[geos-commits] r2613 - in trunk/swig: . ruby
svn_geos at osgeo.org
Wed Jul 15 14:56:30 EDT 2009
Author: pramsey
Date: 2009-07-15 14:56:30 -0400 (Wed, 15 Jul 2009)
New Revision: 2613
trunk/swig/geos.i.in
trunk/swig/ruby/ruby.i
Add PreparedGeometry and STRtree support to SWIG (#279) Schuyler Erle
Modified: trunk/swig/geos.i.in
--- trunk/swig/geos.i.in 2009-07-15 18:55:23 UTC (rev 2612)
+++ trunk/swig/geos.i.in 2009-07-15 18:56:30 UTC (rev 2613)
@@ -950,6 +950,126 @@
%clear GeosCoordinateSequence *s;
+// === Prepared Geometry ===
+typedef void GeosPreparedGeometry;
+%rename (Prepared) GeosPreparedGeometry;
+class GeosPreparedGeometry
+public:
+%extend
+ GeosPreparedGeometry(const GeosGeometry *source)
+ const GEOSPreparedGeometry *prep = GEOSPrepare((const GEOSGeometry *)source);
+ if(prep == NULL)
+ throw std::runtime_error(message);
+ return (GeosPreparedGeometry *) prep;
+ ~GeosPreparedGeometry()
+ GEOSPreparedGeometry *prep = (GEOSPreparedGeometry *) self;
+ return GEOSPreparedGeom_destroy(prep);
+ bool contains (const GeosGeometry* other)
+ GEOSGeom otherGeom = (GEOSGeom) other;
+ return checkBoolResult(GEOSPreparedContains(prep, otherGeom));
+ bool containsProperly(const GeosGeometry* other)
+ return checkBoolResult(GEOSPreparedContainsProperly(prep, otherGeom));
+ bool covers (const GeosGeometry* other)
+ return checkBoolResult(GEOSPreparedCovers(prep, otherGeom));
+ bool intersects (const GeosGeometry* other)
+ return checkBoolResult(GEOSPreparedIntersects(prep, otherGeom));
+// === STRtree ===
+typedef void GeosSTRtree;
+/* GeosIndexItem typedef'd here so it can be %typemap(typecheck)'d
+ as a native object by each language specially */
+typedef void *GeosIndexItem;
+typedef GEOSQueryCallback GeosQueryCallback;
+%rename (STRtree) GeosSTRtree;
+class GeosSTRtree
+public:
+%extend
+ %typemap(default) int nodeCapacity {
+ $1 = 10;
+ GeosSTRtree(int nodeCapacity)
+ GEOSSTRtree *tree = GEOSSTRtree_create(nodeCapacity);
+ if(tree == NULL)
+ return (GeosSTRtree *) tree;
+ ~GeosSTRtree()
+ GEOSSTRtree *tree = (GEOSSTRtree *) self;
+ return GEOSSTRtree_destroy(tree);
+ void insert (const GeosGeometry* g, GeosIndexItem item)
+ const GEOSGeometry *geom = (const GEOSGeometry *) g;
+ GEOSSTRtree_insert(tree, geom, item);
+ void remove (const GeosGeometry* g, GeosIndexItem item)
+ GEOSSTRtree_remove(tree, geom, item);
+ void query (const GeosGeometry* g, GeosQueryCallback callback,
+ GeosIndexItem accumulator)
+ GEOSSTRtree_query(tree, geom, callback, accumulator);
+ void iterate (GeosQueryCallback callback, GeosIndexItem accumulator)
+ GEOSSTRtree_iterate(tree, callback, accumulator);
// === Input/Output ===
/* This typemap allows the scripting language to pass in buffers
Modified: trunk/swig/ruby/ruby.i
--- trunk/swig/ruby/ruby.i 2009-07-15 18:55:23 UTC (rev 2612)
+++ trunk/swig/ruby/ruby.i 2009-07-15 18:56:30 UTC (rev 2613)
@@ -104,3 +104,73 @@
free((void*) $1);
+// GeosPreparedGeometry
+// Use predicates to make the ruby code nicer - so disjoint?
+%rename("contains_properly?") GeosPreparedGeometry::containsProperly;
+%predicate GeosPreparedGeometry::contains;
+%predicate GeosPreparedGeometry::intersects;
+%predicate GeosPreparedGeometry::covers;
+// GeosSTRtree
+%rename("each") GeosSTRtree::iterate;
+%typemap(in) GeosIndexItem
+ $1 = (GeosIndexItem) $input;
+/* accumulator will be blissfully unused because
+ * Ruby supports closures, more or less */
+%typemap(in,numinputs=0) (GeosIndexItem accumulator)
+ $1 = (GeosIndexItem) Qnil;
+/* typecheck GeosIndexItem and make sure it's really a VALUE */
+%typemap(typecheck) GeosIndexItem
+ $1 = (TYPE($input) & T_MASK) ? 1 : 0;
+/* always call the provided block as the query callback */
+%typemap(in,numinputs=0) GeosQueryCallback
+ $1 = GeosSTRtree_query_callback;
+%typemap(typecheck) GeosQueryCallback
+ /* SWIG throws a warning if we don't do this */
+ $1 = 1;
+ /* this callback yields the data item to the block */
+ static void GeosSTRtree_query_callback (void *data, void *nothing) {
+ if (rb_block_given_p()) {
+ rb_yield((VALUE) data);
+/* assuming that GeosIndexItems are all VALUEs (since this gets tested
+ * on typemap(in)), mark them during the mark phase of GC to hang on to them */
+ static void GeosSTRtree_mark_item (void *data, void *nothing)
+ if ((VALUE) data != Qnil) {
+ rb_gc_mark((VALUE)data);
+ static void mark_GeosSTRtree(void *self)
+ GEOSSTRtree_iterate(tree, GeosSTRtree_mark_item, NULL);
+%markfunc GeosSTRtree "mark_GeosSTRtree";
More information about the geos-commits
