DLL GEOSOverlaps_r(GEOSContextHandle_t handle,
+extern char GEOS_DLL GEOSEquals_r(GEOSContextHandle_t handle,
+extern char GEOS_DLL GEOSEqualsExact_r(GEOSContextHandle_t handle,
@@ -339,7 +521,26 @@
extern char GEOS_DLL GEOSPreparedCovers(const GEOSPreparedGeometry* pg1, const GEOSGeometry* g2);
extern char GEOS_DLL GEOSPreparedIntersects(const GEOSPreparedGeometry* pg1, const GEOSGeometry* g2);
+extern const GEOSPreparedGeometry GEOS_DLL *GEOSPrepare_r(
+extern void GEOS_DLL GEOSPreparedGeom_destroy_r(GEOSContextHandle_t handle,
+ const GEOSPreparedGeometry* g);
+extern char GEOS_DLL GEOSPreparedContains_r(GEOSContextHandle_t handle,
+ const GEOSPreparedGeometry* pg1,
+extern char GEOS_DLL GEOSPreparedContainsProperly_r(GEOSContextHandle_t handle,
+extern char GEOS_DLL GEOSPreparedCovers_r(GEOSContextHandle_t handle,
+extern char GEOS_DLL GEOSPreparedIntersects_r(GEOSContextHandle_t handle,
* Unary predicate - return 2 on exception, 1 on true, 0 on false
@@ -353,6 +554,18 @@
extern char GEOS_DLL GEOSisRing(const GEOSGeometry* g1);
extern char GEOS_DLL GEOSHasZ(const GEOSGeometry* g1);
+extern char GEOS_DLL GEOSisEmpty_r(GEOSContextHandle_t handle,
+extern char GEOS_DLL GEOSisValid_r(GEOSContextHandle_t handle,
+extern char GEOS_DLL *GEOSisValidReason_r(GEOSContextHandle_t handle,
+extern char GEOS_DLL GEOSisSimple_r(GEOSContextHandle_t handle,
+extern char GEOS_DLL GEOSisRing_r(GEOSContextHandle_t handle,
+extern char GEOS_DLL GEOSHasZ_r(GEOSContextHandle_t handle,
@@ -363,14 +576,25 @@
/* Return NULL on exception, result must be freed by caller. */
extern char GEOS_DLL *GEOSGeomType(const GEOSGeometry* g1);
+extern char GEOS_DLL *GEOSGeomType_r(GEOSContextHandle_t handle,
/* Return -1 on exception */
extern int GEOS_DLL GEOSGeomTypeId(const GEOSGeometry* g1);
+extern int GEOS_DLL GEOSGeomTypeId_r(GEOSContextHandle_t handle,
/* Return 0 on exception */
extern int GEOS_DLL GEOSGetSRID(const GEOSGeometry* g1);
extern void GEOS_DLL GEOSSetSRID(GEOSGeometry* g, int SRID);
+extern int GEOS_DLL GEOSGetSRID_r(GEOSContextHandle_t handle,
+extern void GEOS_DLL GEOSSetSRID(GEOSGeometry* g, int SRID);
/* May be called on all geometries in GEOS 3.x, returns -1 on error and 1
* for non-multi geometries. Older GEOS versions only accept
* GeometryCollections or Multi* geometries here, and are likely to crash
@@ -379,6 +603,9 @@
extern int GEOS_DLL GEOSGetNumGeometries(const GEOSGeometry* g1);
+extern int GEOS_DLL GEOSGetNumGeometries_r(GEOSContextHandle_t handle,
* Return NULL on exception, Geometry must be a Collection.
* Returned object is a pointer to internal storage:
@@ -386,12 +613,22 @@
extern const GEOSGeometry GEOS_DLL *GEOSGetGeometryN(const GEOSGeometry* g, int n);
+extern const GEOSGeometry GEOS_DLL *GEOSGetGeometryN_r(
+ const GEOSGeometry* g, int n);
extern int GEOS_DLL GEOSNormalize(GEOSGeometry* g1);
+extern int GEOS_DLL GEOSNormalize_r(GEOSContextHandle_t handle,
+ GEOSGeometry* g1);
extern int GEOS_DLL GEOSGetNumInteriorRings(const GEOSGeometry* g1);
+extern int GEOS_DLL GEOSGetNumInteriorRings_r(GEOSContextHandle_t handle,
* Return NULL on exception, Geometry must be a Polygon.
@@ -399,6 +636,10 @@
extern const GEOSGeometry GEOS_DLL *GEOSGetInteriorRingN(const GEOSGeometry* g, int n);
+extern const GEOSGeometry GEOS_DLL *GEOSGetInteriorRingN_r(
@@ -406,20 +647,34 @@
extern const GEOSGeometry GEOS_DLL *GEOSGetExteriorRing(const GEOSGeometry* g);
+extern const GEOSGeometry GEOS_DLL *GEOSGetExteriorRing_r(
extern int GEOS_DLL GEOSGetNumCoordinates(const GEOSGeometry* g1);
+extern int GEOS_DLL GEOSGetNumCoordinates_r(GEOSContextHandle_t handle,
* Geometry must be a LineString, LinearRing or Point.
extern const GEOSCoordSequence GEOS_DLL *GEOSGeom_getCoordSeq(const GEOSGeometry* g);
+extern const GEOSCoordSequence GEOS_DLL *GEOSGeom_getCoordSeq_r(
* Return 0 on exception (or empty geometry)
extern int GEOS_DLL GEOSGeom_getDimensions(const GEOSGeometry* g);
+extern int GEOS_DLL GEOSGeom_getDimensions_r(GEOSContextHandle_t handle,
* Misc functions
@@ -432,6 +687,13 @@
extern int GEOS_DLL GEOSDistance(const GEOSGeometry* g1, const GEOSGeometry* g2,
double *dist);
+extern int GEOS_DLL GEOSArea_r(GEOSContextHandle_t handle,
+ const GEOSGeometry* g1, double *area);
+extern int GEOS_DLL GEOSLength_r(GEOSContextHandle_t handle,
+ const GEOSGeometry* g1, double *length);
+extern int GEOS_DLL GEOSDistance_r(GEOSContextHandle_t handle,
+ const GEOSGeometry* g2, double *dist);
@@ -451,25 +713,71 @@
extern void GEOS_DLL GEOSWKTReader_destroy(GEOSWKTReader* reader);
extern GEOSGeometry GEOS_DLL *GEOSWKTReader_read(GEOSWKTReader* reader, const char *wkt);
+extern GEOSWKTReader GEOS_DLL *GEOSWKTReader_create_r(
+ GEOSContextHandle_t handle);
+extern void GEOS_DLL GEOSWKTReader_destroy_r(GEOSContextHandle_t handle,
+ GEOSWKTReader* reader);
+extern GEOSGeometry GEOS_DLL *GEOSWKTReader_read_r(GEOSContextHandle_t handle,
+ GEOSWKTReader* reader,
+ const char *wkt);
/* WKT Writer */
extern GEOSWKTWriter GEOS_DLL *GEOSWKTWriter_create();
extern void GEOS_DLL GEOSWKTWriter_destroy(GEOSWKTWriter* writer);
extern char GEOS_DLL *GEOSWKTWriter_write(GEOSWKTWriter* reader, const GEOSGeometry* g);
+extern GEOSWKTWriter GEOS_DLL *GEOSWKTWriter_create_r(
+extern void GEOS_DLL GEOSWKTWriter_destroy_r(GEOSContextHandle_t handle,
+ GEOSWKTWriter* writer);
+extern char GEOS_DLL *GEOSWKTWriter_write_r(GEOSContextHandle_t handle,
+ GEOSWKTWriter* reader,
/* WKB Reader */
extern GEOSWKBReader GEOS_DLL *GEOSWKBReader_create();
extern void GEOS_DLL GEOSWKBReader_destroy(GEOSWKBReader* reader);
extern GEOSGeometry GEOS_DLL *GEOSWKBReader_read(GEOSWKBReader* reader, const unsigned char *wkb, size_t size);
extern GEOSGeometry GEOS_DLL *GEOSWKBReader_readHEX(GEOSWKBReader* reader, const unsigned char *hex, size_t size);
+extern GEOSWKBReader GEOS_DLL *GEOSWKBReader_create_r(
+extern void GEOS_DLL GEOSWKBReader_destroy_r(GEOSContextHandle_t handle,
+ GEOSWKBReader* reader);
+extern GEOSGeometry GEOS_DLL *GEOSWKBReader_read_r(GEOSContextHandle_t handle,
+ GEOSWKBReader* reader,
+ size_t size);
+extern GEOSGeometry GEOS_DLL *GEOSWKBReader_readHEX_r(
+ size_t size);
/* WKB Writer */
extern GEOSWKBWriter GEOS_DLL *GEOSWKBWriter_create();
extern void GEOS_DLL GEOSWKBWriter_destroy(GEOSWKBWriter* writer);
+extern GEOSWKBWriter GEOS_DLL *GEOSWKBWriter_create_r(
+extern void GEOS_DLL GEOSWKBWriter_destroy_r(GEOSContextHandle_t handle,
+ GEOSWKBWriter* writer);
/* The owner owns the results for these two methods! */
extern unsigned char GEOS_DLL *GEOSWKBWriter_write(GEOSWKBWriter* writer, const GEOSGeometry* g, size_t *size);
extern unsigned char GEOS_DLL *GEOSWKBWriter_writeHEX(GEOSWKBWriter* writer, const GEOSGeometry* g, size_t *size);
+extern unsigned char GEOS_DLL *GEOSWKBWriter_write_r(
+ GEOSWKBWriter* writer,
+ size_t *size);
+extern unsigned char GEOS_DLL *GEOSWKBWriter_writeHEX_r(
+ size_t *size);
@@ -477,6 +785,13 @@
extern int GEOS_DLL GEOSWKBWriter_getOutputDimension(const GEOSWKBWriter* writer);
extern void GEOS_DLL GEOSWKBWriter_setOutputDimension(GEOSWKBWriter* writer, int newDimension);
+extern int GEOS_DLL GEOSWKBWriter_getOutputDimension_r(
+ const GEOSWKBWriter* writer);
+extern void GEOS_DLL GEOSWKBWriter_setOutputDimension_r(
+ GEOSWKBWriter* writer, int newDimension);
@@ -484,12 +799,22 @@
extern int GEOS_DLL GEOSWKBWriter_getByteOrder(const GEOSWKBWriter* writer);
extern void GEOS_DLL GEOSWKBWriter_setByteOrder(GEOSWKBWriter* writer, int byteOrder);
+extern int GEOS_DLL GEOSWKBWriter_getByteOrder_r(GEOSContextHandle_t handle,
+extern void GEOS_DLL GEOSWKBWriter_setByteOrder_r(GEOSContextHandle_t handle,
+ int byteOrder);
* Specify whether SRID values should be output.
extern char GEOS_DLL GEOSWKBWriter_getIncludeSRID(const GEOSWKBWriter* writer);
extern void GEOS_DLL GEOSWKBWriter_setIncludeSRID(GEOSWKBWriter* writer, const char writeSRID);
+extern char GEOS_DLL GEOSWKBWriter_getIncludeSRID_r(GEOSContextHandle_t handle,
+extern void GEOS_DLL GEOSWKBWriter_setIncludeSRID_r(GEOSContextHandle_t handle,
+ GEOSWKBWriter* writer, const char writeSRID);
Deleted: trunk/capi/geostest.c
--- trunk/capi/geostest.c 2009-01-05 23:42:08 UTC (rev 2231)
+++ trunk/capi/geostest.c 2009-01-13 01:21:05 UTC (rev 2232)
@@ -1,383 +0,0 @@
- * $Id$
- * Test for C-Wrapper of GEOS library
- * Copyright (C) 2005 Refractions Research Inc.
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
- * Author: Sandro Santilli <strk at refractions.net>
-#define _GNU_SOURCE
-#include <stdio.h>
-#include <stdlib.h>
-#include <stdarg.h>
-#include "geos_c.h"
-#define MAXWKTLEN 1047551
-void
-usage(char *me)
- fprintf(stderr, "Usage: %s <wktfile>\n", me);
- exit(1);
-void
-notice(const char *fmt, ...) {
- va_list ap;
- fprintf( stdout, "NOTICE: ");
- va_start (ap, fmt);
- vfprintf( stdout, fmt, ap);
- va_end(ap);
- fprintf( stdout, "\n" );
-void
-log_and_exit(const char *fmt, ...) {
- va_list ap;
- fprintf( stdout, "ERROR: ");
- va_end(ap);
- exit(1);
-GEOSGeometry*
-fineGrainedReconstructionTest(const GEOSGeometry* g1)
- GEOSCoordSequence* cs;
- GEOSGeometry* g2;
- GEOSGeometry* shell;
- const GEOSGeometry* gtmp;
- GEOSGeometry**geoms;
- unsigned int ngeoms, i;
- int type;
- /* Geometry reconstruction from CoordSeq */
- type = GEOSGeomTypeId(g1);
- switch ( type )
- case GEOS_POINT:
- cs = GEOSCoordSeq_clone(GEOSGeom_getCoordSeq(g1));
- g2 = GEOSGeom_createPoint(cs);
- return g2;
- break;
- case GEOS_LINESTRING:
- g2 = GEOSGeom_createLineString(cs);
- return g2;
- break;
- case GEOS_LINEARRING:
- g2 = GEOSGeom_createLinearRing(cs);
- return g2;
- break;
- case GEOS_POLYGON:
- gtmp = GEOSGetExteriorRing(g1);
- cs = GEOSCoordSeq_clone(GEOSGeom_getCoordSeq(gtmp));
- shell = GEOSGeom_createLinearRing(cs);
- ngeoms = GEOSGetNumInteriorRings(g1);
- geoms = malloc(ngeoms*sizeof(GEOSGeometry*));
- gtmp = GEOSGetInteriorRingN(g1, i);
- geoms[i] = GEOSGeom_createLinearRing(cs);
- g2 = GEOSGeom_createPolygon(shell, geoms, ngeoms);
- free(geoms);
- return g2;
- break;
- ngeoms = GEOSGetNumGeometries(g1);
- gtmp = GEOSGetGeometryN(g1, i);
- geoms[i] = fineGrainedReconstructionTest(gtmp);
- g2 = GEOSGeom_createCollection(type, geoms, ngeoms);
- free(geoms);
- return g2;
- break;
- default:
- log_and_exit("Unknown geometry type %d\n", type);
- return NULL;
-void
-printHEX(FILE *where, const unsigned char *bytes, size_t n)
- static char hex[] = "0123456789ABCDEF";
- int i;
- for (i=0; i<n; i++)
- fprintf(where, "%c%c", hex[bytes[i]>>4], hex[bytes[i]&0x0F]);
-int
-do_all(char *inputfile)
- GEOSGeometry* g1;
- GEOSGeometry* g2;
- GEOSGeometry* g3;
- GEOSGeometry* g4;
- const GEOSGeometry **gg;
- unsigned int npoints, ndims;
- static char wkt[MAXWKTLEN];
- FILE *input;
- char *ptr;
- unsigned char* uptr;
- size_t size;
- double dist, area;
- input = fopen(inputfile, "r");
- if ( ! input ) { perror("fopen"); exit(1); }
- size = fread(wkt, 1, MAXWKTLEN-1, input);
- fclose(input);
- if ( ! size ) { perror("fread"); exit(1); }
- if ( size == MAXWKTLEN-1 ) { perror("WKT input too big!"); exit(1); }
- wkt[size] = '\0'; /* ensure it is null terminated */
- /* WKT input */
- g1 = GEOSGeomFromWKT(wkt);
- /* WKT output */
- ptr = GEOSGeomToWKT(g1);
- printf("Input (WKT): %s\n", ptr);
- free(ptr);
- /* WKB output */
- uptr = GEOSGeomToWKB_buf(g1, &size);
- printf("Input (WKB): "); printHEX(stdout, uptr, size); putchar('\n');
- /* WKB input */
- g2 = GEOSGeomFromWKB_buf(uptr, size); free(uptr);
- if ( ! GEOSEquals(g1, g2) ) log_and_exit("Round WKB conversion failed");
- GEOSGeom_destroy(g2);
- /* Size and dimension */
- npoints = GEOSGetNumCoordinates(g1);
- ndims = GEOSGeom_getDimensions(g1);
- printf("Geometry coordinates: %dx%d\n", npoints, ndims);
- /* Geometry fine-grained deconstruction/reconstruction test */
- g2 = fineGrainedReconstructionTest(g1);
- log_and_exit("Reconstruction test failed\n");
- /* Unary predicates */
- if ( GEOSisEmpty(g1) ) printf("isEmpty\n");
- if ( GEOSisValid(g1) ) printf("isValid\n");
- if ( GEOSisSimple(g1) ) printf("isSimple\n");
- if ( GEOSisRing(g1) ) printf("isRing\n");
- /* Convex Hull */
- g2 = GEOSConvexHull(g1);
- if ( ! g2 )
- log_and_exit("GEOSConvexHull() raised an exception");
- ptr = GEOSGeomToWKT(g2);
- printf("ConvexHull: %s\n", ptr);
- free(ptr);
- /* Buffer */
- GEOSGeom_destroy(g1);
- g1 = GEOSBuffer(g2, 100, 30);
- if ( ! g1 )
- log_and_exit("GEOSBuffer() raised an exception");
- printf("Buffer: %s\n", ptr);
- free(ptr);
- /* Intersection */
- g3 = GEOSIntersection(g1, g2);
- if ( ! GEOSEquals(g3, g2) )
- GEOSGeom_destroy(g3);
- log_and_exit("Intersection(g, Buffer(g)) didn't return g");
- ptr = GEOSGeomToWKT(g3);
- printf("Intersection: %s\n", ptr);
- free(ptr);
- /* Difference */
- g3 = GEOSDifference(g1, g2);
- printf("Difference: %s\n", ptr);
- free(ptr);
- /* SymDifference */
- g3 = GEOSSymDifference(g1, g2);
- printf("SymDifference: %s\n", ptr);
- free(ptr);
- /* Boundary */
- g4 = GEOSBoundary(g3);
- ptr = GEOSGeomToWKT(g4);
- printf("Boundary: %s\n", ptr);
- GEOSGeom_destroy(g4);
- free(ptr);
- /* Union */
- g3 = GEOSUnion(g1, g2);
- if ( ! GEOSEquals(g3, g1) )
- log_and_exit("Union(g, Buffer(g)) didn't return Buffer(g)");
- printf("Union: %s\n", ptr);
- free(ptr);
- /* PointOnSurcace */
- g4 = GEOSPointOnSurface(g3);
- printf("PointOnSurface: %s\n", ptr);
- free(ptr);
- /* Centroid */
- g3 = GEOSGetCentroid(g2);
- printf("Centroid: %s\n", ptr);
- free(ptr);
- /* Relate (and RelatePattern )*/
- ptr = GEOSRelate(g1, g2);
- if ( ! GEOSRelatePattern(g1, g2, ptr) )
- free(ptr);
- log_and_exit("! RelatePattern(g1, g2, Relate(g1, g2))");
- printf("Relate: %s\n", ptr);
- free(ptr);
- /* Polygonize */
- gg = (const GEOSGeometry**)malloc(2*sizeof(GEOSGeometry*));
- gg[0] = g1;
- gg[1] = g2;
- g3 = GEOSPolygonize(gg, 2);
- free(gg);
- if ( ! g3 )
- log_and_exit("Exception running GEOSPolygonize");
- printf("Polygonize: %s\n", ptr);
- free(ptr);
- /* LineMerge */
- g3 = GEOSLineMerge(g1);
- if ( ! g3 )
- log_and_exit("Exception running GEOSLineMerge");
- printf("LineMerge: %s\n", ptr);
- free(ptr);
- /* Binary predicates */
- if ( GEOSIntersects(g1, g2) ) printf("Intersect\n");
- if ( GEOSDisjoint(g1, g2) ) printf("Disjoint\n");
- if ( GEOSTouches(g1, g2) ) printf("Touches\n");
- if ( GEOSCrosses(g1, g2) ) printf("Crosses\n");
- if ( GEOSWithin(g1, g2) ) printf("Within\n");
- if ( GEOSContains(g1, g2) ) printf("Contains\n");
- if ( GEOSOverlaps(g1, g2) ) printf("Overlaps\n");
- /* Distance */
- if ( GEOSDistance(g1, g2, &dist) ) printf("Distance: %g\n", dist);
- /* Area */
- if ( GEOSArea(g1, &area) ) printf("Area 1: %g\n", area);
- if ( GEOSArea(g2, &area) ) printf("Area 2: %g\n", area);
- /* Simplify */
- g3 = GEOSSimplify(g1, 0.5);
- printf("Simplify: %s\n", ptr);
- free(ptr);
- /* Topology Preserve Simplify */
- g3 = GEOSTopologyPreserveSimplify(g1, 0.5);
- free(ptr);
- return 0;
-int
-main(int argc, char **argv)
- int i, n=1;
- initGEOS(notice, log_and_exit);
- printf("GEOS version %s\n", GEOSversion());
- if ( argc < 2 ) usage(argv[0]);
- if ( argc > 2 ) n=atoi(argv[2]);
- if ( ! n ) n=1;
- for (i=0; i<n; i++) {
- putc('.', stderr); fflush(stderr);
- do_all(argv[1]);
- putc('+', stderr); fflush(stderr);
- putc('\n', stderr);
- finishGEOS();
- return EXIT_SUCCESS;
Deleted: trunk/capi/test.expected
--- trunk/capi/test.expected 2009-01-05 23:42:08 UTC (rev 2231)
+++ trunk/capi/test.expected 2009-01-13 01:21:05 UTC (rev 2232)
@@ -1,25 +0,0 @@
-GEOS version 3.0.0rc2-CAPI-1.3.0
-Input (WKT): MULTIPOLYGON (((362062.2000000029802322 231744.0000000000000000, 362076.0000000000000000 231749.7999999969906639, 362122.2999999970197678 231753.5000000000000000, 362187.0000000000000000 231767.9000000059895683, 362242.0000000000000000 231776.0000000000000000, 362296.2000000029802322 231786.7000000030093361, 362517.0000000000000000 231821.5000000000000000, 362651.7999999970197678 231844.7999999969906639, 362772.7000000029802322 231871.7999999969906639, 362805.0999999939813279 231874.2999999969906639, 362847.2000000029802322 231876.0000000000000000, 362912.7999999970197678 231888.9000000059895683, 363005.9000000060186721 231903.0000000000000000, 363169.2000000029802322 231929.2999999969906639, 363247.9000000060186721 231934.0000000000000000, 363333.9000000060186721 231950.0000000000000000, 363516.0999999939813279 231985.5000000000000000, 363630.2999999970197678 232004.7000000030093361, 363694.7000000029802322 232012.0000000000000000, 363754.0000000000000000 232021.0999999940104317, 363833.4000000060186721 232029.7999999969906639, 363913.5999999939813279 232048.5000000000000000, 363940.5999999939813279 232052.0000000000000000, 364014.7999999970197678 232060.2999999969906639, 364044.7000000029802322 232065.7999999969906639, 364082.7000000029802322 232074.0999999940104317, 364165.2999999970197678 232083.7999999969906639, 364208.5999999939813279 232097.0999999940104317, 364279.7999999970197678 232104.0000000000000000, 364316.7000000029802322 232112.7999999969906639, 364331.2000000029802322 232113.5999999940104317, 364391.2000000029802322 232127.5999999940104317, 364483.7999999970197678 232140.0000000000000000, 364606.7999999970197678 232159.5999999940104317, 364662.7999999970197678 232170.5999999940104317, 364712.9000000060186721 232182.7000000030093361, 364823.7999999970197678 232201.5000000000000000, 364904.9000000060186721 232211.0000000000000000, 364967.2000000029802322 232221.0999999940104317, 365061.2999999970197678 232240.5000000000000000, 365191.0999999939813279 232255.9000000059895683, 365262.9000000060186721 232262.2999999969906639, 365391.7000000029802322 232283.5999999940104317, 365525.2999999970197678 232308.9000000059895683, 365598.4000000060186721 232326.5999999940104317, 365727.0999999939813279 232341.5999999940104317, 365803.0000000000000000 232352.2999999969906639, 365935.4000000060186721 232377.5999999940104317, 366011.5000000000000000 232384.7999999969906639, 366056.0999999939813279 232391.2000000030093361, 366128.7000000029802322 232407.4000000059895683, 366295.5999999939813279 232442.7000000030093361, 366445.2000000029802322 232457.2000000030093361, 366624.7999999970197678 232486.2999999969906639, 366663.2000000029802322 232490.2000000030093361, 366707.2000000029802322 232502.4000000059895683, 366807.0999999939813279 232522.7000000030093361, 366862.9000000060186721 232529.7999999969906639, 366971.0999999939813279 232543.5000000000000000, 367088.0999999939813279 232563.0999999940104317, 367185.2999999970197678 232575.4000000059895683, 367222.2000000029802322 232582.4000000059895683, 367331.7999999970197678 232597.0000000000000000, 367530.2999999970197678 232629.7999999969906639, 367683.5999999939813279 232660.7000000030093361, 367772.5999999939813279 232675.7999999969906639, 367939.0000000000000000 232693.0999999940104317, 367995.5999999939813279 232701.0000000000000000, 368055.0999999939813279 232702.5999999940104317, 368135.0000000000000000 232714.2999999969906639, 368220.7999999970197678 232735.4000000059895683, 368312.5999999939813279 232753.4000000059895683, 368380.7999999970197678 232770.7999999969906639, 368447.2999999970197678 232777.5999999940104317, 368512.0999999939813279 232792.0999999940104317, 368544.0000000000000000 232795.5999999940104317, 368601.7999999970197678 232805.0999999940104317, 368660.7999999970197678 232813.0999999940104317, 368707.2999999970197678 232826.4000000059895683, 368782.5000000000000000 232836.0999999940104317, 368832.5999999939813279 232847.7999999969906639, 368906.5999999939813279 232860.5000000000000000, 368992.5000000000000000 232873.0999999940104317, 369089.0999999939813279 232892.0000000000000000, 369260.5000000000000000 232916.7000000030093361, 369318.7000000029802322 232931.2000000030093361, 369445.5999999939813279 232945.5999999940104317, 369508.7000000029802322 232950.0999999940104317, 369574.2000000029802322 232960.5000000000000000, 369616.0999999939813279 232967.7999999969906639, 369656.2000000029802322 232978.2000000030093361, 369717.7000000029802322 233002.0000000000000000, 369777.7000000029802322 233016.0999999940104317, 369875.4000000060186721 233024.0000000000000000, 370035.0000000000000000 233046.9000000059895683, 370117.0999999939813279 233056.0000000000000000, 370200.0999999939813279 233077.5999999940104317, 370233.5999999939813279 233079.0999999940104317, 370496.9000000060186721 233123.2999999969906639, 370539.4000000060186721 233127.0000000000000000, 370601.7000000029802322 233135.0000000000000000, 370655.2999999970197678 233146.5999999940104317, 370855.0999999939813279 233178.7999999969906639, 370932.7000000029802322 233182.0999999940104317, 371060.0999999939813279 233205.0000000000000000, 371120.7000000029802322 233223.0000000000000000, 371178.5999999939813279 233233.0000000000000000, 371201.7999999970197678 233229.2000000030093361, 371245.2999999970197678 233232.5000000000000000, 371289.9000000060186721 233243.7000000030093361, 371425.7999999970197678 233259.0000000000000000, 371487.5000000000000000 233276.4000000059895683, 371552.2999999970197678 233291.9000000059895683, 371638.0999999939813279 233306.4000000059895683, 371715.0999999939813279 233318.5999999940104317, 371821.2000000029802322 233332.4000000059895683, 371918.2999999970197678 233350.7999999969906639, 371988.0999999939813279 233360.2000000030093361, 372040.7000000029802322 233366.2999999969906639, 372158.5999999939813279 233382.2999999969906639, 372175.5000000000000000 233379.5999999940104317, 372201.0999999939813279 233382.5999999940104317, 372351.2999999970197678 233410.0999999940104317, 372419.0000000000000000 233417.5000000000000000, 372500.7999999970197678 233432.2000000030093361, 372538.7000000029802322 233434.0999999940104317, 372559.2999999970197678 233439.2000000030093361, 372715.7999999970197678 233463.5999999940104317, 372780.9000000060186721 233472.0999999940104317, 372809.5999999939813279 233479.5999999940104317, 372842.9000000060186721 233484.0000000000000000, 372895.9000000060186721 233498.0999999940104317, 372959.7999999970197678 233506.0999999940104317, 372967.7999999970197678 233500.5000000000000000, 372986.0999999939813279 233503.7000000030093361, 373016.2000000029802322 233511.5999999940104317, 373076.5000000000000000 233519.7000000030093361, 373115.5000000000000000 233524.5000000000000000, 373133.9000000060186721 233529.7000000030093361, 373218.7999999970197678 233538.9000000059895683, 373322.5999999939813279 233555.2000000030093361, 373403.9000000060186721 233574.7999999969906639, 373503.5000000000000000 233590.0999999940104317, 373539.5999999939813279 233594.0999999940104317, 373567.7000000029802322 233595.0999999940104317, 373612.9000000060186721 233595.2999999969906639, 373629.5000000000000000 233598.0000000000000000, 373642.2000000029802322 233597.9000000059895683, 373633.7999999970197678 233582.0999999940104317, 373623.7999999970197678 233570.2000000030093361, 373584.0999999939813279 233479.2000000030093361, 373562.9000000060186721 233422.0999999940104317, 373549.0999999939813279 233399.0000000000000000, 373506.7999999970197678 233325.7999999969906639, 373487.2999999970197678 233294.2000000030093361, 373460.2000000029802322 233259.7999999969906639, 373442.0999999939813279 233240.0999999940104317, 373426.7000000029802322 233220.0000000000000000, 373405.4000000060186721 233187.2999999969906639, 373383.0999999939813279 233164.7999999969906639, 373333.5999999939813279 233096.7000000030093361, 373325.5000000000000000 233078.5000000000000000, 373298.2999999970197678 233028.5999999940104317, 373269.2999999970197678 232982.5999999940104317, 373220.0999999939813279 232893.2000000030093361, 373190.7999999970197678 232853.7000000030093361, 373145.4000000060186721 232784.7000000030093361, 373100.9000000060186721 232712.0000000000000000, 373090.4000000060186721 232680.2999999969906639, 373077.5999999939813279 232660.0999999940104317, 373046.4000000060186721 232597.2999999969906639, 373028.9000000060186721 232538.2000000030093361, 373012.4000000060186721 232520.0000000000000000, 373002.5000000000000000 232506.2999999969906639, 372997.2999999970197678 232499.9000000059895683, 372979.9000000060186721 232471.7999999969906639, 372966.5000000000000000 232452.4000000059895683, 372963.0999999939813279 232436.0999999940104317, 372925.2000000029802322 232361.5000000000000000, 372900.0000000000000000 232326.4000000059895683, 372885.7000000029802322 232295.2000000030093361, 372849.7000000029802322 232245.0000000000000000, 372803.2999999970197678 232173.7999999969906639, 372764.9000000060186721 232096.2000000030093361, 372735.2000000029802322 232063.2999999969906639, 372710.9000000060186721 232032.2000000030093361, 372692.5000000000000000 232004.7000000030093361, 372691.9000000060186721 231988.7000000030093361, 372680.0000000000000000 231952.0000000000000000, 372658.5999999939813279 231917.0000000000000000, 372655.5999999939813279 231898.0000000000000000, 372629.7999999970197678 231847.0999999940104317, 372609.7999999970197678 231810.5999999940104317, 372589.2999999970197678 231778.0000000000000000, 372571.0000000000000000 231743.4000000059895683, 372549.4000000060186721 231706.7000000030093361, 372536.9000000060186721 231677.0999999940104317, 372497.9000000060186721 231600.4000000059895683, 372476.7999999970197678 231562.9000000059895683, 372467.5999999939813279 231529.0999999940104317, 372455.0000000000000000 231502.4000000059895683, 372444.2999999970197678 231467.7000000030093361, 372431.0000000000000000 231419.5000000000000000, 372394.5000000000000000 231364.2999999969906639, 372379.0000000000000000 231339.5000000000000000, 372355.0000000000000000 231312.5999999940104317, 372344.0999999939813279 231286.2999999969906639, 372307.7999999970197678 231214.0000000000000000, 372292.0999999939813279 231194.9000000059895683, 372274.5000000000000000 231145.2999999969906639, 372260.0999999939813279 231120.5999999940104317, 372226.2999999970197678 231083.2999999969906639, 372194.2999999970197678 231041.4000000059895683, 372136.4000000060186721 230959.0999999940104317, 372112.7999999970197678 230922.5000000000000000, 372065.5999999939813279 230841.5999999940104317, 372054.0000000000000000 230818.2999999969906639, 372031.7000000029802322 230784.2999999969906639, 372014.7000000029802322 230735.5999999940104317, 371990.4000000060186721 230694.2000000030093361, 371950.7999999970197678 230628.4000000059895683, 371931.7000000029802322 230578.9000000059895683, 371890.9000000060186721 230511.2999999969906639, 371874.9000000060186721 230494.5000000000000000, 371861.4000000060186721 230513.7000000030093361, 371858.0000000000000000 230493.4000000059895683, 371846.0999999939813279 230455.0999999940104317, 371828.0999999939813279 230407.5000000000000000, 371813.2999999970197678 230374.7999999969906639, 371787.7999999970197678 230316.5000000000000000, 371751.2999999970197678 230262.7000000030093361, 371731.5000000000000000 230213.7000000030093361, 371699.2000000029802322 230171.7999999969906639, 371679.2999999970197678 230125.2000000030093361, 371656.5999999939813279 230095.5999999940104317, 371621.4000000060186721 230055.4000000059895683, 371584.2999999970197678 229987.7000000030093361, 371550.0999999939813279 229912.5000000000000000, 371526.9000000060186721 229867.4000000059895683, 371504.7999999970197678 229838.7999999969906639, 371485.5999999939813279 229801.7999999969906639, 371475.5000000000000000 229778.0000000000000000, 371461.4000000060186721 229752.2000000030093361, 371440.7000000029802322 229706.7999999969906639, 371400.7999999970197678 229629.0999999940104317, 371372.4000000060186721 229581.5999999940104317, 371349.4000000060186721 229546.5999999940104317, 371312.2999999970197678 229480.4000000059895683, 371296.2000000029802322 229454.2999999969906639, 371274.9000000060186721 229432.0999999940104317, 371253.0999999939813279 229396.0999999940104317, 371224.5000000000000000 229358.0999999940104317, 371185.5000000000000000 229294.0000000000000000, 371153.2999999970197678 229239.7000000030093361, 371066.4000000060186721 229032.7000000030093361, 371027.5000000000000000 228966.9000000059895683, 371004.7999999970197678 228913.0000000000000000, 370991.0000000000000000 228890.2000000030093361, 370938.0999999939813279 228790.4000000059895683, 370919.2999999970197678 228762.7999999969906639, 370884.2999999970197678 228707.4000000059895683, 370840.0000000000000000 228630.9000000059895683, 370797.2000000029802322 228558.2999999969906639, 370722.5000000000000000 228398.9000000059895683, 370677.2000000029802322 228323.2999999969906639, 370655.5000000000000000 228268.2999999969906639, 370635.0000000000000000 228228.7999999969906639, 370577.7999999970197678 228117.5999999940104317, 370556.9000000060186721 228088.4000000059895683, 370533.5999999939813279 228047.9000000059895683, 370511.2999999970197678 228025.2999999969906639, 370485.2000000029802322 227994.7999999969906639, 370435.7999999970197678 227946.2999999969906639, 370399.7999999970197678 227881.0999999940104317, 370342.5999999939813279 227793.2000000030093361, 370316.4000000060186721 227755.2999999969906639, 370239.5999999939813279 227614.7999999969906639, 370195.0000000000000000 227565.2000000030093361, 370123.2999999970197678 227431.2000000030093361, 370067.0000000000000000 227353.9000000059895683, 370025.5000000000000000 227277.7000000030093361, 369958.5000000000000000 227171.5000000000000000, 369938.7999999970197678 227130.5000000000000000, 369892.7999999970197678 227050.5000000000000000, 369876.7999999970197678 227022.7999999969906639, 369837.7999999970197678 226970.5000000000000000, 369820.7999999970197678 226933.0000000000000000, 369782.4000000060186721 226859.7999999969906639, 369762.0999999939813279 226819.2000000030093361, 369739.0999999939813279 226782.2000000030093361, 369713.0999999939813279 226749.2000000030093361, 369686.5000000000000000 226704.7000000030093361, 369642.4000000060186721 226620.0999999940104317, 369596.2000000029802322 226546.0999999940104317, 369578.5000000000000000 226510.5000000000000000, 369541.4000000060186721 226455.2000000030093361, 369519.0000000000000000 226397.2000000030093361, 369476.7999999970197678 226327.0999999940104317, 369435.5999999939813279 226235.5999999940104317, 369404.9000000060186721 226135.2999999969906639, 369367.4000000060186721 226063.0999999940104317, 369353.7999999970197678 226024.0000000000000000, 369316.9000000060186721 225937.7999999969906639, 369292.9000000060186721 225899.7999999969906639, 369258.7999999970197678 225837.5000000000000000, 369226.0999999939813279 225790.5999999940104317, 369191.9000000060186721 225739.9000000059895683, 369169.7000000029802322 225702.7999999969906639, 369136.7999999970197678 225661.9000000059895683, 369115.5000000000000000 225641.7999999969906639, 368998.0999999939813279 225443.2999999969906639, 368960.2000000029802322 225358.5999999940104317, 368890.7999999970197678 225224.5999999940104317, 368812.7999999970197678 225025.9000000059895683, 368771.7000000029802322 224939.2999999969906639, 368741.9000000060186721 224859.9000000059895683, 368701.4000000060186721 224765.9000000059895683, 368679.0999999939813279 224703.4000000059895683, 368637.0999999939813279 224627.2999999969906639, 368616.7000000029802322 224565.7999999969906639, 368592.7999999970197678 224525.2999999969906639, 368547.5000000000000000 224416.7999999969906639, 368528.0000000000000000 224383.7999999969906639, 368468.5999999939813279 224270.0000000000000000, 368457.2000000029802322 224234.2000000030093361, 368445.0999999939813279 224206.0000000000000000, 368404.4000000060186721 224140.4000000059895683, 368387.0000000000000000 224066.9000000059895683, 368348.7999999970197678 223972.2000000030093361, 368324.5999999939813279 223901.2999999969906639, 368299.0999999939813279 223849.2999999969906639, 368281.0999999939813279 223819.2000000030093361, 368249.7000000029802322 223748.4000000059895683, 368221.7999999970197678 223704.0000000000000000, 368187.0999999939813279 223625.7999999969906639, 368163.5999999939813279 223575.7999999969906639, 368139.7999999970197678 223508.4000000059895683, 368111.0999999939813279 223455.5000000000000000, 368083.9000000060186721 223370.5999999940104317, 368056.0000000000000000 223315.7000000030093361, 368028.7000000029802322 223248.7999999969906639, 368011.0000000000000000 223201.7000000030093361, 367981.7999999970197678 223133.9000000059895683, 367963.4000000060186721 223102.7999999969906639, 367932.0999999939813279 223056.4000000059895683, 367903.2999999970197678 222978.5999999940104317, 367852.0999999939813279 222807.4000000059895683, 367820.5999999939813279 222727.0999999940104317, 367790.0999999939813279 222635.4000000059895683, 367757.7999999970197678 222557.5999999940104317, 367742.4000000060186721 222516.0000000000000000, 367708.2000000029802322 222426.2999999969906639, 367660.2000000029802322 222299.9000000059895683, 367625.7999999970197678 222225.5999999940104317, 367591.7000000029802322 222159.4000000059895683, 367561.2999999970197678 222093.5000000000000000, 367502.2000000029802322 221924.4000000059895683, 367472.9000000060186721 221842.5999999940104317, 367458.5000000000000000 221819.4000000059895683, 367427.7000000029802322 221735.7000000030093361, 367385.0000000000000000 221624.0999999940104317, 367360.5000000000000000 221574.2000000030093361, 367326.0000000000000000 221490.0000000000000000, 367290.2999999970197678 221393.2999999969906639, 367271.2000000029802322 221339.7000000030093361, 367244.0999999939813279 221268.7999999969906639, 367237.2999999970197678 221245.9000000059895683, 367214.0000000000000000 221194.0000000000000000, 367200.4000000060186721 221137.9000000059895683, 367162.2999999970197678 221044.7000000030093361, 367147.0999999939813279 220987.0999999940104317, 367117.7999999970197678 220919.2999999969906639, 367102.7999999970197678 220894.0999999940104317, 367073.5999999939813279 220814.7999999969906639, 367023.4000000060186721 220673.0000000000000000, 366980.0999999939813279 220598.2999999969906639, 366962.0999999939813279 220558.7999999969906639, 366905.7999999970197678 220454.4000000059895683, 366882.4000000060186721 220416.9000000059895683, 366857.0000000000000000 220370.5000000000000000, 366824.4000000060186721 220272.7999999969906639, 366787.5999999939813279 220128.7000000030093361, 366743.9000000060186721 220049.2000000030093361, 366730.5000000000000000 220013.0000000000000000, 366694.7999999970197678 219922.4000000059895683, 366668.2999999970197678 219845.4000000059895683, 366642.2999999970197678 219788.5000000000000000, 366621.0000000000000000 219728.5000000000000000, 366602.0000000000000000 219663.5000000000000000, 366578.2999999970197678 219606.5999999940104317, 366570.7000000029802322 219575.7000000030093361, 366551.5999999939813279 219513.2000000030093361, 366507.5000000000000000 219429.5999999940104317, 366492.0000000000000000 219386.0000000000000000, 366458.4000000060186721 219301.2000000030093361, 366426.7000000029802322 219211.0000000000000000, 366392.9000000060186721 219139.2000000030093361, 366373.0999999939813279 219087.2000000030093361, 366316.5999999939813279 218974.4000000059895683, 366294.7999999970197678 218940.7999999969906639, 366260.7999999970197678 218889.5000000000000000, 366214.2999999970197678 218764.0999999940104317, 366187.5999999939813279 218662.4000000059895683, 366165.0000000000000000 218615.7999999969906639, 366128.7999999970197678 218519.2000000030093361, 366086.9000000060186721 218417.5999999940104317, 366068.7999999970197678 218378.0000000000000000, 366035.0000000000000000 218307.2000000030093361, 366012.2000000029802322 218231.7999999969906639, 365984.7000000029802322 218153.4000000059895683, 365950.2000000029802322 218060.7999999969906639, 365922.0999999939813279 218017.7999999969906639, 365903.4000000060186721 217982.2000000030093361, 365835.2000000029802322 217851.0999999940104317, 365798.5000000000000000 217801.9000000059895683, 365728.4000000060186721 217660.2999999969906639, 365673.2000000029802322 217559.0000000000000000, 365657.5000000000000000 217511.4000000059895683, 365636.9000000060186721 217461.9000000059895683, 365589.2999999970197678 217352.4000000059895683, 365560.7000000029802322 217312.0000000000000000, 365525.2000000029802322 217245.2999999969906639, 365480.9000000060186721 217133.2000000030093361, 365442.5000000000000000 217056.5999999940104317, 365405.9000000060186721 216955.5000000000000000, 365379.2000000029802322 216908.0000000000000000, 365341.2000000029802322 216825.7999999969906639, 365319.2000000029802322 216784.2999999969906639, 365303.2999999970197678 216741.5999999940104317, 365259.2999999970197678 216668.0000000000000000, 365243.2000000029802322 216626.4000000059895683, 365206.9000000060186721 216581.0999999940104317, 365172.5000000000000000 216521.7999999969906639, 365148.7000000029802322 216481.7999999969906639, 365127.2000000029802322 216438.7999999969906639, 365081.2999999970197678 216365.2000000030093361, 365054.5000000000000000 216305.2999999969906639, 365045.0999999939813279 216300.0000000000000000, 365042.4000000060186721 216280.5999999940104317, 365035.0000000000000000 216259.2999999969906639, 365022.9000000060186721 216243.5000000000000000, 365011.7999999970197678 216224.2000000030093361, 364987.5999999939813279 216190.2000000030093361, 364980.9000000060186721 216167.2999999969906639, 364958.2999999970197678 216136.7999999969906639, 364941.7999999970197678 216095.7000000030093361, 364917.7999999970197678 216058.2000000030093361, 364883.2999999970197678 216007.7999999969906639, 364861.2000000029802322 215961.2999999969906639, 364850.2999999970197678 215946.0000000000000000, 364833.7999999970197678 215915.9000000059895683, 364803.7000000029802322 215856.0000000000000000, 364770.0000000000000000 215806.2000000030093361, 364714.7000000029802322 215744.7999999969906639, 364702.5999999939813279 215717.0000000000000000, 364679.5999999939813279 215672.9000000059895683, 364650.7999999970197678 215618.0000000000000000, 364631.7999999970197678 215591.5000000000000000, 364601.0999999939813279 215554.5000000000000000, 364583.7999999970197678 215510.9000000059895683, 364568.5999999939813279 215482.2000000030093361, 364521.5000000000000000 215423.0999999940104317, 364479.2000000029802322 215387.0000000000000000, 364413.2000000029802322 215308.2000000030093361, 364385.2000000029802322 215279.2000000030093361, 364366.2000000029802322 215262.5999999940104317, 364336.4000000060186721 215230.0999999940104317, 364285.0000000000000000 215148.7000000030093361, 364246.2999999970197678 215118.2999999969906639, 364224.5999999939813279 215094.2999999969906639, 364190.0999999939813279 215058.9000000059895683, 364165.0999999939813279 215030.4000000059895683, 364125.7999999970197678 214999.5999999940104317, 364103.5999999939813279 214973.0000000000000000, 364053.5999999939813279 214926.0000000000000000, 364011.7999999970197678 214890.7000000030093361, 363965.5000000000000000 214853.5000000000000000, 363920.7000000029802322 214801.9000000059895683, 363876.5000000000000000 214769.7000000030093361, 363806.2999999970197678 214703.5000000000000000, 363766.7000000029802322 214674.2000000030093361, 363747.7999999970197678 214657.0000000000000000, 363681.7000000029802322 214592.2999999969906639, 363620.5000000000000000 214559.7999999969906639, 363580.2999999970197678 214535.5000000000000000, 363530.5999999939813279 214496.4000000059895683, 363510.2999999970197678 214495.7000000030093361, 363474.9000000060186721 214488.7999999969906639, 363430.5000000000000000 214476.5000000000000000, 363381.0999999939813279 214465.2999999969906639, 363316.5000000000000000 214466.4000000059895683, 363252.5999999939813279 214461.4000000059895683, 363156.7000000029802322 214466.4000000059895683, 363090.7999999970197678 214484.2999999969906639, 363077.5000000000000000 214493.5000000000000000, 363067.0999999939813279 214497.2000000030093361, 363040.0000000000000000 214500.2000000030093361, 362914.5999999939813279 214528.5000000000000000, 362870.2000000029802322 214553.0999999940104317, 362846.2999999970197678 214560.5999999940104317, 362828.4000000060186721 214561.9000000059895683, 362827.0000000000000000 214572.7999999969906639, 362814.0000000000000000 214577.5000000000000000, 362776.5000000000000000 214595.5999999940104317, 362765.4000000060186721 214599.2000000030093361, 362667.9000000060186721 214651.5999999940104317, 362630.2999999970197678 214667.7000000030093361, 362576.0999999939813279 214694.0000000000000000, 362543.2999999970197678 214725.4000000059895683, 362511.9000000060186721 214750.9000000059895683, 362478.0000000000000000 214757.4000000059895683, 362379.2999999970197678 214796.7999999969906639, 362260.2999999970197678 214866.5000000000000000, 362127.0999999939813279 214946.7999999969906639, 362023.9000000060186721 215017.2999999969906639, 361984.0999999939813279 215042.4000000059895683, 361890.5000000000000000 215113.7000000030093361, 361777.5999999939813279 215181.7999999969906639, 361710.0999999939813279 215233.7999999969906639, 361692.4000000060186721 215248.4000000059895683, 361671.7000000029802322 215256.7000000030093361, 361597.9000000060186721 215286.9000000059895683, 361502.5000000000000000 215343.7000000030093361, 361472.0000000000000000 215357.2000000030093361, 361423.7000000029802322 215382.7999999969906639, 361259.2000000029802322 215487.7000000030093361, 361226.5999999939813279 215505.7000000030093361, 361191.5999999939813279 215527.7000000030093361, 361118.7000000029802322 215568.2999999969906639, 360996.0999999939813279 215603.5000000000000000, 360963.9000000060186721 215608.5000000000000000, 360927.7999999970197678 215621.5000000000000000, 360842.7999999970197678 215661.9000000059895683, 360789.5999999939813279 215691.0000000000000000, 360754.0999999939813279 215720.0999999940104317, 360727.2000000029802322 215747.4000000059895683, 360701.7999999970197678 215765.7999999969906639, 360660.5000000000000000 215812.9000000059895683, 360654.2999999970197678 215825.9000000059895683, 360615.2999999970197678 215860.9000000059895683, 360579.2999999970197678 215885.0000000000000000, 360488.2000000029802322 215951.2000000030093361, 360455.4000000060186721 215982.0999999940104317, 360441.2000000029802322 216003.7999999969906639, 360437.7000000029802322 216052.2000000030093361, 360418.2999999970197678 216065.0000000000000000, 360341.0999999939813279 216078.5999999940104317, 360322.0000000000000000 216078.5000000000000000, 360150.7000000029802322 216078.2000000030093361, 359950.5999999939813279 216070.4000000059895683, 359871.2999999970197678 216067.2000000030093361, 359804.9000000060186721 216063.7999999969906639, 359732.7999999970197678 216061.2999999969906639, 359707.2000000029802322 216057.2999999969906639, 359633.7999999970197678 216055.4000000059895683, 359624.4000000060186721 216048.5999999940104317, 359625.9000000060186721 216033.5999999940104317, 359629.0000000000000000 216003.7000000030093361, 359644.5999999939813279 215957.5999999940104317, 359657.4000000060186721 215924.9000000059895683, 359666.5000000000000000 215890.9000000059895683, 359668.4000000060186721 215838.4000000059895683, 359654.0000000000000000 215798.2999999969906639, 359637.7000000029802322 215765.5999999940104317, 359599.0000000000000000 215719.4000000059895683, 359511.2999999970197678 215645.5000000000000000, 359472.4000000060186721 215625.5999999940104317, 359428.0999999939813279 215611.4000000059895683, 359380.9000000060186721 215602.7000000030093361, 359323.5000000000000000 215606.5999999940104317, 359253.0000000000000000 215621.7000000030093361, 359209.9000000060186721 215664.7000000030093361, 359166.5000000000000000 215718.7000000030093361, 359135.7999999970197678 215767.7000000030093361, 359093.5999999939813279 215819.7000000030093361, 359042.4000000060186721 215891.7000000030093361, 359013.2999999970197678 215925.7000000030093361, 358938.2999999970197678 215980.0999999940104317, 358873.5999999939813279 216000.7000000030093361, 358766.2000000029802322 216007.9000000059895683, 358736.2999999970197678 216003.7999999969906639, 358607.9000000060186721 215998.9000000059895683, 358535.5000000000000000 216001.0000000000000000, 358492.4000000060186721 215997.2000000030093361, 358428.0000000000000000 215997.2000000030093361, 358369.5999999939813279 215995.7000000030093361, 358258.4000000060186721 215994.0000000000000000, 358108.0000000000000000 215982.2999999969906639, 357988.2999999970197678 215983.2000000030093361, 357948.2000000029802322 215980.9000000059895683, 357892.0000000000000000 215980.7999999969906639, 357883.2999999970197678 215978.0000000000000000, 357866.4000000060186721 215979.2000000030093361, 357825.2999999970197678 215971.4000000059895683, 357798.2999999970197678 215947.2999999969906639, 357769.2999999970197678 215922.2999999969906639, 357739.2000000029802322 215886.5000000000000000, 357707.9000000060186721 215864.0000000000000000, 357645.7999999970197678 215826.5999999940104317, 357580.5999999939813279 215805.7000000030093361, 357556.2999999970197678 215796.0999999940104317, 357522.7000000029802322 215787.5999999940104317, 357488.9000000060186721 215777.2999999969906639, 357361.5000000000000000 215746.2999999969906639, 357308.2000000029802322 215729.2000000030093361, 357270.5999999939813279 215713.9000000059895683, 357247.7000000029802322 215699.7999999969906639, 357230.2000000029802322 215689.5999999940104317, 357198.4000000060186721 215674.0999999940104317, 357158.5000000000000000 215656.7999999969906639, 357139.4000000060186721 215647.5999999940104317, 357090.0999999939813279 215625.4000000059895683, 357061.0000000000000000 215606.0000000000000000, 357024.7999999970197678 215585.0000000000000000, 356976.7000000029802322 215540.9000000059895683, 356959.7999999970197678 215519.2999999969906639, 356924.2999999970197678 215495.9000000059895683, 356863.9000000060186721 215441.0000000000000000, 356847.4000000060186721 215434.2999999969906639, 356827.2999999970197678 215423.0999999940104317, 356801.4000000060186721 215401.0999999940104317, 356769.0999999939813279 215372.2000000030093361, 356726.2000000029802322 215341.4000000059895683, 356698.5999999939813279 215325.5000000000000000, 356639.7000000029802322 215286.0000000000000000, 356586.0999999939813279 215239.5000000000000000, 356520.0000000000000000 215173.7000000030093361, 356487.9000000060186721 215140.2999999969906639, 356460.0999999939813279 215110.7000000030093361, 356416.2000000029802322 215058.0999999940104317, 356396.2000000029802322 215039.5000000000000000, 356363.0000000000000000 215005.5999999940104317, 356287.2000000029802322 214938.5000000000000000, 356251.5000000000000000 214906.0999999940104317, 356155.7999999970197678 214810.9000000059895683, 356106.7999999970197678 214766.7999999969906639, 355999.7000000029802322 214667.7000000030093361, 355956.2999999970197678 214633.0000000000000000, 355922.0000000000000000 214604.5999999940104317, 355896.7000000029802322 214583.0000000000000000, 355879.5999999939813279 214565.0000000000000000, 355815.9000000060186721 214515.0999999940104317, 355791.4000000060186721 214485.5000000000000000, 355781.2000000029802322 214480.2000000030093361, 355783.5000000000000000 214472.5999999940104317, 355756.4000000060186721 214447.2000000030093361, 355703.5999999939813279 214373.7999999969906639, 355649.7999999970197678 214316.2000000030093361, 355633.7999999970197678 214298.5000000000000000, 355606.4000000060186721 214267.0000000000000000, 355576.4000000060186721 214229.5999999940104317, 355565.0000000000000000 214217.2999999969906639, 355524.7000000029802322 214182.0000000000000000, 355492.0999999939813279 214141.7000000030093361, 355431.7000000029802322 214075.7999999969906639, 355412.5999999939813279 214056.7000000030093361, 355382.2000000029802322 214028.2000000030093361, 355344.5999999939813279 213994.4000000059895683, 355296.9000000060186721 213940.7999999969906639, 355261.2999999970197678 213908.9000000059895683, 355237.5000000000000000 213876.4000000059895683, 355212.5999999939813279 213844.2999999969906639, 355182.2999999970197678 213811.4000000059895683, 355151.2999999970197678 213757.0000000000000000, 355117.9000000060186721 213724.2000000030093361, 355114.5999999939813279 213715.7999999969906639, 355102.5999999939813279 213703.0000000000000000, 355084.9000000060186721 213673.7999999969906639, 355062.2000000029802322 213654.7999999969906639, 355051.5999999939813279 213640.0000000000000000, 355001.7000000029802322 213589.9000000059895683, 355002.5000000000000000 213576.9000000059895683, 354978.7999999970197678 213553.4000000059895683, 354926.5999999939813279 213487.9000000059895683, 354892.5999999939813279 213432.0000000000000000, 354877.4000000060186721 213414.2999999969906639, 354800.9000000060186721 213315.2000000030093361, 354747.7999999970197678 213259.2999999969906639, 354662.7999999970197678 213136.4000000059895683, 354613.2000000029802322 213069.2999999969906639, 354552.2999999970197678 212996.5000000000000000, 354491.9000000060186721 212928.0999999940104317, 354444.7000000029802322 212858.5999999940104317, 354436.5999999939813279 212851.2000000030093361, 354404.2999999970197678 212798.9000000059895683, 354393.2999999970197678 212790.0999999940104317, 354374.9000000060186721 212772.0000000000000000, 354260.0999999939813279 212618.0999999940104317, 354242.0000000000000000 212583.5000000000000000, 354214.5000000000000000 212556.0000000000000000, 354161.7999999970197678 212490.5999999940104317, 354133.0999999939813279 212448.5999999940104317, 354112.5000000000000000 212416.5000000000000000, 354096.7000000029802322 212404.2999999969906639, 354078.5999999939813279 212384.5999999940104317, 354063.2999999970197678 212363.5000000000000000, 354057.2000000029802322 212342.0999999940104317, 354032.7999999970197678 212313.5000000000000000, 354029.7999999970197678 212300.5999999940104317, 353984.7999999970197678 212246.5000000000000000, 353954.7000000029802322 212221.5000000000000000, 353943.5000000000000000 212207.2000000030093361, 353925.7999999970197678 212184.5000000000000000, 353923.2999999970197678 212167.2000000030093361, 353906.2999999970197678 212149.9000000059895683, 353895.2999999970197678 212132.7000000030093361, 353885.7999999970197678 212113.7999999969906639, 353872.7000000029802322 212104.5999999940104317, 353840.4000000060186721 212061.7999999969906639, 353825.5999999939813279 212045.0000000000000000, 353810.9000000060186721 212021.2999999969906639, 353715.5999999939813279 211903.7000000030093361, 353694.4000000060186721 211872.0999999940104317, 353665.0999999939813279 211831.5999999940104317, 353618.5000000000000000 211776.9000000059895683, 353575.2999999970197678 211713.7999999969906639, 353539.5999999939813279 211678.0000000000000000, 353527.0999999939813279 211661.2000000030093361, 353469.5999999939813279 211595.7999999969906639, 353462.0000000000000000 211575.0000000000000000, 353432.0999999939813279 211538.0999999940104317, 353408.7000000029802322 211500.0000000000000000, 353380.5999999939813279 211457.5000000000000000, 353357.0000000000000000 211426.5000000000000000, 353348.7000000029802322 211410.7000000030093361, 353310.2999999970197678 211358.9000000059895683, 353277.4000000060186721 211317.5000000000000000, 353251.2999999970197678 211272.0000000000000000, 353232.7000000029802322 211244.4000000059895683, 353221.5000000000000000 211230.5999999940104317, 353201.2000000029802322 211201.5000000000000000, 353131.0000000000000000 211097.4000000059895683, 353084.2999999970197678 211045.7999999969906639, 353078.2000000029802322 211033.0000000000000000, 353029.7000000029802322 210970.4000000059895683, 353015.0999999939813279 210947.2000000030093361, 353003.7000000029802322 210934.7999999969906639, 352988.2999999970197678 210915.7000000030093361, 352967.4000000060186721 210878.0000000000000000, 352925.7999999970197678 210816.4000000059895683, 352893.0000000000000000 210747.5999999940104317, 352860.4000000060186721 210698.2000000030093361, 352823.7999999970197678 210635.5000000000000000, 352781.7000000029802322 210565.9000000059895683, 352762.5999999939813279 210546.7000000030093361, 352728.0000000000000000 210503.4000000059895683, 352690.5000000000000000 210446.5000000000000000, 352674.4000000060186721 210429.9000000059895683, 352670.0000000000000000 210419.5000000000000000, 352663.7999999970197678 210413.0999999940104317, 352635.7999999970197678 210358.2000000030093361, 352535.7000000029802322 210213.7000000030093361, 352493.9000000060186721 210170.4000000059895683, 352470.7000000029802322 210140.9000000059895683, 352445.7000000029802322 210099.9000000059895683, 352427.5000000000000000 210066.2000000030093361, 352382.2999999970197678 209981.2000000030093361, 352368.5000000000000000 209965.9000000059895683, 352359.0999999939813279 209939.5999999940104317, 352331.0999999939813279 209892.7000000030093361, 352299.2999999970197678 209856.2999999969906639, 352258.7000000029802322 209851.4000000059895683, 352226.5000000000000000 209815.0000000000000000, 352217.5000000000000000 209803.2000000030093361, 352199.7000000029802322 209760.5999999940104317, 352153.9000000060186721 209689.5000000000000000, 352140.0999999939813279 209666.2999999969906639, 352108.5999999939813279 209619.0000000000000000, 352087.2000000029802322 209578.4000000059895683, 352043.9000000060186721 209503.2999999969906639, 352039.9000000060186721 209481.2999999969906639, 352033.9000000060186721 209464.5000000000000000, 352016.7000000029802322 209458.7999999969906639, 352002.7999999970197678 209447.0999999940104317, 351981.2000000029802322 209410.4000000059895683, 351965.4000000060186721 209386.7000000030093361, 351959.0999999939813279 209368.4000000059895683, 351952.7000000029802322 209354.0999999940104317, 351949.4000000060186721 209335.7000000030093361, 351959.5000000000000000 209322.0000000000000000, 351945.2000000029802322 209310.7999999969906639, 351931.9000000060186721 209286.5999999940104317, 351924.2999999970197678 209269.7000000030093361, 351879.7999999970197678 209172.2000000030093361, 351872.0999999939813279 209156.2999999969906639, 351854.7999999970197678 209130.2000000030093361, 351833.7999999970197678 209081.2000000030093361, 351814.2999999970197678 209049.5000000000000000, 351807.2999999970197678 209017.2000000030093361, 351805.2999999970197678 208997.7999999969906639, 351800.0999999939813279 208972.4000000059895683, 351788.0000000000000000 208948.7000000030093361, 351769.7999999970197678 208923.5000000000000000, 351737.5999999939813279 208896.5999999940104317, 351719.7000000029802322 208862.5000000000000000, 351668.5000000000000000 208798.0000000000000000, 351647.7999999970197678 208777.7999999969906639, 351622.7999999970197678 208745.4000000059895683, 351593.4000000060186721 208671.5000000000000000, 351565.7999999970197678 208633.0999999940104317, 351548.9000000060186721 208607.4000000059895683, 351533.5999999939813279 208587.7000000030093361, 351507.0999999939813279 208526.7000000030093361, 351483.5999999939813279 208493.5999999940104317, 351473.2000000029802322 208472.9000000059895683, 351444.5999999939813279 208419.0000000000000000, 351420.0000000000000000 208394.5000000000000000, 351395.7999999970197678 208356.4000000059895683, 351354.2999999970197678 208306.2000000030093361, 351330.7000000029802322 208260.2000000030093361, 351323.0000000000000000 208236.9000000059895683, 351312.0999999939813279 208223.0999999940104317, 351284.7000000029802322 208184.7000000030093361, 351269.2999999970197678 208153.9000000059895683, 351253.9000000060186721 208135.2999999969906639, 351246.9000000060186721 208120.4000000059895683, 351235.7000000029802322 208102.0000000000000000, 351220.0000000000000000 208066.9000000059895683, 351188.2000000029802322 208028.5999999940104317, 351158.2999999970197678 207975.0999999940104317, 351134.2999999970197678 207936.0999999940104317, 351106.9000000060186721 207910.0999999940104317, 351083.7999999970197678 207887.0000000000000000, 351028.2000000029802322 207819.5999999940104317, 351017.7999999970197678 207801.7999999969906639, 350968.2999999970197678 207727.7999999969906639, 350952.5999999939813279 207693.0999999940104317, 350914.9000000060186721 207638.2999999969906639, 350885.7999999970197678 207584.0000000000000000, 350836.0000000000000000 207520.4000000059895683, 350802.2999999970197678 207459.0000000000000000, 350778.5999999939813279 207427.5000000000000000, 350740.5000000000000000 207359.9000000059895683, 350707.7999999970197678 207312.4000000059895683, 350676.4000000060186721 207266.0999999940104317, 350658.7999999970197678 207244.0000000000000000, 350642.9000000060186721 207212.2000000030093361, 350621.5000000000000000 207161.2000000030093361, 350612.0000000000000000 207144.9000000059895683, 350597.2999999970197678 207114.2000000030093361, 350573.9000000060186721 207063.7999999969906639, 350548.7000000029802322 207024.2000000030093361, 350510.5999999939813279 206945.5000000000000000, 350490.7000000029802322 206918.7999999969906639, 350470.9000000060186721 206883.7999999969906639, 350448.7000000029802322 206833.7999999969906639, 350438.0000000000000000 206803.0000000000000000, 350419.2999999970197678 206768.4000000059895683, 350396.2999999970197678 206737.4000000059895683, 350307.7000000029802322 206541.7999999969906639, 350278.2999999970197678 206492.2999999969906639, 350264.7000000029802322 206447.5999999940104317, 350245.2000000029802322 206420.0999999940104317, 350239.2000000029802322 206393.7000000030093361, 350225.4000000060186721 206355.0999999940104317, 350203.7999999970197678 206318.4000000059895683, 350191.7999999970197678 206281.7999999969906639, 350170.2999999970197678 206242.7000000030093361, 350139.7000000029802322 206161.7999999969906639, 350116.2000000029802322 206120.2999999969906639, 350101.9000000060186721 206062.2000000030093361, 350095.0999999939813279 206017.9000000059895683, 350076.2999999970197678 205961.4000000059895683, 350067.2999999970197678 205922.0999999940104317, 350059.0000000000000000 205906.2999999969906639, 350034.5000000000000000 205833.7999999969906639, 350002.0000000000000000 205734.7000000030093361, 349994.7000000029802322 205699.2999999969906639, 349981.0999999939813279 205653.5999999940104317, 349971.5999999939813279 205630.9000000059895683, 349946.5000000000000000 205574.2999999969906639, 349921.2000000029802322 205527.4000000059895683, 349880.2000000029802322 205445.2999999969906639, 349855.5000000000000000 205409.2999999969906639, 349843.7000000029802322 205381.5000000000000000, 349826.5000000000000000 205338.4000000059895683, 349812.5000000000000000 205318.7000000030093361, 349796.0999999939813279 205294.5000000000000000, 349791.2999999970197678 205267.5999999940104317, 349783.4000000060186721 205237.2999999969906639, 349785.5999999939813279 205189.5000000000000000, 349787.5000000000000000 205149.9000000059895683, 349793.7999999970197678 205129.4000000059895683, 349804.7000000029802322 205105.7999999969906639, 349807.2000000029802322 205080.9000000059895683, 349789.0999999939813279 205031.2999999969906639, 349773.2999999970197678 204995.5000000000000000, 349754.2999999970197678 204967.0000000000000000, 349734.0000000000000000 204914.9000000059895683, 349710.7999999970197678 204872.2999999969906639, 349694.0999999939813279 204833.2000000030093361, 349681.0000000000000000 204808.5000000000000000, 349660.2999999970197678 204758.9000000059895683, 349639.2999999970197678 204711.5000000000000000, 349627.0000000000000000 204694.2000000030093361, 349598.4000000060186721 204651.7000000030093361, 349558.0999999939813279 204591.0000000000000000, 349538.7000000029802322 204553.9000000059895683, 349515.9000000060186721 204519.4000000059895683, 349492.5000000000000000 204467.2999999969906639, 349480.5000000000000000 204430.0999999940104317, 349481.7999999970197678 204403.7000000030093361, 349495.0000000000000000 204367.5999999940104317, 349503.2000000029802322 204334.5999999940104317, 349510.5999999939813279 204280.0000000000000000, 349497.5999999939813279 204248.7999999969906639, 349474.7999999970197678 204224.2999999969906639, 349446.0999999939813279 204199.7999999969906639, 349390.2999999970197678 204161.2999999969906639, 349339.7000000029802322 204111.7000000030093361, 349275.7000000029802322 204003.2000000030093361, 349229.4000000060186721 203905.9000000059895683, 349207.9000000060186721 203842.7000000030093361, 349184.9000000060186721 203794.4000000059895683, 349161.2999999970197678 203725.2999999969906639, 349151.4000000060186721 203692.7999999969906639, 349129.0999999939813279 203631.0000000000000000, 349101.7999999970197678 203550.7999999969906639, 349078.7999999970197678 203504.0999999940104317, 349046.2999999970197678 203443.7999999969906639, 349010.7000000029802322 203349.2999999969906639, 349006.2999999970197678 203325.7000000030093361, 348989.0000000000000000 203263.5999999940104317, 348975.0999999939813279 203228.7000000030093361, 348936.9000000060186721 203132.5000000000000000, 348893.4000000060186721 202993.2999999969906639, 348874.9000000060186721 202924.2000000030093361, 348827.4000000060186721 202790.2999999969906639, 348795.0999999939813279 202738.0000000000000000, 348778.5999999939813279 202708.7999999969906639, 348734.0000000000000000 202608.5000000000000000, 348714.7999999970197678 202559.4000000059895683, 348681.9000000060186721 202471.4000000059895683, 348664.9000000060186721 202410.2999999969906639, 348647.7999999970197678 202366.5000000000000000, 348607.5999999939813279 202268.9000000059895683, 348603.2999999970197678 202260.2000000030093361, 348573.7000000029802322 202189.0999999940104317, 348561.7999999970197678 202157.2999999969906639, 348554.0999999939813279 202129.7000000030093361, 348541.2000000029802322 202100.7999999969906639, 348538.7000000029802322 202088.0999999940104317, 348533.4000000060186721 202062.5000000000000000, 348529.0999999939813279 202051.7000000030093361, 348517.7000000029802322 202010.5999999940104317, 348500.0999999939813279 201994.9000000059895683, 348493.7000000029802322 201986.5999999940104317, 348474.5000000000000000 201949.2999999969906639, 348468.7000000029802322 201906.5999999940104317, 348455.0000000000000000 201870.2999999969906639, 348437.7000000029802322 201827.9000000059895683, 348416.7999999970197678 201787.0000000000000000, 348409.7999999970197678 201770.4000000059895683, 348373.4000000060186721 201718.9000000059895683, 348369.2999999970197678 201703.0000000000000000, 348361.5000000000000000 201684.4000000059895683, 348366.7999999970197678 201670.2000000030093361, 348357.7000000029802322 201646.5999999940104317, 348347.5999999939813279 201624.0000000000000000, 348337.7999999970197678 201601.2999999969906639, 348328.7999999970197678 201591.9000000059895683, 348305.4000000060186721 201501.0000000000000000, 348280.2000000029802322 201448.7999999969906639, 348274.0000000000000000 201440.4000000059895683, 348256.7999999970197678 201412.5999999940104317, 348222.4000000060186721 201350.7000000030093361, 348209.2000000029802322 201327.9000000059895683, 348179.7999999970197678 201279.0000000000000000, 348154.7000000029802322 201235.0000000000000000, 348149.9000000060186721 201212.7000000030093361, 348140.5999999939813279 201190.7000000030093361, 348121.0999999939813279 201148.0000000000000000, 348111.2000000029802322 201129.5000000000000000, 348103.5999999939813279 201097.0000000000000000, 348097.0000000000000000 201022.5000000000000000, 348083.5000000000000000 200995.5000000000000000, 348047.5999999939813279 200940.7999999969906639, 348027.0999999939813279 200916.4000000059895683, 347997.5999999939813279 200894.4000000059895683, 347951.7999999970197678 200833.2999999969906639, 347933.4000000060186721 200791.7000000030093361, 347929.7999999970197678 200765.5999999940104317, 347913.0000000000000000 200717.5999999940104317, 347886.7999999970197678 200685.7000000030093361, 347875.2000000029802322 200667.9000000059895683, 347838.7999999970197678 200623.2999999969906639, 347815.4000000060186721 200583.7999999969906639, 347804.7999999970197678 200567.5999999940104317, 347798.4000000060186721 200547.9000000059895683, 347781.7999999970197678 200509.2999999969906639, 347760.7000000029802322 200484.2000000030093361, 347732.5999999939813279 200444.2999999969906639, 347703.4000000060186721 200392.5999999940104317, 347686.0999999939813279 200363.0999999940104317, 347665.2999999970197678 200341.7000000030093361, 347626.7999999970197678 200296.2999999969906639, 347589.2000000029802322 200263.5999999940104317, 347531.9000000060186721 200206.7000000030093361, 347505.0000000000000000 200189.7000000030093361, 347455.5999999939813279 200145.2999999969906639, 347435.7000000029802322 200129.9000000059895683, 347389.0000000000000000 200102.0000000000000000, 347283.9000000060186721 200050.0000000000000000, 347184.2999999970197678 200008.4000000059895683, 347141.0999999939813279 199982.2000000030093361, 347094.4000000060186721 199954.5000000000000000, 347081.9000000060186721 199936.0000000000000000, 347065.0000000000000000 199901.5000000000000000, 347060.2999999970197678 199886.9000000059895683, 347052.0000000000000000 199860.4000000059895683, 347041.0000000000000000 199814.4000000059895683, 347037.4000000060186721 199800.2000000030093361, 347039.7999999970197678 199787.7000000030093361, 347034.5000000000000000 199753.4000000059895683, 347017.2999999970197678 199708.5000000000000000, 346992.7999999970197678 199693.4000000059895683, 346979.7999999970197678 199674.2000000030093361, 346976.2999999970197678 199635.5000000000000000, 346957.5000000000000000 199602.2000000030093361, 346928.0999999939813279 199553.2999999969906639, 346912.5999999939813279 199523.9000000059895683, 346898.7999999970197678 199497.2000000030093361, 346891.7999999970197678 199472.0999999940104317, 346883.4000000060186721 199455.5000000000000000, 346872.2000000029802322 199416.5000000000000000, 346854.4000000060186721 199384.4000000059895683, 346849.2000000029802322 199371.0999999940104317, 346831.7000000029802322 199346.2000000030093361, 346822.7999999970197678 199319.0000000000000000, 346804.9000000060186721 199292.4000000059895683, 346778.5000000000000000 199226.2999999969906639, 346769.7999999970197678 199211.5000000000000000, 346751.7999999970197678 199158.5999999940104317, 346733.7000000029802322 199123.0000000000000000, 346717.7999999970197678 199091.0000000000000000, 346701.7999999970197678 199060.7000000030093361, 346685.5999999939813279 199036.9000000059895683, 346682.7000000029802322 199019.5000000000000000, 346677.9000000060186721 199009.5999999940104317, 346672.5000000000000000 198996.7999999969906639, 346657.2999999970197678 198960.5000000000000000, 346640.0000000000000000 198874.7999999969906639, 346638.2000000029802322 198824.5000000000000000, 346633.5000000000000000 198808.2999999969906639, 346625.2000000029802322 198758.5999999940104317, 346619.7000000029802322 198743.9000000059895683, 346610.5999999939813279 198709.9000000059895683, 346588.0000000000000000 198658.2000000030093361, 346571.5000000000000000 198627.2000000030093361, 346561.0000000000000000 198615.9000000059895683, 346546.2999999970197678 198587.7999999969906639, 346532.9000000060186721 198544.2999999969906639, 346526.7999999970197678 198533.2000000030093361, 346524.2000000029802322 198521.5000000000000000, 346509.9000000060186721 198481.9000000059895683, 346504.2999999970197678 198448.5000000000000000, 346477.0000000000000000 198369.0999999940104317, 346472.5000000000000000 198338.7000000030093361, 346472.2999999970197678 198315.4000000059895683, 346473.4000000060186721 198277.4000000059895683, 346464.4000000060186721 198268.5999999940104317, 346444.0000000000000000 198217.0000000000000000, 346428.9000000060186721 198158.7000000030093361, 346428.7000000029802322 198125.7999999969906639, 346432.2000000029802322 198103.5000000000000000, 346447.4000000060186721 198074.2999999969906639, 346443.7000000029802322 198060.7000000030093361, 346433.9000000060186721 198028.7000000030093361, 346412.2999999970197678 198003.7999999969906639, 346399.2000000029802322 197987.7999999969906639, 346393.5999999939813279 197971.9000000059895683, 346390.2000000029802322 197941.5999999940104317, 346396.9000000060186721 197911.7999999969906639, 346401.5000000000000000 197880.2000000030093361, 346416.5000000000000000 197832.2000000030093361, 346433.5000000000000000 197790.7000000030093361, 346449.7999999970197678 197751.9000000059895683, 346467.7000000029802322 197704.2999999969906639, 346480.2000000029802322 197686.2999999969906639, 346501.2000000029802322 197682.5000000000000000, 346537.2999999970197678 197670.9000000059895683, 346548.7000000029802322 197661.2999999969906639, 346557.0999999939813279 197624.7000000030093361, 346548.5999999939813279 197600.4000000059895683, 346538.5000000000000000 197586.9000000059895683, 346514.5000000000000000 197571.7999999969906639, 346473.2999999970197678 197580.2000000030093361, 346442.0999999939813279 197576.2000000030093361, 346408.7999999970197678 197557.5000000000000000, 346356.4000000060186721 197535.0999999940104317, 346302.9000000060186721 197505.5000000000000000, 346269.7999999970197678 197463.0999999940104317, 346250.7000000029802322 197445.2999999969906639, 346244.7999999970197678 197431.0000000000000000, 346229.7999999970197678 197391.0999999940104317, 346222.5000000000000000 197356.2000000030093361, 346209.2999999970197678 197330.9000000059895683, 346193.0000000000000000 197295.7000000030093361, 346170.2999999970197678 197240.5000000000000000, 346163.5999999939813279 197206.9000000059895683, 346147.2999999970197678 197158.7999999969906639, 346132.0000000000000000 197126.2000000030093361, 346111.7000000029802322 197075.4000000059895683, 346099.5999999939813279 197040.5999999940104317, 346092.0999999939813279 197005.7999999969906639, 346090.7000000029802322 196966.2000000030093361, 346079.0999999939813279 196914.5000000000000000, 346060.7000000029802322 196874.2999999969906639, 346038.7000000029802322 196845.7999999969906639, 346026.5000000000000000 196800.5999999940104317, 346012.9000000060186721 196730.2999999969906639, 346005.0000000000000000 196697.5000000000000000, 345993.0000000000000000 196683.4000000059895683, 345968.2999999970197678 196635.5000000000000000, 345943.5999999939813279 196562.7999999969906639, 345932.5000000000000000 196492.7999999969906639, 345911.2999999970197678 196413.0999999940104317, 345907.0999999939813279 196382.7999999969906639, 345903.7000000029802322 196356.2999999969906639, 345887.0999999939813279 196300.7000000030093361, 345882.0000000000000000 196257.7999999969906639, 345872.5999999939813279 196226.7000000030093361, 345876.7999999970197678 196207.2000000030093361, 345898.2000000029802322 196172.2000000030093361, 345896.2999999970197678 196162.7000000030093361, 345882.7000000029802322 196134.0000000000000000, 345842.7999999970197678 196099.9000000059895683, 345826.5000000000000000 196087.5000000000000000, 345810.5999999939813279 196071.5999999940104317, 345791.9000000060186721 196032.9000000059895683, 345789.4000000060186721 196011.5000000000000000, 345799.2999999970197678 195979.4000000059895683, 345779.0999999939813279 195887.7000000030093361, 345771.7999999970197678 195829.7999999969906639, 345756.5000000000000000 195784.2000000030093361, 345756.2999999970197678 195752.7000000030093361, 345778.5000000000000000 195741.0999999940104317, 345766.2999999970197678 195722.7000000030093361, 345754.5999999939813279 195711.9000000059895683, 345731.0999999939813279 195677.5000000000000000, 345732.2000000029802322 195630.5999999940104317, 345728.2999999970197678 195611.7999999969906639, 345714.2999999970197678 195586.2999999969906639, 345675.0999999939813279 195564.7000000030093361, 345664.7999999970197678 195557.5999999940104317, 345637.2000000029802322 195541.7999999969906639, 345605.2000000029802322 195509.0000000000000000, 345590.2999999970197678 195471.0000000000000000, 345588.5999999939813279 195416.2000000030093361, 345582.9000000060186721 195362.4000000059895683, 345575.9000000060186721 195332.0999999940104317, 345567.9000000060186721 195285.9000000059895683, 345574.5999999939813279 195259.7000000030093361, 345582.0000000000000000 195228.2000000030093361, 345574.0999999939813279 195183.9000000059895683, 345564.5000000000000000 195158.7000000030093361, 345558.0999999939813279 195127.0999999940104317, 345559.2999999970197678 195056.2999999969906639, 345557.4000000060186721 194980.0000000000000000, 345552.9000000060186721 194913.0000000000000000, 345553.0999999939813279 194872.2999999969906639, 345553.0000000000000000 194814.4000000059895683, 345554.7000000029802322 194766.7999999969906639, 345550.5999999939813279 194687.7999999969906639, 345552.2999999970197678 194655.4000000059895683, 345550.5999999939813279 194615.7999999969906639, 345547.7999999970197678 194573.2000000030093361, 345549.2000000029802322 194434.2999999969906639, 345548.4000000060186721 194378.0999999940104317, 345544.7999999970197678 194326.7999999969906639, 345545.5999999939813279 194273.4000000059895683, 345543.4000000060186721 194229.5000000000000000, 345542.4000000060186721 194102.4000000059895683, 345542.7999999970197678 194045.5000000000000000, 345545.2999999970197678 193957.7000000030093361, 345538.2000000029802322 193757.0999999940104317, 345532.7000000029802322 193721.5000000000000000, 345532.2999999970197678 193642.2000000030093361, 345535.0000000000000000 193526.7000000030093361, 345532.9000000060186721 193482.0000000000000000, 345535.2999999970197678 193417.9000000059895683, 345532.0999999939813279 193351.0000000000000000, 345531.4000000060186721 193304.0999999940104317, 345525.0000000000000000 193187.7999999969906639, 345527.5999999939813279 193120.2999999969906639, 345541.5000000000000000 193070.5000000000000000, 345553.7999999970197678 193027.4000000059895683, 345555.0999999939813279 192987.5000000000000000, 345553.9000000060186721 192962.2999999969906639, 345544.5000000000000000 192948.2999999969906639, 345523.2000000029802322 192916.4000000059895683, 345509.7999999970197678 192880.2000000030093361, 345484.9000000060186721 192773.9000000059895683, 345476.9000000060186721 192725.9000000059895683, 345464.7999999970197678 192692.7999999969906639, 345451.9000000060186721 192660.4000000059895683, 345428.7000000029802322 192543.0999999940104317, 345420.9000000060186721 192509.7999999969906639, 345402.0000000000000000 192438.0000000000000000, 345388.0000000000000000 192381.4000000059895683, 345352.2999999970197678 192249.0000000000000000, 345326.2000000029802322 192158.4000000059895683, 345323.5999999939813279 192145.4000000059895683, 345307.4000000060186721 192097.5000000000000000, 345287.5999999939813279 192047.0000000000000000, 345278.2000000029802322 192027.2000000030093361, 345268.0999999939813279 192002.2000000030093361, 345251.9000000060186721 191950.2999999969906639, 345235.9000000060186721 191907.9000000059895683, 345220.5999999939813279 191865.2999999969906639, 345207.7999999970197678 191833.5000000000000000, 345178.7999999970197678 191738.4000000059895683, 345161.4000000060186721 191684.0999999940104317, 345144.4000000060186721 191627.5999999940104317, 345124.2000000029802322 191550.0999999940104317, 345112.7000000029802322 191523.0000000000000000, 345106.7999999970197678 191499.9000000059895683, 345089.2000000029802322 191461.7999999969906639, 345078.7000000029802322 191418.5999999940104317, 345054.5000000000000000 191360.9000000059895683, 345041.7999999970197678 191312.5999999940104317, 345030.5000000000000000 191287.7000000030093361, 345024.0999999939813279 191256.0999999940104317, 344975.4000000060186721 191082.7999999969906639, 344937.0000000000000000 190983.7000000030093361, 344909.0999999939813279 190875.7999999969906639, 344902.4000000060186721 190841.2999999969906639, 344887.2999999970197678 190805.5000000000000000, 344875.0000000000000000 190759.9000000059895683, 344864.0000000000000000 190728.2000000030093361, 344825.5000000000000000 190666.2000000030093361, 344794.7000000029802322 190596.5000000000000000, 344763.5000000000000000 190542.4000000059895683, 344741.5999999939813279 190487.2000000030093361, 344732.2999999970197678 190443.9000000059895683, 344723.7000000029802322 190372.5000000000000000, 344720.9000000060186721 190331.0999999940104317, 344715.4000000060186721 190306.0000000000000000, 344711.5000000000000000 190288.4000000059895683, 344700.0999999939813279 190241.7000000030093361, 344691.7999999970197678 190186.4000000059895683, 344686.5000000000000000 190175.2999999969906639, 344678.0000000000000000 190139.5000000000000000, 344657.7000000029802322 190075.5000000000000000, 344638.2999999970197678 189943.7999999969906639, 344615.9000000060186721 189896.0999999940104317, 344607.0999999939813279 189865.2999999969906639, 344602.2999999970197678 189854.2999999969906639, 344588.5000000000000000 189802.7999999969906639, 344583.0000000000000000 189777.5999999940104317, 344573.7999999970197678 189711.7000000030093361, 344548.7000000029802322 189646.4000000059895683, 344525.5999999939813279 189563.7999999969906639, 344487.4000000060186721 189433.2000000030093361, 344461.5000000000000000 189319.5999999940104317, 344457.0000000000000000 189292.7999999969906639, 344449.7000000029802322 189257.4000000059895683, 344442.7999999970197678 189214.5000000000000000, 344431.0999999939813279 189181.9000000059895683, 344418.4000000060186721 189132.2999999969906639, 344397.2999999970197678 189060.0000000000000000, 344384.7999999970197678 188995.9000000059895683, 344373.5999999939813279 188938.7999999969906639, 344365.0999999939813279 188892.7000000030093361, 344356.0999999939813279 188869.4000000059895683, 344347.2999999970197678 188837.0999999940104317, 344332.5999999939813279 188782.5000000000000000, 344311.2000000029802322 188714.0000000000000000, 344300.2999999970197678 188677.2000000030093361, 344276.4000000060186721 188503.0999999940104317, 344256.9000000060186721 188448.5000000000000000, 344232.0999999939813279 188387.0000000000000000, 344209.0999999939813279 188316.7999999969906639, 344177.5000000000000000 188213.2999999969906639, 344156.7999999970197678 188165.9000000059895683, 344136.7000000029802322 188122.0999999940104317, 344109.5999999939813279 188073.9000000059895683, 344096.4000000060186721 188038.5000000000000000, 344084.4000000060186721 188010.2999999969906639, 344074.0999999939813279 187978.0000000000000000, 344032.0000000000000000 187900.0000000000000000, 344018.2000000029802322 187865.5999999940104317, 344007.7999999970197678 187843.5999999940104317, 343976.7999999970197678 187763.2999999969906639, 343967.7999999970197678 187737.0000000000000000, 343950.4000000060186721 187688.0999999940104317, 343935.9000000060186721 187627.2999999969906639, 343929.9000000060186721 187612.2999999969906639, 343929.0999999939813279 187571.7999999969906639, 343920.7000000029802322 187561.4000000059895683, 343898.0999999939813279 187528.5000000000000000, 343832.2000000029802322 187399.4000000059895683, 343803.9000000060186721 187338.5000000000000000, 343759.5999999939813279 187216.2000000030093361, 343739.2999999970197678 187174.4000000059895683, 343711.2000000029802322 187121.5000000000000000, 343642.0000000000000000 186939.2999999969906639, 343594.5000000000000000 186828.0000000000000000, 343552.4000000060186721 186695.5999999940104317, 343494.9000000060186721 186553.9000000059895683, 343465.4000000060186721 186459.2000000030093361, 343458.2999999970197678 186417.9000000059895683, 343430.7000000029802322 186333.5000000000000000, 343426.9000000060186721 186314.7999999969906639, 343329.7000000029802322 185976.7999999969906639, 343299.7999999970197678 185837.0999999940104317, 343287.5000000000000000 185760.4000000059895683, 343279.0000000000000000 185682.9000000059895683, 343262.5000000000000000 185542.9000000059895683, 343262.2999999970197678 185487.2999999969906639, 343257.5000000000000000 185408.7999999969906639, 343226.7999999970197678 185225.0999999940104317, 343219.5999999939813279 185150.5000000000000000, 343202.5999999939813279 185068.4000000059895683, 343186.2000000029802322 184961.9000000059895683, 343187.4000000060186721 184936.9000000059895683, 343184.0000000000000000 184869.4000000059895683, 343185.5999999939813279 184836.5000000000000000, 343185.7999999970197678 184672.7000000030093361, 343180.7000000029802322 184543.2999999969906639, 343176.9000000060186721 184427.2000000030093361, 343170.0999999939813279 184292.9000000059895683, 343164.0999999939813279 184241.0000000000000000, 343167.2999999970197678 184175.5999999940104317, 343160.2999999970197678 184119.4000000059895683, 343158.5000000000000000 184074.2999999969906639, 343148.0000000000000000 184014.4000000059895683, 343128.0999999939813279 183934.0999999940104317, 343107.0000000000000000 183870.5999999940104317, 343107.4000000060186721 183861.5999999940104317, 343116.9000000060186721 183815.9000000059895683, 343125.5000000000000000 183762.0000000000000000, 343130.0000000000000000 183746.7999999969906639, 343143.7000000029802322 183724.5999999940104317, 343185.5000000000000000 183676.0999999940104317, 343208.5999999939813279 183661.7999999969906639, 343232.7999999970197678 183632.7000000030093361, 343257.4000000060186721 183608.2000000030093361, 343296.5000000000000000 183578.9000000059895683, 343351.2999999970197678 183551.5999999940104317, 343474.2999999970197678 183521.5000000000000000, 343570.0000000000000000 183499.5999999940104317, 343621.9000000060186721 183474.5999999940104317, 343668.9000000060186721 183454.0000000000000000, 343698.7999999970197678 183446.5000000000000000, 343793.7999999970197678 183417.2999999969906639, 343834.2000000029802322 183406.7999999969906639, 343910.9000000060186721 183381.5999999940104317, 343966.0000000000000000 183371.7999999969906639, 344065.4000000060186721 183344.7999999969906639, 344173.7000000029802322 183312.7000000030093361, 344197.2999999970197678 183310.2999999969906639, 344344.5999999939813279 183294.0000000000000000, 344392.0999999939813279 183293.4000000059895683, 344478.2999999970197678 183311.2999999969906639, 344503.2999999970197678 183318.0999999940104317, 344653.7000000029802322 183335.5000000000000000, 344698.7000000029802322 183352.2000000030093361, 344753.5000000000000000 183370.5999999940104317, 344795.5000000000000000 183370.5999999940104317, 344803.5000000000000000 183366.7999999969906639, 344815.5999999939813279 183339.9000000059895683, 344812.0000000000000000 183316.7999999969906639, 344792.5999999939813279 183283.9000000059895683, 344791.5000000000000000 183256.2000000030093361, 344783.0000000000000000 183220.5000000000000000, 344767.5000000000000000 183183.5000000000000000, 344749.2999999970197678 183147.9000000059895683, 344718.7000000029802322 183112.2999999969906639, 344675.2999999970197678 183076.0999999940104317, 344599.0000000000000000 183039.0000000000000000, 344593.9000000060186721 183032.0999999940104317, 344557.9000000060186721 182996.7999999969906639, 344550.5000000000000000 182966.5000000000000000, 344536.7000000029802322 182927.2999999969906639, 344517.5999999939813279 182912.9000000059895683, 344490.0999999939813279 182909.5000000000000000, 344469.4000000060186721 182900.0999999940104317, 344466.0999999939813279 182882.5000000000000000, 344444.4000000060186721 182847.4000000059895683, 344419.2999999970197678 182777.2000000030093361, 344416.5999999939813279 182764.7999999969906639, 344405.2000000029802322 182725.2999999969906639, 344387.2000000029802322 182687.7000000030093361, 344379.5999999939813279 182646.4000000059895683, 344373.5999999939813279 182597.0999999940104317, 344369.5999999939813279 182559.0000000000000000, 344363.7999999970197678 182457.0000000000000000, 344354.2999999970197678 182330.5999999940104317, 344360.7000000029802322 182197.5999999940104317, 344380.4000000060186721 182099.5000000000000000, 344402.9000000060186721 182032.0999999940104317, 344415.2999999970197678 181985.2999999969906639, 344440.7999999970197678 181930.2999999969906639, 344472.5000000000000000 181860.7000000030093361, 344499.5999999939813279 181747.2000000030093361, 344511.2000000029802322 181704.4000000059895683, 344541.7000000029802322 181658.5000000000000000, 344606.2999999970197678 181542.4000000059895683, 344634.0000000000000000 181478.0999999940104317, 344659.5999999939813279 181424.7999999969906639, 344665.0999999939813279 181356.4000000059895683, 344661.2999999970197678 181338.2000000030093361, 344646.5000000000000000 181307.0999999940104317, 344623.5999999939813279 181271.7999999969906639, 344552.2999999970197678 181195.5000000000000000, 344518.2000000029802322 181166.4000000059895683, 344462.0999999939813279 181110.5999999940104317, 344333.0000000000000000 180989.7000000030093361, 344310.2999999970197678 180971.9000000059895683, 344253.2000000029802322 180924.5999999940104317, 344215.7000000029802322 180880.7999999969906639, 344150.5000000000000000 180800.0000000000000000, 344109.7999999970197678 180738.0999999940104317, 344077.0000000000000000 180695.0999999940104317, 344021.9000000060186721 180606.0000000000000000, 343947.5000000000000000 180480.4000000059895683, 343883.5999999939813279 180357.7000000030093361, 343852.7000000029802322 180303.7999999969906639, 343817.0000000000000000 180222.7999999969906639, 343752.7999999970197678 180108.5999999940104317, 343673.0999999939813279 179983.4000000059895683, 343621.7999999970197678 179912.2999999969906639, 343530.9000000060186721 179755.0999999940104317, 343472.4000000060186721 179636.7999999969906639, 343365.9000000060186721 179396.0999999940104317, 343317.2000000029802322 179286.4000000059895683, 343297.2000000029802322 179250.4000000059895683, 343261.2999999970197678 179174.5000000000000000, 343219.4000000060186721 179096.0000000000000000, 343185.5000000000000000 179041.0000000000000000, 343069.5999999939813279 178832.2999999969906639, 342993.5000000000000000 178689.7999999969906639, 342966.7999999970197678 178650.7999999969906639, 342936.7000000029802322 178597.0999999940104317, 342884.0999999939813279 178494.5999999940104317, 342880.0999999939813279 178480.7000000030093361, 342856.5999999939813279 178432.2000000030093361, 342839.0999999939813279 178394.5999999940104317, 342744.9000000060186721 178208.2999999969906639, 342689.5000000000000000 178087.2000000030093361, 342662.2999999970197678 178032.2999999969906639, 342645.5000000000000000 178004.5999999940104317, 342601.9000000060186721 177926.7000000030093361, 342563.0000000000000000 177860.7000000030093361, 342531.9000000060186721 177794.0999999940104317, 342525.7000000029802322 177786.7000000030093361, 342491.7999999970197678 177718.7999999969906639, 342452.0000000000000000 177648.0000000000000000, 342367.5000000000000000 177495.5999999940104317, 342367.2000000029802322 177481.2000000030093361, 342369.5999999939813279 177468.5999999940104317, 342358.2000000029802322 177443.4000000059895683, 342348.5000000000000000 177416.5000000000000000, 342326.4000000060186721 177389.0000000000000000, 342327.0999999939813279 177375.7999999969906639, 342289.4000000060186721 177310.7000000030093361, 342272.0000000000000000 177272.2999999969906639, 342227.4000000060186721 177180.0000000000000000, 342194.9000000060186721 177141.5999999940104317, 342145.0999999939813279 177053.4000000059895683, 342120.0999999939813279 176999.4000000059895683, 342095.0000000000000000 176959.2000000030093361, 342020.4000000060186721 176812.5999999940104317, 341977.2000000029802322 176741.4000000059895683, 341905.2999999970197678 176612.7999999969906639, 341863.9000000060186721 176551.5999999940104317, 341845.2999999970197678 176523.2999999969906639, 341816.4000000060186721 176474.7999999969906639, 341753.0000000000000000 176360.5000000000000000, 341682.2999999970197678 176184.0000000000000000, 341625.7000000029802322 176077.5000000000000000, 341569.5000000000000000 175969.5999999940104317, 341528.7999999970197678 175906.2999999969906639, 341515.2000000029802322 175878.9000000059895683, 341479.5999999939813279 175808.5999999940104317, 341450.7999999970197678 175744.7000000030093361, 341418.4000000060186721 175695.7999999969906639, 341357.9000000060186721 175580.5000000000000000, 341345.0999999939813279 175546.0000000000000000, 341310.9000000060186721 175482.0000000000000000, 341291.2999999970197678 175440.7999999969906639, 341258.7000000029802322 175384.7999999969906639, 341230.4000000060186721 175313.5999999940104317, 341175.7999999970197678 175210.5000000000000000, 341121.0000000000000000 175069.5000000000000000, 341091.0999999939813279 175014.2000000030093361, 341072.2000000029802322 174971.5000000000000000, 341020.0999999939813279 174856.0000000000000000, 340985.4000000060186721 174792.0000000000000000, 340954.4000000060186721 174727.4000000059895683, 340923.2000000029802322 174663.2000000030093361, 340909.7999999970197678 174619.2000000030093361, 340874.0999999939813279 174533.0000000000000000, 340853.9000000060186721 174482.7000000030093361, 340820.9000000060186721 174430.0000000000000000, 340797.5999999939813279 174342.4000000059895683, 340780.2999999970197678 174291.2999999969906639, 340749.0999999939813279 174228.4000000059895683, 340720.4000000060186721 174112.4000000059895683, 340710.7999999970197678 174051.2000000030093361, 340694.5000000000000000 173954.2000000030093361, 340677.4000000060186721 173898.7999999969906639, 340670.2000000029802322 173874.0000000000000000, 340663.7000000029802322 173859.0999999940104317, 340645.2000000029802322 173794.0000000000000000, 340628.2999999970197678 173722.2999999969906639, 340611.7999999970197678 173664.4000000059895683, 340605.7000000029802322 173631.7999999969906639, 340597.0000000000000000 173597.5000000000000000, 340606.5000000000000000 173590.4000000059895683, 340606.4000000060186721 173575.5000000000000000, 340601.9000000060186721 173556.0000000000000000, 340564.2000000029802322 173475.2999999969906639, 340548.4000000060186721 173457.0000000000000000, 340533.5999999939813279 173424.4000000059895683, 340523.2999999970197678 173378.0999999940104317, 340509.2999999970197678 173342.4000000059895683, 340509.2999999970197678 173321.0999999940104317, 340496.7000000029802322 173268.0000000000000000, 340486.4000000060186721 173234.4000000059895683, 340473.4000000060186721 173201.9000000059895683, 340463.2999999970197678 173163.5999999940104317, 340455.7000000029802322 173148.5000000000000000, 340443.2999999970197678 173113.7999999969906639, 340433.5000000000000000 173094.5000000000000000, 340431.9000000060186721 173082.5000000000000000, 340414.0999999939813279 173051.5999999940104317, 340401.2999999970197678 173015.5999999940104317, 340376.2999999970197678 172960.2000000030093361, 340371.5999999939813279 172944.2999999969906639, 340353.5999999939813279 172897.7000000030093361, 340338.7999999970197678 172868.2000000030093361, 340311.2999999970197678 172775.7999999969906639, 340292.2999999970197678 172731.0999999940104317, 340279.0999999939813279 172705.7999999969906639, 340268.2999999970197678 172670.7999999969906639, 340259.7000000029802322 172660.2000000030093361, 340244.7000000029802322 172633.7000000030093361, 340209.0000000000000000 172578.4000000059895683, 340200.5000000000000000 172552.7000000030093361, 340202.9000000060186721 172543.0999999940104317, 340202.7999999970197678 172522.0999999940104317, 340202.0000000000000000 172512.0000000000000000, 340188.5999999939813279 172492.7000000030093361, 340170.9000000060186721 172457.0000000000000000, 340151.2000000029802322 172431.0999999940104317, 340136.0999999939813279 172392.5000000000000000, 340114.7000000029802322 172352.9000000059895683, 340111.7000000029802322 172337.7000000030093361, 340086.7000000029802322 172284.7999999969906639, 340079.7000000029802322 172254.4000000059895683, 340066.7000000029802322 172228.7000000030093361, 340056.0000000000000000 172198.9000000059895683, 340043.7999999970197678 172164.0999999940104317, 340024.2000000029802322 172121.4000000059895683, 340016.0999999939813279 172099.2000000030093361, 339994.2000000029802322 172056.5000000000000000, 339970.7999999970197678 171994.2000000030093361, 339959.2000000029802322 171973.7000000030093361, 339945.4000000060186721 171945.5000000000000000, 339907.7999999970197678 171869.5000000000000000, 339896.2999999970197678 171843.7000000030093361, 339887.0999999939813279 171825.0999999940104317, 339879.7000000029802322 171799.5999999940104317, 339865.5000000000000000 171771.9000000059895683, 339806.4000000060186721 171651.5000000000000000, 339793.5999999939813279 171618.4000000059895683, 339761.2999999970197678 171566.5000000000000000, 339730.7999999970197678 171533.5999999940104317, 339698.5999999939813279 171479.5999999940104317, 339685.7000000029802322 171447.0999999940104317, 339674.0000000000000000 171429.0999999940104317, 339640.0999999939813279 171368.5000000000000000, 339617.5999999939813279 171338.4000000059895683, 339592.2999999970197678 171302.9000000059895683, 339534.5999999939813279 171229.2999999969906639, 339521.4000000060186721 171200.2000000030093361, 339489.5000000000000000 171141.5999999940104317, 339459.4000000060186721 171111.0999999940104317, 339453.4000000060186721 171102.0000000000000000, 339432.7000000029802322 171081.5999999940104317, 339391.2000000029802322 171032.7000000030093361, 339319.0999999939813279 170968.9000000059895683, 339277.7999999970197678 170938.7999999969906639, 339232.9000000060186721 170895.0000000000000000, 339182.4000000060186721 170861.7000000030093361, 339153.4000000060186721 170847.2999999969906639, 339089.2000000029802322 170807.5999999940104317, 339057.7000000029802322 170786.0000000000000000, 339013.5000000000000000 170755.0999999940104317, 339001.2000000029802322 170740.5999999940104317, 338993.2000000029802322 170714.7000000030093361, 338981.9000000060186721 170675.7999999969906639, 338958.5999999939813279 170622.5000000000000000, 338944.0000000000000000 170542.0999999940104317, 338920.2999999970197678 170485.2000000030093361, 338919.5000000000000000 170471.2999999969906639, 338909.0999999939813279 170452.7000000030093361, 338890.2999999970197678 170396.5999999940104317, 338866.5000000000000000 170339.2999999969906639, 338852.7999999970197678 170312.0999999940104317, 338847.2000000029802322 170289.7999999969906639, 338804.7999999970197678 170158.7000000030093361, 338799.0000000000000000 170130.4000000059895683, 338784.7999999970197678 170062.2999999969906639, 338772.0000000000000000 170030.5000000000000000, 338768.9000000060186721 169997.2000000030093361, 338759.0999999939813279 169973.7999999969906639, 338751.7999999970197678 169938.5000000000000000, 338744.7999999970197678 169921.2000000030093361, 338739.4000000060186721 169896.5999999940104317, 338726.9000000060186721 169879.5000000000000000, 338712.7999999970197678 169874.0999999940104317, 338696.2000000029802322 169871.2999999969906639, 338620.7999999970197678 169859.2999999969906639, 338592.0999999939813279 169846.5000000000000000, 338547.7999999970197678 169829.2000000030093361, 338529.0999999939813279 169817.7999999969906639, 338483.2999999970197678 169794.7999999969906639, 338417.2999999970197678 169753.9000000059895683, 338342.2000000029802322 169713.5999999940104317, 338277.0999999939813279 169665.7999999969906639, 338251.7000000029802322 169633.9000000059895683, 338236.2999999970197678 169614.0000000000000000, 338195.2000000029802322 169555.7000000030093361, 338169.0000000000000000 169526.5000000000000000, 338134.5999999939813279 169477.5999999940104317, 338113.0000000000000000 169451.0000000000000000, 338075.7999999970197678 169389.0000000000000000, 338065.5999999939813279 169359.5000000000000000, 338050.7999999970197678 169319.0000000000000000, 338014.4000000060186721 169230.0999999940104317, 337990.5999999939813279 169173.0000000000000000, 337976.0000000000000000 169122.9000000059895683, 337961.2000000029802322 169047.0000000000000000, 337937.7999999970197678 168968.7999999969906639, 337925.5999999939813279 168939.0999999940104317, 337888.7000000029802322 168844.0999999940104317, 337864.2999999970197678 168752.2000000030093361, 337824.0000000000000000 168661.2999999969906639, 337790.2000000029802322 168602.5000000000000000, 337756.7000000029802322 168562.2999999969906639, 337685.7999999970197678 168497.0999999940104317, 337651.9000000060186721 168467.7000000030093361, 337601.2999999970197678 168427.0000000000000000, 337485.7000000029802322 168368.5999999940104317, 337402.2000000029802322 168344.2999999969906639, 337359.2999999970197678 168333.7000000030093361, 337272.2000000029802322 168309.0999999940104317, 337224.0999999939813279 168291.0999999940104317, 337183.0999999939813279 168282.5000000000000000, 337108.0000000000000000 168263.5999999940104317, 337071.2999999970197678 168254.2999999969906639, 337010.9000000060186721 168234.7999999969906639, 336931.0999999939813279 168216.7000000030093361, 336858.2999999970197678 168206.4000000059895683, 336789.2000000029802322 168188.0000000000000000, 336759.2000000029802322 168176.2000000030093361, 336667.7999999970197678 168150.9000000059895683, 336620.4000000060186721 168137.5999999940104317, 336563.9000000060186721 168124.0999999940104317, 336540.5999999939813279 168118.2000000030093361, 336525.9000000060186721 168113.2999999969906639, 336501.2999999970197678 168107.9000000059895683, 336454.7999999970197678 168089.9000000059895683, 336398.5000000000000000 168069.7000000030093361, 336371.5000000000000000 168057.7000000030093361, 336297.5000000000000000 168032.4000000059895683, 336251.7999999970197678 168018.7000000030093361, 336216.7999999970197678 168011.7000000030093361, 336181.0000000000000000 168000.7999999969906639, 336105.4000000060186721 167973.2000000030093361, 336028.0000000000000000 167947.2000000030093361, 335961.2000000029802322 167931.7999999969906639, 335856.7999999970197678 167902.2000000030093361, 335758.2999999970197678 167871.5000000000000000, 335715.7999999970197678 167857.2000000030093361, 335679.0999999939813279 167844.0000000000000000, 335630.4000000060186721 167817.9000000059895683, 335523.2999999970197678 167758.9000000059895683, 335447.2000000029802322 167714.0999999940104317, 335410.4000000060186721 167693.2999999969906639, 335357.0000000000000000 167673.9000000059895683, 335326.7000000029802322 167666.4000000059895683, 335286.5000000000000000 167652.2999999969906639, 335197.0000000000000000 167635.9000000059895683, 335177.0999999939813279 167637.9000000059895683, 335099.7999999970197678 167643.4000000059895683, 335029.2000000029802322 167674.4000000059895683, 334948.7999999970197678 167729.2999999969906639, 334931.9000000060186721 167746.5000000000000000, 334908.0999999939813279 167762.2999999969906639, 334850.4000000060186721 167812.2999999969906639, 334807.0999999939813279 167858.2999999969906639, 334786.5000000000000000 167877.7000000030093361, 334749.4000000060186721 167906.5999999940104317, 334665.2000000029802322 167980.2999999969906639, 334610.0999999939813279 168027.5000000000000000, 334562.7999999970197678 168070.7999999969906639, 334537.7999999970197678 168091.9000000059895683, 334454.9000000060186721 168163.7999999969906639, 334330.2000000029802322 168277.9000000059895683, 334282.7999999970197678 168314.9000000059895683, 334262.5999999939813279 168333.9000000059895683, 334187.0999999939813279 168400.4000000059895683, 334160.4000000060186721 168415.5000000000000000, 334097.2999999970197678 168452.5999999940104317, 334056.7999999970197678 168478.4000000059895683, 334026.7999999970197678 168488.4000000059895683, 333912.7999999970197678 168559.9000000059895683, 333846.5000000000000000 168597.5999999940104317, 333816.0000000000000000 168617.5000000000000000, 333784.2000000029802322 168633.0000000000000000, 333719.7999999970197678 168669.7000000030093361, 333691.7000000029802322 168691.5999999940104317, 333633.2999999970197678 168727.4000000059895683, 333527.0999999939813279 168808.7999999969906639, 333454.9000000060186721 168843.2999999969906639, 333403.0000000000000000 168861.0999999940104317, 333350.2000000029802322 168873.5999999940104317, 333319.9000000060186721 168877.5999999940104317, 333238.7999999970197678 168882.7000000030093361, 333169.5000000000000000 168887.9000000059895683, 333131.7999999970197678 168891.9000000059895683, 333064.5999999939813279 168892.7000000030093361, 333020.2999999970197678 168889.5999999940104317, 332911.5000000000000000 168887.2999999969906639, 332827.0999999939813279 168887.7999999969906639, 332799.9000000060186721 168887.7999999969906639, 332732.7000000029802322 168887.0999999940104317, 332629.5999999939813279 168890.9000000059895683, 332520.5999999939813279 168881.5000000000000000, 332465.2000000029802322 168870.9000000059895683, 332397.9000000060186721 168864.7000000030093361, 332342.7999999970197678 168871.5999999940104317, 332304.0000000000000000 168867.9000000059895683, 332200.4000000060186721 168880.5000000000000000, 332189.9000000060186721 168878.9000000059895683, 332148.7999999970197678 168879.7000000030093361, 332119.5000000000000000 168873.4000000059895683, 332090.2999999970197678 168870.5000000000000000, 332052.0000000000000000 168865.2999999969906639, 332024.2999999970197678 168867.0000000000000000, 331937.7999999970197678 168877.2000000030093361, 331860.0000000000000000 168878.9000000059895683, 331823.0000000000000000 168876.7999999969906639, 331781.0999999939813279 168881.5999999940104317, 331749.2000000029802322 168882.5999999940104317, 331735.2999999970197678 168885.0000000000000000, 331714.7999999970197678 168886.0999999940104317, 331678.5000000000000000 168888.0999999940104317, 331660.5000000000000000 168889.2000000030093361, 331643.5000000000000000 168894.5000000000000000, 331605.0000000000000000 168896.7999999969906639, 331571.2999999970197678 168893.2999999969906639, 331524.9000000060186721 168896.0999999940104317, 331482.5999999939813279 168899.9000000059895683, 331448.7999999970197678 168903.2000000030093361, 331436.7999999970197678 168901.9000000059895683, 331421.4000000060186721 168904.9000000059895683, 331342.0000000000000000 168905.7999999969906639, 331316.5000000000000000 168907.9000000059895683, 331228.4000000060186721 168903.7999999969906639, 331167.7999999970197678 168898.5000000000000000, 331121.2999999970197678 168892.0000000000000000, 331040.4000000060186721 168882.7999999969906639, 330999.0000000000000000 168878.9000000059895683, 330830.0000000000000000 168875.0000000000000000, 330771.2999999970197678 168882.0000000000000000, 330727.7000000029802322 168888.5000000000000000, 330713.5000000000000000 168893.7000000030093361, 330672.0000000000000000 168919.5999999940104317, 330648.5000000000000000 168937.0999999940104317, 330571.2999999970197678 168975.2000000030093361, 330519.2999999970197678 169015.7000000030093361, 330490.5000000000000000 169028.0999999940104317, 330431.0999999939813279 169046.9000000059895683, 330411.9000000060186721 169048.5000000000000000, 330350.0999999939813279 169041.0000000000000000, 330330.7999999970197678 169030.0000000000000000, 330271.5000000000000000 168999.5000000000000000, 330224.5000000000000000 168961.5000000000000000, 330191.7999999970197678 168932.7999999969906639, 330154.0999999939813279 168889.5999999940104317, 330127.2000000029802322 168850.7999999969906639, 330103.0000000000000000 168826.2999999969906639, 330086.0999999939813279 168803.2999999969906639, 330077.9000000060186721 168787.2000000030093361, 330055.2000000029802322 168747.2999999969906639, 330021.5000000000000000 168708.0000000000000000, 330004.0999999939813279 168680.7999999969906639, 329962.7999999970197678 168637.7999999969906639, 329943.5000000000000000 168618.2000000030093361, 329921.5000000000000000 168598.2999999969906639, 329886.9000000060186721 168564.0999999940104317, 329859.7999999970197678 168542.2999999969906639, 329785.2999999970197678 168465.4000000059895683, 329735.5999999939813279 168420.7000000030093361, 329708.2999999970197678 168401.5000000000000000, 329697.2000000029802322 168383.4000000059895683, 329642.7000000029802322 168339.4000000059895683, 329617.9000000060186721 168317.0999999940104317, 329603.5999999939813279 168304.2999999969906639, 329565.7999999970197678 168276.2000000030093361, 329533.5000000000000000 168248.5000000000000000, 329482.2999999970197678 168209.9000000059895683, 329404.5999999939813279 168146.7000000030093361, 329385.4000000060186721 168122.2999999969906639, 329345.0000000000000000 168085.5999999940104317, 329306.0999999939813279 168048.0000000000000000, 329292.5000000000000000 168040.7000000030093361, 329291.9000000060186721 168050.5999999940104317, 329274.7000000029802322 168071.9000000059895683, 329250.5999999939813279 168110.5000000000000000, 329223.4000000060186721 168160.7000000030093361, 329211.0000000000000000 168182.9000000059895683, 329190.2999999970197678 168213.2999999969906639, 329170.2999999970197678 168251.7999999969906639, 329143.9000000060186721 168286.4000000059895683, 329131.9000000060186721 168311.0000000000000000, 329115.2999999970197678 168341.4000000059895683, 329110.2999999970197678 168358.0000000000000000, 329075.7000000029802322 168412.2000000030093361, 329062.4000000060186721 168439.7999999969906639, 329034.2000000029802322 168479.4000000059895683, 329008.2999999970197678 168513.7000000030093361, 328980.0000000000000000 168563.5000000000000000, 328946.7999999970197678 168618.4000000059895683, 328915.7999999970197678 168657.2999999969906639, 328877.7999999970197678 168698.7999999969906639, 328831.5999999939813279 168768.2999999969906639, 328817.2999999970197678 168792.7999999969906639, 328782.0000000000000000 168837.5000000000000000, 328741.7999999970197678 168872.2000000030093361, 328701.4000000060186721 168923.0000000000000000, 328674.5000000000000000 168953.2999999969906639, 328641.7999999970197678 168974.0000000000000000, 328567.4000000060186721 169016.0999999940104317, 328534.0999999939813279 169031.9000000059895683, 328500.0000000000000000 169053.5000000000000000, 328459.7999999970197678 169064.9000000059895683, 328408.5999999939813279 169077.7999999969906639, 328380.4000000060186721 169088.0000000000000000, 328340.7000000029802322 169099.5999999940104317, 328300.0999999939813279 169106.0000000000000000, 328246.4000000060186721 169110.5999999940104317, 328216.0999999939813279 169112.0000000000000000, 328133.7000000029802322 169112.2999999969906639, 328079.0000000000000000 169108.4000000059895683, 328011.0000000000000000 169096.7000000030093361, 327921.4000000060186721 169072.4000000059895683, 327862.0000000000000000 169053.9000000059895683, 327776.9000000060186721 169009.4000000059895683, 327720.0999999939813279 168988.2000000030093361, 327681.0000000000000000 168974.0000000000000000, 327582.0999999939813279 168920.7000000030093361, 327558.4000000060186721 168911.5000000000000000, 327552.7000000029802322 168904.2000000030093361, 327531.4000000060186721 168905.4000000059895683, 327448.0999999939813279 168876.2999999969906639, 327353.7999999970197678 168857.7999999969906639, 327281.4000000060186721 168839.2000000030093361, 327188.0999999939813279 168826.2000000030093361, 327117.5999999939813279 168818.7999999969906639, 327006.7999999970197678 168819.2000000030093361, 326934.0999999939813279 168838.0999999940104317, 326850.2999999970197678 168853.7000000030093361, 326800.9000000060186721 168865.7999999969906639, 326778.0000000000000000 168869.2999999969906639, 326730.0999999939813279 168889.2999999969906639, 326680.2000000029802322 168914.2000000030093361, 326658.5999999939813279 168919.5000000000000000, 326614.5999999939813279 168948.2000000030093361, 326607.9000000060186721 168960.0000000000000000, 326557.0999999939813279 168982.2000000030093361, 326536.9000000060186721 168988.2999999969906639, 326477.0000000000000000 169031.4000000059895683, 326402.4000000060186721 169103.0999999940104317, 326371.0000000000000000 169142.2999999969906639, 326339.7999999970197678 169182.4000000059895683, 326314.2000000029802322 169225.7000000030093361, 326295.0999999939813279 169269.4000000059895683, 326278.7000000029802322 169296.7999999969906639, 326249.0999999939813279 169353.2000000030093361, 326219.4000000060186721 169439.9000000059895683, 326181.5999999939813279 169524.7999999969906639, 326177.5000000000000000 169546.2999999969906639, 326142.5999999939813279 169657.7999999969906639, 326123.0999999939813279 169725.5000000000000000, 326098.4000000060186721 169848.4000000059895683, 326087.2999999970197678 169902.7000000030093361, 326057.0999999939813279 169968.5000000000000000, 326044.7000000029802322 170012.4000000059895683, 326007.7999999970197678 170166.0000000000000000, 325999.2999999970197678 170205.7999999969906639, 326011.5000000000000000 170276.0000000000000000, 326027.5000000000000000 170322.2000000030093361, 326061.7000000029802322 170373.2999999969906639, 326086.0000000000000000 170418.7999999969906639, 326110.5000000000000000 170441.5999999940104317, 326149.0999999939813279 170467.0000000000000000, 326183.9000000060186721 170495.2999999969906639, 326211.7999999970197678 170513.7999999969906639, 326257.5999999939813279 170540.7999999969906639, 326285.7999999970197678 170553.5999999940104317, 326364.4000000060186721 170580.7999999969906639, 326464.7000000029802322 170610.5000000000000000, 326532.7999999970197678 170637.0999999940104317, 326588.9000000060186721 170669.0999999940104317, 326626.7000000029802322 170682.7999999969906639, 326673.0999999939813279 170717.5000000000000000, 326721.2999999970197678 170755.0999999940104317, 326776.4000000060186721 170799.5999999940104317, 326852.4000000060186721 170882.7000000030093361, 326871.5000000000000000 170907.7999999969906639, 326903.2000000029802322 170952.7999999969906639, 326939.5999999939813279 171020.5000000000000000, 326947.4000000060186721 171045.7000000030093361, 326969.2999999970197678 171105.2000000030093361, 326992.7000000029802322 171156.2000000030093361, 327003.5000000000000000 171169.2000000030093361, 327021.2000000029802322 171200.9000000059895683, 327050.7999999970197678 171234.9000000059895683, 327075.4000000060186721 171275.0999999940104317, 327115.0000000000000000 171326.4000000059895683, 327231.5000000000000000 171443.5000000000000000, 327268.0999999939813279 171470.5000000000000000, 327322.2999999970197678 171517.5999999940104317, 327402.5999999939813279 171573.9000000059895683, 327448.5000000000000000 171606.2000000030093361, 327468.0999999939813279 171624.0999999940104317, 327524.7000000029802322 171659.9000000059895683, 327556.0000000000000000 171688.5999999940104317, 327592.2999999970197678 171721.5000000000000000, 327611.5999999939813279 171744.7000000030093361, 327639.5999999939813279 171775.5999999940104317, 327663.4000000060186721 171816.9000000059895683, 327681.7999999970197678 171860.0000000000000000, 327692.5000000000000000 171925.2000000030093361, 327695.7999999970197678 172008.2000000030093361, 327690.2999999970197678 172069.2000000030093361, 327688.0000000000000000 172115.7000000030093361, 327680.5000000000000000 172147.9000000059895683, 327678.5000000000000000 172175.9000000059895683, 327661.2000000029802322 172236.5000000000000000, 327639.4000000060186721 172286.5000000000000000, 327611.4000000060186721 172381.9000000059895683, 327596.2000000029802322 172449.5000000000000000, 327580.5000000000000000 172495.0999999940104317, 327547.5000000000000000 172594.0000000000000000, 327514.7000000029802322 172677.2999999969906639, 327495.7999999970197678 172740.7000000030093361, 327486.7000000029802322 172804.7000000030093361, 327474.0000000000000000 172870.2999999969906639, 327473.9000000060186721 172932.7999999969906639, 327479.7999999970197678 172971.7000000030093361, 327476.2999999970197678 172986.0000000000000000, 327483.0000000000000000 173019.5000000000000000, 327490.0000000000000000 173035.7999999969906639, 327486.5000000000000000 173054.9000000059895683, 327494.0999999939813279 173072.9000000059895683, 327512.5000000000000000 173105.9000000059895683, 327541.0000000000000000 173137.7999999969906639, 327573.2999999970197678 173165.2999999969906639, 327594.7999999970197678 173184.0000000000000000, 327608.2000000029802322 173194.0999999940104317, 327649.7000000029802322 173228.7999999969906639, 327665.2999999970197678 173255.9000000059895683, 327682.2000000029802322 173268.5999999940104317, 327708.0999999939813279 173294.7000000030093361, 327734.2000000029802322 173327.2999999969906639, 327744.0999999939813279 173347.0000000000000000, 327760.5999999939813279 173369.0000000000000000, 327765.9000000060186721 173378.9000000059895683, 327767.9000000060186721 173388.5999999940104317, 327770.5000000000000000 173407.2999999969906639, 327769.7999999970197678 173436.9000000059895683, 327745.2000000029802322 173473.7000000030093361, 327723.9000000060186721 173499.7999999969906639, 327685.9000000060186721 173528.0000000000000000, 327651.2000000029802322 173545.4000000059895683, 327589.5999999939813279 173575.0999999940104317, 327553.0000000000000000 173596.7999999969906639, 327505.5999999939813279 173618.0999999940104317, 327444.9000000060186721 173638.7000000030093361, 327422.9000000060186721 173644.5000000000000000, 327349.0000000000000000 173657.7999999969906639, 327298.2000000029802322 173663.4000000059895683, 327234.0000000000000000 173666.5999999940104317, 327197.7000000029802322 173662.7000000030093361, 327166.0000000000000000 173654.4000000059895683, 327140.9000000060186721 173650.0999999940104317, 327098.5000000000000000 173633.7999999969906639, 327026.4000000060186721 173603.0000000000000000, 327001.0000000000000000 173591.0999999940104317, 326985.9000000060186721 173581.4000000059895683, 326930.2000000029802322 173563.5999999940104317, 326897.5000000000000000 173549.7999999969906639, 326865.9000000060186721 173534.5999999940104317, 326831.2999999970197678 173528.7000000030093361, 326817.2000000029802322 173530.2999999969906639, 326779.7999999970197678 173534.4000000059895683, 326732.2999999970197678 173555.7999999969906639, 326706.9000000060186721 173582.5999999940104317, 326691.7999999970197678 173635.5999999940104317, 326687.2000000029802322 173657.0999999940104317, 326687.5999999939813279 173669.7000000030093361, 326676.9000000060186721 173692.7000000030093361, 326675.5999999939813279 173717.4000000059895683, 326667.0000000000000000 173734.9000000059895683, 326669.4000000060186721 173758.7000000030093361, 326666.2000000029802322 173789.4000000059895683, 326667.7999999970197678 173807.2999999969906639, 326665.5000000000000000 173851.7000000030093361, 326671.7999999970197678 173875.0999999940104317, 326674.0000000000000000 173893.2000000030093361, 326683.7999999970197678 173923.7000000030093361, 326680.9000000060186721 173958.0000000000000000, 326686.0000000000000000 173979.0999999940104317, 326674.9000000060186721 174019.0000000000000000, 326666.4000000060186721 174048.7999999969906639, 326657.5000000000000000 174069.2999999969906639, 326654.5999999939813279 174103.0999999940104317, 326637.4000000060186721 174160.4000000059895683, 326612.2999999970197678 174206.7999999969906639, 326595.7000000029802322 174236.5999999940104317, 326542.7999999970197678 174296.4000000059895683, 326513.5000000000000000 174354.9000000059895683, 326492.7999999970197678 174399.4000000059895683, 326475.7999999970197678 174499.7000000030093361, 326484.2999999970197678 174524.2999999969906639, 326486.2999999970197678 174542.2000000030093361, 326483.9000000060186721 174578.0999999940104317, 326490.9000000060186721 174608.7000000030093361, 326499.0000000000000000 174619.2999999969906639, 326543.2999999970197678 174649.2999999969906639, 326557.7999999970197678 174660.0000000000000000, 326603.7000000029802322 174667.7999999969906639, 326623.2999999970197678 174671.7000000030093361, 326671.5000000000000000 174674.7000000030093361, 326720.0000000000000000 174679.5000000000000000, 326729.4000000060186721 174687.4000000059895683, 326750.9000000060186721 174688.7999999969906639, 326781.7000000029802322 174684.7999999969906639, 326862.4000000060186721 174670.5999999940104317, 326886.7999999970197678 174669.5000000000000000, 326908.7999999970197678 174662.0999999940104317, 326991.7999999970197678 174653.4000000059895683, 327012.7999999970197678 174650.7999999969906639, 327046.0000000000000000 174651.2999999969906639, 327069.2999999970197678 174668.7000000030093361, 327083.2000000029802322 174677.7000000030093361, 327099.7999999970197678 174696.0999999940104317, 327113.7999999970197678 174729.9000000059895683, 327124.7000000029802322 174743.5999999940104317, 327135.5999999939813279 174790.0999999940104317, 327117.2999999970197678 174844.2999999969906639, 327085.7999999970197678 174885.7000000030093361, 327068.7000000029802322 174916.4000000059895683, 327069.7000000029802322 174933.5000000000000000, 327073.2999999970197678 174957.9000000059895683, 327079.4000000060186721 174992.0999999940104317, 327102.2999999970197678 175038.7999999969906639, 327123.4000000060186721 175053.7000000030093361, 327136.5000000000000000 175067.0000000000000000, 327173.9000000060186721 175104.2999999969906639, 327200.2000000029802322 175120.9000000059895683, 327229.2000000029802322 175143.9000000059895683, 327254.2000000029802322 175160.7999999969906639, 327263.0999999939813279 175164.5000000000000000, 327292.2999999970197678 175184.7999999969906639, 327353.5999999939813279 175222.5000000000000000, 327368.2000000029802322 175231.2999999969906639, 327388.7999999970197678 175242.0000000000000000, 327458.7999999970197678 175275.2999999969906639, 327481.0000000000000000 175289.0999999940104317, 327505.2000000029802322 175299.7000000030093361, 327553.2999999970197678 175328.2000000030093361, 327585.7000000029802322 175353.0999999940104317, 327605.7000000029802322 175389.0999999940104317, 327616.7000000029802322 175422.0000000000000000, 327647.7000000029802322 175480.9000000059895683, 327656.7000000029802322 175505.5000000000000000, 327680.5000000000000000 175586.2000000030093361, 327687.0999999939813279 175611.2999999969906639, 327699.0000000000000000 175662.2000000030093361, 327723.5999999939813279 175729.7999999969906639, 327745.0999999939813279 175797.0000000000000000, 327760.7000000029802322 175833.0999999940104317, 327771.0000000000000000 175870.5999999940104317, 327791.5999999939813279 175941.2000000030093361, 327818.2999999970197678 175999.4000000059895683, 327827.0999999939813279 176028.7000000030093361, 327838.0000000000000000 176061.0000000000000000, 327879.0999999939813279 176123.4000000059895683, 327912.7999999970197678 176170.0000000000000000, 327945.0999999939813279 176215.7000000030093361, 327959.9000000060186721 176245.7999999969906639, 327983.7999999970197678 176272.2000000030093361, 327977.5999999939813279 176288.7999999969906639, 327959.0999999939813279 176298.7999999969906639, 327927.0000000000000000 176326.7000000030093361, 327878.4000000060186721 176359.0999999940104317, 327787.7000000029802322 176404.9000000059895683, 327776.9000000060186721 176415.7999999969906639, 327741.0000000000000000 176435.5999999940104317, 327681.0000000000000000 176468.5000000000000000, 327603.2999999970197678 176521.2999999969906639, 327576.5000000000000000 176534.9000000059895683, 327535.5000000000000000 176563.5000000000000000, 327485.5999999939813279 176597.9000000059895683, 327427.4000000060186721 176632.0000000000000000, 327364.7999999970197678 176671.5999999940104317, 327325.4000000060186721 176686.7000000030093361, 327257.7999999970197678 176724.2000000030093361, 327223.7000000029802322 176747.9000000059895683, 327196.2000000029802322 176765.0000000000000000, 327155.7999999970197678 176795.0999999940104317, 327106.5999999939813279 176825.7000000030093361, 327001.5999999939813279 176881.7999999969906639, 326982.0999999939813279 176895.7999999969906639, 326945.2000000029802322 176914.2999999969906639, 326853.7999999970197678 176970.7999999969906639, 326834.7999999970197678 176977.7000000030093361, 326772.7000000029802322 177018.2999999969906639, 326734.0999999939813279 177043.2999999969906639, 326703.7000000029802322 177059.7000000030093361, 326622.2999999970197678 177114.4000000059895683, 326505.4000000060186721 177189.9000000059895683, 326408.2999999970197678 177241.9000000059895683, 326363.7000000029802322 177268.7000000030093361, 326329.2999999970197678 177283.0000000000000000, 326233.0000000000000000 177341.7999999969906639, 326200.2999999970197678 177359.2999999969906639, 326108.7999999970197678 177421.0000000000000000, 326027.7999999970197678 177475.0999999940104317, 325995.2999999970197678 177498.4000000059895683, 325858.4000000060186721 177579.5999999940104317, 325829.2999999970197678 177591.7000000030093361, 325740.7000000029802322 177645.0000000000000000, 325708.7999999970197678 177660.2999999969906639, 325616.9000000060186721 177713.5000000000000000, 325489.9000000060186721 177789.7999999969906639, 325405.0999999939813279 177835.7000000030093361, 325367.0000000000000000 177863.2999999969906639, 325347.2000000029802322 177874.5999999940104317, 325303.5999999939813279 177902.9000000059895683, 325207.7999999970197678 177964.7999999969906639, 325159.4000000060186721 177994.9000000059895683, 325134.2000000029802322 178008.7000000030093361, 325106.0000000000000000 178021.2000000030093361, 325091.0000000000000000 178029.4000000059895683, 325040.0000000000000000 178061.7999999969906639, 325031.2000000029802322 178068.7999999969906639, 325021.2000000029802322 178075.7999999969906639, 325002.5000000000000000 178089.0000000000000000, 324985.0999999939813279 178098.7999999969906639, 324959.5999999939813279 178117.0000000000000000, 324947.4000000060186721 178118.9000000059895683, 324904.5000000000000000 178148.5000000000000000, 324866.5000000000000000 178173.7999999969906639, 324849.7000000029802322 178186.9000000059895683, 324749.0999999939813279 178246.4000000059895683, 324643.2999999970197678 178306.9000000059895683, 324595.2999999970197678 178337.7999999969906639, 324558.4000000060186721 178369.0999999940104317, 324518.7999999970197678 178392.5000000000000000, 324491.7000000029802322 178404.4000000059895683, 324437.0000000000000000 178438.0000000000000000, 324403.0000000000000000 178468.7999999969906639, 324370.2000000029802322 178487.0000000000000000, 324325.7000000029802322 178511.9000000059895683, 324274.5999999939813279 178545.5999999940104317, 324225.0999999939813279 178572.9000000059895683, 324120.2000000029802322 178635.2999999969906639, 324058.2000000029802322 178675.4000000059895683, 324017.5000000000000000 178703.0000000000000000, 323988.5999999939813279 178717.2000000030093361, 323901.9000000060186721 178778.7000000030093361, 323864.0999999939813279 178800.5000000000000000, 323768.2000000029802322 178856.0000000000000000, 323744.7000000029802322 178865.0999999940104317, 323722.2999999970197678 178881.4000000059895683, 323689.9000000060186721 178905.0999999940104317, 323639.5000000000000000 178938.7999999969906639, 323590.7999999970197678 178962.7999999969906639, 323551.2999999970197678 178983.9000000059895683, 323495.5000000000000000 179000.4000000059895683, 323473.7000000029802322 179018.7000000030093361, 323449.7000000029802322 179039.0000000000000000, 323421.7000000029802322 179060.2000000030093361, 323396.5000000000000000 179066.7999999969906639, 323370.5000000000000000 179057.7999999969906639, 323357.0000000000000000 179038.2000000030093361, 323345.0999999939813279 179021.5000000000000000, 323327.7000000029802322 179010.0000000000000000, 323307.7999999970197678 179011.7999999969906639, 323287.7999999970197678 179024.7999999969906639, 323241.7000000029802322 179045.0000000000000000, 323198.2999999970197678 179058.9000000059895683, 323160.7000000029802322 179063.2000000030093361, 323139.5000000000000000 179052.0999999940104317, 323119.0999999939813279 179037.0999999940104317, 323100.5000000000000000 179001.7999999969906639, 323084.2999999970197678 178972.5000000000000000, 323075.9000000060186721 178949.9000000059895683, 323057.7999999970197678 178924.4000000059895683, 323028.4000000060186721 178895.0999999940104317, 323006.2999999970197678 178884.0000000000000000, 322976.2000000029802322 178859.0000000000000000, 322941.5999999939813279 178852.0000000000000000, 322892.0000000000000000 178852.5999999940104317, 322835.4000000060186721 178865.4000000059895683, 322813.2999999970197678 178863.7000000030093361, 322797.5999999939813279 178861.7000000030093361, 322774.7000000029802322 178849.9000000059895683, 322758.0000000000000000 178846.5999999940104317, 322723.5000000000000000 178827.0000000000000000, 322709.5000000000000000 178817.2000000030093361, 322624.0000000000000000 178754.7000000030093361, 322596.7000000029802322 178733.7999999969906639, 322576.2999999970197678 178721.0000000000000000, 322565.7999999970197678 178714.0000000000000000, 322542.2000000029802322 178703.7999999969906639, 322497.2000000029802322 178697.2999999969906639, 322476.7999999970197678 178699.2999999969906639, 322405.5000000000000000 178714.4000000059895683, 322376.7000000029802322 178728.2999999969906639, 322332.9000000060186721 178744.2000000030093361, 322269.2999999970197678 178770.5999999940104317, 322226.2999999970197678 178808.2000000030093361, 322186.5999999939813279 178832.7999999969906639, 322137.2999999970197678 178844.7000000030093361, 322103.5000000000000000 178846.7999999969906639, 322064.5999999939813279 178852.5999999940104317, 322049.7000000029802322 178850.5999999940104317, 322029.4000000060186721 178846.0999999940104317, 322009.5999999939813279 178832.7999999969906639, 321958.7999999970197678 178784.9000000059895683, 321895.2999999970197678 178717.5000000000000000, 321860.2999999970197678 178682.0999999940104317, 321811.5000000000000000 178634.5000000000000000, 321783.7999999970197678 178608.0000000000000000, 321754.5000000000000000 178580.5000000000000000, 321729.7999999970197678 178565.4000000059895683, 321689.9000000060186721 178555.7999999969906639, 321675.7000000029802322 178550.7000000030093361, 321659.0000000000000000 178547.5000000000000000, 321621.7999999970197678 178534.0999999940104317, 321579.0999999939813279 178521.7999999969906639, 321516.5999999939813279 178491.7999999969906639, 321475.5000000000000000 178473.7999999969906639, 321436.4000000060186721 178456.0000000000000000, 321387.5999999939813279 178447.7000000030093361, 321360.7000000029802322 178443.4000000059895683, 321320.7000000029802322 178436.0000000000000000, 321290.0000000000000000 178431.0000000000000000, 321230.4000000060186721 178422.7000000030093361, 321116.7999999970197678 178402.0000000000000000, 321093.5999999939813279 178401.0999999940104317, 321071.0000000000000000 178400.9000000059895683, 321048.7999999970197678 178400.0999999940104317, 320998.9000000060186721 178401.7999999969906639, 320968.2000000029802322 178411.7999999969906639, 320903.7999999970197678 178434.4000000059895683, 320879.2999999970197678 178448.7999999969906639, 320824.0000000000000000 178479.2999999969906639, 320791.7999999970197678 178495.7999999969906639, 320751.5999999939813279 178510.0999999940104317, 320717.7000000029802322 178523.7000000030093361, 320676.2999999970197678 178521.5000000000000000, 320604.0999999939813279 178531.7999999969906639, 320559.5999999939813279 178532.0999999940104317, 320508.4000000060186721 178519.4000000059895683, 320465.4000000060186721 178509.5999999940104317, 320435.2000000029802322 178503.7999999969906639, 320368.4000000060186721 178498.7999999969906639, 320306.2999999970197678 178488.0000000000000000, 320235.0999999939813279 178480.7000000030093361, 320218.2999999970197678 178474.5000000000000000, 320201.7999999970197678 178468.2000000030093361, 320175.4000000060186721 178468.0999999940104317, 320157.2999999970197678 178469.7000000030093361, 320117.5000000000000000 178469.5000000000000000, 320103.7999999970197678 178466.0000000000000000, 320056.2999999970197678 178458.2000000030093361, 319968.0999999939813279 178428.5999999940104317, 319937.5999999939813279 178413.0000000000000000, 319901.0000000000000000 178387.2999999969906639, 319764.7999999970197678 178297.4000000059895683, 319694.2000000029802322 178253.2999999969906639, 319660.2000000029802322 178235.0999999940104317, 319639.5000000000000000 178228.5000000000000000, 319597.0999999939813279 178211.7000000030093361, 319577.0999999939813279 178205.9000000059895683, 319542.0999999939813279 178203.7000000030093361, 319521.5999999939813279 178206.2999999969906639, 319495.9000000060186721 178204.4000000059895683, 319467.0999999939813279 178206.7000000030093361, 319419.7999999970197678 178215.5999999940104317, 319396.7000000029802322 178221.2000000030093361, 319316.5000000000000000 178239.5999999940104317, 319227.7000000029802322 178258.7999999969906639, 319149.2000000029802322 178282.4000000059895683, 319130.0999999939813279 178287.7000000030093361, 319028.7999999970197678 178321.5999999940104317, 318921.7000000029802322 178348.5000000000000000, 318884.0000000000000000 178358.5999999940104317, 318780.7999999970197678 178405.7999999969906639, 318756.4000000060186721 178411.5000000000000000, 318728.7999999970197678 178424.7999999969906639, 318669.5999999939813279 178481.7000000030093361, 318632.4000000060186721 178503.2000000030093361, 318567.5999999939813279 178553.5999999940104317, 318500.0000000000000000 178618.2000000030093361, 318456.0000000000000000 178671.7999999969906639, 318435.4000000060186721 178701.5000000000000000, 318413.2000000029802322 178734.5000000000000000, 318361.2000000029802322 178805.0000000000000000, 318335.5999999939813279 178839.5000000000000000, 318308.0000000000000000 178862.9000000059895683, 318278.9000000060186721 178879.5000000000000000, 318250.5999999939813279 178891.5000000000000000, 318195.9000000060186721 178930.7999999969906639, 318170.5999999939813279 178942.7999999969906639, 318056.9000000060186721 178971.5000000000000000, 318007.9000000060186721 178975.7999999969906639, 317957.2999999970197678 178971.5999999940104317, 317912.7000000029802322 178961.5000000000000000, 317866.5000000000000000 178955.7999999969906639, 317823.5999999939813279 178924.7999999969906639, 317736.5000000000000000 178898.9000000059895683, 317684.7999999970197678 178873.5000000000000000, 317656.5000000000000000 178853.7000000030093361, 317617.7999999970197678 178823.4000000059895683, 317562.9000000060186721 178785.7999999969906639, 317523.0000000000000000 178756.2999999969906639, 317464.2999999970197678 178727.5000000000000000, 317400.2999999970197678 178681.7999999969906639, 317360.0999999939813279 178671.4000000059895683, 317294.0999999939813279 178656.2999999969906639, 317215.5999999939813279 178617.0999999940104317, 317086.2000000029802322 178569.2000000030093361, 317021.2999999970197678 178554.7000000030093361, 316952.7999999970197678 178536.5999999940104317, 316870.0000000000000000 178517.9000000059895683, 316828.2999999970197678 178512.5000000000000000, 316774.4000000060186721 178507.4000000059895683, 316697.2999999970197678 178498.7999999969906639, 316569.0000000000000000 178481.5999999940104317, 316419.7999999970197678 178472.2000000030093361, 316295.0999999939813279 178479.7999999969906639, 316204.7000000029802322 178485.7999999969906639, 316164.2999999970197678 178485.0999999940104317, 316101.7999999970197678 178490.4000000059895683, 316057.9000000060186721 178491.2999999969906639, 315974.4000000060186721 178513.0999999940104317, 315921.0000000000000000 178524.0000000000000000, 315852.2999999970197678 178551.0999999940104317, 315807.2000000029802322 178566.7000000030093361, 315774.0000000000000000 178580.2000000030093361, 315710.7000000029802322 178599.9000000059895683, 315610.7999999970197678 178628.9000000059895683, 315575.5000000000000000 178634.5999999940104317, 315480.7000000029802322 178659.0999999940104317, 315437.9000000060186721 178661.7000000030093361, 315405.7999999970197678 178666.9000000059895683, 315351.7000000029802322 178668.2999999969906639, 315288.5999999939813279 178657.5999999940104317, 315223.2999999970197678 178639.2999999969906639, 315192.0000000000000000 178624.7000000030093361, 315157.0999999939813279 178601.4000000059895683, 315095.2999999970197678 178575.4000000059895683, 315039.7000000029802322 178533.5999999940104317, 315015.5999999939813279 178472.9000000059895683, 315003.2999999970197678 178431.2000000030093361, 314995.2999999970197678 178409.5999999940104317, 314978.2000000029802322 178355.2000000030093361, 314959.2999999970197678 178286.7000000030093361, 314917.7999999970197678 178184.7999999969906639, 314913.0000000000000000 178173.9000000059895683, 314894.7000000029802322 178157.2000000030093361, 314885.0999999939813279 178153.5000000000000000, 314859.4000000060186721 178136.2999999969906639, 314832.0999999939813279 178108.0000000000000000, 314803.4000000060186721 178090.9000000059895683, 314768.0999999939813279 178085.5000000000000000, 314770.4000000060186721 178101.2000000030093361, 314774.5999999939813279 178114.7000000030093361, 314774.4000000060186721 178130.7999999969906639, 314774.7999999970197678 178148.2999999969906639, 314775.2999999970197678 178173.0000000000000000, 314763.9000000060186721 178188.0999999940104317, 314765.4000000060186721 178206.7999999969906639, 314760.5999999939813279 178218.5999999940104317, 314763.2000000029802322 178228.2999999969906639, 314752.7999999970197678 178242.2000000030093361, 314742.5999999939813279 178252.5999999940104317, 314693.4000000060186721 178363.0999999940104317, 314677.7999999970197678 178402.0999999940104317, 314649.5999999939813279 178451.5999999940104317, 314603.7999999970197678 178502.4000000059895683, 314594.5999999939813279 178521.0000000000000000, 314581.5000000000000000 178542.2999999969906639, 314570.0999999939813279 178577.9000000059895683, 314563.0999999939813279 178610.2999999969906639, 314539.0000000000000000 178648.9000000059895683, 314519.5000000000000000 178681.5999999940104317, 314505.4000000060186721 178726.0000000000000000, 314498.5000000000000000 178730.2999999969906639, 314491.2999999970197678 178813.5999999940104317, 314490.0999999939813279 178854.2000000030093361, 314486.5000000000000000 178903.0000000000000000, 314478.2999999970197678 178922.7000000030093361, 314446.2999999970197678 178960.5000000000000000, 314426.4000000060186721 178976.9000000059895683, 314394.0999999939813279 178986.7000000030093361, 314376.2000000029802322 178969.7999999969906639, 314352.7000000029802322 178961.2999999969906639, 314320.4000000060186721 178991.5999999940104317, 314312.0999999939813279 179030.7999999969906639, 314308.5000000000000000 179112.7000000030093361, 314319.2000000029802322 179153.7999999969906639, 314337.7000000029802322 179181.5999999940104317, 314351.0000000000000000 179194.5000000000000000, 314364.0000000000000000 179234.0999999940104317, 314362.7000000029802322 179261.0999999940104317, 314350.5000000000000000 179277.7000000030093361, 314297.2999999970197678 179321.2000000030093361, 314279.9000000060186721 179334.5000000000000000, 314252.7999999970197678 179407.5000000000000000, 314254.2999999970197678 179473.7999999969906639, 314260.7999999970197678 179519.7999999969906639, 314271.5000000000000000 179569.5999999940104317, 314278.2000000029802322 179592.7999999969906639, 314288.7999999970197678 179619.5000000000000000, 314298.7999999970197678 179649.5999999940104317, 314318.5999999939813279 179698.5999999940104317, 314326.5000000000000000 179722.9000000059895683, 314376.5000000000000000 179842.5999999940104317, 314393.2000000029802322 179910.2999999969906639, 314391.9000000060186721 179935.7000000030093361, 314426.7999999970197678 180008.0000000000000000, 314436.9000000060186721 180038.5999999940104317, 314442.2999999970197678 180097.5999999940104317, 314458.0999999939813279 180171.7000000030093361, 314478.9000000060186721 180268.7000000030093361, 314502.7999999970197678 180322.0999999940104317, 314519.0000000000000000 180372.7999999969906639, 314527.7999999970197678 180404.2999999969906639, 314548.7999999970197678 180449.4000000059895683, 314563.7999999970197678 180478.4000000059895683, 314580.5999999939813279 180515.2999999969906639, 314597.7000000029802322 180550.5000000000000000, 314606.7999999970197678 180583.2999999969906639, 314636.4000000060186721 180642.9000000059895683, 314694.9000000060186721 180785.2999999969906639, 314707.4000000060186721 180815.2000000030093361, 314725.9000000060186721 180840.2000000030093361, 314759.2999999970197678 180906.7000000030093361, 314771.7000000029802322 180925.5000000000000000, 314793.4000000060186721 180988.2999999969906639, 314819.0999999939813279 181036.5000000000000000, 314828.5000000000000000 181055.7999999969906639, 314845.4000000060186721 181077.2999999969906639, 314868.4000000060186721 181121.7999999969906639, 314904.2000000029802322 181168.5000000000000000, 314928.7000000029802322 181218.4000000059895683, 314961.4000000060186721 181288.2999999969906639, 314983.5999999939813279 181335.0999999940104317, 315024.2000000029802322 181381.5999999940104317, 315050.5000000000000000 181406.9000000059895683, 315066.7000000029802322 181431.7999999969906639, 315096.5999999939813279 181460.0000000000000000, 315122.2999999970197678 181477.5999999940104317, 315149.5999999939813279 181518.5999999940104317, 315192.4000000060186721 181554.9000000059895683, 315227.0999999939813279 181571.0999999940104317, 315264.2999999970197678 181604.5999999940104317, 315332.5999999939813279 181660.2000000030093361, 315365.2999999970197678 181683.7000000030093361, 315394.4000000060186721 181710.5999999940104317, 315505.0000000000000000 181774.9000000059895683, 315550.7000000029802322 181796.5999999940104317, 315579.4000000060186721 181812.7999999969906639, 315617.0999999939813279 181830.2000000030093361, 315649.5000000000000000 181850.9000000059895683, 315661.2999999970197678 181869.5999999940104317, 315675.2000000029802322 181884.2000000030093361, 315685.2000000029802322 181908.7999999969906639, 315714.2000000029802322 181992.5999999940104317, 315720.2999999970197678 182027.0000000000000000, 315723.2000000029802322 182129.0999999940104317, 315732.0999999939813279 182231.7999999969906639, 315741.4000000060186721 182363.0999999940104317, 315747.5000000000000000 182457.4000000059895683, 315763.5000000000000000 182524.2000000030093361, 315784.7000000029802322 182671.5000000000000000, 315788.7000000029802322 182711.0000000000000000, 315793.2999999970197678 182754.0000000000000000, 315785.9000000060186721 182806.0000000000000000, 315767.4000000060186721 182831.5999999940104317, 315713.2999999970197678 182843.0000000000000000, 315703.7999999970197678 182854.2000000030093361, 315692.7999999970197678 182878.7999999969906639, 315678.7999999970197678 182898.9000000059895683, 315665.5999999939813279 182930.2999999969906639, 315651.5000000000000000 182947.5000000000000000, 315641.9000000060186721 182964.0999999940104317, 315623.7000000029802322 182992.5999999940104317, 315576.0999999939813279 183067.7000000030093361, 315556.0999999939813279 183108.9000000059895683, 315542.7999999970197678 183137.7999999969906639, 315537.9000000060186721 183151.9000000059895683, 315502.5000000000000000 183197.7999999969906639, 315500.0999999939813279 183224.5000000000000000, 315505.5999999939813279 183247.7000000030093361, 315520.5000000000000000 183284.4000000059895683, 315535.0000000000000000 183299.0999999940104317, 315544.4000000060186721 183327.7000000030093361, 315552.4000000060186721 183358.2000000030093361, 315553.7999999970197678 183367.2000000030093361, 315550.7000000029802322 183394.2000000030093361, 315562.9000000060186721 183418.0999999940104317, 315591.2000000029802322 183439.2000000030093361, 315611.2999999970197678 183468.5999999940104317, 315620.0000000000000000 183487.2000000030093361, 315631.4000000060186721 183502.0000000000000000, 315642.2000000029802322 183528.2000000030093361, 315665.7000000029802322 183573.7999999969906639, 315673.2000000029802322 183604.2999999969906639, 315671.7000000029802322 183648.7999999969906639, 315670.9000000060186721 183691.9000000059895683, 315640.2999999970197678 183741.0999999940104317, 315640.7000000029802322 183756.5000000000000000, 315644.2999999970197678 183769.4000000059895683, 315641.2999999970197678 183828.9000000059895683, 315648.5000000000000000 183866.0999999940104317, 315651.9000000060186721 183892.7999999969906639, 315668.9000000060186721 183930.5000000000000000, 315678.2999999970197678 183960.2999999969906639, 315695.2999999970197678 183993.2999999969906639, 315703.5999999939813279 184021.5000000000000000, 315722.5000000000000000 184061.5999999940104317, 315750.0000000000000000 184102.0000000000000000, 315787.7999999970197678 184164.7999999969906639, 315821.4000000060186721 184232.2000000030093361, 315856.7000000029802322 184295.2000000030093361, 315872.7000000029802322 184333.2000000030093361, 315893.7000000029802322 184363.0000000000000000, 315932.0999999939813279 184388.9000000059895683, 315958.9000000060186721 184415.4000000059895683, 315964.5000000000000000 184425.2999999969906639, 315974.2999999970197678 184435.5999999940104317, 316014.4000000060186721 184496.9000000059895683, 316055.2999999970197678 184558.2999999969906639, 316091.2999999970197678 184620.9000000059895683, 316109.7999999970197678 184651.2999999969906639, 316147.2000000029802322 184696.9000000059895683, 316169.2999999970197678 184734.9000000059895683, 316183.7000000029802322 184762.0999999940104317, 316206.5000000000000000 184798.2000000030093361, 316218.5999999939813279 184823.0000000000000000, 316237.5999999939813279 184839.2000000030093361, 316252.4000000060186721 184870.2000000030093361, 316291.4000000060186721 184932.2000000030093361, 316308.4000000060186721 184967.2999999969906639, 316333.2000000029802322 185000.0000000000000000, 316344.2000000029802322 185035.5999999940104317, 316362.2000000029802322 185069.0000000000000000, 316373.7999999970197678 185114.0000000000000000, 316391.5000000000000000 185159.9000000059895683, 316423.7999999970197678 185235.2000000030093361, 316447.9000000060186721 185284.0000000000000000, 316459.2999999970197678 185298.5000000000000000, 316467.5000000000000000 185316.0999999940104317, 316469.2999999970197678 185327.5999999940104317, 316500.9000000060186721 185379.5999999940104317, 316523.7999999970197678 185431.9000000059895683, 316531.2000000029802322 185453.2999999969906639, 316556.9000000060186721 185489.7999999969906639, 316575.5999999939813279 185514.2000000030093361, 316596.7999999970197678 185545.4000000059895683, 316617.2000000029802322 185584.9000000059895683, 316620.2999999970197678 185595.2000000030093361, 316636.5999999939813279 185620.5000000000000000, 316647.5999999939813279 185653.5999999940104317, 316662.2999999970197678 185685.5000000000000000, 316666.4000000060186721 185720.4000000059895683, 316684.2999999970197678 185798.9000000059895683, 316703.2999999970197678 185851.0000000000000000, 316715.2000000029802322 185894.2999999969906639, 316714.0999999939813279 185906.7999999969906639, 316724.0999999939813279 185918.7999999969906639, 316751.7000000029802322 185922.4000000059895683, 316762.7999999970197678 185927.0999999940104317, 316757.7999999970197678 185952.7000000030093361, 316738.0999999939813279 185976.9000000059895683, 316724.7999999970197678 185992.7000000030093361, 316725.7000000029802322 186009.2999999969906639, 316734.5999999939813279 186024.9000000059895683, 316748.0999999939813279 186056.2000000030093361, 316752.2000000029802322 186074.2999999969906639, 316744.2000000029802322 186101.5999999940104317, 316756.5999999939813279 186130.5999999940104317, 316768.0999999939813279 186153.4000000059895683, 316782.5000000000000000 186164.0999999940104317, 316797.4000000060186721 186204.5999999940104317, 316804.0999999939813279 186214.4000000059895683, 316821.2999999970197678 186233.2999999969906639, 316855.5999999939813279 186293.5000000000000000, 316873.5000000000000000 186307.9000000059895683, 316911.4000000060186721 186368.0999999940104317, 316940.5999999939813279 186424.0999999940104317, 316946.5999999939813279 186434.7999999969906639, 316961.7000000029802322 186510.5999999940104317, 316965.0000000000000000 186520.7000000030093361, 316979.2999999970197678 186539.0000000000000000, 316990.5999999939813279 186584.7000000030093361, 316994.2000000029802322 186597.7000000030093361, 317018.4000000060186721 186638.9000000059895683, 317038.7000000029802322 186669.2999999969906639, 317070.5999999939813279 186694.2999999969906639, 317085.9000000060186721 186722.9000000059895683, 317090.4000000060186721 186730.7999999969906639, 317089.9000000060186721 186742.2999999969906639, 317097.7999999970197678 186764.9000000059895683, 317121.5000000000000000 186810.2000000030093361, 317140.2999999970197678 186835.2000000030093361, 317160.2999999970197678 186880.0000000000000000, 317168.5000000000000000 186905.5000000000000000, 317211.9000000060186721 186991.0999999940104317, 317257.9000000060186721 187073.5000000000000000, 317297.7000000029802322 187156.0000000000000000, 317308.7000000029802322 187177.5999999940104317, 317342.2000000029802322 187247.4000000059895683, 317351.2000000029802322 187269.2999999969906639, 317388.2999999970197678 187349.4000000059895683, 317406.7000000029802322 187390.5999999940104317, 317474.0999999939813279 187525.7999999969906639, 317552.7999999970197678 187692.4000000059895683, 317577.2000000029802322 187735.5999999940104317, 317621.7000000029802322 187821.5000000000000000, 317694.4000000060186721 187969.4000000059895683, 317716.5000000000000000 188024.0000000000000000, 317743.9000000060186721 188078.7999999969906639, 317781.5999999939813279 188157.7999999969906639, 317816.0000000000000000 188218.2999999969906639, 317863.0000000000000000 188324.2000000030093361, 317921.0999999939813279 188427.2000000030093361, 317971.0999999939813279 188527.7999999969906639, 318036.4000000060186721 188645.5000000000000000, 318060.2999999970197678 188697.7999999969906639, 318114.5000000000000000 188796.0000000000000000, 318127.0000000000000000 188812.7999999969906639, 318128.5999999939813279 188825.9000000059895683, 318159.2999999970197678 188891.7999999969906639, 318180.0999999939813279 188930.9000000059895683, 318194.2000000029802322 189015.7999999969906639, 318211.0000000000000000 189076.5999999940104317, 318223.2999999970197678 189131.5999999940104317, 318239.5999999939813279 189158.2000000030093361, 318251.2999999970197678 189190.7999999969906639, 318268.2000000029802322 189250.9000000059895683, 318290.0999999939813279 189295.9000000059895683, 318314.0999999939813279 189331.5000000000000000, 318326.0000000000000000 189359.2999999969906639, 318331.5999999939813279 189392.4000000059895683, 318331.2000000029802322 189414.5000000000000000, 318321.7000000029802322 189446.0999999940104317, 318324.4000000060186721 189466.7000000030093361, 318348.0000000000000000 189514.2999999969906639, 318350.9000000060186721 189527.9000000059895683, 318347.0000000000000000 189560.5000000000000000, 318353.5000000000000000 189573.7999999969906639, 318368.7000000029802322 189581.2999999969906639, 318387.2999999970197678 189573.7000000030093361, 318412.5999999939813279 189557.4000000059895683, 318434.9000000060186721 189556.2999999969906639, 318453.0999999939813279 189569.2999999969906639, 318486.7000000029802322 189593.7000000030093361, 318527.2000000029802322 189625.7000000030093361, 318593.7999999970197678 189695.7999999969906639, 318624.7999999970197678 189735.0000000000000000, 318671.5999999939813279 189751.2999999969906639, 318712.5000000000000000 189761.0000000000000000, 318740.7999999970197678 189776.2999999969906639, 318828.4000000060186721 189866.5999999940104317, 318846.2999999970197678 189891.9000000059895683, 318891.4000000060186721 189930.9000000059895683, 318971.5999999939813279 190014.2000000030093361, 319012.2999999970197678 190057.0000000000000000, 319067.5000000000000000 190111.0000000000000000, 319094.0000000000000000 190146.0000000000000000, 319121.9000000060186721 190176.0999999940104317, 319181.9000000060186721 190242.7000000030093361, 319255.2000000029802322 190328.7999999969906639, 319268.9000000060186721 190345.0999999940104317, 319277.2000000029802322 190348.5000000000000000, 319283.5000000000000000 190355.4000000059895683, 319308.2999999970197678 190373.9000000059895683, 319339.5999999939813279 190389.5000000000000000, 319402.2000000029802322 190440.5999999940104317, 319459.7999999970197678 190492.0000000000000000, 319490.5000000000000000 190530.2999999969906639, 319526.7000000029802322 190551.0999999940104317, 319546.9000000060186721 190565.5000000000000000, 319601.0999999939813279 190627.7999999969906639, 319628.7999999970197678 190653.9000000059895683, 319651.2000000029802322 190677.2000000030093361, 319665.2000000029802322 190695.7000000030093361, 319689.5999999939813279 190724.5000000000000000, 319694.7000000029802322 190733.0999999940104317, 319727.2999999970197678 190769.0000000000000000, 319734.0000000000000000 190781.0000000000000000, 319734.7999999970197678 190805.5999999940104317, 319746.9000000060186721 190823.4000000059895683, 319765.9000000060186721 190839.5000000000000000, 319777.5000000000000000 190853.9000000059895683, 319788.7000000029802322 190865.0999999940104317, 319798.2000000029802322 190883.7999999969906639, 319827.0000000000000000 190936.4000000059895683, 319856.0000000000000000 190970.9000000059895683, 319880.2000000029802322 191020.0999999940104317, 319891.5000000000000000 191043.7000000030093361, 319894.7999999970197678 191077.5000000000000000, 319898.2999999970197678 191100.4000000059895683, 319897.5999999939813279 191117.9000000059895683, 319905.5999999939813279 191151.0000000000000000, 319916.2000000029802322 191229.0999999940104317, 319916.2000000029802322 191269.2999999969906639, 319912.7000000029802322 191276.7999999969906639, 319908.0000000000000000 191289.5999999940104317, 319909.4000000060186721 191307.5000000000000000, 319907.7000000029802322 191320.7000000030093361, 319910.9000000060186721 191351.7000000030093361, 319914.7000000029802322 191372.7999999969906639, 319913.2000000029802322 191394.5999999940104317, 319907.9000000060186721 191410.7999999969906639, 319913.2999999970197678 191490.0000000000000000, 319912.5999999939813279 191539.5000000000000000, 319908.2000000029802322 191606.5999999940104317, 319907.5999999939813279 191656.0999999940104317, 319909.0000000000000000 191675.7000000030093361, 319904.7999999970197678 191698.0999999940104317, 319906.0000000000000000 191724.5999999940104317, 319907.5000000000000000 191780.5000000000000000, 319905.5999999939813279 191807.0000000000000000, 319908.7999999970197678 191826.4000000059895683, 319898.7000000029802322 191901.9000000059895683, 319899.4000000060186721 191945.0000000000000000, 319898.7000000029802322 191975.2999999969906639, 319903.4000000060186721 192040.5999999940104317, 319902.2000000029802322 192087.9000000059895683, 319903.5000000000000000 192124.0999999940104317, 319902.2000000029802322 192172.7000000030093361, 319905.7999999970197678 192210.4000000059895683, 319899.0000000000000000 192276.7999999969906639, 319904.2000000029802322 192321.9000000059895683, 319901.2000000029802322 192370.7999999969906639, 319903.4000000060186721 192412.0000000000000000, 319897.5999999939813279 192444.2999999969906639, 319900.0000000000000000 192480.2999999969906639, 319899.7000000029802322 192501.5999999940104317, 319896.0000000000000000 192536.7999999969906639, 319889.5000000000000000 192562.4000000059895683, 319889.9000000060186721 192590.5999999940104317, 319889.5999999939813279 192631.7000000030093361, 319892.5000000000000000 192696.7000000030093361, 319893.7999999970197678 192735.5000000000000000, 319895.5999999939813279 192757.4000000059895683, 319895.2999999970197678 192774.5000000000000000, 319892.0999999939813279 192782.2999999969906639, 319889.5000000000000000 192819.4000000059895683, 319894.5000000000000000 192881.5999999940104317, 319894.7000000029802322 192939.0000000000000000, 319893.2999999970197678 193003.7999999969906639, 319892.0000000000000000 193070.0000000000000000, 319903.2000000029802322 193084.0000000000000000, 319922.5000000000000000 193096.2000000030093361, 319931.2999999970197678 193115.2000000030093361, 319927.2000000029802322 193125.2999999969906639, 319913.2000000029802322 193139.7999999969906639, 319914.9000000060186721 193153.7000000030093361, 319888.7999999970197678 193172.7999999969906639, 319889.4000000060186721 193193.2000000030093361, 319900.0999999939813279 193208.7999999969906639, 319913.7000000029802322 193226.2999999969906639, 319913.4000000060186721 193244.5000000000000000, 319902.2000000029802322 193280.5999999940104317, 319901.9000000060186721 193307.7999999969906639, 319917.4000000060186721 193351.7000000030093361, 319931.2999999970197678 193374.7000000030093361, 319943.5000000000000000 193381.5000000000000000, 319980.4000000060186721 193390.4000000059895683, 320002.2000000029802322 193401.5999999940104317, 320026.0000000000000000 193394.4000000059895683, 320038.0999999939813279 193393.7000000030093361, 320075.2999999970197678 193419.9000000059895683, 320092.0999999939813279 193436.0000000000000000, 320088.7999999970197678 193466.7000000030093361, 320107.0000000000000000 193486.7000000030093361, 320128.4000000060186721 193504.7999999969906639, 320146.5000000000000000 193530.2999999969906639, 320146.5999999939813279 193550.5999999940104317, 320156.2000000029802322 193565.5000000000000000, 320188.7999999970197678 193587.7000000030093361, 320206.9000000060186721 193612.9000000059895683, 320218.4000000060186721 193647.0999999940104317, 320233.2999999970197678 193687.7999999969906639, 320237.0999999939813279 193698.9000000059895683, 320243.5999999939813279 193709.5000000000000000, 320242.9000000060186721 193737.2999999969906639, 320260.0999999939813279 193767.4000000059895683, 320281.9000000060186721 193792.0999999940104317, 320291.0000000000000000 193791.4000000059895683, 320302.9000000060186721 193805.2000000030093361, 320306.7000000029802322 193823.2999999969906639, 320355.0999999939813279 193942.5999999940104317, 320382.5999999939813279 194024.7000000030093361, 320389.5000000000000000 194040.5000000000000000, 320392.7000000029802322 194066.7999999969906639, 320406.5000000000000000 194102.7000000030093361, 320419.9000000060186721 194160.5999999940104317, 320421.0000000000000000 194173.7999999969906639, 320432.2000000029802322 194205.0000000000000000, 320438.0000000000000000 194236.0999999940104317, 320453.7000000029802322 194272.2000000030093361, 320506.0000000000000000 194383.2000000030093361, 320528.5000000000000000 194416.2999999969906639, 320556.2999999970197678 194461.0000000000000000, 320569.5000000000000000 194486.7000000030093361, 320625.2999999970197678 194552.2999999969906639, 320662.5000000000000000 194590.0999999940104317, 320682.2000000029802322 194624.2000000030093361, 320686.0999999939813279 194640.0000000000000000, 320694.2999999970197678 194655.0000000000000000, 320701.0999999939813279 194691.5000000000000000, 320706.5000000000000000 194705.7000000030093361, 320717.9000000060186721 194754.0999999940104317, 320723.7999999970197678 194780.9000000059895683, 320741.5000000000000000 194927.5999999940104317, 320757.2999999970197678 194984.5000000000000000, 320766.4000000060186721 195032.7000000030093361, 320770.4000000060186721 195060.7999999969906639, 320785.5999999939813279 195110.2999999969906639, 320798.7999999970197678 195186.7000000030093361, 320806.7999999970197678 195217.2000000030093361, 320802.7000000029802322 195240.4000000059895683, 320809.5000000000000000 195271.5000000000000000, 320813.2000000029802322 195307.9000000059895683, 320824.2000000029802322 195368.0000000000000000, 320830.9000000060186721 195401.5000000000000000, 320841.7000000029802322 195427.2000000030093361, 320867.4000000060186721 195442.2999999969906639, 320895.2000000029802322 195444.2999999969906639, 320937.9000000060186721 195442.7000000030093361, 320962.5000000000000000 195457.0000000000000000, 320981.7999999970197678 195481.5999999940104317, 320995.9000000060186721 195488.9000000059895683, 321024.5000000000000000 195484.2000000030093361, 321061.4000000060186721 195464.4000000059895683, 321080.9000000060186721 195462.7999999969906639, 321097.5000000000000000 195468.5000000000000000, 321106.7000000029802322 195476.7000000030093361, 321138.9000000060186721 195495.2000000030093361, 321161.2999999970197678 195504.2999999969906639, 321179.0999999939813279 195510.9000000059895683, 321193.4000000060186721 195514.7999999969906639, 321206.0999999939813279 195522.7999999969906639, 321231.4000000060186721 195533.7999999969906639, 321265.9000000060186721 195556.7000000030093361, 321273.9000000060186721 195565.7000000030093361, 321281.9000000060186721 195561.2999999969906639, 321293.0999999939813279 195566.5999999940104317, 321306.4000000060186721 195581.0999999940104317, 321322.0000000000000000 195588.2999999969906639, 321363.5999999939813279 195617.0999999940104317, 321376.7000000029802322 195632.0999999940104317, 321393.2999999970197678 195637.5999999940104317, 321428.2999999970197678 195659.7999999969906639, 321444.2000000029802322 195667.2000000030093361, 321471.7000000029802322 195684.7999999969906639, 321485.9000000060186721 195689.7999999969906639, 321500.4000000060186721 195700.5000000000000000, 321548.4000000060186721 195725.7999999969906639, 321583.9000000060186721 195761.0999999940104317, 321622.7000000029802322 195795.9000000059895683, 321652.5999999939813279 195814.0999999940104317, 321698.5999999939813279 195832.4000000059895683, 321718.2000000029802322 195849.0000000000000000, 321747.0000000000000000 195879.5999999940104317, 321762.7000000029802322 195901.2999999969906639, 321816.7999999970197678 196000.5999999940104317, 321832.5000000000000000 196027.2999999969906639, 321842.7000000029802322 196052.5999999940104317, 321896.7000000029802322 196145.5999999940104317, 321947.4000000060186721 196223.4000000059895683, 321956.0999999939813279 196244.7000000030093361, 322010.9000000060186721 196333.4000000059895683, 322035.9000000060186721 196374.2999999969906639, 322045.5999999939813279 196384.5000000000000000, 322105.7000000029802322 196477.0000000000000000, 322127.7000000029802322 196518.7000000030093361, 322170.4000000060186721 196577.0999999940104317, 322196.5000000000000000 196613.9000000059895683, 322229.2999999970197678 196671.7999999969906639, 322259.9000000060186721 196719.7999999969906639, 322351.0999999939813279 196877.2999999969906639, 322365.0999999939813279 196908.5999999940104317, 322404.4000000060186721 196969.5000000000000000, 322422.5999999939813279 197016.9000000059895683, 322509.5000000000000000 197143.7999999969906639, 322586.4000000060186721 197262.9000000059895683, 322602.0000000000000000 197300.0000000000000000, 322627.5000000000000000 197344.2000000030093361, 322640.7999999970197678 197359.2999999969906639, 322664.7999999970197678 197396.2999999969906639, 322706.7999999970197678 197472.4000000059895683, 322726.4000000060186721 197504.7999999969906639, 322745.5000000000000000 197531.7000000030093361, 322771.5000000000000000 197580.9000000059895683, 322789.2000000029802322 197609.5999999940104317, 322807.5000000000000000 197633.5000000000000000, 322866.0000000000000000 197728.9000000059895683, 322892.9000000060186721 197783.4000000059895683, 322909.5999999939813279 197806.7999999969906639, 322970.7999999970197678 197909.9000000059895683, 323046.4000000060186721 198039.4000000059895683, 323070.7000000029802322 198083.5999999940104317, 323137.2000000029802322 198190.5999999940104317, 323148.2000000029802322 198213.4000000059895683, 323155.2000000029802322 198229.4000000059895683, 323160.2999999970197678 198261.0999999940104317, 323185.5000000000000000 198290.4000000059895683, 323204.7999999970197678 198336.5000000000000000, 323208.2999999970197678 198366.2000000030093361, 323203.4000000060186721 198380.4000000059895683, 323176.0999999939813279 198408.5999999940104317, 323165.4000000060186721 198440.7000000030093361, 323136.2999999970197678 198482.4000000059895683, 323128.7999999970197678 198502.0999999940104317, 323131.0000000000000000 198520.2000000030093361, 323144.7999999970197678 198531.7999999969906639, 323160.4000000060186721 198544.4000000059895683, 323189.7000000029802322 198588.0000000000000000, 323201.0999999939813279 198614.4000000059895683, 323200.9000000060186721 198625.0999999940104317, 323206.7000000029802322 198635.7999999969906639, 323209.0999999939813279 198656.4000000059895683, 323223.2999999970197678 198687.5999999940104317, 323243.5999999939813279 198750.9000000059895683, 323260.7999999970197678 198796.9000000059895683, 323265.7000000029802322 198808.5000000000000000, 323289.5000000000000000 198850.0000000000000000, 323299.4000000060186721 198895.5000000000000000, 323308.5999999939813279 198929.7000000030093361, 323318.0999999939813279 198971.2999999969906639, 323341.0999999939813279 199038.5000000000000000, 323350.9000000060186721 199070.7999999969906639, 323389.9000000060186721 199137.0000000000000000, 323407.9000000060186721 199164.5000000000000000, 323425.5000000000000000 199187.0999999940104317, 323436.2000000029802322 199203.9000000059895683, 323448.7000000029802322 199241.0999999940104317, 323455.5000000000000000 199272.2000000030093361, 323477.0999999939813279 199288.2999999969906639, 323532.9000000060186721 199315.5999999940104317, 323578.7999999970197678 199374.5000000000000000, 323607.2000000029802322 199425.7000000030093361, 323625.9000000060186721 199483.5999999940104317, 323660.4000000060186721 199516.2000000030093361, 323680.7999999970197678 199568.5000000000000000, 323712.2999999970197678 199611.4000000059895683, 323757.5000000000000000 199662.5999999940104317, 323802.2000000029802322 199706.2999999969906639, 323868.9000000060186721 199758.5999999940104317, 323903.2999999970197678 199793.5000000000000000, 323912.9000000060186721 199799.7000000030093361, 323896.7999999970197678 199808.2999999969906639, 323911.2000000029802322 199818.5000000000000000, 323952.5999999939813279 199858.5999999940104317, 323979.0000000000000000 199874.2999999969906639, 324057.5999999939813279 199944.2999999969906639, 324108.5999999939813279 199981.7999999969906639, 324141.0000000000000000 200034.5000000000000000, 324157.0999999939813279 200064.2000000030093361, 324177.0999999939813279 200084.5000000000000000, 324199.5000000000000000 200092.2999999969906639, 324265.5000000000000000 200100.0999999940104317, 324302.0999999939813279 200115.7999999969906639, 324361.2000000029802322 200151.2999999969906639, 324378.7999999970197678 200166.9000000059895683, 324413.2999999970197678 200191.0999999940104317, 324462.7999999970197678 200228.5000000000000000, 324483.7999999970197678 200242.7000000030093361, 324527.0000000000000000 200282.2000000030093361, 324548.5999999939813279 200295.7000000030093361, 324580.5999999939813279 200327.4000000059895683, 324608.5000000000000000 200348.7000000030093361, 324644.2000000029802322 200382.2999999969906639, 324700.2000000029802322 200421.5999999940104317, 324724.0999999939813279 200435.0000000000000000, 324764.5999999939813279 200469.5000000000000000, 324803.0000000000000000 200498.2999999969906639, 324844.0999999939813279 200543.2999999969906639, 324863.5000000000000000 200566.2000000030093361, 324914.2000000029802322 200614.5999999940104317, 324927.0000000000000000 200632.0999999940104317, 324963.5000000000000000 200665.5999999940104317, 324992.4000000060186721 200699.7000000030093361, 325014.2000000029802322 200719.9000000059895683, 325016.5000000000000000 200732.9000000059895683, 325017.5000000000000000 200761.5999999940104317, 325007.7000000029802322 200900.5000000000000000, 324997.5000000000000000 200953.5000000000000000, 324984.7000000029802322 200978.0999999940104317, 324975.7999999970197678 201014.5000000000000000, 324944.9000000060186721 201092.2000000030093361, 324937.4000000060186721 201132.2000000030093361, 324922.2999999970197678 201161.2000000030093361, 324891.7000000029802322 201184.7999999969906639, 324866.9000000060186721 201223.9000000059895683, 324846.0999999939813279 201252.4000000059895683, 324826.7999999970197678 201266.0000000000000000, 324796.4000000060186721 201287.9000000059895683, 324782.7999999970197678 201292.2999999969906639, 322222.0999999939813279 202654.7999999969906639, 322209.7000000029802322 202660.2999999969906639, 319207.0000000000000000 204261.7000000030093361, 309929.2999999970197678 206015.7000000030093361, 309878.5999999939813279 206031.9000000059895683, 309837.2999999970197678 206038.0000000000000000, 309786.7000000029802322 206036.2999999969906639, 309767.7999999970197678 206032.7000000030093361, 309746.4000000060186721 206036.0000000000000000, 309732.2000000029802322 206031.2999999969906639, 309719.7000000029802322 206031.4000000059895683, 309692.0999999939813279 206030.7999999969906639, 309663.9000000060186721 206036.2999999969906639, 309619.2999999970197678 206037.0999999940104317, 309561.7999999970197678 206045.4000000059895683, 309519.5000000000000000 206046.5000000000000000, 309491.9000000060186721 206047.0000000000000000, 309468.9000000060186721 206048.9000000059895683, 309445.2999999970197678 206060.2000000030093361, 309422.5000000000000000 206062.5999999940104317, 309374.4000000060186721 206071.9000000059895683, 309321.9000000060186721 206089.0999999940104317, 309234.4000000060186721 206131.4000000059895683, 309134.0000000000000000 206203.7999999969906639, 309086.5999999939813279 206236.0000000000000000, 309058.0999999939813279 206251.4000000059895683, 309026.2000000029802322 206254.9000000059895683, 308998.2999999970197678 206278.2999999969906639, 308979.0000000000000000 206367.9000000059895683, 308959.7000000029802322 206406.0999999940104317, 308926.5999999939813279 206443.2000000030093361, 308875.7000000029802322 206485.4000000059895683, 308779.7999999970197678 206569.2000000030093361, 308668.5999999939813279 206648.2999999969906639, 308625.2999999970197678 206686.7999999969906639, 308559.2999999970197678 206757.7999999969906639, 308514.0000000000000000 206809.2999999969906639, 308476.9000000060186721 206842.9000000059895683, 308406.5000000000000000 206901.9000000059895683, 308349.5000000000000000 206937.2000000030093361, 308324.4000000060186721 206942.5000000000000000, 308312.0999999939813279 206934.2999999969906639, 308290.5999999939813279 206898.0999999940104317, 308276.2999999970197678 206891.4000000059895683, 308259.0000000000000000 206901.5999999940104317, 308246.5000000000000000 206889.4000000059895683, 308235.9000000060186721 206890.5999999940104317, 308208.5999999939813279 206912.5000000000000000, 308166.5000000000000000 206981.0000000000000000, 308152.2000000029802322 207034.2000000030093361, 308149.9000000060186721 207064.5999999940104317, 308149.2000000029802322 207093.5000000000000000, 308154.5000000000000000 207134.4000000059895683, 308157.4000000060186721 207149.2999999969906639, 308170.0999999939813279 207218.0000000000000000, 308177.7999999970197678 207233.7000000030093361, 308175.4000000060186721 207260.2999999969906639, 308155.9000000060186721 207287.5000000000000000, 308148.4000000060186721 207304.5999999940104317, 308154.2000000029802322 207325.5000000000000000, 308151.7000000029802322 207350.0000000000000000, 308156.5000000000000000 207389.7999999969906639, 308161.0999999939813279 207404.2000000030093361, 308152.0000000000000000 207419.2999999969906639, 308141.9000000060186721 207453.0000000000000000, 308141.9000000060186721 207480.2999999969906639, 308128.9000000060186721 207523.5000000000000000, 308108.7999999970197678 207574.7000000030093361, 308100.2999999970197678 207603.2999999969906639, 308101.5000000000000000 207631.2000000030093361, 308099.0999999939813279 207652.0999999940104317, 308101.2999999970197678 207681.5000000000000000, 308110.5000000000000000 207716.9000000059895683, 308084.5999999939813279 207728.7000000030093361, 308090.5999999939813279 207741.0999999940104317, 308093.4000000060186721 207759.5000000000000000, 308085.0000000000000000 207784.0999999940104317, 308076.0999999939813279 207818.5999999940104317, 308074.7999999970197678 207833.2000000030093361, 308082.7999999970197678 207876.4000000059895683, 308087.7999999970197678 207899.2999999969906639, 308071.2000000029802322 207905.0000000000000000, 308073.0999999939813279 207915.5000000000000000, 308063.2999999970197678 207919.2000000030093361, 308052.0000000000000000 207920.9000000059895683, 308053.2000000029802322 207930.2999999969906639, 308050.2000000029802322 207943.2999999969906639, 308038.4000000060186721 207972.4000000059895683, 308050.2000000029802322 208005.2000000030093361, 308048.0000000000000000 208023.2000000030093361, 308059.7000000029802322 208032.5000000000000000, 308069.5000000000000000 208055.9000000059895683, 308068.9000000060186721 208102.7000000030093361, 308054.9000000060186721 208153.7999999969906639, 308042.2999999970197678 208168.0000000000000000, 308044.5999999939813279 208178.0000000000000000, 308028.7000000029802322 208200.5999999940104317, 308024.7000000029802322 208255.5999999940104317, 308018.5999999939813279 208283.7000000030093361, 308004.7000000029802322 208305.9000000059895683, 307981.2000000029802322 208323.2000000030093361, 307984.5000000000000000 208337.5999999940104317, 307978.2000000029802322 208358.0999999940104317, 307974.0000000000000000 208372.2000000030093361, 307963.7999999970197678 208420.7999999969906639, 307965.9000000060186721 208464.5999999940104317, 307965.2999999970197678 208472.5000000000000000, 307954.9000000060186721 208493.2999999969906639, 307948.0999999939813279 208521.2999999969906639, 307944.5999999939813279 208558.7999999969906639, 307940.4000000060186721 208578.2999999969906639, 307955.5999999939813279 208664.7999999969906639, 307950.2000000029802322 208736.2999999969906639, 307948.2000000029802322 208765.7000000030093361, 307959.2999999970197678 208821.0000000000000000, 307968.7999999970197678 208862.2000000030093361, 307963.0000000000000000 208894.2000000030093361, 307961.4000000060186721 208904.2999999969906639, 307969.2999999970197678 208938.5000000000000000, 307969.0000000000000000 208983.9000000059895683, 307981.0000000000000000 209034.2000000030093361, 307976.5999999939813279 209085.7000000030093361, 307971.5000000000000000 209104.0999999940104317, 307960.2999999970197678 209137.7999999969906639, 307945.5999999939813279 209178.9000000059895683, 307943.0999999939813279 209227.7999999969906639, 307923.5999999939813279 209246.0999999940104317, 307922.4000000060186721 209272.5999999940104317, 307929.4000000060186721 209300.9000000059895683, 307925.7000000029802322 209330.9000000059895683, 307916.2000000029802322 209341.0999999940104317, 307906.5999999939813279 209363.2000000030093361, 307909.5999999939813279 209388.5999999940104317, 307882.4000000060186721 209437.4000000059895683, 307870.0999999939813279 209482.0000000000000000, 307876.5000000000000000 209511.7999999969906639, 307896.7999999970197678 209538.0000000000000000, 307909.5999999939813279 209546.7999999969906639, 307912.7000000029802322 209555.7000000030093361, 307904.0000000000000000 209564.2999999969906639, 307883.4000000060186721 209604.5000000000000000, 307880.7999999970197678 209646.0000000000000000, 307894.0000000000000000 209681.7999999969906639, 307889.7000000029802322 209696.2999999969906639, 307872.7000000029802322 209713.0000000000000000, 307862.7000000029802322 209731.5999999940104317, 307856.2999999970197678 209766.2000000030093361, 307844.2999999970197678 209789.2000000030093361, 307845.9000000060186721 209828.7000000030093361, 307842.7999999970197678 209846.7000000030093361, 307853.5000000000000000 209897.0000000000000000, 307887.7999999970197678 209958.2999999969906639, 307923.2000000029802322 210024.5999999940104317, 307926.7000000029802322 210050.0000000000000000, 307925.2000000029802322 210097.4000000059895683, 307927.0000000000000000 210155.2000000030093361, 307928.2000000029802322 210170.2999999969906639, 307920.0000000000000000 210276.5999999940104317, 307913.9000000060186721 210324.0999999940104317, 307908.7000000029802322 210337.2000000030093361, 307887.7000000029802322 210355.4000000059895683, 307868.7999999970197678 210363.2000000030093361, 307853.7999999970197678 210373.4000000059895683, 307836.5999999939813279 210380.7000000030093361, 307823.4000000060186721 210395.4000000059895683, 307836.5000000000000000 210423.0999999940104317, 307864.5000000000000000 210463.5000000000000000, 307875.5999999939813279 210482.9000000059895683, 307880.5999999939813279 210504.7999999969906639, 307888.4000000060186721 210530.0999999940104317, 307886.5000000000000000 210571.0000000000000000, 307883.0999999939813279 210589.5000000000000000, 307878.2999999970197678 210627.0999999940104317, 307861.4000000060186721 210676.2000000030093361, 307858.0999999939813279 210693.2000000030093361, 307879.2000000029802322 210733.7999999969906639, 307893.0000000000000000 210780.0000000000000000, 307893.5999999939813279 210796.0000000000000000, 307886.7000000029802322 210827.4000000059895683, 307899.5000000000000000 210857.7000000030093361, 307930.0000000000000000 210886.5999999940104317, 307939.0999999939813279 210897.5000000000000000, 307951.2000000029802322 210897.7999999969906639, 307962.7999999970197678 210919.5999999940104317, 307975.0999999939813279 210961.2999999969906639, 307983.9000000060186721 210977.5999999940104317, 307998.4000000060186721 211017.2999999969906639, 308001.7000000029802322 211048.7000000030093361, 308006.9000000060186721 211062.0999999940104317, 308018.4000000060186721 211098.9000000059895683, 308038.7999999970197678 211138.4000000059895683, 308064.9000000060186721 211169.0000000000000000, 308079.5000000000000000 211183.2000000030093361, 308101.7000000029802322 211219.7999999969906639, 308119.2999999970197678 211242.4000000059895683, 308132.0999999939813279 211274.0999999940104317, 308143.2999999970197678 211293.5000000000000000, 308140.2000000029802322 211321.9000000059895683, 308127.0000000000000000 211344.0999999940104317, 308114.7999999970197678 211385.2000000030093361, 308101.7000000029802322 211417.7999999969906639, 308085.0999999939813279 211448.0000000000000000, 308081.5999999939813279 211461.5000000000000000, 308066.7999999970197678 211479.2999999969906639, 308060.7999999970197678 211506.7999999969906639, 308054.5000000000000000 211522.2999999969906639, 308040.5999999939813279 211559.0000000000000000, 308037.2999999970197678 211567.5000000000000000, 308028.5000000000000000 211587.2000000030093361, 308021.0999999939813279 211597.7999999969906639, 308018.2999999970197678 211610.7999999969906639, 308010.7999999970197678 211628.7999999969906639, 308005.0999999939813279 211647.2999999969906639, 307992.9000000060186721 211676.5999999940104317, 307981.7999999970197678 211700.2000000030093361, 307957.9000000060186721 211763.0000000000000000, 307936.2000000029802322 211813.5999999940104317, 307926.7999999970197678 211834.2000000030093361, 307918.2999999970197678 211858.4000000059895683, 307902.0999999939813279 211872.0999999940104317, 307901.5999999939813279 211882.5999999940104317, 307895.9000000060186721 211898.0999999940104317, 307852.4000000060186721 211942.7999999969906639, 307829.2000000029802322 211987.4000000059895683, 307827.5000000000000000 212029.9000000059895683, 307806.9000000060186721 212072.0999999940104317, 307799.9000000060186721 212093.7000000030093361, 307790.5999999939813279 212111.4000000059895683, 307775.0999999939813279 212145.5000000000000000, 307763.2999999970197678 212164.0999999940104317, 307751.5999999939813279 212190.4000000059895683, 307726.7999999970197678 212237.5999999940104317, 307703.0999999939813279 212288.7999999969906639, 307707.9000000060186721 212312.7999999969906639, 307702.0000000000000000 212325.4000000059895683, 307658.2999999970197678 212380.9000000059895683, 307644.5999999939813279 212400.0999999940104317, 307620.4000000060186721 212413.9000000059895683, 307584.2999999970197678 212426.9000000059895683, 307574.7999999970197678 212442.0999999940104317, 307569.7999999970197678 212451.7000000030093361, 307564.5000000000000000 212463.7000000030093361, 307563.4000000060186721 212473.2000000030093361, 307549.2000000029802322 212485.4000000059895683, 307498.5000000000000000 212569.0999999940104317, 307486.9000000060186721 212585.5999999940104317, 307481.0999999939813279 212620.7000000030093361, 307471.0999999939813279 212653.7999999969906639, 307445.5000000000000000 212694.0999999940104317, 307429.7999999970197678 212749.2999999969906639, 307421.0999999939813279 212814.2000000030093361, 307409.5999999939813279 212842.9000000059895683, 307406.5000000000000000 212869.9000000059895683, 307398.0000000000000000 212906.0000000000000000, 307390.0000000000000000 212918.5000000000000000, 307391.2999999970197678 212956.9000000059895683, 307391.9000000060186721 212994.7999999969906639, 307376.4000000060186721 213015.5999999940104317, 307366.0999999939813279 213044.0999999940104317, 307343.4000000060186721 213084.9000000059895683, 307302.5999999939813279 213137.5000000000000000, 307280.5000000000000000 213158.7999999969906639, 307244.7000000029802322 213212.2999999969906639, 307228.7000000029802322 213238.9000000059895683, 307182.5000000000000000 213304.0000000000000000, 307161.9000000060186721 213326.7999999969906639, 307154.5999999939813279 213364.7999999969906639, 307146.0999999939813279 213381.5000000000000000, 307130.7999999970197678 213396.7000000030093361, 307118.5999999939813279 213416.7999999969906639, 307096.2000000029802322 213430.7000000030093361, 307076.2000000029802322 213432.0000000000000000, 307068.5999999939813279 213439.5999999940104317, 307049.4000000060186721 213477.2999999969906639, 307031.5000000000000000 213507.5999999940104317, 307019.7999999970197678 213529.7000000030093361, 307002.5000000000000000 213547.4000000059895683, 306939.2999999970197678 213650.7000000030093361, 306895.9000000060186721 213709.2000000030093361, 306879.0000000000000000 213749.9000000059895683, 306860.7999999970197678 213813.5999999940104317, 306844.2000000029802322 213874.2000000030093361, 306833.7999999970197678 213897.7999999969906639, 306777.9000000060186721 213903.2000000030093361, 306750.7999999970197678 214018.4000000059895683, 306747.4000000060186721 214036.9000000059895683, 306715.7000000029802322 214108.7999999969906639, 306705.0999999939813279 214125.4000000059895683, 306685.7999999970197678 214166.7000000030093361, 306628.5999999939813279 214263.9000000059895683, 306604.5999999939813279 214313.2000000030093361, 306585.4000000060186721 214347.9000000059895683, 306553.9000000060186721 214393.2999999969906639, 306501.9000000060186721 214469.4000000059895683, 306470.2999999970197678 214512.2999999969906639, 306444.5000000000000000 214548.7000000030093361, 306393.0999999939813279 214614.7999999969906639, 306306.5999999939813279 214750.5000000000000000, 306228.5999999939813279 214864.5000000000000000, 306122.0000000000000000 215018.9000000059895683, 306068.2000000029802322 215095.0999999940104317, 306000.9000000060186721 215204.2999999969906639, 305992.7000000029802322 215223.0000000000000000, 305969.7999999970197678 215274.2000000030093361, 305936.2999999970197678 215330.7000000030093361, 305919.9000000060186721 215359.4000000059895683, 305881.9000000060186721 215424.4000000059895683, 305849.2000000029802322 215493.7000000030093361, 305808.5999999939813279 215566.7000000030093361, 305796.5999999939813279 215592.2999999969906639, 305775.7999999970197678 215628.2000000030093361, 305738.7000000029802322 215697.0999999940104317, 305627.2999999970197678 215880.9000000059895683, 305598.7999999970197678 215935.2999999969906639, 305571.7000000029802322 215987.0999999940104317, 305534.5999999939813279 216040.7000000030093361, 305522.5000000000000000 216057.2999999969906639, 305463.5999999939813279 216155.0999999940104317, 305429.7000000029802322 216209.0000000000000000, 305358.0999999939813279 216318.9000000059895683, 305314.9000000060186721 216390.0000000000000000, 305218.0999999939813279 216534.5999999940104317, 305191.0000000000000000 216584.0000000000000000, 305146.5000000000000000 216663.0000000000000000, 305100.5000000000000000 216727.2000000030093361, 305068.4000000060186721 216793.9000000059895683, 305030.0000000000000000 216862.9000000059895683, 304980.4000000060186721 216942.5999999940104317, 304943.2999999970197678 216992.5000000000000000, 304866.2999999970197678 217124.0000000000000000, 304846.0000000000000000 217160.7999999969906639, 304817.2000000029802322 217203.5999999940104317, 304769.5000000000000000 217297.7000000030093361, 304749.2999999970197678 217338.5000000000000000, 304723.2999999970197678 217393.2999999969906639, 304681.0999999939813279 217467.2999999969906639, 304649.7999999970197678 217538.5999999940104317, 304590.2999999970197678 217662.7999999969906639, 304555.0000000000000000 217746.7000000030093361, 304495.2000000029802322 217838.5000000000000000, 304409.5000000000000000 217989.0000000000000000, 304368.2999999970197678 218042.5999999940104317, 304280.7999999970197678 218211.0999999940104317, 304251.0000000000000000 218276.5000000000000000, 304207.0000000000000000 218355.5000000000000000, 304182.4000000060186721 218412.7999999969906639, 304162.0000000000000000 218462.5000000000000000, 304132.0999999939813279 218530.2999999969906639, 304103.5999999939813279 218614.2000000030093361, 304054.4000000060186721 218721.7999999969906639, 304030.7999999970197678 218797.5000000000000000, 304017.7000000029802322 218842.0999999940104317, 303987.2000000029802322 218927.7999999969906639, 303956.7999999970197678 219045.0999999940104317, 303947.2000000029802322 219105.5999999940104317, 303931.0000000000000000 219169.2999999969906639, 303924.5000000000000000 219261.2000000030093361, 303881.4000000060186721 219431.5999999940104317, 303864.0999999939813279 219476.7999999969906639, 303856.0000000000000000 219533.2000000030093361, 303839.2999999970197678 219688.2000000030093361, 303824.2999999970197678 219766.2000000030093361, 303819.2000000029802322 219807.7999999969906639, 303803.2000000029802322 219863.4000000059895683, 303782.7999999970197678 220000.5000000000000000, 303757.0999999939813279 220131.5999999940104317, 303739.9000000060186721 220203.7000000030093361, 303692.0000000000000000 220368.0999999940104317, 303678.2000000029802322 220431.2999999969906639, 303636.4000000060186721 220547.5999999940104317, 303617.0999999939813279 220621.2999999969906639, 303599.4000000060186721 220689.0000000000000000, 303574.5000000000000000 220780.2000000030093361, 303555.2000000029802322 220857.4000000059895683, 303543.5999999939813279 220910.0000000000000000, 303497.7999999970197678 221055.4000000059895683, 303466.0999999939813279 221140.2000000030093361, 303432.2000000029802322 221243.0999999940104317, 303407.7999999970197678 221300.4000000059895683, 303377.5999999939813279 221436.5999999940104317, 303362.7999999970197678 221508.5999999940104317, 303342.2000000029802322 221596.7999999969906639, 303330.5000000000000000 221664.9000000059895683, 303305.9000000060186721 221775.5000000000000000, 303295.5000000000000000 221890.9000000059895683, 303273.7999999970197678 222024.9000000059895683, 303264.0000000000000000 222176.4000000059895683, 303260.4000000060186721 222250.7999999969906639, 303247.5000000000000000 222320.7999999969906639, 303245.7999999970197678 222443.0999999940104317, 303247.4000000060186721 222456.5000000000000000, 303248.2999999970197678 222483.0000000000000000, 307493.0999999939813279 222616.4000000059895683, 307496.0000000000000000 222606.9000000059895683, 308026.2000000029802322 222622.4000000059895683, 308050.7000000029802322 222623.5000000000000000, 312441.7999999970197678 221993.7000000030093361, 311818.2000000029802322 217599.4000000059895683, 317924.5999999939813279 218352.2999999969906639, 318638.9000000060186721 218380.2999999969906639, 318654.0000000000000000 218373.0999999940104317, 325105.7999999970197678 218717.7000000030093361, 328449.5999999939813279 222082.2999999969906639, 329488.7999999970197678 222431.9000000059895683, 333400.7000000029802322 223759.7999999969906639, 334532.5000000000000000 223883.7999999969906639, 336703.7000000029802322 223376.4000000059895683, 337699.0000000000000000 222898.2000000030093361, 338396.0999999939813279 223092.5999999940104317, 338259.9000000060186721 225268.5000000000000000, 338267.7000000029802322 225279.4000000059895683, 338279.5000000000000000 225283.5999999940104317, 338295.7000000029802322 225313.2999999969906639, 338327.5000000000000000 225357.5999999940104317, 338350.0999999939813279 225389.2000000030093361, 338365.5999999939813279 225402.9000000059895683, 338375.9000000060186721 225414.7000000030093361, 338410.0000000000000000 225468.0999999940104317, 338458.7999999970197678 225516.2000000030093361, 338491.9000000060186721 225553.5999999940104317, 338501.9000000060186721 225572.4000000059895683, 338520.5999999939813279 225595.5000000000000000, 338541.2999999970197678 225624.0999999940104317, 338561.0999999939813279 225663.2000000030093361, 338587.0000000000000000 225723.5999999940104317, 338605.7999999970197678 225770.2000000030093361, 338613.7000000029802322 225810.5000000000000000, 338620.0000000000000000 225825.4000000059895683, 338632.9000000060186721 225931.9000000059895683, 338637.9000000060186721 226013.0999999940104317, 338643.5000000000000000 226035.9000000059895683, 338652.2000000029802322 226101.5999999940104317, 338660.2999999970197678 226133.9000000059895683, 338667.5000000000000000 226148.7999999969906639, 338676.4000000060186721 226187.0999999940104317, 338683.4000000060186721 226216.2999999969906639, 338701.9000000060186721 226259.5000000000000000, 338733.7999999970197678 226316.2999999969906639, 338757.7999999970197678 226356.2999999969906639, 338796.7000000029802322 226397.5999999940104317, 338821.5000000000000000 226421.5999999940104317, 338833.9000000060186721 226438.9000000059895683, 338924.2000000029802322 226569.5999999940104317, 338939.2000000029802322 226585.4000000059895683, 339013.7000000029802322 226672.5000000000000000, 339080.2999999970197678 226723.7999999969906639, 339117.9000000060186721 226742.0999999940104317, 339142.9000000060186721 226748.7999999969906639, 339162.0000000000000000 226752.4000000059895683, 339186.7999999970197678 226762.0000000000000000, 339227.0000000000000000 226762.9000000059895683, 339270.2000000029802322 226751.0999999940104317, 339310.9000000060186721 226731.0999999940104317, 339358.2999999970197678 226684.0000000000000000, 339383.0000000000000000 226644.5999999940104317, 339411.7999999970197678 226599.2000000030093361, 339453.2000000029802322 226553.2999999969906639, 339504.4000000060186721 226488.0999999940104317, 339556.7000000029802322 226440.4000000059895683, 339630.7999999970197678 226385.2999999969906639, 339674.7999999970197678 226360.5999999940104317, 339688.7000000029802322 226357.9000000059895683, 339717.4000000060186721 226351.0000000000000000, 339730.2000000029802322 226344.7999999969906639, 339755.5000000000000000 226347.4000000059895683, 339782.0999999939813279 226341.5000000000000000, 339810.7000000029802322 226349.5000000000000000, 339824.5999999939813279 226348.7999999969906639, 339865.5000000000000000 226372.5000000000000000, 339877.5999999939813279 226382.7999999969906639, 339894.2999999970197678 226395.0000000000000000, 339911.5000000000000000 226415.2000000030093361, 339926.2000000029802322 226446.9000000059895683, 339935.0999999939813279 226499.7000000030093361, 339932.0999999939813279 226535.5999999940104317, 339915.7999999970197678 226573.7999999969906639, 339874.0000000000000000 226631.2999999969906639, 339829.2999999970197678 226673.5000000000000000, 339802.2999999970197678 226708.7000000030093361, 339738.4000000060186721 226774.0999999940104317, 339695.4000000060186721 226836.2000000030093361, 339612.7999999970197678 226943.2999999969906639, 339587.0000000000000000 226980.0999999940104317, 339535.9000000060186721 227041.7999999969906639, 339499.2999999970197678 227077.7000000030093361, 339456.7000000029802322 227151.2999999969906639, 339447.2000000029802322 227171.7999999969906639, 339438.7000000029802322 227195.9000000059895683, 339429.5000000000000000 227236.4000000059895683, 339438.5000000000000000 227325.5999999940104317, 339456.0999999939813279 227395.5999999940104317, 339475.0999999939813279 227451.2000000030093361, 339496.0999999939813279 227487.7999999969906639, 339505.7999999970197678 227513.0000000000000000, 339559.4000000060186721 227573.0000000000000000, 339595.0999999939813279 227605.4000000059895683, 339663.0999999939813279 227664.2000000030093361, 339720.2999999970197678 227700.7000000030093361, 339756.7999999970197678 227717.0000000000000000, 339772.7999999970197678 227721.7999999969906639, 339793.0999999939813279 227738.0000000000000000, 339866.5999999939813279 227760.5999999940104317, 339893.0999999939813279 227762.7999999969906639, 339932.4000000060186721 227768.2000000030093361, 339980.9000000060186721 227781.2999999969906639, 339999.7999999970197678 227794.0000000000000000, 340042.2000000029802322 227807.7999999969906639, 340082.4000000060186721 227833.5999999940104317, 340098.9000000060186721 227844.2000000030093361, 340117.9000000060186721 227872.9000000059895683, 340144.9000000060186721 227925.2999999969906639, 340170.2999999970197678 227994.7000000030093361, 340182.7999999970197678 228047.5000000000000000, 340195.5000000000000000 228118.5000000000000000, 340200.9000000060186721 228144.4000000059895683, 340200.2000000029802322 228156.2999999969906639, 340206.9000000060186721 228182.2000000030093361, 340209.2000000029802322 228222.5000000000000000, 340222.5000000000000000 228268.2999999969906639, 340236.2999999970197678 228320.7999999969906639, 340236.9000000060186721 228335.7999999969906639, 340235.5000000000000000 228359.7999999969906639, 340234.5000000000000000 228382.7999999969906639, 340256.9000000060186721 228463.7000000030093361, 346105.4000000060186721 229356.2000000030093361, 346132.5000000000000000 229361.2999999969906639, 346156.5000000000000000 229366.9000000059895683, 346255.2999999970197678 229377.7999999969906639, 346302.2999999970197678 229388.5000000000000000, 346347.2000000029802322 229389.2000000030093361, 346376.5999999939813279 229390.2999999969906639, 346482.5000000000000000 229402.0000000000000000, 346542.2999999970197678 229410.0999999940104317, 346737.5000000000000000 229441.7999999969906639, 346783.0000000000000000 229445.7000000030093361, 346822.2999999970197678 229453.4000000059895683, 346873.4000000060186721 229468.5999999940104317, 346965.2999999970197678 229481.0999999940104317, 347007.5999999939813279 229482.5000000000000000, 347127.5000000000000000 229501.4000000059895683, 347233.2000000029802322 229516.7000000030093361, 347282.7000000029802322 229526.9000000059895683, 347319.0999999939813279 229531.7999999969906639, 347381.5000000000000000 229548.2999999969906639, 347461.9000000060186721 229562.4000000059895683, 347551.0999999939813279 229573.0000000000000000, 347632.5999999939813279 229580.0999999940104317, 347725.7000000029802322 229593.7000000030093361, 347866.7999999970197678 229608.4000000059895683, 347889.5000000000000000 229613.9000000059895683, 347991.0000000000000000 229629.2999999969906639, 348037.0000000000000000 229636.0999999940104317, 348078.7999999970197678 229643.2999999969906639, 348129.2000000029802322 229647.5000000000000000, 348184.7999999970197678 229653.2000000030093361, 348258.5999999939813279 229659.0000000000000000, 348357.5000000000000000 229677.7999999969906639, 348429.0000000000000000 229689.5999999940104317, 348475.2000000029802322 229694.4000000059895683, 348493.2000000029802322 229693.5000000000000000, 348542.2000000029802322 229700.7999999969906639, 348615.9000000060186721 229705.0999999940104317, 348707.5000000000000000 229718.0000000000000000, 348757.0999999939813279 229722.7999999969906639, 348909.9000000060186721 229746.2000000030093361, 349000.5000000000000000 229753.2999999969906639, 349113.5000000000000000 229768.9000000059895683, 349212.5000000000000000 229784.2999999969906639, 349276.4000000060186721 229794.7000000030093361, 349386.2999999970197678 229819.5000000000000000, 349515.2999999970197678 229845.7999999969906639, 349610.5999999939813279 229860.7000000030093361, 349692.7999999970197678 229864.2999999969906639, 349756.7999999970197678 229870.4000000059895683, 349816.2999999970197678 229882.4000000059895683, 349865.0999999939813279 229894.5999999940104317, 349920.0999999939813279 229906.5999999940104317, 350055.5999999939813279 229936.7999999969906639, 350098.7999999970197678 229940.7000000030093361, 350203.9000000060186721 229959.5000000000000000, 350425.5999999939813279 229997.7999999969906639, 350458.5999999939813279 230001.2000000030093361, 350483.4000000060186721 230009.2999999969906639, 350550.2999999970197678 230016.7999999969906639, 350602.2999999970197678 230025.4000000059895683, 350649.0999999939813279 230030.0999999940104317, 350745.5999999939813279 230047.0000000000000000, 350769.5999999939813279 230049.5999999940104317, 350812.0000000000000000 230056.5000000000000000, 350850.0999999939813279 230061.7999999969906639, 350899.2000000029802322 230069.5000000000000000, 350935.2999999970197678 230067.9000000059895683, 351026.0999999939813279 230082.0000000000000000, 351084.2000000029802322 230088.9000000059895683, 351122.9000000060186721 230091.9000000059895683, 351147.9000000060186721 230097.0000000000000000, 351151.2000000029802322 230031.5000000000000000, 353161.4000000060186721 230412.2999999969906639, 353177.0000000000000000 230413.5999999940104317, 362053.7000000029802322 231736.7000000030093361, 362062.2000000029802322 231744.0000000000000000)))
-Input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
-Geometry coordinates: 3629x3
-isValid
-isSimple
-ConvexHull: POLYGON ((335197.0000000000000000 167635.9000000059895683, 329292.5000000000000000 168040.7000000030093361, 326778.0000000000000000 168869.2999999969906639, 326730.0999999939813279 168889.2999999969906639, 326658.5999999939813279 168919.5000000000000000, 326536.9000000060186721 168988.2999999969906639, 326477.0000000000000000 169031.4000000059895683, 314768.0999999939813279 178085.5000000000000000, 314320.4000000060186721 178991.5999999940104317, 303956.7999999970197678 219045.0999999940104317, 303407.7999999970197678 221300.4000000059895683, 303377.5999999939813279 221436.5999999940104317, 303342.2000000029802322 221596.7999999969906639, 303305.9000000060186721 221775.5000000000000000, 303273.7999999970197678 222024.9000000059895683, 303247.5000000000000000 222320.7999999969906639, 303245.7999999970197678 222443.0999999940104317, 303248.2999999970197678 222483.0000000000000000, 340256.9000000060186721 228463.7000000030093361, 371918.2999999970197678 233350.7999999969906639, 373503.5000000000000000 233590.0999999940104317, 373539.5999999939813279 233594.0999999940104317, 373629.5000000000000000 233598.0000000000000000, 373642.2000000029802322 233597.9000000059895683, 373562.9000000060186721 233422.0999999940104317, 365303.2999999970197678 216741.5999999940104317, 365243.2000000029802322 216626.4000000059895683, 339793.5999999939813279 171618.4000000059895683, 338739.4000000060186721 169896.5999999940104317, 338726.9000000060186721 169879.5000000000000000, 337790.2000000029802322 168602.5000000000000000, 337756.7000000029802322 168562.2999999969906639, 337685.7999999970197678 168497.0999999940104317, 337651.9000000060186721 168467.7000000030093361, 337601.2999999970197678 168427.0000000000000000, 337485.7000000029802322 168368.5999999940104317, 335357.0000000000000000 167673.9000000059895683, 335286.5000000000000000 167652.2999999969906639, 335197.0000000000000000 167635.9000000059895683))
-Buffer: POLYGON ((335215.0239261208334938 167537.5377202073286753, 335210.0916716848732904 167536.7606630478694569, 335205.1267784655792639 167536.2307696900388692, 335200.1416244141873904 167535.9493612084188499, 335195.1486379941343330 167535.9171391811396461, 335190.1602671957225539 167536.1341839407396037, 329285.6602671957225539 167940.9341839377593715, 329280.6851495988667011 167941.4004062979074661, 329275.7395326890982687 167942.1145713863952551, 329270.8357652556151152 167943.0748959931370337, 329265.9860915930476040 167944.2789822683553211, 329261.2026209282921627 167945.7238237099954858, 326746.7026209282921627 168774.3238237039768137, 326739.4700757855316624 168777.0208314917108510, 326691.5700757795129903 168797.0208314917108510, 326691.1906471042311750 168797.1801744560070802, 326619.6906471042311750 168827.3801744590164162, 326614.4661321343737654 168829.7659389766049571, 326609.3872034477535635 168832.4477130909217522, 326487.6872034597909078 168901.2477130879124161, 326483.0105803586193360 168904.0626540626399219, 326478.4945191467413679 168907.1285776514559984, 326418.5945191407226957 168950.2285776604549028, 326415.8285449087852612 168952.2921427348919678, 314706.9285449027665891 178006.3921427289023995, 314703.0203897153842263 178009.5747451371571515, 314699.2775538869318552 178012.9502176995156333, 314695.7095452067442238 178016.5099858262110502, 314692.3254273570491932 178020.2450067681784276, 314689.1337968888110481 178024.1457925880094990, 314686.1427613845444284 178028.2024342618533410, 314683.3599188625812531 178032.4046268509118818, 314680.7923384761670604 178036.7416956787055824, 314678.4465425560483709 178041.2026234475779347, 314230.7465425680857152 178947.3026234415883664, 314228.5878578424453735 178951.9700800933642313, 314226.6719709816970862 178956.7423383510031272, 314225.0039485624292865 178961.6067779435543343, 314223.5882016817340627 178966.5505348258011509, 303859.9882016727351584 219020.0505348258011509, 303859.6373324339510873 219021.4480226553569082, 303310.6373324339510873 221276.7480226673360448, 303310.1711850037681870 221278.7524947684432846, 303279.9711850007297471 221414.9524947564641479, 303279.9555483013973571 221415.0231361427286174, 303244.5555483103962615 221575.2231361457088497, 303244.2014352029073052 221576.8931846534833312, 303207.9014352059457451 221755.5931846564926673, 303206.7181479214923456 221762.7344127797405235, 303174.6181479124934413 222012.1344127857300919, 303174.1926699578762054 222016.0467631698702462, 303147.8926699608564377 222311.9467631608713418, 303147.5096594412461855 222319.4101097332895733, 303145.8096594382659532 222441.7101097303093411, 303145.9957166555686854 222449.3534012049494777, 303148.4957166555686854 222489.2534012109390460, 303148.9538959227502346 222494.4171627500036266, 303149.6790615010540932 222499.5502413932117634, 303150.6692645543371327 222504.6388423194293864, 303151.9218439752003178 222509.6692902386421338, 303153.4334335363237187 222514.6280661432247143, 303155.1999709373340011 222519.5018436395912431, 303157.2167087217676453 222524.2775247619138099, 303159.4782270356081426 222528.9422751721285749, 303161.9784481927636079 222533.4835586513218004, 303164.7106530084856786 222537.8891707901784685, 303167.6674988568993285 222542.1472717873693909, 303170.8410394035163336 222546.2464182683033869, 303174.2227459607529454 222550.1755940386210568, 303177.8035304081276990 222553.9242396893096156, 303181.5737696161959320 222557.4822809745091945, 303185.5233313077478670 222560.8401558854966424, 303189.6416012879926711 222563.9888403478544205, 303193.9175119692226872 222566.9198724731104448, 303198.3395721145207062 222569.6253752996271942, 303202.8958977197180502 222572.0980779612727929, 303207.5742439505993389 222574.3313352275581565, 303212.3620380503707565 222576.3191453621548135, 303217.2464131281594746 222578.0561662522668485, 303222.2142427377984859 222579.5377297651721165, 303227.2521761544630863 222580.7598542935156729, 303232.3466742536984384 222581.7192554557113908, 340240.9466742626973428 228562.4192554587207269, 340241.6451431164168753 228562.5295974992914125, 371903.0451431074179709 233449.6295974932727404, 371903.3732348520425148 233449.6796828560472932, 373488.5732348550227471 233688.9796828530670609, 373492.4870663167093880 233689.4917264690448064, 373528.5870663106907159 233693.4917264690448064, 373535.2659228414413519 233694.0060347228136379, 373625.1659228474600241 233697.9060347288032062, 373625.1659228474600241 233697.9060347288323101, 373630.2873771191225387 233697.9969001383287832, 373642.9873771221027710 233697.8969001443183515, 373648.2118495866889134 233697.7191247496230062, 373653.4198936402681284 233697.2685764613561332, 373658.5972774084657431 233696.5464864801033400, 373663.7298528013634495 233695.5548280406510457, 373668.8035941756097600 233694.2963110199489165, 373673.8046366619528271 233692.7743745317566209, 373678.7193140533054247 233690.9931775288132485, 373683.5341961499652825 233688.9575874376751017, 373688.2361254601855762 233686.6731668577413075, 373692.8122531549306586 233684.1461583603522740, 373697.2500741796684451 233681.3834674300451297, 373701.5374614266911522 233678.3926435940084048, 373705.6626988743664697 233675.1818597918318119, 373709.6145136032719165 233671.7598900413722731, 373713.3821066011441872 233668.1360854624363128, 373716.9551822734647430 233664.3203487230930477, 373720.3239765776088461 233660.3231069790199399, 373723.4792837048298679 233656.1552833794266917, 373726.4124812366790138 233651.8282672177592758, 373729.1155537074664608 233647.3538828085002024, 373731.5811145076295361 233642.7443571751064155, 373733.8024260689853691 233638.0122866376477759, 373735.7734182764543220 233633.1706023911829107, 373737.4887050554389134 233628.2325351690815296, 373738.9435990903875791 233623.2115790876850951, 373740.1341246336232871 233618.1214547714043874, 373741.0570283696870320 233612.9760718587203883, 373741.7097883056849241 233607.7894909917085897, 373742.0906206630170345 233602.5758853929000907, 373742.1984847519779578 233597.3495021346316207, 373742.0330858153756708 233592.1246232062694617, 373741.5948758341837674 233586.9155264864384662, 373740.8850522924331017 233581.7364467261068057, 373739.9055549047770910 233576.6015366498031653, 373738.6590603159856983 233571.5248282807588112, 373737.1489747864543460 233566.5201945960870944, 373735.3794248842168599 233561.6013116164249368, 373733.3552462080260739 233556.7816210339078680, 373654.0552462110645138 233380.9816210219287314, 373652.5153630711138248 233377.7256075733166654, 365392.9153630621149205 216697.2256075733166654, 365391.9598568481160328 216695.3460295358672738, 365331.8598568540764973 216580.1460295478464104, 365330.2477527938899584 216577.1791839415382128, 339880.6477527848910540 171569.1791839415382128, 339878.8843201125273481 171566.1832905930059496, 338824.6843201245646924 169844.3832905810268130, 338822.4769281532499008 169840.9383075150544755, 338820.1304613530519418 169837.5865048365958501, 338807.6304613530519418 169820.4865048425854184, 338807.5334730069153011 169820.3540531243779697, 337870.8334730038768612 168543.3540531243779697, 337867.0221279650577344 168538.4815600363945123, 337833.5221279650577344 168498.2815600333851762, 337830.6202818806632422 168494.9517117698851507, 337827.5742276740493253 168491.7532505890121683, 337824.3899077704991214 168488.6924162408104166, 337753.4899077645386569 168423.4924162378301844, 337751.3185027677100152 168421.5531549594015814, 337717.4185027767089196 168392.1531549684004858, 337714.5758644837187603 168389.7786549685988575, 337663.9758644747198559 168349.0786549655895215, 337659.8087246867362410 168345.9029646954732016, 337655.4809780826326460 168342.9498862957989331, 337651.0045043539139442 168340.2275259852758609, 337646.3915914490935393 168337.7433566600084305, 337530.7915914550540037 168279.3433566540188622, 337526.2029832758707926 168277.1696530297922436, 337521.5099571402533911 168275.2316596969612874, 337516.7246118161710910 168273.5343728628649842, 335388.0246118131908588 167578.8343728748441208, 335386.2942020931513980 167578.2869793250865769, 335315.7942020931513980 167556.6869793160876725, 335310.1989645521389320 167555.1487824073119555, 335304.5239261208334938 167553.9377201983297709, 335215.0239261208334938 167537.5377202073286753))
-Intersection: POLYGON ((335197.0000000000000000 167635.9000000059895683, 329292.5000000000000000 168040.7000000030093361, 326778.0000000000000000 168869.2999999969906639, 326730.0999999939813279 168889.2999999969906639, 326658.5999999939813279 168919.5000000000000000, 326536.9000000060186721 168988.2999999969906639, 326477.0000000000000000 169031.4000000059895683, 314768.0999999939813279 178085.5000000000000000, 314320.4000000060186721 178991.5999999940104317, 303956.7999999970197678 219045.0999999940104317, 303407.7999999970197678 221300.4000000059895683, 303377.5999999939813279 221436.5999999940104317, 303342.2000000029802322 221596.7999999969906639, 303305.9000000060186721 221775.5000000000000000, 303273.7999999970197678 222024.9000000059895683, 303247.5000000000000000 222320.7999999969906639, 303245.7999999970197678 222443.0999999940104317, 303248.2999999970197678 222483.0000000000000000, 340256.9000000060186721 228463.7000000030093361, 371918.2999999970197678 233350.7999999969906639, 373503.5000000000000000 233590.0999999940104317, 373539.5999999939813279 233594.0999999940104317, 373629.5000000000000000 233598.0000000000000000, 373642.2000000029802322 233597.9000000059895683, 373562.9000000060186721 233422.0999999940104317, 365303.2999999970197678 216741.5999999940104317, 365243.2000000029802322 216626.4000000059895683, 339793.5999999939813279 171618.4000000059895683, 338739.4000000060186721 169896.5999999940104317, 338726.9000000060186721 169879.5000000000000000, 337790.2000000029802322 168602.5000000000000000, 337756.7000000029802322 168562.2999999969906639, 337685.7999999970197678 168497.0999999940104317, 337651.9000000060186721 168467.7000000030093361, 337601.2999999970197678 168427.0000000000000000, 337485.7000000029802322 168368.5999999940104317, 335357.0000000000000000 167673.9000000059895683, 335286.5000000000000000 167652.2999999969906639, 335197.0000000000000000 167635.9000000059895683))
-Difference: POLYGON ((335215.0239261208334938 167537.5377202073286753, 335210.0916716848732904 167536.7606630478694569, 335205.1267784655792639 167536.2307696900388692, 335200.1416244141873904 167535.9493612084188499, 335195.1486379941343330 167535.9171391811396461, 335190.1602671957225539 167536.1341839407396037, 329285.6602671957225539 167940.9341839377593715, 329280.6851495988667011 167941.4004062979074661, 329275.7395326890982687 167942.1145713863952551, 329270.8357652556151152 167943.0748959931370337, 329265.9860915930476040 167944.2789822683553211, 329261.2026209282921627 167945.7238237099954858, 326746.7026209282921627 168774.3238237039768137, 326739.4700757855316624 168777.0208314917108510, 326691.5700757795129903 168797.0208314917108510, 326691.1906471042311750 168797.1801744560070802, 326619.6906471042311750 168827.3801744590164162, 326614.4661321343737654 168829.7659389766049571, 326609.3872034477535635 168832.4477130909217522, 326487.6872034597909078 168901.2477130879124161, 326483.0105803586193360 168904.0626540626399219, 326478.4945191467413679 168907.1285776514559984, 326418.5945191407226957 168950.2285776604549028, 326415.8285449087852612 168952.2921427348919678, 314706.9285449027665891 178006.3921427289023995, 314703.0203897153842263 178009.5747451371571515, 314699.2775538869318552 178012.9502176995156333, 314695.7095452067442238 178016.5099858262110502, 314692.3254273570491932 178020.2450067681784276, 314689.1337968888110481 178024.1457925880094990, 314686.1427613845444284 178028.2024342618533410, 314683.3599188625812531 178032.4046268509118818, 314680.7923384761670604 178036.7416956787055824, 314678.4465425560483709 178041.2026234475779347, 314230.7465425680857152 178947.3026234415883664, 314228.5878578424453735 178951.9700800933642313, 314226.6719709816970862 178956.7423383510031272, 314225.0039485624292865 178961.6067779435543343, 314223.5882016817340627 178966.5505348258011509, 303859.9882016727351584 219020.0505348258011509, 303859.6373324339510873 219021.4480226553569082, 303310.6373324339510873 221276.7480226673360448, 303310.1711850037681870 221278.7524947684432846, 303279.9711850007297471 221414.9524947564641479, 303279.9555483013973571 221415.0231361427286174, 303244.5555483103962615 221575.2231361457088497, 303244.2014352029073052 221576.8931846534833312, 303207.9014352059457451 221755.5931846564926673, 303206.7181479214923456 221762.7344127797405235, 303174.6181479124934413 222012.1344127857300919, 303174.1926699578762054 222016.0467631698702462, 303147.8926699608564377 222311.9467631608713418, 303147.5096594412461855 222319.4101097332895733, 303145.8096594382659532 222441.7101097303093411, 303145.9957166555686854 222449.3534012049494777, 303148.4957166555686854 222489.2534012109390460, 303148.9538959227502346 222494.4171627500036266, 303149.6790615010540932 222499.5502413932117634, 303150.6692645543371327 222504.6388423194293864, 303151.9218439752003178 222509.6692902386421338, 303153.4334335363237187 222514.6280661432247143, 303155.1999709373340011 222519.5018436395912431, 303157.2167087217676453 222524.2775247619138099, 303159.4782270356081426 222528.9422751721285749, 303161.9784481927636079 222533.4835586513218004, 303164.7106530084856786 222537.8891707901784685, 303167.6674988568993285 222542.1472717873693909, 303170.8410394035163336 222546.2464182683033869, 303174.2227459607529454 222550.1755940386210568, 303177.8035304081276990 222553.9242396893096156, 303181.5737696161959320 222557.4822809745091945, 303185.5233313077478670 222560.8401558854966424, 303189.6416012879926711 222563.9888403478544205, 303193.9175119692226872 222566.9198724731104448, 303198.3395721145207062 222569.6253752996271942, 303202.8958977197180502 222572.0980779612727929, 303207.5742439505993389 222574.3313352275581565, 303212.3620380503707565 222576.3191453621548135, 303217.2464131281594746 222578.0561662522668485, 303222.2142427377984859 222579.5377297651721165, 303227.2521761544630863 222580.7598542935156729, 303232.3466742536984384 222581.7192554557113908, 340240.9466742626973428 228562.4192554587207269, 340241.6451431164168753 228562.5295974992914125, 371903.0451431074179709 233449.6295974932727404, 371903.3732348520425148 233449.6796828560472932, 373488.5732348550227471 233688.9796828530670609, 373492.4870663167093880 233689.4917264690448064, 373528.5870663106907159 233693.4917264690448064, 373535.2659228414413519 233694.0060347228136379, 373625.1659228474600241 233697.9060347288032062, 373625.1659228474600241 233697.9060347288323101, 373630.2873771191225387 233697.9969001383287832, 373642.9873771221027710 233697.8969001443183515, 373648.2118495866889134 233697.7191247496230062, 373653.4198936402681284 233697.2685764613561332, 373658.5972774084657431 233696.5464864801033400, 373663.7298528013634495 233695.5548280406510457, 373668.8035941756097600 233694.2963110199489165, 373673.8046366619528271 233692.7743745317566209, 373678.7193140533054247 233690.9931775288132485, 373683.5341961499652825 233688.9575874376751017, 373688.2361254601855762 233686.6731668577413075, 373692.8122531549306586 233684.1461583603522740, 373697.2500741796684451 233681.3834674300451297, 373701.5374614266911522 233678.3926435940084048, 373705.6626988743664697 233675.1818597918318119, 373709.6145136032719165 233671.7598900413722731, 373713.3821066011441872 233668.1360854624363128, 373716.9551822734647430 233664.3203487230930477, 373720.3239765776088461 233660.3231069790199399, 373723.4792837048298679 233656.1552833794266917, 373726.4124812366790138 233651.8282672177592758, 373729.1155537074664608 233647.3538828085002024, 373731.5811145076295361 233642.7443571751064155, 373733.8024260689853691 233638.0122866376477759, 373735.7734182764543220 233633.1706023911829107, 373737.4887050554389134 233628.2325351690815296, 373738.9435990903875791 233623.2115790876850951, 373740.1341246336232871 233618.1214547714043874, 373741.0570283696870320 233612.9760718587203883, 373741.7097883056849241 233607.7894909917085897, 373742.0906206630170345 233602.5758853929000907, 373742.1984847519779578 233597.3495021346316207, 373742.0330858153756708 233592.1246232062694617, 373741.5948758341837674 233586.9155264864384662, 373740.8850522924331017 233581.7364467261068057, 373739.9055549047770910 233576.6015366498031653, 373738.6590603159856983 233571.5248282807588112, 373737.1489747864543460 233566.5201945960870944, 373735.3794248842168599 233561.6013116164249368, 373733.3552462080260739 233556.7816210339078680, 373654.0552462110645138 233380.9816210219287314, 373652.5153630711138248 233377.7256075733166654, 365392.9153630621149205 216697.2256075733166654, 365391.9598568481160328 216695.3460295358672738, 365331.8598568540764973 216580.1460295478464104, 365330.2477527938899584 216577.1791839415382128, 339880.6477527848910540 171569.1791839415382128, 339878.8843201125273481 171566.1832905930059496, 338824.6843201245646924 169844.3832905810268130, 338822.4769281532499008 169840.9383075150544755, 338820.1304613530519418 169837.5865048365958501, 338807.6304613530519418 169820.4865048425854184, 338807.5334730069153011 169820.3540531243779697, 337870.8334730038768612 168543.3540531243779697, 337867.0221279650577344 168538.4815600363945123, 337833.5221279650577344 168498.2815600333851762, 337830.6202818806632422 168494.9517117698851507, 337827.5742276740493253 168491.7532505890121683, 337824.3899077704991214 168488.6924162408104166, 337753.4899077645386569 168423.4924162378301844, 337751.3185027677100152 168421.5531549594015814, 337717.4185027767089196 168392.1531549684004858, 337714.5758644837187603 168389.7786549685988575, 337663.9758644747198559 168349.0786549655895215, 337659.8087246867362410 168345.9029646954732016, 337655.4809780826326460 168342.9498862957989331, 337651.0045043539139442 168340.2275259852758609, 337646.3915914490935393 168337.7433566600084305, 337530.7915914550540037 168279.3433566540188622, 337526.2029832758707926 168277.1696530297922436, 337521.5099571402533911 168275.2316596969612874, 337516.7246118161710910 168273.5343728628649842, 335388.0246118131908588 167578.8343728748441208, 335386.2942020931513980 167578.2869793250865769, 335315.7942020931513980 167556.6869793160876725, 335310.1989645521389320 167555.1487824073119555, 335304.5239261208334938 167553.9377201983297709, 335215.0239261208334938 167537.5377202073286753), (335197.0000000000000000 167635.9000000059895683, 335286.5000000000000000 167652.2999999969906639, 335357.0000000000000000 167673.9000000059895683, 337485.7000000029802322 168368.5999999940104317, 337601.2999999970197678 168427.0000000000000000, 337651.9000000060186721 168467.7000000030093361, 337685.7999999970197678 168497.0999999940104317, 337756.7000000029802322 168562.2999999969906639, 337790.2000000029802322 168602.5000000000000000, 338726.9000000060186721 169879.5000000000000000, 338739.4000000060186721 169896.5999999940104317, 339793.5999999939813279 171618.4000000059895683, 365243.2000000029802322 216626.4000000059895683, 365303.2999999970197678 216741.5999999940104317, 373562.9000000060186721 233422.0999999940104317, 373642.2000000029802322 233597.9000000059895683, 373629.5000000000000000 233598.0000000000000000, 373539.5999999939813279 233594.0999999940104317, 373503.5000000000000000 233590.0999999940104317, 371918.2999999970197678 233350.7999999969906639, 340256.9000000060186721 228463.7000000030093361, 303248.2999999970197678 222483.0000000000000000, 303245.7999999970197678 222443.0999999940104317, 303247.5000000000000000 222320.7999999969906639, 303273.7999999970197678 222024.9000000059895683, 303305.9000000060186721 221775.5000000000000000, 303342.2000000029802322 221596.7999999969906639, 303377.5999999939813279 221436.5999999940104317, 303407.7999999970197678 221300.4000000059895683, 303956.7999999970197678 219045.0999999940104317, 314320.4000000060186721 178991.5999999940104317, 314768.0999999939813279 178085.5000000000000000, 326477.0000000000000000 169031.4000000059895683, 326536.9000000060186721 168988.2999999969906639, 326658.5999999939813279 168919.5000000000000000, 326730.0999999939813279 168889.2999999969906639, 326778.0000000000000000 168869.2999999969906639, 329292.5000000000000000 168040.7000000030093361, 335197.0000000000000000 167635.9000000059895683))
-SymDifference: POLYGON ((335215.0239261208334938 167537.5377202073286753, 335210.0916716848732904 167536.7606630478694569, 335205.1267784655792639 167536.2307696900388692, 335200.1416244141873904 167535.9493612084188499, 335195.1486379941343330 167535.9171391811396461, 335190.1602671957225539 167536.1341839407396037, 329285.6602671957225539 167940.9341839377593715, 329280.6851495988667011 167941.4004062979074661, 329275.7395326890982687 167942.1145713863952551, 329270.8357652556151152 167943.0748959931370337, 329265.9860915930476040 167944.2789822683553211, 329261.2026209282921627 167945.7238237099954858, 326746.7026209282921627 168774.3238237039768137, 326739.4700757855316624 168777.0208314917108510, 326691.5700757795129903 168797.0208314917108510, 326691.1906471042311750 168797.1801744560070802, 326619.6906471042311750 168827.3801744590164162, 326614.4661321343737654 168829.7659389766049571, 326609.3872034477535635 168832.4477130909217522, 326487.6872034597909078 168901.2477130879124161, 326483.0105803586193360 168904.0626540626399219, 326478.4945191467413679 168907.1285776514559984, 326418.5945191407226957 168950.2285776604549028, 326415.8285449087852612 168952.2921427348919678, 314706.9285449027665891 178006.3921427289023995, 314703.0203897153842263 178009.5747451371571515, 314699.2775538869318552 178012.9502176995156333, 314695.7095452067442238 178016.5099858262110502, 314692.3254273570491932 178020.2450067681784276, 314689.1337968888110481 178024.1457925880094990, 314686.1427613845444284 178028.2024342618533410, 314683.3599188625812531 178032.4046268509118818, 314680.7923384761670604 178036.7416956787055824, 314678.4465425560483709 178041.2026234475779347, 314230.7465425680857152 178947.3026234415883664, 314228.5878578424453735 178951.9700800933642313, 314226.6719709816970862 178956.7423383510031272, 314225.0039485624292865 178961.6067779435543343, 314223.5882016817340627 178966.5505348258011509, 303859.9882016727351584 219020.0505348258011509, 303859.6373324339510873 219021.4480226553569082, 303310.6373324339510873 221276.7480226673360448, 303310.1711850037681870 221278.7524947684432846, 303279.9711850007297471 221414.9524947564641479, 303279.9555483013973571 221415.0231361427286174, 303244.5555483103962615 221575.2231361457088497, 303244.2014352029073052 221576.8931846534833312, 303207.9014352059457451 221755.5931846564926673, 303206.7181479214923456 221762.7344127797405235, 303174.6181479124934413 222012.1344127857300919, 303174.1926699578762054 222016.0467631698702462, 303147.8926699608564377 222311.9467631608713418, 303147.5096594412461855 222319.4101097332895733, 303145.8096594382659532 222441.7101097303093411, 303145.9957166555686854 222449.3534012049494777, 303148.4957166555686854 222489.2534012109390460, 303148.9538959227502346 222494.4171627500036266, 303149.6790615010540932 222499.5502413932117634, 303150.6692645543371327 222504.6388423194293864, 303151.9218439752003178 222509.6692902386421338, 303153.4334335363237187 222514.6280661432247143, 303155.1999709373340011 222519.5018436395912431, 303157.2167087217676453 222524.2775247619138099, 303159.4782270356081426 222528.9422751721285749, 303161.9784481927636079 222533.4835586513218004, 303164.7106530084856786 222537.8891707901784685, 303167.6674988568993285 222542.1472717873693909, 303170.8410394035163336 222546.2464182683033869, 303174.2227459607529454 222550.1755940386210568, 303177.8035304081276990 222553.9242396893096156, 303181.5737696161959320 222557.4822809745091945, 303185.5233313077478670 222560.8401558854966424, 303189.6416012879926711 222563.9888403478544205, 303193.9175119692226872 222566.9198724731104448, 303198.3395721145207062 222569.6253752996271942, 303202.8958977197180502 222572.0980779612727929, 303207.5742439505993389 222574.3313352275581565, 303212.3620380503707565 222576.3191453621548135, 303217.2464131281594746 222578.0561662522668485, 303222.2142427377984859 222579.5377297651721165, 303227.2521761544630863 222580.7598542935156729, 303232.3466742536984384 222581.7192554557113908, 340240.9466742626973428 228562.4192554587207269, 340241.6451431164168753 228562.5295974992914125, 371903.0451431074179709 233449.6295974932727404, 371903.3732348520425148 233449.6796828560472932, 373488.5732348550227471 233688.9796828530670609, 373492.4870663167093880 233689.4917264690448064, 373528.5870663106907159 233693.4917264690448064, 373535.2659228414413519 233694.0060347228136379, 373625.1659228474600241 233697.9060347288032062, 373625.1659228474600241 233697.9060347288323101, 373630.2873771191225387 233697.9969001383287832, 373642.9873771221027710 233697.8969001443183515, 373648.2118495866889134 233697.7191247496230062, 373653.4198936402681284 233697.2685764613561332, 373658.5972774084657431 233696.5464864801033400, 373663.7298528013634495 233695.5548280406510457, 373668.8035941756097600 233694.2963110199489165, 373673.8046366619528271 233692.7743745317566209, 373678.7193140533054247 233690.9931775288132485, 373683.5341961499652825 233688.9575874376751017, 373688.2361254601855762 233686.6731668577413075, 373692.8122531549306586 233684.1461583603522740, 373697.2500741796684451 233681.3834674300451297, 373701.5374614266911522 233678.3926435940084048, 373705.6626988743664697 233675.1818597918318119, 373709.6145136032719165 233671.7598900413722731, 373713.3821066011441872 233668.1360854624363128, 373716.9551822734647430 233664.3203487230930477, 373720.3239765776088461 233660.3231069790199399, 373723.4792837048298679 233656.1552833794266917, 373726.4124812366790138 233651.8282672177592758, 373729.1155537074664608 233647.3538828085002024, 373731.5811145076295361 233642.7443571751064155, 373733.8024260689853691 233638.0122866376477759, 373735.7734182764543220 233633.1706023911829107, 373737.4887050554389134 233628.2325351690815296, 373738.9435990903875791 233623.2115790876850951, 373740.1341246336232871 233618.1214547714043874, 373741.0570283696870320 233612.9760718587203883, 373741.7097883056849241 233607.7894909917085897, 373742.0906206630170345 233602.5758853929000907, 373742.1984847519779578 233597.3495021346316207, 373742.0330858153756708 233592.1246232062694617, 373741.5948758341837674 233586.9155264864384662, 373740.8850522924331017 233581.7364467261068057, 373739.9055549047770910 233576.6015366498031653, 373738.6590603159856983 233571.5248282807588112, 373737.1489747864543460 233566.5201945960870944, 373735.3794248842168599 233561.6013116164249368, 373733.3552462080260739 233556.7816210339078680, 373654.0552462110645138 233380.9816210219287314, 373652.5153630711138248 233377.7256075733166654, 365392.9153630621149205 216697.2256075733166654, 365391.9598568481160328 216695.3460295358672738, 365331.8598568540764973 216580.1460295478464104, 365330.2477527938899584 216577.1791839415382128, 339880.6477527848910540 171569.1791839415382128, 339878.8843201125273481 171566.1832905930059496, 338824.6843201245646924 169844.3832905810268130, 338822.4769281532499008 169840.9383075150544755, 338820.1304613530519418 169837.5865048365958501, 338807.6304613530519418 169820.4865048425854184, 338807.5334730069153011 169820.3540531243779697, 337870.8334730038768612 168543.3540531243779697, 337867.0221279650577344 168538.4815600363945123, 337833.5221279650577344 168498.2815600333851762, 337830.6202818806632422 168494.9517117698851507, 337827.5742276740493253 168491.7532505890121683, 337824.3899077704991214 168488.6924162408104166, 337753.4899077645386569 168423.4924162378301844, 337751.3185027677100152 168421.5531549594015814, 337717.4185027767089196 168392.1531549684004858, 337714.5758644837187603 168389.7786549685988575, 337663.9758644747198559 168349.0786549655895215, 337659.8087246867362410 168345.9029646954732016, 337655.4809780826326460 168342.9498862957989331, 337651.0045043539139442 168340.2275259852758609, 337646.3915914490935393 168337.7433566600084305, 337530.7915914550540037 168279.3433566540188622, 337526.2029832758707926 168277.1696530297922436, 337521.5099571402533911 168275.2316596969612874, 337516.7246118161710910 168273.5343728628649842, 335388.0246118131908588 167578.8343728748441208, 335386.2942020931513980 167578.2869793250865769, 335315.7942020931513980 167556.6869793160876725, 335310.1989645521389320 167555.1487824073119555, 335304.5239261208334938 167553.9377201983297709, 335215.0239261208334938 167537.5377202073286753), (335197.0000000000000000 167635.9000000059895683, 335286.5000000000000000 167652.2999999969906639, 335357.0000000000000000 167673.9000000059895683, 337485.7000000029802322 168368.5999999940104317, 337601.2999999970197678 168427.0000000000000000, 337651.9000000060186721 168467.7000000030093361, 337685.7999999970197678 168497.0999999940104317, 337756.7000000029802322 168562.2999999969906639, 337790.2000000029802322 168602.5000000000000000, 338726.9000000060186721 169879.5000000000000000, 338739.4000000060186721 169896.5999999940104317, 339793.5999999939813279 171618.4000000059895683, 365243.2000000029802322 216626.4000000059895683, 365303.2999999970197678 216741.5999999940104317, 373562.9000000060186721 233422.0999999940104317, 373642.2000000029802322 233597.9000000059895683, 373629.5000000000000000 233598.0000000000000000, 373539.5999999939813279 233594.0999999940104317, 373503.5000000000000000 233590.0999999940104317, 371918.2999999970197678 233350.7999999969906639, 340256.9000000060186721 228463.7000000030093361, 303248.2999999970197678 222483.0000000000000000, 303245.7999999970197678 222443.0999999940104317, 303247.5000000000000000 222320.7999999969906639, 303273.7999999970197678 222024.9000000059895683, 303305.9000000060186721 221775.5000000000000000, 303342.2000000029802322 221596.7999999969906639, 303377.5999999939813279 221436.5999999940104317, 303407.7999999970197678 221300.4000000059895683, 303956.7999999970197678 219045.0999999940104317, 314320.4000000060186721 178991.5999999940104317, 314768.0999999939813279 178085.5000000000000000, 326477.0000000000000000 169031.4000000059895683, 326536.9000000060186721 168988.2999999969906639, 326658.5999999939813279 168919.5000000000000000, 326730.0999999939813279 168889.2999999969906639, 326778.0000000000000000 168869.2999999969906639, 329292.5000000000000000 168040.7000000030093361, 335197.0000000000000000 167635.9000000059895683))
-Boundary: MULTILINESTRING ((335215.0239261208334938 167537.5377202073286753, 335210.0916716848732904 167536.7606630478694569, 335205.1267784655792639 167536.2307696900388692, 335200.1416244141873904 167535.9493612084188499, 335195.1486379941343330 167535.9171391811396461, 335190.1602671957225539 167536.1341839407396037, 329285.6602671957225539 167940.9341839377593715, 329280.6851495988667011 167941.4004062979074661, 329275.7395326890982687 167942.1145713863952551, 329270.8357652556151152 167943.0748959931370337, 329265.9860915930476040 167944.2789822683553211, 329261.2026209282921627 167945.7238237099954858, 326746.7026209282921627 168774.3238237039768137, 326739.4700757855316624 168777.0208314917108510, 326691.5700757795129903 168797.0208314917108510, 326691.1906471042311750 168797.1801744560070802, 326619.6906471042311750 168827.3801744590164162, 326614.4661321343737654 168829.7659389766049571, 326609.3872034477535635 168832.4477130909217522, 326487.6872034597909078 168901.2477130879124161, 326483.0105803586193360 168904.0626540626399219, 326478.4945191467413679 168907.1285776514559984, 326418.5945191407226957 168950.2285776604549028, 326415.8285449087852612 168952.2921427348919678, 314706.9285449027665891 178006.3921427289023995, 314703.0203897153842263 178009.5747451371571515, 314699.2775538869318552 178012.9502176995156333, 314695.7095452067442238 178016.5099858262110502, 314692.3254273570491932 178020.2450067681784276, 314689.1337968888110481 178024.1457925880094990, 314686.1427613845444284 178028.2024342618533410, 314683.3599188625812531 178032.4046268509118818, 314680.7923384761670604 178036.7416956787055824, 314678.4465425560483709 178041.2026234475779347, 314230.7465425680857152 178947.3026234415883664, 314228.5878578424453735 178951.9700800933642313, 314226.6719709816970862 178956.7423383510031272, 314225.0039485624292865 178961.6067779435543343, 314223.5882016817340627 178966.5505348258011509, 303859.9882016727351584 219020.0505348258011509, 303859.6373324339510873 219021.4480226553569082, 303310.6373324339510873 221276.7480226673360448, 303310.1711850037681870 221278.7524947684432846, 303279.9711850007297471 221414.9524947564641479, 303279.9555483013973571 221415.0231361427286174, 303244.5555483103962615 221575.2231361457088497, 303244.2014352029073052 221576.8931846534833312, 303207.9014352059457451 221755.5931846564926673, 303206.7181479214923456 221762.7344127797405235, 303174.6181479124934413 222012.1344127857300919, 303174.1926699578762054 222016.0467631698702462, 303147.8926699608564377 222311.9467631608713418, 303147.5096594412461855 222319.4101097332895733, 303145.8096594382659532 222441.7101097303093411, 303145.9957166555686854 222449.3534012049494777, 303148.4957166555686854 222489.2534012109390460, 303148.9538959227502346 222494.4171627500036266, 303149.6790615010540932 222499.5502413932117634, 303150.6692645543371327 222504.6388423194293864, 303151.9218439752003178 222509.6692902386421338, 303153.4334335363237187 222514.6280661432247143, 303155.1999709373340011 222519.5018436395912431, 303157.2167087217676453 222524.2775247619138099, 303159.4782270356081426 222528.9422751721285749, 303161.9784481927636079 222533.4835586513218004, 303164.7106530084856786 222537.8891707901784685, 303167.6674988568993285 222542.1472717873693909, 303170.8410394035163336 222546.2464182683033869, 303174.2227459607529454 222550.1755940386210568, 303177.8035304081276990 222553.9242396893096156, 303181.5737696161959320 222557.4822809745091945, 303185.5233313077478670 222560.8401558854966424, 303189.6416012879926711 222563.9888403478544205, 303193.9175119692226872 222566.9198724731104448, 303198.3395721145207062 222569.6253752996271942, 303202.8958977197180502 222572.0980779612727929, 303207.5742439505993389 222574.3313352275581565, 303212.3620380503707565 222576.3191453621548135, 303217.2464131281594746 222578.0561662522668485, 303222.2142427377984859 222579.5377297651721165, 303227.2521761544630863 222580.7598542935156729, 303232.3466742536984384 222581.7192554557113908, 340240.9466742626973428 228562.4192554587207269, 340241.6451431164168753 228562.5295974992914125, 371903.0451431074179709 233449.6295974932727404, 371903.3732348520425148 233449.6796828560472932, 373488.5732348550227471 233688.9796828530670609, 373492.4870663167093880 233689.4917264690448064, 373528.5870663106907159 233693.4917264690448064, 373535.2659228414413519 233694.0060347228136379, 373625.1659228474600241 233697.9060347288032062, 373625.1659228474600241 233697.9060347288323101, 373630.2873771191225387 233697.9969001383287832, 373642.9873771221027710 233697.8969001443183515, 373648.2118495866889134 233697.7191247496230062, 373653.4198936402681284 233697.2685764613561332, 373658.5972774084657431 233696.5464864801033400, 373663.7298528013634495 233695.5548280406510457, 373668.8035941756097600 233694.2963110199489165, 373673.8046366619528271 233692.7743745317566209, 373678.7193140533054247 233690.9931775288132485, 373683.5341961499652825 233688.9575874376751017, 373688.2361254601855762 233686.6731668577413075, 373692.8122531549306586 233684.1461583603522740, 373697.2500741796684451 233681.3834674300451297, 373701.5374614266911522 233678.3926435940084048, 373705.6626988743664697 233675.1818597918318119, 373709.6145136032719165 233671.7598900413722731, 373713.3821066011441872 233668.1360854624363128, 373716.9551822734647430 233664.3203487230930477, 373720.3239765776088461 233660.3231069790199399, 373723.4792837048298679 233656.1552833794266917, 373726.4124812366790138 233651.8282672177592758, 373729.1155537074664608 233647.3538828085002024, 373731.5811145076295361 233642.7443571751064155, 373733.8024260689853691 233638.0122866376477759, 373735.7734182764543220 233633.1706023911829107, 373737.4887050554389134 233628.2325351690815296, 373738.9435990903875791 233623.2115790876850951, 373740.1341246336232871 233618.1214547714043874, 373741.0570283696870320 233612.9760718587203883, 373741.7097883056849241 233607.7894909917085897, 373742.0906206630170345 233602.5758853929000907, 373742.1984847519779578 233597.3495021346316207, 373742.0330858153756708 233592.1246232062694617, 373741.5948758341837674 233586.9155264864384662, 373740.8850522924331017 233581.7364467261068057, 373739.9055549047770910 233576.6015366498031653, 373738.6590603159856983 233571.5248282807588112, 373737.1489747864543460 233566.5201945960870944, 373735.3794248842168599 233561.6013116164249368, 373733.3552462080260739 233556.7816210339078680, 373654.0552462110645138 233380.9816210219287314, 373652.5153630711138248 233377.7256075733166654, 365392.9153630621149205 216697.2256075733166654, 365391.9598568481160328 216695.3460295358672738, 365331.8598568540764973 216580.1460295478464104, 365330.2477527938899584 216577.1791839415382128, 339880.6477527848910540 171569.1791839415382128, 339878.8843201125273481 171566.1832905930059496, 338824.6843201245646924 169844.3832905810268130, 338822.4769281532499008 169840.9383075150544755, 338820.1304613530519418 169837.5865048365958501, 338807.6304613530519418 169820.4865048425854184, 338807.5334730069153011 169820.3540531243779697, 337870.8334730038768612 168543.3540531243779697, 337867.0221279650577344 168538.4815600363945123, 337833.5221279650577344 168498.2815600333851762, 337830.6202818806632422 168494.9517117698851507, 337827.5742276740493253 168491.7532505890121683, 337824.3899077704991214 168488.6924162408104166, 337753.4899077645386569 168423.4924162378301844, 337751.3185027677100152 168421.5531549594015814, 337717.4185027767089196 168392.1531549684004858, 337714.5758644837187603 168389.7786549685988575, 337663.9758644747198559 168349.0786549655895215, 337659.8087246867362410 168345.9029646954732016, 337655.4809780826326460 168342.9498862957989331, 337651.0045043539139442 168340.2275259852758609, 337646.3915914490935393 168337.7433566600084305, 337530.7915914550540037 168279.3433566540188622, 337526.2029832758707926 168277.1696530297922436, 337521.5099571402533911 168275.2316596969612874, 337516.7246118161710910 168273.5343728628649842, 335388.0246118131908588 167578.8343728748441208, 335386.2942020931513980 167578.2869793250865769, 335315.7942020931513980 167556.6869793160876725, 335310.1989645521389320 167555.1487824073119555, 335304.5239261208334938 167553.9377201983297709, 335215.0239261208334938 167537.5377202073286753), (335197.0000000000000000 167635.9000000059895683, 335286.5000000000000000 167652.2999999969906639, 335357.0000000000000000 167673.9000000059895683, 337485.7000000029802322 168368.5999999940104317, 337601.2999999970197678 168427.0000000000000000, 337651.9000000060186721 168467.7000000030093361, 337685.7999999970197678 168497.0999999940104317, 337756.7000000029802322 168562.2999999969906639, 337790.2000000029802322 168602.5000000000000000, 338726.9000000060186721 169879.5000000000000000, 338739.4000000060186721 169896.5999999940104317, 339793.5999999939813279 171618.4000000059895683, 365243.2000000029802322 216626.4000000059895683, 365303.2999999970197678 216741.5999999940104317, 373562.9000000060186721 233422.0999999940104317, 373642.2000000029802322 233597.9000000059895683, 373629.5000000000000000 233598.0000000000000000, 373539.5999999939813279 233594.0999999940104317, 373503.5000000000000000 233590.0999999940104317, 371918.2999999970197678 233350.7999999969906639, 340256.9000000060186721 228463.7000000030093361, 303248.2999999970197678 222483.0000000000000000, 303245.7999999970197678 222443.0999999940104317, 303247.5000000000000000 222320.7999999969906639, 303273.7999999970197678 222024.9000000059895683, 303305.9000000060186721 221775.5000000000000000, 303342.2000000029802322 221596.7999999969906639, 303377.5999999939813279 221436.5999999940104317, 303407.7999999970197678 221300.4000000059895683, 303956.7999999970197678 219045.0999999940104317, 314320.4000000060186721 178991.5999999940104317, 314768.0999999939813279 178085.5000000000000000, 326477.0000000000000000 169031.4000000059895683, 326536.9000000060186721 168988.2999999969906639, 326658.5999999939813279 168919.5000000000000000, 326730.0999999939813279 168889.2999999969906639, 326778.0000000000000000 168869.2999999969906639, 329292.5000000000000000 168040.7000000030093361, 335197.0000000000000000 167635.9000000059895683))
-Union: POLYGON ((335215.0239261208334938 167537.5377202073286753, 335210.0916716848732904 167536.7606630478694569, 335205.1267784655792639 167536.2307696900388692, 335200.1416244141873904 167535.9493612084188499, 335195.1486379941343330 167535.9171391811396461, 335190.1602671957225539 167536.1341839407396037, 329285.6602671957225539 167940.9341839377593715, 329280.6851495988667011 167941.4004062979074661, 329275.7395326890982687 167942.1145713863952551, 329270.8357652556151152 167943.0748959931370337, 329265.9860915930476040 167944.2789822683553211, 329261.2026209282921627 167945.7238237099954858, 326746.7026209282921627 168774.3238237039768137, 326739.4700757855316624 168777.0208314917108510, 326691.5700757795129903 168797.0208314917108510, 326691.1906471042311750 168797.1801744560070802, 326619.6906471042311750 168827.3801744590164162, 326614.4661321343737654 168829.7659389766049571, 326609.3872034477535635 168832.4477130909217522, 326487.6872034597909078 168901.2477130879124161, 326483.0105803586193360 168904.0626540626399219, 326478.4945191467413679 168907.1285776514559984, 326418.5945191407226957 168950.2285776604549028, 326415.8285449087852612 168952.2921427348919678, 314706.9285449027665891 178006.3921427289023995, 314703.0203897153842263 178009.5747451371571515, 314699.2775538869318552 178012.9502176995156333, 314695.7095452067442238 178016.5099858262110502, 314692.3254273570491932 178020.2450067681784276, 314689.1337968888110481 178024.1457925880094990, 314686.1427613845444284 178028.2024342618533410, 314683.3599188625812531 178032.4046268509118818, 314680.7923384761670604 178036.7416956787055824, 314678.4465425560483709 178041.2026234475779347, 314230.7465425680857152 178947.3026234415883664, 314228.5878578424453735 178951.9700800933642313, 314226.6719709816970862 178956.7423383510031272, 314225.0039485624292865 178961.6067779435543343, 314223.5882016817340627 178966.5505348258011509, 303859.9882016727351584 219020.0505348258011509, 303859.6373324339510873 219021.4480226553569082, 303310.6373324339510873 221276.7480226673360448, 303310.1711850037681870 221278.7524947684432846, 303279.9711850007297471 221414.9524947564641479, 303279.9555483013973571 221415.0231361427286174, 303244.5555483103962615 221575.2231361457088497, 303244.2014352029073052 221576.8931846534833312, 303207.9014352059457451 221755.5931846564926673, 303206.7181479214923456 221762.7344127797405235, 303174.6181479124934413 222012.1344127857300919, 303174.1926699578762054 222016.0467631698702462, 303147.8926699608564377 222311.9467631608713418, 303147.5096594412461855 222319.4101097332895733, 303145.8096594382659532 222441.7101097303093411, 303145.9957166555686854 222449.3534012049494777, 303148.4957166555686854 222489.2534012109390460, 303148.9538959227502346 222494.4171627500036266, 303149.6790615010540932 222499.5502413932117634, 303150.6692645543371327 222504.6388423194293864, 303151.9218439752003178 222509.6692902386421338, 303153.4334335363237187 222514.6280661432247143, 303155.1999709373340011 222519.5018436395912431, 303157.2167087217676453 222524.2775247619138099, 303159.4782270356081426 222528.9422751721285749, 303161.9784481927636079 222533.4835586513218004, 303164.7106530084856786 222537.8891707901784685, 303167.6674988568993285 222542.1472717873693909, 303170.8410394035163336 222546.2464182683033869, 303174.2227459607529454 222550.1755940386210568, 303177.8035304081276990 222553.9242396893096156, 303181.5737696161959320 222557.4822809745091945, 303185.5233313077478670 222560.8401558854966424, 303189.6416012879926711 222563.9888403478544205, 303193.9175119692226872 222566.9198724731104448, 303198.3395721145207062 222569.6253752996271942, 303202.8958977197180502 222572.0980779612727929, 303207.5742439505993389 222574.3313352275581565, 303212.3620380503707565 222576.3191453621548135, 303217.2464131281594746 222578.0561662522668485, 303222.2142427377984859 222579.5377297651721165, 303227.2521761544630863 222580.7598542935156729, 303232.3466742536984384 222581.7192554557113908, 340240.9466742626973428 228562.4192554587207269, 340241.6451431164168753 228562.5295974992914125, 371903.0451431074179709 233449.6295974932727404, 371903.3732348520425148 233449.6796828560472932, 373488.5732348550227471 233688.9796828530670609, 373492.4870663167093880 233689.4917264690448064, 373528.5870663106907159 233693.4917264690448064, 373535.2659228414413519 233694.0060347228136379, 373625.1659228474600241 233697.9060347288032062, 373625.1659228474600241 233697.9060347288323101, 373630.2873771191225387 233697.9969001383287832, 373642.9873771221027710 233697.8969001443183515, 373648.2118495866889134 233697.7191247496230062, 373653.4198936402681284 233697.2685764613561332, 373658.5972774084657431 233696.5464864801033400, 373663.7298528013634495 233695.5548280406510457, 373668.8035941756097600 233694.2963110199489165, 373673.8046366619528271 233692.7743745317566209, 373678.7193140533054247 233690.9931775288132485, 373683.5341961499652825 233688.9575874376751017, 373688.2361254601855762 233686.6731668577413075, 373692.8122531549306586 233684.1461583603522740, 373697.2500741796684451 233681.3834674300451297, 373701.5374614266911522 233678.3926435940084048, 373705.6626988743664697 233675.1818597918318119, 373709.6145136032719165 233671.7598900413722731, 373713.3821066011441872 233668.1360854624363128, 373716.9551822734647430 233664.3203487230930477, 373720.3239765776088461 233660.3231069790199399, 373723.4792837048298679 233656.1552833794266917, 373726.4124812366790138 233651.8282672177592758, 373729.1155537074664608 233647.3538828085002024, 373731.5811145076295361 233642.7443571751064155, 373733.8024260689853691 233638.0122866376477759, 373735.7734182764543220 233633.1706023911829107, 373737.4887050554389134 233628.2325351690815296, 373738.9435990903875791 233623.2115790876850951, 373740.1341246336232871 233618.1214547714043874, 373741.0570283696870320 233612.9760718587203883, 373741.7097883056849241 233607.7894909917085897, 373742.0906206630170345 233602.5758853929000907, 373742.1984847519779578 233597.3495021346316207, 373742.0330858153756708 233592.1246232062694617, 373741.5948758341837674 233586.9155264864384662, 373740.8850522924331017 233581.7364467261068057, 373739.9055549047770910 233576.6015366498031653, 373738.6590603159856983 233571.5248282807588112, 373737.1489747864543460 233566.5201945960870944, 373735.3794248842168599 233561.6013116164249368, 373733.3552462080260739 233556.7816210339078680, 373654.0552462110645138 233380.9816210219287314, 373652.5153630711138248 233377.7256075733166654, 365392.9153630621149205 216697.2256075733166654, 365391.9598568481160328 216695.3460295358672738, 365331.8598568540764973 216580.1460295478464104, 365330.2477527938899584 216577.1791839415382128, 339880.6477527848910540 171569.1791839415382128, 339878.8843201125273481 171566.1832905930059496, 338824.6843201245646924 169844.3832905810268130, 338822.4769281532499008 169840.9383075150544755, 338820.1304613530519418 169837.5865048365958501, 338807.6304613530519418 169820.4865048425854184, 338807.5334730069153011 169820.3540531243779697, 337870.8334730038768612 168543.3540531243779697, 337867.0221279650577344 168538.4815600363945123, 337833.5221279650577344 168498.2815600333851762, 337830.6202818806632422 168494.9517117698851507, 337827.5742276740493253 168491.7532505890121683, 337824.3899077704991214 168488.6924162408104166, 337753.4899077645386569 168423.4924162378301844, 337751.3185027677100152 168421.5531549594015814, 337717.4185027767089196 168392.1531549684004858, 337714.5758644837187603 168389.7786549685988575, 337663.9758644747198559 168349.0786549655895215, 337659.8087246867362410 168345.9029646954732016, 337655.4809780826326460 168342.9498862957989331, 337651.0045043539139442 168340.2275259852758609, 337646.3915914490935393 168337.7433566600084305, 337530.7915914550540037 168279.3433566540188622, 337526.2029832758707926 168277.1696530297922436, 337521.5099571402533911 168275.2316596969612874, 337516.7246118161710910 168273.5343728628649842, 335388.0246118131908588 167578.8343728748441208, 335386.2942020931513980 167578.2869793250865769, 335315.7942020931513980 167556.6869793160876725, 335310.1989645521389320 167555.1487824073119555, 335304.5239261208334938 167553.9377201983297709, 335215.0239261208334938 167537.5377202073286753))
-PointOnSurface: POINT (332463.6393159376457334 200616.9570196597487666)
-Centroid: POINT (334794.0925891167717054 204179.0238832769100554)
-Relate: 212FF1FF2
-Polygonize: GEOMETRYCOLLECTION (POLYGON ((335215.0239261208334938 167537.5377202073286753, 335210.0916716848732904 167536.7606630478694569, 335205.1267784655792639 167536.2307696900388692, 335200.1416244141873904 167535.9493612084188499, 335195.1486379941343330 167535.9171391811396461, 335190.1602671957225539 167536.1341839407396037, 329285.6602671957225539 167940.9341839377593715, 329280.6851495988667011 167941.4004062979074661, 329275.7395326890982687 167942.1145713863952551, 329270.8357652556151152 167943.0748959931370337, 329265.9860915930476040 167944.2789822683553211, 329261.2026209282921627 167945.7238237099954858, 326746.7026209282921627 168774.3238237039768137, 326739.4700757855316624 168777.0208314917108510, 326691.5700757795129903 168797.0208314917108510, 326691.1906471042311750 168797.1801744560070802, 326619.6906471042311750 168827.3801744590164162, 326614.4661321343737654 168829.7659389766049571, 326609.3872034477535635 168832.4477130909217522, 326487.6872034597909078 168901.2477130879124161, 326483.0105803586193360 168904.0626540626399219, 326478.4945191467413679 168907.1285776514559984, 326418.5945191407226957 168950.2285776604549028, 326415.8285449087852612 168952.2921427348919678, 314706.9285449027665891 178006.3921427289023995, 314703.0203897153842263 178009.5747451371571515, 314699.2775538869318552 178012.9502176995156333, 314695.7095452067442238 178016.5099858262110502, 314692.3254273570491932 178020.2450067681784276, 314689.1337968888110481 178024.1457925880094990, 314686.1427613845444284 178028.2024342618533410, 314683.3599188625812531 178032.4046268509118818, 314680.7923384761670604 178036.7416956787055824, 314678.4465425560483709 178041.2026234475779347, 314230.7465425680857152 178947.3026234415883664, 314228.5878578424453735 178951.9700800933642313, 314226.6719709816970862 178956.7423383510031272, 314225.0039485624292865 178961.6067779435543343, 314223.5882016817340627 178966.5505348258011509, 303859.9882016727351584 219020.0505348258011509, 303859.6373324339510873 219021.4480226553569082, 303310.6373324339510873 221276.7480226673360448, 303310.1711850037681870 221278.7524947684432846, 303279.9711850007297471 221414.9524947564641479, 303279.9555483013973571 221415.0231361427286174, 303244.5555483103962615 221575.2231361457088497, 303244.2014352029073052 221576.8931846534833312, 303207.9014352059457451 221755.5931846564926673, 303206.7181479214923456 221762.7344127797405235, 303174.6181479124934413 222012.1344127857300919, 303174.1926699578762054 222016.0467631698702462, 303147.8926699608564377 222311.9467631608713418, 303147.5096594412461855 222319.4101097332895733, 303145.8096594382659532 222441.7101097303093411, 303145.9957166555686854 222449.3534012049494777, 303148.4957166555686854 222489.2534012109390460, 303148.9538959227502346 222494.4171627500036266, 303149.6790615010540932 222499.5502413932117634, 303150.6692645543371327 222504.6388423194293864, 303151.9218439752003178 222509.6692902386421338, 303153.4334335363237187 222514.6280661432247143, 303155.1999709373340011 222519.5018436395912431, 303157.2167087217676453 222524.2775247619138099, 303159.4782270356081426 222528.9422751721285749, 303161.9784481927636079 222533.4835586513218004, 303164.7106530084856786 222537.8891707901784685, 303167.6674988568993285 222542.1472717873693909, 303170.8410394035163336 222546.2464182683033869, 303174.2227459607529454 222550.1755940386210568, 303177.8035304081276990 222553.9242396893096156, 303181.5737696161959320 222557.4822809745091945, 303185.5233313077478670 222560.8401558854966424, 303189.6416012879926711 222563.9888403478544205, 303193.9175119692226872 222566.9198724731104448, 303198.3395721145207062 222569.6253752996271942, 303202.8958977197180502 222572.0980779612727929, 303207.5742439505993389 222574.3313352275581565, 303212.3620380503707565 222576.3191453621548135, 303217.2464131281594746 222578.0561662522668485, 303222.2142427377984859 222579.5377297651721165, 303227.2521761544630863 222580.7598542935156729, 303232.3466742536984384 222581.7192554557113908, 340240.9466742626973428 228562.4192554587207269, 340241.6451431164168753 228562.5295974992914125, 371903.0451431074179709 233449.6295974932727404, 371903.3732348520425148 233449.6796828560472932, 373488.5732348550227471 233688.9796828530670609, 373492.4870663167093880 233689.4917264690448064, 373528.5870663106907159 233693.4917264690448064, 373535.2659228414413519 233694.0060347228136379, 373625.1659228474600241 233697.9060347288032062, 373625.1659228474600241 233697.9060347288323101, 373630.2873771191225387 233697.9969001383287832, 373642.9873771221027710 233697.8969001443183515, 373648.2118495866889134 233697.7191247496230062, 373653.4198936402681284 233697.2685764613561332, 373658.5972774084657431 233696.5464864801033400, 373663.7298528013634495 233695.5548280406510457, 373668.8035941756097600 233694.2963110199489165, 373673.8046366619528271 233692.7743745317566209, 373678.7193140533054247 233690.9931775288132485, 373683.5341961499652825 233688.9575874376751017, 373688.2361254601855762 233686.6731668577413075, 373692.8122531549306586 233684.1461583603522740, 373697.2500741796684451 233681.3834674300451297, 373701.5374614266911522 233678.3926435940084048, 373705.6626988743664697 233675.1818597918318119, 373709.6145136032719165 233671.7598900413722731, 373713.3821066011441872 233668.1360854624363128, 373716.9551822734647430 233664.3203487230930477, 373720.3239765776088461 233660.3231069790199399, 373723.4792837048298679 233656.1552833794266917, 373726.4124812366790138 233651.8282672177592758, 373729.1155537074664608 233647.3538828085002024, 373731.5811145076295361 233642.7443571751064155, 373733.8024260689853691 233638.0122866376477759, 373735.7734182764543220 233633.1706023911829107, 373737.4887050554389134 233628.2325351690815296, 373738.9435990903875791 233623.2115790876850951, 373740.1341246336232871 233618.1214547714043874, 373741.0570283696870320 233612.9760718587203883, 373741.7097883056849241 233607.7894909917085897, 373742.0906206630170345 233602.5758853929000907, 373742.1984847519779578 233597.3495021346316207, 373742.0330858153756708 233592.1246232062694617, 373741.5948758341837674 233586.9155264864384662, 373740.8850522924331017 233581.7364467261068057, 373739.9055549047770910 233576.6015366498031653, 373738.6590603159856983 233571.5248282807588112, 373737.1489747864543460 233566.5201945960870944, 373735.3794248842168599 233561.6013116164249368, 373733.3552462080260739 233556.7816210339078680, 373654.0552462110645138 233380.9816210219287314, 373652.5153630711138248 233377.7256075733166654, 365392.9153630621149205 216697.2256075733166654, 365391.9598568481160328 216695.3460295358672738, 365331.8598568540764973 216580.1460295478464104, 365330.2477527938899584 216577.1791839415382128, 339880.6477527848910540 171569.1791839415382128, 339878.8843201125273481 171566.1832905930059496, 338824.6843201245646924 169844.3832905810268130, 338822.4769281532499008 169840.9383075150544755, 338820.1304613530519418 169837.5865048365958501, 338807.6304613530519418 169820.4865048425854184, 338807.5334730069153011 169820.3540531243779697, 337870.8334730038768612 168543.3540531243779697, 337867.0221279650577344 168538.4815600363945123, 337833.5221279650577344 168498.2815600333851762, 337830.6202818806632422 168494.9517117698851507, 337827.5742276740493253 168491.7532505890121683, 337824.3899077704991214 168488.6924162408104166, 337753.4899077645386569 168423.4924162378301844, 337751.3185027677100152 168421.5531549594015814, 337717.4185027767089196 168392.1531549684004858, 337714.5758644837187603 168389.7786549685988575, 337663.9758644747198559 168349.0786549655895215, 337659.8087246867362410 168345.9029646954732016, 337655.4809780826326460 168342.9498862957989331, 337651.0045043539139442 168340.2275259852758609, 337646.3915914490935393 168337.7433566600084305, 337530.7915914550540037 168279.3433566540188622, 337526.2029832758707926 168277.1696530297922436, 337521.5099571402533911 168275.2316596969612874, 337516.7246118161710910 168273.5343728628649842, 335388.0246118131908588 167578.8343728748441208, 335386.2942020931513980 167578.2869793250865769, 335315.7942020931513980 167556.6869793160876725, 335310.1989645521389320 167555.1487824073119555, 335304.5239261208334938 167553.9377201983297709, 335215.0239261208334938 167537.5377202073286753), (335197.0000000000000000 167635.9000000059895683, 335286.5000000000000000 167652.2999999969906639, 335357.0000000000000000 167673.9000000059895683, 337485.7000000029802322 168368.5999999940104317, 337601.2999999970197678 168427.0000000000000000, 337651.9000000060186721 168467.7000000030093361, 337685.7999999970197678 168497.0999999940104317, 337756.7000000029802322 168562.2999999969906639, 337790.2000000029802322 168602.5000000000000000, 338726.9000000060186721 169879.5000000000000000, 338739.4000000060186721 169896.5999999940104317, 339793.5999999939813279 171618.4000000059895683, 365243.2000000029802322 216626.4000000059895683, 365303.2999999970197678 216741.5999999940104317, 373562.9000000060186721 233422.0999999940104317, 373642.2000000029802322 233597.9000000059895683, 373629.5000000000000000 233598.0000000000000000, 373539.5999999939813279 233594.0999999940104317, 373503.5000000000000000 233590.0999999940104317, 371918.2999999970197678 233350.7999999969906639, 340256.9000000060186721 228463.7000000030093361, 303248.2999999970197678 222483.0000000000000000, 303245.7999999970197678 222443.0999999940104317, 303247.5000000000000000 222320.7999999969906639, 303273.7999999970197678 222024.9000000059895683, 303305.9000000060186721 221775.5000000000000000, 303342.2000000029802322 221596.7999999969906639, 303377.5999999939813279 221436.5999999940104317, 303407.7999999970197678 221300.4000000059895683, 303956.7999999970197678 219045.0999999940104317, 314320.4000000060186721 178991.5999999940104317, 314768.0999999939813279 178085.5000000000000000, 326477.0000000000000000 169031.4000000059895683, 326536.9000000060186721 168988.2999999969906639, 326658.5999999939813279 168919.5000000000000000, 326730.0999999939813279 168889.2999999969906639, 326778.0000000000000000 168869.2999999969906639, 329292.5000000000000000 168040.7000000030093361, 335197.0000000000000000 167635.9000000059895683)), POLYGON ((335197.0000000000000000 167635.9000000059895683, 329292.5000000000000000 168040.7000000030093361, 326778.0000000000000000 168869.2999999969906639, 326730.0999999939813279 168889.2999999969906639, 326658.5999999939813279 168919.5000000000000000, 326536.9000000060186721 168988.2999999969906639, 326477.0000000000000000 169031.4000000059895683, 314768.0999999939813279 178085.5000000000000000, 314320.4000000060186721 178991.5999999940104317, 303956.7999999970197678 219045.0999999940104317, 303407.7999999970197678 221300.4000000059895683, 303377.5999999939813279 221436.5999999940104317, 303342.2000000029802322 221596.7999999969906639, 303305.9000000060186721 221775.5000000000000000, 303273.7999999970197678 222024.9000000059895683, 303247.5000000000000000 222320.7999999969906639, 303245.7999999970197678 222443.0999999940104317, 303248.2999999970197678 222483.0000000000000000, 340256.9000000060186721 228463.7000000030093361, 371918.2999999970197678 233350.7999999969906639, 373503.5000000000000000 233590.0999999940104317, 373539.5999999939813279 233594.0999999940104317, 373629.5000000000000000 233598.0000000000000000, 373642.2000000029802322 233597.9000000059895683, 373562.9000000060186721 233422.0999999940104317, 365303.2999999970197678 216741.5999999940104317, 365243.2000000029802322 216626.4000000059895683, 339793.5999999939813279 171618.4000000059895683, 338739.4000000060186721 169896.5999999940104317, 338726.9000000060186721 169879.5000000000000000, 337790.2000000029802322 168602.5000000000000000, 337756.7000000029802322 168562.2999999969906639, 337685.7999999970197678 168497.0999999940104317, 337651.9000000060186721 168467.7000000030093361, 337601.2999999970197678 168427.0000000000000000, 337485.7000000029802322 168368.5999999940104317, 335357.0000000000000000 167673.9000000059895683, 335286.5000000000000000 167652.2999999969906639, 335197.0000000000000000 167635.9000000059895683)))
-LineMerge: GEOMETRYCOLLECTION EMPTY
-Intersect
-Contains
-Distance: 0
-Area 1: 2.67588e+09
-Area 2: 2.65405e+09
-Simplify: POLYGON ((335215.0239261208334938 167537.5377202073286753, 335205.1267784655792639 167536.2307696900388692, 335190.1602671957225539 167536.1341839407396037, 329275.7395326890982687 167942.1145713863952551, 329261.2026209282921627 167945.7238237099954858, 326746.7026209282921627 168774.3238237039768137, 326614.4661321343737654 168829.7659389766049571, 326483.0105803586193360 168904.0626540626399219, 326415.8285449087852612 168952.2921427348919678, 314706.9285449027665891 178006.3921427289023995, 314699.2775538869318552 178012.9502176995156333, 314692.3254273570491932 178020.2450067681784276, 314686.1427613845444284 178028.2024342618533410, 314680.7923384761670604 178036.7416956787055824, 314230.7465425680857152 178947.3026234415883664, 314226.6719709816970862 178956.7423383510031272, 314223.5882016817340627 178966.5505348258011509, 303859.9882016727351584 219020.0505348258011509, 303310.6373324339510873 221276.7480226673360448, 303244.5555483103962615 221575.2231361457088497, 303207.9014352059457451 221755.5931846564926673, 303174.1926699578762054 222016.0467631698702462, 303147.8926699608564377 222311.9467631608713418, 303145.8096594382659532 222441.7101097303093411, 303148.4957166555686854 222489.2534012109390460, 303150.6692645543371327 222504.6388423194293864, 303153.4334335363237187 222514.6280661432247143, 303157.2167087217676453 222524.2775247619138099, 303161.9784481927636079 222533.4835586513218004, 303167.6674988568993285 222542.1472717873693909, 303174.2227459607529454 222550.1755940386210568, 303181.5737696161959320 222557.4822809745091945, 303189.6416012879926711 222563.9888403478544205, 303198.3395721145207062 222569.6253752996271942, 303212.3620380503707565 222576.3191453621548135, 303222.2142427377984859 222579.5377297651721165, 303232.3466742536984384 222581.7192554557113908, 340240.9466742626973428 228562.4192554587207269, 371903.0451431074179709 233449.6295974932727404, 373488.5732348550227471 233688.9796828530670609, 373535.2659228414413519 233694.0060347228136379, 373625.1659228474600241 233697.9060347288323101, 373642.9873771221027710 233697.8969001443183515, 373658.5972774084657431 233696.5464864801033400, 373668.8035941756097600 233694.2963110199489165, 373678.7193140533054247 233690.9931775288132485, 373692.8122531549306586 233684.1461583603522740, 373705.6626988743664697 233675.1818597918318119, 373713.3821066011441872 233668.1360854624363128, 373723.4792837048298679 233656.1552833794266917, 373731.5811145076295361 233642.7443571751064155, 373737.4887050554389134 233628.2325351690815296, 373741.0570283696870320 233612.9760718587203883, 373742.1984847519779578 233597.3495021346316207, 373741.5948758341837674 233586.9155264864384662, 373738.6590603159856983 233571.5248282807588112, 373733.3552462080260739 233556.7816210339078680, 373652.5153630711138248 233377.7256075733166654, 365392.9153630621149205 216697.2256075733166654, 365330.2477527938899584 216577.1791839415382128, 339880.6477527848910540 171569.1791839415382128, 338822.4769281532499008 169840.9383075150544755, 337870.8334730038768612 168543.3540531243779697, 337827.5742276740493253 168491.7532505890121683, 337753.4899077645386569 168423.4924162378301844, 337717.4185027767089196 168392.1531549684004858, 337663.9758644747198559 168349.0786549655895215, 337651.0045043539139442 168340.2275259852758609, 337530.7915914550540037 168279.3433566540188622, 337516.7246118161710910 168273.5343728628649842, 335388.0246118131908588 167578.8343728748441208, 335310.1989645521389320 167555.1487824073119555, 335215.0239261208334938 167537.5377202073286753))
Deleted: trunk/capi/test.wkt
--- trunk/capi/test.wkt 2009-01-05 23:42:08 UTC (rev 2231)
+++ trunk/capi/test.wkt 2009-01-13 01:21:05 UTC (rev 2232)
@@ -1 +0,0 @@
-MULTIPOLYGON(((362062.200000003 231744,362076 231749.799999997,362122.299999997 231753.5,362187 231767.900000006,362242 231776,362296.200000003 231786.700000003,362517 231821.5,362651.799999997 231844.799999997,362772.700000003 231871.799999997,362805.099999994 231874.299999997,362847.200000003 231876,362912.799999997 231888.900000006,363005.900000006 231903,363169.200000003 231929.299999997,363247.900000006 231934,363333.900000006 231950,363516.099999994 231985.5,363630.299999997 232004.700000003,363694.700000003 232012,363754 232021.099999994,363833.400000006 232029.799999997,363913.599999994 232048.5,363940.599999994 232052,364014.799999997 232060.299999997,364044.700000003 232065.799999997,364082.700000003 232074.099999994,364165.299999997 232083.799999997,364208.599999994 232097.099999994,364279.799999997 232104,364316.700000003 232112.799999997,364331.200000003 232113.599999994,364391.200000003 232127.599999994,364483.799999997 232140,364606.799999997 232159.599999994,364662.799999997 232170.599999994,364712.900000006 232182.700000003,364823.799999997 232201.5,364904.900000006 232211,364967.200000003 232221.099999994,365061.299999997 232240.5,365191.099999994 232255.900000006,365262.900000006 232262.299999997,365391.700000003 232283.599999994,365525.299999997 232308.900000006,365598.400000006 232326.599999994,365727.099999994 232341.599999994,365803 232352.299999997,365935.400000006 232377.599999994,366011.5 232384.799999997,366056.099999994 232391.200000003,366128.700000003 232407.400000006,366295.599999994 232442.700000003,366445.200000003 232457.200000003,366624.799999997 232486.299999997,366663.200000003 232490.200000003,366707.200000003 232502.400000006,366807.099999994 232522.700000003,366862.900000006 232529.799999997,366971.099999994 232543.5,367088.099999994 232563.099999994,367185.299999997 232575.400000006,367222.200000003 232582.400000006,367331.799999997 232597,367530.299999997 232629.799999997,367683.599999994 232660.700000003,367772.599999994 232675.799999997,367939 232693.099999994,367995.599999994 232701,368055.099999994 232702.599999994,368135 232714.299999997,368220.799999997 232735.400000006,368312.599999994 232753.400000006,368380.799999997 232770.799999997,368447.299999997 232777.599999994,368512.099999994 232792.099999994,368544 232795.599999994,368601.799999997 232805.099999994,368660.799999997 232813.099999994,368707.299999997 232826.400000006,368782.5 232836.099999994,368832.599999994 232847.799999997,368906.599999994 232860.5,368992.5 232873.099999994,369089.099999994 232892,369260.5 232916.700000003,369318.700000003 232931.200000003,369445.599999994 232945.599999994,369508.700000003 232950.099999994,369574.200000003 232960.5,369616.099999994 232967.799999997,369656.200000003 232978.200000003,369717.700000003 233002,369777.700000003 233016.099999994,369875.400000006 233024,370035 233046.900000006,370117.099999994 233056,370200.099999994 233077.599999994,370233.599999994 233079.099999994,370496.900000006 233123.299999997,370539.400000006 233127,370601.700000003 233135,370655.299999997 233146.599999994,370855.099999994 233178.799999997,370932.700000003 233182.099999994,371060.099999994 233205,371120.700000003 233223,371178.599999994 233233,371201.799999997 233229.200000003,371245.299999997 233232.5,371289.900000006 233243.700000003,371425.799999997 233259,371487.5 233276.400000006,371552.299999997 233291.900000006,371638.099999994 233306.400000006,371715.099999994 233318.599999994,371821.200000003 233332.400000006,371918.299999997 233350.799999997,371988.099999994 233360.200000003,372040.700000003 233366.299999997,372158.599999994 233382.299999997,372175.5 233379.599999994,372201.099999994 233382.599999994,372351.299999997 233410.099999994,372419 233417.5,372500.799999997 233432.200000003,372538.700000003 233434.099999994,372559.299999997 233439.200000003,372715.799999997 233463.599999994,372780.900000006 233472.099999994,372809.599999994 233479.599999994,372842.900000006 233484,372895.900000006 233498.099999994,372959.799999997 233506.099999994,372967.799999997 233500.5,372986.099999994 233503.700000003,373016.200000003 233511.599999994,373076.5 233519.700000003,373115.5 233524.5,373133.900000006 233529.700000003,373218.799999997 233538.900000006,373322.599999994 233555.200000003,373403.900000006 233574.799999997,373503.5 233590.099999994,373539.599999994 233594.099999994,373567.700000003 233595.099999994,373612.900000006 233595.299999997,373629.5 233598,373642.200000003 233597.900000006,373633.799999997 233582.099999994,373623.799999997 233570.200000003,373584.099999994 233479.200000003,373562.900000006 233422.099999994,373549.099999994 233399,373506.799999997 233325.799999997,373487.299999997 233294.200000003,373460.200000003 233259.799999997,373442.099999994 233240.099999994,373426.700000003 233220,373405.400000006 233187.299999997,373383.099999994 233164.799999997,373333.599999994 233096.700000003,373325.5 233078.5,373298.299999997 233028.599999994,373269.299999997 232982.599999994,373220.099999994 232893.200000003,373190.799999997 232853.700000003,373145.400000006 232784.700000003,373100.900000006 232712,373090.400000006 232680.299999997,373077.599999994 232660.099999994,373046.400000006 232597.299999997,373028.900000006 232538.200000003,373012.400000006 232520,373002.5 232506.299999997,372997.299999997 232499.900000006,372979.900000006 232471.799999997,372966.5 232452.400000006,372963.099999994 232436.099999994,372925.200000003 232361.5,372900 232326.400000006,372885.700000003 232295.200000003,372849.700000003 232245,372803.299999997 232173.799999997,372764.900000006 232096.200000003,372735.200000003 232063.299999997,372710.900000006 232032.200000003,372692.5 232004.700000003,372691.900000006 231988.700000003,372680 231952,372658.599999994 231917,372655.599999994 231898,372629.799999997 231847.099999994,372609.799999997 231810.599999994,372589.299999997 231778,372571 231743.400000006,372549.400000006 231706.700000003,372536.900000006 231677.099999994,372497.900000006 231600.400000006,372476.799999997 231562.900000006,372467.599999994 231529.099999994,372455 231502.400000006,372444.299999997 231467.700000003,372431 231419.5,372394.5 231364.299999997,372379 231339.5,372355 231312.599999994,372344.099999994 231286.299999997,372307.799999997 231214,372292.099999994 231194.900000006,372274.5 231145.299999997,372260.099999994 231120.599999994,372226.299999997 231083.299999997,372194.299999997 231041.400000006,372136.400000006 230959.099999994,372112.799999997 230922.5,372065.599999994 230841.599999994,372054 230818.299999997,372031.700000003 230784.299999997,372014.700000003 230735.599999994,371990.400000006 230694.200000003,371950.799999997 230628.400000006,371931.700000003 230578.900000006,371890.900000006 230511.299999997,371874.900000006 230494.5,371861.400000006 230513.700000003,371858 230493.400000006,371846.099999994 230455.099999994,371828.099999994 230407.5,371813.299999997 230374.799999997,371787.799999997 230316.5,371751.299999997 230262.700000003,371731.5 230213.700000003,371699.200000003 230171.799999997,371679.299999997 230125.200000003,371656.599999994 230095.599999994,371621.400000006 230055.400000006,371584.299999997 229987.700000003,371550.099999994 229912.5,371526.900000006 229867.400000006,371504.799999997 229838.799999997,371485.599999994 229801.799999997,371475.5 229778,371461.400000006 229752.200000003,371440.700000003 229706.799999997,371400.799999997 229629.099999994,371372.400000006 229581.599999994,371349.400000006 229546.599999994,371312.299999997 229480.400000006,371296.200000003 229454.299999997,371274.900000006 229432.099999994,371253.099999994 229396.099999994,371224.5 229358.099999994,371185.5 229294,371153.299999997 229239.700000003,371066.400000006 229032.700000003,371027.5 228966.900000006,371004.799999997 228913,370991 228890.200000003,370938.099999994 228790.400000006,370919.299999997 228762.799999997,370884.299999997 228707.400000006,370840 228630.900000006,370797.200000003 228558.299999997,370722.5 228398.900000006,370677.200000003 228323.299999997,370655.5 228268.299999997,370635 228228.799999997,370577.799999997 228117.599999994,370556.900000006 228088.400000006,370533.599999994 228047.900000006,370511.299999997 228025.299999997,370485.200000003 227994.799999997,370435.799999997 227946.299999997,370399.799999997 227881.099999994,370342.599999994 227793.200000003,370316.400000006 227755.299999997,370239.599999994 227614.799999997,370195 227565.200000003,370123.299999997 227431.200000003,370067 227353.900000006,370025.5 227277.700000003,369958.5 227171.5,369938.799999997 227130.5,369892.799999997 227050.5,369876.799999997 227022.799999997,369837.799999997 226970.5,369820.799999997 226933,369782.400000006 226859.799999997,369762.099999994 226819.200000003,369739.099999994 226782.200000003,369713.099999994 226749.200000003,369686.5 226704.700000003,369642.400000006 226620.099999994,369596.200000003 226546.099999994,369578.5 226510.5,369541.400000006 226455.200000003,369519 226397.200000003,369476.799999997 226327.099999994,369435.599999994 226235.599999994,369404.900000006 226135.299999997,369367.400000006 226063.099999994,369353.799999997 226024,369316.900000006 225937.799999997,369292.900000006 225899.799999997,369258.799999997 225837.5,369226.099999994 225790.599999994,369191.900000006 225739.900000006,369169.700000003 225702.799999997,369136.799999997 225661.900000006,369115.5 225641.799999997,368998.099999994 225443.299999997,368960.200000003 225358.599999994,368890.799999997 225224.599999994,368812.799999997 225025.900000006,368771.700000003 224939.299999997,368741.900000006 224859.900000006,368701.400000006 224765.900000006,368679.099999994 224703.400000006,368637.099999994 224627.299999997,368616.700000003 224565.799999997,368592.799999997 224525.299999997,368547.5 224416.799999997,368528 224383.799999997,368468.599999994 224270,368457.200000003 224234.200000003,368445.099999994 224206,368404.400000006 224140.400000006,368387 224066.900000006,368348.799999997 223972.200000003,368324.599999994 223901.299999997,368299.099999994 223849.299999997,368281.099999994 223819.200000003,368249.700000003 223748.400000006,368221.799999997 223704,368187.099999994 223625.799999997,368163.599999994 223575.799999997,368139.799999997 223508.400000006,368111.099999994 223455.5,368083.900000006 223370.599999994,368056 223315.700000003,368028.700000003 223248.799999997,368011 223201.700000003,367981.799999997 223133.900000006,367963.400000006 223102.799999997,367932.099999994 223056.400000006,367903.299999997 222978.599999994,367852.099999994 222807.400000006,367820.599999994 222727.099999994,367790.099999994 222635.400000006,367757.799999997 222557.599999994,367742.400000006 222516,367708.200000003 222426.299999997,367660.200000003 222299.900000006,367625.799999997 222225.599999994,367591.700000003 222159.400000006,367561.299999997 222093.5,367502.200000003 221924.400000006,367472.900000006 221842.599999994,367458.5 221819.400000006,367427.700000003 221735.700000003,367385 221624.099999994,367360.5 221574.200000003,367326 221490,367290.299999997 221393.299999997,367271.200000003 221339.700000003,367244.099999994 221268.799999997,367237.299999997 221245.900000006,367214 221194,367200.400000006 221137.900000006,367162.299999997 221044.700000003,367147.099999994 220987.099999994,367117.799999997 220919.299999997,367102.799999997 220894.099999994,367073.599999994 220814.799999997,367023.400000006 220673,366980.099999994 220598.299999997,366962.099999994 220558.799999997,366905.799999997 220454.400000006,366882.400000006 220416.900000006,366857 220370.5,366824.400000006 220272.799999997,366787.599999994 220128.700000003,366743.900000006 220049.200000003,366730.5 220013,366694.799999997 219922.400000006,366668.299999997 219845.400000006,366642.299999997 219788.5,366621 219728.5,366602 219663.5,366578.299999997 219606.599999994,366570.700000003 219575.700000003,366551.599999994 219513.200000003,366507.5 219429.599999994,366492 219386,366458.400000006 219301.200000003,366426.700000003 219211,366392.900000006 219139.200000003,366373.099999994 219087.200000003,366316.599999994 218974.400000006,366294.799999997 218940.799999997,366260.799999997 218889.5,366214.299999997 218764.099999994,366187.599999994 218662.400000006,366165 218615.799999997,366128.799999997 218519.200000003,366086.900000006 218417.599999994,366068.799999997 218378,366035 218307.200000003,366012.200000003 218231.799999997,365984.700000003 218153.400000006,365950.200000003 218060.799999997,365922.099999994 218017.799999997,365903.400000006 217982.200000003,365835.200000003 217851.099999994,365798.5 217801.900000006,365728.400000006 217660.299999997,365673.200000003 217559,365657.5 217511.400000006,365636.900000006 217461.900000006,365589.299999997 217352.400000006,365560.700000003 217312,365525.200000003 217245.299999997,365480.900000006 217133.200000003,365442.5 217056.599999994,365405.900000006 216955.5,365379.200000003 216908,365341.200000003 216825.799999997,365319.200000003 216784.299999997,365303.299999997 216741.599999994,365259.299999997 216668,365243.200000003 216626.400000006,365206.900000006 216581.099999994,365172.5 216521.799999997,365148.700000003 216481.799999997,365127.200000003 216438.799999997,365081.299999997 216365.200000003,365054.5 216305.299999997,365045.099999994 216300,365042.400000006 216280.599999994,365035 216259.299999997,365022.900000006 216243.5,365011.799999997 216224.200000003,364987.599999994 216190.200000003,364980.900000006 216167.299999997,364958.299999997 216136.799999997,364941.799999997 216095.700000003,364917.799999997 216058.200000003,364883.299999997 216007.799999997,364861.200000003 215961.299999997,364850.299999997 215946,364833.799999997 215915.900000006,364803.700000003 215856,364770 215806.200000003,364714.700000003 215744.799999997,364702.599999994 215717,364679.599999994 215672.900000006,364650.799999997 215618,364631.799999997 215591.5,364601.099999994 215554.5,364583.799999997 215510.900000006,364568.599999994 215482.200000003,364521.5 215423.099999994,364479.200000003 215387,364413.200000003 215308.200000003,364385.200000003 215279.200000003,364366.200000003 215262.599999994,364336.400000006 215230.099999994,364285 215148.700000003,364246.299999997 215118.299999997,364224.599999994 215094.299999997,364190.099999994 215058.900000006,364165.099999994 215030.400000006,364125.799999997 214999.599999994,364103.599999994 214973,364053.599999994 214926,364011.799999997 214890.700000003,363965.5 214853.5,363920.700000003 214801.900000006,363876.5 214769.700000003,363806.299999997 214703.5,363766.700000003 214674.200000003,363747.799999997 214657,363681.700000003 214592.299999997,363620.5 214559.799999997,363580.299999997 214535.5,363530.599999994 214496.400000006,363510.299999997 214495.700000003,363474.900000006 214488.799999997,363430.5 214476.5,363381.099999994 214465.299999997,363316.5 214466.400000006,363252.599999994 214461.400000006,363156.700000003 214466.400000006,363090.799999997 214484.299999997,363077.5 214493.5,363067.099999994 214497.200000003,363040 214500.200000003,362914.599999994 214528.5,362870.200000003 214553.099999994,362846.299999997 214560.599999994,362828.400000006 214561.900000006,362827 214572.799999997,362814 214577.5,362776.5 214595.599999994,362765.400000006 214599.200000003,362667.900000006 214651.599999994,362630.299999997 214667.700000003,362576.099999994 214694,362543.299999997 214725.400000006,362511.900000006 214750.900000006,362478 214757.400000006,362379.299999997 214796.799999997,362260.299999997 214866.5,362127.099999994 214946.799999997,362023.900000006 215017.299999997,361984.099999994 215042.400000006,361890.5 215113.700000003,361777.599999994 215181.799999997,361710.099999994 215233.799999997,361692.400000006 215248.400000006,361671.700000003 215256.700000003,361597.900000006 215286.900000006,361502.5 215343.700000003,361472 215357.200000003,361423.700000003 215382.799999997,361259.200000003 215487.700000003,361226.599999994 215505.700000003,361191.599999994 215527.700000003,361118.700000003 215568.299999997,360996.099999994 215603.5,360963.900000006 215608.5,360927.799999997 215621.5,360842.799999997 215661.900000006,360789.599999994 215691,360754.099999994 215720.099999994,360727.200000003 215747.400000006,360701.799999997 215765.799999997,360660.5 215812.900000006,360654.299999997 215825.900000006,360615.299999997 215860.900000006,360579.299999997 215885,360488.200000003 215951.200000003,360455.400000006 215982.099999994,360441.200000003 216003.799999997,360437.700000003 216052.200000003,360418.299999997 216065,360341.099999994 216078.599999994,360322 216078.5,360150.700000003 216078.200000003,359950.599999994 216070.400000006,359871.299999997 216067.200000003,359804.900000006 216063.799999997,359732.799999997 216061.299999997,359707.200000003 216057.299999997,359633.799999997 216055.400000006,359624.400000006 216048.599999994,359625.900000006 216033.599999994,359629 216003.700000003,359644.599999994 215957.599999994,359657.400000006 215924.900000006,359666.5 215890.900000006,359668.400000006 215838.400000006,359654 215798.299999997,359637.700000003 215765.599999994,359599 215719.400000006,359511.299999997 215645.5,359472.400000006 215625.599999994,359428.099999994 215611.400000006,359380.900000006 215602.700000003,359323.5 215606.599999994,359253 215621.700000003,359209.900000006 215664.700000003,359166.5 215718.700000003,359135.799999997 215767.700000003,359093.599999994 215819.700000003,359042.400000006 215891.700000003,359013.299999997 215925.700000003,358938.299999997 215980.099999994,358873.599999994 216000.700000003,358766.200000003 216007.900000006,358736.299999997 216003.799999997,358607.900000006 215998.900000006,358535.5 216001,358492.400000006 215997.200000003,358428 215997.200000003,358369.599999994 215995.700000003,358258.400000006 215994,358108 215982.299999997,357988.299999997 215983.200000003,357948.200000003 215980.900000006,357892 215980.799999997,357883.299999997 215978,357866.400000006 215979.200000003,357825.299999997 215971.400000006,357798.299999997 215947.299999997,357769.299999997 215922.299999997,357739.200000003 215886.5,357707.900000006 215864,357645.799999997 215826.599999994,357580.599999994 215805.700000003,357556.299999997 215796.099999994,357522.700000003 215787.599999994,357488.900000006 215777.299999997,357361.5 215746.299999997,357308.200000003 215729.200000003,357270.599999994 215713.900000006,357247.700000003 215699.799999997,357230.200000003 215689.599999994,357198.400000006 215674.099999994,357158.5 215656.799999997,357139.400000006 215647.599999994,357090.099999994 215625.400000006,357061 215606,357024.799999997 215585,356976.700000003 215540.900000006,356959.799999997 215519.299999997,356924.299999997 215495.900000006,356863.900000006 215441,356847.400000006 215434.299999997,356827.299999997 215423.099999994,356801.400000006 215401.099999994,356769.099999994 215372.200000003,356726.200000003 215341.400000006,356698.599999994 215325.5,356639.700000003 215286,356586.099999994 215239.5,356520 215173.700000003,356487.900000006 215140.299999997,356460.099999994 215110.700000003,356416.200000003 215058.099999994,356396.200000003 215039.5,356363 215005.599999994,356287.200000003 214938.5,356251.5 214906.099999994,356155.799999997 214810.900000006,356106.799999997 214766.799999997,355999.700000003 214667.700000003,355956.299999997 214633,355922 214604.599999994,355896.700000003 214583,355879.599999994 214565,355815.900000006 214515.099999994,355791.400000006 214485.5,355781.200000003 214480.200000003,355783.5 214472.599999994,355756.400000006 214447.200000003,355703.599999994 214373.799999997,355649.799999997 214316.200000003,355633.799999997 214298.5,355606.400000006 214267,355576.400000006 214229.599999994,355565 214217.299999997,355524.700000003 214182,355492.099999994 214141.700000003,355431.700000003 214075.799999997,355412.599999994 214056.700000003,355382.200000003 214028.200000003,355344.599999994 213994.400000006,355296.900000006 213940.799999997,355261.299999997 213908.900000006,355237.5 213876.400000006,355212.599999994 213844.299999997,355182.299999997 213811.400000006,355151.299999997 213757,355117.900000006 213724.200000003,355114.599999994 213715.799999997,355102.599999994 213703,355084.900000006 213673.799999997,355062.200000003 213654.799999997,355051.599999994 213640,355001.700000003 213589.900000006,355002.5 213576.900000006,354978.799999997 213553.400000006,354926.599999994 213487.900000006,354892.599999994 213432,354877.400000006 213414.299999997,354800.900000006 213315.200000003,354747.799999997 213259.299999997,354662.799999997 213136.400000006,354613.200000003 213069.299999997,354552.299999997 212996.5,354491.900000006 212928.099999994,354444.700000003 212858.599999994,354436.599999994 212851.200000003,354404.299999997 212798.900000006,354393.299999997 212790.099999994,354374.900000006 212772,354260.099999994 212618.099999994,354242 212583.5,354214.5 212556,354161.799999997 212490.599999994,354133.099999994 212448.599999994,354112.5 212416.5,354096.700000003 212404.299999997,354078.599999994 212384.599999994,354063.299999997 212363.5,354057.200000003 212342.099999994,354032.799999997 212313.5,354029.799999997 212300.599999994,353984.799999997 212246.5,353954.700000003 212221.5,353943.5 212207.200000003,353925.799999997 212184.5,353923.299999997 212167.200000003,353906.299999997 212149.900000006,353895.299999997 212132.700000003,353885.799999997 212113.799999997,353872.700000003 212104.599999994,353840.400000006 212061.799999997,353825.599999994 212045,353810.900000006 212021.299999997,353715.599999994 211903.700000003,353694.400000006 211872.099999994,353665.099999994 211831.599999994,353618.5 211776.900000006,353575.299999997 211713.799999997,353539.599999994 211678,353527.099999994 211661.200000003,353469.599999994 211595.799999997,353462 211575,353432.099999994 211538.099999994,353408.700000003 211500,353380.599999994 211457.5,353357 211426.5,353348.700000003 211410.700000003,353310.299999997 211358.900000006,353277.400000006 211317.5,353251.299999997 211272,353232.700000003 211244.400000006,353221.5 211230.599999994,353201.200000003 211201.5,353131 211097.400000006,353084.299999997 211045.799999997,353078.200000003 211033,353029.700000003 210970.400000006,353015.099999994 210947.200000003,353003.700000003 210934.799999997,352988.299999997 210915.700000003,352967.400000006 210878,352925.799999997 210816.400000006,352893 210747.599999994,352860.400000006 210698.200000003,352823.799999997 210635.5,352781.700000003 210565.900000006,352762.599999994 210546.700000003,352728 210503.400000006,352690.5 210446.5,352674.400000006 210429.900000006,352670 210419.5,352663.799999997 210413.099999994,352635.799999997 210358.200000003,352535.700000003 210213.700000003,352493.900000006 210170.400000006,352470.700000003 210140.900000006,352445.700000003 210099.900000006,352427.5 210066.200000003,352382.299999997 209981.200000003,352368.5 209965.900000006,352359.099999994 209939.599999994,352331.099999994 209892.700000003,352299.299999997 209856.299999997,352258.700000003 209851.400000006,352226.5 209815,352217.5 209803.200000003,352199.700000003 209760.599999994,352153.900000006 209689.5,352140.099999994 209666.299999997,352108.599999994 209619,352087.200000003 209578.400000006,352043.900000006 209503.299999997,352039.900000006 209481.299999997,352033.900000006 209464.5,352016.700000003 209458.799999997,352002.799999997 209447.099999994,351981.200000003 209410.400000006,351965.400000006 209386.700000003,351959.099999994 209368.400000006,351952.700000003 209354.099999994,351949.400000006 209335.700000003,351959.5 209322,351945.200000003 209310.799999997,351931.900000006 209286.599999994,351924.299999997 209269.700000003,351879.799999997 209172.200000003,351872.099999994 209156.299999997,351854.799999997 209130.200000003,351833.799999997 209081.200000003,351814.299999997 209049.5,351807.299999997 209017.200000003,351805.299999997 208997.799999997,351800.099999994 208972.400000006,351788 208948.700000003,351769.799999997 208923.5,351737.599999994 208896.599999994,351719.700000003 208862.5,351668.5 208798,351647.799999997 208777.799999997,351622.799999997 208745.400000006,351593.400000006 208671.5,351565.799999997 208633.099999994,351548.900000006 208607.400000006,351533.599999994 208587.700000003,351507.099999994 208526.700000003,351483.599999994 208493.599999994,351473.200000003 208472.900000006,351444.599999994 208419,351420 208394.5,351395.799999997 208356.400000006,351354.299999997 208306.200000003,351330.700000003 208260.200000003,351323 208236.900000006,351312.099999994 208223.099999994,351284.700000003 208184.700000003,351269.299999997 208153.900000006,351253.900000006 208135.299999997,351246.900000006 208120.400000006,351235.700000003 208102,351220 208066.900000006,351188.200000003 208028.599999994,351158.299999997 207975.099999994,351134.299999997 207936.099999994,351106.900000006 207910.099999994,351083.799999997 207887,351028.200000003 207819.599999994,351017.799999997 207801.799999997,350968.299999997 207727.799999997,350952.599999994 207693.099999994,350914.900000006 207638.299999997,350885.799999997 207584,350836 207520.400000006,350802.299999997 207459,350778.599999994 207427.5,350740.5 207359.900000006,350707.799999997 207312.400000006,350676.400000006 207266.099999994,350658.799999997 207244,350642.900000006 207212.200000003,350621.5 207161.200000003,350612 207144.900000006,350597.299999997 207114.200000003,350573.900000006 207063.799999997,350548.700000003 207024.200000003,350510.599999994 206945.5,350490.700000003 206918.799999997,350470.900000006 206883.799999997,350448.700000003 206833.799999997,350438 206803,350419.299999997 206768.400000006,350396.299999997 206737.400000006,350307.700000003 206541.799999997,350278.299999997 206492.299999997,350264.700000003 206447.599999994,350245.200000003 206420.099999994,350239.200000003 206393.700000003,350225.400000006 206355.099999994,350203.799999997 206318.400000006,350191.799999997 206281.799999997,350170.299999997 206242.700000003,350139.700000003 206161.799999997,350116.200000003 206120.299999997,350101.900000006 206062.200000003,350095.099999994 206017.900000006,350076.299999997 205961.400000006,350067.299999997 205922.099999994,350059 205906.299999997,350034.5 205833.799999997,350002 205734.700000003,349994.700000003 205699.299999997,349981.099999994 205653.599999994,349971.599999994 205630.900000006,349946.5 205574.299999997,349921.200000003 205527.400000006,349880.200000003 205445.299999997,349855.5 205409.299999997,349843.700000003 205381.5,349826.5 205338.400000006,349812.5 205318.700000003,349796.099999994 205294.5,349791.299999997 205267.599999994,349783.400000006 205237.299999997,349785.599999994 205189.5,349787.5 205149.900000006,349793.799999997 205129.400000006,349804.700000003 205105.799999997,349807.200000003 205080.900000006,349789.099999994 205031.299999997,349773.299999997 204995.5,349754.299999997 204967,349734 204914.900000006,349710.799999997 204872.299999997,349694.099999994 204833.200000003,349681 204808.5,349660.299999997 204758.900000006,349639.299999997 204711.5,349627 204694.200000003,349598.400000006 204651.700000003,349558.099999994 204591,349538.700000003 204553.900000006,349515.900000006 204519.400000006,349492.5 204467.299999997,349480.5 204430.099999994,349481.799999997 204403.700000003,349495 204367.599999994,349503.200000003 204334.599999994,349510.599999994 204280,349497.599999994 204248.799999997,349474.799999997 204224.299999997,349446.099999994 204199.799999997,349390.299999997 204161.299999997,349339.700000003 204111.700000003,349275.700000003 204003.200000003,349229.400000006 203905.900000006,349207.900000006 203842.700000003,349184.900000006 203794.400000006,349161.299999997 203725.299999997,349151.400000006 203692.799999997,349129.099999994 203631,349101.799999997 203550.799999997,349078.799999997 203504.099999994,349046.299999997 203443.799999997,349010.700000003 203349.299999997,349006.299999997 203325.700000003,348989 203263.599999994,348975.099999994 203228.700000003,348936.900000006 203132.5,348893.400000006 202993.299999997,348874.900000006 202924.200000003,348827.400000006 202790.299999997,348795.099999994 202738,348778.599999994 202708.799999997,348734 202608.5,348714.799999997 202559.400000006,348681.900000006 202471.400000006,348664.900000006 202410.299999997,348647.799999997 202366.5,348607.599999994 202268.900000006,348603.299999997 202260.200000003,348573.700000003 202189.099999994,348561.799999997 202157.299999997,348554.099999994 202129.700000003,348541.200000003 202100.799999997,348538.700000003 202088.099999994,348533.400000006 202062.5,348529.099999994 202051.700000003,348517.700000003 202010.599999994,348500.099999994 201994.900000006,348493.700000003 201986.599999994,348474.5 201949.299999997,348468.700000003 201906.599999994,348455 201870.299999997,348437.700000003 201827.900000006,348416.799999997 201787,348409.799999997 201770.400000006,348373.400000006 201718.900000006,348369.299999997 201703,348361.5 201684.400000006,348366.799999997 201670.200000003,348357.700000003 201646.599999994,348347.599999994 201624,348337.799999997 201601.299999997,348328.799999997 201591.900000006,348305.400000006 201501,348280.200000003 201448.799999997,348274 201440.400000006,348256.799999997 201412.599999994,348222.400000006 201350.700000003,348209.200000003 201327.900000006,348179.799999997 201279,348154.700000003 201235,348149.900000006 201212.700000003,348140.599999994 201190.700000003,348121.099999994 201148,348111.200000003 201129.5,348103.599999994 201097,348097 201022.5,348083.5 200995.5,348047.599999994 200940.799999997,348027.099999994 200916.400000006,347997.599999994 200894.400000006,347951.799999997 200833.299999997,347933.400000006 200791.700000003,347929.799999997 200765.599999994,347913 200717.599999994,347886.799999997 200685.700000003,347875.200000003 200667.900000006,347838.799999997 200623.299999997,347815.400000006 200583.799999997,347804.799999997 200567.599999994,347798.400000006 200547.900000006,347781.799999997 200509.299999997,347760.700000003 200484.200000003,347732.599999994 200444.299999997,347703.400000006 200392.599999994,347686.099999994 200363.099999994,347665.299999997 200341.700000003,347626.799999997 200296.299999997,347589.200000003 200263.599999994,347531.900000006 200206.700000003,347505 200189.700000003,347455.599999994 200145.299999997,347435.700000003 200129.900000006,347389 200102,347283.900000006 200050,347184.299999997 200008.400000006,347141.099999994 199982.200000003,347094.400000006 199954.5,347081.900000006 199936,347065 199901.5,347060.299999997 199886.900000006,347052 199860.400000006,347041 199814.400000006,347037.400000006 199800.200000003,347039.799999997 199787.700000003,347034.5 199753.400000006,347017.299999997 199708.5,346992.799999997 199693.400000006,346979.799999997 199674.200000003,346976.299999997 199635.5,346957.5 199602.200000003,346928.099999994 199553.299999997,346912.599999994 199523.900000006,346898.799999997 199497.200000003,346891.799999997 199472.099999994,346883.400000006 199455.5,346872.200000003 199416.5,346854.400000006 199384.400000006,346849.200000003 199371.099999994,346831.700000003 199346.200000003,346822.799999997 199319,346804.900000006 199292.400000006,346778.5 199226.299999997,346769.799999997 199211.5,346751.799999997 199158.599999994,346733.700000003 199123,346717.799999997 199091,346701.799999997 199060.700000003,346685.599999994 199036.900000006,346682.700000003 199019.5,346677.900000006 199009.599999994,346672.5 198996.799999997,346657.299999997 198960.5,346640 198874.799999997,346638.200000003 198824.5,346633.5 198808.299999997,346625.200000003 198758.599999994,346619.700000003 198743.900000006,346610.599999994 198709.900000006,346588 198658.200000003,346571.5 198627.200000003,346561 198615.900000006,346546.299999997 198587.799999997,346532.900000006 198544.299999997,346526.799999997 198533.200000003,346524.200000003 198521.5,346509.900000006 198481.900000006,346504.299999997 198448.5,346477 198369.099999994,346472.5 198338.700000003,346472.299999997 198315.400000006,346473.400000006 198277.400000006,346464.400000006 198268.599999994,346444 198217,346428.900000006 198158.700000003,346428.700000003 198125.799999997,346432.200000003 198103.5,346447.400000006 198074.299999997,346443.700000003 198060.700000003,346433.900000006 198028.700000003,346412.299999997 198003.799999997,346399.200000003 197987.799999997,346393.599999994 197971.900000006,346390.200000003 197941.599999994,346396.900000006 197911.799999997,346401.5 197880.200000003,346416.5 197832.200000003,346433.5 197790.700000003,346449.799999997 197751.900000006,346467.700000003 197704.299999997,346480.200000003 197686.299999997,346501.200000003 197682.5,346537.299999997 197670.900000006,346548.700000003 197661.299999997,346557.099999994 197624.700000003,346548.599999994 197600.400000006,346538.5 197586.900000006,346514.5 197571.799999997,346473.299999997 197580.200000003,346442.099999994 197576.200000003,346408.799999997 197557.5,346356.400000006 197535.099999994,346302.900000006 197505.5,346269.799999997 197463.099999994,346250.700000003 197445.299999997,346244.799999997 197431,346229.799999997 197391.099999994,346222.5 197356.200000003,346209.299999997 197330.900000006,346193 197295.700000003,346170.299999997 197240.5,346163.599999994 197206.900000006,346147.299999997 197158.799999997,346132 197126.200000003,346111.700000003 197075.400000006,346099.599999994 197040.599999994,346092.099999994 197005.799999997,346090.700000003 196966.200000003,346079.099999994 196914.5,346060.700000003 196874.299999997,346038.700000003 196845.799999997,346026.5 196800.599999994,346012.900000006 196730.299999997,346005 196697.5,345993 196683.400000006,345968.299999997 196635.5,345943.599999994 196562.799999997,345932.5 196492.799999997,345911.299999997 196413.099999994,345907.099999994 196382.799999997,345903.700000003 196356.299999997,345887.099999994 196300.700000003,345882 196257.799999997,345872.599999994 196226.700000003,345876.799999997 196207.200000003,345898.200000003 196172.200000003,345896.299999997 196162.700000003,345882.700000003 196134,345842.799999997 196099.900000006,345826.5 196087.5,345810.599999994 196071.599999994,345791.900000006 196032.900000006,345789.400000006 196011.5,345799.299999997 195979.400000006,345779.099999994 195887.700000003,345771.799999997 195829.799999997,345756.5 195784.200000003,345756.299999997 195752.700000003,345778.5 195741.099999994,345766.299999997 195722.700000003,345754.599999994 195711.900000006,345731.099999994 195677.5,345732.200000003 195630.599999994,345728.299999997 195611.799999997,345714.299999997 195586.299999997,345675.099999994 195564.700000003,345664.799999997 195557.599999994,345637.200000003 195541.799999997,345605.200000003 195509,345590.299999997 195471,345588.599999994 195416.200000003,345582.900000006 195362.400000006,345575.900000006 195332.099999994,345567.900000006 195285.900000006,345574.599999994 195259.700000003,345582 195228.200000003,345574.099999994 195183.900000006,345564.5 195158.700000003,345558.099999994 195127.099999994,345559.299999997 195056.299999997,345557.400000006 194980,345552.900000006 194913,345553.099999994 194872.299999997,345553 194814.400000006,345554.700000003 194766.799999997,345550.599999994 194687.799999997,345552.299999997 194655.400000006,345550.599999994 194615.799999997,345547.799999997 194573.200000003,345549.200000003 194434.299999997,345548.400000006 194378.099999994,345544.799999997 194326.799999997,345545.599999994 194273.400000006,345543.400000006 194229.5,345542.400000006 194102.400000006,345542.799999997 194045.5,345545.299999997 193957.700000003,345538.200000003 193757.099999994,345532.700000003 193721.5,345532.299999997 193642.200000003,345535 193526.700000003,345532.900000006 193482,345535.299999997 193417.900000006,345532.099999994 193351,345531.400000006 193304.099999994,345525 193187.799999997,345527.599999994 193120.299999997,345541.5 193070.5,345553.799999997 193027.400000006,345555.099999994 192987.5,345553.900000006 192962.299999997,345544.5 192948.299999997,345523.200000003 192916.400000006,345509.799999997 192880.200000003,345484.900000006 192773.900000006,345476.900000006 192725.900000006,345464.799999997 192692.799999997,345451.900000006 192660.400000006,345428.700000003 192543.099999994,345420.900000006 192509.799999997,345402 192438,345388 192381.400000006,345352.299999997 192249,345326.200000003 192158.400000006,345323.599999994 192145.400000006,345307.400000006 192097.5,345287.599999994 192047,345278.200000003 192027.200000003,345268.099999994 192002.200000003,345251.900000006 191950.299999997,345235.900000006 191907.900000006,345220.599999994 191865.299999997,345207.799999997 191833.5,345178.799999997 191738.400000006,345161.400000006 191684.099999994,345144.400000006 191627.599999994,345124.200000003 191550.099999994,345112.700000003 191523,345106.799999997 191499.900000006,345089.200000003 191461.799999997,345078.700000003 191418.599999994,345054.5 191360.900000006,345041.799999997 191312.599999994,345030.5 191287.700000003,345024.099999994 191256.099999994,344975.400000006 191082.799999997,344937 190983.700000003,344909.099999994 190875.799999997,344902.400000006 190841.299999997,344887.299999997 190805.5,344875 190759.900000006,344864 190728.200000003,344825.5 190666.200000003,344794.700000003 190596.5,344763.5 190542.400000006,344741.599999994 190487.200000003,344732.299999997 190443.900000006,344723.700000003 190372.5,344720.900000006 190331.099999994,344715.400000006 190306,344711.5 190288.400000006,344700.099999994 190241.700000003,344691.799999997 190186.400000006,344686.5 190175.299999997,344678 190139.5,344657.700000003 190075.5,344638.299999997 189943.799999997,344615.900000006 189896.099999994,344607.099999994 189865.299999997,344602.299999997 189854.299999997,344588.5 189802.799999997,344583 189777.599999994,344573.799999997 189711.700000003,344548.700000003 189646.400000006,344525.599999994 189563.799999997,344487.400000006 189433.200000003,344461.5 189319.599999994,344457 189292.799999997,344449.700000003 189257.400000006,344442.799999997 189214.5,344431.099999994 189181.900000006,344418.400000006 189132.299999997,344397.299999997 189060,344384.799999997 188995.900000006,344373.599999994 188938.799999997,344365.099999994 188892.700000003,344356.099999994 188869.400000006,344347.299999997 188837.099999994,344332.599999994 188782.5,344311.200000003 188714,344300.299999997 188677.200000003,344276.400000006 188503.099999994,344256.900000006 188448.5,344232.099999994 188387,344209.099999994 188316.799999997,344177.5 188213.299999997,344156.799999997 188165.900000006,344136.700000003 188122.099999994,344109.599999994 188073.900000006,344096.400000006 188038.5,344084.400000006 188010.299999997,344074.099999994 187978,344032 187900,344018.200000003 187865.599999994,344007.799999997 187843.599999994,343976.799999997 187763.299999997,343967.799999997 187737,343950.400000006 187688.099999994,343935.900000006 187627.299999997,343929.900000006 187612.299999997,343929.099999994 187571.799999997,343920.700000003 187561.400000006,343898.099999994 187528.5,343832.200000003 187399.400000006,343803.900000006 187338.5,343759.599999994 187216.200000003,343739.299999997 187174.400000006,343711.200000003 187121.5,343642 186939.299999997,343594.5 186828,343552.400000006 186695.599999994,343494.900000006 186553.900000006,343465.400000006 186459.200000003,343458.299999997 186417.900000006,343430.700000003 186333.5,343426.900000006 186314.799999997,343329.700000003 185976.799999997,343299.799999997 185837.099999994,343287.5 185760.400000006,343279 185682.900000006,343262.5 185542.900000006,343262.299999997 185487.299999997,343257.5 185408.799999997,343226.799999997 185225.099999994,343219.599999994 185150.5,343202.599999994 185068.400000006,343186.200000003 184961.900000006,343187.400000006 184936.900000006,343184 184869.400000006,343185.599999994 184836.5,343185.799999997 184672.700000003,343180.700000003 184543.299999997,343176.900000006 184427.200000003,343170.099999994 184292.900000006,343164.099999994 184241,343167.299999997 184175.599999994,343160.299999997 184119.400000006,343158.5 184074.299999997,343148 184014.400000006,343128.099999994 183934.099999994,343107 183870.599999994,343107.400000006 183861.599999994,343116.900000006 183815.900000006,343125.5 183762,343130 183746.799999997,343143.700000003 183724.599999994,343185.5 183676.099999994,343208.599999994 183661.799999997,343232.799999997 183632.700000003,343257.400000006 183608.200000003,343296.5 183578.900000006,343351.299999997 183551.599999994,343474.299999997 183521.5,343570 183499.599999994,343621.900000006 183474.599999994,343668.900000006 183454,343698.799999997 183446.5,343793.799999997 183417.299999997,343834.200000003 183406.799999997,343910.900000006 183381.599999994,343966 183371.799999997,344065.400000006 183344.799999997,344173.700000003 183312.700000003,344197.299999997 183310.299999997,344344.599999994 183294,344392.099999994 183293.400000006,344478.299999997 183311.299999997,344503.299999997 183318.099999994,344653.700000003 183335.5,344698.700000003 183352.200000003,344753.5 183370.599999994,344795.5 183370.599999994,344803.5 183366.799999997,344815.599999994 183339.900000006,344812 183316.799999997,344792.599999994 183283.900000006,344791.5 183256.200000003,344783 183220.5,344767.5 183183.5,344749.299999997 183147.900000006,344718.700000003 183112.299999997,344675.299999997 183076.099999994,344599 183039,344593.900000006 183032.099999994,344557.900000006 182996.799999997,344550.5 182966.5,344536.700000003 182927.299999997,344517.599999994 182912.900000006,344490.099999994 182909.5,344469.400000006 182900.099999994,344466.099999994 182882.5,344444.400000006 182847.400000006,344419.299999997 182777.200000003,344416.599999994 182764.799999997,344405.200000003 182725.299999997,344387.200000003 182687.700000003,344379.599999994 182646.400000006,344373.599999994 182597.099999994,344369.599999994 182559,344363.799999997 182457,344354.299999997 182330.599999994,344360.700000003 182197.599999994,344380.400000006 182099.5,344402.900000006 182032.099999994,344415.299999997 181985.299999997,344440.799999997 181930.299999997,344472.5 181860.700000003,344499.599999994 181747.200000003,344511.200000003 181704.400000006,344541.700000003 181658.5,344606.299999997 181542.400000006,344634 181478.099999994,344659.599999994 181424.799999997,344665.099999994 181356.400000006,344661.299999997 181338.200000003,344646.5 181307.099999994,344623.599999994 181271.799999997,344552.299999997 181195.5,344518.200000003 181166.400000006,344462.099999994 181110.599999994,344333 180989.700000003,344310.299999997 180971.900000006,344253.200000003 180924.599999994,344215.700000003 180880.799999997,344150.5 180800,344109.799999997 180738.099999994,344077 180695.099999994,344021.900000006 180606,343947.5 180480.400000006,343883.599999994 180357.700000003,343852.700000003 180303.799999997,343817 180222.799999997,343752.799999997 180108.599999994,343673.099999994 179983.400000006,343621.799999997 179912.299999997,343530.900000006 179755.099999994,343472.400000006 179636.799999997,343365.900000006 179396.099999994,343317.200000003 179286.400000006,343297.200000003 179250.400000006,343261.299999997 179174.5,343219.400000006 179096,343185.5 179041,343069.599999994 178832.299999997,342993.5 178689.799999997,342966.799999997 178650.799999997,342936.700000003 178597.099999994,342884.099999994 178494.599999994,342880.099999994 178480.700000003,342856.599999994 178432.200000003,342839.099999994 178394.599999994,342744.900000006 178208.299999997,342689.5 178087.200000003,342662.299999997 178032.299999997,342645.5 178004.599999994,342601.900000006 177926.700000003,342563 177860.700000003,342531.900000006 177794.099999994,342525.700000003 177786.700000003,342491.799999997 177718.799999997,342452 177648,342367.5 177495.599999994,342367.200000003 177481.200000003,342369.599999994 177468.599999994,342358.200000003 177443.400000006,342348.5 177416.5,342326.400000006 177389,342327.099999994 177375.799999997,342289.400000006 177310.700000003,342272 177272.299999997,342227.400000006 177180,342194.900000006 177141.599999994,342145.099999994 177053.400000006,342120.099999994 176999.400000006,342095 176959.200000003,342020.400000006 176812.599999994,341977.200000003 176741.400000006,341905.299999997 176612.799999997,341863.900000006 176551.599999994,341845.299999997 176523.299999997,341816.400000006 176474.799999997,341753 176360.5,341682.299999997 176184,341625.700000003 176077.5,341569.5 175969.599999994,341528.799999997 175906.299999997,341515.200000003 175878.900000006,341479.599999994 175808.599999994,341450.799999997 175744.700000003,341418.400000006 175695.799999997,341357.900000006 175580.5,341345.099999994 175546,341310.900000006 175482,341291.299999997 175440.799999997,341258.700000003 175384.799999997,341230.400000006 175313.599999994,341175.799999997 175210.5,341121 175069.5,341091.099999994 175014.200000003,341072.200000003 174971.5,341020.099999994 174856,340985.400000006 174792,340954.400000006 174727.400000006,340923.200000003 174663.200000003,340909.799999997 174619.200000003,340874.099999994 174533,340853.900000006 174482.700000003,340820.900000006 174430,340797.599999994 174342.400000006,340780.299999997 174291.299999997,340749.099999994 174228.400000006,340720.400000006 174112.400000006,340710.799999997 174051.200000003,340694.5 173954.200000003,340677.400000006 173898.799999997,340670.200000003 173874,340663.700000003 173859.099999994,340645.200000003 173794,340628.299999997 173722.299999997,340611.799999997 173664.400000006,340605.700000003 173631.799999997,340597 173597.5,340606.5 173590.400000006,340606.400000006 173575.5,340601.900000006 173556,340564.200000003 173475.299999997,340548.400000006 173457,340533.599999994 173424.400000006,340523.299999997 173378.099999994,340509.299999997 173342.400000006,340509.299999997 173321.099999994,340496.700000003 173268,340486.400000006 173234.400000006,340473.400000006 173201.900000006,340463.299999997 173163.599999994,340455.700000003 173148.5,340443.299999997 173113.799999997,340433.5 173094.5,340431.900000006 173082.5,340414.099999994 173051.599999994,340401.299999997 173015.599999994,340376.299999997 172960.200000003,340371.599999994 172944.299999997,340353.599999994 172897.700000003,340338.799999997 172868.200000003,340311.299999997 172775.799999997,340292.299999997 172731.099999994,340279.099999994 172705.799999997,340268.299999997 172670.799999997,340259.700000003 172660.200000003,340244.700000003 172633.700000003,340209 172578.400000006,340200.5 172552.700000003,340202.900000006 172543.099999994,340202.799999997 172522.099999994,340202 172512,340188.599999994 172492.700000003,340170.900000006 172457,340151.200000003 172431.099999994,340136.099999994 172392.5,340114.700000003 172352.900000006,340111.700000003 172337.700000003,340086.700000003 172284.799999997,340079.700000003 172254.400000006,340066.700000003 172228.700000003,340056 172198.900000006,340043.799999997 172164.099999994,340024.200000003 172121.400000006,340016.099999994 172099.200000003,339994.200000003 172056.5,339970.799999997 171994.200000003,339959.200000003 171973.700000003,339945.400000006 171945.5,339907.799999997 171869.5,339896.299999997 171843.700000003,339887.099999994 171825.099999994,339879.700000003 171799.599999994,339865.5 171771.900000006,339806.400000006 171651.5,339793.599999994 171618.400000006,339761.299999997 171566.5,339730.799999997 171533.599999994,339698.599999994 171479.599999994,339685.700000003 171447.099999994,339674 171429.099999994,339640.099999994 171368.5,339617.599999994 171338.400000006,339592.299999997 171302.900000006,339534.599999994 171229.299999997,339521.400000006 171200.200000003,339489.5 171141.599999994,339459.400000006 171111.099999994,339453.400000006 171102,339432.700000003 171081.599999994,339391.200000003 171032.700000003,339319.099999994 170968.900000006,339277.799999997 170938.799999997,339232.900000006 170895,339182.400000006 170861.700000003,339153.400000006 170847.299999997,339089.200000003 170807.599999994,339057.700000003 170786,339013.5 170755.099999994,339001.200000003 170740.599999994,338993.200000003 170714.700000003,338981.900000006 170675.799999997,338958.599999994 170622.5,338944 170542.099999994,338920.299999997 170485.200000003,338919.5 170471.299999997,338909.099999994 170452.700000003,338890.299999997 170396.599999994,338866.5 170339.299999997,338852.799999997 170312.099999994,338847.200000003 170289.799999997,338804.799999997 170158.700000003,338799 170130.400000006,338784.799999997 170062.299999997,338772 170030.5,338768.900000006 169997.200000003,338759.099999994 169973.799999997,338751.799999997 169938.5,338744.799999997 169921.200000003,338739.400000006 169896.599999994,338726.900000006 169879.5,338712.799999997 169874.099999994,338696.200000003 169871.299999997,338620.799999997 169859.299999997,338592.099999994 169846.5,338547.799999997 169829.200000003,338529.099999994 169817.799999997,338483.299999997 169794.799999997,338417.299999997 169753.900000006,338342.200000003 169713.599999994,338277.099999994 169665.799999997,338251.700000003 169633.900000006,338236.299999997 169614,338195.200000003 169555.700000003,338169 169526.5,338134.599999994 169477.599999994,338113 169451,338075.799999997 169389,338065.599999994 169359.5,338050.799999997 169319,338014.400000006 169230.099999994,337990.599999994 169173,337976 169122.900000006,337961.200000003 169047,337937.799999997 168968.799999997,337925.599999994 168939.099999994,337888.700000003 168844.099999994,337864.299999997 168752.200000003,337824 168661.299999997,337790.200000003 168602.5,337756.700000003 168562.299999997,337685.799999997 168497.099999994,337651.900000006 168467.700000003,337601.299999997 168427,337485.700000003 168368.599999994,337402.200000003 168344.299999997,337359.299999997 168333.700000003,337272.200000003 168309.099999994,337224.099999994 168291.099999994,337183.099999994 168282.5,337108 168263.599999994,337071.299999997 168254.299999997,337010.900000006 168234.799999997,336931.099999994 168216.700000003,336858.299999997 168206.400000006,336789.200000003 168188,336759.200000003 168176.200000003,336667.799999997 168150.900000006,336620.400000006 168137.599999994,336563.900000006 168124.099999994,336540.599999994 168118.200000003,336525.900000006 168113.299999997,336501.299999997 168107.900000006,336454.799999997 168089.900000006,336398.5 168069.700000003,336371.5 168057.700000003,336297.5 168032.400000006,336251.799999997 168018.700000003,336216.799999997 168011.700000003,336181 168000.799999997,336105.400000006 167973.200000003,336028 167947.200000003,335961.200000003 167931.799999997,335856.799999997 167902.200000003,335758.299999997 167871.5,335715.799999997 167857.200000003,335679.099999994 167844,335630.400000006 167817.900000006,335523.299999997 167758.900000006,335447.200000003 167714.099999994,335410.400000006 167693.299999997,335357 167673.900000006,335326.700000003 167666.400000006,335286.5 167652.299999997,335197 167635.900000006,335177.099999994 167637.900000006,335099.799999997 167643.400000006,335029.200000003 167674.400000006,334948.799999997 167729.299999997,334931.900000006 167746.5,334908.099999994 167762.299999997,334850.400000006 167812.299999997,334807.099999994 167858.299999997,334786.5 167877.700000003,334749.400000006 167906.599999994,334665.200000003 167980.299999997,334610.099999994 168027.5,334562.799999997 168070.799999997,334537.799999997 168091.900000006,334454.900000006 168163.799999997,334330.200000003 168277.900000006,334282.799999997 168314.900000006,334262.599999994 168333.900000006,334187.099999994 168400.400000006,334160.400000006 168415.5,334097.299999997 168452.599999994,334056.799999997 168478.400000006,334026.799999997 168488.400000006,333912.799999997 168559.900000006,333846.5 168597.599999994,333816 168617.5,333784.200000003 168633,333719.799999997 168669.700000003,333691.700000003 168691.599999994,333633.299999997 168727.400000006,333527.099999994 168808.799999997,333454.900000006 168843.299999997,333403 168861.099999994,333350.200000003 168873.599999994,333319.900000006 168877.599999994,333238.799999997 168882.700000003,333169.5 168887.900000006,333131.799999997 168891.900000006,333064.599999994 168892.700000003,333020.299999997 168889.599999994,332911.5 168887.299999997,332827.099999994 168887.799999997,332799.900000006 168887.799999997,332732.700000003 168887.099999994,332629.599999994 168890.900000006,332520.599999994 168881.5,332465.200000003 168870.900000006,332397.900000006 168864.700000003,332342.799999997 168871.599999994,332304 168867.900000006,332200.400000006 168880.5,332189.900000006 168878.900000006,332148.799999997 168879.700000003,332119.5 168873.400000006,332090.299999997 168870.5,332052 168865.299999997,332024.299999997 168867,331937.799999997 168877.200000003,331860 168878.900000006,331823 168876.799999997,331781.099999994 168881.599999994,331749.200000003 168882.599999994,331735.299999997 168885,331714.799999997 168886.099999994,331678.5 168888.099999994,331660.5 168889.200000003,331643.5 168894.5,331605 168896.799999997,331571.299999997 168893.299999997,331524.900000006 168896.099999994,331482.599999994 168899.900000006,331448.799999997 168903.200000003,331436.799999997 168901.900000006,331421.400000006 168904.900000006,331342 168905.799999997,331316.5 168907.900000006,331228.400000006 168903.799999997,331167.799999997 168898.5,331121.299999997 168892,331040.400000006 168882.799999997,330999 168878.900000006,330830 168875,330771.299999997 168882,330727.700000003 168888.5,330713.5 168893.700000003,330672 168919.599999994,330648.5 168937.099999994,330571.299999997 168975.200000003,330519.299999997 169015.700000003,330490.5 169028.099999994,330431.099999994 169046.900000006,330411.900000006 169048.5,330350.099999994 169041,330330.799999997 169030,330271.5 168999.5,330224.5 168961.5,330191.799999997 168932.799999997,330154.099999994 168889.599999994,330127.200000003 168850.799999997,330103 168826.299999997,330086.099999994 168803.299999997,330077.900000006 168787.200000003,330055.200000003 168747.299999997,330021.5 168708,330004.099999994 168680.799999997,329962.799999997 168637.799999997,329943.5 168618.200000003,329921.5 168598.299999997,329886.900000006 168564.099999994,329859.799999997 168542.299999997,329785.299999997 168465.400000006,329735.599999994 168420.700000003,329708.299999997 168401.5,329697.200000003 168383.400000006,329642.700000003 168339.400000006,329617.900000006 168317.099999994,329603.599999994 168304.299999997,329565.799999997 168276.200000003,329533.5 168248.5,329482.299999997 168209.900000006,329404.599999994 168146.700000003,329385.400000006 168122.299999997,329345 168085.599999994,329306.099999994 168048,329292.5 168040.700000003,329291.900000006 168050.599999994,329274.700000003 168071.900000006,329250.599999994 168110.5,329223.400000006 168160.700000003,329211 168182.900000006,329190.299999997 168213.299999997,329170.299999997 168251.799999997,329143.900000006 168286.400000006,329131.900000006 168311,329115.299999997 168341.400000006,329110.299999997 168358,329075.700000003 168412.200000003,329062.400000006 168439.799999997,329034.200000003 168479.400000006,329008.299999997 168513.700000003,328980 168563.5,328946.799999997 168618.400000006,328915.799999997 168657.299999997,328877.799999997 168698.799999997,328831.599999994 168768.299999997,328817.299999997 168792.799999997,328782 168837.5,328741.799999997 168872.200000003,328701.400000006 168923,328674.5 168953.299999997,328641.799999997 168974,328567.400000006 169016.099999994,328534.099999994 169031.900000006,328500 169053.5,328459.799999997 169064.900000006,328408.599999994 169077.799999997,328380.400000006 169088,328340.700000003 169099.599999994,328300.099999994 169106,328246.400000006 169110.599999994,328216.099999994 169112,328133.700000003 169112.299999997,328079 169108.400000006,328011 169096.700000003,327921.400000006 169072.400000006,327862 169053.900000006,327776.900000006 169009.400000006,327720.099999994 168988.200000003,327681 168974,327582.099999994 168920.700000003,327558.400000006 168911.5,327552.700000003 168904.200000003,327531.400000006 168905.400000006,327448.099999994 168876.299999997,327353.799999997 168857.799999997,327281.400000006 168839.200000003,327188.099999994 168826.200000003,327117.599999994 168818.799999997,327006.799999997 168819.200000003,326934.099999994 168838.099999994,326850.299999997 168853.700000003,326800.900000006 168865.799999997,326778 168869.299999997,326730.099999994 168889.299999997,326680.200000003 168914.200000003,326658.599999994 168919.5,326614.599999994 168948.200000003,326607.900000006 168960,326557.099999994 168982.200000003,326536.900000006 168988.299999997,326477 169031.400000006,326402.400000006 169103.099999994,326371 169142.299999997,326339.799999997 169182.400000006,326314.200000003 169225.700000003,326295.099999994 169269.400000006,326278.700000003 169296.799999997,326249.099999994 169353.200000003,326219.400000006 169439.900000006,326181.599999994 169524.799999997,326177.5 169546.299999997,326142.599999994 169657.799999997,326123.099999994 169725.5,326098.400000006 169848.400000006,326087.299999997 169902.700000003,326057.099999994 169968.5,326044.700000003 170012.400000006,326007.799999997 170166,325999.299999997 170205.799999997,326011.5 170276,326027.5 170322.200000003,326061.700000003 170373.299999997,326086 170418.799999997,326110.5 170441.599999994,326149.099999994 170467,326183.900000006 170495.299999997,326211.799999997 170513.799999997,326257.599999994 170540.799999997,326285.799999997 170553.599999994,326364.400000006 170580.799999997,326464.700000003 170610.5,326532.799999997 170637.099999994,326588.900000006 170669.099999994,326626.700000003 170682.799999997,326673.099999994 170717.5,326721.299999997 170755.099999994,326776.400000006 170799.599999994,326852.400000006 170882.700000003,326871.5 170907.799999997,326903.200000003 170952.799999997,326939.599999994 171020.5,326947.400000006 171045.700000003,326969.299999997 171105.200000003,326992.700000003 171156.200000003,327003.5 171169.200000003,327021.200000003 171200.900000006,327050.799999997 171234.900000006,327075.400000006 171275.099999994,327115 171326.400000006,327231.5 171443.5,327268.099999994 171470.5,327322.299999997 171517.599999994,327402.599999994 171573.900000006,327448.5 171606.200000003,327468.099999994 171624.099999994,327524.700000003 171659.900000006,327556 171688.599999994,327592.299999997 171721.5,327611.599999994 171744.700000003,327639.599999994 171775.599999994,327663.400000006 171816.900000006,327681.799999997 171860,327692.5 171925.200000003,327695.799999997 172008.200000003,327690.299999997 172069.200000003,327688 172115.700000003,327680.5 172147.900000006,327678.5 172175.900000006,327661.200000003 172236.5,327639.400000006 172286.5,327611.400000006 172381.900000006,327596.200000003 172449.5,327580.5 172495.099999994,327547.5 172594,327514.700000003 172677.299999997,327495.799999997 172740.700000003,327486.700000003 172804.700000003,327474 172870.299999997,327473.900000006 172932.799999997,327479.799999997 172971.700000003,327476.299999997 172986,327483 173019.5,327490 173035.799999997,327486.5 173054.900000006,327494.099999994 173072.900000006,327512.5 173105.900000006,327541 173137.799999997,327573.299999997 173165.299999997,327594.799999997 173184,327608.200000003 173194.099999994,327649.700000003 173228.799999997,327665.299999997 173255.900000006,327682.200000003 173268.599999994,327708.099999994 173294.700000003,327734.200000003 173327.299999997,327744.099999994 173347,327760.599999994 173369,327765.900000006 173378.900000006,327767.900000006 173388.599999994,327770.5 173407.299999997,327769.799999997 173436.900000006,327745.200000003 173473.700000003,327723.900000006 173499.799999997,327685.900000006 173528,327651.200000003 173545.400000006,327589.599999994 173575.099999994,327553 173596.799999997,327505.599999994 173618.099999994,327444.900000006 173638.700000003,327422.900000006 173644.5,327349 173657.799999997,327298.200000003 173663.400000006,327234 173666.599999994,327197.700000003 173662.700000003,327166 173654.400000006,327140.900000006 173650.099999994,327098.5 173633.799999997,327026.400000006 173603,327001 173591.099999994,326985.900000006 173581.400000006,326930.200000003 173563.599999994,326897.5 173549.799999997,326865.900000006 173534.599999994,326831.299999997 173528.700000003,326817.200000003 173530.299999997,326779.799999997 173534.400000006,326732.299999997 173555.799999997,326706.900000006 173582.599999994,326691.799999997 173635.599999994,326687.200000003 173657.099999994,326687.599999994 173669.700000003,326676.900000006 173692.700000003,326675.599999994 173717.400000006,326667 173734.900000006,326669.400000006 173758.700000003,326666.200000003 173789.400000006,326667.799999997 173807.299999997,326665.5 173851.700000003,326671.799999997 173875.099999994,326674 173893.200000003,326683.799999997 173923.700000003,326680.900000006 173958,326686 173979.099999994,326674.900000006 174019,326666.400000006 174048.799999997,326657.5 174069.299999997,326654.599999994 174103.099999994,326637.400000006 174160.400000006,326612.299999997 174206.799999997,326595.700000003 174236.599999994,326542.799999997 174296.400000006,326513.5 174354.900000006,326492.799999997 174399.400000006,326475.799999997 174499.700000003,326484.299999997 174524.299999997,326486.299999997 174542.200000003,326483.900000006 174578.099999994,326490.900000006 174608.700000003,326499 174619.299999997,326543.299999997 174649.299999997,326557.799999997 174660,326603.700000003 174667.799999997,326623.299999997 174671.700000003,326671.5 174674.700000003,326720 174679.5,326729.400000006 174687.400000006,326750.900000006 174688.799999997,326781.700000003 174684.799999997,326862.400000006 174670.599999994,326886.799999997 174669.5,326908.799999997 174662.099999994,326991.799999997 174653.400000006,327012.799999997 174650.799999997,327046 174651.299999997,327069.299999997 174668.700000003,327083.200000003 174677.700000003,327099.799999997 174696.099999994,327113.799999997 174729.900000006,327124.700000003 174743.599999994,327135.599999994 174790.099999994,327117.299999997 174844.299999997,327085.799999997 174885.700000003,327068.700000003 174916.400000006,327069.700000003 174933.5,327073.299999997 174957.900000006,327079.400000006 174992.099999994,327102.299999997 175038.799999997,327123.400000006 175053.700000003,327136.5 175067,327173.900000006 175104.299999997,327200.200000003 175120.900000006,327229.200000003 175143.900000006,327254.200000003 175160.799999997,327263.099999994 175164.5,327292.299999997 175184.799999997,327353.599999994 175222.5,327368.200000003 175231.299999997,327388.799999997 175242,327458.799999997 175275.299999997,327481 175289.099999994,327505.200000003 175299.700000003,327553.299999997 175328.200000003,327585.700000003 175353.099999994,327605.700000003 175389.099999994,327616.700000003 175422,327647.700000003 175480.900000006,327656.700000003 175505.5,327680.5 175586.200000003,327687.099999994 175611.299999997,327699 175662.200000003,327723.599999994 175729.799999997,327745.099999994 175797,327760.700000003 175833.099999994,327771 175870.599999994,327791.599999994 175941.200000003,327818.299999997 175999.400000006,327827.099999994 176028.700000003,327838 176061,327879.099999994 176123.400000006,327912.799999997 176170,327945.099999994 176215.700000003,327959.900000006 176245.799999997,327983.799999997 176272.200000003,327977.599999994 176288.799999997,327959.099999994 176298.799999997,327927 176326.700000003,327878.400000006 176359.099999994,327787.700000003 176404.900000006,327776.900000006 176415.799999997,327741 176435.599999994,327681 176468.5,327603.299999997 176521.299999997,327576.5 176534.900000006,327535.5 176563.5,327485.599999994 176597.900000006,327427.400000006 176632,327364.799999997 176671.599999994,327325.400000006 176686.700000003,327257.799999997 176724.200000003,327223.700000003 176747.900000006,327196.200000003 176765,327155.799999997 176795.099999994,327106.599999994 176825.700000003,327001.599999994 176881.799999997,326982.099999994 176895.799999997,326945.200000003 176914.299999997,326853.799999997 176970.799999997,326834.799999997 176977.700000003,326772.700000003 177018.299999997,326734.099999994 177043.299999997,326703.700000003 177059.700000003,326622.299999997 177114.400000006,326505.400000006 177189.900000006,326408.299999997 177241.900000006,326363.700000003 177268.700000003,326329.299999997 177283,326233 177341.799999997,326200.299999997 177359.299999997,326108.799999997 177421,326027.799999997 177475.099999994,325995.299999997 177498.400000006,325858.400000006 177579.599999994,325829.299999997 177591.700000003,325740.700000003 177645,325708.799999997 177660.299999997,325616.900000006 177713.5,325489.900000006 177789.799999997,325405.099999994 177835.700000003,325367 177863.299999997,325347.200000003 177874.599999994,325303.599999994 177902.900000006,325207.799999997 177964.799999997,325159.400000006 177994.900000006,325134.200000003 178008.700000003,325106 178021.200000003,325091 178029.400000006,325040 178061.799999997,325031.200000003 178068.799999997,325021.200000003 178075.799999997,325002.5 178089,324985.099999994 178098.799999997,324959.599999994 178117,324947.400000006 178118.900000006,324904.5 178148.5,324866.5 178173.799999997,324849.700000003 178186.900000006,324749.099999994 178246.400000006,324643.299999997 178306.900000006,324595.299999997 178337.799999997,324558.400000006 178369.099999994,324518.799999997 178392.5,324491.700000003 178404.400000006,324437 178438,324403 178468.799999997,324370.200000003 178487,324325.700000003 178511.900000006,324274.599999994 178545.599999994,324225.099999994 178572.900000006,324120.200000003 178635.299999997,324058.200000003 178675.400000006,324017.5 178703,323988.599999994 178717.200000003,323901.900000006 178778.700000003,323864.099999994 178800.5,323768.200000003 178856,323744.700000003 178865.099999994,323722.299999997 178881.400000006,323689.900000006 178905.099999994,323639.5 178938.799999997,323590.799999997 178962.799999997,323551.299999997 178983.900000006,323495.5 179000.400000006,323473.700000003 179018.700000003,323449.700000003 179039,323421.700000003 179060.200000003,323396.5 179066.799999997,323370.5 179057.799999997,323357 179038.200000003,323345.099999994 179021.5,323327.700000003 179010,323307.799999997 179011.799999997,323287.799999997 179024.799999997,323241.700000003 179045,323198.299999997 179058.900000006,323160.700000003 179063.200000003,323139.5 179052.099999994,323119.099999994 179037.099999994,323100.5 179001.799999997,323084.299999997 178972.5,323075.900000006 178949.900000006,323057.799999997 178924.400000006,323028.400000006 178895.099999994,323006.299999997 178884,322976.200000003 178859,322941.599999994 178852,322892 178852.599999994,322835.400000006 178865.400000006,322813.299999997 178863.700000003,322797.599999994 178861.700000003,322774.700000003 178849.900000006,322758 178846.599999994,322723.5 178827,322709.5 178817.200000003,322624 178754.700000003,322596.700000003 178733.799999997,322576.299999997 178721,322565.799999997 178714,322542.200000003 178703.799999997,322497.200000003 178697.299999997,322476.799999997 178699.299999997,322405.5 178714.400000006,322376.700000003 178728.299999997,322332.900000006 178744.200000003,322269.299999997 178770.599999994,322226.299999997 178808.200000003,322186.599999994 178832.799999997,322137.299999997 178844.700000003,322103.5 178846.799999997,322064.599999994 178852.599999994,322049.700000003 178850.599999994,322029.400000006 178846.099999994,322009.599999994 178832.799999997,321958.799999997 178784.900000006,321895.299999997 178717.5,321860.299999997 178682.099999994,321811.5 178634.5,321783.799999997 178608,321754.5 178580.5,321729.799999997 178565.400000006,321689.900000006 178555.799999997,321675.700000003 178550.700000003,321659 178547.5,321621.799999997 178534.099999994,321579.099999994 178521.799999997,321516.599999994 178491.799999997,321475.5 178473.799999997,321436.400000006 178456,321387.599999994 178447.700000003,321360.700000003 178443.400000006,321320.700000003 178436,321290 178431,321230.400000006 178422.700000003,321116.799999997 178402,321093.599999994 178401.099999994,321071 178400.900000006,321048.799999997 178400.099999994,320998.900000006 178401.799999997,320968.200000003 178411.799999997,320903.799999997 178434.400000006,320879.299999997 178448.799999997,320824 178479.299999997,320791.799999997 178495.799999997,320751.599999994 178510.099999994,320717.700000003 178523.700000003,320676.299999997 178521.5,320604.099999994 178531.799999997,320559.599999994 178532.099999994,320508.400000006 178519.400000006,320465.400000006 178509.599999994,320435.200000003 178503.799999997,320368.400000006 178498.799999997,320306.299999997 178488,320235.099999994 178480.700000003,320218.299999997 178474.5,320201.799999997 178468.200000003,320175.400000006 178468.099999994,320157.299999997 178469.700000003,320117.5 178469.5,320103.799999997 178466,320056.299999997 178458.200000003,319968.099999994 178428.599999994,319937.599999994 178413,319901 178387.299999997,319764.799999997 178297.400000006,319694.200000003 178253.299999997,319660.200000003 178235.099999994,319639.5 178228.5,319597.099999994 178211.700000003,319577.099999994 178205.900000006,319542.099999994 178203.700000003,319521.599999994 178206.299999997,319495.900000006 178204.400000006,319467.099999994 178206.700000003,319419.799999997 178215.599999994,319396.700000003 178221.200000003,319316.5 178239.599999994,319227.700000003 178258.799999997,319149.200000003 178282.400000006,319130.099999994 178287.700000003,319028.799999997 178321.599999994,318921.700000003 178348.5,318884 178358.599999994,318780.799999997 178405.799999997,318756.400000006 178411.5,318728.799999997 178424.799999997,318669.599999994 178481.700000003,318632.400000006 178503.200000003,318567.599999994 178553.599999994,318500 178618.200000003,318456 178671.799999997,318435.400000006 178701.5,318413.200000003 178734.5,318361.200000003 178805,318335.599999994 178839.5,318308 178862.900000006,318278.900000006 178879.5,318250.599999994 178891.5,318195.900000006 178930.799999997,318170.599999994 178942.799999997,318056.900000006 178971.5,318007.900000006 178975.799999997,317957.299999997 178971.599999994,317912.700000003 178961.5,317866.5 178955.799999997,317823.599999994 178924.799999997,317736.5 178898.900000006,317684.799999997 178873.5,317656.5 178853.700000003,317617.799999997 178823.400000006,317562.900000006 178785.799999997,317523 178756.299999997,317464.299999997 178727.5,317400.299999997 178681.799999997,317360.099999994 178671.400000006,317294.099999994 178656.299999997,317215.599999994 178617.099999994,317086.200000003 178569.200000003,317021.299999997 178554.700000003,316952.799999997 178536.599999994,316870 178517.900000006,316828.299999997 178512.5,316774.400000006 178507.400000006,316697.299999997 178498.799999997,316569 178481.599999994,316419.799999997 178472.200000003,316295.099999994 178479.799999997,316204.700000003 178485.799999997,316164.299999997 178485.099999994,316101.799999997 178490.400000006,316057.900000006 178491.299999997,315974.400000006 178513.099999994,315921 178524,315852.299999997 178551.099999994,315807.200000003 178566.700000003,315774 178580.200000003,315710.700000003 178599.900000006,315610.799999997 178628.900000006,315575.5 178634.599999994,315480.700000003 178659.099999994,315437.900000006 178661.700000003,315405.799999997 178666.900000006,315351.700000003 178668.299999997,315288.599999994 178657.599999994,315223.299999997 178639.299999997,315192 178624.700000003,315157.099999994 178601.400000006,315095.299999997 178575.400000006,315039.700000003 178533.599999994,315015.599999994 178472.900000006,315003.299999997 178431.200000003,314995.299999997 178409.599999994,314978.200000003 178355.200000003,314959.299999997 178286.700000003,314917.799999997 178184.799999997,314913 178173.900000006,314894.700000003 178157.200000003,314885.099999994 178153.5,314859.400000006 178136.299999997,314832.099999994 178108,314803.400000006 178090.900000006,314768.099999994 178085.5,314770.400000006 178101.200000003,314774.599999994 178114.700000003,314774.400000006 178130.799999997,314774.799999997 178148.299999997,314775.299999997 178173,314763.900000006 178188.099999994,314765.400000006 178206.799999997,314760.599999994 178218.599999994,314763.200000003 178228.299999997,314752.799999997 178242.200000003,314742.599999994 178252.599999994,314693.400000006 178363.099999994,314677.799999997 178402.099999994,314649.599999994 178451.599999994,314603.799999997 178502.400000006,314594.599999994 178521,314581.5 178542.299999997,314570.099999994 178577.900000006,314563.099999994 178610.299999997,314539 178648.900000006,314519.5 178681.599999994,314505.400000006 178726,314498.5 178730.299999997,314491.299999997 178813.599999994,314490.099999994 178854.200000003,314486.5 178903,314478.299999997 178922.700000003,314446.299999997 178960.5,314426.400000006 178976.900000006,314394.099999994 178986.700000003,314376.200000003 178969.799999997,314352.700000003 178961.299999997,314320.400000006 178991.599999994,314312.099999994 179030.799999997,314308.5 179112.700000003,314319.200000003 179153.799999997,314337.700000003 179181.599999994,314351 179194.5,314364 179234.099999994,314362.700000003 179261.099999994,314350.5 179277.700000003,314297.299999997 179321.200000003,314279.900000006 179334.5,314252.799999997 179407.5,314254.299999997 179473.799999997,314260.799999997 179519.799999997,314271.5 179569.599999994,314278.200000003 179592.799999997,314288.799999997 179619.5,314298.799999997 179649.599999994,314318.599999994 179698.599999994,314326.5 179722.900000006,314376.5 179842.599999994,314393.200000003 179910.299999997,314391.900000006 179935.700000003,314426.799999997 180008,314436.900000006 180038.599999994,314442.299999997 180097.599999994,314458.099999994 180171.700000003,314478.900000006 180268.700000003,314502.799999997 180322.099999994,314519 180372.799999997,314527.799999997 180404.299999997,314548.799999997 180449.400000006,314563.799999997 180478.400000006,314580.599999994 180515.299999997,314597.700000003 180550.5,314606.799999997 180583.299999997,314636.400000006 180642.900000006,314694.900000006 180785.299999997,314707.400000006 180815.200000003,314725.900000006 180840.200000003,314759.299999997 180906.700000003,314771.700000003 180925.5,314793.400000006 180988.299999997,314819.099999994 181036.5,314828.5 181055.799999997,314845.400000006 181077.299999997,314868.400000006 181121.799999997,314904.200000003 181168.5,314928.700000003 181218.400000006,314961.400000006 181288.299999997,314983.599999994 181335.099999994,315024.200000003 181381.599999994,315050.5 181406.900000006,315066.700000003 181431.799999997,315096.599999994 181460,315122.299999997 181477.599999994,315149.599999994 181518.599999994,315192.400000006 181554.900000006,315227.099999994 181571.099999994,315264.299999997 181604.599999994,315332.599999994 181660.200000003,315365.299999997 181683.700000003,315394.400000006 181710.599999994,315505 181774.900000006,315550.700000003 181796.599999994,315579.400000006 181812.799999997,315617.099999994 181830.200000003,315649.5 181850.900000006,315661.299999997 181869.599999994,315675.200000003 181884.200000003,315685.200000003 181908.799999997,315714.200000003 181992.599999994,315720.299999997 182027,315723.200000003 182129.099999994,315732.099999994 182231.799999997,315741.400000006 182363.099999994,315747.5 182457.400000006,315763.5 182524.200000003,315784.700000003 182671.5,315788.700000003 182711,315793.299999997 182754,315785.900000006 182806,315767.400000006 182831.599999994,315713.299999997 182843,315703.799999997 182854.200000003,315692.799999997 182878.799999997,315678.799999997 182898.900000006,315665.599999994 182930.299999997,315651.5 182947.5,315641.900000006 182964.099999994,315623.700000003 182992.599999994,315576.099999994 183067.700000003,315556.099999994 183108.900000006,315542.799999997 183137.799999997,315537.900000006 183151.900000006,315502.5 183197.799999997,315500.099999994 183224.5,315505.599999994 183247.700000003,315520.5 183284.400000006,315535 183299.099999994,315544.400000006 183327.700000003,315552.400000006 183358.200000003,315553.799999997 183367.200000003,315550.700000003 183394.200000003,315562.900000006 183418.099999994,315591.200000003 183439.200000003,315611.299999997 183468.599999994,315620 183487.200000003,315631.400000006 183502,315642.200000003 183528.200000003,315665.700000003 183573.799999997,315673.200000003 183604.299999997,315671.700000003 183648.799999997,315670.900000006 183691.900000006,315640.299999997 183741.099999994,315640.700000003 183756.5,315644.299999997 183769.400000006,315641.299999997 183828.900000006,315648.5 183866.099999994,315651.900000006 183892.799999997,315668.900000006 183930.5,315678.299999997 183960.299999997,315695.299999997 183993.299999997,315703.599999994 184021.5,315722.5 184061.599999994,315750 184102,315787.799999997 184164.799999997,315821.400000006 184232.200000003,315856.700000003 184295.200000003,315872.700000003 184333.200000003,315893.700000003 184363,315932.099999994 184388.900000006,315958.900000006 184415.400000006,315964.5 184425.299999997,315974.299999997 184435.599999994,316014.400000006 184496.900000006,316055.299999997 184558.299999997,316091.299999997 184620.900000006,316109.799999997 184651.299999997,316147.200000003 184696.900000006,316169.299999997 184734.900000006,316183.700000003 184762.099999994,316206.5 184798.200000003,316218.599999994 184823,316237.599999994 184839.200000003,316252.400000006 184870.200000003,316291.400000006 184932.200000003,316308.400000006 184967.299999997,316333.200000003 185000,316344.200000003 185035.599999994,316362.200000003 185069,316373.799999997 185114,316391.5 185159.900000006,316423.799999997 185235.200000003,316447.900000006 185284,316459.299999997 185298.5,316467.5 185316.099999994,316469.299999997 185327.599999994,316500.900000006 185379.599999994,316523.799999997 185431.900000006,316531.200000003 185453.299999997,316556.900000006 185489.799999997,316575.599999994 185514.200000003,316596.799999997 185545.400000006,316617.200000003 185584.900000006,316620.299999997 185595.200000003,316636.599999994 185620.5,316647.599999994 185653.599999994,316662.299999997 185685.5,316666.400000006 185720.400000006,316684.299999997 185798.900000006,316703.299999997 185851,316715.200000003 185894.299999997,316714.099999994 185906.799999997,316724.099999994 185918.799999997,316751.700000003 185922.400000006,316762.799999997 185927.099999994,316757.799999997 185952.700000003,316738.099999994 185976.900000006,316724.799999997 185992.700000003,316725.700000003 186009.299999997,316734.599999994 186024.900000006,316748.099999994 186056.200000003,316752.200000003 186074.299999997,316744.200000003 186101.599999994,316756.599999994 186130.599999994,316768.099999994 186153.400000006,316782.5 186164.099999994,316797.400000006 186204.599999994,316804.099999994 186214.400000006,316821.299999997 186233.299999997,316855.599999994 186293.5,316873.5 186307.900000006,316911.400000006 186368.099999994,316940.599999994 186424.099999994,316946.599999994 186434.799999997,316961.700000003 186510.599999994,316965 186520.700000003,316979.299999997 186539,316990.599999994 186584.700000003,316994.200000003 186597.700000003,317018.400000006 186638.900000006,317038.700000003 186669.299999997,317070.599999994 186694.299999997,317085.900000006 186722.900000006,317090.400000006 186730.799999997,317089.900000006 186742.299999997,317097.799999997 186764.900000006,317121.5 186810.200000003,317140.299999997 186835.200000003,317160.299999997 186880,317168.5 186905.5,317211.900000006 186991.099999994,317257.900000006 187073.5,317297.700000003 187156,317308.700000003 187177.599999994,317342.200000003 187247.400000006,317351.200000003 187269.299999997,317388.299999997 187349.400000006,317406.700000003 187390.599999994,317474.099999994 187525.799999997,317552.799999997 187692.400000006,317577.200000003 187735.599999994,317621.700000003 187821.5,317694.400000006 187969.400000006,317716.5 188024,317743.900000006 188078.799999997,317781.599999994 188157.799999997,317816 188218.299999997,317863 188324.200000003,317921.099999994 188427.200000003,317971.099999994 188527.799999997,318036.400000006 188645.5,318060.299999997 188697.799999997,318114.5 188796,318127 188812.799999997,318128.599999994 188825.900000006,318159.299999997 188891.799999997,318180.099999994 188930.900000006,318194.200000003 189015.799999997,318211 189076.599999994,318223.299999997 189131.599999994,318239.599999994 189158.200000003,318251.299999997 189190.799999997,318268.200000003 189250.900000006,318290.099999994 189295.900000006,318314.099999994 189331.5,318326 189359.299999997,318331.599999994 189392.400000006,318331.200000003 189414.5,318321.700000003 189446.099999994,318324.400000006 189466.700000003,318348 189514.299999997,318350.900000006 189527.900000006,318347 189560.5,318353.5 189573.799999997,318368.700000003 189581.299999997,318387.299999997 189573.700000003,318412.599999994 189557.400000006,318434.900000006 189556.299999997,318453.099999994 189569.299999997,318486.700000003 189593.700000003,318527.200000003 189625.700000003,318593.799999997 189695.799999997,318624.799999997 189735,318671.599999994 189751.299999997,318712.5 189761,318740.799999997 189776.299999997,318828.400000006 189866.599999994,318846.299999997 189891.900000006,318891.400000006 189930.900000006,318971.599999994 190014.200000003,319012.299999997 190057,319067.5 190111,319094 190146,319121.900000006 190176.099999994,319181.900000006 190242.700000003,319255.200000003 190328.799999997,319268.900000006 190345.099999994,319277.200000003 190348.5,319283.5 190355.400000006,319308.299999997 190373.900000006,319339.599999994 190389.5,319402.200000003 190440.599999994,319459.799999997 190492,319490.5 190530.299999997,319526.700000003 190551.099999994,319546.900000006 190565.5,319601.099999994 190627.799999997,319628.799999997 190653.900000006,319651.200000003 190677.200000003,319665.200000003 190695.700000003,319689.599999994 190724.5,319694.700000003 190733.099999994,319727.299999997 190769,319734 190781,319734.799999997 190805.599999994,319746.900000006 190823.400000006,319765.900000006 190839.5,319777.5 190853.900000006,319788.700000003 190865.099999994,319798.200000003 190883.799999997,319827 190936.400000006,319856 190970.900000006,319880.200000003 191020.099999994,319891.5 191043.700000003,319894.799999997 191077.5,319898.299999997 191100.400000006,319897.599999994 191117.900000006,319905.599999994 191151,319916.200000003 191229.099999994,319916.200000003 191269.299999997,319912.700000003 191276.799999997,319908 191289.599999994,319909.400000006 191307.5,319907.700000003 191320.700000003,319910.900000006 191351.700000003,319914.700000003 191372.799999997,319913.200000003 191394.599999994,319907.900000006 191410.799999997,319913.299999997 191490,319912.599999994 191539.5,319908.200000003 191606.599999994,319907.599999994 191656.099999994,319909 191675.700000003,319904.799999997 191698.099999994,319906 191724.599999994,319907.5 191780.5,319905.599999994 191807,319908.799999997 191826.400000006,319898.700000003 191901.900000006,319899.400000006 191945,319898.700000003 191975.299999997,319903.400000006 192040.599999994,319902.200000003 192087.900000006,319903.5 192124.099999994,319902.200000003 192172.700000003,319905.799999997 192210.400000006,319899 192276.799999997,319904.200000003 192321.900000006,319901.200000003 192370.799999997,319903.400000006 192412,319897.599999994 192444.299999997,319900 192480.299999997,319899.700000003 192501.599999994,319896 192536.799999997,319889.5 192562.400000006,319889.900000006 192590.599999994,319889.599999994 192631.700000003,319892.5 192696.700000003,319893.799999997 192735.5,319895.599999994 192757.400000006,319895.299999997 192774.5,319892.099999994 192782.299999997,319889.5 192819.400000006,319894.5 192881.599999994,319894.700000003 192939,319893.299999997 193003.799999997,319892 193070,319903.200000003 193084,319922.5 193096.200000003,319931.299999997 193115.200000003,319927.200000003 193125.299999997,319913.200000003 193139.799999997,319914.900000006 193153.700000003,319888.799999997 193172.799999997,319889.400000006 193193.200000003,319900.099999994 193208.799999997,319913.700000003 193226.299999997,319913.400000006 193244.5,319902.200000003 193280.599999994,319901.900000006 193307.799999997,319917.400000006 193351.700000003,319931.299999997 193374.700000003,319943.5 193381.5,319980.400000006 193390.400000006,320002.200000003 193401.599999994,320026 193394.400000006,320038.099999994 193393.700000003,320075.299999997 193419.900000006,320092.099999994 193436,320088.799999997 193466.700000003,320107 193486.700000003,320128.400000006 193504.799999997,320146.5 193530.299999997,320146.599999994 193550.599999994,320156.200000003 193565.5,320188.799999997 193587.700000003,320206.900000006 193612.900000006,320218.400000006 193647.099999994,320233.299999997 193687.799999997,320237.099999994 193698.900000006,320243.599999994 193709.5,320242.900000006 193737.299999997,320260.099999994 193767.400000006,320281.900000006 193792.099999994,320291 193791.400000006,320302.900000006 193805.200000003,320306.700000003 193823.299999997,320355.099999994 193942.599999994,320382.599999994 194024.700000003,320389.5 194040.5,320392.700000003 194066.799999997,320406.5 194102.700000003,320419.900000006 194160.599999994,320421 194173.799999997,320432.200000003 194205,320438 194236.099999994,320453.700000003 194272.200000003,320506 194383.200000003,320528.5 194416.299999997,320556.299999997 194461,320569.5 194486.700000003,320625.299999997 194552.299999997,320662.5 194590.099999994,320682.200000003 194624.200000003,320686.099999994 194640,320694.299999997 194655,320701.099999994 194691.5,320706.5 194705.700000003,320717.900000006 194754.099999994,320723.799999997 194780.900000006,320741.5 194927.599999994,320757.299999997 194984.5,320766.400000006 195032.700000003,320770.400000006 195060.799999997,320785.599999994 195110.299999997,320798.799999997 195186.700000003,320806.799999997 195217.200000003,320802.700000003 195240.400000006,320809.5 195271.5,320813.200000003 195307.900000006,320824.200000003 195368,320830.900000006 195401.5,320841.700000003 195427.200000003,320867.400000006 195442.299999997,320895.200000003 195444.299999997,320937.900000006 195442.700000003,320962.5 195457,320981.799999997 195481.599999994,320995.900000006 195488.900000006,321024.5 195484.200000003,321061.400000006 195464.400000006,321080.900000006 195462.799999997,321097.5 195468.5,321106.700000003 195476.700000003,321138.900000006 195495.200000003,321161.299999997 195504.299999997,321179.099999994 195510.900000006,321193.400000006 195514.799999997,321206.099999994 195522.799999997,321231.400000006 195533.799999997,321265.900000006 195556.700000003,321273.900000006 195565.700000003,321281.900000006 195561.299999997,321293.099999994 195566.599999994,321306.400000006 195581.099999994,321322 195588.299999997,321363.599999994 195617.099999994,321376.700000003 195632.099999994,321393.299999997 195637.599999994,321428.299999997 195659.799999997,321444.200000003 195667.200000003,321471.700000003 195684.799999997,321485.900000006 195689.799999997,321500.400000006 195700.5,321548.400000006 195725.799999997,321583.900000006 195761.099999994,321622.700000003 195795.900000006,321652.599999994 195814.099999994,321698.599999994 195832.400000006,321718.200000003 195849,321747 195879.599999994,321762.700000003 195901.299999997,321816.799999997 196000.599999994,321832.5 196027.299999997,321842.700000003 196052.599999994,321896.700000003 196145.599999994,321947.400000006 196223.400000006,321956.099999994 196244.700000003,322010.900000006 196333.400000006,322035.900000006 196374.299999997,322045.599999994 196384.5,322105.700000003 196477,322127.700000003 196518.700000003,322170.400000006 196577.099999994,322196.5 196613.900000006,322229.299999997 196671.799999997,322259.900000006 196719.799999997,322351.099999994 196877.299999997,322365.099999994 196908.599999994,322404.400000006 196969.5,322422.599999994 197016.900000006,322509.5 197143.799999997,322586.400000006 197262.900000006,322602 197300,322627.5 197344.200000003,322640.799999997 197359.299999997,322664.799999997 197396.299999997,322706.799999997 197472.400000006,322726.400000006 197504.799999997,322745.5 197531.700000003,322771.5 197580.900000006,322789.200000003 197609.599999994,322807.5 197633.5,322866 197728.900000006,322892.900000006 197783.400000006,322909.599999994 197806.799999997,322970.799999997 197909.900000006,323046.400000006 198039.400000006,323070.700000003 198083.599999994,323137.200000003 198190.599999994,323148.200000003 198213.400000006,323155.200000003 198229.400000006,323160.299999997 198261.099999994,323185.5 198290.400000006,323204.799999997 198336.5,323208.299999997 198366.200000003,323203.400000006 198380.400000006,323176.099999994 198408.599999994,323165.400000006 198440.700000003,323136.299999997 198482.400000006,323128.799999997 198502.099999994,323131 198520.200000003,323144.799999997 198531.799999997,323160.400000006 198544.400000006,323189.700000003 198588,323201.099999994 198614.400000006,323200.900000006 198625.099999994,323206.700000003 198635.799999997,323209.099999994 198656.400000006,323223.299999997 198687.599999994,323243.599999994 198750.900000006,323260.799999997 198796.900000006,323265.700000003 198808.5,323289.5 198850,323299.400000006 198895.5,323308.599999994 198929.700000003,323318.099999994 198971.299999997,323341.099999994 199038.5,323350.900000006 199070.799999997,323389.900000006 199137,323407.900000006 199164.5,323425.5 199187.099999994,323436.200000003 199203.900000006,323448.700000003 199241.099999994,323455.5 199272.200000003,323477.099999994 199288.299999997,323532.900000006 199315.599999994,323578.799999997 199374.5,323607.200000003 199425.700000003,323625.900000006 199483.599999994,323660.400000006 199516.200000003,323680.799999997 199568.5,323712.299999997 199611.400000006,323757.5 199662.599999994,323802.200000003 199706.299999997,323868.900000006 199758.599999994,323903.299999997 199793.5,323912.900000006 199799.700000003,323896.799999997 199808.299999997,323911.200000003 199818.5,323952.599999994 199858.599999994,323979 199874.299999997,324057.599999994 199944.299999997,324108.599999994 199981.799999997,324141 200034.5,324157.099999994 200064.200000003,324177.099999994 200084.5,324199.5 200092.299999997,324265.5 200100.099999994,324302.099999994 200115.799999997,324361.200000003 200151.299999997,324378.799999997 200166.900000006,324413.299999997 200191.099999994,324462.799999997 200228.5,324483.799999997 200242.700000003,324527 200282.200000003,324548.599999994 200295.700000003,324580.599999994 200327.400000006,324608.5 200348.700000003,324644.200000003 200382.299999997,324700.200000003 200421.599999994,324724.099999994 200435,324764.599999994 200469.5,324803 200498.299999997,324844.099999994 200543.299999997,324863.5 200566.200000003,324914.200000003 200614.599999994,324927 200632.099999994,324963.5 200665.599999994,324992.400000006 200699.700000003,325014.200000003 200719.900000006,325016.5 200732.900000006,325017.5 200761.599999994,325007.700000003 200900.5,324997.5 200953.5,324984.700000003 200978.099999994,324975.799999997 201014.5,324944.900000006 201092.200000003,324937.400000006 201132.200000003,324922.299999997 201161.200000003,324891.700000003 201184.799999997,324866.900000006 201223.900000006,324846.099999994 201252.400000006,324826.799999997 201266,324796.400000006 201287.900000006,324782.799999997 201292.299999997,322222.099999994 202654.799999997,322209.700000003 202660.299999997,319207 204261.700000003,309929.299999997 206015.700000003,309878.599999994 206031.900000006,309837.299999997 206038,309786.700000003 206036.299999997,309767.799999997 206032.700000003,309746.400000006 206036,309732.200000003 206031.299999997,309719.700000003 206031.400000006,309692.099999994 206030.799999997,309663.900000006 206036.299999997,309619.299999997 206037.099999994,309561.799999997 206045.400000006,309519.5 206046.5,309491.900000006 206047,309468.900000006 206048.900000006,309445.299999997 206060.200000003,309422.5 206062.599999994,309374.400000006 206071.900000006,309321.900000006 206089.099999994,309234.400000006 206131.400000006,309134 206203.799999997,309086.599999994 206236,309058.099999994 206251.400000006,309026.200000003 206254.900000006,308998.299999997 206278.299999997,308979 206367.900000006,308959.700000003 206406.099999994,308926.599999994 206443.200000003,308875.700000003 206485.400000006,308779.799999997 206569.200000003,308668.599999994 206648.299999997,308625.299999997 206686.799999997,308559.299999997 206757.799999997,308514 206809.299999997,308476.900000006 206842.900000006,308406.5 206901.900000006,308349.5 206937.200000003,308324.400000006 206942.5,308312.099999994 206934.299999997,308290.599999994 206898.099999994,308276.299999997 206891.400000006,308259 206901.599999994,308246.5 206889.400000006,308235.900000006 206890.599999994,308208.599999994 206912.5,308166.5 206981,308152.200000003 207034.200000003,308149.900000006 207064.599999994,308149.200000003 207093.5,308154.5 207134.400000006,308157.400000006 207149.299999997,308170.099999994 207218,308177.799999997 207233.700000003,308175.400000006 207260.299999997,308155.900000006 207287.5,308148.400000006 207304.599999994,308154.200000003 207325.5,308151.700000003 207350,308156.5 207389.799999997,308161.099999994 207404.200000003,308152 207419.299999997,308141.900000006 207453,308141.900000006 207480.299999997,308128.900000006 207523.5,308108.799999997 207574.700000003,308100.299999997 207603.299999997,308101.5 207631.200000003,308099.099999994 207652.099999994,308101.299999997 207681.5,308110.5 207716.900000006,308084.599999994 207728.700000003,308090.599999994 207741.099999994,308093.400000006 207759.5,308085 207784.099999994,308076.099999994 207818.599999994,308074.799999997 207833.200000003,308082.799999997 207876.400000006,308087.799999997 207899.299999997,308071.200000003 207905,308073.099999994 207915.5,308063.299999997 207919.200000003,308052 207920.900000006,308053.200000003 207930.299999997,308050.200000003 207943.299999997,308038.400000006 207972.400000006,308050.200000003 208005.200000003,308048 208023.200000003,308059.700000003 208032.5,308069.5 208055.900000006,308068.900000006 208102.700000003,308054.900000006 208153.799999997,308042.299999997 208168,308044.599999994 208178,308028.700000003 208200.599999994,308024.700000003 208255.599999994,308018.599999994 208283.700000003,308004.700000003 208305.900000006,307981.200000003 208323.200000003,307984.5 208337.599999994,307978.200000003 208358.099999994,307974 208372.200000003,307963.799999997 208420.799999997,307965.900000006 208464.599999994,307965.299999997 208472.5,307954.900000006 208493.299999997,307948.099999994 208521.299999997,307944.599999994 208558.799999997,307940.400000006 208578.299999997,307955.599999994 208664.799999997,307950.200000003 208736.299999997,307948.200000003 208765.700000003,307959.299999997 208821,307968.799999997 208862.200000003,307963 208894.200000003,307961.400000006 208904.299999997,307969.299999997 208938.5,307969 208983.900000006,307981 209034.200000003,307976.599999994 209085.700000003,307971.5 209104.099999994,307960.299999997 209137.799999997,307945.599999994 209178.900000006,307943.099999994 209227.799999997,307923.599999994 209246.099999994,307922.400000006 209272.599999994,307929.400000006 209300.900000006,307925.700000003 209330.900000006,307916.200000003 209341.099999994,307906.599999994 209363.200000003,307909.599999994 209388.599999994,307882.400000006 209437.400000006,307870.099999994 209482,307876.5 209511.799999997,307896.799999997 209538,307909.599999994 209546.799999997,307912.700000003 209555.700000003,307904 209564.299999997,307883.400000006 209604.5,307880.799999997 209646,307894 209681.799999997,307889.700000003 209696.299999997,307872.700000003 209713,307862.700000003 209731.599999994,307856.299999997 209766.200000003,307844.299999997 209789.200000003,307845.900000006 209828.700000003,307842.799999997 209846.700000003,307853.5 209897,307887.799999997 209958.299999997,307923.200000003 210024.599999994,307926.700000003 210050,307925.200000003 210097.400000006,307927 210155.200000003,307928.200000003 210170.299999997,307920 210276.599999994,307913.900000006 210324.099999994,307908.700000003 210337.200000003,307887.700000003 210355.400000006,307868.799999997 210363.200000003,307853.799999997 210373.400000006,307836.599999994 210380.700000003,307823.400000006 210395.400000006,307836.5 210423.099999994,307864.5 210463.5,307875.599999994 210482.900000006,307880.599999994 210504.799999997,307888.400000006 210530.099999994,307886.5 210571,307883.099999994 210589.5,307878.299999997 210627.099999994,307861.400000006 210676.200000003,307858.099999994 210693.200000003,307879.200000003 210733.799999997,307893 210780,307893.599999994 210796,307886.700000003 210827.400000006,307899.5 210857.700000003,307930 210886.599999994,307939.099999994 210897.5,307951.200000003 210897.799999997,307962.799999997 210919.599999994,307975.099999994 210961.299999997,307983.900000006 210977.599999994,307998.400000006 211017.299999997,308001.700000003 211048.700000003,308006.900000006 211062.099999994,308018.400000006 211098.900000006,308038.799999997 211138.400000006,308064.900000006 211169,308079.5 211183.200000003,308101.700000003 211219.799999997,308119.299999997 211242.400000006,308132.099999994 211274.099999994,308143.299999997 211293.5,308140.200000003 211321.900000006,308127 211344.099999994,308114.799999997 211385.200000003,308101.700000003 211417.799999997,308085.099999994 211448,308081.599999994 211461.5,308066.799999997 211479.299999997,308060.799999997 211506.799999997,308054.5 211522.299999997,308040.599999994 211559,308037.299999997 211567.5,308028.5 211587.200000003,308021.099999994 211597.799999997,308018.299999997 211610.799999997,308010.799999997 211628.799999997,308005.099999994 211647.299999997,307992.900000006 211676.599999994,307981.799999997 211700.200000003,307957.900000006 211763,307936.200000003 211813.599999994,307926.799999997 211834.200000003,307918.299999997 211858.400000006,307902.099999994 211872.099999994,307901.599999994 211882.599999994,307895.900000006 211898.099999994,307852.400000006 211942.799999997,307829.200000003 211987.400000006,307827.5 212029.900000006,307806.900000006 212072.099999994,307799.900000006 212093.700000003,307790.599999994 212111.400000006,307775.099999994 212145.5,307763.299999997 212164.099999994,307751.599999994 212190.400000006,307726.799999997 212237.599999994,307703.099999994 212288.799999997,307707.900000006 212312.799999997,307702 212325.400000006,307658.299999997 212380.900000006,307644.599999994 212400.099999994,307620.400000006 212413.900000006,307584.299999997 212426.900000006,307574.799999997 212442.099999994,307569.799999997 212451.700000003,307564.5 212463.700000003,307563.400000006 212473.200000003,307549.200000003 212485.400000006,307498.5 212569.099999994,307486.900000006 212585.599999994,307481.099999994 212620.700000003,307471.099999994 212653.799999997,307445.5 212694.099999994,307429.799999997 212749.299999997,307421.099999994 212814.200000003,307409.599999994 212842.900000006,307406.5 212869.900000006,307398 212906,307390 212918.5,307391.299999997 212956.900000006,307391.900000006 212994.799999997,307376.400000006 213015.599999994,307366.099999994 213044.099999994,307343.400000006 213084.900000006,307302.599999994 213137.5,307280.5 213158.799999997,307244.700000003 213212.299999997,307228.700000003 213238.900000006,307182.5 213304,307161.900000006 213326.799999997,307154.599999994 213364.799999997,307146.099999994 213381.5,307130.799999997 213396.700000003,307118.599999994 213416.799999997,307096.200000003 213430.700000003,307076.200000003 213432,307068.599999994 213439.599999994,307049.400000006 213477.299999997,307031.5 213507.599999994,307019.799999997 213529.700000003,307002.5 213547.400000006,306939.299999997 213650.700000003,306895.900000006 213709.200000003,306879 213749.900000006,306860.799999997 213813.599999994,306844.200000003 213874.200000003,306833.799999997 213897.799999997,306777.900000006 213903.200000003,306750.799999997 214018.400000006,306747.400000006 214036.900000006,306715.700000003 214108.799999997,306705.099999994 214125.400000006,306685.799999997 214166.700000003,306628.599999994 214263.900000006,306604.599999994 214313.200000003,306585.400000006 214347.900000006,306553.900000006 214393.299999997,306501.900000006 214469.400000006,306470.299999997 214512.299999997,306444.5 214548.700000003,306393.099999994 214614.799999997,306306.599999994 214750.5,306228.599999994 214864.5,306122 215018.900000006,306068.200000003 215095.099999994,306000.900000006 215204.299999997,305992.700000003 215223,305969.799999997 215274.200000003,305936.299999997 215330.700000003,305919.900000006 215359.400000006,305881.900000006 215424.400000006,305849.200000003 215493.700000003,305808.599999994 215566.700000003,305796.599999994 215592.299999997,305775.799999997 215628.200000003,305738.700000003 215697.099999994,305627.299999997 215880.900000006,305598.799999997 215935.299999997,305571.700000003 215987.099999994,305534.599999994 216040.700000003,305522.5 216057.299999997,305463.599999994 216155.099999994,305429.700000003 216209,305358.099999994 216318.900000006,305314.900000006 216390,305218.099999994 216534.599999994,305191 216584,305146.5 216663,305100.5 216727.200000003,305068.400000006 216793.900000006,305030 216862.900000006,304980.400000006 216942.599999994,304943.299999997 216992.5,304866.299999997 217124,304846 217160.799999997,304817.200000003 217203.599999994,304769.5 217297.700000003,304749.299999997 217338.5,304723.299999997 217393.299999997,304681.099999994 217467.299999997,304649.799999997 217538.599999994,304590.299999997 217662.799999997,304555 217746.700000003,304495.200000003 217838.5,304409.5 217989,304368.299999997 218042.599999994,304280.799999997 218211.099999994,304251 218276.5,304207 218355.5,304182.400000006 218412.799999997,304162 218462.5,304132.099999994 218530.299999997,304103.599999994 218614.200000003,304054.400000006 218721.799999997,304030.799999997 218797.5,304017.700000003 218842.099999994,303987.200000003 218927.799999997,303956.799999997 219045.099999994,303947.200000003 219105.599999994,303931 219169.299999997,303924.5 219261.200000003,303881.400000006 219431.599999994,303864.099999994 219476.799999997,303856 219533.200000003,303839.299999997 219688.200000003,303824.299999997 219766.200000003,303819.200000003 219807.799999997,303803.200000003 219863.400000006,303782.799999997 220000.5,303757.099999994 220131.599999994,303739.900000006 220203.700000003,303692 220368.099999994,303678.200000003 220431.299999997,303636.400000006 220547.599999994,303617.099999994 220621.299999997,303599.400000006 220689,303574.5 220780.200000003,303555.200000003 220857.400000006,303543.599999994 220910,303497.799999997 221055.400000006,303466.099999994 221140.200000003,303432.200000003 221243.099999994,303407.799999997 221300.400000006,303377.599999994 221436.599999994,303362.799999997 221508.599999994,303342.200000003 221596.799999997,303330.5 221664.900000006,303305.900000006 221775.5,303295.5 221890.900000006,303273.799999997 222024.900000006,303264 222176.400000006,303260.400000006 222250.799999997,303247.5 222320.799999997,303245.799999997 222443.099999994,303247.400000006 222456.5,303248.299999997 222483,307493.099999994 222616.400000006,307496 222606.900000006,308026.200000003 222622.400000006,308050.700000003 222623.5,312441.799999997 221993.700000003,311818.200000003 217599.400000006,317924.599999994 218352.299999997,318638.900000006 218380.299999997,318654 218373.099999994,325105.799999997 218717.700000003,328449.599999994 222082.299999997,329488.799999997 222431.900000006,333400.700000003 223759.799999997,334532.5 223883.799999997,336703.700000003 223376.400000006,337699 222898.200000003,338396.099999994 223092.599999994,338259.900000006 225268.5,338267.700000003 225279.400000006,338279.5 225283.599999994,338295.700000003 225313.299999997,338327.5 225357.599999994,338350.099999994 225389.200000003,338365.599999994 225402.900000006,338375.900000006 225414.700000003,338410 225468.099999994,338458.799999997 225516.200000003,338491.900000006 225553.599999994,338501.900000006 225572.400000006,338520.599999994 225595.5,338541.299999997 225624.099999994,338561.099999994 225663.200000003,338587 225723.599999994,338605.799999997 225770.200000003,338613.700000003 225810.5,338620 225825.400000006,338632.900000006 225931.900000006,338637.900000006 226013.099999994,338643.5 226035.900000006,338652.200000003 226101.599999994,338660.299999997 226133.900000006,338667.5 226148.799999997,338676.400000006 226187.099999994,338683.400000006 226216.299999997,338701.900000006 226259.5,338733.799999997 226316.299999997,338757.799999997 226356.299999997,338796.700000003 226397.599999994,338821.5 226421.599999994,338833.900000006 226438.900000006,338924.200000003 226569.599999994,338939.200000003 226585.400000006,339013.700000003 226672.5,339080.299999997 226723.799999997,339117.900000006 226742.099999994,339142.900000006 226748.799999997,339162 226752.400000006,339186.799999997 226762,339227 226762.900000006,339270.200000003 226751.099999994,339310.900000006 226731.099999994,339358.299999997 226684,339383 226644.599999994,339411.799999997 226599.200000003,339453.200000003 226553.299999997,339504.400000006 226488.099999994,339556.700000003 226440.400000006,339630.799999997 226385.299999997,339674.799999997 226360.599999994,339688.700000003 226357.900000006,339717.400000006 226351,339730.200000003 226344.799999997,339755.5 226347.400000006,339782.099999994 226341.5,339810.700000003 226349.5,339824.599999994 226348.799999997,339865.5 226372.5,339877.599999994 226382.799999997,339894.299999997 226395,339911.5 226415.200000003,339926.200000003 226446.900000006,339935.099999994 226499.700000003,339932.099999994 226535.599999994,339915.799999997 226573.799999997,339874 226631.299999997,339829.299999997 226673.5,339802.299999997 226708.700000003,339738.400000006 226774.099999994,339695.400000006 226836.200000003,339612.799999997 226943.299999997,339587 226980.099999994,339535.900000006 227041.799999997,339499.299999997 227077.700000003,339456.700000003 227151.299999997,339447.200000003 227171.799999997,339438.700000003 227195.900000006,339429.5 227236.400000006,339438.5 227325.599999994,339456.099999994 227395.599999994,339475.099999994 227451.200000003,339496.099999994 227487.799999997,339505.799999997 227513,339559.400000006 227573,339595.099999994 227605.400000006,339663.099999994 227664.200000003,339720.299999997 227700.700000003,339756.799999997 227717,339772.799999997 227721.799999997,339793.099999994 227738,339866.599999994 227760.599999994,339893.099999994 227762.799999997,339932.400000006 227768.200000003,339980.900000006 227781.299999997,339999.799999997 227794,340042.200000003 227807.799999997,340082.400000006 227833.599999994,340098.900000006 227844.200000003,340117.900000006 227872.900000006,340144.900000006 227925.299999997,340170.299999997 227994.700000003,340182.799999997 228047.5,340195.5 228118.5,340200.900000006 228144.400000006,340200.200000003 228156.299999997,340206.900000006 228182.200000003,340209.200000003 228222.5,340222.5 228268.299999997,340236.299999997 228320.799999997,340236.900000006 228335.799999997,340235.5 228359.799999997,340234.5 228382.799999997,340256.900000006 228463.700000003,346105.400000006 229356.200000003,346132.5 229361.299999997,346156.5 229366.900000006,346255.299999997 229377.799999997,346302.299999997 229388.5,346347.200000003 229389.200000003,346376.599999994 229390.299999997,346482.5 229402,346542.299999997 229410.099999994,346737.5 229441.799999997,346783 229445.700000003,346822.299999997 229453.400000006,346873.400000006 229468.599999994,346965.299999997 229481.099999994,347007.599999994 229482.5,347127.5 229501.400000006,347233.200000003 229516.700000003,347282.700000003 229526.900000006,347319.099999994 229531.799999997,347381.5 229548.299999997,347461.900000006 229562.400000006,347551.099999994 229573,347632.599999994 229580.099999994,347725.700000003 229593.700000003,347866.799999997 229608.400000006,347889.5 229613.900000006,347991 229629.299999997,348037 229636.099999994,348078.799999997 229643.299999997,348129.200000003 229647.5,348184.799999997 229653.200000003,348258.599999994 229659,348357.5 229677.799999997,348429 229689.599999994,348475.200000003 229694.400000006,348493.200000003 229693.5,348542.200000003 229700.799999997,348615.900000006 229705.099999994,348707.5 229718,348757.099999994 229722.799999997,348909.900000006 229746.200000003,349000.5 229753.299999997,349113.5 229768.900000006,349212.5 229784.299999997,349276.400000006 229794.700000003,349386.299999997 229819.5,349515.299999997 229845.799999997,349610.599999994 229860.700000003,349692.799999997 229864.299999997,349756.799999997 229870.400000006,349816.299999997 229882.400000006,349865.099999994 229894.599999994,349920.099999994 229906.599999994,350055.599999994 229936.799999997,350098.799999997 229940.700000003,350203.900000006 229959.5,350425.599999994 229997.799999997,350458.599999994 230001.200000003,350483.400000006 230009.299999997,350550.299999997 230016.799999997,350602.299999997 230025.400000006,350649.099999994 230030.099999994,350745.599999994 230047,350769.599999994 230049.599999994,350812 230056.5,350850.099999994 230061.799999997,350899.200000003 230069.5,350935.299999997 230067.900000006,351026.099999994 230082,351084.200000003 230088.900000006,351122.900000006 230091.900000006,351147.900000006 230097,351151.200000003 230031.5,353161.400000006 230412.299999997,353177 230413.599999994,362053.700000003 231736.700000003,362062.200000003 231744)))
Deleted: trunk/capi/testrunner.sh
--- trunk/capi/testrunner.sh 2009-01-05 23:42:08 UTC (rev 2231)
+++ trunk/capi/testrunner.sh 2009-01-13 01:21:05 UTC (rev 2232)
@@ -1,28 +0,0 @@
-#!/bin/sh
-runner=$1
-shift
-srcdir=$1
-shift
-cat <<EOF > ${runner}
-#!/bin/sh
-./geostest ${srcdir}/test.wkt > test.out
-ret=\$?
-if test "\$ret" -ne "0"; then
- echo "geostest exited with non-zero status (\$ret)"
-fi
-# It's enough that it doesn't segfault for now...
-# computing a diff doesn't currently work as geostest
-# was not initially made taking arch differences into
-# account
-diff ${srcdir}/test.expected test.out >&2
-exit \$ret
-EOF
-chmod +x ${runner}
-echo "Runner: ${runner} created"
Modified: trunk/tests/unit/Makefile.am
--- trunk/tests/unit/Makefile.am 2009-01-05 23:42:08 UTC (rev 2231)
+++ trunk/tests/unit/Makefile.am 2009-01-13 01:21:05 UTC (rev 2232)
@@ -3,8 +3,15 @@
TESTS = geos_unit
+EXTRA_DIST = \
+ capi/brokengrammar \
+ capi/test.expected \
+ capi/test.wkt \
+ capi/testrunner.sh
#noinst_PROGRAMS = geos_unit
-check_PROGRAMS = geos_unit
+check_PROGRAMS = geos_unit geostest threadtest badthreadtest
#bin_PROGRAMS = geos_tut
geos_unit_LDADD = \
@@ -64,3 +71,13 @@
noinst_HEADERS = \
utility.h
+geostest_SOURCES = capi/geostest.c
+geostest_LDADD = $(top_builddir)/capi/libgeos_c.la
+threadtest_SOURCES = capi/threadtest.c
+threadtest_LDADD = $(top_builddir)/capi/libgeos_c.la -lpthread
+badthreadtest_SOURCES = capi/badthreadtest.c
+badthreadtest_LDADD = $(top_builddir)/capi/libgeos_c.la -lpthread
Copied: trunk/tests/unit/capi/geostest.c (from rev 2231, trunk/capi/geostest.c)
--- trunk/tests/unit/capi/geostest.c (rev 0)
+++ trunk/tests/unit/capi/geostest.c 2009-01-13 01:21:05 UTC (rev 2232)
@@ -0,0 +1,383 @@
+ * $Id$
+ * Test for C-Wrapper of GEOS library
+ * Copyright (C) 2005 Refractions Research Inc.
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+ * Author: Sandro Santilli <strk at refractions.net>
+#define _GNU_SOURCE
+#include <stdio.h>
+#include <stdlib.h>
+#include <stdarg.h>
+#include "geos_c.h"
+#define MAXWKTLEN 1047551
+void
+usage(char *me)
+ fprintf(stderr, "Usage: %s <wktfile>\n", me);
+ exit(1);
+void
+notice(const char *fmt, ...) {
+ va_list ap;
+ fprintf( stdout, "NOTICE: ");
+ va_start (ap, fmt);
+ vfprintf( stdout, fmt, ap);
+ va_end(ap);
+ fprintf( stdout, "\n" );
+void
+log_and_exit(const char *fmt, ...) {
+ va_list ap;
+ fprintf( stdout, "ERROR: ");
+ va_end(ap);
+ exit(1);
+GEOSGeometry*
+fineGrainedReconstructionTest(const GEOSGeometry* g1)
+ GEOSCoordSequence* cs;
+ GEOSGeometry* g2;
+ GEOSGeometry* shell;
+ const GEOSGeometry* gtmp;
+ GEOSGeometry**geoms;
+ unsigned int ngeoms, i;
+ int type;
+ /* Geometry reconstruction from CoordSeq */
+ type = GEOSGeomTypeId(g1);
+ switch ( type )
+ case GEOS_POINT:
+ cs = GEOSCoordSeq_clone(GEOSGeom_getCoordSeq(g1));
+ g2 = GEOSGeom_createPoint(cs);
+ return g2;
+ break;
+ case GEOS_LINESTRING:
+ g2 = GEOSGeom_createLineString(cs);
+ return g2;
+ break;
+ case GEOS_LINEARRING:
+ g2 = GEOSGeom_createLinearRing(cs);
+ return g2;
+ break;
+ case GEOS_POLYGON:
+ gtmp = GEOSGetExteriorRing(g1);
+ cs = GEOSCoordSeq_clone(GEOSGeom_getCoordSeq(gtmp));
+ shell = GEOSGeom_createLinearRing(cs);
+ ngeoms = GEOSGetNumInteriorRings(g1);
+ geoms = malloc(ngeoms*sizeof(GEOSGeometry*));
+ for (i=0; i<ngeoms; i++)
+ gtmp = GEOSGetInteriorRingN(g1, i);
+ geoms[i] = GEOSGeom_createLinearRing(cs);
+ g2 = GEOSGeom_createPolygon(shell, geoms, ngeoms);
+ free(geoms);
+ return g2;
+ break;
+ case GEOS_MULTIPOINT:
+ case GEOS_MULTILINESTRING:
+ case GEOS_MULTIPOLYGON:
+ case GEOS_GEOMETRYCOLLECTION:
+ ngeoms = GEOSGetNumGeometries(g1);
+ gtmp = GEOSGetGeometryN(g1, i);
+ geoms[i] = fineGrainedReconstructionTest(gtmp);
+ g2 = GEOSGeom_createCollection(type, geoms, ngeoms);
+ free(geoms);
+ return g2;
+ break;
+ default:
+ log_and_exit("Unknown geometry type %d\n", type);
+ return NULL;
+void
+printHEX(FILE *where, const unsigned char *bytes, size_t n)
+ static char hex[] = "0123456789ABCDEF";
+ int i;
+ for (i=0; i<n; i++)
+ fprintf(where, "%c%c", hex[bytes[i]>>4], hex[bytes[i]&0x0F]);
+int
+do_all(char *inputfile)
+ GEOSGeometry* g1;
+ GEOSGeometry* g2;
+ GEOSGeometry* g3;
+ GEOSGeometry* g4;
+ const GEOSGeometry **gg;
+ unsigned int npoints, ndims;
+ static char wkt[MAXWKTLEN];
+ FILE *input;
+ char *ptr;
+ unsigned char* uptr;
+ size_t size;
+ double dist, area;
+ input = fopen(inputfile, "r");
+ if ( ! input ) { perror("fopen"); exit(1); }
+ size = fread(wkt, 1, MAXWKTLEN-1, input);
+ fclose(input);
+ if ( ! size ) { perror("fread"); exit(1); }
+ if ( size == MAXWKTLEN-1 ) { perror("WKT input too big!"); exit(1); }
+ wkt[size] = '\0'; /* ensure it is null terminated */
+ /* WKT input */
+ g1 = GEOSGeomFromWKT(wkt);
+ /* WKT output */
+ ptr = GEOSGeomToWKT(g1);
+ printf("Input (WKT): %s\n", ptr);
+ free(ptr);
+ /* WKB output */
+ uptr = GEOSGeomToWKB_buf(g1, &size);
+ printf("Input (WKB): "); printHEX(stdout, uptr, size); putchar('\n');
+ /* WKB input */
+ g2 = GEOSGeomFromWKB_buf(uptr, size); free(uptr);
+ if ( ! GEOSEquals(g1, g2) ) log_and_exit("Round WKB conversion failed");
+ GEOSGeom_destroy(g2);
+ /* Size and dimension */
+ npoints = GEOSGetNumCoordinates(g1);
+ ndims = GEOSGeom_getDimensions(g1);
+ printf("Geometry coordinates: %dx%d\n", npoints, ndims);
+ /* Geometry fine-grained deconstruction/reconstruction test */
+ g2 = fineGrainedReconstructionTest(g1);
+ log_and_exit("Reconstruction test failed\n");
+ /* Unary predicates */
+ if ( GEOSisEmpty(g1) ) printf("isEmpty\n");
+ if ( GEOSisValid(g1) ) printf("isValid\n");
+ if ( GEOSisSimple(g1) ) printf("isSimple\n");
+ if ( GEOSisRing(g1) ) printf("isRing\n");
+ /* Convex Hull */
+ g2 = GEOSConvexHull(g1);
+ if ( ! g2 )
+ log_and_exit("GEOSConvexHull() raised an exception");
+ ptr = GEOSGeomToWKT(g2);
+ printf("ConvexHull: %s\n", ptr);
+ free(ptr);
+ /* Buffer */
+ GEOSGeom_destroy(g1);
+ g1 = GEOSBuffer(g2, 100, 30);
+ if ( ! g1 )
+ log_and_exit("GEOSBuffer() raised an exception");
+ printf("Buffer: %s\n", ptr);
+ free(ptr);
+ /* Intersection */
+ g3 = GEOSIntersection(g1, g2);
+ if ( ! GEOSEquals(g3, g2) )
+ GEOSGeom_destroy(g3);
+ log_and_exit("Intersection(g, Buffer(g)) didn't return g");
+ ptr = GEOSGeomToWKT(g3);
+ printf("Intersection: %s\n", ptr);
+ free(ptr);
+ /* Difference */
+ g3 = GEOSDifference(g1, g2);
+ printf("Difference: %s\n", ptr);
+ free(ptr);
+ /* SymDifference */
+ g3 = GEOSSymDifference(g1, g2);
+ printf("SymDifference: %s\n", ptr);
+ free(ptr);
+ /* Boundary */
+ g4 = GEOSBoundary(g3);
+ ptr = GEOSGeomToWKT(g4);
+ printf("Boundary: %s\n", ptr);
+ GEOSGeom_destroy(g4);
+ free(ptr);
+ /* Union */
+ g3 = GEOSUnion(g1, g2);
+ if ( ! GEOSEquals(g3, g1) )
+ log_and_exit("Union(g, Buffer(g)) didn't return Buffer(g)");
+ printf("Union: %s\n", ptr);
+ free(ptr);
+ /* PointOnSurcace */
+ g4 = GEOSPointOnSurface(g3);
+ printf("PointOnSurface: %s\n", ptr);
+ free(ptr);
+ /* Centroid */
+ g3 = GEOSGetCentroid(g2);
+ printf("Centroid: %s\n", ptr);
+ free(ptr);
+ /* Relate (and RelatePattern )*/
+ ptr = GEOSRelate(g1, g2);
+ if ( ! GEOSRelatePattern(g1, g2, ptr) )
+ free(ptr);
+ log_and_exit("! RelatePattern(g1, g2, Relate(g1, g2))");
+ printf("Relate: %s\n", ptr);
+ free(ptr);
+ /* Polygonize */
+ gg = (const GEOSGeometry**)malloc(2*sizeof(GEOSGeometry*));
+ gg[0] = g1;
+ gg[1] = g2;
+ g3 = GEOSPolygonize(gg, 2);
+ free(gg);
+ if ( ! g3 )
+ log_and_exit("Exception running GEOSPolygonize");
+ printf("Polygonize: %s\n", ptr);
+ free(ptr);
+ /* LineMerge */
+ g3 = GEOSLineMerge(g1);
+ if ( ! g3 )
+ log_and_exit("Exception running GEOSLineMerge");
+ printf("LineMerge: %s\n", ptr);
+ free(ptr);
+ /* Binary predicates */
+ if ( GEOSIntersects(g1, g2) ) printf("Intersect\n");
+ if ( GEOSDisjoint(g1, g2) ) printf("Disjoint\n");
+ if ( GEOSTouches(g1, g2) ) printf("Touches\n");
+ if ( GEOSCrosses(g1, g2) ) printf("Crosses\n");
+ if ( GEOSWithin(g1, g2) ) printf("Within\n");
+ if ( GEOSContains(g1, g2) ) printf("Contains\n");
+ if ( GEOSOverlaps(g1, g2) ) printf("Overlaps\n");
+ /* Distance */
+ if ( GEOSDistance(g1, g2, &dist) ) printf("Distance: %g\n", dist);
+ /* Area */
+ if ( GEOSArea(g1, &area) ) printf("Area 1: %g\n", area);
+ if ( GEOSArea(g2, &area) ) printf("Area 2: %g\n", area);
+ /* Simplify */
+ g3 = GEOSSimplify(g1, 0.5);
+ printf("Simplify: %s\n", ptr);
+ free(ptr);
+ /* Topology Preserve Simplify */
+ g3 = GEOSTopologyPreserveSimplify(g1, 0.5);
+ free(ptr);
+ return 0;
+int
+main(int argc, char **argv)
+ int i, n=1;
+ initGEOS(notice, log_and_exit);
+ printf("GEOS version %s\n", GEOSversion());
+ if ( argc < 2 ) usage(argv[0]);
+ if ( argc > 2 ) n=atoi(argv[2]);
+ if ( ! n ) n=1;
+ for (i=0; i<n; i++) {
+ putc('.', stderr); fflush(stderr);
+ do_all(argv[1]);
+ putc('+', stderr); fflush(stderr);
+ putc('\n', stderr);
+ finishGEOS();
+ return EXIT_SUCCESS;
Copied: trunk/tests/unit/capi/test.expected (from rev 2231, trunk/capi/test.expected)
--- trunk/tests/unit/capi/test.expected (rev 0)
+++ trunk/tests/unit/capi/test.expected 2009-01-13 01:21:05 UTC (rev 2232)
@@ -0,0 +1,25 @@
+GEOS version 3.0.0rc2-CAPI-1.3.0
+Input (WKT): MULTIPOLYGON (((362062.2000000029802322 231744.0000000000000000, 362076.0000000000000000 231749.7999999969906639, 362122.2999999970197678 231753.5000000000000000, 362187.0000000000000000 231767.9000000059895683, 362242.0000000000000000 231776.0000000000000000, 362296.2000000029802322 231786.7000000030093361, 362517.0000000000000000 231821.5000000000000000, 362651.7999999970197678 231844.7999999969906639, 362772.7000000029802322 231871.7999999969906639, 362805.0999999939813279 231874.2999999969906639, 362847.2000000029802322 231876.0000000000000000, 362912.7999999970197678 231888.9000000059895683, 363005.9000000060186721 231903.0000000000000000, 363169.2000000029802322 231929.2999999969906639, 363247.9000000060186721 231934.0000000000000000, 363333.9000000060186721 231950.0000000000000000, 363516.0999999939813279 231985.5000000000000000, 363630.2999999970197678 232004.7000000030093361, 363694.7000000029802322 232012.0000000000000000, 363754.0000000000000000 232021.0999999940104317, 363833.4000000060186721 232029.7999999969906639, 363913.5999999939813279 232048.5000000000000000, 363940.5999999939813279 232052.0000000000000000, 364014.7999999970197678 232060.2999999969906639, 364044.7000000029802322 232065.7999999969906639, 364082.7000000029802322 232074.0999999940104317, 364165.2999999970197678 232083.7999999969906639, 364208.5999999939813279 232097.0999999940104317, 364279.7999999970197678 232104.0000000000000000, 364316.7000000029802322 232112.7999999969906639, 364331.2000000029802322 232113.5999999940104317, 364391.2000000029802322 232127.5999999940104317, 364483.7999999970197678 232140.0000000000000000, 364606.7999999970197678 232159.5999999940104317, 364662.7999999970197678 232170.5999999940104317, 364712.9000000060186721 232182.7000000030093361, 364823.7999999970197678 232201.5000000000000000, 364904.9000000060186721 232211.0000000000000000, 364967.2000000029802322 232221.0999999940104317, 365061.2999999970197678 232240.5000000000000000, 365191.0999999939813279 232255.9000000059895683, 365262.9000000060186721 232262.2999999969906639, 365391.7000000029802322 232283.5999999940104317, 365525.2999999970197678 232308.9000000059895683, 365598.4000000060186721 232326.5999999940104317, 365727.0999999939813279 232341.5999999940104317, 365803.0000000000000000 232352.2999999969906639, 365935.4000000060186721 232377.5999999940104317, 366011.5000000000000000 232384.7999999969906639, 366056.0999999939813279 232391.2000000030093361, 366128.7000000029802322 232407.4000000059895683, 366295.5999999939813279 232442.7000000030093361, 366445.2000000029802322 232457.2000000030093361, 366624.7999999970197678 232486.2999999969906639, 366663.2000000029802322 232490.2000000030093361, 366707.2000000029802322 232502.4000000059895683, 366807.0999999939813279 232522.7000000030093361, 366862.9000000060186721 232529.7999999969906639, 366971.0999999939813279 232543.5000000000000000, 367088.0999999939813279 232563.0999999940104317, 367185.2999999970197678 232575.4000000059895683, 367222.2000000029802322 232582.4000000059895683, 367331.7999999970197678 232597.0000000000000000, 367530.2999999970197678 232629.7999999969906639, 367683.5999999939813279 232660.7000000030093361, 367772.5999999939813279 232675.7999999969906639, 367939.0000000000000000 232693.0999999940104317, 367995.5999999939813279 232701.0000000000000000, 368055.0999999939813279 232702.5999999940104317, 368135.0000000000000000 232714.2999999969906639, 368220.7999999970197678 232735.4000000059895683, 368312.5999999939813279 232753.4000000059895683, 368380.7999999970197678 232770.7999999969906639, 368447.2999999970197678 232777.5999999940104317, 368512.0999999939813279 232792.0999999940104317, 368544.0000000000000000 232795.5999999940104317, 368601.7999999970197678 232805.0999999940104317, 368660.7999999970197678 232813.0999999940104317, 368707.2999999970197678 232826.4000000059895683, 368782.5000000000000000 232836.0999999940104317, 368832.5999999939813279 232847.7999999969906639, 368906.5999999939813279 232860.5000000000000000, 368992.5000000000000000 232873.0999999940104317, 369089.0999999939813279 232892.0000000000000000, 369260.5000000000000000 232916.7000000030093361, 369318.7000000029802322 232931.2000000030093361, 369445.5999999939813279 232945.5999999940104317, 369508.7000000029802322 232950.0999999940104317, 369574.2000000029802322 232960.5000000000000000, 369616.0999999939813279 232967.7999999969906639, 369656.2000000029802322 232978.2000000030093361, 369717.7000000029802322 233002.0000000000000000, 369777.7000000029802322 233016.0999999940104317, 369875.4000000060186721 233024.0000000000000000, 370035.0000000000000000 233046.9000000059895683, 370117.0999999939813279 233056.0000000000000000, 370200.0999999939813279 233077.5999999940104317, 370233.5999999939813279 233079.0999999940104317, 370496.9000000060186721 233123.2999999969906639, 370539.4000000060186721 233127.0000000000000000, 370601.7000000029802322 233135.0000000000000000, 370655.2999999970197678 233146.5999999940104317, 370855.0999999939813279 233178.7999999969906639, 370932.7000000029802322 233182.0999999940104317, 371060.0999999939813279 233205.0000000000000000, 371120.7000000029802322 233223.0000000000000000, 371178.5999999939813279 233233.0000000000000000, 371201.7999999970197678 233229.2000000030093361, 371245.2999999970197678 233232.5000000000000000, 371289.9000000060186721 233243.7000000030093361, 371425.7999999970197678 233259.0000000000000000, 371487.5000000000000000 233276.4000000059895683, 371552.2999999970197678 233291.9000000059895683, 371638.0999999939813279 233306.4000000059895683, 371715.0999999939813279 233318.5999999940104317, 371821.2000000029802322 233332.4000000059895683, 371918.2999999970197678 233350.7999999969906639, 371988.0999999939813279 233360.2000000030093361, 372040.7000000029802322 233366.2999999969906639, 372158.5999999939813279 233382.2999999969906639, 372175.5000000000000000 233379.5999999940104317, 372201.0999999939813279 233382.5999999940104317, 372351.2999999970197678 233410.0999999940104317, 372419.0000000000000000 233417.5000000000000000, 372500.7999999970197678 233432.2000000030093361, 372538.7000000029802322 233434.0999999940104317, 372559.2999999970197678 233439.2000000030093361, 372715.7999999970197678 233463.5999999940104317, 372780.9000000060186721 233472.0999999940104317, 372809.5999999939813279 233479.5999999940104317, 372842.9000000060186721 233484.0000000000000000, 372895.9000000060186721 233498.0999999940104317, 372959.7999999970197678 233506.0999999940104317, 372967.7999999970197678 233500.5000000000000000, 372986.0999999939813279 233503.7000000030093361, 373016.2000000029802322 233511.5999999940104317, 373076.5000000000000000 233519.7000000030093361, 373115.5000000000000000 233524.5000000000000000, 373133.9000000060186721 233529.7000000030093361, 373218.7999999970197678 233538.9000000059895683, 373322.5999999939813279 233555.2000000030093361, 373403.9000000060186721 233574.7999999969906639, 373503.5000000000000000 233590.0999999940104317, 373539.5999999939813279 233594.0999999940104317, 373567.7000000029802322 233595.0999999940104317, 373612.9000000060186721 233595.2999999969906639, 373629.5000000000000000 233598.0000000000000000, 373642.2000000029802322 233597.9000000059895683, 373633.7999999970197678 233582.0999999940104317, 373623.7999999970197678 233570.2000000030093361, 373584.0999999939813279 233479.2000000030093361, 373562.9000000060186721 233422.0999999940104317, 373549.0999999939813279 233399.0000000000000000, 373506.7999999970197678 233325.7999999969906639, 373487.2999999970197678 233294.2000000030093361, 373460.2000000029802322 233259.7999999969906639, 373442.0999999939813279 233240.0999999940104317, 373426.7000000029802322 233220.0000000000000000, 373405.4000000060186721 233187.2999999969906639, 373383.0999999939813279 233164.7999999969906639, 373333.5999999939813279 233096.7000000030093361, 373325.5000000000000000 233078.5000000000000000, 373298.2999999970197678 233028.5999999940104317, 373269.2999999970197678 232982.5999999940104317, 373220.0999999939813279 232893.2000000030093361, 373190.7999999970197678 232853.7000000030093361, 373145.4000000060186721 232784.7000000030093361, 373100.9000000060186721 232712.0000000000000000, 373090.4000000060186721 232680.2999999969906639, 373077.5999999939813279 232660.0999999940104317, 373046.4000000060186721 232597.2999999969906639, 373028.9000000060186721 232538.2000000030093361, 373012.4000000060186721 232520.0000000000000000, 373002.5000000000000000 232506.2999999969906639, 372997.2999999970197678 232499.9000000059895683, 372979.9000000060186721 232471.7999999969906639, 372966.5000000000000000 232452.4000000059895683, 372963.0999999939813279 232436.0999999940104317, 372925.2000000029802322 232361.5000000000000000, 372900.0000000000000000 232326.4000000059895683, 372885.7000000029802322 232295.2000000030093361, 372849.7000000029802322 232245.0000000000000000, 372803.2999999970197678 232173.7999999969906639, 372764.9000000060186721 232096.2000000030093361, 372735.2000000029802322 232063.2999999969906639, 372710.9000000060186721 232032.2000000030093361, 372692.5000000000000000 232004.7000000030093361, 372691.9000000060186721 231988.7000000030093361, 372680.0000000000000000 231952.0000000000000000, 372658.5999999939813279 231917.0000000000000000, 372655.5999999939813279 231898.0000000000000000, 372629.7999999970197678 231847.0999999940104317, 372609.7999999970197678 231810.5999999940104317, 372589.2999999970197678 231778.0000000000000000, 372571.0000000000000000 231743.4000000059895683, 372549.4000000060186721 231706.7000000030093361, 372536.9000000060186721 231677.0999999940104317, 372497.9000000060186721 231600.4000000059895683, 372476.7999999970197678 231562.9000000059895683, 372467.5999999939813279 231529.0999999940104317, 372455.0000000000000000 231502.4000000059895683, 372444.2999999970197678 231467.7000000030093361, 372431.0000000000000000 231419.5000000000000000, 372394.5000000000000000 231364.2999999969906639, 372379.0000000000000000 231339.5000000000000000, 372355.0000000000000000 231312.5999999940104317, 372344.0999999939813279 231286.2999999969906639, 372307.7999999970197678 231214.0000000000000000, 372292.0999999939813279 231194.9000000059895683, 372274.5000000000000000 231145.2999999969906639, 372260.0999999939813279 231120.5999999940104317, 372226.2999999970197678 231083.2999999969906639, 372194.2999999970197678 231041.4000000059895683, 372136.4000000060186721 230959.0999999940104317, 372112.7999999970197678 230922.5000000000000000, 372065.5999999939813279 230841.5999999940104317, 372054.0000000000000000 230818.2999999969906639, 372031.7000000029802322 230784.2999999969906639, 372014.7000000029802322 230735.5999999940104317, 371990.4000000060186721 230694.2000000030093361, 371950.7999999970197678 230628.4000000059895683, 371931.7000000029802322 230578.9000000059895683, 371890.9000000060186721 230511.2999999969906639, 371874.9000000060186721 230494.5000000000000000, 371861.4000000060186721 230513.7000000030093361, 371858.0000000000000000 230493.4000000059895683, 371846.0999999939813279 230455.0999999940104317, 371828.0999999939813279 230407.5000000000000000, 371813.2999999970197678 230374.7999999969906639, 371787.7999999970197678 230316.5000000000000000, 371751.2999999970197678 230262.7000000030093361, 371731.5000000000000000 230213.7000000030093361, 371699.2000000029802322 230171.7999999969906639, 371679.2999999970197678 230125.2000000030093361, 371656.5999999939813279 230095.5999999940104317, 371621.4000000060186721 230055.4000000059895683, 371584.2999999970197678 229987.7000000030093361, 371550.0999999939813279 229912.5000000000000000, 371526.9000000060186721 229867.4000000059895683, 371504.7999999970197678 229838.7999999969906639, 371485.5999999939813279 229801.7999999969906639, 371475.5000000000000000 229778.0000000000000000, 371461.4000000060186721 229752.2000000030093361, 371440.7000000029802322 229706.7999999969906639, 371400.7999999970197678 229629.0999999940104317, 371372.4000000060186721 229581.5999999940104317, 371349.4000000060186721 229546.5999999940104317, 371312.2999999970197678 229480.4000000059895683, 371296.2000000029802322 229454.2999999969906639, 371274.9000000060186721 229432.0999999940104317, 371253.0999999939813279 229396.0999999940104317, 371224.5000000000000000 229358.0999999940104317, 371185.5000000000000000 229294.0000000000000000, 371153.2999999970197678 229239.7000000030093361, 371066.4000000060186721 229032.7000000030093361, 371027.5000000000000000 228966.9000000059895683, 371004.7999999970197678 228913.0000000000000000, 370991.0000000000000000 228890.2000000030093361, 370938.0999999939813279 228790.4000000059895683, 370919.2999999970197678 228762.7999999969906639, 370884.2999999970197678 228707.4000000059895683, 370840.0000000000000000 228630.9000000059895683, 370797.2000000029802322 228558.2999999969906639, 370722.5000000000000000 228398.9000000059895683, 370677.2000000029802322 228323.2999999969906639, 370655.5000000000000000 228268.2999999969906639, 370635.0000000000000000 228228.7999999969906639, 370577.7999999970197678 228117.5999999940104317, 370556.9000000060186721 228088.4000000059895683, 370533.5999999939813279 228047.9000000059895683, 370511.2999999970197678 228025.2999999969906639, 370485.2000000029802322 227994.7999999969906639, 370435.7999999970197678 227946.2999999969906639, 370399.7999999970197678 227881.0999999940104317, 370342.5999999939813279 227793.2000000030093361, 370316.4000000060186721 227755.2999999969906639, 370239.5999999939813279 227614.7999999969906639, 370195.0000000000000000 227565.2000000030093361, 370123.2999999970197678 227431.2000000030093361, 370067.0000000000000000 227353.9000000059895683, 370025.5000000000000000 227277.7000000030093361, 369958.5000000000000000 227171.5000000000000000, 369938.7999999970197678 227130.5000000000000000, 369892.7999999970197678 227050.5000000000000000, 369876.7999999970197678 227022.7999999969906639, 369837.7999999970197678 226970.5000000000000000, 369820.7999999970197678 226933.0000000000000000, 369782.4000000060186721 226859.7999999969906639, 369762.0999999939813279 226819.2000000030093361, 369739.0999999939813279 226782.2000000030093361, 369713.0999999939813279 226749.2000000030093361, 369686.5000000000000000 226704.7000000030093361, 369642.4000000060186721 226620.0999999940104317, 369596.2000000029802322 226546.0999999940104317, 369578.5000000000000000 226510.5000000000000000, 369541.4000000060186721 226455.2000000030093361, 369519.0000000000000000 226397.2000000030093361, 369476.7999999970197678 226327.0999999940104317, 369435.5999999939813279 226235.5999999940104317, 369404.9000000060186721 226135.2999999969906639, 369367.4000000060186721 226063.0999999940104317, 369353.7999999970197678 226024.0000000000000000, 369316.9000000060186721 225937.7999999969906639, 369292.9000000060186721 225899.7999999969906639, 369258.7999999970197678 225837.5000000000000000, 369226.0999999939813279 225790.5999999940104317, 369191.9000000060186721 225739.9000000059895683, 369169.7000000029802322 225702.7999999969906639, 369136.7999999970197678 225661.9000000059895683, 369115.5000000000000000 225641.7999999969906639, 368998.0999999939813279 225443.2999999969906639, 368960.2000000029802322 225358.5999999940104317, 368890.7999999970197678 225224.5999999940104317, 368812.7999999970197678 225025.9000000059895683, 368771.7000000029802322 224939.2999999969906639, 368741.9000000060186721 224859.9000000059895683, 368701.4000000060186721 224765.9000000059895683, 368679.0999999939813279 224703.4000000059895683, 368637.0999999939813279 224627.2999999969906639, 368616.7000000029802322 224565.7999999969906639, 368592.7999999970197678 224525.2999999969906639, 368547.5000000000000000 224416.7999999969906639, 368528.0000000000000000 224383.7999999969906639, 368468.5999999939813279 224270.0000000000000000, 368457.2000000029802322 224234.2000000030093361, 368445.0999999939813279 224206.0000000000000000, 368404.4000000060186721 224140.4000000059895683, 368387.0000000000000000 224066.9000000059895683, 368348.7999999970197678 223972.2000000030093361, 368324.5999999939813279 223901.2999999969906639, 368299.0999999939813279 223849.2999999969906639, 368281.0999999939813279 223819.2000000030093361, 368249.7000000029802322 223748.4000000059895683, 368221.7999999970197678 223704.0000000000000000, 368187.0999999939813279 223625.7999999969906639, 368163.5999999939813279 223575.7999999969906639, 368139.7999999970197678 223508.4000000059895683, 368111.0999999939813279 223455.5000000000000000, 368083.9000000060186721 223370.5999999940104317, 368056.0000000000000000 223315.7000000030093361, 368028.7000000029802322 223248.7999999969906639, 368011.0000000000000000 223201.7000000030093361, 367981.7999999970197678 223133.9000000059895683, 367963.4000000060186721 223102.7999999969906639, 367932.0999999939813279 223056.4000000059895683, 367903.2999999970197678 222978.5999999940104317, 367852.0999999939813279 222807.4000000059895683, 367820.5999999939813279 222727.0999999940104317, 367790.0999999939813279 222635.4000000059895683, 367757.7999999970197678 222557.5999999940104317, 367742.4000000060186721 222516.0000000000000000, 367708.2000000029802322 222426.2999999969906639, 367660.2000000029802322 222299.9000000059895683, 367625.7999999970197678 222225.5999999940104317, 367591.7000000029802322 222159.4000000059895683, 367561.2999999970197678 222093.5000000000000000, 367502.2000000029802322 221924.4000000059895683, 367472.9000000060186721 221842.5999999940104317, 367458.5000000000000000 221819.4000000059895683, 367427.7000000029802322 221735.7000000030093361, 367385.0000000000000000 221624.0999999940104317, 367360.5000000000000000 221574.2000000030093361, 367326.0000000000000000 221490.0000000000000000, 367290.2999999970197678 221393.2999999969906639, 367271.2000000029802322 221339.7000000030093361, 367244.0999999939813279 221268.7999999969906639, 367237.2999999970197678 221245.9000000059895683, 367214.0000000000000000 221194.0000000000000000, 367200.4000000060186721 221137.9000000059895683, 367162.2999999970197678 221044.7000000030093361, 367147.0999999939813279 220987.0999999940104317, 367117.7999999970197678 220919.2999999969906639, 367102.7999999970197678 220894.0999999940104317, 367073.5999999939813279 220814.7999999969906639, 367023.4000000060186721 220673.0000000000000000, 366980.0999999939813279 220598.2999999969906639, 366962.0999999939813279 220558.7999999969906639, 366905.7999999970197678 220454.4000000059895683, 366882.4000000060186721 220416.9000000059895683, 366857.0000000000000000 220370.5000000000000000, 366824.4000000060186721 220272.7999999969906639, 366787.5999999939813279 220128.7000000030093361, 366743.9000000060186721 220049.2000000030093361, 366730.5000000000000000 220013.0000000000000000, 366694.7999999970197678 219922.4000000059895683, 366668.2999999970197678 219845.4000000059895683, 366642.2999999970197678 219788.5000000000000000, 366621.0000000000000000 219728.5000000000000000, 366602.0000000000000000 219663.5000000000000000, 366578.2999999970197678 219606.5999999940104317, 366570.7000000029802322 219575.7000000030093361, 366551.5999999939813279 219513.2000000030093361, 366507.5000000000000000 219429.5999999940104317, 366492.0000000000000000 219386.0000000000000000, 366458.4000000060186721 219301.2000000030093361, 366426.7000000029802322 219211.0000000000000000, 366392.9000000060186721 219139.2000000030093361, 366373.0999999939813279 219087.2000000030093361, 366316.5999999939813279 218974.4000000059895683, 366294.7999999970197678 218940.7999999969906639, 366260.7999999970197678 218889.5000000000000000, 366214.2999999970197678 218764.0999999940104317, 366187.5999999939813279 218662.4000000059895683, 366165.0000000000000000 218615.7999999969906639, 366128.7999999970197678 218519.2000000030093361, 366086.9000000060186721 218417.5999999940104317, 366068.7999999970197678 218378.0000000000000000, 366035.0000000000000000 218307.2000000030093361, 366012.2000000029802322 218231.7999999969906639, 365984.7000000029802322 218153.4000000059895683, 365950.2000000029802322 218060.7999999969906639, 365922.0999999939813279 218017.7999999969906639, 365903.4000000060186721 217982.2000000030093361, 365835.2000000029802322 217851.0999999940104317, 365798.5000000000000000 217801.9000000059895683, 365728.4000000060186721 217660.2999999969906639, 365673.2000000029802322 217559.0000000000000000, 365657.5000000000000000 217511.4000000059895683, 365636.9000000060186721 217461.9000000059895683, 365589.2999999970197678 217352.4000000059895683, 365560.7000000029802322 217312.0000000000000000, 365525.2000000029802322 217245.2999999969906639, 365480.9000000060186721 217133.2000000030093361, 365442.5000000000000000 217056.5999999940104317, 365405.9000000060186721 216955.5000000000000000, 365379.2000000029802322 216908.0000000000000000, 365341.2000000029802322 216825.7999999969906639, 365319.2000000029802322 216784.2999999969906639, 365303.2999999970197678 216741.5999999940104317, 365259.2999999970197678 216668.0000000000000000, 365243.2000000029802322 216626.4000000059895683, 365206.9000000060186721 216581.0999999940104317, 365172.5000000000000000 216521.7999999969906639, 365148.7000000029802322 216481.7999999969906639, 365127.2000000029802322 216438.7999999969906639, 365081.2999999970197678 216365.2000000030093361, 365054.5000000000000000 216305.2999999969906639, 365045.0999999939813279 216300.0000000000000000, 365042.4000000060186721 216280.5999999940104317, 365035.0000000000000000 216259.2999999969906639, 365022.9000000060186721 216243.5000000000000000, 365011.7999999970197678 216224.2000000030093361, 364987.5999999939813279 216190.2000000030093361, 364980.9000000060186721 216167.2999999969906639, 364958.2999999970197678 216136.7999999969906639, 364941.7999999970197678 216095.7000000030093361, 364917.7999999970197678 216058.2000000030093361, 364883.2999999970197678 216007.7999999969906639, 364861.2000000029802322 215961.2999999969906639, 364850.2999999970197678 215946.0000000000000000, 364833.7999999970197678 215915.9000000059895683, 364803.7000000029802322 215856.0000000000000000, 364770.0000000000000000 215806.2000000030093361, 364714.7000000029802322 215744.7999999969906639, 364702.5999999939813279 215717.0000000000000000, 364679.5999999939813279 215672.9000000059895683, 364650.7999999970197678 215618.0000000000000000, 364631.7999999970197678 215591.5000000000000000, 364601.0999999939813279 215554.5000000000000000, 364583.7999999970197678 215510.9000000059895683, 364568.5999999939813279 215482.2000000030093361, 364521.5000000000000000 215423.0999999940104317, 364479.2000000029802322 215387.0000000000000000, 364413.2000000029802322 215308.2000000030093361, 364385.2000000029802322 215279.2000000030093361, 364366.2000000029802322 215262.5999999940104317, 364336.4000000060186721 215230.0999999940104317, 364285.0000000000000000 215148.7000000030093361, 364246.2999999970197678 215118.2999999969906639, 364224.5999999939813279 215094.2999999969906639, 364190.0999999939813279 215058.9000000059895683, 364165.0999999939813279 215030.4000000059895683, 364125.7999999970197678 214999.5999999940104317, 364103.5999999939813279 214973.0000000000000000, 364053.5999999939813279 214926.0000000000000000, 364011.7999999970197678 214890.7000000030093361, 363965.5000000000000000 214853.5000000000000000, 363920.7000000029802322 214801.9000000059895683, 363876.5000000000000000 214769.7000000030093361, 363806.2999999970197678 214703.5000000000000000, 363766.7000000029802322 214674.2000000030093361, 363747.7999999970197678 214657.0000000000000000, 363681.7000000029802322 214592.2999999969906639, 363620.5000000000000000 214559.7999999969906639, 363580.2999999970197678 214535.5000000000000000, 363530.5999999939813279 214496.4000000059895683, 363510.2999999970197678 214495.7000000030093361, 363474.9000000060186721 214488.7999999969906639, 363430.5000000000000000 214476.5000000000000000, 363381.0999999939813279 214465.2999999969906639, 363316.5000000000000000 214466.4000000059895683, 363252.5999999939813279 214461.4000000059895683, 363156.7000000029802322 214466.4000000059895683, 363090.7999999970197678 214484.2999999969906639, 363077.5000000000000000 214493.5000000000000000, 363067.0999999939813279 214497.2000000030093361, 363040.0000000000000000 214500.2000000030093361, 362914.5999999939813279 214528.5000000000000000, 362870.2000000029802322 214553.0999999940104317, 362846.2999999970197678 214560.5999999940104317, 362828.4000000060186721 214561.9000000059895683, 362827.0000000000000000 214572.7999999969906639, 362814.0000000000000000 214577.5000000000000000, 362776.5000000000000000 214595.5999999940104317, 362765.4000000060186721 214599.2000000030093361, 362667.9000000060186721 214651.5999999940104317, 362630.2999999970197678 214667.7000000030093361, 362576.0999999939813279 214694.0000000000000000, 362543.2999999970197678 214725.4000000059895683, 362511.9000000060186721 214750.9000000059895683, 362478.0000000000000000 214757.4000000059895683, 362379.2999999970197678 214796.7999999969906639, 362260.2999999970197678 214866.5000000000000000, 362127.0999999939813279 214946.7999999969906639, 362023.9000000060186721 215017.2999999969906639, 361984.0999999939813279 215042.4000000059895683, 361890.5000000000000000 215113.7000000030093361, 361777.5999999939813279 215181.7999999969906639, 361710.0999999939813279 215233.7999999969906639, 361692.4000000060186721 215248.4000000059895683, 361671.7000000029802322 215256.7000000030093361, 361597.9000000060186721 215286.9000000059895683, 361502.5000000000000000 215343.7000000030093361, 361472.0000000000000000 215357.2000000030093361, 361423.7000000029802322 215382.7999999969906639, 361259.2000000029802322 215487.7000000030093361, 361226.5999999939813279 215505.7000000030093361, 361191.5999999939813279 215527.7000000030093361, 361118.7000000029802322 215568.2999999969906639, 360996.0999999939813279 215603.5000000000000000, 360963.9000000060186721 215608.5000000000000000, 360927.7999999970197678 215621.5000000000000000, 360842.7999999970197678 215661.9000000059895683, 360789.5999999939813279 215691.0000000000000000, 360754.0999999939813279 215720.0999999940104317, 360727.2000000029802322 215747.4000000059895683, 360701.7999999970197678 215765.7999999969906639, 360660.5000000000000000 215812.9000000059895683, 360654.2999999970197678 215825.9000000059895683, 360615.2999999970197678 215860.9000000059895683, 360579.2999999970197678 215885.0000000000000000, 360488.2000000029802322 215951.2000000030093361, 360455.4000000060186721 215982.0999999940104317, 360441.2000000029802322 216003.7999999969906639, 360437.7000000029802322 216052.2000000030093361, 360418.2999999970197678 216065.0000000000000000, 360341.0999999939813279 216078.5999999940104317, 360322.0000000000000000 216078.5000000000000000, 360150.7000000029802322 216078.2000000030093361, 359950.5999999939813279 216070.4000000059895683, 359871.2999999970197678 216067.2000000030093361, 359804.9000000060186721 216063.7999999969906639, 359732.7999999970197678 216061.2999999969906639, 359707.2000000029802322 216057.2999999969906639, 359633.7999999970197678 216055.4000000059895683, 359624.4000000060186721 216048.5999999940104317, 359625.9000000060186721 216033.5999999940104317, 359629.0000000000000000 216003.7000000030093361, 359644.5999999939813279 215957.5999999940104317, 359657.4000000060186721 215924.9000000059895683, 359666.5000000000000000 215890.9000000059895683, 359668.4000000060186721 215838.4000000059895683, 359654.0000000000000000 215798.2999999969906639, 359637.7000000029802322 215765.5999999940104317, 359599.0000000000000000 215719.4000000059895683, 359511.2999999970197678 215645.5000000000000000, 359472.4000000060186721 215625.5999999940104317, 359428.0999999939813279 215611.4000000059895683, 359380.9000000060186721 215602.7000000030093361, 359323.5000000000000000 215606.5999999940104317, 359253.0000000000000000 215621.7000000030093361, 359209.9000000060186721 215664.7000000030093361, 359166.5000000000000000 215718.7000000030093361, 359135.7999999970197678 215767.7000000030093361, 359093.5999999939813279 215819.7000000030093361, 359042.4000000060186721 215891.7000000030093361, 359013.2999999970197678 215925.7000000030093361, 358938.2999999970197678 215980.0999999940104317, 358873.5999999939813279 216000.7000000030093361, 358766.2000000029802322 216007.9000000059895683, 358736.2999999970197678 216003.7999999969906639, 358607.9000000060186721 215998.9000000059895683, 358535.5000000000000000 216001.0000000000000000, 358492.4000000060186721 215997.2000000030093361, 358428.0000000000000000 215997.2000000030093361, 358369.5999999939813279 215995.7000000030093361, 358258.4000000060186721 215994.0000000000000000, 358108.0000000000000000 215982.2999999969906639, 357988.2999999970197678 215983.2000000030093361, 357948.2000000029802322 215980.9000000059895683, 357892.0000000000000000 215980.7999999969906639, 357883.2999999970197678 215978.0000000000000000, 357866.4000000060186721 215979.2000000030093361, 357825.2999999970197678 215971.4000000059895683, 357798.2999999970197678 215947.2999999969906639, 357769.2999999970197678 215922.2999999969906639, 357739.2000000029802322 215886.5000000000000000, 357707.9000000060186721 215864.0000000000000000, 357645.7999999970197678 215826.5999999940104317, 357580.5999999939813279 215805.7000000030093361, 357556.2999999970197678 215796.0999999940104317, 357522.7000000029802322 215787.5999999940104317, 357488.9000000060186721 215777.2999999969906639, 357361.5000000000000000 215746.2999999969906639, 357308.2000000029802322 215729.2000000030093361, 357270.5999999939813279 215713.9000000059895683, 357247.7000000029802322 215699.7999999969906639, 357230.2000000029802322 215689.5999999940104317, 357198.4000000060186721 215674.0999999940104317, 357158.5000000000000000 215656.7999999969906639, 357139.4000000060186721 215647.5999999940104317, 357090.0999999939813279 215625.4000000059895683, 357061.0000000000000000 215606.0000000000000000, 357024.7999999970197678 215585.0000000000000000, 356976.7000000029802322 215540.9000000059895683, 356959.7999999970197678 215519.2999999969906639, 356924.2999999970197678 215495.9000000059895683, 356863.9000000060186721 215441.0000000000000000, 356847.4000000060186721 215434.2999999969906639, 356827.2999999970197678 215423.0999999940104317, 356801.4000000060186721 215401.0999999940104317, 356769.0999999939813279 215372.2000000030093361, 356726.2000000029802322 215341.4000000059895683, 356698.5999999939813279 215325.5000000000000000, 356639.7000000029802322 215286.0000000000000000, 356586.0999999939813279 215239.5000000000000000, 356520.0000000000000000 215173.7000000030093361, 356487.9000000060186721 215140.2999999969906639, 356460.0999999939813279 215110.7000000030093361, 356416.2000000029802322 215058.0999999940104317, 356396.2000000029802322 215039.5000000000000000, 356363.0000000000000000 215005.5999999940104317, 356287.2000000029802322 214938.5000000000000000, 356251.5000000000000000 214906.0999999940104317, 356155.7999999970197678 214810.9000000059895683, 356106.7999999970197678 214766.7999999969906639, 355999.7000000029802322 214667.7000000030093361, 355956.2999999970197678 214633.0000000000000000, 355922.0000000000000000 214604.5999999940104317, 355896.7000000029802322 214583.0000000000000000, 355879.5999999939813279 214565.0000000000000000, 355815.9000000060186721 214515.0999999940104317, 355791.4000000060186721 214485.5000000000000000, 355781.2000000029802322 214480.2000000030093361, 355783.5000000000000000 214472.5999999940104317, 355756.4000000060186721 214447.2000000030093361, 355703.5999999939813279 214373.7999999969906639, 355649.7999999970197678 214316.2000000030093361, 355633.7999999970197678 214298.5000000000000000, 355606.4000000060186721 214267.0000000000000000, 355576.4000000060186721 214229.5999999940104317, 355565.0000000000000000 214217.2999999969906639, 355524.7000000029802322 214182.0000000000000000, 355492.0999999939813279 214141.7000000030093361, 355431.7000000029802322 214075.7999999969906639, 355412.5999999939813279 214056.7000000030093361, 355382.2000000029802322 214028.2000000030093361, 355344.5999999939813279 213994.4000000059895683, 355296.9000000060186721 213940.7999999969906639, 355261.2999999970197678 213908.9000000059895683, 355237.5000000000000000 213876.4000000059895683, 355212.5999999939813279 213844.2999999969906639, 355182.2999999970197678 213811.4000000059895683, 355151.2999999970197678 213757.0000000000000000, 355117.9000000060186721 213724.2000000030093361, 355114.5999999939813279 213715.7999999969906639, 355102.5999999939813279 213703.0000000000000000, 355084.9000000060186721 213673.7999999969906639, 355062.2000000029802322 213654.7999999969906639, 355051.5999999939813279 213640.0000000000000000, 355001.7000000029802322 213589.9000000059895683, 355002.5000000000000000 213576.9000000059895683, 354978.7999999970197678 213553.4000000059895683, 354926.5999999939813279 213487.9000000059895683, 354892.5999999939813279 213432.0000000000000000, 354877.4000000060186721 213414.2999999969906639, 354800.9000000060186721 213315.2000000030093361, 354747.7999999970197678 213259.2999999969906639, 354662.7999999970197678 213136.4000000059895683, 354613.2000000029802322 213069.2999999969906639, 354552.2999999970197678 212996.5000000000000000, 354491.9000000060186721 212928.0999999940104317, 354444.7000000029802322 212858.5999999940104317, 354436.5999999939813279 212851.2000000030093361, 354404.2999999970197678 212798.9000000059895683, 354393.2999999970197678 212790.0999999940104317, 354374.9000000060186721 212772.0000000000000000, 354260.0999999939813279 212618.0999999940104317, 354242.0000000000000000 212583.5000000000000000, 354214.5000000000000000 212556.0000000000000000, 354161.7999999970197678 212490.5999999940104317, 354133.0999999939813279 212448.5999999940104317, 354112.5000000000000000 212416.5000000000000000, 354096.7000000029802322 212404.2999999969906639, 354078.5999999939813279 212384.5999999940104317, 354063.2999999970197678 212363.5000000000000000, 354057.2000000029802322 212342.0999999940104317, 354032.7999999970197678 212313.5000000000000000, 354029.7999999970197678 212300.5999999940104317, 353984.7999999970197678 212246.5000000000000000, 353954.7000000029802322 212221.5000000000000000, 353943.5000000000000000 212207.2000000030093361, 353925.7999999970197678 212184.5000000000000000, 353923.2999999970197678 212167.2000000030093361, 353906.2999999970197678 212149.9000000059895683, 353895.2999999970197678 212132.7000000030093361, 353885.7999999970197678 212113.7999999969906639, 353872.7000000029802322 212104.5999999940104317, 353840.4000000060186721 212061.7999999969906639, 353825.5999999939813279 212045.0000000000000000, 353810.9000000060186721 212021.2999999969906639, 353715.5999999939813279 211903.7000000030093361, 353694.4000000060186721 211872.0999999940104317, 353665.0999999939813279 211831.5999999940104317, 353618.5000000000000000 211776.9000000059895683, 353575.2999999970197678 211713.7999999969906639, 353539.5999999939813279 211678.0000000000000000, 353527.0999999939813279 211661.2000000030093361, 353469.5999999939813279 211595.7999999969906639, 353462.0000000000000000 211575.0000000000000000, 353432.0999999939813279 211538.0999999940104317, 353408.7000000029802322 211500.0000000000000000, 353380.5999999939813279 211457.5000000000000000, 353357.0000000000000000 211426.5000000000000000, 353348.7000000029802322 211410.7000000030093361, 353310.2999999970197678 211358.9000000059895683, 353277.4000000060186721 211317.5000000000000000, 353251.2999999970197678 211272.0000000000000000, 353232.7000000029802322 211244.4000000059895683, 353221.5000000000000000 211230.5999999940104317, 353201.2000000029802322 211201.5000000000000000, 353131.0000000000000000 211097.4000000059895683, 353084.2999999970197678 211045.7999999969906639, 353078.2000000029802322 211033.0000000000000000, 353029.7000000029802322 210970.4000000059895683, 353015.0999999939813279 210947.2000000030093361, 353003.7000000029802322 210934.7999999969906639, 352988.2999999970197678 210915.7000000030093361, 352967.4000000060186721 210878.0000000000000000, 352925.7999999970197678 210816.4000000059895683, 352893.0000000000000000 210747.5999999940104317, 352860.4000000060186721 210698.2000000030093361, 352823.7999999970197678 210635.5000000000000000, 352781.7000000029802322 210565.9000000059895683, 352762.5999999939813279 210546.7000000030093361, 352728.0000000000000000 210503.4000000059895683, 352690.5000000000000000 210446.5000000000000000, 352674.4000000060186721 210429.9000000059895683, 352670.0000000000000000 210419.5000000000000000, 352663.7999999970197678 210413.0999999940104317, 352635.7999999970197678 210358.2000000030093361, 352535.7000000029802322 210213.7000000030093361, 352493.9000000060186721 210170.4000000059895683, 352470.7000000029802322 210140.9000000059895683, 352445.7000000029802322 210099.9000000059895683, 352427.5000000000000000 210066.2000000030093361, 352382.2999999970197678 209981.2000000030093361, 352368.5000000000000000 209965.9000000059895683, 352359.0999999939813279 209939.5999999940104317, 352331.0999999939813279 209892.7000000030093361, 352299.2999999970197678 209856.2999999969906639, 352258.7000000029802322 209851.4000000059895683, 352226.5000000000000000 209815.0000000000000000, 352217.5000000000000000 209803.2000000030093361, 352199.7000000029802322 209760.5999999940104317, 352153.9000000060186721 209689.5000000000000000, 352140.0999999939813279 209666.2999999969906639, 352108.5999999939813279 209619.0000000000000000, 352087.2000000029802322 209578.4000000059895683, 352043.9000000060186721 209503.2999999969906639, 352039.9000000060186721 209481.2999999969906639, 352033.9000000060186721 209464.5000000000000000, 352016.7000000029802322 209458.7999999969906639, 352002.7999999970197678 209447.0999999940104317, 351981.2000000029802322 209410.4000000059895683, 351965.4000000060186721 209386.7000000030093361, 351959.0999999939813279 209368.4000000059895683, 351952.7000000029802322 209354.0999999940104317, 351949.4000000060186721 209335.7000000030093361, 351959.5000000000000000 209322.0000000000000000, 351945.2000000029802322 209310.7999999969906639, 351931.9000000060186721 209286.5999999940104317, 351924.2999999970197678 209269.7000000030093361, 351879.7999999970197678 209172.2000000030093361, 351872.0999999939813279 209156.2999999969906639, 351854.7999999970197678 209130.2000000030093361, 351833.7999999970197678 209081.2000000030093361, 351814.2999999970197678 209049.5000000000000000, 351807.2999999970197678 209017.2000000030093361, 351805.2999999970197678 208997.7999999969906639, 351800.0999999939813279 208972.4000000059895683, 351788.0000000000000000 208948.7000000030093361, 351769.7999999970197678 208923.5000000000000000, 351737.5999999939813279 208896.5999999940104317, 351719.7000000029802322 208862.5000000000000000, 351668.5000000000000000 208798.0000000000000000, 351647.7999999970197678 208777.7999999969906639, 351622.7999999970197678 208745.4000000059895683, 351593.4000000060186721 208671.5000000000000000, 351565.7999999970197678 208633.0999999940104317, 351548.9000000060186721 208607.4000000059895683, 351533.5999999939813279 208587.7000000030093361, 351507.0999999939813279 208526.7000000030093361, 351483.5999999939813279 208493.5999999940104317, 351473.2000000029802322 208472.9000000059895683, 351444.5999999939813279 208419.0000000000000000, 351420.0000000000000000 208394.5000000000000000, 351395.7999999970197678 208356.4000000059895683, 351354.2999999970197678 208306.2000000030093361, 351330.7000000029802322 208260.2000000030093361, 351323.0000000000000000 208236.9000000059895683, 351312.0999999939813279 208223.0999999940104317, 351284.7000000029802322 208184.7000000030093361, 351269.2999999970197678 208153.9000000059895683, 351253.9000000060186721 208135.2999999969906639, 351246.9000000060186721 208120.4000000059895683, 351235.7000000029802322 208102.0000000000000000, 351220.0000000000000000 208066.9000000059895683, 351188.2000000029802322 208028.5999999940104317, 351158.2999999970197678 207975.0999999940104317, 351134.2999999970197678 207936.0999999940104317, 351106.9000000060186721 207910.0999999940104317, 351083.7999999970197678 207887.0000000000000000, 351028.2000000029802322 207819.5999999940104317, 351017.7999999970197678 207801.7999999969906639, 350968.2999999970197678 207727.7999999969906639, 350952.5999999939813279 207693.0999999940104317, 350914.9000000060186721 207638.2999999969906639, 350885.7999999970197678 207584.0000000000000000, 350836.0000000000000000 207520.4000000059895683, 350802.2999999970197678 207459.0000000000000000, 350778.5999999939813279 207427.5000000000000000, 350740.5000000000000000 207359.9000000059895683, 350707.7999999970197678 207312.4000000059895683, 350676.4000000060186721 207266.0999999940104317, 350658.7999999970197678 207244.0000000000000000, 350642.9000000060186721 207212.2000000030093361, 350621.5000000000000000 207161.2000000030093361, 350612.0000000000000000 207144.9000000059895683, 350597.2999999970197678 207114.2000000030093361, 350573.9000000060186721 207063.7999999969906639, 350548.7000000029802322 207024.2000000030093361, 350510.5999999939813279 206945.5000000000000000, 350490.7000000029802322 206918.7999999969906639, 350470.9000000060186721 206883.7999999969906639, 350448.7000000029802322 206833.7999999969906639, 350438.0000000000000000 206803.0000000000000000, 350419.2999999970197678 206768.4000000059895683, 350396.2999999970197678 206737.4000000059895683, 350307.7000000029802322 206541.7999999969906639, 350278.2999999970197678 206492.2999999969906639, 350264.7000000029802322 206447.5999999940104317, 350245.2000000029802322 206420.0999999940104317, 350239.2000000029802322 206393.7000000030093361, 350225.4000000060186721 206355.0999999940104317, 350203.7999999970197678 206318.4000000059895683, 350191.7999999970197678 206281.7999999969906639, 350170.2999999970197678 206242.7000000030093361, 350139.7000000029802322 206161.7999999969906639, 350116.2000000029802322 206120.2999999969906639, 350101.9000000060186721 206062.2000000030093361, 350095.0999999939813279 206017.9000000059895683, 350076.2999999970197678 205961.4000000059895683, 350067.2999999970197678 205922.0999999940104317, 350059.0000000000000000 205906.2999999969906639, 350034.5000000000000000 205833.7999999969906639, 350002.0000000000000000 205734.7000000030093361, 349994.7000000029802322 205699.2999999969906639, 349981.0999999939813279 205653.5999999940104317, 349971.5999999939813279 205630.9000000059895683, 349946.5000000000000000 205574.2999999969906639, 349921.2000000029802322 205527.4000000059895683, 349880.2000000029802322 205445.2999999969906639, 349855.5000000000000000 205409.2999999969906639, 349843.7000000029802322 205381.5000000000000000, 349826.5000000000000000 205338.4000000059895683, 349812.5000000000000000 205318.7000000030093361, 349796.0999999939813279 205294.5000000000000000, 349791.2999999970197678 205267.5999999940104317, 349783.4000000060186721 205237.2999999969906639, 349785.5999999939813279 205189.5000000000000000, 349787.5000000000000000 205149.9000000059895683, 349793.7999999970197678 205129.4000000059895683, 349804.7000000029802322 205105.7999999969906639, 349807.2000000029802322 205080.9000000059895683, 349789.0999999939813279 205031.2999999969906639, 349773.2999999970197678 204995.5000000000000000, 349754.2999999970197678 204967.0000000000000000, 349734.0000000000000000 204914.9000000059895683, 349710.7999999970197678 204872.2999999969906639, 349694.0999999939813279 204833.2000000030093361, 349681.0000000000000000 204808.5000000000000000, 349660.2999999970197678 204758.9000000059895683, 349639.2999999970197678 204711.5000000000000000, 349627.0000000000000000 204694.2000000030093361, 349598.4000000060186721 204651.7000000030093361, 349558.0999999939813279 204591.0000000000000000, 349538.7000000029802322 204553.9000000059895683, 349515.9000000060186721 204519.4000000059895683, 349492.5000000000000000 204467.2999999969906639, 349480.5000000000000000 204430.0999999940104317, 349481.7999999970197678 204403.7000000030093361, 349495.0000000000000000 204367.5999999940104317, 349503.2000000029802322 204334.5999999940104317, 349510.5999999939813279 204280.0000000000000000, 349497.5999999939813279 204248.7999999969906639, 349474.7999999970197678 204224.2999999969906639, 349446.0999999939813279 204199.7999999969906639, 349390.2999999970197678 204161.2999999969906639, 349339.7000000029802322 204111.7000000030093361, 349275.7000000029802322 204003.2000000030093361, 349229.4000000060186721 203905.9000000059895683, 349207.9000000060186721 203842.7000000030093361, 349184.9000000060186721 203794.4000000059895683, 349161.2999999970197678 203725.2999999969906639, 349151.4000000060186721 203692.7999999969906639, 349129.0999999939813279 203631.0000000000000000, 349101.7999999970197678 203550.7999999969906639, 349078.7999999970197678 203504.0999999940104317, 349046.2999999970197678 203443.7999999969906639, 349010.7000000029802322 203349.2999999969906639, 349006.2999999970197678 203325.7000000030093361, 348989.0000000000000000 203263.5999999940104317, 348975.0999999939813279 203228.7000000030093361, 348936.9000000060186721 203132.5000000000000000, 348893.4000000060186721 202993.2999999969906639, 348874.9000000060186721 202924.2000000030093361, 348827.4000000060186721 202790.2999999969906639, 348795.0999999939813279 202738.0000000000000000, 348778.5999999939813279 202708.7999999969906639, 348734.0000000000000000 202608.5000000000000000, 348714.7999999970197678 202559.4000000059895683, 348681.9000000060186721 202471.4000000059895683, 348664.9000000060186721 202410.2999999969906639, 348647.7999999970197678 202366.5000000000000000, 348607.5999999939813279 202268.9000000059895683, 348603.2999999970197678 202260.2000000030093361, 348573.7000000029802322 202189.0999999940104317, 348561.7999999970197678 202157.2999999969906639, 348554.0999999939813279 202129.7000000030093361, 348541.2000000029802322 202100.7999999969906639, 348538.7000000029802322 202088.0999999940104317, 348533.4000000060186721 202062.5000000000000000, 348529.0999999939813279 202051.7000000030093361, 348517.7000000029802322 202010.5999999940104317, 348500.0999999939813279 201994.9000000059895683, 348493.7000000029802322 201986.5999999940104317, 348474.5000000000000000 201949.2999999969906639, 348468.7000000029802322 201906.5999999940104317, 348455.0000000000000000 201870.2999999969906639, 348437.7000000029802322 201827.9000000059895683, 348416.7999999970197678 201787.0000000000000000, 348409.7999999970197678 201770.4000000059895683, 348373.4000000060186721 201718.9000000059895683, 348369.2999999970197678 201703.0000000000000000, 348361.5000000000000000 201684.4000000059895683, 348366.7999999970197678 201670.2000000030093361, 348357.7000000029802322 201646.5999999940104317, 348347.5999999939813279 201624.0000000000000000, 348337.7999999970197678 201601.2999999969906639, 348328.7999999970197678 201591.9000000059895683, 348305.4000000060186721 201501.0000000000000000, 348280.2000000029802322 201448.7999999969906639, 348274.0000000000000000 201440.4000000059895683, 348256.7999999970197678 201412.5999999940104317, 348222.4000000060186721 201350.7000000030093361, 348209.2000000029802322 201327.9000000059895683, 348179.7999999970197678 201279.0000000000000000, 348154.7000000029802322 201235.0000000000000000, 348149.9000000060186721 201212.7000000030093361, 348140.5999999939813279 201190.7000000030093361, 348121.0999999939813279 201148.0000000000000000, 348111.2000000029802322 201129.5000000000000000, 348103.5999999939813279 201097.0000000000000000, 348097.0000000000000000 201022.5000000000000000, 348083.5000000000000000 200995.5000000000000000, 348047.5999999939813279 200940.7999999969906639, 348027.0999999939813279 200916.4000000059895683, 347997.5999999939813279 200894.4000000059895683, 347951.7999999970197678 200833.2999999969906639, 347933.4000000060186721 200791.7000000030093361, 347929.7999999970197678 200765.5999999940104317, 347913.0000000000000000 200717.5999999940104317, 347886.7999999970197678 200685.7000000030093361, 347875.2000000029802322 200667.9000000059895683, 347838.7999999970197678 200623.2999999969906639, 347815.4000000060186721 200583.7999999969906639, 347804.7999999970197678 200567.5999999940104317, 347798.4000000060186721 200547.9000000059895683, 347781.7999999970197678 200509.2999999969906639, 347760.7000000029802322 200484.2000000030093361, 347732.5999999939813279 200444.2999999969906639, 347703.4000000060186721 200392.5999999940104317, 347686.0999999939813279 200363.0999999940104317, 347665.2999999970197678 200341.7000000030093361, 347626.7999999970197678 200296.2999999969906639, 347589.2000000029802322 200263.5999999940104317, 347531.9000000060186721 200206.7000000030093361, 347505.0000000000000000 200189.7000000030093361, 347455.5999999939813279 200145.2999999969906639, 347435.7000000029802322 200129.9000000059895683, 347389.0000000000000000 200102.0000000000000000, 347283.9000000060186721 200050.0000000000000000, 347184.2999999970197678 200008.4000000059895683, 347141.0999999939813279 199982.2000000030093361, 347094.4000000060186721 199954.5000000000000000, 347081.9000000060186721 199936.0000000000000000, 347065.0000000000000000 199901.5000000000000000, 347060.2999999970197678 199886.9000000059895683, 347052.0000000000000000 199860.4000000059895683, 347041.0000000000000000 199814.4000000059895683, 347037.4000000060186721 199800.2000000030093361, 347039.7999999970197678 199787.7000000030093361, 347034.5000000000000000 199753.4000000059895683, 347017.2999999970197678 199708.5000000000000000, 346992.7999999970197678 199693.4000000059895683, 346979.7999999970197678 199674.2000000030093361, 346976.2999999970197678 199635.5000000000000000, 346957.5000000000000000 199602.2000000030093361, 346928.0999999939813279 199553.2999999969906639, 346912.5999999939813279 199523.9000000059895683, 346898.7999999970197678 199497.2000000030093361, 346891.7999999970197678 199472.0999999940104317, 346883.4000000060186721 199455.5000000000000000, 346872.2000000029802322 199416.5000000000000000, 346854.4000000060186721 199384.4000000059895683, 346849.2000000029802322 199371.0999999940104317, 346831.7000000029802322 199346.2000000030093361, 346822.7999999970197678 199319.0000000000000000, 346804.9000000060186721 199292.4000000059895683, 346778.5000000000000000 199226.2999999969906639, 346769.7999999970197678 199211.5000000000000000, 346751.7999999970197678 199158.5999999940104317, 346733.7000000029802322 199123.0000000000000000, 346717.7999999970197678 199091.0000000000000000, 346701.7999999970197678 199060.7000000030093361, 346685.5999999939813279 199036.9000000059895683, 346682.7000000029802322 199019.5000000000000000, 346677.9000000060186721 199009.5999999940104317, 346672.5000000000000000 198996.7999999969906639, 346657.2999999970197678 198960.5000000000000000, 346640.0000000000000000 198874.7999999969906639, 346638.2000000029802322 198824.5000000000000000, 346633.5000000000000000 198808.2999999969906639, 346625.2000000029802322 198758.5999999940104317, 346619.7000000029802322 198743.9000000059895683, 346610.5999999939813279 198709.9000000059895683, 346588.0000000000000000 198658.2000000030093361, 346571.5000000000000000 198627.2000000030093361, 346561.0000000000000000 198615.9000000059895683, 346546.2999999970197678 198587.7999999969906639, 346532.9000000060186721 198544.2999999969906639, 346526.7999999970197678 198533.2000000030093361, 346524.2000000029802322 198521.5000000000000000, 346509.9000000060186721 198481.9000000059895683, 346504.2999999970197678 198448.5000000000000000, 346477.0000000000000000 198369.0999999940104317, 346472.5000000000000000 198338.7000000030093361, 346472.2999999970197678 198315.4000000059895683, 346473.4000000060186721 198277.4000000059895683, 346464.4000000060186721 198268.5999999940104317, 346444.0000000000000000 198217.0000000000000000, 346428.9000000060186721 198158.7000000030093361, 346428.7000000029802322 198125.7999999969906639, 346432.2000000029802322 198103.5000000000000000, 346447.4000000060186721 198074.2999999969906639, 346443.7000000029802322 198060.7000000030093361, 346433.9000000060186721 198028.7000000030093361, 346412.2999999970197678 198003.7999999969906639, 346399.2000000029802322 197987.7999999969906639, 346393.5999999939813279 197971.9000000059895683, 346390.2000000029802322 197941.5999999940104317, 346396.9000000060186721 197911.7999999969906639, 346401.5000000000000000 197880.2000000030093361, 346416.5000000000000000 197832.2000000030093361, 346433.5000000000000000 197790.7000000030093361, 346449.7999999970197678 197751.9000000059895683, 346467.7000000029802322 197704.2999999969906639, 346480.2000000029802322 197686.2999999969906639, 346501.2000000029802322 197682.5000000000000000, 346537.2999999970197678 197670.9000000059895683, 346548.7000000029802322 197661.2999999969906639, 346557.0999999939813279 197624.7000000030093361, 346548.5999999939813279 197600.4000000059895683, 346538.5000000000000000 197586.9000000059895683, 346514.5000000000000000 197571.7999999969906639, 346473.2999999970197678 197580.2000000030093361, 346442.0999999939813279 197576.2000000030093361, 346408.7999999970197678 197557.5000000000000000, 346356.4000000060186721 197535.0999999940104317, 346302.9000000060186721 197505.5000000000000000, 346269.7999999970197678 197463.0999999940104317, 346250.7000000029802322 197445.2999999969906639, 346244.7999999970197678 197431.0000000000000000, 346229.7999999970197678 197391.0999999940104317, 346222.5000000000000000 197356.2000000030093361, 346209.2999999970197678 197330.9000000059895683, 346193.0000000000000000 197295.7000000030093361, 346170.2999999970197678 197240.5000000000000000, 346163.5999999939813279 197206.9000000059895683, 346147.2999999970197678 197158.7999999969906639, 346132.0000000000000000 197126.2000000030093361, 346111.7000000029802322 197075.4000000059895683, 346099.5999999939813279 197040.5999999940104317, 346092.0999999939813279 197005.7999999969906639, 346090.7000000029802322 196966.2000000030093361, 346079.0999999939813279 196914.5000000000000000, 346060.7000000029802322 196874.2999999969906639, 346038.7000000029802322 196845.7999999969906639, 346026.5000000000000000 196800.5999999940104317, 346012.9000000060186721 196730.2999999969906639, 346005.0000000000000000 196697.5000000000000000, 345993.0000000000000000 196683.4000000059895683, 345968.2999999970197678 196635.5000000000000000, 345943.5999999939813279 196562.7999999969906639, 345932.5000000000000000 196492.7999999969906639, 345911.2999999970197678 196413.0999999940104317, 345907.0999999939813279 196382.7999999969906639, 345903.7000000029802322 196356.2999999969906639, 345887.0999999939813279 196300.7000000030093361, 345882.0000000000000000 196257.7999999969906639, 345872.5999999939813279 196226.7000000030093361, 345876.7999999970197678 196207.2000000030093361, 345898.2000000029802322 196172.2000000030093361, 345896.2999999970197678 196162.7000000030093361, 345882.7000000029802322 196134.0000000000000000, 345842.7999999970197678 196099.9000000059895683, 345826.5000000000000000 196087.5000000000000000, 345810.5999999939813279 196071.5999999940104317, 345791.9000000060186721 196032.9000000059895683, 345789.4000000060186721 196011.5000000000000000, 345799.2999999970197678 195979.4000000059895683, 345779.0999999939813279 195887.7000000030093361, 345771.7999999970197678 195829.7999999969906639, 345756.5000000000000000 195784.2000000030093361, 345756.2999999970197678 195752.7000000030093361, 345778.5000000000000000 195741.0999999940104317, 345766.2999999970197678 195722.7000000030093361, 345754.5999999939813279 195711.9000000059895683, 345731.0999999939813279 195677.5000000000000000, 345732.2000000029802322 195630.5999999940104317, 345728.2999999970197678 195611.7999999969906639, 345714.2999999970197678 195586.2999999969906639, 345675.0999999939813279 195564.7000000030093361, 345664.7999999970197678 195557.5999999940104317, 345637.2000000029802322 195541.7999999969906639, 345605.2000000029802322 195509.0000000000000000, 345590.2999999970197678 195471.0000000000000000, 345588.5999999939813279 195416.2000000030093361, 345582.9000000060186721 195362.4000000059895683, 345575.9000000060186721 195332.0999999940104317, 345567.9000000060186721 195285.9000000059895683, 345574.5999999939813279 195259.7000000030093361, 345582.0000000000000000 195228.2000000030093361, 345574.0999999939813279 195183.9000000059895683, 345564.5000000000000000 195158.7000000030093361, 345558.0999999939813279 195127.0999999940104317, 345559.2999999970197678 195056.2999999969906639, 345557.4000000060186721 194980.0000000000000000, 345552.9000000060186721 194913.0000000000000000, 345553.0999999939813279 194872.2999999969906639, 345553.0000000000000000 194814.4000000059895683, 345554.7000000029802322 194766.7999999969906639, 345550.5999999939813279 194687.7999999969906639, 345552.2999999970197678 194655.4000000059895683, 345550.5999999939813279 194615.7999999969906639, 345547.7999999970197678 194573.2000000030093361, 345549.2000000029802322 194434.2999999969906639, 345548.4000000060186721 194378.0999999940104317, 345544.7999999970197678 194326.7999999969906639, 345545.5999999939813279 194273.4000000059895683, 345543.4000000060186721 194229.5000000000000000, 345542.4000000060186721 194102.4000000059895683, 345542.7999999970197678 194045.5000000000000000, 345545.2999999970197678 193957.7000000030093361, 345538.2000000029802322 193757.0999999940104317, 345532.7000000029802322 193721.5000000000000000, 345532.2999999970197678 193642.2000000030093361, 345535.0000000000000000 193526.7000000030093361, 345532.9000000060186721 193482.0000000000000000, 345535.2999999970197678 193417.9000000059895683, 345532.0999999939813279 193351.0000000000000000, 345531.4000000060186721 193304.0999999940104317, 345525.0000000000000000 193187.7999999969906639, 345527.5999999939813279 193120.2999999969906639, 345541.5000000000000000 193070.5000000000000000, 345553.7999999970197678 193027.4000000059895683, 345555.0999999939813279 192987.5000000000000000, 345553.9000000060186721 192962.2999999969906639, 345544.5000000000000000 192948.2999999969906639, 345523.2000000029802322 192916.4000000059895683, 345509.7999999970197678 192880.2000000030093361, 345484.9000000060186721 192773.9000000059895683, 345476.9000000060186721 192725.9000000059895683, 345464.7999999970197678 192692.7999999969906639, 345451.9000000060186721 192660.4000000059895683, 345428.7000000029802322 192543.0999999940104317, 345420.9000000060186721 192509.7999999969906639, 345402.0000000000000000 192438.0000000000000000, 345388.0000000000000000 192381.4000000059895683, 345352.2999999970197678 192249.0000000000000000, 345326.2000000029802322 192158.4000000059895683, 345323.5999999939813279 192145.4000000059895683, 345307.4000000060186721 192097.5000000000000000, 345287.5999999939813279 192047.0000000000000000, 345278.2000000029802322 192027.2000000030093361, 345268.0999999939813279 192002.2000000030093361, 345251.9000000060186721 191950.2999999969906639, 345235.9000000060186721 191907.9000000059895683, 345220.5999999939813279 191865.2999999969906639, 345207.7999999970197678 191833.5000000000000000, 345178.7999999970197678 191738.4000000059895683, 345161.4000000060186721 191684.0999999940104317, 345144.4000000060186721 191627.5999999940104317, 345124.2000000029802322 191550.0999999940104317, 345112.7000000029802322 191523.0000000000000000, 345106.7999999970197678 191499.9000000059895683, 345089.2000000029802322 191461.7999999969906639, 345078.7000000029802322 191418.5999999940104317, 345054.5000000000000000 191360.9000000059895683, 345041.7999999970197678 191312.5999999940104317, 345030.5000000000000000 191287.7000000030093361, 345024.0999999939813279 191256.0999999940104317, 344975.4000000060186721 191082.7999999969906639, 344937.0000000000000000 190983.7000000030093361, 344909.0999999939813279 190875.7999999969906639, 344902.4000000060186721 190841.2999999969906639, 344887.2999999970197678 190805.5000000000000000, 344875.0000000000000000 190759.9000000059895683, 344864.0000000000000000 190728.2000000030093361, 344825.5000000000000000 190666.2000000030093361, 344794.7000000029802322 190596.5000000000000000, 344763.5000000000000000 190542.4000000059895683, 344741.5999999939813279 190487.2000000030093361, 344732.2999999970197678 190443.9000000059895683, 344723.7000000029802322 190372.5000000000000000, 344720.9000000060186721 190331.0999999940104317, 344715.4000000060186721 190306.0000000000000000, 344711.5000000000000000 190288.4000000059895683, 344700.0999999939813279 190241.7000000030093361, 344691.7999999970197678 190186.4000000059895683, 344686.5000000000000000 190175.2999999969906639, 344678.0000000000000000 190139.5000000000000000, 344657.7000000029802322 190075.5000000000000000, 344638.2999999970197678 189943.7999999969906639, 344615.9000000060186721 189896.0999999940104317, 344607.0999999939813279 189865.2999999969906639, 344602.2999999970197678 189854.2999999969906639, 344588.5000000000000000 189802.7999999969906639, 344583.0000000000000000 189777.5999999940104317, 344573.7999999970197678 189711.7000000030093361, 344548.7000000029802322 189646.4000000059895683, 344525.5999999939813279 189563.7999999969906639, 344487.4000000060186721 189433.2000000030093361, 344461.5000000000000000 189319.5999999940104317, 344457.0000000000000000 189292.7999999969906639, 344449.7000000029802322 189257.4000000059895683, 344442.7999999970197678 189214.5000000000000000, 344431.0999999939813279 189181.9000000059895683, 344418.4000000060186721 189132.2999999969906639, 344397.2999999970197678 189060.0000000000000000, 344384.7999999970197678 188995.9000000059895683, 344373.5999999939813279 188938.7999999969906639, 344365.0999999939813279 188892.7000000030093361, 344356.0999999939813279 188869.4000000059895683, 344347.2999999970197678 188837.0999999940104317, 344332.5999999939813279 188782.5000000000000000, 344311.2000000029802322 188714.0000000000000000, 344300.2999999970197678 188677.2000000030093361, 344276.4000000060186721 188503.0999999940104317, 344256.9000000060186721 188448.5000000000000000, 344232.0999999939813279 188387.0000000000000000, 344209.0999999939813279 188316.7999999969906639, 344177.5000000000000000 188213.2999999969906639, 344156.7999999970197678 188165.9000000059895683, 344136.7000000029802322 188122.0999999940104317, 344109.5999999939813279 188073.9000000059895683, 344096.4000000060186721 188038.5000000000000000, 344084.4000000060186721 188010.2999999969906639, 344074.0999999939813279 187978.0000000000000000, 344032.0000000000000000 187900.0000000000000000, 344018.2000000029802322 187865.5999999940104317, 344007.7999999970197678 187843.5999999940104317, 343976.7999999970197678 187763.2999999969906639, 343967.7999999970197678 187737.0000000000000000, 343950.4000000060186721 187688.0999999940104317, 343935.9000000060186721 187627.2999999969906639, 343929.9000000060186721 187612.2999999969906639, 343929.0999999939813279 187571.7999999969906639, 343920.7000000029802322 187561.4000000059895683, 343898.0999999939813279 187528.5000000000000000, 343832.2000000029802322 187399.4000000059895683, 343803.9000000060186721 187338.5000000000000000, 343759.5999999939813279 187216.2000000030093361, 343739.2999999970197678 187174.4000000059895683, 343711.2000000029802322 187121.5000000000000000, 343642.0000000000000000 186939.2999999969906639, 343594.5000000000000000 186828.0000000000000000, 343552.4000000060186721 186695.5999999940104317, 343494.9000000060186721 186553.9000000059895683, 343465.4000000060186721 186459.2000000030093361, 343458.2999999970197678 186417.9000000059895683, 343430.7000000029802322 186333.5000000000000000, 343426.9000000060186721 186314.7999999969906639, 343329.7000000029802322 185976.7999999969906639, 343299.7999999970197678 185837.0999999940104317, 343287.5000000000000000 185760.4000000059895683, 343279.0000000000000000 185682.9000000059895683, 343262.5000000000000000 185542.9000000059895683, 343262.2999999970197678 185487.2999999969906639, 343257.5000000000000000 185408.7999999969906639, 343226.7999999970197678 185225.0999999940104317, 343219.5999999939813279 185150.5000000000000000, 343202.5999999939813279 185068.4000000059895683, 343186.2000000029802322 184961.9000000059895683, 343187.4000000060186721 184936.9000000059895683, 343184.0000000000000000 184869.4000000059895683, 343185.5999999939813279 184836.5000000000000000, 343185.7999999970197678 184672.7000000030093361, 343180.7000000029802322 184543.2999999969906639, 343176.9000000060186721 184427.2000000030093361, 343170.0999999939813279 184292.9000000059895683, 343164.0999999939813279 184241.0000000000000000, 343167.2999999970197678 184175.5999999940104317, 343160.2999999970197678 184119.4000000059895683, 343158.5000000000000000 184074.2999999969906639, 343148.0000000000000000 184014.4000000059895683, 343128.0999999939813279 183934.0999999940104317, 343107.0000000000000000 183870.5999999940104317, 343107.4000000060186721 183861.5999999940104317, 343116.9000000060186721 183815.9000000059895683, 343125.5000000000000000 183762.0000000000000000, 343130.0000000000000000 183746.7999999969906639, 343143.7000000029802322 183724.5999999940104317, 343185.5000000000000000 183676.0999999940104317, 343208.5999999939813279 183661.7999999969906639, 343232.7999999970197678 183632.7000000030093361, 343257.4000000060186721 183608.2000000030093361, 343296.5000000000000000 183578.9000000059895683, 343351.2999999970197678 183551.5999999940104317, 343474.2999999970197678 183521.5000000000000000, 343570.0000000000000000 183499.5999999940104317, 343621.9000000060186721 183474.5999999940104317, 343668.9000000060186721 183454.0000000000000000, 343698.7999999970197678 183446.5000000000000000, 343793.7999999970197678 183417.2999999969906639, 343834.2000000029802322 183406.7999999969906639, 343910.9000000060186721 183381.5999999940104317, 343966.0000000000000000 183371.7999999969906639, 344065.4000000060186721 183344.7999999969906639, 344173.7000000029802322 183312.7000000030093361, 344197.2999999970197678 183310.2999999969906639, 344344.5999999939813279 183294.0000000000000000, 344392.0999999939813279 183293.4000000059895683, 344478.2999999970197678 183311.2999999969906639, 344503.2999999970197678 183318.0999999940104317, 344653.7000000029802322 183335.5000000000000000, 344698.7000000029802322 183352.2000000030093361, 344753.5000000000000000 183370.5999999940104317, 344795.5000000000000000 183370.5999999940104317, 344803.5000000000000000 183366.7999999969906639, 344815.5999999939813279 183339.9000000059895683, 344812.0000000000000000 183316.7999999969906639, 344792.5999999939813279 183283.9000000059895683, 344791.5000000000000000 183256.2000000030093361, 344783.0000000000000000 183220.5000000000000000, 344767.5000000000000000 183183.5000000000000000, 344749.2999999970197678 183147.9000000059895683, 344718.7000000029802322 183112.2999999969906639, 344675.2999999970197678 183076.0999999940104317, 344599.0000000000000000 183039.0000000000000000, 344593.9000000060186721 183032.0999999940104317, 344557.9000000060186721 182996.7999999969906639, 344550.5000000000000000 182966.5000000000000000, 344536.7000000029802322 182927.2999999969906639, 344517.5999999939813279 182912.9000000059895683, 344490.0999999939813279 182909.5000000000000000, 344469.4000000060186721 182900.0999999940104317, 344466.0999999939813279 182882.5000000000000000, 344444.4000000060186721 182847.4000000059895683, 344419.2999999970197678 182777.2000000030093361, 344416.5999999939813279 182764.7999999969906639, 344405.2000000029802322 182725.2999999969906639, 344387.2000000029802322 182687.7000000030093361, 344379.5999999939813279 182646.4000000059895683, 344373.5999999939813279 182597.0999999940104317, 344369.5999999939813279 182559.0000000000000000, 344363.7999999970197678 182457.0000000000000000, 344354.2999999970197678 182330.5999999940104317, 344360.7000000029802322 182197.5999999940104317, 344380.4000000060186721 182099.5000000000000000, 344402.9000000060186721 182032.0999999940104317, 344415.2999999970197678 181985.2999999969906639, 344440.7999999970197678 181930.2999999969906639, 344472.5000000000000000 181860.7000000030093361, 344499.5999999939813279 181747.2000000030093361, 344511.2000000029802322 181704.4000000059895683, 344541.7000000029802322 181658.5000000000000000, 344606.2999999970197678 181542.4000000059895683, 344634.0000000000000000 181478.0999999940104317, 344659.5999999939813279 181424.7999999969906639, 344665.0999999939813279 181356.4000000059895683, 344661.2999999970197678 181338.2000000030093361, 344646.5000000000000000 181307.0999999940104317, 344623.5999999939813279 181271.7999999969906639, 344552.2999999970197678 181195.5000000000000000, 344518.2000000029802322 181166.4000000059895683, 344462.0999999939813279 181110.5999999940104317, 344333.0000000000000000 180989.7000000030093361, 344310.2999999970197678 180971.9000000059895683, 344253.2000000029802322 180924.5999999940104317, 344215.7000000029802322 180880.7999999969906639, 344150.5000000000000000 180800.0000000000000000, 344109.7999999970197678 180738.0999999940104317, 344077.0000000000000000 180695.0999999940104317, 344021.9000000060186721 180606.0000000000000000, 343947.5000000000000000 180480.4000000059895683, 343883.5999999939813279 180357.7000000030093361, 343852.7000000029802322 180303.7999999969906639, 343817.0000000000000000 180222.7999999969906639, 343752.7999999970197678 180108.5999999940104317, 343673.0999999939813279 179983.4000000059895683, 343621.7999999970197678 179912.2999999969906639, 343530.9000000060186721 179755.0999999940104317, 343472.4000000060186721 179636.7999999969906639, 343365.9000000060186721 179396.0999999940104317, 343317.2000000029802322 179286.4000000059895683, 343297.2000000029802322 179250.4000000059895683, 343261.2999999970197678 179174.5000000000000000, 343219.4000000060186721 179096.0000000000000000, 343185.5000000000000000 179041.0000000000000000, 343069.5999999939813279 178832.2999999969906639, 342993.5000000000000000 178689.7999999969906639, 342966.7999999970197678 178650.7999999969906639, 342936.7000000029802322 178597.0999999940104317, 342884.0999999939813279 178494.5999999940104317, 342880.0999999939813279 178480.7000000030093361, 342856.5999999939813279 178432.2000000030093361, 342839.0999999939813279 178394.5999999940104317, 342744.9000000060186721 178208.2999999969906639, 342689.5000000000000000 178087.2000000030093361, 342662.2999999970197678 178032.2999999969906639, 342645.5000000000000000 178004.5999999940104317, 342601.9000000060186721 177926.7000000030093361, 342563.0000000000000000 177860.7000000030093361, 342531.9000000060186721 177794.0999999940104317, 342525.7000000029802322 177786.7000000030093361, 342491.7999999970197678 177718.7999999969906639, 342452.0000000000000000 177648.0000000000000000, 342367.5000000000000000 177495.5999999940104317, 342367.2000000029802322 177481.2000000030093361, 342369.5999999939813279 177468.5999999940104317, 342358.2000000029802322 177443.4000000059895683, 342348.5000000000000000 177416.5000000000000000, 342326.4000000060186721 177389.0000000000000000, 342327.0999999939813279 177375.7999999969906639, 342289.4000000060186721 177310.7000000030093361, 342272.0000000000000000 177272.2999999969906639, 342227.4000000060186721 177180.0000000000000000, 342194.9000000060186721 177141.5999999940104317, 342145.0999999939813279 177053.4000000059895683, 342120.0999999939813279 176999.4000000059895683, 342095.0000000000000000 176959.2000000030093361, 342020.4000000060186721 176812.5999999940104317, 341977.2000000029802322 176741.4000000059895683, 341905.2999999970197678 176612.7999999969906639, 341863.9000000060186721 176551.5999999940104317, 341845.2999999970197678 176523.2999999969906639, 341816.4000000060186721 176474.7999999969906639, 341753.0000000000000000 176360.5000000000000000, 341682.2999999970197678 176184.0000000000000000, 341625.7000000029802322 176077.5000000000000000, 341569.5000000000000000 175969.5999999940104317, 341528.7999999970197678 175906.2999999969906639, 341515.2000000029802322 175878.9000000059895683, 341479.5999999939813279 175808.5999999940104317, 341450.7999999970197678 175744.7000000030093361, 341418.4000000060186721 175695.7999999969906639, 341357.9000000060186721 175580.5000000000000000, 341345.0999999939813279 175546.0000000000000000, 341310.9000000060186721 175482.0000000000000000, 341291.2999999970197678 175440.7999999969906639, 341258.7000000029802322 175384.7999999969906639, 341230.4000000060186721 175313.5999999940104317, 341175.7999999970197678 175210.5000000000000000, 341121.0000000000000000 175069.5000000000000000, 341091.0999999939813279 175014.2000000030093361, 341072.2000000029802322 174971.5000000000000000, 341020.0999999939813279 174856.0000000000000000, 340985.4000000060186721 174792.0000000000000000, 340954.4000000060186721 174727.4000000059895683, 340923.2000000029802322 174663.2000000030093361, 340909.7999999970197678 174619.2000000030093361, 340874.0999999939813279 174533.0000000000000000, 340853.9000000060186721 174482.7000000030093361, 340820.9000000060186721 174430.0000000000000000, 340797.5999999939813279 174342.4000000059895683, 340780.2999999970197678 174291.2999999969906639, 340749.0999999939813279 174228.4000000059895683, 340720.4000000060186721 174112.4000000059895683, 340710.7999999970197678 174051.2000000030093361, 340694.5000000000000000 173954.2000000030093361, 340677.4000000060186721 173898.7999999969906639, 340670.2000000029802322 173874.0000000000000000, 340663.7000000029802322 173859.0999999940104317, 340645.2000000029802322 173794.0000000000000000, 340628.2999999970197678 173722.2999999969906639, 340611.7999999970197678 173664.4000000059895683, 340605.7000000029802322 173631.7999999969906639, 340597.0000000000000000 173597.5000000000000000, 340606.5000000000000000 173590.4000000059895683, 340606.4000000060186721 173575.5000000000000000, 340601.9000000060186721 173556.0000000000000000, 340564.2000000029802322 173475.2999999969906639, 340548.4000000060186721 173457.0000000000000000, 340533.5999999939813279 173424.4000000059895683, 340523.2999999970197678 173378.0999999940104317, 340509.2999999970197678 173342.4000000059895683, 340509.2999999970197678 173321.0999999940104317, 340496.7000000029802322 173268.0000000000000000, 340486.4000000060186721 173234.4000000059895683, 340473.4000000060186721 173201.9000000059895683, 340463.2999999970197678 173163.5999999940104317, 340455.7000000029802322 173148.5000000000000000, 340443.2999999970197678 173113.7999999969906639, 340433.5000000000000000 173094.5000000000000000, 340431.9000000060186721 173082.5000000000000000, 340414.0999999939813279 173051.5999999940104317, 340401.2999999970197678 173015.5999999940104317, 340376.2999999970197678 172960.2000000030093361, 340371.5999999939813279 172944.2999999969906639, 340353.5999999939813279 172897.7000000030093361, 340338.7999999970197678 172868.2000000030093361, 340311.2999999970197678 172775.7999999969906639, 340292.2999999970197678 172731.0999999940104317, 340279.0999999939813279 172705.7999999969906639, 340268.2999999970197678 172670.7999999969906639, 340259.7000000029802322 172660.2000000030093361, 340244.7000000029802322 172633.7000000030093361, 340209.0000000000000000 172578.4000000059895683, 340200.5000000000000000 172552.7000000030093361, 340202.9000000060186721 172543.0999999940104317, 340202.7999999970197678 172522.0999999940104317, 340202.0000000000000000 172512.0000000000000000, 340188.5999999939813279 172492.7000000030093361, 340170.9000000060186721 172457.0000000000000000, 340151.2000000029802322 172431.0999999940104317, 340136.0999999939813279 172392.5000000000000000, 340114.7000000029802322 172352.9000000059895683, 340111.7000000029802322 172337.7000000030093361, 340086.7000000029802322 172284.7999999969906639, 340079.7000000029802322 172254.4000000059895683, 340066.7000000029802322 172228.7000000030093361, 340056.0000000000000000 172198.9000000059895683, 340043.7999999970197678 172164.0999999940104317, 340024.2000000029802322 172121.4000000059895683, 340016.0999999939813279 172099.2000000030093361, 339994.2000000029802322 172056.5000000000000000, 339970.7999999970197678 171994.2000000030093361, 339959.2000000029802322 171973.7000000030093361, 339945.4000000060186721 171945.5000000000000000, 339907.7999999970197678 171869.5000000000000000, 339896.2999999970197678 171843.7000000030093361, 339887.0999999939813279 171825.0999999940104317, 339879.7000000029802322 171799.5999999940104317, 339865.5000000000000000 171771.9000000059895683, 339806.4000000060186721 171651.5000000000000000, 339793.5999999939813279 171618.4000000059895683, 339761.2999999970197678 171566.5000000000000000, 339730.7999999970197678 171533.5999999940104317, 339698.5999999939813279 171479.5999999940104317, 339685.7000000029802322 171447.0999999940104317, 339674.0000000000000000 171429.0999999940104317, 339640.0999999939813279 171368.5000000000000000, 339617.5999999939813279 171338.4000000059895683, 339592.2999999970197678 171302.9000000059895683, 339534.5999999939813279 171229.2999999969906639, 339521.4000000060186721 171200.2000000030093361, 339489.5000000000000000 171141.5999999940104317, 339459.4000000060186721 171111.0999999940104317, 339453.4000000060186721 171102.0000000000000000, 339432.7000000029802322 171081.5999999940104317, 339391.2000000029802322 171032.7000000030093361, 339319.0999999939813279 170968.9000000059895683, 339277.7999999970197678 170938.7999999969906639, 339232.9000000060186721 170895.0000000000000000, 339182.4000000060186721 170861.7000000030093361, 339153.4000000060186721 170847.2999999969906639, 339089.2000000029802322 170807.5999999940104317, 339057.7000000029802322 170786.0000000000000000, 339013.5000000000000000 170755.0999999940104317, 339001.2000000029802322 170740.5999999940104317, 338993.2000000029802322 170714.7000000030093361, 338981.9000000060186721 170675.7999999969906639, 338958.5999999939813279 170622.5000000000000000, 338944.0000000000000000 170542.0999999940104317, 338920.2999999970197678 170485.2000000030093361, 338919.5000000000000000 170471.2999999969906639, 338909.0999999939813279 170452.7000000030093361, 338890.2999999970197678 170396.5999999940104317, 338866.5000000000000000 170339.2999999969906639, 338852.7999999970197678 170312.0999999940104317, 338847.2000000029802322 170289.7999999969906639, 338804.7999999970197678 170158.7000000030093361, 338799.0000000000000000 170130.4000000059895683, 338784.7999999970197678 170062.2999999969906639, 338772.0000000000000000 170030.5000000000000000, 338768.9000000060186721 169997.2000000030093361, 338759.0999999939813279 169973.7999999969906639, 338751.7999999970197678 169938.5000000000000000, 338744.7999999970197678 169921.2000000030093361, 338739.4000000060186721 169896.5999999940104317, 338726.9000000060186721 169879.5000000000000000, 338712.7999999970197678 169874.0999999940104317, 338696.2000000029802322 169871.2999999969906639, 338620.7999999970197678 169859.2999999969906639, 338592.0999999939813279 169846.5000000000000000, 338547.7999999970197678 169829.2000000030093361, 338529.0999999939813279 169817.7999999969906639, 338483.2999999970197678 169794.7999999969906639, 338417.2999999970197678 169753.9000000059895683, 338342.2000000029802322 169713.5999999940104317, 338277.0999999939813279 169665.7999999969906639, 338251.7000000029802322 169633.9000000059895683, 338236.2999999970197678 169614.0000000000000000, 338195.2000000029802322 169555.7000000030093361, 338169.0000000000000000 169526.5000000000000000, 338134.5999999939813279 169477.5999999940104317, 338113.0000000000000000 169451.0000000000000000, 338075.7999999970197678 169389.0000000000000000, 338065.5999999939813279 169359.5000000000000000, 338050.7999999970197678 169319.0000000000000000, 338014.4000000060186721 169230.0999999940104317, 337990.5999999939813279 169173.0000000000000000, 337976.0000000000000000 169122.9000000059895683, 337961.2000000029802322 169047.0000000000000000, 337937.7999999970197678 168968.7999999969906639, 337925.5999999939813279 168939.0999999940104317, 337888.7000000029802322 168844.0999999940104317, 337864.2999999970197678 168752.2000000030093361, 337824.0000000000000000 168661.2999999969906639, 337790.2000000029802322 168602.5000000000000000, 337756.7000000029802322 168562.2999999969906639, 337685.7999999970197678 168497.0999999940104317, 337651.9000000060186721 168467.7000000030093361, 337601.2999999970197678 168427.0000000000000000, 337485.7000000029802322 168368.5999999940104317, 337402.2000000029802322 168344.2999999969906639, 337359.2999999970197678 168333.7000000030093361, 337272.2000000029802322 168309.0999999940104317, 337224.0999999939813279 168291.0999999940104317, 337183.0999999939813279 168282.5000000000000000, 337108.0000000000000000 168263.5999999940104317, 337071.2999999970197678 168254.2999999969906639, 337010.9000000060186721 168234.7999999969906639, 336931.0999999939813279 168216.7000000030093361, 336858.2999999970197678 168206.4000000059895683, 336789.2000000029802322 168188.0000000000000000, 336759.2000000029802322 168176.2000000030093361, 336667.7999999970197678 168150.9000000059895683, 336620.4000000060186721 168137.5999999940104317, 336563.9000000060186721 168124.0999999940104317, 336540.5999999939813279 168118.2000000030093361, 336525.9000000060186721 168113.2999999969906639, 336501.2999999970197678 168107.9000000059895683, 336454.7999999970197678 168089.9000000059895683, 336398.5000000000000000 168069.7000000030093361, 336371.5000000000000000 168057.7000000030093361, 336297.5000000000000000 168032.4000000059895683, 336251.7999999970197678 168018.7000000030093361, 336216.7999999970197678 168011.7000000030093361, 336181.0000000000000000 168000.7999999969906639, 336105.4000000060186721 167973.2000000030093361, 336028.0000000000000000 167947.2000000030093361, 335961.2000000029802322 167931.7999999969906639, 335856.7999999970197678 167902.2000000030093361, 335758.2999999970197678 167871.5000000000000000, 335715.7999999970197678 167857.2000000030093361, 335679.0999999939813279 167844.0000000000000000, 335630.4000000060186721 167817.9000000059895683, 335523.2999999970197678 167758.9000000059895683, 335447.2000000029802322 167714.0999999940104317, 335410.4000000060186721 167693.2999999969906639, 335357.0000000000000000 167673.9000000059895683, 335326.7000000029802322 167666.4000000059895683, 335286.5000000000000000 167652.2999999969906639, 335197.0000000000000000 167635.9000000059895683, 335177.0999999939813279 167637.9000000059895683, 335099.7999999970197678 167643.4000000059895683, 335029.2000000029802322 167674.4000000059895683, 334948.7999999970197678 167729.2999999969906639, 334931.9000000060186721 167746.5000000000000000, 334908.0999999939813279 167762.2999999969906639, 334850.4000000060186721 167812.2999999969906639, 334807.0999999939813279 167858.2999999969906639, 334786.5000000000000000 167877.7000000030093361, 334749.4000000060186721 167906.5999999940104317, 334665.2000000029802322 167980.2999999969906639, 334610.0999999939813279 168027.5000000000000000, 334562.7999999970197678 168070.7999999969906639, 334537.7999999970197678 168091.9000000059895683, 334454.9000000060186721 168163.7999999969906639, 334330.2000000029802322 168277.9000000059895683, 334282.7999999970197678 168314.9000000059895683, 334262.5999999939813279 168333.9000000059895683, 334187.0999999939813279 168400.4000000059895683, 334160.4000000060186721 168415.5000000000000000, 334097.2999999970197678 168452.5999999940104317, 334056.7999999970197678 168478.4000000059895683, 334026.7999999970197678 168488.4000000059895683, 333912.7999999970197678 168559.9000000059895683, 333846.5000000000000000 168597.5999999940104317, 333816.0000000000000000 168617.5000000000000000, 333784.2000000029802322 168633.0000000000000000, 333719.7999999970197678 168669.7000000030093361, 333691.7000000029802322 168691.5999999940104317, 333633.2999999970197678 168727.4000000059895683, 333527.0999999939813279 168808.7999999969906639, 333454.9000000060186721 168843.2999999969906639, 333403.0000000000000000 168861.0999999940104317, 333350.2000000029802322 168873.5999999940104317, 333319.9000000060186721 168877.5999999940104317, 333238.7999999970197678 168882.7000000030093361, 333169.5000000000000000 168887.9000000059895683, 333131.7999999970197678 168891.9000000059895683, 333064.5999999939813279 168892.7000000030093361, 333020.2999999970197678 168889.5999999940104317, 332911.5000000000000000 168887.2999999969906639, 332827.0999999939813279 168887.7999999969906639, 332799.9000000060186721 168887.7999999969906639, 332732.7000000029802322 168887.0999999940104317, 332629.5999999939813279 168890.9000000059895683, 332520.5999999939813279 168881.5000000000000000, 332465.2000000029802322 168870.9000000059895683, 332397.9000000060186721 168864.7000000030093361, 332342.7999999970197678 168871.5999999940104317, 332304.0000000000000000 168867.9000000059895683, 332200.4000000060186721 168880.5000000000000000, 332189.9000000060186721 168878.9000000059895683, 332148.7999999970197678 168879.7000000030093361, 332119.5000000000000000 168873.4000000059895683, 332090.2999999970197678 168870.5000000000000000, 332052.0000000000000000 168865.2999999969906639, 332024.2999999970197678 168867.0000000000000000, 331937.7999999970197678 168877.2000000030093361, 331860.0000000000000000 168878.9000000059895683, 331823.0000000000000000 168876.7999999969906639, 331781.0999999939813279 168881.5999999940104317, 331749.2000000029802322 168882.5999999940104317, 331735.2999999970197678 168885.0000000000000000, 331714.7999999970197678 168886.0999999940104317, 331678.5000000000000000 168888.0999999940104317, 331660.5000000000000000 168889.2000000030093361, 331643.5000000000000000 168894.5000000000000000, 331605.0000000000000000 168896.7999999969906639, 331571.2999999970197678 168893.2999999969906639, 331524.9000000060186721 168896.0999999940104317, 331482.5999999939813279 168899.9000000059895683, 331448.7999999970197678 168903.2000000030093361, 331436.7999999970197678 168901.9000000059895683, 331421.4000000060186721 168904.9000000059895683, 331342.0000000000000000 168905.7999999969906639, 331316.5000000000000000 168907.9000000059895683, 331228.4000000060186721 168903.7999999969906639, 331167.7999999970197678 168898.5000000000000000, 331121.2999999970197678 168892.0000000000000000, 331040.4000000060186721 168882.7999999969906639, 330999.0000000000000000 168878.9000000059895683, 330830.0000000000000000 168875.0000000000000000, 330771.2999999970197678 168882.0000000000000000, 330727.7000000029802322 168888.5000000000000000, 330713.5000000000000000 168893.7000000030093361, 330672.0000000000000000 168919.5999999940104317, 330648.5000000000000000 168937.0999999940104317, 330571.2999999970197678 168975.2000000030093361, 330519.2999999970197678 169015.7000000030093361, 330490.5000000000000000 169028.0999999940104317, 330431.0999999939813279 169046.9000000059895683, 330411.9000000060186721 169048.5000000000000000, 330350.0999999939813279 169041.0000000000000000, 330330.7999999970197678 169030.0000000000000000, 330271.5000000000000000 168999.5000000000000000, 330224.5000000000000000 168961.5000000000000000, 330191.7999999970197678 168932.7999999969906639, 330154.0999999939813279 168889.5999999940104317, 330127.2000000029802322 168850.7999999969906639, 330103.0000000000000000 168826.2999999969906639, 330086.0999999939813279 168803.2999999969906639, 330077.9000000060186721 168787.2000000030093361, 330055.2000000029802322 168747.2999999969906639, 330021.5000000000000000 168708.0000000000000000, 330004.0999999939813279 168680.7999999969906639, 329962.7999999970197678 168637.7999999969906639, 329943.5000000000000000 168618.2000000030093361, 329921.5000000000000000 168598.2999999969906639, 329886.9000000060186721 168564.0999999940104317, 329859.7999999970197678 168542.2999999969906639, 329785.2999999970197678 168465.4000000059895683, 329735.5999999939813279 168420.7000000030093361, 329708.2999999970197678 168401.5000000000000000, 329697.2000000029802322 168383.4000000059895683, 329642.7000000029802322 168339.4000000059895683, 329617.9000000060186721 168317.0999999940104317, 329603.5999999939813279 168304.2999999969906639, 329565.7999999970197678 168276.2000000030093361, 329533.5000000000000000 168248.5000000000000000, 329482.2999999970197678 168209.9000000059895683, 329404.5999999939813279 168146.7000000030093361, 329385.4000000060186721 168122.2999999969906639, 329345.0000000000000000 168085.5999999940104317, 329306.0999999939813279 168048.0000000000000000, 329292.5000000000000000 168040.7000000030093361, 329291.9000000060186721 168050.5999999940104317, 329274.7000000029802322 168071.9000000059895683, 329250.5999999939813279 168110.5000000000000000, 329223.4000000060186721 168160.7000000030093361, 329211.0000000000000000 168182.9000000059895683, 329190.2999999970197678 168213.2999999969906639, 329170.2999999970197678 168251.7999999969906639, 329143.9000000060186721 168286.4000000059895683, 329131.9000000060186721 168311.0000000000000000, 329115.2999999970197678 168341.4000000059895683, 329110.2999999970197678 168358.0000000000000000, 329075.7000000029802322 168412.2000000030093361, 329062.4000000060186721 168439.7999999969906639, 329034.2000000029802322 168479.4000000059895683, 329008.2999999970197678 168513.7000000030093361, 328980.0000000000000000 168563.5000000000000000, 328946.7999999970197678 168618.4000000059895683, 328915.7999999970197678 168657.2999999969906639, 328877.7999999970197678 168698.7999999969906639, 328831.5999999939813279 168768.2999999969906639, 328817.2999999970197678 168792.7999999969906639, 328782.0000000000000000 168837.5000000000000000, 328741.7999999970197678 168872.2000000030093361, 328701.4000000060186721 168923.0000000000000000, 328674.5000000000000000 168953.2999999969906639, 328641.7999999970197678 168974.0000000000000000, 328567.4000000060186721 169016.0999999940104317, 328534.0999999939813279 169031.9000000059895683, 328500.0000000000000000 169053.5000000000000000, 328459.7999999970197678 169064.9000000059895683, 328408.5999999939813279 169077.7999999969906639, 328380.4000000060186721 169088.0000000000000000, 328340.7000000029802322 169099.5999999940104317, 328300.0999999939813279 169106.0000000000000000, 328246.4000000060186721 169110.5999999940104317, 328216.0999999939813279 169112.0000000000000000, 328133.7000000029802322 169112.2999999969906639, 328079.0000000000000000 169108.4000000059895683, 328011.0000000000000000 169096.7000000030093361, 327921.4000000060186721 169072.4000000059895683, 327862.0000000000000000 169053.9000000059895683, 327776.9000000060186721 169009.4000000059895683, 327720.0999999939813279 168988.2000000030093361, 327681.0000000000000000 168974.0000000000000000, 327582.0999999939813279 168920.7000000030093361, 327558.4000000060186721 168911.5000000000000000, 327552.7000000029802322 168904.2000000030093361, 327531.4000000060186721 168905.4000000059895683, 327448.0999999939813279 168876.2999999969906639, 327353.7999999970197678 168857.7999999969906639, 327281.4000000060186721 168839.2000000030093361, 327188.0999999939813279 168826.2000000030093361, 327117.5999999939813279 168818.7999999969906639, 327006.7999999970197678 168819.2000000030093361, 326934.0999999939813279 168838.0999999940104317, 326850.2999999970197678 168853.7000000030093361, 326800.9000000060186721 168865.7999999969906639, 326778.0000000000000000 168869.2999999969906639, 326730.0999999939813279 168889.2999999969906639, 326680.2000000029802322 168914.2000000030093361, 326658.5999999939813279 168919.5000000000000000, 326614.5999999939813279 168948.2000000030093361, 326607.9000000060186721 168960.0000000000000000, 326557.0999999939813279 168982.2000000030093361, 326536.9000000060186721 168988.2999999969906639, 326477.0000000000000000 169031.4000000059895683, 326402.4000000060186721 169103.0999999940104317, 326371.0000000000000000 169142.2999999969906639, 326339.7999999970197678 169182.4000000059895683, 326314.2000000029802322 169225.7000000030093361, 326295.0999999939813279 169269.4000000059895683, 326278.7000000029802322 169296.7999999969906639, 326249.0999999939813279 169353.2000000030093361, 326219.4000000060186721 169439.9000000059895683, 326181.5999999939813279 169524.7999999969906639, 326177.5000000000000000 169546.2999999969906639, 326142.5999999939813279 169657.7999999969906639, 326123.0999999939813279 169725.5000000000000000, 326098.4000000060186721 169848.4000000059895683, 326087.2999999970197678 169902.7000000030093361, 326057.0999999939813279 169968.5000000000000000, 326044.7000000029802322 170012.4000000059895683, 326007.7999999970197678 170166.0000000000000000, 325999.2999999970197678 170205.7999999969906639, 326011.5000000000000000 170276.0000000000000000, 326027.5000000000000000 170322.2000000030093361, 326061.7000000029802322 170373.2999999969906639, 326086.0000000000000000 170418.7999999969906639, 326110.5000000000000000 170441.5999999940104317, 326149.0999999939813279 170467.0000000000000000, 326183.9000000060186721 170495.2999999969906639, 326211.7999999970197678 170513.7999999969906639, 326257.5999999939813279 170540.7999999969906639, 326285.7999999970197678 170553.5999999940104317, 326364.4000000060186721 170580.7999999969906639, 326464.7000000029802322 170610.5000000000000000, 326532.7999999970197678 170637.0999999940104317, 326588.9000000060186721 170669.0999999940104317, 326626.7000000029802322 170682.7999999969906639, 326673.0999999939813279 170717.5000000000000000, 326721.2999999970197678 170755.0999999940104317, 326776.4000000060186721 170799.5999999940104317, 326852.4000000060186721 170882.7000000030093361, 326871.5000000000000000 170907.7999999969906639, 326903.2000000029802322 170952.7999999969906639, 326939.5999999939813279 171020.5000000000000000, 326947.4000000060186721 171045.7000000030093361, 326969.2999999970197678 171105.2000000030093361, 326992.7000000029802322 171156.2000000030093361, 327003.5000000000000000 171169.2000000030093361, 327021.2000000029802322 171200.9000000059895683, 327050.7999999970197678 171234.9000000059895683, 327075.4000000060186721 171275.0999999940104317, 327115.0000000000000000 171326.4000000059895683, 327231.5000000000000000 171443.5000000000000000, 327268.0999999939813279 171470.5000000000000000, 327322.2999999970197678 171517.5999999940104317, 327402.5999999939813279 171573.9000000059895683, 327448.5000000000000000 171606.2000000030093361, 327468.0999999939813279 171624.0999999940104317, 327524.7000000029802322 171659.9000000059895683, 327556.0000000000000000 171688.5999999940104317, 327592.2999999970197678 171721.5000000000000000, 327611.5999999939813279 171744.7000000030093361, 327639.5999999939813279 171775.5999999940104317, 327663.4000000060186721 171816.9000000059895683, 327681.7999999970197678 171860.0000000000000000, 327692.5000000000000000 171925.2000000030093361, 327695.7999999970197678 172008.2000000030093361, 327690.2999999970197678 172069.2000000030093361, 327688.0000000000000000 172115.7000000030093361, 327680.5000000000000000 172147.9000000059895683, 327678.5000000000000000 172175.9000000059895683, 327661.2000000029802322 172236.5000000000000000, 327639.4000000060186721 172286.5000000000000000, 327611.4000000060186721 172381.9000000059895683, 327596.2000000029802322 172449.5000000000000000, 327580.5000000000000000 172495.0999999940104317, 327547.5000000000000000 172594.0000000000000000, 327514.7000000029802322 172677.2999999969906639, 327495.7999999970197678 172740.7000000030093361, 327486.7000000029802322 172804.7000000030093361, 327474.0000000000000000 172870.2999999969906639, 327473.9000000060186721 172932.7999999969906639, 327479.7999999970197678 172971.7000000030093361, 327476.2999999970197678 172986.0000000000000000, 327483.0000000000000000 173019.5000000000000000, 327490.0000000000000000 173035.7999999969906639, 327486.5000000000000000 173054.9000000059895683, 327494.0999999939813279 173072.9000000059895683, 327512.5000000000000000 173105.9000000059895683, 327541.0000000000000000 173137.7999999969906639, 327573.2999999970197678 173165.2999999969906639, 327594.7999999970197678 173184.0000000000000000, 327608.2000000029802322 173194.0999999940104317, 327649.7000000029802322 173228.7999999969906639, 327665.2999999970197678 173255.9000000059895683, 327682.2000000029802322 173268.5999999940104317, 327708.0999999939813279 173294.7000000030093361, 327734.2000000029802322 173327.2999999969906639, 327744.0999999939813279 173347.0000000000000000, 327760.5999999939813279 173369.0000000000000000, 327765.9000000060186721 173378.9000000059895683, 327767.9000000060186721 173388.5999999940104317, 327770.5000000000000000 173407.2999999969906639, 327769.7999999970197678 173436.9000000059895683, 327745.2000000029802322 173473.7000000030093361, 327723.9000000060186721 173499.7999999969906639, 327685.9000000060186721 173528.0000000000000000, 327651.2000000029802322 173545.4000000059895683, 327589.5999999939813279 173575.0999999940104317, 327553.0000000000000000 173596.7999999969906639, 327505.5999999939813279 173618.0999999940104317, 327444.9000000060186721 173638.7000000030093361, 327422.9000000060186721 173644.5000000000000000, 327349.0000000000000000 173657.7999999969906639, 327298.2000000029802322 173663.4000000059895683, 327234.0000000000000000 173666.5999999940104317, 327197.7000000029802322 173662.7000000030093361, 327166.0000000000000000 173654.4000000059895683, 327140.9000000060186721 173650.0999999940104317, 327098.5000000000000000 173633.7999999969906639, 327026.4000000060186721 173603.0000000000000000, 327001.0000000000000000 173591.0999999940104317, 326985.9000000060186721 173581.4000000059895683, 326930.2000000029802322 173563.5999999940104317, 326897.5000000000000000 173549.7999999969906639, 326865.9000000060186721 173534.5999999940104317, 326831.2999999970197678 173528.7000000030093361, 326817.2000000029802322 173530.2999999969906639, 326779.7999999970197678 173534.4000000059895683, 326732.2999999970197678 173555.7999999969906639, 326706.9000000060186721 173582.5999999940104317, 326691.7999999970197678 173635.5999999940104317, 326687.2000000029802322 173657.0999999940104317, 326687.5999999939813279 173669.7000000030093361, 326676.9000000060186721 173692.7000000030093361, 326675.5999999939813279 173717.4000000059895683, 326667.0000000000000000 173734.9000000059895683, 326669.4000000060186721 173758.7000000030093361, 326666.2000000029802322 173789.4000000059895683, 326667.7999999970197678 173807.2999999969906639, 326665.5000000000000000 173851.7000000030093361, 326671.7999999970197678 173875.0999999940104317, 326674.0000000000000000 173893.2000000030093361, 326683.7999999970197678 173923.7000000030093361, 326680.9000000060186721 173958.0000000000000000, 326686.0000000000000000 173979.0999999940104317, 326674.9000000060186721 174019.0000000000000000, 326666.4000000060186721 174048.7999999969906639, 326657.5000000000000000 174069.2999999969906639, 326654.5999999939813279 174103.0999999940104317, 326637.4000000060186721 174160.4000000059895683, 326612.2999999970197678 174206.7999999969906639, 326595.7000000029802322 174236.5999999940104317, 326542.7999999970197678 174296.4000000059895683, 326513.5000000000000000 174354.9000000059895683, 326492.7999999970197678 174399.4000000059895683, 326475.7999999970197678 174499.7000000030093361, 326484.2999999970197678 174524.2999999969906639, 326486.2999999970197678 174542.2000000030093361, 326483.9000000060186721 174578.0999999940104317, 326490.9000000060186721 174608.7000000030093361, 326499.0000000000000000 174619.2999999969906639, 326543.2999999970197678 174649.2999999969906639, 326557.7999999970197678 174660.0000000000000000, 326603.7000000029802322 174667.7999999969906639, 326623.2999999970197678 174671.7000000030093361, 326671.5000000000000000 174674.7000000030093361, 326720.0000000000000000 174679.5000000000000000, 326729.4000000060186721 174687.4000000059895683, 326750.9000000060186721 174688.7999999969906639, 326781.7000000029802322 174684.7999999969906639, 326862.4000000060186721 174670.5999999940104317, 326886.7999999970197678 174669.5000000000000000, 326908.7999999970197678 174662.0999999940104317, 326991.7999999970197678 174653.4000000059895683, 327012.7999999970197678 174650.7999999969906639, 327046.0000000000000000 174651.2999999969906639, 327069.2999999970197678 174668.7000000030093361, 327083.2000000029802322 174677.7000000030093361, 327099.7999999970197678 174696.0999999940104317, 327113.7999999970197678 174729.9000000059895683, 327124.7000000029802322 174743.5999999940104317, 327135.5999999939813279 174790.0999999940104317, 327117.2999999970197678 174844.2999999969906639, 327085.7999999970197678 174885.7000000030093361, 327068.7000000029802322 174916.4000000059895683, 327069.7000000029802322 174933.5000000000000000, 327073.2999999970197678 174957.9000000059895683, 327079.4000000060186721 174992.0999999940104317, 327102.2999999970197678 175038.7999999969906639, 327123.4000000060186721 175053.7000000030093361, 327136.5000000000000000 175067.0000000000000000, 327173.9000000060186721 175104.2999999969906639, 327200.2000000029802322 175120.9000000059895683, 327229.2000000029802322 175143.9000000059895683, 327254.2000000029802322 175160.7999999969906639, 327263.0999999939813279 175164.5000000000000000, 327292.2999999970197678 175184.7999999969906639, 327353.5999999939813279 175222.5000000000000000, 327368.2000000029802322 175231.2999999969906639, 327388.7999999970197678 175242.0000000000000000, 327458.7999999970197678 175275.2999999969906639, 327481.0000000000000000 175289.0999999940104317, 327505.2000000029802322 175299.7000000030093361, 327553.2999999970197678 175328.2000000030093361, 327585.7000000029802322 175353.0999999940104317, 327605.7000000029802322 175389.0999999940104317, 327616.7000000029802322 175422.0000000000000000, 327647.7000000029802322 175480.9000000059895683, 327656.7000000029802322 175505.5000000000000000, 327680.5000000000000000 175586.2000000030093361, 327687.0999999939813279 175611.2999999969906639, 327699.0000000000000000 175662.2000000030093361, 327723.5999999939813279 175729.7999999969906639, 327745.0999999939813279 175797.0000000000000000, 327760.7000000029802322 175833.0999999940104317, 327771.0000000000000000 175870.5999999940104317, 327791.5999999939813279 175941.2000000030093361, 327818.2999999970197678 175999.4000000059895683, 327827.0999999939813279 176028.7000000030093361, 327838.0000000000000000 176061.0000000000000000, 327879.0999999939813279 176123.4000000059895683, 327912.7999999970197678 176170.0000000000000000, 327945.0999999939813279 176215.7000000030093361, 327959.9000000060186721 176245.7999999969906639, 327983.7999999970197678 176272.2000000030093361, 327977.5999999939813279 176288.7999999969906639, 327959.0999999939813279 176298.7999999969906639, 327927.0000000000000000 176326.7000000030093361, 327878.4000000060186721 176359.0999999940104317, 327787.7000000029802322 176404.9000000059895683, 327776.9000000060186721 176415.7999999969906639, 327741.0000000000000000 176435.5999999940104317, 327681.0000000000000000 176468.5000000000000000, 327603.2999999970197678 176521.2999999969906639, 327576.5000000000000000 176534.9000000059895683, 327535.5000000000000000 176563.5000000000000000, 327485.5999999939813279 176597.9000000059895683, 327427.4000000060186721 176632.0000000000000000, 327364.7999999970197678 176671.5999999940104317, 327325.4000000060186721 176686.7000000030093361, 327257.7999999970197678 176724.2000000030093361, 327223.7000000029802322 176747.9000000059895683, 327196.2000000029802322 176765.0000000000000000, 327155.7999999970197678 176795.0999999940104317, 327106.5999999939813279 176825.7000000030093361, 327001.5999999939813279 176881.7999999969906639, 326982.0999999939813279 176895.7999999969906639, 326945.2000000029802322 176914.2999999969906639, 326853.7999999970197678 176970.7999999969906639, 326834.7999999970197678 176977.7000000030093361, 326772.7000000029802322 177018.2999999969906639, 326734.0999999939813279 177043.2999999969906639, 326703.7000000029802322 177059.7000000030093361, 326622.2999999970197678 177114.4000000059895683, 326505.4000000060186721 177189.9000000059895683, 326408.2999999970197678 177241.9000000059895683, 326363.7000000029802322 177268.7000000030093361, 326329.2999999970197678 177283.0000000000000000, 326233.0000000000000000 177341.7999999969906639, 326200.2999999970197678 177359.2999999969906639, 326108.7999999970197678 177421.0000000000000000, 326027.7999999970197678 177475.0999999940104317, 325995.2999999970197678 177498.4000000059895683, 325858.4000000060186721 177579.5999999940104317, 325829.2999999970197678 177591.7000000030093361, 325740.7000000029802322 177645.0000000000000000, 325708.7999999970197678 177660.2999999969906639, 325616.9000000060186721 177713.5000000000000000, 325489.9000000060186721 177789.7999999969906639, 325405.0999999939813279 177835.7000000030093361, 325367.0000000000000000 177863.2999999969906639, 325347.2000000029802322 177874.5999999940104317, 325303.5999999939813279 177902.9000000059895683, 325207.7999999970197678 177964.7999999969906639, 325159.4000000060186721 177994.9000000059895683, 325134.2000000029802322 178008.7000000030093361, 325106.0000000000000000 178021.2000000030093361, 325091.0000000000000000 178029.4000000059895683, 325040.0000000000000000 178061.7999999969906639, 325031.2000000029802322 178068.7999999969906639, 325021.2000000029802322 178075.7999999969906639, 325002.5000000000000000 178089.0000000000000000, 324985.0999999939813279 178098.7999999969906639, 324959.5999999939813279 178117.0000000000000000, 324947.4000000060186721 178118.9000000059895683, 324904.5000000000000000 178148.5000000000000000, 324866.5000000000000000 178173.7999999969906639, 324849.7000000029802322 178186.9000000059895683, 324749.0999999939813279 178246.4000000059895683, 324643.2999999970197678 178306.9000000059895683, 324595.2999999970197678 178337.7999999969906639, 324558.4000000060186721 178369.0999999940104317, 324518.7999999970197678 178392.5000000000000000, 324491.7000000029802322 178404.4000000059895683, 324437.0000000000000000 178438.0000000000000000, 324403.0000000000000000 178468.7999999969906639, 324370.2000000029802322 178487.0000000000000000, 324325.7000000029802322 178511.9000000059895683, 324274.5999999939813279 178545.5999999940104317, 324225.0999999939813279 178572.9000000059895683, 324120.2000000029802322 178635.2999999969906639, 324058.2000000029802322 178675.4000000059895683, 324017.5000000000000000 178703.0000000000000000, 323988.5999999939813279 178717.2000000030093361, 323901.9000000060186721 178778.7000000030093361, 323864.0999999939813279 178800.5000000000000000, 323768.2000000029802322 178856.0000000000000000, 323744.7000000029802322 178865.0999999940104317, 323722.2999999970197678 178881.4000000059895683, 323689.9000000060186721 178905.0999999940104317, 323639.5000000000000000 178938.7999999969906639, 323590.7999999970197678 178962.7999999969906639, 323551.2999999970197678 178983.9000000059895683, 323495.5000000000000000 179000.4000000059895683, 323473.7000000029802322 179018.7000000030093361, 323449.7000000029802322 179039.0000000000000000, 323421.7000000029802322 179060.2000000030093361, 323396.5000000000000000 179066.7999999969906639, 323370.5000000000000000 179057.7999999969906639, 323357.0000000000000000 179038.2000000030093361, 323345.0999999939813279 179021.5000000000000000, 323327.7000000029802322 179010.0000000000000000, 323307.7999999970197678 179011.7999999969906639, 323287.7999999970197678 179024.7999999969906639, 323241.7000000029802322 179045.0000000000000000, 323198.2999999970197678 179058.9000000059895683, 323160.7000000029802322 179063.2000000030093361, 323139.5000000000000000 179052.0999999940104317, 323119.0999999939813279 179037.0999999940104317, 323100.5000000000000000 179001.7999999969906639, 323084.2999999970197678 178972.5000000000000000, 323075.9000000060186721 178949.9000000059895683, 323057.7999999970197678 178924.4000000059895683, 323028.4000000060186721 178895.0999999940104317, 323006.2999999970197678 178884.0000000000000000, 322976.2000000029802322 178859.0000000000000000, 322941.5999999939813279 178852.0000000000000000, 322892.0000000000000000 178852.5999999940104317, 322835.4000000060186721 178865.4000000059895683, 322813.2999999970197678 178863.7000000030093361, 322797.5999999939813279 178861.7000000030093361, 322774.7000000029802322 178849.9000000059895683, 322758.0000000000000000 178846.5999999940104317, 322723.5000000000000000 178827.0000000000000000, 322709.5000000000000000 178817.2000000030093361, 322624.0000000000000000 178754.7000000030093361, 322596.7000000029802322 178733.7999999969906639, 322576.2999999970197678 178721.0000000000000000, 322565.7999999970197678 178714.0000000000000000, 322542.2000000029802322 178703.7999999969906639, 322497.2000000029802322 178697.2999999969906639, 322476.7999999970197678 178699.2999999969906639, 322405.5000000000000000 178714.4000000059895683, 322376.7000000029802322 178728.2999999969906639, 322332.9000000060186721 178744.2000000030093361, 322269.2999999970197678 178770.5999999940104317, 322226.2999999970197678 178808.2000000030093361, 322186.5999999939813279 178832.7999999969906639, 322137.2999999970197678 178844.7000000030093361, 322103.5000000000000000 178846.7999999969906639, 322064.5999999939813279 178852.5999999940104317, 322049.7000000029802322 178850.5999999940104317, 322029.4000000060186721 178846.0999999940104317, 322009.5999999939813279 178832.7999999969906639, 321958.7999999970197678 178784.9000000059895683, 321895.2999999970197678 178717.5000000000000000, 321860.2999999970197678 178682.0999999940104317, 321811.5000000000000000 178634.5000000000000000, 321783.7999999970197678 178608.0000000000000000, 321754.5000000000000000 178580.5000000000000000, 321729.7999999970197678 178565.4000000059895683, 321689.9000000060186721 178555.7999999969906639, 321675.7000000029802322 178550.7000000030093361, 321659.0000000000000000 178547.5000000000000000, 321621.7999999970197678 178534.0999999940104317, 321579.0999999939813279 178521.7999999969906639, 321516.5999999939813279 178491.7999999969906639, 321475.5000000000000000 178473.7999999969906639, 321436.4000000060186721 178456.0000000000000000, 321387.5999999939813279 178447.7000000030093361, 321360.7000000029802322 178443.4000000059895683, 321320.7000000029802322 178436.0000000000000000, 321290.0000000000000000 178431.0000000000000000, 321230.4000000060186721 178422.7000000030093361, 321116.7999999970197678 178402.0000000000000000, 321093.5999999939813279 178401.0999999940104317, 321071.0000000000000000 178400.9000000059895683, 321048.7999999970197678 178400.0999999940104317, 320998.9000000060186721 178401.7999999969906639, 320968.2000000029802322 178411.7999999969906639, 320903.7999999970197678 178434.4000000059895683, 320879.2999999970197678 178448.7999999969906639, 320824.0000000000000000 178479.2999999969906639, 320791.7999999970197678 178495.7999999969906639, 320751.5999999939813279 178510.0999999940104317, 320717.7000000029802322 178523.7000000030093361, 320676.2999999970197678 178521.5000000000000000, 320604.0999999939813279 178531.7999999969906639, 320559.5999999939813279 178532.0999999940104317, 320508.4000000060186721 178519.4000000059895683, 320465.4000000060186721 178509.5999999940104317, 320435.2000000029802322 178503.7999999969906639, 320368.4000000060186721 178498.7999999969906639, 320306.2999999970197678 178488.0000000000000000, 320235.0999999939813279 178480.7000000030093361, 320218.2999999970197678 178474.5000000000000000, 320201.7999999970197678 178468.2000000030093361, 320175.4000000060186721 178468.0999999940104317, 320157.2999999970197678 178469.7000000030093361, 320117.5000000000000000 178469.5000000000000000, 320103.7999999970197678 178466.0000000000000000, 320056.2999999970197678 178458.2000000030093361, 319968.0999999939813279 178428.5999999940104317, 319937.5999999939813279 178413.0000000000000000, 319901.0000000000000000 178387.2999999969906639, 319764.7999999970197678 178297.4000000059895683, 319694.2000000029802322 178253.2999999969906639, 319660.2000000029802322 178235.0999999940104317, 319639.5000000000000000 178228.5000000000000000, 319597.0999999939813279 178211.7000000030093361, 319577.0999999939813279 178205.9000000059895683, 319542.0999999939813279 178203.7000000030093361, 319521.5999999939813279 178206.2999999969906639, 319495.9000000060186721 178204.4000000059895683, 319467.0999999939813279 178206.7000000030093361, 319419.7999999970197678 178215.5999999940104317, 319396.7000000029802322 178221.2000000030093361, 319316.5000000000000000 178239.5999999940104317, 319227.7000000029802322 178258.7999999969906639, 319149.2000000029802322 178282.4000000059895683, 319130.0999999939813279 178287.7000000030093361, 319028.7999999970197678 178321.5999999940104317, 318921.7000000029802322 178348.5000000000000000, 318884.0000000000000000 178358.5999999940104317, 318780.7999999970197678 178405.7999999969906639, 318756.4000000060186721 178411.5000000000000000, 318728.7999999970197678 178424.7999999969906639, 318669.5999999939813279 178481.7000000030093361, 318632.4000000060186721 178503.2000000030093361, 318567.5999999939813279 178553.5999999940104317, 318500.0000000000000000 178618.2000000030093361, 318456.0000000000000000 178671.7999999969906639, 318435.4000000060186721 178701.5000000000000000, 318413.2000000029802322 178734.5000000000000000, 318361.2000000029802322 178805.0000000000000000, 318335.5999999939813279 178839.5000000000000000, 318308.0000000000000000 178862.9000000059895683, 318278.9000000060186721 178879.5000000000000000, 318250.5999999939813279 178891.5000000000000000, 318195.9000000060186721 178930.7999999969906639, 318170.5999999939813279 178942.7999999969906639, 318056.9000000060186721 178971.5000000000000000, 318007.9000000060186721 178975.7999999969906639, 317957.2999999970197678 178971.5999999940104317, 317912.7000000029802322 178961.5000000000000000, 317866.5000000000000000 178955.7999999969906639, 317823.5999999939813279 178924.7999999969906639, 317736.5000000000000000 178898.9000000059895683, 317684.7999999970197678 178873.5000000000000000, 317656.5000000000000000 178853.7000000030093361, 317617.7999999970197678 178823.4000000059895683, 317562.9000000060186721 178785.7999999969906639, 317523.0000000000000000 178756.2999999969906639, 317464.2999999970197678 178727.5000000000000000, 317400.2999999970197678 178681.7999999969906639, 317360.0999999939813279 178671.4000000059895683, 317294.0999999939813279 178656.2999999969906639, 317215.5999999939813279 178617.0999999940104317, 317086.2000000029802322 178569.2000000030093361, 317021.2999999970197678 178554.7000000030093361, 316952.7999999970197678 178536.5999999940104317, 316870.0000000000000000 178517.9000000059895683, 316828.2999999970197678 178512.5000000000000000, 316774.4000000060186721 178507.4000000059895683, 316697.2999999970197678 178498.7999999969906639, 316569.0000000000000000 178481.5999999940104317, 316419.7999999970197678 178472.2000000030093361, 316295.0999999939813279 178479.7999999969906639, 316204.7000000029802322 178485.7999999969906639, 316164.2999999970197678 178485.0999999940104317, 316101.7999999970197678 178490.4000000059895683, 316057.9000000060186721 178491.2999999969906639, 315974.4000000060186721 178513.0999999940104317, 315921.0000000000000000 178524.0000000000000000, 315852.2999999970197678 178551.0999999940104317, 315807.2000000029802322 178566.7000000030093361, 315774.0000000000000000 178580.2000000030093361, 315710.7000000029802322 178599.9000000059895683, 315610.7999999970197678 178628.9000000059895683, 315575.5000000000000000 178634.5999999940104317, 315480.7000000029802322 178659.0999999940104317, 315437.9000000060186721 178661.7000000030093361, 315405.7999999970197678 178666.9000000059895683, 315351.7000000029802322 178668.2999999969906639, 315288.5999999939813279 178657.5999999940104317, 315223.2999999970197678 178639.2999999969906639, 315192.0000000000000000 178624.7000000030093361, 315157.0999999939813279 178601.4000000059895683, 315095.2999999970197678 178575.4000000059895683, 315039.7000000029802322 178533.5999999940104317, 315015.5999999939813279 178472.9000000059895683, 315003.2999999970197678 178431.2000000030093361, 314995.2999999970197678 178409.5999999940104317, 314978.2000000029802322 178355.2000000030093361, 314959.2999999970197678 178286.7000000030093361, 314917.7999999970197678 178184.7999999969906639, 314913.0000000000000000 178173.9000000059895683, 314894.7000000029802322 178157.2000000030093361, 314885.0999999939813279 178153.5000000000000000, 314859.4000000060186721 178136.2999999969906639, 314832.0999999939813279 178108.0000000000000000, 314803.4000000060186721 178090.9000000059895683, 314768.0999999939813279 178085.5000000000000000, 314770.4000000060186721 178101.2000000030093361, 314774.5999999939813279 178114.7000000030093361, 314774.4000000060186721 178130.7999999969906639, 314774.7999999970197678 178148.2999999969906639, 314775.2999999970197678 178173.0000000000000000, 314763.9000000060186721 178188.0999999940104317, 314765.4000000060186721 178206.7999999969906639, 314760.5999999939813279 178218.5999999940104317, 314763.2000000029802322 178228.2999999969906639, 314752.7999999970197678 178242.2000000030093361, 314742.5999999939813279 178252.5999999940104317, 314693.4000000060186721 178363.0999999940104317, 314677.7999999970197678 178402.0999999940104317, 314649.5999999939813279 178451.5999999940104317, 314603.7999999970197678 178502.4000000059895683, 314594.5999999939813279 178521.0000000000000000, 314581.5000000000000000 178542.2999999969906639, 314570.0999999939813279 178577.9000000059895683, 314563.0999999939813279 178610.2999999969906639, 314539.0000000000000000 178648.9000000059895683, 314519.5000000000000000 178681.5999999940104317, 314505.4000000060186721 178726.0000000000000000, 314498.5000000000000000 178730.2999999969906639, 314491.2999999970197678 178813.5999999940104317, 314490.0999999939813279 178854.2000000030093361, 314486.5000000000000000 178903.0000000000000000, 314478.2999999970197678 178922.7000000030093361, 314446.2999999970197678 178960.5000000000000000, 314426.4000000060186721 178976.9000000059895683, 314394.0999999939813279 178986.7000000030093361, 314376.2000000029802322 178969.7999999969906639, 314352.7000000029802322 178961.2999999969906639, 314320.4000000060186721 178991.5999999940104317, 314312.0999999939813279 179030.7999999969906639, 314308.5000000000000000 179112.7000000030093361, 314319.2000000029802322 179153.7999999969906639, 314337.7000000029802322 179181.5999999940104317, 314351.0000000000000000 179194.5000000000000000, 314364.0000000000000000 179234.0999999940104317, 314362.7000000029802322 179261.0999999940104317, 314350.5000000000000000 179277.7000000030093361, 314297.2999999970197678 179321.2000000030093361, 314279.9000000060186721 179334.5000000000000000, 314252.7999999970197678 179407.5000000000000000, 314254.2999999970197678 179473.7999999969906639, 314260.7999999970197678 179519.7999999969906639, 314271.5000000000000000 179569.5999999940104317, 314278.2000000029802322 179592.7999999969906639, 314288.7999999970197678 179619.5000000000000000, 314298.7999999970197678 179649.5999999940104317, 314318.5999999939813279 179698.5999999940104317, 314326.5000000000000000 179722.9000000059895683, 314376.5000000000000000 179842.5999999940104317, 314393.2000000029802322 179910.2999999969906639, 314391.9000000060186721 179935.7000000030093361, 314426.7999999970197678 180008.0000000000000000, 314436.9000000060186721 180038.5999999940104317, 314442.2999999970197678 180097.5999999940104317, 314458.0999999939813279 180171.7000000030093361, 314478.9000000060186721 180268.7000000030093361, 314502.7999999970197678 180322.0999999940104317, 314519.0000000000000000 180372.7999999969906639, 314527.7999999970197678 180404.2999999969906639, 314548.7999999970197678 180449.4000000059895683, 314563.7999999970197678 180478.4000000059895683, 314580.5999999939813279 180515.2999999969906639, 314597.7000000029802322 180550.5000000000000000, 314606.7999999970197678 180583.2999999969906639, 314636.4000000060186721 180642.9000000059895683, 314694.9000000060186721 180785.2999999969906639, 314707.4000000060186721 180815.2000000030093361, 314725.9000000060186721 180840.2000000030093361, 314759.2999999970197678 180906.7000000030093361, 314771.7000000029802322 180925.5000000000000000, 314793.4000000060186721 180988.2999999969906639, 314819.0999999939813279 181036.5000000000000000, 314828.5000000000000000 181055.7999999969906639, 314845.4000000060186721 181077.2999999969906639, 314868.4000000060186721 181121.7999999969906639, 314904.2000000029802322 181168.5000000000000000, 314928.7000000029802322 181218.4000000059895683, 314961.4000000060186721 181288.2999999969906639, 314983.5999999939813279 181335.0999999940104317, 315024.2000000029802322 181381.5999999940104317, 315050.5000000000000000 181406.9000000059895683, 315066.7000000029802322 181431.7999999969906639, 315096.5999999939813279 181460.0000000000000000, 315122.2999999970197678 181477.5999999940104317, 315149.5999999939813279 181518.5999999940104317, 315192.4000000060186721 181554.9000000059895683, 315227.0999999939813279 181571.0999999940104317, 315264.2999999970197678 181604.5999999940104317, 315332.5999999939813279 181660.2000000030093361, 315365.2999999970197678 181683.7000000030093361, 315394.4000000060186721 181710.5999999940104317, 315505.0000000000000000 181774.9000000059895683, 315550.7000000029802322 181796.5999999940104317, 315579.4000000060186721 181812.7999999969906639, 315617.0999999939813279 181830.2000000030093361, 315649.5000000000000000 181850.9000000059895683, 315661.2999999970197678 181869.5999999940104317, 315675.2000000029802322 181884.2000000030093361, 315685.2000000029802322 181908.7999999969906639, 315714.2000000029802322 181992.5999999940104317, 315720.2999999970197678 182027.0000000000000000, 315723.2000000029802322 182129.0999999940104317, 315732.0999999939813279 182231.7999999969906639, 315741.4000000060186721 182363.0999999940104317, 315747.5000000000000000 182457.4000000059895683, 315763.5000000000000000 182524.2000000030093361, 315784.7000000029802322 182671.5000000000000000, 315788.7000000029802322 182711.0000000000000000, 315793.2999999970197678 182754.0000000000000000, 315785.9000000060186721 182806.0000000000000000, 315767.4000000060186721 182831.5999999940104317, 315713.2999999970197678 182843.0000000000000000, 315703.7999999970197678 182854.2000000030093361, 315692.7999999970197678 182878.7999999969906639, 315678.7999999970197678 182898.9000000059895683, 315665.5999999939813279 182930.2999999969906639, 315651.5000000000000000 182947.5000000000000000, 315641.9000000060186721 182964.0999999940104317, 315623.7000000029802322 182992.5999999940104317, 315576.0999999939813279 183067.7000000030093361, 315556.0999999939813279 183108.9000000059895683, 315542.7999999970197678 183137.7999999969906639, 315537.9000000060186721 183151.9000000059895683, 315502.5000000000000000 183197.7999999969906639, 315500.0999999939813279 183224.5000000000000000, 315505.5999999939813279 183247.7000000030093361, 315520.5000000000000000 183284.4000000059895683, 315535.0000000000000000 183299.0999999940104317, 315544.4000000060186721 183327.7000000030093361, 315552.4000000060186721 183358.2000000030093361, 315553.7999999970197678 183367.2000000030093361, 315550.7000000029802322 183394.2000000030093361, 315562.9000000060186721 183418.0999999940104317, 315591.2000000029802322 183439.2000000030093361, 315611.2999999970197678 183468.5999999940104317, 315620.0000000000000000 183487.2000000030093361, 315631.4000000060186721 183502.0000000000000000, 315642.2000000029802322 183528.2000000030093361, 315665.7000000029802322 183573.7999999969906639, 315673.2000000029802322 183604.2999999969906639, 315671.7000000029802322 183648.7999999969906639, 315670.9000000060186721 183691.9000000059895683, 315640.2999999970197678 183741.0999999940104317, 315640.7000000029802322 183756.5000000000000000, 315644.2999999970197678 183769.4000000059895683, 315641.2999999970197678 183828.9000000059895683, 315648.5000000000000000 183866.0999999940104317, 315651.9000000060186721 183892.7999999969906639, 315668.9000000060186721 183930.5000000000000000, 315678.2999999970197678 183960.2999999969906639, 315695.2999999970197678 183993.2999999969906639, 315703.5999999939813279 184021.5000000000000000, 315722.5000000000000000 184061.5999999940104317, 315750.0000000000000000 184102.0000000000000000, 315787.7999999970197678 184164.7999999969906639, 315821.4000000060186721 184232.2000000030093361, 315856.7000000029802322 184295.2000000030093361, 315872.7000000029802322 184333.2000000030093361, 315893.7000000029802322 184363.0000000000000000, 315932.0999999939813279 184388.9000000059895683, 315958.9000000060186721 184415.4000000059895683, 315964.5000000000000000 184425.2999999969906639, 315974.2999999970197678 184435.5999999940104317, 316014.4000000060186721 184496.9000000059895683, 316055.2999999970197678 184558.2999999969906639, 316091.2999999970197678 184620.9000000059895683, 316109.7999999970197678 184651.2999999969906639, 316147.2000000029802322 184696.9000000059895683, 316169.2999999970197678 184734.9000000059895683, 316183.7000000029802322 184762.0999999940104317, 316206.5000000000000000 184798.2000000030093361, 316218.5999999939813279 184823.0000000000000000, 316237.5999999939813279 184839.2000000030093361, 316252.4000000060186721 184870.2000000030093361, 316291.4000000060186721 184932.2000000030093361, 316308.4000000060186721 184967.2999999969906639, 316333.2000000029802322 185000.0000000000000000, 316344.2000000029802322 185035.5999999940104317, 316362.2000000029802322 185069.0000000000000000, 316373.7999999970197678 185114.0000000000000000, 316391.5000000000000000 185159.9000000059895683, 316423.7999999970197678 185235.2000000030093361, 316447.9000000060186721 185284.0000000000000000, 316459.2999999970197678 185298.5000000000000000, 316467.5000000000000000 185316.0999999940104317, 316469.2999999970197678 185327.5999999940104317, 316500.9000000060186721 185379.5999999940104317, 316523.7999999970197678 185431.9000000059895683, 316531.2000000029802322 185453.2999999969906639, 316556.9000000060186721 185489.7999999969906639, 316575.5999999939813279 185514.2000000030093361, 316596.7999999970197678 185545.4000000059895683, 316617.2000000029802322 185584.9000000059895683, 316620.2999999970197678 185595.2000000030093361, 316636.5999999939813279 185620.5000000000000000, 316647.5999999939813279 185653.5999999940104317, 316662.2999999970197678 185685.5000000000000000, 316666.4000000060186721 185720.4000000059895683, 316684.2999999970197678 185798.9000000059895683, 316703.2999999970197678 185851.0000000000000000, 316715.2000000029802322 185894.2999999969906639, 316714.0999999939813279 185906.7999999969906639, 316724.0999999939813279 185918.7999999969906639, 316751.7000000029802322 185922.4000000059895683, 316762.7999999970197678 185927.0999999940104317, 316757.7999999970197678 185952.7000000030093361, 316738.0999999939813279 185976.9000000059895683, 316724.7999999970197678 185992.7000000030093361, 316725.7000000029802322 186009.2999999969906639, 316734.5999999939813279 186024.9000000059895683, 316748.0999999939813279 186056.2000000030093361, 316752.2000000029802322 186074.2999999969906639, 316744.2000000029802322 186101.5999999940104317, 316756.5999999939813279 186130.5999999940104317, 316768.0999999939813279 186153.4000000059895683, 316782.5000000000000000 186164.0999999940104317, 316797.4000000060186721 186204.5999999940104317, 316804.0999999939813279 186214.4000000059895683, 316821.2999999970197678 186233.2999999969906639, 316855.5999999939813279 186293.5000000000000000, 316873.5000000000000000 186307.9000000059895683, 316911.4000000060186721 186368.0999999940104317, 316940.5999999939813279 186424.0999999940104317, 316946.5999999939813279 186434.7999999969906639, 316961.7000000029802322 186510.5999999940104317, 316965.0000000000000000 186520.7000000030093361, 316979.2999999970197678 186539.0000000000000000, 316990.5999999939813279 186584.7000000030093361, 316994.2000000029802322 186597.7000000030093361, 317018.4000000060186721 186638.9000000059895683, 317038.7000000029802322 186669.2999999969906639, 317070.5999999939813279 186694.2999999969906639, 317085.9000000060186721 186722.9000000059895683, 317090.4000000060186721 186730.7999999969906639, 317089.9000000060186721 186742.2999999969906639, 317097.7999999970197678 186764.9000000059895683, 317121.5000000000000000 186810.2000000030093361, 317140.2999999970197678 186835.2000000030093361, 317160.2999999970197678 186880.0000000000000000, 317168.5000000000000000 186905.5000000000000000, 317211.9000000060186721 186991.0999999940104317, 317257.9000000060186721 187073.5000000000000000, 317297.7000000029802322 187156.0000000000000000, 317308.7000000029802322 187177.5999999940104317, 317342.2000000029802322 187247.4000000059895683, 317351.2000000029802322 187269.2999999969906639, 317388.2999999970197678 187349.4000000059895683, 317406.7000000029802322 187390.5999999940104317, 317474.0999999939813279 187525.7999999969906639, 317552.7999999970197678 187692.4000000059895683, 317577.2000000029802322 187735.5999999940104317, 317621.7000000029802322 187821.5000000000000000, 317694.4000000060186721 187969.4000000059895683, 317716.5000000000000000 188024.0000000000000000, 317743.9000000060186721 188078.7999999969906639, 317781.5999999939813279 188157.7999999969906639, 317816.0000000000000000 188218.2999999969906639, 317863.0000000000000000 188324.2000000030093361, 317921.0999999939813279 188427.2000000030093361, 317971.0999999939813279 188527.7999999969906639, 318036.4000000060186721 188645.5000000000000000, 318060.2999999970197678 188697.7999999969906639, 318114.5000000000000000 188796.0000000000000000, 318127.0000000000000000 188812.7999999969906639, 318128.5999999939813279 188825.9000000059895683, 318159.2999999970197678 188891.7999999969906639, 318180.0999999939813279 188930.9000000059895683, 318194.2000000029802322 189015.7999999969906639, 318211.0000000000000000 189076.5999999940104317, 318223.2999999970197678 189131.5999999940104317, 318239.5999999939813279 189158.2000000030093361, 318251.2999999970197678 189190.7999999969906639, 318268.2000000029802322 189250.9000000059895683, 318290.0999999939813279 189295.9000000059895683, 318314.0999999939813279 189331.5000000000000000, 318326.0000000000000000 189359.2999999969906639, 318331.5999999939813279 189392.4000000059895683, 318331.2000000029802322 189414.5000000000000000, 318321.7000000029802322 189446.0999999940104317, 318324.4000000060186721 189466.7000000030093361, 318348.0000000000000000 189514.2999999969906639, 318350.9000000060186721 189527.9000000059895683, 318347.0000000000000000 189560.5000000000000000, 318353.5000000000000000 189573.7999999969906639, 318368.7000000029802322 189581.2999999969906639, 318387.2999999970197678 189573.7000000030093361, 318412.5999999939813279 189557.4000000059895683, 318434.9000000060186721 189556.2999999969906639, 318453.0999999939813279 189569.2999999969906639, 318486.7000000029802322 189593.7000000030093361, 318527.2000000029802322 189625.7000000030093361, 318593.7999999970197678 189695.7999999969906639, 318624.7999999970197678 189735.0000000000000000, 318671.5999999939813279 189751.2999999969906639, 318712.5000000000000000 189761.0000000000000000, 318740.7999999970197678 189776.2999999969906639, 318828.4000000060186721 189866.5999999940104317, 318846.2999999970197678 189891.9000000059895683, 318891.4000000060186721 189930.9000000059895683, 318971.5999999939813279 190014.2000000030093361, 319012.2999999970197678 190057.0000000000000000, 319067.5000000000000000 190111.0000000000000000, 319094.0000000000000000 190146.0000000000000000, 319121.9000000060186721 190176.0999999940104317, 319181.9000000060186721 190242.7000000030093361, 319255.2000000029802322 190328.7999999969906639, 319268.9000000060186721 190345.0999999940104317, 319277.2000000029802322 190348.5000000000000000, 319283.5000000000000000 190355.4000000059895683, 319308.2999999970197678 190373.9000000059895683, 319339.5999999939813279 190389.5000000000000000, 319402.2000000029802322 190440.5999999940104317, 319459.7999999970197678 190492.0000000000000000, 319490.5000000000000000 190530.2999999969906639, 319526.7000000029802322 190551.0999999940104317, 319546.9000000060186721 190565.5000000000000000, 319601.0999999939813279 190627.7999999969906639, 319628.7999999970197678 190653.9000000059895683, 319651.2000000029802322 190677.2000000030093361, 319665.2000000029802322 190695.7000000030093361, 319689.5999999939813279 190724.5000000000000000, 319694.7000000029802322 190733.0999999940104317, 319727.2999999970197678 190769.0000000000000000, 319734.0000000000000000 190781.0000000000000000, 319734.7999999970197678 190805.5999999940104317, 319746.9000000060186721 190823.4000000059895683, 319765.9000000060186721 190839.5000000000000000, 319777.5000000000000000 190853.9000000059895683, 319788.7000000029802322 190865.0999999940104317, 319798.2000000029802322 190883.7999999969906639, 319827.0000000000000000 190936.4000000059895683, 319856.0000000000000000 190970.9000000059895683, 319880.2000000029802322 191020.0999999940104317, 319891.5000000000000000 191043.7000000030093361, 319894.7999999970197678 191077.5000000000000000, 319898.2999999970197678 191100.4000000059895683, 319897.5999999939813279 191117.9000000059895683, 319905.5999999939813279 191151.0000000000000000, 319916.2000000029802322 191229.0999999940104317, 319916.2000000029802322 191269.2999999969906639, 319912.7000000029802322 191276.7999999969906639, 319908.0000000000000000 191289.5999999940104317, 319909.4000000060186721 191307.5000000000000000, 319907.7000000029802322 191320.7000000030093361, 319910.9000000060186721 191351.7000000030093361, 319914.7000000029802322 191372.7999999969906639, 319913.2000000029802322 191394.5999999940104317, 319907.9000000060186721 191410.7999999969906639, 319913.2999999970197678 191490.0000000000000000, 319912.5999999939813279 191539.5000000000000000, 319908.2000000029802322 191606.5999999940104317, 319907.5999999939813279 191656.0999999940104317, 319909.0000000000000000 191675.7000000030093361, 319904.7999999970197678 191698.0999999940104317, 319906.0000000000000000 191724.5999999940104317, 319907.5000000000000000 191780.5000000000000000, 319905.5999999939813279 191807.0000000000000000, 319908.7999999970197678 191826.4000000059895683, 319898.7000000029802322 191901.9000000059895683, 319899.4000000060186721 191945.0000000000000000, 319898.7000000029802322 191975.2999999969906639, 319903.4000000060186721 192040.5999999940104317, 319902.2000000029802322 192087.9000000059895683, 319903.5000000000000000 192124.0999999940104317, 319902.2000000029802322 192172.7000000030093361, 319905.7999999970197678 192210.4000000059895683, 319899.0000000000000000 192276.7999999969906639, 319904.2000000029802322 192321.9000000059895683, 319901.2000000029802322 192370.7999999969906639, 319903.4000000060186721 192412.0000000000000000, 319897.5999999939813279 192444.2999999969906639, 319900.0000000000000000 192480.2999999969906639, 319899.7000000029802322 192501.5999999940104317, 319896.0000000000000000 192536.7999999969906639, 319889.5000000000000000 192562.4000000059895683, 319889.9000000060186721 192590.5999999940104317, 319889.5999999939813279 192631.7000000030093361, 319892.5000000000000000 192696.7000000030093361, 319893.7999999970197678 192735.5000000000000000, 319895.5999999939813279 192757.4000000059895683, 319895.2999999970197678 192774.5000000000000000, 319892.0999999939813279 192782.2999999969906639, 319889.5000000000000000 192819.4000000059895683, 319894.5000000000000000 192881.5999999940104317, 319894.7000000029802322 192939.0000000000000000, 319893.2999999970197678 193003.7999999969906639, 319892.0000000000000000 193070.0000000000000000, 319903.2000000029802322 193084.0000000000000000, 319922.5000000000000000 193096.2000000030093361, 319931.2999999970197678 193115.2000000030093361, 319927.2000000029802322 193125.2999999969906639, 319913.2000000029802322 193139.7999999969906639, 319914.9000000060186721 193153.7000000030093361, 319888.7999999970197678 193172.7999999969906639, 319889.4000000060186721 193193.2000000030093361, 319900.0999999939813279 193208.7999999969906639, 319913.7000000029802322 193226.2999999969906639, 319913.4000000060186721 193244.5000000000000000, 319902.2000000029802322 193280.5999999940104317, 319901.9000000060186721 193307.7999999969906639, 319917.4000000060186721 193351.7000000030093361, 319931.2999999970197678 193374.7000000030093361, 319943.5000000000000000 193381.5000000000000000, 319980.4000000060186721 193390.4000000059895683, 320002.2000000029802322 193401.5999999940104317, 320026.0000000000000000 193394.4000000059895683, 320038.0999999939813279 193393.7000000030093361, 320075.2999999970197678 193419.9000000059895683, 320092.0999999939813279 193436.0000000000000000, 320088.7999999970197678 193466.7000000030093361, 320107.0000000000000000 193486.7000000030093361, 320128.4000000060186721 193504.7999999969906639, 320146.5000000000000000 193530.2999999969906639, 320146.5999999939813279 193550.5999999940104317, 320156.2000000029802322 193565.5000000000000000, 320188.7999999970197678 193587.7000000030093361, 320206.9000000060186721 193612.9000000059895683, 320218.4000000060186721 193647.0999999940104317, 320233.2999999970197678 193687.7999999969906639, 320237.0999999939813279 193698.9000000059895683, 320243.5999999939813279 193709.5000000000000000, 320242.9000000060186721 193737.2999999969906639, 320260.0999999939813279 193767.4000000059895683, 320281.9000000060186721 193792.0999999940104317, 320291.0000000000000000 193791.4000000059895683, 320302.9000000060186721 193805.2000000030093361, 320306.7000000029802322 193823.2999999969906639, 320355.0999999939813279 193942.5999999940104317, 320382.5999999939813279 194024.7000000030093361, 320389.5000000000000000 194040.5000000000000000, 320392.7000000029802322 194066.7999999969906639, 320406.5000000000000000 194102.7000000030093361, 320419.9000000060186721 194160.5999999940104317, 320421.0000000000000000 194173.7999999969906639, 320432.2000000029802322 194205.0000000000000000, 320438.0000000000000000 194236.0999999940104317, 320453.7000000029802322 194272.2000000030093361, 320506.0000000000000000 194383.2000000030093361, 320528.5000000000000000 194416.2999999969906639, 320556.2999999970197678 194461.0000000000000000, 320569.5000000000000000 194486.7000000030093361, 320625.2999999970197678 194552.2999999969906639, 320662.5000000000000000 194590.0999999940104317, 320682.2000000029802322 194624.2000000030093361, 320686.0999999939813279 194640.0000000000000000, 320694.2999999970197678 194655.0000000000000000, 320701.0999999939813279 194691.5000000000000000, 320706.5000000000000000 194705.7000000030093361, 320717.9000000060186721 194754.0999999940104317, 320723.7999999970197678 194780.9000000059895683, 320741.5000000000000000 194927.5999999940104317, 320757.2999999970197678 194984.5000000000000000, 320766.4000000060186721 195032.7000000030093361, 320770.4000000060186721 195060.7999999969906639, 320785.5999999939813279 195110.2999999969906639, 320798.7999999970197678 195186.7000000030093361, 320806.7999999970197678 195217.2000000030093361, 320802.7000000029802322 195240.4000000059895683, 320809.5000000000000000 195271.5000000000000000, 320813.2000000029802322 195307.9000000059895683, 320824.2000000029802322 195368.0000000000000000, 320830.9000000060186721 195401.5000000000000000, 320841.7000000029802322 195427.2000000030093361, 320867.4000000060186721 195442.2999999969906639, 320895.2000000029802322 195444.2999999969906639, 320937.9000000060186721 195442.7000000030093361, 320962.5000000000000000 195457.0000000000000000, 320981.7999999970197678 195481.5999999940104317, 320995.9000000060186721 195488.9000000059895683, 321024.5000000000000000 195484.2000000030093361, 321061.4000000060186721 195464.4000000059895683, 321080.9000000060186721 195462.7999999969906639, 321097.5000000000000000 195468.5000000000000000, 321106.7000000029802322 195476.7000000030093361, 321138.9000000060186721 195495.2000000030093361, 321161.2999999970197678 195504.2999999969906639, 321179.0999999939813279 195510.9000000059895683, 321193.4000000060186721 195514.7999999969906639, 321206.0999999939813279 195522.7999999969906639, 321231.4000000060186721 195533.7999999969906639, 321265.9000000060186721 195556.7000000030093361, 321273.9000000060186721 195565.7000000030093361, 321281.9000000060186721 195561.2999999969906639, 321293.0999999939813279 195566.5999999940104317, 321306.4000000060186721 195581.0999999940104317, 321322.0000000000000000 195588.2999999969906639, 321363.5999999939813279 195617.0999999940104317, 321376.7000000029802322 195632.0999999940104317, 321393.2999999970197678 195637.5999999940104317, 321428.2999999970197678 195659.7999999969906639, 321444.2000000029802322 195667.2000000030093361, 321471.7000000029802322 195684.7999999969906639, 321485.9000000060186721 195689.7999999969906639, 321500.4000000060186721 195700.5000000000000000, 321548.4000000060186721 195725.7999999969906639, 321583.9000000060186721 195761.0999999940104317, 321622.7000000029802322 195795.9000000059895683, 321652.5999999939813279 195814.0999999940104317, 321698.5999999939813279 195832.4000000059895683, 321718.2000000029802322 195849.0000000000000000, 321747.0000000000000000 195879.5999999940104317, 321762.7000000029802322 195901.2999999969906639, 321816.7999999970197678 196000.5999999940104317, 321832.5000000000000000 196027.2999999969906639, 321842.7000000029802322 196052.5999999940104317, 321896.7000000029802322 196145.5999999940104317, 321947.4000000060186721 196223.4000000059895683, 321956.0999999939813279 196244.7000000030093361, 322010.9000000060186721 196333.4000000059895683, 322035.9000000060186721 196374.2999999969906639, 322045.5999999939813279 196384.5000000000000000, 322105.7000000029802322 196477.0000000000000000, 322127.7000000029802322 196518.7000000030093361, 322170.4000000060186721 196577.0999999940104317, 322196.5000000000000000 196613.9000000059895683, 322229.2999999970197678 196671.7999999969906639, 322259.9000000060186721 196719.7999999969906639, 322351.0999999939813279 196877.2999999969906639, 322365.0999999939813279 196908.5999999940104317, 322404.4000000060186721 196969.5000000000000000, 322422.5999999939813279 197016.9000000059895683, 322509.5000000000000000 197143.7999999969906639, 322586.4000000060186721 197262.9000000059895683, 322602.0000000000000000 197300.0000000000000000, 322627.5000000000000000 197344.2000000030093361, 322640.7999999970197678 197359.2999999969906639, 322664.7999999970197678 197396.2999999969906639, 322706.7999999970197678 197472.4000000059895683, 322726.4000000060186721 197504.7999999969906639, 322745.5000000000000000 197531.7000000030093361, 322771.5000000000000000 197580.9000000059895683, 322789.2000000029802322 197609.5999999940104317, 322807.5000000000000000 197633.5000000000000000, 322866.0000000000000000 197728.9000000059895683, 322892.9000000060186721 197783.4000000059895683, 322909.5999999939813279 197806.7999999969906639, 322970.7999999970197678 197909.9000000059895683, 323046.4000000060186721 198039.4000000059895683, 323070.7000000029802322 198083.5999999940104317, 323137.2000000029802322 198190.5999999940104317, 323148.2000000029802322 198213.4000000059895683, 323155.2000000029802322 198229.4000000059895683, 323160.2999999970197678 198261.0999999940104317, 323185.5000000000000000 198290.4000000059895683, 323204.7999999970197678 198336.5000000000000000, 323208.2999999970197678 198366.2000000030093361, 323203.4000000060186721 198380.4000000059895683, 323176.0999999939813279 198408.5999999940104317, 323165.4000000060186721 198440.7000000030093361, 323136.2999999970197678 198482.4000000059895683, 323128.7999999970197678 198502.0999999940104317, 323131.0000000000000000 198520.2000000030093361, 323144.7999999970197678 198531.7999999969906639, 323160.4000000060186721 198544.4000000059895683, 323189.7000000029802322 198588.0000000000000000, 323201.0999999939813279 198614.4000000059895683, 323200.9000000060186721 198625.0999999940104317, 323206.7000000029802322 198635.7999999969906639, 323209.0999999939813279 198656.4000000059895683, 323223.2999999970197678 198687.5999999940104317, 323243.5999999939813279 198750.9000000059895683, 323260.7999999970197678 198796.9000000059895683, 323265.7000000029802322 198808.5000000000000000, 323289.5000000000000000 198850.0000000000000000, 323299.4000000060186721 198895.5000000000000000, 323308.5999999939813279 198929.7000000030093361, 323318.0999999939813279 198971.2999999969906639, 323341.0999999939813279 199038.5000000000000000, 323350.9000000060186721 199070.7999999969906639, 323389.9000000060186721 199137.0000000000000000, 323407.9000000060186721 199164.5000000000000000, 323425.5000000000000000 199187.0999999940104317, 323436.2000000029802322 199203.9000000059895683, 323448.7000000029802322 199241.0999999940104317, 323455.5000000000000000 199272.2000000030093361, 323477.0999999939813279 199288.2999999969906639, 323532.9000000060186721 199315.5999999940104317, 323578.7999999970197678 199374.5000000000000000, 323607.2000000029802322 199425.7000000030093361, 323625.9000000060186721 199483.5999999940104317, 323660.4000000060186721 199516.2000000030093361, 323680.7999999970197678 199568.5000000000000000, 323712.2999999970197678 199611.4000000059895683, 323757.5000000000000000 199662.5999999940104317, 323802.2000000029802322 199706.2999999969906639, 323868.9000000060186721 199758.5999999940104317, 323903.2999999970197678 199793.5000000000000000, 323912.9000000060186721 199799.7000000030093361, 323896.7999999970197678 199808.2999999969906639, 323911.2000000029802322 199818.5000000000000000, 323952.5999999939813279 199858.5999999940104317, 323979.0000000000000000 199874.2999999969906639, 324057.5999999939813279 199944.2999999969906639, 324108.5999999939813279 199981.7999999969906639, 324141.0000000000000000 200034.5000000000000000, 324157.0999999939813279 200064.2000000030093361, 324177.0999999939813279 200084.5000000000000000, 324199.5000000000000000 200092.2999999969906639, 324265.5000000000000000 200100.0999999940104317, 324302.0999999939813279 200115.7999999969906639, 324361.2000000029802322 200151.2999999969906639, 324378.7999999970197678 200166.9000000059895683, 324413.2999999970197678 200191.0999999940104317, 324462.7999999970197678 200228.5000000000000000, 324483.7999999970197678 200242.7000000030093361, 324527.0000000000000000 200282.2000000030093361, 324548.5999999939813279 200295.7000000030093361, 324580.5999999939813279 200327.4000000059895683, 324608.5000000000000000 200348.7000000030093361, 324644.2000000029802322 200382.2999999969906639, 324700.2000000029802322 200421.5999999940104317, 324724.0999999939813279 200435.0000000000000000, 324764.5999999939813279 200469.5000000000000000, 324803.0000000000000000 200498.2999999969906639, 324844.0999999939813279 200543.2999999969906639, 324863.5000000000000000 200566.2000000030093361, 324914.2000000029802322 200614.5999999940104317, 324927.0000000000000000 200632.0999999940104317, 324963.5000000000000000 200665.5999999940104317, 324992.4000000060186721 200699.7000000030093361, 325014.2000000029802322 200719.9000000059895683, 325016.5000000000000000 200732.9000000059895683, 325017.5000000000000000 200761.5999999940104317, 325007.7000000029802322 200900.5000000000000000, 324997.5000000000000000 200953.5000000000000000, 324984.7000000029802322 200978.0999999940104317, 324975.7999999970197678 201014.5000000000000000, 324944.9000000060186721 201092.2000000030093361, 324937.4000000060186721 201132.2000000030093361, 324922.2999999970197678 201161.2000000030093361, 324891.7000000029802322 201184.7999999969906639, 324866.9000000060186721 201223.9000000059895683, 324846.0999999939813279 201252.4000000059895683, 324826.7999999970197678 201266.0000000000000000, 324796.4000000060186721 201287.9000000059895683, 324782.7999999970197678 201292.2999999969906639, 322222.0999999939813279 202654.7999999969906639, 322209.7000000029802322 202660.2999999969906639, 319207.0000000000000000 204261.7000000030093361, 309929.2999999970197678 206015.7000000030093361, 309878.5999999939813279 206031.9000000059895683, 309837.2999999970197678 206038.0000000000000000, 309786.7000000029802322 206036.2999999969906639, 309767.7999999970197678 206032.7000000030093361, 309746.4000000060186721 206036.0000000000000000, 309732.2000000029802322 206031.2999999969906639, 309719.7000000029802322 206031.4000000059895683, 309692.0999999939813279 206030.7999999969906639, 309663.9000000060186721 206036.2999999969906639, 309619.2999999970197678 206037.0999999940104317, 309561.7999999970197678 206045.4000000059895683, 309519.5000000000000000 206046.5000000000000000, 309491.9000000060186721 206047.0000000000000000, 309468.9000000060186721 206048.9000000059895683, 309445.2999999970197678 206060.2000000030093361, 309422.5000000000000000 206062.5999999940104317, 309374.4000000060186721 206071.9000000059895683, 309321.9000000060186721 206089.0999999940104317, 309234.4000000060186721 206131.4000000059895683, 309134.0000000000000000 206203.7999999969906639, 309086.5999999939813279 206236.0000000000000000, 309058.0999999939813279 206251.4000000059895683, 309026.2000000029802322 206254.9000000059895683, 308998.2999999970197678 206278.2999999969906639, 308979.0000000000000000 206367.9000000059895683, 308959.7000000029802322 206406.0999999940104317, 308926.5999999939813279 206443.2000000030093361, 308875.7000000029802322 206485.4000000059895683, 308779.7999999970197678 206569.2000000030093361, 308668.5999999939813279 206648.2999999969906639, 308625.2999999970197678 206686.7999999969906639, 308559.2999999970197678 206757.7999999969906639, 308514.0000000000000000 206809.2999999969906639, 308476.9000000060186721 206842.9000000059895683, 308406.5000000000000000 206901.9000000059895683, 308349.5000000000000000 206937.2000000030093361, 308324.4000000060186721 206942.5000000000000000, 308312.0999999939813279 206934.2999999969906639, 308290.5999999939813279 206898.0999999940104317, 308276.2999999970197678 206891.4000000059895683, 308259.0000000000000000 206901.5999999940104317, 308246.5000000000000000 206889.4000000059895683, 308235.9000000060186721 206890.5999999940104317, 308208.5999999939813279 206912.5000000000000000, 308166.5000000000000000 206981.0000000000000000, 308152.2000000029802322 207034.2000000030093361, 308149.9000000060186721 207064.5999999940104317, 308149.2000000029802322 207093.5000000000000000, 308154.5000000000000000 207134.4000000059895683, 308157.4000000060186721 207149.2999999969906639, 308170.0999999939813279 207218.0000000000000000, 308177.7999999970197678 207233.7000000030093361, 308175.4000000060186721 207260.2999999969906639, 308155.9000000060186721 207287.5000000000000000, 308148.4000000060186721 207304.5999999940104317, 308154.2000000029802322 207325.5000000000000000, 308151.7000000029802322 207350.0000000000000000, 308156.5000000000000000 207389.7999999969906639, 308161.0999999939813279 207404.2000000030093361, 308152.0000000000000000 207419.2999999969906639, 308141.9000000060186721 207453.0000000000000000, 308141.9000000060186721 207480.2999999969906639, 308128.9000000060186721 207523.5000000000000000, 308108.7999999970197678 207574.7000000030093361, 308100.2999999970197678 207603.2999999969906639, 308101.5000000000000000 207631.2000000030093361, 308099.0999999939813279 207652.0999999940104317, 308101.2999999970197678 207681.5000000000000000, 308110.5000000000000000 207716.9000000059895683, 308084.5999999939813279 207728.7000000030093361, 308090.5999999939813279 207741.0999999940104317, 308093.4000000060186721 207759.5000000000000000, 308085.0000000000000000 207784.0999999940104317, 308076.0999999939813279 207818.5999999940104317, 308074.7999999970197678 207833.2000000030093361, 308082.7999999970197678 207876.4000000059895683, 308087.7999999970197678 207899.2999999969906639, 308071.2000000029802322 207905.0000000000000000, 308073.0999999939813279 207915.5000000000000000, 308063.2999999970197678 207919.2000000030093361, 308052.0000000000000000 207920.9000000059895683, 308053.2000000029802322 207930.2999999969906639, 308050.2000000029802322 207943.2999999969906639, 308038.4000000060186721 207972.4000000059895683, 308050.2000000029802322 208005.2000000030093361, 308048.0000000000000000 208023.2000000030093361, 308059.7000000029802322 208032.5000000000000000, 308069.5000000000000000 208055.9000000059895683, 308068.9000000060186721 208102.7000000030093361, 308054.9000000060186721 208153.7999999969906639, 308042.2999999970197678 208168.0000000000000000, 308044.5999999939813279 208178.0000000000000000, 308028.7000000029802322 208200.5999999940104317, 308024.7000000029802322 208255.5999999940104317, 308018.5999999939813279 208283.7000000030093361, 308004.7000000029802322 208305.9000000059895683, 307981.2000000029802322 208323.2000000030093361, 307984.5000000000000000 208337.5999999940104317, 307978.2000000029802322 208358.0999999940104317, 307974.0000000000000000 208372.2000000030093361, 307963.7999999970197678 208420.7999999969906639, 307965.9000000060186721 208464.5999999940104317, 307965.2999999970197678 208472.5000000000000000, 307954.9000000060186721 208493.2999999969906639, 307948.0999999939813279 208521.2999999969906639, 307944.5999999939813279 208558.7999999969906639, 307940.4000000060186721 208578.2999999969906639, 307955.5999999939813279 208664.7999999969906639, 307950.2000000029802322 208736.2999999969906639, 307948.2000000029802322 208765.7000000030093361, 307959.2999999970197678 208821.0000000000000000, 307968.7999999970197678 208862.2000000030093361, 307963.0000000000000000 208894.2000000030093361, 307961.4000000060186721 208904.2999999969906639, 307969.2999999970197678 208938.5000000000000000, 307969.0000000000000000 208983.9000000059895683, 307981.0000000000000000 209034.2000000030093361, 307976.5999999939813279 209085.7000000030093361, 307971.5000000000000000 209104.0999999940104317, 307960.2999999970197678 209137.7999999969906639, 307945.5999999939813279 209178.9000000059895683, 307943.0999999939813279 209227.7999999969906639, 307923.5999999939813279 209246.0999999940104317, 307922.4000000060186721 209272.5999999940104317, 307929.4000000060186721 209300.9000000059895683, 307925.7000000029802322 209330.9000000059895683, 307916.2000000029802322 209341.0999999940104317, 307906.5999999939813279 209363.2000000030093361, 307909.5999999939813279 209388.5999999940104317, 307882.4000000060186721 209437.4000000059895683, 307870.0999999939813279 209482.0000000000000000, 307876.5000000000000000 209511.7999999969906639, 307896.7999999970197678 209538.0000000000000000, 307909.5999999939813279 209546.7999999969906639, 307912.7000000029802322 209555.7000000030093361, 307904.0000000000000000 209564.2999999969906639, 307883.4000000060186721 209604.5000000000000000, 307880.7999999970197678 209646.0000000000000000, 307894.0000000000000000 209681.7999999969906639, 307889.7000000029802322 209696.2999999969906639, 307872.7000000029802322 209713.0000000000000000, 307862.7000000029802322 209731.5999999940104317, 307856.2999999970197678 209766.2000000030093361, 307844.2999999970197678 209789.2000000030093361, 307845.9000000060186721 209828.7000000030093361, 307842.7999999970197678 209846.7000000030093361, 307853.5000000000000000 209897.0000000000000000, 307887.7999999970197678 209958.2999999969906639, 307923.2000000029802322 210024.5999999940104317, 307926.7000000029802322 210050.0000000000000000, 307925.2000000029802322 210097.4000000059895683, 307927.0000000000000000 210155.2000000030093361, 307928.2000000029802322 210170.2999999969906639, 307920.0000000000000000 210276.5999999940104317, 307913.9000000060186721 210324.0999999940104317, 307908.7000000029802322 210337.2000000030093361, 307887.7000000029802322 210355.4000000059895683, 307868.7999999970197678 210363.2000000030093361, 307853.7999999970197678 210373.4000000059895683, 307836.5999999939813279 210380.7000000030093361, 307823.4000000060186721 210395.4000000059895683, 307836.5000000000000000 210423.0999999940104317, 307864.5000000000000000 210463.5000000000000000, 307875.5999999939813279 210482.9000000059895683, 307880.5999999939813279 210504.7999999969906639, 307888.4000000060186721 210530.0999999940104317, 307886.5000000000000000 210571.0000000000000000, 307883.0999999939813279 210589.5000000000000000, 307878.2999999970197678 210627.0999999940104317, 307861.4000000060186721 210676.2000000030093361, 307858.0999999939813279 210693.2000000030093361, 307879.2000000029802322 210733.7999999969906639, 307893.0000000000000000 210780.0000000000000000, 307893.5999999939813279 210796.0000000000000000, 307886.7000000029802322 210827.4000000059895683, 307899.5000000000000000 210857.7000000030093361, 307930.0000000000000000 210886.5999999940104317, 307939.0999999939813279 210897.5000000000000000, 307951.2000000029802322 210897.7999999969906639, 307962.7999999970197678 210919.5999999940104317, 307975.0999999939813279 210961.2999999969906639, 307983.9000000060186721 210977.5999999940104317, 307998.4000000060186721 211017.2999999969906639, 308001.7000000029802322 211048.7000000030093361, 308006.9000000060186721 211062.0999999940104317, 308018.4000000060186721 211098.9000000059895683, 308038.7999999970197678 211138.4000000059895683, 308064.9000000060186721 211169.0000000000000000, 308079.5000000000000000 211183.2000000030093361, 308101.7000000029802322 211219.7999999969906639, 308119.2999999970197678 211242.4000000059895683, 308132.0999999939813279 211274.0999999940104317, 308143.2999999970197678 211293.5000000000000000, 308140.2000000029802322 211321.9000000059895683, 308127.0000000000000000 211344.0999999940104317, 308114.7999999970197678 211385.2000000030093361, 308101.7000000029802322 211417.7999999969906639, 308085.0999999939813279 211448.0000000000000000, 308081.5999999939813279 211461.5000000000000000, 308066.7999999970197678 211479.2999999969906639, 308060.7999999970197678 211506.7999999969906639, 308054.5000000000000000 211522.2999999969906639, 308040.5999999939813279 211559.0000000000000000, 308037.2999999970197678 211567.5000000000000000, 308028.5000000000000000 211587.2000000030093361, 308021.0999999939813279 211597.7999999969906639, 308018.2999999970197678 211610.7999999969906639, 308010.7999999970197678 211628.7999999969906639, 308005.0999999939813279 211647.2999999969906639, 307992.9000000060186721 211676.5999999940104317, 307981.7999999970197678 211700.2000000030093361, 307957.9000000060186721 211763.0000000000000000, 307936.2000000029802322 211813.5999999940104317, 307926.7999999970197678 211834.2000000030093361, 307918.2999999970197678 211858.4000000059895683, 307902.0999999939813279 211872.0999999940104317, 307901.5999999939813279 211882.5999999940104317, 307895.9000000060186721 211898.0999999940104317, 307852.4000000060186721 211942.7999999969906639, 307829.2000000029802322 211987.4000000059895683, 307827.5000000000000000 212029.9000000059895683, 307806.9000000060186721 212072.0999999940104317, 307799.9000000060186721 212093.7000000030093361, 307790.5999999939813279 212111.4000000059895683, 307775.0999999939813279 212145.5000000000000000, 307763.2999999970197678 212164.0999999940104317, 307751.5999999939813279 212190.4000000059895683, 307726.7999999970197678 212237.5999999940104317, 307703.0999999939813279 212288.7999999969906639, 307707.9000000060186721 212312.7999999969906639, 307702.0000000000000000 212325.4000000059895683, 307658.2999999970197678 212380.9000000059895683, 307644.5999999939813279 212400.0999999940104317, 307620.4000000060186721 212413.9000000059895683, 307584.2999999970197678 212426.9000000059895683, 307574.7999999970197678 212442.0999999940104317, 307569.7999999970197678 212451.7000000030093361, 307564.5000000000000000 212463.7000000030093361, 307563.4000000060186721 212473.2000000030093361, 307549.2000000029802322 212485.4000000059895683, 307498.5000000000000000 212569.0999999940104317, 307486.9000000060186721 212585.5999999940104317, 307481.0999999939813279 212620.7000000030093361, 307471.0999999939813279 212653.7999999969906639, 307445.5000000000000000 212694.0999999940104317, 307429.7999999970197678 212749.2999999969906639, 307421.0999999939813279 212814.2000000030093361, 307409.5999999939813279 212842.9000000059895683, 307406.5000000000000000 212869.9000000059895683, 307398.0000000000000000 212906.0000000000000000, 307390.0000000000000000 212918.5000000000000000, 307391.2999999970197678 212956.9000000059895683, 307391.9000000060186721 212994.7999999969906639, 307376.4000000060186721 213015.5999999940104317, 307366.0999999939813279 213044.0999999940104317, 307343.4000000060186721 213084.9000000059895683, 307302.5999999939813279 213137.5000000000000000, 307280.5000000000000000 213158.7999999969906639, 307244.7000000029802322 213212.2999999969906639, 307228.7000000029802322 213238.9000000059895683, 307182.5000000000000000 213304.0000000000000000, 307161.9000000060186721 213326.7999999969906639, 307154.5999999939813279 213364.7999999969906639, 307146.0999999939813279 213381.5000000000000000, 307130.7999999970197678 213396.7000000030093361, 307118.5999999939813279 213416.7999999969906639, 307096.2000000029802322 213430.7000000030093361, 307076.2000000029802322 213432.0000000000000000, 307068.5999999939813279 213439.5999999940104317, 307049.4000000060186721 213477.2999999969906639, 307031.5000000000000000 213507.5999999940104317, 307019.7999999970197678 213529.7000000030093361, 307002.5000000000000000 213547.4000000059895683, 306939.2999999970197678 213650.7000000030093361, 306895.9000000060186721 213709.2000000030093361, 306879.0000000000000000 213749.9000000059895683, 306860.7999999970197678 213813.5999999940104317, 306844.2000000029802322 213874.2000000030093361, 306833.7999999970197678 213897.7999999969906639, 306777.9000000060186721 213903.2000000030093361, 306750.7999999970197678 214018.4000000059895683, 306747.4000000060186721 214036.9000000059895683, 306715.7000000029802322 214108.7999999969906639, 306705.0999999939813279 214125.4000000059895683, 306685.7999999970197678 214166.7000000030093361, 306628.5999999939813279 214263.9000000059895683, 306604.5999999939813279 214313.2000000030093361, 306585.4000000060186721 214347.9000000059895683, 306553.9000000060186721 214393.2999999969906639, 306501.9000000060186721 214469.4000000059895683, 306470.2999999970197678 214512.2999999969906639, 306444.5000000000000000 214548.7000000030093361, 306393.0999999939813279 214614.7999999969906639, 306306.5999999939813279 214750.5000000000000000, 306228.5999999939813279 214864.5000000000000000, 306122.0000000000000000 215018.9000000059895683, 306068.2000000029802322 215095.0999999940104317, 306000.9000000060186721 215204.2999999969906639, 305992.7000000029802322 215223.0000000000000000, 305969.7999999970197678 215274.2000000030093361, 305936.2999999970197678 215330.7000000030093361, 305919.9000000060186721 215359.4000000059895683, 305881.9000000060186721 215424.4000000059895683, 305849.2000000029802322 215493.7000000030093361, 305808.5999999939813279 215566.7000000030093361, 305796.5999999939813279 215592.2999999969906639, 305775.7999999970197678 215628.2000000030093361, 305738.7000000029802322 215697.0999999940104317, 305627.2999999970197678 215880.9000000059895683, 305598.7999999970197678 215935.2999999969906639, 305571.7000000029802322 215987.0999999940104317, 305534.5999999939813279 216040.7000000030093361, 305522.5000000000000000 216057.2999999969906639, 305463.5999999939813279 216155.0999999940104317, 305429.7000000029802322 216209.0000000000000000, 305358.0999999939813279 216318.9000000059895683, 305314.9000000060186721 216390.0000000000000000, 305218.0999999939813279 216534.5999999940104317, 305191.0000000000000000 216584.0000000000000000, 305146.5000000000000000 216663.0000000000000000, 305100.5000000000000000 216727.2000000030093361, 305068.4000000060186721 216793.9000000059895683, 305030.0000000000000000 216862.9000000059895683, 304980.4000000060186721 216942.5999999940104317, 304943.2999999970197678 216992.5000000000000000, 304866.2999999970197678 217124.0000000000000000, 304846.0000000000000000 217160.7999999969906639, 304817.2000000029802322 217203.5999999940104317, 304769.5000000000000000 217297.7000000030093361, 304749.2999999970197678 217338.5000000000000000, 304723.2999999970197678 217393.2999999969906639, 304681.0999999939813279 217467.2999999969906639, 304649.7999999970197678 217538.5999999940104317, 304590.2999999970197678 217662.7999999969906639, 304555.0000000000000000 217746.7000000030093361, 304495.2000000029802322 217838.5000000000000000, 304409.5000000000000000 217989.0000000000000000, 304368.2999999970197678 218042.5999999940104317, 304280.7999999970197678 218211.0999999940104317, 304251.0000000000000000 218276.5000000000000000, 304207.0000000000000000 218355.5000000000000000, 304182.4000000060186721 218412.7999999969906639, 304162.0000000000000000 218462.5000000000000000, 304132.0999999939813279 218530.2999999969906639, 304103.5999999939813279 218614.2000000030093361, 304054.4000000060186721 218721.7999999969906639, 304030.7999999970197678 218797.5000000000000000, 304017.7000000029802322 218842.0999999940104317, 303987.2000000029802322 218927.7999999969906639, 303956.7999999970197678 219045.0999999940104317, 303947.2000000029802322 219105.5999999940104317, 303931.0000000000000000 219169.2999999969906639, 303924.5000000000000000 219261.2000000030093361, 303881.4000000060186721 219431.5999999940104317, 303864.0999999939813279 219476.7999999969906639, 303856.0000000000000000 219533.2000000030093361, 303839.2999999970197678 219688.2000000030093361, 303824.2999999970197678 219766.2000000030093361, 303819.2000000029802322 219807.7999999969906639, 303803.2000000029802322 219863.4000000059895683, 303782.7999999970197678 220000.5000000000000000, 303757.0999999939813279 220131.5999999940104317, 303739.9000000060186721 220203.7000000030093361, 303692.0000000000000000 220368.0999999940104317, 303678.2000000029802322 220431.2999999969906639, 303636.4000000060186721 220547.5999999940104317, 303617.0999999939813279 220621.2999999969906639, 303599.4000000060186721 220689.0000000000000000, 303574.5000000000000000 220780.2000000030093361, 303555.2000000029802322 220857.4000000059895683, 303543.5999999939813279 220910.0000000000000000, 303497.7999999970197678 221055.4000000059895683, 303466.0999999939813279 221140.2000000030093361, 303432.2000000029802322 221243.0999999940104317, 303407.7999999970197678 221300.4000000059895683, 303377.5999999939813279 221436.5999999940104317, 303362.7999999970197678 221508.5999999940104317, 303342.2000000029802322 221596.7999999969906639, 303330.5000000000000000 221664.9000000059895683, 303305.9000000060186721 221775.5000000000000000, 303295.5000000000000000 221890.9000000059895683, 303273.7999999970197678 222024.9000000059895683, 303264.0000000000000000 222176.4000000059895683, 303260.4000000060186721 222250.7999999969906639, 303247.5000000000000000 222320.7999999969906639, 303245.7999999970197678 222443.0999999940104317, 303247.4000000060186721 222456.5000000000000000, 303248.2999999970197678 222483.0000000000000000, 307493.0999999939813279 222616.4000000059895683, 307496.0000000000000000 222606.9000000059895683, 308026.2000000029802322 222622.4000000059895683, 308050.7000000029802322 222623.5000000000000000, 312441.7999999970197678 221993.7000000030093361, 311818.2000000029802322 217599.4000000059895683, 317924.5999999939813279 218352.2999999969906639, 318638.9000000060186721 218380.2999999969906639, 318654.0000000000000000 218373.0999999940104317, 325105.7999999970197678 218717.7000000030093361, 328449.5999999939813279 222082.2999999969906639, 329488.7999999970197678 222431.9000000059895683, 333400.7000000029802322 223759.7999999969906639, 334532.5000000000000000 223883.7999999969906639, 336703.7000000029802322 223376.4000000059895683, 337699.0000000000000000 222898.2000000030093361, 338396.0999999939813279 223092.5999999940104317, 338259.9000000060186721 225268.5000000000000000, 338267.7000000029802322 225279.4000000059895683, 338279.5000000000000000 225283.5999999940104317, 338295.7000000029802322 225313.2999999969906639, 338327.5000000000000000 225357.5999999940104317, 338350.0999999939813279 225389.2000000030093361, 338365.5999999939813279 225402.9000000059895683, 338375.9000000060186721 225414.7000000030093361, 338410.0000000000000000 225468.0999999940104317, 338458.7999999970197678 225516.2000000030093361, 338491.9000000060186721 225553.5999999940104317, 338501.9000000060186721 225572.4000000059895683, 338520.5999999939813279 225595.5000000000000000, 338541.2999999970197678 225624.0999999940104317, 338561.0999999939813279 225663.2000000030093361, 338587.0000000000000000 225723.5999999940104317, 338605.7999999970197678 225770.2000000030093361, 338613.7000000029802322 225810.5000000000000000, 338620.0000000000000000 225825.4000000059895683, 338632.9000000060186721 225931.9000000059895683, 338637.9000000060186721 226013.0999999940104317, 338643.5000000000000000 226035.9000000059895683, 338652.2000000029802322 226101.5999999940104317, 338660.2999999970197678 226133.9000000059895683, 338667.5000000000000000 226148.7999999969906639, 338676.4000000060186721 226187.0999999940104317, 338683.4000000060186721 226216.2999999969906639, 338701.9000000060186721 226259.5000000000000000, 338733.7999999970197678 226316.2999999969906639, 338757.7999999970197678 226356.2999999969906639, 338796.7000000029802322 226397.5999999940104317, 338821.5000000000000000 226421.5999999940104317, 338833.9000000060186721 226438.9000000059895683, 338924.2000000029802322 226569.5999999940104317, 338939.2000000029802322 226585.4000000059895683, 339013.7000000029802322 226672.5000000000000000, 339080.2999999970197678 226723.7999999969906639, 339117.9000000060186721 226742.0999999940104317, 339142.9000000060186721 226748.7999999969906639, 339162.0000000000000000 226752.4000000059895683, 339186.7999999970197678 226762.0000000000000000, 339227.0000000000000000 226762.9000000059895683, 339270.2000000029802322 226751.0999999940104317, 339310.9000000060186721 226731.0999999940104317, 339358.2999999970197678 226684.0000000000000000, 339383.0000000000000000 226644.5999999940104317, 339411.7999999970197678 226599.2000000030093361, 339453.2000000029802322 226553.2999999969906639, 339504.4000000060186721 226488.0999999940104317, 339556.7000000029802322 226440.4000000059895683, 339630.7999999970197678 226385.2999999969906639, 339674.7999999970197678 226360.5999999940104317, 339688.7000000029802322 226357.9000000059895683, 339717.4000000060186721 226351.0000000000000000, 339730.2000000029802322 226344.7999999969906639, 339755.5000000000000000 226347.4000000059895683, 339782.0999999939813279 226341.5000000000000000, 339810.7000000029802322 226349.5000000000000000, 339824.5999999939813279 226348.7999999969906639, 339865.5000000000000000 226372.5000000000000000, 339877.5999999939813279 226382.7999999969906639, 339894.2999999970197678 226395.0000000000000000, 339911.5000000000000000 226415.2000000030093361, 339926.2000000029802322 226446.9000000059895683, 339935.0999999939813279 226499.7000000030093361, 339932.0999999939813279 226535.5999999940104317, 339915.7999999970197678 226573.7999999969906639, 339874.0000000000000000 226631.2999999969906639, 339829.2999999970197678 226673.5000000000000000, 339802.2999999970197678 226708.7000000030093361, 339738.4000000060186721 226774.0999999940104317, 339695.4000000060186721 226836.2000000030093361, 339612.7999999970197678 226943.2999999969906639, 339587.0000000000000000 226980.0999999940104317, 339535.9000000060186721 227041.7999999969906639, 339499.2999999970197678 227077.7000000030093361, 339456.7000000029802322 227151.2999999969906639, 339447.2000000029802322 227171.7999999969906639, 339438.7000000029802322 227195.9000000059895683, 339429.5000000000000000 227236.4000000059895683, 339438.5000000000000000 227325.5999999940104317, 339456.0999999939813279 227395.5999999940104317, 339475.0999999939813279 227451.2000000030093361, 339496.0999999939813279 227487.7999999969906639, 339505.7999999970197678 227513.0000000000000000, 339559.4000000060186721 227573.0000000000000000, 339595.0999999939813279 227605.4000000059895683, 339663.0999999939813279 227664.2000000030093361, 339720.2999999970197678 227700.7000000030093361, 339756.7999999970197678 227717.0000000000000000, 339772.7999999970197678 227721.7999999969906639, 339793.0999999939813279 227738.0000000000000000, 339866.5999999939813279 227760.5999999940104317, 339893.0999999939813279 227762.7999999969906639, 339932.4000000060186721 227768.2000000030093361, 339980.9000000060186721 227781.2999999969906639, 339999.7999999970197678 227794.0000000000000000, 340042.2000000029802322 227807.7999999969906639, 340082.4000000060186721 227833.5999999940104317, 340098.9000000060186721 227844.2000000030093361, 340117.9000000060186721 227872.9000000059895683, 340144.9000000060186721 227925.2999999969906639, 340170.2999999970197678 227994.7000000030093361, 340182.7999999970197678 228047.5000000000000000, 340195.5000000000000000 228118.5000000000000000, 340200.9000000060186721 228144.4000000059895683, 340200.2000000029802322 228156.2999999969906639, 340206.9000000060186721 228182.2000000030093361, 340209.2000000029802322 228222.5000000000000000, 340222.5000000000000000 228268.2999999969906639, 340236.2999999970197678 228320.7999999969906639, 340236.9000000060186721 228335.7999999969906639, 340235.5000000000000000 228359.7999999969906639, 340234.5000000000000000 228382.7999999969906639, 340256.9000000060186721 228463.7000000030093361, 346105.4000000060186721 229356.2000000030093361, 346132.5000000000000000 229361.2999999969906639, 346156.5000000000000000 229366.9000000059895683, 346255.2999999970197678 229377.7999999969906639, 346302.2999999970197678 229388.5000000000000000, 346347.2000000029802322 229389.2000000030093361, 346376.5999999939813279 229390.2999999969906639, 346482.5000000000000000 229402.0000000000000000, 346542.2999999970197678 229410.0999999940104317, 346737.5000000000000000 229441.7999999969906639, 346783.0000000000000000 229445.7000000030093361, 346822.2999999970197678 229453.4000000059895683, 346873.4000000060186721 229468.5999999940104317, 346965.2999999970197678 229481.0999999940104317, 347007.5999999939813279 229482.5000000000000000, 347127.5000000000000000 229501.4000000059895683, 347233.2000000029802322 229516.7000000030093361, 347282.7000000029802322 229526.9000000059895683, 347319.0999999939813279 229531.7999999969906639, 347381.5000000000000000 229548.2999999969906639, 347461.9000000060186721 229562.4000000059895683, 347551.0999999939813279 229573.0000000000000000, 347632.5999999939813279 229580.0999999940104317, 347725.7000000029802322 229593.7000000030093361, 347866.7999999970197678 229608.4000000059895683, 347889.5000000000000000 229613.9000000059895683, 347991.0000000000000000 229629.2999999969906639, 348037.0000000000000000 229636.0999999940104317, 348078.7999999970197678 229643.2999999969906639, 348129.2000000029802322 229647.5000000000000000, 348184.7999999970197678 229653.2000000030093361, 348258.5999999939813279 229659.0000000000000000, 348357.5000000000000000 229677.7999999969906639, 348429.0000000000000000 229689.5999999940104317, 348475.2000000029802322 229694.4000000059895683, 348493.2000000029802322 229693.5000000000000000, 348542.2000000029802322 229700.7999999969906639, 348615.9000000060186721 229705.0999999940104317, 348707.5000000000000000 229718.0000000000000000, 348757.0999999939813279 229722.7999999969906639, 348909.9000000060186721 229746.2000000030093361, 349000.5000000000000000 229753.2999999969906639, 349113.5000000000000000 229768.9000000059895683, 349212.5000000000000000 229784.2999999969906639, 349276.4000000060186721 229794.7000000030093361, 349386.2999999970197678 229819.5000000000000000, 349515.2999999970197678 229845.7999999969906639, 349610.5999999939813279 229860.7000000030093361, 349692.7999999970197678 229864.2999999969906639, 349756.7999999970197678 229870.4000000059895683, 349816.2999999970197678 229882.4000000059895683, 349865.0999999939813279 229894.5999999940104317, 349920.0999999939813279 229906.5999999940104317, 350055.5999999939813279 229936.7999999969906639, 350098.7999999970197678 229940.7000000030093361, 350203.9000000060186721 229959.5000000000000000, 350425.5999999939813279 229997.7999999969906639, 350458.5999999939813279 230001.2000000030093361, 350483.4000000060186721 230009.2999999969906639, 350550.2999999970197678 230016.7999999969906639, 350602.2999999970197678 230025.4000000059895683, 350649.0999999939813279 230030.0999999940104317, 350745.5999999939813279 230047.0000000000000000, 350769.5999999939813279 230049.5999999940104317, 350812.0000000000000000 230056.5000000000000000, 350850.0999999939813279 230061.7999999969906639, 350899.2000000029802322 230069.5000000000000000, 350935.2999999970197678 230067.9000000059895683, 351026.0999999939813279 230082.0000000000000000, 351084.2000000029802322 230088.9000000059895683, 351122.9000000060186721 230091.9000000059895683, 351147.9000000060186721 230097.0000000000000000, 351151.2000000029802322 230031.5000000000000000, 353161.4000000060186721 230412.2999999969906639, 353177.0000000000000000 230413.5999999940104317, 362053.7000000029802322 231736.7000000030093361, 362062.2000000029802322 231744.0000000000000000)))
+Input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
+Geometry coordinates: 3629x3
+isValid
+isSimple
+ConvexHull: POLYGON ((335197.0000000000000000 167635.9000000059895683, 329292.5000000000000000 168040.7000000030093361, 326778.0000000000000000 168869.2999999969906639, 326730.0999999939813279 168889.2999999969906639, 326658.5999999939813279 168919.5000000000000000, 326536.9000000060186721 168988.2999999969906639, 326477.0000000000000000 169031.4000000059895683, 314768.0999999939813279 178085.5000000000000000, 314320.4000000060186721 178991.5999999940104317, 303956.7999999970197678 219045.0999999940104317, 303407.7999999970197678 221300.4000000059895683, 303377.5999999939813279 221436.5999999940104317, 303342.2000000029802322 221596.7999999969906639, 303305.9000000060186721 221775.5000000000000000, 303273.7999999970197678 222024.9000000059895683, 303247.5000000000000000 222320.7999999969906639, 303245.7999999970197678 222443.0999999940104317, 303248.2999999970197678 222483.0000000000000000, 340256.9000000060186721 228463.7000000030093361, 371918.2999999970197678 233350.7999999969906639, 373503.5000000000000000 233590.0999999940104317, 373539.5999999939813279 233594.0999999940104317, 373629.5000000000000000 233598.0000000000000000, 373642.2000000029802322 233597.9000000059895683, 373562.9000000060186721 233422.0999999940104317, 365303.2999999970197678 216741.5999999940104317, 365243.2000000029802322 216626.4000000059895683, 339793.5999999939813279 171618.4000000059895683, 338739.4000000060186721 169896.5999999940104317, 338726.9000000060186721 169879.5000000000000000, 337790.2000000029802322 168602.5000000000000000, 337756.7000000029802322 168562.2999999969906639, 337685.7999999970197678 168497.0999999940104317, 337651.9000000060186721 168467.7000000030093361, 337601.2999999970197678 168427.0000000000000000, 337485.7000000029802322 168368.5999999940104317, 335357.0000000000000000 167673.9000000059895683, 335286.5000000000000000 167652.2999999969906639, 335197.0000000000000000 167635.9000000059895683))
+Buffer: POLYGON ((335215.0239261208334938 167537.5377202073286753, 335210.0916716848732904 167536.7606630478694569, 335205.1267784655792639 167536.2307696900388692, 335200.1416244141873904 167535.9493612084188499, 335195.1486379941343330 167535.9171391811396461, 335190.1602671957225539 167536.1341839407396037, 329285.6602671957225539 167940.9341839377593715, 329280.6851495988667011 167941.4004062979074661, 329275.7395326890982687 167942.1145713863952551, 329270.8357652556151152 167943.0748959931370337, 329265.9860915930476040 167944.2789822683553211, 329261.2026209282921627 167945.7238237099954858, 326746.7026209282921627 168774.3238237039768137, 326739.4700757855316624 168777.0208314917108510, 326691.5700757795129903 168797.0208314917108510, 326691.1906471042311750 168797.1801744560070802, 326619.6906471042311750 168827.3801744590164162, 326614.4661321343737654 168829.7659389766049571, 326609.3872034477535635 168832.4477130909217522, 326487.6872034597909078 168901.2477130879124161, 326483.0105803586193360 168904.0626540626399219, 326478.4945191467413679 168907.1285776514559984, 326418.5945191407226957 168950.2285776604549028, 326415.8285449087852612 168952.2921427348919678, 314706.9285449027665891 178006.3921427289023995, 314703.0203897153842263 178009.5747451371571515, 314699.2775538869318552 178012.9502176995156333, 314695.7095452067442238 178016.5099858262110502, 314692.3254273570491932 178020.2450067681784276, 314689.1337968888110481 178024.1457925880094990, 314686.1427613845444284 178028.2024342618533410, 314683.3599188625812531 178032.4046268509118818, 314680.7923384761670604 178036.7416956787055824, 314678.4465425560483709 178041.2026234475779347, 314230.7465425680857152 178947.3026234415883664, 314228.5878578424453735 178951.9700800933642313, 314226.6719709816970862 178956.7423383510031272, 314225.0039485624292865 178961.6067779435543343, 314223.5882016817340627 178966.5505348258011509, 303859.9882016727351584 219020.0505348258011509, 303859.6373324339510873 219021.4480226553569082, 303310.6373324339510873 221276.7480226673360448, 303310.1711850037681870 221278.7524947684432846, 303279.9711850007297471 221414.9524947564641479, 303279.9555483013973571 221415.0231361427286174, 303244.5555483103962615 221575.2231361457088497, 303244.2014352029073052 221576.8931846534833312, 303207.9014352059457451 221755.5931846564926673, 303206.7181479214923456 221762.7344127797405235, 303174.6181479124934413 222012.1344127857300919, 303174.1926699578762054 222016.0467631698702462, 303147.8926699608564377 222311.9467631608713418, 303147.5096594412461855 222319.4101097332895733, 303145.8096594382659532 222441.7101097303093411, 303145.9957166555686854 222449.3534012049494777, 303148.4957166555686854 222489.2534012109390460, 303148.9538959227502346 222494.4171627500036266, 303149.6790615010540932 222499.5502413932117634, 303150.6692645543371327 222504.6388423194293864, 303151.9218439752003178 222509.6692902386421338, 303153.4334335363237187 222514.6280661432247143, 303155.1999709373340011 222519.5018436395912431, 303157.2167087217676453 222524.2775247619138099, 303159.4782270356081426 222528.9422751721285749, 303161.9784481927636079 222533.4835586513218004, 303164.7106530084856786 222537.8891707901784685, 303167.6674988568993285 222542.1472717873693909, 303170.8410394035163336 222546.2464182683033869, 303174.2227459607529454 222550.1755940386210568, 303177.8035304081276990 222553.9242396893096156, 303181.5737696161959320 222557.4822809745091945, 303185.5233313077478670 222560.8401558854966424, 303189.6416012879926711 222563.9888403478544205, 303193.9175119692226872 222566.9198724731104448, 303198.3395721145207062 222569.6253752996271942, 303202.8958977197180502 222572.0980779612727929, 303207.5742439505993389 222574.3313352275581565, 303212.3620380503707565 222576.3191453621548135, 303217.2464131281594746 222578.0561662522668485, 303222.2142427377984859 222579.5377297651721165, 303227.2521761544630863 222580.7598542935156729, 303232.3466742536984384 222581.7192554557113908, 340240.9466742626973428 228562.4192554587207269, 340241.6451431164168753 228562.5295974992914125, 371903.0451431074179709 233449.6295974932727404, 371903.3732348520425148 233449.6796828560472932, 373488.5732348550227471 233688.9796828530670609, 373492.4870663167093880 233689.4917264690448064, 373528.5870663106907159 233693.4917264690448064, 373535.2659228414413519 233694.0060347228136379, 373625.1659228474600241 233697.9060347288032062, 373625.1659228474600241 233697.9060347288323101, 373630.2873771191225387 233697.9969001383287832, 373642.9873771221027710 233697.8969001443183515, 373648.2118495866889134 233697.7191247496230062, 373653.4198936402681284 233697.2685764613561332, 373658.5972774084657431 233696.5464864801033400, 373663.7298528013634495 233695.5548280406510457, 373668.8035941756097600 233694.2963110199489165, 373673.8046366619528271 233692.7743745317566209, 373678.7193140533054247 233690.9931775288132485, 373683.5341961499652825 233688.9575874376751017, 373688.2361254601855762 233686.6731668577413075, 373692.8122531549306586 233684.1461583603522740, 373697.2500741796684451 233681.3834674300451297, 373701.5374614266911522 233678.3926435940084048, 373705.6626988743664697 233675.1818597918318119, 373709.6145136032719165 233671.7598900413722731, 373713.3821066011441872 233668.1360854624363128, 373716.9551822734647430 233664.3203487230930477, 373720.3239765776088461 233660.3231069790199399, 373723.4792837048298679 233656.1552833794266917, 373726.4124812366790138 233651.8282672177592758, 373729.1155537074664608 233647.3538828085002024, 373731.5811145076295361 233642.7443571751064155, 373733.8024260689853691 233638.0122866376477759, 373735.7734182764543220 233633.1706023911829107, 373737.4887050554389134 233628.2325351690815296, 373738.9435990903875791 233623.2115790876850951, 373740.1341246336232871 233618.1214547714043874, 373741.0570283696870320 233612.9760718587203883, 373741.7097883056849241 233607.7894909917085897, 373742.0906206630170345 233602.5758853929000907, 373742.1984847519779578 233597.3495021346316207, 373742.0330858153756708 233592.1246232062694617, 373741.5948758341837674 233586.9155264864384662, 373740.8850522924331017 233581.7364467261068057, 373739.9055549047770910 233576.6015366498031653, 373738.6590603159856983 233571.5248282807588112, 373737.1489747864543460 233566.5201945960870944, 373735.3794248842168599 233561.6013116164249368, 373733.3552462080260739 233556.7816210339078680, 373654.0552462110645138 233380.9816210219287314, 373652.5153630711138248 233377.7256075733166654, 365392.9153630621149205 216697.2256075733166654, 365391.9598568481160328 216695.3460295358672738, 365331.8598568540764973 216580.1460295478464104, 365330.2477527938899584 216577.1791839415382128, 339880.6477527848910540 171569.1791839415382128, 339878.8843201125273481 171566.1832905930059496, 338824.6843201245646924 169844.3832905810268130, 338822.4769281532499008 169840.9383075150544755, 338820.1304613530519418 169837.5865048365958501, 338807.6304613530519418 169820.4865048425854184, 338807.5334730069153011 169820.3540531243779697, 337870.8334730038768612 168543.3540531243779697, 337867.0221279650577344 168538.4815600363945123, 337833.5221279650577344 168498.2815600333851762, 337830.6202818806632422 168494.9517117698851507, 337827.5742276740493253 168491.7532505890121683, 337824.3899077704991214 168488.6924162408104166, 337753.4899077645386569 168423.4924162378301844, 337751.3185027677100152 168421.5531549594015814, 337717.4185027767089196 168392.1531549684004858, 337714.5758644837187603 168389.7786549685988575, 337663.9758644747198559 168349.0786549655895215, 337659.8087246867362410 168345.9029646954732016, 337655.4809780826326460 168342.9498862957989331, 337651.0045043539139442 168340.2275259852758609, 337646.3915914490935393 168337.7433566600084305, 337530.7915914550540037 168279.3433566540188622, 337526.2029832758707926 168277.1696530297922436, 337521.5099571402533911 168275.2316596969612874, 337516.7246118161710910 168273.5343728628649842, 335388.0246118131908588 167578.8343728748441208, 335386.2942020931513980 167578.2869793250865769, 335315.7942020931513980 167556.6869793160876725, 335310.1989645521389320 167555.1487824073119555, 335304.5239261208334938 167553.9377201983297709, 335215.0239261208334938 167537.5377202073286753))
+Intersection: POLYGON ((335197.0000000000000000 167635.9000000059895683, 329292.5000000000000000 168040.7000000030093361, 326778.0000000000000000 168869.2999999969906639, 326730.0999999939813279 168889.2999999969906639, 326658.5999999939813279 168919.5000000000000000, 326536.9000000060186721 168988.2999999969906639, 326477.0000000000000000 169031.4000000059895683, 314768.0999999939813279 178085.5000000000000000, 314320.4000000060186721 178991.5999999940104317, 303956.7999999970197678 219045.0999999940104317, 303407.7999999970197678 221300.4000000059895683, 303377.5999999939813279 221436.5999999940104317, 303342.2000000029802322 221596.7999999969906639, 303305.9000000060186721 221775.5000000000000000, 303273.7999999970197678 222024.9000000059895683, 303247.5000000000000000 222320.7999999969906639, 303245.7999999970197678 222443.0999999940104317, 303248.2999999970197678 222483.0000000000000000, 340256.9000000060186721 228463.7000000030093361, 371918.2999999970197678 233350.7999999969906639, 373503.5000000000000000 233590.0999999940104317, 373539.5999999939813279 233594.0999999940104317, 373629.5000000000000000 233598.0000000000000000, 373642.2000000029802322 233597.9000000059895683, 373562.9000000060186721 233422.0999999940104317, 365303.2999999970197678 216741.5999999940104317, 365243.2000000029802322 216626.4000000059895683, 339793.5999999939813279 171618.4000000059895683, 338739.4000000060186721 169896.5999999940104317, 338726.9000000060186721 169879.5000000000000000, 337790.2000000029802322 168602.5000000000000000, 337756.7000000029802322 168562.2999999969906639, 337685.7999999970197678 168497.0999999940104317, 337651.9000000060186721 168467.7000000030093361, 337601.2999999970197678 168427.0000000000000000, 337485.7000000029802322 168368.5999999940104317, 335357.0000000000000000 167673.9000000059895683, 335286.5000000000000000 167652.2999999969906639, 335197.0000000000000000 167635.9000000059895683))
+Difference: POLYGON ((335215.0239261208334938 167537.5377202073286753, 335210.0916716848732904 167536.7606630478694569, 335205.1267784655792639 167536.2307696900388692, 335200.1416244141873904 167535.9493612084188499, 335195.1486379941343330 167535.9171391811396461, 335190.1602671957225539 167536.1341839407396037, 329285.6602671957225539 167940.9341839377593715, 329280.6851495988667011 167941.4004062979074661, 329275.7395326890982687 167942.1145713863952551, 329270.8357652556151152 167943.0748959931370337, 329265.9860915930476040 167944.2789822683553211, 329261.2026209282921627 167945.7238237099954858, 326746.7026209282921627 168774.3238237039768137, 326739.4700757855316624 168777.0208314917108510, 326691.5700757795129903 168797.0208314917108510, 326691.1906471042311750 168797.1801744560070802, 326619.6906471042311750 168827.3801744590164162, 326614.4661321343737654 168829.7659389766049571, 326609.3872034477535635 168832.4477130909217522, 326487.6872034597909078 168901.2477130879124161, 326483.0105803586193360 168904.0626540626399219, 326478.4945191467413679 168907.1285776514559984, 326418.5945191407226957 168950.2285776604549028, 326415.8285449087852612 168952.2921427348919678, 314706.9285449027665891 178006.3921427289023995, 314703.0203897153842263 178009.5747451371571515, 314699.2775538869318552 178012.9502176995156333, 314695.7095452067442238 178016.5099858262110502, 314692.3254273570491932 178020.2450067681784276, 314689.1337968888110481 178024.1457925880094990, 314686.1427613845444284 178028.2024342618533410, 314683.3599188625812531 178032.4046268509118818, 314680.7923384761670604 178036.7416956787055824, 314678.4465425560483709 178041.2026234475779347, 314230.7465425680857152 178947.3026234415883664, 314228.5878578424453735 178951.9700800933642313, 314226.6719709816970862 178956.7423383510031272, 314225.0039485624292865 178961.6067779435543343, 314223.5882016817340627 178966.5505348258011509, 303859.9882016727351584 219020.0505348258011509, 303859.6373324339510873 219021.4480226553569082, 303310.6373324339510873 221276.7480226673360448, 303310.1711850037681870 221278.7524947684432846, 303279.9711850007297471 221414.9524947564641479, 303279.9555483013973571 221415.0231361427286174, 303244.5555483103962615 221575.2231361457088497, 303244.2014352029073052 221576.8931846534833312, 303207.9014352059457451 221755.5931846564926673, 303206.7181479214923456 221762.7344127797405235, 303174.6181479124934413 222012.1344127857300919, 303174.1926699578762054 222016.0467631698702462, 303147.8926699608564377 222311.9467631608713418, 303147.5096594412461855 222319.4101097332895733, 303145.8096594382659532 222441.7101097303093411, 303145.9957166555686854 222449.3534012049494777, 303148.4957166555686854 222489.2534012109390460, 303148.9538959227502346 222494.4171627500036266, 303149.6790615010540932 222499.5502413932117634, 303150.6692645543371327 222504.6388423194293864, 303151.9218439752003178 222509.6692902386421338, 303153.4334335363237187 222514.6280661432247143, 303155.1999709373340011 222519.5018436395912431, 303157.2167087217676453 222524.2775247619138099, 303159.4782270356081426 222528.9422751721285749, 303161.9784481927636079 222533.4835586513218004, 303164.7106530084856786 222537.8891707901784685, 303167.6674988568993285 222542.1472717873693909, 303170.8410394035163336 222546.2464182683033869, 303174.2227459607529454 222550.1755940386210568, 303177.8035304081276990 222553.9242396893096156, 303181.5737696161959320 222557.4822809745091945, 303185.5233313077478670 222560.8401558854966424, 303189.6416012879926711 222563.9888403478544205, 303193.9175119692226872 222566.9198724731104448, 303198.3395721145207062 222569.6253752996271942, 303202.8958977197180502 222572.0980779612727929, 303207.5742439505993389 222574.3313352275581565, 303212.3620380503707565 222576.3191453621548135, 303217.2464131281594746 222578.0561662522668485, 303222.2142427377984859 222579.5377297651721165, 303227.2521761544630863 222580.7598542935156729, 303232.3466742536984384 222581.7192554557113908, 340240.9466742626973428 228562.4192554587207269, 340241.6451431164168753 228562.5295974992914125, 371903.0451431074179709 233449.6295974932727404, 371903.3732348520425148 233449.6796828560472932, 373488.5732348550227471 233688.9796828530670609, 373492.4870663167093880 233689.4917264690448064, 373528.5870663106907159 233693.4917264690448064, 373535.2659228414413519 233694.0060347228136379, 373625.1659228474600241 233697.9060347288032062, 373625.1659228474600241 233697.9060347288323101, 373630.2873771191225387 233697.9969001383287832, 373642.9873771221027710 233697.8969001443183515, 373648.2118495866889134 233697.7191247496230062, 373653.4198936402681284 233697.2685764613561332, 373658.5972774084657431 233696.5464864801033400, 373663.7298528013634495 233695.5548280406510457, 373668.8035941756097600 233694.2963110199489165, 373673.8046366619528271 233692.7743745317566209, 373678.7193140533054247 233690.9931775288132485, 373683.5341961499652825 233688.9575874376751017, 373688.2361254601855762 233686.6731668577413075, 373692.8122531549306586 233684.1461583603522740, 373697.2500741796684451 233681.3834674300451297, 373701.5374614266911522 233678.3926435940084048, 373705.6626988743664697 233675.1818597918318119, 373709.6145136032719165 233671.7598900413722731, 373713.3821066011441872 233668.1360854624363128, 373716.9551822734647430 233664.3203487230930477, 373720.3239765776088461 233660.3231069790199399, 373723.4792837048298679 233656.1552833794266917, 373726.4124812366790138 233651.8282672177592758, 373729.1155537074664608 233647.3538828085002024, 373731.5811145076295361 233642.7443571751064155, 373733.8024260689853691 233638.0122866376477759, 373735.7734182764543220 233633.1706023911829107, 373737.4887050554389134 233628.2325351690815296, 373738.9435990903875791 233623.2115790876850951, 373740.1341246336232871 233618.1214547714043874, 373741.0570283696870320 233612.9760718587203883, 373741.7097883056849241 233607.7894909917085897, 373742.0906206630170345 233602.5758853929000907, 373742.1984847519779578 233597.3495021346316207, 373742.0330858153756708 233592.1246232062694617, 373741.5948758341837674 233586.9155264864384662, 373740.8850522924331017 233581.7364467261068057, 373739.9055549047770910 233576.6015366498031653, 373738.6590603159856983 233571.5248282807588112, 373737.1489747864543460 233566.5201945960870944, 373735.3794248842168599 233561.6013116164249368, 373733.3552462080260739 233556.7816210339078680, 373654.0552462110645138 233380.9816210219287314, 373652.5153630711138248 233377.7256075733166654, 365392.9153630621149205 216697.2256075733166654, 365391.9598568481160328 216695.3460295358672738, 365331.8598568540764973 216580.1460295478464104, 365330.2477527938899584 216577.1791839415382128, 339880.6477527848910540 171569.1791839415382128, 339878.8843201125273481 171566.1832905930059496, 338824.6843201245646924 169844.3832905810268130, 338822.4769281532499008 169840.9383075150544755, 338820.1304613530519418 169837.5865048365958501, 338807.6304613530519418 169820.4865048425854184, 338807.5334730069153011 169820.3540531243779697, 337870.8334730038768612 168543.3540531243779697, 337867.0221279650577344 168538.4815600363945123, 337833.5221279650577344 168498.2815600333851762, 337830.6202818806632422 168494.9517117698851507, 337827.5742276740493253 168491.7532505890121683, 337824.3899077704991214 168488.6924162408104166, 337753.4899077645386569 168423.4924162378301844, 337751.3185027677100152 168421.5531549594015814, 337717.4185027767089196 168392.1531549684004858, 337714.5758644837187603 168389.7786549685988575, 337663.9758644747198559 168349.0786549655895215, 337659.8087246867362410 168345.9029646954732016, 337655.4809780826326460 168342.9498862957989331, 337651.0045043539139442 168340.2275259852758609, 337646.3915914490935393 168337.7433566600084305, 337530.7915914550540037 168279.3433566540188622, 337526.2029832758707926 168277.1696530297922436, 337521.5099571402533911 168275.2316596969612874, 337516.7246118161710910 168273.5343728628649842, 335388.0246118131908588 167578.8343728748441208, 335386.2942020931513980 167578.2869793250865769, 335315.7942020931513980 167556.6869793160876725, 335310.1989645521389320 167555.1487824073119555, 335304.5239261208334938 167553.9377201983297709, 335215.0239261208334938 167537.5377202073286753), (335197.0000000000000000 167635.9000000059895683, 335286.5000000000000000 167652.2999999969906639, 335357.0000000000000000 167673.9000000059895683, 337485.7000000029802322 168368.5999999940104317, 337601.2999999970197678 168427.0000000000000000, 337651.9000000060186721 168467.7000000030093361, 337685.7999999970197678 168497.0999999940104317, 337756.7000000029802322 168562.2999999969906639, 337790.2000000029802322 168602.5000000000000000, 338726.9000000060186721 169879.5000000000000000, 338739.4000000060186721 169896.5999999940104317, 339793.5999999939813279 171618.4000000059895683, 365243.2000000029802322 216626.4000000059895683, 365303.2999999970197678 216741.5999999940104317, 373562.9000000060186721 233422.0999999940104317, 373642.2000000029802322 233597.9000000059895683, 373629.5000000000000000 233598.0000000000000000, 373539.5999999939813279 233594.0999999940104317, 373503.5000000000000000 233590.0999999940104317, 371918.2999999970197678 233350.7999999969906639, 340256.9000000060186721 228463.7000000030093361, 303248.2999999970197678 222483.0000000000000000, 303245.7999999970197678 222443.0999999940104317, 303247.5000000000000000 222320.7999999969906639, 303273.7999999970197678 222024.9000000059895683, 303305.9000000060186721 221775.5000000000000000, 303342.2000000029802322 221596.7999999969906639, 303377.5999999939813279 221436.5999999940104317, 303407.7999999970197678 221300.4000000059895683, 303956.7999999970197678 219045.0999999940104317, 314320.4000000060186721 178991.5999999940104317, 314768.0999999939813279 178085.5000000000000000, 326477.0000000000000000 169031.4000000059895683, 326536.9000000060186721 168988.2999999969906639, 326658.5999999939813279 168919.5000000000000000, 326730.0999999939813279 168889.2999999969906639, 326778.0000000000000000 168869.2999999969906639, 329292.5000000000000000 168040.7000000030093361, 335197.0000000000000000 167635.9000000059895683))
+SymDifference: POLYGON ((335215.0239261208334938 167537.5377202073286753, 335210.0916716848732904 167536.7606630478694569, 335205.1267784655792639 167536.2307696900388692, 335200.1416244141873904 167535.9493612084188499, 335195.1486379941343330 167535.9171391811396461, 335190.1602671957225539 167536.1341839407396037, 329285.6602671957225539 167940.9341839377593715, 329280.6851495988667011 167941.4004062979074661, 329275.7395326890982687 167942.1145713863952551, 329270.8357652556151152 167943.0748959931370337, 329265.9860915930476040 167944.2789822683553211, 329261.2026209282921627 167945.7238237099954858, 326746.7026209282921627 168774.3238237039768137, 326739.4700757855316624 168777.0208314917108510, 326691.5700757795129903 168797.0208314917108510, 326691.1906471042311750 168797.1801744560070802, 326619.6906471042311750 168827.3801744590164162, 326614.4661321343737654 168829.7659389766049571, 326609.3872034477535635 168832.4477130909217522, 326487.6872034597909078 168901.2477130879124161, 326483.0105803586193360 168904.0626540626399219, 326478.4945191467413679 168907.1285776514559984, 326418.5945191407226957 168950.2285776604549028, 326415.8285449087852612 168952.2921427348919678, 314706.9285449027665891 178006.3921427289023995, 314703.0203897153842263 178009.5747451371571515, 314699.2775538869318552 178012.9502176995156333, 314695.7095452067442238 178016.5099858262110502, 314692.3254273570491932 178020.2450067681784276, 314689.1337968888110481 178024.1457925880094990, 314686.1427613845444284 178028.2024342618533410, 314683.3599188625812531 178032.4046268509118818, 314680.7923384761670604 178036.7416956787055824, 314678.4465425560483709 178041.2026234475779347, 314230.7465425680857152 178947.3026234415883664, 314228.5878578424453735 178951.9700800933642313, 314226.6719709816970862 178956.7423383510031272, 314225.0039485624292865 178961.6067779435543343, 314223.5882016817340627 178966.5505348258011509, 303859.9882016727351584 219020.0505348258011509, 303859.6373324339510873 219021.4480226553569082, 303310.6373324339510873 221276.7480226673360448, 303310.1711850037681870 221278.7524947684432846, 303279.9711850007297471 221414.9524947564641479, 303279.9555483013973571 221415.0231361427286174, 303244.5555483103962615 221575.2231361457088497, 303244.2014352029073052 221576.8931846534833312, 303207.9014352059457451 221755.5931846564926673, 303206.7181479214923456 221762.7344127797405235, 303174.6181479124934413 222012.1344127857300919, 303174.1926699578762054 222016.0467631698702462, 303147.8926699608564377 222311.9467631608713418, 303147.5096594412461855 222319.4101097332895733, 303145.8096594382659532 222441.7101097303093411, 303145.9957166555686854 222449.3534012049494777, 303148.4957166555686854 222489.2534012109390460, 303148.9538959227502346 222494.4171627500036266, 303149.6790615010540932 222499.5502413932117634, 303150.6692645543371327 222504.6388423194293864, 303151.9218439752003178 222509.6692902386421338, 303153.4334335363237187 222514.6280661432247143, 303155.1999709373340011 222519.5018436395912431, 303157.2167087217676453 222524.2775247619138099, 303159.4782270356081426 222528.9422751721285749, 303161.9784481927636079 222533.4835586513218004, 303164.7106530084856786 222537.8891707901784685, 303167.6674988568993285 222542.1472717873693909, 303170.8410394035163336 222546.2464182683033869, 303174.2227459607529454 222550.1755940386210568, 303177.8035304081276990 222553.9242396893096156, 303181.5737696161959320 222557.4822809745091945, 303185.5233313077478670 222560.8401558854966424, 303189.6416012879926711 222563.9888403478544205, 303193.9175119692226872 222566.9198724731104448, 303198.3395721145207062 222569.6253752996271942, 303202.8958977197180502 222572.0980779612727929, 303207.5742439505993389 222574.3313352275581565, 303212.3620380503707565 222576.3191453621548135, 303217.2464131281594746 222578.0561662522668485, 303222.2142427377984859 222579.5377297651721165, 303227.2521761544630863 222580.7598542935156729, 303232.3466742536984384 222581.7192554557113908, 340240.9466742626973428 228562.4192554587207269, 340241.6451431164168753 228562.5295974992914125, 371903.0451431074179709 233449.6295974932727404, 371903.3732348520425148 233449.6796828560472932, 373488.5732348550227471 233688.9796828530670609, 373492.4870663167093880 233689.4917264690448064, 373528.5870663106907159 233693.4917264690448064, 373535.2659228414413519 233694.0060347228136379, 373625.1659228474600241 233697.9060347288032062, 373625.1659228474600241 233697.9060347288323101, 373630.2873771191225387 233697.9969001383287832, 373642.9873771221027710 233697.8969001443183515, 373648.2118495866889134 233697.7191247496230062, 373653.4198936402681284 233697.2685764613561332, 373658.5972774084657431 233696.5464864801033400, 373663.7298528013634495 233695.5548280406510457, 373668.8035941756097600 233694.2963110199489165, 373673.8046366619528271 233692.7743745317566209, 373678.7193140533054247 233690.9931775288132485, 373683.5341961499652825 233688.9575874376751017, 373688.2361254601855762 233686.6731668577413075, 373692.8122531549306586 233684.1461583603522740, 373697.2500741796684451 233681.3834674300451297, 373701.5374614266911522 233678.3926435940084048, 373705.6626988743664697 233675.1818597918318119, 373709.6145136032719165 233671.7598900413722731, 373713.3821066011441872 233668.1360854624363128, 373716.9551822734647430 233664.3203487230930477, 373720.3239765776088461 233660.3231069790199399, 373723.4792837048298679 233656.1552833794266917, 373726.4124812366790138 233651.8282672177592758, 373729.1155537074664608 233647.3538828085002024, 373731.5811145076295361 233642.7443571751064155, 373733.8024260689853691 233638.0122866376477759, 373735.7734182764543220 233633.1706023911829107, 373737.4887050554389134 233628.2325351690815296, 373738.9435990903875791 233623.2115790876850951, 373740.1341246336232871 233618.1214547714043874, 373741.0570283696870320 233612.9760718587203883, 373741.7097883056849241 233607.7894909917085897, 373742.0906206630170345 233602.5758853929000907, 373742.1984847519779578 233597.3495021346316207, 373742.0330858153756708 233592.1246232062694617, 373741.5948758341837674 233586.9155264864384662, 373740.8850522924331017 233581.7364467261068057, 373739.9055549047770910 233576.6015366498031653, 373738.6590603159856983 233571.5248282807588112, 373737.1489747864543460 233566.5201945960870944, 373735.3794248842168599 233561.6013116164249368, 373733.3552462080260739 233556.7816210339078680, 373654.0552462110645138 233380.9816210219287314, 373652.5153630711138248 233377.7256075733166654, 365392.9153630621149205 216697.2256075733166654, 365391.9598568481160328 216695.3460295358672738, 365331.8598568540764973 216580.1460295478464104, 365330.2477527938899584 216577.1791839415382128, 339880.6477527848910540 171569.1791839415382128, 339878.8843201125273481 171566.1832905930059496, 338824.6843201245646924 169844.3832905810268130, 338822.4769281532499008 169840.9383075150544755, 338820.1304613530519418 169837.5865048365958501, 338807.6304613530519418 169820.4865048425854184, 338807.5334730069153011 169820.3540531243779697, 337870.8334730038768612 168543.3540531243779697, 337867.0221279650577344 168538.4815600363945123, 337833.5221279650577344 168498.2815600333851762, 337830.6202818806632422 168494.9517117698851507, 337827.5742276740493253 168491.7532505890121683, 337824.3899077704991214 168488.6924162408104166, 337753.4899077645386569 168423.4924162378301844, 337751.3185027677100152 168421.5531549594015814, 337717.4185027767089196 168392.1531549684004858, 337714.5758644837187603 168389.7786549685988575, 337663.9758644747198559 168349.0786549655895215, 337659.8087246867362410 168345.9029646954732016, 337655.4809780826326460 168342.9498862957989331, 337651.0045043539139442 168340.2275259852758609, 337646.3915914490935393 168337.7433566600084305, 337530.7915914550540037 168279.3433566540188622, 337526.2029832758707926 168277.1696530297922436, 337521.5099571402533911 168275.2316596969612874, 337516.7246118161710910 168273.5343728628649842, 335388.0246118131908588 167578.8343728748441208, 335386.2942020931513980 167578.2869793250865769, 335315.7942020931513980 167556.6869793160876725, 335310.1989645521389320 167555.1487824073119555, 335304.5239261208334938 167553.9377201983297709, 335215.0239261208334938 167537.5377202073286753), (335197.0000000000000000 167635.9000000059895683, 335286.5000000000000000 167652.2999999969906639, 335357.0000000000000000 167673.9000000059895683, 337485.7000000029802322 168368.5999999940104317, 337601.2999999970197678 168427.0000000000000000, 337651.9000000060186721 168467.7000000030093361, 337685.7999999970197678 168497.0999999940104317, 337756.7000000029802322 168562.2999999969906639, 337790.2000000029802322 168602.5000000000000000, 338726.9000000060186721 169879.5000000000000000, 338739.4000000060186721 169896.5999999940104317, 339793.5999999939813279 171618.4000000059895683, 365243.2000000029802322 216626.4000000059895683, 365303.2999999970197678 216741.5999999940104317, 373562.9000000060186721 233422.0999999940104317, 373642.2000000029802322 233597.9000000059895683, 373629.5000000000000000 233598.0000000000000000, 373539.5999999939813279 233594.0999999940104317, 373503.5000000000000000 233590.0999999940104317, 371918.2999999970197678 233350.7999999969906639, 340256.9000000060186721 228463.7000000030093361, 303248.2999999970197678 222483.0000000000000000, 303245.7999999970197678 222443.0999999940104317, 303247.5000000000000000 222320.7999999969906639, 303273.7999999970197678 222024.9000000059895683, 303305.9000000060186721 221775.5000000000000000, 303342.2000000029802322 221596.7999999969906639, 303377.5999999939813279 221436.5999999940104317, 303407.7999999970197678 221300.4000000059895683, 303956.7999999970197678 219045.0999999940104317, 314320.4000000060186721 178991.5999999940104317, 314768.0999999939813279 178085.5000000000000000, 326477.0000000000000000 169031.4000000059895683, 326536.9000000060186721 168988.2999999969906639, 326658.5999999939813279 168919.5000000000000000, 326730.0999999939813279 168889.2999999969906639, 326778.0000000000000000 168869.2999999969906639, 329292.5000000000000000 168040.7000000030093361, 335197.0000000000000000 167635.9000000059895683))
+Boundary: MULTILINESTRING ((335215.0239261208334938 167537.5377202073286753, 335210.0916716848732904 167536.7606630478694569, 335205.1267784655792639 167536.2307696900388692, 335200.1416244141873904 167535.9493612084188499, 335195.1486379941343330 167535.9171391811396461, 335190.1602671957225539 167536.1341839407396037, 329285.6602671957225539 167940.9341839377593715, 329280.6851495988667011 167941.4004062979074661, 329275.7395326890982687 167942.1145713863952551, 329270.8357652556151152 167943.0748959931370337, 329265.9860915930476040 167944.2789822683553211, 329261.2026209282921627 167945.7238237099954858, 326746.7026209282921627 168774.3238237039768137, 326739.4700757855316624 168777.0208314917108510, 326691.5700757795129903 168797.0208314917108510, 326691.1906471042311750 168797.1801744560070802, 326619.6906471042311750 168827.3801744590164162, 326614.4661321343737654 168829.7659389766049571, 326609.3872034477535635 168832.4477130909217522, 326487.6872034597909078 168901.2477130879124161, 326483.0105803586193360 168904.0626540626399219, 326478.4945191467413679 168907.1285776514559984, 326418.5945191407226957 168950.2285776604549028, 326415.8285449087852612 168952.2921427348919678, 314706.9285449027665891 178006.3921427289023995, 314703.0203897153842263 178009.5747451371571515, 314699.2775538869318552 178012.9502176995156333, 314695.7095452067442238 178016.5099858262110502, 314692.3254273570491932 178020.2450067681784276, 314689.1337968888110481 178024.1457925880094990, 314686.1427613845444284 178028.2024342618533410, 314683.3599188625812531 178032.4046268509118818, 314680.7923384761670604 178036.7416956787055824, 314678.4465425560483709 178041.2026234475779347, 314230.7465425680857152 178947.3026234415883664, 314228.5878578424453735 178951.9700800933642313, 314226.6719709816970862 178956.7423383510031272, 314225.0039485624292865 178961.6067779435543343, 314223.5882016817340627 178966.5505348258011509, 303859.9882016727351584 219020.0505348258011509, 303859.6373324339510873 219021.4480226553569082, 303310.6373324339510873 221276.7480226673360448, 303310.1711850037681870 221278.7524947684432846, 303279.9711850007297471 221414.9524947564641479, 303279.9555483013973571 221415.0231361427286174, 303244.5555483103962615 221575.2231361457088497, 303244.2014352029073052 221576.8931846534833312, 303207.9014352059457451 221755.5931846564926673, 303206.7181479214923456 221762.7344127797405235, 303174.6181479124934413 222012.1344127857300919, 303174.1926699578762054 222016.0467631698702462, 303147.8926699608564377 222311.9467631608713418, 303147.5096594412461855 222319.4101097332895733, 303145.8096594382659532 222441.7101097303093411, 303145.9957166555686854 222449.3534012049494777, 303148.4957166555686854 222489.2534012109390460, 303148.9538959227502346 222494.4171627500036266, 303149.6790615010540932 222499.5502413932117634, 303150.6692645543371327 222504.6388423194293864, 303151.9218439752003178 222509.6692902386421338, 303153.4334335363237187 222514.6280661432247143, 303155.1999709373340011 222519.5018436395912431, 303157.2167087217676453 222524.2775247619138099, 303159.4782270356081426 222528.9422751721285749, 303161.9784481927636079 222533.4835586513218004, 303164.7106530084856786 222537.8891707901784685, 303167.6674988568993285 222542.1472717873693909, 303170.8410394035163336 222546.2464182683033869, 303174.2227459607529454 222550.1755940386210568, 303177.8035304081276990 222553.9242396893096156, 303181.5737696161959320 222557.4822809745091945, 303185.5233313077478670 222560.8401558854966424, 303189.6416012879926711 222563.9888403478544205, 303193.9175119692226872 222566.9198724731104448, 303198.3395721145207062 222569.6253752996271942, 303202.8958977197180502 222572.0980779612727929, 303207.5742439505993389 222574.3313352275581565, 303212.3620380503707565 222576.3191453621548135, 303217.2464131281594746 222578.0561662522668485, 303222.2142427377984859 222579.5377297651721165, 303227.2521761544630863 222580.7598542935156729, 303232.3466742536984384 222581.7192554557113908, 340240.9466742626973428 228562.4192554587207269, 340241.6451431164168753 228562.5295974992914125, 371903.0451431074179709 233449.6295974932727404, 371903.3732348520425148 233449.6796828560472932, 373488.5732348550227471 233688.9796828530670609, 373492.4870663167093880 233689.4917264690448064, 373528.5870663106907159 233693.4917264690448064, 373535.2659228414413519 233694.0060347228136379, 373625.1659228474600241 233697.9060347288032062, 373625.1659228474600241 233697.9060347288323101, 373630.2873771191225387 233697.9969001383287832, 373642.9873771221027710 233697.8969001443183515, 373648.2118495866889134 233697.7191247496230062, 373653.4198936402681284 233697.2685764613561332, 373658.5972774084657431 233696.5464864801033400, 373663.7298528013634495 233695.5548280406510457, 373668.8035941756097600 233694.2963110199489165, 373673.8046366619528271 233692.7743745317566209, 373678.7193140533054247 233690.9931775288132485, 373683.5341961499652825 233688.9575874376751017, 373688.2361254601855762 233686.6731668577413075, 373692.8122531549306586 233684.1461583603522740, 373697.2500741796684451 233681.3834674300451297, 373701.5374614266911522 233678.3926435940084048, 373705.6626988743664697 233675.1818597918318119, 373709.6145136032719165 233671.7598900413722731, 373713.3821066011441872 233668.1360854624363128, 373716.9551822734647430 233664.3203487230930477, 373720.3239765776088461 233660.3231069790199399, 373723.4792837048298679 233656.1552833794266917, 373726.4124812366790138 233651.8282672177592758, 373729.1155537074664608 233647.3538828085002024, 373731.5811145076295361 233642.7443571751064155, 373733.8024260689853691 233638.0122866376477759, 373735.7734182764543220 233633.1706023911829107, 373737.4887050554389134 233628.2325351690815296, 373738.9435990903875791 233623.2115790876850951, 373740.1341246336232871 233618.1214547714043874, 373741.0570283696870320 233612.9760718587203883, 373741.7097883056849241 233607.7894909917085897, 373742.0906206630170345 233602.5758853929000907, 373742.1984847519779578 233597.3495021346316207, 373742.0330858153756708 233592.1246232062694617, 373741.5948758341837674 233586.9155264864384662, 373740.8850522924331017 233581.7364467261068057, 373739.9055549047770910 233576.6015366498031653, 373738.6590603159856983 233571.5248282807588112, 373737.1489747864543460 233566.5201945960870944, 373735.3794248842168599 233561.6013116164249368, 373733.3552462080260739 233556.7816210339078680, 373654.0552462110645138 233380.9816210219287314, 373652.5153630711138248 233377.7256075733166654, 365392.9153630621149205 216697.2256075733166654, 365391.9598568481160328 216695.3460295358672738, 365331.8598568540764973 216580.1460295478464104, 365330.2477527938899584 216577.1791839415382128, 339880.6477527848910540 171569.1791839415382128, 339878.8843201125273481 171566.1832905930059496, 338824.6843201245646924 169844.3832905810268130, 338822.4769281532499008 169840.9383075150544755, 338820.1304613530519418 169837.5865048365958501, 338807.6304613530519418 169820.4865048425854184, 338807.5334730069153011 169820.3540531243779697, 337870.8334730038768612 168543.3540531243779697, 337867.0221279650577344 168538.4815600363945123, 337833.5221279650577344 168498.2815600333851762, 337830.6202818806632422 168494.9517117698851507, 337827.5742276740493253 168491.7532505890121683, 337824.3899077704991214 168488.6924162408104166, 337753.4899077645386569 168423.4924162378301844, 337751.3185027677100152 168421.5531549594015814, 337717.4185027767089196 168392.1531549684004858, 337714.5758644837187603 168389.7786549685988575, 337663.9758644747198559 168349.0786549655895215, 337659.8087246867362410 168345.9029646954732016, 337655.4809780826326460 168342.9498862957989331, 337651.0045043539139442 168340.2275259852758609, 337646.3915914490935393 168337.7433566600084305, 337530.7915914550540037 168279.3433566540188622, 337526.2029832758707926 168277.1696530297922436, 337521.5099571402533911 168275.2316596969612874, 337516.7246118161710910 168273.5343728628649842, 335388.0246118131908588 167578.8343728748441208, 335386.2942020931513980 167578.2869793250865769, 335315.7942020931513980 167556.6869793160876725, 335310.1989645521389320 167555.1487824073119555, 335304.5239261208334938 167553.9377201983297709, 335215.0239261208334938 167537.5377202073286753), (335197.0000000000000000 167635.9000000059895683, 335286.5000000000000000 167652.2999999969906639, 335357.0000000000000000 167673.9000000059895683, 337485.7000000029802322 168368.5999999940104317, 337601.2999999970197678 168427.0000000000000000, 337651.9000000060186721 168467.7000000030093361, 337685.7999999970197678 168497.0999999940104317, 337756.7000000029802322 168562.2999999969906639, 337790.2000000029802322 168602.5000000000000000, 338726.9000000060186721 169879.5000000000000000, 338739.4000000060186721 169896.5999999940104317, 339793.5999999939813279 171618.4000000059895683, 365243.2000000029802322 216626.4000000059895683, 365303.2999999970197678 216741.5999999940104317, 373562.9000000060186721 233422.0999999940104317, 373642.2000000029802322 233597.9000000059895683, 373629.5000000000000000 233598.0000000000000000, 373539.5999999939813279 233594.0999999940104317, 373503.5000000000000000 233590.0999999940104317, 371918.2999999970197678 233350.7999999969906639, 340256.9000000060186721 228463.7000000030093361, 303248.2999999970197678 222483.0000000000000000, 303245.7999999970197678 222443.0999999940104317, 303247.5000000000000000 222320.7999999969906639, 303273.7999999970197678 222024.9000000059895683, 303305.9000000060186721 221775.5000000000000000, 303342.2000000029802322 221596.7999999969906639, 303377.5999999939813279 221436.5999999940104317, 303407.7999999970197678 221300.4000000059895683, 303956.7999999970197678 219045.0999999940104317, 314320.4000000060186721 178991.5999999940104317, 314768.0999999939813279 178085.5000000000000000, 326477.0000000000000000 169031.4000000059895683, 326536.9000000060186721 168988.2999999969906639, 326658.5999999939813279 168919.5000000000000000, 326730.0999999939813279 168889.2999999969906639, 326778.0000000000000000 168869.2999999969906639, 329292.5000000000000000 168040.7000000030093361, 335197.0000000000000000 167635.9000000059895683))
+Union: POLYGON ((335215.0239261208334938 167537.5377202073286753, 335210.0916716848732904 167536.7606630478694569, 335205.1267784655792639 167536.2307696900388692, 335200.1416244141873904 167535.9493612084188499, 335195.1486379941343330 167535.9171391811396461, 335190.1602671957225539 167536.1341839407396037, 329285.6602671957225539 167940.9341839377593715, 329280.6851495988667011 167941.4004062979074661, 329275.7395326890982687 167942.1145713863952551, 329270.8357652556151152 167943.0748959931370337, 329265.9860915930476040 167944.2789822683553211, 329261.2026209282921627 167945.7238237099954858, 326746.7026209282921627 168774.3238237039768137, 326739.4700757855316624 168777.0208314917108510, 326691.5700757795129903 168797.0208314917108510, 326691.1906471042311750 168797.1801744560070802, 326619.6906471042311750 168827.3801744590164162, 326614.4661321343737654 168829.7659389766049571, 326609.3872034477535635 168832.4477130909217522, 326487.6872034597909078 168901.2477130879124161, 326483.0105803586193360 168904.0626540626399219, 326478.4945191467413679 168907.1285776514559984, 326418.5945191407226957 168950.2285776604549028, 326415.8285449087852612 168952.2921427348919678, 314706.9285449027665891 178006.3921427289023995, 314703.0203897153842263 178009.5747451371571515, 314699.2775538869318552 178012.9502176995156333, 314695.7095452067442238 178016.5099858262110502, 314692.3254273570491932 178020.2450067681784276, 314689.1337968888110481 178024.1457925880094990, 314686.1427613845444284 178028.2024342618533410, 314683.3599188625812531 178032.4046268509118818, 314680.7923384761670604 178036.7416956787055824, 314678.4465425560483709 178041.2026234475779347, 314230.7465425680857152 178947.3026234415883664, 314228.5878578424453735 178951.9700800933642313, 314226.6719709816970862 178956.7423383510031272, 314225.0039485624292865 178961.6067779435543343, 314223.5882016817340627 178966.5505348258011509, 303859.9882016727351584 219020.0505348258011509, 303859.6373324339510873 219021.4480226553569082, 303310.6373324339510873 221276.7480226673360448, 303310.1711850037681870 221278.7524947684432846, 303279.9711850007297471 221414.9524947564641479, 303279.9555483013973571 221415.0231361427286174, 303244.5555483103962615 221575.2231361457088497, 303244.2014352029073052 221576.8931846534833312, 303207.9014352059457451 221755.5931846564926673, 303206.7181479214923456 221762.7344127797405235, 303174.6181479124934413 222012.1344127857300919, 303174.1926699578762054 222016.0467631698702462, 303147.8926699608564377 222311.9467631608713418, 303147.5096594412461855 222319.4101097332895733, 303145.8096594382659532 222441.7101097303093411, 303145.9957166555686854 222449.3534012049494777, 303148.4957166555686854 222489.2534012109390460, 303148.9538959227502346 222494.4171627500036266, 303149.6790615010540932 222499.5502413932117634, 303150.6692645543371327 222504.6388423194293864, 303151.9218439752003178 222509.6692902386421338, 303153.4334335363237187 222514.6280661432247143, 303155.1999709373340011 222519.5018436395912431, 303157.2167087217676453 222524.2775247619138099, 303159.4782270356081426 222528.9422751721285749, 303161.9784481927636079 222533.4835586513218004, 303164.7106530084856786 222537.8891707901784685, 303167.6674988568993285 222542.1472717873693909, 303170.8410394035163336 222546.2464182683033869, 303174.2227459607529454 222550.1755940386210568, 303177.8035304081276990 222553.9242396893096156, 303181.5737696161959320 222557.4822809745091945, 303185.5233313077478670 222560.8401558854966424, 303189.6416012879926711 222563.9888403478544205, 303193.9175119692226872 222566.9198724731104448, 303198.3395721145207062 222569.6253752996271942, 303202.8958977197180502 222572.0980779612727929, 303207.5742439505993389 222574.3313352275581565, 303212.3620380503707565 222576.3191453621548135, 303217.2464131281594746 222578.0561662522668485, 303222.2142427377984859 222579.5377297651721165, 303227.2521761544630863 222580.7598542935156729, 303232.3466742536984384 222581.7192554557113908, 340240.9466742626973428 228562.4192554587207269, 340241.6451431164168753 228562.5295974992914125, 371903.0451431074179709 233449.6295974932727404, 371903.3732348520425148 233449.6796828560472932, 373488.5732348550227471 233688.9796828530670609, 373492.4870663167093880 233689.4917264690448064, 373528.5870663106907159 233693.4917264690448064, 373535.2659228414413519 233694.0060347228136379, 373625.1659228474600241 233697.9060347288032062, 373625.1659228474600241 233697.9060347288323101, 373630.2873771191225387 233697.9969001383287832, 373642.9873771221027710 233697.8969001443183515, 373648.2118495866889134 233697.7191247496230062, 373653.4198936402681284 233697.2685764613561332, 373658.5972774084657431 233696.5464864801033400, 373663.7298528013634495 233695.5548280406510457, 373668.8035941756097600 233694.2963110199489165, 373673.8046366619528271 233692.7743745317566209, 373678.7193140533054247 233690.9931775288132485, 373683.5341961499652825 233688.9575874376751017, 373688.2361254601855762 233686.6731668577413075, 373692.8122531549306586 233684.1461583603522740, 373697.2500741796684451 233681.3834674300451297, 373701.5374614266911522 233678.3926435940084048, 373705.6626988743664697 233675.1818597918318119, 373709.6145136032719165 233671.7598900413722731, 373713.3821066011441872 233668.1360854624363128, 373716.9551822734647430 233664.3203487230930477, 373720.3239765776088461 233660.3231069790199399, 373723.4792837048298679 233656.1552833794266917, 373726.4124812366790138 233651.8282672177592758, 373729.1155537074664608 233647.3538828085002024, 373731.5811145076295361 233642.7443571751064155, 373733.8024260689853691 233638.0122866376477759, 373735.7734182764543220 233633.1706023911829107, 373737.4887050554389134 233628.2325351690815296, 373738.9435990903875791 233623.2115790876850951, 373740.1341246336232871 233618.1214547714043874, 373741.0570283696870320 233612.9760718587203883, 373741.7097883056849241 233607.7894909917085897, 373742.0906206630170345 233602.5758853929000907, 373742.1984847519779578 233597.3495021346316207, 373742.0330858153756708 233592.1246232062694617, 373741.5948758341837674 233586.9155264864384662, 373740.8850522924331017 233581.7364467261068057, 373739.9055549047770910 233576.6015366498031653, 373738.6590603159856983 233571.5248282807588112, 373737.1489747864543460 233566.5201945960870944, 373735.3794248842168599 233561.6013116164249368, 373733.3552462080260739 233556.7816210339078680, 373654.0552462110645138 233380.9816210219287314, 373652.5153630711138248 233377.7256075733166654, 365392.9153630621149205 216697.2256075733166654, 365391.9598568481160328 216695.3460295358672738, 365331.8598568540764973 216580.1460295478464104, 365330.2477527938899584 216577.1791839415382128, 339880.6477527848910540 171569.1791839415382128, 339878.8843201125273481 171566.1832905930059496, 338824.6843201245646924 169844.3832905810268130, 338822.4769281532499008 169840.9383075150544755, 338820.1304613530519418 169837.5865048365958501, 338807.6304613530519418 169820.4865048425854184, 338807.5334730069153011 169820.3540531243779697, 337870.8334730038768612 168543.3540531243779697, 337867.0221279650577344 168538.4815600363945123, 337833.5221279650577344 168498.2815600333851762, 337830.6202818806632422 168494.9517117698851507, 337827.5742276740493253 168491.7532505890121683, 337824.3899077704991214 168488.6924162408104166, 337753.4899077645386569 168423.4924162378301844, 337751.3185027677100152 168421.5531549594015814, 337717.4185027767089196 168392.1531549684004858, 337714.5758644837187603 168389.7786549685988575, 337663.9758644747198559 168349.0786549655895215, 337659.8087246867362410 168345.9029646954732016, 337655.4809780826326460 168342.9498862957989331, 337651.0045043539139442 168340.2275259852758609, 337646.3915914490935393 168337.7433566600084305, 337530.7915914550540037 168279.3433566540188622, 337526.2029832758707926 168277.1696530297922436, 337521.5099571402533911 168275.2316596969612874, 337516.7246118161710910 168273.5343728628649842, 335388.0246118131908588 167578.8343728748441208, 335386.2942020931513980 167578.2869793250865769, 335315.7942020931513980 167556.6869793160876725, 335310.1989645521389320 167555.1487824073119555, 335304.5239261208334938 167553.9377201983297709, 335215.0239261208334938 167537.5377202073286753))
+PointOnSurface: POINT (332463.6393159376457334 200616.9570196597487666)
+Centroid: POINT (334794.0925891167717054 204179.0238832769100554)
+Relate: 212FF1FF2
+Polygonize: GEOMETRYCOLLECTION (POLYGON ((335215.0239261208334938 167537.5377202073286753, 335210.0916716848732904 167536.7606630478694569, 335205.1267784655792639 167536.2307696900388692, 335200.1416244141873904 167535.9493612084188499, 335195.1486379941343330 167535.9171391811396461, 335190.1602671957225539 167536.1341839407396037, 329285.6602671957225539 167940.9341839377593715, 329280.6851495988667011 167941.4004062979074661, 329275.7395326890982687 167942.1145713863952551, 329270.8357652556151152 167943.0748959931370337, 329265.9860915930476040 167944.2789822683553211, 329261.2026209282921627 167945.7238237099954858, 326746.7026209282921627 168774.3238237039768137, 326739.4700757855316624 168777.0208314917108510, 326691.5700757795129903 168797.0208314917108510, 326691.1906471042311750 168797.1801744560070802, 326619.6906471042311750 168827.3801744590164162, 326614.4661321343737654 168829.7659389766049571, 326609.3872034477535635 168832.4477130909217522, 326487.6872034597909078 168901.2477130879124161, 326483.0105803586193360 168904.0626540626399219, 326478.4945191467413679 168907.1285776514559984, 326418.5945191407226957 168950.2285776604549028, 326415.8285449087852612 168952.2921427348919678, 314706.9285449027665891 178006.3921427289023995, 314703.0203897153842263 178009.5747451371571515, 314699.2775538869318552 178012.9502176995156333, 314695.7095452067442238 178016.5099858262110502, 314692.3254273570491932 178020.2450067681784276, 314689.1337968888110481 178024.1457925880094990, 314686.1427613845444284 178028.2024342618533410, 314683.3599188625812531 178032.4046268509118818, 314680.7923384761670604 178036.7416956787055824, 314678.4465425560483709 178041.2026234475779347, 314230.7465425680857152 178947.3026234415883664, 314228.5878578424453735 178951.9700800933642313, 314226.6719709816970862 178956.7423383510031272, 314225.0039485624292865 178961.6067779435543343, 314223.5882016817340627 178966.5505348258011509, 303859.9882016727351584 219020.0505348258011509, 303859.6373324339510873 219021.4480226553569082, 303310.6373324339510873 221276.7480226673360448, 303310.1711850037681870 221278.7524947684432846, 303279.9711850007297471 221414.9524947564641479, 303279.9555483013973571 221415.0231361427286174, 303244.5555483103962615 221575.2231361457088497, 303244.2014352029073052 221576.8931846534833312, 303207.9014352059457451 221755.5931846564926673, 303206.7181479214923456 221762.7344127797405235, 303174.6181479124934413 222012.1344127857300919, 303174.1926699578762054 222016.0467631698702462, 303147.8926699608564377 222311.9467631608713418, 303147.5096594412461855 222319.4101097332895733, 303145.8096594382659532 222441.7101097303093411, 303145.9957166555686854 222449.3534012049494777, 303148.4957166555686854 222489.2534012109390460, 303148.9538959227502346 222494.4171627500036266, 303149.6790615010540932 222499.5502413932117634, 303150.6692645543371327 222504.6388423194293864, 303151.9218439752003178 222509.6692902386421338, 303153.4334335363237187 222514.6280661432247143, 303155.1999709373340011 222519.5018436395912431, 303157.2167087217676453 222524.2775247619138099, 303159.4782270356081426 222528.9422751721285749, 303161.9784481927636079 222533.4835586513218004, 303164.7106530084856786 222537.8891707901784685, 303167.6674988568993285 222542.1472717873693909, 303170.8410394035163336 222546.2464182683033869, 303174.2227459607529454 222550.1755940386210568, 303177.8035304081276990 222553.9242396893096156, 303181.5737696161959320 222557.4822809745091945, 303185.5233313077478670 222560.8401558854966424, 303189.6416012879926711 222563.9888403478544205, 303193.9175119692226872 222566.9198724731104448, 303198.3395721145207062 222569.6253752996271942, 303202.8958977197180502 222572.0980779612727929, 303207.5742439505993389 222574.3313352275581565, 303212.3620380503707565 222576.3191453621548135, 303217.2464131281594746 222578.0561662522668485, 303222.2142427377984859 222579.5377297651721165, 303227.2521761544630863 222580.7598542935156729, 303232.3466742536984384 222581.7192554557113908, 340240.9466742626973428 228562.4192554587207269, 340241.6451431164168753 228562.5295974992914125, 371903.0451431074179709 233449.6295974932727404, 371903.3732348520425148 233449.6796828560472932, 373488.5732348550227471 233688.9796828530670609, 373492.4870663167093880 233689.4917264690448064, 373528.5870663106907159 233693.4917264690448064, 373535.2659228414413519 233694.0060347228136379, 373625.1659228474600241 233697.9060347288032062, 373625.1659228474600241 233697.9060347288323101, 373630.2873771191225387 233697.9969001383287832, 373642.9873771221027710 233697.8969001443183515, 373648.2118495866889134 233697.7191247496230062, 373653.4198936402681284 233697.2685764613561332, 373658.5972774084657431 233696.5464864801033400, 373663.7298528013634495 233695.5548280406510457, 373668.8035941756097600 233694.2963110199489165, 373673.8046366619528271 233692.7743745317566209, 373678.7193140533054247 233690.9931775288132485, 373683.5341961499652825 233688.9575874376751017, 373688.2361254601855762 233686.6731668577413075, 373692.8122531549306586 233684.1461583603522740, 373697.2500741796684451 233681.3834674300451297, 373701.5374614266911522 233678.3926435940084048, 373705.6626988743664697 233675.1818597918318119, 373709.6145136032719165 233671.7598900413722731, 373713.3821066011441872 233668.1360854624363128, 373716.9551822734647430 233664.3203487230930477, 373720.3239765776088461 233660.3231069790199399, 373723.4792837048298679 233656.1552833794266917, 373726.4124812366790138 233651.8282672177592758, 373729.1155537074664608 233647.3538828085002024, 373731.5811145076295361 233642.7443571751064155, 373733.8024260689853691 233638.0122866376477759, 373735.7734182764543220 233633.1706023911829107, 373737.4887050554389134 233628.2325351690815296, 373738.9435990903875791 233623.2115790876850951, 373740.1341246336232871 233618.1214547714043874, 373741.0570283696870320 233612.9760718587203883, 373741.7097883056849241 233607.7894909917085897, 373742.0906206630170345 233602.5758853929000907, 373742.1984847519779578 233597.3495021346316207, 373742.0330858153756708 233592.1246232062694617, 373741.5948758341837674 233586.9155264864384662, 373740.8850522924331017 233581.7364467261068057, 373739.9055549047770910 233576.6015366498031653, 373738.6590603159856983 233571.5248282807588112, 373737.1489747864543460 233566.5201945960870944, 373735.3794248842168599 233561.6013116164249368, 373733.3552462080260739 233556.7816210339078680, 373654.0552462110645138 233380.9816210219287314, 373652.5153630711138248 233377.7256075733166654, 365392.9153630621149205 216697.2256075733166654, 365391.9598568481160328 216695.3460295358672738, 365331.8598568540764973 216580.1460295478464104, 365330.2477527938899584 216577.1791839415382128, 339880.6477527848910540 171569.1791839415382128, 339878.8843201125273481 171566.1832905930059496, 338824.6843201245646924 169844.3832905810268130, 338822.4769281532499008 169840.9383075150544755, 338820.1304613530519418 169837.5865048365958501, 338807.6304613530519418 169820.4865048425854184, 338807.5334730069153011 169820.3540531243779697, 337870.8334730038768612 168543.3540531243779697, 337867.0221279650577344 168538.4815600363945123, 337833.5221279650577344 168498.2815600333851762, 337830.6202818806632422 168494.9517117698851507, 337827.5742276740493253 168491.7532505890121683, 337824.3899077704991214 168488.6924162408104166, 337753.4899077645386569 168423.4924162378301844, 337751.3185027677100152 168421.5531549594015814, 337717.4185027767089196 168392.1531549684004858, 337714.5758644837187603 168389.7786549685988575, 337663.9758644747198559 168349.0786549655895215, 337659.8087246867362410 168345.9029646954732016, 337655.4809780826326460 168342.9498862957989331, 337651.0045043539139442 168340.2275259852758609, 337646.3915914490935393 168337.7433566600084305, 337530.7915914550540037 168279.3433566540188622, 337526.2029832758707926 168277.1696530297922436, 337521.5099571402533911 168275.2316596969612874, 337516.7246118161710910 168273.5343728628649842, 335388.0246118131908588 167578.8343728748441208, 335386.2942020931513980 167578.2869793250865769, 335315.7942020931513980 167556.6869793160876725, 335310.1989645521389320 167555.1487824073119555, 335304.5239261208334938 167553.9377201983297709, 335215.0239261208334938 167537.5377202073286753), (335197.0000000000000000 167635.9000000059895683, 335286.5000000000000000 167652.2999999969906639, 335357.0000000000000000 167673.9000000059895683, 337485.7000000029802322 168368.5999999940104317, 337601.2999999970197678 168427.0000000000000000, 337651.9000000060186721 168467.7000000030093361, 337685.7999999970197678 168497.0999999940104317, 337756.7000000029802322 168562.2999999969906639, 337790.2000000029802322 168602.5000000000000000, 338726.9000000060186721 169879.5000000000000000, 338739.4000000060186721 169896.5999999940104317, 339793.5999999939813279 171618.4000000059895683, 365243.2000000029802322 216626.4000000059895683, 365303.2999999970197678 216741.5999999940104317, 373562.9000000060186721 233422.0999999940104317, 373642.2000000029802322 233597.9000000059895683, 373629.5000000000000000 233598.0000000000000000, 373539.5999999939813279 233594.0999999940104317, 373503.5000000000000000 233590.0999999940104317, 371918.2999999970197678 233350.7999999969906639, 340256.9000000060186721 228463.7000000030093361, 303248.2999999970197678 222483.0000000000000000, 303245.7999999970197678 222443.0999999940104317, 303247.5000000000000000 222320.7999999969906639, 303273.7999999970197678 222024.9000000059895683, 303305.9000000060186721 221775.5000000000000000, 303342.2000000029802322 221596.7999999969906639, 303377.5999999939813279 221436.5999999940104317, 303407.7999999970197678 221300.4000000059895683, 303956.7999999970197678 219045.0999999940104317, 314320.4000000060186721 178991.5999999940104317, 314768.0999999939813279 178085.5000000000000000, 326477.0000000000000000 169031.4000000059895683, 326536.9000000060186721 168988.2999999969906639, 326658.5999999939813279 168919.5000000000000000, 326730.0999999939813279 168889.2999999969906639, 326778.0000000000000000 168869.2999999969906639, 329292.5000000000000000 168040.7000000030093361, 335197.0000000000000000 167635.9000000059895683)), POLYGON ((335197.0000000000000000 167635.9000000059895683, 329292.5000000000000000 168040.7000000030093361, 326778.0000000000000000 168869.2999999969906639, 326730.0999999939813279 168889.2999999969906639, 326658.5999999939813279 168919.5000000000000000, 326536.9000000060186721 168988.2999999969906639, 326477.0000000000000000 169031.4000000059895683, 314768.0999999939813279 178085.5000000000000000, 314320.4000000060186721 178991.5999999940104317, 303956.7999999970197678 219045.0999999940104317, 303407.7999999970197678 221300.4000000059895683, 303377.5999999939813279 221436.5999999940104317, 303342.2000000029802322 221596.7999999969906639, 303305.9000000060186721 221775.5000000000000000, 303273.7999999970197678 222024.9000000059895683, 303247.5000000000000000 222320.7999999969906639, 303245.7999999970197678 222443.0999999940104317, 303248.2999999970197678 222483.0000000000000000, 340256.9000000060186721 228463.7000000030093361, 371918.2999999970197678 233350.7999999969906639, 373503.5000000000000000 233590.0999999940104317, 373539.5999999939813279 233594.0999999940104317, 373629.5000000000000000 233598.0000000000000000, 373642.2000000029802322 233597.9000000059895683, 373562.9000000060186721 233422.0999999940104317, 365303.2999999970197678 216741.5999999940104317, 365243.2000000029802322 216626.4000000059895683, 339793.5999999939813279 171618.4000000059895683, 338739.4000000060186721 169896.5999999940104317, 338726.9000000060186721 169879.5000000000000000, 337790.2000000029802322 168602.5000000000000000, 337756.7000000029802322 168562.2999999969906639, 337685.7999999970197678 168497.0999999940104317, 337651.9000000060186721 168467.7000000030093361, 337601.2999999970197678 168427.0000000000000000, 337485.7000000029802322 168368.5999999940104317, 335357.0000000000000000 167673.9000000059895683, 335286.5000000000000000 167652.2999999969906639, 335197.0000000000000000 167635.9000000059895683)))
+LineMerge: GEOMETRYCOLLECTION EMPTY
+Intersect
+Contains
+Distance: 0
+Area 1: 2.67588e+09
+Area 2: 2.65405e+09
+Simplify: POLYGON ((335215.0239261208334938 167537.5377202073286753, 335205.1267784655792639 167536.2307696900388692, 335190.1602671957225539 167536.1341839407396037, 329275.7395326890982687 167942.1145713863952551, 329261.2026209282921627 167945.7238237099954858, 326746.7026209282921627 168774.3238237039768137, 326614.4661321343737654 168829.7659389766049571, 326483.0105803586193360 168904.0626540626399219, 326415.8285449087852612 168952.2921427348919678, 314706.9285449027665891 178006.3921427289023995, 314699.2775538869318552 178012.9502176995156333, 314692.3254273570491932 178020.2450067681784276, 314686.1427613845444284 178028.2024342618533410, 314680.7923384761670604 178036.7416956787055824, 314230.7465425680857152 178947.3026234415883664, 314226.6719709816970862 178956.7423383510031272, 314223.5882016817340627 178966.5505348258011509, 303859.9882016727351584 219020.0505348258011509, 303310.6373324339510873 221276.7480226673360448, 303244.5555483103962615 221575.2231361457088497, 303207.9014352059457451 221755.5931846564926673, 303174.1926699578762054 222016.0467631698702462, 303147.8926699608564377 222311.9467631608713418, 303145.8096594382659532 222441.7101097303093411, 303148.4957166555686854 222489.2534012109390460, 303150.6692645543371327 222504.6388423194293864, 303153.4334335363237187 222514.6280661432247143, 303157.2167087217676453 222524.2775247619138099, 303161.9784481927636079 222533.4835586513218004, 303167.6674988568993285 222542.1472717873693909, 303174.2227459607529454 222550.1755940386210568, 303181.5737696161959320 222557.4822809745091945, 303189.6416012879926711 222563.9888403478544205, 303198.3395721145207062 222569.6253752996271942, 303212.3620380503707565 222576.3191453621548135, 303222.2142427377984859 222579.5377297651721165, 303232.3466742536984384 222581.7192554557113908, 340240.9466742626973428 228562.4192554587207269, 371903.0451431074179709 233449.6295974932727404, 373488.5732348550227471 233688.9796828530670609, 373535.2659228414413519 233694.0060347228136379, 373625.1659228474600241 233697.9060347288323101, 373642.9873771221027710 233697.8969001443183515, 373658.5972774084657431 233696.5464864801033400, 373668.8035941756097600 233694.2963110199489165, 373678.7193140533054247 233690.9931775288132485, 373692.8122531549306586 233684.1461583603522740, 373705.6626988743664697 233675.1818597918318119, 373713.3821066011441872 233668.1360854624363128, 373723.4792837048298679 233656.1552833794266917, 373731.5811145076295361 233642.7443571751064155, 373737.4887050554389134 233628.2325351690815296, 373741.0570283696870320 233612.9760718587203883, 373742.1984847519779578 233597.3495021346316207, 373741.5948758341837674 233586.9155264864384662, 373738.6590603159856983 233571.5248282807588112, 373733.3552462080260739 233556.7816210339078680, 373652.5153630711138248 233377.7256075733166654, 365392.9153630621149205 216697.2256075733166654, 365330.2477527938899584 216577.1791839415382128, 339880.6477527848910540 171569.1791839415382128, 338822.4769281532499008 169840.9383075150544755, 337870.8334730038768612 168543.3540531243779697, 337827.5742276740493253 168491.7532505890121683, 337753.4899077645386569 168423.4924162378301844, 337717.4185027767089196 168392.1531549684004858, 337663.9758644747198559 168349.0786549655895215, 337651.0045043539139442 168340.2275259852758609, 337530.7915914550540037 168279.3433566540188622, 337516.7246118161710910 168273.5343728628649842, 335388.0246118131908588 167578.8343728748441208, 335310.1989645521389320 167555.1487824073119555, 335215.0239261208334938 167537.5377202073286753))
Copied: trunk/tests/unit/capi/test.wkt (from rev 2231, trunk/capi/test.wkt)
--- trunk/tests/unit/capi/test.wkt (rev 0)
+++ trunk/tests/unit/capi/test.wkt 2009-01-13 01:21:05 UTC (rev 2232)
@@ -0,0 +1 @@
+MULTIPOLYGON(((362062.200000003 231744,362076 231749.799999997,362122.299999997 231753.5,362187 231767.900000006,362242 231776,362296.200000003 231786.700000003,362517 231821.5,362651.799999997 231844.799999997,362772.700000003 231871.799999997,362805.099999994 231874.299999997,362847.200000003 231876,362912.799999997 231888.900000006,363005.900000006 231903,363169.200000003 231929.299999997,363247.900000006 231934,363333.900000006 231950,363516.099999994 231985.5,363630.299999997 232004.700000003,363694.700000003 232012,363754 232021.099999994,363833.400000006 232029.799999997,363913.599999994 232048.5,363940.599999994 232052,364014.799999997 232060.299999997,364044.700000003 232065.799999997,364082.700000003 232074.099999994,364165.299999997 232083.799999997,364208.599999994 232097.099999994,364279.799999997 232104,364316.700000003 232112.799999997,364331.200000003 232113.599999994,364391.200000003 232127.599999994,364483.799999997 232140,364606.799999997 232159.599999994,364662.799999997 232170.599999994,364712.900000006 232182.700000003,364823.799999997 232201.5,364904.900000006 232211,364967.200000003 232221.099999994,365061.299999997 232240.5,365191.099999994 232255.900000006,365262.900000006 232262.299999997,365391.700000003 232283.599999994,365525.299999997 232308.900000006,365598.400000006 232326.599999994,365727.099999994 232341.599999994,365803 232352.299999997,365935.400000006 232377.599999994,366011.5 232384.799999997,366056.099999994 232391.200000003,366128.700000003 232407.400000006,366295.599999994 232442.700000003,366445.200000003 232457.200000003,366624.799999997 232486.299999997,366663.200000003 232490.200000003,366707.200000003 232502.400000006,366807.099999994 232522.700000003,366862.900000006 232529.799999997,366971.099999994 232543.5,367088.099999994 232563.099999994,367185.299999997 232575.400000006,367222.200000003 232582.400000006,367331.799999997 232597,367530.299999997 232629.799999997,367683.599999994 232660.700000003,367772.599999994 232675.799999997,367939 232693.099999994,367995.599999994 232701,368055.099999994 232702.599999994,368135 232714.299999997,368220.799999997 232735.400000006,368312.599999994 232753.400000006,368380.799999997 232770.799999997,368447.299999997 232777.599999994,368512.099999994 232792.099999994,368544 232795.599999994,368601.799999997 232805.099999994,368660.799999997 232813.099999994,368707.299999997 232826.400000006,368782.5 232836.099999994,368832.599999994 232847.799999997,368906.599999994 232860.5,368992.5 232873.099999994,369089.099999994 232892,369260.5 232916.700000003,369318.700000003 232931.200000003,369445.599999994 232945.599999994,369508.700000003 232950.099999994,369574.200000003 232960.5,369616.099999994 232967.799999997,369656.200000003 232978.200000003,369717.700000003 233002,369777.700000003 233016.099999994,369875.400000006 233024,370035 233046.900000006,370117.099999994 233056,370200.099999994 233077.599999994,370233.599999994 233079.099999994,370496.900000006 233123.299999997,370539.400000006 233127,370601.700000003 233135,370655.299999997 233146.599999994,370855.099999994 233178.799999997,370932.700000003 233182.099999994,371060.099999994 233205,371120.700000003 233223,371178.599999994 233233,371201.799999997 233229.200000003,371245.299999997 233232.5,371289.900000006 233243.700000003,371425.799999997 233259,371487.5 233276.400000006,371552.299999997 233291.900000006,371638.099999994 233306.400000006,371715.099999994 233318.599999994,371821.200000003 233332.400000006,371918.299999997 233350.799999997,371988.099999994 233360.200000003,372040.700000003 233366.299999997,372158.599999994 233382.299999997,372175.5 233379.599999994,372201.099999994 233382.599999994,372351.299999997 233410.099999994,372419 233417.5,372500.799999997 233432.200000003,372538.700000003 233434.099999994,372559.299999997 233439.200000003,372715.799999997 233463.599999994,372780.900000006 233472.099999994,372809.599999994 233479.599999994,372842.900000006 233484,372895.900000006 233498.099999994,372959.799999997 233506.099999994,372967.799999997 233500.5,372986.099999994 233503.700000003,373016.200000003 233511.599999994,373076.5 233519.700000003,373115.5 233524.5,373133.900000006 233529.700000003,373218.799999997 233538.900000006,373322.599999994 233555.200000003,373403.900000006 233574.799999997,373503.5 233590.099999994,373539.599999994 233594.099999994,373567.700000003 233595.099999994,373612.900000006 233595.299999997,373629.5 233598,373642.200000003 233597.900000006,373633.799999997 233582.099999994,373623.799999997 233570.200000003,373584.099999994 233479.200000003,373562.900000006 233422.099999994,373549.099999994 233399,373506.799999997 233325.799999997,373487.299999997 233294.200000003,373460.200000003 233259.799999997,373442.099999994 233240.099999994,373426.700000003 233220,373405.400000006 233187.299999997,373383.099999994 233164.799999997,373333.599999994 233096.700000003,373325.5 233078.5,373298.299999997 233028.599999994,373269.299999997 232982.599999994,373220.099999994 232893.200000003,373190.799999997 232853.700000003,373145.400000006 232784.700000003,373100.900000006 232712,373090.400000006 232680.299999997,373077.599999994 232660.099999994,373046.400000006 232597.299999997,373028.900000006 232538.200000003,373012.400000006 232520,373002.5 232506.299999997,372997.299999997 232499.900000006,372979.900000006 232471.799999997,372966.5 232452.400000006,372963.099999994 232436.099999994,372925.200000003 232361.5,372900 232326.400000006,372885.700000003 232295.200000003,372849.700000003 232245,372803.299999997 232173.799999997,372764.900000006 232096.200000003,372735.200000003 232063.299999997,372710.900000006 232032.200000003,372692.5 232004.700000003,372691.900000006 231988.700000003,372680 231952,372658.599999994 231917,372655.599999994 231898,372629.799999997 231847.099999994,372609.799999997 231810.599999994,372589.299999997 231778,372571 231743.400000006,372549.400000006 231706.700000003,372536.900000006 231677.099999994,372497.900000006 231600.400000006,372476.799999997 231562.900000006,372467.599999994 231529.099999994,372455 231502.400000006,372444.299999997 231467.700000003,372431 231419.5,372394.5 231364.299999997,372379 231339.5,372355 231312.599999994,372344.099999994 231286.299999997,372307.799999997 231214,372292.099999994 231194.900000006,372274.5 231145.299999997,372260.099999994 231120.599999994,372226.299999997 231083.299999997,372194.299999997 231041.400000006,372136.400000006 230959.099999994,372112.799999997 230922.5,372065.599999994 230841.599999994,372054 230818.299999997,372031.700000003 230784.299999997,372014.700000003 230735.599999994,371990.400000006 230694.200000003,371950.799999997 230628.400000006,371931.700000003 230578.900000006,371890.900000006 230511.299999997,371874.900000006 230494.5,371861.400000006 230513.700000003,371858 230493.400000006,371846.099999994 230455.099999994,371828.099999994 230407.5,371813.299999997 230374.799999997,371787.799999997 230316.5,371751.299999997 230262.700000003,371731.5 230213.700000003,371699.200000003 230171.799999997,371679.299999997 230125.200000003,371656.599999994 230095.599999994,371621.400000006 230055.400000006,371584.299999997 229987.700000003,371550.099999994 229912.5,371526.900000006 229867.400000006,371504.799999997 229838.799999997,371485.599999994 229801.799999997,371475.5 229778,371461.400000006 229752.200000003,371440.700000003 229706.799999997,371400.799999997 229629.099999994,371372.400000006 229581.599999994,371349.400000006 229546.599999994,371312.299999997 229480.400000006,371296.200000003 229454.299999997,371274.900000006 229432.099999994,371253.099999994 229396.099999994,371224.5 229358.099999994,371185.5 229294,371153.299999997 229239.700000003,371066.400000006 229032.700000003,371027.5 228966.900000006,371004.799999997 228913,370991 228890.200000003,370938.099999994 228790.400000006,370919.299999997 228762.799999997,370884.299999997 228707.400000006,370840 228630.900000006,370797.200000003 228558.299999997,370722.5 228398.900000006,370677.200000003 228323.299999997,370655.5 228268.299999997,370635 228228.799999997,370577.799999997 228117.599999994,370556.900000006 228088.400000006,370533.599999994 228047.900000006,370511.299999997 228025.299999997,370485.200000003 227994.799999997,370435.799999997 227946.299999997,370399.799999997 227881.099999994,370342.599999994 227793.200000003,370316.400000006 227755.299999997,370239.599999994 227614.799999997,370195 227565.200000003,370123.299999997 227431.200000003,370067 227353.900000006,370025.5 227277.700000003,369958.5 227171.5,369938.799999997 227130.5,369892.799999997 227050.5,369876.799999997 227022.799999997,369837.799999997 226970.5,369820.799999997 226933,369782.400000006 226859.799999997,369762.099999994 226819.200000003,369739.099999994 226782.200000003,369713.099999994 226749.200000003,369686.5 226704.700000003,369642.400000006 226620.099999994,369596.200000003 226546.099999994,369578.5 226510.5,369541.400000006 226455.200000003,369519 226397.200000003,369476.799999997 226327.099999994,369435.599999994 226235.599999994,369404.900000006 226135.299999997,369367.400000006 226063.099999994,369353.799999997 226024,369316.900000006 225937.799999997,369292.900000006 225899.799999997,369258.799999997 225837.5,369226.099999994 225790.599999994,369191.900000006 225739.900000006,369169.700000003 225702.799999997,369136.799999997 225661.900000006,369115.5 225641.799999997,368998.099999994 225443.299999997,368960.200000003 225358.599999994,368890.799999997 225224.599999994,368812.799999997 225025.900000006,368771.700000003 224939.299999997,368741.900000006 224859.900000006,368701.400000006 224765.900000006,368679.099999994 224703.400000006,368637.099999994 224627.299999997,368616.700000003 224565.799999997,368592.799999997 224525.299999997,368547.5 224416.799999997,368528 224383.799999997,368468.599999994 224270,368457.200000003 224234.200000003,368445.099999994 224206,368404.400000006 224140.400000006,368387 224066.900000006,368348.799999997 223972.200000003,368324.599999994 223901.299999997,368299.099999994 223849.299999997,368281.099999994 223819.200000003,368249.700000003 223748.400000006,368221.799999997 223704,368187.099999994 223625.799999997,368163.599999994 223575.799999997,368139.799999997 223508.400000006,368111.099999994 223455.5,368083.900000006 223370.599999994,368056 223315.700000003,368028.700000003 223248.799999997,368011 223201.700000003,367981.799999997 223133.900000006,367963.400000006 223102.799999997,367932.099999994 223056.400000006,367903.299999997 222978.599999994,367852.099999994 222807.400000006,367820.599999994 222727.099999994,367790.099999994 222635.400000006,367757.799999997 222557.599999994,367742.400000006 222516,367708.200000003 222426.299999997,367660.200000003 222299.900000006,367625.799999997 222225.599999994,367591.700000003 222159.400000006,367561.299999997 222093.5,367502.200000003 221924.400000006,367472.900000006 221842.599999994,367458.5 221819.400000006,367427.700000003 221735.700000003,367385 221624.099999994,367360.5 221574.200000003,367326 221490,367290.299999997 221393.299999997,367271.200000003 221339.700000003,367244.099999994 221268.799999997,367237.299999997 221245.900000006,367214 221194,367200.400000006 221137.900000006,367162.299999997 221044.700000003,367147.099999994 220987.099999994,367117.799999997 220919.299999997,367102.799999997 220894.099999994,367073.599999994 220814.799999997,367023.400000006 220673,366980.099999994 220598.299999997,366962.099999994 220558.799999997,366905.799999997 220454.400000006,366882.400000006 220416.900000006,366857 220370.5,366824.400000006 220272.799999997,366787.599999994 220128.700000003,366743.900000006 220049.200000003,366730.5 220013,366694.799999997 219922.400000006,366668.299999997 219845.400000006,366642.299999997 219788.5,366621 219728.5,366602 219663.5,366578.299999997 219606.599999994,366570.700000003 219575.700000003,366551.599999994 219513.200000003,366507.5 219429.599999994,366492 219386,366458.400000006 219301.200000003,366426.700000003 219211,366392.900000006 219139.200000003,366373.099999994 219087.200000003,366316.599999994 218974.400000006,366294.799999997 218940.799999997,366260.799999997 218889.5,366214.299999997 218764.099999994,366187.599999994 218662.400000006,366165 218615.799999997,366128.799999997 218519.200000003,366086.900000006 218417.599999994,366068.799999997 218378,366035 218307.200000003,366012.200000003 218231.799999997,365984.700000003 218153.400000006,365950.200000003 218060.799999997,365922.099999994 218017.799999997,365903.400000006 217982.200000003,365835.200000003 217851.099999994,365798.5 217801.900000006,365728.400000006 217660.299999997,365673.200000003 217559,365657.5 217511.400000006,365636.900000006 217461.900000006,365589.299999997 217352.400000006,365560.700000003 217312,365525.200000003 217245.299999997,365480.900000006 217133.200000003,365442.5 217056.599999994,365405.900000006 216955.5,365379.200000003 216908,365341.200000003 216825.799999997,365319.200000003 216784.299999997,365303.299999997 216741.599999994,365259.299999997 216668,365243.200000003 216626.400000006,365206.900000006 216581.099999994,365172.5 216521.799999997,365148.700000003 216481.799999997,365127.200000003 216438.799999997,365081.299999997 216365.200000003,365054.5 216305.299999997,365045.099999994 216300,365042.400000006 216280.599999994,365035 216259.299999997,365022.900000006 216243.5,365011.799999997 216224.200000003,364987.599999994 216190.200000003,364980.900000006 216167.299999997,364958.299999997 216136.799999997,364941.799999997 216095.700000003,364917.799999997 216058.200000003,364883.299999997 216007.799999997,364861.200000003 215961.299999997,364850.299999997 215946,364833.799999997 215915.900000006,364803.700000003 215856,364770 215806.200000003,364714.700000003 215744.799999997,364702.599999994 215717,364679.599999994 215672.900000006,364650.799999997 215618,364631.799999997 215591.5,364601.099999994 215554.5,364583.799999997 215510.900000006,364568.599999994 215482.200000003,364521.5 215423.099999994,364479.200000003 215387,364413.200000003 215308.200000003,364385.200000003 215279.200000003,364366.200000003 215262.599999994,364336.400000006 215230.099999994,364285 215148.700000003,364246.299999997 215118.299999997,364224.599999994 215094.299999997,364190.099999994 215058.900000006,364165.099999994 215030.400000006,364125.799999997 214999.599999994,364103.599999994 214973,364053.599999994 214926,364011.799999997 214890.700000003,363965.5 214853.5,363920.700000003 214801.900000006,363876.5 214769.700000003,363806.299999997 214703.5,363766.700000003 214674.200000003,363747.799999997 214657,363681.700000003 214592.299999997,363620.5 214559.799999997,363580.299999997 214535.5,363530.599999994 214496.400000006,363510.299999997 214495.700000003,363474.900000006 214488.799999997,363430.5 214476.5,363381.099999994 214465.299999997,363316.5 214466.400000006,363252.599999994 214461.400000006,363156.700000003 214466.400000006,363090.799999997 214484.299999997,363077.5 214493.5,363067.099999994 214497.200000003,363040 214500.200000003,362914.599999994 214528.5,362870.200000003 214553.099999994,362846.299999997 214560.599999994,362828.400000006 214561.900000006,362827 214572.799999997,362814 214577.5,362776.5 214595.599999994,362765.400000006 214599.200000003,362667.900000006 214651.599999994,362630.299999997 214667.700000003,362576.099999994 214694,362543.299999997 214725.400000006,362511.900000006 214750.900000006,362478 214757.400000006,362379.299999997 214796.799999997,362260.299999997 214866.5,362127.099999994 214946.799999997,362023.900000006 215017.299999997,361984.099999994 215042.400000006,361890.5 215113.700000003,361777.599999994 215181.799999997,361710.099999994 215233.799999997,361692.400000006 215248.400000006,361671.700000003 215256.700000003,361597.900000006 215286.900000006,361502.5 215343.700000003,361472 215357.200000003,361423.700000003 215382.799999997,361259.200000003 215487.700000003,361226.599999994 215505.700000003,361191.599999994 215527.700000003,361118.700000003 215568.299999997,360996.099999994 215603.5,360963.900000006 215608.5,360927.799999997 215621.5,360842.799999997 215661.900000006,360789.599999994 215691,360754.099999994 215720.099999994,360727.200000003 215747.400000006,360701.799999997 215765.799999997,360660.5 215812.900000006,360654.299999997 215825.900000006,360615.299999997 215860.900000006,360579.299999997 215885,360488.200000003 215951.200000003,360455.400000006 215982.099999994,360441.200000003 216003.799999997,360437.700000003 216052.200000003,360418.299999997 216065,360341.099999994 216078.599999994,360322 216078.5,360150.700000003 216078.200000003,359950.599999994 216070.400000006,359871.299999997 216067.200000003,359804.900000006 216063.799999997,359732.799999997 216061.299999997,359707.200000003 216057.299999997,359633.799999997 216055.400000006,359624.400000006 216048.599999994,359625.900000006 216033.599999994,359629 216003.700000003,359644.599999994 215957.599999994,359657.400000006 215924.900000006,359666.5 215890.900000006,359668.400000006 215838.400000006,359654 215798.299999997,359637.700000003 215765.599999994,359599 215719.400000006,359511.299999997 215645.5,359472.400000006 215625.599999994,359428.099999994 215611.400000006,359380.900000006 215602.700000003,359323.5 215606.599999994,359253 215621.700000003,359209.900000006 215664.700000003,359166.5 215718.700000003,359135.799999997 215767.700000003,359093.599999994 215819.700000003,359042.400000006 215891.700000003,359013.299999997 215925.700000003,358938.299999997 215980.099999994,358873.599999994 216000.700000003,358766.200000003 216007.900000006,358736.299999997 216003.799999997,358607.900000006 215998.900000006,358535.5 216001,358492.400000006 215997.200000003,358428 215997.200000003,358369.599999994 215995.700000003,358258.400000006 215994,358108 215982.299999997,357988.299999997 215983.200000003,357948.200000003 215980.900000006,357892 215980.799999997,357883.299999997 215978,357866.400000006 215979.200000003,357825.299999997 215971.400000006,357798.299999997 215947.299999997,357769.299999997 215922.299999997,357739.200000003 215886.5,357707.900000006 215864,357645.799999997 215826.599999994,357580.599999994 215805.700000003,357556.299999997 215796.099999994,357522.700000003 215787.599999994,357488.900000006 215777.299999997,357361.5 215746.299999997,357308.200000003 215729.200000003,357270.599999994 215713.900000006,357247.700000003 215699.799999997,357230.200000003 215689.599999994,357198.400000006 215674.099999994,357158.5 215656.799999997,357139.400000006 215647.599999994,357090.099999994 215625.400000006,357061 215606,357024.799999997 215585,356976.700000003 215540.900000006,356959.799999997 215519.299999997,356924.299999997 215495.900000006,356863.900000006 215441,356847.400000006 215434.299999997,356827.299999997 215423.099999994,356801.400000006 215401.099999994,356769.099999994 215372.200000003,356726.200000003 215341.400000006,356698.599999994 215325.5,356639.700000003 215286,356586.099999994 215239.5,356520 215173.700000003,356487.900000006 215140.299999997,356460.099999994 215110.700000003,356416.200000003 215058.099999994,356396.200000003 215039.5,356363 215005.599999994,356287.200000003 214938.5,356251.5 214906.099999994,356155.799999997 214810.900000006,356106.799999997 214766.799999997,355999.700000003 214667.700000003,355956.299999997 214633,355922 214604.599999994,355896.700000003 214583,355879.599999994 214565,355815.900000006 214515.099999994,355791.400000006 214485.5,355781.200000003 214480.200000003,355783.5 214472.599999994,355756.400000006 214447.200000003,355703.599999994 214373.799999997,355649.799999997 214316.200000003,355633.799999997 214298.5,355606.400000006 214267,355576.400000006 214229.599999994,355565 214217.299999997,355524.700000003 214182,355492.099999994 214141.700000003,355431.700000003 214075.799999997,355412.599999994 214056.700000003,355382.200000003 214028.200000003,355344.599999994 213994.400000006,355296.900000006 213940.799999997,355261.299999997 213908.900000006,355237.5 213876.400000006,355212.599999994 213844.299999997,355182.299999997 213811.400000006,355151.299999997 213757,355117.900000006 213724.200000003,355114.599999994 213715.799999997,355102.599999994 213703,355084.900000006 213673.799999997,355062.200000003 213654.799999997,355051.599999994 213640,355001.700000003 213589.900000006,355002.5 213576.900000006,354978.799999997 213553.400000006,354926.599999994 213487.900000006,354892.599999994 213432,354877.400000006 213414.299999997,354800.900000006 213315.200000003,354747.799999997 213259.299999997,354662.799999997 213136.400000006,354613.200000003 213069.299999997,354552.299999997 212996.5,354491.900000006 212928.099999994,354444.700000003 212858.599999994,354436.599999994 212851.200000003,354404.299999997 212798.900000006,354393.299999997 212790.099999994,354374.900000006 212772,354260.099999994 212618.099999994,354242 212583.5,354214.5 212556,354161.799999997 212490.599999994,354133.099999994 212448.599999994,354112.5 212416.5,354096.700000003 212404.299999997,354078.599999994 212384.599999994,354063.299999997 212363.5,354057.200000003 212342.099999994,354032.799999997 212313.5,354029.799999997 212300.599999994,353984.799999997 212246.5,353954.700000003 212221.5,353943.5 212207.200000003,353925.799999997 212184.5,353923.299999997 212167.200000003,353906.299999997 212149.900000006,353895.299999997 212132.700000003,353885.799999997 212113.799999997,353872.700000003 212104.599999994,353840.400000006 212061.799999997,353825.599999994 212045,353810.900000006 212021.299999997,353715.599999994 211903.700000003,353694.400000006 211872.099999994,353665.099999994 211831.599999994,353618.5 211776.900000006,353575.299999997 211713.799999997,353539.599999994 211678,353527.099999994 211661.200000003,353469.599999994 211595.799999997,353462 211575,353432.099999994 211538.099999994,353408.700000003 211500,353380.599999994 211457.5,353357 211426.5,353348.700000003 211410.700000003,353310.299999997 211358.900000006,353277.400000006 211317.5,353251.299999997 211272,353232.700000003 211244.400000006,353221.5 211230.599999994,353201.200000003 211201.5,353131 211097.400000006,353084.299999997 211045.799999997,353078.200000003 211033,353029.700000003 210970.400000006,353015.099999994 210947.200000003,353003.700000003 210934.799999997,352988.299999997 210915.700000003,352967.400000006 210878,352925.799999997 210816.400000006,352893 210747.599999994,352860.400000006 210698.200000003,352823.799999997 210635.5,352781.700000003 210565.900000006,352762.599999994 210546.700000003,352728 210503.400000006,352690.5 210446.5,352674.400000006 210429.900000006,352670 210419.5,352663.799999997 210413.099999994,352635.799999997 210358.200000003,352535.700000003 210213.700000003,352493.900000006 210170.400000006,352470.700000003 210140.900000006,352445.700000003 210099.900000006,352427.5 210066.200000003,352382.299999997 209981.200000003,352368.5 209965.900000006,352359.099999994 209939.599999994,352331.099999994 209892.700000003,352299.299999997 209856.299999997,352258.700000003 209851.400000006,352226.5 209815,352217.5 209803.200000003,352199.700000003 209760.599999994,352153.900000006 209689.5,352140.099999994 209666.299999997,352108.599999994 209619,352087.200000003 209578.400000006,352043.900000006 209503.299999997,352039.900000006 209481.299999997,352033.900000006 209464.5,352016.700000003 209458.799999997,352002.799999997 209447.099999994,351981.200000003 209410.400000006,351965.400000006 209386.700000003,351959.099999994 209368.400000006,351952.700000003 209354.099999994,351949.400000006 209335.700000003,351959.5 209322,351945.200000003 209310.799999997,351931.900000006 209286.599999994,351924.299999997 209269.700000003,351879.799999997 209172.200000003,351872.099999994 209156.299999997,351854.799999997 209130.200000003,351833.799999997 209081.200000003,351814.299999997 209049.5,351807.299999997 209017.200000003,351805.299999997 208997.799999997,351800.099999994 208972.400000006,351788 208948.700000003,351769.799999997 208923.5,351737.599999994 208896.599999994,351719.700000003 208862.5,351668.5 208798,351647.799999997 208777.799999997,351622.799999997 208745.400000006,351593.400000006 208671.5,351565.799999997 208633.099999994,351548.900000006 208607.400000006,351533.599999994 208587.700000003,351507.099999994 208526.700000003,351483.599999994 208493.599999994,351473.200000003 208472.900000006,351444.599999994 208419,351420 208394.5,351395.799999997 208356.400000006,351354.299999997 208306.200000003,351330.700000003 208260.200000003,351323 208236.900000006,351312.099999994 208223.099999994,351284.700000003 208184.700000003,351269.299999997 208153.900000006,351253.900000006 208135.299999997,351246.900000006 208120.400000006,351235.700000003 208102,351220 208066.900000006,351188.200000003 208028.599999994,351158.299999997 207975.099999994,351134.299999997 207936.099999994,351106.900000006 207910.099999994,351083.799999997 207887,351028.200000003 207819.599999994,351017.799999997 207801.799999997,350968.299999997 207727.799999997,350952.599999994 207693.099999994,350914.900000006 207638.299999997,350885.799999997 207584,350836 207520.400000006,350802.299999997 207459,350778.599999994 207427.5,350740.5 207359.900000006,350707.799999997 207312.400000006,350676.400000006 207266.099999994,350658.799999997 207244,350642.900000006 207212.200000003,350621.5 207161.200000003,350612 207144.900000006,350597.299999997 207114.200000003,350573.900000006 207063.799999997,350548.700000003 207024.200000003,350510.599999994 206945.5,350490.700000003 206918.799999997,350470.900000006 206883.799999997,350448.700000003 206833.799999997,350438 206803,350419.299999997 206768.400000006,350396.299999997 206737.400000006,350307.700000003 206541.799999997,350278.299999997 206492.299999997,350264.700000003 206447.599999994,350245.200000003 206420.099999994,350239.200000003 206393.700000003,350225.400000006 206355.099999994,350203.799999997 206318.400000006,350191.799999997 206281.799999997,350170.299999997 206242.700000003,350139.700000003 206161.799999997,350116.200000003 206120.299999997,350101.900000006 206062.200000003,350095.099999994 206017.900000006,350076.299999997 205961.400000006,350067.299999997 205922.099999994,350059 205906.299999997,350034.5 205833.799999997,350002 205734.700000003,349994.700000003 205699.299999997,349981.099999994 205653.599999994,349971.599999994 205630.900000006,349946.5 205574.299999997,349921.200000003 205527.400000006,349880.200000003 205445.299999997,349855.5 205409.299999997,349843.700000003 205381.5,349826.5 205338.400000006,349812.5 205318.700000003,349796.099999994 205294.5,349791.299999997 205267.599999994,349783.400000006 205237.299999997,349785.599999994 205189.5,349787.5 205149.900000006,349793.799999997 205129.400000006,349804.700000003 205105.799999997,349807.200000003 205080.900000006,349789.099999994 205031.299999997,349773.299999997 204995.5,349754.299999997 204967,349734 204914.900000006,349710.799999997 204872.299999997,349694.099999994 204833.200000003,349681 204808.5,349660.299999997 204758.900000006,349639.299999997 204711.5,349627 204694.200000003,349598.400000006 204651.700000003,349558.099999994 204591,349538.700000003 204553.900000006,349515.900000006 204519.400000006,349492.5 204467.299999997,349480.5 204430.099999994,349481.799999997 204403.700000003,349495 204367.599999994,349503.200000003 204334.599999994,349510.599999994 204280,349497.599999994 204248.799999997,349474.799999997 204224.299999997,349446.099999994 204199.799999997,349390.299999997 204161.299999997,349339.700000003 204111.700000003,349275.700000003 204003.200000003,349229.400000006 203905.900000006,349207.900000006 203842.700000003,349184.900000006 203794.400000006,349161.299999997 203725.299999997,349151.400000006 203692.799999997,349129.099999994 203631,349101.799999997 203550.799999997,349078.799999997 203504.099999994,349046.299999997 203443.799999997,349010.700000003 203349.299999997,349006.299999997 203325.700000003,348989 203263.599999994,348975.099999994 203228.700000003,348936.900000006 203132.5,348893.400000006 202993.299999997,348874.900000006 202924.200000003,348827.400000006 202790.299999997,348795.099999994 202738,348778.599999994 202708.799999997,348734 202608.5,348714.799999997 202559.400000006,348681.900000006 202471.400000006,348664.900000006 202410.299999997,348647.799999997 202366.5,348607.599999994 202268.900000006,348603.299999997 202260.200000003,348573.700000003 202189.099999994,348561.799999997 202157.299999997,348554.099999994 202129.700000003,348541.200000003 202100.799999997,348538.700000003 202088.099999994,348533.400000006 202062.5,348529.099999994 202051.700000003,348517.700000003 202010.599999994,348500.099999994 201994.900000006,348493.700000003 201986.599999994,348474.5 201949.299999997,348468.700000003 201906.599999994,348455 201870.299999997,348437.700000003 201827.900000006,348416.799999997 201787,348409.799999997 201770.400000006,348373.400000006 201718.900000006,348369.299999997 201703,348361.5 201684.400000006,348366.799999997 201670.200000003,348357.700000003 201646.599999994,348347.599999994 201624,348337.799999997 201601.299999997,348328.799999997 201591.900000006,348305.400000006 201501,348280.200000003 201448.799999997,348274 201440.400000006,348256.799999997 201412.599999994,348222.400000006 201350.700000003,348209.200000003 201327.900000006,348179.799999997 201279,348154.700000003 201235,348149.900000006 201212.700000003,348140.599999994 201190.700000003,348121.099999994 201148,348111.200000003 201129.5,348103.599999994 201097,348097 201022.5,348083.5 200995.5,348047.599999994 200940.799999997,348027.099999994 200916.400000006,347997.599999994 200894.400000006,347951.799999997 200833.299999997,347933.400000006 200791.700000003,347929.799999997 200765.599999994,347913 200717.599999994,347886.799999997 200685.700000003,347875.200000003 200667.900000006,347838.799999997 200623.299999997,347815.400000006 200583.799999997,347804.799999997 200567.599999994,347798.400000006 200547.900000006,347781.799999997 200509.299999997,347760.700000003 200484.200000003,347732.599999994 200444.299999997,347703.400000006 200392.599999994,347686.099999994 200363.099999994,347665.299999997 200341.700000003,347626.799999997 200296.299999997,347589.200000003 200263.599999994,347531.900000006 200206.700000003,347505 200189.700000003,347455.599999994 200145.299999997,347435.700000003 200129.900000006,347389 200102,347283.900000006 200050,347184.299999997 200008.400000006,347141.099999994 199982.200000003,347094.400000006 199954.5,347081.900000006 199936,347065 199901.5,347060.299999997 199886.900000006,347052 199860.400000006,347041 199814.400000006,347037.400000006 199800.200000003,347039.799999997 199787.700000003,347034.5 199753.400000006,347017.299999997 199708.5,346992.799999997 199693.400000006,346979.799999997 199674.200000003,346976.299999997 199635.5,346957.5 199602.200000003,346928.099999994 199553.299999997,346912.599999994 199523.900000006,346898.799999997 199497.200000003,346891.799999997 199472.099999994,346883.400000006 199455.5,346872.200000003 199416.5,346854.400000006 199384.400000006,346849.200000003 199371.099999994,346831.700000003 199346.200000003,346822.799999997 199319,346804.900000006 199292.400000006,346778.5 199226.299999997,346769.799999997 199211.5,346751.799999997 199158.599999994,346733.700000003 199123,346717.799999997 199091,346701.799999997 199060.700000003,346685.599999994 199036.900000006,346682.700000003 199019.5,346677.900000006 199009.599999994,346672.5 198996.799999997,346657.299999997 198960.5,346640 198874.799999997,346638.200000003 198824.5,346633.5 198808.299999997,346625.200000003 198758.599999994,346619.700000003 198743.900000006,346610.599999994 198709.900000006,346588 198658.200000003,346571.5 198627.200000003,346561 198615.900000006,346546.299999997 198587.799999997,346532.900000006 198544.299999997,346526.799999997 198533.200000003,346524.200000003 198521.5,346509.900000006 198481.900000006,346504.299999997 198448.5,346477 198369.099999994,346472.5 198338.700000003,346472.299999997 198315.400000006,346473.400000006 198277.400000006,346464.400000006 198268.599999994,346444 198217,346428.900000006 198158.700000003,346428.700000003 198125.799999997,346432.200000003 198103.5,346447.400000006 198074.299999997,346443.700000003 198060.700000003,346433.900000006 198028.700000003,346412.299999997 198003.799999997,346399.200000003 197987.799999997,346393.599999994 197971.900000006,346390.200000003 197941.599999994,346396.900000006 197911.799999997,346401.5 197880.200000003,346416.5 197832.200000003,346433.5 197790.700000003,346449.799999997 197751.900000006,346467.700000003 197704.299999997,346480.200000003 197686.299999997,346501.200000003 197682.5,346537.299999997 197670.900000006,346548.700000003 197661.299999997,346557.099999994 197624.700000003,346548.599999994 197600.400000006,346538.5 197586.900000006,346514.5 197571.799999997,346473.299999997 197580.200000003,346442.099999994 197576.200000003,346408.799999997 197557.5,346356.400000006 197535.099999994,346302.900000006 197505.5,346269.799999997 197463.099999994,346250.700000003 197445.299999997,346244.799999997 197431,346229.799999997 197391.099999994,346222.5 197356.200000003,346209.299999997 197330.900000006,346193 197295.700000003,346170.299999997 197240.5,346163.599999994 197206.900000006,346147.299999997 197158.799999997,346132 197126.200000003,346111.700000003 197075.400000006,346099.599999994 197040.599999994,346092.099999994 197005.799999997,346090.700000003 196966.200000003,346079.099999994 196914.5,346060.700000003 196874.299999997,346038.700000003 196845.799999997,346026.5 196800.599999994,346012.900000006 196730.299999997,346005 196697.5,345993 196683.400000006,345968.299999997 196635.5,345943.599999994 196562.799999997,345932.5 196492.799999997,345911.299999997 196413.099999994,345907.099999994 196382.799999997,345903.700000003 196356.299999997,345887.099999994 196300.700000003,345882 196257.799999997,345872.599999994 196226.700000003,345876.799999997 196207.200000003,345898.200000003 196172.200000003,345896.299999997 196162.700000003,345882.700000003 196134,345842.799999997 196099.900000006,345826.5 196087.5,345810.599999994 196071.599999994,345791.900000006 196032.900000006,345789.400000006 196011.5,345799.299999997 195979.400000006,345779.099999994 195887.700000003,345771.799999997 195829.799999997,345756.5 195784.200000003,345756.299999997 195752.700000003,345778.5 195741.099999994,345766.299999997 195722.700000003,345754.599999994 195711.900000006,345731.099999994 195677.5,345732.200000003 195630.599999994,345728.299999997 195611.799999997,345714.299999997 195586.299999997,345675.099999994 195564.700000003,345664.799999997 195557.599999994,345637.200000003 195541.799999997,345605.200000003 195509,345590.299999997 195471,345588.599999994 195416.200000003,345582.900000006 195362.400000006,345575.900000006 195332.099999994,345567.900000006 195285.900000006,345574.599999994 195259.700000003,345582 195228.200000003,345574.099999994 195183.900000006,345564.5 195158.700000003,345558.099999994 195127.099999994,345559.299999997 195056.299999997,345557.400000006 194980,345552.900000006 194913,345553.099999994 194872.299999997,345553 194814.400000006,345554.700000003 194766.799999997,345550.599999994 194687.799999997,345552.299999997 194655.400000006,345550.599999994 194615.799999997,345547.799999997 194573.200000003,345549.200000003 194434.299999997,345548.400000006 194378.099999994,345544.799999997 194326.799999997,345545.599999994 194273.400000006,345543.400000006 194229.5,345542.400000006 194102.400000006,345542.799999997 194045.5,345545.299999997 193957.700000003,345538.200000003 193757.099999994,345532.700000003 193721.5,345532.299999997 193642.200000003,345535 193526.700000003,345532.900000006 193482,345535.299999997 193417.900000006,345532.099999994 193351,345531.400000006 193304.099999994,345525 193187.799999997,345527.599999994 193120.299999997,345541.5 193070.5,345553.799999997 193027.400000006,345555.099999994 192987.5,345553.900000006 192962.299999997,345544.5 192948.299999997,345523.200000003 192916.400000006,345509.799999997 192880.200000003,345484.900000006 192773.900000006,345476.900000006 192725.900000006,345464.799999997 192692.799999997,345451.900000006 192660.400000006,345428.700000003 192543.099999994,345420.900000006 192509.799999997,345402 192438,345388 192381.400000006,345352.299999997 192249,345326.200000003 192158.400000006,345323.599999994 192145.400000006,345307.400000006 192097.5,345287.599999994 192047,345278.200000003 192027.200000003,345268.099999994 192002.200000003,345251.900000006 191950.299999997,345235.900000006 191907.900000006,345220.599999994 191865.299999997,345207.799999997 191833.5,345178.799999997 191738.400000006,345161.400000006 191684.099999994,345144.400000006 191627.599999994,345124.200000003 191550.099999994,345112.700000003 191523,345106.799999997 191499.900000006,345089.200000003 191461.799999997,345078.700000003 191418.599999994,345054.5 191360.900000006,345041.799999997 191312.599999994,345030.5 191287.700000003,345024.099999994 191256.099999994,344975.400000006 191082.799999997,344937 190983.700000003,344909.099999994 190875.799999997,344902.400000006 190841.299999997,344887.299999997 190805.5,344875 190759.900000006,344864 190728.200000003,344825.5 190666.200000003,344794.700000003 190596.5,344763.5 190542.400000006,344741.599999994 190487.200000003,344732.299999997 190443.900000006,344723.700000003 190372.5,344720.900000006 190331.099999994,344715.400000006 190306,344711.5 190288.400000006,344700.099999994 190241.700000003,344691.799999997 190186.400000006,344686.5 190175.299999997,344678 190139.5,344657.700000003 190075.5,344638.299999997 189943.799999997,344615.900000006 189896.099999994,344607.099999994 189865.299999997,344602.299999997 189854.299999997,344588.5 189802.799999997,344583 189777.599999994,344573.799999997 189711.700000003,344548.700000003 189646.400000006,344525.599999994 189563.799999997,344487.400000006 189433.200000003,344461.5 189319.599999994,344457 189292.799999997,344449.700000003 189257.400000006,344442.799999997 189214.5,344431.099999994 189181.900000006,344418.400000006 189132.299999997,344397.299999997 189060,344384.799999997 188995.900000006,344373.599999994 188938.799999997,344365.099999994 188892.700000003,344356.099999994 188869.400000006,344347.299999997 188837.099999994,344332.599999994 188782.5,344311.200000003 188714,344300.299999997 188677.200000003,344276.400000006 188503.099999994,344256.900000006 188448.5,344232.099999994 188387,344209.099999994 188316.799999997,344177.5 188213.299999997,344156.799999997 188165.900000006,344136.700000003 188122.099999994,344109.599999994 188073.900000006,344096.400000006 188038.5,344084.400000006 188010.299999997,344074.099999994 187978,344032 187900,344018.200000003 187865.599999994,344007.799999997 187843.599999994,343976.799999997 187763.299999997,343967.799999997 187737,343950.400000006 187688.099999994,343935.900000006 187627.299999997,343929.900000006 187612.299999997,343929.099999994 187571.799999997,343920.700000003 187561.400000006,343898.099999994 187528.5,343832.200000003 187399.400000006,343803.900000006 187338.5,343759.599999994 187216.200000003,343739.299999997 187174.400000006,343711.200000003 187121.5,343642 186939.299999997,343594.5 186828,343552.400000006 186695.599999994,343494.900000006 186553.900000006,343465.400000006 186459.200000003,343458.299999997 186417.900000006,343430.700000003 186333.5,343426.900000006 186314.799999997,343329.700000003 185976.799999997,343299.799999997 185837.099999994,343287.5 185760.400000006,343279 185682.900000006,343262.5 185542.900000006,343262.299999997 185487.299999997,343257.5 185408.799999997,343226.799999997 185225.099999994,343219.599999994 185150.5,343202.599999994 185068.400000006,343186.200000003 184961.900000006,343187.400000006 184936.900000006,343184 184869.400000006,343185.599999994 184836.5,343185.799999997 184672.700000003,343180.700000003 184543.299999997,343176.900000006 184427.200000003,343170.099999994 184292.900000006,343164.099999994 184241,343167.299999997 184175.599999994,343160.299999997 184119.400000006,343158.5 184074.299999997,343148 184014.400000006,343128.099999994 183934.099999994,343107 183870.599999994,343107.400000006 183861.599999994,343116.900000006 183815.900000006,343125.5 183762,343130 183746.799999997,343143.700000003 183724.599999994,343185.5 183676.099999994,343208.599999994 183661.799999997,343232.799999997 183632.700000003,343257.400000006 183608.200000003,343296.5 183578.900000006,343351.299999997 183551.599999994,343474.299999997 183521.5,343570 183499.599999994,343621.900000006 183474.599999994,343668.900000006 183454,343698.799999997 183446.5,343793.799999997 183417.299999997,343834.200000003 183406.799999997,343910.900000006 183381.599999994,343966 183371.799999997,344065.400000006 183344.799999997,344173.700000003 183312.700000003,344197.299999997 183310.299999997,344344.599999994 183294,344392.099999994 183293.400000006,344478.299999997 183311.299999997,344503.299999997 183318.099999994,344653.700000003 183335.5,344698.700000003 183352.200000003,344753.5 183370.599999994,344795.5 183370.599999994,344803.5 183366.799999997,344815.599999994 183339.900000006,344812 183316.799999997,344792.599999994 183283.900000006,344791.5 183256.200000003,344783 183220.5,344767.5 183183.5,344749.299999997 183147.900000006,344718.700000003 183112.299999997,344675.299999997 183076.099999994,344599 183039,344593.900000006 183032.099999994,344557.900000006 182996.799999997,344550.5 182966.5,344536.700000003 182927.299999997,344517.599999994 182912.900000006,344490.099999994 182909.5,344469.400000006 182900.099999994,344466.099999994 182882.5,344444.400000006 182847.400000006,344419.299999997 182777.200000003,344416.599999994 182764.799999997,344405.200000003 182725.299999997,344387.200000003 182687.700000003,344379.599999994 182646.400000006,344373.599999994 182597.099999994,344369.599999994 182559,344363.799999997 182457,344354.299999997 182330.599999994,344360.700000003 182197.599999994,344380.400000006 182099.5,344402.900000006 182032.099999994,344415.299999997 181985.299999997,344440.799999997 181930.299999997,344472.5 181860.700000003,344499.599999994 181747.200000003,344511.200000003 181704.400000006,344541.700000003 181658.5,344606.299999997 181542.400000006,344634 181478.099999994,344659.599999994 181424.799999997,344665.099999994 181356.400000006,344661.299999997 181338.200000003,344646.5 181307.099999994,344623.599999994 181271.799999997,344552.299999997 181195.5,344518.200000003 181166.400000006,344462.099999994 181110.599999994,344333 180989.700000003,344310.299999997 180971.900000006,344253.200000003 180924.599999994,344215.700000003 180880.799999997,344150.5 180800,344109.799999997 180738.099999994,344077 180695.099999994,344021.900000006 180606,343947.5 180480.400000006,343883.599999994 180357.700000003,343852.700000003 180303.799999997,343817 180222.799999997,343752.799999997 180108.599999994,343673.099999994 179983.400000006,343621.799999997 179912.299999997,343530.900000006 179755.099999994,343472.400000006 179636.799999997,343365.900000006 179396.099999994,343317.200000003 179286.400000006,343297.200000003 179250.400000006,343261.299999997 179174.5,343219.400000006 179096,343185.5 179041,343069.599999994 178832.299999997,342993.5 178689.799999997,342966.799999997 178650.799999997,342936.700000003 178597.099999994,342884.099999994 178494.599999994,342880.099999994 178480.700000003,342856.599999994 178432.200000003,342839.099999994 178394.599999994,342744.900000006 178208.299999997,342689.5 178087.200000003,342662.299999997 178032.299999997,342645.5 178004.599999994,342601.900000006 177926.700000003,342563 177860.700000003,342531.900000006 177794.099999994,342525.700000003 177786.700000003,342491.799999997 177718.799999997,342452 177648,342367.5 177495.599999994,342367.200000003 177481.200000003,342369.599999994 177468.599999994,342358.200000003 177443.400000006,342348.5 177416.5,342326.400000006 177389,342327.099999994 177375.799999997,342289.400000006 177310.700000003,342272 177272.299999997,342227.400000006 177180,342194.900000006 177141.599999994,342145.099999994 177053.400000006,342120.099999994 176999.400000006,342095 176959.200000003,342020.400000006 176812.599999994,341977.200000003 176741.400000006,341905.299999997 176612.799999997,341863.900000006 176551.599999994,341845.299999997 176523.299999997,341816.400000006 176474.799999997,341753 176360.5,341682.299999997 176184,341625.700000003 176077.5,341569.5 175969.599999994,341528.799999997 175906.299999997,341515.200000003 175878.900000006,341479.599999994 175808.599999994,341450.799999997 175744.700000003,341418.400000006 175695.799999997,341357.900000006 175580.5,341345.099999994 175546,341310.900000006 175482,341291.299999997 175440.799999997,341258.700000003 175384.799999997,341230.400000006 175313.599999994,341175.799999997 175210.5,341121 175069.5,341091.099999994 175014.200000003,341072.200000003 174971.5,341020.099999994 174856,340985.400000006 174792,340954.400000006 174727.400000006,340923.200000003 174663.200000003,340909.799999997 174619.200000003,340874.099999994 174533,340853.900000006 174482.700000003,340820.900000006 174430,340797.599999994 174342.400000006,340780.299999997 174291.299999997,340749.099999994 174228.400000006,340720.400000006 174112.400000006,340710.799999997 174051.200000003,340694.5 173954.200000003,340677.400000006 173898.799999997,340670.200000003 173874,340663.700000003 173859.099999994,340645.200000003 173794,340628.299999997 173722.299999997,340611.799999997 173664.400000006,340605.700000003 173631.799999997,340597 173597.5,340606.5 173590.400000006,340606.400000006 173575.5,340601.900000006 173556,340564.200000003 173475.299999997,340548.400000006 173457,340533.599999994 173424.400000006,340523.299999997 173378.099999994,340509.299999997 173342.400000006,340509.299999997 173321.099999994,340496.700000003 173268,340486.400000006 173234.400000006,340473.400000006 173201.900000006,340463.299999997 173163.599999994,340455.700000003 173148.5,340443.299999997 173113.799999997,340433.5 173094.5,340431.900000006 173082.5,340414.099999994 173051.599999994,340401.299999997 173015.599999994,340376.299999997 172960.200000003,340371.599999994 172944.299999997,340353.599999994 172897.700000003,340338.799999997 172868.200000003,340311.299999997 172775.799999997,340292.299999997 172731.099999994,340279.099999994 172705.799999997,340268.299999997 172670.799999997,340259.700000003 172660.200000003,340244.700000003 172633.700000003,340209 172578.400000006,340200.5 172552.700000003,340202.900000006 172543.099999994,340202.799999997 172522.099999994,340202 172512,340188.599999994 172492.700000003,340170.900000006 172457,340151.200000003 172431.099999994,340136.099999994 172392.5,340114.700000003 172352.900000006,340111.700000003 172337.700000003,340086.700000003 172284.799999997,340079.700000003 172254.400000006,340066.700000003 172228.700000003,340056 172198.900000006,340043.799999997 172164.099999994,340024.200000003 172121.400000006,340016.099999994 172099.200000003,339994.200000003 172056.5,339970.799999997 171994.200000003,339959.200000003 171973.700000003,339945.400000006 171945.5,339907.799999997 171869.5,339896.299999997 171843.700000003,339887.099999994 171825.099999994,339879.700000003 171799.599999994,339865.5 171771.900000006,339806.400000006 171651.5,339793.599999994 171618.400000006,339761.299999997 171566.5,339730.799999997 171533.599999994,339698.599999994 171479.599999994,339685.700000003 171447.099999994,339674 171429.099999994,339640.099999994 171368.5,339617.599999994 171338.400000006,339592.299999997 171302.900000006,339534.599999994 171229.299999997,339521.400000006 171200.200000003,339489.5 171141.599999994,339459.400000006 171111.099999994,339453.400000006 171102,339432.700000003 171081.599999994,339391.200000003 171032.700000003,339319.099999994 170968.900000006,339277.799999997 170938.799999997,339232.900000006 170895,339182.400000006 170861.700000003,339153.400000006 170847.299999997,339089.200000003 170807.599999994,339057.700000003 170786,339013.5 170755.099999994,339001.200000003 170740.599999994,338993.200000003 170714.700000003,338981.900000006 170675.799999997,338958.599999994 170622.5,338944 170542.099999994,338920.299999997 170485.200000003,338919.5 170471.299999997,338909.099999994 170452.700000003,338890.299999997 170396.599999994,338866.5 170339.299999997,338852.799999997 170312.099999994,338847.200000003 170289.799999997,338804.799999997 170158.700000003,338799 170130.400000006,338784.799999997 170062.299999997,338772 170030.5,338768.900000006 169997.200000003,338759.099999994 169973.799999997,338751.799999997 169938.5,338744.799999997 169921.200000003,338739.400000006 169896.599999994,338726.900000006 169879.5,338712.799999997 169874.099999994,338696.200000003 169871.299999997,338620.799999997 169859.299999997,338592.099999994 169846.5,338547.799999997 169829.200000003,338529.099999994 169817.799999997,338483.299999997 169794.799999997,338417.299999997 169753.900000006,338342.200000003 169713.599999994,338277.099999994 169665.799999997,338251.700000003 169633.900000006,338236.299999997 169614,338195.200000003 169555.700000003,338169 169526.5,338134.599999994 169477.599999994,338113 169451,338075.799999997 169389,338065.599999994 169359.5,338050.799999997 169319,338014.400000006 169230.099999994,337990.599999994 169173,337976 169122.900000006,337961.200000003 169047,337937.799999997 168968.799999997,337925.599999994 168939.099999994,337888.700000003 168844.099999994,337864.299999997 168752.200000003,337824 168661.299999997,337790.200000003 168602.5,337756.700000003 168562.299999997,337685.799999997 168497.099999994,337651.900000006 168467.700000003,337601.299999997 168427,337485.700000003 168368.599999994,337402.200000003 168344.299999997,337359.299999997 168333.700000003,337272.200000003 168309.099999994,337224.099999994 168291.099999994,337183.099999994 168282.5,337108 168263.599999994,337071.299999997 168254.299999997,337010.900000006 168234.799999997,336931.099999994 168216.700000003,336858.299999997 168206.400000006,336789.200000003 168188,336759.200000003 168176.200000003,336667.799999997 168150.900000006,336620.400000006 168137.599999994,336563.900000006 168124.099999994,336540.599999994 168118.200000003,336525.900000006 168113.299999997,336501.299999997 168107.900000006,336454.799999997 168089.900000006,336398.5 168069.700000003,336371.5 168057.700000003,336297.5 168032.400000006,336251.799999997 168018.700000003,336216.799999997 168011.700000003,336181 168000.799999997,336105.400000006 167973.200000003,336028 167947.200000003,335961.200000003 167931.799999997,335856.799999997 167902.200000003,335758.299999997 167871.5,335715.799999997 167857.200000003,335679.099999994 167844,335630.400000006 167817.900000006,335523.299999997 167758.900000006,335447.200000003 167714.099999994,335410.400000006 167693.299999997,335357 167673.900000006,335326.700000003 167666.400000006,335286.5 167652.299999997,335197 167635.900000006,335177.099999994 167637.900000006,335099.799999997 167643.400000006,335029.200000003 167674.400000006,334948.799999997 167729.299999997,334931.900000006 167746.5,334908.099999994 167762.299999997,334850.400000006 167812.299999997,334807.099999994 167858.299999997,334786.5 167877.700000003,334749.400000006 167906.599999994,334665.200000003 167980.299999997,334610.099999994 168027.5,334562.799999997 168070.799999997,334537.799999997 168091.900000006,334454.900000006 168163.799999997,334330.200000003 168277.900000006,334282.799999997 168314.900000006,334262.599999994 168333.900000006,334187.099999994 168400.400000006,334160.400000006 168415.5,334097.299999997 168452.599999994,334056.799999997 168478.400000006,334026.799999997 168488.400000006,333912.799999997 168559.900000006,333846.5 168597.599999994,333816 168617.5,333784.200000003 168633,333719.799999997 168669.700000003,333691.700000003 168691.599999994,333633.299999997 168727.400000006,333527.099999994 168808.799999997,333454.900000006 168843.299999997,333403 168861.099999994,333350.200000003 168873.599999994,333319.900000006 168877.599999994,333238.799999997 168882.700000003,333169.5 168887.900000006,333131.799999997 168891.900000006,333064.599999994 168892.700000003,333020.299999997 168889.599999994,332911.5 168887.299999997,332827.099999994 168887.799999997,332799.900000006 168887.799999997,332732.700000003 168887.099999994,332629.599999994 168890.900000006,332520.599999994 168881.5,332465.200000003 168870.900000006,332397.900000006 168864.700000003,332342.799999997 168871.599999994,332304 168867.900000006,332200.400000006 168880.5,332189.900000006 168878.900000006,332148.799999997 168879.700000003,332119.5 168873.400000006,332090.299999997 168870.5,332052 168865.299999997,332024.299999997 168867,331937.799999997 168877.200000003,331860 168878.900000006,331823 168876.799999997,331781.099999994 168881.599999994,331749.200000003 168882.599999994,331735.299999997 168885,331714.799999997 168886.099999994,331678.5 168888.099999994,331660.5 168889.200000003,331643.5 168894.5,331605 168896.799999997,331571.299999997 168893.299999997,331524.900000006 168896.099999994,331482.599999994 168899.900000006,331448.799999997 168903.200000003,331436.799999997 168901.900000006,331421.400000006 168904.900000006,331342 168905.799999997,331316.5 168907.900000006,331228.400000006 168903.799999997,331167.799999997 168898.5,331121.299999997 168892,331040.400000006 168882.799999997,330999 168878.900000006,330830 168875,330771.299999997 168882,330727.700000003 168888.5,330713.5 168893.700000003,330672 168919.599999994,330648.5 168937.099999994,330571.299999997 168975.200000003,330519.299999997 169015.700000003,330490.5 169028.099999994,330431.099999994 169046.900000006,330411.900000006 169048.5,330350.099999994 169041,330330.799999997 169030,330271.5 168999.5,330224.5 168961.5,330191.799999997 168932.799999997,330154.099999994 168889.599999994,330127.200000003 168850.799999997,330103 168826.299999997,330086.099999994 168803.299999997,330077.900000006 168787.200000003,330055.200000003 168747.299999997,330021.5 168708,330004.099999994 168680.799999997,329962.799999997 168637.799999997,329943.5 168618.200000003,329921.5 168598.299999997,329886.900000006 168564.099999994,329859.799999997 168542.299999997,329785.299999997 168465.400000006,329735.599999994 168420.700000003,329708.299999997 168401.5,329697.200000003 168383.400000006,329642.700000003 168339.400000006,329617.900000006 168317.099999994,329603.599999994 168304.299999997,329565.799999997 168276.200000003,329533.5 168248.5,329482.299999997 168209.900000006,329404.599999994 168146.700000003,329385.400000006 168122.299999997,329345 168085.599999994,329306.099999994 168048,329292.5 168040.700000003,329291.900000006 168050.599999994,329274.700000003 168071.900000006,329250.599999994 168110.5,329223.400000006 168160.700000003,329211 168182.900000006,329190.299999997 168213.299999997,329170.299999997 168251.799999997,329143.900000006 168286.400000006,329131.900000006 168311,329115.299999997 168341.400000006,329110.299999997 168358,329075.700000003 168412.200000003,329062.400000006 168439.799999997,329034.200000003 168479.400000006,329008.299999997 168513.700000003,328980 168563.5,328946.799999997 168618.400000006,328915.799999997 168657.299999997,328877.799999997 168698.799999997,328831.599999994 168768.299999997,328817.299999997 168792.799999997,328782 168837.5,328741.799999997 168872.200000003,328701.400000006 168923,328674.5 168953.299999997,328641.799999997 168974,328567.400000006 169016.099999994,328534.099999994 169031.900000006,328500 169053.5,328459.799999997 169064.900000006,328408.599999994 169077.799999997,328380.400000006 169088,328340.700000003 169099.599999994,328300.099999994 169106,328246.400000006 169110.599999994,328216.099999994 169112,328133.700000003 169112.299999997,328079 169108.400000006,328011 169096.700000003,327921.400000006 169072.400000006,327862 169053.900000006,327776.900000006 169009.400000006,327720.099999994 168988.200000003,327681 168974,327582.099999994 168920.700000003,327558.400000006 168911.5,327552.700000003 168904.200000003,327531.400000006 168905.400000006,327448.099999994 168876.299999997,327353.799999997 168857.799999997,327281.400000006 168839.200000003,327188.099999994 168826.200000003,327117.599999994 168818.799999997,327006.799999997 168819.200000003,326934.099999994 168838.099999994,326850.299999997 168853.700000003,326800.900000006 168865.799999997,326778 168869.299999997,326730.099999994 168889.299999997,326680.200000003 168914.200000003,326658.599999994 168919.5,326614.599999994 168948.200000003,326607.900000006 168960,326557.099999994 168982.200000003,326536.900000006 168988.299999997,326477 169031.400000006,326402.400000006 169103.099999994,326371 169142.299999997,326339.799999997 169182.400000006,326314.200000003 169225.700000003,326295.099999994 169269.400000006,326278.700000003 169296.799999997,326249.099999994 169353.200000003,326219.400000006 169439.900000006,326181.599999994 169524.799999997,326177.5 169546.299999997,326142.599999994 169657.799999997,326123.099999994 169725.5,326098.400000006 169848.400000006,326087.299999997 169902.700000003,326057.099999994 169968.5,326044.700000003 170012.400000006,326007.799999997 170166,325999.299999997 170205.799999997,326011.5 170276,326027.5 170322.200000003,326061.700000003 170373.299999997,326086 170418.799999997,326110.5 170441.599999994,326149.099999994 170467,326183.900000006 170495.299999997,326211.799999997 170513.799999997,326257.599999994 170540.799999997,326285.799999997 170553.599999994,326364.400000006 170580.799999997,326464.700000003 170610.5,326532.799999997 170637.099999994,326588.900000006 170669.099999994,326626.700000003 170682.799999997,326673.099999994 170717.5,326721.299999997 170755.099999994,326776.400000006 170799.599999994,326852.400000006 170882.700000003,326871.5 170907.799999997,326903.200000003 170952.799999997,326939.599999994 171020.5,326947.400000006 171045.700000003,326969.299999997 171105.200000003,326992.700000003 171156.200000003,327003.5 171169.200000003,327021.200000003 171200.900000006,327050.799999997 171234.900000006,327075.400000006 171275.099999994,327115 171326.400000006,327231.5 171443.5,327268.099999994 171470.5,327322.299999997 171517.599999994,327402.599999994 171573.900000006,327448.5 171606.200000003,327468.099999994 171624.099999994,327524.700000003 171659.900000006,327556 171688.599999994,327592.299999997 171721.5,327611.599999994 171744.700000003,327639.599999994 171775.599999994,327663.400000006 171816.900000006,327681.799999997 171860,327692.5 171925.200000003,327695.799999997 172008.200000003,327690.299999997 172069.200000003,327688 172115.700000003,327680.5 172147.900000006,327678.5 172175.900000006,327661.200000003 172236.5,327639.400000006 172286.5,327611.400000006 172381.900000006,327596.200000003 172449.5,327580.5 172495.099999994,327547.5 172594,327514.700000003 172677.299999997,327495.799999997 172740.700000003,327486.700000003 172804.700000003,327474 172870.299999997,327473.900000006 172932.799999997,327479.799999997 172971.700000003,327476.299999997 172986,327483 173019.5,327490 173035.799999997,327486.5 173054.900000006,327494.099999994 173072.900000006,327512.5 173105.900000006,327541 173137.799999997,327573.299999997 173165.299999997,327594.799999997 173184,327608.200000003 173194.099999994,327649.700000003 173228.799999997,327665.299999997 173255.900000006,327682.200000003 173268.599999994,327708.099999994 173294.700000003,327734.200000003 173327.299999997,327744.099999994 173347,327760.599999994 173369,327765.900000006 173378.900000006,327767.900000006 173388.599999994,327770.5 173407.299999997,327769.799999997 173436.900000006,327745.200000003 173473.700000003,327723.900000006 173499.799999997,327685.900000006 173528,327651.200000003 173545.400000006,327589.599999994 173575.099999994,327553 173596.799999997,327505.599999994 173618.099999994,327444.900000006 173638.700000003,327422.900000006 173644.5,327349 173657.799999997,327298.200000003 173663.400000006,327234 173666.599999994,327197.700000003 173662.700000003,327166 173654.400000006,327140.900000006 173650.099999994,327098.5 173633.799999997,327026.400000006 173603,327001 173591.099999994,326985.900000006 173581.400000006,326930.200000003 173563.599999994,326897.5 173549.799999997,326865.900000006 173534.599999994,326831.299999997 173528.700000003,326817.200000003 173530.299999997,326779.799999997 173534.400000006,326732.299999997 173555.799999997,326706.900000006 173582.599999994,326691.799999997 173635.599999994,326687.200000003 173657.099999994,326687.599999994 173669.700000003,326676.900000006 173692.700000003,326675.599999994 173717.400000006,326667 173734.900000006,326669.400000006 173758.700000003,326666.200000003 173789.400000006,326667.799999997 173807.299999997,326665.5 173851.700000003,326671.799999997 173875.099999994,326674 173893.200000003,326683.799999997 173923.700000003,326680.900000006 173958,326686 173979.099999994,326674.900000006 174019,326666.400000006 174048.799999997,326657.5 174069.299999997,326654.599999994 174103.099999994,326637.400000006 174160.400000006,326612.299999997 174206.799999997,326595.700000003 174236.599999994,326542.799999997 174296.400000006,326513.5 174354.900000006,326492.799999997 174399.400000006,326475.799999997 174499.700000003,326484.299999997 174524.299999997,326486.299999997 174542.200000003,326483.900000006 174578.099999994,326490.900000006 174608.700000003,326499 174619.299999997,326543.299999997 174649.299999997,326557.799999997 174660,326603.700000003 174667.799999997,326623.299999997 174671.700000003,326671.5 174674.700000003,326720 174679.5,326729.400000006 174687.400000006,326750.900000006 174688.799999997,326781.700000003 174684.799999997,326862.400000006 174670.599999994,326886.799999997 174669.5,326908.799999997 174662.099999994,326991.799999997 174653.400000006,327012.799999997 174650.799999997,327046 174651.299999997,327069.299999997 174668.700000003,327083.200000003 174677.700000003,327099.799999997 174696.099999994,327113.799999997 174729.900000006,327124.700000003 174743.599999994,327135.599999994 174790.099999994,327117.299999997 174844.299999997,327085.799999997 174885.700000003,327068.700000003 174916.400000006,327069.700000003 174933.5,327073.299999997 174957.900000006,327079.400000006 174992.099999994,327102.299999997 175038.799999997,327123.400000006 175053.700000003,327136.5 175067,327173.900000006 175104.299999997,327200.200000003 175120.900000006,327229.200000003 175143.900000006,327254.200000003 175160.799999997,327263.099999994 175164.5,327292.299999997 175184.799999997,327353.599999994 175222.5,327368.200000003 175231.299999997,327388.799999997 175242,327458.799999997 175275.299999997,327481 175289.099999994,327505.200000003 175299.700000003,327553.299999997 175328.200000003,327585.700000003 175353.099999994,327605.700000003 175389.099999994,327616.700000003 175422,327647.700000003 175480.900000006,327656.700000003 175505.5,327680.5 175586.200000003,327687.099999994 175611.299999997,327699 175662.200000003,327723.599999994 175729.799999997,327745.099999994 175797,327760.700000003 175833.099999994,327771 175870.599999994,327791.599999994 175941.200000003,327818.299999997 175999.400000006,327827.099999994 176028.700000003,327838 176061,327879.099999994 176123.400000006,327912.799999997 176170,327945.099999994 176215.700000003,327959.900000006 176245.799999997,327983.799999997 176272.200000003,327977.599999994 176288.799999997,327959.099999994 176298.799999997,327927 176326.700000003,327878.400000006 176359.099999994,327787.700000003 176404.900000006,327776.900000006 176415.799999997,327741 176435.599999994,327681 176468.5,327603.299999997 176521.299999997,327576.5 176534.900000006,327535.5 176563.5,327485.599999994 176597.900000006,327427.400000006 176632,327364.799999997 176671.599999994,327325.400000006 176686.700000003,327257.799999997 176724.200000003,327223.700000003 176747.900000006,327196.200000003 176765,327155.799999997 176795.099999994,327106.599999994 176825.700000003,327001.599999994 176881.799999997,326982.099999994 176895.799999997,326945.200000003 176914.299999997,326853.799999997 176970.799999997,326834.799999997 176977.700000003,326772.700000003 177018.299999997,326734.099999994 177043.299999997,326703.700000003 177059.700000003,326622.299999997 177114.400000006,326505.400000006 177189.900000006,326408.299999997 177241.900000006,326363.700000003 177268.700000003,326329.299999997 177283,326233 177341.799999997,326200.299999997 177359.299999997,326108.799999997 177421,326027.799999997 177475.099999994,325995.299999997 177498.400000006,325858.400000006 177579.599999994,325829.299999997 177591.700000003,325740.700000003 177645,325708.799999997 177660.299999997,325616.900000006 177713.5,325489.900000006 177789.799999997,325405.099999994 177835.700000003,325367 177863.299999997,325347.200000003 177874.599999994,325303.599999994 177902.900000006,325207.799999997 177964.799999997,325159.400000006 177994.900000006,325134.200000003 178008.700000003,325106 178021.200000003,325091 178029.400000006,325040 178061.799999997,325031.200000003 178068.799999997,325021.200000003 178075.799999997,325002.5 178089,324985.099999994 178098.799999997,324959.599999994 178117,324947.400000006 178118.900000006,324904.5 178148.5,324866.5 178173.799999997,324849.700000003 178186.900000006,324749.099999994 178246.400000006,324643.299999997 178306.900000006,324595.299999997 178337.799999997,324558.400000006 178369.099999994,324518.799999997 178392.5,324491.700000003 178404.400000006,324437 178438,324403 178468.799999997,324370.200000003 178487,324325.700000003 178511.900000006,324274.599999994 178545.599999994,324225.099999994 178572.900000006,324120.200000003 178635.299999997,324058.200000003 178675.400000006,324017.5 178703,323988.599999994 178717.200000003,323901.900000006 178778.700000003,323864.099999994 178800.5,323768.200000003 178856,323744.700000003 178865.099999994,323722.299999997 178881.400000006,323689.900000006 178905.099999994,323639.5 178938.799999997,323590.799999997 178962.799999997,323551.299999997 178983.900000006,323495.5 179000.400000006,323473.700000003 179018.700000003,323449.700000003 179039,323421.700000003 179060.200000003,323396.5 179066.799999997,323370.5 179057.799999997,323357 179038.200000003,323345.099999994 179021.5,323327.700000003 179010,323307.799999997 179011.799999997,323287.799999997 179024.799999997,323241.700000003 179045,323198.299999997 179058.900000006,323160.700000003 179063.200000003,323139.5 179052.099999994,323119.099999994 179037.099999994,323100.5 179001.799999997,323084.299999997 178972.5,323075.900000006 178949.900000006,323057.799999997 178924.400000006,323028.400000006 178895.099999994,323006.299999997 178884,322976.200000003 178859,322941.599999994 178852,322892 178852.599999994,322835.400000006 178865.400000006,322813.299999997 178863.700000003,322797.599999994 178861.700000003,322774.700000003 178849.900000006,322758 178846.599999994,322723.5 178827,322709.5 178817.200000003,322624 178754.700000003,322596.700000003 178733.799999997,322576.299999997 178721,322565.799999997 178714,322542.200000003 178703.799999997,322497.200000003 178697.299999997,322476.799999997 178699.299999997,322405.5 178714.400000006,322376.700000003 178728.299999997,322332.900000006 178744.200000003,322269.299999997 178770.599999994,322226.299999997 178808.200000003,322186.599999994 178832.799999997,322137.299999997 178844.700000003,322103.5 178846.799999997,322064.599999994 178852.599999994,322049.700000003 178850.599999994,322029.400000006 178846.099999994,322009.599999994 178832.799999997,321958.799999997 178784.900000006,321895.299999997 178717.5,321860.299999997 178682.099999994,321811.5 178634.5,321783.799999997 178608,321754.5 178580.5,321729.799999997 178565.400000006,321689.900000006 178555.799999997,321675.700000003 178550.700000003,321659 178547.5,321621.799999997 178534.099999994,321579.099999994 178521.799999997,321516.599999994 178491.799999997,321475.5 178473.799999997,321436.400000006 178456,321387.599999994 178447.700000003,321360.700000003 178443.400000006,321320.700000003 178436,321290 178431,321230.400000006 178422.700000003,321116.799999997 178402,321093.599999994 178401.099999994,321071 178400.900000006,321048.799999997 178400.099999994,320998.900000006 178401.799999997,320968.200000003 178411.799999997,320903.799999997 178434.400000006,320879.299999997 178448.799999997,320824 178479.299999997,320791.799999997 178495.799999997,320751.599999994 178510.099999994,320717.700000003 178523.700000003,320676.299999997 178521.5,320604.099999994 178531.799999997,320559.599999994 178532.099999994,320508.400000006 178519.400000006,320465.400000006 178509.599999994,320435.200000003 178503.799999997,320368.400000006 178498.799999997,320306.299999997 178488,320235.099999994 178480.700000003,320218.299999997 178474.5,320201.799999997 178468.200000003,320175.400000006 178468.099999994,320157.299999997 178469.700000003,320117.5 178469.5,320103.799999997 178466,320056.299999997 178458.200000003,319968.099999994 178428.599999994,319937.599999994 178413,319901 178387.299999997,319764.799999997 178297.400000006,319694.200000003 178253.299999997,319660.200000003 178235.099999994,319639.5 178228.5,319597.099999994 178211.700000003,319577.099999994 178205.900000006,319542.099999994 178203.700000003,319521.599999994 178206.299999997,319495.900000006 178204.400000006,319467.099999994 178206.700000003,319419.799999997 178215.599999994,319396.700000003 178221.200000003,319316.5 178239.599999994,319227.700000003 178258.799999997,319149.200000003 178282.400000006,319130.099999994 178287.700000003,319028.799999997 178321.599999994,318921.700000003 178348.5,318884 178358.599999994,318780.799999997 178405.799999997,318756.400000006 178411.5,318728.799999997 178424.799999997,318669.599999994 178481.700000003,318632.400000006 178503.200000003,318567.599999994 178553.599999994,318500 178618.200000003,318456 178671.799999997,318435.400000006 178701.5,318413.200000003 178734.5,318361.200000003 178805,318335.599999994 178839.5,318308 178862.900000006,318278.900000006 178879.5,318250.599999994 178891.5,318195.900000006 178930.799999997,318170.599999994 178942.799999997,318056.900000006 178971.5,318007.900000006 178975.799999997,317957.299999997 178971.599999994,317912.700000003 178961.5,317866.5 178955.799999997,317823.599999994 178924.799999997,317736.5 178898.900000006,317684.799999997 178873.5,317656.5 178853.700000003,317617.799999997 178823.400000006,317562.900000006 178785.799999997,317523 178756.299999997,317464.299999997 178727.5,317400.299999997 178681.799999997,317360.099999994 178671.400000006,317294.099999994 178656.299999997,317215.599999994 178617.099999994,317086.200000003 178569.200000003,317021.299999997 178554.700000003,316952.799999997 178536.599999994,316870 178517.900000006,316828.299999997 178512.5,316774.400000006 178507.400000006,316697.299999997 178498.799999997,316569 178481.599999994,316419.799999997 178472.200000003,316295.099999994 178479.799999997,316204.700000003 178485.799999997,316164.299999997 178485.099999994,316101.799999997 178490.400000006,316057.900000006 178491.299999997,315974.400000006 178513.099999994,315921 178524,315852.299999997 178551.099999994,315807.200000003 178566.700000003,315774 178580.200000003,315710.700000003 178599.900000006,315610.799999997 178628.900000006,315575.5 178634.599999994,315480.700000003 178659.099999994,315437.900000006 178661.700000003,315405.799999997 178666.900000006,315351.700000003 178668.299999997,315288.599999994 178657.599999994,315223.299999997 178639.299999997,315192 178624.700000003,315157.099999994 178601.400000006,315095.299999997 178575.400000006,315039.700000003 178533.599999994,315015.599999994 178472.900000006,315003.299999997 178431.200000003,314995.299999997 178409.599999994,314978.200000003 178355.200000003,314959.299999997 178286.700000003,314917.799999997 178184.799999997,314913 178173.900000006,314894.700000003 178157.200000003,314885.099999994 178153.5,314859.400000006 178136.299999997,314832.099999994 178108,314803.400000006 178090.900000006,314768.099999994 178085.5,314770.400000006 178101.200000003,314774.599999994 178114.700000003,314774.400000006 178130.799999997,314774.799999997 178148.299999997,314775.299999997 178173,314763.900000006 178188.099999994,314765.400000006 178206.799999997,314760.599999994 178218.599999994,314763.200000003 178228.299999997,314752.799999997 178242.200000003,314742.599999994 178252.599999994,314693.400000006 178363.099999994,314677.799999997 178402.099999994,314649.599999994 178451.599999994,314603.799999997 178502.400000006,314594.599999994 178521,314581.5 178542.299999997,314570.099999994 178577.900000006,314563.099999994 178610.299999997,314539 178648.900000006,314519.5 178681.599999994,314505.400000006 178726,314498.5 178730.299999997,314491.299999997 178813.599999994,314490.099999994 178854.200000003,314486.5 178903,314478.299999997 178922.700000003,314446.299999997 178960.5,314426.400000006 178976.900000006,314394.099999994 178986.700000003,314376.200000003 178969.799999997,314352.700000003 178961.299999997,314320.400000006 178991.599999994,314312.099999994 179030.799999997,314308.5 179112.700000003,314319.200000003 179153.799999997,314337.700000003 179181.599999994,314351 179194.5,314364 179234.099999994,314362.700000003 179261.099999994,314350.5 179277.700000003,314297.299999997 179321.200000003,314279.900000006 179334.5,314252.799999997 179407.5,314254.299999997 179473.799999997,314260.799999997 179519.799999997,314271.5 179569.599999994,314278.200000003 179592.799999997,314288.799999997 179619.5,314298.799999997 179649.599999994,314318.599999994 179698.599999994,314326.5 179722.900000006,314376.5 179842.599999994,314393.200000003 179910.299999997,314391.900000006 179935.700000003,314426.799999997 180008,314436.900000006 180038.599999994,314442.299999997 180097.599999994,314458.099999994 180171.700000003,314478.900000006 180268.700000003,314502.799999997 180322.099999994,314519 180372.799999997,314527.799999997 180404.299999997,314548.799999997 180449.400000006,314563.799999997 180478.400000006,314580.599999994 180515.299999997,314597.700000003 180550.5,314606.799999997 180583.299999997,314636.400000006 180642.900000006,314694.900000006 180785.299999997,314707.400000006 180815.200000003,314725.900000006 180840.200000003,314759.299999997 180906.700000003,314771.700000003 180925.5,314793.400000006 180988.299999997,314819.099999994 181036.5,314828.5 181055.799999997,314845.400000006 181077.299999997,314868.400000006 181121.799999997,314904.200000003 181168.5,314928.700000003 181218.400000006,314961.400000006 181288.299999997,314983.599999994 181335.099999994,315024.200000003 181381.599999994,315050.5 181406.900000006,315066.700000003 181431.799999997,315096.599999994 181460,315122.299999997 181477.599999994,315149.599999994 181518.599999994,315192.400000006 181554.900000006,315227.099999994 181571.099999994,315264.299999997 181604.599999994,315332.599999994 181660.200000003,315365.299999997 181683.700000003,315394.400000006 181710.599999994,315505 181774.900000006,315550.700000003 181796.599999994,315579.400000006 181812.799999997,315617.099999994 181830.200000003,315649.5 181850.900000006,315661.299999997 181869.599999994,315675.200000003 181884.200000003,315685.200000003 181908.799999997,315714.200000003 181992.599999994,315720.299999997 182027,315723.200000003 182129.099999994,315732.099999994 182231.799999997,315741.400000006 182363.099999994,315747.5 182457.400000006,315763.5 182524.200000003,315784.700000003 182671.5,315788.700000003 182711,315793.299999997 182754,315785.900000006 182806,315767.400000006 182831.599999994,315713.299999997 182843,315703.799999997 182854.200000003,315692.799999997 182878.799999997,315678.799999997 182898.900000006,315665.599999994 182930.299999997,315651.5 182947.5,315641.900000006 182964.099999994,315623.700000003 182992.599999994,315576.099999994 183067.700000003,315556.099999994 183108.900000006,315542.799999997 183137.799999997,315537.900000006 183151.900000006,315502.5 183197.799999997,315500.099999994 183224.5,315505.599999994 183247.700000003,315520.5 183284.400000006,315535 183299.099999994,315544.400000006 183327.700000003,315552.400000006 183358.200000003,315553.799999997 183367.200000003,315550.700000003 183394.200000003,315562.900000006 183418.099999994,315591.200000003 183439.200000003,315611.299999997 183468.599999994,315620 183487.200000003,315631.400000006 183502,315642.200000003 183528.200000003,315665.700000003 183573.799999997,315673.200000003 183604.299999997,315671.700000003 183648.799999997,315670.900000006 183691.900000006,315640.299999997 183741.099999994,315640.700000003 183756.5,315644.299999997 183769.400000006,315641.299999997 183828.900000006,315648.5 183866.099999994,315651.900000006 183892.799999997,315668.900000006 183930.5,315678.299999997 183960.299999997,315695.299999997 183993.299999997,315703.599999994 184021.5,315722.5 184061.599999994,315750 184102,315787.799999997 184164.799999997,315821.400000006 184232.200000003,315856.700000003 184295.200000003,315872.700000003 184333.200000003,315893.700000003 184363,315932.099999994 184388.900000006,315958.900000006 184415.400000006,315964.5 184425.299999997,315974.299999997 184435.599999994,316014.400000006 184496.900000006,316055.299999997 184558.299999997,316091.299999997 184620.900000006,316109.799999997 184651.299999997,316147.200000003 184696.900000006,316169.299999997 184734.900000006,316183.700000003 184762.099999994,316206.5 184798.200000003,316218.599999994 184823,316237.599999994 184839.200000003,316252.400000006 184870.200000003,316291.400000006 184932.200000003,316308.400000006 184967.299999997,316333.200000003 185000,316344.200000003 185035.599999994,316362.200000003 185069,316373.799999997 185114,316391.5 185159.900000006,316423.799999997 185235.200000003,316447.900000006 185284,316459.299999997 185298.5,316467.5 185316.099999994,316469.299999997 185327.599999994,316500.900000006 185379.599999994,316523.799999997 185431.900000006,316531.200000003 185453.299999997,316556.900000006 185489.799999997,316575.599999994 185514.200000003,316596.799999997 185545.400000006,316617.200000003 185584.900000006,316620.299999997 185595.200000003,316636.599999994 185620.5,316647.599999994 185653.599999994,316662.299999997 185685.5,316666.400000006 185720.400000006,316684.299999997 185798.900000006,316703.299999997 185851,316715.200000003 185894.299999997,316714.099999994 185906.799999997,316724.099999994 185918.799999997,316751.700000003 185922.400000006,316762.799999997 185927.099999994,316757.799999997 185952.700000003,316738.099999994 185976.900000006,316724.799999997 185992.700000003,316725.700000003 186009.299999997,316734.599999994 186024.900000006,316748.099999994 186056.200000003,316752.200000003 186074.299999997,316744.200000003 186101.599999994,316756.599999994 186130.599999994,316768.099999994 186153.400000006,316782.5 186164.099999994,316797.400000006 186204.599999994,316804.099999994 186214.400000006,316821.299999997 186233.299999997,316855.599999994 186293.5,316873.5 186307.900000006,316911.400000006 186368.099999994,316940.599999994 186424.099999994,316946.599999994 186434.799999997,316961.700000003 186510.599999994,316965 186520.700000003,316979.299999997 186539,316990.599999994 186584.700000003,316994.200000003 186597.700000003,317018.400000006 186638.900000006,317038.700000003 186669.299999997,317070.599999994 186694.299999997,317085.900000006 186722.900000006,317090.400000006 186730.799999997,317089.900000006 186742.299999997,317097.799999997 186764.900000006,317121.5 186810.200000003,317140.299999997 186835.200000003,317160.299999997 186880,317168.5 186905.5,317211.900000006 186991.099999994,317257.900000006 187073.5,317297.700000003 187156,317308.700000003 187177.599999994,317342.200000003 187247.400000006,317351.200000003 187269.299999997,317388.299999997 187349.400000006,317406.700000003 187390.599999994,317474.099999994 187525.799999997,317552.799999997 187692.400000006,317577.200000003 187735.599999994,317621.700000003 187821.5,317694.400000006 187969.400000006,317716.5 188024,317743.900000006 188078.799999997,317781.599999994 188157.799999997,317816 188218.299999997,317863 188324.200000003,317921.099999994 188427.200000003,317971.099999994 188527.799999997,318036.400000006 188645.5,318060.299999997 188697.799999997,318114.5 188796,318127 188812.799999997,318128.599999994 188825.900000006,318159.299999997 188891.799999997,318180.099999994 188930.900000006,318194.200000003 189015.799999997,318211 189076.599999994,318223.299999997 189131.599999994,318239.599999994 189158.200000003,318251.299999997 189190.799999997,318268.200000003 189250.900000006,318290.099999994 189295.900000006,318314.099999994 189331.5,318326 189359.299999997,318331.599999994 189392.400000006,318331.200000003 189414.5,318321.700000003 189446.099999994,318324.400000006 189466.700000003,318348 189514.299999997,318350.900000006 189527.900000006,318347 189560.5,318353.5 189573.799999997,318368.700000003 189581.299999997,318387.299999997 189573.700000003,318412.599999994 189557.400000006,318434.900000006 189556.299999997,318453.099999994 189569.299999997,318486.700000003 189593.700000003,318527.200000003 189625.700000003,318593.799999997 189695.799999997,318624.799999997 189735,318671.599999994 189751.299999997,318712.5 189761,318740.799999997 189776.299999997,318828.400000006 189866.599999994,318846.299999997 189891.900000006,318891.400000006 189930.900000006,318971.599999994 190014.200000003,319012.299999997 190057,319067.5 190111,319094 190146,319121.900000006 190176.099999994,319181.900000006 190242.700000003,319255.200000003 190328.799999997,319268.900000006 190345.099999994,319277.200000003 190348.5,319283.5 190355.400000006,319308.299999997 190373.900000006,319339.599999994 190389.5,319402.200000003 190440.599999994,319459.799999997 190492,319490.5 190530.299999997,319526.700000003 190551.099999994,319546.900000006 190565.5,319601.099999994 190627.799999997,319628.799999997 190653.900000006,319651.200000003 190677.200000003,319665.200000003 190695.700000003,319689.599999994 190724.5,319694.700000003 190733.099999994,319727.299999997 190769,319734 190781,319734.799999997 190805.599999994,319746.900000006 190823.400000006,319765.900000006 190839.5,319777.5 190853.900000006,319788.700000003 190865.099999994,319798.200000003 190883.799999997,319827 190936.400000006,319856 190970.900000006,319880.200000003 191020.099999994,319891.5 191043.700000003,319894.799999997 191077.5,319898.299999997 191100.400000006,319897.599999994 191117.900000006,319905.599999994 191151,319916.200000003 191229.099999994,319916.200000003 191269.299999997,319912.700000003 191276.799999997,319908 191289.599999994,319909.400000006 191307.5,319907.700000003 191320.700000003,319910.900000006 191351.700000003,319914.700000003 191372.799999997,319913.200000003 191394.599999994,319907.900000006 191410.799999997,319913.299999997 191490,319912.599999994 191539.5,319908.200000003 191606.599999994,319907.599999994 191656.099999994,319909 191675.700000003,319904.799999997 191698.099999994,319906 191724.599999994,319907.5 191780.5,319905.599999994 191807,319908.799999997 191826.400000006,319898.700000003 191901.900000006,319899.400000006 191945,319898.700000003 191975.299999997,319903.400000006 192040.599999994,319902.200000003 192087.900000006,319903.5 192124.099999994,319902.200000003 192172.700000003,319905.799999997 192210.400000006,319899 192276.799999997,319904.200000003 192321.900000006,319901.200000003 192370.799999997,319903.400000006 192412,319897.599999994 192444.299999997,319900 192480.299999997,319899.700000003 192501.599999994,319896 192536.799999997,319889.5 192562.400000006,319889.900000006 192590.599999994,319889.599999994 192631.700000003,319892.5 192696.700000003,319893.799999997 192735.5,319895.599999994 192757.400000006,319895.299999997 192774.5,319892.099999994 192782.299999997,319889.5 192819.400000006,319894.5 192881.599999994,319894.700000003 192939,319893.299999997 193003.799999997,319892 193070,319903.200000003 193084,319922.5 193096.200000003,319931.299999997 193115.200000003,319927.200000003 193125.299999997,319913.200000003 193139.799999997,319914.900000006 193153.700000003,319888.799999997 193172.799999997,319889.400000006 193193.200000003,319900.099999994 193208.799999997,319913.700000003 193226.299999997,319913.400000006 193244.5,319902.200000003 193280.599999994,319901.900000006 193307.799999997,319917.400000006 193351.700000003,319931.299999997 193374.700000003,319943.5 193381.5,319980.400000006 193390.400000006,320002.200000003 193401.599999994,320026 193394.400000006,320038.099999994 193393.700000003,320075.299999997 193419.900000006,320092.099999994 193436,320088.799999997 193466.700000003,320107 193486.700000003,320128.400000006 193504.799999997,320146.5 193530.299999997,320146.599999994 193550.599999994,320156.200000003 193565.5,320188.799999997 193587.700000003,320206.900000006 193612.900000006,320218.400000006 193647.099999994,320233.299999997 193687.799999997,320237.099999994 193698.900000006,320243.599999994 193709.5,320242.900000006 193737.299999997,320260.099999994 193767.400000006,320281.900000006 193792.099999994,320291 193791.400000006,320302.900000006 193805.200000003,320306.700000003 193823.299999997,320355.099999994 193942.599999994,320382.599999994 194024.700000003,320389.5 194040.5,320392.700000003 194066.799999997,320406.5 194102.700000003,320419.900000006 194160.599999994,320421 194173.799999997,320432.200000003 194205,320438 194236.099999994,320453.700000003 194272.200000003,320506 194383.200000003,320528.5 194416.299999997,320556.299999997 194461,320569.5 194486.700000003,320625.299999997 194552.299999997,320662.5 194590.099999994,320682.200000003 194624.200000003,320686.099999994 194640,320694.299999997 194655,320701.099999994 194691.5,320706.5 194705.700000003,320717.900000006 194754.099999994,320723.799999997 194780.900000006,320741.5 194927.599999994,320757.299999997 194984.5,320766.400000006 195032.700000003,320770.400000006 195060.799999997,320785.599999994 195110.299999997,320798.799999997 195186.700000003,320806.799999997 195217.200000003,320802.700000003 195240.400000006,320809.5 195271.5,320813.200000003 195307.900000006,320824.200000003 195368,320830.900000006 195401.5,320841.700000003 195427.200000003,320867.400000006 195442.299999997,320895.200000003 195444.299999997,320937.900000006 195442.700000003,320962.5 195457,320981.799999997 195481.599999994,320995.900000006 195488.900000006,321024.5 195484.200000003,321061.400000006 195464.400000006,321080.900000006 195462.799999997,321097.5 195468.5,321106.700000003 195476.700000003,321138.900000006 195495.200000003,321161.299999997 195504.299999997,321179.099999994 195510.900000006,321193.400000006 195514.799999997,321206.099999994 195522.799999997,321231.400000006 195533.799999997,321265.900000006 195556.700000003,321273.900000006 195565.700000003,321281.900000006 195561.299999997,321293.099999994 195566.599999994,321306.400000006 195581.099999994,321322 195588.299999997,321363.599999994 195617.099999994,321376.700000003 195632.099999994,321393.299999997 195637.599999994,321428.299999997 195659.799999997,321444.200000003 195667.200000003,321471.700000003 195684.799999997,321485.900000006 195689.799999997,321500.400000006 195700.5,321548.400000006 195725.799999997,321583.900000006 195761.099999994,321622.700000003 195795.900000006,321652.599999994 195814.099999994,321698.599999994 195832.400000006,321718.200000003 195849,321747 195879.599999994,321762.700000003 195901.299999997,321816.799999997 196000.599999994,321832.5 196027.299999997,321842.700000003 196052.599999994,321896.700000003 196145.599999994,321947.400000006 196223.400000006,321956.099999994 196244.700000003,322010.900000006 196333.400000006,322035.900000006 196374.299999997,322045.599999994 196384.5,322105.700000003 196477,322127.700000003 196518.700000003,322170.400000006 196577.099999994,322196.5 196613.900000006,322229.299999997 196671.799999997,322259.900000006 196719.799999997,322351.099999994 196877.299999997,322365.099999994 196908.599999994,322404.400000006 196969.5,322422.599999994 197016.900000006,322509.5 197143.799999997,322586.400000006 197262.900000006,322602 197300,322627.5 197344.200000003,322640.799999997 197359.299999997,322664.799999997 197396.299999997,322706.799999997 197472.400000006,322726.400000006 197504.799999997,322745.5 197531.700000003,322771.5 197580.900000006,322789.200000003 197609.599999994,322807.5 197633.5,322866 197728.900000006,322892.900000006 197783.400000006,322909.599999994 197806.799999997,322970.799999997 197909.900000006,323046.400000006 198039.400000006,323070.700000003 198083.599999994,323137.200000003 198190.599999994,323148.200000003 198213.400000006,323155.200000003 198229.400000006,323160.299999997 198261.099999994,323185.5 198290.400000006,323204.799999997 198336.5,323208.299999997 198366.200000003,323203.400000006 198380.400000006,323176.099999994 198408.599999994,323165.400000006 198440.700000003,323136.299999997 198482.400000006,323128.799999997 198502.099999994,323131 198520.200000003,323144.799999997 198531.799999997,323160.400000006 198544.400000006,323189.700000003 198588,323201.099999994 198614.400000006,323200.900000006 198625.099999994,323206.700000003 198635.799999997,323209.099999994 198656.400000006,323223.299999997 198687.599999994,323243.599999994 198750.900000006,323260.799999997 198796.900000006,323265.700000003 198808.5,323289.5 198850,323299.400000006 198895.5,323308.599999994 198929.700000003,323318.099999994 198971.299999997,323341.099999994 199038.5,323350.900000006 199070.799999997,323389.900000006 199137,323407.900000006 199164.5,323425.5 199187.099999994,323436.200000003 199203.900000006,323448.700000003 199241.099999994,323455.5 199272.200000003,323477.099999994 199288.299999997,323532.900000006 199315.599999994,323578.799999997 199374.5,323607.200000003 199425.700000003,323625.900000006 199483.599999994,323660.400000006 199516.200000003,323680.799999997 199568.5,323712.299999997 199611.400000006,323757.5 199662.599999994,323802.200000003 199706.299999997,323868.900000006 199758.599999994,323903.299999997 199793.5,323912.900000006 199799.700000003,323896.799999997 199808.299999997,323911.200000003 199818.5,323952.599999994 199858.599999994,323979 199874.299999997,324057.599999994 199944.299999997,324108.599999994 199981.799999997,324141 200034.5,324157.099999994 200064.200000003,324177.099999994 200084.5,324199.5 200092.299999997,324265.5 200100.099999994,324302.099999994 200115.799999997,324361.200000003 200151.299999997,324378.799999997 200166.900000006,324413.299999997 200191.099999994,324462.799999997 200228.5,324483.799999997 200242.700000003,324527 200282.200000003,324548.599999994 200295.700000003,324580.599999994 200327.400000006,324608.5 200348.700000003,324644.200000003 200382.299999997,324700.200000003 200421.599999994,324724.099999994 200435,324764.599999994 200469.5,324803 200498.299999997,324844.099999994 200543.299999997,324863.5 200566.200000003,324914.200000003 200614.599999994,324927 200632.099999994,324963.5 200665.599999994,324992.400000006 200699.700000003,325014.200000003 200719.900000006,325016.5 200732.900000006,325017.5 200761.599999994,325007.700000003 200900.5,324997.5 200953.5,324984.700000003 200978.099999994,324975.799999997 201014.5,324944.900000006 201092.200000003,324937.400000006 201132.200000003,324922.299999997 201161.200000003,324891.700000003 201184.799999997,324866.900000006 201223.900000006,324846.099999994 201252.400000006,324826.799999997 201266,324796.400000006 201287.900000006,324782.799999997 201292.299999997,322222.099999994 202654.799999997,322209.700000003 202660.299999997,319207 204261.700000003,309929.299999997 206015.700000003,309878.599999994 206031.900000006,309837.299999997 206038,309786.700000003 206036.299999997,309767.799999997 206032.700000003,309746.400000006 206036,309732.200000003 206031.299999997,309719.700000003 206031.400000006,309692.099999994 206030.799999997,309663.900000006 206036.299999997,309619.299999997 206037.099999994,309561.799999997 206045.400000006,309519.5 206046.5,309491.900000006 206047,309468.900000006 206048.900000006,309445.299999997 206060.200000003,309422.5 206062.599999994,309374.400000006 206071.900000006,309321.900000006 206089.099999994,309234.400000006 206131.400000006,309134 206203.799999997,309086.599999994 206236,309058.099999994 206251.400000006,309026.200000003 206254.900000006,308998.299999997 206278.299999997,308979 206367.900000006,308959.700000003 206406.099999994,308926.599999994 206443.200000003,308875.700000003 206485.400000006,308779.799999997 206569.200000003,308668.599999994 206648.299999997,308625.299999997 206686.799999997,308559.299999997 206757.799999997,308514 206809.299999997,308476.900000006 206842.900000006,308406.5 206901.900000006,308349.5 206937.200000003,308324.400000006 206942.5,308312.099999994 206934.299999997,308290.599999994 206898.099999994,308276.299999997 206891.400000006,308259 206901.599999994,308246.5 206889.400000006,308235.900000006 206890.599999994,308208.599999994 206912.5,308166.5 206981,308152.200000003 207034.200000003,308149.900000006 207064.599999994,308149.200000003 207093.5,308154.5 207134.400000006,308157.400000006 207149.299999997,308170.099999994 207218,308177.799999997 207233.700000003,308175.400000006 207260.299999997,308155.900000006 207287.5,308148.400000006 207304.599999994,308154.200000003 207325.5,308151.700000003 207350,308156.5 207389.799999997,308161.099999994 207404.200000003,308152 207419.299999997,308141.900000006 207453,308141.900000006 207480.299999997,308128.900000006 207523.5,308108.799999997 207574.700000003,308100.299999997 207603.299999997,308101.5 207631.200000003,308099.099999994 207652.099999994,308101.299999997 207681.5,308110.5 207716.900000006,308084.599999994 207728.700000003,308090.599999994 207741.099999994,308093.400000006 207759.5,308085 207784.099999994,308076.099999994 207818.599999994,308074.799999997 207833.200000003,308082.799999997 207876.400000006,308087.799999997 207899.299999997,308071.200000003 207905,308073.099999994 207915.5,308063.299999997 207919.200000003,308052 207920.900000006,308053.200000003 207930.299999997,308050.200000003 207943.299999997,308038.400000006 207972.400000006,308050.200000003 208005.200000003,308048 208023.200000003,308059.700000003 208032.5,308069.5 208055.900000006,308068.900000006 208102.700000003,308054.900000006 208153.799999997,308042.299999997 208168,308044.599999994 208178,308028.700000003 208200.599999994,308024.700000003 208255.599999994,308018.599999994 208283.700000003,308004.700000003 208305.900000006,307981.200000003 208323.200000003,307984.5 208337.599999994,307978.200000003 208358.099999994,307974 208372.200000003,307963.799999997 208420.799999997,307965.900000006 208464.599999994,307965.299999997 208472.5,307954.900000006 208493.299999997,307948.099999994 208521.299999997,307944.599999994 208558.799999997,307940.400000006 208578.299999997,307955.599999994 208664.799999997,307950.200000003 208736.299999997,307948.200000003 208765.700000003,307959.299999997 208821,307968.799999997 208862.200000003,307963 208894.200000003,307961.400000006 208904.299999997,307969.299999997 208938.5,307969 208983.900000006,307981 209034.200000003,307976.599999994 209085.700000003,307971.5 209104.099999994,307960.299999997 209137.799999997,307945.599999994 209178.900000006,307943.099999994 209227.799999997,307923.599999994 209246.099999994,307922.400000006 209272.599999994,307929.400000006 209300.900000006,307925.700000003 209330.900000006,307916.200000003 209341.099999994,307906.599999994 209363.200000003,307909.599999994 209388.599999994,307882.400000006 209437.400000006,307870.099999994 209482,307876.5 209511.799999997,307896.799999997 209538,307909.599999994 209546.799999997,307912.700000003 209555.700000003,307904 209564.299999997,307883.400000006 209604.5,307880.799999997 209646,307894 209681.799999997,307889.700000003 209696.299999997,307872.700000003 209713,307862.700000003 209731.599999994,307856.299999997 209766.200000003,307844.299999997 209789.200000003,307845.900000006 209828.700000003,307842.799999997 209846.700000003,307853.5 209897,307887.799999997 209958.299999997,307923.200000003 210024.599999994,307926.700000003 210050,307925.200000003 210097.400000006,307927 210155.200000003,307928.200000003 210170.299999997,307920 210276.599999994,307913.900000006 210324.099999994,307908.700000003 210337.200000003,307887.700000003 210355.400000006,307868.799999997 210363.200000003,307853.799999997 210373.400000006,307836.599999994 210380.700000003,307823.400000006 210395.400000006,307836.5 210423.099999994,307864.5 210463.5,307875.599999994 210482.900000006,307880.599999994 210504.799999997,307888.400000006 210530.099999994,307886.5 210571,307883.099999994 210589.5,307878.299999997 210627.099999994,307861.400000006 210676.200000003,307858.099999994 210693.200000003,307879.200000003 210733.799999997,307893 210780,307893.599999994 210796,307886.700000003 210827.400000006,307899.5 210857.700000003,307930 210886.599999994,307939.099999994 210897.5,307951.200000003 210897.799999997,307962.799999997 210919.599999994,307975.099999994 210961.299999997,307983.900000006 210977.599999994,307998.400000006 211017.299999997,308001.700000003 211048.700000003,308006.900000006 211062.099999994,308018.400000006 211098.900000006,308038.799999997 211138.400000006,308064.900000006 211169,308079.5 211183.200000003,308101.700000003 211219.799999997,308119.299999997 211242.400000006,308132.099999994 211274.099999994,308143.299999997 211293.5,308140.200000003 211321.900000006,308127 211344.099999994,308114.799999997 211385.200000003,308101.700000003 211417.799999997,308085.099999994 211448,308081.599999994 211461.5,308066.799999997 211479.299999997,308060.799999997 211506.799999997,308054.5 211522.299999997,308040.599999994 211559,308037.299999997 211567.5,308028.5 211587.200000003,308021.099999994 211597.799999997,308018.299999997 211610.799999997,308010.799999997 211628.799999997,308005.099999994 211647.299999997,307992.900000006 211676.599999994,307981.799999997 211700.200000003,307957.900000006 211763,307936.200000003 211813.599999994,307926.799999997 211834.200000003,307918.299999997 211858.400000006,307902.099999994 211872.099999994,307901.599999994 211882.599999994,307895.900000006 211898.099999994,307852.400000006 211942.799999997,307829.200000003 211987.400000006,307827.5 212029.900000006,307806.900000006 212072.099999994,307799.900000006 212093.700000003,307790.599999994 212111.400000006,307775.099999994 212145.5,307763.299999997 212164.099999994,307751.599999994 212190.400000006,307726.799999997 212237.599999994,307703.099999994 212288.799999997,307707.900000006 212312.799999997,307702 212325.400000006,307658.299999997 212380.900000006,307644.599999994 212400.099999994,307620.400000006 212413.900000006,307584.299999997 212426.900000006,307574.799999997 212442.099999994,307569.799999997 212451.700000003,307564.5 212463.700000003,307563.400000006 212473.200000003,307549.200000003 212485.400000006,307498.5 212569.099999994,307486.900000006 212585.599999994,307481.099999994 212620.700000003,307471.099999994 212653.799999997,307445.5 212694.099999994,307429.799999997 212749.299999997,307421.099999994 212814.200000003,307409.599999994 212842.900000006,307406.5 212869.900000006,307398 212906,307390 212918.5,307391.299999997 212956.900000006,307391.900000006 212994.799999997,307376.400000006 213015.599999994,307366.099999994 213044.099999994,307343.400000006 213084.900000006,307302.599999994 213137.5,307280.5 213158.799999997,307244.700000003 213212.299999997,307228.700000003 213238.900000006,307182.5 213304,307161.900000006 213326.799999997,307154.599999994 213364.799999997,307146.099999994 213381.5,307130.799999997 213396.700000003,307118.599999994 213416.799999997,307096.200000003 213430.700000003,307076.200000003 213432,307068.599999994 213439.599999994,307049.400000006 213477.299999997,307031.5 213507.599999994,307019.799999997 213529.700000003,307002.5 213547.400000006,306939.299999997 213650.700000003,306895.900000006 213709.200000003,306879 213749.900000006,306860.799999997 213813.599999994,306844.200000003 213874.200000003,306833.799999997 213897.799999997,306777.900000006 213903.200000003,306750.799999997 214018.400000006,306747.400000006 214036.900000006,306715.700000003 214108.799999997,306705.099999994 214125.400000006,306685.799999997 214166.700000003,306628.599999994 214263.900000006,306604.599999994 214313.200000003,306585.400000006 214347.900000006,306553.900000006 214393.299999997,306501.900000006 214469.400000006,306470.299999997 214512.299999997,306444.5 214548.700000003,306393.099999994 214614.799999997,306306.599999994 214750.5,306228.599999994 214864.5,306122 215018.900000006,306068.200000003 215095.099999994,306000.900000006 215204.299999997,305992.700000003 215223,305969.799999997 215274.200000003,305936.299999997 215330.700000003,305919.900000006 215359.400000006,305881.900000006 215424.400000006,305849.200000003 215493.700000003,305808.599999994 215566.700000003,305796.599999994 215592.299999997,305775.799999997 215628.200000003,305738.700000003 215697.099999994,305627.299999997 215880.900000006,305598.799999997 215935.299999997,305571.700000003 215987.099999994,305534.599999994 216040.700000003,305522.5 216057.299999997,305463.599999994 216155.099999994,305429.700000003 216209,305358.099999994 216318.900000006,305314.900000006 216390,305218.099999994 216534.599999994,305191 216584,305146.5 216663,305100.5 216727.200000003,305068.400000006 216793.900000006,305030 216862.900000006,304980.400000006 216942.599999994,304943.299999997 216992.5,304866.299999997 217124,304846 217160.799999997,304817.200000003 217203.599999994,304769.5 217297.700000003,304749.299999997 217338.5,304723.299999997 217393.299999997,304681.099999994 217467.299999997,304649.799999997 217538.599999994,304590.299999997 217662.799999997,304555 217746.700000003,304495.200000003 217838.5,304409.5 217989,304368.299999997 218042.599999994,304280.799999997 218211.099999994,304251 218276.5,304207 218355.5,304182.400000006 218412.799999997,304162 218462.5,304132.099999994 218530.299999997,304103.599999994 218614.200000003,304054.400000006 218721.799999997,304030.799999997 218797.5,304017.700000003 218842.099999994,303987.200000003 218927.799999997,303956.799999997 219045.099999994,303947.200000003 219105.599999994,303931 219169.299999997,303924.5 219261.200000003,303881.400000006 219431.599999994,303864.099999994 219476.799999997,303856 219533.200000003,303839.299999997 219688.200000003,303824.299999997 219766.200000003,303819.200000003 219807.799999997,303803.200000003 219863.400000006,303782.799999997 220000.5,303757.099999994 220131.599999994,303739.900000006 220203.700000003,303692 220368.099999994,303678.200000003 220431.299999997,303636.400000006 220547.599999994,303617.099999994 220621.299999997,303599.400000006 220689,303574.5 220780.200000003,303555.200000003 220857.400000006,303543.599999994 220910,303497.799999997 221055.400000006,303466.099999994 221140.200000003,303432.200000003 221243.099999994,303407.799999997 221300.400000006,303377.599999994 221436.599999994,303362.799999997 221508.599999994,303342.200000003 221596.799999997,303330.5 221664.900000006,303305.900000006 221775.5,303295.5 221890.900000006,303273.799999997 222024.900000006,303264 222176.400000006,303260.400000006 222250.799999997,303247.5 222320.799999997,303245.799999997 222443.099999994,303247.400000006 222456.5,303248.299999997 222483,307493.099999994 222616.400000006,307496 222606.900000006,308026.200000003 222622.400000006,308050.700000003 222623.5,312441.799999997 221993.700000003,311818.200000003 217599.400000006,317924.599999994 218352.299999997,318638.900000006 218380.299999997,318654 218373.099999994,325105.799999997 218717.700000003,328449.599999994 222082.299999997,329488.799999997 222431.900000006,333400.700000003 223759.799999997,334532.5 223883.799999997,336703.700000003 223376.400000006,337699 222898.200000003,338396.099999994 223092.599999994,338259.900000006 225268.5,338267.700000003 225279.400000006,338279.5 225283.599999994,338295.700000003 225313.299999997,338327.5 225357.599999994,338350.099999994 225389.200000003,338365.599999994 225402.900000006,338375.900000006 225414.700000003,338410 225468.099999994,338458.799999997 225516.200000003,338491.900000006 225553.599999994,338501.900000006 225572.400000006,338520.599999994 225595.5,338541.299999997 225624.099999994,338561.099999994 225663.200000003,338587 225723.599999994,338605.799999997 225770.200000003,338613.700000003 225810.5,338620 225825.400000006,338632.900000006 225931.900000006,338637.900000006 226013.099999994,338643.5 226035.900000006,338652.200000003 226101.599999994,338660.299999997 226133.900000006,338667.5 226148.799999997,338676.400000006 226187.099999994,338683.400000006 226216.299999997,338701.900000006 226259.5,338733.799999997 226316.299999997,338757.799999997 226356.299999997,338796.700000003 226397.599999994,338821.5 226421.599999994,338833.900000006 226438.900000006,338924.200000003 226569.599999994,338939.200000003 226585.400000006,339013.700000003 226672.5,339080.299999997 226723.799999997,339117.900000006 226742.099999994,339142.900000006 226748.799999997,339162 226752.400000006,339186.799999997 226762,339227 226762.900000006,339270.200000003 226751.099999994,339310.900000006 226731.099999994,339358.299999997 226684,339383 226644.599999994,339411.799999997 226599.200000003,339453.200000003 226553.299999997,339504.400000006 226488.099999994,339556.700000003 226440.400000006,339630.799999997 226385.299999997,339674.799999997 226360.599999994,339688.700000003 226357.900000006,339717.400000006 226351,339730.200000003 226344.799999997,339755.5 226347.400000006,339782.099999994 226341.5,339810.700000003 226349.5,339824.599999994 226348.799999997,339865.5 226372.5,339877.599999994 226382.799999997,339894.299999997 226395,339911.5 226415.200000003,339926.200000003 226446.900000006,339935.099999994 226499.700000003,339932.099999994 226535.599999994,339915.799999997 226573.799999997,339874 226631.299999997,339829.299999997 226673.5,339802.299999997 226708.700000003,339738.400000006 226774.099999994,339695.400000006 226836.200000003,339612.799999997 226943.299999997,339587 226980.099999994,339535.900000006 227041.799999997,339499.299999997 227077.700000003,339456.700000003 227151.299999997,339447.200000003 227171.799999997,339438.700000003 227195.900000006,339429.5 227236.400000006,339438.5 227325.599999994,339456.099999994 227395.599999994,339475.099999994 227451.200000003,339496.099999994 227487.799999997,339505.799999997 227513,339559.400000006 227573,339595.099999994 227605.400000006,339663.099999994 227664.200000003,339720.299999997 227700.700000003,339756.799999997 227717,339772.799999997 227721.799999997,339793.099999994 227738,339866.599999994 227760.599999994,339893.099999994 227762.799999997,339932.400000006 227768.200000003,339980.900000006 227781.299999997,339999.799999997 227794,340042.200000003 227807.799999997,340082.400000006 227833.599999994,340098.900000006 227844.200000003,340117.900000006 227872.900000006,340144.900000006 227925.299999997,340170.299999997 227994.700000003,340182.799999997 228047.5,340195.5 228118.5,340200.900000006 228144.400000006,340200.200000003 228156.299999997,340206.900000006 228182.200000003,340209.200000003 228222.5,340222.5 228268.299999997,340236.299999997 228320.799999997,340236.900000006 228335.799999997,340235.5 228359.799999997,340234.5 228382.799999997,340256.900000006 228463.700000003,346105.400000006 229356.200000003,346132.5 229361.299999997,346156.5 229366.900000006,346255.299999997 229377.799999997,346302.299999997 229388.5,346347.200000003 229389.200000003,346376.599999994 229390.299999997,346482.5 229402,346542.299999997 229410.099999994,346737.5 229441.799999997,346783 229445.700000003,346822.299999997 229453.400000006,346873.400000006 229468.599999994,346965.299999997 229481.099999994,347007.599999994 229482.5,347127.5 229501.400000006,347233.200000003 229516.700000003,347282.700000003 229526.900000006,347319.099999994 229531.799999997,347381.5 229548.299999997,347461.900000006 229562.400000006,347551.099999994 229573,347632.599999994 229580.099999994,347725.700000003 229593.700000003,347866.799999997 229608.400000006,347889.5 229613.900000006,347991 229629.299999997,348037 229636.099999994,348078.799999997 229643.299999997,348129.200000003 229647.5,348184.799999997 229653.200000003,348258.599999994 229659,348357.5 229677.799999997,348429 229689.599999994,348475.200000003 229694.400000006,348493.200000003 229693.5,348542.200000003 229700.799999997,348615.900000006 229705.099999994,348707.5 229718,348757.099999994 229722.799999997,348909.900000006 229746.200000003,349000.5 229753.299999997,349113.5 229768.900000006,349212.5 229784.299999997,349276.400000006 229794.700000003,349386.299999997 229819.5,349515.299999997 229845.799999997,349610.599999994 229860.700000003,349692.799999997 229864.299999997,349756.799999997 229870.400000006,349816.299999997 229882.400000006,349865.099999994 229894.599999994,349920.099999994 229906.599999994,350055.599999994 229936.799999997,350098.799999997 229940.700000003,350203.900000006 229959.5,350425.599999994 229997.799999997,350458.599999994 230001.200000003,350483.400000006 230009.299999997,350550.299999997 230016.799999997,350602.299999997 230025.400000006,350649.099999994 230030.099999994,350745.599999994 230047,350769.599999994 230049.599999994,350812 230056.5,350850.099999994 230061.799999997,350899.200000003 230069.5,350935.299999997 230067.900000006,351026.099999994 230082,351084.200000003 230088.900000006,351122.900000006 230091.900000006,351147.900000006 230097,351151.200000003 230031.5,353161.400000006 230412.299999997,353177 230413.599999994,362053.700000003 231736.700000003,362062.200000003 231744)))
Copied: trunk/tests/unit/capi/testrunner.sh (from rev 2231, trunk/capi/testrunner.sh)
--- trunk/tests/unit/capi/testrunner.sh (rev 0)
+++ trunk/tests/unit/capi/testrunner.sh 2009-01-13 01:21:05 UTC (rev 2232)
@@ -0,0 +1,28 @@
+#!/bin/sh
+runner=$1
+shift
+srcdir=$1
+shift
+cat <<EOF > ${runner}
+#!/bin/sh
+./geostest ${srcdir}/test.wkt > test.out
+ret=\$?
+if test "\$ret" -ne "0"; then
+ echo "geostest exited with non-zero status (\$ret)"
+fi
+# It's enough that it doesn't segfault for now...
+# computing a diff doesn't currently work as geostest
+# was not initially made taking arch differences into
+# account
+diff ${srcdir}/test.expected test.out >&2
+exit \$ret
+EOF
+chmod +x ${runner}
+echo "Runner: ${runner} created"
More information about the geos-commits
