[geos-commits] r2299 - trunk/capi
svn_geos at osgeo.org
Mon Mar 23 19:50:09 EDT 2009
Author: mloskot
Date: 2009-03-23 19:50:08 -0400 (Mon, 23 Mar 2009)
New Revision: 2299
trunk/capi/geos_ts_c.cpp
capi/geos_ts_c.cpp: refactoring, use single return expression per function, added assert() to test against nullptr where it is forbidden.
Modified: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp 2009-03-23 23:29:54 UTC (rev 2298)
+++ trunk/capi/geos_ts_c.cpp 2009-03-23 23:50:08 UTC (rev 2299)
@@ -3535,7 +3535,7 @@
try
- return writer->setOutputDimension(newDimension);
+ writer->setOutputDimension(newDimension);
catch (...)
@@ -3590,7 +3590,7 @@
try
- return writer->setByteOrder(newByteOrder);
+ writer->setByteOrder(newByteOrder);
catch (...)
@@ -3664,17 +3664,18 @@
if ( 0 == extHandle )
- return NULL;
+ return 0;
GEOSContextHandleInternal_t *handle = 0;
handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
if ( 0 == handle->initialized )
- return NULL;
+ return 0;
- const geos::geom::prep::PreparedGeometry* prep = NULL;
+ const geos::geom::prep::PreparedGeometry* prep = 0;
try
prep = geos::geom::prep::PreparedGeometryFactory::prepare(g);
@@ -3733,8 +3734,12 @@
char
-GEOSPreparedContains_r(GEOSContextHandle_t extHandle, const geos::geom::prep::PreparedGeometry *pg1, const Geometry *g2)
+GEOSPreparedContains_r(GEOSContextHandle_t extHandle,
+ const geos::geom::prep::PreparedGeometry *pg, const Geometry *g)
+ assert(0 != pg);
+ assert(0 != g);
return 2;
@@ -3749,25 +3754,28 @@
try
- bool result;
- result = pg1->contains(g2);
+ bool result = pg->contains(g);
return result;
catch (const std::exception &e)
handle->ERROR_MESSAGE("%s", e.what());
- return 2;
catch (...)
handle->ERROR_MESSAGE("Unknown exception thrown");
- return 2;
+ return 2;
char
-GEOSPreparedContainsProperly_r(GEOSContextHandle_t extHandle, const geos::geom::prep::PreparedGeometry *pg1, const Geometry *g2)
+GEOSPreparedContainsProperly_r(GEOSContextHandle_t extHandle,
+ assert(0 != pg);
+ assert(0 != g);
return 2;
@@ -3782,25 +3790,28 @@
try
- bool result;
- result = pg1->containsProperly(g2);
+ bool result = pg->containsProperly(g);
return result;
- return 2;
catch (...)
- return 2;
+ return 2;
char
-GEOSPreparedCovers_r(GEOSContextHandle_t extHandle, const geos::geom::prep::PreparedGeometry *pg1, const Geometry *g2)
+GEOSPreparedCovers_r(GEOSContextHandle_t extHandle,
+ assert(0 != pg);
+ assert(0 != g);
return 2;
@@ -3815,25 +3826,28 @@
try
- bool result;
- result = pg1->covers(g2);
+ bool result = pg->covers(g);
return result;
- return 2;
catch (...)
- return 2;
+ return 2;
char
-GEOSPreparedIntersects_r(GEOSContextHandle_t extHandle, const geos::geom::prep::PreparedGeometry *pg1, const Geometry *g2)
+GEOSPreparedIntersects_r(GEOSContextHandle_t extHandle,
+ assert(0 != pg);
+ assert(0 != g);
return 2;
@@ -3848,20 +3862,19 @@
try
- bool result;
- result = pg1->intersects(g2);
+ bool result = pg->intersects(g);
return result;
- return 2;
catch (...)
- return 2;
+ return 2;
} /* extern "C" */
More information about the geos-commits
