[geos-commits] r2612 - trunk/capi
svn_geos at osgeo.org
Wed Jul 15 14:55:23 EDT 2009
Author: pramsey
Date: 2009-07-15 14:55:23 -0400 (Wed, 15 Jul 2009)
New Revision: 2612
trunk/capi/geos_c.cpp
trunk/capi/geos_c.h.in
trunk/capi/geos_ts_c.cpp
Add STRtree support to the C API (#278) Schuyler Erle
Modified: trunk/capi/geos_c.cpp
--- trunk/capi/geos_c.cpp 2009-07-15 18:53:02 UTC (rev 2611)
+++ trunk/capi/geos_c.cpp 2009-07-15 18:55:23 UTC (rev 2612)
@@ -16,6 +16,7 @@
#include <geos/geom/prep/PreparedGeometryFactory.h>
+#include <geos/index/strtree/STRtree.h>
#include <geos/io/WKTReader.h>
#include <geos/io/WKBReader.h>
#include <geos/io/WKTWriter.h>
@@ -29,6 +30,7 @@
#define GEOSGeometry geos::geom::Geometry
#define GEOSPreparedGeometry geos::geom::prep::PreparedGeometry
#define GEOSCoordSequence geos::geom::CoordinateSequence
+#define GEOSSTRtree geos::index::strtree::STRtree
#define GEOSWKTReader_t geos::io::WKTReader
#define GEOSWKTWriter_t geos::io::WKTWriter
#define GEOSWKBReader_t geos::io::WKBReader
@@ -64,11 +66,12 @@
using geos::io::WKBWriter;
using geos::io::CLocalizer;
+using geos::index::strtree::STRtree;
using geos::operation::overlay::OverlayOp;
using geos::operation::overlay::overlayOp;
using geos::operation::geounion::CascadedPolygonUnion;
typedef std::auto_ptr<Geometry> GeomAutoPtr;
//## GLOBALS ################################################
@@ -835,4 +838,49 @@
return GEOSPreparedIntersects_r( handle, pg1, g2 );
+STRtree *
+GEOSSTRtree_create (size_t nodeCapacity)
+ return GEOSSTRtree_create_r( handle, nodeCapacity );
+void
+GEOSSTRtree_insert (geos::index::strtree::STRtree *tree,
+ const geos::geom::Geometry *g,
+ void *item)
+ GEOSSTRtree_insert_r( handle, tree, g, item );
+void
+GEOSSTRtree_query (geos::index::strtree::STRtree *tree,
+ GEOSQueryCallback cb,
+ void *userdata)
+ GEOSSTRtree_query_r( handle, tree, g, cb, userdata );
+void
+GEOSSTRtree_iterate(geos::index::strtree::STRtree *tree,
+ GEOSQueryCallback callback,
+ void *userdata)
+ GEOSSTRtree_iterate_r( handle, tree, callback, userdata );
+char
+GEOSSTRtree_remove (geos::index::strtree::STRtree *tree,
+ void *item)
+ return GEOSSTRtree_remove_r( handle, tree, g, item );
+void
+GEOSSTRtree_destroy (geos::index::strtree::STRtree *tree)
+ GEOSSTRtree_destroy_r( handle, tree );
} /* extern "C" */
Modified: trunk/capi/geos_c.h.in
--- trunk/capi/geos_c.h.in 2009-07-15 18:53:02 UTC (rev 2611)
+++ trunk/capi/geos_c.h.in 2009-07-15 18:55:23 UTC (rev 2612)
@@ -100,6 +100,7 @@
typedef struct GEOSGeom_t GEOSGeometry;
typedef struct GEOSPrepGeom_t GEOSPreparedGeometry;
typedef struct GEOSCoordSeq_t GEOSCoordSequence;
+typedef struct GEOSSTRtree_t GEOSSTRtree;
#endif
/* Those are compatibility definitions for source compatibility
@@ -132,6 +133,8 @@
typedef struct GEOSContextHandle_HS *GEOSContextHandle_t;
+typedef void (*GEOSQueryCallback)(void *item, void *userdata);
* Initialization, cleanup, version
@@ -576,6 +579,57 @@
+ * STRtree functions
+ * GEOSGeometry ownership is retained by caller
+extern GEOSSTRtree GEOS_DLL *GEOSSTRtree_create(size_t nodeCapacity);
+extern void GEOS_DLL GEOSSTRtree_insert(GEOSSTRtree *tree,
+ const GEOSGeometry *g,
+ void *item);
+extern void GEOS_DLL GEOSSTRtree_query(GEOSSTRtree *tree,
+ void *userdata);
+extern void GEOS_DLL GEOSSTRtree_iterate(GEOSSTRtree *tree,
+ void *userdata);
+extern char GEOS_DLL GEOSSTRtree_remove(GEOSSTRtree *tree,
+ void *item);
+extern void GEOS_DLL GEOSSTRtree_destroy(GEOSSTRtree *tree);
+extern GEOSSTRtree GEOS_DLL *GEOSSTRtree_create_r(
+ GEOSContextHandle_t handle,
+ size_t nodeCapacity);
+extern void GEOS_DLL GEOSSTRtree_insert_r(GEOSContextHandle_t handle,
+ GEOSSTRtree *tree,
+ void *item);
+extern void GEOS_DLL GEOSSTRtree_query_r(GEOSContextHandle_t handle,
+ void *userdata);
+extern void GEOS_DLL GEOSSTRtree_iterate_r(GEOSContextHandle_t handle,
+ void *userdata);
+extern char GEOS_DLL GEOSSTRtree_remove_r(GEOSContextHandle_t handle,
+ void *item);
+extern void GEOS_DLL GEOSSTRtree_destroy_r(GEOSContextHandle_t handle,
+ GEOSSTRtree *tree);
* Unary predicate - return 2 on exception, 1 on true, 0 on false
Modified: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp 2009-07-15 18:53:02 UTC (rev 2611)
+++ trunk/capi/geos_ts_c.cpp 2009-07-15 18:55:23 UTC (rev 2612)
@@ -31,6 +31,9 @@
#include <geos/geom/GeometryFactory.h>
#include <geos/geom/CoordinateSequenceFactory.h>
#include <geos/geom/IntersectionMatrix.h>
+#include <geos/geom/Envelope.h>
+#include <geos/index/ItemVisitor.h>
@@ -66,6 +69,7 @@
@@ -112,6 +116,19 @@
int initialized;
} GEOSContextHandleInternal_t;
+// CAPI_ItemVisitor is used internally by the CAPI STRtree
+// wrappers. It's defined here just to keep it out of the
+// extern "C" block.
+class CAPI_ItemVisitor : public geos::index::ItemVisitor {
+ GEOSQueryCallback callback;
+ void *userdata;
+ public:
+ CAPI_ItemVisitor (GEOSQueryCallback cb, void *ud)
+ : ItemVisitor(), callback(cb), userdata(ud) {};
+ void visitItem (void *item) { callback(item, userdata); };
//## PROTOTYPES #############################################
extern "C" const char GEOS_DLL *GEOSjtsport();
@@ -4022,5 +4039,265 @@
return 2;
+// STRtree
+geos::index::strtree::STRtree *
+GEOSSTRtree_create_r(GEOSContextHandle_t extHandle,
+ if ( 0 == extHandle )
+ return 0;
+ GEOSContextHandleInternal_t *handle = 0;
+ handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
+ if ( 0 == handle->initialized )
+ return 0;
+ geos::index::strtree::STRtree *tree = 0;
+ try
+ tree = new geos::index::strtree::STRtree(nodeCapacity);
+ catch (const std::exception &e)
+ handle->ERROR_MESSAGE("%s", e.what());
+ catch (...)
+ handle->ERROR_MESSAGE("Unknown exception thrown");
+ return tree;
+void
+GEOSSTRtree_insert_r(GEOSContextHandle_t extHandle,
+ geos::index::strtree::STRtree *tree,
+ void *item)
+ assert(tree != 0);
+ assert(g != 0);
+ try
+ tree->insert(g->getEnvelopeInternal(), item);
+ return;
+ return;
+ catch (...)
+ return;
+ return;
+void
+GEOSSTRtree_query_r(GEOSContextHandle_t extHandle,
+ void *userdata)
+ assert(g != 0);
+ assert(callback != 0);
+ try
+ CAPI_ItemVisitor visitor(callback, userdata);
+ tree->query(g->getEnvelopeInternal(), visitor);
+ return;
+ return;
+ catch (...)
+ return;
+ return;
+void
+GEOSSTRtree_iterate_r(GEOSContextHandle_t extHandle,
+ void *userdata)
+ try
+ tree->iterate(visitor);
+ return;
+ return;
+ catch (...)
+ return;
+ return;
+char
+GEOSSTRtree_remove_r(GEOSContextHandle_t extHandle,
+ void *item)
+ assert(0 != tree);
+ assert(0 != g);
+ return 2;
+ return 2;
+ try
+ bool result = tree->remove(g->getEnvelopeInternal(), item);
+ return result;
+ catch (...)
+ return 2;
+void
+GEOSSTRtree_destroy_r(GEOSContextHandle_t extHandle,
+ geos::index::strtree::STRtree *tree)
+ try
+ delete tree;
+ return;
+ return;
+ catch (...)
+ return;
+ return;
} /* extern "C" */
More information about the geos-commits
