[geos-commits] r2301 - trunk/capi
svn_geos at osgeo.org svn_geos at osgeo.org
Mon Mar 23 20:30:58 EDT 2009
Author: mloskot
Date: 2009-03-23 20:30:58 -0400 (Mon, 23 Mar 2009)
New Revision: 2301
   trunk/capi/geos_c.cpp
   trunk/capi/geos_c.h.in
   trunk/capi/geos_ts_c.cpp
REVERTED r2299: Fixed GEOSSetSRID_r missing, GEOSSetSRID duplicated (Ticket #242). A little of refactoring.
Modified: trunk/capi/geos_c.cpp
--- trunk/capi/geos_c.cpp	2009-03-24 00:19:33 UTC (rev 2300)
+++ trunk/capi/geos_c.cpp	2009-03-24 00:30:58 UTC (rev 2301)
@@ -455,17 +455,11 @@
 int
-GEOSGetSRID(const Geometry *g)
+GEOSGetSRID(const Geometry *g1)
-    return GEOSGetSRID_r( handle, g );
+    return GEOSGetSRID_r( handle, g1 );
-void
-GEOSSetSRID(Geometry *g, int srid)
-    GEOSSetSRID_r( handle, g, srid );
 char
 GEOSHasZ(const Geometry *g)
Modified: trunk/capi/geos_c.h.in
--- trunk/capi/geos_c.h.in	2009-03-24 00:19:33 UTC (rev 2300)
+++ trunk/capi/geos_c.h.in	2009-03-24 00:30:58 UTC (rev 2301)
@@ -591,14 +591,13 @@
 /* Return 0 on exception */
 extern int GEOS_DLL GEOSGetSRID(const GEOSGeometry* g1);
+extern void GEOS_DLL GEOSSetSRID(GEOSGeometry* g, int SRID);
 extern int GEOS_DLL GEOSGetSRID_r(GEOSContextHandle_t handle,
-extern void GEOS_DLL GEOSSetSRID(GEOSGeometry* g, int srid);
-extern void GEOS_DLL GEOSSetSRID_r(GEOSContextHandle_t handle,
-                                   GEOSGeometry* g, int srid);
 /* May be called on all geometries in GEOS 3.x, returns -1 on error and 1
  * for non-multi geometries. Older GEOS versions only accept
  * GeometryCollections or Multi* geometries here, and are likely to crash
Modified: trunk/capi/geos_ts_c.cpp
--- trunk/capi/geos_ts_c.cpp	2009-03-24 00:19:33 UTC (rev 2300)
+++ trunk/capi/geos_ts_c.cpp	2009-03-24 00:30:58 UTC (rev 2301)
@@ -1578,6 +1578,17 @@
+void
+GEOSSetSRID(Geometry *g, int SRID)
+    assert(0 != g);
+    if (0 != g)
+        g->setSRID(SRID);
 int
 GEOSGetNumCoordinates_r(GEOSContextHandle_t extHandle, const Geometry *g1)
@@ -2114,7 +2125,7 @@
 #endif
         std::vector<Geometry *>*geoms = new std::vector<Geometry *>(lines->size());
-        for (std::size_t i = 0; i < lines->size(); ++i)
+        for (int i = 0; i < lines->size(); ++i)
             (*geoms)[i] = (*lines)[i];
@@ -2140,10 +2151,8 @@
 int
-GEOSGetSRID_r(GEOSContextHandle_t extHandle, const Geometry *g)
+GEOSGetSRID_r(GEOSContextHandle_t extHandle, const Geometry *g1)
-    assert(0 != g);
     if ( 0 == extHandle )
         return 0;
@@ -2158,7 +2167,7 @@
     try
-        return g->getSRID();
+        return g1->getSRID();
     catch (const std::exception &e)
@@ -2172,35 +2181,6 @@
     return 0;
-void
-GEOSSetSRID_r(GEOSContextHandle_t extHandle, Geometry *g, int srid)
-    assert(0 != g);
-    if ( 0 == extHandle )
-        return;
-    GEOSContextHandleInternal_t *handle = 0;
-    handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
-    if ( 0 != handle->initialized && 0 != g)
-        try
-            g->setSRID(srid);
-        catch (const std::exception &e)
-            handle->ERROR_MESSAGE("%s", e.what());
-        catch (...)
-            handle->ERROR_MESSAGE("Unknown exception thrown");
 const char* GEOSversion()
     return GEOS_CAPI_VERSION;
More information about the geos-commits mailing list
