[geos-commits] r2233 - trunk/capi
svn_geos at osgeo.org
Tue Jan 13 10:47:47 EST 2009
Author: pramsey
Date: 2009-01-13 10:47:47 -0500 (Tue, 13 Jan 2009)
New Revision: 2233
Added:
trunk/capi/geos_ts_c.cpp
Add missing file to SVN.
Added: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp (rev 0)
+++ trunk/capi/geos_ts_c.cpp 2009-01-13 15:47:47 UTC (rev 2233)
@@ -0,0 +1,3956 @@
+ * $Id: geos_ts_c.cpp 2179 2008-08-29 18:17:21Z mloskot $
+ * C-Wrapper for GEOS library
+ * Copyright (C) 2005-2006 Refractions Research Inc.
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+ * Author: Sandro Santilli <strk at refractions.net>
+ * Thread Safety modifications: Chuck Thibert <charles.thibert at ingres.com>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/prep/PreparedGeometry.h>
+#include <geos/geom/prep/PreparedGeometryFactory.h>
+#include <geos/geom/GeometryCollection.h>
+#include <geos/geom/Polygon.h>
+#include <geos/geom/Point.h>
+#include <geos/geom/MultiPoint.h>
+#include <geos/geom/MultiLineString.h>
+#include <geos/geom/MultiPolygon.h>
+#include <geos/geom/LinearRing.h>
+#include <geos/geom/LineString.h>
+#include <geos/geom/PrecisionModel.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/CoordinateSequenceFactory.h>
+#include <geos/geom/IntersectionMatrix.h>
+#include <geos/io/WKTReader.h>
+#include <geos/io/WKBReader.h>
+#include <geos/io/WKTWriter.h>
+#include <geos/io/WKBWriter.h>
+#include <geos/io/CLocalizer.h>
+#include <geos/simplify/DouglasPeuckerSimplifier.h>
+#include <geos/simplify/TopologyPreservingSimplifier.h>
+#include <geos/operation/valid/IsValidOp.h>
+#include <geos/operation/polygonize/Polygonizer.h>
+#include <geos/operation/linemerge/LineMerger.h>
+#include <geos/operation/overlay/OverlayOp.h>
+#include <geos/geom/BinaryOp.h>
+#include <geos/version.h>
+// This should go away
+#include <cstdio>
+#include <cstdlib>
+#include <cstring>
+#include <fstream>
+#include <iostream>
+#include <sstream>
+#include <string>
+#include <memory>
+// Some extra magic to make type declarations in geos_c.h work -
+// for cross-checking of types in header.
+#define GEOSGeometry geos::geom::Geometry
+#define GEOSPreparedGeometry geos::geom::prep::PreparedGeometry
+#define GEOSCoordSequence geos::geom::CoordinateSequence
+#define GEOSWKTReader_t geos::io::WKTReader
+#define GEOSWKTWriter_t geos::io::WKTWriter
+#define GEOSWKBReader_t geos::io::WKBReader
+#define GEOSWKBWriter_t geos::io::WKBWriter
+#include "geos_c.h"
+/// Define this if you want operations triggering Exceptions to
+/// be printed.
+/// (will use the NOTIFY channel - only implemented for GEOSUnion so far)
+#undef VERBOSE_EXCEPTIONS
+#if defined(_MSC_VER)
+# define GEOS_DLL __declspec(dllexport)
+#else
+# define GEOS_DLL
+#endif
+// import the most frequently used definitions globally
+using geos::geom::Geometry;
+using geos::geom::LineString;
+using geos::geom::Polygon;
+using geos::geom::CoordinateSequence;
+using geos::geom::GeometryFactory;
+using geos::io::WKTReader;
+using geos::io::WKTWriter;
+using geos::io::WKBReader;
+using geos::io::WKBWriter;
+using geos::io::CLocalizer;
+using geos::operation::overlay::OverlayOp;
+using geos::operation::overlay::overlayOp;
+typedef std::auto_ptr<Geometry> GeomAutoPtr;
+typedef struct GEOSContextHandleInternal
+ const GeometryFactory *geomFactory;
+ GEOSMessageHandler NOTICE_MESSAGE;
+ GEOSMessageHandler ERROR_MESSAGE;
+ int WKBOutputDims;
+ int WKBByteOrder;
+ int initialized;
+} GEOSContextHandleInternal_t;
+//## PROTOTYPES #############################################
+extern "C" const char GEOS_DLL *GEOSjtsport();
+extern "C" char GEOS_DLL *GEOSasText(Geometry *g1);
+extern "C" {
+GEOSContextHandle_t
+initGEOS_r(GEOSMessageHandler nf, GEOSMessageHandler ef)
+ GEOSContextHandleInternal_t *handle;
+ void *extHandle;
+ extHandle = malloc(sizeof(GEOSContextHandleInternal_t));
+ if(extHandle != NULL)
+ handle = (GEOSContextHandleInternal_t*)extHandle;
+ handle->NOTICE_MESSAGE = nf;
+ handle->ERROR_MESSAGE = ef;
+ handle->geomFactory = GeometryFactory::getDefaultInstance();
+ handle->WKBOutputDims = 2;
+ handle->WKBByteOrder = getMachineByteOrder();
+ handle->initialized = 1;
+ return (GEOSContextHandle_t)extHandle;
+void
+finishGEOS_r(GEOSContextHandle_t extHandle)
+ //Fix up freeing handle w.r.t. malloc above
+ if( extHandle == NULL )
+ return;
+ free(extHandle);
+ extHandle = NULL;
+// relate()-related functions
+// return 0 = false, 1 = true, 2 = error occured
+char
+GEOSDisjoint_r(GEOSContextHandle_t extHandle, const Geometry *g1,
+ const Geometry *g2)
+ return 2;
+ if( handle->initialized == 0 )
+ return 2;
+ try {
+ bool result;
+ result = g1->disjoint(g2);
+ return result;
+ catch (const std::exception &e)
+ handle->ERROR_MESSAGE("%s", e.what());
+ return 2;
+ catch (...)
+ handle->ERROR_MESSAGE("Unknown exception thrown");
+ return 2;
+char
+GEOSTouches_r(GEOSContextHandle_t extHandle, const Geometry *g1,
+ return 2;
+ return 2;
+ try {
+ bool result;
+ result = g1->touches(g2);
+ return result;
+ return 2;
+ catch (...)
+ return 2;
+char
+GEOSIntersects_r(GEOSContextHandle_t extHandle, const Geometry *g1,
+ return 2;
+ return 2;
+ try {
+ bool result;
+ result = g1->intersects(g2);
+ return result;
+ return 2;
+ catch (...)
+ return 2;
+char
+GEOSCrosses_r(GEOSContextHandle_t extHandle, const Geometry *g1,
+ return 2;
+ return 2;
+ try {
+ bool result;
+ result = g1->crosses(g2);
+ return result;
+ return 2;
+ catch (...)
+ return 2;
+char
+GEOSWithin_r(GEOSContextHandle_t extHandle, const Geometry *g1,
+ return 2;
+ return 2;
+ try {
+ bool result;
+ result = g1->within(g2);
+ return result;
+ return 2;
+ catch (...)
+ return 2;
+// call g1->contains(g2)
+// returns 0 = false
+// 1 = true
+// 2 = error was trapped
+char
+GEOSContains_r(GEOSContextHandle_t extHandle, const Geometry *g1,
+ return 2;
+ return 2;
+ try {
+ bool result;
+ result = g1->contains(g2);
+ return result;
+ return 2;
+ catch (...)
+ return 2;
+char
+GEOSOverlaps_r(GEOSContextHandle_t extHandle, const Geometry *g1,
+ return 2;
+ return 2;
+ try {
+ bool result;
+ result = g1->overlaps(g2);
+ return result;
+ return 2;
+ catch (...)
+ return 2;
+// low-level relate functions
+char
+GEOSRelatePattern_r(GEOSContextHandle_t extHandle, const Geometry *g1,
+ const Geometry *g2, const char *pat)
+ return 2;
+ return 2;
+ try {
+ bool result;
+ std::string s = pat;
+ result = g1->relate(g2,s);
+ return result;
+ return 2;
+ catch (...)
+ return 2;
+char *
+GEOSRelate_r(GEOSContextHandle_t extHandle, const Geometry *g1,
+ return NULL;
+ return NULL;
+ using geos::geom::IntersectionMatrix;
+ try {
+ IntersectionMatrix *im = g1->relate(g2);
+ if (im == NULL)
+ return NULL;
+ std::string s(im->toString());
+ char *result = NULL;
+ result = (char*) std::malloc( s.length() + 1);
+ std::strcpy(result, s.c_str() );
+ delete im;
+ return result;
+ catch (...)
+ return NULL;
+// isValid
+char
+GEOSisValid_r(GEOSContextHandle_t extHandle, const Geometry *g1)
+ return 2;
+ return 2;
+ using geos::operation::valid::IsValidOp;
+ using geos::operation::valid::TopologyValidationError;
+ IsValidOp ivo(g1);
+ bool result;
+ try {
+ result = ivo.isValid();
+ if ( result == 0 )
+ TopologyValidationError *err = ivo.getValidationError();
+ if ( err ) {
+ std::string errmsg = err->toString();
+ handle->NOTICE_MESSAGE("%s", errmsg.c_str());
+ return result;
+ return 2;
+ catch (...)
+ return 2;
+char *
+GEOSisValidReason_r(GEOSContextHandle_t extHandle, const Geometry *g1)
+ return NULL;
+ return NULL;
+ try {
+ bool isvalid = ivo.isValid();
+ if ( ! isvalid )
+ int msglen = 0;
+ int loclen = 0;
+ std::string errmsg = err->getMessage();
+ std::string errloc = err->getCoordinate().toString();
+ msglen = errmsg.length();
+ loclen = errloc.length();
+ result = (char*)std::malloc(msglen + loclen + 3);
+ sprintf(result, "%s [%s]", errmsg.c_str(), errloc.c_str());
+ else {
+ result = strdup( "Valid Geometry" );
+ return result;
+ return NULL;
+ catch (...)
+ return NULL;
+// general purpose
+char
+GEOSEquals_r(GEOSContextHandle_t extHandle, const Geometry *g1,
+ return 2;
+ return 2;
+ try {
+ bool result;
+ result = g1->equals(g2);
+ return result;
+ return 2;
+ catch (...)
+ return 2;
+char
+GEOSEqualsExact_r(GEOSContextHandle_t extHandle, const Geometry *g1,
+ const Geometry *g2, double tolerance)
+ return 2;
+ return 2;
+ try {
+ bool result;
+ result = g1->equalsExact(g2, tolerance);
+ return result;
+ return 2;
+ catch (...)
+ return 2;
+int
+GEOSDistance_r(GEOSContextHandle_t extHandle, const Geometry *g1,
+ const Geometry *g2, double *dist)
+ return 0;
+ return 0;
+ try {
+ *dist = g1->distance(g2);
+ return 1;
+ return 0;
+ catch (...)
+ return 0;
+int
+GEOSArea_r(GEOSContextHandle_t extHandle, const Geometry *g, double *area)
+ return 0;
+ return 0;
+ try {
+ *area = g->getArea();
+ return 1;
+ return 0;
+ catch (...)
+ return 0;
+int
+GEOSLength_r(GEOSContextHandle_t extHandle, const Geometry *g, double *length)
+ return 2;
+ return 0;
+ try {
+ *length = g->getLength();
+ return 1;
+ return 0;
+ catch (...)
+ return 0;
+Geometry *
+GEOSGeomFromWKT_r(GEOSContextHandle_t extHandle, const char *wkt)
+ return NULL;
+ return NULL;
+ CLocalizer clocale;
+ try
+ WKTReader r((GeometryFactory*)handle->geomFactory);
+ const std::string wktstring = std::string(wkt);
+ Geometry *g = r.read(wktstring);
+ return g;
+ return NULL;
+ catch (...)
+ return NULL;
+char *
+GEOSGeomToWKT_r(GEOSContextHandle_t extHandle, const Geometry *g1)
+ return NULL;
+ return NULL;
+ try
+ std::string s = g1->toString();
+ char *result;
+ return result;
+ return NULL;
+ catch (...)
+ return NULL;
+// Remember to free the result!
+unsigned char *
+GEOSGeomToWKB_buf_r(GEOSContextHandle_t extHandle, const Geometry *g,
+ size_t *size)
+ return NULL;
+ return NULL;
+ using geos::io::WKBWriter;
+ try
+ int byteOrder = (int) handle->WKBByteOrder;
+ WKBWriter w(handle->WKBOutputDims, byteOrder);
+ std::ostringstream s(std::ios_base::binary);
+ w.write(*g, s);
+ std::string wkbstring = s.str();
+ size_t len = wkbstring.length();
+ unsigned char *result;
+ result = (unsigned char*) std::malloc(len);
+ std::memcpy(result, wkbstring.c_str(), len);
+ *size = len;
+ return result;
+ return NULL;
+ catch (...)
+ return NULL;
+Geometry *
+GEOSGeomFromWKB_buf_r(GEOSContextHandle_t extHandle, const unsigned char *wkb,
+ size_t size)
+ return NULL;
+ return NULL;
+ using geos::io::WKBReader;
+ try
+ std::string wkbstring = std::string((const char*)wkb, size); // make it binary !
+ WKBReader r(*(GeometryFactory*)handle->geomFactory);
+ std::istringstream s(std::ios_base::binary);
+ s.str(wkbstring);
+ s.seekg(0, std::ios::beg); // rewind reader pointer
+ Geometry *g = r.read(s);
+ return g;
+ return NULL;
+ catch (...)
+ return NULL;
+/* Read/write wkb hex values. Returned geometries are
+ owned by the caller.*/
+unsigned char *
+GEOSGeomToHEX_buf_r(GEOSContextHandle_t extHandle, const Geometry *g,
+ size_t *size)
+ return NULL;
+ return NULL;
+ try
+ w.writeHEX(*g, s);
+ std::string hexstring = s.str();
+ size_t len = hexstring.length();
+ char *result;
+ result = (char*) std::malloc(len);
+ std::memcpy(result, hexstring.c_str(), len);
+ *size = len;
+ return (unsigned char*) result;
+ return NULL;
+ catch (...)
+ return NULL;
+Geometry *
+GEOSGeomFromHEX_buf_r(GEOSContextHandle_t extHandle, const unsigned char *hex,
+ size_t size)
+ return NULL;
+ return NULL;
+ try
+ std::string hexstring = std::string((const char*)hex, size);
+ s.str(hexstring);
+ Geometry *g = r.readHEX(s);
+ return g;
+ return NULL;
+ catch (...)
+ return NULL;
+char
+GEOSisEmpty_r(GEOSContextHandle_t extHandle, const Geometry *g1)
+ return 2;
+ return 2;
+ try
+ return g1->isEmpty();
+ return 2;
+ catch (...)
+ return 2;
+char
+GEOSisSimple_r(GEOSContextHandle_t extHandle, const Geometry *g1)
+ return 2;
+ return 2;
+ try
+ return g1->isSimple();
+ return 2;
+ catch (...)
+ return 2;
+char
+GEOSisRing_r(GEOSContextHandle_t extHandle, const Geometry *g)
+ return 2;
+ return 2;
+ try
+ const LineString *ls = dynamic_cast<const LineString *>(g);
+ if ( ls ) {
+ return (ls->isRing());
+ } else {
+ return 0;
+ return 2;
+ catch (...)
+ return 2;
+//free the result of this
+char *
+GEOSGeomType_r(GEOSContextHandle_t extHandle, const Geometry *g1)
+ return NULL;
+ return NULL;
+ try
+ std::string s = g1->getGeometryType();
+ char *result;
+ return result;
+ return NULL;
+ catch (...)
+ return NULL;
+// Return postgis geometry type index
+int
+GEOSGeomTypeId_r(GEOSContextHandle_t extHandle, const Geometry *g1)
+ return -1;
+ return -1;
+ try
+ return g1->getGeometryTypeId();
+ return -1;
+ catch (...)
+ return -1;
+// GEOS functions that return geometries
+Geometry *
+GEOSEnvelope_r(GEOSContextHandle_t extHandle, const Geometry *g1)
+ return NULL;
+ return NULL;
+ try
+ Geometry *g3 = g1->getEnvelope();
+ return g3;
+ return NULL;
+ catch (...)
+ return NULL;
+Geometry *
+GEOSIntersection_r(GEOSContextHandle_t extHandle, const Geometry *g1,
+ return NULL;
+ return NULL;
+ try
+ GeomAutoPtr g3 = BinaryOp(g1, g2, overlayOp(OverlayOp::opINTERSECTION));
+ return g3.release();
+ //Geometry *g3 = g1->intersection(g2);
+ //return g3;
+ return NULL;
+ catch (...)
+ return NULL;
+Geometry *
+GEOSBuffer_r(GEOSContextHandle_t extHandle, const Geometry *g1, double width,
+ int quadrantsegments)
+ return NULL;
+ return NULL;
+ try
+ Geometry *g3 = g1->buffer(width, quadrantsegments);
+ return g3;
+ return NULL;
+ catch (...)
+ return NULL;
+Geometry *
+GEOSConvexHull_r(GEOSContextHandle_t extHandle, const Geometry *g1)
+ return NULL;
+ return NULL;
+ try
+ Geometry *g3 = g1->convexHull();
+ return g3;
+ return NULL;
+ catch (...)
+ return NULL;
+Geometry *
+GEOSDifference_r(GEOSContextHandle_t extHandle, const Geometry *g1,
+ return NULL;
+ return NULL;
+ try
+ GeomAutoPtr g3 = BinaryOp(g1, g2, overlayOp(OverlayOp::opDIFFERENCE));
+ //Geometry *g3 = g1->difference(g2);
+ //return g3;
+ return NULL;
+ catch (...)
+ return NULL;
+Geometry *
+GEOSBoundary_r(GEOSContextHandle_t extHandle, const Geometry *g1)
+ return NULL;
+ return NULL;
+ try
+ Geometry *g3 = g1->getBoundary();
+ return g3;
+ return NULL;
+ catch (...)
+ return NULL;
+Geometry *
+GEOSSymDifference_r(GEOSContextHandle_t extHandle, const Geometry *g1,
+ return NULL;
+ return NULL;
+ try
+ GeomAutoPtr g3 = BinaryOp(g1, g2, overlayOp(OverlayOp::opSYMDIFFERENCE));
+ //Geometry *g3 = g1->symDifference(g2);
+ //return g3;
+ return NULL;
+ catch (...)
+ return NULL;
+Geometry *
+GEOSUnion_r(GEOSContextHandle_t extHandle, const Geometry *g1,
+ return NULL;
+ return NULL;
+ try
+ GeomAutoPtr g3 = BinaryOp(g1, g2, overlayOp(OverlayOp::opUNION));
+ //Geometry *g3 = g1->Union(g2);
+ //return g3;
+#if VERBOSE_EXCEPTIONS
+ std::ostringstream s;
+ s << "Exception on GEOSUnion with following inputs:" << std::endl;
+ s << "A: "<<g1->toString() << std::endl;
+ s << "B: "<<g2->toString() << std::endl;
+ handle->NOTICE_MESSAGE("%s", s.str().c_str());
+#endif // VERBOSE_EXCEPTIONS
+ return NULL;
+ catch (...)
+ return NULL;
+Geometry *
+GEOSPointOnSurface_r(GEOSContextHandle_t extHandle, const Geometry *g1)
+ return NULL;
+ return NULL;
+ try
+ Geometry *ret = g1->getInteriorPoint();
+ if ( ! ret )
+ const GeometryFactory *gf;
+ gf=handle->geomFactory;
+ return gf->createGeometryCollection();
+ return ret;
+ return NULL;
+ catch (...)
+ return NULL;
+// memory management functions
+void
+GEOSGeom_destroy_r(GEOSContextHandle_t extHandle, Geometry *a)
+ try{
+ delete a;
+ return;
+ return;
+ catch (...)
+ return;
+ return;
+void
+GEOSSetSRID(Geometry *g, int SRID)
+ g->setSRID(SRID);
+void
+GEOSdeleteChar(char *a)
+ try{
+ free(a);
+ catch (...)
+int
+GEOSGetNumCoordinates_r(GEOSContextHandle_t extHandle, const Geometry *g1)
+ return -1;
+ return -1;
+ try{
+ return g1->getNumPoints();
+ return -1;
+ catch (...)
+ return -1;
+ * Return -1 on exception, 0 otherwise.
+ * Converts Geometry to normal form (or canonical form).
+int
+GEOSNormalize_r(GEOSContextHandle_t extHandle, Geometry *g1)
+ return -1;
+ return -1;
+ try{
+ g1->normalize();
+ return -1;
+ catch (...)
+ return -1;
+ return 0;
+int
+GEOSGetNumInteriorRings_r(GEOSContextHandle_t extHandle, const Geometry *g1)
+ return -1;
+ return -1;
+ try{
+ const Polygon *p = dynamic_cast<const Polygon *>(g1);
+ if ( ! p )
+ handle->ERROR_MESSAGE("Argument is not a Polygon");
+ return -1;
+ return p->getNumInteriorRing();
+ return -1;
+ catch (...)
+ return -1;
+// returns -1 on error and 1 for non-multi geometries
+int
+GEOSGetNumGeometries_r(GEOSContextHandle_t extHandle, const Geometry *g1)
+ return -1;
+ return -1;
+ try{
+ return g1->getNumGeometries();
+ return -1;
+ catch (...)
+ return -1;
+ * Call only on GEOMETRYCOLLECTION or MULTI*.
+ * Return a pointer to the internal Geometry.
+const Geometry *
+GEOSGetGeometryN_r(GEOSContextHandle_t extHandle, const Geometry *g1, int n)
+ return NULL;
+ return NULL;
+ using geos::geom::GeometryCollection;
+ try{
+ const GeometryCollection *gc = dynamic_cast<const GeometryCollection *>(g1);
+ if ( ! gc )
+ handle->ERROR_MESSAGE("Argument is not a GeometryCollection");
+ return NULL;
+ return gc->getGeometryN(n);
+ return NULL;
+ catch (...)
+ return NULL;
+ * Call only on polygon
+ * Return a copy of the internal Geometry.
+const Geometry *
+GEOSGetExteriorRing_r(GEOSContextHandle_t extHandle, const Geometry *g1)
+ return NULL;
+ return NULL;
+ try{
+ if ( ! p )
+ handle->ERROR_MESSAGE("Invalid argument (must be a Polygon)");
+ return NULL;
+ return p->getExteriorRing();
+ return NULL;
+ catch (...)
+ return NULL;
+ * Return a pointer to internal storage, do not destroy it.
+const Geometry *
+GEOSGetInteriorRingN_r(GEOSContextHandle_t extHandle, const Geometry *g1, int n)
+ return NULL;
+ return NULL;
+ try{
+ if ( ! p )
+ return NULL;
+ return p->getInteriorRingN(n);
+ return NULL;
+ catch (...)
+ return NULL;
+Geometry *
+GEOSGetCentroid_r(GEOSContextHandle_t extHandle, const Geometry *g)
+ return NULL;
+ return NULL;
+ try{
+ Geometry *ret = g->getCentroid();
+ if ( ! ret )
+ return ret;
+ return NULL;
+ catch (...)
+ return NULL;
+Geometry *
+GEOSGeom_createCollection_r(GEOSContextHandle_t extHandle, int type,
+ Geometry **geoms, unsigned int ngeoms)
+ return NULL;
+ return NULL;
+#ifdef GEOS_DEBUG
+ char buf[256];
+ sprintf(buf, "PostGIS2GEOS_collection: requested type %d, ngeoms: %d",
+ type, ngeoms);
+ handle->NOTICE_MESSAGE("%s", buf);// TODO: Can handle->NOTICE_MESSAGE format that directly?
+#endif
+ try
+ Geometry *g;
+ std::vector<Geometry *> *vgeoms = new std::vector<Geometry *>(geoms, geoms+ngeoms);
+ switch (type)
+ case GEOS_GEOMETRYCOLLECTION:
+ g = gf->createGeometryCollection(vgeoms);
+ break;
+ case GEOS_MULTIPOINT:
+ g = gf->createMultiPoint(vgeoms);
+ break;
+ case GEOS_MULTILINESTRING:
+ g = gf->createMultiLineString(vgeoms);
+ break;
+ case GEOS_MULTIPOLYGON:
+ g = gf->createMultiPolygon(vgeoms);
+ break;
+ default:
+ handle->ERROR_MESSAGE("Unsupported type request for PostGIS2GEOS_collection");
+ g = NULL;
+ if (g==NULL) return NULL;
+ return g;
+ return NULL;
+ catch (...)
+ return NULL;
+Geometry *
+GEOSPolygonize_r(GEOSContextHandle_t extHandle, const Geometry * const * g,
+ unsigned int ngeoms)
+ return NULL;
+ return NULL;
+ using geos::operation::polygonize::Polygonizer;
+ unsigned int i;
+ Geometry *out = NULL;
+ try{
+ // Polygonize
+ Polygonizer plgnzr;
+ for (i=0; i<ngeoms; i++) plgnzr.add(g[i]);
+#if GEOS_DEBUG
+ handle->NOTICE_MESSAGE("geometry vector added to polygonizer");
+#endif
+ std::vector<Polygon *>*polys = plgnzr.getPolygons();
+#if GEOS_DEBUG
+ handle->NOTICE_MESSAGE("output polygons got");
+#endif
+ // We need a vector of Geometry pointers, not
+ // Polygon pointers.
+ // STL vector doesn't allow transparent upcast of this
+ // nature, so we explicitly convert.
+ // (it's just a waste of processor and memory, btw)
+ std::vector<Geometry*> *polyvec =
+ new std::vector<Geometry *>(polys->size());
+ for (i=0; i<polys->size(); i++) (*polyvec)[i] = (*polys)[i];
+ delete polys;
+ out = gf->createGeometryCollection(polyvec);
+ // the above method takes ownership of the passed
+ // vector, so we must *not* delete it
+ return NULL;
+ catch (...)
+ return NULL;
+ return out;
+Geometry *
+GEOSPolygonizer_getCutEdges_r(GEOSContextHandle_t extHandle,
+ const Geometry * const * g, unsigned int ngeoms)
+ return NULL;
+ return NULL;
+ unsigned int i;
+ try{
+ // Polygonize
+#if GEOS_DEBUG
+#endif
+ std::vector<const LineString *>*lines = plgnzr.getCutEdges();
+#if GEOS_DEBUG
+#endif
+ std::vector<Geometry*> *linevec =
+ new std::vector<Geometry *>(lines->size());
+ for (i=0; i<lines->size(); i++) (*linevec)[i] = (*lines)[i]->clone();
+ out = gf->createGeometryCollection(linevec);
+ return NULL;
+ catch (...)
+ return NULL;
+ return out;
+Geometry *
+GEOSLineMerge_r(GEOSContextHandle_t extHandle, const Geometry *g)
+ return NULL;
+ return NULL;
+ using geos::operation::linemerge::LineMerger;
+ unsigned int i;
+ try{
+ // LineMerge
+ LineMerger lmrgr;
+ lmrgr.add(g);
+ std::vector<LineString *>*lines = lmrgr.getMergedLineStrings();
+#if GEOS_DEBUG
+ handle->NOTICE_MESSAGE("output lines got");
+#endif
+ std::vector<Geometry *>*geoms =
+ for (i=0; i<lines->size(); i++) (*geoms)[i] = (*lines)[i];
+ delete lines;
+ out = gf->buildGeometry(geoms);
+ //out = gf->createGeometryCollection(geoms);
+ return NULL;
+ catch (...)
+ return NULL;
+ return out;
+int
+GEOSGetSRID_r(GEOSContextHandle_t extHandle, const Geometry *g1)
+ return 0;
+ return 0;
+ try{
+ return g1->getSRID();
+ return 0;
+ catch (...)
+ return 0;
+const char *
+GEOSversion()
+ //static string version = GEOS_CAPI_VERSION;
+ return GEOS_CAPI_VERSION;
+const char *
+GEOSjtsport()
+ //string version = jtsport();
+ //char *res = strdup(version.c_str());
+ //return res;
+ return GEOS_JTS_PORT;
+char
+GEOSHasZ_r(GEOSContextHandle_t extHandle, const Geometry *g)
+ return -1;
+ return -1;
+ if ( g->isEmpty() ) return false;
+ double az = g->getCoordinate()->z;
+ //handle->ERROR_MESSAGE("ZCoord: %g", az);
+ return FINITE(az);
+int
+GEOS_getWKBOutputDims_r(GEOSContextHandle_t extHandle)
+ return -1;
+ return -1;
+ return handle->WKBOutputDims;
+int
+GEOS_setWKBOutputDims_r(GEOSContextHandle_t extHandle, int newdims)
+ return -1;
+ return -1;
+ if ( newdims < 2 || newdims > 3 )
+ handle->ERROR_MESSAGE("WKB output dimensions out of range 2..3");
+ int olddims = handle->WKBOutputDims;
+ handle->WKBOutputDims = newdims;
+ return olddims;
+int
+GEOS_getWKBByteOrder_r(GEOSContextHandle_t extHandle)
+ return -1;
+ return -1;
+ return handle->WKBByteOrder;
+int
+GEOS_setWKBByteOrder_r(GEOSContextHandle_t extHandle, int byteOrder)
+ return -1;
+ return -1;
+ int oldByteOrder = handle->WKBByteOrder;
+ handle->WKBByteOrder = byteOrder;
+ return oldByteOrder;
+CoordinateSequence *
+GEOSCoordSeq_create_r(GEOSContextHandle_t extHandle, unsigned int size,
+ unsigned int dims)
+ return NULL;
+ return NULL;
+ try {
+ return gf->getCoordinateSequenceFactory()->create(size, dims);
+ return NULL;
+ catch (...)
+ return NULL;
+int
+GEOSCoordSeq_setOrdinate_r(GEOSContextHandle_t extHandle, CoordinateSequence *s,
+ unsigned int idx, unsigned int dim, double val)
+ return 0;
+ return 0;
+ try {
+ s->setOrdinate(static_cast<int>(idx),
+ static_cast<int>(dim), val);
+ return 1;
+ return 0;
+ catch (...)
+ return 0;
+int
+GEOSCoordSeq_setX_r(GEOSContextHandle_t extHandle, CoordinateSequence *s,
+ unsigned int idx, double val)
+ return GEOSCoordSeq_setOrdinate_r(extHandle, s, idx, 0, val);
+int
+GEOSCoordSeq_setY_r(GEOSContextHandle_t extHandle, CoordinateSequence *s,
+ return GEOSCoordSeq_setOrdinate_r(extHandle, s, idx, 1, val);
+int
+GEOSCoordSeq_setZ_r(GEOSContextHandle_t extHandle, CoordinateSequence *s,
+ return GEOSCoordSeq_setOrdinate_r(extHandle, s, idx, 2, val);
+GEOSCoordSeq_clone_r(GEOSContextHandle_t extHandle, const CoordinateSequence *s)
+ return NULL;
+ return NULL;
+ try { return s->clone(); }
+ return NULL;
+ catch (...)
+ return NULL;
+int
+GEOSCoordSeq_getOrdinate_r(GEOSContextHandle_t extHandle, const CoordinateSequence *s,
+ unsigned int idx, unsigned int dim, double *val)
+ return 0;
+ return 0;
+ try {
+ double d = s->getOrdinate(static_cast<int>(idx),
+ static_cast<int>(dim));
+ *val = d;
+ return 1;
+ return 0;
+ catch (...)
+ return 0;
+int
+GEOSCoordSeq_getX_r(GEOSContextHandle_t extHandle, const CoordinateSequence *s,
+ unsigned int idx, double *val)
+ return GEOSCoordSeq_getOrdinate_r(extHandle, s, idx, 0, val);
+int
+GEOSCoordSeq_getY_r(GEOSContextHandle_t extHandle, const CoordinateSequence *s,
+ return GEOSCoordSeq_getOrdinate_r(extHandle, s, idx, 1, val);
+int
+GEOSCoordSeq_getZ_r(GEOSContextHandle_t extHandle, const CoordinateSequence *s,
+ return GEOSCoordSeq_getOrdinate_r(extHandle, s, idx, 2, val);
+int
+GEOSCoordSeq_getSize_r(GEOSContextHandle_t extHandle,
+ const CoordinateSequence *s, unsigned int *size)
+ return 0;
+ return 0;
+ try {
+ int sz = s->getSize();
+ *size = static_cast<unsigned int>(sz);
+ return 1;
+ return 0;
+ catch (...)
+ return 0;
+int
+GEOSCoordSeq_getDimensions_r(GEOSContextHandle_t extHandle,
+ const CoordinateSequence *s, unsigned int *dims)
+ return 0;
+ return 0;
+ try {
+ unsigned int dm = s->getDimension();
+ *dims = dm;
+ return 1;
+ return 0;
+ catch (...)
+ return 0;
+void
+GEOSCoordSeq_destroy_r(GEOSContextHandle_t extHandle, CoordinateSequence *s)
+ try{
+ delete s;
+ return;
+ return;
+ catch (...)
+ return;
+ return;
+const CoordinateSequence *
+GEOSGeom_getCoordSeq_r(GEOSContextHandle_t extHandle, const Geometry *g)
+ return NULL;
+ return NULL;
+ using geos::geom::Point;
+ try
+ if ( ls )
+ return ls->getCoordinatesRO();
+ const Point *p = dynamic_cast<const Point *>(g);
+ if ( p )
+ return p->getCoordinatesRO();
+ handle->ERROR_MESSAGE("Geometry must be a Point or LineString");
+ return NULL;
+ return NULL;
+ catch (...)
+ return NULL;
+Geometry *
+GEOSGeom_createPoint_r(GEOSContextHandle_t extHandle, CoordinateSequence *cs)
+ return NULL;
+ return NULL;
+ try {
+ return gf->createPoint(cs);
+ return NULL;
+ catch (...)
+ return NULL;
+Geometry *
+GEOSGeom_createLinearRing_r(GEOSContextHandle_t extHandle,
+ CoordinateSequence *cs)
+ return NULL;
+ return NULL;
+ try {
+ return gf->createLinearRing(cs);
+ return NULL;
+ catch (...)
+ return NULL;
+Geometry *
+GEOSGeom_createLineString_r(GEOSContextHandle_t extHandle,
+ return NULL;
+ return NULL;
+ try {
+ return gf->createLineString(cs);
+ return NULL;
+ catch (...)
+ return NULL;
+Geometry *
+GEOSGeom_createPolygon_r(GEOSContextHandle_t extHandle, Geometry *shell,
+ Geometry **holes, unsigned int nholes)
+ return NULL;
+ return NULL;
+ using geos::geom::LinearRing;
+ try
+ std::vector<Geometry *> *vholes =
+ new std::vector<Geometry *>(holes, holes+nholes);
+ LinearRing *nshell = dynamic_cast<LinearRing *>(shell);
+ if ( ! nshell )
+ handle->ERROR_MESSAGE("Shell is not a LinearRing");
+ return NULL;
+ return gf->createPolygon(nshell, vholes);
+ return NULL;
+ catch (...)
+ return NULL;
+Geometry *
+GEOSGeom_clone_r(GEOSContextHandle_t extHandle, const Geometry *g)
+ return NULL;
+ return NULL;
+ try { return g->clone(); }
+ return NULL;
+ catch (...)
+ return NULL;
+int
+GEOSGeom_getDimensions_r(GEOSContextHandle_t extHandle, const Geometry *g)
+ return 0;
+ return 0;
+ try {
+ if ( ls )
+ return ls->getCoordinatesRO()->getDimension();
+ if ( p )
+ return p->getCoordinatesRO()->getDimension();
+ const Polygon *poly = dynamic_cast<const Polygon *>(g);
+ if ( poly )
+ return GEOSGeom_getDimensions_r(extHandle, poly->getExteriorRing());
+ const GeometryCollection *coll =
+ dynamic_cast<const GeometryCollection *>(g);
+ if ( coll )
+ if ( coll->isEmpty() ) return 0;
+ return GEOSGeom_getDimensions_r(extHandle, coll->getGeometryN(0));
+ handle->ERROR_MESSAGE("Unknown geometry type");
+ return 0;
+ return 0;
+ catch (...)
+ return 0;
+Geometry *
+GEOSSimplify_r(GEOSContextHandle_t extHandle, const Geometry *g1,
+ double tolerance)
+ return NULL;
+ return NULL;
+ using namespace geos::simplify;
+ try
+ Geometry::AutoPtr g(DouglasPeuckerSimplifier::simplify(
+ g1, tolerance));
+ return g.release();
+ return NULL;
+ catch (...)
+ return NULL;
+Geometry *
+GEOSTopologyPreserveSimplify_r(GEOSContextHandle_t extHandle,
+ const Geometry *g1, double tolerance)
+ return NULL;
+ return NULL;
+ try
+ Geometry::AutoPtr g(TopologyPreservingSimplifier::simplify(
+ g1, tolerance));
+ return NULL;
+ catch (...)
+ return NULL;
+/* WKT Reader */
+WKTReader *
+GEOSWKTReader_create_r(GEOSContextHandle_t extHandle)
+ return NULL;
+ return NULL;
+ using geos::io::WKTReader;
+ try
+ return new WKTReader((GeometryFactory*)handle->geomFactory);
+ return NULL;
+ catch (...)
+ return NULL;
+void
+GEOSWKTReader_destroy_r(GEOSContextHandle_t extHandle, WKTReader *reader)
+ try
+ delete reader;
+ return;
+ return;
+ catch (...)
+ return;
+ return;
+Geometry*
+GEOSWKTReader_read_r(GEOSContextHandle_t extHandle, WKTReader *reader,
+ const char *wkt)
+ return NULL;
+ return NULL;
+ try
+ Geometry *g = reader->read(wktstring);
+ return g;
+ return NULL;
+ catch (...)
+ return NULL;
+/* WKT Writer */
+WKTWriter *
+GEOSWKTWriter_create_r(GEOSContextHandle_t extHandle)
+ return NULL;
+ return NULL;
+ using geos::io::WKTWriter;
+ try
+ return new WKTWriter();
+ return NULL;
+ catch (...)
+ return NULL;
+void
+GEOSWKTWriter_destroy_r(GEOSContextHandle_t extHandle, WKTWriter *Writer)
+ try
+ delete Writer;
+ return;
+ return;
+ catch (...)
+ return;
+ return;
+char*
+GEOSWKTWriter_write_r(GEOSContextHandle_t extHandle, WKTWriter *writer,
+ const Geometry *geom)
+ return NULL;
+ return NULL;
+ try
+ std::string s = writer->write(geom);
+ return result;
+ catch (...)
+ return NULL;
+/* WKB Reader */
+WKBReader *
+GEOSWKBReader_create_r(GEOSContextHandle_t extHandle)
+ return NULL;
+ return NULL;
+ try
+ return new WKBReader(*(GeometryFactory*)handle->geomFactory);
+ catch (...)
+ return NULL;
+void
+GEOSWKBReader_destroy_r(GEOSContextHandle_t extHandle, WKBReader *reader)
+ try
+ delete reader;
+ return;
+ return;
+ catch (...)
+ return;
+ return;
+Geometry*
+GEOSWKBReader_read_r(GEOSContextHandle_t extHandle, WKBReader *reader,
+ const unsigned char *wkb, size_t size)
+ return NULL;
+ return NULL;
+ try
+ s.str(wkbstring);
+ Geometry *g = reader->read(s);
+ return g;
+ catch (...)
+ return NULL;
+Geometry*
+GEOSWKBReader_readHEX_r(GEOSContextHandle_t extHandle, WKBReader *reader,
+ const unsigned char *hex, size_t size)
+ return NULL;
+ return NULL;
+ try
+ s.str(hexstring);
+ Geometry *g = reader->readHEX(s);
+ return g;
+ catch (...)
+ return NULL;
+/* WKB Writer */
+WKBWriter *
+GEOSWKBWriter_create_r(GEOSContextHandle_t extHandle)
+ return NULL;
+ return NULL;
+ try
+ return new WKBWriter();
+ catch (...)
+ return NULL;
+void
+GEOSWKBWriter_destroy_r(GEOSContextHandle_t extHandle, WKBWriter *Writer)
+ try
+ delete Writer;
+ return;
+ return;
+ catch (...)
+ return;
+ return;
+/* The owner owns the result */
+unsigned char*
+GEOSWKBWriter_write_r(GEOSContextHandle_t extHandle, WKBWriter *writer,
+ const Geometry *geom, size_t *size)
+ return NULL;
+ return NULL;
+ try
+ writer->write(*geom, s);
+ unsigned char *result = NULL;
+ *size = len;
+ return result;
+ catch (...)
+ return NULL;
+unsigned char*
+GEOSWKBWriter_writeHEX_r(GEOSContextHandle_t extHandle, WKBWriter *writer,
+ return NULL;
+ return NULL;
+ try
+ writer->writeHEX(*geom, s);
+ const size_t len = wkbstring.length();
+ *size = len;
+ return result;
+ catch (...)
+ return NULL;
+int
+GEOSWKBWriter_getOutputDimension_r(GEOSContextHandle_t extHandle,
+ const GEOSWKBWriter* writer)
+ return 0;
+ return 0;
+ try
+ return writer->getOutputDimension();
+ catch (...)
+ return 0;
+void
+GEOSWKBWriter_setOutputDimension_r(GEOSContextHandle_t extHandle,
+ GEOSWKBWriter* writer, int newDimension)
+ return;
+ return;
+ try
+ return writer->setOutputDimension(newDimension);
+ catch (...)
+int
+GEOSWKBWriter_getByteOrder_r(GEOSContextHandle_t extHandle,
+ return 0;
+ return 0;
+ try
+ return writer->getByteOrder();
+ catch (...)
+ return 0;
+void
+GEOSWKBWriter_setByteOrder_r(GEOSContextHandle_t extHandle,
+ GEOSWKBWriter* writer, int newByteOrder)
+ return;
+ return;
+ try
+ return writer->setByteOrder(newByteOrder);
+ catch (...)
+char
+GEOSWKBWriter_getIncludeSRID_r(GEOSContextHandle_t extHandle,
+ return NULL;
+ return NULL;
+ try
+ return writer->getIncludeSRID();
+ catch (...)
+ return NULL;
+void
+GEOSWKBWriter_setIncludeSRID_r(GEOSContextHandle_t extHandle,
+ GEOSWKBWriter* writer, const char newIncludeSRID)
+ return;
+ return;
+ try
+ writer->setIncludeSRID(newIncludeSRID);
+ catch (...)
+// Prepared Geometry
+const geos::geom::prep::PreparedGeometry*
+GEOSPrepare_r(GEOSContextHandle_t extHandle, const Geometry *g)
+ const geos::geom::prep::PreparedGeometry* prep = NULL;
+ return NULL;
+ return NULL;
+ try
+ prep = geos::geom::prep::PreparedGeometryFactory::prepare(g);
+ catch (...)
+ return prep;
+void
+GEOSPreparedGeom_destroy_r(GEOSContextHandle_t extHandle,
+ const geos::geom::prep::PreparedGeometry *a)
+ try
+ delete a;
+ return;
+ return;
+ catch (...)
+ return;
+ return;
+char
+GEOSPreparedContains_r(GEOSContextHandle_t extHandle,
+ const geos::geom::prep::PreparedGeometry *pg1,
+ return 2;
+ return 2;
+ try
+ bool result;
+ result = pg1->contains(g2);
+ return result;
+ return 2;
+ catch (...)
+ return 2;
+char
+GEOSPreparedContainsProperly_r(GEOSContextHandle_t extHandle,
+ return 2;
+ return 2;
+ try
+ bool result;
+ result = pg1->containsProperly(g2);
+ return result;
+ return 2;
+ catch (...)
+ return 2;
+char
+GEOSPreparedCovers_r(GEOSContextHandle_t extHandle,
+ return 2;
+ return 2;
+ try
+ bool result;
+ result = pg1->covers(g2);
+ return result;
+ return 2;
+ catch (...)
+ return 2;
+char
+GEOSPreparedIntersects_r(GEOSContextHandle_t extHandle,
+ return 2;
+ return 2;
+ try
+ bool result;
+ result = pg1->intersects(g2);
+ return result;
+ return 2;
+ catch (...)
+ return 2;
+} //extern "C"
More information about the geos-commits
