[geos-commits] r2300 - trunk/capi
svn_geos at osgeo.org
Mon Mar 23 20:19:33 EDT 2009
Author: mloskot
Date: 2009-03-23 20:19:33 -0400 (Mon, 23 Mar 2009)
New Revision: 2300
trunk/capi/geos_c.cpp
trunk/capi/geos_c.h.in
trunk/capi/geos_ts_c.cpp
Fixed GEOSSetSRID_r missing, GEOSSetSRID duplicated (Ticket #242). A little of refactoring.
Modified: trunk/capi/geos_c.cpp
--- trunk/capi/geos_c.cpp 2009-03-23 23:50:08 UTC (rev 2299)
+++ trunk/capi/geos_c.cpp 2009-03-24 00:19:33 UTC (rev 2300)
@@ -455,11 +455,17 @@
int
-GEOSGetSRID(const Geometry *g1)
+GEOSGetSRID(const Geometry *g)
- return GEOSGetSRID_r( handle, g1 );
+ return GEOSGetSRID_r( handle, g );
+void
+GEOSSetSRID(Geometry *g, int srid)
+ GEOSSetSRID_r( handle, g, srid );
char
GEOSHasZ(const Geometry *g)
Modified: trunk/capi/geos_c.h.in
--- trunk/capi/geos_c.h.in 2009-03-23 23:50:08 UTC (rev 2299)
+++ trunk/capi/geos_c.h.in 2009-03-24 00:19:33 UTC (rev 2300)
@@ -591,13 +591,14 @@
/* Return 0 on exception */
extern int GEOS_DLL GEOSGetSRID(const GEOSGeometry* g1);
-extern void GEOS_DLL GEOSSetSRID(GEOSGeometry* g, int SRID);
extern int GEOS_DLL GEOSGetSRID_r(GEOSContextHandle_t handle,
+extern void GEOS_DLL GEOSSetSRID(GEOSGeometry* g, int srid);
+extern void GEOS_DLL GEOSSetSRID_r(GEOSContextHandle_t handle,
+ GEOSGeometry* g, int srid);
/* May be called on all geometries in GEOS 3.x, returns -1 on error and 1
* for non-multi geometries. Older GEOS versions only accept
* GeometryCollections or Multi* geometries here, and are likely to crash
Modified: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp 2009-03-23 23:50:08 UTC (rev 2299)
+++ trunk/capi/geos_ts_c.cpp 2009-03-24 00:19:33 UTC (rev 2300)
@@ -1578,17 +1578,6 @@
-void
-GEOSSetSRID(Geometry *g, int SRID)
- assert(0 != g);
- if (0 != g)
- g->setSRID(SRID);
int
GEOSGetNumCoordinates_r(GEOSContextHandle_t extHandle, const Geometry *g1)
@@ -2125,7 +2114,7 @@
#endif
std::vector<Geometry *>*geoms = new std::vector<Geometry *>(lines->size());
- for (int i = 0; i < lines->size(); ++i)
+ for (std::size_t i = 0; i < lines->size(); ++i)
(*geoms)[i] = (*lines)[i];
@@ -2151,8 +2140,10 @@
int
-GEOSGetSRID_r(GEOSContextHandle_t extHandle, const Geometry *g1)
+GEOSGetSRID_r(GEOSContextHandle_t extHandle, const Geometry *g)
+ assert(0 != g);
if ( 0 == extHandle )
return 0;
@@ -2167,7 +2158,7 @@
try
- return g1->getSRID();
+ return g->getSRID();
catch (const std::exception &e)
@@ -2181,6 +2172,35 @@
return 0;
+void
+GEOSSetSRID_r(GEOSContextHandle_t extHandle, Geometry *g, int srid)
+ assert(0 != g);
+ if ( 0 == extHandle )
+ return;
+ GEOSContextHandleInternal_t *handle = 0;
+ handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
+ if ( 0 != handle->initialized && 0 != g)
+ try
+ g->setSRID(srid);
+ catch (const std::exception &e)
+ handle->ERROR_MESSAGE("%s", e.what());
+ catch (...)
+ handle->ERROR_MESSAGE("Unknown exception thrown");
const char* GEOSversion()
return GEOS_CAPI_VERSION;
More information about the geos-commits
